[GRASS-SVN] r51992 - grass/trunk/lib/segment
svn_grass at osgeo.org
Wed Jun 6 09:48:51 PDT 2012
Author: mmetz
Date: 2012-06-06 09:48:51 -0700 (Wed, 06 Jun 2012)
New Revision: 51992
grass/trunk/lib/segment/segmentlib.dox
segment lib: update documentation
Modified: grass/trunk/lib/segment/segmentlib.dox
--- grass/trunk/lib/segment/segmentlib.dox 2012-06-06 16:34:00 UTC (rev 51991)
+++ grass/trunk/lib/segment/segmentlib.dox 2012-06-06 16:48:51 UTC (rev 51992)
@@ -393,9 +393,11 @@
about 10% if <B>srows, scols</B> are each powers of 2; in this case a
faster alternative is used to access the segment file. An additional
improvement can be achieved if <B>len</B> is also a power of 2. For
-highly random and scattered access to a large dataset, smaller segments,
-i.e. values for <B>srows, scols</B> of 32, 64, or 128 seem to provide
-better performance than e.g. srows = nrows / 4 + 1.
+scattered access to a large dataset, smaller segments, i.e. values
+for <B>srows, scols</B> of 32, 64, or 128 seem to provide
+the best performance. Calculating segment size as a fraction of the
+data matrix size, e.g. srows = nrows / 4 + 1, will result in very poor
+performance, particularly for larger datasets.
\section Loading_the_Segment_Library Loading the Segment Library
