[GRASS-SVN] r51969 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Mon Jun 4 06:03:54 PDT 2012
Author: mmetz
Date: 2012-06-04 06:03:51 -0700 (Mon, 04 Jun 2012)
New Revision: 51969
grass/trunk/lib/vector/Vlib/ascii.c
Vlib: speed up v.out.ascii for multiple column export
Modified: grass/trunk/lib/vector/Vlib/ascii.c
--- grass/trunk/lib/vector/Vlib/ascii.c 2012-06-04 09:33:20 UTC (rev 51968)
+++ grass/trunk/lib/vector/Vlib/ascii.c 2012-06-04 13:03:51 UTC (rev 51969)
@@ -317,13 +317,23 @@
int count;
/* where || columns */
- struct field_info *Fi;
- dbDriver *driver;
- dbValue value = {0};
+ struct field_info *Fi = NULL;
+ dbDriver *driver = NULL;
+ dbValue value;
dbHandle handle;
- int *cats, ncats;
+ int *cats, ncats, more;
+ dbTable *Table;
+ dbString dbstring;
+ dbColumn *Column;
+ dbValue *Value;
+ char buf[2000];
+ dbCursor cursor;
int *coltypes = NULL;
+ char *all_columns = NULL;
+ G_zero(&value, sizeof(dbValue));
+ db_init_string(&dbstring);
/* TODO: free memory allocated by G_asprintf(),
* this is a bad memory leak */
xstring = NULL;
@@ -367,15 +377,32 @@
db_shutdown_driver(driver);
else {
+ int len_all = 0;
i = 0;
- while (columns[i++]);
+ while (columns[i])
+ len_all += strlen(columns[i++]);
coltypes = G_malloc(i * sizeof(int));
+ all_columns = G_malloc(len_all + i + 2);
i = 0;
+ strcpy(all_columns, columns[0]);
while (columns[i]) {
/* get column types */
coltypes[i] = db_column_Ctype(driver, Fi->table, columns[i]);
+ if (coltypes[i] < 0) {
+ db_close_database(driver);
+ db_shutdown_driver(driver);
+ G_warning(_("Unknown type of column <%s>, export cancelled"),
+ columns[i]);
+ return -1;
+ if (i > 0) {
+ strcat(all_columns, ",");
+ strcat(all_columns, columns[i]);
i++;
@@ -399,6 +426,9 @@
if (columns) {
+ G_free(coltypes);
+ G_free(all_columns);
return -1;
@@ -408,6 +438,9 @@
if (columns) {
+ G_free(coltypes);
break;
@@ -554,28 +587,48 @@
/* print attributes */
if (columns) {
+ sprintf(buf, "SELECT %s FROM %s WHERE %s = %d",
+ all_columns, Fi->table, Fi->key, fcats->value[0]);
+ G_debug(2, "SQL: %s", buf);
+ db_set_string(&dbstring, buf);
+ if (db_open_select_cursor
+ (driver, &dbstring, &cursor, DB_SEQUENTIAL) != DB_OK) {
+ G_fatal_error(_("Cannot select attributes for cat = %d"),
+ fcats->value[0]);
+ if (db_fetch(&cursor, DB_NEXT, &more) != DB_OK) {
+ G_fatal_error(_("Unable to fetch data from table"));
+ Table = db_get_cursor_table(&cursor);
for(i = 0; columns[i]; i++) {
- if (db_select_value(driver, Fi->table, Fi->key, fcats->value[0],
- columns[i], &value) < 0)
- G_fatal_error(_("Unable to select record from table <%s> (key %s, column %s)"),
- Fi->table, Fi->key, columns[i]);
- if (db_test_value_isnull(&value)) {
+ Column = db_get_table_column(Table, i);
+ Value = db_get_column_value(Column);
+ if (db_test_value_isnull(Value)) {
fprintf(ascii, "%s", fs);
else {
switch(coltypes[i])
case DB_C_TYPE_INT: {
- fprintf(ascii, "%s%d", fs, db_get_value_int(&value));
+ fprintf(ascii, "%s%d", fs, db_get_value_int(Value));
break;
case DB_C_TYPE_DOUBLE: {
- fprintf(ascii, "%s%.*f", fs, dp, db_get_value_double(&value));
+ fprintf(ascii, "%s%.*f", fs, dp, db_get_value_double(Value));
break;
case DB_C_TYPE_STRING: {
- fprintf(ascii, "%s%s", fs, db_get_value_string(&value));
+ fprintf(ascii, "%s%s", fs, db_get_value_string(Value));
break;
case DB_C_TYPE_DATETIME: {
@@ -589,6 +642,7 @@
+ db_close_cursor(&cursor);
