[GRASS-SVN] r51956 - in grass/trunk: include/defs lib/vector/Vlib
    svn_grass at osgeo.org
    Sun Jun  3 09:36:19 PDT 2012
Author: martinl
Date: 2012-06-03 09:36:19 -0700 (Sun, 03 Jun 2012)
New Revision: 51956
Added:
   grass/trunk/lib/vector/Vlib/header_finfo.c
   grass/trunk/include/defs/vector.h
   grass/trunk/lib/vector/Vlib/header.c
vlib: separate fInfo-related subroutines into header_finfo.c
      introduced Vect_get_finfo_geometry_column()
Modified: grass/trunk/include/defs/vector.h
--- grass/trunk/include/defs/vector.h	2012-06-03 13:40:45 UTC (rev 51955)
+++ grass/trunk/include/defs/vector.h	2012-06-03 16:36:19 UTC (rev 51956)
@@ -164,6 +164,7 @@
 char *Vect_get_finfo_layer_name(const struct Map_info *);
 const char *Vect_get_finfo_format_info(const struct Map_info *);
 const char *Vect_get_finfo_geometry_type(const struct Map_info *);
+const char *Vect_get_finfo_geometry_column(const struct Map_info *);
 int Vect_is_3d(const struct Map_info *);
 int Vect_set_organization(struct Map_info *, const char *);
 const char *Vect_get_organization(const struct Map_info *);
Modified: grass/trunk/lib/vector/Vlib/header.c
--- grass/trunk/lib/vector/Vlib/header.c	2012-06-03 13:40:45 UTC (rev 51955)
+++ grass/trunk/lib/vector/Vlib/header.c	2012-06-03 16:36:19 UTC (rev 51956)
@@ -251,188 +251,6 @@
-   \brief Get datasource name (relevant only for non-native formats)
-   Returns:
-    - datasource name for OGR format (GV_FORMAT_OGR and GV_FORMAT_OGR_DIRECT)
-    - database name for PostGIS format (GV_FORMAT_POSTGIS)
-   \param Map pointer to Map_info structure
-   \return string containing OGR/PostGIS datasource name
-   \return NULL on error (map format is native)
-const char *Vect_get_finfo_dsn_name(const struct Map_info *Map)
-    if (Map->format == GV_FORMAT_OGR ||
-	Map->format == GV_FORMAT_OGR_DIRECT) {
-#ifndef HAVE_OGR
-	G_warning(_("GRASS is not compiled with OGR support"));
-#endif
-        return Map->fInfo.ogr.dsn;
-    else if (Map->format == GV_FORMAT_POSTGIS) {
-#ifndef HAVE_POSTGRES
-	G_warning(_("GRASS is not compiled with PostgreSQL support"));
-#endif
-        return Map->fInfo.pg.db_name;
-    G_warning(_("Native vector format detected for <%s>"),
-	      Vect_get_full_name(Map));
-    return NULL;
-   \brief Get layer name (relevant only for non-native formats)
-   Returns:
-    - layer name for OGR format (GV_FORMAT_OGR and GV_FORMAT_OGR_DIRECT)
-    - table name for PostGIS format (GV_FORMAT_POSTGIS)
-   Note: allocated string should be freed by G_free()
-   \return string containing layer name
-char *Vect_get_finfo_layer_name(const struct Map_info *Map)
-    char *name;
-    name = NULL;
-#ifndef HAVE_OGR
-#endif
-	name = G_store(Map->fInfo.ogr.layer_name);
-#endif
-	G_asprintf(&name, "%s.%s", Map->fInfo.pg.schema_name,
-		   Map->fInfo.pg.table_name);
-    else {
-    return name;
-  \brief Get format info (relevant only for non-native formats)
-   Returns:
-  \return string containing name of OGR format (allocated by G_store())
-  \return NULL on error (or on missing OGR/PostgreSQL support)
-const char *Vect_get_finfo_format_info(const struct Map_info *Map)
-#ifndef HAVE_OGR
-#else
-	if (!Map->fInfo.ogr.ds)
-	    return NULL;
-	return OGR_Dr_GetName(OGR_DS_GetDriver(Map->fInfo.ogr.ds));
-#endif
-#ifndef HAVE_OGR
-#else
-	return "PostgreSQL";
-#endif
-    return NULL;
-  \brief Get geometry type (relevant only for non-native formats)
-  Note: All inner spaces are removed, function returns feature type in
-  lowercase.
-  \return allocated string containing geometry type info
-  (point, linestring, polygon, ...)
-const char *Vect_get_finfo_geometry_type(const struct Map_info *Map)
-    char *ftype, *ftype_tmp;
-    ftype_tmp = ftype = NULL;
-#ifndef HAVE_OGR
-#else
-    OGRwkbGeometryType Ogr_geom_type;
-    OGRFeatureDefnH    Ogr_feature_defn;
-    if (!Map->fInfo.ogr.layer)
-	return NULL;
-    Ogr_feature_defn = OGR_L_GetLayerDefn(Map->fInfo.ogr.layer);
-    Ogr_geom_type = wkbFlatten(OGR_FD_GetGeomType(Ogr_feature_defn));
-    ftype_tmp = G_store(OGRGeometryTypeToName(Ogr_geom_type));
-#endif
-#else
-	char stmt[DB_SQL_MAX];
-	const struct Format_info_pg *pg_info;
-	PGresult *res;
-	pg_info = &(Map->fInfo.pg);
-	sprintf(stmt, "SELECT type FROM geometry_columns "
-		"WHERE f_table_schema = '%s' AND f_table_name = '%s'",
-		pg_info->schema_name, pg_info->table_name);
-	G_debug(2, "SQL: %s", stmt);
-	res = PQexec(pg_info->conn, stmt);
-	if (!res || PQresultStatus(res) != PGRES_TUPLES_OK ||
-	    PQntuples(res) != 1) {
-	    G_warning("%s\n%s", _("Unable to get feature type"),
-		      PQresultErrorMessage(res));
-	    return NULL;
-	ftype_tmp = G_store(PQgetvalue(res, 0, 0));
-	PQclear(res);
-#endif
-    if (!ftype_tmp)
-	return NULL;
-    ftype = G_str_replace(ftype_tmp, " ", "");
-    G_free(ftype_tmp);
-    G_str_to_lower(ftype);
-    return ftype;
    \brief Check if vector map is 3D
    Check vector map header.
@@ -773,13 +591,3 @@
     G_debug(1, "Vect_get_thresh(): thresh = %f", Map->head.digit_thresh);
     return Map->head.digit_thresh;
-/* from lib/gis/proj3.c */
-static int lookup(const char *file, const char *key, char *value, size_t len)
-    char path[GPATH_MAX];
-    G_file_name(path, "", file, "PERMANENT");
-    return G_lookup_key_value_from_file(path, key, value, (int) len) == 1;
Added: grass/trunk/lib/vector/Vlib/header_finfo.c
--- grass/trunk/lib/vector/Vlib/header_finfo.c	                        (rev 0)
+++ grass/trunk/lib/vector/Vlib/header_finfo.c	2012-06-03 16:36:19 UTC (rev 51956)
@@ -0,0 +1,222 @@
+   \file lib/vector/Vlib/header_finfo.c
+   \brief Vector library - header manipulation (external formats)
+   Higher level functions for reading/writing/manipulating vectors.
+   (C) 2001-2010, 2012 by the GRASS Development Team
+   This program is free software under the GNU General Public License
+   (>=v2). Read the file COPYING that comes with GRASS for details.
+   \author Original author CERL, probably Dave Gerdes or Mike Higgins.
+   \author Update to GRASS 5.7 Radim Blazek and David D. Gray.
+   \author Update to GRASS 7 (OGR support) by Martin Landa <landa.martin gmail.com>
+#include <grass/vector.h>
+#include <grass/glocale.h>
+   \brief Get datasource name (relevant only for non-native formats)
+   Returns:
+    - datasource name for OGR format (GV_FORMAT_OGR and GV_FORMAT_OGR_DIRECT)
+    - database name for PostGIS format (GV_FORMAT_POSTGIS)
+   \param Map pointer to Map_info structure
+   \return string containing OGR/PostGIS datasource name
+   \return NULL on error (map format is native)
+const char *Vect_get_finfo_dsn_name(const struct Map_info *Map)
+    if (Map->format == GV_FORMAT_OGR ||
+        Map->format == GV_FORMAT_OGR_DIRECT) {
+#ifndef HAVE_OGR
+        G_warning(_("GRASS is not compiled with OGR support"));
+#endif
+        return Map->fInfo.ogr.dsn;
+    else if (Map->format == GV_FORMAT_POSTGIS) {
+#ifndef HAVE_POSTGRES
+        G_warning(_("GRASS is not compiled with PostgreSQL support"));
+#endif
+        return Map->fInfo.pg.db_name;
+    G_warning(_("Native vector format detected for <%s>"),
+              Vect_get_full_name(Map));
+    return NULL;
+   \brief Get layer name (relevant only for non-native formats)
+   Returns:
+    - layer name for OGR format (GV_FORMAT_OGR and GV_FORMAT_OGR_DIRECT)
+    - table name for PostGIS format (GV_FORMAT_POSTGIS)
+   Note: allocated string should be freed by G_free()
+   \return string containing layer name
+char *Vect_get_finfo_layer_name(const struct Map_info *Map)
+    char *name;
+    name = NULL;
+#ifndef HAVE_OGR
+#endif
+        name = G_store(Map->fInfo.ogr.layer_name);
+#endif
+        G_asprintf(&name, "%s.%s", Map->fInfo.pg.schema_name,
+                   Map->fInfo.pg.table_name);
+    else {
+    return name;
+  \brief Get format info (relevant only for non-native formats)
+   Returns:
+  \return string containing name of OGR format (allocated by G_store())
+  \return NULL on error (or on missing OGR/PostgreSQL support)
+const char *Vect_get_finfo_format_info(const struct Map_info *Map)
+#ifndef HAVE_OGR
+#else
+        if (!Map->fInfo.ogr.ds)
+            return NULL;
+        return OGR_Dr_GetName(OGR_DS_GetDriver(Map->fInfo.ogr.ds));
+#endif
+#ifndef HAVE_OGR
+#else
+        return "PostgreSQL";
+#endif
+    return NULL;
+  \brief Get geometry type (relevant only for non-native formats)
+  Note: All inner spaces are removed, function returns feature type in
+  lowercase.
+  \return allocated string containing geometry type info
+  (point, linestring, polygon, ...)
+const char *Vect_get_finfo_geometry_type(const struct Map_info *Map)
+    char *ftype, *ftype_tmp;
+    ftype_tmp = ftype = NULL;
+#ifndef HAVE_OGR
+#else
+    OGRwkbGeometryType Ogr_geom_type;
+    OGRFeatureDefnH    Ogr_feature_defn;
+    if (!Map->fInfo.ogr.layer)
+        return NULL;
+    Ogr_feature_defn = OGR_L_GetLayerDefn(Map->fInfo.ogr.layer);
+    Ogr_geom_type = wkbFlatten(OGR_FD_GetGeomType(Ogr_feature_defn));
+    ftype_tmp = G_store(OGRGeometryTypeToName(Ogr_geom_type));
+#endif
+#else
+        char stmt[DB_SQL_MAX];
+        const struct Format_info_pg *pg_info;
+        PGresult *res;
+        pg_info = &(Map->fInfo.pg);
+        sprintf(stmt, "SELECT type FROM geometry_columns "
+                "WHERE f_table_schema = '%s' AND f_table_name = '%s'",
+                pg_info->schema_name, pg_info->table_name);
+        G_debug(2, "SQL: %s", stmt);
+        res = PQexec(pg_info->conn, stmt);
+        if (!res || PQresultStatus(res) != PGRES_TUPLES_OK ||
+            PQntuples(res) != 1) {
+            G_warning("%s\n%s", _("Unable to get feature type"),
+                      PQresultErrorMessage(res));
+            return NULL;
+        ftype_tmp = G_store(PQgetvalue(res, 0, 0));
+        PQclear(res);
+#endif
+    if (!ftype_tmp)
+        return NULL;
+    ftype = G_str_replace(ftype_tmp, " ", "");
+    G_free(ftype_tmp);
+    G_str_to_lower(ftype);
+    return ftype;
+  \brief Get geometry column (relevant only for non-native DB formats)
+  \return allocated string with geometry column name
+const char *Vect_get_finfo_geometry_column(const struct Map_info *Map)
+    if (Map->format == GV_FORMAT_POSTGIS) {
+#else
+        return Map->fInfo.pg.geom_column;
+#endif
+    return NULL;
Property changes on: grass/trunk/lib/vector/Vlib/header_finfo.c
___________________________________________________________________
Added: svn:mime-type
   + text/x-csrc
Added: svn:eol-style
   + native
