[GRASS-SVN] r52129 - grass-addons/grass7/imagery/i.segment
svn_grass at osgeo.org
Mon Jun 18 20:56:21 PDT 2012
Author: momsen
Date: 2012-06-18 20:56:20 -0700 (Mon, 18 Jun 2012)
New Revision: 52129
grass-addons/grass7/imagery/i.segment/create_isegs.c
grass-addons/grass7/imagery/i.segment/iseg.h
grass-addons/grass7/imagery/i.segment/open_files.c
linked list structures are working. But it is much too slow, stick with 10x10 resolution unless you are patient...
Modified: grass-addons/grass7/imagery/i.segment/create_isegs.c
--- grass-addons/grass7/imagery/i.segment/create_isegs.c 2012-06-19 01:49:35 UTC (rev 52128)
+++ grass-addons/grass7/imagery/i.segment/create_isegs.c 2012-06-19 03:56:20 UTC (rev 52129)
@@ -20,11 +20,6 @@
/* TODO consider if there are _method specific_ parameter set up and memory allocation, should that happen here? */
- if (functions->method == 1) { /*region growing */
- /* nothing yet */
/*TODO: implement outer loop to process polygon interior, then all remaining pixels */
/* This loop could go in here, or in main to contain open/create/write to reduced memory reqs. But how merge the writes? */
@@ -43,19 +38,17 @@
/* end outer loop for processing polygons */
- /* clean up */
+ /* clean up? */
return successflag;
+/* writes row+col to the output raster. Also using for the linkm speed test. */
int io_debug(struct files *files, struct functions *functions)
int row, col;
- /* for testing other stuff */
/* from speed.c to test speed of malloc vs. memory manager */
register int i;
struct link_head *head;
@@ -74,10 +67,7 @@
- /* spot to test things... */
/*speed test... showed a difference of 1min 9s for G_malloc and 34s for linkm. (with i < 2000000000 */
- /* TODO: fine tune the chunk size */
#ifdef LINKM
head = (struct link_head *)link_init(sizeof(struct pixels));
@@ -107,18 +97,17 @@
int ll_test(struct files *files, struct functions *functions)
int row, col, n, count;
- struct pixels *Rkn, *current, *newpixel, *Rin_head; /*current will be used to iterate over any of the linked lists. */
+ struct pixels *Rkn, *current, *newpixel, *Rin_head, *Rin_second; /*current will be used to iterate over any of the linked lists. */
+ struct link_head *Rkn_token;
- G_verbose_message("testing linked lists");
+ G_message("testing linked lists");
- /*allocate linked list memory */
- /*todo: should the be done in open_files, where other memory things go? or just leave here, data structure / memory for the actual segmentation? */
- //~ G_debug(1, "setting up linked lists");
- //~ Token = (struct link_head *)link_init(sizeof(struct pixels));
- //~ G_debug(1, "have token");
Rin_head = NULL;
+ Rin_second = NULL;
Rkn = NULL;
+ Rkn_token = link_init(sizeof(struct pixels));
+ if (Rkn_token == NULL)
+ G_message("Rkn_token is null");
/* make a neighbor list */
for (n = 0; n < 5; n++) {
@@ -130,57 +119,96 @@
G_message("Added: Rin %d: row: %d, col: %d", n,
Rin_head->row, Rin_head->col);
+ /* make a second neighbor list, using same token */
+ for (n = 0; n < 4; n++) {
+ newpixel = (struct pixels *)link_new(files->token);
+ newpixel->next = Rin_second; /*point the new pixel to the current first pixel */
+ newpixel->row = n * 100;
+ newpixel->col = n * 100;
+ Rin_second = newpixel; /*change the first pixel to be the new pixel. */
+ G_message("Added: Rin (second list) %d: row: %d, col: %d", n,
+ Rin_second->row, Rin_second->col);
+ /* make a third neighbor list, using local token */
- newpixel = (struct pixels *)link_new(files->token);
+ newpixel = (struct pixels *)link_new(Rkn_token);
newpixel->next = Rkn; /*point the new pixel to the current first pixel */
newpixel->row = 5 * n;
newpixel->col = n;
Rkn = newpixel; /*change the first pixel to be the new pixel. */
G_message("Added: Rkn %d: row: %d, col: %d", n, Rkn->row, Rkn->col);
G_message(" Test pass token result: %d",
test_pass_token(&Rin_head, files));
G_message("Printing out:");
/*print out neighbors */
for (current = Rin_head; current != NULL; current = current->next)
- G_debug(1, "Rin: row: %d, col: %d", current->row, current->col);
+ G_message("Rin: row: %d, col: %d", current->row, current->col);
+ for (current = Rin_second; current != NULL; current = current->next)
+ G_message("Rin (second): row: %d, col: %d", current->row,
+ current->col);
for (current = Rkn; current != NULL; current = current->next)
- G_debug(1, "Rkn: row: %d, col: %d", current->row, current->col);
+ G_message("Rkn: row: %d, col: %d", current->row, current->col);
/* remove all from Rkn list, 5 from Rin list */
+ G_message("removing 5 from Rin...");
current = Rin_head; /* get first in list */
- Rin_head = current->next; /* point head to the next one *//*pop */
- link_dispose((struct link_head *)current, (VOID_T *) files->token);
+ Rin_head = Rin_head->next; /* point head to the next one *//*pop */
+ link_dispose(files->token, (VOID_T *) current);
- for (current = Rkn; current != NULL; current = current->next) {
+ G_message("Printing out, after 5 removed from Rin:");
+ for (current = Rin_head; current != NULL; current = current->next)
+ current->col);
+ for (current = Rkn; current != NULL; current = current->next)
+ G_message("removing all from Rkn...");
+ /* for (current = Rkn; current != NULL; current = current->next) { ||||this shortcut won't work, current is gone! */
+ while (Rkn != NULL) {
+ G_message("In Rkn remove loop");
+ current = Rkn; /* rememer "old" head */
+ Rkn = Rkn->next; /* move head to next pixel */
+ link_dispose(Rkn_token, (VOID_T *) current); /* remove "old" head */
- Rkn = NULL; /* TODO: if emptying whole list - can just empty and then set head to null ? */
+ G_message("removed Rkn...");
+ if (Rkn == NULL)
+ G_message("which set Rkn to null");
+ else
+ G_message("hmm, still need to set Rkn to null?!");
- G_message("Printing out, after removed:");
- /*print out neighbors */
+ /* Rkn = NULL; not needed *//* TODO: if emptying whole list - can just empty and then set head to null ? */
+ G_message("Printing out, after removed Rin and Rkn:");
+ current->col);
/* **************write fake data to test I/O portion of module */
- G_verbose_message("writing fake data to segmentation file");
+ G_message("writing fake data to segmentation file");
for (row = 0; row < files->nrows; row++) {
G_percent(row, files->nrows, 1); /* TODO this didn't get displayed in the output??? Does it get erased when done? */
for (col = 0; col < files->ncols; col++) {
@@ -195,27 +223,25 @@
for (n = 0; n < functions->threshold; n++) {
/*make tokens */
- test_pass_token(&Rkn, files);
+ test_pass_token(&Rin_head, files);
count += 5;
- G_debug(1, "estimate of tokens created %d", count);
+ G_message("estimate of tokens created %d", count + 15);
/*dispose tokens */
- link_dispose((struct link_head *)Rkn, (VOID_T *) files->token);
+ while (Rin_head != NULL) {
+ current = Rin_head; /* rememer "old" head */
+ Rin_head = Rin_head->next; /* move head to next pixel */
+ link_dispose(files->token, (VOID_T *) current); /* remove "old" head */
- G_debug(1, "are they gone?");
+ G_message("are they gone?");
- G_debug(1,
- "Checking after set head to null.... TODO: anyway to find out if linkm memory manager knows they are gone???");
+ /* TODO: anyway to confirm if linkm memory manager knows they are gone???" */
+ link_cleanup(Rkn_token);
+ G_message("after link_cleanup(Rkn_token)");
G_message("end linked list test");
return 0;
@@ -252,26 +278,19 @@
/* Ri = current focus segment
* Rk = Ri's most similar neighbor
* Rkn = Rk's neighbors
- * Rin = Ri's neigbors (as pixels or segments ?) currently as pixels, so repeat calculations are made when multiple neighbors in same segment
+ * Rin = Ri's neigbors currently as pixels, so repeat calculations are made when multiple neighbors in same segment
+ * Todo: should Rin be checked for unique segments? Or is checking for unique longer then just calculating similarity a few extra times?
+ * files->token has the "link_head" for linkm: linked list memory allocation. */
- /* lets get this running, and just use fixed dimension arrays for now. t is limited to 90, segments will be small. */
- /* linkm - linked list memory allocation. */
- //~ struct link_head *Token; /* seems we can "manage multiple lists" will use one token for all lists, since all have same size elements. */
struct pixels *Ri_head, *Rk_head, *Rin_head, *Rkn_head, *current, *newpixel; /*current will be used to iterate over any of the linked lists. */
- int Ri_count, Rk_count; /*TODO when to calculate these. */
- struct pixels *Ri_bestn; /* best neighbor pixel for Ri, don't use as a linked list, just one pixel... */
+ int Ri_count, Rk_count; /*TODO when to calculate these, currently accumulating during find_neighbor() */
+ struct pixels *Ri_bestn; /* best neighbor pixel for Ri, not used as a linked list, just one pixel... */
G_verbose_message("Running region growing algorithm");
t = 0;
files->candidate_count = 0;
- /* done in open_files() */
/*set next pointers to null. */
Ri_head = NULL;
Rk_head = NULL;
@@ -283,18 +302,19 @@
/* do while loop on t to slowly lower threshold. also check that endflag==0 (no merges were made) */
G_debug(1,
- "############# Starting outer do loop! t = %d ###############",
+ "########## Starting outer do loop! t = %d ##########",
t);
threshold = functions->threshold; /* TODO, consider making this a function of t. */
endflag = 1;
- /* Set candidate flag to true/1 for all pixels TODO: for polygon group, need to just set to true for those being processed */
+ /* Set candidate flag to true/1 for all pixels TODO: for polygon/vector constraint, need to just set to true for those being processed */
- segment_get(&files->out_seg, (void *)files->out_val, row, col); /*need to get, since we only want to change the flag, and not overwrite the segment value. */
+ segment_get(&files->out_seg, (void *)files->out_val, row, col); /*need to get, since we only want to change the flag, and not overwrite the segment value.
+ TODO: consider splitting this, put flag in one segmentmentation file (or RAM), and segment assignment in another. */
/* TODO: if we are starting from seeds...and only allow merges between unassigned pixels
* and seeds/existing segments, then this needs an if (and will be very inefficient)
* maybe consider the sorted array, btree, map... but the number of seeds could still be high for a large map */
@@ -320,19 +340,20 @@
G_debug(1,
"Next starting pixel from next row/col, not from Rk");
segment_get(&files->out_seg, (void *)files->out_val, row, col); /*TODO small time savings - if candidate_count reaches zero, bail out of these loops too? */
if (files->out_val[1] == 1) { /* out_val[1] is the candidate pixel flag, want to process the 1's */
+ G_debug(1, "going to free memory on linked lists...");
/*free memory for linked lists */
- my_dispose(&Ri_head, files);
- my_dispose(&Rk_head, files);
- my_dispose(&Rin_head, files);
- my_dispose(&Rkn_head, files); /* TODO, better style for repeating this for all structures? */
+ my_dispose_list(files->token, &Ri_head);
+ my_dispose_list(files->token, &Rk_head);
+ my_dispose_list(files->token, &Rin_head);
+ my_dispose_list(files->token, &Rkn_head); /* TODO, better style for repeating this for all structures? */
Rk_count = 0;
+ G_debug(1, "finished free memory on linked lists...");
- /* First pixel in Ri is current pixel. We may add more later if it is part of a segment */
- Ri_count = 1; /* TODO, count as we go, or when process? */
+ /* First pixel in Ri is current row/col pixel. We may add more later if it is part of a segment */
+ Ri_count = 1;
newpixel->next = Ri_head;
newpixel->row = row;
@@ -352,13 +373,24 @@
G_debug(1, "line 165, \t\t\t\tcc = %d",
files->candidate_count);
+ /* what is passed to find segment neighors: */
+ /* G_debug(1, "calling find_segment_neigors() with:");
+ for (current = Ri_head; current != NULL;
+ current = current->next)
+ G_debug(1, "Ri: row: %d, col: %d", current->row,
+ current->col);
+ G_debug(1, "Rin: row: %d, col: %d", current->row,
+ current->col);
+ G_debug(1, "also passing Ri_count: %d", Ri_count);
/* find segment neighbors */
if (find_segment_neighbors
(&Ri_head, &Rin_head, &Ri_count, files,
functions) != 0) {
G_fatal_error("find_segment_neighbors() failed");
+ } /* TODO - shouldn't be just fatal error - need to still close_files(). Just put that here then fatal error? */
if (Rin_head == NULL) {
G_debug(1, "2a, Segment had no valid neighbors"); /*this could happen if there is a segment surrounded by pixels that have already been processed */
@@ -379,7 +411,6 @@
current->col);
G_debug(1, "2b, Found Ri's neighbors");
@@ -420,12 +451,19 @@
if (Ri_bestn != NULL && Ri_similarity < threshold) { /* small TODO: should this be < or <= for threshold? */
/* we'll have the neighbor pixel to start with. */
G_debug(1, "3a: Working with Rk");
- Ri_bestn->next = NULL; /* Don't want to carry any of the other pixels with this one... */
Rk_count = 1;
+ newpixel =
+ (struct pixels *)link_new(files->token);
+ newpixel->next = NULL; /* or = Rk_head; *//*TODO, should this be Rk_head or just NULL? amounts to the same thing here? */
+ newpixel->row = Ri_bestn->row;
+ newpixel->col = Ri_bestn->col;
+ Rk_head = newpixel;
+ /* TODO - lists starting, should this be a helper function, did at start of Ri and Rk. */
- Rk_head = Ri_bestn; /* TODO, OK like this? Maybe forget Ri_bestn, just use Rk from the beginning? */
+ /*Todo: Do we want to put Ri into Rkn ? Hmm, we don't want to actually check similarity on them when they are in Rkn, since we'll
+ * start with Ri as the initial similarity. Maybe add a 3rd input list to find_segment_neighbors(), and put them directily into
+ * the no_check list so we avoid a small amount of processing? But that might take longer then just checking their similarity in the first place! */
- /* TODO need to copy the data, not just use Ri itself! *//* Rkn = Ri; *//* we know Ri should be a neighbor of Rk *//*Todo: is there a way to skip similarity calculations on these? keep a count, and pop them before doing the similarity check? */
find_segment_neighbors(&Rk_head, &Rkn_head, &Rk_count, files, functions); /* data structure for Rk's neighbors, and pixels in Rk if we don't already have it */
G_debug(1, "Found Rk's pixels");
@@ -455,7 +493,6 @@
if (Rk_similarity == Ri_similarity) { /* so they agree, both are mutually most similar neighbors, none of Rk's other neighbors were more similar */
- /* TODO: put these steps in merge_segments(Ri, Rk) function? */
merge_values(Ri_head, Rk_head, Ri_count, Rk_count, files); /* TODO error trap */
endflag = 0; /* we've made at least one merge, so need another t iteration */
pathflag = 0; /* go to next row,column pixel - end of Rk -> Ri chain since we found mutual best neighbors */
@@ -465,7 +502,7 @@
"Ri was not Rk's best neighbor, Ri_sim: %g, Rk_sim, %g",
Ri_similarity, Rk_similarity);
- /* did this at beginning of trail loop */
+ /* did this at beginning of path loop */
set_candidate_flag(Ri_head, 0, files); /* remove all Ri members from candidate pixels (set flag) */
files->candidate_count++; /* add one back, we had already set Ri[0] flag at the beginning. */
G_debug(1, "line 247, \t\t\t\tcc = %d",
@@ -481,7 +518,7 @@
- } /*end if Rk exists and < threshold */
+ } /*end else (from if mutually best neighbors) */
else
G_debug(1,
"3b Rk didn't didn't exist or similarity was > threshold");
@@ -496,11 +533,10 @@
G_debug(1, "Finished one pass, t was = %d", t);
t++;
} while (t < 90 && endflag == 0);
- /*end t loop */
+ /*end t loop *//*TODO, should there be a max t that it can iterate for? Include t in G_message? */
- /* free memory *//*TODO: anything else? */
+ /* free memory *//*TODO: anything ? */
- /* in close_files() link_cleanup((struct link_head *)Token); */
return 0;
@@ -509,36 +545,32 @@
struct pixels **neighbors_head, int *seg_count,
- // G_debug(1, "\tin find_segment_neighbors()");
int n, m, Ri_seg_ID = -1;
- struct pixels *newpixel, *current;
+ struct pixels *newpixel, *current, *to_check; /* need to check the pixel neighbors of to_check */
+ int val_no_check = -1; /*value of the no_check flag for the particular pixel. */
+ int pixel_neighbors[8][2]; /* TODO: data type? put in files to allocate memory once? */
/* neighbor list will be a listing of pixels that are neighbors? Include segment numbers? Only include unique segments?
* Maybe the most complete return would be a structure array, structure to include the segment ID and a list of points in it?
* But the list of points would NOT be inclusive - just the points bordering the current segment...
+ /* parameter: R, current segment membership, could be single pixel or list of pixels.
+ * parameter: neighbors/Rin/Rik, neighbor pixels, could have a list already, or could be empty ?
+ * files->out_seg is currently an array [0] for seg ID and [1] for "candidate pixel"
+ * files->no_check is a segmentation data structure, if the pixel should no longer be checked on this current find_neighbors() run
+ * functions->num_pn int, 4 or 8, for number of pixel neighbors
- /* parameter: R, current segment membership, could be single pixel or list of pixels. */
- /* parameter: neighbors/Rin, neighbor pixels, could have a list already, or could be empty ? Or just the head of a list? */
+ /* show what was sent to function *//*
+ G_debug(1, "in find_segment_neigors() with:");
+ for (current = *R_head; current != NULL; current = current->next)
+ G_debug(1, "R: row: %d, col: %d", current->row, current->col);
+ for (current = *neighbors_head; current != NULL; current = current->next)
+ G_debug(1, "neig: row: %d, col: %d", current->row, current->col);
+ G_debug(1, "also passing Ri_count: %d", *seg_count); */
- /* TODO local data structures... but maybe they should be allocated out in the main function, is it really slow to create/free on each pass? */
- struct pixels *to_check; /* need to check the neighbors of these pixels */
- /* put no_check in files structure for now... */
- /* int[100][2] no_check; *//* sorted array or btree: list of pixels (by row / column ?) that have been put into the to_check queue, been processed, or are not candidate pixels */
- /* or use flag for no_check? ... need a better name for this variable??? */
- int val_no_check = -1; /*value of the no_check flag for the particular pixel. */
- int pixel_neighbors[8][2]; /* TODO: data type? put in files to allocate memory once? */
- /*int current_pixel = 0; *//* TODO: for now, row index for pixel_neighbors[][]. With linked list will be the popped pixel in each loop. */
- /* Notes, these are in functions structure:
- * functions->num_pn int, 4 or 8, for number of pixel neighbors */
/*initialize data.... TODO: maybe remember min max row/col that was looked at each time, initialize in open_files, and reset smaller region at end of this functions */
for (n = 0; n < files->nrows; n++) {
for (m = 0; m < files->ncols; m++) {
@@ -549,7 +581,7 @@
to_check = NULL;
- /* Put Ri in to be checked and no check lists (don't expand them if we find them again) */
+ /* Copy R in to_check and no_check data structures (don't expand them if we find them again) */
/* NOTE: in pseudo code also have a "current segment" list, but think we can just pass Ri and use it directly */
for (current = *R_head; current != NULL; current = current->next) {
@@ -574,11 +606,6 @@
while (to_check != NULL) { /* removing from to_check list as we go, NOT iterating over the list. */
G_debug(1,
- "\tfind neighbors(): head to_check pixel: row: %d, col: %d",
- to_check->row, to_check->col);
- /* current_pixel = just use to_check - the row/col, and remove at end */
- G_debug(1,
"\tfind_pixel_neighbors for row: %d , col %d",
@@ -590,13 +617,16 @@
current = to_check; /* temporary store the old head */
to_check = to_check->next; /*head now points to the next element in the list */
/*print out to_check */
G_debug(1, "remaining pixel's in to_check, after popping:");
for (current = to_check; current != NULL; current = current->next)
G_debug(1, "to_check... row: %d, col: %d", current->row,
current->col);
+ G_debug(1, "Rn... row: %d, col: %d", current->row, current->col);
/*now check the pixel neighbors and add to the lists */
@@ -642,7 +672,7 @@
to_check = newpixel; /*change the first pixel to be the new pixel. */
- else {
+ else { /* segment id's were different */
/* put pixel_neighbor[n] in Rin */
G_debug(1, "Put in neighbors_head");
/* TODO - helper function for adding pixel to a list */
@@ -655,7 +685,9 @@
} /*end if valid candidate pixel */
else
- G_debug(1, "pixel was not a valid candidate pixel");
+ G_debug(1,
+ "pixel row: %d col: %d was not a valid candidate pixel",
+ pixel_neighbors[n][0], pixel_neighbors[n][1]);
} /*end if for pixel_neighbor was in "don't check" list */
} /* end for loop - next pixel neighbor */
@@ -664,15 +696,13 @@
current->col);
+ G_debug(1, "\t### end of pixel neighors");
} /* while to_check has more elements */
return 0;
-int find_four_pixel_neighbors(int p_row, int p_col, int pixel_neighbors[][2],
+int find_four_pixel_neighbors(int p_row, int p_col, int pixel_neighbors[8][2],
struct files *files)
@@ -719,7 +749,7 @@
find_four_pixel_neighbors(p_row, p_col, pixel_neighbors, files);
/* get the 4 diagonal neighbors */
+ G_warning("Diagonal neighbors Not Implemented");
/*TODO... continue as above */
return 0;
@@ -750,7 +780,7 @@
int merge_values(struct pixels *Ri_head, struct pixels *Rk_head, int Ri_count,
int Rk_count, struct files *files)
-{ /* TODO: correct assumption that this should be a weighted mean. */
+{ /* TODO: correct assumption that this should be a weighted mean? */
int n;
struct pixels *current;
@@ -828,14 +858,15 @@
/* let memory manager know space is available again and reset head to NULL */
-int my_dispose(struct pixels **head, struct files *files)
+int my_dispose_list(struct link_head *token, struct pixels **head)
- for (current = *head; current != NULL; current = current->next)
+ while ((*head) != NULL) {
+ current = *head; /* rememer "old" head */
+ *head = (*head)->next; /* move head to next pixel */
+ link_dispose(token, (VOID_T *) current); /* remove "old" head */
- *head = NULL;
return 0;
Modified: grass-addons/grass7/imagery/i.segment/iseg.h
--- grass-addons/grass7/imagery/i.segment/iseg.h 2012-06-19 01:49:35 UTC (rev 52128)
+++ grass-addons/grass7/imagery/i.segment/iseg.h 2012-06-19 03:56:20 UTC (rev 52129)
@@ -102,7 +102,7 @@
int find_eight_pixel_neighbors(int, int, int[8][2], struct files *);
double calculate_euclidean_similarity(struct pixels *, struct pixels *,
struct files *, struct functions *);
-int my_dispose(struct pixels **, struct files *);
+int my_dispose_list(struct link_head *, struct pixels **);
/* write_output.c */
int write_output(struct files *);
Modified: grass-addons/grass7/imagery/i.segment/open_files.c
--- grass-addons/grass7/imagery/i.segment/open_files.c 2012-06-19 01:49:35 UTC (rev 52128)
+++ grass-addons/grass7/imagery/i.segment/open_files.c 2012-06-19 03:56:20 UTC (rev 52129)
@@ -110,6 +110,8 @@
/* Initialize output segmentation file */
+ /* TODO: Need to carry MASK over to the output file as well. Need an additional flag that is set, during input read? */
G_debug(1, "G_malloc size: = <%d>", (int)(2 * sizeof(int)));
files->out_val = (int *)G_malloc(2 * sizeof(int));
@@ -127,9 +129,9 @@
/* linked list memory management linkm */
- link_set_chunk_size(10000); /* TODO: fine tune this number - high for now with dispose not working! */
- files->token = (struct link_head *)link_init(sizeof(struct pixels));
+ link_set_chunk_size(20); /* TODO: fine tune this number */
+ files->token = link_init(sizeof(struct pixels));
/* Free memory */
