[GRASS-SVN] r52058 - grass-addons/grass7/imagery/i.histo.match
svn_grass at osgeo.org
Wed Jun 13 00:16:59 PDT 2012
Author: lucadelu
Date: 2012-06-13 00:16:58 -0700 (Wed, 13 Jun 2012)
New Revision: 52058
grass-addons/grass7/imagery/i.histo.match/i.histo.match.py
fix bug releated to fullname in input maps
Modified: grass-addons/grass7/imagery/i.histo.match/i.histo.match.py
--- grass-addons/grass7/imagery/i.histo.match/i.histo.match.py 2012-06-13 06:52:25 UTC (rev 52057)
+++ grass-addons/grass7/imagery/i.histo.match/i.histo.match.py 2012-06-13 07:16:58 UTC (rev 52058)
@@ -78,11 +78,12 @@
curs = db.cursor()
# for each image
for i in images:
+ iname = i.split('@')[0]
# drop table if exist
- query_drop = "DROP TABLE if exists t%s" % i
+ query_drop = "DROP TABLE if exists t%s" % iname
curs.execute(query_drop)
# create table
- query_create = "CREATE TABLE t%s (grey_value integer,pixel_frequency " % i
+ query_create = "CREATE TABLE t%s (grey_value integer,pixel_frequency " % iname
query_create += "integer, cumulative_histogram integer, cdf real)"
curs.execute(query_create)
# set the region on the raster
@@ -98,11 +99,13 @@
try:
val = int(stats_dict[str(n)])
cdf += val
- insert = "INSERT INTO t%s VALUES (%i, %i, %i, 0.000000)" % (i, n, val, cdf)
+ insert = "INSERT INTO t%s VALUES (%i, %i, %i, 0.000000)" % (
+ iname, n, val, cdf)
curs.execute(insert)
except:
cdf += 0
- insert = "INSERT INTO t%s VALUES (%i, 0, %i, 0.000000)" % (i, n, cdf)
+ insert = "INSERT INTO t%s VALUES (%i, 0, %i, 0.000000)" % (
+ iname, n, cdf)
db.commit()
# number of pixel is the cdf value
@@ -110,13 +113,15 @@
# for each number in the range
for n in range(0,max_value):
# select value for cumulative_histogram for the range number
- select_ch="SELECT cumulative_histogram FROM t%s WHERE (grey_value=%i)" % (i, n)
+ select_ch="SELECT cumulative_histogram FROM t%s WHERE (grey_value=%i)" % (
+ iname, n)
result = curs.execute(select_ch)
val = result.fetchone()[0]
# update cdf with new value
if val != 0 and numPixel != 0:
update_cdf = round(float(val) / float(numPixel),6)
- update_cdf = "UPDATE t%s SET cdf=%s WHERE (grey_value=%i)" % (i, update_cdf, n)
+ update_cdf = "UPDATE t%s SET cdf=%s WHERE (grey_value=%i)" % (
+ iname, update_cdf, n)
curs.execute(update_cdf)
db.commit()
db.commit()
@@ -126,7 +131,9 @@
numPixel = 0
# for each image
for i in images:
- pixel_freq = "SELECT pixel_frequency FROM t%s WHERE (grey_value=%i)" % (i, n)
+ pixel_freq = "SELECT pixel_frequency FROM t%s WHERE (grey_value=%i)" % (
+ iname, n)
result = curs.execute(pixel_freq)
numPixel += val
@@ -146,8 +153,10 @@
tot = 0
# for each image
for i in images:
# select pixel frequency
+ iname, n)
tot += val
@@ -162,16 +171,17 @@
db.commit()
# for each image
for i in images:
grass.run_command('g.region', rast = i)
# write average rules file
- outfile = open(os.path.join(path,'%s.reclass' % i),'w')
+ outfile = open(os.path.join(path,'%s.reclass' % iname),'w')
new_grey = 0
- select_min = "SELECT min(abs(a.cdf - b.cdf)) FROM t%s as a," % i \
+ select_min = "SELECT min(abs(a.cdf - b.cdf)) FROM t%s as a," % iname \
+ " %s as b WHERE (a.grey_value=%i)" % (table_ave, n)
result_min = curs.execute(select_min)
min_abs = result_min.fetchone()[0]
- select_cdf = "SELECT cdf FROM t%s WHERE grey_value=%i" % (i, n)
+ select_cdf = "SELECT cdf FROM t%s WHERE grey_value=%i" % (iname, n)
result_cdf = curs.execute(select_cdf)
cdf = result_cdf.fetchone()[0]
select_newgrey = "SELECT grey_value FROM %s WHERE " % table_ave \
@@ -185,8 +195,8 @@
except:
out_line = "%d = %d\n" % (n, new_grey)
outfile.write(out_line)
- outfile.close()
- outname = '%s.%s' % (i, suffix)
+ outfile.close()
+ outname = '%s.%s' % (iname, suffix)
# check if a output map already exists
result = grass.core.find_file(outname, element = 'cell')
if result['fullname'] and grass.overwrite():
