[GRASS-SVN] r52080 - grass-addons/grass7/imagery/i.segment
svn_grass at osgeo.org
Fri Jun 15 08:51:55 PDT 2012
Author: momsen
Date: 2012-06-15 08:51:54 -0700 (Fri, 15 Jun 2012)
New Revision: 52080
grass-addons/grass7/imagery/i.segment/create_isegs.c
grass-addons/grass7/imagery/i.segment/iseg.h
grass-addons/grass7/imagery/i.segment/main.c
compiles without error, but region_growing() won't start
Modified: grass-addons/grass7/imagery/i.segment/create_isegs.c
--- grass-addons/grass7/imagery/i.segment/create_isegs.c 2012-06-15 15:15:36 UTC (rev 52079)
+++ grass-addons/grass7/imagery/i.segment/create_isegs.c 2012-06-15 15:51:54 UTC (rev 52080)
@@ -11,12 +11,8 @@
#include <grass/linkm.h> /* memory manager for linked lists */
#include "iseg.h"
#define LINKM
int create_isegs(struct files *files, struct functions *functions)
@@ -60,7 +56,7 @@
/* from speed.c to test speed of malloc vs. memory manager */
register int i;
- VOID_T *head;
+ struct link_head *head;
struct pixels *p;
/* **************write fake data to test I/O portion of module */
@@ -82,13 +78,13 @@
/* TODO: fine tune the chunk size */
#ifdef LINKM
- head = (VOID_T *) link_init(sizeof(struct pixels));
+ head = (struct link_head *)link_init(sizeof(struct pixels));
#endif
for (i = 0; i < 10; i++) {
#ifdef LINKM
p = (struct pixels *)link_new(head);
- link_dispose(head, p);
+ link_dispose(head, (VOID_T *) p);
#else
p = (struct pixels *)G_malloc(sizeof(struct pixels));
G_free(p);
@@ -125,7 +121,7 @@
/* lets get this running, and just use fixed dimension arrays for now. t is limited to 90, segments will be small. */
/* linkm - linked list memory allocation. */
- VOID_T *linkm_token; /* looks like VOID_T is defined as an int in the linkm header files, also seems we can "manage multiple lists" will use one token for all lists, since all have same size elements. */
+ struct link_head *Token; /* seems we can "manage multiple lists" will use one token for all lists, since all have same size elements. */
struct pixels *Rin, *Rkn, *current; /*current will be used to iterate over any of the linked lists. */
int Ri[100][2], Rk[100][2]; /* 100 or so maximum members, second dimension is for: 0: row 1: col */
int Ri_count, Rk_count; /*crutch for now, probably won't need later. */
@@ -141,16 +137,21 @@
/*allocate linked list memory */
/*todo: should the be done in open_files, where other memory things go? or just leave here, data structure / memory for the actual segmentation? */
- linkm_token = (VOID_T *) link_init(sizeof(struct pixels));
+ G_debug(1, "setting up linked lists");
+ Token = (struct link_head *)link_init(sizeof(struct pixels));
+ G_debug(1, "have token");
/*set next pointers to null. TODO: use an element with row/col empty and NULL for next pointer? */
- Rin = (struct pixels *)link_new(linkm_token);
+ Rin = (struct pixels *)link_new(Token);
+ G_debug(1, "have Rin, first pixel in list");
Rin->next = NULL;
+ G_debug(1, "set pointer to NULL");
- Rkn = (struct pixels *)link_new(linkm_token);
+ Rkn = (struct pixels *)link_new(Token);
+ G_debug(1, "have Rkn, first pixel in list");
Rkn->next = NULL;
- Ri_bestn = (struct pixels *)link_new(linkm_token);
+ Ri_bestn = (struct pixels *)link_new(Token);
+ G_debug(1, "have Ri_best, first pixel in list");
Ri_bestn->next = NULL;
do {
@@ -212,14 +213,14 @@
for (current = Rin; Rin->next != NULL;
current = current->next) {
- link_dispose(linkm_token, current);
+ link_dispose(Token, (VOID_T *) current);
Rin = current; /* this should be the "empty" slot at the end of the list. */
for (current = Rkn; Rkn->next != NULL;
Rkn = current; /* this should be the "empty" slot at the end of the list. */
@@ -245,8 +246,7 @@
/* find segment neighbors */
if (find_segment_neighbors
- (Ri, Rin, &Ri_count, files,
- functions, linkm_token) != 0) {
+ (Ri, Rin, &Ri_count, files, functions, Token) != 0) {
G_fatal_error("find_segment_neighbors() failed");
/*TODO: for above function call, Rin is a pointer... so passing the pointer allows the what Rin is pointing at to be changed. I hope! */
@@ -306,7 +306,7 @@
Rk[0][1] = Ri_bestn->col;
/* TODO need to copy the data, not just use Ri itself! *//* Rkn = Ri; *//* we know Ri should be a neighbor of Rk *//*Todo: is there a way to skip similarity calculations on these? keep a count, and pop them before doing the similarity check? */
- find_segment_neighbors(Rk, Rkn, &Rk_count, files, functions, linkm_token); /* data structure for Rk's neighbors, and pixels in Rk if we don't already have it */
+ find_segment_neighbors(Rk, Rkn, &Rk_count, files, functions, Token); /* data structure for Rk's neighbors, and pixels in Rk if we don't already have it */
G_debug(1, "Found Rk's pixels");
/*print out neighbors */
@@ -382,14 +382,15 @@
/* free memory *//*TODO: anything else? */
- link_cleanup(linkm_token);
+ link_cleanup((struct link_head *)Token);
return 0;
int find_segment_neighbors(int Ri[][2], struct pixels *neighbors,
int *seg_count, struct files *files,
- struct functions *functions, VOID_T * token)
+ struct functions *functions,
+ struct link_head *token)
// G_debug(1, "\tin find_segment_neighbors()");
int n, m, Ri_seg_ID = -1;
Modified: grass-addons/grass7/imagery/i.segment/iseg.h
--- grass-addons/grass7/imagery/i.segment/iseg.h 2012-06-15 15:15:36 UTC (rev 52079)
+++ grass-addons/grass7/imagery/i.segment/iseg.h 2012-06-15 15:51:54 UTC (rev 52080)
@@ -90,7 +90,7 @@
int create_isegs(struct files *, struct functions *);
int io_debug(struct files *, struct functions *);
int region_growing(struct files *, struct functions *);
-int find_segment_neighbors(int[][2], struct pixels *, int *, struct files *, struct functions *, VOID_T *); /* TODO: need data structure for Ri, Rin */
+int find_segment_neighbors(int[][2], struct pixels *, int *, struct files *, struct functions *, struct link_head *); /* TODO: need data structure for Ri, Rin */
int set_candidate_flag(int[100][2], int, int, struct files *);
int merge_values(int[100][2], int[100][2], int, int, struct files *); /* I assume this is a weighted mean? */
int find_four_pixel_neighbors(int, int, int[][2], struct files *);
Modified: grass-addons/grass7/imagery/i.segment/main.c
--- grass-addons/grass7/imagery/i.segment/main.c 2012-06-15 15:15:36 UTC (rev 52079)
+++ grass-addons/grass7/imagery/i.segment/main.c 2012-06-15 15:51:54 UTC (rev 52080)
@@ -60,7 +60,7 @@
* "Standard C applications have a header file that contains the steps that the process should follow if it receives a particular signal. "
- G_done_msg("Number of segments created: TODO linkm");
+ G_done_msg("Number of segments created: TODO");
exit(EXIT_SUCCESS);
