[GRASS-SVN] r52124 - grass/trunk/vector/v.net.distance
svn_grass at osgeo.org
Mon Jun 18 06:50:55 PDT 2012
Author: mmetz
Date: 2012-06-18 06:50:55 -0700 (Mon, 18 Jun 2012)
New Revision: 52124
grass/trunk/vector/v.net.distance/main.c
v.net.distance fix for unreachable features
Modified: grass/trunk/vector/v.net.distance/main.c
--- grass/trunk/vector/v.net.distance/main.c 2012-06-18 13:13:43 UTC (rev 52123)
+++ grass/trunk/vector/v.net.distance/main.c 2012-06-18 13:50:55 UTC (rev 52124)
@@ -30,7 +30,7 @@
struct Map_info In, Out;
static struct line_pnts *Points;
- struct line_cats *Cats;
+ struct line_cats *Cats, *TCats;
struct GModule *module; /* GRASS module for parsing arguments */
struct Option *map_in, *map_out;
struct Option *catf_opt, *fieldf_opt, *wheref_opt;
@@ -164,6 +164,7 @@
Points = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
+ TCats = Vect_new_cats_struct();
Vect_check_input_output_name(map_in->answer, map_out->answer,
G_FATAL_EXIT);
@@ -279,7 +280,8 @@
if (node < 1)
continue;
- Vect_write_line(&Out, type, Points, Cats);
+ if (dst[node] < 0)
+ continue; /* unreachable */
cost = dst[node] / (double)In.cost_multip;
vertex = dglGetNode(graph, node);
vertex_id = node;
@@ -290,9 +292,12 @@
vertex = dglEdgeGet_Head(graph, prev[vertex_id]);
vertex_id = dglNodeGet_Id(graph, vertex);
- Vect_read_line(&In, NULL, Cats, nodes_to_features[vertex_id]);
- if (!Vect_cat_get(Cats, tlayer, &tcat))
+ G_debug(3, "read line %d, vertex id %d", nodes_to_features[vertex_id], (int)vertex_id);
+ Vect_read_line(&In, NULL, TCats, nodes_to_features[vertex_id]);
+ if (!Vect_cat_get(TCats, tlayer, &tcat))
continue;
+ Vect_write_line(&Out, type, Points, Cats);
sprintf(buf, "insert into %s values (%d, %d, %f)", Fi->table, cat,
tcat, cost);
