[GRASS-SVN] r52136 - grass/trunk/vector/v.net.distance
svn_grass at osgeo.org
Tue Jun 19 08:41:24 PDT 2012
Author: mmetz
Date: 2012-06-19 08:41:24 -0700 (Tue, 19 Jun 2012)
New Revision: 52136
grass/trunk/vector/v.net.distance/main.c
v.net.distance: add safety check, warning
Modified: grass/trunk/vector/v.net.distance/main.c
--- grass/trunk/vector/v.net.distance/main.c 2012-06-19 15:40:18 UTC (rev 52135)
+++ grass/trunk/vector/v.net.distance/main.c 2012-06-19 15:41:24 UTC (rev 52136)
@@ -46,6 +46,7 @@
struct ilist *nodest;
int i, nnodes, nlines;
int *dst, *nodes_to_features;
+ int from_nr; /* 'from' features not reachable */
dglInt32_t **prev;
struct line_cats **on_path;
char buf[2000];
@@ -212,11 +213,19 @@
flayer = atoi(fieldf_opt->answer);
tlayer = atoi(fieldt_opt->answer);
- NetA_initialise_varray(&In, flayer, GV_POINT, wheref_opt->answer,
- catf_opt->answer, &varrayf);
+ if (NetA_initialise_varray(&In, flayer, GV_POINT, wheref_opt->answer,
+ catf_opt->answer, &varrayf) <= 0) {
+ G_fatal_error(_("No 'from' features selected. "
+ "Please check options '%s', '%s', '%s'"),
+ fieldf_opt->key, wheref_opt->key, catf_opt->key);
- NetA_initialise_varray(&In, tlayer, ttype, wheret_opt->answer,
- catt_opt->answer, &varrayt);
+ if (NetA_initialise_varray(&In, tlayer, ttype, wheret_opt->answer,
+ catt_opt->answer, &varrayt) <= 0) {
+ G_fatal_error(_("No 'to' features selected. "
+ fieldt_opt->key, wheret_opt->key, catt_opt->key);
nodest = Vect_new_list();
NetA_varray_to_nodes(&In, varrayt, nodest, nodes_to_features);
@@ -262,6 +271,7 @@
Vect_hist_copy(&In, &Out);
Vect_hist_command(&Out);
+ from_nr = 0;
for (i = 1; i <= nlines; i++) {
if (varrayf->c[i]) {
int type = Vect_read_line(&In, Points, Cats, i);
@@ -280,8 +290,11 @@
if (node < 1)
continue;
- if (dst[node] < 0)
- continue; /* unreachable */
+ if (dst[node] < 0) {
+ /* unreachable */
+ from_nr++;
+ continue;
cost = dst[node] / (double)In.cost_multip;
vertex = dglGetNode(graph, node);
vertex_id = node;
@@ -333,5 +346,8 @@
G_free(dst);
G_free(prev);
+ if (from_nr)
+ G_warning(_("%d 'from' features were not reachable"), from_nr);
exit(EXIT_SUCCESS);
