[GRASS-SVN] r52044 - in grass/trunk: include include/defs lib/ogsf
svn_grass at osgeo.org
Tue Jun 12 05:08:34 PDT 2012
Author: mmetz
Date: 2012-06-12 05:08:33 -0700 (Tue, 12 Jun 2012)
New Revision: 52044
grass/trunk/include/defs/ogsf.h
grass/trunk/include/ogsf.h
grass/trunk/lib/ogsf/gs.c
grass/trunk/lib/ogsf/gsds.c
grass/trunk/lib/ogsf/rowcol.h
size_t: update ogsf lib
Modified: grass/trunk/include/defs/ogsf.h
--- grass/trunk/include/defs/ogsf.h 2012-06-12 11:48:20 UTC (rev 52043)
+++ grass/trunk/include/defs/ogsf.h 2012-06-12 12:08:33 UTC (rev 52044)
@@ -382,7 +382,7 @@
int gs_get_att_type(geosurf *, int);
int gs_get_att_src(geosurf *, int);
typbuff *gs_get_att_typbuff(geosurf *, int, int);
-int gs_malloc_att_buff(geosurf *, int, int);
+size_t gs_malloc_att_buff(geosurf *, int, int);
int gs_malloc_lookup(geosurf *, int);
int gs_set_att_type(geosurf *, int, int);
int gs_set_att_src(geosurf *, int, int);
@@ -615,8 +615,8 @@
char *gsds_get_name(int);
int gsds_free_datah(int);
int gsds_free_data_buff(int, int);
-int free_data_buffs(dataset *, int);
-int gsds_alloc_typbuff(int, int *, int, int);
+size_t free_data_buffs(dataset *, int);
+size_t gsds_alloc_typbuff(int, int *, int, int);
int gsds_get_changed(int);
int gsds_set_changed(int, IFLAG);
int gsds_get_type(int);
Modified: grass/trunk/include/ogsf.h
--- grass/trunk/include/ogsf.h 2012-06-12 11:48:20 UTC (rev 52043)
+++ grass/trunk/include/ogsf.h 2012-06-12 12:08:33 UTC (rev 52044)
@@ -234,7 +234,7 @@
int data_id;
int dims[MAXDIMS];
int ndims;
- int numbytes;
+ size_t numbytes;
char *unique_name;
typbuff databuff;
IFLAG changed;
Modified: grass/trunk/lib/ogsf/gs.c
--- grass/trunk/lib/ogsf/gs.c 2012-06-12 11:48:20 UTC (rev 52043)
+++ grass/trunk/lib/ogsf/gs.c 2012-06-12 12:08:33 UTC (rev 52044)
@@ -712,9 +712,9 @@
\param type buffer type (based on raster map type)
\return -1 on error
- \return pointer to typbuff (casted)
+ \return amount of allocated memory
-int gs_malloc_att_buff(geosurf * gs, int desc, int type)
+size_t gs_malloc_att_buff(geosurf * gs, int desc, int type)
int hdata, dims[2], ndims;
Modified: grass/trunk/lib/ogsf/gsds.c
--- grass/trunk/lib/ogsf/gsds.c 2012-06-12 11:48:20 UTC (rev 52043)
+++ grass/trunk/lib/ogsf/gsds.c 2012-06-12 12:08:33 UTC (rev 52044)
@@ -76,7 +76,7 @@
static int Cur_id = LUCKY;
static int Cur_max;
-static int Tot_mem = 0;
+static size_t Tot_mem = 0;
\brief Initialize gsds
@@ -390,9 +390,10 @@
\return freed size
-int free_data_buffs(dataset * ds, int typ)
+size_t free_data_buffs(dataset * ds, int typ)
- int nsiz = 1, i, siz, freed = 0;
+ int i;
+ size_t siz, nsiz = 1, freed = 0;
for (i = 0; i < ds->ndims; i++) {
nsiz *= ds->dims[i];
@@ -476,12 +477,13 @@
\param ndims number of dimensions
\param type data type
- \return
-int gsds_alloc_typbuff(int id, int *dims, int ndims, int type)
+size_t gsds_alloc_typbuff(int id, int *dims, int ndims, int type)
dataset *ds;
- int i, siz = 1;
+ int i;
+ size_t siz = 1;
if ((ds = get_dataset(id))) {
Modified: grass/trunk/lib/ogsf/rowcol.h
--- grass/trunk/lib/ogsf/rowcol.h 2012-06-12 11:48:20 UTC (rev 52043)
+++ grass/trunk/lib/ogsf/rowcol.h 2012-06-12 12:08:33 UTC (rev 52044)
@@ -3,6 +3,8 @@
/* these defines work with modeling coordinates only */
+/* TODO: avoid integer overflow */
/* view resolutions */
#define VXRES(gs) (gs->x_mod * gs->xres)
#define VYRES(gs) (gs->y_mod * gs->yres)
