[GRASS-SVN] r52133 - grass/branches/develbranch_6/include/iostream
Tue Jun 19 03:31:36 PDT 2012
Author: martinl
Date: 2012-06-19 03:31:36 -0700 (Tue, 19 Jun 2012)
New Revision: 52133
   grass/branches/develbranch_6/include/iostream/ami_stream.h
glynn: Fix compilation errors (bug #1676)
       (merge r52130 from trunk)
Modified: grass/branches/develbranch_6/include/iostream/ami_stream.h
--- grass/branches/develbranch_6/include/iostream/ami_stream.h	2012-06-19 09:51:47 UTC (rev 52132)
+++ grass/branches/develbranch_6/include/iostream/ami_stream.h	2012-06-19 10:31:36 UTC (rev 52133)
@@ -140,7 +140,7 @@
   AMI_STREAM();
   // An AMI stream based on a specific path name.
-  AMI_STREAM(const char *path_name, AMI_stream_type st);
+  AMI_STREAM(const char *path_name, AMI_stream_type st = AMI_READ_WRITE_STREAM);
   // convenience function with split path_name
   //AMI_STREAM(const char *dir_name, const char *file_name, AMI_stream_type st);
@@ -156,7 +156,7 @@
   // Read and write elements.
   AMI_err read_item(T **elt);
   AMI_err write_item(const T &elt);
-  AMI_err read_array(T *data, off_t len, off_t *lenp);
+  AMI_err read_array(T *data, off_t len, off_t *lenp=NULL);
   AMI_err write_array(const T *data, off_t len);
   // Return the number of items in the stream.
@@ -171,8 +171,7 @@
   // Query memory usage
   static AMI_err main_memory_usage(size_t *usage,
-			    //MM_stream_usage usage_type= MM_STREAM_USAGE_OVERHEAD);
-			    MM_stream_usage usage_type);
+			    MM_stream_usage usage_type= MM_STREAM_USAGE_OVERHEAD);
   void persist(persistence p);
@@ -248,8 +247,7 @@
 template<class T>
-AMI_STREAM<T>::AMI_STREAM(const char *path_name,
-			  AMI_stream_type st = AMI_READ_WRITE_STREAM) {
+AMI_STREAM<T>::AMI_STREAM(const char *path_name, AMI_stream_type st) {
   access_mode = st;
@@ -466,8 +464,7 @@
 template<class T>
 AMI_err
-AMI_STREAM<T>::main_memory_usage(size_t *usage,
-								 MM_stream_usage usage_type= MM_STREAM_USAGE_OVERHEAD) {
+AMI_STREAM<T>::main_memory_usage(size_t *usage, MM_stream_usage usage_type) {
    switch (usage_type) {
    case MM_STREAM_USAGE_OVERHEAD:
@@ -546,7 +543,7 @@
 template<class T>
-AMI_err AMI_STREAM<T>::read_array(T *data, off_t len, off_t *lenp=NULL) {
+AMI_err AMI_STREAM<T>::read_array(T *data, off_t len, off_t *lenp) {
   size_t nobj;
   assert(fp);
