[GRASS-SVN] r52084 - grass-addons/grass7/imagery/i.segment
svn_grass at osgeo.org
Fri Jun 15 10:29:46 PDT 2012
Author: momsen
Date: 2012-06-15 10:29:46 -0700 (Fri, 15 Jun 2012)
New Revision: 52084
grass-addons/grass7/imagery/i.segment/create_isegs.c
grass-addons/grass7/imagery/i.segment/iseg.h
grass-addons/grass7/imagery/i.segment/parse_args.c
linked list test case works, need to update region_growing functions with correct linked list usage.
Modified: grass-addons/grass7/imagery/i.segment/create_isegs.c
--- grass-addons/grass7/imagery/i.segment/create_isegs.c 2012-06-15 16:34:40 UTC (rev 52083)
+++ grass-addons/grass7/imagery/i.segment/create_isegs.c 2012-06-15 17:29:46 UTC (rev 52084)
@@ -38,6 +38,8 @@
G_debug(1, "starting region_growing()");
successflag = region_growing(files, functions);
+ else if (functions->method == 2)
+ successflag = ll_test(files, functions);
/* end outer loop for processing polygons */
@@ -102,7 +104,118 @@
return 0;
+int ll_test(struct files *files, struct functions *functions)
+ int row, col, n, m, t;
+ double threshold, Ri_similarity, Rk_similarity, tempsim;
+ /* linkm - linked list memory allocation. */
+ struct link_head *Token; /* seems we can "manage multiple lists" will use one token for all lists, since all have same size elements. */
+ struct pixels *Rin, *Rkn, *current, *newpixel, *Rin_head; /*current will be used to iterate over any of the linked lists. */
+ int Ri[100][2], Rk[100][2]; /* 100 or so maximum members, second dimension is for: 0: row 1: col */
+ int Ri_count, Rk_count; /*crutch for now, probably won't need later. */
+ struct pixels *Ri_bestn; /* best neighbor pixel for Ri, not a linked list, just one pixel... */
+ int temparray[2];
+ G_verbose_message("testing linked lists");
+ /*allocate linked list memory */
+ /*todo: should the be done in open_files, where other memory things go? or just leave here, data structure / memory for the actual segmentation? */
+ G_debug(1, "setting up linked lists");
+ Token = (struct link_head *)link_init(sizeof(struct pixels));
+ G_debug(1, "have token");
+ Rin_head = NULL;
+#ifdef NODEF
+ /*set next pointers to null. TODO: use an element with row/col empty and NULL for next pointer? */
+ Rin = (struct pixels *)link_new(Token);
+ G_debug(1, "have Rin, first pixel in list");
+ Rin->next = NULL;
+ G_debug(1, "set pointer to NULL");
+ Rkn = (struct pixels *)link_new(Token);
+ G_debug(1, "have Rkn, first pixel in list");
+ Rkn->next = NULL;
+ Ri_bestn = (struct pixels *)link_new(Token);
+ G_debug(1, "have Ri_best, first pixel in list");
+ Ri_bestn->next = NULL;
+#endif
+#ifdef NODEF
+ /* code that worked in speed test: */
+ head = (struct link_head *)link_init(sizeof(struct pixels));
+ p = (struct pixels *)link_new(head);
+ link_dispose(head, (VOID_T *) p);
+ link_cleanup(head);
+#endif
+ /* make a neighbor list */
+ for (n = 0; n < 5; n++) {
+ newpixel = (struct pixels *)link_new(Token);
+ newpixel->next = Rin_head; /*point the new pixel to the current first pixel */
+ newpixel->row = n;
+ newpixel->col = n + 2;
+ Rin_head = newpixel; /*change the first pixel to be the new pixel. */
+ G_message("Added: Rin %d: row: %d, col: %d", n,
+ Rin_head->row, Rin_head->col);
+ G_message(" Test pass token result: %d",
+ test_pass_token(&Rin_head, Token));
+ G_message("Printing out:");
+ /*print out neighbors */
+ for (current = Rin_head; current != NULL; current = current->next)
+ G_debug(1, "Rin: row: %d, col: %d", current->row, current->col);
+ /* **************write fake data to test I/O portion of module */
+ G_verbose_message("writing fake data to segmentation file");
+ for (row = 0; row < files->nrows; row++) {
+ G_percent(row, files->nrows, 1); /* TODO this didn't get displayed in the output??? Does it get erased when done? */
+ for (col = 0; col < files->ncols; col++) {
+ /*files->out_val[0] = files->out_val[0]; *//*segment number *//* just copying the map for testing. */
+ files->out_val[0] = col + row;
+ files->out_val[1] = 1; /*processing flag */
+ segment_put(&files->out_seg, (void *)files->out_val, row, col);
+ link_cleanup((struct link_head *)Token);
+ G_message("end linked list test");
+ return 0;
+int test_pass_token(struct pixels **head, struct link_head *token)
+ int n;
+ struct pixels *newpixel;
+ for (n = 10; n < 15; n++) {
+ newpixel = (struct pixels *)link_new(token);
+ newpixel->next = *head; /*point the new pixel to the current first pixel */
+ newpixel->col = n * 2;
+ *head = newpixel; /*change the first pixel to be the new pixel. */
+ newpixel->row, newpixel->col);
+ return 0;
int region_growing(struct files *files, struct functions *functions)
@@ -125,7 +238,7 @@
struct pixels *Rin, *Rkn, *current; /*current will be used to iterate over any of the linked lists. */
- struct pixels *Ri_bestn; /* best neighbor pixel for Ri, not a pointer, just one pixel... */
int temparray[2];
@@ -136,23 +249,16 @@
- /*todo: should the be done in open_files, where other memory things go? or just leave here, data structure / memory for the actual segmentation? */
- G_debug(1, "setting up linked lists");
+ /*todo: should this be done in open_files, where other memory things go? or just leave here, data structure / memory for the actual segmentation? */
- G_debug(1, "have token");
- G_debug(1, "have Rin, first pixel in list");
Rin->next = NULL;
- G_debug(1, "set pointer to NULL");
- G_debug(1, "have Rkn, first pixel in list");
Rkn->next = NULL;
- G_debug(1, "have Ri_best, first pixel in list");
+ G_debug(1, "Have 'head' pixel's allocated from linkm");
do {
/* do while loop on t to slowly lower threshold. also check that endflag==0 (no merges were made) */
Modified: grass-addons/grass7/imagery/i.segment/iseg.h
--- grass-addons/grass7/imagery/i.segment/iseg.h 2012-06-15 16:34:40 UTC (rev 52083)
+++ grass-addons/grass7/imagery/i.segment/iseg.h 2012-06-15 17:29:46 UTC (rev 52084)
@@ -89,6 +89,8 @@
/* create_isegs.c */
int create_isegs(struct files *, struct functions *);
int io_debug(struct files *, struct functions *);
+int ll_test(struct files *, struct functions *);
+int test_pass_token(struct pixels **, struct link_head *);
int region_growing(struct files *, struct functions *);
int find_segment_neighbors(int[][2], struct pixels *, int *, struct files *, struct functions *, struct link_head *); /* TODO: need data structure for Ri, Rin */
int set_candidate_flag(int[100][2], int, int, struct files *);
Modified: grass-addons/grass7/imagery/i.segment/parse_args.c
--- grass-addons/grass7/imagery/i.segment/parse_args.c 2012-06-15 16:34:40 UTC (rev 52083)
+++ grass-addons/grass7/imagery/i.segment/parse_args.c 2012-06-15 17:29:46 UTC (rev 52084)
@@ -96,7 +96,7 @@
functions->method = 0;
else if (strncmp(method->answer, "region_growing", 10) == 0)
functions->method = 1;
- else if (strncmp(method->answer, "ll_list", 5) == 0)
+ else if (strncmp(method->answer, "ll_test", 5) == 0)
functions->method = 2;
else
G_fatal_error("Couldn't assign segmentation method."); /*shouldn't be able to get here */
