[GRASS-SVN] r51989 - grass/trunk/vector/v.build
svn_grass at osgeo.org
Wed Jun 6 08:38:23 PDT 2012
Author: martinl
Date: 2012-06-06 08:38:22 -0700 (Wed, 06 Jun 2012)
New Revision: 51989
grass/trunk/vector/v.build/main.c
v.build: allow to dump topo/sidx/cidx/fidx also for vector maps from other mapsets
Modified: grass/trunk/vector/v.build/main.c
--- grass/trunk/vector/v.build/main.c 2012-06-06 15:05:02 UTC (rev 51988)
+++ grass/trunk/vector/v.build/main.c 2012-06-06 15:38:22 UTC (rev 51989)
@@ -7,12 +7,11 @@
* PURPOSE: Build topology
- * COPYRIGHT: (C) 2001 by the GRASS Development Team
+ * COPYRIGHT: (C) 2001, 2012 by the GRASS Development Team
- * This program is free software under the
- * GNU General Public License (>=v2).
- * Read the file COPYING that comes with GRASS
- * for details.
+ * This program is free software under the GNU General
+ * Public License (>=v2). Read the file COPYING that
+ * comes with GRASS for details.
@@ -114,17 +113,15 @@
Vect_set_open_level(1);
- if (Vect_open_old(&Map, map_opt->answer, G_mapset()) < 0) {
- G_fatal_error(_("Unable to build topology for <%s>"),
- map_opt->answer);
+ Vect_open_old(&Map, map_opt->answer, G_mapset());
Vect_build(&Map);
/* dump topology */
if (dump || sdump || cdump || fdump) {
if (!build) {
Vect_set_open_level(2);
- Vect_open_old(&Map, map_opt->answer, G_mapset());
+ Vect_open_old(&Map, map_opt->answer, "");
if (dump)
Vect_topo_dump(&Map, stdout);
