[GRASS-SVN] r51959 - grass/trunk/lib/segment
Sun Jun 3 10:02:18 PDT 2012
Author: mmetz
Date: 2012-06-03 10:02:17 -0700 (Sun, 03 Jun 2012)
New Revision: 51959
   grass/trunk/lib/segment/segmentlib.dox
segment lib: update programmers manual
Modified: grass/trunk/lib/segment/segmentlib.dox
--- grass/trunk/lib/segment/segmentlib.dox	2012-06-03 17:01:15 UTC (rev 51958)
+++ grass/trunk/lib/segment/segmentlib.dox	2012-06-03 17:02:17 UTC (rev 51959)
@@ -82,12 +82,32 @@
 \endverbatim
 <P>
-The first step is to create a file which is properly formatted for use by
-the <I>Segment Library</I> routines:
+A temporary file needs to be prepared and a SEGMENT structure needs to
+be initialized before any data can be transferred to the segment file.
+This can be done with the <I>Segment Library</I> routine:
+<P>
+<I>int segment_open(SEGMENT *SEG, char *fname, off_t nrows, off_t ncols,
+  int srows, int scols, int len, int nseg), open a new segment structure.
+<P>
+  A new file with full path name <B>fname</B> will be created and
+  formatted. The original nonsegmented data matrix consists of
+  <B>nrows</B> and <B>ncols. The segments consist of <B>srows</B> by
+  <B>scols</B>. The data items have length <B>len</B> bytes. The number
+  of segments to be retained in memory is given by <B>nseg</B>. This
+  routine calls segment_format() and segment_init(), see below. If
+  segment_open() is used, the routines segment_format() and segment_init()
+  must not be used.
+<P>
+Return codes are: 1 ok; else a negative number between -1 and -6 encoding
+  the error type.
 <P>
-<I>int segment_format (int fd, int nrows, int ncols, int srows, int scols,
+Alternatively, the first step is to create a file which is properly
+formatted for use by the <I>Segment Library</I> routines:
+<P>
+<I>int segment_format (int fd, int nrows, off_t ncols,off_t srows, int scols,
   int len)</I>, format a segment file
 <P>
   The segmentation routines require a disk file to be used for paging
@@ -101,9 +121,9 @@
 <P>
 The corresponding nonsegmented data matrix, which is to be transferred to the
   segment file, is <B>nrows</B> by <B>ncols.</B> The segment file is to be
-  formed of segments which are <B>srows</B> by <B>scols.</B> The data items
-  have length <B>len</B> bytes. For example, if the <I>data type is int</I>,
-  <B><I>len</I> </B><I>is sizeof(int) .</I>
+  formed of segments which are <B>srows</B> by <B>scols</B>. The data items
+  have length <B>len</B> bytes. For example, if the data type is <I>int</I>,
+  <B><I>len</I></B> is <I>sizeof(int)</I>.
 <P>
 Return codes are: 1 ok; else -1 could not seek or write <I>fd</I>, or -3
@@ -220,15 +240,37 @@
 <P>
+The following routine both deletes the segment file and releases allocated
+memory:
+<P>
+<I>int segment_close (SEGMENT *seg)</I>, close segment structure
+<P>
+  Deletes the segment file and uses segment_release() to release the
+  allocated memory. No further cleaing up is required.
+<P>
 \section How_to_Use_the_Library_Routines How to Use the Library Routines
 The following should provide the programmer with a good idea of how to use the
 <I>Segment Library</I> routines. The examples assume that the data is integer.
-The first step is the creation and formatting of a segment file. A file is
-created, formatted and then closed:
+Creation of a segment file and initialization of the segment structure
+at once:
+\verbatim
+SEGMENT seg;
+segment_open (&seg, G_tempfile(), nrows, ncols, srows, scols, sizeof(int), nseg);
+\endverbatim
+Alternatively, the first step is the creation and formatting of a segment
+file. A file is created, formatted and then closed:
 \verbatim
 fd = creat (file, 0666);
@@ -239,21 +281,26 @@
 <P>
 The next step is the conversion of the nonsegmented matrix data into segment
-file format. The segment file is reopened for read and write, initialized, and
-then data read row by row from the original data file and put into the segment
-file:
+file format. The segment file is reopened for read and write and initialized:
 \verbatim
 #include <fcntl.h>
-int buf[NCOLS];
 SEGMENT seg;
 fd = open (file, O_RDWR);
 segment_init (&seg, fd, nseg);
+\endverbatim
+<P>
+Both the segment file and the segment structure are now ready to use, and
+data can be read row by row from the original data file and put into the
+segment file:
+\verbatim
 for (row = 0; row < nrows; row++)
     <code to get original matrix data for row into buf>
