[GRASS-SVN] r51985 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Wed Jun 6 06:54:09 PDT 2012
Author: martinl
Date: 2012-06-06 06:54:08 -0700 (Wed, 06 Jun 2012)
New Revision: 51985
grass/trunk/lib/vector/Vlib/close.c
grass/trunk/lib/vector/Vlib/close_pg.c
vlib/pg: remove topo file for PG-links (full 2D topology)
Modified: grass/trunk/lib/vector/Vlib/close.c
--- grass/trunk/lib/vector/Vlib/close.c 2012-06-06 13:26:09 UTC (rev 51984)
+++ grass/trunk/lib/vector/Vlib/close.c 2012-06-06 13:54:08 UTC (rev 51985)
@@ -60,6 +60,8 @@
#endif
+static void unlink_file(const struct Map_info *, const char *);
\brief Close vector map
@@ -80,29 +82,15 @@
if (strcmp(Map->mapset, G_mapset()) == 0 &&
Map->support_updated &&
Map->plus.built == GV_BUILD_ALL) {
- char buf[GPATH_MAX];
- char file_path[GPATH_MAX];
- /* delete old support files if available */
- sprintf(buf, "%s/%s", GV_DIRECTORY, Map->name);
+ unlink_file(Map, GV_TOPO_ELEMENT); /* topo */
- G_file_name(file_path, buf, GV_TOPO_ELEMENT, G_mapset());
- if (access(file_path, F_OK) == 0) /* file exists? */
- unlink(file_path);
+ unlink_file(Map, GV_SIDX_ELEMENT); /* sidx */
- G_file_name(file_path, buf, GV_SIDX_ELEMENT, G_mapset());
+ unlink_file(Map, GV_CIDX_ELEMENT); /* cidx */
- G_file_name(file_path, buf, GV_CIDX_ELEMENT, G_mapset());
- if (Map->format == GV_FORMAT_OGR ||
- Map->format == GV_FORMAT_POSTGIS) {
- G_file_name(file_path, buf, GV_FIDX_ELEMENT, G_mapset());
+ if (Map->format == GV_FORMAT_OGR || Map->format == GV_FORMAT_POSTGIS) {
+ unlink_file(Map, GV_FIDX_ELEMENT); /* fidx */
Vect_coor_info(Map, &CInfo);
@@ -113,7 +101,7 @@
Vect_save_topo(Map);
/* write out sidx file */
- Map->plus.Spidx_new = TRUE;
+ Map->plus.Spidx_new = TRUE; /* force writing */
Vect_save_sidx(Map);
/* write out cidx file */
@@ -171,3 +159,16 @@
return 0;
+void unlink_file(const struct Map_info *Map, const char *name)
+ char buf[GPATH_MAX];
+ char file_path[GPATH_MAX];
+ /* delete old support files if available */
+ sprintf(buf, "%s/%s", GV_DIRECTORY, Map->name);
+ G_file_name(file_path, buf, name, G_mapset());
+ if (access(file_path, F_OK) == 0) /* file exists? */
+ unlink(file_path);
Modified: grass/trunk/lib/vector/Vlib/close_pg.c
--- grass/trunk/lib/vector/Vlib/close_pg.c 2012-06-06 13:26:09 UTC (rev 51984)
+++ grass/trunk/lib/vector/Vlib/close_pg.c 2012-06-06 13:54:08 UTC (rev 51985)
@@ -14,6 +14,7 @@
#include <stdlib.h>
+#include <unistd.h>
#include <grass/vector.h>
#include <grass/dbmi.h>
#include <grass/glocale.h>
@@ -109,9 +110,24 @@
if (!VECT_OPEN(Map))
return -1;
- if (Map->fInfo.pg.toposchema_name) /* no fidx file for PostGIS topology */
+ if (Map->fInfo.pg.toposchema_name) {
+ /* no fidx file for PostGIS topology
+ remove topo file (which was required for saving sidx file)
+ G_file_name(file_path, buf, GV_TOPO_ELEMENT, G_mapset());
return 0;
/* write fidx for maps in the current mapset */
if (Vect_save_fidx(Map, &(Map->fInfo.pg.offset)) != 1)
G_warning(_("Unable to save feature index file for vector map <%s>"),
