[GRASS-SVN] r52017 - in grass/trunk/lib/vector: Vlib diglib
svn_grass at osgeo.org
Sat Jun 9 10:30:57 PDT 2012
Author: martinl
Date: 2012-06-09 10:30:56 -0700 (Sat, 09 Jun 2012)
New Revision: 52017
grass/trunk/lib/vector/Vlib/build_sfa.c
grass/trunk/lib/vector/Vlib/open_pg.c
grass/trunk/lib/vector/Vlib/pg_local_proto.h
grass/trunk/lib/vector/Vlib/read_pg.c
grass/trunk/lib/vector/diglib/spindex.c
vlib/pg: fix various issues when building areas/isles from PostGIS topology schema
Modified: grass/trunk/lib/vector/Vlib/build_sfa.c
--- grass/trunk/lib/vector/Vlib/build_sfa.c 2012-06-08 21:43:41 UTC (rev 52016)
+++ grass/trunk/lib/vector/Vlib/build_sfa.c 2012-06-09 17:30:56 UTC (rev 52017)
@@ -345,8 +345,8 @@
G_progress(iFeature + 1, 1e4);
/* cache feature (lines) */
- if (SF_NONE == cache_feature(wkb_data,
- FALSE, &(pg_info->cache), &fparts)) {
+ if (SF_NONE == cache_feature(wkb_data, FALSE, FALSE,
+ &(pg_info->cache), &fparts)) {
G_warning(_("Feature %d without geometry skipped"),
iFeature + 1);
continue;
@@ -681,9 +681,7 @@
int Vect__build_sfa(struct Map_info *Map, int build)
- int line;
struct Plus_head *plus;
- struct P_line *Line;
plus = &(Map->plus);
Modified: grass/trunk/lib/vector/Vlib/open_pg.c
--- grass/trunk/lib/vector/Vlib/open_pg.c 2012-06-08 21:43:41 UTC (rev 52016)
+++ grass/trunk/lib/vector/Vlib/open_pg.c 2012-06-09 17:30:56 UTC (rev 52017)
@@ -29,6 +29,7 @@
int end_node;
int left_face;
int right_face;
+ char *wkb_geom;
static char *get_key_column(struct Format_info_pg *);
@@ -40,8 +41,11 @@
static int check_topo(struct Format_info_pg *, struct Plus_head *);
static int parse_bbox(const char *, struct bound_box *);
static int num_of_records(const struct Format_info_pg *, const char *);
-static struct P_node *read_p_node(struct Plus_head *, int, int, struct Format_info_pg *);
-static struct P_line *read_p_line(struct Plus_head *, int, const struct edge_data *);
+static struct P_node *read_p_node(struct Plus_head *, int, int,
+ const char *, struct Format_info_pg *);
+static struct P_line *read_p_line(struct Plus_head *, int,
+ const struct edge_data *,
+ struct Format_info_cache *);
static int load_plus_head(struct Format_info_pg *, struct Plus_head *);
static void notice_processor(void *, const char *);
#endif
@@ -955,18 +959,21 @@
\param plus pointer to Plus_head structure
\param n index (starts at 1)
\param id node id (table "node")
+ \param wkb_data geometry data (wkb)
\param pg_info pointer to Format_info_pg sttucture
\return pointer to new P_node struct
\return NULL on error
-struct P_node *read_p_node(struct Plus_head *plus, int n, int id,
+struct P_node *read_p_node(struct Plus_head *plus, int n,
+ int id, const char *wkb_data,
struct Format_info_pg *pg_info)
int i, cnt;
char stmt[DB_SQL_MAX];
struct P_node *node;
+ struct line_pnts *points;
PGresult *res;
@@ -1021,33 +1028,23 @@
PQclear(res);
- if (plus->with_z)
- if (0 >= dig__fread_port_P(&n_edges, 1, fp))
+ /* get node coordinates */
+ if (SF_POINT != cache_feature(wkb_data, FALSE, FALSE,
+ &(pg_info->cache), NULL))
+ G_warning(_("Node %d: unexpected feature type %d"),
+ n, pg_info->cache.sf_type);
- /* get node coordinates */
- sprintf(stmt,
- "SELECT ST_X(geom),ST_Y(geom),ST_Z(geom) FROM \"%s\".node "
- "WHERE node_id = %d",
- pg_info->toposchema_name, id);
- G_debug(2, "SQL: %s", stmt);
- res = PQexec(pg_info->conn, stmt);
- if (!res || PQresultStatus(res) != PGRES_TUPLES_OK ||
- PQntuples(res) != 1) {
- G_warning(_("Unable to read node %d"), id);
- if (res)
- PQclear(res);
- return NULL;
- node->x = atof(PQgetvalue(res, 0, 0));
- node->y = atof(PQgetvalue(res, 0, 1));
+ points = pg_info->cache.lines[0];
+ node->x = points->x[0];
+ node->y = points->y[0];
if (plus->with_z)
- node->z = atof(PQgetvalue(res, 0, 2));
+ node->z = points->z[0];
else
- node->z = 0;
- PQclear(res);
+ node->z = 0.0;
+ /* update spatial index */
+ dig_spidx_add_node(plus, n, node->x, node->y, node->z);
plus->Node[n] = node;
return node;
@@ -1072,11 +1069,15 @@
struct P_line *read_p_line(struct Plus_head *plus, int n,
- const struct edge_data *data)
+ const struct edge_data *data,
+ struct Format_info_cache *cache)
- int tp;
+ int tp, itype;
struct P_line *line;
+ struct bound_box box;
if (data->start_node == 0 && data->end_node == 0) {
if (data->left_face == 0)
tp = GV_POINT;
@@ -1131,11 +1132,22 @@
else if (line->type == GV_CENTROID) {
struct P_topo_c *topo = (struct P_topo_c *)line->topo;
- topo->area = data->left_face;
+ topo->area = data->left_face;
/* TODO: faces | kernels */
+ cache_feature(data->wkb_geom, FALSE, FALSE, cache, NULL);
+ itype = cache->lines_types[0];
+ if ((line->type & GV_POINTS && itype != GV_POINT) ||
+ (line->type & GV_LINES && itype != GV_LINE))
+ G_warning(_("Line %d: unexpected feature type"), n);
+ points = cache->lines[0];
+ dig_line_box(points, &box);
+ dig_spidx_add_line(plus, n, &box);
plus->Line[n] = line;
return line;
@@ -1279,7 +1291,7 @@
note: standalone nodes are ignored
sprintf(stmt,
- "SELECT node_id FROM \"%s\".node WHERE node_id IN "
+ "SELECT node_id,geom FROM \"%s\".node WHERE node_id IN "
"(SELECT node FROM (SELECT start_node AS node FROM \"%s\".edge "
"GROUP BY start_node UNION ALL SELECT end_node AS node FROM "
"\"%s\".edge GROUP BY end_node) AS foo)",
@@ -1297,9 +1309,10 @@
G_debug(3, "load_plus(): n_nodes = %d", plus->n_nodes);
dig_alloc_nodes(plus, plus->n_nodes);
- for (i = 1; i <= plus->n_nodes; i++) {
- id = atoi(PQgetvalue(res, i - 1, 0));
- read_p_node(plus, i, id, pg_info);
+ for (i = 0; i < plus->n_nodes; i++) {
+ id = atoi(PQgetvalue(res, i, 0));
+ read_p_node(plus, i + 1, /* node index starts at 1 */
+ id, (const char *) PQgetvalue(res, i, 1), pg_info);
PQclear(res);
@@ -1314,7 +1327,7 @@
-> points
sprintf(stmt,
- "SELECT node_id FROM \"%s\".node WHERE node_id NOT IN "
+ "SELECT node_id,geom FROM \"%s\".node WHERE node_id NOT IN "
@@ -1335,7 +1348,8 @@
for (i = 0; i < ntuples; i++) {
/* process standalone nodes (PostGIS Topo) */
line_data.id = atoi(PQgetvalue(res, i, 0));
- read_p_line(plus, i + 1, &line_data);
+ line_data.wkb_geom = (char *) PQgetvalue(res, i, 1);
+ read_p_line(plus, i + 1, &line_data, &(pg_info->cache));
PQclear(res);
@@ -1344,7 +1358,7 @@
-> boundaries
sprintf(stmt,
- "SELECT edge_id,start_node,end_node,left_face,right_face "
+ "SELECT edge_id,start_node,end_node,left_face,right_face,geom "
"FROM \"%s\".edge",
pg_info->toposchema_name);
@@ -1365,9 +1379,10 @@
line_data.end_node = atoi(PQgetvalue(res, i, 2));
line_data.left_face = atoi(PQgetvalue(res, i, 3));
line_data.right_face = atoi(PQgetvalue(res, i, 4));
+ line_data.wkb_geom = (char *) PQgetvalue(res, i, 5);
id = plus->n_plines + i + 1; /* points already registered */
- line = read_p_line(plus, id, &line_data);
+ line = read_p_line(plus, id, &line_data, &(pg_info->cache));
if (line_data.left_face != 0 || line_data.right_face != 0) {
/* boundary detected -> build area/isle on left and right*/
@@ -1391,6 +1406,7 @@
if (line_data.right_face == 0)
line_data.right_face = -1;
+ /* check topo - left / right areas */
topo = (struct P_topo_b *)line->topo;
if (topo->left != line_data.left_face)
G_warning(_("Left area detected as %d (should be %d"),
@@ -1403,15 +1419,36 @@
PQclear(res);
/* attach centroids */
- G_zero(&line_data, sizeof(struct edge_data));
- for (i = 1; i <= plus->n_areas; i++) {
- area = plus->Area[i];
+ if (plus->n_areas > 0) {
+ sprintf(stmt,
+ "SELECT ST_PointOnSurface(geom) AS geom FROM "
+ "ST_GetFaceGeometry('%s',"
+ "(SELECT face_id FROM \"%s\".face WHERE face_id > 0)) "
+ "AS geom",
+ pg_info->toposchema_name, pg_info->toposchema_name);
+ G_debug(2, "SQL: %s", stmt);
+ res = PQexec(pg_info->conn, stmt);
+ if (!res || PQresultStatus(res) != PGRES_TUPLES_OK ||
+ PQntuples(res) > plus->n_areas) {
+ G_warning(_("Unable to attach centroids"));
+ if (res)
+ PQclear(res);
+ return -1;
- line_data.id = plus->n_lines - plus->n_clines + i;
- line_data.left_face = i;
- read_p_line(plus, line_data.id, &line_data);
- area->centroid = line_data.id;
+ G_zero(&line_data, sizeof(struct edge_data));
+ for (i = 1; i <= plus->n_areas; i++) {
+ area = plus->Area[i];
+ id = plus->n_lines - plus->n_clines + i;
+ line_data.id = line_data.left_face = i;
+ line_data.wkb_geom = (char *)PQgetvalue(res, 0, 0);
+ read_p_line(plus, id, &line_data, &(pg_info->cache));
+ area->centroid = line_data.id;
return 0;
Modified: grass/trunk/lib/vector/Vlib/pg_local_proto.h
--- grass/trunk/lib/vector/Vlib/pg_local_proto.h 2012-06-08 21:43:41 UTC (rev 52016)
+++ grass/trunk/lib/vector/Vlib/pg_local_proto.h 2012-06-09 17:30:56 UTC (rev 52017)
@@ -49,7 +49,7 @@
/* functions used in *_pg.c files */
int execute(PGconn *, const char *);
-SF_FeatureType cache_feature(const char *, int,
+SF_FeatureType cache_feature(const char *, int, int,
struct Format_info_cache *,
struct feat_parts *);
int set_initial_query(struct Format_info_pg *, int);
Modified: grass/trunk/lib/vector/Vlib/read_pg.c
--- grass/trunk/lib/vector/Vlib/read_pg.c 2012-06-08 21:43:41 UTC (rev 52016)
+++ grass/trunk/lib/vector/Vlib/read_pg.c 2012-06-09 17:30:56 UTC (rev 52017)
@@ -467,7 +467,8 @@
char *data;
+ int left_face, right_face;
if (!topotable_name && !pg_info->geom_column) {
G_warning(_("No geometry column defined"));
return -1;
@@ -500,7 +501,8 @@
else {
/* topological access */
sprintf(stmt,
- "DECLARE %s_%s%p CURSOR FOR SELECT geom FROM \"%s\".\"%s\" "
+ "DECLARE %s_%s%p CURSOR FOR SELECT geom,left_face,right_face "
+ " FROM \"%s\".\"%s\" "
"WHERE %s_id = %d", pg_info->schema_name, pg_info->table_name,
pg_info->conn, pg_info->toposchema_name,
topotable_name, topotable_name, fid);
@@ -557,9 +559,21 @@
return -2;
data = (char *)PQgetvalue(pg_info->res, pg_info->next_line, 0);
+ left_face = right_face = 0;
+ if (pg_info->toposchema_name) { /* -> PostGIS topology access */
+ if (fid < 0) { /* sequential access */
+ left_face = atoi(PQgetvalue(pg_info->res, pg_info->next_line, 2));
+ right_face = atoi(PQgetvalue(pg_info->res, pg_info->next_line, 3));
+ else { /* random access */
+ left_face = atoi(PQgetvalue(pg_info->res, pg_info->next_line, 1));
+ right_face = atoi(PQgetvalue(pg_info->res, pg_info->next_line, 2));
pg_info->cache.sf_type =
- cache_feature(data, FALSE, &(pg_info->cache), NULL);
+ cache_feature(data, FALSE,
+ left_face != 0 || right_face != 0 ? TRUE : FALSE,
+ &(pg_info->cache), NULL);
if (fid < 0) {
pg_info->cache.fid =
@@ -633,6 +647,7 @@
\param data HEX data
\param skip_polygon skip polygons (level 1)
+ \param force_boundary force GV_BOUNDARY feature type (for PostGIS topology)
\param[out] cache lines cache
\param[out] fparts used for building pseudo-topology (or NULL)
@@ -640,7 +655,8 @@
\return SF_UNKNOWN on error
SF_FeatureType cache_feature(const char *data, int skip_polygon,
- struct Format_info_cache * cache,
+ int force_boundary,
+ struct Format_info_cache *cache,
struct feat_parts * fparts)
int ret, byte_order, nbytes, is3D;
@@ -738,7 +754,10 @@
else if (ftype == SF_LINESTRING) {
cache->lines_num = 1;
- cache->lines_types[0] = GV_LINE;
+ if (force_boundary)
+ cache->lines_types[0] = GV_BOUNDARY;
+ else
+ cache->lines_types[0] = GV_LINE;
ret = linestring_from_wkb(wkb_data, nbytes, byte_order,
is3D, cache->lines[0], FALSE);
add_fpart(fparts, ftype, 0, 1);
@@ -1119,12 +1138,14 @@
sprintf(stmt,
"DECLARE %s_%s%p CURSOR FOR "
"SELECT geom,row_number() OVER "
- "(ORDER BY ST_GeometryType(geom) DESC) AS fid FROM ("
- "SELECT geom FROM \"%s\".node WHERE node_id NOT IN "
+ "(ORDER BY ST_GeometryType(geom) DESC) AS fid,"
+ "left_face,right_face FROM ("
+ "SELECT geom,0 AS left_face, 0 AS right_face FROM "
+ "\"%s\".node WHERE node_id NOT IN "
"\"%s\".edge GROUP BY end_node) AS foo) "
- "UNION ALL SELECT geom FROM \"%s\".edge) AS foo",
+ "UNION ALL SELECT geom,left_face,right_face FROM \"%s\".edge) AS foo",
pg_info->schema_name, pg_info->table_name, pg_info->conn,
pg_info->toposchema_name, pg_info->toposchema_name,
@@ -1257,7 +1278,7 @@
sprintf(stmt,
- "ST_GetFaceGeometry('%s', %d) as geom",
+ "ST_GetFaceGeometry('%s', %d) AS geom",
pg_info->toposchema_name, centroid);
@@ -1272,7 +1293,7 @@
data = (char *)PQgetvalue(res, 0, 0);
PQclear(res);
- if (GV_POINT != cache_feature(data, FALSE, &(pg_info->cache), NULL))
+ if (GV_POINT != cache_feature(data, FALSE, FALSE, &(pg_info->cache), NULL))
return -1;
Vect_append_points(line_p, pg_info->cache.lines[0], GV_FORWARD);
Modified: grass/trunk/lib/vector/diglib/spindex.c
--- grass/trunk/lib/vector/diglib/spindex.c 2012-06-08 21:43:41 UTC (rev 52016)
+++ grass/trunk/lib/vector/diglib/spindex.c 2012-06-09 17:30:56 UTC (rev 52017)
@@ -287,7 +287,7 @@
\return 0
-int dig_spidx_add_line(struct Plus_head *Plus, int line, struct bound_box * box)
+int dig_spidx_add_line(struct Plus_head *Plus, int line, const struct bound_box * box)
static struct RTree_Rect rect;
static int rect_init = 0;
@@ -320,7 +320,7 @@
\return 0
-int dig_spidx_add_area(struct Plus_head *Plus, int area, struct bound_box * box)
+int dig_spidx_add_area(struct Plus_head *Plus, int area, const struct bound_box * box)
@@ -354,7 +354,7 @@
\return 0
-int dig_spidx_add_isle(struct Plus_head *Plus, int isle, struct bound_box * box)
+int dig_spidx_add_isle(struct Plus_head *Plus, int isle, const struct bound_box * box)
@@ -433,7 +433,6 @@
int dig_spidx_del_line(struct Plus_head *Plus, int line, double x, double y, double z)
int ret;
@@ -445,8 +444,6 @@
G_debug(3, "dig_spidx_del_line(): line = %d", line);
- Line = Plus->Line[line];
rect.boundary[0] = x;
rect.boundary[1] = y;
rect.boundary[2] = z;
