[GRASS-SVN] r52112 - grass-addons/tools
Sun Jun 17 03:24:27 PDT 2012
Author: hamish
Date: 2012-06-17 03:24:26 -0700 (Sun, 17 Jun 2012)
New Revision: 52112
Added:
   grass-addons/tools/csv_dequote.pl
add script for parsing CSV files containg "quoted comma, containing" strings into a pipe delimited ascii file which v.in.ascii will accept
Added: grass-addons/tools/csv_dequote.pl
--- grass-addons/tools/csv_dequote.pl	                        (rev 0)
+++ grass-addons/tools/csv_dequote.pl	2012-06-17 10:24:26 UTC (rev 52112)
@@ -0,0 +1,67 @@
+#!/usr/bin/perl
+# csv_dequote.pl:
+#  Take a .csv file with quoted strings, convert the real comma delims
+#  to pipes (|) and strip away the double quote chars.
+#  Author:   Hamish Bowman, Dunedin, New Zealand, June 2012
+#            (c) 2012 M. Hamish Bowman, and the GRASS Development Team
+#  License:  GNU GPL >=2. See the GPL.TXT file which comes with GRASS
+#            for details.
+# Requires:  Text::CSV   ('apt-get install libtext-csv-perl')
+#  USAGE:  csv_dequote.pl infile.csv [outfile.psv]
+#   if outfile is not given it will take the basename of the input
+#   file and give it the .psv extension (".Pipe Sep Vars").
+use strict;
+use warnings;
+use Text::CSV;
+use File::Basename;
+my $outsep = '|';
+my $infile = shift
+  or die "USAGE: csv_dequote.pl infile.csv [outfile.psv]\n";
+my $outfile = shift || '';
+unless($outfile) {
+    my $file = '';
+    my $dir = '';
+    my $ext = '';
+    ($file, $dir, $ext) = fileparse($infile, qr/\.[^.]*/);
+    $outfile = "$file.psv";
+if (-e $outfile) {
+    die "ERROR: \"$outfile\" already exists.\
+       Will not overwrite; aborting.\n";
+my $csv = Text::CSV->new();
+open (CSVin, "<", $infile) or die "$infile: $!";
+open (CSVout, ">", $outfile) or die "$outfile: $!";
+while (<CSVin>) {
+    if ($csv->parse($_)) {
+	my @columns = $csv->fields();
+	print CSVout join("$outsep", @columns);
+	print CSVout "\n";
+    } else {
+	my $bad = $csv->error_input;
+	print "Unable to parse line: $bad";
+close CSVin or die "$infile: $!";
+close CSVout or die "$outfile: $!";
Property changes on: grass-addons/tools/csv_dequote.pl
___________________________________________________________________
Added: svn:executable
Added: svn:mime-type
   + text/x-perl
Added: svn:eol-style
   + native
