[GRASS-SVN] r51995 - grass-addons/grass7/vector/v.ply.rectify
svn_grass at osgeo.org
Wed Jun 6 09:55:14 PDT 2012
Author: mmetz
Date: 2012-06-06 09:55:11 -0700 (Wed, 06 Jun 2012)
New Revision: 51995
Added:
grass-addons/grass7/vector/v.ply.rectify/Makefile
grass-addons/grass7/vector/v.ply.rectify/v.ply.rectify.html
grass-addons/grass7/vector/v.ply.rectify/v.ply.rectify.py
v.ply.rectify: wrapper for v.in.ply, v.rectify -3o, v.out.ply
Property changes on: grass-addons/grass7/vector/v.ply.rectify
___________________________________________________________________
Added: svn:ignore
+ OBJ.* *.tmp.html
Added: grass-addons/grass7/vector/v.ply.rectify/Makefile
--- grass-addons/grass7/vector/v.ply.rectify/Makefile (rev 0)
+++ grass-addons/grass7/vector/v.ply.rectify/Makefile 2012-06-06 16:55:11 UTC (rev 51995)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = v.ply.rectify
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/vector/v.ply.rectify/v.ply.rectify.html
--- grass-addons/grass7/vector/v.ply.rectify/v.ply.rectify.html (rev 0)
+++ grass-addons/grass7/vector/v.ply.rectify/v.ply.rectify.html 2012-06-06 16:55:11 UTC (rev 51995)
@@ -0,0 +1,62 @@
+<h2>DESCRIPTION</h2>
+<em>v.ply.rectify</em> imports a PLY point cloud, georeferences and
+exports it. The first three vertex properties must be the x, y, z
+coordinates with property names "x", "y",
+"z", in this order.
+<p>
+A text file with Ground Control Points (GCPs) must exist in
+the same folder where the point cloud is located, and the textfile must
+have the same name like the point cloud, but ending on .txt instead of
+.ply.
+<p>
+The text file with GCPs must have the following format with one GCP per line:
+<div class="code"><pre>
+ x y z east north height status
+</pre></div>
+with <em>x, y, z</em> as source coordinates and <em>east, north, height</em>
+as target coordinates. The <em>status</em> indicates whether to use a GCP
+(status is not zero) or not (status is zero). Entries must be separated
+by whitespace or tabs. Decimal delimiters must be points.
+<p>
+The georecitifictation method used is a 3D orthogonal rectification
+where angles are preserved. 3D objects are shifted, scaled and rotated,
+but no shear is introduced. Please read the output of the module, in
+particular the root mean square (RMS) errors.
+<p>
+<em>v.ply.rectify</em> optionally exports the georeferenced point cloud
+not only with real coordinates, but also with shifted coordinates
+(<em>-s</em> flag) for display in meshlab or similar software that can
+not deal with real coordinates. The exported PLY point clouds will be in
+the same folder like the input PLY point cloud.
+<h2>EXAMPLE</h2>
+With a point cloud file <em>pointcloud.ply</em> and associated control
+points in <em>pointcloud.txt</em>,
+v.ply.rectify -s input=pointcloud.ply
+</pre></div>
+will generate three files: <em>pointcloud_georef.ply</em> with the
+georeferenced point cloud, <em>pointcloud_georef_shifted.ply</em> with
+the georeferenced point cloud shifted to the coordinates' center, and
+<em>pointcloud_rms.csv</em> with the RMS errors of the control points.
+<h2>SEE ALSO</h2>
+<em>
+<a href="v.in.ply.html">v.in.ply</a>,
+<a href="v.out.ply.html">v.out.ply</a>,
+<a href="v.rectify.html">v.rectify</a>,
+<a href="v.transform.html">v.transform</a>
+</em>
+<h2>AUTHOR</h2>
+Markus Metz
+<p><i>Last changed: $Date$</i>
Property changes on: grass-addons/grass7/vector/v.ply.rectify/v.ply.rectify.html
Added: svn:mime-type
+ text/html
Added: svn:keywords
+ Author Date Id
Added: svn:eol-style
+ native
Added: grass-addons/grass7/vector/v.ply.rectify/v.ply.rectify.py
--- grass-addons/grass7/vector/v.ply.rectify/v.ply.rectify.py (rev 0)
+++ grass-addons/grass7/vector/v.ply.rectify/v.ply.rectify.py 2012-06-06 16:55:11 UTC (rev 51995)
@@ -0,0 +1,178 @@
+#!/usr/bin/env python
+# MODULE: v.ply.rectify
+# AUTHOR(S): Markus Metz
+# PURPOSE: Import PLY point data, georeference and export them
+# COPYRIGHT: (c) 2012 The GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Imports PLY points, georeferences and exports them.
+#% keywords: vector
+#% keywords: import
+#% keywords: export
+#% keywords: rectify
+#%end
+#%option G_OPT_F_INPUT
+#% description: Name of input PLY file
+#%end
+#%option G_OPT_V_OUTPUT
+#% description: Default is input name without .ply
+#% required: no
+#%end
+#%flag
+#% key: s
+#% description: Also export point cloud shifted to center
+#%end
+import sys
+import os
+import atexit
+import string
+import shutil
+from grass.script import core as grass
+from grass.script import vector as gvector
+def main():
+ export_shifted = flags['s']
+ currmapset = grass.gisenv()['MAPSET']
+ #### check for v.in.ply, v.out.ply
+ if not grass.find_program("v.in.ply", ['help']):
+ grass.fatal(_("The GRASS addon v.in.ply was not found, please install it first.\n"))
+ if not grass.find_program("v.out.ply", ['help']):
+ grass.fatal(_("The GRASS addon v.out.ply was not found, please install it first.\n"))
+ # import input PLY file
+ infile = options['input']
+ if not os.path.exists(infile):
+ grass.fatal(_("Unable to read input file <%s>") % infile)
+ grass.debug("input file=[%s]" % infile)
+ if not infile[-4:].lower() == '.ply':
+ grass.fatal(_("Input file must end with .ply or .PLY"))
+ gcpfile = infile[:-4] + ".txt"
+ srcdir, ply = os.path.split(infile)
+ ply = ply[:-4]
+ if not os.path.exists(gcpfile):
+ gcpfile = infile[:-4] + ".TXT"
+ grass.fatal(_("Input file with GCPs must be <%s> or <%s>") % ply + ".txt", ply + ".TXT")
+ if options['output'] is not None and options['output'] != '':
+ ply = options['output']
+ clist = list()
+ plydesc = grass.read_command('v.in.ply', flags = 'p',
+ input = infile, output = ply)
+ # remember column names for vertices
+ currname = ''
+ currprop = ''
+ for l in plydesc.splitlines():
+ f = l.split(':')
+ if f[0] == 'element name':
+ # new element
+ currname = f[1].strip()
+ currprop = ''
+ if f[0] == 'property name':
+ currprop = f[1].strip()
+ if currname == 'vertex' and currprop not in ['x', 'y', 'z']:
+ clist.append(currprop)
+ columns = ','.join(clist)
+ grass.run_command('v.in.ply', flags = 'b',
+ # import vector exists?
+ found = grass.find_file(ply, element = 'vector', mapset = currmapset)
+ if found['name'] != ply:
+ grass.fatal(_('PLY import failed!'))
+ # detach table
+ table = gvector.vector_layer_db(map = ply, layer = 1)['table']
+ grass.run_command('v.db.connect', map = ply, layer = 1, flags = 'd')
+ # print RMS
+ rmsfile = os.path.join(srcdir, ply + "_rms.csv")
+ grass.run_command('v.rectify', input = ply, output = ply + '_georef',
+ points = gcpfile, flags = '3bor', fs = ';', rmsfile = rmsfile)
+ # georectify
+ ply_georef = ply + '_georef'
+ grass.run_command('v.rectify', input = ply, output = ply_georef,
+ points = gcpfile, flags = '3bo')
+ # output vector exists?
+ found = grass.find_file(ply_georef, element = 'vector', mapset = currmapset)
+ if found['name'] != ply_georef:
+ layer = 1, table = table, key = 'cat')
+ grass.fatal('PLY import failed!')
+ grass.run_command('v.db.connect', map = ply_georef,
+ output = os.path.join(srcdir, ply_georef + '.ply')
+ grass.run_command('v.out.ply', input = ply_georef, output = output,
+ columns = columns)
+ grass.run_command('v.db.connect', map = ply_georef, layer = 1, flags = 'd')
+ if export_shifted:
+ vinfo = gvector.vector_info(map = ply_georef)
+ north_center = (float(vinfo['north']) + float(vinfo['south'])) / -2.0
+ east_center = (float(vinfo['east']) + float(vinfo['west'])) / -2.0
+ height_center = (float(vinfo['top']) + float(vinfo['bottom'])) / -2.0
+ ply_shifted = ply_georef + '_shifted'
+ grass.run_command('v.transform', input = ply_georef, layer = -1,
+ output = ply_shifted, xshift = east_center,
+ yshift = north_center, zshift = height_center,
+ xscale = 1.0, yscale = 1.0, zscale = 1.0, zrot = 0.0,
+ flags = 'b')
+ found = grass.find_file(ply_shifted, element = 'vector', mapset = currmapset)
+ if found['name'] != ply_shifted:
+ grass.run_command('v.db.connect', map = ply_shifted,
+ output = os.path.join(srcdir, ply_shifted + '.ply')
+ grass.run_command('v.out.ply', input = ply_shifted, output = output,
+ grass.run_command('v.db.connect', map = ply_shifted, layer = 1, flags = 'd')
+ grass.message(_("Done: Pointcloud '%s' has been successfully imported, georeferenced, and exported") % ply)
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
Property changes on: grass-addons/grass7/vector/v.ply.rectify/v.ply.rectify.py
Added: svn:executable
+ text/x-python
+ native
