[GRASS-SVN] r52093 - grass/trunk/vector/v.net.distance
svn_grass at osgeo.org
Sat Jun 16 01:35:00 PDT 2012
Author: mmetz
Date: 2012-06-16 01:35:00 -0700 (Sat, 16 Jun 2012)
New Revision: 52093
grass/trunk/vector/v.net.distance/main.c
v.net.distance: fix layers and types
Modified: grass/trunk/vector/v.net.distance/main.c
--- grass/trunk/vector/v.net.distance/main.c 2012-06-16 05:45:26 UTC (rev 52092)
+++ grass/trunk/vector/v.net.distance/main.c 2012-06-16 08:35:00 UTC (rev 52093)
@@ -32,13 +32,14 @@
struct line_cats *Cats;
struct GModule *module; /* GRASS module for parsing arguments */
struct Option *map_in, *map_out;
- struct Option *catf_opt, *wheref_opt;
- struct Option *catt_opt, *wheret_opt, *to_type_opt;
- struct Option *afield_opt, *nfield_opt, *abcol, *afcol, *ncol;
+ struct Option *catf_opt, *fieldf_opt, *wheref_opt;
+ struct Option *catt_opt, *fieldt_opt, *wheret_opt, *typet_opt;
+ struct Option *afield_opt, *nfield_opt, *abcol, *afcol, *ncol, *atype_opt;
struct Flag *geo_f;
int with_z, geo;
- int mask_type;
+ int atype, ttype;
struct varray *varrayf, *varrayt;
+ int flayer, tlayer;
int afield, nfield;
dglGraph_s *graph;
struct ilist *nodest;
@@ -64,7 +65,7 @@
module->label = _("Computes shortest distance via the network between "
"the given sets of features.");
module->description =
- _("Finds the shortest paths from a feature 'to' to every feature 'from' "
+ _("Finds the shortest paths from a point 'from' to every feature 'to' "
"and various information about this relation are uploaded to the attribute table.");
/* Define the different options as defined in gis.h */
@@ -77,12 +78,23 @@
afield_opt->description = _("Arc layer");
afield_opt->guisection = _("Cost");
+ atype_opt = G_define_standard_option(G_OPT_V_TYPE);
+ atype_opt->options = "line,boundary";
+ atype_opt->answer = "line,boundary";
+ atype_opt->description = _("Arc type");
+ atype_opt->guisection = _("Cost");
nfield_opt = G_define_standard_option(G_OPT_V_FIELD);
nfield_opt->key = "nlayer";
nfield_opt->answer = "2";
nfield_opt->description = _("Node layer");
nfield_opt->guisection = _("Cost");
+ fieldf_opt = G_define_standard_option(G_OPT_V_FIELD);
+ fieldf_opt->key = "from_layer";
+ fieldf_opt->label = _("From layer number or name");
+ fieldf_opt->guisection = _("From");
catf_opt = G_define_standard_option(G_OPT_V_CATS);
catf_opt->key = "from_cats";
catf_opt->label = _("From category values");
@@ -94,6 +106,18 @@
_("From WHERE conditions of SQL statement without 'where' keyword");
wheref_opt->guisection = _("From");
+ fieldt_opt = G_define_standard_option(G_OPT_V_FIELD);
+ fieldt_opt->key = "to_layer";
+ fieldt_opt->description = _("To layer number or name");
+ fieldt_opt->guisection = _("To");
+ typet_opt = G_define_standard_option(G_OPT_V_TYPE);
+ typet_opt->key = "to_type";
+ typet_opt->options = "point,line,boundary";
+ typet_opt->answer = "point";
+ typet_opt->description = _("To feature type");
+ typet_opt->guisection = _("To");
catt_opt = G_define_standard_option(G_OPT_V_CATS);
catt_opt->key = "to_cats";
catt_opt->label = _("To category values");
@@ -105,13 +129,6 @@
_("To WHERE conditions of SQL statement without 'where' keyword");
wheret_opt->guisection = _("To");
- to_type_opt = G_define_standard_option(G_OPT_V_TYPE);
- to_type_opt->key = "to_type";
- to_type_opt->options = "point,line,boundary";
- to_type_opt->answer = "point";
- to_type_opt->description = _("To feature type");
- to_type_opt->guisection = _("To");
afcol = G_define_standard_option(G_OPT_DB_COLUMN);
afcol->key = "afcolumn";
afcol->required = NO;
@@ -140,8 +157,10 @@
/* options and flags parser */
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- mask_type = Vect_option_to_types(to_type_opt);
+ atype = Vect_option_to_types(atype_opt);
+ ttype = Vect_option_to_types(typet_opt);
Points = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
@@ -188,16 +207,21 @@
afield = Vect_get_field_number(&In, afield_opt->answer);
nfield = Vect_get_field_number(&In, nfield_opt->answer);
- NetA_initialise_varray(&In, nfield, GV_POINT, wheref_opt->answer,
+ flayer = atoi(fieldf_opt->answer);
+ tlayer = atoi(fieldt_opt->answer);
+ NetA_initialise_varray(&In, flayer, GV_POINT, wheref_opt->answer,
catf_opt->answer, &varrayf);
- NetA_initialise_varray(&In, nfield, mask_type, wheret_opt->answer,
+ NetA_initialise_varray(&In, tlayer, ttype, wheret_opt->answer,
catt_opt->answer, &varrayt);
nodest = Vect_new_list();
NetA_varray_to_nodes(&In, varrayt, nodest, nodes_to_features);
- Vect_net_build_graph(&In, mask_type, 1, 0, afcol->answer, abcol->answer,
+ Vect_net_build_graph(&In, atype, afield, nfield, afcol->answer, abcol->answer,
ncol->answer, geo, 0);
graph = &(In.graph);
NetA_distance_from_points(graph, nodest, dst, prev);
@@ -236,14 +260,14 @@
Vect_hist_copy(&In, &Out);
Vect_hist_command(&Out);
- for (i = 1; i <= nlines; i++)
+ for (i = 1; i <= nlines; i++) {
if (varrayf->c[i]) {
int type = Vect_read_line(&In, Points, Cats, i);
int node, tcat, cat;
double cost;
dglInt32_t *vertex, vertex_id;
- if (!Vect_cat_get(Cats, nfield, &cat))
+ if (!Vect_cat_get(Cats, flayer, &cat))
continue;
if (type & GV_POINTS) {
@@ -266,7 +290,7 @@
vertex_id = dglNodeGet_Id(graph, vertex);
Vect_read_line(&In, NULL, Cats, nodes_to_features[vertex_id]);
- if (!Vect_cat_get(Cats, nfield, &tcat))
+ if (!Vect_cat_get(Cats, tlayer, &tcat))
continue;
sprintf(buf, "insert into %s values (%d, %d, %f)", Fi->table, cat,
tcat, cost);
@@ -279,6 +303,7 @@
db_get_string(&sql));
if (on_path[i]->n_cats > 0) {
