[GRASS-SVN] r52142 - grass/branches/releasebranch_6_4/locale/po
Tue Jun 19 15:28:16 PDT 2012
Author: lucadelu
Date: 2012-06-19 15:28:16 -0700 (Tue, 19 Jun 2012)
New Revision: 52142
Added:
   grass/branches/releasebranch_6_4/locale/po/grasslibs_nl.po
   grass/branches/releasebranch_6_4/locale/po/grassmods_nl.po
   grass/branches/releasebranch_6_4/locale/po/grassnviz_nl.po
   grass/branches/releasebranch_6_4/locale/po/grasstcl_nl.po
   grass/branches/releasebranch_6_4/locale/po/grasswxpy_nl.po
add dutch translation files
Added: grass/branches/releasebranch_6_4/locale/po/grasslibs_nl.po
--- grass/branches/releasebranch_6_4/locale/po/grasslibs_nl.po	                        (rev 0)
+++ grass/branches/releasebranch_6_4/locale/po/grasslibs_nl.po	2012-06-19 22:28:16 UTC (rev 52142)
@@ -0,0 +1,4708 @@
+# SOME DESCRIPTIVE TITLE.
+# Copyright (C) YEAR THE PACKAGE'S COPYRIGHT HOLDER
+# This file is distributed under the same license as the PACKAGE package.
+# FIRST AUTHOR <EMAIL at ADDRESS>, YEAR.
+#, fuzzy
+msgid ""
+msgstr ""
+"Project-Id-Version: PACKAGE VERSION\n"
+"Report-Msgid-Bugs-To: \n"
+"POT-Creation-Date: 2012-06-19 23:46+0200\n"
+"PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
+"Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
+"Language-Team: LANGUAGE <LL at li.org>\n"
+"Language: \n"
+"MIME-Version: 1.0\n"
+"Content-Type: text/plain; charset=CHARSET\n"
+"Content-Transfer-Encoding: 8bit\n"
+#: ../lib/db/dbmi_client/column.c:115
+#, c-format
+msgid "Unable to describe table <%s>"
+msgstr ""
+#: ../lib/db/dbmi_client/table.c:46
+#, c-format
+msgid "Unable open database <%s> by driver <%s>"
+msgstr ""
+#: ../lib/db/dbmi_client/table.c:110 ../lib/db/dbmi_client/copy_tab.c:199
+#: ../lib/db/dbmi_client/copy_tab.c:276 ../lib/sites/sites.c:381
+#, c-format
+msgid "Unable to open select cursor: '%s'"
+msgstr ""
+#: ../lib/db/dbmi_client/copy_tab.c:100 ../lib/db/dbmi_client/copy_tab.c:120
+#: ../lib/db/dbmi_client/db.c:41
+#, c-format
+msgid "Unable to start driver <%s>"
+msgstr ""
+#: ../lib/db/dbmi_client/copy_tab.c:105 ../lib/db/dbmi_client/copy_tab.c:126
+#: ../lib/db/dbmi_client/db.c:46 ../lib/db/dbmi_client/delete_tab.c:49
+#: ../lib/sites/sites.c:372 ../lib/rst/interp_float/vinput2d.c:88
+#: ../lib/vector/neta/timetables.c:133 ../lib/vector/neta/utils.c:116
+#: ../lib/vector/Vlib/net.c:185 ../lib/vector/Vlib/net.c:355
+#: ../lib/vector/Vlib/array.c:284 ../lib/vector/Vlib/map.c:271
+#: ../lib/vector/Vlib/map.c:405 ../lib/vector/Vlib/map.c:621
+#, c-format
+msgid "Unable to open database <%s> by driver <%s>"
+msgstr ""
+#: ../lib/db/dbmi_client/copy_tab.c:144
+#, c-format
+msgid "Unable to get list tables in database <%s>"
+msgstr ""
+#: ../lib/db/dbmi_client/copy_tab.c:157
+#, c-format
+msgid "Table <%s> already exists in database <%s>"
+msgstr ""
+#: ../lib/db/dbmi_client/copy_tab.c:231
+#, c-format
+msgid "Column <%s> is not integer"
+msgstr ""
+#: ../lib/db/dbmi_client/copy_tab.c:248 ../lib/rst/interp_float/vinput2d.c:94
+#: ../lib/rst/interp_float/vinput2d.c:108
+#, c-format
+msgid "Column <%s> not found"
+msgstr ""
+#: ../lib/db/dbmi_client/copy_tab.c:251
+#, c-format
+msgid "Unable to create table <%s>"
+msgstr ""
+#: ../lib/db/dbmi_client/copy_tab.c:295
+#, c-format
+msgid "Unable to fetch data from table <%s>"
+msgstr ""
+#: ../lib/db/dbmi_client/copy_tab.c:351
+#, c-format
+msgid "Unknown column type (column <%s>)"
+msgstr ""
+#: ../lib/db/dbmi_client/delete_tab.c:44
+#, c-format
+msgid "Unable to open driver <%s>"
+msgstr ""
+#: ../lib/db/dbmi_client/delete_tab.c:62
+#, c-format
+msgid "Unable to drop table: '%s'"
+msgstr ""
+#: ../lib/db/dbmi_client/select.c:119 ../lib/db/dbmi_client/select.c:217
+#: ../lib/db/dbmi_client/select.c:283
+msgid "Missing column name"
+msgstr ""
+#: ../lib/db/dbmi_client/select.c:212 ../lib/db/dbmi_client/select.c:278
+msgid "Missing key column name"
+msgstr ""
+#: ../lib/db/dbmi_client/select.c:305
+#, c-format
+msgid "Unable select records from table <%s>"
+msgstr ""
+#: ../lib/db/dbmi_base/default_name.c:127
+msgid "Programmer error"
+msgstr ""
+#: ../lib/db/dbmi_base/login.c:98
+msgid "Login file corrupted"
+msgstr ""
+#: ../lib/db/dbmi_base/legal_dbname.c:25
+#, c-format
+msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'.\n"
+msgstr ""
+#: ../lib/db/dbmi_base/legal_dbname.c:33
+#, c-format
+msgid "Illegal table map name <%s>. Must start with a letter.\n"
+msgstr ""
+#: ../lib/db/dbmi_base/legal_dbname.c:43
+#, c-format
+msgid "Illegal table map name <%s>. Character <%c> not allowed.\n"
+msgstr ""
+#: ../lib/cairodriver/Draw_bitmap.c:47
+msgid "Cairo_draw_bitmap: Failed to create source"
+msgstr ""
+#: ../lib/ogsf/gsdrape.c:207
+msgid "Unable to process vector map - out of memory"
+msgstr ""
+#: ../lib/ogsf/gsd_prim.c:146
+#, c-format
+msgid "Color Material: %d"
+msgstr ""
+#: ../lib/ogsf/gsd_prim.c:630
+#, c-format
+msgid ""
+"gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please "
+"advise GRASS developers of this error"
+msgstr ""
+#: ../lib/ogsf/gsd_img_mpeg.c:63
+msgid "Unable to allocate stream"
+msgstr ""
+#: ../lib/ogsf/gsd_img_mpeg.c:156
+msgid "Video codec not found"
+msgstr ""
+#: ../lib/ogsf/gsd_img_mpeg.c:162
+msgid "Unable to open codec"
+msgstr ""
+#: ../lib/ogsf/gsd_img_mpeg.c:181
+msgid "Unable to allocate picture"
+msgstr ""
+#: ../lib/ogsf/gsd_img_mpeg.c:192
+msgid "Unable to allocate temporary picture"
+msgstr ""
+#: ../lib/ogsf/gsd_img_mpeg.c:252
+msgid "Error while writing video frame"
+msgstr ""
+#: ../lib/ogsf/gsd_img_mpeg.c:298
+#, c-format
+msgid "Opening MPEG stream <%s>..."
+msgstr ""
+#: ../lib/ogsf/gsd_img_mpeg.c:306
+msgid "Unable to deduce output format from file extension: using MPEG"
+msgstr ""
+#: ../lib/ogsf/gsd_img_mpeg.c:310
+msgid "Unable to find suitable output format"
+msgstr ""
+#: ../lib/ogsf/gsd_img_mpeg.c:317 ../lib/rst/interp_float/segmen2d.c:175
+#: ../lib/rst/interp_float/segmen2d.c:181
+#: ../lib/rst/interp_float/segmen2d.c:187
+#: ../lib/rst/interp_float/segmen2d.c:197
+#: ../lib/rst/interp_float/interp2d.c:119
+#: ../lib/rst/interp_float/interp2d.c:125 ../lib/vector/neta/timetables.c:69
+#: ../lib/vector/neta/timetables.c:168 ../lib/vector/neta/timetables.c:178
+#: ../lib/vector/neta/timetables.c:191 ../lib/vector/neta/timetables.c:278
+#: ../lib/vector/neta/timetables.c:413 ../lib/vector/neta/timetables.c:425
+#: ../lib/vector/neta/centrality.c:63 ../lib/vector/neta/centrality.c:145
+#: ../lib/vector/neta/spanningtree.c:99
+#: ../lib/vector/neta/articulation_point.c:60 ../lib/vector/neta/path.c:134
+#: ../lib/vector/neta/bridge.c:59 ../lib/vector/neta/components.c:46
+#: ../lib/vector/neta/components.c:113 ../lib/vector/neta/allpairs.c:50
+#: ../lib/vector/neta/flow.c:64 ../lib/vector/neta/flow.c:178
+#: ../lib/vector/Vlib/line.c:60
+msgid "Out of memory"
+msgstr ""
+#: ../lib/ogsf/gsd_img_mpeg.c:337
+msgid "Invalid output format parameters"
+msgstr ""
+#: ../lib/ogsf/gsd_img_mpeg.c:351
+#, c-format
+msgid "Unable to open <%s>"
+msgstr ""
+#: ../lib/ogsf/gsd_img_mpeg.c:361
+msgid "NVIZ has not been built with MPEG output support"
+msgstr ""
+#: ../lib/ogsf/gsd_img_ppm.c:53 ../lib/ogsf/gsd_img_ppm.c:96
+#: ../lib/ogsf/GK2.c:219 ../lib/ogsf/gsd_img_tif.c:64
+#, c-format
+msgid "Unable to open file <%s> for writing"
+msgstr ""
+#: ../lib/ogsf/trans.c:180
+msgid "Out of matrix stack space"
+msgstr ""
+#: ../lib/ogsf/trans.c:200
+msgid "Tried to pop an empty stack"
+msgstr ""
+#: ../lib/ogsf/gsd_surf.c:1742
+msgid "Cut-plane points mis-match between surfaces. Check resolution(s)."
+msgstr ""
+#: ../lib/ogsf/gsd_label.c:58
+msgid "Max. number of labels reached!"
+msgstr ""
+#: ../lib/ogsf/Gp3.c:54 ../lib/ogsf/gsd_legend.c:238 ../lib/ogsf/Gs3.c:126
+#: ../lib/ogsf/Gs3.c:201 ../lib/ogsf/Gs3.c:286 ../lib/ogsf/Gs3.c:359
+#: ../lib/ogsf/Gs3.c:475 ../lib/ogsf/Gs3.c:572 ../lib/ogsf/Gs3.c:639
+#: ../lib/ogsf/Gs3.c:696 ../lib/ogsf/Gs3.c:767 ../lib/ogsf/Gs3.c:837
+#: ../lib/gpde/N_arrays_io.c:56 ../lib/gis/opencell.c:1011
+#: ../lib/gis/legal_name.c:94 ../lib/gis/legal_name.c:97
+#, c-format
+msgid "Raster map <%s> not found"
+msgstr ""
+#: ../lib/ogsf/Gp3.c:109 ../lib/ogsf/Gv3.c:57
+#: ../lib/vector/Vlib/legal_vname.c:118 ../lib/vector/Vlib/legal_vname.c:121
+#: ../lib/vector/Vlib/map.c:327 ../lib/vector/Vlib/open.c:168
+#, c-format
+msgid "Vector map <%s> not found"
+msgstr ""
+#: ../lib/ogsf/Gp3.c:115 ../lib/ogsf/Gv3.c:63 ../lib/vector/Vlib/open.c:199
+#, c-format
+msgid "Unable to open vector map <%s>"
+msgstr ""
+#: ../lib/ogsf/Gp3.c:145 ../lib/vector/Vlib/map.c:68
+#: ../lib/vector/Vlib/map.c:84
+#, c-format
+msgid "Unable to read vector map <%s>"
+msgstr ""
+#: ../lib/ogsf/Gp3.c:206
+#, c-format
+msgid "No points from vector map <%s> fall within current region"
+msgstr ""
+#: ../lib/ogsf/Gp3.c:211
+#, c-format
+msgid "Vector map <%s> loaded (%d points)"
+msgstr ""
+#: ../lib/ogsf/gsd_legend.c:245
+#, c-format
+msgid "Unable to read color file of raster map <%s>"
+msgstr ""
+#: ../lib/ogsf/gsd_legend.c:251
+#, c-format
+msgid "Unable to read category file of raster map <%s>"
+msgstr ""
+#: ../lib/ogsf/gsd_legend.c:268
+#, c-format
+msgid "Unable to read fp range of raster map <%s>"
+msgstr ""
+#: ../lib/ogsf/gsd_legend.c:280
+#, c-format
+msgid "Unable to read range of raster map <%s>"
+msgstr ""
+#: ../lib/ogsf/gsd_legend.c:294
+msgid "Range request error for legend"
+msgstr ""
+#: ../lib/ogsf/gsd_legend.c:384
+msgid "Unable to show discrete FP range (use list"
+msgstr ""
+#: ../lib/ogsf/gsd_legend.c:500
+msgid "Too many categories to show as discrete!"
+msgstr ""
+#: ../lib/ogsf/gsd_legend.c:502
+msgid "Try using smaller font!"
+msgstr ""
+#: ../lib/ogsf/Gv3.c:249
+#, c-format
+msgid "No features from vector map <%s> fall within current region"
+msgstr ""
+#: ../lib/ogsf/Gv3.c:254
+#, c-format
+msgid "Vector map <%s> loaded (%d features)"
+msgstr ""
+#: ../lib/ogsf/gsds.c:109
+msgid "Maximum number of datasets exceeded"
+msgstr ""
+#: ../lib/ogsf/gk.c:322
+msgid "Need at least 3 keyframes for spline"
+msgstr ""
+#: ../lib/ogsf/gk.c:624
+msgid "Need at least 2 keyframes for interpolation"
+msgstr ""
+#: ../lib/ogsf/GK2.c:275 ../lib/ogsf/GK2.c:288
+msgid "Check no. of frames requested and keyframes marked"
+msgstr ""
+#: ../lib/ogsf/gvl_file.c:104
+msgid "Maximum number of datafiles exceeded"
+msgstr ""
+#: ../lib/ogsf/gvl_file.c:428 ../lib/ogsf/Gvl3.c:39
+#: ../lib/gpde/N_arrays_io.c:296
+#, c-format
+msgid "3D raster map <%s> not found"
+msgstr ""
+#: ../lib/ogsf/gvl_file.c:437 ../lib/gpde/N_arrays_io.c:304
+#, c-format
+msgid "Unable to open 3D raster map <%s>"
+msgstr ""
+#: ../lib/ogsf/gvl_file.c:443
+#, c-format
+msgid "Unable to read range of 3D raster map <%s>"
+msgstr ""
+#: ../lib/ogsf/gvl_file.c:471
+#, c-format
+msgid "Unable to close 3D raster map <%s>"
+msgstr ""
+#: ../lib/ogsf/GVL2.c:248
+#, c-format
+msgid "Loading 3d raster map <%s>..."
+msgstr ""
+#: ../lib/ogsf/gs_bm.c:124
+msgid "Bitmap mismatch"
+msgstr ""
+#: ../lib/ogsf/Gs3.c:133 ../lib/ogsf/Gs3.c:208 ../lib/ogsf/Gs3.c:366
+#: ../lib/ogsf/Gs3.c:482 ../lib/ogsf/Gs3.c:587
+msgid "Unable to allocate memory for a null buffer"
+msgstr ""
+#: ../lib/ogsf/Gs3.c:137 ../lib/ogsf/Gs3.c:212 ../lib/ogsf/Gs3.c:370
+#: ../lib/ogsf/Gs3.c:486 ../lib/ogsf/Gs3.c:577 ../lib/gpde/N_arrays_io.c:68
+#, c-format
+msgid "Unable to open raster map <%s>"
+msgstr ""
+#: ../lib/ogsf/Gs3.c:140 ../lib/ogsf/Gs3.c:215 ../lib/ogsf/Gs3.c:378
+#: ../lib/ogsf/Gs3.c:494 ../lib/ogsf/Gs3.c:590
+#, c-format
+msgid "Loading raster map <%s>..."
+msgstr ""
+#: ../lib/ogsf/Gs3.c:647
+#, c-format
+msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
+msgstr ""
+#: ../lib/ogsf/Gs3.c:709 ../lib/ogsf/Gs3.c:781
+#, c-format
+msgid "Translating colors from raster map <%s>..."
+msgstr ""
+#: ../lib/ogsf/Gs3.c:1020
+msgid "View not saved by this program,there may be some inconsistancies"
+msgstr ""
+#: ../lib/ogsf/GS2.c:1207
+#, c-format
+msgid "no category info"
+msgstr ""
+#: ../lib/ogsf/GS2.c:1226
+#, c-format
+msgid "no data"
+msgstr ""
+#: ../lib/ogsf/GS2.c:1651
+#, c-format
+msgid "Raster map <%s> is outside of current region. Load failed."
+msgstr ""
+#: ../lib/ogsf/GS2.c:1729 ../lib/ogsf/GS2.c:1735 ../lib/ogsf/GS2.c:1743
+#: ../lib/ogsf/GS2.c:1752 ../lib/ogsf/GS2.c:1760 ../lib/ogsf/GS2.c:1770
+#: ../lib/ogsf/GS2.c:1818
+msgid "GS_load_att_map(): Out of memory. Unable to load map"
+msgstr ""
+#: ../lib/ogsf/GS2.c:1846
+msgid "Loading failed"
+msgstr ""
+#: ../lib/ogsf/GS2.c:1850
+msgid "Error finding range"
+msgstr ""
+#: ../lib/gmath/del2g.c:50
+msgid "    taking FFT of image..."
+msgstr ""
+#: ../lib/gmath/del2g.c:56
+msgid "    computing del**2 g..."
+msgstr ""
+#: ../lib/gmath/del2g.c:59
+msgid "    taking FFT of del**2 g..."
+msgstr ""
+#: ../lib/gmath/del2g.c:63
+msgid "    multiplying transforms..."
+msgstr ""
+#: ../lib/gmath/del2g.c:66
+msgid "    taking inverse FFT..."
+msgstr ""
+#: ../lib/gmath/la.c:64 ../lib/gmath/la.c:120
+msgid "Matrix dimensions out of range"
+msgstr ""
+#: ../lib/gmath/la.c:153
+msgid "Matrix is not initialised fully."
+msgstr ""
+#: ../lib/gmath/la.c:158
+msgid "Unable to allocate space for matrix copy"
+msgstr ""
+#: ../lib/gmath/la.c:247
+msgid "First scalar multiplier must be non-zero"
+msgstr ""
+#: ../lib/gmath/la.c:253 ../lib/gmath/la.c:261 ../lib/gmath/la.c:326
+msgid "One or both input matrices uninitialised"
+msgstr ""
+#: ../lib/gmath/la.c:266 ../lib/gmath/la.c:331
+msgid "Matrix order does not match"
+msgstr ""
+#: ../lib/gmath/la.c:272
+msgid "Unable to allocate space for matrix sum"
+msgstr ""
+#: ../lib/gmath/la.c:336
+msgid "Unable to allocate space for matrix product"
+msgstr ""
+#: ../lib/gmath/la.c:448
+msgid "Input: one or both data matrices uninitialised"
+msgstr ""
+#: ../lib/gmath/la.c:453
+msgid "Principal matrix is not properly dimensioned"
+msgstr ""
+#: ../lib/gmath/la.c:458
+msgid "Input: you must have at least one array to solve"
+msgstr ""
+#: ../lib/gmath/la.c:464
+msgid "Could not allocate space for solution matrix"
+msgstr ""
+#: ../lib/gmath/la.c:470 ../lib/gmath/la.c:478
+msgid "Could not allocate space for working matrix"
+msgstr ""
+#: ../lib/gmath/la.c:531
+msgid "Matrix (or submatrix is singular). Solution undetermined"
+msgstr ""
+#: ../lib/gmath/la.c:535
+msgid "Problem in LA routine."
+msgstr ""
+#: ../lib/gmath/la.c:542
+msgid "Procedure not yet available for selected matrix type"
+msgstr ""
+#: ../lib/gmath/la.c:576
+msgid "Matrix is not square. Cannot determine inverse"
+msgstr ""
+#: ../lib/gmath/la.c:581
+msgid "Unable to allocate space for matrix"
+msgstr ""
+#: ../lib/gmath/la.c:598
+msgid "Matrix is singular"
+msgstr ""
+#: ../lib/gmath/la.c:603
+msgid "Problem in LA procedure."
+msgstr ""
+#: ../lib/gmath/la.c:691
+msgid "Element array has not been allocated"
+msgstr ""
+#: ../lib/gmath/la.c:696
+msgid "Specified element is outside array bounds"
+msgstr ""
+#: ../lib/gmath/la.c:750
+msgid "Specified matrix column index is outside range"
+msgstr ""
+#: ../lib/gmath/la.c:755 ../lib/gmath/la.c:796 ../lib/gmath/la.c:1109
+#: ../lib/gmath/la.c:1161 ../lib/gmath/la.c:1236
+msgid "Matrix is not initialised"
+msgstr ""
+#: ../lib/gmath/la.c:760 ../lib/gmath/la.c:801
+msgid "Could not allocate space for vector structure"
+msgstr ""
+#: ../lib/gmath/la.c:791
+msgid "Specified matrix row index is outside range"
+msgstr ""
+#: ../lib/gmath/la.c:831
+msgid "Specified row index is outside range"
+msgstr ""
+#: ../lib/gmath/la.c:836
+msgid "Specified column index is outside range"
+msgstr ""
+#: ../lib/gmath/la.c:856
+msgid "Unknown vector type."
+msgstr ""
+#: ../lib/gmath/la.c:981
+msgid "Output vector is uninitialized"
+msgstr ""
+#: ../lib/gmath/la.c:986
+msgid "Vectors are not of the same type"
+msgstr ""
+#: ../lib/gmath/la.c:991
+msgid "Output vector is of incorrect type"
+msgstr ""
+#: ../lib/gmath/la.c:996
+msgid "Matrices not allowed"
+msgstr ""
+#: ../lib/gmath/la.c:1002
+msgid "Vectors have differing dimensions"
+msgstr ""
+#: ../lib/gmath/la.c:1008
+msgid "Output vector has incorrect dimension"
+msgstr ""
+#: ../lib/gmath/la.c:1054
+msgid "Vector dimensions out of range"
+msgstr ""
+#: ../lib/gmath/la.c:1059
+msgid "Row/column out of range"
+msgstr ""
+#: ../lib/gmath/la.c:1274
+msgid "Vector structure is not initialised"
+msgstr ""
+#: ../lib/gmath/la.c:1395 ../lib/gmath/la.c:1403 ../lib/gmath/la.c:1408
+msgid "Input format error"
+msgstr ""
+#: ../lib/nviz/nviz.c:126
+#, c-format
+msgid "Invalid color (%s), using \"white\" as default"
+msgstr ""
+#: ../lib/nviz/map_obj.c:59
+msgid "Maximum surfaces loaded!"
+msgstr ""
+#: ../lib/nviz/map_obj.c:88
+msgid "Maximum vector line maps loaded!"
+msgstr ""
+#: ../lib/nviz/map_obj.c:97 ../lib/nviz/map_obj.c:128
+#, c-format
+msgid "Error loading vector map <%s>"
+msgstr ""
+#: ../lib/nviz/map_obj.c:116
+msgid "Maximum vector point maps loaded!"
+msgstr ""
+#: ../lib/nviz/map_obj.c:143
+msgid "Maximum volumes loaded!"
+msgstr ""
+#: ../lib/nviz/map_obj.c:152
+#, c-format
+msgid "Error loading 3d raster map <%s>"
+msgstr ""
+#: ../lib/nviz/map_obj.c:160
+msgid "Nviz_new_map_obj(): unsupported data type"
+msgstr ""
+#: ../lib/nviz/position.c:56
+msgid "Unable to set focus"
+msgstr ""
+#: ../lib/nviz/render.c:104
+msgid "Bad server connection"
+msgstr ""
+#: ../lib/nviz/render.c:113
+msgid "Unable to create rendering context"
+msgstr ""
+#: ../lib/nviz/lights.c:171
+msgid "Unable to define new light"
+msgstr ""
+#: ../lib/gpde/N_solvers.c:50
+msgid "The gauss elimination solver does not work with sparse matrices"
+msgstr ""
+#: ../lib/gpde/N_solvers.c:55 ../lib/gpde/N_solvers.c:93
+#: ../lib/gpde/N_solvers.c:160 ../lib/gpde/N_solvers_classic_iter.c:57
+#: ../lib/gpde/N_solvers_classic_iter.c:94 ../lib/gpde/N_solvers_krylov.c:78
+#: ../lib/gpde/N_solvers_krylov.c:255 ../lib/gpde/N_solvers_krylov.c:423
+#: ../lib/gpde/N_solvers_krylov.c:832
+msgid "The linear equation system is not quadratic"
+msgstr ""
+#: ../lib/gpde/N_solvers.c:60
+msgid "Starting direct gauss elimination solver"
+msgstr ""
+#: ../lib/gpde/N_solvers.c:88
+msgid "The lu solver does not work with sparse matrices"
+msgstr ""
+#: ../lib/gpde/N_solvers.c:98
+msgid "Starting direct lu decomposition solver"
+msgstr ""
+#: ../lib/gpde/N_solvers.c:155
+msgid "The cholesky solver does not work with sparse matrices"
+msgstr ""
+#: ../lib/gpde/N_solvers.c:166 ../lib/gpde/N_solvers_krylov.c:84
+#: ../lib/gpde/N_solvers_krylov.c:261
+msgid "Matrix is not symmetric!"
+msgstr ""
+#: ../lib/gpde/N_solvers.c:170
+msgid "Starting cholesky decomposition solver"
+msgstr ""
+#: ../lib/gpde/N_solvers.c:173 ../lib/gpde/N_solvers_krylov.c:190
+#: ../lib/gpde/N_solvers_krylov.c:357 ../lib/gpde/N_solvers_krylov.c:481
+msgid "Unable to solve the linear equation system"
+msgstr ""
+#: ../lib/gpde/N_parse_options.c:59
+msgid ""
+"The type of solver which should solve the symmetric linear equation system"
+msgstr ""
+#: ../lib/gpde/N_parse_options.c:71
+msgid "The type of solver which should solve the linear equation system"
+msgstr ""
+#: ../lib/gpde/N_parse_options.c:80
+msgid "Maximum number of iteration used to solver the linear equation system"
+msgstr ""
+#: ../lib/gpde/N_parse_options.c:89
+msgid ""
+"Error break criteria for iterative solvers (jacobi, sor, cg or bicgstab)"
+msgstr ""
+#: ../lib/gpde/N_parse_options.c:98
+msgid ""
+"The relaxation parameter used by the jacobi and sor solver for speedup or "
+"stabilizing"
+msgstr ""
+#: ../lib/gpde/N_parse_options.c:106
+msgid "The calculation time in seconds"
+msgstr ""
+#: ../lib/gpde/N_solvers_classic_iter.c:152
+#, c-format
+msgid "sparse Jacobi -- iteration %5i error %g\n"
+msgstr ""
+#: ../lib/gpde/N_solvers_classic_iter.c:154
+#, c-format
+msgid "sparse SOR -- iteration %5i error %g\n"
+msgstr ""
+#: ../lib/gpde/N_solvers_classic_iter.c:197
+#, c-format
+msgid "Jacobi -- iteration %5i error %g\n"
+msgstr ""
+#: ../lib/gpde/N_solvers_classic_iter.c:235
+#, c-format
+msgid "SOR -- iteration %5i error %g\n"
+msgstr ""
+#: ../lib/gpde/N_solvers_krylov.c:198
+#, c-format
+msgid "Sparse PCG -- iteration %i error  %g\n"
+msgstr ""
+#: ../lib/gpde/N_solvers_krylov.c:200
+#, c-format
+msgid "PCG -- iteration %i error  %g\n"
+msgstr ""
+#: ../lib/gpde/N_solvers_krylov.c:365
+#, c-format
+msgid "Sparse CG -- iteration %i error  %g\n"
+msgstr ""
+#: ../lib/gpde/N_solvers_krylov.c:367
+#, c-format
+msgid "CG -- iteration %i error  %g\n"
+msgstr ""
+#: ../lib/gpde/N_solvers_krylov.c:530
+#, c-format
+msgid "Sparse BiCGStab -- iteration %i error  %g\n"
+msgstr ""
+#: ../lib/gpde/N_solvers_krylov.c:533
+#, c-format
+msgid "BiCGStab -- iteration %i error  %g\n"
+msgstr ""
+#: ../lib/gpde/test/test_heat.c:33
+msgid ""
+"\n"
+"++ Running heat flow integration tests ++"
+msgstr ""
+#: ../lib/gpde/test/test_heat.c:35
+msgid "\t 1. testing 2d heat flow"
+msgstr ""
+#: ../lib/gpde/test/test_heat.c:37
+msgid "\t 2. testing 3d heat flow"
+msgstr ""
+#: ../lib/gpde/test/test_heat.c:40
+msgid ""
+"\n"
+"-- heat flow integration tests failure --"
+msgstr ""
+#: ../lib/gpde/test/test_heat.c:42
+msgid ""
+"\n"
+"-- heat flow integration tests finished successfully --"
+msgstr ""
+#: ../lib/gpde/test/test_geom.c:36
+msgid ""
+"\n"
+"++ Running geom_data unit tests ++"
+msgstr ""
+#: ../lib/gpde/test/test_geom.c:41
+msgid ""
+"\n"
+"-- geom_data unit tests failure --"
+msgstr ""
+#: ../lib/gpde/test/test_geom.c:43
+msgid ""
+"\n"
+"-- geom_data unit tests finished successfully --"
+msgstr ""
+#: ../lib/gpde/test/test_les.c:34
+msgid ""
+"\n"
+"++ Running les creation unit tests ++"
+msgstr ""
+#: ../lib/gpde/test/test_les.c:39
+msgid ""
+"\n"
+"-- les creation unit tests failure --"
+msgstr ""
+#: ../lib/gpde/test/test_les.c:41
+msgid ""
+"\n"
+"-- les creation unit tests finished successfully --"
+msgstr ""
+#: ../lib/gpde/test/test_les.c:95
+msgid "\t * testing les creation in parallel\n"
+msgstr ""
+#: ../lib/gpde/test/test_les.c:126
+msgid "\t * testing les creation in serial\n"
+msgstr ""
+#: ../lib/gpde/test/test_assemble.c:42
+msgid ""
+"\n"
+"++ Running assembling unit tests ++"
+msgstr ""
+#: ../lib/gpde/test/test_assemble.c:44
+msgid "\t 1. testing 2d assembling"
+msgstr ""
+#: ../lib/gpde/test/test_assemble.c:47
+msgid "\t 2. testing 3d assembling"
+msgstr ""
+#: ../lib/gpde/test/test_assemble.c:51
+msgid ""
+"\n"
+"-- Assembling unit tests failure --"
+msgstr ""
+#: ../lib/gpde/test/test_assemble.c:53
+msgid ""
+"\n"
+"-- Assembling unit tests finished successfully --"
+msgstr ""
+#: ../lib/gpde/test/test_gradient.c:42
+msgid ""
+"\n"
+"++ Running gradient unit tests ++"
+msgstr ""
+#: ../lib/gpde/test/test_gradient.c:44
+msgid "\t 1. testing 2d gradient"
+msgstr ""
+#: ../lib/gpde/test/test_gradient.c:47
+msgid "\t 2. testing 3d gradient"
+msgstr ""
+#: ../lib/gpde/test/test_gradient.c:51
+msgid ""
+"\n"
+"-- Gradient unit tests failure --"
+msgstr ""
+#: ../lib/gpde/test/test_gradient.c:53
+msgid ""
+"\n"
+"-- Gradient unit tests finished successfully --"
+msgstr ""
+#: ../lib/gpde/test/test_main.c:49
+msgid "Choose the unit tests to run"
+msgstr ""
+#: ../lib/gpde/test/test_main.c:56
+msgid "Choose the integration tests to run"
+msgstr ""
+#: ../lib/gpde/test/test_main.c:61
+msgid "Run all unit tests"
+msgstr ""
+#: ../lib/gpde/test/test_main.c:65
+msgid "Run all integration tests"
+msgstr ""
+#: ../lib/gpde/test/test_main.c:69
+msgid "Run all unit and integration tests"
+msgstr ""
+#: ../lib/gpde/test/test_main.c:85
+msgid "test, gpde"
+msgstr ""
+#: ../lib/gpde/test/test_main.c:87
+msgid "Performs unit and integration tests for gpde library"
+msgstr ""
+#: ../lib/gpde/test/test_solvers.c:37
+msgid ""
+"\n"
+"++ Running solver unit tests ++"
+msgstr ""
+#: ../lib/gpde/test/test_solvers.c:42
+msgid ""
+"\n"
+"-- Solver unit tests failure --"
+msgstr ""
+#: ../lib/gpde/test/test_solvers.c:44
+msgid ""
+"\n"
+"-- Solver unit tests finished successfully --"
+msgstr ""
+#: ../lib/gpde/test/test_tools.c:34
+msgid ""
+"\n"
+"++ Running math tool unit tests ++"
+msgstr ""
+#: ../lib/gpde/test/test_tools.c:39
+msgid ""
+"\n"
+"-- math tool unit tests failure --"
+msgstr ""
+#: ../lib/gpde/test/test_tools.c:41
+msgid ""
+"\n"
+"-- math tool unit tests finished successfully --"
+msgstr ""
+#: ../lib/gpde/test/test_gwflow.c:43
+msgid ""
+"\n"
+"++ Running gwflow integration tests ++"
+msgstr ""
+#: ../lib/gpde/test/test_gwflow.c:45
+msgid "\t 1. testing 2d gwflow"
+msgstr ""
+#: ../lib/gpde/test/test_gwflow.c:48
+msgid "\t 2. testing 3d gwflow"
+msgstr ""
+#: ../lib/gpde/test/test_gwflow.c:52
+msgid ""
+"\n"
+"-- gwflow integration tests failure --"
+msgstr ""
+#: ../lib/gpde/test/test_gwflow.c:54
+msgid ""
+"\n"
+"-- gwflow integration tests finished successfully --"
+msgstr ""
+#: ../lib/gpde/test/test_arrays.c:48
+msgid ""
+"\n"
+"++ Running array unit tests ++"
+msgstr ""
+#: ../lib/gpde/test/test_arrays.c:50
+msgid "\t 1. testing 2d arrays"
+msgstr ""
+#: ../lib/gpde/test/test_arrays.c:53
+msgid "\t 2. testing 3d arrays"
+msgstr ""
+#: ../lib/gpde/test/test_arrays.c:57
+msgid ""
+"\n"
+"-- Array unit tests failure --"
+msgstr ""
+#: ../lib/gpde/test/test_arrays.c:59
+msgid ""
+"\n"
+"-- Array unit tests finished successfully --"
+msgstr ""
+#: ../lib/gpde/test/test_solute_transport.c:43
+msgid ""
+"\n"
+"++ Running solute_transport integration tests ++"
+msgstr ""
+#: ../lib/gpde/test/test_solute_transport.c:45
+msgid "\t 1. testing 2d solute_transport"
+msgstr ""
+#: ../lib/gpde/test/test_solute_transport.c:48
+msgid "\t 2. testing 3d solute_transport"
+msgstr ""
+#: ../lib/gpde/test/test_solute_transport.c:52
+msgid ""
+"\n"
+"-- solute_transport integration tests failure --"
+msgstr ""
+#: ../lib/gpde/test/test_solute_transport.c:54
+msgid ""
+"\n"
+"-- solute_transport integration tests finished successfully --"
+msgstr ""
+#: ../lib/gpde/N_arrays_io.c:97
+#, c-format
+msgid "Reading raster map <%s> into memory"
+msgstr ""
+#: ../lib/gpde/N_arrays_io.c:104
+msgid "Could not get raster row"
+msgstr ""
+#: ../lib/gpde/N_arrays_io.c:162 ../lib/gpde/N_arrays_io.c:244
+msgid "Unable to close input map"
+msgstr ""
+#: ../lib/gpde/N_arrays_io.c:191
+msgid "N_array_2d * array is empty"
+msgstr ""
+#: ../lib/gpde/N_arrays_io.c:203
+#, c-format
+msgid "Unable to create raster map <%s>"
+msgstr ""
+#: ../lib/gpde/N_arrays_io.c:212
+#, c-format
+msgid "Write 2d array to raster map <%s>"
+msgstr ""
+#: ../lib/gpde/N_arrays_io.c:228 ../lib/gpde/N_arrays_io.c:233
+#: ../lib/gpde/N_arrays_io.c:238
+#, c-format
+msgid "Unable to write raster row %i"
+msgstr ""
+#: ../lib/gpde/N_arrays_io.c:332
+#, c-format
+msgid "Read g3d map <%s> into the memory"
+msgstr ""
+#: ../lib/gpde/N_arrays_io.c:387 ../lib/gpde/N_arrays_io.c:487
+msgid "Error closing g3d file"
+msgstr ""
+#: ../lib/gpde/N_arrays_io.c:446
+#, c-format
+msgid "Error opening g3d map <%s>"
+msgstr ""
+#: ../lib/gpde/N_arrays_io.c:448
+#, c-format
+msgid "Write 3d array to g3d map <%s>"
+msgstr ""
+#: ../lib/sites/sites.c:97
+#, c-format
+msgid "Attributes for category %d not found"
+msgstr ""
+#: ../lib/sites/sites.c:136
+msgid "Category must be integer"
+msgstr ""
+#: ../lib/sites/sites.c:210
+msgid "Memory error in writing timestamp"
+msgstr ""
+#: ../lib/sites/sites.c:212
+msgid "Illegal TimeStamp string"
+msgstr ""
+#: ../lib/sites/sites.c:241
+msgid "Memory error in allocating timestamp"
+msgstr ""
+#: ../lib/sites/sites.c:348 ../lib/sites/sites.c:478
+msgid ""
+"Dev note: Adapted sites library used for vector points. (module should be "
+"updated to GRASS 6 vector library)"
+msgstr ""
+#: ../lib/sites/sites.c:397
+msgid "Cannot fetch row"
+msgstr ""
+#: ../lib/sites/sites.c:579
+msgid "G_oldsite_new_struct: invalid # dims or fields"
+msgstr ""
+#: ../lib/sites/sites.c:1249
+#, c-format
+msgid "Cannot open database %s by driver %s"
+msgstr ""
+#: ../lib/sites/sites.c:1257
+msgid "Cannot select attributes"
+msgstr ""
+#: ../lib/rst/interp_float/segmen2d.c:111
+msgid ""
+"Taking too long to find points for interpolation - please change the region "
+"to area where your points are. Continuing calculations..."
+msgstr ""
+#: ../lib/rst/interp_float/output2d.c:125
+#, c-format
+msgid "First change your cols number to nsizc %d %d"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:73
+#, c-format
+msgid "Vector map <%s> is not 3D"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:76
+msgid "Loading data from attribute table ..."
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:79 ../lib/vector/Vlib/net.c:179
+#: ../lib/vector/Vlib/net.c:350 ../lib/vector/Vlib/array.c:278
+#: ../lib/vector/Vlib/map.c:243 ../lib/vector/Vlib/map.c:364
+#: ../lib/vector/Vlib/map.c:470 ../lib/vector/Vlib/map.c:588
+#: ../lib/vector/Vlib/map.c:686
+#, c-format
+msgid "Database connection not defined for layer %d"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:97
+#: ../lib/rst/interp_float/vinput2d.c:110
+#, c-format
+msgid "Data type of column <%s> must be numeric"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:121
+msgid "Reading features from vector map ..."
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:153
+#: ../lib/rst/interp_float/vinput2d.c:270
+#, c-format
+msgid "Database record for cat %d not found"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:171
+#: ../lib/rst/interp_float/vinput2d.c:288
+msgid "Negative value of smoothing detected: sm must be >= 0"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:233
+msgid "Reading nodes from vector map ..."
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:314
+msgid "Strip exists with insufficient data"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:328
+#, c-format
+msgid "There are points outside specified 2D/3D region - %d points ignored"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:331
+#, c-format
+msgid "Ignoring %d points (too dense)"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:335
+#, c-format
+msgid ""
+"%d points given for interpolation (after thinning) is less than given NPMIN="
+"%d"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:340
+msgid "Zero points in the given region"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:345
+#, c-format
+msgid ""
+"Segmentation parameters set to invalid values: npmin= %d, segmax= %d for "
+"smooth connection of segments, npmin > segmax (see manual)"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:351
+#, c-format
+msgid ""
+"There are less than %d points for interpolation. No segmentation is "
+"necessary, to run the program faster set segmax=%d (see manual)"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:355
+#, c-format
+msgid "Number of points from vector map %d"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:356
+#, c-format
+msgid "Number of points outside of 2D/3D region %d"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:358
+#, c-format
+msgid "Number of points being used %d"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:391
+msgid "Some points outside of region (ignored)"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:397
+msgid "Unable to allocate memory"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:405
+#, c-format
+msgid "Unable to insert %f,%f,%f a = %d"
+msgstr ""
+#: ../lib/rst/interp_float/input2d.c:47
+#, c-format
+msgid "Mask raster map <%s> not found"
+msgstr ""
+#: ../lib/rst/interp_float/input2d.c:69
+msgid "Bitmap mask created"
+msgstr ""
+#: ../lib/rst/interp_float/interp2d.c:212
+#, c-format
+msgid ""
+"Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) "
+"cell. Z-value %f, zmin %f, zmax %f."
+msgstr ""
+#: ../lib/imagery/list_subgp.c:36
+#, c-format
+msgid "subgroup <%s> of group <%s> is empty\n"
+msgstr ""
+#: ../lib/imagery/list_subgp.c:48
+#, c-format
+msgid "subgroup <%s> of group <%s> references the following raster maps\n"
+msgstr ""
+#: ../lib/imagery/points.c:124
+#, c-format
+msgid "Unable to open control point file for group [%s in %s]"
+msgstr ""
+#: ../lib/imagery/points.c:132
+#, c-format
+msgid "Bad format in control point file for group [%s in %s]"
+msgstr ""
+#: ../lib/imagery/points.c:159
+#, c-format
+msgid "Unable to create control point file for group [%s in %s]"
+msgstr ""
+#: ../lib/imagery/target.c:38
+#, c-format
+msgid "Unable to read target file for group [%s]"
+msgstr ""
+#: ../lib/imagery/sigsetfile.c:41
+#, c-format
+msgid ""
+"Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> "
+"is not current mapset"
+msgstr ""
+#: ../lib/imagery/sigsetfile.c:57
+#, c-format
+msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s>"
+msgstr ""
+#: ../lib/imagery/sigsetfile.c:86
+#, c-format
+msgid "Unable to open signature file <%s> for subgroup <%s> of group <%s@%s>"
+msgstr ""
+#: ../lib/imagery/fopen.c:23
+#, c-format
+msgid "Unable to create file [%s] of group [%s in %s]"
+msgstr ""
+#: ../lib/imagery/fopen.c:36 ../lib/imagery/fopen.c:57
+#, c-format
+msgid "Unable to open file [%s] of group [%s in %s]"
+msgstr ""
+#: ../lib/imagery/fopen.c:49
+#, c-format
+msgid "Unable to find file [%s] of group [%s in %s]"
+msgstr ""
+#: ../lib/imagery/fopen.c:79
+#, c-format
+msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
+msgstr ""
+#: ../lib/imagery/fopen.c:101 ../lib/imagery/fopen.c:127
+#, c-format
+msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
+msgstr ""
+#: ../lib/imagery/fopen.c:116
+#, c-format
+msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
+msgstr ""
+#: ../lib/imagery/list_gp.c:34
+#, c-format
+msgid "group <%s> is empty\n"
+msgstr ""
+#: ../lib/imagery/list_gp.c:44
+#, c-format
+msgid "group <%s> references the following raster maps\n"
+msgstr ""
+#: ../lib/symbol/read.c:211
+#, c-format
+msgid "Cannot read symbol line coordinates: %s"
+msgstr ""
+#: ../lib/symbol/read.c:259
+#, c-format
+msgid ""
+"Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
+msgstr ""
+#: ../lib/symbol/read.c:283
+#, c-format
+msgid "Cannot find/open symbol: '%s'"
+msgstr ""
+#: ../lib/symbol/read.c:388 ../lib/symbol/read.c:406 ../lib/symbol/read.c:416
+#: ../lib/symbol/read.c:434
+#, c-format
+msgid "Incorrect symbol color: '%s', using default."
+msgstr ""
+#: ../lib/driver/command.c:508
+#, c-format
+msgid "Unknown command: %d last: %d"
+msgstr ""
+#: ../lib/driver/command.c:547
+msgid "Monitor: get_command: Premature EOF"
+msgstr ""
+#: ../lib/driver/parse_ftcap.c:32
+#, c-format
+msgid "%s: Unable to read font definition file; use the default"
+msgstr ""
+#: ../lib/driver/parse_ftcap.c:38
+#, c-format
+msgid "%s: No font definition file"
+msgstr ""
+#: ../lib/driver/main.c:90
+#, c-format
+msgid "Graphics driver [%s] started"
+msgstr ""
+#: ../lib/vector/neta/timetables.c:46 ../lib/vector/neta/timetables.c:203
+#: ../lib/vector/neta/timetables.c:244 ../lib/vector/neta/timetables.c:286
+#, c-format
+msgid "Unable to open select cursor: %s"
+msgstr ""
+#: ../lib/vector/neta/spanningtree.c:104
+msgid "Computing minimum spanning tree..."
+msgstr ""
+#: ../lib/vector/neta/allpairs.c:53
+msgid "Computing all pairs shortest paths..."
+msgstr ""
+#: ../lib/vector/neta/utils.c:219 ../lib/vector/neta/utils.c:232
+#, c-format
+msgid "'%s' must be > 0 for '%s'"
+msgstr ""
+#: ../lib/vector/neta/utils.c:221
+msgid "'where' and 'cats' parameters were supplied, cat will be ignored"
+msgstr ""
+#: ../lib/vector/neta/utils.c:225
+msgid "Unable to load data from database"
+msgstr ""
+#: ../lib/vector/neta/utils.c:236
+msgid "Problem loading category values"
+msgstr ""
+#: ../lib/vector/neta/flow.c:309 ../lib/vector/Vlib/net.c:432
+#: ../lib/vector/Vlib/graph.c:110
+msgid "GngFlatten error"
+msgstr ""
+#: ../lib/vector/diglib/spindex.c:248
+#, c-format
+msgid "Unable to delete node %d from spatial index"
+msgstr ""
+#: ../lib/vector/diglib/spindex.c:288
+#, c-format
+msgid "Unable to delete line %d from spatial index"
+msgstr ""
+#: ../lib/vector/diglib/spindex.c:314
+msgid "Attempt to delete sidx for dead area"
+msgstr ""
+#: ../lib/vector/diglib/spindex.c:327
+#, c-format
+msgid "Unable to delete area %d from spatial index"
+msgstr ""
+#: ../lib/vector/diglib/spindex.c:362
+#, c-format
+msgid "Unable to delete isle %d from spatial index"
+msgstr ""
+#: ../lib/vector/diglib/plus_area.c:207 ../lib/vector/diglib/plus_area.c:675
+#: ../lib/vector/diglib/plus_area.c:683
+#, c-format
+msgid "Line %d already has area/isle %d to left"
+msgstr ""
+#: ../lib/vector/diglib/plus_area.c:217
+#, c-format
+msgid "Line %d already has area/isle %d to right"
+msgstr ""
+#: ../lib/vector/diglib/plus_area.c:299
+msgid "Attempt to delete isle from dead area"
+msgstr ""
+#: ../lib/vector/diglib/plus_area.c:316
+#, c-format
+msgid "Attempt to delete not registered isle %d from area %d"
+msgstr ""
+#: ../lib/vector/diglib/plus_area.c:354
+msgid "Attempt to delete dead area"
+msgstr ""
+#: ../lib/vector/diglib/plus_area.c:394
+#, c-format
+msgid "Dead centroid %d registered for area (bug in the vector library)"
+msgstr ""
+#: ../lib/vector/diglib/plus_area.c:418
+#, c-format
+msgid "Attempt to delete area %d info from dead isle %d"
+msgstr ""
+#: ../lib/vector/diglib/plus_area.c:773
+#, c-format
+msgid "Attempt to delete isle %d info from dead area %d"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:288
+msgid "Unable read topology for nodes"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:293
+#, c-format
+msgid "Unable to read topology for node %d"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:298
+msgid "Unable read topology for lines"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:303
+#, c-format
+msgid "Unable to read topology for line %d"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:308
+msgid "Unable to read topo for areas"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:313
+#, c-format
+msgid "Unable read topology for area %d"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:318
+msgid "Unable to read topology for isles"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:323
+#, c-format
+msgid "Unable to read topology for isle %d"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:345 ../lib/vector/diglib/plus.c:371
+msgid "Unable to write head to plus file"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:350
+msgid "Unable to write nodes to plus file"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:355
+msgid "Unable to write lines to plus file"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:360
+msgid "Unable to write areas to plus file"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:365
+msgid "Unable to write isles to plus file"
+msgstr ""
+#: ../lib/vector/diglib/plus_node.c:217
+#, c-format
+msgid ""
+"Attempt to read line angle for the line which is not connected to the node: "
+"node %d, line %d"
+msgstr ""
+#: ../lib/vector/diglib/file.c:157
+msgid "Writing to file loaded to memory not supported"
+msgstr ""
+#: ../lib/vector/diglib/file.c:200
+msgid "Unable to load file to memory, file not open"
+msgstr ""
+#: ../lib/vector/diglib/file.c:215
+msgid "Vector memory mode not supported, using 'AUTO'"
+msgstr ""
+#: ../lib/vector/Vlib/net.c:121
+msgid "Building graph..."
+msgstr ""
+#: ../lib/vector/Vlib/net.c:163
+msgid "Unable to build network graph"
+msgstr ""
+#: ../lib/vector/Vlib/net.c:169
+msgid "Forward costs column not specified"
+msgstr ""
+#: ../lib/vector/Vlib/net.c:176
+msgid "Arc field < 1"
+msgstr ""
+#: ../lib/vector/Vlib/net.c:190 ../lib/vector/Vlib/net.c:207
+#: ../lib/vector/Vlib/net.c:360
+#, c-format
+msgid "Column <%s> not found in table <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/net.c:196 ../lib/vector/Vlib/net.c:213
+#: ../lib/vector/Vlib/net.c:366
+#, c-format
+msgid "Data type of column <%s> not supported (must be numeric)"
+msgstr ""
+#: ../lib/vector/Vlib/net.c:226
+msgid "Registering arcs..."
+msgstr ""
+#: ../lib/vector/Vlib/net.c:254
+#, c-format
+msgid ""
+"Database record for line %d (cat = %d, forward/both direction(s)) not found "
+"(forward/both direction(s) of line skipped)"
+msgstr ""
+#: ../lib/vector/Vlib/net.c:273
+#, c-format
+msgid ""
+"Database record for line %d (cat = %d, backword direction) not found"
+"(direction of line skipped)"
+msgstr ""
+#: ../lib/vector/Vlib/net.c:322
+msgid "Cannot add network arc"
+msgstr ""
+#: ../lib/vector/Vlib/net.c:346
+msgid "Setting node costs..."
+msgstr ""
+#: ../lib/vector/Vlib/net.c:402
+#, c-format
+msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
+msgstr ""
+#: ../lib/vector/Vlib/net.c:429
+msgid "Flattening the graph..."
+msgstr ""
+#: ../lib/vector/Vlib/net.c:438
+msgid "Graph was built"
+msgstr ""
+#: ../lib/vector/Vlib/net.c:521 ../lib/vector/Vlib/graph.c:231
+#, c-format
+msgid "dglShortestPath error: %s"
+msgstr ""
+#: ../lib/vector/Vlib/net.c:602
+msgid "Wrong line direction in Vect_net_get_line_cost()"
+msgstr ""
+#: ../lib/vector/Vlib/poly.c:235
+msgid "Unable to find point in polygon"
+msgstr ""
+#: ../lib/vector/Vlib/poly.c:649
+msgid "conditions failed"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:93
+msgid "Layer number must be 1 or greater"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:98
+msgid "Unable to add database link, map is not opened in WRITE mode"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:104
+msgid "Unable to add database link"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:110 ../lib/vector/Vlib/field.c:155
+msgid "Unable to write database links"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:223
+#, c-format
+msgid "Layer number %d or name <%s> already exists"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:302
+#, c-format
+msgid ""
+"Default driver / database set to:\n"
+"driver: %s\n"
+"database: %s"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:309
+msgid "Default driver is not set"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:312
+msgid "Default database is not set"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:371
+#, c-format
+msgid "Requested dblink %d, maximum link number %d"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:512
+msgid "Unable to open OGR DBMI driver"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:551
+msgid ""
+"All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' "
+"available in OGR DB table"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:606
+#, c-format
+msgid "Don't know how to read links for format %d"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:639
+#, c-format
+msgid "Error in rule on row %d in %s"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:709
+#, c-format
+msgid "Unable to open vector database definition file '%s'"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:804
+msgid "Bug: attempt to update map which is not in current mapset"
+msgstr ""
+#: ../lib/vector/Vlib/array.c:99
+#, c-format
+msgid "%d errors in category string."
+msgstr ""
+#: ../lib/vector/Vlib/array.c:145 ../lib/vector/Vlib/array.c:269
+msgid "Mixed area and other type requested for vector array"
+msgstr ""
+#: ../lib/vector/Vlib/array.c:155 ../lib/vector/Vlib/array.c:178
+#: ../lib/vector/Vlib/array.c:306 ../lib/vector/Vlib/array.c:339
+msgid "Not enough space in vector array"
+msgstr ""
+#: ../lib/vector/Vlib/array.c:294
+#, c-format
+msgid "Unable to select record from table <%s> (key %s, where %s)"
+msgstr ""
+#: ../lib/vector/Vlib/open_nat.c:145
+#, c-format
+msgid ""
+"Coor files of vector map <%s@%s> is larger than it should be (%ld bytes "
+"excess)"
+msgstr ""
+#: ../lib/vector/Vlib/open_nat.c:149
+#, c-format
+msgid ""
+"Coor files of vector <%s@%s> is shorter than it should be (%ld bytes "
+"missing)."
+msgstr ""
+#: ../lib/vector/Vlib/break_lines.c:374
+#, c-format
+msgid "Intersections: %5d"
+msgstr ""
+#: ../lib/vector/Vlib/open_ogr.c:53
+msgid "OGR format cannot be updated"
+msgstr ""
+#: ../lib/vector/Vlib/open_ogr.c:65
+#, c-format
+msgid "Unable to open OGR data source '%s'"
+msgstr ""
+#: ../lib/vector/Vlib/open_ogr.c:85
+#, c-format
+msgid "Unable to open layer <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open_ogr.c:129
+#, c-format
+msgid "Unable to open fidx file for vector map <%s@%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open_ogr.c:147
+#, c-format
+msgid ""
+"Feature index format version %d.%d is not supported by this release. Try to "
+"rebuild topology or upgrade GRASS."
+msgstr ""
+#: ../lib/vector/Vlib/open_ogr.c:152
+#, c-format
+msgid ""
+"Your GRASS version does not fully support feature index format %d.%d of the "
+"vector. Consider to rebuild topology or upgrade GRASS."
+msgstr ""
+#: ../lib/vector/Vlib/close.c:38 ../lib/vector/Vlib/read.c:30
+#: ../lib/vector/Vlib/build.c:31 ../lib/vector/Vlib/write.c:53
+#: ../lib/vector/Vlib/write.c:59 ../lib/vector/Vlib/open.c:40
+#: ../lib/vector/Vlib/rewind.c:35
+msgid "Requested format is not compiled in this version"
+msgstr ""
+#: ../lib/vector/Vlib/close.c:134
+#, c-format
+msgid "Unable to close vector <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/intersect.c:127
+msgid "3D not supported by Vect_segment_intersection()"
+msgstr ""
+#: ../lib/vector/Vlib/intersect.c:322
+msgid "Vect_segment_intersection() ERROR (collinear vertical segments)"
+msgstr ""
+#: ../lib/vector/Vlib/intersect.c:448
+msgid "Vect_segment_intersection() ERROR (collinear non vertical segments)"
+msgstr ""
+#: ../lib/vector/Vlib/intersect.c:1099 ../lib/vector/Vlib/intersect.c:1105
+#: ../lib/vector/Vlib/intersect.c:1107 ../lib/vector/Vlib/intersect.c:1155
+#: ../lib/vector/Vlib/intersect.c:1164 ../lib/vector/Vlib/intersect.c:1185
+#: ../lib/vector/Vlib/intersect.c:1202
+msgid "Error while adding point to array. Out of memory"
+msgstr ""
+#: ../lib/vector/Vlib/build_nat.c:93
+msgid "Unable to add area (map closed, topo saved)"
+msgstr ""
+#: ../lib/vector/Vlib/build_nat.c:102
+msgid "Unable to add isle (map closed, topo saved)"
+msgstr ""
+#: ../lib/vector/Vlib/build_nat.c:112
+msgid "Area of size = 0.0 ignored"
+msgstr ""
+#: ../lib/vector/Vlib/build_nat.c:148
+msgid "Request to find area outside nonexistent isle"
+msgstr ""
+#: ../lib/vector/Vlib/build_nat.c:516
+msgid "Registering primitives..."
+msgstr ""
+#: ../lib/vector/Vlib/build_nat.c:525
+msgid "Unable to read vector map"
+msgstr ""
+#: ../lib/vector/Vlib/build_nat.c:569
+#, c-format
+msgid "%d primitives registered"
+msgstr ""
+#: ../lib/vector/Vlib/build_nat.c:570
+#, c-format
+msgid "%d vertices registered"
+msgstr ""
+#: ../lib/vector/Vlib/build_nat.c:581
+msgid "Building areas..."
+msgstr ""
+#: ../lib/vector/Vlib/build_nat.c:604
+#, c-format
+msgid "%d areas built"
+msgstr ""
+#: ../lib/vector/Vlib/build_nat.c:605
+#, c-format
+msgid "%d isles built"
+msgstr ""
+#: ../lib/vector/Vlib/build_nat.c:614
+msgid "Attaching islands..."
+msgstr ""
+#: ../lib/vector/Vlib/build_nat.c:629
+msgid "Attaching centroids..."
+msgstr ""
+#: ../lib/vector/Vlib/cats.c:45
+msgid "Vect_new_cats_struct(): Out of memory"
+msgstr ""
+#: ../lib/vector/Vlib/cats.c:129
+#, c-format
+msgid "Too many categories (%d), unable to set cat %d (layer %d)"
+msgstr ""
+#: ../lib/vector/Vlib/cats.c:407
+#, c-format
+msgid "Unable to convert category string '%s' (from '%s') to category range"
+msgstr ""
+#: ../lib/vector/Vlib/legal_vname.c:48
+#, c-format
+msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
+msgstr ""
+#: ../lib/vector/Vlib/legal_vname.c:55
+#, c-format
+msgid "Illegal vector map name <%s>. Must start with a letter."
+msgstr ""
+#: ../lib/vector/Vlib/legal_vname.c:63
+#, c-format
+msgid "Illegal vector map name <%s>. Character '%c' not allowed."
+msgstr ""
+#: ../lib/vector/Vlib/legal_vname.c:70
+#, c-format
+msgid ""
+"Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
+msgstr ""
+#: ../lib/vector/Vlib/legal_vname.c:101 ../lib/vector/Vlib/legal_vname.c:105
+#, c-format
+msgid "Output vector map name <%s> is not valid map name"
+msgstr ""
+#: ../lib/vector/Vlib/legal_vname.c:142 ../lib/vector/Vlib/legal_vname.c:146
+#, c-format
+msgid "Output vector map <%s> is used as input"
+msgstr ""
+#: ../lib/vector/Vlib/line.c:199 ../lib/vector/Vlib/line.c:231
+msgid "Index out of range in"
+msgstr ""
+#: ../lib/vector/Vlib/line.c:527
+msgid "Segment outside line, no segment created"
+msgstr ""
+#: ../lib/vector/Vlib/geos.c:53 ../lib/vector/Vlib/read.c:99
+msgid "vector map is not opened"
+msgstr ""
+#: ../lib/vector/Vlib/geos.c:56
+#, c-format
+msgid ""
+"Vect_read_line_geos(): feature id %d is not reasonable (max features in "
+"vector map <%s>: %d)"
+msgstr ""
+#: ../lib/vector/Vlib/geos.c:61
+msgid "only native format supported"
+msgstr ""
+#: ../lib/vector/Vlib/geos.c:66 ../lib/vector/Vlib/geos.c:256
+#: ../lib/vector/Vlib/read_nat.c:136
+msgid "Attempt to read dead line"
+msgstr ""
+#: ../lib/vector/Vlib/geos.c:91
+#, c-format
+msgid "Vect_read_area_geos(): unable to read area id %d"
+msgstr ""
+#: ../lib/vector/Vlib/geos.c:105
+#, c-format
+msgid "Vect_read_area_geos(): unable to read isle id %d of area id %d"
+msgstr ""
+#: ../lib/vector/Vlib/geos.c:203
+#, c-format
+msgid "Unable to read line offset %ld"
+msgstr ""
+#: ../lib/vector/Vlib/geos.c:410
+#, c-format
+msgid "Attempt to read points of nonexistent area id %d"
+msgstr ""
+#: ../lib/vector/Vlib/geos.c:470
+#, c-format
+msgid "Unable to read feature id %d"
+msgstr ""
+#: ../lib/vector/Vlib/remove_areas.c:94
+msgid "Area is composed of dead boundary"
+msgstr ""
+#: ../lib/vector/Vlib/level.c:38
+msgid "Map structure was never initialized"
+msgstr ""
+#: ../lib/vector/Vlib/level.c:40
+msgid "Map structure has been closed"
+msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:364
+msgid "Line is not looped"
+msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:598 ../lib/vector/Vlib/buffer2.c:609
+msgid "Next edge was visited but it is not the first one !!! breaking loop"
+msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:657
+msgid "side != 0 feature not implemented"
+msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:899 ../lib/vector/Vlib/buffer2.c:946
+msgid "zero area size"
+msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:905 ../lib/vector/Vlib/buffer2.c:952
+msgid "Line was not closed"
+msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:918 ../lib/vector/Vlib/buffer2.c:969
+msgid "Vect_get_point_in_poly() failed"
+msgstr ""
+#: ../lib/vector/Vlib/merge_lines.c:192
+#, c-format
+msgid "%d boundaries merged"
+msgstr ""
+#: ../lib/vector/Vlib/merge_lines.c:193
+#, c-format
+msgid "%d new boundaries"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:31
+msgid "Category index is not up to date"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:61 ../lib/vector/Vlib/cindex.c:125
+#: ../lib/vector/Vlib/cindex.c:143 ../lib/vector/Vlib/cindex.c:166
+msgid "Invalid layer index (index >= number of layers)"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:107
+msgid "Invalid layer index (index < 0 or index >= number of layers)"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:232
+msgid "Layer or category index out of range"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:283
+msgid "Layer index out of range"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:460
+#, c-format
+msgid "Unable to open cidx file <%s> for write"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:468
+#, c-format
+msgid "Error writing out category index file <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:511
+#, c-format
+msgid "Unable to open category index file for vector map <%s@%s>"
+msgstr ""
+#: ../lib/vector/Vlib/read.c:102
+#, c-format
+msgid ""
+"Vect_read_line(): feature id %d is not reasonable (max features in vector "
+"map <%s>: %d)"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:123
+#, c-format
+msgid "Building topology for vector map <%s>..."
+msgstr ""
+#: ../lib/vector/Vlib/build.c:141
+msgid "Topology was built"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:153
+#, c-format
+msgid "Number of nodes: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:154
+#, c-format
+msgid "Number of primitives: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:155
+#, c-format
+msgid "Number of points: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:156
+#, c-format
+msgid "Number of lines: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:157
+#, c-format
+msgid "Number of boundaries: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:158
+#, c-format
+msgid "Number of centroids: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:161
+#, c-format
+msgid "Number of faces: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:164
+#, c-format
+msgid "Number of kernels: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:205
+#, c-format
+msgid "Number of areas: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:206
+#, c-format
+msgid "Number of isles: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:209
+#, c-format
+msgid "Number of incorrect boundaries: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:213
+#, c-format
+msgid "Number of centroids outside area: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:217
+#, c-format
+msgid "Number of duplicate centroids: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:221
+#, c-format
+msgid "Number of areas without centroid: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:226
+msgid "Number of areas: -"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:227
+msgid "Number of isles: -"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:256
+#, c-format
+msgid "Unable to open topo file for write <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:264
+msgid "Error writing out topo file"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:407
+#, c-format
+msgid "Unable open spatial index file for write <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:415
+msgid "Error writing out spatial index file"
+msgstr ""
+#: ../lib/vector/Vlib/write.c:27 ../lib/vector/Vlib/write.c:33
+#: ../lib/vector/Vlib/write.c:39 ../lib/vector/Vlib/write.c:46
+msgid "for this format/level not supported"
+msgstr ""
+#: ../lib/vector/Vlib/write.c:135
+msgid "Unable to write feature, vector map is not opened"
+msgstr ""
+#: ../lib/vector/Vlib/write.c:148
+msgid "Unable to write feature (negative offset)"
+msgstr ""
+#: ../lib/vector/Vlib/write.c:181
+msgid "Unable to rewrite feature, vector map is not opened"
+msgstr ""
+#: ../lib/vector/Vlib/write.c:194
+#, c-format
+msgid "Unable to rewrite feature %d"
+msgstr ""
+#: ../lib/vector/Vlib/write.c:219
+#, c-format
+msgid ""
+"Unable to delete feature %d, vector map <%s> is not opened on topology level"
+msgstr ""
+#: ../lib/vector/Vlib/write.c:225
+#, c-format
+msgid ""
+"Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
+msgstr ""
+#: ../lib/vector/Vlib/write.c:239
+#, c-format
+msgid "Unable to delete feature %d from vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/write.c:265
+#, c-format
+msgid ""
+"Unable to restore feature %d, vector map <%s> is not opened on topology level"
+msgstr ""
+#: ../lib/vector/Vlib/write.c:271
+#, c-format
+msgid ""
+"Unable to restore feature %d, vector map <%s> is not opened in 'write' mode"
+msgstr ""
+#: ../lib/vector/Vlib/write.c:285
+#, c-format
+msgid "Unable to restore feature %d from vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/overlay.c:74
+msgid "unknown operator"
+msgstr ""
+#: ../lib/vector/Vlib/overlay.c:123
+msgid "Overlay: line/boundary types not supported by AND operator"
+msgstr ""
+#: ../lib/vector/Vlib/overlay.c:126
+msgid "Overlay: area x area types not supported by AND operator"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:55
+msgid "input vector map is not open"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:178 ../lib/vector/Vlib/map.c:314
+#: ../lib/vector/Vlib/open.c:540
+#, c-format
+msgid "Vector map name is not SQL compliant"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:182
+#, c-format
+msgid "Unable to find vector map <%s> in <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:189 ../lib/vector/Vlib/map.c:318
+#: ../lib/vector/Vlib/open.c:547
+#, c-format
+msgid "Vector map <%s> already exists and will be overwritten"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:193 ../lib/vector/Vlib/open.c:552
+#, c-format
+msgid "Unable to delete vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:213 ../lib/vector/Vlib/map.c:331
+#, c-format
+msgid "Unable to copy vector map <%s> to <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:260 ../lib/vector/Vlib/map.c:381
+#: ../lib/vector/Vlib/map.c:613 ../lib/vector/Vlib/map.c:720
+#, c-format
+msgid "Unable to copy table <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:276 ../lib/vector/Vlib/map.c:410
+#: ../lib/vector/Vlib/map.c:626
+#, c-format
+msgid "Unable to create index for table <%s>, key <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:395 ../lib/vector/Vlib/map.c:490
+#, c-format
+msgid "Unable to delete table <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:444
+#, c-format
+msgid "Invalid vector map name <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:458
+#, c-format
+msgid "Unable to open header file for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:480
+#, c-format
+msgid "Unable to find table <%s> linked to vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:497
+#, c-format
+msgid "Table <%s> linked to vector map <%s> does not exist"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:511
+#, c-format
+msgid "Unable to open directory '%s'"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:525
+#, c-format
+msgid "Unable to delete file '%s'"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:542
+#, c-format
+msgid "Unable to rename directory '%s' to '%s'"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:550
+#, c-format
+msgid "Unable to remove directory '%s'"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:604 ../lib/vector/Vlib/map.c:705
+#, c-format
+msgid "Unable to add database link for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:100
+#, c-format
+msgid "Programmer requested unknown open level %d"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:179
+msgid ""
+"Vector map which is not in the current mapset cannot be opened for update"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:211 ../lib/vector/Vlib/open.c:279
+#: ../lib/vector/Vlib/open.c:299
+#, c-format
+msgid ""
+"Unable to open vector map <%s> on level %d. Try to rebuild vector topology "
+"by v.build."
+msgstr ""
+#: ../lib/vector/Vlib/open.c:214
+msgid "Unable to read head file"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:236
+#, c-format
+msgid "Unable to open topology file for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:262
+#, c-format
+msgid "Unable to open category index file for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:353 ../lib/vector/Vlib/open.c:576
+#, c-format
+msgid "Unable to open history file for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:531
+#, c-format
+msgid "%s is not in the current mapset (%s)"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:566
+#, c-format
+msgid "Unable to create vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:622
+#, c-format
+msgid "Unable to stat file <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:731
+msgid "Size of 'coor' file differs from value saved in topology file"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:742
+#, c-format
+msgid "Please rebuild topology for vector map <%s@%s>"
+msgstr ""
+#: ../lib/vector/Vlib/header.c:95 ../lib/vector/Vlib/header.c:143
+#, c-format
+msgid "Unable to open header file of vector <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/header.c:151
+#, c-format
+msgid "Corrupted row in head: %s"
+msgstr ""
+#: ../lib/vector/Vlib/header.c:189
+#, c-format
+msgid "Unknown keyword %s in vector head"
+msgstr ""
+#: ../lib/vector/Vlib/header.c:512 ../lib/gis/proj3.c:64
+msgid "Unknown projection"
+msgstr ""
+#: ../lib/vector/Vlib/build_ogr.c:272
+#, c-format
+msgid "Unable to calculate centroid for area %d"
+msgstr ""
+#: ../lib/vector/Vlib/build_ogr.c:309 ../lib/vector/Vlib/read_ogr.c:120
+#: ../lib/vector/Vlib/read_ogr.c:306
+#, c-format
+msgid "OGR feature type %d not supported"
+msgstr ""
+#: ../lib/vector/Vlib/build_ogr.c:333
+msgid "Partial build for OGR is not supported"
+msgstr ""
+#: ../lib/vector/Vlib/build_ogr.c:342
+msgid ""
+"Random read is not supported by OGR for this layer, cannot build support"
+msgstr ""
+#: ../lib/vector/Vlib/build_ogr.c:349
+msgid "Feature: "
+msgstr ""
+#: ../lib/vector/Vlib/build_ogr.c:361
+#, c-format
+msgid "Feature %d without geometry ignored"
+msgstr ""
+#: ../lib/vector/Vlib/build_ogr.c:368
+msgid "OGR feature without ID ignored"
+msgstr ""
+#: ../lib/vector/Vlib/sindex.c:97
+msgid "not implemented"
+msgstr ""
+#: ../lib/vector/Vlib/sindex.c:109
+#, c-format
+msgid "Unable to delete item %d from spatial index"
+msgstr ""
+#: ../lib/vector/Vlib/sindex.c:127
+msgid ""
+"Unable to build spatial index from topology, vector map is not opened at "
+"topo level 2"
+msgstr ""
+#: ../lib/vector/Vlib/sindex.c:168
+msgid "BUG (Vect_build_sidx_from_topo): node does not exist"
+msgstr ""
+#: ../lib/vector/Vlib/sindex.c:180
+msgid "BUG (Vect_build_sidx_from_topo): line does not exist"
+msgstr ""
+#: ../lib/vector/Vlib/sindex.c:199
+msgid "BUG (Vect_build_sidx_from_topo): area does not exist"
+msgstr ""
+#: ../lib/vector/Vlib/sindex.c:218
+msgid "BUG (Vect_build_sidx_from_topo): isle does not exist"
+msgstr ""
+#: ../lib/vector/Vlib/area.c:53
+msgid "Attempt to read points of nonexistent area"
+msgstr ""
+#: ../lib/vector/Vlib/area.c:125
+#, c-format
+msgid "Unable to read line %d"
+msgstr ""
+#: ../lib/vector/Vlib/area.c:164 ../lib/vector/Vlib/area.c:193
+#: ../lib/vector/Vlib/area.c:257 ../lib/vector/Vlib/area.c:286
+#, c-format
+msgid "Attempt to read topo for dead area (%d)"
+msgstr ""
+#: ../lib/vector/Vlib/area.c:313
+#, c-format
+msgid "Attempt to read topo for dead isle (%d)"
+msgstr ""
+#: ../lib/vector/Vlib/read_ogr.c:178
+msgid "OGR feature without ID"
+msgstr ""
+#: ../lib/vector/Vlib/read_ogr.c:378 ../lib/vector/Vlib/read_ogr.c:386
+#, c-format
+msgid "Unable to get feature geometry, FID %ld"
+msgstr ""
+#: ../lib/vector/Vlib/level_two.c:234 ../lib/vector/Vlib/level_two.c:259
+#: ../lib/vector/Vlib/level_two.c:283 ../lib/vector/Vlib/level_two.c:302
+#: ../lib/vector/Vlib/level_two.c:320 ../lib/vector/Vlib/level_two.c:339
+#, c-format
+msgid "Vector map <%s> is not open on level >= 2"
+msgstr ""
+#: ../lib/vector/Vlib/graph.c:143
+msgid "Unable to add network arc"
+msgstr ""
+#: ../lib/vector/Vlib/write_nat.c:50 ../lib/vector/Vlib/write_nat.c:83
+#, c-format
+msgid "%s: Area %d does not exist"
+msgstr ""
+#: ../lib/vector/Vlib/write_nat.c:640
+msgid "Attempt to delete dead feature"
+msgstr ""
+#: ../lib/vector/Vlib/write_nat.c:885
+msgid "Attempt to restore alive feature"
+msgstr ""
+#: ../lib/vector/vedit/cats.c:63
+#, c-format
+msgid "Unable to set category %d for (feature id %d)"
+msgstr ""
+#: ../lib/vector/vedit/select.c:230
+msgid "Unknown query tool"
+msgstr ""
+#: ../lib/proj/convert.c:110
+msgid "Unable parse GRASS PROJ_INFO file"
+msgstr ""
+#: ../lib/proj/convert.c:115
+msgid "Unable get PROJ.4-style parameter string"
+msgstr ""
+#: ../lib/proj/convert.c:127
+#, c-format
+msgid ""
+"OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
+msgstr ""
+#: ../lib/proj/convert.c:133
+#, c-format
+msgid "OGR can't get WKT-style parameter string (OGR Error code was %d)"
+msgstr ""
+#: ../lib/proj/convert.c:390
+msgid "No projection name! Projection parameters likely to be meaningless."
+msgstr ""
+#: ../lib/proj/convert.c:426
+#, c-format
+msgid "Datum <%s> not recognised by GRASS and no parameters found"
+msgstr ""
+#: ../lib/proj/convert.c:442
+#, c-format
+msgid ""
+"Datum <%s> apparently recognised by GRASS but no parameters found. You may "
+"want to look into this."
+msgstr ""
+#: ../lib/proj/convert.c:446
+#, c-format
+msgid ""
+"Invalid transformation number %d; valid range is 1 to %d. Leaving datum "
+"transform parameters unspecified."
+msgstr ""
+#: ../lib/proj/get_proj.c:150
+#, c-format
+msgid "Invalid zone %s specified"
+msgstr ""
+#: ../lib/proj/get_proj.c:230
+msgid "Unable to initialise PROJ.4 with the following parameter list:"
+msgstr ""
+#: ../lib/proj/get_proj.c:238
+#, c-format
+msgid "The error message: %s"
+msgstr ""
+#: ../lib/proj/get_proj.c:296
+msgid "Option input overflowed option table"
+msgstr ""
+#: ../lib/proj/get_proj.c:327
+#, c-format
+msgid "Unable to initialize pj cause: %s"
+msgstr ""
+#: ../lib/proj/get_proj.c:403
+msgid "Input Projection Parameters"
+msgstr ""
+#: ../lib/proj/get_proj.c:406
+msgid "Input Unit Factor"
+msgstr ""
+#: ../lib/proj/get_proj.c:416
+msgid "Output Projection Parameters"
+msgstr ""
+#: ../lib/proj/get_proj.c:419
+msgid "Output Unit Factor"
+msgstr ""
+#: ../lib/proj/ellipse.c:75
+#, c-format
+msgid "Invalid ellipsoid <%s> in file"
+msgstr ""
+#: ../lib/proj/ellipse.c:98
+msgid "No secondary ellipsoid descriptor (rf, es or b) in file"
+msgstr ""
+#: ../lib/proj/ellipse.c:102
+msgid "Invalid ellipsoid descriptors (a, rf, es or b) in file"
+msgstr ""
+#: ../lib/proj/ellipse.c:115
+msgid "No ellipsoid info given in file"
+msgstr ""
+#: ../lib/proj/ellipse.c:215 ../lib/gis/get_ellipse.c:283
+#, c-format
+msgid "Unable to open ellipsoid table file <%s>"
+msgstr ""
+#: ../lib/proj/ellipse.c:268 ../lib/gis/get_ellipse.c:338
+#, c-format
+msgid "Line%s of ellipsoid table file <%s> is invalid"
+msgstr ""
+#: ../lib/proj/ellipse.c:269 ../lib/gis/get_ellipse.c:336
+#, c-format
+msgid "Lines%s of ellipsoid table file <%s> are invalid"
+msgstr ""
+#: ../lib/proj/datum.c:251
+msgid "Unable to open temporary file"
+msgstr ""
+#: ../lib/proj/datum.c:345 ../lib/gis/get_ell_name.c:45
+#: ../lib/gis/get_datum_name.c:58 ../lib/gis/get_projname.c:52
+#, c-format
+msgid "Hit RETURN to cancel request\n"
+msgstr ""
+#: ../lib/proj/datum.c:419 ../lib/proj/datum.c:484
+#, c-format
+msgid "Unable to open datum table file <%s>"
+msgstr ""
+#: ../lib/proj/datum.c:432 ../lib/proj/datum.c:498
+#, c-format
+msgid "Error in datum table file <%s>, line %d"
+msgstr ""
+#: ../lib/proj/do_proj.c:106 ../lib/proj/do_proj.c:180
+#, c-format
+msgid "pj_transform() failed: %s"
+msgstr ""
+#: ../lib/gis/get_window.c:67 ../lib/gis/get_window.c:85
+#, c-format
+msgid ""
+"region for current mapset %s\n"
+"run \"g.region\""
+msgstr ""
+#: ../lib/gis/get_window.c:120
+#, c-format
+msgid "default region %s"
+msgstr ""
+#: ../lib/gis/get_window.c:141
+msgid "is not set"
+msgstr ""
+#: ../lib/gis/get_window.c:150
+#, c-format
+msgid ""
+"is invalid\n"
+"%s"
+msgstr ""
+#: ../lib/gis/get_cellhd.c:71 ../lib/gis/get_cellhd.c:100
+#, c-format
+msgid "Unable to read header file for raster map <%s@%s>."
+msgstr ""
+#: ../lib/gis/get_cellhd.c:74
+#, c-format
+msgid " It is a reclass of raster map <%s@%s> "
+msgstr ""
+#: ../lib/gis/get_cellhd.c:78
+#, c-format
+msgid "which is missing."
+msgstr ""
+#: ../lib/gis/get_cellhd.c:80
+#, c-format
+msgid "whose header file can't be opened."
+msgstr ""
+#: ../lib/gis/get_cellhd.c:88
+#, c-format
+msgid "Unable to open header file for raster map <%s@%s>"
+msgstr ""
+#: ../lib/gis/get_cellhd.c:105
+#, c-format
+msgid " It is a reclass of raster map <%s@%s> whose header file is invalid."
+msgstr ""
+#: ../lib/gis/get_cellhd.c:109
+#, c-format
+msgid " Invalid format."
+msgstr ""
+#: ../lib/gis/mapset.c:39
+msgid "MAPSET is not set"
+msgstr ""
+#: ../lib/gis/mapset.c:57 ../lib/gis/gisinit.c:66
+#, c-format
+msgid "MAPSET %s not found"
+msgstr ""
+#: ../lib/gis/color_rules.c:110
+msgid "syntax error"
+msgstr ""
+#: ../lib/gis/color_rules.c:112
+msgid "R/G/B not in range 0-255"
+msgstr ""
+#: ../lib/gis/color_rules.c:114
+msgid "invalid color name"
+msgstr ""
+#: ../lib/gis/color_rules.c:116
+msgid "percentage not in range 0-100"
+msgstr ""
+#: ../lib/gis/color_rules.c:118
+msgid "invalid value"
+msgstr ""
+#: ../lib/gis/color_rules.c:120
+msgid "unknown error"
+msgstr ""
+#: ../lib/gis/color_rules.c:151
+#, c-format
+msgid "bad rule (%s): [%s]"
+msgstr ""
+#: ../lib/gis/color_rules.c:265
+#, c-format
+msgid "Unable to load color rules <%s>"
+msgstr ""
+#: ../lib/gis/color_read.c:116
+#, c-format
+msgid "color support for [%s] in mapset [%s] %s"
+msgstr ""
+#: ../lib/gis/auto_mask.c:64
+msgid "Unable to open automatic MASK file"
+msgstr ""
+#: ../lib/gis/range.c:192
+#, c-format
+msgid "can't read f_range file for [%s in %s]"
+msgstr ""
+#: ../lib/gis/range.c:308
+#, c-format
+msgid "can't read range file for [%s in %s]"
+msgstr ""
+#: ../lib/gis/range.c:359 ../lib/gis/range.c:412
+#, c-format
+msgid "can't write range file for [%s in %s]"
+msgstr ""
+#: ../lib/gis/get_ellipse.c:85
+#, c-format
+msgid "Unable to open file %s in <%s>"
+msgstr ""
+#: ../lib/gis/get_ellipse.c:358 ../lib/gis/get_ellipse.c:384
+#, c-format
+msgid "Invalid a: field '%s' in file %s in <%s>"
+msgstr ""
+#: ../lib/gis/get_ellipse.c:371
+#, c-format
+msgid "Invalid ellipsoid '%s' in file %s in <%s>"
+msgstr ""
+#: ../lib/gis/get_ellipse.c:388
+#, c-format
+msgid "Invalid es: field '%s' in file %s in <%s>"
+msgstr ""
+#: ../lib/gis/get_ellipse.c:402
+#, c-format
+msgid "No ellipsoid info given in file %s in <%s>"
+msgstr ""
+#: ../lib/gis/get_ell_name.c:31 ../lib/gis/get_datum_name.c:69
+#: ../lib/gis/get_projname.c:38
+msgid "Cannot open temp file"
+msgstr ""
+#: ../lib/gis/get_ell_name.c:42
+#, c-format
+msgid ""
+"\n"
+"Please specify ellipsoid name\n"
+msgstr ""
+#: ../lib/gis/get_ell_name.c:44
+#, c-format
+msgid "Enter 'list' for the list of available ellipsoids\n"
+msgstr ""
+#: ../lib/gis/get_ell_name.c:67
+#, c-format
+msgid ""
+"\n"
+"invalid ellipsoid\n"
+msgstr ""
+#: ../lib/gis/sample.c:71
+msgid "Unknown interpolation type"
+msgstr ""
+#: ../lib/gis/sample.c:284
+msgid "\"no data\" label found; setting to zero"
+msgstr ""
+#: ../lib/gis/sample.c:299
+msgid "Problem reading raster map"
+msgstr ""
+#: ../lib/gis/unix_socks.c:102
+msgid "Unable to get GIS_LOCK environment variable value"
+msgstr ""
+#: ../lib/gis/get_row.c:46 ../lib/gis/get_row.c:1049
+#, c-format
+msgid "Reading raster map <%s@%s> request for row %d is outside region"
+msgstr ""
+#: ../lib/gis/get_row.c:324
+#, c-format
+msgid "cell_values_float: xdr_float failed for index %d"
+msgstr ""
+#: ../lib/gis/get_row.c:365
+#, c-format
+msgid "cell_values_double: xdr_double failed for index %d"
+msgstr ""
+#: ../lib/gis/get_row.c:621
+#, c-format
+msgid "Error reading compressed map <%s@%s>, row %d"
+msgstr ""
+#: ../lib/gis/get_row.c:624
+#, c-format
+msgid "Error reading map <%s@%s>, row %d"
+msgstr ""
+#: ../lib/gis/get_row.c:1031 ../lib/gis/get_row.c:1036
+#, c-format
+msgid "Error reading null row %d"
+msgstr ""
+#: ../lib/gis/get_row.c:1115
+msgid "Unable to realloc buffer"
+msgstr ""
+#: ../lib/gis/ask_cell.c:54 ../lib/gis/ask_cell.c:72 ../lib/gis/ask_cell.c:91
+#: ../lib/gis/ask_cell.c:96
+msgid "with titles"
+msgstr ""
+#: ../lib/gis/ask_cell.c:110
+msgid "(no title)"
+msgstr ""
+#: ../lib/gis/proj2.c:46
+msgid "Latitude-Longitude"
+msgstr ""
+#: ../lib/gis/proj2.c:48
+msgid "Other Projection"
+msgstr ""
+#: ../lib/gis/system.c:85
+msgid "Can not create a new process!"
+msgstr ""
+#: ../lib/gis/mask_info.c:40
+#, c-format
+msgid "<%s> in mapset <%s>"
+msgstr ""
+#: ../lib/gis/mask_info.c:43
+msgid "none"
+msgstr ""
+#: ../lib/gis/mask_info.c:46
+msgid "not known"
+msgstr ""
+#: ../lib/gis/cats.c:381
+#, c-format
+msgid "category support for [%s] in mapset [%s] %s"
+msgstr ""
+#: ../lib/gis/cats.c:417
+#, c-format
+msgid "category support for vector map [%s] in mapset [%s] %s"
+msgstr ""
+#: ../lib/gis/closecell.c:228
+#, c-format
+msgid ""
+"closecell: can't move %s\n"
+"to null file %s"
+msgstr ""
+#: ../lib/gis/closecell.c:250
+#, c-format
+msgid "Error writing floating point format file for map %s"
+msgstr ""
+#: ../lib/gis/closecell.c:300
+#, c-format
+msgid ""
+"to cell file %s"
+msgstr ""
+#: ../lib/gis/closecell.c:355
+msgid "unable to write quant file!"
+msgstr ""
+#: ../lib/gis/closecell.c:406
+msgid "unable to write f_format file for CELL maps"
+msgstr ""
+#: ../lib/gis/get_projinfo.c:33 ../lib/gis/get_projinfo.c:60
+#, c-format
+msgid "<%s> file not found for location <%s>"
+msgstr ""
+#: ../lib/gis/get_projinfo.c:39 ../lib/gis/get_projinfo.c:66
+#, c-format
+msgid "ERROR in reading <%s> file for location <%s>"
+msgstr ""
+#: ../lib/gis/ask.c:341
+msgid "to cancel request"
+msgstr ""
+#: ../lib/gis/ask.c:390
+#, c-format
+msgid "Enter a new %s file name"
+msgstr ""
+#: ../lib/gis/ask.c:396
+#, c-format
+msgid "Enter the name of an existing %s file"
+msgstr ""
+#: ../lib/gis/ask.c:401
+#, c-format
+msgid "Enter %s file name"
+msgstr ""
+#: ../lib/gis/ask.c:421
+#, c-format
+msgid "Enter 'list' for a list of existing %s files\n"
+msgstr ""
+#: ../lib/gis/ask.c:424
+#, c-format
+msgid "Enter 'list -f' for "
+msgstr ""
+#: ../lib/gis/ask.c:426
+#, c-format
+msgid "a list %s"
+msgstr ""
+#: ../lib/gis/ask.c:428
+#, c-format
+msgid "an extended list"
+msgstr ""
+#: ../lib/gis/ask.c:432
+#, c-format
+msgid "Hit RETURN %s\n"
+msgstr ""
+#: ../lib/gis/ask.c:452 ../lib/gis/ask.c:557 ../lib/gis/ask.c:577
+#, c-format
+msgid ""
+"\n"
+"** %s - not found **\n"
+msgstr ""
+#: ../lib/gis/ask.c:459 ../lib/gis/ask.c:544
+#, c-format
+msgid ""
+"\n"
+"** %s exists. ok to overwrite? "
+msgstr ""
+#: ../lib/gis/ask.c:506
+#, c-format
+msgid ""
+"\n"
+"**<%s> illegal name **\n"
+msgstr ""
+#: ../lib/gis/ask.c:518
+#, c-format
+msgid ""
+"\n"
+"** %s - illegal request **\n"
+msgstr ""
+#: ../lib/gis/ask.c:533
+#, c-format
+msgid ""
+"\n"
+"** %s - exists, select another name **\n"
+msgstr ""
+#: ../lib/gis/ask.c:561
+msgid "ask: can't happen"
+msgstr ""
+#: ../lib/gis/timestamp.c:282
+#, c-format
+msgid "Can't create timestamp file for %s map %s in mapset %s"
+msgstr ""
+#: ../lib/gis/timestamp.c:291
+#, c-format
+msgid "Invalid timestamp specified for %s map %s in mapset %s"
+msgstr ""
+#: ../lib/gis/timestamp.c:313
+#, c-format
+msgid "Can't open timestamp file for %s map %s in mapset %s"
+msgstr ""
+#: ../lib/gis/timestamp.c:322
+#, c-format
+msgid "Invalid timestamp file for %s map %s in mapset %s"
+msgstr ""
+#: ../lib/gis/spawn.c:385
+#, c-format
+msgid "CreateProcess() failed: error = %d"
+msgstr ""
+#: ../lib/gis/spawn.c:416
+#, c-format
+msgid "G_spawn: unable to redirect descriptor %d"
+msgstr ""
+#: ../lib/gis/spawn.c:424 ../lib/gis/spawn.c:609
+#, c-format
+msgid "G_spawn: unable to open file %s"
+msgstr ""
+#: ../lib/gis/spawn.c:493 ../lib/gis/spawn.c:679
+msgid "Unable to execute command"
+msgstr ""
+#: ../lib/gis/spawn.c:518 ../lib/gis/spawn.c:526
+#, c-format
+msgid "G_spawn: unable to restore signal %d"
+msgstr ""
+#: ../lib/gis/spawn.c:557
+#, c-format
+msgid "G_spawn: unable to reset signal %d"
+msgstr ""
+#: ../lib/gis/spawn.c:566
+#, c-format
+msgid "G_spawn: unable to ignore signal %d"
+msgstr ""
+#: ../lib/gis/spawn.c:577
+#, c-format
+msgid "G_spawn: unable to block signal %d"
+msgstr ""
+#: ../lib/gis/spawn.c:585
+#, c-format
+msgid "G_spawn: unable to unblock signal %d"
+msgstr ""
+#: ../lib/gis/spawn.c:614 ../lib/gis/spawn.c:623
+#, c-format
+msgid "G_spawn: unable to duplicate descriptor %d to %d"
+msgstr ""
+#: ../lib/gis/spawn.c:656
+msgid "Unable to create a new process"
+msgstr ""
+#: ../lib/gis/spawn.c:671
+#, c-format
+msgid "Unable to change directory to %s"
+msgstr ""
+#: ../lib/gis/gdal.c:66
+#, c-format
+msgid "Unable to locate symbol <%s>"
+msgstr ""
+#: ../lib/gis/gdal.c:114
+msgid "Unable to load GDAL library"
+msgstr ""
+#: ../lib/gis/histogram.c:57
+#, c-format
+msgid "Histogram for [%s in %s] missing (run r.support)"
+msgstr ""
+#: ../lib/gis/histogram.c:65
+#, c-format
+msgid "Can't read histogram for [%s in %s]"
+msgstr ""
+#: ../lib/gis/histogram.c:74 ../lib/gis/histogram.c:84
+#, c-format
+msgid "Invalid histogram file for [%s in %s]"
+msgstr ""
+#: ../lib/gis/histogram.c:356
+#, c-format
+msgid "can't create histogram for [%s in %s]"
+msgstr ""
+#: ../lib/gis/open_misc.c:45
+#, c-format
+msgid "G__open_misc(read): mapset <%s> doesn't match xmapset <%s>"
+msgstr ""
+#: ../lib/gis/open_misc.c:67
+#, c-format
+msgid "G__open_misc(write): xmapset <%s> != G_mapset() <%s>"
+msgstr ""
+#: ../lib/gis/get_datum_name.c:53
+#, c-format
+msgid ""
+"\n"
+"Please specify datum name\n"
+msgstr ""
+#: ../lib/gis/get_datum_name.c:55
+#, c-format
+msgid "Enter 'list' for the list of available datums\n"
+msgstr ""
+#: ../lib/gis/get_datum_name.c:57
+#, c-format
+msgid "or 'custom' if you wish to enter custom parameters\n"
+msgstr ""
+#: ../lib/gis/get_datum_name.c:97
+#, c-format
+msgid ""
+"\n"
+"invalid datum\n"
+msgstr ""
+#: ../lib/gis/debug.c:74
+#, c-format
+msgid "Cannot open debug file '%s'"
+msgstr ""
+#: ../lib/gis/null_val.c:91
+msgid "EmbedGivenNulls: wrong data type!"
+msgstr ""
+#: ../lib/gis/null_val.c:112
+msgid "Null values have not been initialized. "
+msgstr ""
+#: ../lib/gis/null_val.c:113
+msgid "G_gisinit() must be called first. "
+msgstr ""
+#: ../lib/gis/null_val.c:114
+msgid "Please advise GRASS developers of this error.\n"
+msgstr ""
+#: ../lib/gis/null_val.c:223
+msgid "G_set_null_value: wrong data type!"
+msgstr ""
+#: ../lib/gis/history.c:132 ../lib/g3d/g3dhistory.c:42
+#, c-format
+msgid "can't get history information for [%s] in mapset [%s]"
+msgstr ""
+#: ../lib/gis/history.c:180
+#, c-format
+msgid "can't write history information for [%s]"
+msgstr ""
+#: ../lib/gis/history.c:263
+msgid "Not enough room in history file to record command line."
+msgstr ""
+#: ../lib/gis/history.c:285
+msgid "Not enough room in history file for command line (truncated)."
+msgstr ""
+#: ../lib/gis/ls.c:96
+#, c-format
+msgid "Unable to open directory %s"
+msgstr ""
+#: ../lib/gis/myname.c:50
+msgid "This location has no description."
+msgstr ""
+#: ../lib/gis/put_title.c:29
+#, c-format
+msgid "category information for [%s] in [%s] missing or invalid"
+msgstr ""
+#: ../lib/gis/put_title.c:39
+#, c-format
+msgid "G_put_title - can't create a temp file"
+msgstr ""
+#: ../lib/gis/put_title.c:56
+#, c-format
+msgid "category information for [%s] in [%s] invalid"
+msgstr ""
+#: ../lib/gis/put_title.c:64
+#, c-format
+msgid "G_put_title - can't reopen temp file"
+msgstr ""
+#: ../lib/gis/put_title.c:72
+#, c-format
+msgid "can't write category information for [%s] in [%s]"
+msgstr ""
+#: ../lib/gis/alloc.c:43
+#, c-format
+msgid "G_malloc: unable to allocate %lu bytes at %s:%d"
+msgstr ""
+#: ../lib/gis/alloc.c:76
+#, c-format
+msgid "G_calloc: unable to allocate %lu * %lu bytes at %s:%d"
+msgstr ""
+#: ../lib/gis/alloc.c:114
+#, c-format
+msgid "G_realloc: unable to allocate %lu bytes at %s:%d"
+msgstr ""
+#: ../lib/gis/put_row.c:215
+#, c-format
+msgid "G_put_map_row: %s is not integer! Use G_put_[f/d]_raster_row()!"
+msgstr ""
+#: ../lib/gis/put_row.c:251
+#, c-format
+msgid "%s: map [%s] not open for write - request ignored"
+msgstr ""
+#: ../lib/gis/put_row.c:259
+#, c-format
+msgid "%s: map [%s] not open for random write - request ignored"
+msgstr ""
+#: ../lib/gis/put_row.c:266
+#, c-format
+msgid "%s: map [%s] not open for sequential write - request ignored"
+msgstr ""
+#: ../lib/gis/put_row.c:270
+#, c-format
+msgid "%s: unopened file descriptor - request ignored"
+msgstr ""
+#: ../lib/gis/put_row.c:310
+#, c-format
+msgid "map [%s] - unable to write row %d"
+msgstr ""
+#: ../lib/gis/put_row.c:393
+#, c-format
+msgid "xdr_float failed for index %d of row %d"
+msgstr ""
+#: ../lib/gis/put_row.c:419
+#, c-format
+msgid "xdr_double failed for index %d of row %d"
+msgstr ""
+#: ../lib/gis/put_row.c:754
+#, c-format
+msgid "unable to find a temporary null file %s"
+msgstr ""
+#: ../lib/gis/put_row.c:776 ../lib/gis/put_row.c:781
+#, c-format
+msgid "error writing null row %d"
+msgstr ""
+#: ../lib/gis/get_projname.c:31
+#, c-format
+msgid "%s not found"
+msgstr ""
+#: ../lib/gis/get_projname.c:34
+#, c-format
+msgid "ERROR in reading %s"
+msgstr ""
+#: ../lib/gis/get_projname.c:49
+#, c-format
+msgid ""
+"\n"
+"\n"
+"Please specify projection name\n"
+msgstr ""
+#: ../lib/gis/get_projname.c:51
+#, c-format
+msgid "Enter 'list' for the list of available projections\n"
+msgstr ""
+#: ../lib/gis/get_projname.c:74
+#, c-format
+msgid ""
+"\n"
+"invalid projection\n"
+msgstr ""
+#: ../lib/gis/quant_rw.c:206
+#, c-format
+msgid "Cannot write quant rules: map %s is integer"
+msgstr ""
+#: ../lib/gis/quant_rw.c:215
+#, c-format
+msgid "Cannot write quant rules for map %s"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:143
+msgid "duplicate projection field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:153
+msgid "duplicate zone field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:163
+msgid "projection field missing"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:165
+msgid "zone field missing"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:187
+msgid "duplicate north field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:195
+msgid "duplicate south field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:203
+msgid "duplicate east field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:211
+msgid "duplicate west field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:219
+msgid "duplicate top field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:227
+msgid "duplicate bottom field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:235
+msgid "duplicate e-w resolution field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:245
+msgid "duplicate 3D e-w resolution field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:255
+msgid "duplicate n-s resolution field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:265
+msgid "duplicate 3D n-s resolution field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:275
+msgid "duplicate t-b resolution field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:285
+msgid "duplicate rows field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:295
+msgid "duplicate 3D rows field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:305
+msgid "duplicate cols field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:315
+msgid "duplicate 3D cols field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:325
+msgid "duplicate depths field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:335
+msgid "duplicate format field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:343
+msgid "duplicate compressed field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:354
+msgid "north field missing"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:356
+msgid "south field missing"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:358
+msgid "west field missing"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:360
+msgid "east field missing"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:362
+msgid "cols field missing"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:364
+msgid "rows field missing"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:375
+msgid "ewres3 field missing"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:377
+msgid "nsres3 field missing"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:379
+msgid "cols3 field missing"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:381
+msgid "rows3 field missing"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:438
+#, c-format
+msgid "line %d: <%s>"
+msgstr ""
+#: ../lib/gis/put_cellhd.c:26
+#, c-format
+msgid "Unable to create header file for [%s]"
+msgstr ""
+#: ../lib/gis/reclass.c:145
+#, c-format
+msgid "Too many reclass categories for [%s in %s]"
+msgstr ""
+#: ../lib/gis/reclass.c:148
+#, c-format
+msgid "Illegal reclass format in header file for [%s in %s]"
+msgstr ""
+#: ../lib/gis/reclass.c:238
+msgid "Illegal reclass request"
+msgstr ""
+#: ../lib/gis/reclass.c:243
+msgid "Illegal reclass type"
+msgstr ""
+#: ../lib/gis/reclass.c:249
+#, c-format
+msgid "Unable to create header file for [%s in %s]"
+msgstr ""
+#: ../lib/gis/reclass.c:297
+#, c-format
+msgid "Unable to create dependency file in [%s in %s]"
+msgstr ""
+#: ../lib/gis/find_file.c:74
+#, c-format
+msgid "'%s/%s' was found in more mapsets (also found in <%s>)"
+msgstr ""
+#: ../lib/gis/find_file.c:82
+#, c-format
+msgid "Using <%s@%s>"
+msgstr ""
+#: ../lib/gis/view.c:177
+#, c-format
+msgid "Unable to open %s for writing"
+msgstr ""
+#: ../lib/gis/view.c:263 ../lib/gis/view.c:480
+#, c-format
+msgid "Unable to open %s for reading"
+msgstr ""
+#: ../lib/gis/view.c:466
+#, c-format
+msgid "GRASS window when view was saved:\n"
+msgstr ""
+#: ../lib/gis/view.c:546
+#, c-format
+msgid " Window saved in \"%s\" is completely outside of current GRASS window."
+msgstr ""
+#: ../lib/gis/view.c:550
+#, c-format
+msgid ""
+" Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
+msgstr ""
+#: ../lib/gis/open.c:62
+#, c-format
+msgid "G__open(read): mapset <%s> doesn't match xmapset <%s>"
+msgstr ""
+#: ../lib/gis/open.c:84
+#, c-format
+msgid "G__open(write): xmapset <%s> != G_mapset() <%s>"
+msgstr ""
+#: ../lib/gis/format.c:157
+#, c-format
+msgid "Fail of initial read of compressed file [%s in %s]"
+msgstr ""
+#: ../lib/gis/done_msg.c:38
+#, c-format
+msgid "%s complete. %s"
+msgstr ""
+#: ../lib/gis/raster_metadata.c:111
+#, c-format
+msgid "Can't read %s for [%s in %s]"
+msgstr ""
+#: ../lib/gis/raster_metadata.c:144
+#, c-format
+msgid "Can't create %s metadata file for [%s in %s]"
+msgstr ""
+#: ../lib/gis/env.c:242
+msgid "GISRC - variable not set"
+msgstr ""
+#: ../lib/gis/env.c:274
+#, c-format
+msgid "G_getenv(): Variable %s not set"
+msgstr ""
+#: ../lib/gis/env.c:300
+#, c-format
+msgid "%s not set"
+msgstr ""
+#: ../lib/gis/distance.c:160
+#, c-format
+msgid ""
+"G_distance_point_to_line_segment: shouldn't happen: code=%d P=(%f,%f) S=(%f,"
+"%f)(%f,%f)"
+msgstr ""
+#: ../lib/gis/gisinit.c:54 ../lib/gis/gisinit.c:90
+msgid ""
+"Incompatible library version for module. You need to rebuild GRASS or "
+"untangle multiple installations."
+msgstr ""
+#: ../lib/gis/gisinit.c:63
+#, c-format
+msgid "MAPSET %s - permission denied"
+msgstr ""
+#: ../lib/gis/gisinit.c:110
+msgid "System not initialized. Programmer forgot to call G_gisinit()."
+msgstr ""
+#: ../lib/gis/set_window.c:76
+msgid ""
+"G_set_window(): projection/zone differs from that of currently open raster "
+"maps"
+msgstr ""
+#: ../lib/gis/quant_io.c:89
+#, c-format
+msgid "The floating data range for %s@%s is empty"
+msgstr ""
+#: ../lib/gis/quant_io.c:99
+#, c-format
+msgid "The integer data range for %s@%s is empty"
+msgstr ""
+#: ../lib/gis/quant_io.c:168
+#, c-format
+msgid "quantization file [%s] in mapset [%s] %s"
+msgstr ""
+#: ../lib/gis/location.c:44
+#, c-format
+msgid "LOCATION << %s >> not available"
+msgstr ""
+#: ../lib/gis/make_colr.c:40
+#, c-format
+msgid " The raster map %s@%s is empty"
+msgstr ""
+#: ../lib/gis/make_colr.c:49
+#, c-format
+msgid ""
+"\n"
+"\n"
+"Color table needed for file [%s] in mapset [%s].\n"
+msgstr ""
+#: ../lib/gis/make_colr.c:52
+#, c-format
+msgid ""
+"\n"
+"Please identify the type desired:\n"
+msgstr ""
+#: ../lib/gis/make_colr.c:53
+#, c-format
+msgid "    1:  Random colors\n"
+msgstr ""
+#: ../lib/gis/make_colr.c:54
+#, c-format
+msgid "    2:  Red, green, and blue color ramps\n"
+msgstr ""
+#: ../lib/gis/make_colr.c:55
+#, c-format
+msgid "    3:  Color wave\n"
+msgstr ""
+#: ../lib/gis/make_colr.c:56
+#, c-format
+msgid "    4:  Gray scale\n"
+msgstr ""
+#: ../lib/gis/make_colr.c:57
+#, c-format
+msgid "    5:  Aspect\n"
+msgstr ""
+#: ../lib/gis/make_colr.c:58
+#, c-format
+msgid "    6:  Rainbow colors\n"
+msgstr ""
+#: ../lib/gis/make_colr.c:59
+#, c-format
+msgid "    7:  Red through yellow to green\n"
+msgstr ""
+#: ../lib/gis/make_colr.c:60
+#, c-format
+msgid "    8:  Green through yellow to red\n"
+msgstr ""
+#: ../lib/gis/make_colr.c:61
+#, c-format
+msgid "RETURN  quit\n"
+msgstr ""
+#: ../lib/gis/make_colr.c:91
+#, c-format
+msgid ""
+"\n"
+"%s invalid; Try again > "
+msgstr ""
+#: ../lib/gis/list.c:115
+#, c-format
+msgid "no %s files available in current mapset\n"
+msgstr ""
+#: ../lib/gis/list.c:118
+#, c-format
+msgid "no %s files available in mapset <%s>\n"
+msgstr ""
+#: ../lib/gis/list.c:133
+#, c-format
+msgid "hit RETURN to continue -->"
+msgstr ""
+#: ../lib/gis/list.c:184
+#, c-format
+msgid "%s files available in mapset <%s>:\n"
+msgstr ""
+#: ../lib/gis/list.c:255
+msgid "G_list: Unknown element type"
+msgstr ""
+#: ../lib/gis/opencell.c:105
+#, c-format
+msgid "Unable to open raster map <%s@%s>"
+msgstr ""
+#: ../lib/gis/opencell.c:171
+#, c-format
+msgid "Unable to find <%s@%s>"
+msgstr ""
+#: ../lib/gis/opencell.c:188
+#, c-format
+msgid ""
+"Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@"
+"%s> which does not exist"
+msgstr ""
+#: ../lib/gis/opencell.c:212
+#, c-format
+msgid "Raster map <%s@%s>: format field in header file invalid"
+msgstr ""
+#: ../lib/gis/opencell.c:219
+#, c-format
+msgid ""
+"Raster map <%s@%s> is in different projection than current region. Found "
+"raster map <%s@%s>, should be <%s>."
+msgstr ""
+#: ../lib/gis/opencell.c:226
+#, c-format
+msgid "Raster map <%s@%s> is in different zone (%d) than current region (%d)"
+msgstr ""
+#: ../lib/gis/opencell.c:233
+#, c-format
+msgid "Raster map <%s@%s>: bytes per cell (%d) too large"
+msgstr ""
+#: ../lib/gis/opencell.c:262
+#, c-format
+msgid "map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
+msgstr ""
+#: ../lib/gis/opencell.c:642
+#, c-format
+msgid "Raster map <%s> is not in the current mapset (%s)"
+msgstr ""
+#: ../lib/gis/opencell.c:649
+#, c-format
+msgid "<%s> is an illegal file name"
+msgstr ""
+#: ../lib/gis/opencell.c:655
+#, c-format
+msgid "<%s>: bad mapset"
+msgstr ""
+#: ../lib/gis/opencell.c:666 ../lib/gis/opencell.c:767
+msgid "G__open_raster_new(): no temp files available"
+msgstr ""
+#: ../lib/gis/opencell.c:736
+msgid ""
+"Unable to write embedded null values for raster map open for random access"
+msgstr ""
+#: ../lib/gis/opencell.c:941
+msgid "G_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
+msgstr ""
+#: ../lib/gis/opencell.c:976 ../lib/gis/opencell.c:1064
+#, c-format
+msgid "Unable to find '%s' in '%s'"
+msgstr ""
+#: ../lib/gis/opencell.c:1009
+#, c-format
+msgid "Raster map <%s> not found in mapset <%s>"
+msgstr ""
+#: ../lib/gis/opencell.c:1070
+#, c-format
+msgid "Unable to find '%s'"
+msgstr ""
+#: ../lib/gis/opencell.c:1075
+#, c-format
+msgid "Unable to open '%s'"
+msgstr ""
+#: ../lib/gis/opencell.c:1085
+#, c-format
+msgid "Invalid type: field '%s' in file '%s'"
+msgstr ""
+#: ../lib/gis/opencell.c:1099
+#, c-format
+msgid "Raster map <%s> is not xdr: byte_order: %s"
+msgstr ""
+#: ../lib/gis/opencell.c:1179
+msgid ""
+"G_set_quant_rules() can be called only for raster maps opened for reading"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:47 ../lib/gis/adj_cellhd.c:199
+msgid "Illegal n-s resolution value"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:51 ../lib/gis/adj_cellhd.c:205
+msgid "Illegal row value"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:55 ../lib/gis/adj_cellhd.c:211
+msgid "Illegal e-w resolution value"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:59 ../lib/gis/adj_cellhd.c:217
+msgid "Illegal col value"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:79 ../lib/gis/adj_cellhd.c:247
+#, c-format
+msgid "Fixing subtle input data rounding error of north boundary (%g>%g)"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:84 ../lib/gis/adj_cellhd.c:252
+msgid "Illegal latitude for North"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:90 ../lib/gis/adj_cellhd.c:258
+#, c-format
+msgid "Fixing subtle input data rounding error of south boundary (%g>%g)"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:95 ../lib/gis/adj_cellhd.c:263
+msgid "Illegal latitude for South"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:107 ../lib/gis/adj_cellhd.c:275
+#, c-format
+msgid "Fixing subtle input data rounding error of west boundary (%g>%g)"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:118 ../lib/gis/adj_cellhd.c:286
+#, c-format
+msgid "Fixing subtle input data rounding error of east boundary (%g>%g)"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:131 ../lib/gis/adj_cellhd.c:299
+msgid "North must be north of South"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:133 ../lib/gis/adj_cellhd.c:301
+msgid "North must be larger than South"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:136 ../lib/gis/adj_cellhd.c:304
+msgid "East must be larger than West"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:155 ../lib/gis/adj_cellhd.c:348
+msgid "Invalid coordinates"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:201
+msgid "Illegal n-s3 resolution value"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:207
+msgid "Illegal row3 value"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:213
+msgid "Illegal e-w3 resolution value"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:219
+msgid "Illegal col3 value"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:223
+msgid "Illegal t-b3 resolution value"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:227
+msgid "Illegal depths value"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:306
+msgid "Top must be larger than Bottom"
+msgstr ""
+#: ../lib/gis/error.c:257
+msgid "WARNING: "
+msgstr ""
+#: ../lib/gis/error.c:258
+msgid "ERROR: "
+msgstr ""
+#: ../lib/gis/gishelp.c:45
+#, c-format
+msgid "one moment...\n"
+msgstr ""
+#: ../lib/gis/gishelp.c:49
+#, c-format
+msgid "No help available for command [%s]\n"
+msgstr ""
+#: ../lib/gis/legal_name.c:39
+#, c-format
+msgid "Illegal filename.  Cannot be '.' or 'NULL'\n"
+msgstr ""
+#: ../lib/gis/legal_name.c:47
+#, c-format
+msgid "Illegal filename. Character <%c> not allowed.\n"
+msgstr ""
+#: ../lib/gis/legal_name.c:77 ../lib/gis/legal_name.c:81
+#, c-format
+msgid "Output raster map name <%s> is not valid map name"
+msgstr ""
+#: ../lib/gis/legal_name.c:118 ../lib/gis/legal_name.c:122
+#, c-format
+msgid "Output raster map <%s> is used as input"
+msgstr ""
+#: ../lib/gis/mapset_msc.c:60
+#, c-format
+msgid "Unable to make mapset element %s (%s): %s"
+msgstr ""
+#: ../lib/gis/mapset_msc.c:64
+#, c-format
+msgid "Unable to access mapset element %s (%s): %s"
+msgstr ""
+#: ../lib/gis/datum.c:160
+#, c-format
+msgid "unable to open datum table file: %s"
+msgstr ""
+#: ../lib/gis/datum.c:181
+#, c-format
+msgid "error in datum table file, line %d"
+msgstr ""
+#: ../lib/gis/home.c:39
+msgid "unable to determine user's home directory"
+msgstr ""
+#: ../lib/gis/parser.c:340
+msgid "WHERE conditions of SQL statement without 'where' keyword"
+msgstr ""
+#: ../lib/gis/parser.c:341
+msgid "Example: income < 1000 and inhab >= 10000"
+msgstr ""
+#: ../lib/gis/parser.c:349
+msgid "Table name"
+msgstr ""
+#: ../lib/gis/parser.c:358
+msgid "Driver name"
+msgstr ""
+#: ../lib/gis/parser.c:367
+msgid "Database name"
+msgstr ""
+#: ../lib/gis/parser.c:376
+msgid "Name of attribute column"
+msgstr ""
+#: ../lib/gis/parser.c:385
+msgid "Name of attribute column(s)"
+msgstr ""
+#: ../lib/gis/parser.c:396
+msgid "Name of input imagery group"
+msgstr ""
+#: ../lib/gis/parser.c:404
+msgid "Name of input imagery subgroup"
+msgstr ""
+#: ../lib/gis/parser.c:414 ../lib/gis/parser.c:439
+msgid "Name of input raster map"
+msgstr ""
+#: ../lib/gis/parser.c:423 ../lib/gis/parser.c:448
+msgid "Name of input raster map(s)"
+msgstr ""
+#: ../lib/gis/parser.c:431
+msgid "Name for output raster map"
+msgstr ""
+#: ../lib/gis/parser.c:456
+msgid "Name of base raster map"
+msgstr ""
+#: ../lib/gis/parser.c:464
+msgid "Name of cover raster map"
+msgstr ""
+#: ../lib/gis/parser.c:472
+msgid "Name of elevation raster map"
+msgstr ""
+#: ../lib/gis/parser.c:481
+msgid "Name of elevation raster map(s)"
+msgstr ""
+#: ../lib/gis/parser.c:491 ../lib/gis/parser.c:516
+msgid "Name of input raster3d map"
+msgstr ""
+#: ../lib/gis/parser.c:500 ../lib/gis/parser.c:525
+msgid "Name of input raster3d map(s)"
+msgstr ""
+#: ../lib/gis/parser.c:508
+msgid "Name for output raster3d map"
+msgstr ""
+#: ../lib/gis/parser.c:535 ../lib/gis/parser.c:560
+msgid "Name of input vector map"
+msgstr ""
+#: ../lib/gis/parser.c:544 ../lib/gis/parser.c:569
+msgid "Name of input vector map(s)"
+msgstr ""
+#: ../lib/gis/parser.c:552
+msgid "Name for output vector map"
+msgstr ""
+#: ../lib/gis/parser.c:578 ../lib/gis/parser.c:587
+msgid "Feature type"
+msgstr ""
+#: ../lib/gis/parser.c:594
+msgid "Layer number"
+msgstr ""
+#: ../lib/gis/parser.c:596
+msgid ""
+"A single vector map can be connected to multiple database tables. This "
+"number determines which table to use."
+msgstr ""
+#: ../lib/gis/parser.c:605
+msgid "Category value"
+msgstr ""
+#: ../lib/gis/parser.c:612
+msgid "Category values"
+msgstr ""
+#: ../lib/gis/parser.c:613 ../lib/gis/parser.c:627
+msgid "Example: 1,3,7-9,13"
+msgstr ""
+#: ../lib/gis/parser.c:619
+msgid "Feature id"
+msgstr ""
+#: ../lib/gis/parser.c:626
+msgid "Feature ids"
+msgstr ""
+#: ../lib/gis/parser.c:637
+msgid "Name of input file"
+msgstr ""
+#: ../lib/gis/parser.c:645
+msgid "Name for output file"
+msgstr ""
+#: ../lib/gis/parser.c:653
+msgid "Field separator"
+msgstr ""
+#: ../lib/gis/parser.c:664
+msgid "Color"
+msgstr ""
+#: ../lib/gis/parser.c:665
+msgid "Either a standard color name or R:G:B triplet"
+msgstr ""
+#: ../lib/gis/parser.c:674
+msgid "Background color"
+msgstr ""
+#: ../lib/gis/parser.c:676
+msgid "Either a standard GRASS color, R:G:B triplet, or \"none\""
+msgstr ""
+#: ../lib/gis/parser.c:817
+#, c-format
+msgid "BUG in descriptions, option '%s' in <%s> does not exist"
+msgstr ""
+#: ../lib/gis/parser.c:925
+msgid "Use either --quiet or --verbose flag, not both. Assuming --verbose."
+msgstr ""
+#: ../lib/gis/parser.c:939
+msgid "Use either --quiet or --verbose flag, not both. Assuming --quiet."
+msgstr ""
+#: ../lib/gis/parser.c:970
+#, c-format
+msgid "Sorry <%s> is not a valid option\n"
+msgstr ""
+#: ../lib/gis/parser.c:1074
+#, c-format
+msgid ""
+"\n"
+"Description:\n"
+msgstr ""
+#: ../lib/gis/parser.c:1081
+#, c-format
+msgid ""
+"\n"
+"Keywords:\n"
+msgstr ""
+#: ../lib/gis/parser.c:1085
+#, c-format
+msgid ""
+"\n"
+"Usage:\n"
+msgstr ""
+#: ../lib/gis/parser.c:1153
+#, c-format
+msgid ""
+"\n"
+"Flags:\n"
+msgstr ""
+#: ../lib/gis/parser.c:1176 ../lib/gis/parser.c:1500 ../lib/gis/parser.c:1660
+#: ../lib/gis/parser.c:1948
+msgid "Allow output files to overwrite existing files"
+msgstr ""
+#: ../lib/gis/parser.c:1178 ../lib/gis/parser.c:1508 ../lib/gis/parser.c:1664
+msgid "Verbose module output"
+msgstr ""
+#: ../lib/gis/parser.c:1179 ../lib/gis/parser.c:1515 ../lib/gis/parser.c:1667
+msgid "Quiet module output"
+msgstr ""
+#: ../lib/gis/parser.c:1184
+#, c-format
+msgid ""
+"\n"
+"Parameters:\n"
+msgstr ""
+#: ../lib/gis/parser.c:1207
+#, c-format
+msgid "  %*s   default: %s\n"
+msgstr ""
+#: ../lib/gis/parser.c:1551
+msgid "NAME"
+msgstr ""
+#: ../lib/gis/parser.c:1564
+msgid "KEYWORDS"
+msgstr ""
+#: ../lib/gis/parser.c:1569
+msgid "SYNOPSIS"
+msgstr ""
+#: ../lib/gis/parser.c:1637
+msgid "Flags"
+msgstr ""
+#: ../lib/gis/parser.c:1675
+msgid "Parameters"
+msgstr ""
+#: ../lib/gis/parser.c:1715
+msgid "Options"
+msgstr ""
+#: ../lib/gis/parser.c:1721
+msgid "Default"
+msgstr ""
+#: ../lib/gis/parser.c:1950
+msgid "Allow overwrite"
+msgstr ""
+#: ../lib/gis/parser.c:1958
+msgid "Run with minimal output messages"
+msgstr ""
+#: ../lib/gis/parser.c:1960
+msgid "Run quietly"
+msgstr ""
+#: ../lib/gis/parser.c:1993
+msgid "Unable to spawn the 'wish' program"
+msgstr ""
+#: ../lib/gis/parser.c:2012
+msgid "Unable to determine program name"
+msgstr ""
+#: ../lib/gis/parser.c:2069
+#, c-format
+msgid "  %*s   options: "
+msgstr ""
+#: ../lib/gis/parser.c:2114 ../lib/gis/parser.c:2129
+#, c-format
+msgid "Sorry, <%c> is not a valid flag\n"
+msgstr ""
+#: ../lib/gis/parser.c:2195
+#, c-format
+msgid "Sorry, <%s=> is ambiguous\n"
+msgstr ""
+#: ../lib/gis/parser.c:2201
+#, c-format
+msgid "Sorry, <%s> is not a valid parameter\n"
+msgstr ""
+#: ../lib/gis/parser.c:2208
+#, c-format
+msgid "Option <%s> does not accept multiple answers\n"
+msgstr ""
+#: ../lib/gis/parser.c:2286
+#, c-format
+msgid ""
+"\n"
+"ERROR: illegal range syntax for parameter <%s>\n"
+msgstr ""
+#: ../lib/gis/parser.c:2287
+#, c-format
+msgid "       Presented as: %s\n"
+msgstr ""
+#: ../lib/gis/parser.c:2291
+#, c-format
+msgid ""
+"\n"
+"ERROR: value <%s> out of range for parameter <%s>\n"
+msgstr ""
+#: ../lib/gis/parser.c:2293
+#, c-format
+msgid "       Legal range: %s\n"
+msgstr ""
+#: ../lib/gis/parser.c:2296
+#, c-format
+msgid ""
+"\n"
+"ERROR: Missing value for parameter <%s>\n"
+msgstr ""
+#: ../lib/gis/parser.c:2444
+#, c-format
+msgid ""
+"ERROR: Required parameter <%s> not set:\n"
+"\t(%s)\n"
+msgstr ""
+#: ../lib/gis/parser.c:2539
+#, c-format
+msgid ""
+"\n"
+"ERROR: option <%s> must be provided in multiples of %d\n"
+msgstr ""
+#: ../lib/gis/parser.c:2541
+#, c-format
+msgid "       You provided %d items:\n"
+msgstr ""
+#: ../lib/gis/parser.c:2597
+#, c-format
+msgid "ERROR: option <%s>: <%s> exists.\n"
+msgstr ""
+#: ../lib/gis/parser.c:2652
+#, c-format
+msgid ""
+"\n"
+"FLAG: Set the following flag?\n"
+msgstr ""
+#: ../lib/gis/parser.c:2666
+#, c-format
+msgid ""
+"\n"
+"OPTION:   %s\n"
+msgstr ""
+#: ../lib/gis/parser.c:2667
+#, c-format
+msgid "     key: %s\n"
+msgstr ""
+#: ../lib/gis/parser.c:2669
+#, c-format
+msgid "  format: %s\n"
+msgstr ""
+#: ../lib/gis/parser.c:2671
+#, c-format
+msgid " default: %s\n"
+msgstr ""
+#: ../lib/gis/parser.c:2672
+#, c-format
+msgid "required: %s\n"
+msgstr ""
+#: ../lib/gis/parser.c:2674
+#, c-format
+msgid "multiple: %s\n"
+msgstr ""
+#: ../lib/gis/parser.c:2676
+#, c-format
+msgid " options: %s\n"
+msgstr ""
+#: ../lib/gis/parser.c:2689
+#, c-format
+msgid "enter option > "
+msgstr ""
+#: ../lib/gis/parser.c:2706 ../lib/gis/parser.c:2716
+msgid "   Try again? "
+msgstr ""
+#: ../lib/gis/parser.c:2714
+#, c-format
+msgid "Sorry, %s is not accepted.\n"
+msgstr ""
+#: ../lib/gis/parser.c:2724
+#, c-format
+msgid ""
+"\n"
+"You have chosen:\n"
+"  %s\n"
+msgstr ""
+#: ../lib/gis/parser.c:2725
+msgid "Is this correct? "
+msgstr ""
+#: ../lib/gis/parser.c:2790
+msgid "to accept the default"
+msgstr ""
+#: ../lib/gis/seek.c:52 ../lib/gis/seek.c:58
+msgid "Unable to seek"
+msgstr ""
+#: ../lib/gis/seek.c:56
+msgid "Seek offset out of range"
+msgstr ""
+#: ../lib/display/tran_colr.c:129 ../lib/display/tran_colr.c:131
+#, c-format
+msgid "[%s]: No such color"
+msgstr ""
+#: ../lib/vask/V_support.c:60
+#, c-format
+msgid "Unable to open file %s"
+msgstr ""
+#: ../lib/init/lock.c:38
+#, c-format
+msgid "Usage: %s file pid"
+msgstr ""
+#: ../lib/init/lock.c:42
+msgid "Concurrent mapset locking is not supported on Windows"
+msgstr ""
+#: ../lib/init/lock.c:60
+#, c-format
+msgid "Unable to write lockfile %s (disk full? Permissions?)"
+msgstr ""
+#: ../lib/g3d/g3dparam.c:52
+msgid "Data type used in the output file"
+msgstr ""
+#: ../lib/g3d/g3dparam.c:61
+msgid "Precision used in the output file (default, max, or 0 to 52)"
+msgstr ""
+#: ../lib/g3d/g3dparam.c:71
+msgid "The compression method used in the output file"
+msgstr ""
+#: ../lib/g3d/g3dparam.c:81
+msgid "The dimensions of the tiles used in the output file"
+msgstr ""
+#: ../lib/g3d/g3dparam.c:116
+msgid "G3d_getStandard3dParams: precision value invalid"
+msgstr ""
+#: ../lib/g3d/g3dparam.c:149
+msgid "G3d_getStandard3dParams: tile dimension value invalid"
+msgstr ""
+#: ../lib/g3d/g3dparam.c:173
+msgid "Window replacing the default"
+msgstr ""
+#: ../lib/g3d/g3dopen.c:20
+msgid "G3d_openCellOldNoHeader: error in G3d_maskOpenOld"
+msgstr ""
+#: ../lib/g3d/g3dopen.c:26
+msgid "G3d_openCellOldNoHeader: error in G3d_malloc"
+msgstr ""
+#: ../lib/g3d/g3dopen.c:45
+msgid "G3d_openCellOldNoHeader: error in G_open_old"
+msgstr ""
+#: ../lib/g3d/g3dopen.c:99
+msgid "G3d_openCellOld: error in G3d_openCellOldNoHeader"
+msgstr ""
+#: ../lib/g3d/g3dopen.c:104
+msgid "G3d_openCellOld: can't rewind file"
+msgstr ""
+#: ../lib/g3d/g3dopen.c:116
+msgid "G3d_openCellOld: error in G3d_readHeader"
+msgstr ""
+#: ../lib/g3d/g3dopen.c:124
+msgid "G3d_openCellOld: projection does not match window projection"
+msgstr ""
+#: ../lib/g3d/g3dopen.c:128
+msgid "G3d_openCellOld: zone does not match window zone"
+msgstr ""
+#: ../lib/g3d/g3dopen.c:140 ../lib/g3d/g3dopen.c:157
+msgid "G3d_openCellOld: can't read header"
+msgstr ""
+#: ../lib/g3d/g3dopen.c:146
+msgid "G3d_openCellOld: index does not fit into long"
+msgstr ""
+#: ../lib/g3d/g3dopen.c:150
+msgid "G3d_openCellOld: error in G3d_malloc"
+msgstr ""
+#: ../lib/g3d/g3dopen.c:176
+msgid "G3d_openCellOld: error in G3d_fillHeader"
+msgstr ""
+#: ../lib/g3d/g3dopen.c:223
+msgid "G3d_openCellNew: error in G3d_maskOpenOld"
+msgstr ""
+#: ../lib/g3d/g3dopen.c:232
+msgid "G3d_openCellNew: error in G3d_malloc"
+msgstr ""
+#: ../lib/g3d/g3dopen.c:245
+msgid "G3d_openCellNew: could not open file"
+msgstr ""
+#: ../lib/g3d/g3dopen.c:290 ../lib/g3d/g3dopen.c:295
+msgid "G3d_openCellNew: can't write header"
+msgstr ""
+#: ../lib/g3d/g3dopen.c:318
+msgid "G3d_openCellNew: error in G3d_fillHeader"
+msgstr ""
+#: ../lib/arraystats/class.c:21
+msgid "Discont algorithm currently not available because of bugs"
+msgstr ""
+#: ../lib/arraystats/class.c:23
+#, c-format
+msgid "%s: Unknown algorithm"
+msgstr ""
+#: ../lib/arraystats/class.c:26
+#, c-format
+msgid "%s: Error in classification algorithm"
+msgstr ""
+#: ../lib/arraystats/class.c:221
+#, c-format
+msgid ""
+"There are classbreaks outside the range min-max. Number of classes reduced "
+"to %i, but using probabilities for %i classes."
+msgstr ""
+#: ../lib/raster/io_sock.c:63
+msgid "No graphics monitor has been selected for output."
+msgstr ""
+#: ../lib/raster/io_sock.c:64
+msgid "Please run \"d.mon\" to select a graphics monitor."
+msgstr ""
+#: ../lib/raster/io_sock.c:72
+#, c-format
+msgid "Failed to get socket name for monitor <%s>."
+msgstr ""
+#: ../lib/raster/io_sock.c:81
+#, c-format
+msgid "No socket to connect to for monitor <%s>."
+msgstr ""
+#: ../lib/raster/io_sock.c:98
+msgid "Socket is already in use or not accepting connections."
+msgstr ""
+#: ../lib/raster/io_sock.c:99
+msgid "Use d.mon to select a monitor"
+msgstr ""
+#: ../lib/raster/io_sock.c:105
+msgid "Trying to connect to something not a socket."
+msgstr ""
+#: ../lib/raster/io_sock.c:106
+msgid "Probably program error."
+msgstr ""
+#: ../lib/raster/io_sock.c:111
+msgid "Connect attempt timed out."
+msgstr ""
+#: ../lib/raster/io_sock.c:112
+msgid "Probably an error with the server."
+msgstr ""
+#: ../lib/raster/io_sock.c:120
+msgid "Connection failed."
+msgstr ""
+#: ../lib/raster/rem_io.c:40
+#, c-format
+msgid "ERROR %s from graphics driver.\n"
+msgstr ""
+#: ../lib/raster/rem_io.c:167
+#, c-format
+msgid "Unable to allocate memory\n"
+msgstr ""
+#: ../lib/raster/rem_io.c:217
+#, c-format
+msgid "ERROR - eof from graphics monitor.\n"
+msgstr ""
+#: ../lib/raster/rem_io.c:237
+#, c-format
+msgid "Warning - no response from graphics monitor <%s>.\n"
+msgstr ""
+#: ../lib/raster/rem_io.c:239
+#, c-format
+msgid "Check to see if the mouse is still active.\n"
+msgstr ""
+#: ../lib/raster/rem_io.c:244
+#, c-format
+msgid "ERROR - no response from graphics monitor <%s>.\n"
+msgstr ""
Added: grass/branches/releasebranch_6_4/locale/po/grassmods_nl.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_nl.po	                        (rev 0)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_nl.po	2012-06-19 22:28:16 UTC (rev 52142)
@@ -0,0 +1,32008 @@
+# SOME DESCRIPTIVE TITLE.
+# Copyright (C) YEAR THE PACKAGE'S COPYRIGHT HOLDER
+# This file is distributed under the same license as the PACKAGE package.
+# FIRST AUTHOR <EMAIL at ADDRESS>, YEAR.
+#, fuzzy
+msgid ""
+msgstr ""
+"Project-Id-Version: PACKAGE VERSION\n"
+"Report-Msgid-Bugs-To: \n"
+"POT-Creation-Date: 2012-06-19 23:46+0200\n"
+"PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
+"Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
+"Language-Team: LANGUAGE <LL at li.org>\n"
+"Language: \n"
+"MIME-Version: 1.0\n"
+"Content-Type: text/plain; charset=CHARSET\n"
+"Content-Transfer-Encoding: 8bit\n"
+#: ../db/base/execute.c:61 ../db/base/databases.c:52 ../db/base/tables.c:46
+#: ../db/base/dropdb.c:43 ../db/base/describe.c:52 ../db/base/createdb.c:43
+#: ../db/base/droptable.c:44 ../db/base/columns.c:45 ../db/base/select.c:67
+#: ../vector/v.extract/main.c:286 ../vector/v.edit/select.c:513
+#: ../vector/v.db.connect/main.c:212 ../vector/v.db.connect/main.c:278
+#: ../vector/v.out.vtk/writeVTK.c:634 ../vector/v.in.sites/main.c:158
+#: ../vector/v.out.svg/main.c:141 ../vector/v.drape/main.c:288
+#: ../vector/v.out.ogr/main.c:629 ../vector/v.out.ascii/b2a.c:45
+#: ../doc/vector/v.example/main.c:123 ../display/d.vect/main.c:470
+#: ../display/d.thematic.area/main.c:231
+#, c-format
+msgid "Unable to start driver <%s>"
+msgstr ""
+#: ../db/base/execute.c:68 ../db/base/tables.c:51 ../db/base/describe.c:57
+#: ../db/base/select.c:73 ../vector/v.convert/att.c:73
+#: ../display/d.vect/main.c:475 ../display/d.thematic.area/main.c:236
+#, c-format
+msgid "Unable to open database <%s>"
+msgstr ""
+#: ../db/base/execute.c:78 ../db/base/execute.c:86
+#, c-format
+msgid "Error while executing: '%s'"
+msgstr ""
+#: ../db/base/execute.c:112 ../db/base/copy.c:37 ../db/base/select.c:255
+msgid "database, attribute table, SQL"
+msgstr ""
+#: ../db/base/execute.c:113
+msgid "Executes any SQL statement."
+msgstr ""
+#: ../db/base/execute.c:117
+msgid "Name of file containing SQL statements"
+msgstr ""
+#: ../db/base/execute.c:118 ../vector/v.to.db/parse.c:47
+#: ../vector/v.to.db/parse.c:99
+msgid "Query"
+msgstr ""
+#: ../db/base/execute.c:119
+msgid "If not given or '-' read from standard input"
+msgstr ""
+#: ../db/base/execute.c:123 ../db/base/execute.c:128
+#: ../vector/v.in.db/main.c:63 ../vector/v.in.db/main.c:67
+msgid "Connection"
+msgstr ""
+#: ../db/base/execute.c:134
+msgid "Ignore SQL errors and continue"
+msgstr ""
+#: ../db/base/databases.c:56
+msgid "Unable to list databases"
+msgstr ""
+#: ../db/base/databases.c:85
+msgid "Location name"
+msgstr ""
+#: ../db/base/databases.c:90 ../db/base/dropdb.c:71 ../db/base/createdb.c:71
+#: ../db/base/droptable.c:78
+msgid "database, SQL"
+msgstr ""
+#: ../db/base/databases.c:92
+msgid "List all databases for a given driver and location."
+msgstr ""
+#: ../db/base/copy.c:38
+msgid "Copy a table."
+msgstr ""
+#: ../db/base/copy.c:40
+msgid ""
+"Either 'from_table' (optionally with 'where') can be used or 'select' "
+"option, but not 'from_table' and 'select' at the same time."
+msgstr ""
+#: ../db/base/copy.c:46
+msgid "Input driver name"
+msgstr ""
+#: ../db/base/copy.c:52
+msgid "Input database name"
+msgstr ""
+#: ../db/base/copy.c:59
+msgid "Input table name (only, if 'select' is not used)"
+msgstr ""
+#: ../db/base/copy.c:65
+msgid "Output driver name"
+msgstr ""
+#: ../db/base/copy.c:71
+msgid "Output database name"
+msgstr ""
+#: ../db/base/copy.c:78
+msgid "Output table name"
+msgstr ""
+#: ../db/base/copy.c:87
+msgid "Full select statement (only, if 'from_table' and 'where' is not used)"
+msgstr ""
+#: ../db/base/copy.c:88
+msgid "E.g.: SELECT dedek FROM starobince WHERE obec = 'Frimburg'"
+msgstr ""
+#: ../db/base/copy.c:96
+msgid "Cannot combine 'from_table' and 'select' options"
+msgstr ""
+#: ../db/base/copy.c:114
+msgid "Either 'from_table' or 'select' option must be given."
+msgstr ""
+#: ../db/base/copy.c:117
+msgid "Cannot combine 'select' and 'where' options"
+msgstr ""
+#: ../db/base/copy.c:127
+msgid "Copy table failed"
+msgstr ""
+#: ../db/base/tables.c:87
+msgid "Print tables and exit"
+msgstr ""
+#: ../db/base/tables.c:91
+msgid "System tables instead of user tables"
+msgstr ""
+#: ../db/base/tables.c:95 ../db/base/describe.c:125 ../db/base/columns.c:92
+#: ../db/base/drivers.c:73 ../locale/scriptstrings/db.out.ogr_to_translate.c:2
+#: ../locale/scriptstrings/db.dropcol_to_translate.c:2
+#: ../locale/scriptstrings/db.droptable_to_translate.c:2
+#: ../locale/scriptstrings/db.test_to_translate.c:2
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:2
+msgid "database, attribute table"
+msgstr ""
+#: ../db/base/tables.c:96
+msgid "Lists all tables for a given database."
+msgstr ""
+#: ../db/base/dropdb.c:72
+msgid "Removes a database."
+msgstr ""
+#: ../db/base/describe.c:63 ../vector/v.in.ascii/in.c:408
+#: ../vector/v.db.connect/main.c:223 ../vector/v.out.vtk/writeVTK.c:643
+#: ../vector/v.info/main.c:222 ../vector/v.out.svg/main.c:154
+#: ../vector/v.drape/main.c:299 ../vector/v.out.ogr/main.c:639
+#: ../vector/v.patch/main.c:139 ../vector/v.patch/main.c:177
+#: ../vector/v.random/main.c:214 ../doc/vector/v.example/main.c:134
+#, c-format
+msgid "Unable to describe table <%s>"
+msgstr ""
+#: ../db/base/describe.c:104
+msgid "Print column names only instead of full column descriptions"
+msgstr ""
+#: ../db/base/describe.c:109
+msgid "Print table structure"
+msgstr ""
+#: ../db/base/describe.c:126
+msgid "Describes a table in detail."
+msgstr ""
+#: ../db/base/createdb.c:72
+msgid "Creates an empty database."
+msgstr ""
+#: ../db/base/connect.c:45
+msgid "database, attribute table, connection settings"
+msgstr ""
+#: ../db/base/connect.c:47
+msgid "Prints/sets general DB connection for current mapset and exits."
+msgstr ""
+#: ../db/base/connect.c:51
+msgid "Print current connection parameters and exit"
+msgstr ""
+#: ../db/base/connect.c:52 ../general/g.mapsets/main.c:98
+#: ../general/g.mapsets/main.c:103 ../general/g.region/main.c:89
+#: ../general/g.region/main.c:95 ../general/g.region/main.c:100
+#: ../general/g.region/main.c:106 ../general/g.region/main.c:112
+#: ../general/g.region/main.c:118 ../general/g.region/main.c:124
+#: ../general/g.region/main.c:132 ../general/g.region/main.c:137
+#: ../general/g.region/main.c:143 ../general/g.region/main.c:148
+#: ../general/g.proj/main.c:63 ../general/g.proj/main.c:69
+#: ../general/g.proj/main.c:75 ../general/g.proj/main.c:81
+#: ../general/g.proj/main.c:86 ../general/g.proj/main.c:92
+#: ../general/g.mlist/main.c:140 ../general/g.mlist/main.c:145
+#: ../general/g.mlist/main.c:150 ../general/g.mlist/main.c:155
+#: ../general/g.mapset/main.c:87
+#: ../locale/scriptstrings/g.extension_to_translate.c:9
+#: ../imagery/i.group/main.c:77 ../imagery/i.group/main.c:83
+#: ../vector/v.db.connect/main.c:81 ../vector/v.db.connect/main.c:86
+#: ../vector/v.db.connect/main.c:94 ../vector/v.db.connect/main.c:110
+#: ../vector/v.info/main.c:75 ../vector/v.info/main.c:81
+#: ../vector/v.info/main.c:86 ../vector/v.info/main.c:91
+#: ../vector/v.info/main.c:96 ../vector/v.to.db/parse.c:104
+#: ../vector/v.to.db/parse.c:109 ../vector/v.to.db/parse.c:115
+#: ../raster/r.external/main.c:571 ../raster/r.in.gdal/main.c:145
+#: ../raster/r.stats/main.c:147 ../raster/r.stats/main.c:152
+#: ../raster/r.stats/main.c:157 ../raster/r.stats/main.c:163
+#: ../raster/r.stats/main.c:168 ../raster/r.stats/main.c:173
+#: ../raster/r.stats/main.c:178 ../raster/r.stats/main.c:183
+#: ../raster/r.sunmask/main.c:232 ../raster/r.sunmask/main.c:238
+#: ../raster/r.out.gdal/main.c:133
+msgid "Print"
+msgstr ""
+#: ../db/base/connect.c:57
+msgid "Check connection parameters, set if uninitialized, and exit"
+msgstr ""
+#: ../db/base/connect.c:62 ../db/base/connect.c:66 ../db/base/connect.c:77
+#: ../db/base/connect.c:87 ../general/g.mapset/main.c:58
+#: ../general/g.mapset/main.c:66 ../general/g.mapset/main.c:76
+#: ../imagery/i.landsat.toar/main.c:148 ../imagery/i.landsat.toar/main.c:156
+#: ../imagery/i.landsat.toar/main.c:165 ../imagery/i.landsat.toar/main.c:173
+#: ../imagery/i.landsat.toar/main.c:181 ../imagery/i.landsat.toar/main.c:191
+#: ../imagery/i.cluster/main.c:105 ../imagery/i.cluster/main.c:121
+#: ../imagery/i.cluster/main.c:129 ../imagery/i.cluster/main.c:138
+#: ../imagery/i.cluster/main.c:146 ../imagery/i.cluster/main.c:154
+#: ../vector/v.surf.idw/main.c:115 ../vector/v.surf.idw/main.c:123
+#: ../vector/v.surf.idw/main.c:131 ../vector/v.db.connect/main.c:60
+#: ../vector/v.db.connect/main.c:65
+#: ../vector/lidar/v.lidar.edgedetection/main.c:99
+#: ../vector/lidar/v.lidar.edgedetection/main.c:108
+#: ../vector/lidar/v.lidar.edgedetection/main.c:117
+#: ../vector/lidar/v.lidar.edgedetection/main.c:126
+#: ../vector/lidar/v.lidar.edgedetection/main.c:135
+#: ../vector/lidar/v.lidar.edgedetection/main.c:143
+#: ../vector/lidar/v.lidar.edgedetection/main.c:152
+#: ../vector/lidar/v.surf.bspline/main.c:120
+#: ../vector/lidar/v.surf.bspline/main.c:129
+#: ../vector/lidar/v.surf.bspline/main.c:138
+#: ../vector/lidar/v.surf.bspline/main.c:146
+#: ../vector/lidar/v.surf.bspline/main.c:153
+#: ../vector/lidar/v.surf.bspline/main.c:160 ../vector/v.vol.rst/main.c:261
+#: ../vector/v.vol.rst/main.c:269 ../vector/v.vol.rst/main.c:277
+#: ../vector/v.vol.rst/main.c:310 ../vector/v.vol.rst/main.c:319
+#: ../vector/v.vol.rst/main.c:328 ../vector/v.vol.rst/main.c:337
+#: ../vector/v.vol.rst/main.c:346 ../vector/v.vol.rst/main.c:354
+#: ../raster/r.in.bin/main.c:251 ../raster/r.in.bin/main.c:256
+#: ../raster/r.in.bin/main.c:285 ../raster/r.in.bin/main.c:346
+#: ../raster/r.slope.aspect/main.c:179 ../raster/r.slope.aspect/main.c:189
+#: ../raster/r.slope.aspect/main.c:247 ../raster/r.slope.aspect/main.c:256
+#: ../raster/r.slope.aspect/main.c:267 ../raster/r.resamp.rst/main.c:231
+#: ../raster/r.resamp.rst/main.c:239 ../raster/r.resamp.rst/main.c:247
+#: ../raster/r.resamp.rst/main.c:255 ../raster/r.resamp.rst/main.c:263
+msgid "Settings"
+msgstr ""
+#: ../db/base/connect.c:74
+msgid "Database schema"
+msgstr ""
+#: ../db/base/connect.c:75
+msgid ""
+"Do not use this option if schemas are not supported by driver/database server"
+msgstr ""
+#: ../db/base/connect.c:85
+msgid "Default group of database users to which select privilege is granted"
+msgstr ""
+#: ../db/base/connect.c:121
+msgid "Database connection not defined. Run db.connect."
+msgstr ""
+#: ../db/base/connect.c:141
+#, c-format
+msgid ""
+"Default driver / database set to:\n"
+"driver: %s\n"
+"database: %s"
+msgstr ""
+#: ../db/base/connect.c:148
+msgid "Default driver is not set"
+msgstr ""
+#: ../db/base/connect.c:151
+msgid "Default database is not set"
+msgstr ""
+#: ../db/base/droptable.c:79
+msgid "Removes a table from database."
+msgstr ""
+#: ../db/base/columns.c:93
+msgid "List all columns for a given table."
+msgstr ""
+#: ../db/base/drivers.c:41
+msgid "Error trying to read dbmscap file"
+msgstr ""
+#: ../db/base/drivers.c:65
+msgid "Full output"
+msgstr ""
+#: ../db/base/drivers.c:69
+msgid "Print drivers and exit"
+msgstr ""
+#: ../db/base/drivers.c:74
+msgid "Lists all database drivers."
+msgstr ""
+#: ../db/base/select.c:93
+#, c-format
+msgid "Test %s."
+msgstr ""
+#: ../db/base/select.c:93 ../imagery/i.rectify/report.c:10
+#: ../imagery/i.ortho.photo/i.photo.rectify/report.c:10
+msgid "failed"
+msgstr ""
+msgid "succeeded"
+msgstr ""
+#: ../db/base/select.c:130 ../vector/v.db.select/main.c:111
+#: ../raster/r.univar2/r.univar_main.c:110
+#: ../raster/r.univar2/r3.univar_main.c:123
+#: ../raster/r.regression.line/main.c:75 ../raster/r.stats/main.c:208
+#, c-format
+msgid "Unable to open file <%s> for writing"
+msgstr ""
+#: ../db/base/select.c:205
+msgid "SQL select statement"
+msgstr ""
+#: ../db/base/select.c:207
+msgid "For example: 'select * from rybniky where kapri = 'hodne'"
+msgstr ""
+#: ../db/base/select.c:211
+msgid "Name of file with sql statement"
+msgstr ""
+#: ../db/base/select.c:214 ../locale/scriptstrings/r.tileset_to_translate.c:13
+#: ../vector/v.db.select/main.c:64 ../raster/r.stats/main.c:119
+#: ../raster/r.distance/parse.c:50 ../raster/r.cats/main.c:72
+msgid "Output field separator"
+msgstr ""
+#: ../db/base/select.c:215 ../db/base/select.c:221 ../db/base/select.c:228
+#: ../db/base/select.c:238 ../db/base/select.c:247
+#: ../vector/v.db.select/main.c:65 ../vector/v.db.select/main.c:71
+#: ../vector/v.db.select/main.c:78 ../vector/v.db.select/main.c:94
+#: ../vector/v.db.select/main.c:99
+msgid "Format"
+msgstr ""
+#: ../db/base/select.c:219 ../vector/v.db.select/main.c:69
+msgid "Output vertical record separator"
+msgstr ""
+#: ../db/base/select.c:227 ../vector/v.db.select/main.c:77
+msgid "Null value indicator"
+msgstr ""
+#: ../db/base/select.c:233 ../locale/scriptstrings/r.out.xyz_to_translate.c:4
+#: ../vector/v.db.select/main.c:84 ../raster/r.univar2/r.univar_main.c:42
+#: ../raster/r.univar2/r3.univar_main.c:43 ../raster/r.stats/main.c:114
+msgid "Name for output file (if omitted or \"-\" output to stdout)"
+msgstr ""
+#: ../db/base/select.c:237 ../vector/v.db.select/main.c:93
+msgid "Do not include column names in output"
+msgstr ""
+#: ../db/base/select.c:242
+msgid "Describe query only (don't run it)"
+msgstr ""
+#: ../db/base/select.c:246 ../vector/v.db.select/main.c:98
+msgid "Vertical output (instead of horizontal)"
+msgstr ""
+#: ../db/base/select.c:251
+msgid "Only test query, do not execute"
+msgstr ""
+#: ../db/base/select.c:256
+msgid "Selects data from attribute table (performs SQL query statement(s))."
+msgstr ""
+#: ../db/db.login/main.c:43
+msgid "database, connection settings"
+msgstr ""
+#: ../db/db.login/main.c:44
+msgid "Sets user/password for driver/database."
+msgstr ""
+#: ../db/db.login/main.c:60
+msgid "Username"
+msgstr ""
+#: ../db/db.login/main.c:67
+msgid "Password"
+msgstr ""
+#: ../db/db.login/main.c:83
+#, c-format
+msgid ""
+"\n"
+"Enter database password for connection\n"
+"<%s:%s:user=%s>\n"
+msgstr ""
+#: ../db/db.login/main.c:85
+#, c-format
+msgstr ""
+#: ../db/db.login/main.c:93
+msgid "Exiting. Not changing current settings"
+msgstr ""
+#: ../db/db.login/main.c:97
+msgid "New password set"
+msgstr ""
+#: ../db/db.login/main.c:106
+msgid "Unable to set user/password"
+msgstr ""
+#: ../db/db.login/main.c:110
+msgid "The password was stored in file"
+msgstr ""
+#: ../db/drivers/postgres/parse.c:55 ../db/drivers/mysql/parse.c:71
+msgid "'user' in database definition is not supported, use db.login"
+msgstr ""
+#: ../db/drivers/postgres/parse.c:59 ../db/drivers/mysql/parse.c:75
+msgid "'password' in database definition is not supported, use db.login"
+msgstr ""
+#: ../db/drivers/postgres/parse.c:63
+msgid "Unknown option in database definition for PostgreSQL: "
+msgstr ""
+#: ../db/drivers/postgres/describe.c:103
+#, c-format
+msgid "pg driver: PostGIS column '%s', type 'geometry'  will not be converted"
+msgstr ""
+#: ../db/drivers/postgres/describe.c:109
+#, c-format
+msgid "pg driver: column '%s', type %d  is not supported"
+msgstr ""
+#: ../db/drivers/postgres/describe.c:116
+#, c-format
+msgid ""
+"column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data "
+"may be damaged"
+msgstr ""
+#: ../db/drivers/postgres/describe.c:120
+#, c-format
+msgid ""
+"column '%s' : type character varying is stored as varchar(250) some data may "
+"be lost"
+msgstr ""
+#: ../db/drivers/postgres/describe.c:126
+#, c-format
+msgid ""
+"column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 "
+"(true)"
+msgstr ""
+#: ../db/drivers/postgres/fetch.c:172
+msgid "Cannot recognize boolean value"
+msgstr ""
+#: ../db/drivers/sqlite/describe.c:160
+#, c-format
+msgid "SQLite driver: column '%s', SQLite type %d  is not supported"
+msgstr ""
+#: ../db/drivers/sqlite/db.c:85
+msgid "Unable to open database: "
+msgstr ""
+#: ../db/drivers/sqlite/db.c:110
+msgid "SQLite database connection is still busy"
+msgstr ""
+#: ../db/drivers/ogr/describe.c:94
+#, c-format
+msgid "OGR driver: column '%s', OGR type %d  is not supported"
+msgstr ""
+#: ../db/drivers/ogr/describe.c:157
+#, c-format
+msgid ""
+"column '%s', type 'string': unknown width -> stored as varchar(250) some "
+"data may be lost"
+msgstr ""
+#: ../db/drivers/ogr/describe.c:165 ../db/drivers/ogr/fetch.c:132
+msgid "Unknown type"
+msgstr ""
+#: ../db/drivers/mysql/parse.c:60
+msgid "Wrong port number in MySQL database definition: "
+msgstr ""
+#: ../db/drivers/mysql/parse.c:79
+msgid "Unknown option in database definition for "
+msgstr ""
+#: ../db/drivers/mysql/describe.c:120
+#, c-format
+msgid "MySQL driver: column '%s', type %d is not supported"
+msgstr ""
+#: ../db/drivers/mysql/describe.c:126
+#, c-format
+msgid ""
+"column '%s' : type BIGINT is stored as integer (4 bytes) some data may be "
+"damaged"
+msgstr ""
+#: ../db/drivers/mysql/db.c:67
+msgid "Cannot connect to MySQL: "
+msgstr ""
+#: ../db/drivers/mysql/db.c:83
+msgid "Cannot parse MySQL embedded database name"
+msgstr ""
+#: ../db/drivers/mysql/db.c:99
+msgid "Cannot initialize MySQL embedded server"
+msgstr ""
+#: ../db/drivers/mysql/db.c:118
+msgid "Cannot connect to MySQL embedded server: "
+msgstr ""
+#: ../db/drivers/mysql/cursor.c:46
+msgid "Cannot allocate cursor."
+msgstr ""
+#: ../db/drivers/mysql/cursor.c:55
+msgid "Cannot ad new token."
+msgstr ""
+#: ../db/drivers/mysql/listtab.c:36
+msgid "Cannot get list of tables:\n"
+msgstr ""
+#: ../db/drivers/mysql/error.c:29
+msgid "DBMI-MySQL driver error:\n"
+msgstr ""
+#: ../db/drivers/mysql/fetch.c:34
+msgid "Cursor not found"
+msgstr ""
+#: ../db/drivers/mysql/fetch.c:52
+msgid "Cursor position is not supported by MySQL driver"
+msgstr ""
+#: ../db/drivers/mysql/fetch.c:190
+msgid "Cannot scan timestamp: "
+msgstr ""
+#: ../db/drivers/mysql/fetch.c:198
+msgid "Unknown timestamp format: "
+msgstr ""
+#: ../db/drivers/mysql/fetch.c:212
+msgid "Cannot scan date: "
+msgstr ""
+#: ../db/drivers/mysql/fetch.c:225
+msgid "Cannot scan time: "
+msgstr ""
+#: ../db/drivers/mysql/fetch.c:240
+msgid "Cannot scan datetime: "
+msgstr ""
+#: ../db/drivers/mysql/select.c:43
+msgid "Cannot select data: \n"
+msgstr ""
+#: ../general/g.mremove/read_list.c:144 ../general/g.mlist/read_list.c:144
+#, c-format
+msgid ""
+"Format error: <%s>\n"
+"Line: %d\n"
+"%s"
+msgstr ""
+#: ../general/g.mremove/check_reclass.c:14 ../general/manage/cmd/remove.c:38
+#, c-format
+msgid "[%s@%s] is a base map for [%s]. Remove forced."
+msgstr ""
+#: ../general/g.mremove/check_reclass.c:18 ../general/manage/cmd/remove.c:41
+#, c-format
+msgid "[%s@%s] is a base map. Remove reclassed map first: %s"
+msgstr ""
+#: ../general/g.mremove/check_reclass.c:41
+#: ../general/g.mremove/check_reclass.c:55 ../general/manage/cmd/remove.c:63
+#: ../general/manage/cmd/remove.c:76
+#, c-format
+msgid "Removing information about reclassed map from [%s@%s] failed"
+msgstr ""
+#: ../general/g.mremove/do_remove.c:21
+#, c-format
+msgid "Removing %s <%s>"
+msgstr ""
+#: ../general/g.mremove/do_remove.c:34 ../general/g.region/main.c:545
+#: ../misc/m.nviz.image/vector.c:81 ../vector/v.kernel/main.c:274
+#: ../vector/v.kcv/main.c:132 ../vector/v.extract/main.c:193
+#: ../vector/v.segment/main.c:99 ../vector/v.edit/main.c:145
+#: ../vector/v.lrs/v.lrs.where/main.c:127
+#: ../vector/v.lrs/v.lrs.where/main.c:135
+#: ../vector/v.lrs/v.lrs.create/main.c:249
+#: ../vector/v.lrs/v.lrs.create/main.c:256
+#: ../vector/v.lrs/v.lrs.segment/main.c:138
+#: ../vector/v.lrs/v.lrs.label/main.c:286 ../vector/v.sample/main.c:152
+#: ../vector/v.reclass/main.c:107 ../vector/v.univar/main.c:131
+#: ../vector/v.db.connect/main.c:140 ../vector/v.hull/main.c:300
+#: ../vector/v.net/main.c:143 ../vector/v.net/main.c:158
+#: ../vector/v.clean/main.c:241 ../vector/v.net.alloc/main.c:143
+#: ../vector/v.info/main.c:103 ../vector/v.net.salesman/main.c:171
+#: ../vector/v.to.points/main.c:244 ../vector/v.net.steiner/main.c:428
+#: ../vector/v.to.db/parse.c:128 ../vector/v.qcount/main.c:128
+#: ../vector/v.db.select/main.c:132 ../vector/v.extrude/main.c:144
+#: ../vector/v.generalize/main.c:289 ../vector/v.buffer/main.c:365
+#: ../vector/v.convert/att.c:30 ../vector/v.convert/old2new.c:26
+#: ../vector/v.out.pov/main.c:96 ../vector/v.what.rast/main.c:119
+#: ../vector/v.out.svg/main.c:127 ../vector/v.drape/main.c:261
+#: ../vector/v.voronoi/vo_main.c:158 ../vector/v.voronoi/dt_main.c:77
+#: ../vector/v.out.dxf/main.c:69 ../vector/v.to.rast/vect2rast.c:37
+#: ../vector/v.out.ogr/main.c:196 ../vector/v.build.polylines/main.c:139
+#: ../vector/lidar/v.lidar.correction/main.c:182
+#: ../vector/lidar/v.outlier/main.c:156
+#: ../vector/lidar/v.lidar.growing/main.c:129
+#: ../vector/lidar/v.lidar.edgedetection/main.c:217
+#: ../vector/lidar/v.surf.bspline/main.c:219
+#: ../vector/lidar/v.surf.bspline/main.c:278 ../vector/v.surf.rst/main.c:565
+#: ../vector/v.class/main.c:95 ../vector/v.perturb/main.c:154
+#: ../vector/v.label/main.c:270 ../vector/v.overlay/main.c:204
+#: ../vector/v.select/main.c:103 ../vector/v.normal/main.c:128
+#: ../vector/v.buffer2/main.c:310 ../vector/v.category/main.c:197
+#: ../vector/v.distance/main.c:303 ../vector/v.transform/main.c:242
+#: ../vector/v.what/main.c:151 ../vector/v.type/main.c:202
+#: ../vector/v.net.iso/main.c:181 ../vector/v.net.path/main.c:131
+#: ../vector/v.label.sa/labels.c:60 ../vector/v.delaunay2/main.c:117
+#: ../doc/vector/v.example/main.c:73 ../display/d.what.vect/main.c:148
+#: ../display/d.extend/main.c:97 ../display/d.extract/main.c:98
+#: ../display/d.vect.chart/main.c:246 ../display/d.vect/main.c:451
+#: ../display/d.path/main.c:193 ../display/d.zoom/main.c:245
+#: ../display/d.thematic.area/main.c:212 ../raster/r.region/main.c:237
+#: ../raster/r.cost/main.c:301 ../raster/r.drain/main.c:202
+#: ../raster/r.carve/main.c:172
+#, c-format
+msgid "Vector map <%s> not found"
+msgstr ""
+#: ../general/g.mremove/do_remove.c:42 ../general/g.mremove/do_remove.c:84
+msgid "couldn't be removed"
+msgstr ""
+#: ../general/g.mremove/do_remove.c:50 ../general/g.region/main.c:477
+#: ../general/g.region/main.c:820 ../general/g.region/main.c:828
+#: ../ps/ps.map/outl_io.c:68 ../misc/m.nviz.image/surface.c:51
+#: ../misc/m.nviz.image/surface.c:108 ../visualization/xganim/main.c:366
+#: ../imagery/i.zc/main.c:111 ../imagery/i.gensigset/parse.c:42
+#: ../imagery/i.landsat.acca/algorithm.c:387
+#: ../imagery/i.landsat.acca/tools.c:127 ../imagery/i.landsat.acca/main.c:58
+#: ../imagery/i.gensig/parse.c:36 ../imagery/i.topo.corr/main.c:34
+#: ../imagery/i.group/main.c:201 ../imagery/i.group/main.c:240
+#: ../imagery/i.fft/fftmain.c:108 ../imagery/i.landsat.toar/main.c:347
+#: ../imagery/i.landsat.toar/main.c:481 ../imagery/i.pca/main.c:136
+#: ../imagery/i.rgb.his/openfiles.c:14 ../imagery/i.rgb.his/openfiles.c:16
+#: ../imagery/i.rgb.his/openfiles.c:18
+#: ../imagery/i.ortho.photo/i.photo.2target/main.c:197
+#: ../imagery/i.ortho.photo/i.photo.2target/main.c:227
+#: ../imagery/i.his.rgb/openfiles.c:31 ../imagery/i.his.rgb/openfiles.c:36
+#: ../imagery/i.his.rgb/openfiles.c:41 ../imagery/i.class/main.c:127
+#: ../imagery/i.ifft/ifftmain.c:95 ../imagery/i.ifft/ifftmain.c:105
+#: ../imagery/i.modis.qc/main.c:217 ../vector/v.sample/main.c:158
+#: ../vector/v.extrude/main.c:180 ../vector/v.what.rast/main.c:138
+#: ../vector/v.drape/main.c:245 ../vector/v.vol.rst/main.c:606
+#: ../doc/raster/r.example/main.c:111 ../display/d.profile/main.c:94
+#: ../display/d.extend/main.c:60 ../display/d.rgb/main.c:95
+#: ../display/d.legend/main.c:256 ../display/d.rast/main.c:111
+#: ../display/d.title/main.c:105 ../display/d.his/main.c:137
+#: ../display/d.his/main.c:174 ../display/d.his/main.c:199
+#: ../display/d.colortable/main.c:95 ../display/d.rast.arrow/arrow.c:195
+#: ../display/d.rast.arrow/arrow.c:237 ../display/d.rast.arrow/arrow.c:372
+#: ../display/d.what.rast/opencell.c:13 ../display/d.what.rast/main.c:155
+#: ../display/d.zoom/main.c:208 ../display/d.nviz/main.c:185
+#: ../display/d.rast.num/number.c:153 ../display/d.histogram/main.c:162
+#: ../raster/simwe/simlib/input.c:178 ../raster/simwe/simlib/input.c:184
+#: ../raster/simwe/simlib/input.c:189 ../raster/simwe/simlib/input.c:198
+#: ../raster/simwe/simlib/input.c:206 ../raster/simwe/simlib/input.c:212
+#: ../raster/simwe/simlib/input.c:218 ../raster/simwe/simlib/input.c:225
+#: ../raster/simwe/simlib/input.c:232 ../raster/simwe/simlib/input.c:239
+#: ../raster/simwe/simlib/input.c:246 ../raster/r.to.vect/main.c:113
+#: ../raster/r.buffer/main.c:127 ../raster/r.univar2/r.univar_main.c:216
+#: ../raster/r.slope.aspect/main.c:358 ../raster/r.lake/main.c:254
+#: ../raster/r.lake/main.c:265 ../raster/r.out.mpeg/main.c:217
+#: ../raster/r.region/main.c:166 ../raster/r.region/main.c:225
+#: ../raster/r.region/main.c:348 ../raster/r.to.rast3elev/main.c:114
+#: ../raster/r.to.rast3elev/main.c:129 ../raster/r.flow/io.c:65
+#: ../raster/r.regression.line/main.c:86 ../raster/r.regression.line/main.c:95
+#: ../raster/r.out.png/r.out.png.c:214 ../raster/r.covar/main.c:95
+#: ../raster/r.surf.idw/main.c:108 ../raster/r.walk/main.c:523
+#: ../raster/r.walk/main.c:526 ../raster/r.sum/main.c:62
+#: ../raster/r.resample/main.c:97 ../raster/r.median/main.c:75
+#: ../raster/r.out.tiff/r.out.tiff.c:166 ../raster/r.grow2/main.c:187
+#: ../raster/r.info/main.c:118 ../raster/r.kappa/stats.c:30
+#: ../raster/r.kappa/stats.c:35 ../raster/r.kappa/main.c:161
+#: ../raster/r.cross/main.c:125 ../raster/r.neighbors/main.c:193
+#: ../raster/r.out.ppm3/main.c:120 ../raster/r.out.vtk/main.c:47
+#: ../raster/r.out.vtk/main.c:60 ../raster/r.mapcalc/map.c:377
+#: ../raster/r.null/null.c:119 ../raster/r.transect/main.c:119
+#: ../raster/r.fill.dir/main.c:172 ../raster/r.cost/main.c:322
+#: ../raster/r.out.ascii/main.c:146 ../raster/r.basins.fill/main.c:82
+#: ../raster/r.basins.fill/main.c:94 ../raster/r.stats/main.c:270
+#: ../raster/r.drain/main.c:140 ../raster/r.out.ppm/main.c:116
+#: ../raster/r.resamp.interp/main.c:103 ../raster/r.topidx/check_ready.c:11
+#: ../raster/r.surf.idw2/read_cell.c:19 ../raster/r.los/main.c:162
+#: ../raster/r.los/main.c:168 ../raster/r.colors/main.c:306
+#: ../raster/r.colors/main.c:387 ../raster/r.resamp.rst/main.c:397
+#: ../raster/r.resamp.rst/main.c:423 ../raster/r.water.outlet/legal.c:23
+#: ../raster/r.his/main.c:127 ../raster/r.his/main.c:164
+#: ../raster/r.his/main.c:189 ../raster/r.bitpattern/main.c:101
+#: ../raster/r.report/parse.c:243 ../raster/r.support/front/front.c:224
+#: ../raster/r.support/modcolr/modcolr.c:45 ../raster/r.distance/parse.c:79
+#: ../raster/r.distance/parse.c:86 ../raster/r.resamp.stats/main.c:296
+#: ../raster/r.out.pov/main.c:174 ../raster/r.mfilter/main.c:121
+#: ../raster/r.random/main.c:119 ../raster/r.random/main.c:124
+#: ../raster/r.carve/main.c:178 ../raster/r.contour/main.c:158
+#: ../raster/r.average/main.c:72 ../raster/r.average/main.c:75
+#: ../raster/r.surf.area/main.c:118 ../raster/r.bilinear/main.c:81
+#: ../raster/r.colors.out/main.c:88 ../raster/r.coin/inter.c:40
+#: ../raster/r.coin/inter.c:44 ../raster/r.coin/main.c:127
+#: ../raster/r.coin/main.c:130 ../raster/r.param.scale/interface.c:172
+#: ../raster/r.reclass/main.c:78 ../raster/r.horizon/main.c:550
+#: ../raster/r.clump/main.c:87 ../raster/r.sun2/main.c:811
+#: ../raster/r.sun2/main.c:826 ../raster/r.sun2/main.c:843
+#: ../raster/r.sun2/main.c:857 ../raster/r.sun2/main.c:869
+#: ../raster/r.sun2/main.c:881 ../raster/r.sun2/main.c:892
+#: ../raster/r.sun2/main.c:904 ../raster/r.sun2/main.c:916
+#: ../raster/wildfire/r.ros/main.c:322 ../raster/wildfire/r.ros/main.c:335
+#: ../raster/wildfire/r.ros/main.c:340 ../raster/wildfire/r.ros/main.c:345
+#: ../raster/wildfire/r.ros/main.c:350 ../raster/wildfire/r.ros/main.c:368
+#: ../raster/wildfire/r.ros/main.c:372 ../raster/wildfire/r.ros/main.c:391
+#: ../raster/wildfire/r.ros/main.c:395 ../raster/wildfire/r.ros/main.c:408
+#: ../raster/wildfire/r.spread/main.c:356
+#: ../raster/wildfire/r.spread/main.c:359
+#: ../raster/wildfire/r.spread/main.c:362
+#: ../raster/wildfire/r.spread/main.c:365
+#: ../raster/wildfire/r.spread/main.c:369
+#: ../raster/wildfire/r.spread/main.c:372
+#: ../raster/wildfire/r.spread/main.c:375 ../raster/r.composite/main.c:155
+#: ../raster/r.out.arc/main.c:113 ../raster/r.out.gridatb/check_ready.c:12
+#: ../raster/r.mfilter.fp/main.c:126 ../raster/r.texture/main.c:228
+#: ../raster/r.recode/main.c:81 ../raster/r.series/main.c:212
+#: ../raster/r.support.stats/main.c:49 ../raster/r.profile/main.c:142
+#: ../raster/r.statistics/main.c:79 ../raster/r.statistics/main.c:85
+#: ../raster/r.out.mat/main.c:103 ../raster/r.cats/main.c:125
+#: ../raster/r.cats/main.c:146 ../raster/r.patch/main.c:113
+#: ../raster/r.thin/io.c:96
+#, c-format
+msgid "Raster map <%s> not found"
+msgstr ""
+#: ../general/g.mremove/do_remove.c:55 ../general/g.region/main.c:505
+#: ../raster3d/base/r3.mask.main.c:78 ../raster3d/base/r3.null.main.c:106
+#: ../raster3d/r3.stats/main.c:611 ../raster3d/r3.out.vtk/main.c:143
+#: ../raster3d/r3.out.vtk/main.c:153 ../raster3d/r3.cross.rast/main.c:284
+#: ../raster3d/r3.out.ascii/main.c:259 ../raster3d/r3.out.v5d/main.c:307
+#: ../raster3d/r3.to.rast/main.c:228 ../raster/r.univar2/r3.univar_main.c:147
+#: ../raster/r.univar2/r3.univar_main.c:186
+#, c-format
+msgid "3D raster map <%s> not found"
+msgstr ""
+#: ../general/g.mremove/do_remove.c:62
+#, c-format
+msgid "%s: couldn't be removed"
+msgstr ""
+#: ../general/g.mremove/do_remove.c:67 ../general/g.mremove/do_remove.c:89
+#, c-format
+msgid "%s: missing"
+msgstr ""
+#: ../general/g.mremove/do_remove.c:71 ../general/g.mremove/do_remove.c:93
+#, c-format
+msgid "%s: removed"
+msgstr ""
+#: ../general/g.mremove/do_remove.c:100
+#, c-format
+msgid "<%s> nothing removed"
+msgstr ""
+#: ../general/g.mremove/main.c:58 ../general/manage/cmd/copy.c:39
+#: ../general/manage/cmd/remove.c:99 ../general/manage/cmd/list.c:41
+#: ../general/manage/cmd/rename.c:40 ../general/g.access/main.c:37
+#: ../general/g.filename/main.c:39 ../general/g.tempfile/main.c:36
+#: ../general/g.ask/main.c:40 ../general/g.findetc/main.c:28
+#: ../general/g.findfile/main.c:35 ../general/g.mlist/main.c:65
+msgid "general, map management"
+msgstr ""
+#: ../general/g.mremove/main.c:60 ../general/manage/cmd/remove.c:101
+msgid "Removes data base element files from the user's current mapset."
+msgstr ""
+#: ../general/g.mremove/main.c:66 ../general/g.mlist/main.c:128
+msgid "Use basic regular expressions instead of wildcards"
+msgstr ""
+#: ../general/g.mremove/main.c:71 ../general/g.mlist/main.c:134
+msgid "Use extended regular expressions instead of wildcards"
+msgstr ""
+#: ../general/g.mremove/main.c:76
+#: ../locale/scriptstrings/db.dropcol_to_translate.c:3
+#: ../locale/scriptstrings/db.droptable_to_translate.c:3
+msgid "Force removal (required for actual deletion of files)"
+msgstr ""
+#: ../general/g.mremove/main.c:80
+msgid "Remove base maps"
+msgstr ""
+#: ../general/g.mremove/main.c:96 ../general/manage/cmd/remove.c:120
+#, c-format
+msgid "%s file(s) to be removed"
+msgstr ""
+#: ../general/g.mremove/main.c:104 ../general/g.mlist/main.c:163
+msgid "-r and -e are mutually exclusive"
+msgstr ""
+#: ../general/g.mremove/main.c:107
+msgid "The following files would be deleted:"
+msgstr ""
+#: ../general/g.mremove/main.c:130 ../general/g.mlist/main.c:172
+#: ../general/g.mlist/main.c:183
+#, c-format
+msgid "Unable to compile regular expression %s"
+msgstr ""
+#: ../general/g.mremove/main.c:158
+msgid "You must use the force flag to actually remove them. Exiting."
+msgstr ""
+#: ../general/g.setproj/get_stp.c:43
+msgid "This should not happen see your system admin"
+msgstr ""
+#: ../general/g.setproj/get_stp.c:99
+msgid "Unable to open FIPS code file"
+msgstr ""
+#: ../general/g.setproj/get_stp.c:125
+#, c-format
+msgid "No match of fips state %d county %d"
+msgstr ""
+#: ../general/g.setproj/get_stp.c:162 ../general/g.setproj/get_stp.c:165
+#: ../general/g.setproj/get_stp.c:282 ../general/g.setproj/get_stp.c:286
+#: ../vector/v.in.ascii/in.c:248 ../vector/v.surf.rst/main.c:646
+#: ../vector/v.surf.rst/main.c:655 ../vector/v.surf.rst/main.c:664
+#: ../vector/v.surf.rst/main.c:674 ../vector/v.surf.rst/main.c:683
+#: ../vector/v.surf.rst/main.c:692 ../display/d.title/main.c:119
+#: ../display/d.text.new/main.c:417 ../display/d.text/main.c:193
+#: ../raster/r.resamp.rst/main.c:616 ../raster/r.resamp.rst/main.c:628
+#: ../raster/r.resamp.rst/main.c:641 ../raster/r.resamp.rst/main.c:655
+#: ../raster/r.resamp.rst/main.c:668 ../raster/r.resamp.rst/main.c:681
+#: ../raster/r.in.arc/main.c:114 ../raster/r.in.ascii/main.c:128
+#: ../raster/r.in.ascii/main.c:155
+#, c-format
+msgid "Unable to open temporary file <%s>"
+msgstr ""
+#: ../general/g.setproj/get_stp.c:179
+msgid "Reading sf key_value temp file"
+msgstr ""
+#: ../general/g.setproj/get_stp.c:212
+msgid "Invalid State FIPS code"
+msgstr ""
+#: ../general/g.setproj/get_stp.c:302
+msgid "Reading cf key_value temp file"
+msgstr ""
+#: ../general/g.setproj/get_stp.c:336
+msgid "Invalid County FIPS code"
+msgstr ""
+#: ../general/g.setproj/proj.c:168
+#, c-format
+msgid "Unrecognized 'ask' value in proj-parms.table: %s"
+msgstr ""
+#: ../general/g.setproj/proj.c:178
+#, c-format
+msgid "Unrecognized default value in proj-parms.table: %s"
+msgstr ""
+#: ../general/g.setproj/main.c:78 ../general/g.proj/main.c:54
+msgid "general, projection"
+msgstr ""
+#: ../general/g.setproj/main.c:80
+msgid "Interactively reset the location's projection settings."
+msgstr ""
+#: ../general/g.setproj/main.c:87
+msgid "You must be in the PERMANENT mapset to run g.setproj"
+msgstr ""
+#: ../general/g.setproj/main.c:100
+msgid "PERMANENT: permission denied"
+msgstr ""
+#: ../general/g.setproj/main.c:104
+msgid "Current region cannot be set"
+msgstr ""
+#: ../general/g.setproj/main.c:107 ../raster/r.resamp.rst/main.c:293
+msgid "Retrieving and setting region failed"
+msgstr ""
+#: ../general/g.setproj/main.c:134
+msgid "Would you still like to change some of the parameters?"
+msgstr ""
+#: ../general/g.setproj/main.c:136
+msgid "The projection information will not be updated"
+msgstr ""
+#: ../general/g.setproj/main.c:147
+#, c-format
+msgid ""
+"Zone in default geographic region definition: %d\n"
+" is different from zone in PROJ_INFO file: %d"
+msgstr ""
+#: ../general/g.setproj/main.c:157
+msgid "XY-location cannot be projected"
+msgstr ""
+#: ../general/g.setproj/main.c:191
+msgid "Unknown projection"
+msgstr ""
+#: ../general/g.setproj/main.c:197
+#, c-format
+msgid "Projection %s is not specified in the file 'proj-parms.table'"
+msgstr ""
+#: ../general/g.setproj/main.c:204
+msgid "Do you wish to specify a geodetic datum for this location?"
+msgstr ""
+#: ../general/g.setproj/main.c:213
+#, c-format
+msgid "The current datum is %s (%s)"
+msgstr ""
+#: ../general/g.setproj/main.c:216
+msgid "Do you wish to change the datum (or datum transformation parameters)?"
+msgstr ""
+#: ../general/g.setproj/main.c:224
+msgid "The datum information has not been changed"
+msgstr ""
+#: ../general/g.setproj/main.c:287
+#, c-format
+msgid "The current ellipsoid is %s"
+msgstr ""
+#: ../general/g.setproj/main.c:289
+msgid "Do you want to change ellipsoid parameter?"
+msgstr ""
+#: ../general/g.setproj/main.c:293
+msgid "The ellipse information has not been changed"
+msgstr ""
+#: ../general/g.setproj/main.c:310
+#, c-format
+msgid "The radius is currently %f"
+msgstr ""
+#: ../general/g.setproj/main.c:311
+msgid "Do you want to change the radius?"
+msgstr ""
+#: ../general/g.setproj/main.c:313 ../general/g.setproj/main.c:319
+msgid "Enter radius for the sphere in meters"
+msgstr ""
+#: ../general/g.setproj/main.c:335
+msgid "Invalid input ellipsoid"
+msgstr ""
+#: ../general/g.setproj/main.c:446
+#, c-format
+msgid "The UTM zone is now set to %d"
+msgstr ""
+#: ../general/g.setproj/main.c:449
+msgid "Do you want to change the UTM zone?"
+msgstr ""
+#: ../general/g.setproj/main.c:450
+msgid "UTM zone information has not been updated"
+msgstr ""
+#: ../general/g.setproj/main.c:455
+msgid ""
+"But if you change zone, all the existing data will be interpreted by "
+"projection software. GRASS will not automatically re-project or even change "
+"the headers for existing maps."
+msgstr ""
+#: ../general/g.setproj/main.c:460
+msgid "Would you still like to change the UTM zone?"
+msgstr ""
+#: ../general/g.setproj/main.c:496
+#, c-format
+msgid "Error writing PROJ_INFO file <%s>"
+msgstr ""
+#: ../general/g.setproj/main.c:570
+#, c-format
+msgid "Enter plural form of units [meters]: "
+msgstr ""
+#: ../general/g.setproj/main.c:602
+#, c-format
+msgid "Enter singular for unit: "
+msgstr ""
+#: ../general/g.setproj/main.c:610
+#, c-format
+msgid "Enter conversion factor from %s to meters: "
+msgstr ""
+#: ../general/g.setproj/main.c:635
+#, c-format
+msgid "Error writing into UNITS output file <%s>"
+msgstr ""
+#: ../general/g.setproj/main.c:642
+msgid "Unable to write to DEFAULT_WIND region file"
+msgstr ""
+#: ../general/g.setproj/main.c:644
+#, c-format
+msgid ""
+"\n"
+"Projection information has been recorded for this location\n"
+"\n"
+msgstr ""
+#: ../general/g.setproj/main.c:646
+msgid "The geographic region information in WIND is now obsolete"
+msgstr ""
+#: ../general/g.setproj/main.c:647
+msgid "Run g.region -d to update it"
+msgstr ""
+#: ../general/g.dirseps/main.c:36
+msgid "Internal GRASS utility for converting directory separator characters."
+msgstr ""
+#: ../general/g.mapsets/dsply_maps.c:23
+#, c-format
+msgid "Available mapsets:"
+msgstr ""
+#: ../general/g.mapsets/dsply_maps.c:33
+#, c-format
+msgid "** no mapsets **\n"
+msgstr ""
+#: ../general/g.mapsets/dsply_path.c:30
+#, c-format
+msgid "Your mapset search list:\n"
+msgstr ""
+#: ../general/g.mapsets/dsply_path.c:38
+#, c-format
+msgid "<%s> not found in mapset list"
+msgstr ""
+#: ../general/g.mapsets/main.c:59
+msgid "general, settings, search path"
+msgstr ""
+#: ../general/g.mapsets/main.c:60
+msgid "Modifies the user's current mapset search path."
+msgstr ""
+#: ../general/g.mapsets/main.c:61
+msgid ""
+"Affects the user's access to data existing under the other mapsets in the "
+"current location."
+msgstr ""
+#: ../general/g.mapsets/main.c:69
+msgid "Name(s) of existing mapset(s)"
+msgstr ""
+#: ../general/g.mapsets/main.c:70 ../general/g.mapsets/main.c:79
+#: ../general/g.mapsets/main.c:88
+msgid "Search path"
+msgstr ""
+#: ../general/g.mapsets/main.c:78
+msgid "Name(s) of existing mapset(s) to add to search path"
+msgstr ""
+#: ../general/g.mapsets/main.c:87
+msgid "Name(s) of existing mapset(s) to remove from search path"
+msgstr ""
+#: ../general/g.mapsets/main.c:91
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:5
+#: ../locale/scriptstrings/m.proj_to_translate.c:7
+#: ../locale/scriptstrings/v.in.lines_to_translate.c:6
+msgstr ""
+#: ../general/g.mapsets/main.c:92
+msgid "Special characters: newline, space, comma, tab"
+msgstr ""
+#: ../general/g.mapsets/main.c:97
+msgid "List all available mapsets in alphabetical order"
+msgstr ""
+#: ../general/g.mapsets/main.c:102
+msgid "Print mapsets in current search path"
+msgstr ""
+#: ../general/g.mapsets/main.c:107
+msgid "Show mapset selection dialog"
+msgstr ""
+#: ../general/g.mapsets/main.c:132 ../general/g.mapsets/main.c:161
+#, c-format
+msgid "Mapset <%s> not found"
+msgstr ""
+#: ../general/g.mapsets/main.c:163
+#, c-format
+msgid "Mapset <%s> added to search path"
+msgstr ""
+#: ../general/g.mapsets/main.c:189
+#, c-format
+msgid "Mapset <%s> removed from search path"
+msgstr ""
+#: ../general/g.mapsets/main.c:222
+msgid "Cannot open SEARCH_PATH for write"
+msgstr ""
+#: ../general/manage/cmd/copy.c:41
+msgid ""
+"Copies available data files in the user's current mapset search path and "
+"location to the appropriate element directories under the user's current "
+"mapset."
+msgstr ""
+#: ../general/manage/cmd/copy.c:58
+#, c-format
+msgid "%s file(s) to be copied"
+msgstr ""
+#: ../general/manage/cmd/copy.c:74
+#, c-format
+msgid "<%s> not found"
+msgstr ""
+#: ../general/manage/cmd/copy.c:79
+#, c-format
+msgid "%s=%s,%s: files are the same, no copy required"
+msgstr ""
+#: ../general/manage/cmd/copy.c:84
+#, c-format
+msgid "<%s> already exists"
+msgstr ""
+#: ../general/manage/cmd/copy.c:88 ../general/manage/cmd/rename.c:84
+#: ../imagery/i.zc/main.c:119 ../imagery/i.landsat.acca/main.c:189
+#: ../imagery/i.fft/fftmain.c:121 ../imagery/i.fft/fftmain.c:124
+#: ../imagery/i.landsat.toar/main.c:505
+#: ../imagery/i.ortho.photo/i.photo.camera/main.c:91
+#: ../imagery/i.ifft/ifftmain.c:116 ../vector/v.kernel/main.c:322
+#: ../vector/v.edit/main.c:86 ../vector/v.surf.idw/main.c:137
+#: ../vector/v.in.ogr/main.c:330 ../vector/v.to.rast3/main.c:69
+#: ../doc/raster/r.example/main.c:114 ../raster/r.buffer/main.c:130
+#: ../raster/r.slope.aspect/opennew.c:11 ../raster/r.to.rast3elev/main.c:472
+#: ../raster/r.surf.idw/main.c:112 ../raster/r.walk/main.c:531
+#: ../raster/r.surf.fractal/interface.c:79 ../raster/r.median/main.c:77
+#: ../raster/r.neighbors/main.c:197 ../raster/r.in.gdal/main.c:225
+#: ../raster/r.surf.gauss/main.c:77 ../raster/r.cost/main.c:327
+#: ../raster/r.surf.idw2/main.c:83 ../raster/r.los/main.c:173
+#: ../raster/r.water.outlet/legal.c:10 ../raster/r.mode/main.c:94
+#: ../raster/r.bitpattern/main.c:104 ../raster/r.random/main.c:147
+#: ../raster/r.random/main.c:152 ../raster/r.average/main.c:78
+#: ../raster/r.in.ascii/main.c:203 ../raster/r.reclass/main.c:81
+#: ../raster/r.clump/main.c:90 ../raster/wildfire/r.spread/main.c:380
+#: ../raster/wildfire/r.spread/main.c:389
+#: ../raster/wildfire/r.spread/main.c:399 ../raster/r.texture/main.c:231
+#: ../raster/r.recode/main.c:84 ../raster/r.in.mat/main.c:388
+#: ../raster/r.watershed/shed/com_line.c:231
+#: ../raster/r.watershed/shed/com_line.c:266
+#, c-format
+msgstr ""
+#: ../general/manage/cmd/remove.c:106
+msgid "Force remove"
+msgstr ""
+#: ../general/manage/cmd/list.c:43
+msgid "Lists available GRASS data base files of the user-specified data type."
+msgstr ""
+#: ../general/manage/cmd/list.c:72 ../general/g.mlist/main.c:123
+msgid "Mapset to list (default: current search path)"
+msgstr ""
+#: ../general/manage/cmd/list.c:76 ../general/g.mlist/main.c:154
+msgid "Verbose listing (also list map titles)"
+msgstr ""
+#: ../general/manage/cmd/rename.c:42
+msgid "Renames data base element files in the user's current mapset."
+msgstr ""
+#: ../general/manage/cmd/rename.c:57
+#, c-format
+msgid "%s file(s) to be renamed"
+msgstr ""
+#: ../general/manage/cmd/rename.c:75
+#, c-format
+msgid "%s <%s> not found"
+msgstr ""
+#: ../general/manage/cmd/rename.c:79
+#, c-format
+msgid "<%s> already exists in mapset <%s>"
+msgstr ""
+#: ../general/manage/cmd/rename.c:89
+#, c-format
+msgid "%s=%s,%s: files could be the same, no rename possible"
+msgstr ""
+#: ../general/manage/cmd/rename.c:99
+msgid "Renaming reclass maps"
+msgstr ""
+#: ../general/g.access/exp_perms.c:11 ../general/g.access/exp_perms.c:29
+msgid "have"
+msgstr ""
+#: ../general/g.access/exp_perms.c:12
+msgid "read "
+msgstr ""
+#: ../general/g.access/exp_perms.c:15
+msgid "Everyone"
+msgstr ""
+#: ../general/g.access/exp_perms.c:16
+msgid "has"
+msgstr ""
+#: ../general/g.access/exp_perms.c:19
+msgid "Only users in your group"
+msgstr ""
+#: ../general/g.access/exp_perms.c:22
+msgid "Only users outside your group"
+msgstr ""
+#: ../general/g.access/exp_perms.c:25
+msgid "Only you"
+msgstr ""
+#: ../general/g.access/exp_perms.c:31
+#, c-format
+msgid "%s %s %s %saccess to mapset %s"
+msgstr ""
+#: ../general/g.access/exp_perms.c:32
+msgid "will"
+msgstr ""
+msgid "now"
+msgstr ""
+#: ../general/g.access/set_perms.c:26
+msgid "Unable to change mapset permissions"
+msgstr ""
+#: ../general/g.access/main.c:39
+msgid "Controls access to the current mapset for other users on the system."
+msgstr ""
+#: ../general/g.access/main.c:46
+msgid "Access for group"
+msgstr ""
+#: ../general/g.access/main.c:53
+msgid "Access for others"
+msgstr ""
+#: ../general/g.access/main.c:59
+msgid "UNIX filesystem access controls are not supported by MS-Windows"
+msgstr ""
+#: ../general/g.access/main.c:67
+msgid "Access to the PERMANENT mapset must be open, nothing changed"
+msgstr ""
+#: ../general/g.access/main.c:71
+msgid "Unable to determine mapset permissions"
+msgstr ""
+#: ../general/g.filename/main.c:40
+msgid "Prints GRASS data base file names."
+msgstr ""
+#: ../general/g.filename/main.c:48 ../general/g.findfile/main.c:48
+msgid "Name of an element"
+msgstr ""
+#: ../general/g.filename/main.c:54
+msgid "Name of a database file"
+msgstr ""
+#: ../general/g.filename/main.c:60
+msgid "Name of a mapset (default: current)"
+msgstr ""
+#: ../general/g.region/zoom.c:23
+#, c-format
+msgid "Unable to open raster map <%s> in <%s>"
+msgstr ""
+#: ../general/g.region/zoom.c:35
+#, c-format
+msgid "Could not read from <%s>"
+msgstr ""
+#: ../general/g.region/printwindow.c:247 ../general/g.region/printwindow.c:503
+#: ../general/g.region/printwindow.c:622 ../display/d.where/main.c:93
+#: ../raster/r.sun2/main.c:728
+msgid "Can't get projection info of current location"
+msgstr ""
+#: ../general/g.region/printwindow.c:250 ../general/g.region/printwindow.c:506
+#: ../general/g.region/printwindow.c:625 ../display/d.where/main.c:96
+#: ../raster/r.sun/main.c:475 ../raster/r.horizon/main.c:482
+#: ../raster/r.sun2/main.c:732
+msgid "Can't get projection units of current location"
+msgstr ""
+#: ../general/g.region/printwindow.c:253 ../general/g.region/printwindow.c:509
+#: ../general/g.region/printwindow.c:628 ../ps/ps.map/do_geogrid.c:272
+#: ../display/d.grid/plot.c:294 ../display/d.where/main.c:99
+#: ../raster/r.sun/main.c:479 ../raster/r.horizon/main.c:486
+#: ../raster/r.sun2/main.c:736
+msgid "Can't get projection key values of current location"
+msgstr ""
+#: ../general/g.region/printwindow.c:263 ../general/g.region/printwindow.c:516
+#: ../general/g.region/printwindow.c:647
+msgid "Unable to update lat/long projection parameters"
+msgstr ""
+#: ../general/g.region/printwindow.c:281 ../general/g.region/printwindow.c:289
+#: ../general/g.region/printwindow.c:297 ../general/g.region/printwindow.c:305
+#: ../general/g.region/printwindow.c:534 ../general/g.region/printwindow.c:542
+#: ../general/g.region/printwindow.c:550 ../general/g.region/printwindow.c:558
+#: ../general/g.region/printwindow.c:676 ../general/g.region/printwindow.c:684
+#: ../general/g.region/printwindow.c:692 ../general/g.region/printwindow.c:700
+#: ../raster/r.proj.seg/main.c:353 ../raster/r.proj.seg/main.c:355
+#: ../raster/r.sunmask/g_solposition.c:127
+msgid "Error in pj_do_proj (projection of input coordinate pair)"
+msgstr ""
+#: ../general/g.region/printwindow.c:410
+msgid "You are already in Lat/Long. Use the -p flag instead."
+msgstr ""
+#: ../general/g.region/printwindow.c:412
+msgid ""
+"You are in a simple XY location, projection to Lat/Lon is not possible. Use "
+"the -p flag instead."
+msgstr ""
+#: ../general/g.region/printwindow.c:637
+msgid ""
+"WGS84 output not possible as this location does not contain datum "
+"transformation parameters. Try running g.setproj."
+msgstr ""
+#: ../general/g.region/printwindow.c:783
+msgid "Lat/Long calculations are not possible from a simple XY system"
+msgstr ""
+#: ../general/g.region/adjust.c:11 ../raster/r.region/main.c:360
+#, c-format
+msgid "Invalid region: %s"
+msgstr ""
+#: ../general/g.region/main.c:70 ../general/g.gisenv/main.c:38
+#: ../general/g.mapset/main.c:48
+msgid "general, settings"
+msgstr ""
+#: ../general/g.region/main.c:72
+msgid "Manages the boundary definitions for the geographic region."
+msgstr ""
+#: ../general/g.region/main.c:78 ../raster/r.region/main.c:70
+msgid "Set from default region"
+msgstr ""
+#: ../general/g.region/main.c:79 ../general/g.region/main.c:84
+#: ../general/g.region/main.c:172 ../general/g.region/main.c:179
+#: ../general/g.region/main.c:188 ../general/g.region/main.c:195
+#: ../general/g.region/main.c:205
+msgid "Existing"
+msgstr ""
+#: ../general/g.region/main.c:83
+msgid "Save as default region"
+msgstr ""
+#: ../general/g.region/main.c:88
+msgid "Print the current region"
+msgstr ""
+#: ../general/g.region/main.c:93
+msgid "Print the current region in lat/long using the current ellipsoid/datum"
+msgstr ""
+#: ../general/g.region/main.c:99
+msgid "Print the current region extent"
+msgstr ""
+#: ../general/g.region/main.c:105
+msgid "Print the current region map center coordinates"
+msgstr ""
+#: ../general/g.region/main.c:111
+msgid "Print the current region in GMT style"
+msgstr ""
+#: ../general/g.region/main.c:117
+msgid "Print the current region in WMS style"
+msgstr ""
+#: ../general/g.region/main.c:123
+msgid "Print region resolution in meters (geodesic)"
+msgstr ""
+#: ../general/g.region/main.c:128
+msgid "Print the convergence angle (degrees CCW)"
+msgstr ""
+#: ../general/g.region/main.c:130
+msgid ""
+"The difference between the projection's grid north and true north, measured "
+"at the center coordinates of the current region."
+msgstr ""
+#: ../general/g.region/main.c:136
+msgid "Print also 3D settings"
+msgstr ""
+#: ../general/g.region/main.c:142
+msgid "Print the maximum bounding box in lat/long on WGS84"
+msgstr ""
+#: ../general/g.region/main.c:147
+#: ../locale/scriptstrings/i.oif_to_translate.c:9
+#: ../raster/r.regression.line/main.c:63
+msgid "Print in shell script style"
+msgstr ""
+#: ../general/g.region/main.c:153
+msgid ""
+"Align region to resolution (default = align to bounds, works only for 2D "
+"resolution)"
+msgstr ""
+#: ../general/g.region/main.c:155 ../general/g.region/main.c:215
+#: ../general/g.region/main.c:225 ../general/g.region/main.c:235
+#: ../general/g.region/main.c:245 ../general/g.region/main.c:254
+#: ../general/g.region/main.c:263 ../general/g.region/main.c:341
+#: ../general/g.region/main.c:352 ../raster/r.in.bin/main.c:261
+#: ../raster/r.in.bin/main.c:301 ../raster/r.in.bin/main.c:309
+#: ../raster/r.in.bin/main.c:317 ../raster/r.in.bin/main.c:325
+#: ../raster/r.in.bin/main.c:332 ../raster/r.in.bin/main.c:339
+msgid "Bounds"
+msgstr ""
+#: ../general/g.region/main.c:159
+msgid "Do not update the current region"
+msgstr ""
+#: ../general/g.region/main.c:160 ../general/g.region/main.c:363
+#: ../vector/v.label/main.c:91 ../vector/v.label/main.c:96
+#: ../vector/v.label/main.c:171 ../vector/v.label/main.c:184
+msgid "Effects"
+msgstr ""
+#: ../general/g.region/main.c:170
+msgid "Set current region from named region"
+msgstr ""
+#: ../general/g.region/main.c:178 ../raster/r.region/main.c:96
+msgid "Set region to match this raster map"
+msgstr ""
+#: ../general/g.region/main.c:186
+msgid "Set region to match this 3D raster map (both 2D and 3D values)"
+msgstr ""
+#: ../general/g.region/main.c:194 ../raster/r.region/main.c:102
+msgid "Set region to match this vector map"
+msgstr ""
+#: ../general/g.region/main.c:203 ../raster/r.region/main.c:110
+msgid "Set region to match this 3dview file"
+msgstr ""
+#: ../general/g.region/main.c:213 ../raster/r.region/main.c:120
+msgid "Value for the northern edge"
+msgstr ""
+#: ../general/g.region/main.c:223 ../raster/r.region/main.c:130
+msgid "Value for the southern edge"
+msgstr ""
+#: ../general/g.region/main.c:233 ../raster/r.region/main.c:140
+msgid "Value for the eastern edge"
+msgstr ""
+#: ../general/g.region/main.c:243 ../raster/r.region/main.c:150
+msgid "Value for the western edge"
+msgstr ""
+#: ../general/g.region/main.c:253
+msgid "Value for the top edge"
+msgstr ""
+#: ../general/g.region/main.c:262
+msgid "Value for the bottom edge"
+msgstr ""
+#: ../general/g.region/main.c:271
+msgid "Number of rows in the new region"
+msgstr ""
+#: ../general/g.region/main.c:272 ../general/g.region/main.c:281
+#: ../general/g.region/main.c:291 ../general/g.region/main.c:301
+#: ../general/g.region/main.c:311 ../general/g.region/main.c:321
+#: ../general/g.region/main.c:330
+msgid "Resolution"
+msgstr ""
+#: ../general/g.region/main.c:280
+msgid "Number of columns in the new region"
+msgstr ""
+#: ../general/g.region/main.c:290
+msgid "Grid resolution 2D (both north-south and east-west)"
+msgstr ""
+#: ../general/g.region/main.c:300
+msgid "3D grid resolution (north-south, east-west and top-bottom)"
+msgstr ""
+#: ../general/g.region/main.c:309
+msgid "North-south grid resolution 2D"
+msgstr ""
+#: ../general/g.region/main.c:319
+msgid "East-west grid resolution 2D"
+msgstr ""
+#: ../general/g.region/main.c:329
+msgid "Top-bottom grid resolution 3D"
+msgstr ""
+#: ../general/g.region/main.c:339
+msgid "Shrink region until it meets non-NULL data from this raster map"
+msgstr ""
+#: ../general/g.region/main.c:350
+msgid "Adjust region cells to cleanly align with this raster map"
+msgstr ""
+#: ../general/g.region/main.c:361
+msgid "Save current region settings in named region file"
+msgstr ""
+#: ../general/g.region/main.c:420 ../raster/r.region/main.c:182
+#, c-format
+msgid "Region <%s> not found"
+msgstr ""
+#: ../general/g.region/main.c:422 ../raster/r.region/main.c:184
+#, c-format
+msgid "Unable to read region <%s> in <%s>"
+msgstr ""
+#: ../general/g.region/main.c:434 ../raster/r.region/main.c:195
+#, c-format
+msgid "3dview file <%s> not found"
+msgstr ""
+#: ../general/g.region/main.c:439 ../raster/r.region/main.c:201
+#, c-format
+msgid "Unable to open 3dview file <%s> in <%s>"
+msgstr ""
+#: ../general/g.region/main.c:445 ../raster/r.region/main.c:206
+#, c-format
+msgid "Unable to read 3dview file <%s> in <%s>"
+msgstr ""
+#: ../general/g.region/main.c:448 ../raster/r.region/main.c:209
+#, c-format
+msgid "Old 3dview file. Region <%s> not found in <%s>"
+msgstr ""
+#: ../general/g.region/main.c:479 ../general/g.region/main.c:830
+#: ../display/d.title/main.c:108 ../raster/r.region/main.c:168
+#: ../raster/r.region/main.c:227 ../raster/r.region/main.c:350
+#, c-format
+msgid "Unable to read header of raster map <%s@%s>"
+msgstr ""
+#: ../general/g.region/main.c:508
+#, c-format
+msgid "Unable to read header of 3D raster map <%s@%s>"
+msgstr ""
+#: ../general/g.region/main.c:551
+#, c-format
+msgid "Unable to open vector map <%s@%s>"
+msgstr ""
+#: ../general/g.region/main.c:833
+#, c-format
+msgid "Raster map <%s@%s>: %s"
+msgstr ""
+#: ../general/g.region/main.c:839
+#, c-format
+msgid "<%s> is an illegal region name"
+msgstr ""
+#: ../general/g.region/main.c:843
+#, c-format
+msgid "Unable to set region <%s>"
+msgstr ""
+#: ../general/g.region/main.c:849
+msgid "Unable to update current region"
+msgstr ""
+#: ../general/g.region/main.c:857
+msgid "Unable to change default region. The current mapset is not <PERMANENT>."
+msgstr ""
+#: ../general/g.region/main.c:874
+#, c-format
+msgid "Invalid input <%s=%s>"
+msgstr ""
+#: ../general/g.region/main.c:895
+msgid "format"
+msgstr ""
+#: ../general/g.message/main.c:33
+msgid "general, scripts"
+msgstr ""
+#: ../general/g.message/main.c:35
+msgid ""
+"Prints a message, warning, progress info, or fatal error in the GRASS way."
+msgstr ""
+#: ../general/g.message/main.c:37
+msgid "This module should be used in scripts for messages served to user."
+msgstr ""
+#: ../general/g.message/main.c:41 ../general/g.message/main.c:46
+#: ../general/g.message/main.c:51 ../general/g.message/main.c:56
+msgid "Type"
+msgstr ""
+#: ../general/g.message/main.c:42
+msgid "Print message as warning"
+msgstr ""
+#: ../general/g.message/main.c:47
+msgid "Print message as fatal error"
+msgstr ""
+#: ../general/g.message/main.c:52
+msgid "Print message as debug message"
+msgstr ""
+#: ../general/g.message/main.c:57
+msgid "Print message as progress info"
+msgstr ""
+#: ../general/g.message/main.c:61 ../general/g.message/main.c:66
+#: ../general/g.message/main.c:80
+msgid "Level"
+msgstr ""
+#: ../general/g.message/main.c:62
+msgid "Print message in all but full quiet mode"
+msgstr ""
+#: ../general/g.message/main.c:67
+msgid "Print message only in verbose mode"
+msgstr ""
+#: ../general/g.message/main.c:74
+msgid "Text of the message to be printed"
+msgstr ""
+#: ../general/g.message/main.c:83
+msgid "Level to use for debug messages"
+msgstr ""
+#: ../general/g.message/main.c:91
+msgid "Select only one message level"
+msgstr ""
+#: ../general/g.message/main.c:104
+msgid "Unable to parse input message"
+msgstr ""
+#: ../general/g.findfile/main.c:37
+msgid "Searches for GRASS data base files and sets variables for the shell."
+msgstr ""
+#: ../general/g.findfile/main.c:54
+msgid "Name of an existing map"
+msgstr ""
+#: ../general/g.findfile/main.c:60
+msgid "Name of a mapset"
+msgstr ""
+#: ../general/g.findfile/main.c:65
+msgid "Don't add quotes"
+msgstr ""
+#: ../general/g.findfile/main.c:79
+#, c-format
+msgid ""
+"Parameter 'file' contains reference to <%s> mapset, but mapset parameter <"
+"%s> does not correspond"
+msgstr ""
+#: ../general/g.proj/input.c:82
+msgid "Error reading WKT projection description"
+msgstr ""
+#: ../general/g.proj/input.c:89
+#, c-format
+msgid "Unable to open file [%s] for reading"
+msgstr ""
+#: ../general/g.proj/input.c:134
+msgid "Can't parse PROJ.4-style parameter string"
+msgstr ""
+#: ../general/g.proj/input.c:172
+msgid "Unable to translate EPSG code"
+msgstr ""
+#: ../general/g.proj/input.c:209
+msgid "Trying to open with OGR..."
+msgstr ""
+#: ../general/g.proj/input.c:217 ../general/g.proj/input.c:236
+msgid "...succeeded."
+msgstr ""
+#: ../general/g.proj/input.c:230
+msgid "Trying to open with GDAL..."
+msgstr ""
+#: ../general/g.proj/input.c:245
+#, c-format
+msgid "Could not read georeferenced file %s using either OGR nor GDAL"
+msgstr ""
+#: ../general/g.proj/input.c:250
+#, c-format
+msgid ""
+"Read of file %s was successful, but it did not contain projection "
+"information. 'XY (unprojected)' will be used"
+msgstr ""
+#: ../general/g.proj/output.c:141
+#, c-format
+msgid "%s: Unable to convert to WKT"
+msgstr ""
+#: ../general/g.proj/output.c:153
+#, c-format
+msgid "Location %s created!"
+msgstr ""
+#: ../general/g.proj/output.c:155
+#, c-format
+msgid "Unable to create location: %s"
+msgstr ""
+#: ../general/g.proj/output.c:158
+#, c-format
+msgid "Unable to create projection files: %s"
+msgstr ""
+#: ../general/g.proj/output.c:162
+msgid "Unspecified error while creating new location"
+msgstr ""
+#: ../general/g.proj/output.c:174
+#, c-format
+msgid ""
+"You must select the PERMANENT mapset before updating the current location's "
+"projection. (Current mapset is %s)"
+msgstr ""
+#: ../general/g.proj/output.c:190
+#, c-format
+msgid ""
+"\n"
+"\n"
+"WARNING!  A projection file already exists for this location\n"
+msgstr ""
+#: ../general/g.proj/output.c:205
+msgid "Would you still like to overwrite the current projection information "
+msgstr ""
+#: ../general/g.proj/output.c:227
+msgid "Error writing PROJ_INFO"
+msgstr ""
+#: ../general/g.proj/output.c:234
+msgid "Error writing PROJ_UNITS"
+msgstr ""
+#: ../general/g.proj/output.c:243
+msgid ""
+"N.B. The default region was updated to the new projection, but if you have "
+"multiple mapsets g.region -d should be run in each to update the region from "
+"the default."
+msgstr ""
+#: ../general/g.proj/output.c:247
+msgid "Projection information updated!"
+msgstr ""
+#: ../general/g.proj/output.c:250
+msgid "The projection information will not be updated."
+msgstr ""
+#: ../general/g.proj/main.c:56
+msgid ""
+"Converts co-ordinate system descriptions (i.e. projection information) "
+"between various formats (including GRASS format)."
+msgstr ""
+#: ../general/g.proj/main.c:59
+msgid "Can also be used to create GRASS locations."
+msgstr ""
+#: ../general/g.proj/main.c:65
+msgid "Print projection information (in conventional GRASS format)"
+msgstr ""
+#: ../general/g.proj/main.c:71
+msgid "Verify datum information and print transformation parameters"
+msgstr ""
+#: ../general/g.proj/main.c:77
+msgid "Print projection information in PROJ.4 format"
+msgstr ""
+#: ../general/g.proj/main.c:82
+msgid "Print projection information in WKT format"
+msgstr ""
+#: ../general/g.proj/main.c:88
+msgid "Use ESRI-style format (applies to WKT output only)"
+msgstr ""
+#: ../general/g.proj/main.c:94
+msgid ""
+"Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
+msgstr ""
+#: ../general/g.proj/main.c:102 ../general/g.proj/main.c:111
+#: ../general/g.proj/main.c:120 ../general/g.proj/main.c:128
+#: ../vector/v.edit/args.c:103 ../vector/v.edit/args.c:212
+#: ../vector/v.out.ogr/main.c:108 ../vector/v.out.ogr/main.c:128
+#: ../raster/simwe/r.sim.water/main.c:126
+#: ../raster/simwe/r.sim.water/main.c:131
+#: ../raster/simwe/r.sim.water/main.c:136
+#: ../raster/simwe/r.sim.water/main.c:143
+#: ../raster/simwe/r.sim.water/main.c:152
+#: ../raster/simwe/r.sim.water/main.c:159
+#: ../raster/simwe/r.sim.water/main.c:168
+#: ../raster/simwe/r.sim.water/main.c:174
+#: ../raster/simwe/r.sim.water/main.c:182
+#: ../raster/simwe/r.sim.water/main.c:189
+#: ../raster/simwe/r.sim.sediment/main.c:119
+#: ../raster/simwe/r.sim.sediment/main.c:124
+#: ../raster/simwe/r.sim.sediment/main.c:129
+#: ../raster/simwe/r.sim.sediment/main.c:134
+#: ../raster/simwe/r.sim.sediment/main.c:140
+#: ../raster/simwe/r.sim.sediment/main.c:146
+#: ../raster/simwe/r.sim.sediment/main.c:152
+#: ../raster/simwe/r.sim.sediment/main.c:158
+#: ../raster/simwe/r.sim.sediment/main.c:166 ../raster/r.in.xyz/main.c:188
+#: ../raster/r.in.xyz/main.c:197 ../raster/r.in.xyz/main.c:205
+#: ../raster/r.in.xyz/main.c:213
+msgid "Input"
+msgstr ""
+#: ../general/g.proj/main.c:103
+msgid "Georeferenced data file to read projection information from"
+msgstr ""
+#: ../general/g.proj/main.c:112
+msgid "ASCII file containing a WKT projection description (- for stdin)"
+msgstr ""
+#: ../general/g.proj/main.c:121
+msgid "PROJ.4 projection description (- for stdin)"
+msgstr ""
+#: ../general/g.proj/main.c:129
+msgid "EPSG projection code"
+msgstr ""
+#: ../general/g.proj/main.c:137 ../general/g.proj/main.c:143
+msgid "Datum"
+msgstr ""
+#: ../general/g.proj/main.c:138
+msgid "Index number of datum transform parameters"
+msgstr ""
+#: ../general/g.proj/main.c:139
+msgid "\"0\" for unspecified or \"-1\" to list and exit"
+msgstr ""
+#: ../general/g.proj/main.c:145
+msgid ""
+"Force override of datum transformation information in input co-ordinate "
+"system"
+msgstr ""
+#: ../general/g.proj/main.c:150 ../general/g.proj/main.c:159
+msgid "Create/Edit"
+msgstr ""
+#: ../general/g.proj/main.c:151
+msgid ""
+"Create new projection files (modifies current location unless 'location' "
+"option specified)"
+msgstr ""
+#: ../general/g.proj/main.c:160
+msgid "Name of new location to create"
+msgstr ""
+#: ../general/g.proj/main.c:165
+msgid "Enable interactive prompting (for command-line use only)"
+msgstr ""
+#: ../general/g.proj/main.c:183
+#, c-format
+msgid "Only one of '%s', '%s', '%s' or '%s' options may be specified"
+msgstr ""
+#: ../general/g.proj/main.c:210
+msgid "Projection files missing"
+msgstr ""
+#: ../general/g.mlist/main.c:67
+msgid ""
+"Lists available GRASS data base files of the user-specified data type "
+"optionally using the search pattern."
+msgstr ""
+#: ../general/g.mlist/main.c:97
+msgid "Map name search pattern (default: all)"
+msgstr ""
+#: ../general/g.mlist/main.c:98 ../general/g.mlist/main.c:106
+#: ../general/g.mlist/main.c:129 ../general/g.mlist/main.c:135
+msgid "Pattern"
+msgstr ""
+#: ../general/g.mlist/main.c:105
+msgid "Map name exclusion pattern (default: none)"
+msgstr ""
+#: ../general/g.mlist/main.c:115
+msgid "One-character output separator, newline, comma, space, or tab"
+msgstr ""
+#: ../general/g.mlist/main.c:139
+msgid "Print data types"
+msgstr ""
+#: ../general/g.mlist/main.c:144
+msgid "Print fully-qualified map names (including mapsets)"
+msgstr ""
+#: ../general/g.mlist/main.c:149
+msgid "Pretty printing in human readable format"
+msgstr ""
+#: ../general/g.gisenv/main.c:40
+msgid "Outputs and modifies the user's current GRASS variable settings."
+msgstr ""
+#: ../general/g.gisenv/main.c:45
+msgid "GRASS variable to get"
+msgstr ""
+#: ../general/g.gisenv/main.c:52
+msgid "GRASS variable to set"
+msgstr ""
+#: ../general/g.gisenv/main.c:61
+msgid "Where GRASS variable is stored"
+msgstr ""
+#: ../general/g.gisenv/main.c:66
+msgid "Use shell syntax (for \"eval\")"
+msgstr ""
+#: ../general/g.gisenv/main.c:70
+msgid "Don't use shell syntax"
+msgstr ""
+#: ../general/g.gisenv/main.c:76
+msgid "-s and -n are mutually exclusive"
+msgstr ""
+#: ../general/g.mapset/main.c:49
+msgid "Changes current mapset."
+msgstr ""
+#: ../general/g.mapset/main.c:50
+msgid ""
+"Optionally create new mapset or list available mapsets in given location."
+msgstr ""
+#: ../general/g.mapset/main.c:57
+msgid "Name of mapset where to switch"
+msgstr ""
+#: ../general/g.mapset/main.c:65
+msgid "Location name (not location path)"
+msgstr ""
+#: ../general/g.mapset/main.c:75
+msgid ""
+"GIS data directory (full path to the directory where the new location is)"
+msgstr ""
+#: ../general/g.mapset/main.c:80
+msgid "Create mapset if it doesn't exist"
+msgstr ""
+#: ../general/g.mapset/main.c:82
+#: ../locale/scriptstrings/r.mask_to_translate.c:4
+#: ../locale/scriptstrings/r.mask_to_translate.c:6
+#: ../locale/scriptstrings/r.mask_to_translate.c:8
+msgid "Create"
+msgstr ""
+#: ../general/g.mapset/main.c:86
+msgid "List available mapsets"
+msgstr ""
+#: ../general/g.mapset/main.c:93
+msgid "Either mapset= or -l must be used"
+msgstr ""
+#: ../general/g.mapset/main.c:139
+#, c-format
+msgid "<%s> is already the current mapset"
+msgstr ""
+#: ../general/g.mapset/main.c:147
+msgid "You don't have permission to use this mapset"
+msgstr ""
+#: ../general/g.mapset/main.c:156
+msgid "The mapset does not exist. Use -c flag to create it."
+msgstr ""
+#: ../general/g.mapset/main.c:165
+msgid "Unable to read GIS_LOCK environment variable"
+msgstr ""
+#: ../general/g.mapset/main.c:179
+#, c-format
+msgid ""
+"%s is currently running GRASS in selected mapset or lock file cannot be "
+"checked"
+msgstr ""
+#: ../general/g.mapset/main.c:183
+msgid "Erasing monitors..."
+msgstr ""
+#: ../general/g.mapset/main.c:199
+msgid "Cleaning up temporary files..."
+msgstr ""
+#: ../general/g.mapset/main.c:213
+msgid "Your shell continues to use the history for the old mapset"
+msgstr ""
+#: ../general/g.mapset/main.c:217
+#, c-format
+msgid ""
+"You can switch the history by commands:\n"
+"history -w; history -r %s/.bash_history; HISTFILE=%s/.bash_history"
+msgstr ""
+#: ../general/g.mapset/main.c:222
+#, c-format
+msgid ""
+"history -S; history -L %s/.history; setenv histfile=%s/.history"
+msgstr ""
+#: ../general/g.mapset/main.c:228
+#, c-format
+msgid "Your current mapset is <%s>"
+msgstr ""
+#: ../general/g.version/main.c:41
+msgid "general, version"
+msgstr ""
+#: ../general/g.version/main.c:42
+msgid "Displays version and copyright information."
+msgstr ""
+#: ../general/g.version/main.c:46
+msgid "Print also the copyright message"
+msgstr ""
+#: ../general/g.version/main.c:50
+msgid "Print also the GRASS build information"
+msgstr ""
+#: ../general/g.version/main.c:55
+msgid "Print also the GIS library revision number and time"
+msgstr ""
+#: ../general/g.version/main.c:59
+msgid "Print info in shell script style (including SVN revision number)"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:37
+#, c-format
+msgid "Invalid color: %s"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:53
+msgid "Error reading PPM file"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:68 ../general/g.pnmcomp/main.c:73
+#: ../general/g.pnmcomp/main.c:82 ../general/g.pnmcomp/main.c:133
+#: ../general/g.pnmcomp/main.c:146
+msgid "Invalid PPM file"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:95
+#, c-format
+msgid "File <%s> not found"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:103
+msgid "Expecting PPM but got PGM"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:108
+msgid "Expecting PGM but got PPM"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:111
+#, c-format
+msgid "Invalid magic number: 'P%c'"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:124 ../general/g.pnmcomp/main.c:141
+msgid "Invalid PGM file"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:241 ../general/g.pnmcomp/main.c:258
+#: ../general/g.transform/main.c:281 ../vector/v.out.vtk/main.c:176
+#: ../vector/v.out.ascii/out.c:169 ../display/d.nviz/main.c:204
+#: ../raster/r.out.ppm3/main.c:149 ../raster/r.out.ascii/main.c:172
+#: ../raster/r.out.arc/main.c:134 ../raster/r.recode/main.c:93
+#: ../raster/r.profile/main.c:157 ../raster/r.cats/main.c:177
+#, c-format
+msgid "Unable to open file <%s>"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:246
+msgid "Error writing PPM file"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:263
+msgid "Error writing PGM file"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:281 ../general/g.gui/main.c:36
+msgid "general, gui"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:289
+msgid "Names of input files"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:296
+msgid "Names of mask files"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:303
+msgid "Layer opacities"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:309
+msgid "Name of output file"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:316
+msgid "Name of output mask file"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:323
+msgid "Image width"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:329
+msgid "Image height"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:334 ../vector/v.lrs/v.lrs.label/main.c:228
+#: ../vector/v.label/main.c:188 ../vector/v.label.sa/main.c:170
+#: ../display/d.path/main.c:116
+msgid "Background color"
+msgstr ""
+#: ../general/g.transform/main.c:97
+#, c-format
+msgid "Not enough points, %d are required"
+msgstr ""
+#: ../general/g.transform/main.c:101
+#, c-format
+msgid "Error conducting transform (%d)"
+msgstr ""
+#: ../general/g.transform/main.c:199
+msgid "Poorly placed control points"
+msgstr ""
+#: ../general/g.transform/main.c:201
+msgid "Insufficient memory"
+msgstr ""
+#: ../general/g.transform/main.c:203
+msgid "Parameter error"
+msgstr ""
+#: ../general/g.transform/main.c:205
+msgid "No active control points"
+msgstr ""
+#: ../general/g.transform/main.c:300
+#, c-format
+msgid "Invalid coordinates: [%s]"
+msgstr ""
+#: ../general/g.transform/main.c:320
+msgid "general, transformation, GCP"
+msgstr ""
+#: ../general/g.transform/main.c:322
+msgid "Computes a coordinate transformation based on the control points."
+msgstr ""
+#: ../general/g.transform/main.c:331
+msgid "Rectification polynomial order"
+msgstr ""
+#: ../general/g.transform/main.c:339
+msgid ""
+"idx;point index;src;source coordinates;dst;destination coordinates;fwd;"
+"forward coordinates (destination);rev;reverse coordinates (source);fxy;"
+"forward coordinates difference (destination);rxy;reverse coordinates "
+"difference (source);fd;forward error (destination);rd;reverse error (source)"
+msgstr ""
+#: ../general/g.transform/main.c:349 ../vector/v.out.ascii/out.c:63
+msgid "Output format"
+msgstr ""
+#: ../general/g.transform/main.c:353
+msgid "Display summary information"
+msgstr ""
+#: ../general/g.transform/main.c:359
+msgid "File containing coordinates to transform (\"-\" to read from stdin)"
+msgstr ""
+#: ../general/g.transform/main.c:360
+msgid "Local x,y coordinates to target east,north"
+msgstr ""
+#: ../general/g.transform/main.c:364
+msgid "Reverse transform of coords file or coeff. dump"
+msgstr ""
+#: ../general/g.transform/main.c:365
+msgid "Target east,north coordinates to local x,y"
+msgstr ""
+#: ../general/g.transform/main.c:369
+msgid "Display transform matrix coefficients"
+msgstr ""
+#: ../general/g.gui/main.c:38
+msgid "Launches a GRASS graphical user interface (GUI) session."
+msgstr ""
+#: ../general/g.gui/main.c:43
+msgid "GUI type"
+msgstr ""
+#: ../general/g.gui/main.c:44
+msgid "Default value: GRASS_GUI if defined, otherwise wxpython"
+msgstr ""
+#: ../general/g.gui/main.c:45
+msgid ""
+"wxpython;wxPython based GUI - wxGUI;tcltk;Tcl/Tk based GUI - GIS Manager "
+"(gis.m);oldtcltk;Old Tcl/Tk based GUI - Display Manager (d.m);text;command "
+"line interface only"
+msgstr ""
+#: ../general/g.gui/main.c:54
+msgid "Name of workspace file"
+msgstr ""
+#: ../general/g.gui/main.c:58
+msgid "Update default GUI setting"
+msgstr ""
+#: ../general/g.gui/main.c:63
+msgid "Do not launch GUI after updating the default GUI setting"
+msgstr ""
+#: ../general/g.gui/main.c:90
+#, c-format
+msgid "<%s> is now the default GUI"
+msgstr ""
+#: ../general/g.gui/main.c:103
+#, c-format
+msgid "Launching '%s' GUI in the background, please wait ..."
+msgstr ""
+#: ../general/g.gui/main.c:107
+msgid "The old d.m GUI is not available for WinGRASS"
+msgstr ""
+#: ../locale/scriptstrings/v.db.update_to_translate.c:1
+msgid ""
+"Allows to update a column in the attribute table connected to a vector map."
+msgstr ""
+#: ../locale/scriptstrings/v.db.update_to_translate.c:2
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:2
+#: ../locale/scriptstrings/v.db.join_to_translate.c:2
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:2
+#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:2
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:2
+#: ../locale/scriptstrings/v.db.addcol_to_translate.c:2
+#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:2
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:2
+#: ../vector/v.db.connect/main.c:50 ../vector/v.to.db/main.c:33
+#: ../vector/v.db.select/main.c:53 ../vector/v.distance/main.c:114
+msgid "vector, database, attribute table"
+msgstr ""
+#: ../locale/scriptstrings/v.db.update_to_translate.c:3
+msgid "Vector map to edit the attribute table for"
+msgstr ""
+#: ../locale/scriptstrings/v.db.update_to_translate.c:4
+msgid "Layer to which the table to be changed is connected"
+msgstr ""
+#: ../locale/scriptstrings/v.db.update_to_translate.c:5
+msgid "Column to update"
+msgstr ""
+#: ../locale/scriptstrings/v.db.update_to_translate.c:6
+msgid ""
+"Value to update the column with (varchar values have to be in single quotes, "
+"e.g. 'grass')"
+msgstr ""
+#: ../locale/scriptstrings/v.db.update_to_translate.c:7
+msgid "Column to query"
+msgstr ""
+#: ../locale/scriptstrings/v.db.update_to_translate.c:8
+msgid ""
+"WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/"
+"col2>1)"
+msgstr ""
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:1
+msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
+msgstr ""
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:2
+msgid "raster, imagery"
+msgstr ""
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:3
+msgid "use transformation rules for LANDSAT-4"
+msgstr ""
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:4
+msgid "use transformation rules for LANDSAT-5"
+msgstr ""
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:5
+msgid "use transformation rules for LANDSAT-7"
+msgstr ""
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:6
+msgid "raster input map (LANDSAT channel 1)"
+msgstr ""
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:7
+msgid "raster input map (LANDSAT channel 2)"
+msgstr ""
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:8
+msgid "raster input map (LANDSAT channel 3)"
+msgstr ""
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:9
+msgid "raster input map (LANDSAT channel 4)"
+msgstr ""
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:10
+msgid "raster input map (LANDSAT channel 5)"
+msgstr ""
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:11
+msgid "raster input map (LANDSAT channel 7)"
+msgstr ""
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:12
+msgid "raster output TC maps prefix"
+msgstr ""
+#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:1
+msgid "Performs auto-balancing of colors for LANDSAT images."
+msgstr ""
+#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:2
+msgid "raster, imagery, colors"
+msgstr ""
+#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:3
+msgid "LANDSAT red channel"
+msgstr ""
+#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:4
+msgid "LANDSAT green channel"
+msgstr ""
+#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:5
+msgid "LANDSAT blue channel"
+msgstr ""
+#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:6
+msgid "Cropping intensity (upper brightness level)"
+msgstr ""
+#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:7
+msgid "Extend colors to full range of data on each channel"
+msgstr ""
+#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:8
+msgid "Preserve relative colors, adjust brightness only"
+msgstr ""
+#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:9
+msgid "Reset to standard color range"
+msgstr ""
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:1
+msgid "Import GetFeature from WFS"
+msgstr ""
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:2
+msgid "vector, import, wfs"
+msgstr ""
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:3
+msgid "GetFeature URL starting with 'http'"
+msgstr ""
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:4
+#: ../locale/scriptstrings/v.in.e00_to_translate.c:6
+#: ../locale/scriptstrings/v.in.geonames_to_translate.c:4
+#: ../locale/scriptstrings/v.centroids_to_translate.c:4
+#: ../locale/scriptstrings/v.in.gns_to_translate.c:4
+#: ../locale/scriptstrings/v.in.lines_to_translate.c:5
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:4
+msgid "Name for output vector map"
+msgstr ""
+#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:1
+msgid ""
+"Brovey transform to merge multispectral and high-res panchromatic channels"
+msgstr ""
+#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:2
+msgid "imagery, fusion, Brovey"
+msgstr ""
+#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:3
+msgid "LANDSAT sensor"
+msgstr ""
+#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:4
+#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:6
+#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:8
+msgid "Sensor"
+msgstr ""
+#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:5
+msgid "QuickBird sensor"
+msgstr ""
+#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:7
+msgid "SPOT sensor"
+msgstr ""
+#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:9
+msgid "Name of input raster map (green: tm2 | qbird_green | spot1)"
+msgstr ""
+#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:10
+msgid "Name of input raster map (NIR: tm4 | qbird_nir | spot2)"
+msgstr ""
+#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:11
+msgid "Name of input raster map (MIR; tm5 | qbird_red | spot3)"
+msgstr ""
+#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:12
+msgid "Name of input raster map (etmpan | qbird_pan | spotpan)"
+msgstr ""
+#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:13
+msgid "Name for output raster map prefix (e.g. 'brov')"
+msgstr ""
+#: ../locale/scriptstrings/v.in.e00_to_translate.c:1
+msgid "Import E00 file into a vector map."
+msgstr ""
+#: ../locale/scriptstrings/v.in.e00_to_translate.c:2
+#: ../locale/scriptstrings/v.convert.all_to_translate.c:2
+#: ../locale/scriptstrings/v.in.lines_to_translate.c:2
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:2
+#: ../vector/v.in.ascii/in.c:48 ../vector/v.in.dwg/main.c:65
+#: ../vector/v.in.ogr/main.c:103 ../vector/v.in.dxf/main.c:60
+msgid "vector, import"
+msgstr ""
+#: ../locale/scriptstrings/v.in.e00_to_translate.c:3
+#: ../locale/scriptstrings/v.in.garmin_to_translate.c:3
+#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:3
+#: ../raster/r.out.tiff/r.out.tiff.c:136 ../raster/r.in.mat/main.c:115
+#: ../raster/r.out.mat/main.c:81
+msgid "Verbose mode"
+msgstr ""
+#: ../locale/scriptstrings/v.in.e00_to_translate.c:4
+msgid "E00 file"
+msgstr ""
+#: ../locale/scriptstrings/v.in.e00_to_translate.c:5
+msgid "Input type point, line or area"
+msgstr ""
+#: ../locale/scriptstrings/v.convert.all_to_translate.c:1
+msgid ""
+"Converts all older versions of GRASS vector maps in current mapset to "
+"current format."
+msgstr ""
+#: ../locale/scriptstrings/v.convert.all_to_translate.c:3
+msgid "run non-interactively"
+msgstr ""
+#: ../locale/scriptstrings/r.plane_to_translate.c:1
+msgid ""
+"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
+"point."
+msgstr ""
+#: ../locale/scriptstrings/r.plane_to_translate.c:2
+#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:2
+msgid "raster, elevation"
+msgstr ""
+#: ../locale/scriptstrings/r.plane_to_translate.c:3
+msgid "Name of raster plane to be created"
+msgstr ""
+#: ../locale/scriptstrings/r.plane_to_translate.c:4
+msgid "Dip of plane. Value must be between -90 and 90 degrees"
+msgstr ""
+#: ../locale/scriptstrings/r.plane_to_translate.c:5
+msgid "Azimuth of the plane. Value must be between 0 and 360 degrees"
+msgstr ""
+#: ../locale/scriptstrings/r.plane_to_translate.c:6
+msgid "Easting coordinate of a point on the plane"
+msgstr ""
+#: ../locale/scriptstrings/r.plane_to_translate.c:7
+msgid "Northing coordinate of a point on the plane"
+msgstr ""
+#: ../locale/scriptstrings/r.plane_to_translate.c:8
+msgid "Elevation coordinate of a point on the plane"
+msgstr ""
+#: ../locale/scriptstrings/r.plane_to_translate.c:9
+msgid "Type of the raster map to be created"
+msgstr ""
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
+msgid ""
+"Reclasses a raster map greater or less than user specified area size (in "
+"hectares)."
+msgstr ""
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:2
+msgid "raster, statistics, aggregation"
+msgstr ""
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:3
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:3
+#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:3
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:3
+#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:5
+#: ../imagery/i.zc/main.c:69 ../raster/r.out.bin/main.c:289
+#: ../raster/r.water.outlet/main.c:55 ../raster/r.random/main.c:57
+msgid "Name of input raster map"
+msgstr ""
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:4
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:4
+#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:5
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:6
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:18
+#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:9
+#: ../imagery/i.ifft/ifftmain.c:83 ../raster/r.in.gridatb/main.c:53
+msgid "Name for output raster map"
+msgstr ""
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
+msgid "Lesser value option that sets the <= area size limit [hectares]"
+msgstr ""
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:6
+msgid "Greater value option that sets the >= area size limit [hectares]"
+msgstr ""
+#: ../locale/scriptstrings/d.shadedmap_to_translate.c:1
+msgid "Drapes a color raster over a shaded relief map using d.his"
+msgstr ""
+#: ../locale/scriptstrings/d.shadedmap_to_translate.c:2
+msgid "Name of shaded relief or aspect map"
+msgstr ""
+#: ../locale/scriptstrings/d.shadedmap_to_translate.c:3
+msgid "Name of raster to drape over relief map"
+msgstr ""
+#: ../locale/scriptstrings/d.shadedmap_to_translate.c:4
+msgid "Percent to brighten"
+msgstr ""
+#: ../locale/scriptstrings/v.colors_to_translate.c:1
+msgid ""
+"Set color rules for features in a vector using a numeric attribute column."
+msgstr ""
+#: ../locale/scriptstrings/v.colors_to_translate.c:2
+msgid "vector, color table"
+msgstr ""
+#: ../locale/scriptstrings/v.colors_to_translate.c:3
+#: ../locale/scriptstrings/v.centroids_to_translate.c:3
+#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:6
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:3
+#: ../locale/scriptstrings/v.report_to_translate.c:5
+#: ../vector/v.hull/main.c:278
+msgid "Name of input vector map"
+msgstr ""
+#: ../locale/scriptstrings/v.colors_to_translate.c:4
+msgid "Name of column containing numeric data"
+msgstr ""
+#: ../locale/scriptstrings/v.colors_to_translate.c:5
+msgid "Layer number of data column"
+msgstr ""
+#: ../locale/scriptstrings/v.colors_to_translate.c:6
+msgid "Name of color column to populate"
+msgstr ""
+#: ../locale/scriptstrings/v.colors_to_translate.c:7
+#: ../locale/scriptstrings/v.colors_to_translate.c:10
+#: ../locale/scriptstrings/v.colors_to_translate.c:12
+#: ../locale/scriptstrings/v.colors_to_translate.c:14
+#: ../locale/scriptstrings/v.colors_to_translate.c:17
+#: ../vector/v.label/main.c:153 ../vector/v.label/main.c:177
+#: ../vector/v.label/main.c:190 ../vector/v.label/main.c:196
+#: ../vector/v.label/main.c:206 ../vector/v.label.sa/main.c:149
+#: ../vector/v.label.sa/main.c:159 ../vector/v.label.sa/main.c:166
+#: ../vector/v.label.sa/main.c:176 ../vector/v.label.sa/main.c:186
+#: ../vector/v.label.sa/main.c:196 ../vector/v.label.sa/main.c:203
+#: ../display/d.vect/main.c:123 ../display/d.vect/main.c:133
+#: ../display/d.vect/main.c:140 ../display/d.vect/main.c:151
+#: ../display/d.vect/main.c:319 ../display/d.vect/main.c:325
+#: ../display/d.vect/main.c:345 ../display/d.rast.num/number.c:101
+#: ../display/d.rast.num/number.c:111 ../display/d.rast.num/number.c:125
+#: ../raster/r.colors/main.c:193 ../raster/r.colors/main.c:207
+#: ../raster/r.colors/main.c:225 ../raster/r.colors/main.c:230
+#: ../raster/r.colors/main.c:235 ../raster/r.colors/main.c:240
+msgid "Colors"
+msgstr ""
+#: ../locale/scriptstrings/v.colors_to_translate.c:8
+msgid "Manually set range (min,max)"
+msgstr ""
+#: ../locale/scriptstrings/v.colors_to_translate.c:9
+#: ../raster/r.colors/main.c:191
+msgid "Type of color table"
+msgstr ""
+#: ../locale/scriptstrings/v.colors_to_translate.c:11
+#: ../raster/r.colors/main.c:201
+msgid "Raster map name from which to copy color table"
+msgstr ""
+#: ../locale/scriptstrings/v.colors_to_translate.c:13
+msgid "Path to rules file"
+msgstr ""
+#: ../locale/scriptstrings/v.colors_to_translate.c:15
+msgid "Save placeholder raster map for use with d.legend"
+msgstr ""
+#: ../locale/scriptstrings/v.colors_to_translate.c:16
+#: ../raster/r.colors/main.c:224
+msgid "Invert colors"
+msgstr ""
+#: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:1
+msgid "Export display monitor to a GpsDrive compatible backdrop image"
+msgstr ""
+#: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:2
+msgid "display, export, GPS"
+msgstr ""
+#: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:3
+msgid "name for new map image (lives in ~/.gpsdrive/maps/)"
+msgstr ""
+#: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:4
+msgid "Make JPEG instead of PNG image"
+msgstr ""
+#: ../locale/scriptstrings/r.univar.sh_to_translate.c:1
+msgid "calculates univariate statistics from a GRASS raster map"
+msgstr ""
+#: ../locale/scriptstrings/r.univar.sh_to_translate.c:2
+#: ../raster/r.univar2/r.univar_main.c:97
+#: ../raster/r.regression.line/main.c:42 ../raster/r.covar/main.c:53
+#: ../raster/r.sum/main.c:46 ../raster/r.median/main.c:46
+#: ../raster/r.kappa/main.c:67 ../raster/r.cross/main.c:75
+#: ../raster/r.neighbors/main.c:108 ../raster/r.surf.gauss/main.c:46
+#: ../raster/r.stats/main.c:103 ../raster/r.mode/main.c:50
+#: ../raster/r.report/main.c:64 ../raster/r.quantile/main.c:254
+#: ../raster/r.average/main.c:51 ../raster/r.surf.area/main.c:86
+#: ../raster/r.coin/main.c:66 ../raster/r.texture/main.c:74
+#: ../raster/r.support.stats/main.c:39 ../raster/r.statistics/main.c:42
+msgid "raster, statistics"
+msgstr ""
+#: ../locale/scriptstrings/r.univar.sh_to_translate.c:3
+msgid "extended statistics (quartiles and percentile)"
+msgstr ""
+#: ../locale/scriptstrings/r.univar.sh_to_translate.c:4
+#: ../display/d.legend/main.c:92 ../display/d.zoom/main.c:90
+msgid "Name of raster map"
+msgstr ""
+#: ../locale/scriptstrings/r.univar.sh_to_translate.c:5
+msgid "Percentile to calculate (requires -e flag)"
+msgstr ""
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:1
+msgid "Exports attribute tables into various formats."
+msgstr ""
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:3
+msgid "GRASS table name"
+msgstr ""
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:4
+msgid "Table file to be exported or DB connection string"
+msgstr ""
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:5
+msgid "Table format"
+msgstr ""
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:6
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:5
+msgid "Name for output table"
+msgstr ""
+#: ../locale/scriptstrings/d.split.frame_to_translate.c:1
+msgid "Split the display into subframes."
+msgstr ""
+#: ../locale/scriptstrings/d.split.frame_to_translate.c:2
+msgid "Number of subframes"
+msgstr ""
+#: ../locale/scriptstrings/d.split.frame_to_translate.c:3
+msgid "Split horizontally not vertically"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:1
+#: ../display/d.rast.edit/main.c:61
+msgid "Interactively edit cell values in a raster map."
+msgstr ""
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:2
+#: ../display/d.rast.edit/main.c:59 ../display/d.rast/main.c:51
+#: ../display/d.colortable/main.c:60 ../display/d.rast.arrow/arrow.c:110
+#: ../display/d.what.rast/main.c:52 ../display/d.rast.num/number.c:84
+#: ../display/d.colors/main.c:50
+msgid "display, raster"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:5
+msgid "Name of aspect raster map"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:6
+msgid "Width of display canvas"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:7
+msgid "Height of display canvas"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:8
+msgid "Minimum size of each cell"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:9
+msgid "Maximum number of rows to load"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:10
+msgid "Maximum number of columns to load"
+msgstr ""
+#: ../locale/scriptstrings/db.dropcol_to_translate.c:1
+msgid "Drops a column from selected attribute table"
+msgstr ""
+#: ../locale/scriptstrings/db.dropcol_to_translate.c:4
+msgid "Table from which to drop attribute column"
+msgstr ""
+#: ../locale/scriptstrings/db.dropcol_to_translate.c:5
+msgid "Name of the column"
+msgstr ""
+#: ../locale/scriptstrings/gis.m_to_translate.c:1
+msgid "GIS manager for GRASS"
+msgstr ""
+#: ../locale/scriptstrings/gis.m_to_translate.c:2
+msgid "Name of GIS manager settings file (.grc)"
+msgstr ""
+#: ../locale/scriptstrings/v.in.geonames_to_translate.c:1
+msgid "Imports geonames.org country files into a GRASS vector points map."
+msgstr ""
+#: ../locale/scriptstrings/v.in.geonames_to_translate.c:2
+#: ../locale/scriptstrings/v.in.gns_to_translate.c:2
+msgid "vector, import, gazetteer"
+msgstr ""
+#: ../locale/scriptstrings/v.in.geonames_to_translate.c:3
+msgid "Uncompressed geonames file from (with .txt extension)"
+msgstr ""
+#: ../locale/scriptstrings/g.manual_to_translate.c:1
+msgid "Display the HTML man pages of GRASS"
+msgstr ""
+#: ../locale/scriptstrings/g.manual_to_translate.c:2
+msgid "general, manual, help"
+msgstr ""
+#: ../locale/scriptstrings/g.manual_to_translate.c:3
+msgid "Display index"
+msgstr ""
+#: ../locale/scriptstrings/g.manual_to_translate.c:4
+msgid "Display as MAN text page instead of HTML page in browser"
+msgstr ""
+#: ../locale/scriptstrings/g.manual_to_translate.c:5
+msgid "Manual entry to be displayed"
+msgstr ""
+#: ../locale/scriptstrings/v.centroids_to_translate.c:1
+msgid "Adds missing centroids to closed boundaries."
+msgstr ""
+#: ../locale/scriptstrings/v.centroids_to_translate.c:2
+msgid "vector, centroid, area"
+msgstr ""
+#: ../locale/scriptstrings/v.centroids_to_translate.c:5
+msgid "Action to be taken"
+msgstr ""
+#: ../locale/scriptstrings/v.centroids_to_translate.c:6
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:17
+#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:10
+#: ../locale/scriptstrings/v.report_to_translate.c:6
+#: ../vector/v.out.vtk/main.c:83
+msgid "Layer number"
+msgstr ""
+#: ../locale/scriptstrings/v.centroids_to_translate.c:7
+msgid "Category number starting value"
+msgstr ""
+#: ../locale/scriptstrings/v.centroids_to_translate.c:8
+#: ../vector/v.category/main.c:112
+msgid "Category increment"
+msgstr ""
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:1
+msgid ""
+"Creates and connects a new attribute table to a given layer of an existing "
+"vector map."
+msgstr ""
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:3
+msgid "Vector map for which to add new attribute table"
+msgstr ""
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:4
+msgid "Name of new attribute table (default: vector map name)"
+msgstr ""
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
+msgid "Layer where to add new attribute table"
+msgstr ""
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:6
+msgid ""
+"Name and type of the new column(s) (types depend on database backend, but "
+"all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:1
+msgid "Tool to maintain GRASS extensions in local GRASS installation."
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:2
+msgid ""
+"Downloads, installs extensions from GRASS Addons SVN repository into local "
+"GRASS installation or removes installed extensions."
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:3
+msgid "general, extensions"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:4
+msgid "Name of extension to install/remove"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:5
+#: ../vector/v.net/main.c:69
+msgid "Operation to be performed"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:6
+msgid "SVN Addons repository URL"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:7
+msgid "Prefix where to install extension"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:8
+msgid "List available modules in the GRASS Addons SVN repository"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:10
+msgid "Install system-wide (may need system administrator rights)"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:11
+msgid "Install system-wide using sudo"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:1
+msgid "Creates a MASK for limiting raster operation."
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:2
+msgid "raster, mask"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:3
+msgid "Raster map to use as MASK"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:5
+msgid "Category values to use for MASK (format: 1 2 3 thru 7 *)"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:7
+msgid "Create inverse MASK from specified 'maskcats' list"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:9
+msgid "Overwrite existing MASK"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:10
+msgid "Remove existing MASK (overrides other options)"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:11
+#: ../raster/r.null/null.c:105
+msgid "Remove"
+msgstr ""
+#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:1
+msgid "Set color rules based on stddev from a map's mean value."
+msgstr ""
+#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:2
+#: ../raster/r.colors/main.c:175
+msgid "raster, color table"
+msgstr ""
+#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:4
+msgid "Color using standard deviation bands"
+msgstr ""
+#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:5
+msgid "Force center at zero"
+msgstr ""
+#: ../locale/scriptstrings/v.in.gns_to_translate.c:1
+msgid ""
+"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
+"points map."
+msgstr ""
+#: ../locale/scriptstrings/v.in.gns_to_translate.c:3
+msgid "Uncompressed GNS file from NGA (with .txt extension)"
+msgstr ""
+#: ../locale/scriptstrings/v.db.join_to_translate.c:1
+msgid "Allows to join a table to a vector map table."
+msgstr ""
+#: ../locale/scriptstrings/v.db.join_to_translate.c:3
+msgid "Vector map to which to join other table"
+msgstr ""
+#: ../locale/scriptstrings/v.db.join_to_translate.c:4
+msgid "Layer where to join"
+msgstr ""
+#: ../locale/scriptstrings/v.db.join_to_translate.c:5
+msgid "Join column in map table"
+msgstr ""
+#: ../locale/scriptstrings/v.db.join_to_translate.c:6
+msgid "Other table name"
+msgstr ""
+#: ../locale/scriptstrings/v.db.join_to_translate.c:7
+msgid "Join column in other table"
+msgstr ""
+#: ../locale/scriptstrings/i.spectral_to_translate.c:1
+msgid ""
+"Displays spectral response at user specified locations in group or images."
+msgstr ""
+#: ../locale/scriptstrings/i.spectral_to_translate.c:2
+msgid "imagery, raster, multispectral"
+msgstr ""
+#: ../locale/scriptstrings/i.spectral_to_translate.c:3
+msgid "Group input"
+msgstr ""
+#: ../locale/scriptstrings/i.spectral_to_translate.c:4
+msgid "Raster input maps"
+msgstr ""
+#: ../locale/scriptstrings/i.spectral_to_translate.c:5
+msgid "Write output to PNG image"
+msgstr ""
+#: ../locale/scriptstrings/i.spectral_to_translate.c:6
+msgid "Use image list and not group"
+msgstr ""
+#: ../locale/scriptstrings/i.spectral_to_translate.c:7
+msgid "Select multiple points"
+msgstr ""
+#: ../locale/scriptstrings/i.spectral_to_translate.c:8
+msgid "Label with coordinates instead of numbering"
+msgstr ""
+#: ../locale/scriptstrings/i.oif_to_translate.c:1
+msgid "Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7"
+msgstr ""
+#: ../locale/scriptstrings/i.oif_to_translate.c:2
+msgid "raster, imagery, statistics"
+msgstr ""
+#: ../locale/scriptstrings/i.oif_to_translate.c:3
+msgid "LANDSAT TM band 1."
+msgstr ""
+#: ../locale/scriptstrings/i.oif_to_translate.c:4
+msgid "LANDSAT TM band 2."
+msgstr ""
+#: ../locale/scriptstrings/i.oif_to_translate.c:5
+msgid "LANDSAT TM band 3."
+msgstr ""
+#: ../locale/scriptstrings/i.oif_to_translate.c:6
+msgid "LANDSAT TM band 4."
+msgstr ""
+#: ../locale/scriptstrings/i.oif_to_translate.c:7
+msgid "LANDSAT TM band 5."
+msgstr ""
+#: ../locale/scriptstrings/i.oif_to_translate.c:8
+msgid "LANDSAT TM band 7."
+msgstr ""
+#: ../locale/scriptstrings/v.build.all_to_translate.c:1
+msgid "Rebuilds topology on all vector maps in the current mapset."
+msgstr ""
+#: ../locale/scriptstrings/v.build.all_to_translate.c:2
+#: ../vector/v.clean/test/topocheck.c:42 ../vector/v.info/main.c:265
+msgid "vector"
+msgstr ""
+#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:1
+msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
+msgstr ""
+#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:2
+msgid "raster, imagery, mosaicking"
+msgstr ""
+#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:3
+msgid "1st map for mosaic (top of image stack)."
+msgstr ""
+#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:4
+msgid "2nd map for mosaic."
+msgstr ""
+#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:5
+msgid "3rd map for mosaic."
+msgstr ""
+#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:6
+msgid "4th map for mosaic."
+msgstr ""
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
+msgid ""
+"Export a raster map to a text file as x,y,z values based on cell centers."
+msgstr ""
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:2
+#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:2
+#: ../raster/r.out.mpeg/main.c:384 ../raster/r.out.tiff/r.out.tiff.c:99
+#: ../raster/r.out.ppm3/main.c:57 ../raster/r.out.vtk/main.c:148
+#: ../raster/r.out.ascii/main.c:59 ../raster/r.out.ppm/main.c:54
+#: ../raster/r.out.bin/main.c:279 ../raster/r.out.pov/main.c:121
+#: ../raster/r.out.arc/main.c:60 ../raster/r.out.gridatb/main.c:44
+#: ../raster/r.out.mat/main.c:64 ../raster/r.out.gdal/main.c:128
+msgid "raster, export"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:1
+msgid "Convert coordinates from one projection to another (cs2cs frontend)."
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:2
+msgid "miscellaneous, projection"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:3
+msgid "Input coordinate file (omit to read from stdin)"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:4
+#: ../locale/scriptstrings/m.proj_to_translate.c:6
+#: ../locale/scriptstrings/m.proj_to_translate.c:8
+#: ../locale/scriptstrings/m.proj_to_translate.c:18
+#: ../locale/scriptstrings/m.proj_to_translate.c:20
+msgid "Files & format"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:5
+msgid "Output coordinate file (omit to send to stdout)"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:9
+msgid "Input projection parameters (PROJ.4 style)"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:10
+#: ../locale/scriptstrings/m.proj_to_translate.c:12
+#: ../locale/scriptstrings/m.proj_to_translate.c:14
+#: ../locale/scriptstrings/m.proj_to_translate.c:16
+msgid "Projections"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:11
+msgid "Output projection parameters (PROJ.4 style)"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:13
+msgid "Use LL WGS84 as input and current location as output projection"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:15
+msgid "Use current location as input and LL WGS84 as output projection"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:17
+msgid ""
+"Output long/lat in decimal degrees, or other projections with many decimal "
+"places"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:19
+msgid ""
+"Script style output in CSV format respecting the field separator settings"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:21
+msgid "Verbose mode (print projection parameters and filenames to stderr)"
+msgstr ""
+#: ../locale/scriptstrings/v.in.lines_to_translate.c:1
+msgid "Import ASCII x,y[,z] coordinates as a series of lines."
+msgstr ""
+#: ../locale/scriptstrings/v.in.lines_to_translate.c:3
+msgid "Create a 3D line from 3 column data"
+msgstr ""
+#: ../locale/scriptstrings/v.in.lines_to_translate.c:4
+msgid "Name of input file (or \"-\" to read from stdin)"
+msgstr ""
+#: ../locale/scriptstrings/d.split_to_translate.c:1
+msgid ""
+"Divides active display into two frames & displays maps/executes commands in "
+"each frame."
+msgstr ""
+#: ../locale/scriptstrings/d.split_to_translate.c:2
+#: ../locale/scriptstrings/d.resize_to_translate.c:2
+#: ../locale/scriptstrings/d.mvmon_to_translate.c:2
+#: ../locale/scriptstrings/d.monsize_to_translate.c:2
+#: ../display/d.colorlist/main.c:35 ../display/d.extend/main.c:31
+#: ../display/d.font.freetype/main.c:59 ../display/d.frame/frame.c:60
+#: ../display/d.erase/main.c:32 ../display/d.font/main.c:46
+msgid "display, setup"
+msgstr ""
+#: ../locale/scriptstrings/d.split_to_translate.c:3
+msgid "Enter raster map to display in 1st frame"
+msgstr ""
+#: ../locale/scriptstrings/d.split_to_translate.c:4
+msgid "Enter command to execute in 1st frame"
+msgstr ""
+#: ../locale/scriptstrings/d.split_to_translate.c:5
+msgid "Enter raster map to display in 2nd frame"
+msgstr ""
+#: ../locale/scriptstrings/d.split_to_translate.c:6
+msgid "Enter command to execute in 2nd frame"
+msgstr ""
+#: ../locale/scriptstrings/d.split_to_translate.c:7
+msgid "How to split display"
+msgstr ""
+#: ../locale/scriptstrings/r.unpack_to_translate.c:1
+msgid "Unpacks a raster map packed with r.pack."
+msgstr ""
+#: ../locale/scriptstrings/r.unpack_to_translate.c:2
+#: ../locale/scriptstrings/r.pack_to_translate.c:2
+msgid "raster, copying"
+msgstr ""
+#: ../locale/scriptstrings/r.unpack_to_translate.c:3
+msgid "Name of input pack file"
+msgstr ""
+#: ../locale/scriptstrings/r.unpack_to_translate.c:4
+msgid "Name for output raster map (default: taken from input file internals)"
+msgstr ""
+#: ../locale/scriptstrings/r.unpack_to_translate.c:5
+msgid "Override projection check (use current location's projection)"
+msgstr ""
+#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:1
+msgid "Import of SPOT VGT NDVI file into a raster map"
+msgstr ""
+#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:2
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:2
+msgid "raster, imagery, import"
+msgstr ""
+#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:3
+msgid "Also import quality map (SM status map layer) and filter NDVI map"
+msgstr ""
+#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:4
+msgid "existing SPOT VGT NDVI HDF file (0001_NDV.HDF)"
+msgstr ""
+#: ../locale/scriptstrings/d.resize_to_translate.c:1
+msgid "Resizes active display monitor"
+msgstr ""
+#: ../locale/scriptstrings/d.resize_to_translate.c:3
+msgid "New width for window"
+msgstr ""
+#: ../locale/scriptstrings/d.resize_to_translate.c:4
+msgid "New height for window"
+msgstr ""
+#: ../locale/scriptstrings/d.mvmon_to_translate.c:1
+msgid "Moves displayed maps to another monitor"
+msgstr ""
+#: ../locale/scriptstrings/d.mvmon_to_translate.c:3
+msgid "clear target monitor before moving"
+msgstr ""
+#: ../locale/scriptstrings/d.mvmon_to_translate.c:4
+msgid "stay with source monitor"
+msgstr ""
+#: ../locale/scriptstrings/d.mvmon_to_translate.c:5
+msgid "kill source monitor after moving"
+msgstr ""
+#: ../locale/scriptstrings/d.mvmon_to_translate.c:6
+msgid "Target monitor"
+msgstr ""
+#: ../locale/scriptstrings/d.mvmon_to_translate.c:7
+msgid "Source monitor"
+msgstr ""
+#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:1
+msgid "Creates shaded relief map from an elevation map (DEM)."
+msgstr ""
+#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:3
+#: ../raster/r.topidx/main.c:42
+msgid "Input elevation map"
+msgstr ""
+#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:4
+msgid "Output shaded relief map name"
+msgstr ""
+#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:5
+msgid "Altitude of the sun in degrees above the horizon"
+msgstr ""
+#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:6
+msgid "Azimuth of the sun in degrees to the east of north"
+msgstr ""
+#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:7
+msgid "Factor for exaggerating relief"
+msgstr ""
+#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:8
+msgid "Scale factor for converting horizontal units to elevation units"
+msgstr ""
+#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:9
+msgid ""
+"Set scaling factor (applies to lat./long. locations only, none: scale=1)"
+msgstr ""
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:1
+msgid "Reconnects vectors to a new database."
+msgstr ""
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:3
+msgid "Name of old database"
+msgstr ""
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:4
+msgid ""
+"The database must be in form printed by v.db.connect -g, i.e. with "
+"substituted variables"
+msgstr ""
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
+msgid "Name of new database"
+msgstr ""
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:6
+msgid "Old schema"
+msgstr ""
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:7
+msgid "New schema"
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:1
+msgid ""
+"Produces tilings of the source projection for use in the destination region "
+"and projection."
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:2
+msgid "raster, tiling"
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:3
+msgid "Produces shell script output"
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:4
+msgid "Produces web map server query string output"
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:5
+msgid ""
+"Name of region to use instead of current region for bounds and resolution"
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:6
+msgid "Source projection"
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:7
+#: ../locale/scriptstrings/r.tileset_to_translate.c:9
+msgid "Conversion factor from units to meters in source projection"
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:8
+msgid "Destination projection, defaults to this location's projection"
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:10
+msgid "Maximum number of columns for a tile in the source projection"
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:11
+msgid "Maximum number of rows for a tile in the source projection"
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:12
+msgid "Number of cells tiles should overlap in each direction"
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:14
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:50
+msgid "Verbosity level"
+msgstr ""
+#: ../locale/scriptstrings/db.droptable_to_translate.c:1
+msgid "Drops an attribute table."
+msgstr ""
+#: ../locale/scriptstrings/db.droptable_to_translate.c:4
+msgid "Table to drop"
+msgstr ""
+#: ../locale/scriptstrings/r.blend_to_translate.c:1
+msgid "Blends color components of two raster maps by a given ratio."
+msgstr ""
+#: ../locale/scriptstrings/r.blend_to_translate.c:2
+msgid "raster"
+msgstr ""
+#: ../locale/scriptstrings/r.blend_to_translate.c:3
+msgid "Name of first raster map for blending"
+msgstr ""
+#: ../locale/scriptstrings/r.blend_to_translate.c:4
+msgid "Name of second raster map for blending"
+msgstr ""
+#: ../locale/scriptstrings/r.blend_to_translate.c:5
+msgid "Base name for red, green and blue output maps containing the blend"
+msgstr ""
+#: ../locale/scriptstrings/r.blend_to_translate.c:6
+msgid "Percentage weight of first map for color blending"
+msgstr ""
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:1
+msgid ""
+"Georeference, rectify and import Terra-ASTER imagery and relative DEM's "
+"using gdalwarp."
+msgstr ""
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:3
+msgid "Input ASTER image to be georeferenced & rectified"
+msgstr ""
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:4
+msgid "ASTER imagery processing type (Level 1A, Level 1B, or relative DEM)"
+msgstr ""
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:5
+msgid ""
+"L1A or L1B band to translate (1, 2, 3n, 3b, 4-14). Can only translate a "
+"single band"
+msgstr ""
+#: ../locale/scriptstrings/v.in.garmin_to_translate.c:1
+msgid ""
+"Download waypoints, routes, and tracks from a Garmin GPS receiver into a "
+"vector map."
+msgstr ""
+#: ../locale/scriptstrings/v.in.garmin_to_translate.c:2
+#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:2
+msgid "vector, import, GPS"
+msgstr ""
+#: ../locale/scriptstrings/v.in.garmin_to_translate.c:4
+msgid "Download Waypoints from GPS"
+msgstr ""
+#: ../locale/scriptstrings/v.in.garmin_to_translate.c:5
+msgid "Download Routes from GPS"
+msgstr ""
+#: ../locale/scriptstrings/v.in.garmin_to_translate.c:6
+msgid "Download Track from GPS"
+msgstr ""
+#: ../locale/scriptstrings/v.in.garmin_to_translate.c:7
+msgid "Force import of track or route data as points"
+msgstr ""
+#: ../locale/scriptstrings/v.in.garmin_to_translate.c:8
+msgid "Use gardump instead of gpstrans as the download program"
+msgstr ""
+#: ../locale/scriptstrings/v.in.garmin_to_translate.c:9
+msgid "Import track in 3D (gardump only)"
+msgstr ""
+#: ../locale/scriptstrings/v.in.garmin_to_translate.c:10
+#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:8
+msgid "Do not attempt projection transform from WGS84"
+msgstr ""
+#: ../locale/scriptstrings/v.in.garmin_to_translate.c:11
+#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:10
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:6
+msgid "Name for output vector map (omit for display to stdout)"
+msgstr ""
+#: ../locale/scriptstrings/v.in.garmin_to_translate.c:12
+msgid "Port Garmin receiver is connected to"
+msgstr ""
+#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:1
+msgid ""
+"Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
+msgstr ""
+#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:2
+msgid "sites, vector, import"
+msgstr ""
+#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:3
+msgid "Run non-interactively"
+msgstr ""
+#: ../locale/scriptstrings/d.m_to_translate.c:1
+msgid "Display manager for GRASS"
+msgstr ""
+#: ../locale/scriptstrings/d.m_to_translate.c:2
+msgid "Name of .dmrc settings file"
+msgstr ""
+msgid "Downloads and imports data from WMS servers."
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:2
+msgid "wms"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:3
+#: ../vector/v.in.dwg/main.c:96 ../vector/v.in.dxf/main.c:82
+msgid "List available layers and exit"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:4
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:8
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:17
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:21
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:23
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:25
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:27
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:29
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:31
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:33
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:35
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:38
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:49
+msgid "Request"
+msgstr ""
+msgid "Skip to downloading (to resume downloads faster)"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:6
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:10
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:40
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:42
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:44
+msgid "Download"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:7
+msgid "Don't request transparent data"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:9
+msgid "Clean existing data out of download directory"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:11
+#: ../raster/r.in.gdal/main.c:155
+msgid "Keep band numbers instead of using band color names"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:12
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:14
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:19
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:46
+msgid "Import"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:13
+msgid "Don't reproject the data, just patch it"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:15
+msgid "Use GET method instead of POST data method"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:16
+msgid "This may be needed to connect to servers which lack POST capability"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:20
+msgid "Mapserver to request data from"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:22
+msgid "Layers to request from map server"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:24
+msgid "Styles to request from map server"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:26
+msgid "Source projection to request from server"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:28
+msgid "Image format requested from the server"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:30
+msgid "Addition query options for server"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:32
+msgid "Maximum columns to request at a time"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:34
+msgid "Maximum rows to request at a time"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:36
+msgid "Additional options for r.tileset"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:37
+msgid "Named region to request data for. Current region used if omitted"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:39
+msgid "Folder to save downloaded data to"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:41
+msgid "Additional options for wget"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:43
+msgid "Additional options for curl"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:45
+msgid "Reprojection method to use"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:47
+msgid "Filename to save capabilities XML file to"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:48
+msgid "Requires list available layers flag"
+msgstr ""
+#: ../locale/scriptstrings/r.pack_to_translate.c:1
+msgid "Packs up a raster map and support files for copying."
+msgstr ""
+#: ../locale/scriptstrings/r.pack_to_translate.c:3
+msgid "Name of raster map to pack up"
+msgstr ""
+#: ../locale/scriptstrings/r.pack_to_translate.c:4
+msgid "Name for output file (default is input-map.pack)"
+msgstr ""
+#: ../locale/scriptstrings/d.polar_to_translate.c:1
+msgid "Draws polar diagram of angle map such as aspect or flow directions"
+msgstr ""
+#: ../locale/scriptstrings/d.polar_to_translate.c:2
+#: ../locale/scriptstrings/d.correlate_to_translate.c:2
+msgid "display, diagram"
+msgstr ""
+#: ../locale/scriptstrings/d.polar_to_translate.c:3
+msgid "Name of raster angle map"
+msgstr ""
+#: ../locale/scriptstrings/d.polar_to_translate.c:4
+msgid "Pixel value to be interpreted as undefined (different from NULL)"
+msgstr ""
+#: ../locale/scriptstrings/d.polar_to_translate.c:5
+msgid "Name of optional EPS output file"
+msgstr ""
+#: ../locale/scriptstrings/d.polar_to_translate.c:6
+msgid "Plot using Xgraph"
+msgstr ""
+#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:1
+msgid ""
+"Drops a column from the attribute table connected to a given vector map."
+msgstr ""
+#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:3
+msgid "Vector map for which to drop attribute column"
+msgstr ""
+#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:4
+msgid "Layer where to drop column"
+msgstr ""
+#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:5
+msgid "Name of the column to drop"
+msgstr ""
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:1
+msgid "Uploads vector values at positions of vector points to the table."
+msgstr ""
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:3
+msgid "Vector map to modify"
+msgstr ""
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:4
+msgid "Layer in the vector to be modified"
+msgstr ""
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:5
+msgid "Column to be updated with the query result"
+msgstr ""
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:6
+msgid "Vector map to be queried"
+msgstr ""
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:7
+msgid "Layer of the query vector containing data"
+msgstr ""
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:8
+msgid "Column to be queried"
+msgstr ""
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:9
+msgid "Maximum query distance in map units"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:1
+msgid "Displays a raster map and its legend on a graphics window"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:2
+#: ../locale/scriptstrings/d.redraw_to_translate.c:2
+#: ../visualization/ximgview/main.c:270 ../display/d.mon/cmd/main.c:49
+msgid "display"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:3
+#: ../display/d.legend/main.c:184
+msgid "Flip legend"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:4
+msgid "Omit entries with missing label"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:5
+msgid "Name of raster map to display"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:6
+msgid "Number of lines to appear in the legend"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:7
+msgid "Name of raster map to generate legend from"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:8
+msgid "Name of raster map to print in legend"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:9
+msgid "Position of vertical map-legend separator (in percent)"
+msgstr ""
+#: ../locale/scriptstrings/r.in.srtm_to_translate.c:1
+msgid "Import SRTM HGT files into GRASS"
+msgstr ""
+#: ../locale/scriptstrings/r.in.srtm_to_translate.c:2
+#: ../raster/r.in.bin/main.c:234 ../raster/r.external/main.c:520
+#: ../raster/r.in.gdal/main.c:79 ../raster/r.in.poly/main.c:29
+#: ../raster/r.in.arc/main.c:59 ../raster/r.in.gridatb/main.c:41
+#: ../raster/r.in.mat/main.c:92
+msgid "raster, import"
+msgstr ""
+#: ../locale/scriptstrings/r.in.srtm_to_translate.c:3
+msgid "SRTM input tile (file without .hgt.zip extension)"
+msgstr ""
+#: ../locale/scriptstrings/r.in.srtm_to_translate.c:4
+msgid "Output raster map (default: input tile)"
+msgstr ""
+#: ../locale/scriptstrings/r.in.srtm_to_translate.c:5
+msgid "Input is a 1-arcsec tile (default: 3-arcsec)"
+msgstr ""
+#: ../locale/scriptstrings/v.db.addcol_to_translate.c:1
+msgid ""
+"Adds one or more columns to the attribute table connected to a given vector "
+"map."
+msgstr ""
+#: ../locale/scriptstrings/v.db.addcol_to_translate.c:3
+msgid "Name of vector map for which to edit attribute table"
+msgstr ""
+#: ../locale/scriptstrings/v.db.addcol_to_translate.c:4
+msgid "Layer number where to add column(s)"
+msgstr ""
+#: ../locale/scriptstrings/v.db.addcol_to_translate.c:5
+#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:11
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:6
+msgid ""
+"A single vector map can be connected to multiple database tables. This "
+"number determines which table to use."
+msgstr ""
+#: ../locale/scriptstrings/v.db.addcol_to_translate.c:6
+msgid "Name and type of the new column(s) ('name type [,name type, ...]')"
+msgstr ""
+#: ../locale/scriptstrings/v.db.addcol_to_translate.c:7
+msgid ""
+"Data types depend on database backend, but all support VARCHAR(), INT, "
+"DOUBLE PRECISION and DATE"
+msgstr ""
+#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:1
+msgid "Exports GRASS raster into GDAL supported formats."
+msgstr ""
+#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:3
+#: ../raster/r.out.gdal/main.c:132
+msgid "List supported output formats"
+msgstr ""
+#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:4
+msgid "Region sensitive output"
+msgstr ""
+#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:6
+#: ../raster/r.out.gdal/main.c:154
+msgid "GIS format to write (case sensitive, see also -l flag)"
+msgstr ""
+#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:7
+#: ../raster/r.out.gdal/main.c:175
+msgid "File type"
+msgstr ""
+#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:8
+#: ../raster/r.out.mpeg/main.c:406
+msgid "Name for output file"
+msgstr ""
+#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:9
+msgid ""
+"Creation option to the output format driver. Multiple options may be listed"
+msgstr ""
+#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:10
+msgid "Metadata key passed on the output dataset if possible"
+msgstr ""
+#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:1
+msgid "Calculate new raster map from a r.mapcalc expression."
+msgstr ""
+#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:2
+msgid "A"
+msgstr ""
+#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:3
+msgid "B"
+msgstr ""
+#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:4
+msgid "C"
+msgstr ""
+#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:5
+msgid "D"
+msgstr ""
+#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:6
+msgid "E"
+msgstr ""
+#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:7
+msgid "F"
+msgstr ""
+#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:8
+#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:8
+msgid "Formula (e.g. A-B or A*C+B)"
+msgstr ""
+#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:10
+#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:10
+msgid "Show help"
+msgstr ""
+#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:11
+msgid "Expert mode (enter a set of r.mapcalc expressions)"
+msgstr ""
+#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:12
+#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:12
+msgid "Do not overwrite existing map"
+msgstr ""
+#: ../locale/scriptstrings/db.test_to_translate.c:1
+msgid "Test database driver, database must exist and set by db.connect."
+msgstr ""
+#: ../locale/scriptstrings/db.test_to_translate.c:3
+msgid "Test name"
+msgstr ""
+#: ../locale/scriptstrings/d.slide.show_to_translate.c:1
+msgid "Slide show of GRASS raster/vector maps."
+msgstr ""
+#: ../locale/scriptstrings/d.slide.show_to_translate.c:2
+msgid "display, slideshow"
+msgstr ""
+#: ../locale/scriptstrings/d.slide.show_to_translate.c:3
+msgid "Show vector maps rather than raster maps"
+msgstr ""
+#: ../locale/scriptstrings/d.slide.show_to_translate.c:4
+msgid "Map prefix. Specify character(s) to view selected maps only"
+msgstr ""
+#: ../locale/scriptstrings/d.slide.show_to_translate.c:5
+msgid "Map number show across the monitor"
+msgstr ""
+#: ../locale/scriptstrings/d.slide.show_to_translate.c:6
+msgid "Map number show down the monitor"
+msgstr ""
+#: ../locale/scriptstrings/d.slide.show_to_translate.c:7
+msgid "Mapsets to use. Specify multiple mapsets comma separated"
+msgstr ""
+#: ../locale/scriptstrings/d.slide.show_to_translate.c:8
+msgid "Number of seconds to pause between slides"
+msgstr ""
+#: ../locale/scriptstrings/v.univar.sh_to_translate.c:1
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:1
+msgid ""
+"Calculates univariate statistics on selected table column for a GRASS vector "
+"map."
+msgstr ""
+#: ../locale/scriptstrings/v.univar.sh_to_translate.c:2
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:2
+#: ../vector/v.kcv/main.c:76 ../vector/v.univar/main.c:71
+#: ../vector/v.qcount/main.c:69 ../vector/lidar/v.outlier/main.c:73
+#: ../vector/v.class/main.c:45 ../vector/v.normal/main.c:79
+#: ../vector/v.random/main.c:84
+msgid "vector, statistics"
+msgstr ""
+#: ../locale/scriptstrings/v.univar.sh_to_translate.c:3
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:3
+msgid "Extended statistics (quartiles and 90th percentile)"
+msgstr ""
+#: ../locale/scriptstrings/v.univar.sh_to_translate.c:4
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:4
+msgid "Name of data table"
+msgstr ""
+#: ../locale/scriptstrings/v.univar.sh_to_translate.c:5
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:5
+msgid "Column on which to calculate statistics (must be numeric)"
+msgstr ""
+#: ../locale/scriptstrings/v.univar.sh_to_translate.c:6
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
+msgid "Database/directory for table"
+msgstr ""
+#: ../locale/scriptstrings/v.univar.sh_to_translate.c:7
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
+msgid "Database driver"
+msgstr ""
+#: ../locale/scriptstrings/v.univar.sh_to_translate.c:8
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:47
+#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:13
+msgid "WHERE conditions of SQL statement without 'where' keyword"
+msgstr ""
+msgid ""
+"Import waypoints, routes, and tracks from a GPS receiver or GPS download "
+"file into a vector map."
+msgstr ""
+#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:4
+msgid "Import waypoints"
+msgstr ""
+#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:5
+msgid "Import routes"
+msgstr ""
+#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:6
+msgid "Import track"
+msgstr ""
+#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:7
+msgid "Force vertices of track or route data as points"
+msgstr ""
+#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:9
+msgid "Device or file used to import data"
+msgstr ""
+#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:11
+msgid "Format of GPS input data (use gpsbabel supported formats)"
+msgstr ""
+#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:12
+msgid ""
+"Projection of input data (PROJ.4 style), if not set Lat/Lon WGS84 is assumed"
+msgstr ""
+#: ../locale/scriptstrings/d.out.png_to_translate.c:1
+msgid "Saves active display monitor to PNG file in home directory"
+msgstr ""
+#: ../locale/scriptstrings/d.out.png_to_translate.c:2
+#: ../locale/scriptstrings/d.out.file_to_translate.c:2
+msgid "display, export"
+msgstr ""
+#: ../locale/scriptstrings/d.out.png_to_translate.c:3
+msgid "Name of PNG file"
+msgstr ""
+#: ../locale/scriptstrings/d.out.png_to_translate.c:4
+msgid "Resolution of output file (single=1, double=2, quad=4)"
+msgstr ""
+#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:1
+msgid ""
+"Renames a column in the attribute table connected to a given vector map."
+msgstr ""
+#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:3
+msgid "Vector map for which to rename attribute column"
+msgstr ""
+#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:4
+msgid "Layer where to rename column"
+msgstr ""
+#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:5
+msgid "Old and new name of the column (old,new)"
+msgstr ""
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:1
+msgid "Fills no-data areas in raster maps using spline interpolation."
+msgstr ""
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:2
+msgid "raster, elevation, interpolation"
+msgstr ""
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:3
+msgid "Name of input raster map in which to fill nulls"
+msgstr ""
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:4
+msgid "Name for output raster map with nulls filled by interpolation"
+msgstr ""
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:5
+msgid "Spline tension parameter"
+msgstr ""
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:6
+msgid "Spline smoothing parameter"
+msgstr ""
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:7
+#: ../raster/r.resamp.interp/main.c:83
+msgid "Interpolation method"
+msgstr ""
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:1
+msgid "Imports Mapgen or Matlab-ASCII vector maps into GRASS."
+msgstr ""
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:3
+msgid "Input map is in Matlab format"
+msgstr ""
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:4
+msgid "Create a 3D vector points map from 3 column Matlab data"
+msgstr ""
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:5
+msgid "Name of input file in Mapgen/Matlab format"
+msgstr ""
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:1
+msgid "Imports attribute tables in various formats."
+msgstr ""
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:3
+msgid "Table file to be imported or DB connection string"
+msgstr ""
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:4
+msgid "Table name of SQL DB table"
+msgstr ""
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:6
+msgid "Name for auto-generated unique key column"
+msgstr ""
+msgid "Displays thematic vector map"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:2
+msgid "display, vector, thematic, legend"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:3
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:44
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:48
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:51
+msgid "Files"
+msgstr ""
+#: ../display/d.zoom/main.c:100
+msgid "Name of vector map"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:7
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:9
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:11
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:13
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:16
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:25
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:46
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:53
+msgid "Theme"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:6
+#: ../vector/v.to.db/parse.c:36 ../vector/v.net.bridge/main.c:63
+#: ../raster/r.to.vect/main.c:64
+msgid "Feature type"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:8
+msgid "Name of attribute column to use for thematic display (must be numeric)"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:10
+msgid "Type of thematic display"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:12
+msgid "Thematic divisions of data for display"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:14
+msgid "Break points for custom breaks option"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:15
+msgid "Separate values by spaces (0 10 20 30 ...)"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:18
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:20
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:23
+#: ../vector/v.in.ascii/in.c:84 ../vector/v.in.ascii/in.c:91
+#: ../vector/v.in.ascii/in.c:103 ../vector/v.in.ascii/in.c:113
+#: ../vector/v.in.ascii/in.c:123 ../vector/v.in.ascii/in.c:133
+#: ../vector/v.in.ascii/in.c:157 ../vector/v.in.ascii/in.c:162
+#: ../vector/v.in.ascii/in.c:168 ../vector/v.transform/main.c:114
+#: ../vector/v.out.ascii/out.c:67 ../vector/v.out.ascii/out.c:77
+#: ../vector/v.out.ascii/out.c:84 ../vector/v.out.ascii/out.c:97
+#: ../raster/r.random/main.c:95
+msgid "Points"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:19
+msgid "Vector point icon for point data"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:21
+msgid "Icon size for point data"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:22
+msgid "Minimum icon size/line width for graduated points/lines)"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:24
+msgid "Maximum icon size/line width for graduated points and lines"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:26
+msgid "Number of classes for interval theme (integer)"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:27
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:30
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:33
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:36
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:39
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:55
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:57
+#: ../display/d.grid/main.c:76 ../display/d.grid/main.c:81
+#: ../display/d.grid/main.c:87
+msgid "Color"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:28
+msgid "Color scheme for graduated color mapping"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:29
+msgid "Select 'single_color' for graduated point/line display"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:31
+msgid "Color for graduated points map"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:32
+msgid "GRASS named color or R:G:B triplet. Set color scheme to single color"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:34
+msgid "Color for graduated lines or point/area outlines"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:35
+msgid "GRASS named color or R:G:B triplet. Set color scheme to single color."
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:37
+msgid "Beginning color for custom color gradient"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:38
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:41
+msgid "Must be expressed as R:G:B triplet"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:40
+msgid "Ending color for custom color gradient"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:42
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:59
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:61
+msgid "Misc"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:43
+msgid "Select x11 display monitor for legend"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:45
+msgid "Save thematic map commands to group file for GIS Manager"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:49
+msgid "Root for the name of psmap instruction files to be in current directory"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:50
+msgid "If not set, no psmap instruction files will be created)"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:52
+msgid "Name of group file where thematic map commands will be saved"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:54
+msgid "Create graphic legend in x11 display monitor"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:56
+msgid "Only draw fills (no outlines) for areas and points"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:58
+msgid "Update color values to GRASSRGB column in attribute table"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:60
+msgid "Output legend for GIS Manager (for scripting use only)"
+msgstr ""
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:62
+msgid "Use math notation brackets in legend"
+msgstr ""
+msgid ""
+"Exports a vector map to a GPS receiver or file format supported by GpsBabel."
+msgstr ""
+#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:2
+msgid "vector, export, GPS"
+msgstr ""
+#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:3
+msgid "Export as waypoints"
+msgstr ""
+#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:4
+msgid "Export as routes"
+msgstr ""
+#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:5
+msgid "Export as tracks"
+msgstr ""
+#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:7
+msgid "Feature type(s)"
+msgstr ""
+#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:8
+msgid "Name for output file or GPS device"
+msgstr ""
+#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:9
+msgid "GpsBabel supported output format"
+msgstr ""
+#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:12
+#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:15
+msgid "Subset"
+msgstr ""
+#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:14
+msgid "Example: income < 1000 and inhab >= 10000"
+msgstr ""
+#: ../locale/scriptstrings/r.li.setup_to_translate.c:1
+msgid "Configuration editor for r.li.'index'"
+msgstr ""
+#: ../locale/scriptstrings/r.li.setup_to_translate.c:2
+msgid "raster, landscape structure analysis"
+msgstr ""
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:1
+msgid ""
+"Dissolves boundaries between adjacent areas sharing a common category number "
+"or attribute."
+msgstr ""
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:2
+msgid "vector, area, dissolve"
+msgstr ""
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:5
+msgid "Layer number. If -1, all layers are extracted."
+msgstr ""
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:7
+msgid "Name of column used to dissolve common boundaries"
+msgstr ""
+#: ../locale/scriptstrings/d.redraw_to_translate.c:1
+msgid "Redraws the current display frame in the GRASS monitor"
+msgstr ""
+#: ../locale/scriptstrings/d.redraw_to_translate.c:3
+msgid "Redraw all frames"
+msgstr ""
+#: ../locale/scriptstrings/d.redraw_to_translate.c:4
+msgid "Do not preserve individual regions when redrawing all frames"
+msgstr ""
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
+msgid "Removes existing attribute table of a vector map."
+msgstr ""
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:3
+msgid "Force removal (required for actual deletion of table)"
+msgstr ""
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:4
+msgid "Vector map from which to remove attribute table"
+msgstr ""
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:5
+msgid "Name of existing attribute table (default: vector map name)"
+msgstr ""
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:6
+msgid "Layer from which to drop linked attribute table"
+msgstr ""
+#: ../locale/scriptstrings/d.monsize_to_translate.c:1
+msgid "Selects/starts specified monitor at specified size"
+msgstr ""
+#: ../locale/scriptstrings/d.monsize_to_translate.c:3
+msgid "Display monitor to start"
+msgstr ""
+#: ../locale/scriptstrings/d.monsize_to_translate.c:4
+msgid "Width in pixels of new display monitor"
+msgstr ""
+#: ../locale/scriptstrings/d.monsize_to_translate.c:5
+msgid "Height in pixels of new display monitor"
+msgstr ""
+#: ../locale/scriptstrings/d.correlate_to_translate.c:1
+msgid "Prints a graph of the correlation between data layers (in pairs)."
+msgstr ""
+#: ../locale/scriptstrings/d.correlate_to_translate.c:3
+#: ../locale/scriptstrings/d.correlate_to_translate.c:4
+#: ../locale/scriptstrings/d.correlate_to_translate.c:5
+#: ../locale/scriptstrings/d.correlate_to_translate.c:6
+msgid "raster input map"
+msgstr ""
+#: ../locale/scriptstrings/d.out.file_to_translate.c:1
+msgid "Saves the contents of the active display monitor to a graphics file."
+msgstr ""
+#: ../locale/scriptstrings/d.out.file_to_translate.c:3
+msgid "Name for output file (do NOT add extension)"
+msgstr ""
+#: ../locale/scriptstrings/d.out.file_to_translate.c:4
+#: ../misc/m.nviz.image/args.c:102
+msgid "Graphics file format"
+msgstr ""
+#: ../locale/scriptstrings/d.out.file_to_translate.c:5
+msgid "Dimensions of output file versus current window size"
+msgstr ""
+#: ../locale/scriptstrings/d.out.file_to_translate.c:6
+msgid "(same=1, double size=2, quadruple size=4)"
+msgstr ""
+#: ../locale/scriptstrings/d.out.file_to_translate.c:7
+#: ../locale/scriptstrings/d.out.file_to_translate.c:9
+#: ../locale/scriptstrings/d.out.file_to_translate.c:12
+#: ../locale/scriptstrings/d.out.file_to_translate.c:15
+#: ../locale/scriptstrings/d.out.file_to_translate.c:28
+#: ../locale/scriptstrings/d.out.file_to_translate.c:30
+msgid "Images"
+msgstr ""
+#: ../locale/scriptstrings/d.out.file_to_translate.c:8
+msgid "Width and height of output image (overrides resolution setting)"
+msgstr ""
+#: ../locale/scriptstrings/d.out.file_to_translate.c:10
+msgid "Compression for PNG files"
+msgstr ""
+#: ../locale/scriptstrings/d.out.file_to_translate.c:11
+msgid "(0=none, 1=fastest, 9=most; lossless, only time vs. filesize)"
+msgstr ""
+#: ../locale/scriptstrings/d.out.file_to_translate.c:13
+msgid "File size/quality for JPEG files"
+msgstr ""
+#: ../locale/scriptstrings/d.out.file_to_translate.c:14
+msgid "(10=smallest/worst, 100=largest/best)"
+msgstr ""
+#: ../locale/scriptstrings/d.out.file_to_translate.c:16
+msgid "Paper size for PostScript output"
+msgstr ""
+#: ../locale/scriptstrings/d.out.file_to_translate.c:17
+#: ../locale/scriptstrings/d.out.file_to_translate.c:19
+#: ../locale/scriptstrings/d.out.file_to_translate.c:32
+msgid "PostScript"
+msgstr ""
+#: ../locale/scriptstrings/d.out.file_to_translate.c:18
+msgid "PostScript level (only limits functionality!)"
+msgstr ""
+#: ../locale/scriptstrings/d.out.file_to_translate.c:20
+msgid "GeoTIFF creation option(s)"
+msgstr ""
+#: ../locale/scriptstrings/d.out.file_to_translate.c:21
+#: ../raster/r.out.gdal/main.c:192
+msgid "In the form of \"NAME=VALUE\", separate multiple entries with a comma."
+msgstr ""
+#: ../locale/scriptstrings/d.out.file_to_translate.c:22
+#: ../locale/scriptstrings/d.out.file_to_translate.c:25
+#: ../locale/scriptstrings/d.out.file_to_translate.c:34
+msgid "GeoTIFF"
+msgstr ""
+#: ../locale/scriptstrings/d.out.file_to_translate.c:23
+msgid "GeoTIFF metadata key(s) and value(s) to add"
+msgstr ""
+#: ../locale/scriptstrings/d.out.file_to_translate.c:24
+msgid ""
+"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma."
+msgstr ""
+#: ../locale/scriptstrings/d.out.file_to_translate.c:26
+msgid "Set background color to black (white default)"
+msgstr ""
+#: ../locale/scriptstrings/d.out.file_to_translate.c:27
+msgid "Set transparent background"
+msgstr ""
+#: ../locale/scriptstrings/d.out.file_to_translate.c:29
+msgid "Use the Cario driver to render images"
+msgstr ""
+#: ../locale/scriptstrings/d.out.file_to_translate.c:31
+msgid "Set paper orientation to landscape (for PostScript output)"
+msgstr ""
+#: ../locale/scriptstrings/d.out.file_to_translate.c:33
+msgid "Do not crop away margins"
+msgstr ""
+msgid "Calculates new grid3D volume from r3.mapcalc expression."
+msgstr ""
+#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:2
+msgid "A (grid3D file)"
+msgstr ""
+#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:3
+msgid "B (grid3D file)"
+msgstr ""
+#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:4
+msgid "C (grid3D file)"
+msgstr ""
+#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:5
+msgid "D (grid3D file)"
+msgstr ""
+#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:6
+msgid "E (grid3D file)"
+msgstr ""
+#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:7
+msgid "F (grid3D file)"
+msgstr ""
+#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:9
+msgid "Name for output grid3D volume"
+msgstr ""
+#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:11
+msgid "Expert mode (enter a set of r3.mapcalc expressions)"
+msgstr ""
+#: ../locale/scriptstrings/v.report_to_translate.c:1
+msgid "Reports geometry statistics for vectors."
+msgstr ""
+#: ../locale/scriptstrings/v.report_to_translate.c:2
+msgid "vector, report, statistics"
+msgstr ""
+#: ../locale/scriptstrings/v.report_to_translate.c:3
+msgid "Reverse sort the result"
+msgstr ""
+#: ../locale/scriptstrings/v.report_to_translate.c:4
+msgid "Sort the result"
+msgstr ""
+#: ../locale/scriptstrings/v.report_to_translate.c:7
+msgid "Value to calculate"
+msgstr ""
+#: ../locale/scriptstrings/v.report_to_translate.c:8
+msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
+msgstr ""
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:1
+msgid ""
+"Calculates univariate statistics from a raster map based on vector polygons "
+"and uploads statistics to new attribute columns."
+msgstr ""
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:2
+msgid "vector, raster, statistics"
+msgstr ""
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:3
+msgid "Continue if upload column(s) already exist"
+msgstr ""
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:4
+#: ../vector/v.univar/main.c:107 ../raster/r.univar2/r.univar_main.c:64
+#: ../raster/r.univar2/r3.univar_main.c:65
+msgid "Calculate extended statistics"
+msgstr ""
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:5
+msgid "Name of vector polygon map"
+msgstr ""
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:6
+msgid ""
+"number determines which table to use"
+msgstr ""
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:7
+msgid "Name of raster map to calculate statistics from"
+msgstr ""
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:8
+msgid "Column prefix for new attribute columns"
+msgstr ""
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:9
+#: ../vector/v.univar/main.c:99 ../raster/r.univar2/r.univar_main.c:52
+#: ../raster/r.univar2/r3.univar_main.c:53
+msgid "Percentile to calculate (requires extended statistics flag)"
+msgstr ""
+#: ../ps/ps.map/ps_vlines.c:55 ../ps/ps.map/ps_vpoints.c:71
+#: ../ps/ps.map/ps_vareas.c:163
+msgid "Cannot load data from table"
+msgstr ""
+#: ../ps/ps.map/ps_vlines.c:83 ../ps/ps.map/ps_vpoints.c:127
+#: ../ps/ps.map/ps_vareas.c:66 ../ps/ps.map/ps_vareas.c:77
+msgid "Read error in vector map"
+msgstr ""
+#: ../ps/ps.map/ps_vlines.c:118 ../ps/ps.map/ps_vpoints.c:164
+#: ../ps/ps.map/ps_vpoints.c:175 ../ps/ps.map/ps_vpoints.c:199
+#: ../ps/ps.map/ps_vpoints.c:240 ../ps/ps.map/ps_vpoints.c:250
+#: ../ps/ps.map/ps_vareas.c:101
+#, c-format
+msgid "No record for category [%d]"
+msgstr ""
+#: ../ps/ps.map/ps_vlines.c:124 ../ps/ps.map/ps_vpoints.c:205
+#: ../ps/ps.map/ps_vareas.c:107
+#, c-format
+msgid "Invalid RGB color definition in column <%s> for category [%d]"
+msgstr ""
+#: ../ps/ps.map/ps_vpoints.c:87 ../ps/ps.map/do_plt.c:147
+msgid "Cannot read symbol, using default icon"
+msgstr ""
+#: ../ps/ps.map/ps_vpoints.c:181
+#, c-format
+msgid "Attribute is of invalid size [%.3f] for category [%d]"
+msgstr ""
+#: ../ps/ps.map/eps.c:19
+#, c-format
+msgid "Can't open eps file <%s>"
+msgstr ""
+#: ../ps/ps.map/eps.c:38
+#, c-format
+msgid "Bounding box in eps file <%s> was not found"
+msgstr ""
+#: ../ps/ps.map/do_masking.c:23
+msgid "Can't open temporary PostScript mask file."
+msgstr ""
+#: ../ps/ps.map/r_colortable.c:61 ../ps/ps.map/r_vlegend.c:49
+#: ../ps/ps.map/r_info.c:48
+msgid "illegal where request"
+msgstr ""
+#: ../ps/ps.map/r_colortable.c:69
+msgid "illegal width request"
+msgstr ""
+#: ../ps/ps.map/r_colortable.c:77
+msgid "illegal height request"
+msgstr ""
+#: ../ps/ps.map/r_colortable.c:94
+msgid "illegal range request"
+msgstr ""
+#: ../ps/ps.map/r_colortable.c:110
+msgid "illegal columns request"
+msgstr ""
+#: ../ps/ps.map/r_colortable.c:129
+msgid "Unsupported color request (colortable)"
+msgstr ""
+#: ../ps/ps.map/r_colortable.c:131
+msgid "illegal color request (colortable)"
+msgstr ""
+#: ../ps/ps.map/r_colortable.c:158
+msgid "illegal colortabe sub-request"
+msgstr ""
+#: ../ps/ps.map/r_colortable.c:169
+msgid "No raster selected for colortable!"
+msgstr ""
+#: ../ps/ps.map/map_setup.c:88
+#, c-format
+msgid "Scale set to %s."
+msgstr ""
+#: ../ps/ps.map/ps_raster.c:43
+msgid "Can't create temporary PostScript mask file."
+msgstr ""
+#: ../ps/ps.map/ps_raster.c:103
+#, c-format
+msgid "Reading raster map <%s in %s> ..."
+msgstr ""
+#: ../ps/ps.map/ps_raster.c:106
+#, c-format
+msgid "Reading raster maps in group <%s> ..."
+msgstr ""
+#: ../ps/ps.map/r_vlegend.c:86 ../ps/ps.map/r_info.c:93
+msgid "illegal border color request"
+msgstr ""
+#: ../ps/ps.map/r_vlegend.c:97
+msgid "illegal vlegend sub-request"
+msgstr ""
+#: ../ps/ps.map/r_info.c:67
+msgid "Unsupported color request"
+msgstr ""
+#: ../ps/ps.map/r_info.c:69
+msgid "illegal color request"
+msgstr ""
+#: ../ps/ps.map/r_info.c:81
+msgid "illegal bgcolor request"
+msgstr ""
+#: ../ps/ps.map/r_info.c:103
+msgid "illegal mapinfo sub-request"
+msgstr ""
+#: ../ps/ps.map/outl_io.c:72 ../raster/r.neighbors/main.c:216
+#: ../raster/r.series/main.c:217
+#, c-format
+msgid "Unable to open raster map <%s> in mapset <%s>"
+msgstr ""
+#: ../ps/ps.map/r_vpoints.c:244
+#, c-format
+msgid ""
+"The mapping instruction <%s> will be renamed to <%s> in future versions of "
+"GRASS. Please use <%s> instead."
+msgstr ""
+#: ../ps/ps.map/r_group.c:31
+msgid "Can't get group information"
+msgstr ""
+#: ../ps/ps.map/do_labels.c:43
+#, c-format
+msgid "Can't open label file <%s> in mapset <%s>"
+msgstr ""
+#: ../ps/ps.map/do_labels.c:47
+#, c-format
+msgid "Reading labels file <%s in %s> ..."
+msgstr ""
+#: ../ps/ps.map/do_labels.c:65
+#, c-format
+msgid "Can't open temporary label file <%s>"
+msgstr ""
+#: ../ps/ps.map/do_labels.c:68
+msgid "Reading text file ..."
+msgstr ""
+#: ../ps/ps.map/do_labels.c:161
+msgid "Text labels: 'fontsize' given so ignoring 'size'"
+msgstr ""
+#: ../ps/ps.map/ps_clrtbl.c:35 ../ps/ps.map/ps_fclrtbl.c:46
+#, c-format
+msgid "Creating color table for <%s in %s>..."
+msgstr ""
+#: ../ps/ps.map/ps_clrtbl.c:39 ../display/d.legend/main.c:269
+#: ../display/d.histogram/main.c:168
+#, c-format
+msgid "Category file for <%s> not available"
+msgstr ""
+#: ../ps/ps.map/ps_clrtbl.c:44 ../ps/ps.map/ps_fclrtbl.c:69
+msgid "Unable to read colors for colorbar"
+msgstr ""
+#: ../ps/ps.map/ps_clrtbl.c:54
+msgid ""
+"Your cats/ file is invalid. A cats/ file with categories and labels is "
+"required for 'colortable' when using categorical legends; see the r.category "
+"help page. Colortable creation has been skipped."
+msgstr ""
+#: ../ps/ps.map/ps_clrtbl.c:69 ../ps/ps.map/ps_fclrtbl.c:92
+#: ../ps/ps.map/ps_fclrtbl.c:97
+msgid "Colorbar y location beyond page margins. Adjusting."
+msgstr ""
+#: ../ps/ps.map/ps_clrtbl.c:75 ../ps/ps.map/ps_fclrtbl.c:103
+#: ../ps/ps.map/ps_fclrtbl.c:108
+msgid "Colorbar x location beyond page margins. Adjusting."
+msgstr ""
+#: ../ps/ps.map/do_vectors.c:34
+#, c-format
+msgid "Reading vector map <%s in %s> ..."
+msgstr ""
+#: ../ps/ps.map/do_vectors.c:139
+#, c-format
+msgid "Reading vector points file <%s in %s> ..."
+msgstr ""
+#: ../ps/ps.map/do_geogrid.c:87 ../ps/ps.map/do_geogrid.c:92
+#: ../ps/ps.map/do_geogrid.c:116 ../ps/ps.map/do_geogrid.c:121
+#: ../ps/ps.map/do_geogrid.c:191 ../ps/ps.map/do_geogrid.c:230
+#: ../ps/ps.map/do_geogrid.c:306 ../ps/ps.map/do_geogrid.c:322
+#: ../ps/ps.map/do_geogrid.c:339 ../ps/ps.map/do_geogrid.c:356
+#: ../ps/ps.map/do_geogrid.c:412 ../ps/ps.map/do_geogrid.c:418
+#: ../ps/ps.map/do_geogrid.c:422 ../ps/ps.map/do_geogrid.c:430
+#: ../ps/ps.map/do_geogrid.c:434 ../display/d.grid/plot.c:193
+#: ../display/d.grid/plot.c:199 ../display/d.grid/plot.c:244
+#: ../display/d.grid/plot.c:250 ../display/d.grid/plot.c:379
+#: ../display/d.grid/plot.c:395 ../display/d.grid/plot.c:412
+#: ../display/d.grid/plot.c:429 ../raster/r.sun/main.c:1345
+#: ../raster/r.horizon/main.c:815 ../raster/r.horizon/main.c:833
+msgid "Error in pj_do_proj"
+msgstr ""
+#: ../ps/ps.map/do_geogrid.c:278 ../display/d.grid/plot.c:301
+#: ../display/d.grid/plot.c:328 ../display/d.where/main.c:106
+#: ../display/d.where/main.c:132 ../raster/r.sun/main.c:489
+#: ../raster/r.horizon/main.c:496 ../raster/r.sun2/main.c:746
+msgid "Unable to set up lat/long projection parameters"
+msgstr ""
+#: ../ps/ps.map/catval.c:49 ../ps/ps.map/catval.c:111
+#: ../ps/ps.map/catval.c:177 ../vector/v.univar/main.c:257
+#: ../vector/v.buffer/main.c:383 ../vector/v.class/main.c:105
+#: ../vector/v.label/main.c:278 ../vector/v.to.rast3/main.c:82
+#: ../vector/v.vol.rst/user1.c:93 ../vector/v.label.sa/labels.c:80
+msgid "Unable to get layer info for vector map"
+msgstr ""
+#: ../ps/ps.map/catval.c:54 ../ps/ps.map/catval.c:116
+#: ../ps/ps.map/catval.c:182 ../vector/v.mkgrid/main.c:237
+#: ../vector/v.kcv/main.c:181 ../vector/v.extract/main.c:291
+#: ../vector/v.in.db/main.c:119 ../vector/v.to.3d/trans3.c:53
+#: ../vector/v.to.3d/trans2.c:52 ../vector/v.in.ascii/in.c:317
+#: ../vector/v.edit/select.c:520 ../vector/v.lrs/v.lrs.create/main.c:286
+#: ../vector/v.lrs/v.lrs.create/main.c:294 ../vector/v.sample/main.c:207
+#: ../vector/v.reclass/main.c:126 ../vector/v.surf.idw/read_sites.c:39
+#: ../vector/v.db.connect/main.c:218 ../vector/v.db.connect/main.c:326
+#: ../vector/v.net.allpairs/main.c:141 ../vector/v.net.flow/main.c:157
+#: ../vector/v.out.vtk/writeVTK.c:639 ../vector/v.in.sites/main.c:163
+#: ../vector/v.info/main.c:217 ../vector/v.to.points/main.c:285
+#: ../vector/v.to.db/query.c:89 ../vector/v.to.db/update.c:46
+#: ../vector/v.db.select/main.c:155 ../vector/v.db.select/main.c:286
+#: ../vector/v.extrude/main.c:168 ../vector/v.in.dwg/main.c:194
+#: ../vector/v.buffer/main.c:387 ../vector/v.what.rast/main.c:132
+#: ../vector/v.out.svg/main.c:148 ../vector/v.net.components/main.c:137
+#: ../vector/v.drape/main.c:293 ../vector/v.to.rast/support.c:131
+#: ../vector/v.to.rast/support.c:286 ../vector/v.to.rast/vect2rast.c:56
+#: ../vector/v.out.ogr/main.c:634
+#: ../vector/lidar/v.surf.bspline/crosscorr.c:123
+#: ../vector/lidar/v.surf.bspline/main.c:334 ../vector/v.surf.rst/main.c:607
+#: ../vector/v.net.distance/main.c:196 ../vector/v.patch/main.c:132
+#: ../vector/v.patch/main.c:162 ../vector/v.patch/main.c:274
+#: ../vector/v.patch/main.c:332 ../vector/v.label/main.c:282
+#: ../vector/v.overlay/main.c:186 ../vector/v.overlay/main.c:295
+#: ../vector/v.normal/main.c:141 ../vector/v.random/main.c:168
+#: ../vector/v.to.rast3/main.c:86 ../vector/v.buffer2/main.c:333
+#: ../vector/v.distance/main.c:364 ../vector/v.distance/main.c:401
+#: ../vector/v.net.centrality/main.c:220 ../vector/v.vol.rst/user1.c:97
+#: ../vector/v.vol.rst/main.c:590 ../vector/v.transform/trans_digit.c:58
+#: ../vector/v.in.dxf/write_vect.c:198 ../vector/v.net.timetable/main.c:93
+#: ../vector/v.out.ascii/b2a.c:51 ../vector/v.net.path/path.c:96
+#: ../vector/v.label.sa/labels.c:83 ../doc/vector/v.example/main.c:128
+#: ../display/d.vect.chart/plot.c:44 ../display/d.vect/plot1.c:208
+#: ../display/d.vect/attr.c:45 ../display/d.vect/area.c:60
+#: ../display/d.thematic.area/plot1.c:199 ../raster/r.to.vect/main.c:158
+#: ../raster/r.random/random.c:74 ../raster/r.contour/main.c:185
+#, c-format
+msgid "Unable to open database <%s> by driver <%s>"
+msgstr ""
+#: ../ps/ps.map/catval.c:64
+msgid "Column type not supported (must be string)"
+msgstr ""
+#: ../ps/ps.map/catval.c:67 ../ps/ps.map/catval.c:132
+#: ../ps/ps.map/catval.c:199 ../vector/v.sample/main.c:185
+#: ../vector/v.univar/main.c:276 ../vector/v.surf.idw/read_sites.c:52
+#: ../vector/v.buffer/main.c:397 ../vector/lidar/v.surf.bspline/main.c:347
+#: ../vector/v.class/main.c:126 ../vector/v.normal/main.c:154
+#: ../vector/v.to.rast3/main.c:96
+msgid "Unable to select data from table"
+msgstr ""
+#: ../ps/ps.map/catval.c:129
+msgid "Size column type must be numeric"
+msgstr ""
+#: ../ps/ps.map/catval.c:196
+msgid "Rotation column type must be numeric"
+msgstr ""
+#: ../ps/ps.map/makeprocs.c:29
+#, c-format
+msgid "Unable to open prolog <%s>"
+msgstr ""
+#: ../ps/ps.map/r_plt.c:158
+msgid "Can't open eps file"
+msgstr ""
+#: ../ps/ps.map/scale.c:137
+msgid "PSmap: do_scale(): shouldn't happen"
+msgstr ""
+#: ../ps/ps.map/ps_fclrtbl.c:51
+msgid "Range information not available (run r.support)"
+msgstr ""
+#: ../ps/ps.map/ps_fclrtbl.c:64
+msgid "A floating point colortable must contain a range of values"
+msgstr ""
+#: ../ps/ps.map/do_plt.c:41
+msgid "Reading point/line file ..."
+msgstr ""
+#: ../ps/ps.map/read_cfg.c:64
+#, c-format
+msgid "Paper '%s' not found, using defaults"
+msgstr ""
+#: ../ps/ps.map/ps_outline.c:41
+#, c-format
+msgid "Outlining areas in raster map <%s in %s> ..."
+msgstr ""
+#: ../ps/ps.map/main.c:100
+msgid "postscript, map, printing"
+msgstr ""
+#: ../ps/ps.map/main.c:101
+msgid "Produces hardcopy PostScript map output."
+msgstr ""
+#: ../ps/ps.map/main.c:105
+msgid "Rotate plot 90 degrees"
+msgstr ""
+#: ../ps/ps.map/main.c:110
+msgid "List paper formats ( name width height left right top bottom(margin) )"
+msgstr ""
+#: ../ps/ps.map/main.c:115
+msgid "Create EPS (Encapsulated PostScript) instead of PostScript file"
+msgstr ""
+#: ../ps/ps.map/main.c:120
+msgid ""
+"Describe map-box's position on the page and exit (inches from top-left of "
+"paper)"
+msgstr ""
+#: ../ps/ps.map/main.c:126
+msgid ""
+"File containing mapping instructions (or use input=- to enter from keyboard)"
+msgstr ""
+#: ../ps/ps.map/main.c:134
+msgid "PostScript output file"
+msgstr ""
+#: ../ps/ps.map/main.c:142
+msgid "Scale of the output map, e.g. 1:25000 (default: Auto-sized to fit page)"
+msgstr ""
+#: ../ps/ps.map/main.c:148
+msgid "Number of copies to print"
+msgstr ""
+#: ../ps/ps.map/main.c:241
+#, c-format
+msgid ""
+"Using <%s> from the command line is depreciated. Please use the <%s> mapping "
+"instruction instead. The parameter <%s> will be removed in future versions "
+"of GRASS."
+msgstr ""
+#: ../ps/ps.map/main.c:267
+#, c-format
+msgid ""
+"ERROR: Required parameter <%s> not set:\n"
+"\t(%s)\n"
+msgstr ""
+#: ../ps/ps.map/main.c:282
+msgid "Current region cannot be set."
+msgstr ""
+#: ../ps/ps.map/main.c:291
+msgid "Data exists after final 'end' instruction!"
+msgstr ""
+#: ../ps/ps.map/main.c:324
+msgid ""
+"GRASS environment variable GRASS_VERBOSE is overwritten by VERBOSE mapping "
+"instruction. This mapping instruction is superseded and will be removed in "
+"future versions of GRASS. Please use --verbose instead."
+msgstr ""
+#: ../ps/ps.map/main.c:331
+msgid "Cannot set GRASS_VERBOSE variable."
+msgstr ""
+#: ../ps/ps.map/main.c:742
+#, c-format
+msgid "PostScript file [%s] successfully written."
+msgstr ""
+#: ../ps/ps.map/do_psfiles.c:20
+#, c-format
+msgid "Reading PostScript include file <%s> ..."
+msgstr ""
+#: ../raster3d/base/mask_functions.c:82
+#, c-format
+msgid "Adding rule: %lf - %lf"
+msgstr ""
+#: ../raster3d/base/mask_functions.c:100 ../raster/r.null/null.c:266
+#, c-format
+msgid "%s: illegal value spec"
+msgstr ""
+#: ../raster3d/base/r3.mask.main.c:44
+msgid "3D raster map with reference values"
+msgstr ""
+#: ../raster3d/base/r3.mask.main.c:52
+msgid "List of cell values to be masked out"
+msgstr ""
+#: ../raster3d/base/r3.mask.main.c:84 ../raster3d/base/r3.null.main.c:113
+#: ../raster3d/base/r3.info.main.c:128 ../raster3d/r3.stats/main.c:618
+#: ../raster3d/r3.out.vtk/main.c:209 ../raster3d/r3.out.vtk/main.c:293
+#: ../raster3d/r3.out.vtk/main.c:517 ../raster3d/r3.cross.rast/main.c:318
+#: ../raster3d/r3.out.ascii/main.c:268 ../raster3d/r3.out.v5d/main.c:312
+#: ../raster/r.univar2/r3.univar_main.c:154
+#: ../raster/r.univar2/r3.univar_main.c:193
+#, c-format
+msgid "Unable to open 3D raster map <%s>"
+msgstr ""
+#: ../raster3d/base/r3.mask.main.c:95
+msgid "Unable to open 3D raster mask file"
+msgstr ""
+#: ../raster3d/base/r3.mask.main.c:124
+msgid "makeMask: error flushing tiles in cube"
+msgstr ""
+#: ../raster3d/base/r3.mask.main.c:129
+msgid "makeMask: error flushing all tiles"
+msgstr ""
+#: ../raster3d/base/r3.mask.main.c:137
+msgid "Unable to close 3D raster mask file"
+msgstr ""
+#: ../raster3d/base/r3.mask.main.c:139
+#, c-format
+msgid "Unable to close raster map <%s>"
+msgstr ""
+#: ../raster3d/base/r3.mask.main.c:153 ../raster3d/base/r3.null.main.c:205
+#: ../raster3d/base/r3.info.main.c:78 ../raster3d/base/r3.timestamp.main.c:43
+#: ../raster3d/r3.mkdspf/main.c:75 ../raster3d/r3.cross.rast/main.c:270
+#: ../raster3d/r3.gwflow/main.c:169 ../raster3d/r3.to.rast/main.c:215
+msgid "raster3d, voxel"
+msgstr ""
+#: ../raster3d/base/r3.mask.main.c:155
+msgid "Establishes the current working 3D raster mask."
+msgstr ""
+#: ../raster3d/base/r3.mask.main.c:159
+msgid ""
+"Cannot create mask file: G3D_MASK already exists!\n"
+" Use 'g.remove rast3d=G3D_MASK' to remove the existing mask."
+msgstr ""
+#: ../raster3d/base/r3.null.main.c:58
+msgid "3d raster map for which to modify null values"
+msgstr ""
+#: ../raster3d/base/r3.null.main.c:66 ../raster/r.null/null.c:70
+msgid "List of cell values to be set to NULL"
+msgstr ""
+#: ../raster3d/base/r3.null.main.c:73 ../raster/r.null/null.c:78
+msgid "The value to replace the null value by"
+msgstr ""
+#: ../raster3d/base/r3.null.main.c:88
+msgid "Illegal value for null"
+msgstr ""
+#: ../raster3d/base/r3.null.main.c:125
+msgid "modifyNull: error opening tmp file"
+msgstr ""
+#: ../raster3d/base/r3.null.main.c:174
+msgid "modifyNull: error flushing tiles in cube"
+msgstr ""
+#: ../raster3d/base/r3.null.main.c:180
+msgid "modifyNull: error flushing all tiles"
+msgstr ""
+#: ../raster3d/base/r3.null.main.c:188 ../raster/r.mapcalc/map.c:521
+msgid "Unable to close raster map"
+msgstr ""
+#: ../raster3d/base/r3.null.main.c:190
+msgid "modifyNull: Unable to close tmp file"
+msgstr ""
+#: ../raster3d/base/r3.null.main.c:207
+msgid "Explicitly create the 3D NULL-value bitmap file."
+msgstr ""
+#: ../raster3d/base/r3.info.main.c:80
+msgid "Outputs basic information about a user-specified 3D raster map layer."
+msgstr ""
+#: ../raster3d/base/r3.info.main.c:87
+msgid "Name of input 3D raster map"
+msgstr ""
+#: ../raster3d/base/r3.info.main.c:91 ../raster/r.info/main.c:77
+msgid "Print range only"
+msgstr ""
+#: ../raster3d/base/r3.info.main.c:96
+msgid "Print 3D raster map resolution (NS-res, EW-res, TB-res) only"
+msgstr ""
+#: ../raster3d/base/r3.info.main.c:100
+msgid "Print 3D raster map type (float/double) only"
+msgstr ""
+#: ../raster3d/base/r3.info.main.c:104
+msgid "Print 3D raster map region only"
+msgstr ""
+#: ../raster3d/base/r3.info.main.c:108
+msgid "Print 3D raster history instead of info"
+msgstr ""
+#: ../raster3d/base/r3.info.main.c:113
+msgid "Print 3D raster map timestamp (day.month.year hour:minute:seconds) only"
+msgstr ""
+#: ../raster3d/base/r3.info.main.c:121
+#, c-format
+msgid "3D Raster map <%s> not found"
+msgstr ""
+#: ../raster3d/base/r3.info.main.c:158 ../raster3d/base/r3.info.main.c:166
+#: ../raster3d/base/r3.info.main.c:172 ../raster3d/base/r3.info.main.c:177
+#: ../raster3d/base/r3.info.main.c:184 ../raster3d/base/r3.info.main.c:195
+#: ../raster3d/base/r3.info.main.c:201 ../raster3d/base/r3.info.main.c:217
+#: ../raster3d/base/r3.info.main.c:224 ../raster3d/base/r3.info.main.c:231
+#: ../raster3d/base/r3.info.main.c:236 ../raster3d/base/r3.info.main.c:241
+#: ../raster3d/base/r3.info.main.c:248 ../raster3d/base/r3.info.main.c:255
+#: ../raster3d/base/r3.info.main.c:265 ../raster3d/base/r3.info.main.c:275
+#: ../raster3d/base/r3.info.main.c:285 ../raster3d/base/r3.info.main.c:298
+#: ../raster3d/base/r3.info.main.c:308 ../raster3d/base/r3.info.main.c:313
+#: ../raster3d/base/r3.info.main.c:321 ../raster3d/base/r3.info.main.c:334
+#: ../raster/r.info/main.c:307 ../raster/r.info/main.c:433
+msgid "Cannot allocate memory for string"
+msgstr ""
+#: ../raster3d/base/r3.info.main.c:287 ../raster3d/base/r3.info.main.c:349
+#, c-format
+msgid "Unable to read range of 3D raster map <%s>"
+msgstr ""
+#: ../raster3d/base/r3.info.main.c:404
+msgid "Error while reading history file"
+msgstr ""
+#: ../raster3d/base/r3.info.main.c:425
+#: ../raster3d/r3.out.vtk/errorHandling.c:67
+#: ../raster3d/r3.cross.rast/main.c:404 ../raster3d/r3.gwflow/main.c:415
+#, c-format
+msgid "Unable to close 3D raster map <%s>"
+msgstr ""
+#: ../raster3d/base/r3.timestamp.main.c:45
+msgid "Print/add/remove a timestamp for a 3D raster map"
+msgstr ""
+#: ../raster3d/base/r3.timestamp.main.c:52
+msgid "Input grid3 filename"
+msgstr ""
+#: ../raster3d/base/r3.timestamp.main.c:59
+msgid "Datetime, datetime1/datetime2, or none"
+msgstr ""
+#: ../raster3d/base/r3.timestamp.main.c:74
+#, c-format
+msgid "Grid3 <%s> not found %s"
+msgstr ""
+#: ../raster3d/r3.stats/main.c:568 ../raster/r.univar2/r3.univar_main.c:100
+msgid "raster3d, voxel, statistics"
+msgstr ""
+#: ../raster3d/r3.stats/main.c:569
+msgid "Generates volume statistics for 3D raster maps."
+msgstr ""
+#: ../raster3d/r3.stats/main.c:580
+msgid "Number of subranges to collect stats from"
+msgstr ""
+#: ../raster3d/r3.stats/main.c:586
+msgid "Calculate statistics based on equal value groups"
+msgstr ""
+#: ../raster3d/r3.stats/main.c:606
+msgid "The number of subranges has to be equal or greater than 1"
+msgstr ""
+#: ../raster3d/r3.stats/main.c:665
+msgid "Sort non-null values"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:77
+msgid ""
+"Creates a display file from an existing grid3 file according to specified "
+"threshold levels."
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:85
+msgid "Name of an existing 3d raster map"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:91
+msgid "Name of output display file"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:98
+msgid "List of thresholds for isosurfaces"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:104
+msgid "Minimum isosurface level"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:110
+msgid "Maximum isosurface level"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:116
+msgid "Positive increment between isosurface levels"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:123
+msgid "Number of isosurface threshold levels"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:127
+msgid "Suppress progress report & min/max information"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:131
+msgid "Use flat shading rather than gradient"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:139
+#, c-format
+msgid "Region from getWindow: %d %d %d"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:151
+#, c-format
+msgid "Not able to find grid3 file for [%s]"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:163
+#, c-format
+msgid "Error opening grid3 file [%s]"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:166
+#, c-format
+msgid "Error reading range for [%s]"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:195
+#, c-format
+msgid "Error opening display file [%s]"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:216
+#, c-format
+msgid "Writing %s from %s..."
+msgstr ""
+#: ../raster3d/r3.out.vtk/errorHandling.c:52
+msgid "Unable to close input raster map"
+msgstr ""
+#: ../raster3d/r3.out.vtk/errorHandling.c:107
+msgid "Unable to close input raster maps"
+msgstr ""
+#: ../raster3d/r3.out.vtk/writeVTKData.c:122
+msgid "write_vtk_points: Writing point coordinates"
+msgstr ""
+#: ../raster3d/r3.out.vtk/writeVTKData.c:131
+msgid "Unable to read top raster row \n"
+msgstr ""
+#: ../raster3d/r3.out.vtk/writeVTKData.c:135
+msgid "Unable to read bottom raster row \n"
+msgstr ""
+#: ../raster3d/r3.out.vtk/writeVTKData.c:256
+msgid "write_vtk_unstructured_grid_cells: Writing the cells"
+msgstr ""
+#: ../raster3d/r3.out.vtk/writeVTKData.c:429
+#: ../raster3d/r3.out.vtk/writeVTKData.c:462
+msgid "Wrong 3D raster map values: Values should in between 0 and 255\n"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:30
+msgid "G3D map(s) to be converted to VTK-ASCII data format"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:34 ../raster/r.out.vtk/parameters.c:38
+msgid "Name for VTK-ASCII output file"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:41
+msgid "Float value to represent no data cell/points"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:47
+msgid "Create VTK pointdata instead of VTK celldata (celldata is default)"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:56
+msgid "top surface 2D raster map"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:65
+msgid "bottom surface 2D raster map"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:71
+msgid ""
+"Create 3d elevation output with a top and a bottom surface, both raster maps "
+"are required."
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:82
+msgid ""
+"Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:92
+msgid "Three (x,y,z) 3D raster maps to create vector values [xmap,ymap,zmap]"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:99 ../vector/v.out.vtk/main.c:75
+#: ../raster/r.out.vtk/parameters.c:93
+msgid "Scale factor for elevation"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:112 ../vector/v.out.vtk/main.c:69
+#: ../vector/v.out.ascii/out.c:76 ../display/d.rast.num/number.c:120
+#: ../raster/r.out.vtk/parameters.c:105 ../raster/r.out.ascii/main.c:85
+msgid "Number of significant digits (floating point only)"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:117 ../raster3d/r3.gwflow/main.c:136
+msgid "Use 3D raster mask (if exists) with input maps"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:122
+msgid "Scale factor effects the origin"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:128 ../vector/v.out.vtk/main.c:88
+#: ../raster/r.out.vtk/parameters.c:135
+msgid "Correct the coordinates to fit the VTK-OpenGL precision"
+msgstr ""
+#: ../raster3d/r3.out.vtk/writeVTKHead.c:39
+msgid "write_vtk_structured_point_header: Writing VTKStructuredPoint-Header"
+msgstr ""
+#: ../raster3d/r3.out.vtk/writeVTKHead.c:95
+msgid "write_vtk_structured_grid_header: Writing VTKStructuredGrid-Header"
+msgstr ""
+#: ../raster3d/r3.out.vtk/writeVTKHead.c:116
+msgid "write_vtk_unstructured_grid_header: Writing VTKUnstructuredGrid-Header"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:99
+#, c-format
+msgid "Could not open map %s"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:118
+msgid "Specify top and bottom map"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:125
+#, c-format
+msgid "Top cell map <%s> not found"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:134
+#, c-format
+msgid "Bottom cell map <%s> not found"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:157
+msgid "Please provide three RGB 3D raster maps"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:167
+#, c-format
+msgid "3D vector map <%s> not found"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:171
+msgid "Please provide three G3D vector maps [x,y,z]"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:178
+msgid ""
+"No 3D raster data, RGB or xyz-vector maps are provided. Will only write the "
+"geometry"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:211
+msgid "No RGB Data will be created"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:254 ../raster3d/r3.out.vtk/main.c:339
+#: ../raster3d/r3.cross.rast/main.c:55 ../raster3d/r3.out.ascii/main.c:58
+#: ../raster3d/r3.out.ascii/main.c:300 ../raster3d/r3.in.v5d/main.c:218
+#: ../raster3d/r3.in.ascii/main.c:274 ../raster3d/r3.out.v5d/main.c:54
+#: ../raster3d/r3.out.v5d/main.c:326 ../raster3d/r3.to.rast/main.c:55
+#: ../raster3d/r3.to.rast/main.c:390
+msgid "Unable to close 3D raster map"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:295
+msgid "No vector data will be created"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:376 ../raster3d/r3.out.ascii/main.c:244
+#: ../raster3d/r3.out.v5d/main.c:286
+msgid "raster3d, voxel, export"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:378
+msgid "Converts 3D raster maps into the VTK-ASCII format."
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:389
+msgid "failed to interpret dp as an integer"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:391 ../raster/r.out.ascii/main.c:125
+msgid "dp has to be from 0 to 20"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:451 ../raster3d/r3.to.rast/main.c:267
+msgid ""
+"The 2D and 3D region settings are different. Using the 2D window settings to "
+"adjust the 2D part of the 3D region."
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:489
+msgid "Unable to close top raster map"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:494
+msgid "Unable to close bottom raster map"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:546
+msgid "Unable to close 3D raster map, the VTK file may be incomplete"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:561
+msgid "Unable to close VTK-ASCII file"
+msgstr ""
+#: ../raster3d/r3.cross.rast/main.c:77 ../raster3d/r3.cross.rast/main.c:392
+#: ../raster3d/r3.to.rast/main.c:194
+msgid "Unable to close output map"
+msgstr ""
+#: ../raster3d/r3.cross.rast/main.c:91
+msgid "Input 3D raster map for cross section."
+msgstr ""
+#: ../raster3d/r3.cross.rast/main.c:98
+msgid "2D elevation map used to create the cross section map"
+msgstr ""
+#: ../raster3d/r3.cross.rast/main.c:105
+msgid "Resulting cross section 2D raster map"
+msgstr ""
+#: ../raster3d/r3.cross.rast/main.c:110 ../raster3d/r3.out.ascii/main.c:107
+#: ../raster3d/r3.to.rast/main.c:90
+msgid "Use 3D raster mask (if exists) with input map"
+msgstr ""
+#: ../raster3d/r3.cross.rast/main.c:162
+msgid "Unable to get elevation raster row"
+msgstr ""
+#: ../raster3d/r3.cross.rast/main.c:230 ../raster3d/r3.cross.rast/main.c:237
+#: ../raster3d/r3.to.rast/main.c:152 ../raster3d/r3.to.rast/main.c:159
+msgid "Unable to write raster row"
+msgstr ""
+#: ../raster3d/r3.cross.rast/main.c:272
+msgid ""
+"Creates cross section 2D raster map from 3D raster map based on 2D elevation "
+"map."
+msgstr ""
+#: ../raster3d/r3.cross.rast/main.c:298
+msgid ""
+"The 2D and 3D region settings are different. Using the 3D raster map "
+"settings to adjust the 2D region."
+msgstr ""
+#: ../raster3d/r3.cross.rast/main.c:333
+msgid "Elevation map not found"
+msgstr ""
+#: ../raster3d/r3.cross.rast/main.c:338
+msgid "Unable to open elevation map"
+msgstr ""
+#: ../raster3d/r3.cross.rast/main.c:349 ../raster3d/r3.to.rast/main.c:302
+#: ../raster/r.to.rast3/main.c:239
+msgid "Illegal output file name"
+msgstr ""
+#: ../raster3d/r3.cross.rast/main.c:352
+msgid "Output map already exists. Will be overwritten!"
+msgstr ""
+#: ../raster3d/r3.cross.rast/main.c:358 ../raster3d/r3.cross.rast/main.c:364
+msgid "Unable to create raster map"
+msgstr ""
+#: ../raster3d/r3.cross.rast/main.c:394
+msgid "Unable to close elevation map"
+msgstr ""
+#: ../raster3d/r3.cross.rast/main.c:399
+msgid "Wrong 3D raster map datatype! Unable to create raster map."
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:55
+msgid "Input 3D raster map with initial piezometric heads in [m]"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:63
+msgid "The status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:71
+msgid "The x-part of the hydraulic conductivity tensor in [m/s]"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:79
+msgid "The y-part of the hydraulic conductivity tensor in [m/s]"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:87
+msgid "The z-part of the hydraulic conductivity tensor in [m/s]"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:94
+msgid "Sources and sinks in [m^3/s]"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:101
+msgid "Specific yield in 1/m"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:108
+msgid "Recharge raster map in m^3/s"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:116
+msgid ""
+"The piezometric head result of the numerical calculation will be written to "
+"this map"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:123
+msgid ""
+"Calculate the groundwater distance velocity vector field \n"
+"and write the x, y, and z components to maps named name_[xyz].\n"
+"Name is basename for the new 3D raster maps."
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:141
+msgid ""
+"Use a sparse linear equation system, only available with iterative solvers"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:171
+msgid ""
+"Calculates numerically transient, confined groundwater flow in three "
+"dimensions."
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:189 ../raster/r.gwflow/main.c:240
+msgid "The direct LU solver do not work with sparse matrices"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:191 ../raster/r.gwflow/main.c:242
+msgid "The direct Gauss solver do not work with sparse matrices"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:193
+msgid "The direct Cholesky solver do not work with sparse matrices"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:294 ../raster/r.gwflow/main.c:529
+msgid "Unable to create and solve the linear equation system"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:371
+#, c-format
+msgid "Unable to create 3D raster map <%s>"
+msgstr ""
+#: ../raster3d/r3.out.ascii/main.c:76
+msgid "3D raster map to be converted to ASCII"
+msgstr ""
+#: ../raster3d/r3.out.ascii/main.c:83
+msgid "Name for ASCII output file"
+msgstr ""
+#: ../raster3d/r3.out.ascii/main.c:92
+msgid "Number of decimal places for floats"
+msgstr ""
+#: ../raster3d/r3.out.ascii/main.c:98 ../raster/r.what/main.c:117
+#: ../raster/r.transect/main.c:85
+msgid "Char string to represent no data cell"
+msgstr ""
+#: ../raster3d/r3.out.ascii/main.c:103 ../raster/r.out.ascii/main.c:104
+#: ../raster/r.out.arc/main.c:81
+msgid "Suppress printing of header information"
+msgstr ""
+#: ../raster3d/r3.out.ascii/main.c:246
+msgid "Converts a 3D raster map layer into an ASCII text file."
+msgstr ""
+#: ../raster3d/r3.out.ascii/main.c:305
+msgid "Unable to close new ASCII file"
+msgstr ""
+#: ../raster3d/r3.in.v5d/main.c:191 ../raster3d/r3.in.ascii/main.c:240
+msgid "raster3d, voxel, import"
+msgstr ""
+#: ../raster3d/r3.in.v5d/main.c:193
+msgid ""
+"Imports 3-dimensional Vis5D files (i.e. the V5D file with 1 variable and 1 "
+"time step)."
+msgstr ""
+#: ../raster3d/r3.in.v5d/main.c:213 ../raster3d/r3.in.ascii/main.c:268
+msgid "Unable to open 3D raster map"
+msgstr ""
+#: ../raster3d/r3.in.ascii/main.c:79
+msgid "ASCII raster map to be imported"
+msgstr ""
+#: ../raster3d/r3.in.ascii/main.c:90
+msgid "String representing NULL value data cell (use 'none' if no such value)"
+msgstr ""
+#: ../raster3d/r3.in.ascii/main.c:174
+#, c-format
+msgid "Loading data ...  (%dx%dx%d)"
+msgstr ""
+#: ../raster3d/r3.in.ascii/main.c:190
+msgid "End of file reached while still loading data."
+msgstr ""
+#: ../raster3d/r3.in.ascii/main.c:209
+#, c-format
+msgid ""
+"Data exists in input file after fully importing expected data.  [%.4f ...]"
+msgstr ""
+#: ../raster3d/r3.in.ascii/main.c:242
+msgid ""
+"Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
+msgstr ""
+#: ../raster3d/r3.in.ascii/main.c:284
+msgid "Unable to close ASCII file"
+msgstr ""
+#: ../raster3d/r3.out.v5d/main.c:72
+msgid "3D raster map to be converted to Vis5D (V5D) file"
+msgstr ""
+#: ../raster3d/r3.out.v5d/main.c:79
+msgid "Name for V5D output file"
+msgstr ""
+#: ../raster3d/r3.out.v5d/main.c:149
+#, c-format
+msgid "Vis5D allows %d columns, %d columns found"
+msgstr ""
+#: ../raster3d/r3.out.v5d/main.c:152
+#, c-format
+msgid "Vis5D allows %d rows, %d rows found"
+msgstr ""
+#: ../raster3d/r3.out.v5d/main.c:259
+#, c-format
+msgid "Unable to create V5D file <%s>"
+msgstr ""
+#: ../raster3d/r3.out.v5d/main.c:264
+msgid "Failed writing V5D file"
+msgstr ""
+#: ../raster3d/r3.out.v5d/main.c:288
+msgid "Exports GRASS 3D raster map to 3-dimensional Vis5D file."
+msgstr ""
+#: ../raster3d/r3.out.v5d/main.c:295
+msgid "Use map coordinates instead of xyz coordinates"
+msgstr ""
+#: ../raster3d/r3.to.rast/main.c:79
+msgid "3D raster map(s) to be converted to 2D raster slices"
+msgstr ""
+#: ../raster3d/r3.to.rast/main.c:85
+msgid "Basename for resultant raster slice maps"
+msgstr ""
+#: ../raster3d/r3.to.rast/main.c:95
+msgid ""
+"Use the same resolution as the input 3D raster map for the 2D outputmaps, "
+"independent of the current region settings"
+msgstr ""
+#: ../raster3d/r3.to.rast/main.c:183 ../imagery/i.landsat.acca/algorithm.c:234
+#: ../imagery/i.landsat.acca/algorithm.c:397
+#: ../imagery/i.landsat.acca/tools.c:140 ../imagery/i.topo.corr/main.c:58
+#: ../imagery/i.smap/shapiro/opencell.c:30
+#: ../imagery/i.landsat.toar/main.c:508 ../imagery/i.pca/main.c:406
+#: ../imagery/i.rgb.his/openfiles.c:29 ../imagery/i.rgb.his/openfiles.c:31
+#: ../imagery/i.rgb.his/openfiles.c:33 ../imagery/i.his.rgb/openfiles.c:15
+#: ../imagery/i.his.rgb/openfiles.c:17 ../imagery/i.his.rgb/openfiles.c:19
+#: ../imagery/i.ifft/ifftmain.c:219 ../imagery/i.maxlik/open.c:74
+#: ../imagery/i.modis.qc/main.c:235 ../vector/v.kernel/main.c:327
+#: ../vector/v.surf.idw/main.c:264 ../vector/v.neighbors/main.c:96
+#: ../vector/v.to.rast/vect2rast.c:125 ../vector/v.to.rast/vect2rast.c:129
+#: ../vector/lidar/v.surf.bspline/main.c:319
+#: ../doc/raster/r.example/main.c:141 ../raster/r.buffer/write_map.c:40
+#: ../raster/r.slope.aspect/opennew.c:19 ../raster/r.lake/main.c:229
+#: ../raster/r.lake/main.c:318 ../raster/r.flow/io.c:173
+#: ../raster/r.flow/io.c:208 ../raster/r.surf.idw/main.c:147
+#: ../raster/r.surf.fractal/write_rast.c:58 ../raster/r.circle/dist.c:127
+#: ../raster/r.grow2/main.c:209 ../raster/r.li/r.li.daemon/daemon.c:132
+#: ../raster/r.cross/main.c:145 ../raster/r.mapcalc/map.c:507
+#: ../raster/r.mapcalc/map3.c:580 ../raster/r.null/null.c:329
+#: ../raster/r.in.gdal/main.c:757 ../raster/r.in.gdal/main.c:762
+#: ../raster/r.in.gdal/main.c:776 ../raster/r.random.surface/save.c:23
+#: ../raster/r.basins.fill/main.c:106 ../raster/r.resamp.interp/main.c:148
+#: ../raster/r.surf.idw2/main.c:111 ../raster/r.los/main.c:203
+#: ../raster/r.bitpattern/main.c:125 ../raster/r.in.xyz/main.c:498
+#: ../raster/r.resamp.stats/main.c:341 ../raster/r.in.arc/main.c:154
+#: ../raster/r.sunmask/main.c:450 ../raster/r.random/random.c:55
+#: ../raster/r.carve/main.c:189 ../raster/r.in.ascii/main.c:206
+#: ../raster/r.bilinear/main.c:104 ../raster/r.clump/main.c:98
+#: ../raster/r.sun2/main.c:1164 ../raster/r.sun2/main.c:1171
+#: ../raster/r.sun2/main.c:1178 ../raster/r.sun2/main.c:1185
+#: ../raster/r.sun2/main.c:1192 ../raster/r.sun2/main.c:1199
+#: ../raster/r.surf.random/randsurf.c:28 ../raster/r.surf.random/randsurf.c:32
+#: ../raster/r.composite/main.c:192 ../raster/r.texture/main.c:309
+#: ../raster/r.in.mat/main.c:430 ../raster/r.series/main.c:250
+#: ../raster/r.patch/main.c:144 ../raster/r.thin/io.c:168
+#, c-format
+msgid "Unable to create raster map <%s>"
+msgstr ""
+#: ../raster3d/r3.to.rast/main.c:216
+msgid "Converts 3D raster maps to 2D raster maps"
+msgstr ""
+#: ../raster3d/r3.to.rast/main.c:225
+#, c-format
+msgid "Open 3D raster map <%s>"
+msgstr ""
+#: ../raster3d/r3.to.rast/main.c:243 ../raster3d/r3.to.rast/main.c:284
+#, c-format
+msgid "Error opening 3D raster map <%s>"
+msgstr ""
+#: ../raster3d/r3.to.rast/main.c:299 ../imagery/i.ask/popup.c:174
+#: ../imagery/i.smap/bouman/multialloc.c:115
+#: ../vector/v.mkgrid/write_grid.c:131 ../vector/v.in.ascii/a2b.c:172
+#: ../vector/v.edit/a2b.c:198 ../vector/v.net.allpairs/main.c:174
+#: ../vector/v.net.flow/main.c:214 ../vector/v.generalize/point.c:121
+#: ../vector/v.generalize/smoothing.c:94
+#: ../vector/v.generalize/smoothing.c:151
+#: ../vector/v.generalize/smoothing.c:252
+#: ../vector/v.generalize/smoothing.c:376
+#: ../vector/v.generalize/smoothing.c:405
+#: ../vector/v.generalize/smoothing.c:409
+#: ../vector/v.generalize/smoothing.c:413
+#: ../vector/v.generalize/smoothing.c:417
+#: ../vector/v.generalize/smoothing.c:421
+#: ../vector/v.generalize/smoothing.c:425
+#: ../vector/v.generalize/smoothing.c:429
+#: ../vector/v.generalize/simplification.c:33
+#: ../vector/v.generalize/simplification.c:40
+#: ../vector/v.generalize/simplification.c:309
+#: ../vector/v.generalize/simplification.c:317
+#: ../vector/v.generalize/simplification.c:341
+#: ../vector/v.generalize/network.c:93 ../vector/v.generalize/network.c:128
+#: ../vector/v.generalize/matrix.c:144 ../vector/v.net.components/main.c:127
+#: ../vector/v.surf.rst/main.c:887 ../vector/v.net.distance/main.c:168
+#: ../vector/v.mapcalc/list.c:54 ../vector/v.mapcalc/list.c:501
+#: ../vector/v.net.centrality/main.c:265 ../vector/v.net.centrality/main.c:270
+#: ../vector/v.net.centrality/main.c:276 ../vector/v.net.centrality/main.c:282
+#: ../vector/v.net.centrality/main.c:288
+#: ../vector/v.net.connectivity/main.c:165
+#: ../vector/v.net.connectivity/main.c:181
+#: ../vector/v.net.timetable/main.c:353 ../vector/v.net.timetable/main.c:363
+#: ../raster/r.li/r.li.daemon/list.c:49 ../raster/r.to.rast3/main.c:236
+#: ../raster/r.gwflow/main.c:350
+msgid "Out of memory"
+msgstr ""
+#: ../raster3d/r3.to.rast/main.c:304
+#, c-format
+msgid "Creating %i raster maps"
+msgstr ""
+#: ../raster3d/r3.to.rast/main.c:310
+#, c-format
+msgid "Raster map %i Filename: %s"
+msgstr ""
+#: ../raster3d/r3.to.rast/main.c:313
+#, c-format
+msgid "Raster map %d Filename: %s already exists. Will be overwritten!"
+msgstr ""
+#: ../misc/m.cogo/main.c:225
+msgid "miscellaneous, distance"
+msgstr ""
+#: ../misc/m.cogo/main.c:226
+msgid ""
+"A simple utility for converting bearing and distance measurements to "
+"coordinates and vice versa."
+msgstr ""
+#: ../misc/m.cogo/main.c:228
+msgid "It assumes a cartesian coordinate system"
+msgstr ""
+#: ../misc/m.cogo/main.c:232
+msgid "Lines are labelled"
+msgstr ""
+#: ../misc/m.cogo/main.c:236
+msgid "Suppress warnings"
+msgstr ""
+#: ../misc/m.cogo/main.c:241
+msgid "Convert from coordinates to bearing and distance"
+msgstr ""
+#: ../misc/m.cogo/main.c:256
+msgid "Starting coordinate pair"
+msgstr ""
+#: ../misc/m.cogo/main.c:266
+#, c-format
+msgid "Couldn't open COGO file <%s>"
+msgstr ""
+#: ../misc/m.cogo/main.c:275
+#, c-format
+msgid "Couldn't open output file <%s>"
+msgstr ""
+#: ../misc/m.cogo/main.c:305 ../misc/m.cogo/main.c:308
+msgid "Converting starting coordinate pair"
+msgstr ""
+#: ../misc/m.cogo/main.c:324
+#, c-format
+msgid "Input parse error on line %d"
+msgstr ""
+#: ../misc/m.nviz.image/vector.c:179
+msgid "Unknown icon marker"
+msgstr ""
+#: ../misc/m.nviz.image/surface.c:68
+#, c-format
+msgid "Missing topography attribute for surface %d"
+msgstr ""
+#: ../misc/m.nviz.image/surface.c:129 ../misc/m.nviz.image/volume.c:144
+#, c-format
+msgid "Color attribute not defined, using default <%s>"
+msgstr ""
+#: ../misc/m.nviz.image/surface.c:134
+#, c-format
+msgid "Missing color attribute for surface %d"
+msgstr ""
+#: ../misc/m.nviz.image/surface.c:211
+#, c-format
+msgid "Surface id %d doesn't exist"
+msgstr ""
+#: ../misc/m.nviz.image/surface.c:258 ../misc/m.nviz.image/surface.c:265
+#, c-format
+msgid "Unable to set draw mode for surface id %d"
+msgstr ""
+#: ../misc/m.nviz.image/cplane.c:40
+#, c-format
+msgid "Cutting plane number <%d> not found"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:51
+msgid "Use draw mode for all loaded surfaces"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:52 ../misc/m.nviz.image/args.c:130
+#: ../misc/m.nviz.image/args.c:139 ../misc/m.nviz.image/args.c:146
+#: ../misc/m.nviz.image/args.c:152 ../misc/m.nviz.image/args.c:160
+#: ../misc/m.nviz.image/args.c:169 ../misc/m.nviz.image/args.c:179
+#: ../misc/m.nviz.image/args.c:187 ../misc/m.nviz.image/args.c:197
+#: ../misc/m.nviz.image/args.c:205 ../misc/m.nviz.image/args.c:215
+msgid "Surfaces"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:89
+msgid "Name for output image file (without extension)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:90 ../misc/m.nviz.image/args.c:104
+#: ../misc/m.nviz.image/args.c:114
+msgid "Image"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:112
+msgid "Size (width, height) of output image"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:129
+msgid "Name of raster map(s) for elevation"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:138
+msgid "Elevation value(s)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:145
+msgid "Name of raster map(s) for color"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:151
+msgid "Color value(s)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:159
+msgid "Name of raster map(s) for mask"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:168
+msgid "Name of raster map(s) for transparency"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:178
+msgid "Transparency value(s)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:186
+msgid "Name of raster map(s) for shininess"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:196
+msgid "Shininess value(s)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:204
+msgid "Name of raster map(s) for emission"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:214
+msgid "Emission value(s)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:228
+msgid "Draw mode"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:231 ../misc/m.nviz.image/args.c:242
+#: ../misc/m.nviz.image/args.c:253 ../misc/m.nviz.image/args.c:265
+#: ../misc/m.nviz.image/args.c:277 ../misc/m.nviz.image/args.c:286
+#: ../misc/m.nviz.image/args.c:296 ../misc/m.nviz.image/args.c:526
+#: ../misc/m.nviz.image/args.c:538
+msgid "Draw"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:240
+msgid "Fine resolution"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:251
+msgid "Coarse resolution"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:262
+msgid "Draw style"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:274
+msgid "Shading"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:283
+msgid "Wire color"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:295
+msgid "Surface position"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:307
+msgid "Name of line vector overlay map(s)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:308 ../misc/m.nviz.image/args.c:319
+#: ../misc/m.nviz.image/args.c:330 ../misc/m.nviz.image/args.c:342
+#: ../misc/m.nviz.image/args.c:352 ../misc/m.nviz.image/args.c:364
+msgid "Vector lines"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:318
+msgid "Vector line width"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:327
+msgid "Vector line color"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:339
+msgid "Vector line display mode"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:351
+msgid "Vector line height"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:363
+msgid "Vector lines position"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:375
+msgid "Name of point vector overlay map(s)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:376 ../misc/m.nviz.image/args.c:387
+#: ../misc/m.nviz.image/args.c:399 ../misc/m.nviz.image/args.c:410
+#: ../misc/m.nviz.image/args.c:423 ../misc/m.nviz.image/args.c:433
+msgid "Vector points"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:386
+msgid "Icon size"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:398
+msgid "Icon width"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:407
+msgid "Icon color"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:419
+msgid "Icon marker"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:432
+msgid "Vector points position"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:449
+msgid "Viewpoint position (x,y model coordinates)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:450 ../misc/m.nviz.image/args.c:461
+#: ../misc/m.nviz.image/args.c:471 ../misc/m.nviz.image/args.c:483
+#: ../misc/m.nviz.image/args.c:504
+msgid "Viewpoint"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:460
+msgid "Viewpoint height (in map units)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:470
+msgid "Viewpoint field of view (in degrees)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:482
+msgid "Viewpoint twist angle (in degrees)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:494 ../raster/r.out.vrml/main.c:70
+msgid "Vertical exaggeration"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:503
+msgid "Focus to point on surface (from SW corner in map units)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:513 ../misc/m.nviz.image/args.c:548
+#: ../misc/m.nviz.image/args.c:560 ../misc/m.nviz.image/args.c:570
+#: ../misc/m.nviz.image/args.c:578 ../misc/m.nviz.image/args.c:586
+#: ../misc/m.nviz.image/args.c:595 ../misc/m.nviz.image/args.c:605
+#: ../misc/m.nviz.image/args.c:613 ../misc/m.nviz.image/args.c:623
+#: ../misc/m.nviz.image/args.c:635 ../misc/m.nviz.image/args.c:645
+#: ../misc/m.nviz.image/args.c:656
+msgid "Volumes"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:523
+msgid "Volume draw mode"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:535
+msgid "Volume shading"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:547
+msgid "Volume position"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:558
+msgid "Volume resolution"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:569
+msgid "Isosurface level"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:577
+msgid "Name of volume for isosurface color"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:585
+msgid "Isosurface color"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:594
+msgid "Name of 3D raster map(s) for isosurface transparency"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:604
+msgid "Transparency value(s)for isosurfaces"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:612
+msgid "Name of 3D raster map(s) for shininess"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:622
+msgid "Shininess value(s) for isosurfaces"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:634
+msgid "Volume slice parallel to given axis (x, y, z)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:644
+msgid "Volume slice position"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:655
+msgid "Volume slice transparency"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:671
+msgid "Cutting plane index (0-5)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:672 ../misc/m.nviz.image/args.c:681
+#: ../misc/m.nviz.image/args.c:690 ../misc/m.nviz.image/args.c:701
+#: ../misc/m.nviz.image/args.c:712
+msgid "Cutting planes"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:680
+msgid "Cutting plane x,y,z coordinates"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:691
+msgid "Cutting plane rotation along the vertical axis"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:702
+msgid "Cutting plane tilt"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:713
+msgid "Cutting plane color (between two surfaces)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:727
+msgid "Light position (x,y,z model coordinates)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:728 ../misc/m.nviz.image/args.c:734
+#: ../misc/m.nviz.image/args.c:743 ../misc/m.nviz.image/args.c:753
+msgid "Lighting"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:733
+msgid "Light color"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:742
+msgid "Light brightness"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:752
+msgid "Light ambient"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:764
+msgid ""
+"nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East edge"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:768
+msgid "Fringe edges"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:769 ../misc/m.nviz.image/args.c:775
+#: ../misc/m.nviz.image/args.c:784
+msgid "Fringe"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:774
+msgid "Fringe color"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:783
+msgid "Fringe elevation"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:796
+msgid ""
+"Place north arrow at given position \t(in screen coordinates from bottom "
+"left corner)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:798 ../misc/m.nviz.image/args.c:807
+#: ../misc/m.nviz.image/args.c:814
+msgid "Decoration"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:806
+msgid "North arrow size (in map units)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:813
+msgid "North arrow color"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:862
+#, c-format
+msgid "At least one <%s> or <%s> required"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:876 ../misc/m.nviz.image/args.c:906
+#: ../misc/m.nviz.image/args.c:912 ../misc/m.nviz.image/args.c:918
+#: ../misc/m.nviz.image/args.c:924 ../misc/m.nviz.image/args.c:930
+#: ../misc/m.nviz.image/args.c:936
+#, c-format
+msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:947
+#, c-format
+msgid "Inconsistent number of attributes (<%s> %d: <%s> %d x 3)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:952 ../misc/m.nviz.image/args.c:957
+#: ../misc/m.nviz.image/args.c:968 ../misc/m.nviz.image/args.c:975
+#: ../misc/m.nviz.image/args.c:982 ../misc/m.nviz.image/args.c:989
+#: ../misc/m.nviz.image/args.c:996 ../misc/m.nviz.image/args.c:1028
+#, c-format
+msgid "Inconsistent number of attributes (<%s> %d: <%s> %d)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:1012 ../misc/m.nviz.image/args.c:1021
+#, c-format
+msgid "Inconsistent number of attributes (<%s> %d: <%s> %d, <%s> %d)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:1034
+#, c-format
+msgid "Inconsistent number of attributes (<%s> %d: <%s> %d x 6)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:1045
+#, c-format
+msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d, <%s> %d)"
+msgstr ""
+#: ../misc/m.nviz.image/volume.c:42 ../misc/m.nviz.image/volume.c:125
+#, c-format
+msgid "3d raster map <%s> not found"
+msgstr ""
+#: ../misc/m.nviz.image/volume.c:92 ../misc/m.nviz.image/volume.c:231
+#, c-format
+msgid "Error tokenize '%s'"
+msgstr ""
+#: ../misc/m.nviz.image/volume.c:99 ../misc/m.nviz.image/volume.c:247
+#, c-format
+msgid "Volume set number %d is not available"
+msgstr ""
+#: ../misc/m.nviz.image/volume.c:105
+#, c-format
+msgid "Unable to add isosurface (volume set %d)"
+msgstr ""
+#: ../misc/m.nviz.image/volume.c:113 ../misc/m.nviz.image/volume.c:131
+#: ../misc/m.nviz.image/volume.c:139 ../misc/m.nviz.image/volume.c:155
+#: ../misc/m.nviz.image/volume.c:162 ../misc/m.nviz.image/volume.c:173
+#: ../misc/m.nviz.image/volume.c:180
+#, c-format
+msgid "Unable to set isosurface (%d) attribute (%d) of volume %d"
+msgstr ""
+#: ../misc/m.nviz.image/volume.c:242
+#, c-format
+msgid "Wrong name for axis: %s"
+msgstr ""
+#: ../misc/m.nviz.image/volume.c:253
+#, c-format
+msgid "Unable to add slice (volume set %d)"
+msgstr ""
+#: ../misc/m.nviz.image/volume.c:266
+#, c-format
+msgid "Unable to set slice (%d) position of volume %d"
+msgstr ""
+#: ../misc/m.nviz.image/volume.c:271
+#, c-format
+msgid "Unable to set slice (%d) transparency of volume %d"
+msgstr ""
+#: ../misc/m.nviz.image/main.c:49 ../visualization/nviz/src/nviz_init.c:53
+msgid "visualization, raster, vector, raster3d"
+msgstr ""
+#: ../misc/m.nviz.image/main.c:50
+msgid "Creates a 3D rendering of GIS data."
+msgstr ""
+#: ../misc/m.nviz.image/main.c:51
+msgid ""
+"Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster "
+"data) in 3D."
+msgstr ""
+#: ../misc/m.nviz.image/main.c:134
+#, c-format
+msgid "Vertical exaggeration not given, using calculated value %.0f"
+msgstr ""
+#: ../misc/m.nviz.image/main.c:146
+#, c-format
+msgid "Viewpoint height not given, using calculated value %.0f"
+msgstr ""
+#: ../misc/m.nviz.image/main.c:229
+msgid "Unsupported output format"
+msgstr ""
+#: ../misc/m.nviz.image/main.c:231 ../imagery/i.cluster/main.c:346
+#, c-format
+msgid "File <%s> created."
+msgstr ""
+#: ../sites/s.in.ascii/main.c:50 ../sites/s.out.ascii/main.c:47
+msgid "sites"
+msgstr ""
+#: ../visualization/xganim/Clr_table.c:94
+#: ../visualization/xganim/Clr_table.c:292
+#: ../visualization/xganim/Clr_table.c:318
+#: ../visualization/ximgview/color.c:90 ../visualization/ximgview/color.c:288
+#, c-format
+msgid "Unknown visual class [%d]."
+msgstr ""
+#: ../visualization/xganim/Clr_table.c:243
+#: ../visualization/ximgview/color.c:239
+msgid "Unable to get sufficient gray shades."
+msgstr ""
+#: ../visualization/xganim/Clr_table.c:260
+#: ../visualization/ximgview/color.c:256
+msgid "Unable to get sufficient colors."
+msgstr ""
+#: ../visualization/xganim/Clr_table.c:273
+#: ../visualization/ximgview/color.c:269
+msgid "Using private colormap for DirectColor visual."
+msgstr ""
+#: ../visualization/xganim/main.c:362
+#, c-format
+msgid "Reading file [%s]..."
+msgstr ""
+#: ../visualization/xganim/main.c:370 ../imagery/i.gensigset/opencell.c:13
+#: ../imagery/i.landsat.acca/algorithm.c:389
+#: ../imagery/i.landsat.acca/tools.c:130 ../imagery/i.landsat.acca/main.c:61
+#: ../imagery/i.gensig/opencell.c:12 ../imagery/i.smap/shapiro/opencell.c:16
+#: ../imagery/i.landsat.toar/main.c:351 ../imagery/i.landsat.toar/main.c:495
+#: ../imagery/i.pca/main.c:139 ../imagery/i.rgb.his/openfiles.c:21
+#: ../imagery/i.rgb.his/openfiles.c:23 ../imagery/i.rgb.his/openfiles.c:25
+#: ../imagery/i.his.rgb/openfiles.c:33 ../imagery/i.his.rgb/openfiles.c:38
+#: ../imagery/i.his.rgb/openfiles.c:43 ../imagery/i.maxlik/open.c:41
+#: ../imagery/i.modis.qc/main.c:221 ../imagery/i.cluster/open_files.c:56
+#: ../vector/v.sample/main.c:161 ../vector/v.extrude/main.c:184
+#: ../vector/v.what.rast/main.c:141 ../vector/v.drape/main.c:250
+#: ../vector/v.to.rast/support.c:267 ../vector/v.to.rast/support.c:426
+#: ../vector/v.vol.rst/main.c:609 ../doc/raster/r.example/main.c:122
+#: ../display/d.profile/What.c:23 ../display/d.profile/ExtractProf.c:93
+#: ../display/d.rast.edit/cell.c:92 ../display/d.rgb/main.c:99
+#: ../display/d.rast/display.c:79 ../display/d.his/main.c:141
+#: ../display/d.his/main.c:164 ../display/d.rast.arrow/arrow.c:380
+#: ../display/d.what.rast/opencell.c:24 ../display/d.nviz/main.c:187
+#: ../display/d.rast.num/number.c:157 ../raster/r.to.vect/main.c:116
+#: ../raster/r.buffer/read_map.c:42 ../raster/r.buffer/write_map.c:45
+#: ../raster/r.univar2/r.univar_main.c:221 ../raster/r.lake/main.c:258
+#: ../raster/r.lake/main.c:269 ../raster/r.to.rast3elev/main.c:160
+#: ../raster/r.regression.line/main.c:90 ../raster/r.regression.line/main.c:99
+#: ../raster/r.out.png/r.out.png.c:217 ../raster/r.covar/main.c:98
+#: ../raster/r.surf.idw/main.c:135 ../raster/r.walk/main.c:545
+#: ../raster/r.walk/main.c:548 ../raster/r.walk/main.c:854
+#: ../raster/r.sum/main.c:65 ../raster/r.out.tiff/r.out.tiff.c:188
+#: ../raster/r.grow2/main.c:203 ../raster/r.cross/main.c:129
+#: ../raster/r.out.ppm3/main.c:124 ../raster/r.out.vtk/main.c:222
+#: ../raster/r.out.vtk/main.c:288 ../raster/r.out.vtk/main.c:317
+#: ../raster/r.out.vtk/main.c:364 ../raster/r.mapcalc/map3.c:510
+#: ../raster/r.null/null.c:324 ../raster/r.cost/main.c:340
+#: ../raster/r.cost/main.c:590 ../raster/r.random.surface/init.c:134
+#: ../raster/r.random.surface/main.c:54 ../raster/r.random.cells/init.c:68
+#: ../raster/r.random.cells/indep.c:134 ../raster/r.grow.distance/main.c:177
+#: ../raster/r.out.ascii/main.c:151 ../raster/r.out.ppm/main.c:120
+#: ../raster/r.resamp.interp/main.c:138 ../raster/r.surf.idw2/read_cell.c:34
+#: ../raster/r.los/main.c:198 ../raster/r.los/main.c:209
+#: ../raster/r.colors/stats.c:33 ../raster/r.resamp.rst/main.c:402
+#: ../raster/r.resamp.rst/main.c:434 ../raster/r.his/main.c:131
+#: ../raster/r.his/main.c:154 ../raster/r.his/main.c:179
+#: ../raster/r.bitpattern/main.c:108 ../raster/r.support/front/front.c:227
+#: ../raster/r.resamp.stats/main.c:329 ../raster/r.sunmask/main.c:448
+#: ../raster/r.out.pov/main.c:178 ../raster/r.random/count.c:24
+#: ../raster/r.random/count.c:30 ../raster/r.random/random.c:41
+#: ../raster/r.random/random.c:45 ../raster/r.quantile/main.c:311
+#: ../raster/r.to.rast3/main.c:366 ../raster/r.carve/main.c:181
+#: ../raster/r.contour/main.c:162 ../raster/r.surf.area/main.c:121
+#: ../raster/r.bilinear/main.c:94 ../raster/r.clump/main.c:94
+#: ../raster/wildfire/r.ros/main.c:475 ../raster/wildfire/r.ros/main.c:483
+#: ../raster/wildfire/r.ros/main.c:491 ../raster/wildfire/r.ros/main.c:499
+#: ../raster/wildfire/r.ros/main.c:507 ../raster/wildfire/r.ros/main.c:515
+#: ../raster/wildfire/r.ros/main.c:523 ../raster/wildfire/r.ros/main.c:532
+#: ../raster/wildfire/r.ros/main.c:540 ../raster/wildfire/r.ros/main.c:549
+#: ../raster/wildfire/r.spread/main.c:411
+#: ../raster/wildfire/r.spread/main.c:415
+#: ../raster/wildfire/r.spread/main.c:419
+#: ../raster/wildfire/r.spread/main.c:425
+#: ../raster/wildfire/r.spread/main.c:430
+#: ../raster/wildfire/r.spread/main.c:434
+#: ../raster/wildfire/r.spread/main.c:503 ../raster/r.composite/main.c:159
+#: ../raster/r.out.arc/main.c:117 ../raster/r.texture/main.c:234
+#: ../raster/r.recode/recode.c:48 ../raster/r.profile/main.c:144
+#: ../raster/r.out.mat/main.c:108 ../raster/r.cats/main.c:150
+#: ../raster/r.out.gdal/export_band.c:48
+#: ../raster/r.out.gdal/export_band.c:246 ../raster/r.thin/io.c:100
+#, c-format
+msgid "Unable to open raster map <%s>"
+msgstr ""
+#: ../visualization/xganim/main.c:384
+msgid "Unable to determine raster cell type"
+msgstr ""
+#: ../visualization/xganim/main.c:388
+msgid "Unable to read color file"
+msgstr ""
+#: ../visualization/xganim/main.c:393
+msgid "Unable to read raster row"
+msgstr ""
+#: ../visualization/xganim/main.c:544 ../raster/r.out.mpeg/main.c:346
+msgid "Error reading wildcard"
+msgstr ""
+#: ../visualization/xganim/main.c:600 ../raster/r.out.mpeg/main.c:396
+#, c-format
+msgid "Raster file(s) for View%d"
+msgstr ""
+#: ../visualization/ximgview/main.c:62
+msgid "Unable to open display"
+msgstr ""
+#: ../visualization/ximgview/main.c:82
+msgid "Unable to get window attributes"
+msgstr ""
+#: ../visualization/ximgview/main.c:238
+msgid "Unable to open image file"
+msgstr ""
+#: ../visualization/ximgview/main.c:241
+msgid "Unable to read BMP header"
+msgstr ""
+#: ../visualization/ximgview/main.c:244
+msgid "Invalid BMP header"
+msgstr ""
+#: ../visualization/ximgview/main.c:250
+msgid "Unable to map image file"
+msgstr ""
+#: ../visualization/ximgview/main.c:271
+msgid "View BMP images from the PNG driver."
+msgstr ""
+#: ../visualization/ximgview/main.c:279
+msgid "Image file"
+msgstr ""
+#: ../visualization/ximgview/main.c:286
+msgid "Percentage of CPU time to use"
+msgstr ""
+#: ../visualization/nviz/src/nviz_init.c:55
+msgid "nviz - Visualization and animation tool for GRASS data."
+msgstr ""
+#: ../visualization/nviz/src/nviz_init.c:60
+msgid "Name of raster map(s) for Elevation"
+msgstr ""
+#: ../visualization/nviz/src/nviz_init.c:61
+#: ../visualization/nviz/src/nviz_init.c:70
+#: ../visualization/nviz/src/nviz_init.c:97
+msgid "Raster"
+msgstr ""
+#: ../visualization/nviz/src/nviz_init.c:69
+msgid "Name of raster map(s) for Color"
+msgstr ""
+#: ../visualization/nviz/src/nviz_init.c:78
+msgid "Name of vector lines/areas overlay map(s)"
+msgstr ""
+#: ../visualization/nviz/src/nviz_init.c:79
+#: ../visualization/nviz/src/nviz_init.c:88
+msgid "Vector"
+msgstr ""
+#: ../visualization/nviz/src/nviz_init.c:87
+msgid "Name of vector points overlay file(s)"
+msgstr ""
+#: ../visualization/nviz/src/nviz_init.c:96
+msgid "Name of existing 3d raster map"
+msgstr ""
+#: ../visualization/nviz/src/nviz_init.c:101
+msgid "Quickstart - Do not load any data"
+msgstr ""
+#: ../visualization/nviz/src/nviz_init.c:106
+msgid "Exit after completing script launched from the command line"
+msgstr ""
+#: ../visualization/nviz/src/nviz_init.c:111
+msgid "Start in Demo mode (skip the \"please wait\" message)"
+msgstr ""
+#: ../visualization/nviz/src/nviz_init.c:115
+msgid "Verbose module output"
+msgstr ""
+#: ../visualization/nviz/src/nviz_init.c:121
+msgid "Set alternative panel path"
+msgstr ""
+#: ../visualization/nviz/src/nviz_init.c:127
+msgid "Execute script file at startup"
+msgstr ""
+#: ../visualization/nviz/src/nviz_init.c:133
+msgid "Load previously saved state file"
+msgstr ""
+#: ../visualization/nviz/src/nviz_init.c:157 ../display/d.vect/main.c:367
+#: ../display/d.mon/pgms/release.c:36 ../raster/r.out.tiff/r.out.tiff.c:144
+#: ../raster/r.cost/main.c:226 ../raster/wildfire/r.ros/main.c:314
+#: ../raster/wildfire/r.spread/main.c:255 ../raster/r.in.mat/main.c:125
+#: ../raster/r.out.mat/main.c:90
+msgid ""
+"The '-v' flag is superseded and will be removed in future. Please use '--"
+"verbose' instead."
+msgstr ""
+#: ../visualization/nviz/src/nviz_init.c:287
+msgid "Number of elevation files does not match number of colors files"
+msgstr ""
+#: ../visualization/nviz/src/nviz_init.c:298
+msgid "Loading data failed"
+msgstr ""
+#: ../visualization/nviz/src/nviz_init.c:411
+msgid "Entering script mode ..."
+msgstr ""
+#: ../imagery/i.zc/main.c:57
+msgid "imagery, edges"
+msgstr ""
+#: ../imagery/i.zc/main.c:59
+msgid "Zero-crossing \"edge detection\" raster function for image processing."
+msgstr ""
+#: ../imagery/i.zc/main.c:78
+msgid "Zero crossing raster map"
+msgstr ""
+#: ../imagery/i.zc/main.c:86
+msgid "x-y extent of the Gaussian filter"
+msgstr ""
+#: ../imagery/i.zc/main.c:94
+msgid "Sensitivity of Gaussian filter"
+msgstr ""
+#: ../imagery/i.zc/main.c:102
+msgid "Number of azimuth directions categorized"
+msgstr ""
+#: ../imagery/i.zc/main.c:123
+msgid "Threshold less than or equal to zero not allowed"
+msgstr ""
+#: ../imagery/i.zc/main.c:129
+msgid "Width less than or equal to zero not allowed"
+msgstr ""
+#: ../imagery/i.zc/main.c:133
+msgid "Fewer than 1 orientation classes not allowed"
+msgstr ""
+#: ../imagery/i.zc/main.c:147
+#, c-format
+msgid "Power 2 values : %d rows %d columns"
+msgstr ""
+#: ../imagery/i.zc/main.c:157
+msgid "Initializing data..."
+msgstr ""
+#: ../imagery/i.zc/main.c:167 ../raster/r.out.tiff/r.out.tiff.c:283
+#: ../raster/r.carve/raster.c:12 ../raster/r.texture/main.c:261
+msgid "Reading raster map..."
+msgstr ""
+#: ../imagery/i.zc/main.c:170 ../imagery/i.fft/fftmain.c:170
+msgid "Error while reading input raster map."
+msgstr ""
+#: ../imagery/i.zc/main.c:188
+msgid "Writing transformed data to file..."
+msgstr ""
+#: ../imagery/i.zc/main.c:209
+msgid "Transform successful"
+msgstr ""
+#: ../imagery/i.gensigset/read_data.c:19 ../imagery/i.ifft/ifftmain.c:144
+#: ../imagery/i.cluster/main.c:285
+msgid "Reading raster maps..."
+msgstr ""
+#: ../imagery/i.gensigset/read_data.c:27
+#: ../imagery/i.gensigset/read_train.c:10 ../imagery/i.gensig/read_train.c:10
+#: ../imagery/i.gensig/covariance.c:34
+#: ../imagery/i.smap/bouman/read_block.c:16 ../imagery/i.pca/main.c:265
+#: ../imagery/i.pca/main.c:315 ../imagery/i.pca/main.c:327
+#: ../imagery/i.pca/main.c:441 ../imagery/i.maxlik/main.c:117
+#: ../imagery/i.cluster/main.c:290 ../raster/r.proj/readcell.c:27
+#: ../raster/r.out.png/r.out.png.c:321 ../raster/r.surf.idw/main.c:690
+#: ../raster/r.mapcalc/map.c:234
+#, c-format
+msgid "Unable to read raster map row %d"
+msgstr ""
+#: ../imagery/i.gensigset/parse.c:13 ../imagery/i.gensig/parse.c:14
+msgid "Ground truth training map"
+msgstr ""
+#: ../imagery/i.gensigset/parse.c:21 ../imagery/i.gensig/parse.c:22
+#: ../imagery/i.cluster/main.c:97
+msgid "Name for output file containing result signatures"
+msgstr ""
+#: ../imagery/i.gensigset/parse.c:27
+msgid "Maximum number of sub-signatures in any class"
+msgstr ""
+#: ../imagery/i.gensigset/parse.c:45 ../imagery/i.gensig/parse.c:39
+#: ../imagery/i.smap/shapiro/parse.c:58
+#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:177
+#: ../imagery/i.maxlik/open.c:16 ../imagery/i.cluster/open_files.c:17
+#, c-format
+msgid "Group <%s> not found"
+msgstr ""
+#: ../imagery/i.gensigset/parse.c:48 ../imagery/i.gensig/parse.c:42
+#: ../imagery/i.smap/shapiro/parse.c:61
+#, c-format
+msgid "Subgroup <%s> not found"
+msgstr ""
+#: ../imagery/i.gensigset/parse.c:52
+#, c-format
+msgid "Illegal number of sub-signatures (%s)"
+msgstr ""
+#: ../imagery/i.gensigset/write_sig.c:13 ../imagery/i.gensig/write_sig.c:15
+#, c-format
+msgid "Unable to create signature file <%s>"
+msgstr ""
+#: ../imagery/i.gensigset/write_sig.c:16 ../imagery/i.gensig/write_sig.c:18
+msgid "Writing signatures..."
+msgstr ""
+#: ../imagery/i.gensigset/openfiles.c:15 ../imagery/i.gensig/openfiles.c:16
+#: ../imagery/i.smap/shapiro/openfiles.c:15
+#: ../imagery/i.smap/shapiro/read_sig.c:13
+#, c-format
+msgid "Unable to read REF file for subgroup <%s> in group <%s>"
+msgstr ""
+#: ../imagery/i.gensigset/openfiles.c:19 ../imagery/i.gensig/openfiles.c:20
+#, c-format
+msgid "Subgroup <%s> in group <%s> contains no raster maps."
+msgstr ""
+#: ../imagery/i.gensigset/get_train.c:32 ../imagery/i.gensig/get_train.c:28
+msgid "Finding training classes..."
+msgstr ""
+#: ../imagery/i.gensigset/get_train.c:36
+#: ../imagery/i.landsat.acca/algorithm.c:252
+#: ../imagery/i.landsat.acca/algorithm.c:411
+#: ../imagery/i.landsat.acca/algorithm.c:414
+#: ../imagery/i.landsat.acca/tools.c:155 ../imagery/i.landsat.acca/tools.c:159
+#: ../imagery/i.landsat.acca/tools.c:163 ../imagery/i.gensig/get_train.c:32
+#: ../vector/v.what.rast/main.c:271 ../vector/v.what.rast/main.c:276
+#: ../vector/v.to.rast/support.c:440 ../doc/raster/r.example/main.c:154
+#: ../raster/r.buffer/read_map.c:63 ../raster/r.buffer/write_map.c:61
+#: ../raster/r.lake/main.c:288 ../raster/r.lake/main.c:293
+#: ../raster/r.walk/main.c:697 ../raster/r.walk/main.c:756
+#: ../raster/r.walk/main.c:872 ../raster/r.walk/main.c:1413
+#: ../raster/r.walk/main.c:1448 ../raster/r.walk/main.c:1483
+#: ../raster/r.null/null.c:340 ../raster/r.cost/main.c:405
+#: ../raster/r.cost/main.c:606 ../raster/r.cost/main.c:921
+#: ../raster/r.cost/main.c:954 ../raster/r.cost/main.c:987
+#: ../raster/r.out.ppm/main.c:188 ../raster/r.topidx/file_io.c:77
+#: ../raster/r.los/main.c:264 ../raster/r.los/main.c:272
+#: ../raster/r.colors/stats.c:46 ../raster/r.colors/stats.c:113
+#: ../raster/r.bitpattern/main.c:135 ../raster/r.sunmask/main.c:481
+#: ../raster/r.profile/read_rast.c:45 ../raster/r.profile/read_rast.c:73
+#: ../raster/r.profile/read_rast.c:101 ../raster/r.patch/main.c:156
+#: ../raster/r.patch/main.c:163 ../raster/r.out.gdal/export_band.c:90
+#: ../raster/r.out.gdal/export_band.c:121
+#: ../raster/r.out.gdal/export_band.c:152
+#: ../raster/r.out.gdal/export_band.c:397
+#: ../raster/r.out.gdal/export_band.c:430
+#: ../raster/r.out.gdal/export_band.c:463
+#, c-format
+msgid "Unable to read raster map <%s> row %d"
+msgstr ""
+#: ../imagery/i.gensigset/get_train.c:57 ../imagery/i.gensig/get_train.c:53
+#, c-format
+msgid "Training class %d only has one cell - this class will be ignored"
+msgstr ""
+#: ../imagery/i.gensigset/get_train.c:62 ../imagery/i.gensig/get_train.c:58
+msgid "Training map has no classes"
+msgstr ""
+#: ../imagery/i.gensigset/get_train.c:78 ../imagery/i.gensig/get_train.c:73
+msgid "1 class found"
+msgstr ""
+#: ../imagery/i.gensigset/get_train.c:80 ../imagery/i.gensig/get_train.c:75
+#, c-format
+msgid "%d classes found"
+msgstr ""
+#: ../imagery/i.gensigset/subcluster.c:75
+#, c-format
+msgid "Not enough pixels in class %d"
+msgstr ""
+#: ../imagery/i.gensigset/subcluster.c:85
+#, c-format
+msgid "Too many subclasses for class index %d"
+msgstr ""
+#: ../imagery/i.gensigset/subcluster.c:87
+#, c-format
+msgid "Number of subclasses set to %d"
+msgstr ""
+#: ../imagery/i.gensigset/subcluster.c:102
+#, c-format
+msgid "Combining subclasses (%d,%d)..."
+msgstr ""
+#: ../imagery/i.gensigset/subcluster.c:312
+#, c-format
+msgid "Subsignature %d only contains %f pixels"
+msgstr ""
+#: ../imagery/i.gensigset/subcluster.c:547
+msgid "Unreliable clustering. Try a smaller initial number of clusters"
+msgstr ""
+#: ../imagery/i.gensigset/subcluster.c:556
+#, c-format
+msgid "Removed a singular subsignature number %d (%d remain)"
+msgstr ""
+#: ../imagery/i.gensigset/main.c:40 ../imagery/i.smap/shapiro/main.c:38
+msgid "imagery, classification, supervised, SMAP"
+msgstr ""
+#: ../imagery/i.gensigset/main.c:42
+msgid "Generates statistics for i.smap from raster map."
+msgstr ""
+#: ../imagery/i.gensigset/main.c:52
+#, c-format
+msgid "Clustering class %d (%d pixels)..."
+msgstr ""
+#: ../imagery/i.gensigset/main.c:55
+#, c-format
+msgid "Number of subclasses is %d"
+msgstr ""
+#: ../imagery/i.ask/popup.c:239
+#, c-format
+msgid "name=%s\n"
+msgstr ""
+#: ../imagery/i.ask/popup.c:240
+#, c-format
+msgid "mapset=%s\n"
+msgstr ""
+#: ../imagery/i.ask/popup.c:241
+#, c-format
+msgid "fullname=%s\n"
+msgstr ""
+#: ../imagery/i.ask/main.c:26
+#, c-format
+msgid "usage: %s file [prompt %%x %%y]\n"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:124
+msgid "Preliminary scene analysis:"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:125
+#, c-format
+msgid "* Desert index: %.2lf"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:126
+#, c-format
+msgid "* Snow cover: %.2lf %%"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:127
+#, c-format
+msgid "* Cloud cover: %.2lf %%"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:128
+msgid "* Temperature of clouds:"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:129
+#, c-format
+msgid "** Maximum: %.2lf K"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:130
+#, c-format
+msgid "** Mean (%s cloud): %.2lf K"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:132
+#, c-format
+msgid "** Minimum: %.2lf K"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:142
+msgid "Histogram cloud signature:"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:148
+#, c-format
+msgid "* Mean temperature: %.2lf K"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:149
+#, c-format
+msgid "* Standard deviation: %.2lf"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:150
+#, c-format
+msgid "* Skewness: %.2lf"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:151
+#, c-format
+msgid "* Histogram classes: %d"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:163
+#, c-format
+msgid "* 98.75 percentile: %.2lf K"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:164
+#, c-format
+msgid "* 97.50 percentile: %.2lf K"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:165
+#, c-format
+msgid "* 83.50 percentile: %.2lf K"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:186
+msgid "Maximum temperature:"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:187
+#, c-format
+msgid "* Cold cloud: %.2lf K"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:188
+#, c-format
+msgid "* Warm cloud: %.2lf K"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:193
+msgid "Result: Scene with clouds"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:200
+msgid "Result: Scene cloud free"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:238
+msgid "Processing first pass..."
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:362
+#: ../imagery/i.landsat.acca/tools.c:291 ../raster/r.buffer/write_map.c:78
+#: ../raster/r.proj/main.c:445 ../raster/r.null/null.c:348
+#: ../raster/r.proj.seg/main.c:513 ../raster/r.los/main.c:380
+#: ../raster/r.texture/main.c:356 ../raster/r.texture/main.c:360
+#: ../raster/r.texture/main.c:367
+#, c-format
+msgid "Failed writing raster map <%s> row %d"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:400
+msgid "Removing ambiguous pixels..."
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:402
+msgid "Pass two processing..."
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:448
+#, c-format
+msgid "Cannot write to raster map <%s>"
+msgstr ""
+#: ../imagery/i.landsat.acca/tools.c:142
+msgid "Filling small holes in clouds..."
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:74
+#, c-format
+msgid ""
+"Input raster map <%s> is not floating point (process DN using i.landsat.toar "
+"to radiance first)"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:106
+msgid "Performs Landsat TM/ETM+ Automatic Cloud Cover Assessment (ACCA)."
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:107
+msgid "imagery, landsat, acca"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:111 ../imagery/i.landsat.toar/main.c:72
+msgid "Base name of input raster bands"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:112 ../imagery/i.landsat.toar/main.c:73
+msgid "Example: 'B.' for B.1, B.2, ..."
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:122
+msgid "B56composite (step 6)"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:129
+msgid "B45ratio: Desert detection (step 10)"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:137
+msgid "Number of classes in the cloud temperature histogram"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:139 ../imagery/i.landsat.acca/main.c:154
+#: ../imagery/i.landsat.acca/main.c:160 ../imagery/i.landsat.acca/main.c:165
+msgid "Cloud settings"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:143
+msgid "Data is Landsat-5 TM"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:144
+msgid "I.e. Thermal band is '.6' not '.61')"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:149
+msgid "Apply post-processing filter to remove small holes"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:153
+msgid "Always use cloud signature (step 14)"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:159
+msgid ""
+"Bypass second-pass processing, and merge warm (not ambiguous) and cold clouds"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:164
+msgid "Include a category for cloud shadows"
+msgstr ""
+#: ../imagery/i.gensig/check.c:21
+#, c-format
+msgid "Signature %d not invertible"
+msgstr ""
+#: ../imagery/i.gensig/check.c:27
+#, c-format
+msgid "Signature %d unable to get eigen values"
+msgstr ""
+#: ../imagery/i.gensig/check.c:33
+#, c-format
+msgid "Signature %d not positive definite"
+msgstr ""
+#: ../imagery/i.gensig/covariance.c:26
+msgid "Calculating class covariance matrices..."
+msgstr ""
+#: ../imagery/i.gensig/means.c:24
+msgid "Calculating class means..."
+msgstr ""
+#: ../imagery/i.gensig/main.c:39
+msgid "imagery, classification, supervised, MLC"
+msgstr ""
+#: ../imagery/i.gensig/main.c:41
+msgid "Generates statistics for i.maxlik from raster map."
+msgstr ""
+#: ../imagery/i.topo.corr/correction.c:100
+#, c-format
+msgid "Minnaert constant = %lf"
+msgstr ""
+#: ../imagery/i.topo.corr/correction.c:105
+#, c-format
+msgid "C-factor constant = %lf (a=%.4f; m=%.4f)"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:38 ../raster/r.mapcalc/map.c:442
+#, c-format
+msgid "Unable to open raster map <%s@%s>"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:52 ../raster/r.random.cells/init.c:156
+#, c-format
+msgid "<%s> is an illegal name"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:84
+msgid "Computes topographic correction of reflectance."
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:86
+msgid "imagery, terrain, topographic correction"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:94
+msgid "Name of reflectance raster maps to be corrected topographically"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:98
+msgid "Name (flag -i) or prefix for output raster maps"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:102
+msgid "Name of input base raster map (elevation or illumination)"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:108
+msgid "Solar zenith in degrees"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:114
+msgid "Solar azimuth in degrees (only if flag -i)"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:121
+msgid "Topographic correction method"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:126
+msgid "Output sun illumination terrain model"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:132
+msgid "Solar azimuth is necessary to calculate illumination terrain model"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:135
+msgid "Reflectance maps are necessary to make topographic correction"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:167
+msgid "Elevation raster map of unknown type"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:197 ../raster/r.resamp.interp/main.c:97
+#, c-format
+msgid "Invalid method: %s"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:201
+msgid "Illumination model is of CELL type"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:208
+#, c-format
+msgid "Reflectance of raster map <%s> is not of DCELL type - ignored"
+msgstr ""
+#: ../imagery/i.group/main.c:52 ../imagery/i.target/main.c:45
+msgid "imagery, map management"
+msgstr ""
+#: ../imagery/i.group/main.c:54
+msgid "Creates, edits, and lists groups and subgroups of imagery files."
+msgstr ""
+#: ../imagery/i.group/main.c:58
+#: ../imagery/i.ortho.photo/i.photo.2target/main.c:62
+msgid "Name of imagery group"
+msgstr ""
+#: ../imagery/i.group/main.c:64
+msgid "Name of imagery sub-group"
+msgstr ""
+#: ../imagery/i.group/main.c:68
+msgid "Name of raster map(s) to include in group"
+msgstr ""
+#: ../imagery/i.group/main.c:72
+msgid "Remove selected files from specified group"
+msgstr ""
+#: ../imagery/i.group/main.c:76
+msgid "List files from specified (sub)group (fancy)"
+msgstr ""
+#: ../imagery/i.group/main.c:82
+msgid "List files from specified (sub)group (shell script style)"
+msgstr ""
+#: ../imagery/i.group/main.c:102
+msgid "No input raster map(s) specified"
+msgstr ""
+#: ../imagery/i.group/main.c:110 ../imagery/i.target/main.c:79
+#: ../imagery/i.class/main.c:103
+msgid "Group must exist in the current mapset"
+msgstr ""
+#: ../imagery/i.group/main.c:120 ../imagery/i.group/main.c:141
+msgid "Specified group does not exist in current mapset"
+msgstr ""
+#: ../imagery/i.group/main.c:124
+#, c-format
+msgid "Removing raster maps from subgroup <%s>..."
+msgstr ""
+#: ../imagery/i.group/main.c:129
+#, c-format
+msgid "Removing raster maps from group <%s>..."
+msgstr ""
+#: ../imagery/i.group/main.c:164
+#, c-format
+msgid "Group <%s> does not yet exist. Creating..."
+msgstr ""
+#: ../imagery/i.group/main.c:168 ../imagery/i.group/main.c:177
+#, c-format
+msgid "Adding raster maps to group <%s>..."
+msgstr ""
+#: ../imagery/i.group/main.c:172
+#, c-format
+msgid "Adding raster maps to subgroup <%s>..."
+msgstr ""
+#: ../imagery/i.group/main.c:203
+#, c-format
+msgid "Adding raster map <%s> to group"
+msgstr ""
+#: ../imagery/i.group/main.c:209
+#, c-format
+msgid "Raster map <%s> exists in group. Skipping..."
+msgstr ""
+#: ../imagery/i.group/main.c:243
+#, c-format
+msgid "Adding raster map <%s> to subgroup"
+msgstr ""
+#: ../imagery/i.group/main.c:249
+#, c-format
+msgid "Raster map <%s> exists in subgroup. Skipping..."
+msgstr ""
+#: ../imagery/i.group/main.c:298
+#, c-format
+msgid "Removing raster map <%s> from group"
+msgstr ""
+#: ../imagery/i.group/main.c:315 ../imagery/i.group/main.c:374
+msgid "No raster map removed"
+msgstr ""
+#: ../imagery/i.group/main.c:357
+#, c-format
+msgid "Removing raster map <%s> from subgroup"
+msgstr ""
+#: ../imagery/i.target/main.c:47
+msgid "Targets an imagery group to a GRASS location and mapset."
+msgstr ""
+#: ../imagery/i.target/main.c:56
+msgid "Name of imagery target location"
+msgstr ""
+#: ../imagery/i.target/main.c:62
+msgid "Name of target mapset"
+msgstr ""
+#: ../imagery/i.target/main.c:67
+msgid "Set current location and mapset as target for of imagery group"
+msgstr ""
+#: ../imagery/i.target/main.c:89 ../imagery/i.target/main.c:106
+#: ../imagery/i.target/main.c:115
+#, c-format
+msgid "Group <%s> targeted for location [%s], mapset [%s]"
+msgstr ""
+#: ../imagery/i.target/main.c:92
+#, c-format
+msgid "Group <%s> has no target"
+msgstr ""
+#: ../imagery/i.target/main.c:100
+msgid ""
+"Use either the Current Mapset and Location Flag (-c)\n"
+" OR\n"
+" manually enter the variables"
+msgstr ""
+#: ../imagery/i.fft/save_fft.c:17 ../imagery/i.fft/save_fft.c:22
+msgid "Unable to open file in the 'cell_misc' directory"
+msgstr ""
+#: ../imagery/i.fft/fftmain.c:74 ../imagery/i.ifft/ifftmain.c:68
+msgid "imagery, FFT"
+msgstr ""
+#: ../imagery/i.fft/fftmain.c:76
+msgid "Fast Fourier Transform (FFT) for image processing."
+msgstr ""
+#: ../imagery/i.fft/fftmain.c:84
+msgid "Name for output real part arrays stored as raster map"
+msgstr ""
+#: ../imagery/i.fft/fftmain.c:88
+msgid "Name for output imaginary part arrays stored as raster map"
+msgstr ""
+#: ../imagery/i.fft/fftmain.c:96
+msgid "Range of values in output display files"
+msgstr ""
+#: ../imagery/i.fft/fftmain.c:115
+msgid "Raster MASK found, consider to remove (see man-page). Will continue..."
+msgstr ""
+#: ../imagery/i.fft/fftmain.c:129
+msgid "Range less than or equal to zero not allowed"
+msgstr ""
+#: ../imagery/i.fft/fftmain.c:166
+#, c-format
+msgid "Reading the raster map <%s>..."
+msgstr ""
+#: ../imagery/i.fft/fftmain.c:182
+msgid "Starting FFT..."
+msgstr ""
+#: ../imagery/i.fft/fftmain.c:201 ../imagery/i.ifft/ifftmain.c:172
+msgid "Rotating data..."
+msgstr ""
+#: ../imagery/i.fft/fftmain.c:225
+msgid "Writing transformed data..."
+msgstr ""
+#: ../imagery/i.fft/fftmain.c:231
+msgid "Writing viewable versions of transformed data..."
+msgstr ""
+#: ../imagery/i.fft/fftmain.c:274
+msgid " "
+msgstr ""
+#: ../imagery/i.smap/bouman/model.c:39
+#, c-format
+msgid "Nonsymetric covariance for class %d subclass %d"
+msgstr ""
+#: ../imagery/i.smap/bouman/model.c:49
+#, c-format
+msgid "Nonpositive eigenvalues for class %d subclass %d"
+msgstr ""
+#: ../imagery/i.smap/bouman/segment.c:70
+msgid "Number of classes must be < 256"
+msgstr ""
+#: ../imagery/i.smap/bouman/segment.c:95
+#, c-format
+msgid "Processing rows %d-%d (of %d)..."
+msgstr ""
+#: ../imagery/i.smap/bouman/interp.c:38
+msgid "pyramid constructed."
+msgstr ""
+#: ../imagery/i.smap/bouman/interp.c:69 ../raster/r.cost/main.c:600
+#: ../raster/r.texture/h_measure.c:770
+msgid "Unable to allocate memory"
+msgstr ""
+#: ../imagery/i.smap/bouman/interp.c:237
+msgid "Invalid parameter values"
+msgstr ""
+#: ../imagery/i.smap/shapiro/parse.c:21 ../imagery/i.maxlik/main.c:79
+msgid "Name of file containing signatures"
+msgstr ""
+#: ../imagery/i.smap/shapiro/parse.c:22
+msgid "Generated by i.gensigset"
+msgstr ""
+#: ../imagery/i.smap/shapiro/parse.c:31
+msgid "Size of submatrix to process at one time"
+msgstr ""
+#: ../imagery/i.smap/shapiro/parse.c:39
+msgid "Use maximum likelihood estimation (instead of smap)"
+msgstr ""
+#: ../imagery/i.smap/shapiro/parse.c:43 ../imagery/i.maxlik/main.c:95
+#: ../raster/r.buffer/main.c:101 ../raster/r.out.png/r.out.png.c:136
+#: ../raster/r.covar/main.c:67 ../raster/r.cross/main.c:100
+#: ../raster/r.neighbors/main.c:171 ../raster/r.out.ppm3/main.c:90
+#: ../raster/r.out.ppm/main.c:69 ../raster/r.colors/main.c:249
+#: ../raster/r.distance/parse.c:64 ../raster/r.carve/main.c:116
+#: ../raster/r.contour/main.c:135 ../raster/r.compress/main.c:82
+#: ../raster/r.describe/main.c:107 ../raster/r.clump/main.c:68
+#: ../raster/r.series/main.c:170
+msgid "Run quietly"
+msgstr ""
+#: ../imagery/i.smap/shapiro/openfiles.c:19
+#: ../imagery/i.smap/shapiro/read_sig.c:17
+#, c-format
+msgid "Subgroup <%s> in group <%s> contains no raster maps"
+msgstr ""
+#: ../imagery/i.smap/shapiro/read_sig.c:23 ../imagery/i.maxlik/open.c:54
+#: ../imagery/i.cluster/open_files.c:70
+#, c-format
+msgid "Unable to read signature file <%s>"
+msgstr ""
+#: ../imagery/i.smap/shapiro/read_sig.c:27
+#, c-format
+msgid "Signature file <%s> is invalid"
+msgstr ""
+#: ../imagery/i.smap/shapiro/read_sig.c:30
+#, c-format
+msgid "Signature file <%s> is empty"
+msgstr ""
+#: ../imagery/i.smap/shapiro/write_img.c:12 ../raster/r.cost/main.c:907
+#: ../raster/r.random.surface/save.c:100 ../raster/r.random.cells/indep.c:137
+#: ../raster/r.drain/main.c:362 ../raster/r.drain/main.c:415
+#: ../raster/r.composite/main.c:199
+#, c-format
+msgid "Writing raster map <%s>..."
+msgstr ""
+#: ../imagery/i.smap/shapiro/main.c:40
+msgid ""
+"Performs contextual image classification using sequential maximum a "
+"posteriori (SMAP) estimation."
+msgstr ""
+#: ../imagery/i.points/main.c:96 ../imagery/i.vpoints/main.c:94
+msgid "imagery, geometry"
+msgstr ""
+#: ../imagery/i.points/main.c:98
+msgid "Mark ground control points on image to be rectified."
+msgstr ""
+#: ../imagery/i.points/main.c:105 ../imagery/i.vpoints/main.c:104
+msgid "Name of imagery group to be registered"
+msgstr ""
+#: ../imagery/i.points/main.c:123
+#: ../imagery/i.ortho.photo/i.photo.2target/main.c:97
+#: ../imagery/i.ortho.photo/i.photo.2image/main.c:81
+#: ../imagery/i.class/main.c:90 ../vector/v.label/main.c:234
+#: ../display/d.geodesic/main.c:105 ../display/d.graph/main.c:96
+#: ../display/d.grid/main.c:186 ../display/d.profile/main.c:134
+#: ../display/d.measure/main.c:87 ../display/d.what.vect/main.c:160
+#: ../display/d.extend/main.c:41 ../display/d.rgb/main.c:83
+#: ../display/d.legend/main.c:274 ../display/d.extract/main.c:79
+#: ../display/d.rast/main.c:114 ../display/d.vect.chart/main.c:257
+#: ../display/d.his/main.c:117 ../display/d.ask/main.c:61
+#: ../display/d.font.freetype/main.c:103 ../display/d.colortable/main.c:138
+#: ../display/d.vect/main.c:377 ../display/d.path/main.c:159
+#: ../display/d.frame/frame.c:129 ../display/d.frame/frame.c:183
+#: ../display/d.frame/frame.c:223 ../display/d.frame/list.c:23
+#: ../display/d.frame/select.c:36 ../display/d.barscale/main.c:134
+#: ../display/d.rast.arrow/arrow.c:245 ../display/d.what.rast/main.c:116
+#: ../display/d.zoom/redraw.c:39 ../display/d.zoom/main.c:158
+#: ../display/d.zoom/main.c:293 ../display/d.nviz/main.c:250
+#: ../display/d.where/main.c:144 ../display/d.linegraph/linegraph.c:251
+#: ../display/d.erase/main.c:58 ../display/d.rast.num/number.c:132
+#: ../display/d.rhumbline/main.c:108 ../display/d.font/main.c:86
+#: ../display/d.histogram/main.c:181 ../display/d.info/main.c:74
+#: ../display/d.text.freetype/main.c:310 ../display/d.thematic.area/main.c:397
+#: ../display/d.text.new/main.c:295 ../display/d.text/main.c:132
+#: ../display/d.paint.labels/main.c:90 ../display/d.menu/main.c:108
+msgid "No graphics device selected"
+msgstr ""
+#: ../imagery/i.points/main.c:130 ../imagery/i.vpoints/main.c:127
+#, c-format
+msgid "[%s] Only local groups may be used"
+msgstr ""
+#: ../imagery/i.points/main.c:139 ../imagery/i.points/main.c:143
+#: ../imagery/i.vpoints/main.c:136 ../imagery/i.vpoints/main.c:140
+#, c-format
+msgid "Group [%s] contains no maps, run i.group"
+msgstr ""
+#: ../imagery/i.points/main.c:248
+#: ../imagery/i.ortho.photo/i.photo.2target/main.c:302
+#: ../imagery/i.ortho.photo/i.photo.2image/main.c:195
+#: ../imagery/i.vpoints/main.c:254
+#, c-format
+msgid "ERROR: %s"
+msgstr ""
+#: ../imagery/i.points/main.c:250
+#: ../imagery/i.ortho.photo/i.photo.2target/main.c:304
+#: ../imagery/i.ortho.photo/i.photo.2image/main.c:197
+#: ../imagery/i.vpoints/main.c:256
+#, c-format
+msgid "WARNING: %s (click mouse to continue)"
+msgstr ""
+#: ../imagery/i.cca/transform.c:18
+msgid "Unable to allocate cell buffers."
+msgstr ""
+#: ../imagery/i.cca/transform.c:24
+msgid "Error reading cell map during transform."
+msgstr ""
+#: ../imagery/i.cca/transform.c:46
+msgid "Error writing cell map during transform."
+msgstr ""
+#: ../imagery/i.cca/transform.c:51
+msgid "Transform completed.\n"
+msgstr ""
+#: ../imagery/i.cca/main.c:84
+msgid "imagery, statistics"
+msgstr ""
+#: ../imagery/i.cca/main.c:86
+msgid "Canonical components analysis (cca) program for image processing."
+msgstr ""
+#: ../imagery/i.cca/main.c:93 ../imagery/i.class/main.c:72
+msgid "Name of input imagery subgroup"
+msgstr ""
+#: ../imagery/i.cca/main.c:99
+msgid "File containing spectral signatures"
+msgstr ""
+#: ../imagery/i.cca/main.c:102
+msgid "Output raster map prefix name"
+msgstr ""
+#: ../imagery/i.cca/main.c:108
+#, c-format
+msgid "Illegal group name <%s>"
+msgstr ""
+#: ../imagery/i.cca/main.c:111
+#, c-format
+msgid "Illegal subgroup name <%s>"
+msgstr ""
+#: ../imagery/i.cca/main.c:114
+#, c-format
+msgid "Illegal signature file name <%s>"
+msgstr ""
+#: ../imagery/i.cca/main.c:117 ../raster/r.kappa/main.c:121
+#, c-format
+msgid "Illegal output file name <%s>"
+msgstr ""
+#: ../imagery/i.cca/main.c:122
+msgid "Unknown imagery group."
+msgstr ""
+#: ../imagery/i.cca/main.c:125
+msgid "Unable to find subgroup reference information."
+msgstr ""
+#: ../imagery/i.cca/main.c:131
+msgid "Unable to open the signature file"
+msgstr ""
+#: ../imagery/i.cca/main.c:135
+msgid "Error while reading the signatures file."
+msgstr ""
+#: ../imagery/i.cca/main.c:140
+msgid "Need at least two signatures in signature file."
+msgstr ""
+#: ../imagery/i.cca/main.c:145
+#, c-format
+msgid ""
+"Subgroup too large.  Maximum number of bands is %d\n"
+msgstr ""
+#: ../imagery/i.cca/main.c:185 ../raster/r.topidx/file_io.c:17
+#: ../raster/r.mfilter/perform.c:38 ../raster/r.param.scale/open_files.c:26
+#: ../raster/r.mfilter.fp/perform.c:38
+#, c-format
+msgid "Cannot open raster map <%s>"
+msgstr ""
+#: ../imagery/i.cca/main.c:191 ../raster/r.topidx/file_io.c:96
+#: ../raster/r.mfilter/perform.c:84 ../raster/r.param.scale/open_files.c:32
+#: ../raster/r.param.scale/open_files.c:36 ../raster/r.reclass/reclass.c:235
+#: ../raster/r.mfilter.fp/perform.c:84
+#, c-format
+msgid "Cannot create raster map <%s>"
+msgstr ""
+#: ../imagery/i.cca/main.c:207
+#, c-format
+msgid "The output cell map <%s.%d> has values outside the 0-255 range."
+msgstr ""
+#: ../imagery/i.rectify/get_wind.c:113
+#, c-format
+msgid "Region N=%f S=%f E=%f W=%f"
+msgstr ""
+#: ../imagery/i.rectify/get_wind.c:115
+#, c-format
+msgid "Resolution EW=%f NS=%f"
+msgstr ""
+#: ../imagery/i.rectify/readcell.c:55
+#: ../imagery/i.ortho.photo/i.photo.rectify/readcell.c:62
+#: ../raster/r.proj.seg/readcell.c:56
+msgid "Unable to open temporary file"
+msgstr ""
+#: ../imagery/i.rectify/readcell.c:61
+#: ../imagery/i.ortho.photo/i.photo.rectify/readcell.c:70
+#: ../raster/r.proj/readcell.c:22 ../raster/r.proj.seg/readcell.c:62
+msgid "Allocating memory and reading input map..."
+msgstr ""
+#: ../imagery/i.rectify/readcell.c:87 ../imagery/i.rectify/readcell.c:126
+#: ../imagery/i.ortho.photo/i.photo.rectify/readcell.c:98
+#: ../raster/r.proj.seg/readcell.c:89 ../raster/r.proj.seg/readcell.c:128
+msgid "Error writing segment file"
+msgstr ""
+#: ../imagery/i.rectify/readcell.c:114
+#: ../imagery/i.ortho.photo/i.photo.rectify/readcell.c:128
+#: ../raster/r.proj.seg/readcell.c:116
+msgid "Internal error: cache miss on fully-cached map"
+msgstr ""
+#: ../imagery/i.rectify/readcell.c:123
+#: ../imagery/i.ortho.photo/i.photo.rectify/readcell.c:137
+#: ../raster/r.proj.seg/readcell.c:125
+msgid "Error seeking on segment file"
+msgstr ""
+#: ../imagery/i.rectify/target.c:14
+#: ../imagery/i.ortho.photo/i.photo.rectify/target.c:13
+#, c-format
+msgid "Target information for group <%s> missing"
+msgstr ""
+#: ../imagery/i.rectify/target.c:20
+#: ../imagery/i.ortho.photo/i.photo.rectify/target.c:19
+#, c-format
+msgid "Target location <%s> not found"
+msgstr ""
+#: ../imagery/i.rectify/target.c:32
+#: ../imagery/i.ortho.photo/i.photo.rectify/target.c:31
+#: ../raster/r.in.gdal/main.c:675
+#, c-format
+msgid "Mapset <%s> in target location <%s> - "
+msgstr ""
+#: ../imagery/i.rectify/target.c:33
+#: ../imagery/i.ortho.photo/i.photo.rectify/target.c:32
+#: ../raster/r.proj/main.c:245 ../raster/r.in.gdal/main.c:677
+#: ../raster/r.proj.seg/main.c:280
+msgid "permission denied"
+msgstr ""
+#: ../raster/r.proj/main.c:246 ../raster/r.in.gdal/main.c:678
+#: ../raster/r.proj.seg/main.c:281
+msgid "not found"
+msgstr ""
+#: ../imagery/i.rectify/target.c:35
+msgid "Please run i.target for group."
+msgstr ""
+#: ../imagery/i.rectify/cp.c:15
+#, c-format
+msgid "Control Point file for group <%s@%s> - "
+msgstr ""
+#: ../imagery/i.rectify/cp.c:21
+#, c-format
+msgid "Not enough active control points for current order, %d are required."
+msgstr ""
+#: ../imagery/i.rectify/cp.c:25
+msgid "Poorly placed control points."
+msgstr ""
+#: ../imagery/i.rectify/cp.c:26
+msgid " Can not generate the transformation equation."
+msgstr ""
+#: ../imagery/i.rectify/cp.c:29
+msgid "Not enough memory to solve for transformation equation"
+msgstr ""
+#: ../imagery/i.rectify/cp.c:32
+msgid "Invalid order"
+msgstr ""
+#: ../imagery/i.rectify/rectify.c:43
+#: ../imagery/i.ortho.photo/i.photo.rectify/rectify.c:46
+#, c-format
+msgid "Rectify <%s@%s> (location <%s>)"
+msgstr ""
+#: ../imagery/i.rectify/rectify.c:47
+#: ../imagery/i.ortho.photo/i.photo.rectify/rectify.c:50
+#, c-format
+msgid "into  <%s@%s> (location <%s>) ..."
+msgstr ""
+#: ../imagery/i.rectify/rectify.c:109
+#: ../imagery/i.ortho.photo/i.photo.rectify/rectify.c:131
+#, c-format
+msgid "Raster map <%s@%s>: projection don't match current settings"
+msgstr ""
+#: ../imagery/i.rectify/rectify.c:115
+#: ../imagery/i.ortho.photo/i.photo.rectify/rectify.c:137
+#, c-format
+msgid "Raster map <%s@%s>: zone don't match current settings"
+msgstr ""
+#: ../imagery/i.rectify/report.c:10
+#: ../imagery/i.ortho.photo/i.photo.rectify/report.c:10
+msgid "complete"
+msgstr ""
+#: ../imagery/i.rectify/report.c:20
+#: ../imagery/i.ortho.photo/i.photo.rectify/report.c:20
+#, c-format
+msgid "%d rows, %d cols (%ld cells) completed in"
+msgstr ""
+#: ../imagery/i.rectify/report.c:23
+#: ../imagery/i.ortho.photo/i.photo.rectify/report.c:23
+#, c-format
+msgid "%d:%02d:%02ld hours"
+msgstr ""
+#: ../imagery/i.rectify/report.c:25
+#: ../imagery/i.ortho.photo/i.photo.rectify/report.c:25
+#, c-format
+msgid "%d:%02ld minutes"
+msgstr ""
+#: ../imagery/i.rectify/report.c:27
+#: ../imagery/i.ortho.photo/i.photo.rectify/report.c:27
+#, c-format
+msgid "%.1f cells per minute"
+msgstr ""
+#: ../imagery/i.rectify/main.c:90
+msgid "imagery, rectify"
+msgstr ""
+#: ../imagery/i.rectify/main.c:92
+msgid ""
+"Rectifies an image by computing a coordinate transformation for each pixel "
+"in the image based on the control points."
+msgstr ""
+#: ../imagery/i.rectify/main.c:106
+#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:100
+msgid "Output raster map(s) suffix"
+msgstr ""
+#: ../imagery/i.rectify/main.c:112
+msgid "Rectification polynom order (1-3)"
+msgstr ""
+#: ../imagery/i.rectify/main.c:118
+#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:106
+msgid "Target resolution (ignored if -c flag used)"
+msgstr ""
+#: ../imagery/i.rectify/main.c:126
+#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:114
+msgid "Amount of memory to use in MB"
+msgstr ""
+#: ../imagery/i.rectify/main.c:136
+#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:124
+#: ../raster/r.proj/main.c:178 ../raster/r.proj.seg/main.c:187
+msgid "Interpolation method to use"
+msgstr ""
+#: ../imagery/i.rectify/main.c:141
+#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:134
+msgid ""
+"Use current region settings in target location (def.=calculate smallest area)"
+msgstr ""
+#: ../imagery/i.rectify/main.c:145
+#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:138
+msgid "Rectify all raster maps in group"
+msgstr ""
+#: ../imagery/i.rectify/main.c:156
+#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:149
+#: ../raster/r.proj/main.c:210 ../raster/r.neighbors/main.c:226
+#: ../raster/r.proj.seg/main.c:238 ../raster/r.statistics/main.c:100
+#, c-format
+msgid "<%s=%s> unknown %s"
+msgstr ""
+#: ../imagery/i.rectify/main.c:183
+#, c-format
+msgid "Invalid order (%d); please enter 1 to %d"
+msgstr ""
+#: ../imagery/i.rectify/main.c:188
+#, c-format
+msgid "Group <%s> does not exist"
+msgstr ""
+#: ../imagery/i.rectify/main.c:191
+#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:184
+#, c-format
+msgid "Group <%s> contains no raster maps; run i.group"
+msgstr ""
+#: ../imagery/i.rectify/main.c:266
+#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:109
+#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:278
+#, c-format
+msgid "Extension <%s> is illegal"
+msgstr ""
+#: ../imagery/i.rectify/main.c:269
+#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:281
+#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:290
+msgid "The following raster map already exists in"
+msgstr ""
+#: ../imagery/i.rectify/main.c:270
+#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:282
+#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:291
+#, c-format
+msgid "target LOCATION %s, MAPSET %s:"
+msgstr ""
+#: ../imagery/i.rectify/main.c:273
+#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:112
+#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:144
+#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:285
+#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:294
+#, c-format
+msgid "Orthorectification cancelled."
+msgstr ""
+#: ../imagery/i.rectify/main.c:288
+#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:309
+msgid "Target resolution must be > 0, ignored"
+msgstr ""
+#: ../imagery/i.rectify/main.c:294 ../imagery/i.rectify/main.c:300
+#: ../imagery/i.landsat.toar/main.c:353 ../imagery/i.landsat.toar/main.c:498
+#: ../raster/r.out.tiff/r.out.tiff.c:169 ../raster/r.null/null.c:163
+#: ../raster/r.topidx/file_io.c:21 ../raster/r.bitpattern/main.c:114
+#: ../raster/r.texture/main.c:240
+#, c-format
+msgid "Unable to read header of raster map <%s>"
+msgstr ""
+#: ../imagery/i.rectify/main.c:306
+#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:316
+#, c-format
+msgid "Using region: N=%f S=%f, E=%f W=%f"
+msgstr ""
+#: ../imagery/i.rectify/main.c:321
+#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:383
+#, c-format
+msgid "Input raster map <%s> does not exist in group <%s>."
+msgstr ""
+#: ../imagery/i.rectify/main.c:323
+#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:385
+msgid "Try:"
+msgstr ""
+#: ../imagery/i.rectify/main.c:328
+#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:390
+msgid "Exit!"
+msgstr ""
+#: ../imagery/i.landsat.toar/landsat_met.c:57
+#: ../imagery/i.landsat.toar/landsat_met.c:146
+#: ../imagery/i.landsat.toar/landsat_met.c:234
+#, c-format
+msgid "Metadata file <%s> not found"
+msgstr ""
+#: ../imagery/i.landsat.toar/landsat_met.c:160
+#, c-format
+msgid "Product creation date not in metadata file <%s>"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:65
+msgid ""
+"Calculates top-of-atmosphere radiance or reflectance and temperature for "
+"Landsat MSS/TM/ETM+."
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:66
+msgid ""
+"imagery, landsat, top-of-atmosphere reflectance, dos-type simple atmospheric "
+"correction"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:79
+msgid "Prefix for output raster maps"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:80
+msgid "Example: 'B.toar.' generates B.toar.1, B.toar.2, ..."
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:87
+msgid "Name of Landsat ETM+ or TM5 header file (.met/MTL.txt)"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:88 ../imagery/i.landsat.toar/main.c:104
+#: ../imagery/i.landsat.toar/main.c:114 ../imagery/i.landsat.toar/main.c:123
+#: ../imagery/i.landsat.toar/main.c:131 ../imagery/i.landsat.toar/main.c:140
+#: ../imagery/i.landsat.toar/main.c:196 ../raster/r.external/main.c:551
+#: ../raster/r.in.gdal/main.c:122
+msgid "Metadata"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:93
+msgid "Spacecraft sensor"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:94 ../imagery/i.landsat.toar/main.c:112
+#: ../imagery/i.landsat.toar/main.c:122 ../imagery/i.landsat.toar/main.c:130
+#: ../imagery/i.landsat.toar/main.c:139
+msgid "Required only if 'metfile' not given"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:97
+msgid ""
+"mss1;Landsat-1 MSS;mss2;Landsat-2 MSS;mss3;Landsat-3 MSS;tm4;Landsat-4 TM;"
+"tm5;Landsat-5 TM;tm7;Landsat-7 ETM+"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:111
+msgid "Atmospheric correction method"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:121
+msgid "Image acquisition date (yyyy-mm-dd)"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:129
+msgid "Solar elevation in degrees"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:138
+msgid "Image creation date (yyyy-mm-dd)"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:147
+msgid "Gain (H/L) of all Landsat ETM+ bands (1-5,61,62,7,8)"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:154
+msgid "Percent of solar radiance in path radiance"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:163
+msgid "Minimum pixels to consider digital number as dark object"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:171
+msgid "Satellite zenith in degrees"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:179
+msgid "Rayleigh atmosphere"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:186
+msgid "Output at-sensor radiance for all bands"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:190
+msgid "Set sensor of Landsat TM4/5 to MSS"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:195
+msgid "Landsat ETM+/TM5 has a MTL.txt file instead of .met"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:220 ../imagery/i.landsat.toar/main.c:230
+#, c-format
+msgid "Illegal date format: [%s] (yyyy-mm-dd)"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:254
+msgid "Failed to identify satellite"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:263
+#, c-format
+msgid "Lacking '%s' or '%s' for this satellite"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:273
+msgid "Landsat-7 requires band gain with 9 (H/L) data"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:304
+#, c-format
+msgid "Unknown satellite type (defined by '%s')"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:416
+#, c-format
+msgid "Unknown production date (defined by '%s')"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:474
+msgid "Calculating..."
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:487 ../raster/r.in.gdal/main.c:230
+#, c-format
+msgid "Raster map <%s> already exists and will be overwritten"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:490
+#, c-format
+msgid "Raster map <%s> exists. Skipping."
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:517
+#, c-format
+msgid "Writing %s of <%s> to <%s>..."
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:518
+msgid "radiance"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:520
+msgid "temperature"
+msgstr ""
+msgid "reflectance"
+msgstr ""
+#: ../imagery/i.pca/support.c:27 ../raster/r.random.surface/save.c:219
+#, c-format
+msgid "Unable to write color table for raster map <%s>"
+msgstr ""
+#: ../imagery/i.pca/support.c:44
+msgid "Eigen values, (vectors), and [percent importance]:"
+msgstr ""
+#: ../imagery/i.pca/main.c:63
+msgid "imagery, image transformation, PCA"
+msgstr ""
+#: ../imagery/i.pca/main.c:64
+msgid "Principal components analysis (PCA) for image processing."
+msgstr ""
+#: ../imagery/i.pca/main.c:69
+msgid "Name of two or more input raster maps"
+msgstr ""
+#: ../imagery/i.pca/main.c:72
+msgid "Base name for output raster maps"
+msgstr ""
+#: ../imagery/i.pca/main.c:74
+msgid "A numerical suffix will be added for each component map"
+msgstr ""
+#: ../imagery/i.pca/main.c:87
+msgid "Rescaling range for output maps"
+msgstr ""
+#: ../imagery/i.pca/main.c:89
+msgid "For no rescaling use 0,0"
+msgstr ""
+#: ../imagery/i.pca/main.c:90
+msgid "Rescale"
+msgstr ""
+#: ../imagery/i.pca/main.c:100
+msgid "Sorry, at least 2 input bands must be provided"
+msgstr ""
+#: ../imagery/i.pca/main.c:143
+msgid "Calculating covariance matrix..."
+msgstr ""
+#: ../imagery/i.pca/main.c:219
+msgid "Scale range length should be > 0. Using default values: 0,255."
+msgstr ""
+#: ../imagery/i.pca/main.c:256 ../imagery/i.pca/main.c:305
+#: ../imagery/i.pca/main.c:438
+msgid "Unable allocate memory for row buffer"
+msgstr ""
+#: ../imagery/i.pca/main.c:258
+#, c-format
+msgid "Computing means for band %d..."
+msgstr ""
+#: ../imagery/i.pca/main.c:307
+#, c-format
+msgid "Computing row %d (of %d) of covariance matrix..."
+msgstr ""
+#: ../imagery/i.pca/main.c:324
+msgid "Unable to allocate memory for row buffer"
+msgstr ""
+#: ../imagery/i.pca/main.c:386
+msgid "Unable to allocate memory for raster row"
+msgstr ""
+#: ../imagery/i.pca/main.c:395
+#, c-format
+msgid "Transforming <%s>..."
+msgstr ""
+#: ../imagery/i.pca/main.c:414
+#, c-format
+msgid "Rescaling <%s> to range %d,%d..."
+msgstr ""
+#: ../imagery/i.rgb.his/openfiles.c:37 ../imagery/i.rgb.his/openfiles.c:39
+#: ../imagery/i.rgb.his/openfiles.c:41 ../imagery/i.his.rgb/openfiles.c:23
+#: ../imagery/i.his.rgb/openfiles.c:25 ../imagery/i.his.rgb/openfiles.c:27
+msgid "Unable to allocate the input row buffer"
+msgstr ""
+#: ../imagery/i.rgb.his/r2hmain.c:45 ../imagery/i.his.rgb/h2rmain.c:45
+msgid "imagery, color transformation, RGB, HIS"
+msgstr ""
+#: ../imagery/i.rgb.his/r2hmain.c:47
+msgid ""
+"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
+"Intensity-Saturation) color space."
+msgstr ""
+#: ../imagery/i.rgb.his/r2hmain.c:53
+msgid "Name of input raster map (red)"
+msgstr ""
+#: ../imagery/i.rgb.his/r2hmain.c:57
+msgid "Name of input raster map (green)"
+msgstr ""
+#: ../imagery/i.rgb.his/r2hmain.c:61
+msgid "Name of input raster map (blue)"
+msgstr ""
+#: ../imagery/i.rgb.his/r2hmain.c:65
+msgid "Name for output raster map (hue)"
+msgstr ""
+#: ../imagery/i.rgb.his/r2hmain.c:69
+msgid "Name for output raster map (intensity)"
+msgstr ""
+#: ../imagery/i.rgb.his/r2hmain.c:73
+msgid "Name for output raster map (saturation)"
+msgstr ""
+#: ../imagery/i.rgb.his/r2hmain.c:93 ../imagery/i.his.rgb/h2rmain.c:95
+#, c-format
+msgid "Unable to read raster map row %ld"
+msgstr ""
+#: ../imagery/i.rgb.his/r2hmain.c:102 ../imagery/i.his.rgb/h2rmain.c:104
+#, c-format
+msgid "Failed writing raster map row %ld"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.camera/main.c:55
+#: ../imagery/i.ortho.photo/menu/menu.c:43
+#: ../imagery/i.ortho.photo/i.photo.2target/main.c:53
+#: ../imagery/i.ortho.photo/i.photo.init/main.c:44
+#: ../imagery/i.ortho.photo/i.photo.target/main.c:46
+#: ../imagery/i.ortho.photo/i.photo.2image/main.c:54
+#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:86
+#: ../imagery/i.ortho.photo/i.photo.elev/main.c:62
+msgid "imagery, orthorectify"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.camera/main.c:57
+msgid ""
+"Interactively select and modify the imagery group camera reference file."
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.camera/main.c:61
+#: ../imagery/i.ortho.photo/menu/menu.c:48
+#: ../imagery/i.ortho.photo/i.photo.init/main.c:52
+#: ../imagery/i.ortho.photo/i.photo.target/main.c:52
+#: ../imagery/i.ortho.photo/i.photo.2image/main.c:60
+#: ../imagery/i.ortho.photo/i.photo.elev/main.c:68
+msgid "Name of imagery group for ortho-rectification"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.camera/main.c:68
+msgid "Name of camera reference file to use"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.camera/main.c:84
+msgid "Enter a camera reference file to be used with this imagery group"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.camera/main.c:101
+#, c-format
+msgid "Group [%s] in location [%s] mapset [%s] now has camera file [%s]"
+msgstr ""
+#: ../imagery/i.ortho.photo/menu/menu.c:44
+msgid "Menu driver for the photo imagery programs."
+msgstr ""
+#: ../imagery/i.ortho.photo/menu/menu.c:62
+#, c-format
+msgid "Pre-selected group <%s> not found"
+msgstr ""
+#: ../imagery/i.ortho.photo/menu/menu.c:68
+msgid "Enter imagery group for ortho-rectification"
+msgstr ""
+#: ../imagery/i.ortho.photo/menu/menu.c:74
+#, c-format
+msgid "Group [%s] contains no files"
+msgstr ""
+#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:44
+#, c-format
+msgid "Could not read REF file for group [%s]"
+msgstr ""
+#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:45
+#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:50
+#, c-format
+msgid "Orthorectification cancelled"
+msgstr ""
+#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:49
+#, c-format
+msgid "No files in this group!"
+msgstr ""
+#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:61
+msgid ""
+"\n"
+"Rectify all images in the group? "
+msgstr ""
+#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:71
+#, c-format
+msgid ""
+"\n"
+"Rectify image <%s>? "
+msgstr ""
+#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:84
+#, c-format
+msgid ""
+"\n"
+"No images selected, orthorectification cancelled."
+msgstr ""
+#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:99
+msgid "Enter an extension to be appended to rectified maps:"
+msgstr ""
+#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:110
+msgid ""
+"\n"
+"Choose another extension? "
+msgstr ""
+#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:122
+msgid ""
+"\n"
+"Compute local camera angle? "
+msgstr ""
+#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:132
+msgid "Enter a name for the camera angle map:"
+msgstr ""
+#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:141
+#, c-format
+msgid "Map name <%s> is illegal"
+msgstr ""
+#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:142
+msgid ""
+"\n"
+"Choose another name? "
+msgstr ""
+#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:156
+msgid ""
+"\n"
+"Overwrite maps in target location/mapset? "
+msgstr ""
+#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:224
+#, c-format
+msgid "Please select one of the following interpolation methods\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:225
+#, c-format
+msgid " 1. nearest neighbor\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:226
+#, c-format
+msgid " 2. bilinear\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:227
+#, c-format
+msgid " 3. bicubic\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:228
+#, c-format
+msgid " 4. bilinear with fallback\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:229
+#, c-format
+msgid " 5. bicubic with fallback\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:291
+#, c-format
+msgid "Enter amount of memory to use in MB, or\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:293
+#, c-format
+msgid "RETURN   use %d MB to keep all data in RAM\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:295
+#, c-format
+msgid "RETURN   use %d MB\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.2target/curses.c:22
+#: ../imagery/i.class/curses.c:22
+#, c-format
+msgid "make_window(%d,%d,%d,%d): illegal screen values."
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.2target/curses.c:148
+#: ../imagery/i.class/curses.c:153
+#, c-format
+msgid "%s"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.2target/main.c:54
+msgid "Creates control points on an image to be ortho-rectified."
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.2target/main.c:66
+msgid "Name of image to be rectified which will be initially drawn on screen"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.2target/main.c:72
+msgid ""
+"Name of a map from target mapset which will be initially drawn on screen"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.2target/main.c:102
+#: ../imagery/i.ortho.photo/i.photo.init/main.c:64
+#, c-format
+msgid "Group [%s] not found"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.2target/main.c:114
+#: ../imagery/i.ortho.photo/i.photo.2image/main.c:98
+#, c-format
+msgid "No camera reference file selected for group [%s]"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.2target/main.c:118
+#: ../imagery/i.ortho.photo/i.photo.2image/main.c:102
+#, c-format
+msgid "Bad format in camera file for group [%s]"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.2target/main.c:125
+#, c-format
+msgid "No initial camera exposure station for group [%s]"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.2target/main.c:129
+#, c-format
+msgid "Bad format in initial camera exposure station for group [%s]"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.2target/main.c:143
+#, c-format
+msgid "No photo points for group [%s]"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.2target/main.c:145
+#, c-format
+msgid "Poorly placed photo points for group [%s]"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.2target/main.c:167
+msgid "Computing equations ..."
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.2target/main.c:202
+#: ../imagery/i.ortho.photo/i.photo.2target/main.c:233
+#, c-format
+msgid "Unable to read raster header of <%s>"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.init/main.c:46
+msgid ""
+"Interactively creates or modifies entries in a camera initial exposure "
+"station file for imagery group referenced by a sub-block."
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.target/main.c:48
+msgid "Interactively select or modify the imagery group target."
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.target/main.c:66
+#, c-format
+msgid "Group [%s] targeted for location [%s], mapset [%s]"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.2image/main.c:56
+msgid "Interactively mark fiducial or reseau points on an image."
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.2image/main.c:86
+#, c-format
+msgid "Image Group [%s] not found"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.rectify/exec.c:43
+#: ../imagery/i.ortho.photo/i.photo.rectify/angle.c:51
+msgid "Could not open elevation raster"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.rectify/readcell.c:140
+msgid "Error reading segment file"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.rectify/angle.c:36
+msgid "Calculating camera angle to local surface..."
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.rectify/angle.c:67
+#: ../raster/r.slope.aspect/main.c:408
+#, c-format
+msgid "Converting units to meters, factor=%.6f"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:13
+#, c-format
+msgid ""
+"Control Z Point file for group [%s] in [%s] \n"
+" \n"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:16
+msgid "Computing equations..."
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:22
+msgid "Poorly placed Control Points!\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:23
+#: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:28
+#: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:52
+#: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:58
+msgid "Can not generate the transformation equation.\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:24
+msgid "Run OPTION 7 of i.ortho.photo again!\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:27
+msgid "No active Control Points!\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:29
+msgid "Run OPTION 7 of i.ortho.photo!\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:45
+#, c-format
+msgid ""
+"Reference Point file for group [%s] in [%s] \n"
+" \n"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:51
+msgid "Poorly placed Reference Points!\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:53
+msgid "Run OPTION 5 of i.ortho.photo again!\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:57
+msgid "No active Reference Points!\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:59
+msgid "Run OPTION 5 of i.ortho.photo!\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.rectify/rectify.c:84
+#, c-format
+msgid "No elevation available at row = %d, col = %d"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:88
+msgid ""
+"Orthorectifies an image by using the image to photo coordinate "
+"transformation matrix."
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:129
+msgid "Raster map with camera angle relative to ground surface"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:181
+#, c-format
+msgid "Could not read REF file for group <%s>"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:238
+#, c-format
+msgid "No camera reference file selected for group <%s>"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:242
+#, c-format
+msgid "Bad format in camera file for group <%s>"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:248
+#, c-format
+msgid "Bad format in initial exposure station file for group <%s>"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:324
+#, c-format
+msgid "No target elevation model selected for group <%s>"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.elev/main.c:64
+msgid "Interactively select or modify the target elevation model."
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.elev/main.c:91
+#, c-format
+msgid "Target information for group [%s] missing\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.elev/main.c:98
+#, c-format
+msgid "Target location [%s] not found\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.elev/main.c:127
+#, c-format
+msgid "Mapset [%s] in target location [%s] - "
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.elev/main.c:128
+msgid "permission denied\n"
+msgstr ""
+msgid "not found\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.photo.elev/main.c:131
+msgid "Please select a target for group"
+msgstr ""
+#: ../imagery/i.his.rgb/h2rmain.c:47
+msgid ""
+"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
+"RGB (Red-Green-Blue) color space."
+msgstr ""
+#: ../imagery/i.his.rgb/h2rmain.c:53
+msgid "Name of input raster map (hue)"
+msgstr ""
+#: ../imagery/i.his.rgb/h2rmain.c:57
+msgid "Name of input raster map (intensity)"
+msgstr ""
+#: ../imagery/i.his.rgb/h2rmain.c:61
+msgid "Name of input raster map (saturation)"
+msgstr ""
+#: ../imagery/i.his.rgb/h2rmain.c:65
+msgid "Name for output raster map (red)"
+msgstr ""
+#: ../imagery/i.his.rgb/h2rmain.c:69
+msgid "Name for output raster map (green)"
+msgstr ""
+#: ../imagery/i.his.rgb/h2rmain.c:73
+msgid "Name for output raster map (blue)"
+msgstr ""
+#: ../imagery/i.class/signature.c:50 ../imagery/i.class/signature.c:55
+msgid "Unable to allocate space for signature statistics."
+msgstr ""
+#: ../imagery/i.class/signature.c:82
+msgid "prepare_signature: outline has odd number of points."
+msgstr ""
+#: ../imagery/i.class/signature.c:113
+#, c-format
+msgid "prepare_signature: scan line %d has odd number of points."
+msgstr ""
+#: ../imagery/i.class/signature.c:123
+msgid "signature: perimeter points out of order."
+msgstr ""
+#: ../imagery/i.class/signature.c:132
+msgid "prepare_signature: data error."
+msgstr ""
+#: ../imagery/i.class/signature.c:234
+msgid "Unknown Menu selection in show_signature()."
+msgstr ""
+#: ../imagery/i.class/signature.c:276
+msgid "Unable to open the cell map MASK."
+msgstr ""
+#: ../imagery/i.class/signature.c:278
+msgid "Unable to allocate the cell buffer in display_signature()."
+msgstr ""
+#: ../imagery/i.class/signature.c:310
+msgid "Did not find input cell map MASK."
+msgstr ""
+#: ../imagery/i.class/analyze_sig.c:12
+msgid "Cannot analyze until region is completed."
+msgstr ""
+#: ../imagery/i.class/add_point.c:22
+#, c-format
+msgid "Can't mark another point.  Only %d points allowed.  Sorry."
+msgstr ""
+#: ../imagery/i.class/remove_mask.c:15
+msgid "Error while removing the old MASK cell map."
+msgstr ""
+#: ../imagery/i.class/erase_reg.c:10
+msgid "Can not erase an undefined region."
+msgstr ""
+#: ../imagery/i.class/save_reg.c:14
+msgid "Region is not complete, can not save."
+msgstr ""
+#: ../imagery/i.class/band_files.c:22
+msgid "Unable to open band files."
+msgstr ""
+#: ../imagery/i.class/redisplay.c:56
+msgid "No zoom window is defined."
+msgstr ""
+#: ../imagery/i.class/draw_reg.c:89
+#, c-format
+msgid ""
+"\n"
+"Orig:(x1 y1), (x2 y2) = (%d %d), (%d %d)"
+msgstr ""
+#: ../imagery/i.class/draw_reg.c:97
+#, c-format
+msgid ""
+"\n"
+"New:(x1 y1), (x2 y2) = (%d %d), (%d %d)"
+msgstr ""
+#: ../imagery/i.class/restore_reg.c:15
+msgid "No region is saved, can not restore."
+msgstr ""
+#: ../imagery/i.class/outline.c:57
+msgid "Absurd polygon."
+msgstr ""
+#: ../imagery/i.class/outline.c:99
+msgid "Outlined area is too large."
+msgstr ""
+#: ../imagery/i.class/readbands.c:12
+msgid "Error reading raster map in function readbands."
+msgstr ""
+#: ../imagery/i.class/complete_reg.c:12
+msgid "Too few points for region.  Must have at least 3 points."
+msgstr ""
+#: ../imagery/i.class/complete_reg.c:14
+msgid "Area already completed."
+msgstr ""
+#: ../imagery/i.class/main.c:53
+msgid "imagery, classification"
+msgstr ""
+#: ../imagery/i.class/main.c:55
+msgid ""
+"Generates spectral signatures for an image by allowing the user to outline "
+"regions of interest."
+msgstr ""
+#: ../imagery/i.class/main.c:58
+msgid ""
+"The resulting signature file can be used as input for i.maxlik or as a seed "
+"signature file for i.cluster."
+msgstr ""
+#: ../imagery/i.class/main.c:62 ../display/d.rast/main.c:57
+msgid "Name of raster map to be displayed"
+msgstr ""
+#: ../imagery/i.class/main.c:77
+msgid "File to contain result signatures"
+msgstr ""
+#: ../imagery/i.class/main.c:82
+msgid "File containing input signatures (seed)"
+msgstr ""
+#: ../imagery/i.class/main.c:94
+msgid "You have a mask set. Unset mask and run again"
+msgstr ""
+#: ../imagery/i.class/main.c:213
+#, c-format
+msgid "** The following raster maps in subgroup [%s] do not exist:"
+msgstr ""
+#: ../imagery/i.class/main.c:222
+#, c-format
+msgid "Subgroup [%s] does not have any files"
+msgstr ""
+#: ../imagery/i.class/main.c:223 ../imagery/i.class/main.c:227
+msgid "The subgroup must have at least 2 files to run"
+msgstr ""
+#: ../imagery/i.class/main.c:226
+#, c-format
+msgid "Subgroup [%s] only has 1 file"
+msgstr ""
+#: ../imagery/i.class/main.c:232
+msgid "Unable to read cell header for first band file"
+msgstr ""
+#: ../imagery/i.class/main.c:237
+msgid ""
+"\n"
+"RESULT SIGNATURE"
+msgstr ""
+#: ../imagery/i.class/main.c:242
+#, c-format
+msgid "Unable to open output signature file '%s'"
+msgstr ""
+#: ../imagery/i.class/main.c:248
+msgid ""
+"\n"
+"SEED SIGNATURES"
+msgstr ""
+#: ../imagery/i.class/main.c:254
+#, c-format
+msgid "Unable to read signature file [%s]"
+msgstr ""
+#: ../imagery/i.class/main.c:257
+#, c-format
+msgid "** Unable to read signature file [%s] **"
+msgstr ""
+#: ../imagery/i.class/main.c:264
+#, c-format
+msgid "%s has too many signatures"
+msgstr ""
+#: ../imagery/i.find/main.c:63
+#, c-format
+msgid "usage: %s location mapset element file."
+msgstr ""
+#: ../imagery/i.find/main.c:83
+msgid "Unable to open temp file."
+msgstr ""
+#: ../imagery/i.ifft/orig_wind.c:27
+msgid "The real and imaginary original windows did not match"
+msgstr ""
+#: ../imagery/i.ifft/ifftmain.c:70
+msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
+msgstr ""
+#: ../imagery/i.ifft/ifftmain.c:75
+msgid "Name of input raster map (image fft, real part)"
+msgstr ""
+#: ../imagery/i.ifft/ifftmain.c:79
+msgid "Name of input raster map (image fft, imaginary part"
+msgstr ""
+#: ../imagery/i.ifft/ifftmain.c:101
+msgid ""
+"Unable to open real-image in the 'cell_misc' directory. Raster map probably "
+"wasn't created by i.fft"
+msgstr ""
+#: ../imagery/i.ifft/ifftmain.c:111
+msgid ""
+"Unable to open imaginary-image in the 'cell_misc' directory. Raster map "
+"probably wasn't created by i.fft"
+msgstr ""
+#: ../imagery/i.ifft/ifftmain.c:134
+#, c-format
+msgid "Power 2 values: %d rows %d columns"
+msgstr ""
+#: ../imagery/i.ifft/ifftmain.c:151
+msgid "Masking raster maps..."
+msgstr ""
+#: ../imagery/i.ifft/ifftmain.c:211
+msgid "Starting Inverse FFT..."
+msgstr ""
+#: ../imagery/i.ifft/ifftmain.c:225
+msgid "Writing data..."
+msgstr ""
+#: ../imagery/i.vpoints/plot.c:61 ../imagery/i.vpoints/plot.c:143
+#: ../display/d.graph/do_graph.c:415
+msgid "Cannot read symbol, cannot display points"
+msgstr ""
+#: ../imagery/i.vpoints/main.c:96
+msgid ""
+"Set registration points for an imagery group from a vector map or keyboard "
+"entry."
+msgstr ""
+#: ../imagery/i.maxlik/open.c:19 ../imagery/i.cluster/open_files.c:21
+#, c-format
+msgid "Subgroup <%s> in group <%s> not found"
+msgstr ""
+#: ../imagery/i.maxlik/open.c:26
+#, c-format
+msgid ""
+"Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must "
+"have at least 2 raster maps."
+msgstr ""
+#: ../imagery/i.maxlik/open.c:29
+#, c-format
+msgid ""
+"Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at "
+"least 2 raster maps."
+msgstr ""
+#: ../imagery/i.maxlik/open.c:48
+#, c-format
+msgid "Unable to open signature file <%s>"
+msgstr ""
+#: ../imagery/i.maxlik/open.c:58 ../imagery/i.cluster/open_files.c:74
+#, c-format
+msgid "<%s> has too many signatures (limit is 255)"
+msgstr ""
+#: ../imagery/i.maxlik/invert.c:28
+#, c-format
+msgid "Signature %d is not valid (ill-conditioned) - ignored"
+msgstr ""
+#: ../imagery/i.maxlik/invert.c:31
+#, c-format
+msgid "Signature %d is not valid (singular) - ignored"
+msgstr ""
+#: ../imagery/i.maxlik/main.c:63
+msgid "imagery, classification, MLC"
+msgstr ""
+#: ../imagery/i.maxlik/main.c:65
+msgid "Classifies the cell spectral reflectances in imagery data."
+msgstr ""
+#: ../imagery/i.maxlik/main.c:67
+msgid ""
+"Classification is based on the spectral signature information generated by "
+"either i.cluster, i.class, or i.gensig."
+msgstr ""
+#: ../imagery/i.maxlik/main.c:80
+msgid "Generated by either i.cluster, i.class, or i.gensig"
+msgstr ""
+#: ../imagery/i.maxlik/main.c:85
+msgid "Name for raster map holding classification results"
+msgstr ""
+#: ../imagery/i.maxlik/main.c:91
+msgid "Name for raster map holding reject threshold results"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:90
+msgid "QC, Quality Control, surface reflectance, Modis"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:92
+msgid "Extracts quality control parameters from Modis QC layers."
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:98
+msgid "Name of input surface reflectance QC layer [bit array]"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:103
+msgid "Name for output QC type classification layer"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:109
+msgid "Name of MODIS product type"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:110
+msgid ""
+"mod09Q1;surf. refl. 250m 8-days;mod09A1;surf. refl. 500m 8-days;mod09A1s;"
+"surf. refl. 500m 8-days, State QA;mod11A1;LST 1Km daily (Day/Night);mod11A2;"
+"LST 1Km 8-days (Day/Night);"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:122
+msgid "Name of QC type to extract"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:123
+msgid ""
+"adjcorr;mod09: Adjacency Correction;atcorr;mod09: Atmospheric Correction;"
+"cloud;mod09: Cloud State;data_quality;mod09: Band-Wise Data Quality Flag;"
+"diff_orbit_from_500m;mod09: 250m Band is at Different Orbit than 500m;"
+"modland_qa_bits;mod09: MODIS Land General Quality Assessment;"
+"mandatory_qa_11A1;mod11A1: MODIS Land General Quality Assessment;"
+"data_quality_flag_11A1;mod11A1: Detailed Quality Indications;emis_error_11A1;"
+"mod11A1: Average Emissivity Error Classes;lst_error_11A1;mod11A1: Average "
+"LST Error Classes;data_quality_flag_11A2;mod11A2: Detailed Quality "
+"Indications;emis_error_11A2;mod11A2: Average Emissivity Error Classes;"
+"mandatory_qa_11A2;mod11A2: MODIS Land General Quality Assessment;"
+"lst_error_11A2;mod11A2: Average LST Error Classes;aerosol_quantity;mod09A1s: "
+"StateQA Internal Snow Mask;brdf_correction_performed;mod09A1s: StateQA "
+"Internal Snow Mask;cirrus_detected;mod09A1s: StateQA Internal Snow Mask;"
+"cloud_shadow;mod09A1s: StateQA Internal Snow Mask;cloud_state;mod09A1s: "
+"StateQA Internal Snow Mask;internal_clou_algorithm;mod09A1s: StateQA "
+"Internal Snow Mask;internal_fire_algorithm;mod09A1s: StateQA Internal Snow "
+"Mask;internal_snow_mask;mod09A1s: StateQA Internal Snow Mask;land_water;"
+"mod09A1s: StateQA Internal Snow Mask;mod35_snow_ice;mod09A1s: StateQA "
+"Internal Snow Mask;pixel_adjacent_to_cloud;mod09A1s: StateQA Internal Snow "
+"Mask;"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:157
+msgid "Band number of Modis product (mod09Q1=[1,2],mod09A1=[1-7])"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:158
+msgid ""
+"1;mod09Q1/A1 Band 1: Red;2;mod09Q1/A1 Band 2: NIR;3;mod09A1 Band 3: Blue;4;"
+"mod09A1 Band 4: Green;5;mod09A1 Band 5: SWIR 1;6;mod09A1 Band 6: SWIR 2;7;"
+"mod09A1 Band 7: SWIR 3;"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:181
+msgid "This flag is only available for MOD09Q1 @ 250m products"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:185
+msgid "Band number out of allowed range [1-7]"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:187
+msgid "mod09Q1 product only has 2 bands"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:194
+msgid "This flag is only available for MOD11A1 @ 1Km products"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:200
+msgid "This flag is only available for MOD11A2 @ 1Km products"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:213
+msgid "This flag is only available for MOD09A1s @ 500m products"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:354
+msgid "Unknown flag name, please check spelling"
+msgstr ""
+#: ../imagery/i.cluster/print4.c:16
+#, c-format
+msgid "class centroids (sum/count=mean)\n"
+msgstr ""
+#: ../imagery/i.cluster/print4.c:18
+#, c-format
+msgid "band %d"
+msgstr ""
+#: ../imagery/i.cluster/print1.c:12
+#, c-format
+msgid ""
+"means and standard deviations for %d band%s\n"
+"\n"
+msgstr ""
+#: ../imagery/i.cluster/print1.c:14
+#, c-format
+msgid " means  "
+msgstr ""
+#: ../imagery/i.cluster/print1.c:18
+#, c-format
+msgid " stddev "
+msgstr ""
+#: ../imagery/i.cluster/checkpt.c:16
+#, c-format
+msgid "using seed means (%d files)\n"
+msgstr ""
+#: ../imagery/i.cluster/checkpt.c:28
+#, c-format
+msgid ""
+"\n"
+"######## iteration %d ###########\n"
+msgstr ""
+#: ../imagery/i.cluster/checkpt.c:30
+#, c-format
+msgid "%d classes, %.2f%% points stable\n"
+msgstr ""
+#: ../imagery/i.cluster/checkpt.c:40
+#, c-format
+msgid "Iteration %.2d: convergence %.2f%% (%s elapsed, %s left)"
+msgstr ""
+#: ../imagery/i.cluster/print2.c:18
+#, c-format
+msgid ""
+"\n"
+"class means/stddev for each band\n"
+"\n"
+msgstr ""
+#: ../imagery/i.cluster/print2.c:22
+#, c-format
+msgid "class %d (%d)\n"
+msgstr ""
+#: ../imagery/i.cluster/print2.c:23
+#, c-format
+msgid "  means "
+msgstr ""
+#: ../imagery/i.cluster/print2.c:28
+#, c-format
+msgid "  stddev"
+msgstr ""
+#: ../imagery/i.cluster/print6.c:11
+#, c-format
+msgid "class distribution"
+msgstr ""
+#: ../imagery/i.cluster/open_files.c:33
+#, c-format
+msgid "Raster map <%s> do not exists in subgroup <%s>"
+msgstr ""
+#: ../imagery/i.cluster/open_files.c:38
+msgid "No raster maps found"
+msgstr ""
+#: ../imagery/i.cluster/open_files.c:42
+#, c-format
+msgid "Subgroup <%s> doesn't have any raster maps"
+msgstr ""
+#: ../imagery/i.cluster/open_files.c:45
+#, c-format
+msgid "Subgroup <%s> only has 1 raster map"
+msgstr ""
+#: ../imagery/i.cluster/open_files.c:46
+msgid "Subgroup must have at least 2 raster maps"
+msgstr ""
+#: ../imagery/i.cluster/open_files.c:64
+#, c-format
+msgid "Unable to open seed signature file <%s>"
+msgstr ""
+#: ../imagery/i.cluster/print5.c:15
+#, c-format
+msgid ""
+"\n"
+"class separability matrix\n"
+"\n"
+msgstr ""
+#: ../imagery/i.cluster/print3.c:16
+#, c-format
+msgid ""
+"\n"
+"initial means for each band\n"
+"\n"
+msgstr ""
+#: ../imagery/i.cluster/print3.c:19
+#, c-format
+msgid "class %-3d "
+msgstr ""
+#: ../imagery/i.cluster/main.c:80
+msgid "imagery, classification, signatures"
+msgstr ""
+#: ../imagery/i.cluster/main.c:82
+msgid ""
+"Generates spectral signatures for land cover types in an image using a "
+"clustering algorithm."
+msgstr ""
+#: ../imagery/i.cluster/main.c:85
+msgid ""
+"The resulting signature file is used as input for i.maxlik, to generate an "
+"unsupervised image classification."
+msgstr ""
+#: ../imagery/i.cluster/main.c:104
+msgid "Initial number of classes"
+msgstr ""
+#: ../imagery/i.cluster/main.c:112
+msgid "Name of file containing initial signatures"
+msgstr ""
+#: ../imagery/i.cluster/main.c:120
+msgid "Sampling intervals (by row and col); default: ~10,000 pixels"
+msgstr ""
+#: ../imagery/i.cluster/main.c:127
+msgid "Maximum number of iterations"
+msgstr ""
+#: ../imagery/i.cluster/main.c:136
+msgid "Percent convergence"
+msgstr ""
+#: ../imagery/i.cluster/main.c:144
+msgid "Cluster separation"
+msgstr ""
+#: ../imagery/i.cluster/main.c:152
+msgid "Minimum number of pixels in a class"
+msgstr ""
+#: ../imagery/i.cluster/main.c:159
+msgid "Name for output file containing final report"
+msgstr ""
+#: ../imagery/i.cluster/main.c:163 ../vector/v.kcv/main.c:106
+#: ../vector/v.sample/main.c:129 ../vector/v.perturb/main.c:117
+#: ../doc/raster/r.example/main.c:96 ../raster/r.slope.aspect/main.c:261
+#: ../raster/r.resample/main.c:79 ../raster/r.grow2/main.c:167
+#: ../raster/r.kappa/main.c:102 ../raster/r.bitpattern/main.c:87
+#: ../raster/r.report/parse.c:95 ../raster/r.mfilter/main.c:85
+#: ../raster/r.rescale.eq/main.c:98 ../raster/r.mfilter.fp/main.c:91
+#: ../raster/r.texture/main.c:111 ../raster/r.patch/main.c:72
+msgid "Quiet"
+msgstr ""
+#: ../imagery/i.cluster/main.c:182
+#, c-format
+msgid "Illegal number of initial classes (%s)"
+msgstr ""
+#: ../imagery/i.cluster/main.c:193
+#, c-format
+msgid "Illegal value(s) of sample intervals (%s)"
+msgstr ""
+#: ../imagery/i.cluster/main.c:207
+#, c-format
+msgid "Illegal value of iterations (%s>)"
+msgstr ""
+#: ../imagery/i.cluster/main.c:213
+#, c-format
+msgid "Illegal value of convergence (%s)"
+msgstr ""
+#: ../imagery/i.cluster/main.c:218
+#, c-format
+msgid "Illegal value of separation (%s)"
+msgstr ""
+#: ../imagery/i.cluster/main.c:223
+#, c-format
+msgid "Illegal value of min_size (%s)"
+msgstr ""
+#: ../imagery/i.cluster/main.c:234
+#, c-format
+msgid "Unable to create report file <%s>"
+msgstr ""
+#: ../imagery/i.cluster/main.c:242
+#, c-format
+msgid ""
+"#################### CLUSTER (%s) ####################\n"
+"\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:244
+#, c-format
+msgid "Location: %s\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:245
+#, c-format
+msgid "Mapset:   %s\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:246
+#, c-format
+msgid "Group:    %s\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:247
+#, c-format
+msgid "Subgroup: %s\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:249
+#, c-format
+msgid " %s\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:252
+#, c-format
+msgid "Result signature file: %s\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:254
+#, c-format
+msgid "Region\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:255
+#, c-format
+msgid "  North: %12.2f  East: %12.2f\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:257
+#, c-format
+msgid "  South: %12.2f  West: %12.2f\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:259
+#, c-format
+msgid "  Res:   %12.2f  Res:  %12.2f\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:261
+#, c-format
+msgid "  Rows:  %12d  Cols: %12d  Cells: %d\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:263
+#, c-format
+msgid "Mask: %s\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:265
+#, c-format
+msgid "Cluster parameters\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:266
+#, c-format
+msgid " Number of initial classes:    %d"
+msgstr ""
+#: ../imagery/i.cluster/main.c:268
+#, c-format
+msgid " [from signature file %s]"
+msgstr ""
+#: ../imagery/i.cluster/main.c:270
+#, c-format
+msgid " Minimum class size:           %d\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:271
+#, c-format
+msgid " Minimum class separation:     %f\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:272
+#, c-format
+msgid " Percent convergence:          %f\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:273
+#, c-format
+msgid " Maximum number of iterations: %d\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:275
+#, c-format
+msgid " Row sampling interval:        %d\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:276
+#, c-format
+msgid " Col sampling interval:        %d\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:297
+msgid "Out of Memory. Please run again and choose a smaller sample size."
+msgstr ""
+#: ../imagery/i.cluster/main.c:303
+#, c-format
+msgid "Sample size: %d points\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:306
+msgid ""
+"Not enough sample points. Please run again and choose a larger sample size."
+msgstr ""
+#: ../imagery/i.cluster/main.c:310
+msgid ""
+"Not enough non-zero sample data points. Check your current region (and mask)."
+msgstr ""
+#: ../imagery/i.cluster/main.c:323
+#, c-format
+msgid ""
+"\n"
+"########## final results #############\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:324
+#, c-format
+msgid "%d classes (convergence=%.1f%%)\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:335
+#, c-format
+msgid "Unable to create signature file <%s> for group <%s>, subsgroup <%s>"
+msgstr ""
+#: ../imagery/i.cluster/main.c:340
+#, c-format
+msgid ""
+"\n"
+"\n"
+"#################### CLASSES ####################\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:341
+#, c-format
+msgid ""
+"\n"
+"%d classes, %.2f%% points stable\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:343
+#, c-format
+msgid ""
+"\n"
+"######## CLUSTER END (%s) ########\n"
+msgstr ""
+#: ../vector/v.mkgrid/write_grid.c:42
+msgid "Writing out vector rows..."
+msgstr ""
+#: ../vector/v.mkgrid/write_grid.c:79
+msgid "Writing out vector columns..."
+msgstr ""
+#: ../vector/v.mkgrid/main.c:63 ../vector/v.segment/main.c:52
+#: ../vector/v.hull/main.c:273 ../vector/v.parallel2/main.c:44
+#: ../vector/v.split/main.c:42 ../vector/v.to.points/main.c:173
+#: ../vector/v.in.region/main.c:38 ../vector/v.parallel/main.c:39
+#: ../vector/v.patch/main.c:68 ../vector/v.overlay/main.c:55
+#: ../vector/v.type/main.c:47
+msgid "vector, geometry"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:65
+msgid "Creates a GRASS vector map of a user-defined grid."
+msgstr ""
+#: ../vector/v.mkgrid/main.c:76
+msgid "Number of rows and columns in grid"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:85
+msgid "Where to place the grid"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:86
+msgid "region;current region;coor;use 'coor' and 'box' options"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:96
+msgid "Lower left easting and northing coordinates of map"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:104
+msgid "Width and height of boxes in grid"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:111
+msgid "Angle of rotation (in degrees counter-clockwise)"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:119
+msgid "Number of horizontal vertex points per grid cell"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:126
+msgid "Create grid of points instead of areas and centroids"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:131
+msgid "Quiet; No chatter"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:141 ../vector/v.qcount/main.c:117
+#: ../raster/r.to.vect/main.c:99 ../raster/r.buffer/main.c:110
+#: ../raster/r.slope.aspect/main.c:299 ../raster/r.out.png/r.out.png.c:159
+#: ../raster/r.covar/main.c:75 ../raster/r.resample/main.c:90
+#: ../raster/r.cross/main.c:107 ../raster/r.neighbors/main.c:292
+#: ../raster/r.out.ppm3/main.c:102 ../raster/r.random.surface/init.c:109
+#: ../raster/r.colors/main.c:258 ../raster/r.distance/parse.c:72
+#: ../raster/r.rescale.eq/main.c:107 ../raster/r.carve/main.c:126
+#: ../raster/r.compress/main.c:90 ../raster/r.rescale/main.c:103
+#: ../raster/r.describe/main.c:115 ../raster/r.clump/main.c:77
+#: ../raster/r.texture/main.c:221 ../raster/r.series/main.c:188
+#: ../raster/r.patch/main.c:87
+msgid ""
+"The '-q' flag is superseded and will be removed in future. Please use '--"
+"quiet' instead."
+msgstr ""
+#: ../vector/v.mkgrid/main.c:189
+msgid "'coor' option missing"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:192
+msgid "'box' option missing"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:196
+msgid "Invalid easting"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:199
+msgid "Invalid northing"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:203 ../vector/v.mkgrid/main.c:206
+msgid "Invalid distance"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:223 ../vector/v.net.spanningtree/main.c:87
+#: ../vector/v.to.3d/main.c:88 ../vector/v.edit/main.c:105
+#: ../vector/v.net.allpairs/main.c:116 ../vector/v.hull/main.c:334
+#: ../vector/v.net.flow/main.c:138 ../vector/v.net.flow/main.c:144
+#: ../vector/v.generalize/main.c:301 ../vector/v.net.components/main.c:114
+#: ../vector/v.drape/main.c:339 ../vector/v.drape/main.c:380
+#: ../vector/v.voronoi/vo_main.c:165 ../vector/v.voronoi/dt_main.c:92
+#: ../vector/v.voronoi/dt_main.c:98
+#: ../vector/lidar/v.lidar.correction/main.c:209
+#: ../vector/lidar/v.lidar.correction/main.c:215
+#: ../vector/lidar/v.outlier/main.c:205 ../vector/lidar/v.outlier/main.c:210
+#: ../vector/lidar/v.outlier/main.c:216
+#: ../vector/lidar/v.lidar.edgedetection/main.c:245
+#: ../vector/lidar/v.surf.bspline/main.c:298
+#: ../vector/v.net.distance/main.c:146 ../vector/v.net.visibility/main.c:87
+#: ../vector/v.buffer2/main.c:319 ../vector/v.net.centrality/main.c:194
+#: ../vector/v.net.connectivity/main.c:121 ../vector/v.in.dxf/main.c:168
+#: ../vector/v.net.timetable/main.c:323 ../vector/v.net.path/main.c:139
+#: ../vector/v.net.bridge/main.c:86 ../vector/v.delaunay2/main.c:126
+#: ../doc/vector/v.example/main.c:96 ../raster/r.flow/io.c:176
+#, c-format
+msgid "Unable to create vector map <%s>"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:255 ../vector/v.in.ascii/in.c:386
+#: ../vector/v.lrs/v.lrs.create/main.c:325 ../vector/v.in.sites/main.c:170
+#: ../vector/v.random/main.c:193 ../vector/v.in.dxf/write_vect.c:218
+#: ../raster/r.to.vect/main.c:194
+#, c-format
+msgid "Unable to create table: %s"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:259 ../vector/v.overlay/main.c:469
+#: ../raster/r.to.vect/main.c:198
+msgid "Unable to create index"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:263 ../vector/v.in.ascii/in.c:395
+#: ../vector/v.sample/main.c:223 ../vector/v.reclass/main.c:228
+#: ../vector/v.in.sites/main.c:179 ../vector/v.to.points/main.c:306
+#: ../vector/v.in.dwg/main.c:228 ../vector/v.convert/att.c:90
+#: ../vector/v.in.ogr/main.c:791 ../vector/v.overlay/main.c:474
+#: ../vector/v.random/main.c:204 ../vector/v.distance/main.c:827
+#: ../vector/v.in.dxf/write_vect.c:223 ../raster/r.to.vect/main.c:203
+#: ../raster/r.contour/main.c:206
+#, c-format
+msgid "Unable to grant privileges on table <%s>"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:272
+msgid "Creating centroids..."
+msgstr ""
+#: ../vector/v.mkgrid/main.c:309 ../vector/v.in.ascii/points.c:405
+#: ../vector/v.in.sites/main.c:240 ../vector/v.in.dxf/write_vect.c:58
+#, c-format
+msgid "Unable to insert new record: %s"
+msgstr ""
+#: ../vector/v.kernel/function.c:220
+msgid "Dimension > 2 supported only by gaussian function"
+msgstr ""
+#: ../vector/v.kernel/main.c:66
+#, c-format
+msgid "\tScore Value=%f\tsmoothing parameter (standard deviation)=%f"
+msgstr ""
+#: ../vector/v.kernel/main.c:105
+msgid "vector, kernel density"
+msgstr ""
+#: ../vector/v.kernel/main.c:107
+msgid ""
+"Generates a raster density map from vector point data using a moving kernel "
+"or optionally generates a vector density map on a vector network."
+msgstr ""
+#: ../vector/v.kernel/main.c:111
+msgid "Input vector with training points"
+msgstr ""
+#: ../vector/v.kernel/main.c:115
+msgid "Input network vector map"
+msgstr ""
+#: ../vector/v.kernel/main.c:123
+msgid "Output raster/vector map"
+msgstr ""
+#: ../vector/v.kernel/main.c:129
+msgid "Standard deviation in map units"
+msgstr ""
+#: ../vector/v.kernel/main.c:135
+msgid "Discretization error in map units"
+msgstr ""
+#: ../vector/v.kernel/main.c:142
+msgid "Maximum length of segment on network"
+msgstr ""
+#: ../vector/v.kernel/main.c:149
+msgid "Maximum distance from point to network"
+msgstr ""
+#: ../vector/v.kernel/main.c:156
+msgid "Multiply the density result by this number"
+msgstr ""
+#: ../vector/v.kernel/main.c:163
+msgid "Node method"
+msgstr ""
+#: ../vector/v.kernel/main.c:167
+msgid ""
+"none;No method applied at nodes with more than 2 arcs;split;Equal split "
+"(Okabe 2009) applied at nodes;"
+msgstr ""
+#: ../vector/v.kernel/main.c:174
+msgid "Kernel function"
+msgstr ""
+#: ../vector/v.kernel/main.c:182
+msgid ""
+"Try to calculate an optimal standard deviation with 'stddeviation' taken as "
+"maximum (experimental)"
+msgstr ""
+#: ../vector/v.kernel/main.c:187
+msgid "Only calculate optimal standard deviation and exit (no map is written)"
+msgstr ""
+#: ../vector/v.kernel/main.c:192
+msgid ""
+"In network mode, normalize values by sum of density multiplied by length of "
+"each segment. Integral over the output map then gives 1.0 * mult"
+msgstr ""
+#: ../vector/v.kernel/main.c:197
+msgid "In network mode, multiply the result by number of input points."
+msgstr ""
+#: ../vector/v.kernel/main.c:202
+msgid "Verbose module output (retained for backwards compatibility)"
+msgstr ""
+#: ../vector/v.kernel/main.c:224
+msgid "Unknown node method"
+msgstr ""
+#: ../vector/v.kernel/main.c:242
+msgid "Unknown kernel function"
+msgstr ""
+#: ../vector/v.kernel/main.c:248
+msgid ""
+"Optimal standard deviation calculation is supported only for node method "
+"'none' and kernel function 'gaussian'."
+msgstr ""
+#: ../vector/v.kernel/main.c:252
+msgid ""
+"Optimal standard deviation calculation is supported only for kernel function "
+"'gaussian'."
+msgstr ""
+#: ../vector/v.kernel/main.c:289
+#, c-format
+msgid "Network input map <%s> not found"
+msgstr ""
+#: ../vector/v.kernel/main.c:316
+#, c-format
+msgid "%d points outside threshold"
+msgstr ""
+#: ../vector/v.kernel/main.c:344
+#, c-format
+msgid ""
+"Automatic choice of smoothing parameter (standard deviation), maximum "
+"possible value of standard deviation is set to %f"
+msgstr ""
+#: ../vector/v.kernel/main.c:351
+#, c-format
+msgid "Using maximum distance between points: %f"
+msgstr ""
+#: ../vector/v.kernel/main.c:365
+#, c-format
+msgid "Number of input points: %d."
+msgstr ""
+#: ../vector/v.kernel/main.c:366
+#, c-format
+msgid "%d distances read from the map."
+msgstr ""
+#: ../vector/v.kernel/main.c:369
+#, c-format
+msgid ""
+"Distances between all points are beyond %e (4 * standard deviation), unable "
+"to calculate optimal value."
+msgstr ""
+#: ../vector/v.kernel/main.c:380
+#, c-format
+msgid "Optimal smoothing parameter (standard deviation): %f."
+msgstr ""
+#: ../vector/v.kernel/main.c:407
+#, c-format
+msgid ""
+"\n"
+"Writing output vector map using smooth parameter=%f."
+msgstr ""
+#: ../vector/v.kernel/main.c:409 ../vector/v.kernel/main.c:516
+#, c-format
+msgid ""
+"\n"
+"Normalising factor=%f."
+msgstr ""
+#: ../vector/v.kernel/main.c:514
+#, c-format
+msgid ""
+"\n"
+"Writing output raster map using smooth parameter=%f."
+msgstr ""
+#: ../vector/v.kernel/main.c:523
+msgid "Unable to read MASK"
+msgstr ""
+#: ../vector/v.kernel/main.c:550
+#, c-format
+msgid "Maximum value in output: %e."
+msgstr ""
+#: ../vector/v.net.spanningtree/main.c:46
+msgid "vector, network, spanning tree"
+msgstr ""
+#: ../vector/v.net.spanningtree/main.c:48
+msgid "Computes minimum spanning tree for the network."
+msgstr ""
+#: ../vector/v.net.spanningtree/main.c:59
+msgid "Name of Arc cost column"
+msgstr ""
+#: ../vector/v.net.spanningtree/main.c:64 ../vector/v.net.allpairs/main.c:89
+#: ../vector/v.net.alloc/main.c:117 ../vector/v.net.salesman/main.c:136
+#: ../vector/v.net.steiner/main.c:394 ../vector/v.net.distance/main.c:123
+#: ../vector/v.net.centrality/main.c:167 ../vector/v.net.iso/main.c:127
+#: ../vector/v.net.path/main.c:102 ../display/d.path/main.c:123
+msgid "Use geodesic calculation for longitude-latitude locations"
+msgstr ""
+#: ../vector/v.net.spanningtree/main.c:81 ../vector/v.to.3d/main.c:72
+#: ../vector/v.edit/main.c:165 ../vector/v.net.allpairs/main.c:110
+#: ../vector/v.hull/main.c:307 ../vector/v.net/main.c:164
+#: ../vector/v.net.flow/main.c:132 ../vector/v.info/main.c:113
+#: ../vector/v.generalize/main.c:294 ../vector/v.net.components/main.c:108
+#: ../vector/lidar/v.lidar.correction/main.c:186
+#: ../vector/lidar/v.lidar.growing/main.c:141
+#: ../vector/lidar/v.lidar.growing/main.c:145
+#: ../vector/lidar/v.lidar.edgedetection/main.c:223
+#: ../vector/v.surf.rst/main.c:569 ../vector/v.surf.rst/main.c:724
+#: ../vector/v.surf.rst/main.c:813 ../vector/v.net.distance/main.c:140
+#: ../vector/v.net.visibility/main.c:82 ../vector/v.net.visibility/main.c:94
+#: ../vector/v.buffer2/main.c:315 ../vector/v.net.centrality/main.c:188
+#: ../vector/v.net.connectivity/main.c:115
+#: ../vector/v.net.timetable/main.c:317 ../vector/v.out.ascii/out.c:154
+#: ../vector/v.support/main.c:135 ../vector/v.net.bridge/main.c:80
+#: ../doc/vector/v.example/main.c:85 ../display/d.what.vect/main.c:126
+#, c-format
+msgid "Unable to open vector map <%s>"
+msgstr ""
+#: ../vector/v.net.spanningtree/main.c:93 ../vector/v.net.allpairs/main.c:122
+#: ../vector/v.net.distance/main.c:153 ../vector/v.net.centrality/main.c:201
+#: ../vector/v.net.path/main.c:120 ../display/d.path/main.c:185
+msgid "The current projection is not longitude-latitude"
+msgstr ""
+#: ../vector/v.kcv/main.c:78
+msgid "Randomly partition points into test/train sets."
+msgstr ""
+#: ../vector/v.kcv/main.c:87
+msgid "Number of partitions"
+msgstr ""
+#: ../vector/v.kcv/main.c:97
+msgid "Name for new column to which partition number is written"
+msgstr ""
+#: ../vector/v.kcv/main.c:101
+msgid "Use drand48()"
+msgstr ""
+#: ../vector/v.kcv/main.c:137 ../vector/v.edit/main.c:130
+#, c-format
+msgid "Unable to open vector map <%s> at topological level %d"
+msgstr ""
+#: ../vector/v.kcv/main.c:161 ../vector/v.net/main.c:197
+#: ../vector/v.clean/main.c:281 ../vector/v.proj/main.c:296
+#: ../vector/v.build.polylines/main.c:220 ../vector/v.category/main.c:527
+#: ../vector/v.transform/main.c:339 ../vector/v.type/main.c:234
+msgid "Failed to copy attribute table to output map"
+msgstr ""
+#: ../vector/v.kcv/main.c:174
+#, c-format
+msgid "Unable to get layer info for vector map <%s>"
+msgstr ""
+#: ../vector/v.kcv/main.c:198
+#, c-format
+msgid "Cannot alter table: %s"
+msgstr ""
+#: ../vector/v.kcv/main.c:270 ../vector/v.sample/main.c:289
+#, c-format
+msgid "Unable to insert row: %s"
+msgstr ""
+#: ../vector/v.extract/main.c:91
+msgid "vector, extract"
+msgstr ""
+#: ../vector/v.extract/main.c:93
+msgid ""
+"Selects vector objects from an existing vector map and creates a new map "
+"containing only the selected objects."
+msgstr ""
+#: ../vector/v.extract/main.c:98
+msgid "Dissolve common boundaries (default is no)"
+msgstr ""
+#: ../vector/v.extract/main.c:102
+msgid "Do not copy table (see also 'new' parameter)"
+msgstr ""
+#: ../vector/v.extract/main.c:106 ../vector/v.edit/args.c:201
+#: ../vector/v.select/args.c:88
+msgid "Reverse selection"
+msgstr ""
+#: ../vector/v.extract/main.c:107 ../vector/v.extract/main.c:117
+#: ../vector/v.extract/main.c:123 ../vector/v.extract/main.c:127
+#: ../vector/v.extract/main.c:130 ../vector/v.extract/main.c:138
+#: ../vector/v.extract/main.c:148 ../vector/v.edit/args.c:42
+#: ../vector/v.edit/args.c:47 ../vector/v.edit/args.c:125
+#: ../vector/v.edit/args.c:129 ../vector/v.edit/args.c:138
+#: ../vector/v.edit/args.c:147 ../vector/v.edit/args.c:156
+#: ../vector/v.edit/args.c:159 ../vector/v.edit/args.c:173
+#: ../vector/v.edit/args.c:202 ../vector/v.reclass/main.c:75
+#: ../vector/v.reclass/main.c:78 ../vector/v.net.allpairs/main.c:67
+#: ../vector/v.net.allpairs/main.c:69 ../vector/v.net.allpairs/main.c:71
+#: ../vector/v.to.rast/main.c:44 ../vector/v.to.rast/main.c:49
+#: ../vector/v.surf.rst/main.c:193 ../vector/v.surf.rst/main.c:219
+#: ../vector/v.surf.rst/main.c:222 ../vector/v.in.ogr/main.c:132
+#: ../vector/v.in.ogr/main.c:146 ../vector/v.in.ogr/main.c:168
+#: ../vector/v.select/args.c:16 ../vector/v.select/args.c:21
+#: ../vector/v.select/args.c:30 ../vector/v.select/args.c:35
+#: ../vector/v.select/args.c:89 ../vector/v.buffer2/main.c:159
+#: ../vector/v.buffer2/main.c:162 ../vector/v.category/main.c:92
+#: ../vector/v.category/main.c:97 ../vector/v.category/main.c:101
+#: ../vector/v.net.centrality/main.c:107 ../vector/v.net.centrality/main.c:109
+#: ../vector/v.out.ascii/out.c:80 ../vector/v.out.ascii/out.c:87
+#: ../display/d.rast/main.c:66 ../display/d.rast/main.c:75
+#: ../display/d.rast/main.c:94 ../display/d.vect/main.c:103
+#: ../display/d.vect/main.c:109 ../display/d.vect/main.c:112
+#: ../display/d.vect/main.c:115 ../display/d.vect/main.c:333
+#: ../display/d.thematic.area/main.c:131 ../display/d.thematic.area/main.c:134
+msgid "Selection"
+msgstr ""
+#: ../vector/v.extract/main.c:116
+msgid "Types to be extracted"
+msgstr ""
+#: ../vector/v.extract/main.c:122
+msgid ""
+"Layer number (if -1, all features in all layers of given type are extracted)"
+msgstr ""
+#: ../vector/v.extract/main.c:136
+msgid "Input text file with category numbers/number ranges to be extracted"
+msgstr ""
+#: ../vector/v.extract/main.c:137
+msgid "If '-' given reads from standard input"
+msgstr ""
+#: ../vector/v.extract/main.c:145
+msgid "Number of random categories matching vector objects to extract"
+msgstr ""
+#: ../vector/v.extract/main.c:147
+msgid "Number must be smaller than unique cat count in layer"
+msgstr ""
+#: ../vector/v.extract/main.c:156
+msgid "Enter -1 to keep original categories or the desired NEW category value"
+msgstr ""
+#: ../vector/v.extract/main.c:157
+msgid "If new >= 0, table is not copied"
+msgstr ""
+#: ../vector/v.extract/main.c:175
+msgid ""
+"List, file, where and random options are exclusive. Please specify only one "
+"of them"
+msgstr ""
+#: ../vector/v.extract/main.c:204 ../vector/v.drape/main.c:220
+msgid "Layer 0 not supported"
+msgstr ""
+#: ../vector/v.extract/main.c:228
+#, c-format
+msgid "Category value in '%s' not valid"
+msgstr ""
+#: ../vector/v.extract/main.c:244
+#, c-format
+msgid "Process file <%s> for category numbers"
+msgstr ""
+#: ../vector/v.extract/main.c:249
+#, c-format
+msgid "Unable to open specified file <%s>"
+msgstr ""
+#: ../vector/v.extract/main.c:259
+#, c-format
+msgid "Ignored text entry: %s"
+msgstr ""
+#: ../vector/v.extract/main.c:274 ../vector/v.univar/main.c:172
+#: ../vector/v.surf.rst/main.c:450 ../display/d.vect/main.c:463
+msgid "'layer' must be > 0 for 'where'."
+msgstr ""
+#: ../vector/v.extract/main.c:278 ../vector/v.to.3d/trans3.c:46
+#: ../vector/v.to.3d/trans2.c:45 ../vector/v.edit/select.c:506
+#: ../vector/v.sample/main.c:167 ../vector/v.reclass/main.c:121
+#: ../vector/v.univar/main.c:176 ../vector/v.surf.idw/read_sites.c:34
+#: ../vector/v.db.connect/main.c:208 ../vector/v.info/main.c:208
+#: ../vector/v.db.select/main.c:149 ../vector/v.extrude/main.c:163
+#: ../vector/v.generalize/misc.c:161 ../vector/v.what.rast/main.c:126
+#: ../vector/v.drape/main.c:271 ../vector/v.to.rast/support.c:126
+#: ../vector/v.to.rast/support.c:280 ../vector/v.to.rast/vect2rast.c:51
+#: ../vector/lidar/v.surf.bspline/crosscorr.c:114
+#: ../vector/v.overlay/main.c:287 ../vector/v.buffer2/main.c:328
+#: ../vector/v.distance/main.c:359 ../vector/v.distance/main.c:395
+#: ../vector/v.out.ascii/b2a.c:39 ../doc/vector/v.example/main.c:103
+#: ../display/d.vect.chart/plot.c:38 ../display/d.vect/plot1.c:202
+#: ../display/d.vect/area.c:54 ../display/d.thematic.area/plot1.c:193
+#, c-format
+msgid "Database connection not defined for layer %d"
+msgstr ""
+#: ../vector/v.extract/main.c:297
+#, c-format
+msgid "Unable select records from table <%s>"
+msgstr ""
+#: ../vector/v.extract/main.c:298
+#, c-format
+msgid "%d categories loaded from table <%s>"
+msgstr ""
+#: ../vector/v.extract/main.c:313
+msgid ""
+"This map has no categories attached. Use v.category to attach categories to "
+"this vector map."
+msgstr ""
+#: ../vector/v.extract/main.c:319
+msgid "Please specify random number larger than 0"
+msgstr ""
+#: ../vector/v.extract/main.c:323
+#, c-format
+msgid ""
+"Random category count must be smaller than feature count. There are only %d "
+"features of type(s): %s"
+msgstr ""
+#: ../vector/v.extract/main.c:346
+#, c-format
+msgid ""
+"Random category count is larger or equal to uniq \"%s\" feature category "
+"count %d"
+msgstr ""
+#: ../vector/v.extract/main.c:383
+msgid "Extracting features..."
+msgstr ""
+#: ../vector/v.extract/main.c:428 ../vector/v.generalize/misc.c:125
+#: ../vector/v.select/main.c:480
+msgid "Writing attributes..."
+msgstr ""
+#: ../vector/v.extract/main.c:461 ../vector/v.generalize/misc.c:157
+#: ../vector/v.voronoi/vo_main.c:339 ../vector/v.digit/attr.c:536
+#, c-format
+msgid "Layer %d"
+msgstr ""
+#: ../vector/v.extract/main.c:466 ../vector/v.voronoi/vo_main.c:344
+msgid "No table"
+msgstr ""
+#: ../vector/v.extract/main.c:481 ../vector/v.in.db/main.c:225
+msgid "Unable to copy table"
+msgstr ""
+#: ../vector/v.extract/main.c:498
+msgid "Removing duplicate centroids..."
+msgstr ""
+#: ../vector/v.in.db/main.c:52
+msgid "vector, import, database, points"
+msgstr ""
+#: ../vector/v.in.db/main.c:54
+msgid ""
+"Creates new vector (points) map from database table containing coordinates."
+msgstr ""
+#: ../vector/v.in.db/main.c:58
+msgid "Input table name"
+msgstr ""
+#: ../vector/v.in.db/main.c:72
+msgid "Name of column containing x coordinate"
+msgstr ""
+#: ../vector/v.in.db/main.c:77
+msgid "Name of column containing y coordinate"
+msgstr ""
+#: ../vector/v.in.db/main.c:81
+msgid "Name of column containing z coordinate"
+msgstr ""
+#: ../vector/v.in.db/main.c:86
+msgid "Name of column containing category number"
+msgstr ""
+#: ../vector/v.in.db/main.c:87 ../vector/v.db.connect/main.c:73
+msgid "Must refer to an integer column"
+msgstr ""
+#: ../vector/v.in.db/main.c:130
+#, c-format
+msgid ""
+"Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
+msgstr ""
+#: ../vector/v.in.db/main.c:138 ../vector/v.db.connect/main.c:284
+#: ../vector/v.transform/trans_digit.c:93
+#, c-format
+msgid "Missing column <%s> in table <%s>"
+msgstr ""
+#: ../vector/v.in.db/main.c:141 ../vector/v.db.connect/main.c:290
+msgid "Data type of key column must be integer"
+msgstr ""
+#: ../vector/v.in.db/main.c:163 ../display/d.vect.chart/plot.c:85
+#: ../display/d.vect/attr.c:110
+#, c-format
+msgid "Unable to open select cursor: '%s'"
+msgstr ""
+#: ../vector/v.in.db/main.c:173
+msgid "Writing features..."
+msgstr ""
+#: ../vector/v.in.db/main.c:180
+msgid "Key column must be integer"
+msgstr ""
+#: ../vector/v.in.db/main.c:188
+msgid "x/y/z column must be integer or double"
+msgstr ""
+#: ../vector/v.in.db/main.c:212 ../vector/v.to.3d/main.c:97
+#: ../vector/v.to.3d/main.c:127
+msgid "Copying attributes..."
+msgstr ""
+#: ../vector/v.in.db/main.c:235
+#, c-format
+msgid "%d points written to vector map."
+msgstr ""
+#: ../vector/v.to.3d/trans3.c:61 ../vector/v.to.3d/trans2.c:60
+#: ../vector/v.reclass/main.c:137 ../vector/v.distance/main.c:377
+#: ../vector/v.distance/main.c:411 ../vector/v.out.ascii/b2a.c:236
+#, c-format
+msgid "Column <%s> not found in table <%s>"
+msgstr ""
+#: ../vector/v.to.3d/trans3.c:66 ../vector/v.to.3d/trans2.c:65
+msgid "Column must be numeric"
+msgstr ""
+#: ../vector/v.to.3d/trans3.c:81 ../vector/v.to.3d/trans2.c:81
+#: ../vector/v.info/main.c:388 ../vector/v.label/main.c:297
+#: ../vector/v.label.sa/labels.c:146 ../display/d.vect/plot1.c:416
+msgid "Unable to read vector map"
+msgstr ""
+#: ../vector/v.to.3d/trans3.c:99
+#, c-format
+msgid "Feature id %d has no category - skipping"
+msgstr ""
+#: ../vector/v.to.3d/trans3.c:102
+#, c-format
+msgid "Feature id %d has more categories. Using category %d."
+msgstr ""
+#: ../vector/v.to.3d/trans3.c:128 ../vector/v.to.db/update.c:221
+#, c-format
+msgid "Record (cat %d) does not exist (not updated)"
+msgstr ""
+#: ../vector/v.to.3d/trans2.c:98
+msgid "Skipping feature without category"
+msgstr ""
+#: ../vector/v.to.3d/trans2.c:113
+#, c-format
+msgid "Unable to get height for feature category %d"
+msgstr ""
+#: ../vector/v.to.3d/args.c:11
+msgid "Reverse transformation; 3D vector features to 2D"
+msgstr ""
+#: ../vector/v.to.3d/args.c:15
+msgid "Do not copy table"
+msgstr ""
+#: ../vector/v.to.3d/args.c:30
+msgid "Fixed height for 3D vector features"
+msgstr ""
+#: ../vector/v.to.3d/args.c:31 ../vector/v.to.3d/args.c:34
+#: ../vector/v.to.3d/args.c:41
+msgid "Height"
+msgstr ""
+#: ../vector/v.to.3d/args.c:37
+msgid "Name of attribute column used for height"
+msgstr ""
+#: ../vector/v.to.3d/args.c:39
+msgid "Can be used for reverse transformation, to store height of points"
+msgstr ""
+#: ../vector/v.to.3d/main.c:37
+msgid "vector, transformation, 3D"
+msgstr ""
+#: ../vector/v.to.3d/main.c:39
+msgid "Performs transformation of 2D vector features to 3D."
+msgstr ""
+#: ../vector/v.to.3d/main.c:52
+#, c-format
+msgid "Either '%s' or '%s' parameter have to be used"
+msgstr ""
+#: ../vector/v.to.3d/main.c:58
+#, c-format
+msgid "Parameters '%s' ignored"
+msgstr ""
+#: ../vector/v.to.3d/main.c:63
+msgid "Attribute table required"
+msgstr ""
+#: ../vector/v.to.3d/main.c:76
+#, c-format
+msgid "Vector map <%s> is 2D"
+msgstr ""
+#: ../vector/v.to.3d/main.c:81
+#, c-format
+msgid "Vector map <%s> is 3D"
+msgstr ""
+#: ../vector/v.to.3d/main.c:99 ../vector/v.to.3d/main.c:129
+msgid "Unable to copy attributes"
+msgstr ""
+#: ../vector/v.to.3d/main.c:103
+msgid "Transforming features..."
+msgstr ""
+#: ../vector/v.to.3d/main.c:123
+#, c-format
+msgid "%s failed"
+msgstr ""
+#: ../vector/v.to.3d/main.c:138
+#, c-format
+msgid "Vertical extent of vector map <%s>: B: %f T: %f"
+msgstr ""
+#: ../vector/v.in.ascii/head.c:22
+#, c-format
+msgid ""
+"Unexpected data in vector head:\n"
+"[%s]"
+msgstr ""
+#: ../vector/v.in.ascii/head.c:56
+#, c-format
+msgid "Unknown keyword <%s> in vector head"
+msgstr ""
+#: ../vector/v.in.ascii/points.c:83
+msgid "Scanning input for column types..."
+msgstr ""
+#: ../vector/v.in.ascii/points.c:165
+#, c-format
+msgid "Unparsable longitude value in column <%d>: %s"
+msgstr ""
+#: ../vector/v.in.ascii/points.c:184
+#, c-format
+msgid "Unparsable latitude value in column <%d>: %s"
+msgstr ""
+#: ../vector/v.in.ascii/points.c:265
+#, c-format
+msgid "Skipping %d of %d rows falling outside of current region"
+msgstr ""
+#: ../vector/v.in.ascii/points.c:293
+msgid "Importing points..."
+msgstr ""
+#: ../vector/v.in.ascii/a2b.c:52
+#, c-format
+msgid "Error reading ASCII file: (bad type) [%s]"
+msgstr ""
+#: ../vector/v.in.ascii/a2b.c:90
+#, c-format
+msgid "Error reading ASCII file: (unknown type) [%s]"
+msgstr ""
+#: ../vector/v.in.ascii/a2b.c:103 ../vector/v.edit/a2b.c:136
+msgid "End of ASCII file reached before end of coordinates"
+msgstr ""
+#: ../vector/v.in.ascii/a2b.c:114
+#, c-format
+msgid "Error reading ASCII file: (bad point) [%s]"
+msgstr ""
+#: ../vector/v.in.ascii/a2b.c:118
+#, c-format
+msgid "Unparsable longitude value: [%s]"
+msgstr ""
+#: ../vector/v.in.ascii/a2b.c:121
+#, c-format
+msgid "Unparsable latitude value: [%s]"
+msgstr ""
+#: ../vector/v.in.ascii/a2b.c:154
+msgid "End of ASCII file reached before end of categories"
+msgstr ""
+#: ../vector/v.in.ascii/a2b.c:164
+#, c-format
+msgid "Error reading categories: [%s]"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:50
+msgid "Creates a vector map from ASCII points file or ASCII vector file."
+msgstr ""
+#: ../vector/v.in.ascii/in.c:56
+msgid "ASCII file to be imported, if not given reads from standard input"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:57 ../vector/v.in.ogr/main.c:116
+#: ../vector/v.in.ogr/main.c:120 ../vector/v.select/args.c:50
+#: ../display/d.rast.num/number.c:91 ../raster/r.external/main.c:527
+#: ../raster/r.external/main.c:537 ../raster/r.in.gdal/main.c:90
+#: ../raster/r.in.gdal/main.c:94 ../raster/r.colors/main.c:181
+#: ../raster/r.recode/main.c:54 ../raster/r.out.gdal/main.c:148
+#: ../raster/r.out.gdal/main.c:184
+msgid "Required"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:67
+msgid "point;simple x,y[,z] list;standard;GRASS vector ASCII format"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:70
+msgid "Input file format"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:71 ../vector/v.in.ascii/in.c:74
+#: ../vector/v.in.ascii/in.c:152
+msgid "Input format"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:83
+msgid "Number of header lines to skip at top of input file (points mode)"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:92
+msgid "Column definition in SQL style (points mode)"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:93
+msgid ""
+"For example: 'x double precision, y double precision, cat int, name varchar"
+"(10)'"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:105 ../vector/v.in.ascii/in.c:115
+msgid "First column is 1"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:114
+msgid "Number of column used as y coordinate (points mode)"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:124
+msgid "Number of column used as z coordinate (points mode)"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:125
+msgid "First column is 1. If 0, z coordinate is not used"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:135
+msgid "Number of column used as category (points mode)"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:137
+msgid ""
+"First column is 1. If 0, unique category is assigned to each row and written "
+"to new column 'cat'"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:141 ../vector/v.in.dwg/main.c:88
+msgid "Create 3D vector map"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:146
+msgid "Create a new empty vector map and exit. Nothing is read from input."
+msgstr ""
+#: ../vector/v.in.ascii/in.c:151
+msgid "Don't expect a header when reading in standard format"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:156
+msgid "Do not create table in points mode"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:161 ../raster/r.random/main.c:94
+msgid "Do not build topology in points mode"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:167
+msgid "Only import points falling within current region (points mode)"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:181
+msgid "Please specify reasonable number of lines to skip"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:184
+msgid "Please specify z column"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:195
+msgid "Please specify reasonable z column"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:200
+msgid "Column numbers must not be negative"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:204 ../vector/v.edit/main.c:77
+#, c-format
+msgid "Unable to open ASCII file <%s>"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:256
+#, c-format
+msgid "Maximum input row length: %d"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:257
+#, c-format
+msgid "Maximum number of columns: %d"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:258
+#, c-format
+msgid "Minimum number of columns: %d"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:263
+msgid ""
+"x column number > minimum last column number\n"
+"(incorrect field separator?)"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:267
+msgid ""
+"y column number > minimum last column number\n"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:271
+msgid ""
+"z column number > minimum last column number (incorrect field separator?)"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:276
+msgid ""
+"cat column number > minimum last column number (incorrect field separator?)"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:282
+msgid "x column is not of number type"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:286
+msgid "y column is not of number type"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:290
+msgid "z column is not of number type"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:294
+msgid "cat column is not of number type"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:336
+msgid "Category column is not of integer type"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:417
+#, c-format
+msgid ""
+"Number of columns defined (%d) does not match number of columns (%d) in input"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:445
+#, c-format
+msgid "Column number %d <%s> defined as double has only integer values"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:450
+#, c-format
+msgid "Column number %d <%s> defined as string has only integer values"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:458
+#, c-format
+msgid "Column number %d <%s> defined as integer has double values"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:463
+#, c-format
+msgid "Column number %d <%s> defined as string has double values"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:471
+#, c-format
+msgid "Column number %d <%s> defined as integer has string values"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:477
+#, c-format
+msgid "Column number %d <%s> defined as double has string values"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:483
+#, c-format
+msgid "Length of column %d <%s> (%d) is less than maximum value length (%d)"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:505 ../vector/v.reclass/main.c:223
+#: ../vector/v.in.sites/main.c:174 ../vector/v.to.points/main.c:300
+#: ../vector/v.in.dwg/main.c:223 ../vector/v.convert/att.c:85
+#: ../vector/v.in.ogr/main.c:785 ../vector/v.in.dxf/write_vect.c:225
+#: ../raster/r.contour/main.c:201
+#, c-format
+msgid "Unable to create index for table <%s>, key <%s>"
+msgstr ""
+#: ../vector/v.in.ascii/in.c:523
+msgid "Populating table..."
+msgstr ""
+#: ../vector/v.in.ascii/in.c:530
+msgid ""
+"Could not close attribute table. The DBMI driver did not accept all "
+"attributes"
+msgstr ""
+#: ../vector/v.segment/main.c:54
+msgid "Creates points/segments from input vector lines and positions."
+msgstr ""
+#: ../vector/v.segment/main.c:57
+msgid "Name of input vector map containing lines"
+msgstr ""
+#: ../vector/v.segment/main.c:61
+msgid "Name for output vector map where segments will be written"
+msgstr ""
+#: ../vector/v.segment/main.c:66 ../vector/v.lrs/v.lrs.where/main.c:74
+#: ../vector/v.lrs/v.lrs.create/main.c:144
+#: ../vector/v.lrs/v.lrs.segment/main.c:85
+#: ../vector/v.lrs/v.lrs.label/main.c:116
+msgid "Line layer"
+msgstr ""
+#: ../vector/v.segment/main.c:71 ../vector/v.lrs/v.lrs.segment/main.c:112
+msgid "Name of file containing segment rules. If not given, read from stdin."
+msgstr ""
+#: ../vector/v.segment/main.c:92 ../vector/v.lrs/v.lrs.segment/main.c:131
+#: ../vector/v.net.path/path.c:49 ../display/d.linegraph/linegraph.c:193
+#: ../display/d.linegraph/linegraph.c:204 ../raster/r.in.xyz/main.c:470
+#: ../raster/r.in.arc/main.c:124 ../raster/r.in.mat/main.c:144
+#, c-format
+msgid "Unable to open input file <%s>"
+msgstr ""
+#: ../vector/v.segment/main.c:137 ../vector/v.segment/main.c:177
+#, c-format
+msgid "Unable to read input: %s"
+msgstr ""
+#: ../vector/v.segment/main.c:147 ../vector/v.segment/main.c:186
+#, c-format
+msgid "Unable to find line of cat %d"
+msgstr ""
+#: ../vector/v.segment/main.c:157
+#, c-format
+msgid ""
+"Unable to get point on line: cat = %d offset = %f (line length = %.15g)\n"
+"%s"
+msgstr ""
+#: ../vector/v.segment/main.c:194
+msgid "End of segment > line length -> cut"
+msgstr ""
+#: ../vector/v.segment/main.c:200
+#, c-format
+msgid ""
+"Unable to make line segment: cat = %d : %f - %f (line length = %.15g)\n"
+"%s"
+msgstr ""
+#: ../vector/v.segment/main.c:222 ../vector/v.lrs/v.lrs.segment/main.c:331
+#, c-format
+msgid "Incorrect segment type: %s"
+msgstr ""
+#: ../vector/v.segment/main.c:227
+#, c-format
+msgid "%d points read from input"
+msgstr ""
+#: ../vector/v.segment/main.c:228
+#, c-format
+msgid "%d points written to output map (%d lost)"
+msgstr ""
+#: ../vector/v.segment/main.c:230
+#, c-format
+msgid "%d lines read from input"
+msgstr ""
+#: ../vector/v.segment/main.c:231
+#, c-format
+msgid "%d lines written to output map (%d lost)"
+msgstr ""
+#: ../vector/v.edit/a2b.c:85 ../vector/v.edit/a2b.c:123
+#: ../vector/v.edit/a2b.c:147
+#, c-format
+msgid "Error reading ASCII file: '%s'"
+msgstr ""
+#: ../vector/v.edit/a2b.c:178
+msgid "End of ascii file reached before end of categories"
+msgstr ""
+#: ../vector/v.edit/a2b.c:189
+#, c-format
+msgid "Error reading categories: '%s'"
+msgstr ""
+#: ../vector/v.edit/a2b.c:236
+#, c-format
+msgid "Unexpected data in vector head: '%s'"
+msgstr ""
+#: ../vector/v.edit/a2b.c:270
+#, c-format
+msgid "Unknown keyword '%s' in vector head"
+msgstr ""
+#: ../vector/v.edit/a2b.c:328 ../vector/v.edit/snap.c:111
+#, c-format
+msgid "Unable to rewrite line %d"
+msgstr ""
+#: ../vector/v.edit/args.c:38
+msgid "Name of vector map to edit"
+msgstr ""
+#: ../vector/v.edit/args.c:54
+msgid "Tool"
+msgstr ""
+#: ../vector/v.edit/args.c:55
+msgid ""
+"create;Create new (empty) vector map;add;Add new features to existing vector "
+"map;delete;Delete selected features from vector map;move;Move selected "
+"features in vector map;vertexmove;Move vertex of selected vector lines;"
+"vertexdel;Remove vertex from selected vector lines;vertexadd;Add new vertex "
+"to selected vector lines;merge;Merge selected vector lines;break;Break/split "
+"vector lines;select;Select lines and print their ID's;catadd;Set new "
+"categories to selected vector features for defined layer;catdel;Delete "
+"categories from selected vector features for defined layer;copy;Copy "
+"selected features;snap;Snap vector features in given threshold;flip;Flip "
+"direction of selected vector lines;connect;Connect two lines;zbulk;Z bulk-"
+"labeling (automated assignment of z coordinate to vector lines);chtype;"
+"Change feature type (point<->centroid, line<->boundary)"
+msgstr ""
+#: ../vector/v.edit/args.c:100
+msgid "ASCII file to be converted to binary vector map"
+msgstr ""
+#: ../vector/v.edit/args.c:102
+msgid "If not given (or \"-\") reads from standard input"
+msgstr ""
+#: ../vector/v.edit/args.c:112
+msgid "Difference in x,y direction for moving feature or vertex"
+msgstr ""
+#: ../vector/v.edit/args.c:119
+msgid "Threshold distance (coords,snap,query)"
+msgstr ""
+#: ../vector/v.edit/args.c:121
+msgid "'-1' for threshold based on the current resolution settings"
+msgstr ""
+#: ../vector/v.edit/args.c:137
+msgid "List of point coordinates"
+msgstr ""
+#: ../vector/v.edit/args.c:146
+msgid "Bounding box for selecting features"
+msgstr ""
+#: ../vector/v.edit/args.c:155
+msgid "Polygon for selecting features"
+msgstr ""
+#: ../vector/v.edit/args.c:165
+msgid "Query tool"
+msgstr ""
+#: ../vector/v.edit/args.c:167
+msgid "For 'shorter' use negative threshold value, positive value for 'longer'"
+msgstr ""
+#: ../vector/v.edit/args.c:170
+msgid ""
+"length;Select only lines or boundaries shorter/longer than threshold "
+"distance;dangle;Select dangles shorter/longer than threshold distance"
+msgstr ""
+#: ../vector/v.edit/args.c:178
+msgid "Name of background vector map(s)"
+msgstr ""
+#: ../vector/v.edit/args.c:185
+msgid ""
+"Snap added or modified features in the given threshold to the nearest "
+"existing feature"
+msgstr ""
+#: ../vector/v.edit/args.c:187
+msgid ""
+"no;Not apply snapping;node;Snap only to node;vertex;Allow snapping also to "
+"vertex"
+msgstr ""
+#: ../vector/v.edit/args.c:195
+msgid "Starting value and step for z bulk-labeling"
+msgstr ""
+#: ../vector/v.edit/args.c:196
+msgid "Pair: value,step (e.g. 1100,10)"
+msgstr ""
+#: ../vector/v.edit/args.c:207
+msgid "Close added boundaries (using threshold distance)"
+msgstr ""
+#: ../vector/v.edit/args.c:211
+msgid "Do not expect header of input data"
+msgstr ""
+#: ../vector/v.edit/args.c:216 ../vector/v.random/main.c:136
+#: ../vector/v.in.dxf/main.c:74
+msgid "Do not build topology"
+msgstr ""
+#: ../vector/v.edit/args.c:221
+msgid "Modify only first found feature in bounding box"
+msgstr ""
+#: ../vector/v.edit/args.c:233
+msgid "Polygon must have at least 3 coordinate pairs"
+msgstr ""
+#: ../vector/v.edit/args.c:294
+#, c-format
+msgid "Operation '%s' not implemented"
+msgstr ""
+#: ../vector/v.edit/args.c:303
+#, c-format
+msgid "At least one option from %s must be specified"
+msgstr ""
+#: ../vector/v.edit/args.c:309 ../vector/v.edit/args.c:318
+#: ../vector/v.edit/args.c:325 ../vector/v.edit/args.c:332
+#: ../vector/v.edit/args.c:336
+#, c-format
+msgid "Tool %s requires option %s"
+msgstr ""
+#: ../vector/v.edit/select.c:72
+#, c-format
+msgid "Threshold value for coordinates is %.2f"
+msgstr ""
+#: ../vector/v.edit/select.c:159
+#, c-format
+msgid "Threshold value for querying is %.2f"
+msgstr ""
+#: ../vector/v.edit/select.c:175
+#, c-format
+msgid "%d of %d features selected from vector map <%s>"
+msgstr ""
+#: ../vector/v.edit/select.c:500
+msgid "Layer must be > 0 for 'where'"
+msgstr ""
+#: ../vector/v.edit/main.c:55
+msgid "vector, editing, geometry"
+msgstr ""
+#: ../vector/v.edit/main.c:56
+msgid ""
+"Edits a vector map, allows adding, deleting and modifying selected vector "
+"features."
+msgstr ""
+#: ../vector/v.edit/main.c:65
+#, c-format
+msgid "Unable to get category list <%s>"
+msgstr ""
+#: ../vector/v.edit/main.c:93 ../vector/v.in.ogr/main.c:338
+#, c-format
+msgid "Vector map <%s> already exists"
+msgstr ""
+#: ../vector/v.edit/main.c:98
+msgid "Creating new DB connection based on default mapset settings..."
+msgstr ""
+#: ../vector/v.edit/main.c:119 ../vector/v.neighbors/main.c:77
+#: ../vector/v.build/main.c:84 ../vector/v.support/main.c:129
+#, c-format
+msgid "Vector map <%s> not found in the current mapset"
+msgstr ""
+#: ../vector/v.edit/main.c:153
+#, c-format
+msgid ""
+"Unable to open vector map <%s> as the background map. It is given as vector "
+"map to be edited."
+msgstr ""
+#: ../vector/v.edit/main.c:168
+#, c-format
+msgid "Background vector map <%s> registered"
+msgstr ""
+#: ../vector/v.edit/main.c:208
+msgid "Selecting features..."
+msgstr ""
+#: ../vector/v.edit/main.c:220
+msgid "No features selected, nothing to edit"
+msgstr ""
+#: ../vector/v.edit/main.c:228
+#, c-format
+msgid ""
+"Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert "
+"the vector map to 3D using e.g. %s."
+msgstr ""
+#: ../vector/v.edit/main.c:266
+#, c-format
+msgid "%d features added"
+msgstr ""
+#: ../vector/v.edit/main.c:268 ../vector/v.edit/main.c:289
+#: ../vector/v.edit/main.c:297 ../vector/v.edit/main.c:322
+#: ../vector/v.edit/main.c:359
+#, c-format
+msgid "Threshold value for snapping is %.2f"
+msgstr ""
+#: ../vector/v.edit/main.c:277
+#, c-format
+msgid "%d boundaries closed"
+msgstr ""
+#: ../vector/v.edit/main.c:284
+#, c-format
+msgid "%d features deleted"
+msgstr ""
+#: ../vector/v.edit/main.c:292
+#, c-format
+msgid "%d features moved"
+msgstr ""
+#: ../vector/v.edit/main.c:301
+#, c-format
+msgid "%d vertices moved"
+msgstr ""
+#: ../vector/v.edit/main.c:305
+#, c-format
+msgid "%d vertices added"
+msgstr ""
+#: ../vector/v.edit/main.c:309
+#, c-format
+msgid "%d vertices removed"
+msgstr ""
+#: ../vector/v.edit/main.c:319
+#, c-format
+msgid "%d lines broken"
+msgstr ""
+#: ../vector/v.edit/main.c:325
+#, c-format
+msgid "%d lines connected"
+msgstr ""
+#: ../vector/v.edit/main.c:329
+#, c-format
+msgid "%d lines merged"
+msgstr ""
+#: ../vector/v.edit/main.c:337 ../vector/v.edit/main.c:341
+#, c-format
+msgid "%d features modified"
+msgstr ""
+#: ../vector/v.edit/main.c:346
+#, c-format
+msgid ""
+"Multiple background maps were given. Selected features will be copied only "
+"from vector map <%s>."
+msgstr ""
+#: ../vector/v.edit/main.c:356
+#, c-format
+msgid "%d features copied"
+msgstr ""
+#: ../vector/v.edit/main.c:365
+#, c-format
+msgid "%d lines flipped"
+msgstr ""
+#: ../vector/v.edit/main.c:385
+#, c-format
+msgid "%d lines labeled"
+msgstr ""
+#: ../vector/v.edit/main.c:392
+#, c-format
+msgid "%d features converted"
+msgstr ""
+#: ../vector/v.edit/main.c:395
+msgid "No feature modified"
+msgstr ""
+#: ../vector/v.edit/main.c:400
+msgid "Operation not implemented"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.where/main.c:58
+#: ../vector/v.lrs/v.lrs.create/main.c:120
+#: ../vector/v.lrs/v.lrs.segment/main.c:70
+#: ../vector/v.lrs/v.lrs.label/main.c:102
+msgid "vector, LRS, networking"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.where/main.c:60
+msgid ""
+"Finds line id and real km+offset for given points in vector map using linear "
+"reference system."
+msgstr ""
+#: ../vector/v.lrs/v.lrs.where/main.c:65
+#: ../vector/v.lrs/v.lrs.create/main.c:125
+#: ../vector/v.lrs/v.lrs.segment/main.c:76
+#: ../vector/v.lrs/v.lrs.label/main.c:107 ../vector/v.to.points/main.c:178
+msgid "Input vector map containing lines"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.where/main.c:69
+msgid "Input vector map containing points"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.where/main.c:79
+#: ../vector/v.lrs/v.lrs.create/main.c:148
+msgid "Point layer"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.where/main.c:85
+#: ../vector/v.lrs/v.lrs.create/main.c:204
+#: ../vector/v.lrs/v.lrs.segment/main.c:91
+#: ../vector/v.lrs/v.lrs.label/main.c:122
+msgid "Driver name for reference system table"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.where/main.c:93
+#: ../vector/v.lrs/v.lrs.create/main.c:212
+#: ../vector/v.lrs/v.lrs.segment/main.c:99
+#: ../vector/v.lrs/v.lrs.label/main.c:130
+msgid "Database name for reference system table"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.where/main.c:101
+#: ../vector/v.lrs/v.lrs.segment/main.c:107
+#: ../vector/v.lrs/v.lrs.label/main.c:138
+msgid "Name of the reference system table"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.where/main.c:108
+msgid "Maximum distance to nearest line"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.where/main.c:145
+#: ../vector/v.lrs/v.lrs.create/main.c:303
+#: ../vector/v.lrs/v.lrs.segment/main.c:151
+#: ../vector/v.lrs/v.lrs.label/main.c:308
+msgid "Unable to open database for reference table"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.where/main.c:220
+#: ../vector/v.lrs/v.lrs.segment/main.c:346
+#, c-format
+msgid "[%d] points read from input"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.where/main.c:221
+#, c-format
+msgid "[%d] positions found"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.where/main.c:223
+#, c-format
+msgid "[%d] points outside threshold"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.where/main.c:225
+#, c-format
+msgid "[%d] points - no record found"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.where/main.c:227
+#, c-format
+msgid "[%d] points - too many records found"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:121
+msgid "Create Linear Reference System"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:130
+msgid "Output vector map where oriented lines are written"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:135
+msgid "Output vector map of errors"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:140
+msgid "Input vector map containing reference points"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:155
+msgid "Column containing line identifiers for lines"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:162
+msgid "Column containing line identifiers for points"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:170
+msgid "Column containing milepost position for the beginning of next segment"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:179
+msgid ""
+"Column containing offset from milepost for the beginning of next segment"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:188
+msgid "Column containing milepost position for the end of previous segment"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:197
+msgid "Column containing offset from milepost for the end of previous segment"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:221
+msgid "Name of table where the reference system will be written"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:222
+msgid "New table is created by this module"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:229
+msgid "Maximum distance of point to line allowed"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:276
+msgid "Cannot get layer info for lines"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:279
+msgid "Cannot get layer info for points"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:314
+#, c-format
+msgid "Unable to drop table: %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:333
+#, c-format
+msgid "Unable to select line id values from %s.%s."
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:343
+msgid "Line id column must be integer"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:354
+#: ../vector/v.lrs/v.lrs.create/main.c:456
+msgid "Unable to fetch line id from line table"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:406
+#, c-format
+msgid "Line [%d] without category (layer [%d])"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:426
+#, c-format
+msgid "No lines selected for line id [%d]"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:446
+#, c-format
+msgid "Unable to select point attributes from <%s>"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:477
+#, c-format
+msgid "Milepost (start) %f+%f used as %f+%f (change MP to integer)"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:499
+#, c-format
+msgid "Milepost (end) %f+%f used as %f+%f (change MP to integer)"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:525
+#, c-format
+msgid "Point [%d] without category (layer [%d])"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:572
+#, c-format
+msgid "Point [%d] cat [%d] is out of threshold (distance = %f)"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:704
+#, c-format
+msgid "End > start for point cat [%d]"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:721
+msgid "Start of 1. MP >= end of 2. MP for points' cats %[d], [%d]"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:738
+#, c-format
+msgid "Start of 1. MP >= start of 2. MP for points' cats [%d], [%d]"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:748
+#, c-format
+msgid "Distance along line identical for points' cats [%d], [%d]"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:762
+#, c-format
+msgid "Not enough points (%d) attached to the line (cat %d), line skip."
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:767
+#, c-format
+msgid "Unable to guess direction for the line (cat %d), line skip."
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:771
+#, c-format
+msgid "Incorrect order of points along line cat [%d]"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:821
+#, c-format
+msgid "Unable to insert reference records: %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:862
+msgid "Building topology for output (out_lines) map..."
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:868
+msgid "Building topology for error (err) map..."
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:72
+msgid ""
+"Creates points/segments from input lines, linear reference system and "
+"positions read from stdin or a file."
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:80
+msgid "Output vector map where segments will be written"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:179
+#: ../vector/v.lrs/v.lrs.segment/main.c:233
+#, c-format
+msgid "Cannot read input: %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:191
+#, c-format
+msgid "No record in LR table for: %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:195
+#, c-format
+msgid "More than one record in LR table for: %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:202
+#: ../vector/v.lrs/v.lrs.segment/main.c:289
+#, c-format
+msgid "Unable to find line of cat [%d]"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:212
+#, c-format
+msgid ""
+"Cannot get point on line: cat = [%d] distance = [%f] (line length = %f)\n"
+"%s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:248
+#, c-format
+msgid ""
+"No record in LRS table for 1. point of:\n"
+"  %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:253
+#, c-format
+msgid ""
+"Using last from more offsets found for 1. point of:\n"
+"  %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:257
+#, c-format
+msgid ""
+"Requested offset for the 1. point not found, using nearest found:\n"
+"  %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:268
+#, c-format
+msgid ""
+"No record in LRS table for 2. point of:\n"
+"  %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:273
+#, c-format
+msgid ""
+"Requested offset for the 2. point not found, using nearest found:\n"
+"  %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:277
+#, c-format
+msgid ""
+"Using first from more offsets found for 2. point of:\n"
+"  %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:282
+msgid "Segment over 2 (or more) segments, not yet supported"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:299
+#, c-format
+msgid "End of segment > line length (%e) -> cut"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:308
+#, c-format
+msgid ""
+"Cannot make line segment: cat = %d : %f - %f (line length = %f)\n"
+"%s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:347
+#, c-format
+msgid "[%d] points written to output map (%d lost)"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:349
+#, c-format
+msgid "[%d] lines read from input"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:350
+#, c-format
+msgid "[%d] lines written to output map (%d lost)"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:103
+msgid "Create stationing from input lines, and linear reference system"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:111
+msgid "Output vector map where stationing will be written"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:146
+msgid "Label file"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:155
+msgid "PM left, MP right, stationing left, stationing right offset"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:160
+msgid "Offset label in label x-direction in map units"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:167
+msgid "Offset label in label y-direction in map units"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:173 ../vector/v.label/main.c:114
+msgid "Reference position"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:180 ../vector/v.label/main.c:126
+#: ../vector/v.label/main.c:133 ../vector/v.label/main.c:141
+#: ../vector/v.label/main.c:149 ../vector/v.label.sa/main.c:118
+#: ../vector/v.label.sa/main.c:119 ../vector/v.label.sa/main.c:126
+msgid "Font"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:186 ../vector/v.label/main.c:130
+#: ../vector/v.label.sa/main.c:123
+msgid "Label size (in map-units)"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:193 ../vector/v.label/main.c:152
+#: ../vector/v.label.sa/main.c:144 ../display/d.grid/main.c:86
+#: ../display/d.barscale/main.c:88 ../display/d.rhumbline/main.c:70
+msgid "Text color"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:202
+msgid "Line width of text"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:203
+#: ../vector/v.lrs/v.lrs.label/main.c:211
+#: ../vector/v.lrs/v.lrs.label/main.c:221
+msgid "Only for d.label output"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:210 ../vector/v.label/main.c:175
+#: ../vector/v.label.sa/main.c:153
+msgid "Highlight color for text"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:220
+msgid "Line width of highlight color"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:237 ../vector/v.label/main.c:194
+#: ../vector/v.label.sa/main.c:190 ../display/d.grid/main.c:80
+msgid "Border color"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:246
+msgid "Opaque to vector"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:247
+msgid "Only relevant if background color is selected"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:299 ../display/d.paint.labels/main.c:121
+#, c-format
+msgid "Unable to open label file <%s>"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:338
+#, c-format
+msgid "Unable to select records from LRS table: %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:347 ../vector/v.out.vtk/writeVTK.c:579
+#: ../vector/v.out.svg/main.c:370 ../vector/v.out.ogr/main.c:1066
+#: ../vector/v.overlay/main.c:365
+msgid "Unable to fetch data from table"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:428
+msgid "No record in LR table"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:432
+msgid "More than one record in LR table"
+msgstr ""
+#: ../vector/v.sample/main.c:86
+msgid "vector, raster, resample"
+msgstr ""
+#: ../vector/v.sample/main.c:88
+msgid "Samples a raster map at vector point locations."
+msgstr ""
+#: ../vector/v.sample/main.c:91
+msgid "Vector map defining sample points"
+msgstr ""
+#: ../vector/v.sample/main.c:98
+msgid "Vector map attribute column to use for comparison"
+msgstr ""
+#: ../vector/v.sample/main.c:101
+msgid "Vector map to store differences"
+msgstr ""
+#: ../vector/v.sample/main.c:105
+msgid "Raster map to be sampled"
+msgstr ""
+#: ../vector/v.sample/main.c:113
+msgid ""
+"Option scaling factor for values read from raster map. Sampled values will "
+"be multiplied by this factor"
+msgstr ""
+#: ../vector/v.sample/main.c:119
+msgid "Bilinear interpolation (default is nearest neighbor)"
+msgstr ""
+#: ../vector/v.sample/main.c:124
+msgid "Cubic convolution interpolation (default is nearest neighbor)"
+msgstr ""
+#: ../vector/v.sample/main.c:142
+msgid "Flags -b & -c are mutually exclusive. Choose only one."
+msgstr ""
+#: ../vector/v.sample/main.c:181
+#, c-format
+msgid "Column type <%s> not supported (must be integer or double precision)"
+msgstr ""
+#: ../vector/v.sample/main.c:187 ../vector/v.surf.idw/read_sites.c:54
+#: ../vector/v.normal/main.c:155
+#, c-format
+msgid "%d records selected from table"
+msgstr ""
+#: ../vector/v.sample/main.c:216 ../vector/v.patch/main.c:285
+#, c-format
+msgid "Unable to create table <%s>"
+msgstr ""
+#: ../vector/v.sample/main.c:219 ../vector/v.db.connect/main.c:331
+#: ../vector/v.net.flow/main.c:172 ../vector/v.net.components/main.c:151
+#: ../vector/v.net.distance/main.c:212 ../vector/v.net.centrality/main.c:244
+#: ../vector/v.net.timetable/main.c:107 ../vector/v.digit/c_face.c:282
+#: ../vector/v.net.path/path.c:113
+msgid "Cannot create index"
+msgstr ""
+#: ../vector/v.sample/main.c:227
+msgid "Checking vector points..."
+msgstr ""
+#: ../vector/v.sample/main.c:252 ../vector/v.sample/main.c:260
+#: ../vector/v.buffer/main.c:454 ../vector/v.buffer/main.c:466
+#: ../vector/v.buffer/main.c:531 ../vector/v.buffer/main.c:543
+#: ../vector/v.what.rast/main.c:313 ../vector/v.label/main.c:329
+#: ../vector/v.buffer2/main.c:416 ../vector/v.buffer2/main.c:488
+#: ../vector/v.vol.rst/user1.c:170 ../vector/v.label.sa/labels.c:178
+#, c-format
+msgid "No record for category %d in table <%s>"
+msgstr ""
+#: ../vector/v.sample/main.c:266 ../vector/v.univar/main.c:273
+#: ../vector/v.surf.idw/read_sites.c:49 ../vector/v.buffer/main.c:402
+#: ../vector/v.what.rast/main.c:158
+#: ../vector/lidar/v.surf.bspline/crosscorr.c:133
+#: ../vector/lidar/v.surf.bspline/main.c:344 ../vector/v.class/main.c:123
+#: ../vector/v.to.rast3/main.c:100 ../vector/v.buffer2/main.c:349
+msgid "Column type not supported"
+msgstr ""
+#: ../vector/v.reclass/main.c:63
+msgid "vector, reclass, attributes"
+msgstr ""
+#: ../vector/v.reclass/main.c:65
+msgid ""
+"Changes vector category values for an existing vector map according to "
+"results of SQL queries or a value in attribute table column."
+msgstr ""
+#: ../vector/v.reclass/main.c:82
+msgid "The name of the column whose values are to be used as new categories"
+msgstr ""
+#: ../vector/v.reclass/main.c:83
+msgid "The source for the new key column must be type integer or string"
+msgstr ""
+#: ../vector/v.reclass/main.c:88
+msgid "Full path to the reclass rule file"
+msgstr ""
+#: ../vector/v.reclass/main.c:99
+msgid "Either 'rules' or 'col' must be specified"
+msgstr ""
+#: ../vector/v.reclass/main.c:186 ../vector/v.to.rast/support.c:145
+#: ../vector/v.to.rast/support.c:297 ../vector/v.to.rast/vect2rast.c:73
+#, c-format
+msgid "No records selected from table <%s>"
+msgstr ""
+#: ../vector/v.reclass/main.c:199
+msgid "Key column type is not integer"
+msgstr ""
+#: ../vector/v.reclass/main.c:237 ../vector/v.db.select/main.c:197
+#, c-format
+msgid "Unable to fetch data from table <%s>"
+msgstr ""
+#: ../vector/v.reclass/main.c:263
+#, c-format
+msgid "Cannot insert data: [%s]"
+msgstr ""
+#: ../vector/v.reclass/main.c:289
+msgid "Column type must be integer or string"
+msgstr ""
+#: ../vector/v.reclass/main.c:301
+#, c-format
+msgid "Unable to open rule file <%s>"
+msgstr ""
+#: ../vector/v.reclass/main.c:317
+#, c-format
+msgid "Category %d overwritten by '%s'"
+msgstr ""
+#: ../vector/v.reclass/main.c:321
+#, c-format
+msgid "Category '%s' invalid"
+msgstr ""
+#: ../vector/v.reclass/main.c:325
+#, c-format
+msgid "Label '%s' overwritten by '%s'"
+msgstr ""
+#: ../vector/v.reclass/main.c:331
+#, c-format
+msgid "Condition '%s' overwritten by '%s'"
+msgstr ""
+#: ../vector/v.reclass/main.c:336
+#, c-format
+msgid "Unknown rule option: '%s'"
+msgstr ""
+#: ../vector/v.reclass/main.c:350
+msgid "Cannot select values from database"
+msgstr ""
+#: ../vector/v.reclass/main.c:366
+#, c-format
+msgid "%d previously set categories overwritten by new category %d"
+msgstr ""
+#: ../vector/v.reclass/main.c:392
+msgid "Incomplete rule"
+msgstr ""
+#: ../vector/v.reclass/main.c:428
+#, c-format
+msgid "%d features reclassed."
+msgstr ""
+#: ../vector/v.univar/main.c:73
+msgid ""
+"Calculates univariate statistics for attribute. Variance and standard "
+"deviation is calculated only for points if specified."
+msgstr ""
+#: ../vector/v.univar/main.c:86
+msgid "Column name"
+msgstr ""
+#: ../vector/v.univar/main.c:103 ../vector/v.what/main.c:89
+#: ../raster/r.univar2/r.univar_main.c:60
+#: ../raster/r.univar2/r3.univar_main.c:61
+msgid "Print the stats in shell script style"
+msgstr ""
+#: ../vector/v.univar/main.c:111
+msgid "Calculate geometry distances instead of table data."
+msgstr ""
+#: ../vector/v.univar/main.c:119
+#, c-format
+msgid ""
+"Required parameter <%s> not set:\n"
+"\t(%s)"
+msgstr ""
+#: ../vector/v.univar/main.c:145
+msgid ""
+"Incompatible vector type(s) specified, only number of features, minimum, "
+"maximum and range can be calculated"
+msgstr ""
+#: ../vector/v.univar/main.c:150
+msgid "Extended statistics is currently supported only for points/centroids"
+msgstr ""
+#: ../vector/v.univar/main.c:187
+#, c-format
+msgid "Unable select categories from table <%s>"
+msgstr ""
+#: ../vector/v.univar/main.c:547
+msgid "Cannot sort the key/value array"
+msgstr ""
+#: ../vector/v.surf.idw/read_sites.c:86
+#: ../vector/lidar/v.surf.bspline/crosscorr.c:219
+#, c-format
+msgid "No record for point (cat = %d)"
+msgstr ""
+#: ../vector/v.surf.idw/read_sites.c:102
+#, c-format
+msgid "%d points loaded"
+msgstr ""
+#: ../vector/v.surf.idw/main.c:84 ../vector/lidar/v.surf.bspline/main.c:83
+#: ../vector/v.surf.rst/main.c:164 ../vector/v.vol.rst/main.c:202
+msgid "vector, interpolation"
+msgstr ""
+#: ../vector/v.surf.idw/main.c:86
+msgid ""
+"Surface interpolation from vector point data by Inverse Distance Squared "
+"Weighting."
+msgstr ""
+#: ../vector/v.surf.idw/main.c:95
+msgid "If set to 0, z coordinates are used (3D vector only)"
+msgstr ""
+#: ../vector/v.surf.idw/main.c:98 ../vector/v.surf.idw/main.c:106
+msgid "Values"
+msgstr ""
+#: ../vector/v.surf.idw/main.c:104
+msgid "Attribute table column with values to interpolate"
+msgstr ""
+#: ../vector/v.surf.idw/main.c:105
+msgid "Required if layer > 0"
+msgstr ""
+#: ../vector/v.surf.idw/main.c:113 ../raster/r.surf.idw/main.c:81
+#: ../raster/r.surf.idw2/main.c:72
+msgid "Number of interpolation points"
+msgstr ""
+#: ../vector/v.surf.idw/main.c:122
+msgid ""
+"Power parameter; greater values assign greater influence to closer points"
+msgstr ""
+#: ../vector/v.surf.idw/main.c:127
+msgid "Don't index points by raster cell"
+msgstr ""
+#: ../vector/v.surf.idw/main.c:128
+msgid ""
+"Slower but uses less memory and includes points from outside region in the "
+"interpolation"
+msgstr ""
+#: ../vector/v.surf.idw/main.c:141 ../raster/r.surf.idw2/main.c:87
+#, c-format
+msgid "%s=%s - illegal number of interpolation points"
+msgstr ""
+#: ../vector/v.surf.idw/main.c:147
+msgid "No attribute column specified"
+msgstr ""
+#: ../vector/v.surf.idw/main.c:182
+msgid "No data points found"
+msgstr ""
+#: ../vector/v.surf.idw/main.c:267
+#, c-format
+msgid "Interpolating raster map <%s> (%d rows, %d cols)... "
+msgstr ""
+#: ../vector/v.db.connect/main.c:52
+msgid "Prints/sets DB connection for a vector map to attribute table."
+msgstr ""
+#: ../vector/v.db.connect/main.c:72
+msgid "Key column name"
+msgstr ""
+#: ../vector/v.db.connect/main.c:79
+msgid "Field separator for shell script style output"
+msgstr ""
+#: ../vector/v.db.connect/main.c:85
+msgid "Print all map connection parameters and exit"
+msgstr ""
+#: ../vector/v.db.connect/main.c:90
+msgid "Print all map connection parameters and exit in shell script style"
+msgstr ""
+#: ../vector/v.db.connect/main.c:93
+msgid "Format: layer[/layer name] table key database driver"
+msgstr ""
+#: ../vector/v.db.connect/main.c:103
+msgid "When printing, limit to layer specified by the layer option"
+msgstr ""
+#: ../vector/v.db.connect/main.c:108
+msgid "Print types/names of table columns for specified layer and exit"
+msgstr ""
+#: ../vector/v.db.connect/main.c:115
+msgid "Overwrite connection parameter for certain layer"
+msgstr ""
+#: ../vector/v.db.connect/main.c:120
+msgid "Delete connection for certain layer (not the table)"
+msgstr ""
+#: ../vector/v.db.connect/main.c:153
+msgid "Unable to modify vector map stored in other mapset"
+msgstr ""
+#: ../vector/v.db.connect/main.c:161 ../vector/v.info/main.c:199
+#, c-format
+msgid "Database connection for map <%s> is not defined in DB file"
+msgstr ""
+#: ../vector/v.db.connect/main.c:170
+#, c-format
+msgid "Vector map <%s> is connected by:"
+msgstr ""
+#: ../vector/v.db.connect/main.c:175 ../display/d.what.vect/what.c:446
+#: ../display/d.vect/main.c:466 ../display/d.thematic.area/main.c:227
+#, c-format
+msgid "Database connection not defined"
+msgstr ""
+#: ../vector/v.db.connect/main.c:198
+#, c-format
+msgid ""
+"layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
+msgstr ""
+#: ../vector/v.db.connect/main.c:261
+#, c-format
+msgid "Use -o to overwrite existing link for layer <%d>"
+msgstr ""
+#: ../vector/v.db.connect/main.c:269 ../vector/v.db.connect/main.c:309
+#, c-format
+msgid "Table <%s> does not exist in database <%s>"
+msgstr ""
+#: ../vector/v.db.connect/main.c:297 ../vector/v.db.connect/main.c:315
+#, c-format
+msgid ""
+"The table <%s> is now part of vector map <%s> and may be deleted or "
+"overwritten by GRASS modules"
+msgstr ""
+#: ../vector/v.db.connect/main.c:336 ../vector/v.digit/c_face.c:294
+#, c-format
+msgid "Cannot grant privileges on table %s"
+msgstr ""
+#: ../vector/v.db.connect/main.c:339
+msgid "Select privileges were granted on the table"
+msgstr ""
+#: ../vector/v.db.connect/main.c:346
+msgid ""
+"For defining a new connection you have to specify these parameters: driver, "
+"database, table [, key [, layer]]"
+msgstr ""
+#: ../vector/v.net.allpairs/main.c:58 ../vector/v.net.distance/main.c:60
+#: ../vector/v.net.timetable/main.c:254 ../vector/v.net.path/main.c:41
+msgid "vector, network, shortest path"
+msgstr ""
+#: ../vector/v.net.allpairs/main.c:60
+msgid "Computes the shortest path between all pairs of nodes in the network."
+msgstr ""
+#: ../vector/v.net.allpairs/main.c:77 ../vector/v.net.centrality/main.c:115
+msgid "Name of arc forward/both direction(s) cost column"
+msgstr ""
+#: ../vector/v.net.allpairs/main.c:78 ../vector/v.net.allpairs/main.c:84
+#: ../vector/v.net.centrality/main.c:116 ../vector/v.net.centrality/main.c:122
+msgid "Cost"
+msgstr ""
+#: ../vector/v.net.allpairs/main.c:83 ../vector/v.net.centrality/main.c:121
+msgid "Name of arc backward direction cost column"
+msgstr ""
+#: ../vector/v.net.allpairs/main.c:93
+msgid "Add points on nodes without points"
+msgstr ""
+#: ../vector/v.net.allpairs/main.c:153 ../vector/v.net.flow/main.c:168
+#: ../vector/v.to.points/main.c:295 ../vector/v.in.dwg/main.c:219
+#: ../vector/v.convert/att.c:80 ../vector/v.net.components/main.c:147
+#: ../vector/v.surf.rst/main.c:613 ../vector/v.net.distance/main.c:208
+#: ../vector/v.in.ogr/main.c:780 ../vector/v.overlay/main.c:464
+#: ../vector/v.distance/main.c:822 ../vector/v.net.centrality/main.c:240
+#: ../vector/v.net.timetable/main.c:103 ../vector/v.net.path/path.c:109
+#: ../raster/r.contour/main.c:196
+#, c-format
+msgid "Unable to create table: '%s'"
+msgstr ""
+#: ../vector/v.net.allpairs/main.c:161 ../vector/v.net.flow/main.c:176
+#: ../vector/v.net.components/main.c:155 ../vector/v.net.distance/main.c:216
+#: ../vector/v.net.centrality/main.c:248 ../vector/v.net.timetable/main.c:112
+#: ../vector/v.net.path/path.c:117
+#, c-format
+msgid "Cannot grant privileges on table <%s>"
+msgstr ""
+#: ../vector/v.net.allpairs/main.c:209
+msgid "New points are excluded from shortest path calculations."
+msgstr ""
+#: ../vector/v.net.allpairs/main.c:219 ../vector/v.net.centrality/main.c:311
+msgid "Writing data into the table..."
+msgstr ""
+#: ../vector/v.net.allpairs/main.c:241 ../vector/v.net.flow/main.c:244
+#: ../vector/v.net.components/main.c:38 ../vector/v.net.distance/main.c:256
+#: ../vector/v.net.centrality/main.c:69 ../vector/v.net.timetable/main.c:134
+#: ../vector/v.net.timetable/main.c:156 ../vector/v.digit/attr.c:157
+#: ../vector/v.net.path/path.c:309 ../raster/r.random/random.c:194
+#, c-format
+msgid "Cannot insert new record: %s"
+msgstr ""
+#: ../vector/v.hull/main.c:141
+msgid "Simple planar hulls not implemented yet"
+msgstr ""
+#: ../vector/v.hull/main.c:275
+msgid "Produces a convex hull for a given vector map."
+msgstr ""
+#: ../vector/v.hull/main.c:279
+msgid "For vector lines reads their vertices"
+msgstr ""
+#: ../vector/v.hull/main.c:286
+msgid "Use all vector points (do not limit to current region)"
+msgstr ""
+#: ../vector/v.hull/main.c:291
+msgid "Create a 'flat' 2D hull even if the input is 3D points"
+msgstr ""
+#: ../vector/v.hull/main.c:314
+#, c-format
+msgid "Error loading vector points from <%s>"
+msgstr ""
+#: ../vector/v.hull/main.c:318
+msgid "Convex hull calculation requires at least three points. Exiting."
+msgstr ""
+#: ../vector/v.hull/main.c:320
+#, c-format
+msgid "%d points read from vector map <%s>"
+msgstr ""
+#: ../vector/v.net/nodes.c:85
+#, c-format
+msgid "%d new points written to output"
+msgstr ""
+#: ../vector/v.net/report.c:44
+#, c-format
+msgid "Line %d has no category"
+msgstr ""
+#: ../vector/v.net/report.c:67
+#, c-format
+msgid "Point not found: %.3lf %.3lf %.3lf line category: %d"
+msgstr ""
+#: ../vector/v.net/report.c:70
+#, c-format
+msgid "%d points found: %.3lf %.3lf %.3lf line category: %d"
+msgstr ""
+#: ../vector/v.net/main.c:47
+msgid "vector, networking, maintenance"
+msgstr ""
+#: ../vector/v.net/main.c:48
+msgid "Performs network maintenance."
+msgstr ""
+#: ../vector/v.net/main.c:55
+msgid "Name of input point vector map"
+msgstr ""
+#: ../vector/v.net/main.c:56
+msgid "Required for operation 'connect'"
+msgstr ""
+#: ../vector/v.net/main.c:71
+msgid ""
+"nodes;new point is placed on each node (line end) if doesn't exist;connect;"
+"connect still unconnected points to vector network by inserting new line(s);"
+"report;print to standard output {line_category start_point_category "
+"end_point_category};nreport;print to standard output {point_category "
+"line_category[,line_category...]}"
+msgstr ""
+#: ../vector/v.net/main.c:82 ../vector/v.net.alloc/main.c:80
+#: ../vector/v.net.salesman/main.c:114 ../vector/v.net.steiner/main.c:364
+#: ../vector/v.net.iso/main.c:89 ../vector/v.net.path/main.c:55
+#: ../display/d.path/main.c:71
+msgid "Arc layer"
+msgstr ""
+#: ../vector/v.net/main.c:88 ../vector/v.net.alloc/main.c:85
+#: ../vector/v.net.iso/main.c:94 ../vector/v.net.path/main.c:60
+#: ../display/d.path/main.c:76
+msgid "Node layer"
+msgstr ""
+#: ../vector/v.net/main.c:97
+msgid "Required for operation 'connect'. Connect points in given threshold."
+msgstr ""
+#: ../vector/v.net/main.c:101
+msgid "Assign unique categories to new points"
+msgstr ""
+#: ../vector/v.net/main.c:102
+msgid "For operation 'nodes'"
+msgstr ""
+#: ../vector/v.net/main.c:120
+msgid "Unknown operation"
+msgstr ""
+#: ../vector/v.net/main.c:124
+msgid "Output vector map must be specified"
+msgstr ""
+#: ../vector/v.net/main.c:129
+msgid "Point vector map must be specified"
+msgstr ""
+#: ../vector/v.net/main.c:132
+msgid "Threshold value must be specified"
+msgstr ""
+#: ../vector/v.net/main.c:137
+msgid "Threshold value must be >= 0"
+msgstr ""
+#: ../vector/v.net/main.c:174
+#, c-format
+msgid "Unable to open vector map <%s> at topology level %d"
+msgstr ""
+#: ../vector/v.net/main.c:190
+#, c-format
+msgid "%d arcs added to network (nlayer %d)"
+msgstr ""
+#: ../vector/v.clean/prune.c:217
+#, c-format
+msgid ""
+"\n"
+"%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
+msgstr ""
+#: ../vector/v.clean/prune.c:221
+#, c-format
+msgid "%d boundaries not pruned because pruning would damage topology"
+msgstr ""
+#: ../vector/v.clean/rmdac.c:61
+#, c-format
+msgid "Duplicate area centroids: %d"
+msgstr ""
+#: ../vector/v.clean/rmline.c:62
+#, c-format
+msgid "Lines / boundaries removed: %d"
+msgstr ""
+#: ../vector/v.clean/main.c:43 ../vector/v.build/main.c:34
+msgid "vector, topology"
+msgstr ""
+#: ../vector/v.clean/main.c:44
+msgid "Toolset for cleaning topology of vector map."
+msgstr ""
+#: ../vector/v.clean/main.c:53
+msgid "Name of output map where errors are written"
+msgstr ""
+#: ../vector/v.clean/main.c:64
+msgid "Cleaning tool"
+msgstr ""
+#: ../vector/v.clean/main.c:66
+msgid ""
+"break;break lines at each intersection;rmdupl;remove duplicate geometry "
+"features (pay attention to categories!);rmdangle;remove dangles, threshold "
+"ignored if < 0;chdangle;change the type of boundary dangle to line, "
+"threshold ignored if < 0, input line type is ignored;rmbridge;remove bridges "
+"connecting area and island or 2 islands;chbridge;change the type of bridges "
+"connecting area and island or 2 islands from boundary to line;snap;snap "
+"lines to vertex in threshold;rmdac;remove duplicate area centroids ('type' "
+"option ignored);bpol;break (topologically clean) polygons (imported from non "
+"topological format, like ShapeFile). Boundaries are broken on each point "
+"shared between 2 and more polygons where angles of segments are different;"
+"prune;remove vertices in threshold from lines and boundaries, boundary is "
+"pruned only if topology is not damaged (new intersection, changed "
+"attachement of centroid), first and last segment of the boundary is never "
+"changed;rmarea;remove small areas, the longest boundary with adjacent area "
+"is removed;rmline;remove all lines or boundaries of zero length, threshold "
+"is ignored;rmsa;remove small angles between lines at nodes"
+msgstr ""
+#: ../vector/v.clean/main.c:94
+msgid ""
+"Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
+msgstr ""
+#: ../vector/v.clean/main.c:100
+msgid "Don't build topology for the output vector"
+msgstr ""
+#: ../vector/v.clean/main.c:121
+msgid "You must select at least one tool"
+msgstr ""
+#: ../vector/v.clean/main.c:156
+msgid "Tool doesn't exist"
+msgstr ""
+#: ../vector/v.clean/main.c:176
+#, c-format
+msgid "Threshold for tool %d may not be > 0, set to 0"
+msgstr ""
+#: ../vector/v.clean/main.c:185
+msgid "Tool: Threshold"
+msgstr ""
+#: ../vector/v.clean/main.c:190
+msgid "Break"
+msgstr ""
+#: ../vector/v.clean/main.c:193
+msgid "Remove duplicates"
+msgstr ""
+#: ../vector/v.clean/main.c:196
+msgid "Remove dangles"
+msgstr ""
+#: ../vector/v.clean/main.c:199
+msgid "Change type of boundary dangles"
+msgstr ""
+#: ../vector/v.clean/main.c:203
+msgid "Remove bridges"
+msgstr ""
+#: ../vector/v.clean/main.c:206
+msgid "Change type of boundary bridges"
+msgstr ""
+#: ../vector/v.clean/main.c:210
+msgid "Snap vertices"
+msgstr ""
+#: ../vector/v.clean/main.c:213
+msgid "Remove duplicate area centroids"
+msgstr ""
+#: ../vector/v.clean/main.c:217
+msgid "Break polygons"
+msgstr ""
+#: ../vector/v.clean/main.c:220
+msgid "Prune"
+msgstr ""
+#: ../vector/v.clean/main.c:223
+msgid "Remove small areas"
+msgstr ""
+#: ../vector/v.clean/main.c:226
+msgid "Remove small angles at nodes"
+msgstr ""
+#: ../vector/v.clean/main.c:231
+msgid "Remove all lines or boundaries of zero length"
+msgstr ""
+#: ../vector/v.clean/main.c:273
+msgid "Copying vector lines..."
+msgstr ""
+#: ../vector/v.clean/main.c:295 ../vector/v.clean/main.c:305
+msgid "Rebuilding parts of topology..."
+msgstr ""
+#: ../vector/v.clean/main.c:313
+msgid "Tool: Break lines at intersections"
+msgstr ""
+#: ../vector/v.clean/main.c:317
+msgid "Tool: Remove duplicates"
+msgstr ""
+#: ../vector/v.clean/main.c:321
+msgid "Tool: Remove dangles"
+msgstr ""
+#: ../vector/v.clean/main.c:325
+msgid "Tool: Change type of boundary dangles"
+msgstr ""
+#: ../vector/v.clean/main.c:329
+msgid "Tool: Remove bridges"
+msgstr ""
+#: ../vector/v.clean/main.c:333
+msgid "Tool: Change type of boundary bridges"
+msgstr ""
+#: ../vector/v.clean/main.c:337
+msgid "Tool: Remove duplicate area centroids"
+msgstr ""
+#: ../vector/v.clean/main.c:341
+msgid "Tool: Snap line to vertex in threshold"
+msgstr ""
+#: ../vector/v.clean/main.c:345
+msgid "Tool: Break polygons"
+msgstr ""
+#: ../vector/v.clean/main.c:349
+msgid "Tool: Prune lines/boundaries"
+msgstr ""
+#: ../vector/v.clean/main.c:353
+msgid "Tool: Remove small areas"
+msgstr ""
+#: ../vector/v.clean/main.c:356
+#, c-format
+msgid "%d areas of total size %g removed"
+msgstr ""
+#: ../vector/v.clean/main.c:359
+msgid "Tool: Remove small angles at nodes"
+msgstr ""
+#: ../vector/v.clean/main.c:362
+#, c-format
+msgid "%d modifications done"
+msgstr ""
+#: ../vector/v.clean/main.c:365
+msgid "Tool: Remove all lines and boundaries of zero length"
+msgstr ""
+#: ../vector/v.clean/main.c:367
+#, c-format
+msgid "%d lines / boundaries removed"
+msgstr ""
+#: ../vector/v.clean/main.c:375
+msgid "Rebuilding topology for output vector map..."
+msgstr ""
+#: ../vector/v.clean/main.c:386
+msgid "Building topology for error vector map..."
+msgstr ""
+#: ../vector/v.parallel2/main.c:45
+msgid "Creates parallel line to input vector lines."
+msgstr ""
+#: ../vector/v.parallel2/main.c:57
+msgid "Offset along major axis in map units"
+msgstr ""
+#: ../vector/v.parallel2/main.c:65
+msgid "Offset along minor axis in map units"
+msgstr ""
+#: ../vector/v.parallel2/main.c:73 ../vector/v.buffer2/main.c:185
+msgid "Angle of major axis in degrees"
+msgstr ""
+#: ../vector/v.parallel2/main.c:82
+msgid "Side"
+msgstr ""
+#: ../vector/v.parallel2/main.c:84
+msgid ""
+"left;Parallel line is on the left;right;Parallel line is on the right;both;"
+"Parallel lines on both sides"
+msgstr ""
+#: ../vector/v.parallel2/main.c:94
+msgid "Tolerance of arc polylines in map units"
+msgstr ""
+#: ../vector/v.parallel2/main.c:98
+msgid "Make outside corners round"
+msgstr ""
+#: ../vector/v.parallel2/main.c:102
+msgid "Create buffer-like parallel lines"
+msgstr ""
+#: ../vector/v.net.flow/main.c:58
+msgid "vector, network, flow"
+msgstr ""
+#: ../vector/v.net.flow/main.c:60
+msgid "Computes the maximum flow between two sets of nodes in the network."
+msgstr ""
+#: ../vector/v.net.flow/main.c:71
+msgid "Name for output vector map containing a minimum cut"
+msgstr ""
+#: ../vector/v.net.flow/main.c:77
+msgid "Name of arc forward/both direction(s) capacity column"
+msgstr ""
+#: ../vector/v.net.flow/main.c:82
+msgid "Name of arc backward direction capacity column"
+msgstr ""
+#: ../vector/v.net.flow/main.c:86
+msgid "Source layer number or name"
+msgstr ""
+#: ../vector/v.net.flow/main.c:87 ../vector/v.net.flow/main.c:92
+#: ../vector/v.net.flow/main.c:98 ../vector/v.proj/main.c:70
+#: ../vector/v.proj/main.c:87 ../vector/v.proj/main.c:96
+#: ../raster/r.proj/main.c:137 ../raster/r.proj/main.c:154
+#: ../raster/r.proj/main.c:163 ../raster/r.proj.seg/main.c:146
+#: ../raster/r.proj.seg/main.c:163 ../raster/r.proj.seg/main.c:172
+msgid "Source"
+msgstr ""
+#: ../vector/v.net.flow/main.c:91
+msgid "Source category values"
+msgstr ""
+#: ../vector/v.net.flow/main.c:97
+msgid "Source WHERE conditions of SQL statement without 'where' keyword"
+msgstr ""
+#: ../vector/v.net.flow/main.c:102
+msgid "Sink layer number or name"
+msgstr ""
+#: ../vector/v.net.flow/main.c:103 ../vector/v.net.flow/main.c:108
+#: ../vector/v.net.flow/main.c:114
+msgid "Sink"
+msgstr ""
+#: ../vector/v.net.flow/main.c:107
+msgid "Sink category values"
+msgstr ""
+#: ../vector/v.net.flow/main.c:113
+msgid "Sink WHERE conditions of SQL statement without 'where' keyword"
+msgstr ""
+#: ../vector/v.net.flow/main.c:186 ../vector/v.net.flow/main.c:191
+#: ../vector/v.net.connectivity/main.c:130
+#: ../vector/v.net.connectivity/main.c:135
+#, c-format
+msgid "Neither %s nor %s was given"
+msgstr ""
+#: ../vector/v.net.flow/main.c:199
+msgid "No sources"
+msgstr ""
+#: ../vector/v.net.flow/main.c:202
+msgid "No sinks"
+msgstr ""
+#: ../vector/v.net.flow/main.c:224
+msgid "Writing the output..."
+msgstr ""
+#: ../vector/v.out.vtk/head.c:27
+msgid "writeVTKHeader: Writing VTK-Header"
+msgstr ""
+#: ../vector/v.out.vtk/writeVTK.c:187
+msgid ""
+"No coordinates to generate the output! Maybe an empty vector type chosen?"
+msgstr ""
+#: ../vector/v.out.vtk/writeVTK.c:575 ../vector/v.out.ogr/main.c:1061
+#, c-format
+msgid "Cannot select attributes for cat = %d"
+msgstr ""
+#: ../vector/v.out.vtk/writeVTK.c:622
+msgid "Cannot export attribute table fields for layer < 1. Skipping export"
+msgstr ""
+#: ../vector/v.out.vtk/writeVTK.c:630
+msgid "No attribute table found"
+msgstr ""
+#: ../vector/v.out.vtk/writeVTK.c:662
+msgid "No numerical attributes found. Skipping export"
+msgstr ""
+#: ../vector/v.out.vtk/writeVTK.c:716 ../vector/v.out.vtk/writeVTK.c:743
+#: ../vector/v.out.vtk/writeVTK.c:770 ../vector/v.out.vtk/writeVTK.c:796
+#, c-format
+msgid "Error reading value of attribute '%s'"
+msgstr ""
+#: ../vector/v.out.vtk/main.c:46 ../vector/v.out.pov/main.c:43
+#: ../vector/v.out.svg/main.c:73 ../vector/v.out.dxf/main.c:48
+#: ../vector/v.out.ogr/main.c:96 ../vector/v.out.ascii/out.c:45
+msgid "vector, export"
+msgstr ""
+#: ../vector/v.out.vtk/main.c:48
+msgid "Converts a GRASS binary vector map to VTK ASCII output."
+msgstr ""
+#: ../vector/v.out.vtk/main.c:58
+msgid "Path to resulting VTK file"
+msgstr ""
+#: ../vector/v.out.vtk/main.c:93
+msgid "Export numeric attribute table fields as VTK scalar variables"
+msgstr ""
+#: ../vector/v.out.vtk/main.c:186 ../vector/v.out.ascii/out.c:140
+msgid "Failed to interpret 'dp' parameter as an integer"
+msgstr ""
+#: ../vector/v.out.vtk/main.c:188
+msgid "dp has to be from 0 to 8"
+msgstr ""
+#: ../vector/v.out.vtk/main.c:197
+msgid "Failed to interpret 'layer' parameter as an integer"
+msgstr ""
+#: ../vector/v.net.alloc/main.c:61
+msgid "vector, network, allocation"
+msgstr ""
+#: ../vector/v.net.alloc/main.c:63
+msgid "Allocate subnets for nearest centres (direction from centre)."
+msgstr ""
+#: ../vector/v.net.alloc/main.c:65
+msgid ""
+"Centre node must be opened (costs >= 0). Costs of centre node are used in "
+"calculation"
+msgstr ""
+#: ../vector/v.net.alloc/main.c:75 ../vector/v.net.salesman/main.c:110
+#: ../vector/v.net.steiner/main.c:359 ../vector/v.net.iso/main.c:85
+#: ../vector/v.net.path/main.c:50 ../display/d.path/main.c:59
+msgid "Arc type"
+msgstr ""
+#: ../vector/v.net.alloc/main.c:92 ../vector/v.net.iso/main.c:99
+msgid "Arc forward/both direction(s) cost column (number)"
+msgstr ""
+#: ../vector/v.net.alloc/main.c:98 ../vector/v.net.iso/main.c:103
+msgid "Arc backward direction cost column (number)"
+msgstr ""
+#: ../vector/v.net.alloc/main.c:104 ../vector/v.net.iso/main.c:107
+msgid "Node cost column (number)"
+msgstr ""
+#: ../vector/v.net.alloc/main.c:110
+msgid ""
+"Categories of centres (points on nodes) to which net will be allocated, "
+"layer for this categories is given by nlayer option"
+msgstr ""
+#: ../vector/v.net.alloc/main.c:186
+#, c-format
+msgid "Number of centres: [%d] (nlayer: [%d])"
+msgstr ""
+#: ../vector/v.net.alloc/main.c:189 ../vector/v.net.iso/main.c:227
+msgid "Not enough centres for selected nlayer. Nothing will be allocated."
+msgstr ""
+#: ../vector/v.net.alloc/main.c:200
+msgid "Calculating costs from centres ..."
+msgstr ""
+#: ../vector/v.net.alloc/main.c:340 ../vector/v.net.alloc/main.c:351
+#: ../vector/v.net.iso/main.c:508
+msgid "Cannot get line segment, segment out of line"
+msgstr ""
+#: ../vector/v.neighbors/main.c:48
+msgid "vector, raster, aggregation"
+msgstr ""
+#: ../vector/v.in.sites/main.c:57
+msgid "vector, import, sites"
+msgstr ""
+#: ../vector/v.in.sites/main.c:59
+msgid "Converts a GRASS site_lists file into a vector map."
+msgstr ""
+#: ../vector/v.in.sites/main.c:83
+#, c-format
+msgid "Site file <%s> not found"
+msgstr ""
+#: ../vector/v.in.sites/main.c:86
+#, c-format
+msgid "Unable to open site file <%s@%s>"
+msgstr ""
+#: ../vector/v.in.sites/main.c:89
+msgid "Unable to guess site_list format"
+msgstr ""
+#: ../vector/v.in.sites/main.c:92
+msgid "Failed to allocate site structure"
+msgstr ""
+#: ../vector/v.in.sites/main.c:94
+#, c-format
+msgid "Input format: dimension: %d strings: %d FP: %d"
+msgstr ""
+#: ../vector/v.in.sites/main.c:98
+msgid "Floating point category values, using sequential integer for category"
+msgstr ""
+#: ../vector/v.in.sites/main.c:101
+msgid "No category values, using sequential integer for category"
+msgstr ""
+#: ../vector/v.in.sites/main.c:183
+msgid "Transferring sites to vector point map..."
+msgstr ""
+#: ../vector/v.in.sites/main.c:255
+#, c-format
+msgid "%d sites written."
+msgstr ""
+#: ../vector/v.info/main.c:63
+msgid "vector, metadata, history"
+msgstr ""
+#: ../vector/v.info/main.c:65
+msgid "Outputs basic information about a user-specified vector map."
+msgstr ""
+#: ../vector/v.info/main.c:74
+msgid "Print vector history instead of info"
+msgstr ""
+#: ../vector/v.info/main.c:80
+msgid "Print types/names of table columns for specified layer instead of info"
+msgstr ""
+#: ../vector/v.info/main.c:85 ../raster/r.info/main.c:90
+msgid "Print map region only"
+msgstr ""
+#: ../vector/v.info/main.c:90 ../raster/r.info/main.c:106
+msgid "Print map title only"
+msgstr ""
+#: ../vector/v.info/main.c:95
+msgid "Print topology information only"
+msgstr ""
+#: ../vector/v.info/main.c:205
+#, c-format
+msgid "Displaying column types/names for database connection of layer %d:"
+msgstr ""
+#: ../vector/v.info/main.c:212 ../vector/v.convert/att.c:67
+#, c-format
+msgid "Unable to open driver <%s>"
+msgstr ""
+#: ../vector/v.info/main.c:240
+#, c-format
+msgid "Layer:           %s"
+msgstr ""
+#: ../vector/v.info/main.c:242
+#, c-format
+msgid "Mapset:          %s"
+msgstr ""
+#: ../vector/v.info/main.c:244
+#, c-format
+msgid "Location:        %s"
+msgstr ""
+#: ../vector/v.info/main.c:246
+#, c-format
+msgid "Database:        %s"
+msgstr ""
+#: ../vector/v.info/main.c:248
+#, c-format
+msgid "Title:           %s"
+msgstr ""
+#: ../vector/v.info/main.c:250
+#, c-format
+msgid "Map scale:       1:%d"
+msgstr ""
+#: ../vector/v.info/main.c:252
+#, c-format
+msgid "Map format:      %s"
+msgstr ""
+#: ../vector/v.info/main.c:254
+#, c-format
+msgid "Name of creator: %s"
+msgstr ""
+#: ../vector/v.info/main.c:256
+#, c-format
+msgid "Organization:    %s"
+msgstr ""
+#: ../vector/v.info/main.c:259
+#, c-format
+msgid "Source date:     %s"
+msgstr ""
+#: ../vector/v.info/main.c:264
+#, c-format
+msgid "  Type of Map:  %s (level: %i)        "
+msgstr ""
+#: ../vector/v.info/main.c:272
+#, c-format
+msgid "  Number of points:       %-9ld       Number of areas:      %-9ld"
+msgstr ""
+#: ../vector/v.info/main.c:277
+#, c-format
+msgid "  Number of lines:        %-9ld       Number of islands:    %-9ld"
+msgstr ""
+#: ../vector/v.info/main.c:282
+#, c-format
+msgid "  Number of boundaries:   %-9ld       Number of faces:      %-9ld"
+msgstr ""
+#: ../vector/v.info/main.c:287
+#, c-format
+msgid "  Number of centroids:    %-9ld       Number of kernels:    %-9ld"
+msgstr ""
+#: ../vector/v.info/main.c:292
+#, c-format
+msgid "  Map is 3D:              %s"
+msgstr ""
+#: ../vector/v.info/main.c:295
+#, c-format
+msgid "  Number of dblinks:      %-9ld"
+msgstr ""
+#: ../vector/v.info/main.c:304
+#, c-format
+msgid "        Projection: %s (zone %d)"
+msgstr ""
+#: ../vector/v.info/main.c:307
+#, c-format
+msgid "        Projection: %s"
+msgstr ""
+#: ../vector/v.info/main.c:332
+#, c-format
+msgid "  Digitization threshold: %s"
+msgstr ""
+#: ../vector/v.info/main.c:334
+#, c-format
+msgid "  Comments:"
+msgstr ""
+#: ../vector/v.net.salesman/main.c:97
+msgid "vector, network, salesman"
+msgstr ""
+#: ../vector/v.net.salesman/main.c:99
+msgid "Creates a cycle connecting given nodes (Traveling salesman problem)."
+msgstr ""
+#: ../vector/v.net.salesman/main.c:101
+msgid ""
+"Note that TSP is NP-hard, heuristic algorithm is used by this module and "
+"created cycle may be sub optimal"
+msgstr ""
+#: ../vector/v.net.salesman/main.c:119
+msgid "Node layer (used for cities)"
+msgstr ""
+#: ../vector/v.net.salesman/main.c:125 ../vector/v.net.steiner/main.c:375
+msgid "Arcs' cost column (for both directions)"
+msgstr ""
+#: ../vector/v.net.salesman/main.c:130
+msgid "Categories of points ('cities') on nodes (layer is specified by nlayer)"
+msgstr ""
+#: ../vector/v.net.salesman/main.c:193
+#, c-format
+msgid "Number of cities: [%d]"
+msgstr ""
+#: ../vector/v.net.salesman/main.c:195
+msgid "Not enough cities (< 2)"
+msgstr ""
+#: ../vector/v.net.salesman/main.c:227
+#, c-format
+msgid "Destination node [%d] is unreachable from node [%d]"
+msgstr ""
+#: ../vector/v.to.points/main.c:63 ../vector/v.convert/att.c:110
+#: ../vector/v.overlay/area_area.c:238 ../vector/v.overlay/line_area.c:217
+#: ../raster/r.contour/main.c:224
+#, c-format
+msgid "Unable to insert new record: '%s'"
+msgstr ""
+#: ../vector/v.to.points/main.c:175
+msgid "Create points along input lines in new vector with 2 layers."
+msgstr ""
+#: ../vector/v.to.points/main.c:182
+msgid "Output vector map where points will be written"
+msgstr ""
+#: ../vector/v.to.points/main.c:194
+msgid "Write line nodes"
+msgstr ""
+#: ../vector/v.to.points/main.c:198
+msgid "Write line vertices"
+msgstr ""
+#: ../vector/v.to.points/main.c:202
+msgid "Interpolate points between line vertices"
+msgstr ""
+#: ../vector/v.to.points/main.c:209
+msgid "Maximum distance between points in map units"
+msgstr ""
+#: ../vector/v.to.points/main.c:213 ../vector/v.voronoi/vo_main.c:140
+#: ../vector/v.in.ogr/main.c:215 ../vector/v.overlay/main.c:120
+#: ../vector/v.select/args.c:80
+msgid "Do not create attribute table"
+msgstr ""
+#: ../vector/v.to.points/main.c:229
+msgid "Use either -n or -v flag, not both"
+msgstr ""
+#: ../vector/v.to.points/main.c:273 ../vector/v.generalize/misc.c:175
+#, c-format
+msgid "Unable to copy table <%s>"
+msgstr ""
+#: ../vector/v.to.points/main.c:384
+#, c-format
+msgid "%d points written to output vector map"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:58
+#, c-format
+msgid "Init costs from node %d"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:345
+msgid "vector, network, steiner tree"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:347
+msgid "Create Steiner tree for the network and given terminals"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:349
+msgid ""
+"Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm "
+"is used in this module so the result may be sub optimal"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:369
+msgid "Node layer (used for terminals)"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:381
+msgid "Categories of points on terminals (layer is specified by nlayer)"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:389
+msgid "Number of steiner points (-1 for all possible)"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:453
+msgid "Not enough terminals (< 2)"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:459
+msgid "Requested number of Steiner points > than possible"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:511
+#, c-format
+msgid "Terminal at node [%d] cannot be connected to terminal at node [%d]"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:527
+#, c-format
+msgid ""
+"[%d] (not reachable) nodes removed from list of Steiner point candidates"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:532
+#, c-format
+msgid "MST costs = %f"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:538
+#, c-format
+msgid "Search for [%d]. Steiner point"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:559
+#, c-format
+msgid "Steiner point at node [%d] was added to terminals (MST costs = %f)"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:571
+msgid "No Steiner point found -> leaving cycle"
+msgstr ""
+#: ../vector/v.to.db/lines.c:74 ../vector/v.to.db/query.c:23
+#: ../vector/v.to.rast/do_lines.c:35
+msgid "Reading features..."
+msgstr ""
+#: ../vector/v.to.db/query.c:83 ../vector/v.to.db/update.c:28
+#: ../vector/v.to.db/update.c:32 ../vector/v.to.db/main.c:48
+#, c-format
+msgid "Database connection not defined for layer %d. Use v.db.connect first."
+msgstr ""
+#: ../vector/v.to.db/query.c:93
+msgid "Querying database... "
+msgstr ""
+#: ../vector/v.to.db/query.c:108
+#, c-format
+msgid ""
+"Query for category '0' (no category) was not executed because of too many "
+"(%d) query categories. All later reported values for cat 0 are not valid."
+msgstr ""
+#: ../vector/v.to.db/query.c:145
+#, c-format
+msgid "Multiple query results, output value set to NULL (category [%d])"
+msgstr ""
+#: ../vector/v.to.db/query.c:152
+msgid "Unable to fetch record"
+msgstr ""
+#: ../vector/v.to.db/parse.c:38
+msgid "For coor valid point/centroid, for length valid line/boundary"
+msgstr ""
+#: ../vector/v.to.db/parse.c:42
+msgid "Layer number (write to)"
+msgstr ""
+#: ../vector/v.to.db/parse.c:46
+msgid "Query layer number (read from)"
+msgstr ""
+#: ../vector/v.to.db/parse.c:56
+msgid "Value to upload"
+msgstr ""
+#: ../vector/v.to.db/parse.c:85 ../raster/r.report/parse.c:44
+msgid "Units"
+msgstr ""
+#: ../vector/v.to.db/parse.c:87
+msgid ""
+"mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d(egrees)"
+msgstr ""
+#: ../vector/v.to.db/parse.c:93
+msgid "Name of attribute column used for 'query' option"
+msgstr ""
+#: ../vector/v.to.db/parse.c:94
+msgid "E.g. 'cat', 'count(*)', 'sum(val)'"
+msgstr ""
+#: ../vector/v.to.db/parse.c:103
+msgid "Print only"
+msgstr ""
+#: ../vector/v.to.db/parse.c:108
+msgid "Only print SQL statements"
+msgstr ""
+#: ../vector/v.to.db/parse.c:114
+msgid "In print mode prints totals for options: length,area,count"
+msgstr ""
+#: ../vector/v.to.db/parse.c:153
+msgid "This option requires one column"
+msgstr ""
+#: ../vector/v.to.db/parse.c:158
+msgid "This option requires two columns"
+msgstr ""
+#: ../vector/v.to.db/parse.c:163
+msgid "This option requires at least two columns"
+msgstr ""
+#: ../vector/v.to.db/parse.c:169
+msgid "Parameter 'qcolumn' must be specified for 'option=query'"
+msgstr ""
+#: ../vector/v.to.db/parse.c:174
+msgid "The 'sides' option makes sense only for boundaries"
+msgstr ""
+#: ../vector/v.to.db/parse.c:177
+msgid "The 'sinuous' option makes sense only for lines"
+msgstr ""
+#: ../vector/v.to.db/parse.c:180
+msgid "The 'azimuth' option makes sense only for lines"
+msgstr ""
+#: ../vector/v.to.db/areas.c:28 ../vector/v.to.rast/do_areas.c:33
+msgid "Reading areas..."
+msgstr ""
+#: ../vector/v.to.db/update.c:82
+msgid "Updating database..."
+msgstr ""
+#: ../vector/v.to.db/update.c:115
+#, c-format
+msgid "More elements of category %d, nothing loaded to database"
+msgstr ""
+#: ../vector/v.to.db/update.c:213
+#, c-format
+msgid "Record (cat %d) already exists (not inserted)"
+msgstr ""
+#: ../vector/v.to.db/report.c:187
+#, c-format
+msgid "%d categories read from vector map (layer %d)"
+msgstr ""
+#: ../vector/v.to.db/report.c:191
+#, c-format
+msgid "%d records selected from table (layer %d)"
+msgstr ""
+#: ../vector/v.to.db/report.c:194
+#, c-format
+msgid "%d categories read from vector map exist in selection from table"
+msgstr ""
+#: ../vector/v.to.db/report.c:197
+#, c-format
+msgid "%d categories read from vector map don't exist in selection from table"
+msgstr ""
+#: ../vector/v.to.db/report.c:199
+#, c-format
+msgid "%d records updated/inserted (layer %d)"
+msgstr ""
+#: ../vector/v.to.db/report.c:202
+#, c-format
+msgid "%d update/insert errors (layer %d)"
+msgstr ""
+#: ../vector/v.to.db/report.c:205
+#, c-format
+msgid "%d categories with more points (coordinates not loaded)"
+msgstr ""
+#: ../vector/v.to.db/main.c:34
+msgid "Populates database values from vector features."
+msgstr ""
+#: ../vector/v.qcount/main.c:70
+msgid "Indices for quadrat counts of sites lists."
+msgstr ""
+#: ../vector/v.qcount/main.c:76
+msgid "Vector of points defining sample points"
+msgstr ""
+#: ../vector/v.qcount/main.c:84
+msgid "Output quadrant centres, number of points is written as category"
+msgstr ""
+#: ../vector/v.qcount/main.c:91
+msgid "Number of quadrats"
+msgstr ""
+#: ../vector/v.qcount/main.c:98
+msgid "Quadrat radius"
+msgstr ""
+#: ../vector/v.qcount/main.c:103
+msgid "Print results in shell script style"
+msgstr ""
+#: ../vector/v.qcount/main.c:134
+msgid "Finding quadrats..."
+msgstr ""
+#: ../vector/v.qcount/main.c:139
+msgid "Counting sites in quadrats..."
+msgstr ""
+#: ../vector/v.in.region/main.c:39
+msgid "Creates a vector polygon from the current region extent."
+msgstr ""
+#: ../vector/v.in.region/main.c:47
+msgid "Select type: line or area"
+msgstr ""
+#: ../vector/v.proj/main.c:63
+msgid "vector, projection, transformation"
+msgstr ""
+#: ../vector/v.proj/main.c:64
+msgid "Re-projects a vector map from one location to the current location."
+msgstr ""
+#: ../vector/v.proj/main.c:76
+msgid "Location containing input vector map"
+msgstr ""
+#: ../vector/v.proj/main.c:84
+msgid "Mapset containing input vector map"
+msgstr ""
+#: ../vector/v.proj/main.c:93 ../raster/r.proj/main.c:160
+#: ../raster/r.proj.seg/main.c:169
+msgid "Path to GRASS database of input location"
+msgstr ""
+#: ../vector/v.proj/main.c:100
+msgid "Name for output vector map (default: input)"
+msgstr ""
+#: ../vector/v.proj/main.c:101 ../vector/v.proj/main.c:113
+#: ../raster/r.proj/main.c:168 ../raster/r.proj/main.c:179
+#: ../raster/r.proj/main.c:186 ../raster/r.proj.seg/main.c:177
+#: ../raster/r.proj.seg/main.c:188 ../raster/r.proj.seg/main.c:201
+#: ../raster/r.proj.seg/main.c:215 ../raster/r.proj.seg/main.c:221
+msgid "Target"
+msgstr ""
+#: ../vector/v.proj/main.c:105
+msgid "List vector maps in input location and exit"
+msgstr ""
+#: ../vector/v.proj/main.c:109
+msgid "3D vector maps only"
+msgstr ""
+#: ../vector/v.proj/main.c:111
+msgid "Assume z co-ordinate is ellipsoidal height and transform if possible"
+msgstr ""
+#: ../vector/v.proj/main.c:132 ../raster/r.proj/main.c:217
+#: ../raster/r.proj.seg/main.c:245
+#, c-format
+msgid "option <%s>: <%s> exists."
+msgstr ""
+#: ../vector/v.proj/main.c:149 ../raster/r.proj/main.c:222
+#: ../raster/r.proj.seg/main.c:251
+msgid "Input and output locations can not be the same"
+msgstr ""
+#: ../vector/v.proj/main.c:169 ../raster/r.proj/main.c:252
+#: ../raster/r.proj.seg/main.c:287
+#, c-format
+msgid "Checking location <%s> mapset <%s>"
+msgstr ""
+#: ../vector/v.proj/main.c:181 ../vector/v.in.ogr/main.c:274
+#: ../vector/v.in.ogr/main.c:326 ../vector/v.select/main.c:90
+#: ../raster/r.proj/main.c:264 ../raster/r.in.gdal/main.c:219
+#: ../raster/r.proj.seg/main.c:299 ../raster/r.out.gdal/main.c:230
+#, c-format
+msgid "Required parameter <%s> not set"
+msgstr ""
+#: ../vector/v.proj/main.c:188
+#, c-format
+msgid "Vector map <%s> in location <%s> mapset <%s> not found"
+msgstr ""
+#: ../vector/v.proj/main.c:211
+#, c-format
+msgid "Mapset <%s> in input location <%s> - permission denied"
+msgstr ""
+#: ../vector/v.proj/main.c:214
+#, c-format
+msgid "Mapset <%s> in input location <%s> not found"
+msgstr ""
+#: ../vector/v.proj/main.c:270
+#, c-format
+msgid "Reprojecting primitives: "
+msgstr ""
+#: ../vector/v.proj/main.c:281
+msgid "Reading input vector map"
+msgstr ""
+#: ../vector/v.proj/main.c:287
+msgid "Error in pj_do_transform"
+msgstr ""
+#: ../vector/v.db.select/main.c:54
+msgid "Prints vector map attributes."
+msgstr ""
+#: ../vector/v.db.select/main.c:89
+msgid ""
+"Print minimal region extent of selected vector features instead of attributes"
+msgstr ""
+#: ../vector/v.db.select/main.c:141
+#, c-format
+msgid ""
+"Unable to open vector map <%s> at topology level. Flag '%c' requires "
+"topology level."
+msgstr ""
+#: ../vector/v.db.select/main.c:176
+msgid "Unable to open select cursor"
+msgstr ""
+#: ../vector/v.db.select/main.c:243
+#, c-format
+msgid "Unable to get bounding box of area %d"
+msgstr ""
+#: ../vector/v.db.select/main.c:248
+#, c-format
+msgid "Unable to get bounding box of line %d"
+msgstr ""
+#: ../vector/v.extrude/main.c:69
+msgid "vector, geometry, 3D"
+msgstr ""
+#: ../vector/v.extrude/main.c:71
+msgid "Extrudes flat vector object to 3D with defined height."
+msgstr ""
+#: ../vector/v.extrude/main.c:75
+msgid "Trace elevation"
+msgstr ""
+#: ../vector/v.extrude/main.c:78
+msgid "Name of input 2D vector map"
+msgstr ""
+#: ../vector/v.extrude/main.c:81
+msgid "Name of resulting 3D vector map"
+msgstr ""
+#: ../vector/v.extrude/main.c:85 ../vector/v.transform/main.c:139
+msgid "Shifting value for z coordinates"
+msgstr ""
+#: ../vector/v.extrude/main.c:93
+msgid "Elevation raster for height extraction"
+msgstr ""
+#: ../vector/v.extrude/main.c:100
+msgid "Fixed height for 3D vector objects"
+msgstr ""
+#: ../vector/v.extrude/main.c:105
+msgid "Name of attribute column with object heights"
+msgstr ""
+#: ../vector/v.extrude/main.c:119
+#, c-format
+msgid "One of '%s' or '%s' parameters must be set"
+msgstr ""
+#: ../vector/v.extrude/main.c:194
+msgid "Extruding areas..."
+msgstr ""
+#: ../vector/v.extrude/main.c:204 ../vector/v.out.svg/main.c:215
+#, c-format
+msgid "Skipping area %d without centroid"
+msgstr ""
+#: ../vector/v.extrude/main.c:219
+#, c-format
+msgid "Cannot select attributes for area %d"
+msgstr ""
+#: ../vector/v.extrude/main.c:258
+msgid "Extruding vector primitives..."
+msgstr ""
+#: ../vector/v.extrude/main.c:291
+#, c-format
+msgid "Cannot select attributes for area #%d"
+msgstr ""
+#: ../vector/v.extrude/main.c:309
+#, c-format
+msgid "Column <%s>: invalid data type"
+msgstr ""
+#: ../vector/v.generalize/misc.c:206 ../vector/v.generalize/misc.c:219
+#, c-format
+msgid "'%s' must be > 0 for '%s'"
+msgstr ""
+#: ../vector/v.generalize/misc.c:208
+msgid "'where' and 'cats' parameters were supplied, cat will be ignored"
+msgstr ""
+#: ../vector/v.generalize/misc.c:214
+msgid "Unable to load data from database"
+msgstr ""
+#: ../vector/v.generalize/misc.c:225
+msgid "Problem loading category values"
+msgstr ""
+#: ../vector/v.generalize/displacement.c:78 ../raster/r.contour/main.c:244
+msgid "Reading data..."
+msgstr ""
+#: ../vector/v.generalize/displacement.c:196
+msgid "Inverting matrix..."
+msgstr ""
+#: ../vector/v.generalize/displacement.c:198
+msgid "Unable to calculate the inverse matrix"
+msgstr ""
+#: ../vector/v.generalize/displacement.c:201
+msgid "Resolving conflicts..."
+msgstr ""
+#: ../vector/v.generalize/smoothing.c:85
+#: ../vector/v.generalize/smoothing.c:145
+msgid "Look ahead parameter must be odd"
+msgstr ""
+#: ../vector/v.generalize/smoothing.c:480
+msgid "Unable to find the inverse matrix"
+msgstr ""
+#: ../vector/v.generalize/smoothing.c:487
+msgid "Unable to calculate the output vectors"
+msgstr ""
+#: ../vector/v.generalize/network.c:163
+msgid "Calculating centrality measures..."
+msgstr ""
+#: ../vector/v.generalize/main.c:76
+msgid ""
+"vector, generalization, simplification, smoothing, displacement, network "
+"generalization"
+msgstr ""
+#: ../vector/v.generalize/main.c:77
+msgid "Vector based generalization."
+msgstr ""
+#: ../vector/v.generalize/main.c:94
+msgid ""
+"douglas;Douglas-Peucker Algorithm;douglas_reduction;Douglas-Peucker "
+"Algorithm with reduction parameter;lang;Lang Simplification Algorithm;"
+"reduction;Vertex Reduction Algorithm eliminates points close to each other;"
+"reumann;Reumann-Witkam Algorithm;boyle;Boyle's Forward-Looking Algorithm;"
+"sliding_averaging;McMaster's Sliding Averaging Algorithm;distance_weighting;"
+"McMaster's Distance-Weighting Algorithm;chaiken;Chaiken's Algorithm;hermite;"
+"Interpolation by Cubic Hermite Splines;snakes;Snakes method for line "
+"smoothing;network;Network generalization;displacement;Displacement of lines "
+"close to each other;"
+msgstr ""
+#: ../vector/v.generalize/main.c:108
+msgid "Generalization algorithm"
+msgstr ""
+#: ../vector/v.generalize/main.c:115
+msgid "Maximal tolerance value"
+msgstr ""
+#: ../vector/v.generalize/main.c:122
+msgid "Look-ahead parameter"
+msgstr ""
+#: ../vector/v.generalize/main.c:131
+msgid "Percentage of the points in the output of 'douglas_reduction' algorithm"
+msgstr ""
+#: ../vector/v.generalize/main.c:140
+msgid "Slide of computed point toward the original point"
+msgstr ""
+#: ../vector/v.generalize/main.c:149
+msgid "Minimum angle between two consecutive segments in Hermite method"
+msgstr ""
+#: ../vector/v.generalize/main.c:157
+msgid "Degree threshold in network generalization"
+msgstr ""
+#: ../vector/v.generalize/main.c:166
+msgid "Closeness threshold in network generalization"
+msgstr ""
+#: ../vector/v.generalize/main.c:174
+msgid "Betweeness threshold in network generalization"
+msgstr ""
+#: ../vector/v.generalize/main.c:181
+msgid "Snakes alpha parameter"
+msgstr ""
+#: ../vector/v.generalize/main.c:188
+msgid "Snakes beta parameter"
+msgstr ""
+#: ../vector/v.generalize/main.c:195
+msgid "Number of iterations"
+msgstr ""
+#: ../vector/v.generalize/main.c:203
+msgid "Copy attributes"
+msgstr ""
+#: ../vector/v.generalize/main.c:208 ../vector/v.buffer2/main.c:217
+#: ../raster/r.sun2/main.c:502
+msgid "This does nothing. It is retained for backwards compatibility"
+msgstr ""
+#: ../vector/v.generalize/main.c:209 ../vector/v.build.polylines/main.c:128
+#: ../vector/v.buffer2/main.c:215 ../vector/v.buffer2/main.c:227
+#: ../raster/r.sun2/main.c:503
+msgid "Unused"
+msgstr ""
+#: ../vector/v.generalize/main.c:262
+msgid "Unknown method"
+msgstr ""
+#: ../vector/v.generalize/main.c:322
+msgid "Displacement..."
+msgstr ""
+#: ../vector/v.generalize/main.c:331
+msgid "Network generalization..."
+msgstr ""
+#: ../vector/v.generalize/main.c:346
+msgid "Attributes are needed for 'where' option, copying table"
+msgstr ""
+#: ../vector/v.generalize/main.c:368
+#, c-format
+msgid "Generalization (%s)..."
+msgstr ""
+#: ../vector/v.generalize/main.c:462
+#, c-format
+msgid "Method '%s' did not preserve first point"
+msgstr ""
+#: ../vector/v.generalize/main.c:467
+#, c-format
+msgid "Method '%s' did not preserve last point"
+msgstr ""
+#: ../vector/v.generalize/main.c:494
+#, c-format
+msgid ""
+"%d boundaries were not modified because modification would damage topology"
+msgstr ""
+#: ../vector/v.generalize/main.c:497
+#, c-format
+msgid "%d lines/boundaries were not modified due to over-simplification"
+msgstr ""
+#: ../vector/v.generalize/main.c:512
+#, c-format
+msgid "Number of vertices for selected lines %s from %d to %d (%d%%)."
+msgstr ""
+#: ../vector/v.generalize/main.c:513
+msgid "reduced"
+msgstr ""
+msgid "changed"
+msgstr ""
+#: ../vector/v.in.dwg/main.c:66
+msgid "Converts DWG/DXF to GRASS vector map"
+msgstr ""
+#: ../vector/v.in.dwg/main.c:69
+msgid "Name of DWG or DXF file"
+msgstr ""
+#: ../vector/v.in.dwg/main.c:79 ../vector/v.in.dxf/main.c:107
+msgid "List of layers to import"
+msgstr ""
+#: ../vector/v.in.dwg/main.c:84 ../vector/v.in.dxf/main.c:88
+msgid "Invert selection by layers (don't import layers in list)"
+msgstr ""
+#: ../vector/v.in.dwg/main.c:92
+msgid "Write circles as points (centre)"
+msgstr ""
+#: ../vector/v.in.dwg/main.c:100
+msgid "Use numeric type for attribute \"layer\""
+msgstr ""
+#: ../vector/v.in.dwg/main.c:120
+#, c-format
+msgid "Unable to initialize OpenDWG Toolkit, error: %d: %s."
+msgstr ""
+#: ../vector/v.in.dwg/main.c:123
+#, c-format
+msgid "%s Cannot open %s"
+msgstr ""
+#: ../vector/v.in.dwg/main.c:131
+#, c-format
+msgid "Unable to open input file <%s>. Error %d: %s"
+msgstr ""
+#: ../vector/v.in.dwg/main.c:266
+#, c-format
+msgid "%d elements skipped (layer name was not in list)"
+msgstr ""
+#: ../vector/v.in.dwg/main.c:269
+#, c-format
+msgid "%d elements processed"
+msgstr ""
+#: ../vector/v.buffer/main.c:223 ../vector/v.overlay/main.c:494
+msgid "Rebuilding topology..."
+msgstr ""
+#: ../vector/v.buffer/main.c:254
+msgid "vector, geometry, buffer"
+msgstr ""
+#: ../vector/v.buffer/main.c:256 ../vector/v.buffer2/main.c:151
+msgid ""
+"Creates a buffer around features of given type (areas must contain centroid)."
+msgstr ""
+#: ../vector/v.buffer/main.c:271 ../vector/v.buffer2/main.c:226
+msgid "Buffer distance in map units"
+msgstr ""
+#: ../vector/v.buffer/main.c:278
+msgid "Attribute column to use for buffer distances"
+msgstr ""
+#: ../vector/v.buffer/main.c:279 ../vector/v.buffer/main.c:287
+#: ../vector/v.buffer/main.c:294 ../vector/v.buffer/main.c:304
+#: ../display/d.legend/main.c:108 ../display/d.legend/main.c:117
+#: ../display/d.legend/main.c:125 ../display/d.legend/main.c:146
+#: ../display/d.legend/main.c:155 ../display/d.legend/main.c:165
+#: ../display/d.legend/main.c:170 ../display/d.legend/main.c:175
+#: ../display/d.legend/main.c:180 ../display/d.legend/main.c:185
+#: ../raster/r.what/main.c:110 ../raster/r.what/main.c:148
+msgid "Advanced"
+msgstr ""
+#: ../vector/v.buffer/main.c:286 ../vector/v.buffer2/main.c:199
+msgid "Scaling factor for attribute column values"
+msgstr ""
+#: ../vector/v.buffer/main.c:296 ../vector/v.buffer2/main.c:208
+msgid ""
+"Maximum distance between theoretical arc and polygon segments as multiple of "
+"buffer"
+msgstr ""
+#: ../vector/v.buffer/main.c:305
+msgid "Stop the process at a certain stage"
+msgstr ""
+#: ../vector/v.buffer/main.c:319 ../vector/v.buffer2/main.c:250
+msgid ""
+"The bufcol option may contain bugs during the cleaning step. If you "
+"encounter problems, use the debug option or clean manually with v.clean "
+"tool=break; v.category step=0; v.extract -d type=area"
+msgstr ""
+#: ../vector/v.buffer/main.c:335 ../vector/v.buffer/main.c:485
+#: ../vector/v.buffer/main.c:562 ../vector/v.buffer2/main.c:436
+#: ../vector/v.buffer2/main.c:508
+#, c-format
+msgid "The tolerance in map units: %g"
+msgstr ""
+#: ../vector/v.buffer/main.c:342
+#, c-format
+msgid "The tolerance was reset to %g (map units)"
+msgstr ""
+#: ../vector/v.buffer/main.c:432
+msgid "Lines buffers... "
+msgstr ""
+#: ../vector/v.buffer/main.c:473 ../vector/v.buffer/main.c:550
+#: ../vector/v.buffer2/main.c:422 ../vector/v.buffer2/main.c:494
+#, c-format
+msgid "Attribute is of invalid size (%.3f) for category %d"
+msgstr ""
+#: ../vector/v.buffer/main.c:492 ../vector/v.buffer/main.c:569
+#, c-format
+msgid "The tolerance was reset to %g (map units). [category %d]"
+msgstr ""
+#: ../vector/v.buffer/main.c:509
+msgid "Areas buffers... "
+msgstr ""
+#: ../vector/v.buffer/main.c:607 ../vector/v.buffer2/main.c:539
+msgid "Building parts of topology..."
+msgstr ""
+#: ../vector/v.buffer/main.c:619 ../vector/v.buffer2/main.c:542
+msgid "Snapping boundaries..."
+msgstr ""
+#: ../vector/v.buffer/main.c:622 ../vector/v.buffer2/main.c:552
+msgid "Breaking boundaries..."
+msgstr ""
+#: ../vector/v.buffer/main.c:625 ../vector/v.overlay/area_area.c:43
+#: ../vector/v.buffer2/main.c:548 ../vector/v.buffer2/main.c:555
+msgid "Removing duplicates..."
+msgstr ""
+#: ../vector/v.buffer/main.c:637 ../vector/v.overlay/area_area.c:55
+#: ../vector/v.buffer2/main.c:573
+msgid "Attaching islands..."
+msgstr ""
+#: ../vector/v.buffer/main.c:644 ../vector/v.buffer/main.c:734
+#: ../vector/v.buffer2/main.c:579 ../vector/v.buffer2/main.c:672
+msgid "Calculating centroids for areas..."
+msgstr ""
+#: ../vector/v.buffer/main.c:663 ../vector/v.buffer/main.c:750
+#: ../vector/v.voronoi/dt_main.c:142 ../vector/v.in.ogr/main.c:1043
+#: ../vector/v.overlay/area_area.c:68 ../vector/v.buffer2/main.c:593
+#: ../vector/v.buffer2/main.c:685
+msgid "Cannot calculate area centroid"
+msgstr ""
+#: ../vector/v.buffer/main.c:686 ../vector/v.buffer2/main.c:610
+msgid "Generating list of boundaries to be deleted..."
+msgstr ""
+#: ../vector/v.buffer/main.c:718 ../vector/v.buffer2/main.c:643
+msgid "Deleting boundaries..."
+msgstr ""
+#: ../vector/v.buffer/main.c:760 ../vector/v.overlay/area_area.c:264
+msgid "Attaching centroids..."
+msgstr ""
+#: ../vector/v.external/main.c:58
+msgid "vector, external, import"
+msgstr ""
+#: ../vector/v.external/main.c:60
+msgid "Creates a new vector as a read-only link to OGR layer."
+msgstr ""
+#: ../vector/v.external/main.c:75
+msgid "Output vector. If not given, available layers are printed only."
+msgstr ""
+#: ../vector/v.external/main.c:83
+msgid ""
+"OGR layer name. If not given, available layers are printed only. Examples:\n"
+"\t\tESRI Shapefile: shapefile name\n"
+"\t\tMapInfo File: mapinfo file name"
+msgstr ""
+#: ../vector/v.external/main.c:91
+msgid "Output vector name was not specified"
+msgstr ""
+#: ../vector/v.external/main.c:96
+msgid "Cannot open data source"
+msgstr ""
+#: ../vector/v.external/main.c:128 ../vector/v.in.ogr/main.c:363
+#, c-format
+msgid "Layer <%s> not available"
+msgstr ""
+#: ../vector/v.convert/att.c:36
+msgid "No category labels (dig_cats) found, no table created"
+msgstr ""
+#: ../vector/v.convert/att.c:41
+msgid "Unable to open dig_cats file"
+msgstr ""
+#: ../vector/v.convert/type.c:29
+#, c-format
+msgid "OLD_T_NEW Got a bad type code [%x]"
+msgstr ""
+#: ../vector/v.convert/type.c:50
+#, c-format
+msgid "NEW_T_OLD Got a bad type code [%x]"
+msgstr ""
+#: ../vector/v.convert/read.c:41
+msgid "Reading dig file..."
+msgstr ""
+#: ../vector/v.convert/read.c:82
+msgid "Input file is version 3."
+msgstr ""
+#: ../vector/v.convert/read.c:86
+msgid "Input file is version 4."
+msgstr ""
+#: ../vector/v.convert/read.c:96
+msgid "Input file is portable."
+msgstr ""
+#: ../vector/v.convert/read.c:99
+msgid ""
+"Input file is not portable. We will attempt to convert anyway but conversion "
+"may fail. Please read manual for detail information."
+msgstr ""
+#: ../vector/v.convert/read.c:185
+#, c-format
+msgid "[%d] points read to memory"
+msgstr ""
+#: ../vector/v.convert/read.c:186
+#, c-format
+msgid "[%d] lines read to memory"
+msgstr ""
+#: ../vector/v.convert/read.c:189
+#, c-format
+msgid "[%d] points read and written to output"
+msgstr ""
+#: ../vector/v.convert/read.c:190
+#, c-format
+msgid "[%d] lines read and written to output"
+msgstr ""
+#: ../vector/v.convert/read.c:192
+#, c-format
+msgid "[%d] area boundaries read and written to output"
+msgstr ""
+#: ../vector/v.convert/read.c:193
+#, c-format
+msgid "[%d] dead points skipped"
+msgstr ""
+#: ../vector/v.convert/read.c:194
+#, c-format
+msgid "[%d] dead lines skipped"
+msgstr ""
+#: ../vector/v.convert/read.c:195
+#, c-format
+msgid "[%d] dead area boundaries skipped"
+msgstr ""
+#: ../vector/v.convert/read.c:196
+#, c-format
+msgid "[%d] elements of unknown type skipped"
+msgstr ""
+#: ../vector/v.convert/read.c:198
+#, c-format
+msgid "[%d] elements read to memory"
+msgstr ""
+#: ../vector/v.convert/read.c:241
+msgid "Reading dig_att file..."
+msgstr ""
+#: ../vector/v.convert/read.c:249
+#, c-format
+msgid "Error: %s"
+msgstr ""
+#: ../vector/v.convert/read.c:270
+#, c-format
+msgid "Unknown type: %c"
+msgstr ""
+#: ../vector/v.convert/read.c:293
+#, c-format
+msgid "[%d] point categories read"
+msgstr ""
+#: ../vector/v.convert/read.c:294
+#, c-format
+msgid "[%d] line categories read"
+msgstr ""
+#: ../vector/v.convert/read.c:295
+#, c-format
+msgid "[%d] centroids read"
+msgstr ""
+#: ../vector/v.convert/read.c:296
+#, c-format
+msgid "[%d] dead point categories skipped"
+msgstr ""
+#: ../vector/v.convert/read.c:297
+#, c-format
+msgid "[%d] dead line categories skipped"
+msgstr ""
+#: ../vector/v.convert/read.c:298
+#, c-format
+msgid "[%d] dead centroids skipped"
+msgstr ""
+#: ../vector/v.convert/read.c:299
+#, c-format
+msgid "[%d] categories of unknown type skipped"
+msgstr ""
+#: ../vector/v.convert/read.c:301
+#, c-format
+msgid "[%d] categories read into memory"
+msgstr ""
+#: ../vector/v.convert/main.c:36
+msgid "vector, import, conversion"
+msgstr ""
+#: ../vector/v.convert/main.c:37
+msgid "Imports older versions of GRASS vector maps."
+msgstr ""
+#: ../vector/v.convert/main.c:54
+msgid "Endian of input vector map"
+msgstr ""
+#: ../vector/v.convert/old2new.c:31
+msgid "Failed opening input dig file."
+msgstr ""
+#: ../vector/v.convert/old2new.c:46
+msgid "dig_att file doesn't exist."
+msgstr ""
+#: ../vector/v.convert/old2new.c:50
+msgid "Failed opening input dig_att file."
+msgstr ""
+#: ../vector/v.convert/old2new.c:72
+msgid "Attaching categories..."
+msgstr ""
+#: ../vector/v.convert/old2new.c:89
+#, c-format
+msgid "Failed to attach an attribute (category %d) to a line."
+msgstr ""
+#: ../vector/v.convert/old2new.c:94
+#, c-format
+msgid "Line %d label: %d matched another label: %d."
+msgstr ""
+#: ../vector/v.convert/old2new.c:103
+msgid "Writing new file..."
+msgstr ""
+#: ../vector/v.convert/old2new.c:125
+#, c-format
+msgid "[%d] points and lines written to output file."
+msgstr ""
+#: ../vector/v.convert/old2new.c:139
+#, c-format
+msgid "[%d] centroids written to output file."
+msgstr ""
+#: ../vector/v.out.pov/main.c:207
+#, c-format
+msgid "%d features written"
+msgstr ""
+#: ../vector/v.what.rast/main.c:80
+msgid "vector, raster, attribute table"
+msgstr ""
+#: ../vector/v.what.rast/main.c:82
+msgid "Uploads raster values at positions of vector points to the table."
+msgstr ""
+#: ../vector/v.what.rast/main.c:87
+msgid "Name of input vector points map for which to edit attribute table"
+msgstr ""
+#: ../vector/v.what.rast/main.c:91
+msgid "Name of existing raster map to be queried"
+msgstr ""
+#: ../vector/v.what.rast/main.c:100
+msgid "Column name (will be updated by raster values)"
+msgstr ""
+#: ../vector/v.what.rast/main.c:155 ../vector/v.to.rast/support.c:315
+#: ../vector/v.to.rast/vect2rast.c:64
+#, c-format
+msgid "Column <%s> not found"
+msgstr ""
+#: ../vector/v.what.rast/main.c:161
+msgid "Raster type is integer and column type is float"
+msgstr ""
+#: ../vector/v.what.rast/main.c:164
+msgid "Raster type is float and column type is integer, some data lost!!"
+msgstr ""
+#: ../vector/v.what.rast/main.c:244
+#, c-format
+msgid "%d points outside current region were skipped"
+msgstr ""
+#: ../vector/v.what.rast/main.c:248
+#, c-format
+msgid "%d points without category were skipped"
+msgstr ""
+#: ../vector/v.what.rast/main.c:302
+#, c-format
+msgid "More points (%d) of category %d, value set to 'NULL'"
+msgstr ""
+#: ../vector/v.what.rast/main.c:367
+#, c-format
+msgid "%d categories loaded from table"
+msgstr ""
+#: ../vector/v.what.rast/main.c:368
+#, c-format
+msgid "%d categories loaded from vector"
+msgstr ""
+#: ../vector/v.what.rast/main.c:369
+#, c-format
+msgid "%d categories from vector missing in table"
+msgstr ""
+#: ../vector/v.what.rast/main.c:370
+#, c-format
+msgid "%d duplicate categories in vector"
+msgstr ""
+#: ../vector/v.what.rast/main.c:372 ../vector/v.distance/main.c:1136
+#, c-format
+msgid "%d records updated"
+msgstr ""
+#: ../vector/v.what.rast/main.c:373 ../vector/v.distance/main.c:1138
+#, c-format
+msgid "%d update errors"
+msgstr ""
+#: ../vector/v.out.svg/main.c:72
+msgid "Exports a GRASS vector map to SVG."
+msgstr ""
+#: ../vector/v.out.svg/main.c:78
+msgid "Name for SVG output file"
+msgstr ""
+#: ../vector/v.out.svg/main.c:87
+msgid "Output type"
+msgstr ""
+#: ../vector/v.out.svg/main.c:88
+msgid "Defines which feature-type will be extracted"
+msgstr ""
+#: ../vector/v.out.svg/main.c:96
+msgid "Coordinate precision"
+msgstr ""
+#: ../vector/v.out.svg/main.c:103
+msgid "Attribute(s) to include in output SVG"
+msgstr ""
+#: ../vector/v.out.svg/main.c:116
+msgid "Precision must not be negative"
+msgstr ""
+#: ../vector/v.out.svg/main.c:119
+msgid "Precision must not be higher than 15"
+msgstr ""
+#: ../vector/v.out.svg/main.c:190
+#, c-format
+msgid "Unable to open SVG file <%s>"
+msgstr ""
+#: ../vector/v.out.svg/main.c:205
+msgid "No areas found, skipping type=poly"
+msgstr ""
+#: ../vector/v.out.svg/main.c:242
+#, c-format
+msgid "Extracted %d areas"
+msgstr ""
+#: ../vector/v.out.svg/main.c:248
+msgid "No points found, skipping type=point"
+msgstr ""
+#: ../vector/v.out.svg/main.c:271
+#, c-format
+msgid "Extracted %d points"
+msgstr ""
+#: ../vector/v.out.svg/main.c:277
+msgid "No lines found, skipping type=line"
+msgstr ""
+#: ../vector/v.out.svg/main.c:298
+#, c-format
+msgid "Extracted %d lines"
+msgstr ""
+#: ../vector/v.out.svg/main.c:366
+#, c-format
+msgid "Cannot select attributes for cat=%d"
+msgstr ""
+#: ../vector/v.parallel/main.c:40
+msgid "Create parallel line to input lines"
+msgstr ""
+#: ../vector/v.parallel/main.c:52
+msgid "Offset in map units, positive for right side, negative for left side."
+msgstr ""
+#: ../vector/v.net.components/main.c:69
+msgid "vector, network, components"
+msgstr ""
+#: ../vector/v.net.components/main.c:71
+msgid "Computes strongly and weakly connected components in the network."
+msgstr ""
+#: ../vector/v.net.components/main.c:85
+msgid "weak;Weakly connected components;strong;Strongly connected components;"
+msgstr ""
+#: ../vector/v.net.components/main.c:87
+msgid "Type of components"
+msgstr ""
+#: ../vector/v.net.components/main.c:91 ../vector/v.net.centrality/main.c:171
+msgid "Add points on nodes"
+msgstr ""
+#: ../vector/v.drape/main.c:166
+msgid "vector, geometry, sampling"
+msgstr ""
+#: ../vector/v.drape/main.c:168
+msgid "Converts vector map to 3D by sampling of elevation raster map."
+msgstr ""
+#: ../vector/v.drape/main.c:180
+msgid "Elevation raster map for height extraction"
+msgstr ""
+#: ../vector/v.drape/main.c:194
+msgid "Sampling method"
+msgstr ""
+#: ../vector/v.drape/main.c:199
+msgid "Scale sampled raster values"
+msgstr ""
+#: ../vector/v.drape/main.c:206
+msgid "Layer is only used for WHERE SQL statement"
+msgstr ""
+#: ../vector/v.drape/main.c:211
+msgid "Vector Z value for unknown height"
+msgstr ""
+#: ../vector/v.drape/main.c:213
+msgid "Will set Z to this value, if value from raster map can not be read"
+msgstr ""
+#: ../vector/v.drape/main.c:305
+msgid "No features match Your query"
+msgstr ""
+#: ../vector/v.drape/main.c:407 ../vector/v.drape/main.c:417
+msgid "Due to error attribute data to new map are not transferred"
+msgstr ""
+#: ../vector/v.drape/main.c:425
+msgid ""
+"No features drapped. Check Your computational region and input raster map."
+msgstr ""
+#: ../vector/v.voronoi/vo_main.c:120 ../vector/v.voronoi/dt_main.c:46
+#: ../vector/v.delaunay2/main.c:86
+msgid "vector, geometry, triangulation"
+msgstr ""
+#: ../vector/v.voronoi/vo_main.c:121
+msgid ""
+"Creates a Voronoi diagram from an input vector map containing points or "
+"centroids."
+msgstr ""
+#: ../vector/v.voronoi/vo_main.c:136
+msgid "Output tessellation as a graph (lines), not areas"
+msgstr ""
+#: ../vector/v.voronoi/vo_main.c:179
+msgid "Reading sites..."
+msgstr ""
+#: ../vector/v.voronoi/vo_main.c:189
+msgid "Voronoi triangulation..."
+msgstr ""
+#: ../vector/v.voronoi/vo_main.c:271
+msgid "Writing sites to output..."
+msgstr ""
+#: ../vector/v.voronoi/vo_main.c:359
+msgid "Cannot copy table"
+msgstr ""
+#: ../vector/v.voronoi/vo_main.c:415
+msgid "Output needs topological cleaning"
+msgstr ""
+#: ../vector/v.voronoi/vo_main.c:447
+msgid "Removing incorrect boundaries from output"
+msgstr ""
+#: ../vector/v.voronoi/dt_main.c:47 ../vector/v.delaunay2/main.c:87
+msgid ""
+"Creates a Delaunay triangulation from an input vector map containing points "
+"or centroids."
+msgstr ""
+#: ../vector/v.voronoi/dt_main.c:55 ../vector/v.delaunay2/main.c:95
+msgid "Use only points in current region"
+msgstr ""
+#: ../vector/v.voronoi/dt_main.c:60 ../vector/v.delaunay2/main.c:100
+msgid "Output triangulation as a graph (lines), not areas"
+msgstr ""
+#: ../vector/v.voronoi/dt_main.c:149
+msgid "Cannot calculate area centroid z coordinate"
+msgstr ""
+#: ../vector/v.out.dxf/write_dxf.c:21
+#, c-format
+msgid "The file '%s' already exists."
+msgstr ""
+#: ../vector/v.out.dxf/write_dxf.c:23
+#, c-format
+msgid "The file '%s' already exists and will be overwritten."
+msgstr ""
+#: ../vector/v.out.dxf/write_dxf.c:27
+#, c-format
+msgid "%s: Cannot write dxf file."
+msgstr ""
+#: ../vector/v.out.dxf/main.c:50
+msgid "Exports GRASS vector map layers to DXF file format."
+msgstr ""
+#: ../vector/v.out.dxf/main.c:60
+msgid "DXF output file"
+msgstr ""
+#: ../vector/v.out.dxf/main.c:97
+#, c-format
+msgid "%d features written to '%s'."
+msgstr ""
+#: ../vector/v.to.rast/do_lines.c:51 ../vector/v.to.rast/do_lines.c:59
+#: ../vector/v.to.rast3/main.c:150
+#, c-format
+msgid "No record for line (cat = %d)"
+msgstr ""
+#: ../vector/v.to.rast/do_lines.c:65 ../vector/v.to.rast/do_areas.c:63
+msgid "Unable to use column specified"
+msgstr ""
+#: ../vector/v.to.rast/do_lines.c:125
+#, c-format
+msgid "%d lines with varying height were not written to raster"
+msgstr ""
+#: ../vector/v.to.rast/support.c:141 ../vector/v.to.rast/support.c:293
+#, c-format
+msgid "Unknown column <%s> in table <%s>"
+msgstr ""
+#: ../vector/v.to.rast/support.c:162 ../vector/v.to.rast/support.c:328
+msgid "No records selected"
+msgstr ""
+#: ../vector/v.to.rast/support.c:175
+#, c-format
+msgid "Error in color definition column (%s) with cat %d: colorstring [%s]"
+msgstr ""
+#: ../vector/v.to.rast/support.c:178
+msgid "Color set to [200:200:200]"
+msgstr ""
+#: ../vector/v.to.rast/support.c:183
+#, c-format
+msgid "Error in color definition column (%s), with cat %d"
+msgstr ""
+#: ../vector/v.to.rast/support.c:307
+msgid "Label column was not specified, no labels will be written"
+msgstr ""
+#: ../vector/v.to.rast/support.c:351
+#, c-format
+msgid "Column type (%s) not supported"
+msgstr ""
+#: ../vector/v.to.rast/support.c:431
+msgid "Cannot allocate memory for row buffer"
+msgstr ""
+#: ../vector/v.to.rast/support.c:493 ../vector/v.to.rast/vect2rast.c:119
+#, c-format
+msgid "Unknown use type: %d"
+msgstr ""
+#: ../vector/v.to.rast/support.c:499
+#, c-format
+msgid "Unable to write categories for raster map <%s>"
+msgstr ""
+#: ../vector/v.to.rast/do_areas.c:49 ../vector/v.to.rast/do_areas.c:57
+#, c-format
+msgid "No record for area (cat = %d)"
+msgstr ""
+#: ../vector/v.to.rast/do_areas.c:78
+#, c-format
+msgid "Get area %d failed"
+msgstr ""
+#: ../vector/v.to.rast/do_areas.c:118
+msgid "Area without centroid (may be OK for island)"
+msgstr ""
+#: ../vector/v.to.rast/do_areas.c:125
+msgid "Area centroid without category"
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:39
+msgid "Loading data..."
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:44
+#, c-format
+msgid "Vector map <%s> is not 3D"
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:69
+#, c-format
+msgid "Column type (%s) not supported (did you mean 'labelcolumn'?)"
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:101
+#, c-format
+msgid "Unable to use column <%s>"
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:132
+msgid "Unknown raster map type"
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:140
+#, c-format
+msgid "Unable to process areas from vector map <%s>"
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:156
+#, c-format
+msgid "Pass %d of %d:"
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:164
+#, c-format
+msgid "Problem processing areas from vector map <%s>, continuing..."
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:175
+#, c-format
+msgid "Problem processing lines from vector map <%s>, continuing..."
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:182 ../raster/r.in.poly/poly2rast.c:78
+#: ../raster/r.carve/raster.c:32
+msgid "Writing raster map..."
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:200
+msgid "Creating support files for raster map..."
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:207
+msgid "Color can be updated from database only if use=attr"
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:226
+#, c-format
+msgid "Converted areas: %d of %d"
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:227
+#, c-format
+msgid "Converted points/lines: %d of %d"
+msgstr ""
+#: ../vector/v.to.rast/main.c:38
+msgid "vector, raster, conversion"
+msgstr ""
+#: ../vector/v.to.rast/main.c:39
+msgid "Converts (rasterize) a vector map into a raster map."
+msgstr ""
+#: ../vector/v.to.rast/main.c:60
+msgid "Source of raster values"
+msgstr ""
+#: ../vector/v.to.rast/main.c:61
+msgid ""
+"attr;read values from attribute table;cat;use category values;val;use value "
+"specified by value option;z;use z coordinate (points or contours only);dir;"
+"output as flow direction (lines only)"
+msgstr ""
+#: ../vector/v.to.rast/main.c:70
+msgid "Name of column for 'attr' parameter (data type must be numeric)"
+msgstr ""
+#: ../vector/v.to.rast/main.c:71 ../vector/v.to.rast/main.c:77
+#: ../vector/v.to.rast/main.c:83 ../vector/v.in.ogr/main.c:193
+#: ../vector/v.in.ogr/main.c:216 ../vector/v.in.ogr/main.c:239
+#: ../vector/v.transform/main.c:183 ../vector/v.transform/main.c:194
+#: ../vector/v.digit/line.c:86 ../vector/v.digit/attr.c:539
+#: ../vector/v.digit/attr.c:575 ../raster/r.to.vect/main.c:74
+#: ../raster/r.to.vect/main.c:81
+msgid "Attributes"
+msgstr ""
+#: ../vector/v.to.rast/main.c:76
+msgid "Name of color definition column (with RRR:GGG:BBB entries)"
+msgstr ""
+#: ../vector/v.to.rast/main.c:82
+msgid "Name of column used as raster category labels"
+msgstr ""
+#: ../vector/v.to.rast/main.c:91
+msgid "Raster value (for use=val)"
+msgstr ""
+#: ../vector/v.to.rast/main.c:99 ../raster/r.in.poly/main.c:50
+msgid "Number of rows to hold in memory"
+msgstr ""
+#: ../vector/v.to.rast/main.c:112
+msgid "Column parameter missing (or use value parameter)"
+msgstr ""
+#: ../vector/v.to.rast/main.c:117
+msgid "Column parameter cannot be combined with use of category values option"
+msgstr ""
+#: ../vector/v.to.rast/main.c:122
+msgid "Column parameter cannot be combined with use of value option"
+msgstr ""
+#: ../vector/v.to.rast/main.c:127
+msgid "Column parameter cannot be combined with use of z coordinate"
+msgstr ""
+#: ../vector/v.to.rast/main.c:133
+#, c-format
+msgid "Unknown option '%s'"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:98
+msgid "Converts GRASS vector map to one of the supported OGR vector formats."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:106
+msgid ""
+"Feature type(s). Combinations not supported by all output formats. Default: "
+"first type found in input."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:114
+msgid "OGR output datasource name"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:116
+msgid "For example: ESRI Shapefile: filename or directory for storage"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:123
+msgid "OGR layer name. If not specified, input name is used."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:124
+msgid "For example: ESRI Shapefile: shapefile name"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:125 ../vector/v.out.ogr/main.c:138
+#: ../vector/v.out.ogr/main.c:148 ../vector/v.out.ogr/main.c:158
+msgid "Creation"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:137
+msgid "OGR format"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:147
+msgid "OGR dataset creation option (format specific, NAME=VALUE)"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:157
+msgid "OGR layer creation option (format specific, NAME=VALUE)"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:162
+msgid "Open an existing datasource for update"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:167
+msgid "Skip export of GRASS category ID ('cat') attribute"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:171
+msgid ""
+"Export features with category (labeled) only. Otherwise all features are "
+"exported"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:176
+msgid "Use ESRI-style .prj file format (applies to Shapefile output only)"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:181
+msgid "Create 3D output if input is 3D (applies to Shapefile output only)"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:186
+msgid "Export lines as polygons"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:230
+msgid "Skipping all boundaries that are not part of an area."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:249
+msgid "Volumes will be exported as sets of faces."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:267
+msgid "Could not determine input map's feature type(s)."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:312
+msgid "The combination of types is not supported by all formats."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:326
+msgid ""
+"The map contains islands. To preserve them in the output map, use the -c flag"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:331
+#, c-format
+msgid ""
+"%d point(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:336
+#, c-format
+msgid ""
+"%d line(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:342
+#, c-format
+msgid ""
+"%d boundary(ies) found, but not requested to be exported. Verify 'type' "
+"parameter."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:348
+#, c-format
+msgid ""
+"%d centroid(s) found, but not requested to be exported. Verify 'type' "
+"parameter."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:353
+#, c-format
+msgid ""
+"%d areas found, but not requested to be exported. Verify 'type' parameter."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:357
+#, c-format
+msgid ""
+"%d face(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:363
+#, c-format
+msgid ""
+"%d kernel(s) found, but not requested to be exported. Verify 'type' "
+"parameter."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:368
+#, c-format
+msgid ""
+"%d volume(s) found, but not requested to be exported. Verify 'type' "
+"parameter."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:374
+msgid ""
+"No points found, but requested to be exported. Will skip this geometry type."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:383
+msgid ""
+"No lines found, but requested to be exported. Will skip this geometry type."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:393
+msgid ""
+"No boundaries found, but requested to be exported. Will skip this geometry "
+"type."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:402
+msgid ""
+"No areas found, but requested to be exported. Will skip this geometry type."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:412
+msgid ""
+"No centroids found, but requested to be exported. Will skip this geometry "
+"type."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:421
+msgid ""
+"No faces found, but requested to be exported. Will skip this geometry type."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:430
+msgid ""
+"No kernels found, but requested to be exported. Will skip this geometry type."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:439
+msgid ""
+"No volumes found, but requested to be exported. Will skip this geometry type."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:450
+msgid "Nothing to export"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:483
+#, c-format
+msgid "OGR driver <%s> not found"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:508
+#, c-format
+msgid "Unable to open OGR data source '%s'"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:522
+#, c-format
+msgid "Layer <%s> already exists in OGR data source '%s'"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:526
+#, c-format
+msgid "OGR layer <%s> already exists and will be overwritten"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:567
+msgid "Overriding existing user-defined 'SHPT=' LCO."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:583
+#, c-format
+msgid ""
+"Vector map <%s> is 3D. Use format specific layer creation options (parameter "
+"'lco') or '-z' flag to export in 3D rather than 2D (default)"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:590
+#, c-format
+msgid ""
+"'lco') to export in 3D rather than 2D (default)"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:603
+msgid "Unable to create OGR layer"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:613
+msgid "No attribute table found -> using only category numbers as attributes"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:617
+msgid "Exporting 'cat' anyway, as it is the only attribute table field"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:694
+#, c-format
+msgid "Key column '%s' not found"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:707
+#, c-format
+msgid "Exporting %i geometries..."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:789
+#, c-format
+msgid "Exporting %i areas (may take some time)..."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:864
+#, c-format
+msgid "Exporting %i faces (may take some time) ..."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:927
+#, c-format
+msgid "Exporting %i kernels..."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:986
+#, c-format
+msgid "Exporting %i volumes..."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:987
+msgid "Export of volumes not implemented yet. Skipping."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:1004
+#, c-format
+msgid "%d features without category were written"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:1006
+#, c-format
+msgid "%d features without attributes were written"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:1008
+#, c-format
+msgid "%d features found without category were skipped"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:1019
+#, c-format
+msgid "%d features written to <%s> (%s)."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:1077
+#, c-format
+msgid "No database record for cat = %d and export of 'cat' disabled"
+msgstr ""
+#: ../vector/v.build.polylines/main.c:108
+msgid "vector, geometry, topology"
+msgstr ""
+#: ../vector/v.build.polylines/main.c:109
+msgid "Builds polylines from lines or boundaries."
+msgstr ""
+#: ../vector/v.build.polylines/main.c:119
+msgid "Category number mode"
+msgstr ""
+#: ../vector/v.build.polylines/main.c:121
+msgid ""
+"no;Do not assign any category number to polyline;first;Assign category "
+"number of first line to polyline;multi;Assign multiple category numbers to "
+"polyline"
+msgstr ""
+#: ../vector/v.build.polylines/main.c:212
+#, c-format
+msgid "%d lines or boundaries found in vector map <%s@%s>"
+msgstr ""
+#: ../vector/v.build.polylines/main.c:214
+#, c-format
+msgid "%d polylines stored in vector map <%s@%s>"
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/correction.c:96
+#: ../vector/lidar/v.lidar.correction/correction.c:130
+#: ../vector/lidar/v.lidar.correction/correction.c:154
+#: ../vector/lidar/v.lidar.correction/correction.c:166
+#: ../vector/lidar/v.lidar.correction/correction.c:190
+#: ../vector/lidar/v.outlier/outlier.c:75
+#: ../vector/lidar/v.outlier/outlier.c:112
+#: ../vector/lidar/v.outlier/outlier.c:138
+#: ../vector/lidar/v.outlier/outlier.c:151
+#: ../vector/lidar/v.outlier/outlier.c:175
+msgid "Impossible to read the database"
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/correction.c:100
+#: ../vector/lidar/v.lidar.correction/correction.c:158
+#: ../vector/lidar/v.outlier/outlier.c:79
+#: ../vector/lidar/v.outlier/outlier.c:142
+msgid "Impossible to update the database"
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/correction.c:110
+#: ../vector/lidar/v.lidar.correction/correction.c:118
+#: ../vector/lidar/v.lidar.correction/correction.c:213
+#: ../vector/lidar/v.outlier/outlier.c:90
+#: ../vector/lidar/v.outlier/outlier.c:99
+#: ../vector/lidar/v.outlier/outlier.c:197
+msgid "Impossible to write in the database"
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/main.c:73
+#: ../vector/lidar/v.lidar.growing/main.c:79
+msgid "vector, LIDAR"
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/main.c:75
+msgid ""
+"Correction of the v.lidar.growing output. It is the last of the three "
+"algorithms for LIDAR filtering."
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/main.c:79
+#: ../vector/lidar/v.outlier/main.c:78
+#: ../vector/lidar/v.lidar.edgedetection/main.c:84
+#: ../vector/lidar/v.surf.bspline/main.c:94
+msgid "Estimate point density and distance"
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/main.c:81
+#: ../vector/lidar/v.outlier/main.c:80
+#: ../vector/lidar/v.lidar.edgedetection/main.c:86
+#: ../vector/lidar/v.surf.bspline/main.c:96
+msgid ""
+"Estimate point density and distance for the input vector points within the "
+"current region extends and quit"
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/main.c:85
+msgid "Input observation vector map name (v.lidar.growing output)"
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/main.c:88
+msgid "Output classified vector map name"
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/main.c:97
+msgid "Only 'terrain' points output vector map"
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/main.c:105
+#: ../vector/lidar/v.outlier/main.c:108
+#: ../vector/lidar/v.lidar.edgedetection/main.c:98
+msgid "Interpolation spline step value in east direction"
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/main.c:113
+#: ../vector/lidar/v.outlier/main.c:116
+#: ../vector/lidar/v.lidar.edgedetection/main.c:107
+msgid "Interpolation spline step value in north direction"
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/main.c:120
+msgid "Regularization weight in reclassification evaluation"
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/main.c:128
+msgid "High threshold for object to terrain reclassification"
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/main.c:136
+msgid "Low threshold for terrain to object reclassification"
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/main.c:152
+#: ../vector/lidar/v.outlier/main.c:139
+#: ../vector/lidar/v.lidar.edgedetection/main.c:173
+#: ../vector/lidar/v.surf.bspline/main.c:191
+msgid "Unable to read name of database"
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/main.c:155
+#: ../vector/lidar/v.outlier/main.c:142
+#: ../vector/lidar/v.lidar.edgedetection/main.c:176
+#: ../vector/lidar/v.surf.bspline/main.c:194
+msgid "Unable to read name of driver"
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/main.c:169
+#: ../vector/lidar/v.lidar.correction/main.c:229
+#: ../vector/lidar/v.outlier/main.c:171 ../vector/lidar/v.outlier/main.c:237
+#: ../vector/lidar/v.lidar.growing/main.c:166
+#: ../vector/lidar/v.lidar.edgedetection/main.c:193
+#: ../vector/lidar/v.lidar.edgedetection/main.c:205
+#: ../vector/lidar/v.lidar.edgedetection/main.c:255
+#: ../vector/lidar/v.surf.bspline/main.c:210
+#: ../vector/lidar/v.surf.bspline/main.c:361
+#, c-format
+msgid "No database connection for driver <%s> is defined. Run db.connect."
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/main.c:172
+#: ../vector/lidar/v.outlier/main.c:174
+#: ../vector/lidar/v.lidar.edgedetection/main.c:196
+#: ../vector/lidar/v.lidar.edgedetection/main.c:208
+#: ../vector/lidar/v.surf.bspline/main.c:213
+msgid "Old auxiliar table could not be dropped"
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/main.c:190
+#: ../vector/lidar/v.outlier/main.c:186
+#: ../vector/lidar/v.lidar.edgedetection/main.c:227
+#, c-format
+msgid "Input vector map <%s> is not 3D!"
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/main.c:200
+#: ../vector/lidar/v.outlier/main.c:196
+#: ../vector/lidar/v.lidar.edgedetection/main.c:237
+#: ../vector/lidar/v.surf.bspline/main.c:241
+msgid "No points in current region!"
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/main.c:278
+#: ../vector/lidar/v.outlier/main.c:276
+#: ../vector/lidar/v.lidar.edgedetection/main.c:298
+#: ../vector/lidar/v.surf.bspline/main.c:415
+#, c-format
+msgid "adjusted EW splines %d"
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/main.c:279
+#: ../vector/lidar/v.outlier/main.c:277
+#: ../vector/lidar/v.lidar.edgedetection/main.c:299
+#: ../vector/lidar/v.surf.bspline/main.c:416
+#, c-format
+msgid "adjusted NS splines %d"
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/main.c:325
+#, c-format
+msgid "nsply = %d"
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/main.c:334
+#: ../vector/lidar/v.outlier/main.c:332
+#: ../vector/lidar/v.lidar.growing/main.c:249
+#: ../vector/lidar/v.lidar.edgedetection/main.c:354
+#: ../vector/lidar/v.surf.bspline/main.c:480
+#, c-format
+msgid "subregion %d of %d"
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/main.c:358
+#, c-format
+msgid "nsplx = %d"
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/main.c:361
+msgid "read vector region map"
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/main.c:366
+#, c-format
+msgid "npoints = %d, nterrain = %d"
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/main.c:372
+msgid "Mean calculation"
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/main.c:386
+msgid "Only TERRAIN points"
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/main.c:403
+#: ../vector/lidar/v.outlier/main.c:393
+#: ../vector/lidar/v.lidar.edgedetection/main.c:417
+msgid "Bilinear interpolation"
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/main.c:416
+msgid "Correction and creation of terrain vector"
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/main.c:429
+#: ../vector/lidar/v.outlier/main.c:423
+#: ../vector/lidar/v.lidar.edgedetection/main.c:460
+#: ../vector/lidar/v.surf.bspline/main.c:681
+msgid "No data within this subregion. Consider changing the spline step."
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/main.c:438
+#: ../vector/lidar/v.lidar.edgedetection/main.c:468
+#, c-format
+msgid "Dropping <%s>"
+msgstr ""
+#: ../vector/lidar/v.lidar.correction/main.c:440
+#: ../vector/lidar/v.outlier/main.c:433
+#: ../vector/lidar/v.lidar.edgedetection/main.c:470
+#: ../vector/lidar/v.surf.bspline/main.c:703
+msgid "Auxiliar table could not be dropped"
+msgstr ""
+#: ../vector/lidar/v.outlier/main.c:74
+msgid "Removes outliers from vector point data."
+msgstr ""
+#: ../vector/lidar/v.outlier/main.c:92
+msgid "Name of output outlier vector map"
+msgstr ""
+#: ../vector/lidar/v.outlier/main.c:100
+msgid "Name of vector map for visualization in QGIS"
+msgstr ""
+#: ../vector/lidar/v.outlier/main.c:122
+msgid "Tykhonov regularization weight"
+msgstr ""
+#: ../vector/lidar/v.outlier/main.c:129
+msgid "Threshold for the outliers"
+msgstr ""
+#: ../vector/lidar/v.outlier/main.c:181
+#: ../vector/lidar/v.surf.bspline/main.c:223
+#: ../vector/lidar/v.surf.bspline/main.c:282
+#, c-format
+msgid "Unable to open vector map <%s> at the topological level"
+msgstr ""
+#: ../vector/lidar/v.outlier/main.c:243
+#, c-format
+msgid "It was impossible to create <%s> table."
+msgstr ""
+#: ../vector/lidar/v.outlier/main.c:405
+msgid "Outlier detection"
+msgstr ""
+#: ../vector/lidar/lidarlib/zones.c:413 ../vector/lidar/lidarlib/zones.c:450
+#, c-format
+msgid "<%s> created in database."
+msgstr ""
+#: ../vector/lidar/lidarlib/zones.c:417 ../vector/lidar/lidarlib/zones.c:454
+#, c-format
+msgid "<%s> has not been created in database."
+msgstr ""
+#: ../vector/lidar/lidarlib/TcholBand.c:28
+msgid "Decomposition failed"
+msgstr ""
+#: ../vector/lidar/lidarlib/raster.c:80 ../vector/lidar/lidarlib/raster.c:95
+#: ../vector/lidar/lidarlib/raster.c:108 ../vector/lidar/lidarlib/raster.c:125
+#: ../vector/lidar/lidarlib/raster.c:140 ../vector/lidar/lidarlib/raster.c:153
+#: ../vector/lidar/lidarlib/raster.c:168 ../vector/lidar/lidarlib/raster.c:181
+#, c-format
+msgid "Unable to access table <%s>"
+msgstr ""
+#: ../vector/lidar/v.lidar.growing/ConvexHull.c:269
+msgid "...now exiting to system..."
+msgstr ""
+#: ../vector/lidar/v.lidar.growing/main.c:81
+msgid ""
+"Building contour determination and Region Growing algorithm for determining "
+"the building inside"
+msgstr ""
+#: ../vector/lidar/v.lidar.growing/main.c:86
+msgid "Input vector (v.lidar.edgedetection output"
+msgstr ""
+#: ../vector/lidar/v.lidar.growing/main.c:96
+msgid "Name of the first pulse vector map"
+msgstr ""
+#: ../vector/lidar/v.lidar.growing/main.c:103
+msgid "Threshold for cell object frequency in region growing"
+msgstr ""
+#: ../vector/lidar/v.lidar.growing/main.c:111
+msgid "Threshold for double pulse in region growing"
+msgstr ""
+#: ../vector/lidar/v.lidar.growing/main.c:179
+#, c-format
+msgid "Unable to open table <%s>"
+msgstr ""
+#: ../vector/lidar/v.lidar.growing/main.c:204
+msgid "Setting regions and boxes"
+msgstr ""
+#: ../vector/lidar/v.lidar.growing/main.c:270
+#, c-format
+msgid "Rows = %d"
+msgstr ""
+#: ../vector/lidar/v.lidar.growing/main.c:271
+#, c-format
+msgid "Columns = %d"
+msgstr ""
+#: ../vector/lidar/v.lidar.growing/main.c:291
+msgid "read points in input vector"
+msgstr ""
+#: ../vector/lidar/v.lidar.growing/main.c:440
+msgid "Region Growing"
+msgstr ""
+#: ../vector/lidar/v.lidar.edgedetection/edgedetection.c:232
+#: ../vector/lidar/v.lidar.edgedetection/edgedetection.c:278
+#: ../vector/lidar/v.lidar.edgedetection/edgedetection.c:308
+#: ../vector/lidar/v.lidar.edgedetection/edgedetection.c:326
+#: ../vector/lidar/v.lidar.edgedetection/edgedetection.c:356
+msgid "Impossible to read from aux table"
+msgstr ""
+#: ../vector/lidar/v.lidar.edgedetection/edgedetection.c:237
+#: ../vector/lidar/v.lidar.edgedetection/edgedetection.c:313
+msgid "Impossible to update aux table"
+msgstr ""
+#: ../vector/lidar/v.lidar.edgedetection/edgedetection.c:250
+#: ../vector/lidar/v.lidar.edgedetection/edgedetection.c:262
+#: ../vector/lidar/v.lidar.edgedetection/edgedetection.c:383
+msgid "Impossible to write to aux table"
+msgstr ""
+#: ../vector/lidar/v.lidar.edgedetection/main.c:78
+msgid "vector, LIDAR, edges"
+msgstr ""
+#: ../vector/lidar/v.lidar.edgedetection/main.c:80
+msgid "Detects the object's edges from a LIDAR data set."
+msgstr ""
+#: ../vector/lidar/v.lidar.edgedetection/main.c:115
+msgid "Regularization weight in gradient evaluation"
+msgstr ""
+#: ../vector/lidar/v.lidar.edgedetection/main.c:124
+msgid "High gradient threshold for edge classification"
+msgstr ""
+#: ../vector/lidar/v.lidar.edgedetection/main.c:133
+msgid "Low gradient threshold for edge classification"
+msgstr ""
+#: ../vector/lidar/v.lidar.edgedetection/main.c:141
+msgid "Angle range for same direction detection"
+msgstr ""
+#: ../vector/lidar/v.lidar.edgedetection/main.c:150
+msgid "Regularization weight in residual evaluation"
+msgstr ""
+#: ../vector/lidar/v.lidar.edgedetection/main.c:260
+#, c-format
+msgid "It was impossible to create <%s>."
+msgstr ""
+#: ../vector/lidar/v.lidar.edgedetection/main.c:263
+#, c-format
+msgid "It was impossible to create <%s> interpolation table in database."
+msgstr ""
+#: ../vector/lidar/v.lidar.edgedetection/main.c:396
+msgid "Allocating memory for bilinear interpolation"
+msgstr ""
+#: ../vector/lidar/v.lidar.edgedetection/main.c:429
+msgid "Allocating memory for bicubic interpolation"
+msgstr ""
+#: ../vector/lidar/v.lidar.edgedetection/main.c:434
+msgid "Bicubic interpolation"
+msgstr ""
+#: ../vector/lidar/v.lidar.edgedetection/main.c:446
+msgid "Point classification"
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/crosscorr.c:77
+#, c-format
+msgid "%d are too many points. The cross validation would take too much time."
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/crosscorr.c:86
+#, c-format
+msgid "%d points read in region"
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/crosscorr.c:90
+msgid ""
+"Maybe, it takes too long. It will depend on how many points you are "
+"considering."
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/crosscorr.c:119
+#, c-format
+msgid "CrossCorrelation: driver=%s db=%s"
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/crosscorr.c:136
+#, c-format
+msgid "No records selected from table <%s> "
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/crosscorr.c:151
+#, c-format
+msgid ""
+"Too many splines (%d x %d). Consider changing spline steps \"sie=\" \"sin=\"."
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/crosscorr.c:169
+#, c-format
+msgid "Beginning cross validation with lambda_i=%.4f..."
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/crosscorr.c:289
+#, c-format
+msgid "Mean = %.5lf"
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/crosscorr.c:290
+#, c-format
+msgid "Root Means Square (RMS) = %.5lf"
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/crosscorr.c:306
+msgid ""
+"Different number of splines and lambda_i values have been taken for the "
+"cross correlation"
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/crosscorr.c:308
+#, c-format
+msgid ""
+"The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/crosscorr.c:316
+msgid "Results into a table:"
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/crosscorr.c:317
+msgid " lambda    | mean        | rms         |"
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/crosscorr.c:319
+#, c-format
+msgid " %-10.5f| %-12.4f| %-12.4f|"
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/crosscorr.c:327
+msgid "No point lies into the current region"
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/main.c:85
+msgid "Bicubic or bilinear spline interpolation with Tykhonov regularization."
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/main.c:90
+msgid ""
+"Find the best Tykhonov regularizing parameter using a \"leave-one-out\" "
+"cross validation method"
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/main.c:104
+msgid "Name of input vector map of sparse points"
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/main.c:119
+msgid "Length of each spline step in the east-west direction"
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/main.c:128
+msgid "Length of each spline step in the north-south direction"
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/main.c:135
+msgid "Spline interpolation algorithm"
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/main.c:144
+msgid "Tykhonov regularization parameter (affects smoothing)"
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/main.c:150 ../vector/v.surf.rst/main.c:216
+msgid "If set to 0, z coordinates are used. (3D vector only)"
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/main.c:159
+msgid "Attribute table column with values to interpolate (if layer>0)"
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/main.c:172
+msgid "Choose either vector or raster output, not both"
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/main.c:175
+msgid "No raster or vector or cross-validation output"
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/main.c:229
+msgid "Need either 3D vector or layer and column with z values"
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/main.c:231
+msgid "Layer but not column with z values given"
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/main.c:254
+msgid "Cross validation didn't finish correctly"
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/main.c:260
+#, c-format
+msgid "Cross validation finished for sie = %f and sin = %f"
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/main.c:268
+#, c-format
+msgid ""
+"No vector map of sparse points to interpolate was specified. Interpolation "
+"will be done with <%s> vector map"
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/main.c:274
+#, c-format
+msgid "Vector map <%s> of sparse points will be interpolated"
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/main.c:290
+#, c-format
+msgid ""
+"Sorry, <%s> driver is not allowed for vector output in this module. Try with "
+"a raster output or other driver."
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/main.c:328
+msgid "Cannot read field info"
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/main.c:349
+#, c-format
+msgid "[%d] records selected from table"
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/main.c:368
+#, c-format
+msgid "Interpolation: Creating table: It was impossible to create table <%s>."
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/main.c:391
+msgid ""
+"Cannot allocate memory for auxiliar matrix.Consider changing region "
+"resolution"
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/main.c:568
+#, c-format
+msgid "Interpolation: (%d,%d): No record for point (cat = %d)"
+msgstr ""
+#: ../vector/lidar/v.surf.bspline/main.c:687
+msgid "Writing output..."
+msgstr ""
+#: ../vector/v.surf.rst/main.c:166
+msgid ""
+"Spatial approximation and topographic analysis from given point or isoline "
+"data in vector format to floating point raster format using regularized "
+"spline with tension."
+msgstr ""
+#: ../vector/v.surf.rst/main.c:192
+msgid "Use z-coordinates (3D vector only)"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:198
+msgid "Perform cross-validation procedure without raster approximation"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:199 ../vector/v.surf.rst/main.c:204
+#: ../vector/v.surf.rst/main.c:293 ../vector/v.surf.rst/main.c:301
+#: ../vector/v.surf.rst/main.c:309 ../vector/v.surf.rst/main.c:316
+#: ../vector/v.surf.rst/main.c:324 ../vector/v.surf.rst/main.c:332
+#: ../vector/v.surf.rst/main.c:341 ../vector/v.surf.rst/main.c:350
+#: ../vector/v.surf.rst/main.c:359 ../vector/v.surf.rst/main.c:368
+#: ../vector/v.surf.rst/main.c:376 ../vector/v.surf.rst/main.c:383
+#: ../raster/simwe/r.sim.water/main.c:233
+#: ../raster/simwe/r.sim.water/main.c:241
+#: ../raster/simwe/r.sim.water/main.c:250
+#: ../raster/simwe/r.sim.water/main.c:268
+#: ../raster/simwe/r.sim.water/main.c:277
+#: ../raster/simwe/r.sim.water/main.c:285
+#: ../raster/simwe/r.sim.water/main.c:294
+#: ../raster/simwe/r.sim.sediment/main.c:215
+#: ../raster/simwe/r.sim.sediment/main.c:223
+#: ../raster/simwe/r.sim.sediment/main.c:232
+#: ../raster/simwe/r.sim.sediment/main.c:250
+msgid "Parameters"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:203
+msgid "Use scale dependent tension"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:209 ../raster/r.resamp.rst/main.c:286
+msgid "Output partial derivatives instead of topographic parameters"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:210 ../vector/v.surf.rst/main.c:228
+#: ../vector/v.surf.rst/main.c:234 ../vector/v.surf.rst/main.c:240
+#: ../vector/v.surf.rst/main.c:246 ../vector/v.surf.rst/main.c:252
+#: ../vector/v.surf.rst/main.c:258 ../vector/v.surf.rst/main.c:266
+#: ../vector/v.surf.rst/main.c:273 ../vector/v.surf.rst/main.c:280
+#: ../vector/v.surf.rst/main.c:287 ../raster/r.slope.aspect/main.c:164
+#: ../raster/r.slope.aspect/main.c:170 ../raster/r.slope.aspect/main.c:196
+#: ../raster/r.slope.aspect/main.c:203 ../raster/r.slope.aspect/main.c:210
+#: ../raster/r.slope.aspect/main.c:217 ../raster/r.slope.aspect/main.c:224
+#: ../raster/r.slope.aspect/main.c:231 ../raster/r.slope.aspect/main.c:238
+msgid "Outputs"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:227
+msgid "Output surface raster map (elevation)"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:233
+msgid "Output slope raster map"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:239
+msgid "Output aspect raster map"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:245
+msgid "Output profile curvature raster map"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:251
+msgid "Output tangential curvature raster map"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:257
+msgid "Output mean curvature raster map"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:265 ../vector/v.vol.rst/main.c:286
+msgid "Output deviations vector point file"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:272
+msgid "Output cross-validation errors vector point file"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:279
+msgid "Output vector map showing quadtree segmentation"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:286
+msgid "Output vector map showing overlapping windows"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:292 ../vector/v.vol.rst/main.c:302
+msgid "Name of the raster map used as mask"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:300
+msgid ""
+"Name of the attribute column with values to be used for approximation (if "
+"layer>0)"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:308 ../vector/v.vol.rst/main.c:260
+msgid "Tension parameter"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:315 ../vector/v.vol.rst/main.c:268
+msgid "Smoothing parameter"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:323
+msgid "Name of the attribute column with smoothing parameters"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:331 ../vector/v.vol.rst/main.c:309
+msgid "Maximum number of points in a segment"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:340 ../vector/v.vol.rst/main.c:318
+msgid "Minimum number of points for approximation in a segment (>segmax)"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:349 ../vector/v.vol.rst/main.c:336
+msgid "Minimum distance between points (to remove almost identical points)"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:358
+msgid ""
+"Maximum distance between points on isoline (to insert additional points)"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:367
+msgid "Conversion factor for values used for approximation"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:375
+msgid "Anisotropy angle (in degrees counterclockwise from East)"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:382 ../raster/r.resamp.rst/main.c:276
+msgid "Anisotropy scaling factor"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:408 ../vector/v.surf.rst/main.c:413
+#: ../vector/v.surf.rst/main.c:418 ../vector/v.surf.rst/main.c:423
+#, c-format
+msgid "Output vector map name <%s> is not valid map name"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:436
+msgid "You are not outputting any raster or vector maps"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:456
+msgid ""
+"Both cross-validation options (-c flag and cvdev vector output) must be "
+"specified"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:459
+msgid ""
+"The cross-validation cannot be computed simultaneously with output raster or "
+"devi file"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:462
+msgid "Both z-coordinate and zcol attribute defined, only one is allowed"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:464
+msgid "Only smoothing column defined, zcol or -z flag is missing"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:484
+msgid "Using anisotropy - both theta and scalex have to be specified"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:492
+msgid "Both smatt and smooth options specified - using constant"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:502
+msgid "The computation will last too long - lower npmin is suggested"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:520 ../raster/r.resamp.rst/main.c:366
+msgid "Not enough memory for az"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:525 ../raster/r.resamp.rst/main.c:371
+msgid "Not enough memory for adx"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:529 ../raster/r.resamp.rst/main.c:375
+msgid "Not enough memory for ady"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:534 ../raster/r.resamp.rst/main.c:380
+msgid "Not enough memory for adxx"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:538 ../raster/r.resamp.rst/main.c:384
+msgid "Not enough memory for adyy"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:542 ../raster/r.resamp.rst/main.c:388
+msgid "Not enough memory for adxy"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:549
+msgid "Cannot create quaddata"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:555
+msgid "Cannot create quadfunc"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:558
+msgid "Cannot create tree"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:562
+msgid "Cannot create tree info"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:622 ../vector/v.surf.rst/main.c:773
+#: ../raster/r.resample/main.c:137 ../raster/r.resamp.rst/main.c:527
+msgid "Percent complete: "
+msgstr ""
+#: ../vector/v.surf.rst/main.c:638 ../raster/r.resamp.rst/main.c:607
+msgid "Not enough memory for zero_array_cell"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:650 ../vector/v.surf.rst/main.c:659
+#: ../vector/v.surf.rst/main.c:668 ../vector/v.surf.rst/main.c:678
+#: ../vector/v.surf.rst/main.c:687 ../vector/v.surf.rst/main.c:696
+#: ../raster/r.resamp.rst/main.c:622 ../raster/r.resamp.rst/main.c:635
+#: ../raster/r.resamp.rst/main.c:648 ../raster/r.resamp.rst/main.c:662
+#: ../raster/r.resamp.rst/main.c:675 ../raster/r.resamp.rst/main.c:688
+msgid "Not enough disk space -- cannot write files"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:717 ../vector/v.surf.rst/main.c:769
+#: ../raster/simwe/r.sim.water/main.c:480
+#: ../raster/simwe/r.sim.sediment/main.c:358
+msgid "Input failed"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:755
+#, c-format
+msgid ""
+"Processing all selected output files\n"
+"will require %d bytes of disk space for temp files"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:779
+msgid "Interp_segmets failed"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:796
+msgid "Cannot write raster maps -- try to increase resolution"
+msgstr ""
+#: ../vector/v.class/main.c:47
+msgid "Classifies attribute data, e.g. for thematic mapping"
+msgstr ""
+#: ../vector/v.class/main.c:58
+msgid "Column name or expression"
+msgstr ""
+#: ../vector/v.class/main.c:68 ../display/d.thematic.area/main.c:105
+msgid "Algorithm to use for classification"
+msgstr ""
+#: ../vector/v.class/main.c:69 ../display/d.thematic.area/main.c:106
+msgid ""
+"int;simple intervals;std;standard deviations;qua;quantiles;equ;equiprobable "
+"(normal distribution);"
+msgstr ""
+#: ../vector/v.class/main.c:80 ../display/d.thematic.area/main.c:117
+msgid "Number of classes to define"
+msgstr ""
+#: ../vector/v.class/main.c:85
+msgid "Print only class breaks (without min and max)"
+msgstr ""
+#: ../vector/v.class/main.c:166
+msgid ""
+"The discontinuities algorithm indicates that some class breaks are not "
+"statistically significant at alpha=0.05. You are advised to reduce the "
+"number of classes."
+msgstr ""
+#: ../vector/v.class/main.c:193
+#, c-format
+msgid ""
+"\n"
+"Classification of %s into %i classes\n"
+msgstr ""
+#: ../vector/v.class/main.c:195 ../display/d.thematic.area/main.c:462
+#, c-format
+msgid "Using algorithm: *** %s ***\n"
+msgstr ""
+#: ../vector/v.class/main.c:196 ../display/d.thematic.area/main.c:464
+#, c-format
+msgid "Mean: %f\tStandard deviation = %f\n"
+msgstr ""
+#: ../vector/v.class/main.c:200
+#, c-format
+msgid "Lowest chi2 = %f\n"
+msgstr ""
+#: ../vector/v.class/main.c:203 ../display/d.thematic.area/main.c:471
+#, c-format
+msgid "Stdev multiplied by %.4f to define step\n"
+msgstr ""
+#: ../vector/v.class/main.c:206
+#, c-format
+msgid ""
+"%15s%15s%15s\n"
+"\n"
+msgstr ""
+#: ../vector/v.class/main.c:218
+#, c-format
+msgid ""
+"\n"
+"Note: Minimum of first class is including\n"
+"\n"
+msgstr ""
+#: ../vector/v.net.distance/main.c:61
+msgid ""
+"Computes shortest distance via the network between the given sets of "
+"features."
+msgstr ""
+#: ../vector/v.net.distance/main.c:64
+msgid ""
+"Finds the shortest paths from a feature 'to' to every feature 'from' and "
+"various information about this realtion are uploaded to the attribute table."
+msgstr ""
+#: ../vector/v.net.distance/main.c:73
+msgid "From layer number or name"
+msgstr ""
+#: ../vector/v.net.distance/main.c:74 ../vector/v.net.distance/main.c:79
+#: ../vector/v.net.distance/main.c:85 ../vector/v.distance/main.c:121
+#: ../vector/v.distance/main.c:133 ../vector/v.distance/main.c:145
+msgid "From"
+msgstr ""
+#: ../vector/v.net.distance/main.c:78
+msgid "From category values"
+msgstr ""
+#: ../vector/v.net.distance/main.c:84
+msgid "From WHERE conditions of SQL statement without 'where' keyword"
+msgstr ""
+#: ../vector/v.net.distance/main.c:89
+msgid "To layer number or name"
+msgstr ""
+#: ../vector/v.net.distance/main.c:90 ../vector/v.net.distance/main.c:95
+#: ../vector/v.net.distance/main.c:101 ../vector/v.net.distance/main.c:108
+#: ../vector/v.distance/main.c:126 ../vector/v.distance/main.c:140
+#: ../vector/v.distance/main.c:150 ../vector/v.distance/main.c:209
+msgid "To"
+msgstr ""
+#: ../vector/v.net.distance/main.c:94
+msgid "To category values"
+msgstr ""
+#: ../vector/v.net.distance/main.c:100
+msgid "To WHERE conditions of SQL statement without 'where' keyword"
+msgstr ""
+#: ../vector/v.net.distance/main.c:107
+msgid "To feature type"
+msgstr ""
+#: ../vector/v.net.distance/main.c:113 ../vector/v.net.path/main.c:73
+#: ../display/d.path/main.c:82
+msgid "Arc forward/both direction(s) cost column"
+msgstr ""
+#: ../vector/v.net.distance/main.c:118 ../vector/v.net.path/main.c:79
+#: ../display/d.path/main.c:88
+msgid "Arc backward direction cost column"
+msgstr ""
+#: ../vector/v.perturb/normalrs.c:31
+msgid "normalsv: restoration of unitialized block"
+msgstr ""
+#: ../vector/v.perturb/normalsv.c:29
+msgid "normalsv: save of unitialized block"
+msgstr ""
+#: ../vector/v.perturb/main.c:73
+msgid "vector, geometry, statistics"
+msgstr ""
+#: ../vector/v.perturb/main.c:75
+msgid "Random location perturbations of GRASS vector points"
+msgstr ""
+#: ../vector/v.perturb/main.c:78
+msgid "Vector points to be spatially perturbed"
+msgstr ""
+#: ../vector/v.perturb/main.c:88
+msgid "Distribution of perturbation"
+msgstr ""
+#: ../vector/v.perturb/main.c:96
+msgid ""
+"Parameter(s) of distribution. If the distribution is uniform, only one "
+"parameter, the maximum, is needed. For a normal distribution, two "
+"parameters, the mean and standard deviation, are required."
+msgstr ""
+#: ../vector/v.perturb/main.c:106
+msgid "Minimum deviation in map units"
+msgstr ""
+#: ../vector/v.perturb/main.c:113
+msgid "Seed for random number generation"
+msgstr ""
+#: ../vector/v.perturb/main.c:137 ../vector/v.perturb/main.c:144
+msgid "Error scanning arguments"
+msgstr ""
+#: ../vector/v.perturb/main.c:140
+msgid "Maximum of uniform distribution must be >= zero"
+msgstr ""
+#: ../vector/v.perturb/main.c:147
+msgid "Standard deviation of normal distribution must be >= zero"
+msgstr ""
+#: ../vector/v.perturb/main.c:232
+msgid "Cannot get db link info"
+msgstr ""
+#: ../vector/v.patch/main.c:69
+msgid "Create a new vector map layer by combining other vector map layers."
+msgstr ""
+#: ../vector/v.patch/main.c:80
+msgid ""
+"Name for output vector map where bounding boxes of input vector maps are "
+"written to"
+msgstr ""
+#: ../vector/v.patch/main.c:84
+msgid ""
+"Append files to existing file (overwriting existing files must be activated)"
+msgstr ""
+#: ../vector/v.patch/main.c:89
+msgid "Copy also attribute table"
+msgstr ""
+#: ../vector/v.patch/main.c:91
+msgid "Only the table of layer 1 is currently supported"
+msgstr ""
+#: ../vector/v.patch/main.c:189
+msgid "Missing table"
+msgstr ""
+#: ../vector/v.patch/main.c:193
+msgid "Key columns differ"
+msgstr ""
+#: ../vector/v.patch/main.c:199
+msgid "Number of columns differ"
+msgstr ""
+#: ../vector/v.patch/main.c:211
+msgid "Column names differ"
+msgstr ""
+#: ../vector/v.patch/main.c:219
+msgid "Column types differ"
+msgstr ""
+#: ../vector/v.patch/main.c:224
+msgid "Length of string columns differ"
+msgstr ""
+#: ../vector/v.patch/main.c:238
+msgid "Key column not found"
+msgstr ""
+#: ../vector/v.patch/main.c:245
+msgid "The output map is not 3D"
+msgstr ""
+#: ../vector/v.patch/main.c:298
+#, c-format
+msgid "Patching vector map <%s@%s>..."
+msgstr ""
+#: ../vector/v.patch/main.c:322
+#, c-format
+msgid "Error reading vector map <%s> - some data may not be correct"
+msgstr ""
+#: ../vector/v.patch/main.c:364
+#, c-format
+msgid "Building topology for vector map <%s>..."
+msgstr ""
+#: ../vector/v.patch/main.c:370
+msgid "Intersections at borders will have to be snapped"
+msgstr ""
+#: ../vector/v.patch/main.c:371
+msgid "Lines common between files will have to be edited"
+msgstr ""
+#: ../vector/v.patch/main.c:372
+msgid "The header information also may have to be edited"
+msgstr ""
+#: ../vector/v.patch/main.c:374
+#, c-format
+msgid "%d vector maps patched"
+msgstr ""
+#: ../vector/v.patch/main.c:397
+#, c-format
+msgid "Cannot open select cursor: '%s'"
+msgstr ""
+#: ../vector/v.patch/main.c:408
+msgid "Cannot fetch row"
+msgstr ""
+#: ../vector/v.patch/main.c:459
+msgid "Unknown column type"
+msgstr ""
+#: ../vector/v.patch/main.c:467
+#, c-format
+msgid "Cannot insert new record: '%s'"
+msgstr ""
+#: ../vector/v.build/main.c:35
+msgid "Creates topology for GRASS vector map."
+msgstr ""
+#: ../vector/v.build/main.c:42
+msgid "Name for vector map where erroneous vector features are written to"
+msgstr ""
+#: ../vector/v.build/main.c:53
+msgid "Build topology or dump topology or spatial index to stdout"
+msgstr ""
+#: ../vector/v.build/main.c:55
+msgid ""
+"build;build topology;dump;write topology to stdout;sdump;write spatial index "
+"to stdout;cdump;write category index to stdout"
+msgstr ""
+#: ../vector/v.in.ogr/geom.c:195
+msgid "Cannot read part of geometry"
+msgstr ""
+#: ../vector/v.in.ogr/geom.c:234 ../vector/v.in.ogr/geom.c:247
+#: ../vector/v.in.ogr/geom.c:275 ../vector/v.in.ogr/geom.c:321
+msgid "Skipping empty geometry feature"
+msgstr ""
+#: ../vector/v.in.ogr/geom.c:291
+#, c-format
+msgid "Degenerate polygon ([%d] vertices)"
+msgstr ""
+#: ../vector/v.in.ogr/geom.c:334
+#, c-format
+msgid "Degenerate island ([%d] vertices)"
+msgstr ""
+#: ../vector/v.in.ogr/geom.c:368
+msgid "Cannot calculate centroid"
+msgstr ""
+#: ../vector/v.in.ogr/geom.c:399
+msgid "No centroid written for polygon with 0 vertices"
+msgstr ""
+#: ../vector/v.in.ogr/geom.c:420
+msgid "Cannot write part of geometry"
+msgstr ""
+#: ../vector/v.in.ogr/geom.c:426
+msgid "Unknown geometry type"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:105
+msgid "Convert OGR vector layers to GRASS vector map."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:112
+msgid "OGR datasource name"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:113
+msgid ""
+"Examples:\n"
+"\t\tESRI Shapefile: directory containing shapefiles\n"
+"\t\tMapInfo File: directory containing mapinfo files"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:128
+msgid "OGR layer name. If not given, all available layers are imported"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:130
+msgid ""
+"Examples:\n"
+"\t\tESRI Shapefile: shapefile name\n"
+"\t\tMapInfo File: mapinfo file name"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:140
+msgid "Import subregion only"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:141 ../vector/v.in.ogr/main.c:225
+msgid "Subregion"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:143
+msgid "Format: xmin,ymin,xmax,ymax - usually W,S,E,N"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:154
+msgid "Minimum size of area to be imported (square units)"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:155 ../vector/v.in.ogr/main.c:176
+msgid "Min-area & snap"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:156
+msgid "Smaller areas and islands are ignored. Should be greater than snap^2"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:162
+msgid "Optionally change default input type"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:164
+msgid ""
+"point;import area centroids as points;line;import area boundaries as lines;"
+"boundary;import lines as area boundaries;centroid;import points as centroids"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:175
+msgid "Snapping threshold for boundaries"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:177
+msgid "'-1' for no snap"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:183 ../raster/r.in.gdal/main.c:128
+msgid "Name for new location to create"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:191
+msgid ""
+"List of column names to be used instead of original names, first is used for "
+"category column"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:198
+msgid "List available layers in data source and exit"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:202 ../raster/r.external/main.c:570
+#: ../raster/r.in.gdal/main.c:144
+msgid "List supported formats and exit"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:207
+msgid "Do not clean polygons (not recommended)"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:211 ../vector/v.random/main.c:127
+msgid "Create 3D output"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:221
+msgid "Override dataset projection (use location's projection)"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:226
+msgid "Limit import to the current region"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:231 ../raster/r.external/main.c:560
+#: ../raster/r.in.gdal/main.c:138
+msgid "Extend region extents based on new dataset"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:233 ../raster/r.external/main.c:562
+#: ../raster/r.in.gdal/main.c:140
+msgid "Also updates the default region if in the PERMANENT mapset"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:238
+msgid "Change column names to lowercase characters"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:255
+msgid "Available OGR Drivers:"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:295
+#, c-format
+msgid "Unable to open data source <%s>"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:303
+#, c-format
+msgid "Data source contains %d layers:"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:335
+#, c-format
+msgid "Vector map <%s> already exists and will be overwritten"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:379
+msgid "Select either the current region flag or the spatial option, not both"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:407
+msgid "4 parameters required for 'spatial' parameter"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:484
+msgid ""
+"Unable to convert input map projection to GRASS format; cannot create new "
+"location"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:496
+msgid ""
+"Unable to convert input map projection information to GRASS format for "
+"checking"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:511 ../raster/r.external/main.c:99
+#: ../raster/r.in.gdal/main.c:357
+msgid "Over-riding projection check"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:520 ../raster/r.external/main.c:107
+#: ../raster/r.in.gdal/main.c:367
+msgid ""
+"Projection of dataset does not appear to match current location.\n"
+"\n"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:526
+msgid "GRASS LOCATION PROJ_INFO is:\n"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:536 ../vector/v.in.ogr/main.c:543
+#: ../raster/r.external/main.c:150 ../raster/r.in.gdal/main.c:410
+msgid "Import dataset PROJ_INFO is:\n"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:586
+#, c-format
+msgid ""
+"\n"
+"You can use the -o flag to %s to override this projection check.\n"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:589
+msgid ""
+"Consider generating a new location with 'location' parameter from input data "
+"set.\n"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:594 ../raster/r.external/main.c:180
+#: ../raster/r.in.gdal/main.c:440
+msgid "Projection of input dataset and current location appear to match"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:612
+#, c-format
+msgid "Using temporary vector <%s>"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:631
+#, c-format
+msgid "Layer: %s"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:695
+#, c-format
+msgid "Column name changed: '%s' -> '%s'"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:719
+#, c-format
+msgid "Writing column <%s> with fixed length %d chars (may be truncated)"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:742
+#, c-format
+msgid ""
+"Width for column %s set to 255 (was not specified by OGR), some strings may "
+"be truncated!"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:754
+#, c-format
+msgid "Writing column %s with fixed length %d chars (may be truncated)"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:758
+#, c-format
+msgid "Column type not supported (%s)"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:773
+#, c-format
+msgid "Unable open database <%s> by driver <%s>"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:810
+#, c-format
+msgid "Counting polygons for %d features..."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:832
+#, c-format
+msgid "Boundary splitting distance in map units: %G"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:837
+#, c-format
+msgid "Importing map %d features..."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:916 ../vector/v.random/main.c:300
+#: ../raster/r.to.vect/areas_io.c:371 ../raster/r.to.vect/util.c:156
+#, c-format
+msgid "Cannot insert new row: %s"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:932
+#, c-format
+msgid "%d %s without geometry"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:957
+msgid "Cleaning polygons, result is not guaranteed!"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:961
+#, c-format
+msgid "Snap boundaries (threshold = %.3e):"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:975
+msgid "Break polygons:"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:980 ../vector/v.in.ogr/main.c:994
+msgid "Remove duplicates:"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:990
+msgid "Break boundaries:"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:998
+msgid "Clean boundaries at nodes:"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1005
+msgid "Merge boundaries:"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1010
+msgid "Change boundary dangles to lines:"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1014
+msgid "Change dangles to lines:"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1020
+msgid "Change boundary bridges to lines:"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1024
+msgid "Remove bridges:"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1059
+#, c-format
+msgid "Find centroids for layer: %s"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1080
+msgid "Write centroids:"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1130
+#, c-format
+msgid ""
+"%d areas represent more (overlapping) features, because polygons overlap in "
+"input layer(s). Such areas are linked to more than 1 row in attribute table. "
+"The number of features for those areas is stored as category in layer %d"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1140
+#, c-format
+msgid "%d input polygons\n"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1141
+#, c-format
+msgid "%d input polygons"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1144
+#, c-format
+msgid "Total area: %G (%d areas)\n"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1145
+#, c-format
+msgid "Total area: %G (%d areas)"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1148
+#, c-format
+msgid "Overlapping area: %G (%d areas)\n"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1150
+#, c-format
+msgid "Overlapping area: %G (%d areas)"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1154
+#, c-format
+msgid "Area without category: %G (%d areas)\n"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1156
+#, c-format
+msgid "Area without category: %G (%d areas)"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1201 ../raster/r.external/main.c:264
+#: ../raster/r.in.gdal/main.c:621
+msgid "Default region for this location updated"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1204 ../raster/r.external/main.c:267
+#: ../raster/r.in.gdal/main.c:624
+msgid "Region for the current mapset updated"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1208
+msgid ""
+"Input data contains 3D features. Created vector is 2D only, use -z flag to "
+"import 3D vector"
+msgstr ""
+#: ../vector/v.label/main.c:61 ../vector/v.label.sa/main.c:54
+msgid "vector, paint labels"
+msgstr ""
+#: ../vector/v.label/main.c:63
+msgid "Creates paint labels for a vector map from attached attributes."
+msgstr ""
+#: ../vector/v.label/main.c:68 ../vector/v.label.sa/main.c:107
+msgid "Name for new paint-label file"
+msgstr ""
+#: ../vector/v.label/main.c:70
+msgid "If not given the name of the input map is used"
+msgstr ""
+#: ../vector/v.label/main.c:79 ../vector/v.label.sa/main.c:103
+msgid "Name of attribute column to be used for labels"
+msgstr ""
+#: ../vector/v.label/main.c:90
+msgid "Rotate labels to align with lines"
+msgstr ""
+#: ../vector/v.label/main.c:95
+msgid "Curl labels along lines"
+msgstr ""
+#: ../vector/v.label/main.c:100
+msgid "Offset label in x-direction"
+msgstr ""
+#: ../vector/v.label/main.c:103 ../vector/v.label/main.c:110
+#: ../vector/v.label/main.c:119 ../vector/v.label/main.c:163
+msgid "Placement"
+msgstr ""
+#: ../vector/v.label/main.c:107
+msgid "Offset label in y-direction"
+msgstr ""
+#: ../vector/v.label/main.c:123 ../display/d.vect/main.c:262
+#: ../display/d.text.freetype/main.c:168 ../display/d.text.new/main.c:221
+msgid "Font name"
+msgstr ""
+#: ../vector/v.label/main.c:138
+msgid "Space between letters for curled labels (in map-units)"
+msgstr ""
+#: ../vector/v.label/main.c:145
+msgid "Label size (in points)"
+msgstr ""
+#: ../vector/v.label/main.c:157
+msgid "Rotation angle (degrees counter-clockwise)"
+msgstr ""
+#: ../vector/v.label/main.c:167
+msgid "Border width"
+msgstr ""
+#: ../vector/v.label/main.c:181 ../vector/v.label.sa/main.c:163
+msgid "Width of highlight coloring"
+msgstr ""
+#: ../vector/v.label/main.c:201 ../vector/v.label.sa/main.c:181
+msgid "Opaque to vector (only relevant if background color is selected)"
+msgstr ""
+#: ../vector/v.label/main.c:252
+msgid ""
+"size and space options vary significantly which may lead to crummy output"
+msgstr ""
+#: ../vector/v.label/main.c:260
+msgid "Too many parameters for <reference>"
+msgstr ""
+#: ../vector/v.label/main.c:323 ../vector/v.overlay/main.c:304
+#: ../vector/v.label.sa/labels.c:174
+msgid "Unable to select attributes"
+msgstr ""
+#: ../vector/v.label/main.c:442
+#, c-format
+msgid "Labeled %d lines."
+msgstr ""
+#: ../vector/v.overlay/area_area.c:39 ../vector/v.overlay/line_area.c:69
+msgid "Breaking lines..."
+msgstr ""
+#: ../vector/v.overlay/area_area.c:46
+msgid "Cleaning boundaries at nodes..."
+msgstr ""
+#: ../vector/v.overlay/area_area.c:78
+#, c-format
+msgid "Querying vector map <%s>..."
+msgstr ""
+#: ../vector/v.overlay/area_area.c:103 ../vector/v.overlay/area_area.c:183
+#: ../vector/v.overlay/area_area.c:211 ../vector/v.overlay/line_area.c:161
+#: ../vector/v.overlay/line_area.c:189
+msgid "Attribute not found"
+msgstr ""
+#: ../vector/v.overlay/area_area.c:114
+msgid "Writing centroids..."
+msgstr ""
+#: ../vector/v.overlay/main.c:56
+msgid "Overlays two vector maps."
+msgstr ""
+#: ../vector/v.overlay/main.c:59 ../vector/v.select/args.c:10
+msgid "Name of input vector map (A)"
+msgstr ""
+#: ../vector/v.overlay/main.c:63 ../vector/v.select/args.c:14
+msgid "Feature type (vector map A)"
+msgstr ""
+#: ../vector/v.overlay/main.c:69 ../vector/v.select/args.c:19
+msgid "Layer number (vector map A)"
+msgstr ""
+#: ../vector/v.overlay/main.c:73 ../vector/v.select/args.c:24
+msgid "Name of input vector map (B)"
+msgstr ""
+#: ../vector/v.overlay/main.c:77 ../vector/v.select/args.c:28
+msgid "Feature type (vector map B)"
+msgstr ""
+#: ../vector/v.overlay/main.c:83 ../vector/v.select/args.c:33
+msgid "Layer number (vector map B)"
+msgstr ""
+#: ../vector/v.overlay/main.c:95
+msgid "Operator defines features written to output vector map"
+msgstr ""
+#: ../vector/v.overlay/main.c:98
+msgid ""
+"Feature is written to output if the result of operation 'ainput operator "
+"binput' is true. Input feature is considered to be true, if category of "
+"given layer is defined."
+msgstr ""
+#: ../vector/v.overlay/main.c:103
+msgid ""
+"and;also known as 'intersection' in GIS;or;also known as 'union' in GIS "
+"(only for atype=area);not;features from ainput not overlayed by features "
+"from binput;xor;features from either ainput or binput but not those from "
+"ainput overlayed by binput (only for atype=area)"
+msgstr ""
+#: ../vector/v.overlay/main.c:114
+msgid "Output layer for new category, ainput and binput"
+msgstr ""
+#: ../vector/v.overlay/main.c:115
+msgid "If 0 or not given, the category is not written"
+msgstr ""
+#: ../vector/v.overlay/main.c:152
+#, c-format
+msgid "Operator '%s' is not supported for type line"
+msgstr ""
+#: ../vector/v.overlay/main.c:199
+#, c-format
+msgid "Copying vector objects from vector map <%s>..."
+msgstr ""
+#: ../vector/v.overlay/main.c:235
+#, c-format
+msgid "No %s features found in vector map <%s>. Verify '%s' parameter."
+msgstr ""
+#: ../vector/v.overlay/main.c:269
+msgid "Collecting input attributes..."
+msgstr ""
+#: ../vector/v.overlay/main.c:352
+#, c-format
+msgid "Unknown column type '%s'"
+msgstr ""
+#: ../vector/v.overlay/main.c:417
+#, c-format
+msgid "Unknown column type '%s' values lost"
+msgstr ""
+#: ../vector/v.overlay/main.c:482
+msgid "Building partial topology..."
+msgstr ""
+#: ../vector/v.select/args.c:45
+msgid "Operator defines required relation between features"
+msgstr ""
+#: ../vector/v.select/args.c:47
+msgid ""
+"A feature is written to output if the result of operation 'ainput operator "
+"binput' is true. An input feature is considered to be true, if category of "
+msgstr ""
+#: ../vector/v.select/args.c:53
+msgid "overlap;features partially or completely overlap"
+msgstr ""
+#: ../vector/v.select/args.c:58
+msgid ""
+"overlap;features partially or completely overlap;equals;features are "
+"spatially equals (using GEOS);disjoint;features do not spatially intersect "
+"(using GEOS);intersects;features spatially intersect (using GEOS);touches;"
+"features spatially touches (using GEOS);crosses;features spatially crosses "
+"(using GEOS);within;feature A is completely inside feature B (using GEOS);"
+"contains;feature B is completely inside feature A (using GEOS);overlaps;"
+"features spatially overlap (using GEOS);relate;feature A is spatially "
+"related to feature B (using GEOS, requires 'relate' option);"
+msgstr ""
+#: ../vector/v.select/args.c:75
+msgid "Intersection Matrix Pattern used for 'relate' operator"
+msgstr ""
+#: ../vector/v.select/args.c:84
+msgid "Do not skip features without category"
+msgstr ""
+#: ../vector/v.select/main.c:52
+msgid "vector, spatial query"
+msgstr ""
+#: ../vector/v.select/main.c:54
+msgid ""
+"Selects features from vector map (A) by features from other vector map (B)."
+msgstr ""
+#: ../vector/v.select/main.c:87
+msgid "Unknown operator"
+msgstr ""
+#: ../vector/v.select/main.c:124
+msgid "Output from v.select"
+msgstr ""
+#: ../vector/v.select/main.c:143 ../vector/v.what/main.c:162
+#: ../display/d.what.vect/main.c:154
+msgid "Building spatial index..."
+msgstr ""
+#: ../vector/v.select/main.c:149 ../vector/v.category/main.c:229
+msgid "Processing features..."
+msgstr ""
+#: ../vector/v.select/main.c:172
+#, c-format
+msgid "Unable to read line id %d from vector map <%s>"
+msgstr ""
+#: ../vector/v.select/main.c:278
+msgid "Processing areas..."
+msgstr ""
+#: ../vector/v.select/main.c:301
+#, c-format
+msgid "Unable to read area id %d from vector map <%s>"
+msgstr ""
+#: ../vector/v.select/main.c:446
+msgid "Writing selected features..."
+msgstr ""
+#: ../vector/v.select/main.c:512
+#, c-format
+msgid "Layer %d - no table"
+msgstr ""
+#: ../vector/v.select/main.c:527
+#, c-format
+msgid "Layer %d - unable to copy table"
+msgstr ""
+#: ../vector/v.select/main.c:542
+#, c-format
+msgid "%d features without category skipped"
+msgstr ""
+#: ../vector/v.select/main.c:545
+#, c-format
+msgid "%d features written to output."
+msgstr ""
+#: ../vector/v.net.visibility/main.c:46
+msgid "vector, path, visibility"
+msgstr ""
+#: ../vector/v.net.visibility/main.c:47
+msgid "Visibility graph construction."
+msgstr ""
+#: ../vector/v.net.visibility/main.c:59
+msgid "One or more coordinates"
+msgstr ""
+#: ../vector/v.net.visibility/main.c:65
+msgid "Add points after computing the vis graph"
+msgstr ""
+#: ../vector/v.net.visibility/main.c:98
+#, c-format
+msgid "Unable to copy elements from vector map <%s>"
+msgstr ""
+#: ../vector/v.net.visibility/main.c:104
+msgid "Lat-long projection"
+msgstr ""
+#: ../vector/v.normal/main.c:80
+msgid "Tests for normality for points."
+msgstr ""
+#: ../vector/v.normal/main.c:223
+msgid "Doing log transformation"
+msgstr ""
+#: ../vector/v.random/main.c:85
+msgid "Randomly generate a 2D/3D vector points map."
+msgstr ""
+#: ../vector/v.random/main.c:93
+msgid "Number of points to be created"
+msgstr ""
+#: ../vector/v.random/main.c:100
+msgid "Minimum z height (needs -z flag or column name)"
+msgstr ""
+#: ../vector/v.random/main.c:102 ../vector/v.random/main.c:111
+#: ../vector/v.random/main.c:123 ../vector/v.random/main.c:128
+msgid "3D output"
+msgstr ""
+#: ../vector/v.random/main.c:109
+msgid "Maximum z height (needs -z flag or column name)"
+msgstr ""
+#: ../vector/v.random/main.c:119
+msgid "Column name and type (i.e. INTEGER, DOUBLE PRECISION) for z values"
+msgstr ""
+#: ../vector/v.random/main.c:121
+msgid ""
+"If type is not given then DOUBLE PRECISION is used. Writes Z data to column "
+"instead of 3D vector."
+msgstr ""
+#: ../vector/v.random/main.c:132
+msgid "Use drand48() function instead of rand()"
+msgstr ""
+#: ../vector/v.random/main.c:142
+msgid "v.random can't create 3D vector and attribute table at same time"
+msgstr ""
+#: ../vector/v.random/main.c:150
+#, c-format
+msgid "Number of points must be > 0 (%d given)"
+msgstr ""
+#: ../vector/v.random/main.c:179
+#, c-format
+msgid "Using 'double precision' for column <%s>"
+msgstr ""
+#: ../vector/v.random/main.c:221
+msgid "Table should contain only two columns"
+msgstr ""
+#: ../vector/v.random/main.c:234
+msgid ""
+"You have created unsupported column type. This module supports only INTEGER "
+"and DOUBLE PRECISION column types."
+msgstr ""
+#: ../vector/v.random/main.c:264
+msgid "Generating points..."
+msgstr ""
+#: ../vector/v.mapcalc/vector.c:244
+msgid "Can't call bad function"
+msgstr ""
+#: ../vector/v.mapcalc/vector.c:281
+#, c-format
+msgid "Bad arguments to pointfunc %s"
+msgstr ""
+#: ../vector/v.mapcalc/vector.c:304 ../vector/v.mapcalc/number.c:216
+#, c-format
+msgid "No function defined to perform ``point %c point''"
+msgstr ""
+#: ../vector/v.mapcalc/number.c:159
+msgid "Can't call bad num-function"
+msgstr ""
+#: ../vector/v.mapcalc/number.c:189
+#, c-format
+msgid "Bad arguments to numfunc %s"
+msgstr ""
+#: ../vector/v.mapcalc/number.c:213
+#, c-format
+msgid "No function defined to perform ``number %c number''"
+msgstr ""
+#: ../vector/v.mapcalc/map.c:67
+#, c-format
+msgid "Performing 1 arg map function on map %s"
+msgstr ""
+#: ../vector/v.mapcalc/map.c:78
+#, c-format
+msgid "Performing 2 arg map function on maps %s and %s"
+msgstr ""
+#: ../vector/v.mapcalc/map.c:90
+#, c-format
+msgid "Performing map %s + %s"
+msgstr ""
+#: ../vector/v.mapcalc/map.c:264
+msgid "Can't call bad map-function"
+msgstr ""
+#: ../vector/v.mapcalc/map.c:276
+#, c-format
+msgid "Bad arguments to mapfunc %s (argc = %d)"
+msgstr ""
+#: ../vector/v.mapcalc/map.c:300
+#, c-format
+msgid "No function defined to perform map %c map"
+msgstr ""
+#: ../vector/v.mapcalc/any.c:116
+msgid "Can't call bad any-function"
+msgstr ""
+#: ../vector/v.mapcalc/any.c:128
+#, c-format
+msgid "Bad arguments to anyfunc %s (argc = %d)"
+msgstr ""
+#: ../vector/v.to.rast3/main.c:45
+msgid "vector, volume, conversion"
+msgstr ""
+#: ../vector/v.to.rast3/main.c:46
+msgid ""
+"Converts a binary GRASS vector map (only points) layer into a 3D GRASS "
+"raster map layer."
+msgstr ""
+#: ../vector/v.to.rast3/main.c:59
+msgid "Column name (type must be numeric)"
+msgstr ""
+#: ../vector/v.to.rast3/main.c:108
+msgid "Unable to create output map"
+msgstr ""
+#: ../vector/v.to.rast3/main.c:162
+msgid "Unable to close new 3d raster map"
+msgstr ""
+#: ../vector/v.buffer2/main.c:149
+msgid "vector, buffer"
+msgstr ""
+#: ../vector/v.buffer2/main.c:169
+msgid "Buffer distance along major axis in map units"
+msgstr ""
+#: ../vector/v.buffer2/main.c:170 ../vector/v.buffer2/main.c:178
+#: ../vector/v.buffer2/main.c:186 ../vector/v.buffer2/main.c:192
+#: ../vector/v.buffer2/main.c:200 ../vector/v.buffer2/main.c:209
+msgid "Distance"
+msgstr ""
+#: ../vector/v.buffer2/main.c:177
+msgid "Buffer distance along minor axis in map units"
+msgstr ""
+#: ../vector/v.buffer2/main.c:191
+msgid "Name of column to use for buffer distances"
+msgstr ""
+#: ../vector/v.buffer2/main.c:224
+msgid ""
+"This is an alias to the distance option. It is retained for backwards "
+"compatibility"
+msgstr ""
+#: ../vector/v.buffer2/main.c:231
+msgid "Make outside corners straight"
+msgstr ""
+#: ../vector/v.buffer2/main.c:235
+msgid "Don't make caps at the ends of polylines"
+msgstr ""
+#: ../vector/v.buffer2/main.c:246
+msgid "Select a buffer distance/minordistance/angle or column, but not both."
+msgstr ""
+#: ../vector/v.buffer2/main.c:261
+msgid "The bufcol option requires a valid layer."
+msgstr ""
+#: ../vector/v.buffer2/main.c:264
+msgid ""
+"The buffer option has been replaced by the distance option and will be "
+"removed in future."
+msgstr ""
+#: ../vector/v.buffer2/main.c:267
+msgid "Use the distance option instead of the buffer option."
+msgstr ""
+#: ../vector/v.buffer2/main.c:271
+msgid "The tolerance must be > 0."
+msgstr ""
+#: ../vector/v.buffer2/main.c:274
+#, c-format
+msgid "The tolerance was reset to %g"
+msgstr ""
+#: ../vector/v.buffer2/main.c:298
+#, c-format
+msgid "The tolerance in map units = %g"
+msgstr ""
+#: ../vector/v.buffer2/main.c:343
+#, c-format
+msgid "Unable to select data from table <%s>"
+msgstr ""
+#: ../vector/v.buffer2/main.c:379
+msgid ""
+"No features available for buffering. Check type option and features "
+"available in the input vector."
+msgstr ""
+#: ../vector/v.buffer2/main.c:393
+msgid "Buffering lines..."
+msgstr ""
+#: ../vector/v.buffer2/main.c:467
+msgid "Buffering areas..."
+msgstr ""
+#: ../vector/v.buffer2/main.c:523
+msgid "Writing buffers..."
+msgstr ""
+#: ../vector/v.buffer2/main.c:545
+msgid "Breaking polygons..."
+msgstr ""
+#: ../vector/v.buffer2/main.c:558
+msgid "Cleaning boundaries at nodes"
+msgstr ""
+#: ../vector/v.category/main.c:67
+msgid "vector, category"
+msgstr ""
+#: ../vector/v.category/main.c:69
+msgid "Attach, delete or report vector categories to map geometry."
+msgstr ""
+#: ../vector/v.category/main.c:83
+msgid "Action to be done"
+msgstr ""
+#: ../vector/v.category/main.c:84
+msgid ""
+"add;add a new category;del;delete all categories of given layer;chlayer;"
+"change layer number (e.g. layer=3,1 changes layer 3 to layer 1);sum;add the "
+"value specified by cat option to the current category value;report;print "
+"report (statistics), in shell style: layer type count min max;print;print "
+"category values, more cats in the same layer are separated by '/'"
+msgstr ""
+#: ../vector/v.category/main.c:100
+msgid "Feature ids (by default all features are processed)"
+msgstr ""
+#: ../vector/v.category/main.c:116
+msgid "Shell script style, currently only for report"
+msgstr ""
+#: ../vector/v.category/main.c:117
+msgid "Format: layer type count min max"
+msgstr ""
+#: ../vector/v.category/main.c:135
+msgid ""
+"Database connection and attribute tables for concerned layers are not changed"
+msgstr ""
+#: ../vector/v.category/main.c:153
+msgid ""
+"Invalid category number (must be equal to or greater than 0). Normally "
+"category number starts at 1."
+msgstr ""
+#: ../vector/v.category/main.c:162
+#, c-format
+msgid "%d errors in id option"
+msgstr ""
+#: ../vector/v.category/main.c:183
+msgid "Too many layers for this operation"
+msgstr ""
+#: ../vector/v.category/main.c:186
+msgid "2 layers must be specified"
+msgstr ""
+#: ../vector/v.category/main.c:190
+msgid "Output vector wasn't entered"
+msgstr ""
+#: ../vector/v.category/main.c:261 ../vector/v.delaunay2/main.c:172
+msgid "Unable to calculate area centroid"
+msgstr ""
+#: ../vector/v.category/main.c:274
+#, c-format
+msgid "%d new centroids placed in output map"
+msgstr ""
+#: ../vector/v.category/main.c:445
+msgid "Layer/table"
+msgstr ""
+#: ../vector/v.category/main.c:449
+msgid "Layer"
+msgstr ""
+#: ../vector/v.category/main.c:451
+#, c-format
+msgid "type       count        min        max\n"
+msgstr ""
+#: ../vector/v.category/main.c:452
+msgid "point"
+msgstr ""
+#: ../vector/v.category/main.c:456
+msgid "line"
+msgstr ""
+#: ../vector/v.category/main.c:460
+msgid "boundary"
+msgstr ""
+#: ../vector/v.category/main.c:464
+msgid "centroid"
+msgstr ""
+#: ../vector/v.category/main.c:468
+msgid "area"
+msgstr ""
+#: ../vector/v.category/main.c:472
+msgid "all"
+msgstr ""
+#: ../vector/v.category/main.c:525
+msgid "Copying attribute table(s)..."
+msgstr ""
+#: ../vector/v.category/main.c:531
+#, c-format
+msgid "%d features modified."
+msgstr ""
+#: ../vector/v.distance/main.c:116
+msgid ""
+"Finds the nearest element in vector map 'to' for elements in vector map "
+"'from'."
+msgstr ""
+#: ../vector/v.distance/main.c:120
+msgid "Name of existing vector map (from)"
+msgstr ""
+#: ../vector/v.distance/main.c:125
+msgid "Name of existing vector map (to)"
+msgstr ""
+#: ../vector/v.distance/main.c:132
+msgid "Feature type (from)"
+msgstr ""
+#: ../vector/v.distance/main.c:139
+msgid "Feature type (to)"
+msgstr ""
+#: ../vector/v.distance/main.c:144
+msgid "Layer number (from)"
+msgstr ""
+#: ../vector/v.distance/main.c:149
+msgid "Layer number (to)"
+msgstr ""
+#: ../vector/v.distance/main.c:155
+msgid "Name for output vector map containing lines connecting nearest elements"
+msgstr ""
+#: ../vector/v.distance/main.c:163
+msgid "Maximum distance or -1 for no limit"
+msgstr ""
+#: ../vector/v.distance/main.c:170
+msgid "Minimum distance or -1 for no limit"
+msgstr ""
+#: ../vector/v.distance/main.c:179
+msgid "Values describing the relation between two nearest features"
+msgstr ""
+#: ../vector/v.distance/main.c:181
+msgid ""
+"cat;category of the nearest feature;dist;minimum distance to nearest feature;"
+"to_x;x coordinate of the nearest point on the 'to' feature;to_y;y coordinate "
+"of the nearest point on the 'to' feature;to_along;distance to the nearest "
+"point on the 'to' feature along that linear feature;to_angle;angle along the "
+"nearest linear feature in the 'to' map, measured CCW from the +x axis, in "
+"radians, between -Pi and Pi inclusive;to_attr;attribute of nearest feature "
+"given by to_column option"
+msgstr ""
+#: ../vector/v.distance/main.c:202
+msgid ""
+"Column name(s) where values specified by 'upload' option will be uploaded"
+msgstr ""
+#: ../vector/v.distance/main.c:203
+msgid "From_map"
+msgstr ""
+#: ../vector/v.distance/main.c:208
+msgid "Column name of nearest feature (used with upload=to_attr)"
+msgstr ""
+#: ../vector/v.distance/main.c:214
+msgid "Name of table created for output when the distance to all flag is used"
+msgstr ""
+#: ../vector/v.distance/main.c:219
+msgid "Print output to stdout, don't update attribute table"
+msgstr ""
+#: ../vector/v.distance/main.c:221
+msgid "First column is always category of 'from' feature called from_cat"
+msgstr ""
+#: ../vector/v.distance/main.c:226
+msgid "Calculate distances to all features within the threshold"
+msgstr ""
+#: ../vector/v.distance/main.c:228
+msgid ""
+"Output is written to stdout but may be uploaded to a new table created by "
+"this module; multiple 'upload' options may be used."
+msgstr ""
+#: ../vector/v.distance/main.c:280
+msgid "to_column option missing"
+msgstr ""
+#: ../vector/v.distance/main.c:292
+msgid "Too many column names"
+msgstr ""
+#: ../vector/v.distance/main.c:299
+msgid "Not enough column names"
+msgstr ""
+#: ../vector/v.distance/main.c:306
+#, c-format
+msgid "Vector map <%s> is not in user mapset and cannot be updated"
+msgstr ""
+#: ../vector/v.distance/main.c:387
+msgid "Unable to open default database"
+msgstr ""
+#: ../vector/v.distance/main.c:443
+msgid "Incompatible column types"
+msgstr ""
+#: ../vector/v.distance/main.c:516
+msgid "Finding nearest lines..."
+msgstr ""
+#: ../vector/v.distance/main.c:646
+msgid "Finding nearest areas..."
+msgstr ""
+#: ../vector/v.distance/main.c:718
+#, c-format
+msgid "More cats found in to_layer (area=%d)"
+msgstr ""
+#: ../vector/v.distance/main.c:859
+msgid "DATETIME type not yet supported, no attributes will be uploaded"
+msgstr ""
+#: ../vector/v.distance/main.c:1108
+#, c-format
+msgid "%d categories with more than 1 feature in vector map <%s>"
+msgstr ""
+#: ../vector/v.distance/main.c:1111
+#, c-format
+msgid "%d categories - no nearest feature found"
+msgstr ""
+#: ../vector/v.distance/main.c:1120
+#, c-format
+msgid "%d distances calculated"
+msgstr ""
+#: ../vector/v.distance/main.c:1121
+#, c-format
+msgid "%d records inserted"
+msgstr ""
+#: ../vector/v.distance/main.c:1123
+#, c-format
+msgid "%d insert errors"
+msgstr ""
+#: ../vector/v.distance/main.c:1127
+#, c-format
+msgid "%d categories read from the map"
+msgstr ""
+#: ../vector/v.distance/main.c:1129
+#, c-format
+msgid "%d categories exist in the table"
+msgstr ""
+#: ../vector/v.distance/main.c:1131
+#, c-format
+msgid "%d categories read from the map exist in the table"
+msgstr ""
+#: ../vector/v.distance/main.c:1134
+#, c-format
+msgid "%d categories read from the map don't exist in the table"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:95
+msgid "vector, network, centrality measures"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:97
+msgid ""
+"Computes degree, centrality, betweeness, closeness and eigenvector "
+"centrality measures in the network."
+msgstr ""
+#: ../vector/v.net.centrality/main.c:127
+msgid "Name of degree centrality column"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:128 ../vector/v.net.centrality/main.c:134
+#: ../vector/v.net.centrality/main.c:140 ../vector/v.net.centrality/main.c:146
+msgid "Columns"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:133
+msgid "Name of closeness centrality column"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:139
+msgid "Name of betweenness centrality column"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:145
+msgid "Name of eigenvector centrality column"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:154
+msgid "Maximum number of iterations to compute eigenvector centrality"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:162
+msgid "Cummulative error tolerance for eigenvector centrality"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:293
+msgid "Computing degree centrality measure"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:297
+msgid "Computing betweenness and/or closeness centrality measure"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:304
+msgid "Computing eigenvector centrality measure"
+msgstr ""
+#: ../vector/v.net.connectivity/main.c:53
+msgid "vector, network, connectivity"
+msgstr ""
+#: ../vector/v.net.connectivity/main.c:55
+msgid "Computes vertex connectivity between two sets of nodes in the network."
+msgstr ""
+#: ../vector/v.net.connectivity/main.c:66
+msgid "Name of node capacity column"
+msgstr ""
+#: ../vector/v.net.connectivity/main.c:70
+msgid "Set1 layer number or name"
+msgstr ""
+#: ../vector/v.net.connectivity/main.c:71
+#: ../vector/v.net.connectivity/main.c:76
+#: ../vector/v.net.connectivity/main.c:82
+msgid "Set1"
+msgstr ""
+#: ../vector/v.net.connectivity/main.c:75
+msgid "Set1 category values"
+msgstr ""
+#: ../vector/v.net.connectivity/main.c:81
+msgid "Set1 WHERE conditions of SQL statement without 'where' keyword"
+msgstr ""
+#: ../vector/v.net.connectivity/main.c:86
+msgid "Set2 layer number or name"
+msgstr ""
+#: ../vector/v.net.connectivity/main.c:87
+#: ../vector/v.net.connectivity/main.c:92
+#: ../vector/v.net.connectivity/main.c:98
+msgid "Set2"
+msgstr ""
+#: ../vector/v.net.connectivity/main.c:91
+msgid "Set2 category values"
+msgstr ""
+#: ../vector/v.net.connectivity/main.c:97
+msgid "Set2 WHERE conditions of SQL statement without 'where' keyword"
+msgstr ""
+#: ../vector/v.net.connectivity/main.c:148
+#: ../vector/v.net.connectivity/main.c:151
+#, c-format
+msgid "%s is empty"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:107
+msgid "Column type of wcolumn is not supported (must be integer or double)"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:126
+msgid ""
+"Column type of smooth column is not supported (must be integer or double)"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:204
+msgid ""
+"Interpolates point data to a 3D raster map using regularized spline with "
+"tension (RST) algorithm."
+msgstr ""
+#: ../vector/v.vol.rst/main.c:237
+msgid "Name of the vector map with input x,y,z,w"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:245
+msgid "Name of the surface raster map for cross-section"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:252
+msgid "Name of the column containing w attribute to interpolate"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:276
+msgid "Name of the column with smoothing parameters"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:287 ../vector/v.vol.rst/main.c:295
+msgid "Analysis"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:294
+msgid "Output cross-validation vector map"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:327
+msgid "Maximum number of points for approximation in a segment (>npmin)"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:345
+msgid "Conversion factor for w-values used for interpolation"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:353
+msgid "Conversion factor for z-values"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:361
+msgid "Output cross-section raster map"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:362 ../vector/v.vol.rst/main.c:379
+#: ../vector/v.vol.rst/main.c:389 ../vector/v.vol.rst/main.c:398
+#: ../vector/v.vol.rst/main.c:407 ../vector/v.vol.rst/main.c:416
+#: ../vector/v.vol.rst/main.c:425 ../raster/r.sun/main.c:312
+#: ../raster/r.sun/main.c:321 ../raster/r.sun/main.c:330
+#: ../raster/r.sun/main.c:339 ../raster/r.sun/main.c:348
+#: ../raster/r.resamp.rst/main.c:183 ../raster/r.resamp.rst/main.c:191
+#: ../raster/r.resamp.rst/main.c:199 ../raster/r.resamp.rst/main.c:207
+#: ../raster/r.resamp.rst/main.c:215 ../raster/r.resamp.rst/main.c:223
+#: ../raster/r.resamp.rst/main.c:287 ../raster/r.horizon/main.c:300
+#: ../raster/r.horizon/main.c:310 ../raster/r.horizon/main.c:318
+#: ../raster/r.sun2/main.c:381 ../raster/r.sun2/main.c:390
+#: ../raster/r.sun2/main.c:399 ../raster/r.sun2/main.c:408
+#: ../raster/r.sun2/main.c:417 ../raster/r.sun2/main.c:426
+#: ../raster/r.watershed/front/main.c:97
+#: ../raster/r.watershed/front/main.c:103
+#: ../raster/r.watershed/front/main.c:110
+#: ../raster/r.watershed/front/main.c:116
+#: ../raster/r.watershed/front/main.c:123
+#: ../raster/r.watershed/front/main.c:130
+#: ../raster/r.watershed/front/main.c:137
+#: ../raster/r.watershed/front/main.c:143
+msgid "Output_options"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:370
+msgid "Output elevation g3d-file"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:378
+msgid "Output gradient magnitude g3d-file"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:388
+msgid "Output gradient horizontal angle g3d-file"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:397
+msgid "Output gradient vertical angle g3d-file"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:406
+msgid "Output change of gradient g3d-file"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:415
+msgid "Output gaussian curvature g3d-file"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:424
+msgid "Output mean curvature g3d-file"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:430
+msgid "Perform a cross-validation procedure without volume interpolation"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:467
+msgid "Smoothing must be a positive value"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:473
+msgid "Both crossvalidation options (-c, cvdev) must be specified"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:475
+msgid "Both crossvalidation and deviations file specified"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:557
+msgid "Vector is not 3D"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:596 ../vector/v.digit/c_face.c:269
+#, c-format
+msgid "Cannot create table: %s"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:612
+#, c-format
+msgid "Cannot open %s"
+msgstr ""
+#: ../vector/v.transform/trans_digit.c:96
+#, c-format
+msgid "Unsupported column type of <%s>"
+msgstr ""
+#: ../vector/v.transform/trans_digit.c:104
+#, c-format
+msgid ""
+"Unable to select value for category %d from table <%s>, column <%s>. For "
+"category %d using default transformation parameter %.3f."
+msgstr ""
+#: ../vector/v.transform/trans_digit.c:115
+msgid "No category number defined. Using default transformation parameters."
+msgstr ""
+#: ../vector/v.transform/creat_trans.c:69
+#, c-format
+msgid " Number of points that have been entered: %d\n"
+msgstr ""
+#: ../vector/v.transform/creat_trans.c:102
+msgid "Please answer yes or no"
+msgstr ""
+#: ../vector/v.transform/creat_trans.c:118
+msgid "Error reading coordinates file"
+msgstr ""
+#: ../vector/v.transform/creat_trans.c:123
+#, c-format
+msgid "Number of points that have been entered [%d]"
+msgstr ""
+#: ../vector/v.transform/creat_trans.c:126
+msgid "Error creating transformation"
+msgstr ""
+#: ../vector/v.transform/ask_trans.c:88
+msgid "ask_transform_coor():  Leaving session.. \n"
+msgstr ""
+#: ../vector/v.transform/get_coor.c:36
+msgid "Reading coordinates from file."
+msgstr ""
+#: ../vector/v.transform/setup_trans.c:83
+msgid "The points weren't spread out enough."
+msgstr ""
+#: ../vector/v.transform/setup_trans.c:86
+#, c-format
+msgid "You need to enter at least %d points."
+msgstr ""
+#: ../vector/v.transform/main.c:72
+msgid "vector, transformation"
+msgstr ""
+#: ../vector/v.transform/main.c:74
+msgid ""
+"Performs an affine transformation (shift, scale and rotate, or GPCs) on "
+"vector map."
+msgstr ""
+#: ../vector/v.transform/main.c:80
+msgid "Suppress display of residuals or other information"
+msgstr ""
+#: ../vector/v.transform/main.c:84
+msgid "Shift all z values to bottom=0"
+msgstr ""
+#: ../vector/v.transform/main.c:85 ../vector/v.transform/main.c:98
+#: ../vector/v.transform/main.c:123 ../vector/v.transform/main.c:132
+#: ../vector/v.transform/main.c:141 ../vector/v.transform/main.c:150
+#: ../vector/v.transform/main.c:159 ../vector/v.transform/main.c:168
+#: ../vector/v.transform/main.c:178
+msgid "Custom"
+msgstr ""
+#: ../vector/v.transform/main.c:90
+msgid "Print the transformation matrix to stdout"
+msgstr ""
+#: ../vector/v.transform/main.c:96
+msgid ""
+"Instead of points use transformation parameters (xshift, yshift, zshift, "
+"xscale, yscale, zscale, zrot)"
+msgstr ""
+#: ../vector/v.transform/main.c:109
+msgid "ASCII file holding transform coordinates"
+msgstr ""
+#: ../vector/v.transform/main.c:110
+msgid ""
+"If not given, transformation parameters (xshift, yshift, zshift, xscale, "
+"yscale, zscale, zrot) are used instead"
+msgstr ""
+#: ../vector/v.transform/main.c:121
+msgid "Shifting value for x coordinates"
+msgstr ""
+#: ../vector/v.transform/main.c:130
+msgid "Shifting value for y coordinates"
+msgstr ""
+#: ../vector/v.transform/main.c:148
+msgid "Scaling factor for x coordinates"
+msgstr ""
+#: ../vector/v.transform/main.c:157
+msgid "Scaling factor for y coordinates"
+msgstr ""
+#: ../vector/v.transform/main.c:166
+msgid "Scaling factor for z coordinates"
+msgstr ""
+#: ../vector/v.transform/main.c:176
+msgid "Rotation around z axis in degrees counterclockwise"
+msgstr ""
+#: ../vector/v.transform/main.c:182
+msgid "Name of table containing transformation parameters"
+msgstr ""
+#: ../vector/v.transform/main.c:191
+msgid "Name of attribute column(s) used as transformation parameters"
+msgstr ""
+#: ../vector/v.transform/main.c:193
+msgid "Format: parameter:column, e.g. xshift:xs,yshift:ys,zrot:zr"
+msgstr ""
+#: ../vector/v.transform/main.c:206
+#, c-format
+msgid ""
+"The '%c' flag is deprecated and will be removed in future. Transformation "
+"parameters are used automatically when no pointsfile is given."
+msgstr ""
+#: ../vector/v.transform/main.c:211
+#, c-format
+msgid ""
+"The '%c' flag is deprecated and will be removed in future. Please use '--"
+"quiet' instead."
+msgstr ""
+#: ../vector/v.transform/main.c:217
+#, c-format
+msgid "Table name is not defined. Please use '%s' parameter."
+msgstr ""
+#: ../vector/v.transform/main.c:222
+msgid ""
+"Name of table and name for output vector map must be different. Otherwise "
+"the table is overwritten."
+msgstr ""
+#: ../vector/v.transform/main.c:236
+#, c-format
+msgid "Unable to open file with coordinates <%s>"
+msgstr ""
+#: ../vector/v.transform/main.c:318
+#, c-format
+msgid "Unable to tokenize column string: [%s]"
+msgstr ""
+#: ../vector/v.transform/main.c:345
+#, c-format
+msgid ""
+"\n"
+"New vector map <%s> boundary coordinates:"
+msgstr ""
+#: ../vector/v.transform/main.c:347
+#, c-format
+msgid " N: %-10.3f    S: %-10.3f"
+msgstr ""
+#: ../vector/v.transform/main.c:348
+#, c-format
+msgid " E: %-10.3f    W: %-10.3f"
+msgstr ""
+#: ../vector/v.transform/main.c:349
+#, c-format
+msgid " B: %6.3f    T: %6.3f"
+msgstr ""
+#: ../vector/v.what/what.c:105 ../vector/v.what/what.c:107
+#: ../display/d.what.vect/what.c:179 ../display/d.what.vect/what.c:181
+#, c-format
+msgid "Nothing Found.\n"
+msgstr ""
+#: ../vector/v.what/what.c:157
+#, c-format
+msgid ""
+"Id: %d\n"
+"Type: %s\n"
+"Left: %d\n"
+"Right: %d\n"
+msgstr ""
+#: ../vector/v.what/what.c:162 ../vector/v.what/what.c:217
+#: ../display/d.what.vect/what.c:241
+#, c-format
+msgid "Length: %f\n"
+msgstr ""
+#: ../vector/v.what/what.c:180
+#, c-format
+msgid ""
+"Node[%d]=%d\n"
+"Number_lines=%d\n"
+"Coordinates=%.6f,%.6f,%.6f\n"
+msgstr ""
+#: ../vector/v.what/what.c:185
+#, c-format
+msgid ""
+"Node[%d]: %d\n"
+"Number of lines: %d\n"
+"Coordinates: %.6f, %.6f, %.6f\n"
+msgstr ""
+#: ../vector/v.what/what.c:199
+#, c-format
+msgid ""
+"Id: %5d\n"
+"Angle: %.8f\n"
+msgstr ""
+#: ../vector/v.what/what.c:214
+#, c-format
+msgid "Type: %s"
+msgstr ""
+#: ../vector/v.what/what.c:215
+#, c-format
+msgid "Id: %d\n"
+msgstr ""
+#: ../vector/v.what/what.c:231 ../display/d.what.vect/what.c:295
+#, c-format
+msgid "Point height: %f\n"
+msgstr ""
+#: ../vector/v.what/what.c:248 ../display/d.what.vect/what.c:313
+#, c-format
+msgid "Line height: %f\n"
+msgstr ""
+#: ../vector/v.what/what.c:259
+#, c-format
+msgid ""
+"Line height min: %f\n"
+"Line height max: %f\n"
+msgstr ""
+#: ../vector/v.what/what.c:273
+#, c-format
+msgid ""
+"Type: Area\n"
+"Area height: %f\n"
+msgstr ""
+#: ../vector/v.what/what.c:281
+#, c-format
+msgid "Type: Area\n"
+msgstr ""
+#: ../vector/v.what/what.c:303
+#, c-format
+msgid ""
+"Area: %d\n"
+"Number of isles: %d\n"
+msgstr ""
+#: ../vector/v.what/what.c:313
+#, c-format
+msgid "Isle[%d]: %d\n"
+msgstr ""
+#: ../vector/v.what/what.c:326
+#, c-format
+msgid "Island: %d In area: %d\n"
+msgstr ""
+#: ../vector/v.what/what.c:339 ../vector/v.what/what.c:346
+#, c-format
+msgid ""
+"Sq Meters: %.3f\n"
+"Hectares: %.3f\n"
+msgstr ""
+#: ../vector/v.what/what.c:341 ../vector/v.what/what.c:349
+#, c-format
+msgid ""
+"Acres: %.3f\n"
+"Sq Miles: %.4f\n"
+msgstr ""
+#: ../vector/v.what/what.c:372
+#, c-format
+msgid ""
+"Layer: %d\n"
+"Category: %d\n"
+msgstr ""
+#: ../vector/v.what/what.c:386
+#, c-format
+msgid ""
+"\n"
+"Driver: %s\n"
+"Database: %s\n"
+"Table: %s\n"
+"Key column: %s\n"
+msgstr ""
+#: ../vector/v.what/main.c:56
+msgid "vector, querying"
+msgstr ""
+#: ../vector/v.what/main.c:57
+msgid "Queries a vector map layer at given locations."
+msgstr ""
+#: ../vector/v.what/main.c:69 ../raster/r.what/main.c:127
+msgid "Coordinates for query"
+msgstr ""
+#: ../vector/v.what/main.c:70
+msgid "If not given reads from standard input"
+msgstr ""
+#: ../vector/v.what/main.c:77
+msgid "Query threshold distance"
+msgstr ""
+#: ../vector/v.what/main.c:81 ../display/d.what.vect/main.c:98
+msgid "Print topological information (debugging)"
+msgstr ""
+#: ../vector/v.what/main.c:85
+msgid "Print attribute information"
+msgstr ""
+#: ../vector/v.what/main.c:159
+#, c-format
+msgid "You must build topology on vector map <%s>"
+msgstr ""
+#: ../vector/v.what/main.c:178
+#, c-format
+msgid "Unknown input format, skipping: '%s'"
+msgstr ""
+#: ../vector/v.in.dxf/add_point.c:27 ../vector/v.in.dxf/add_arc.c:36
+#: ../vector/v.in.dxf/add_circle.c:32 ../vector/v.in.dxf/add_text.c:35
+#: ../vector/v.in.dxf/add_line.c:28 ../vector/v.in.dxf/add_3dface.c:29
+#: ../vector/v.in.dxf/add_polyline.c:90 ../vector/v.in.dxf/add_lwpolyline.c:33
+#, c-format
+msgid "Layer %d: %s\n"
+msgstr ""
+#: ../vector/v.in.dxf/read_dxf.c:57
+msgid "end of file while looking for HEADER"
+msgstr ""
+#: ../vector/v.in.dxf/write_vect.c:78
+msgid "No DXF layers found!"
+msgstr ""
+#: ../vector/v.in.dxf/write_vect.c:87
+msgid "Following DXF layers found:"
+msgstr ""
+#: ../vector/v.in.dxf/write_vect.c:91
+#, c-format
+msgid "Layer %d: %s"
+msgstr ""
+#: ../vector/v.in.dxf/write_vect.c:230
+#, c-format
+msgid "Unable to add database link for vector map <%s>"
+msgstr ""
+#: ../vector/v.in.dxf/add_polyline.c:45
+msgid "vertices following flag missing"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:62
+msgid "Converts files in DXF format to GRASS vector map format."
+msgstr ""
+#: ../vector/v.in.dxf/main.c:66
+msgid "Ignore the map extent of DXF file"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:70
+msgid "Do not create attribute tables"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:78
+msgid "Import polyface meshes as 3D wire frame"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:83 ../vector/v.in.dxf/main.c:89
+#: ../vector/v.in.dxf/main.c:94 ../vector/v.in.dxf/main.c:108
+msgid "DXF layers"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:93
+msgid "Import all objects into one layer"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:97
+msgid "Name of input DXF file"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:122
+#, c-format
+msgid "Unable to open DXF file <%s>"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:157
+#, c-format
+msgid "Option <%s>: <%s> exists."
+msgstr ""
+#: ../vector/v.in.dxf/main.c:162
+#, c-format
+msgid "Use '%s' option to change vector map name"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:189
+msgid "Building topology failed"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:195
+msgid "Failed to import DXF file!"
+msgstr ""
+#: ../vector/v.net.timetable/main.c:218
+#, c-format
+msgid "Could not find a path between stops %d and %d"
+msgstr ""
+#: ../vector/v.net.timetable/main.c:255
+msgid "Finds shortest path using timetables."
+msgstr ""
+#: ../vector/v.net.timetable/main.c:267
+msgid "Layer number or name with walking connections or -1"
+msgstr ""
+#: ../vector/v.net.timetable/main.c:272
+msgid "Layer number or name with route paths or -1"
+msgstr ""
+#: ../vector/v.net.timetable/main.c:278
+msgid "Name of column name with route ids"
+msgstr ""
+#: ../vector/v.net.timetable/main.c:285
+msgid "Name of column name with stop timestamps"
+msgstr ""
+#: ../vector/v.net.timetable/main.c:291
+msgid "Name of column name with stop ids"
+msgstr ""
+#: ../vector/v.net.timetable/main.c:297
+msgid "Name of column name with walk lengths"
+msgstr ""
+#: ../vector/v.net.timetable/main.c:345
+msgid "Could not initialize the timetables"
+msgstr ""
+#: ../vector/v.net.timetable/main.c:421 ../vector/v.net.timetable/main.c:452
+#: ../vector/v.net.timetable/main.c:460
+#, c-format
+msgid "No stop with category: %d"
+msgstr ""
+#: ../vector/v.net.timetable/main.c:444 ../vector/v.net.path/path.c:149
+#, c-format
+msgid "Wrong input format: %s"
+msgstr ""
+#: ../vector/v.net.timetable/main.c:467
+msgid "'From' and 'To' stops are the same"
+msgstr ""
+#: ../vector/v.net.timetable/main.c:476
+msgid "No path between the stops"
+msgstr ""
+#: ../vector/v.type/main.c:48
+msgid "Change the type of geometry elements."
+msgstr ""
+#: ../vector/v.type/main.c:62
+msgid "Feature type to convert from"
+msgstr ""
+#: ../vector/v.type/main.c:72
+msgid "Feature type to convert to"
+msgstr ""
+#: ../vector/v.type/main.c:77
+msgid "Pairs for input and output type separated by comma"
+msgstr ""
+#: ../vector/v.type/main.c:79
+msgid ""
+"<input_type1>,<output_type1>,<input_type2>,<output_type2>,...\n"
+"\t\tExample1: line,boundary\n"
+"\t\tExample2: line,boundary,point,centroid"
+msgstr ""
+#: ../vector/v.type/main.c:92
+msgid "Nothing to do"
+msgstr ""
+#: ../vector/v.type/main.c:141 ../vector/v.type/main.c:174
+msgid "Incompatible types"
+msgstr ""
+#: ../vector/v.type/main.c:186
+msgid "Not enough types"
+msgstr ""
+#: ../vector/v.type/main.c:189
+msgid "Odd number of types"
+msgstr ""
+#: ../vector/v.out.ascii/b2a.c:159
+#, c-format
+msgid "got type %d"
+msgstr ""
+#: ../vector/v.out.ascii/b2a.c:201
+#, c-format
+msgid "Feature has more categories. Only first category (%d) is exported."
+msgstr ""
+#: ../vector/v.out.ascii/b2a.c:211
+#, c-format
+msgid "Unable to select record from table <%s> (key %s, column %s)"
+msgstr ""
+#: ../vector/v.out.ascii/b2a.c:238
+#, c-format
+msgid "Column <%s>: unsupported data type"
+msgstr ""
+#: ../vector/v.out.ascii/out.c:47
+msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
+msgstr ""
+#: ../vector/v.out.ascii/out.c:54
+msgid "Path to resulting ASCII file or ASCII vector name if '-o' is defined"
+msgstr ""
+#: ../vector/v.out.ascii/out.c:66
+msgid "Field separator (points mode)"
+msgstr ""
+#: ../vector/v.out.ascii/out.c:83
+msgid "Name of attribute column(s) to be exported (point mode)"
+msgstr ""
+#: ../vector/v.out.ascii/out.c:91
+msgid "Create old (version 4) ASCII file"
+msgstr ""
+#: ../vector/v.out.ascii/out.c:96
+msgid "Only export points falling within current 3D region (points mode)"
+msgstr ""
+#: ../vector/v.out.ascii/out.c:111
+#, c-format
+msgid "Parameter '%s' ignored in standard mode"
+msgstr ""
+#: ../vector/v.out.ascii/out.c:119
+msgid "Format 'point' is not supported for old version"
+msgstr ""
+#: ../vector/v.out.ascii/out.c:123
+msgid "'output' must be given for old version"
+msgstr ""
+#: ../vector/v.out.ascii/out.c:147
+#, c-format
+msgid ""
+"Unable to open vector map <%s> at topology level. Areas will not be "
+"processed."
+msgstr ""
+#: ../vector/v.out.ascii/out.c:185
+msgid "dig_att file already exist"
+msgstr ""
+#: ../vector/v.out.ascii/out.c:188
+#, c-format
+msgid "Unable to open dig_att file <%s>"
+msgstr ""
+#: ../vector/v.net.iso/main.c:72
+msgid "Splits net by cost isolines."
+msgstr ""
+#: ../vector/v.net.iso/main.c:73
+msgid "vector, network, isolines"
+msgstr ""
+#: ../vector/v.net.iso/main.c:75
+msgid ""
+"Splits net to bands between cost isolines (direction from centre). Centre "
+"node must be opened (costs >= 0). Costs of centre node are used in "
+"calculation."
+msgstr ""
+#: ../vector/v.net.iso/main.c:113
+msgid ""
+"Categories of centres (points on nodes) to which net will be allocated. "
+"Layer for this categories is given by nlayer option."
+msgstr ""
+#: ../vector/v.net.iso/main.c:122
+msgid "Costs for isolines"
+msgstr ""
+#: ../vector/v.net.iso/main.c:159
+#, c-format
+msgid "Wrong iso cost: %f"
+msgstr ""
+#: ../vector/v.net.iso/main.c:162
+#, c-format
+msgid "Iso cost: %f less than previous"
+msgstr ""
+#: ../vector/v.net.iso/main.c:164
+#, c-format
+msgid "Iso cost %d: %f"
+msgstr ""
+#: ../vector/v.net.iso/main.c:171
+msgid "Not enough costs, everything reachable falls to first band"
+msgstr ""
+#: ../vector/v.net.iso/main.c:205
+msgid "Centre at closed node (costs = -1) ignored"
+msgstr ""
+#: ../vector/v.net.iso/main.c:224
+#, c-format
+msgid "Number of centres: %d (nlayer %d)"
+msgstr ""
+#: ../vector/v.net.iso/main.c:247
+#, c-format
+msgid "Calculating costs from centre %d..."
+msgstr ""
+#: ../vector/v.digit/form.c:97
+msgid "db connection was not set by form\n"
+msgstr ""
+#: ../vector/v.digit/form.c:108
+msgid "Cannot open driver\n"
+msgstr ""
+#: ../vector/v.digit/form.c:120
+msgid "Cannot open database\n"
+msgstr ""
+#: ../vector/v.digit/form.c:133
+msgid "Cannot describe table\n"
+msgstr ""
+#: ../vector/v.digit/form.c:162
+msgid "Cannot find column type"
+msgstr ""
+#: ../vector/v.digit/form.c:199
+#, c-format
+msgid "Could not set Tcl system encoding to '%s' (%s)"
+msgstr ""
+#: ../vector/v.digit/form.c:228
+msgid "Could not convert UTF to external."
+msgstr ""
+#: ../vector/v.digit/form.c:256
+msgid "Cannot update table"
+msgstr ""
+#: ../vector/v.digit/zoom.c:26
+msgid "Zoom by window"
+msgstr ""
+#: ../vector/v.digit/zoom.c:27 ../vector/v.digit/zoom.c:44
+#: ../vector/v.digit/zoom.c:75
+msgid "1. corner"
+msgstr ""
+#: ../vector/v.digit/zoom.c:75 ../vector/v.digit/zoom.c:158
+msgid "Quit"
+msgstr ""
+#: ../vector/v.digit/zoom.c:44
+msgid "2. corner"
+msgstr ""
+#: ../vector/v.digit/zoom.c:157
+msgid "Pan"
+msgstr ""
+#: ../vector/v.digit/zoom.c:158
+msgid "New center"
+msgstr ""
+#: ../vector/v.digit/zoom.c:247
+#, c-format
+msgid "Cannot find window '%s'"
+msgstr ""
+#: ../vector/v.digit/c_face.c:183 ../vector/v.digit/c_face.c:241
+#, c-format
+msgid "Cannot open driver %s"
+msgstr ""
+#: ../vector/v.digit/c_face.c:189 ../vector/v.digit/c_face.c:251
+#, c-format
+msgid "Cannot open database %s"
+msgstr ""
+#: ../vector/v.digit/c_face.c:242
+msgid "Cannot open driver "
+msgstr ""
+#: ../vector/v.digit/c_face.c:252 ../vector/v.digit/attr.c:137
+#: ../vector/v.digit/attr.c:650
+#, c-format
+msgid "Cannot open database %s by driver %s"
+msgstr ""
+#: ../vector/v.digit/c_face.c:270
+msgid "Cannot create table: "
+msgstr ""
+#: ../vector/v.digit/c_face.c:283
+msgid "Cannot create index:\n"
+msgstr ""
+#: ../vector/v.digit/c_face.c:295
+msgid "Cannot grant privileges on table:\n"
+msgstr ""
+#: ../vector/v.digit/c_face.c:312
+msgid ""
+"Cannot add database link to vector, link for given field probably already "
+"exists."
+msgstr ""
+#: ../vector/v.digit/line.c:55
+msgid "Form"
+msgstr ""
+#: ../vector/v.digit/line.c:64
+msgid "New record was created.<BR>"
+msgstr ""
+#: ../vector/v.digit/line.c:68
+msgid "Record for this category already existed.<BR>"
+msgstr ""
+#: ../vector/v.digit/line.c:138
+#, c-format
+msgid "Digitize new %s:"
+msgstr ""
+#: ../vector/v.digit/line.c:140 ../vector/v.digit/line.c:224
+#: ../vector/v.digit/line.c:253
+msgid "New point"
+msgstr ""
+#: ../vector/v.digit/line.c:481 ../vector/v.digit/line.c:564
+#: ../vector/v.digit/line.c:566 ../vector/v.digit/line.c:620
+#: ../vector/v.digit/line.c:671 ../vector/v.digit/line.c:705
+#: ../vector/v.digit/attr.c:192 ../vector/v.digit/attr.c:302
+#: ../vector/v.digit/attr.c:398 ../vector/v.digit/attr.c:403
+#: ../vector/v.digit/attr.c:407 ../vector/v.digit/attr.c:463
+#: ../vector/v.digit/vertex.c:36 ../vector/v.digit/vertex.c:56
+#: ../vector/v.digit/vertex.c:131 ../vector/v.digit/vertex.c:152
+#: ../vector/v.digit/vertex.c:200 ../vector/v.digit/vertex.c:220
+#: ../vector/v.digit/vertex.c:304 ../vector/v.digit/vertex.c:325
+#: ../vector/v.digit/vertex.c:373 ../vector/v.digit/vertex.c:471
+#: ../vector/v.digit/vertex.c:516 ../vector/v.digit/vertex.c:570
+#: ../vector/v.digit/vertex.c:633 ../vector/v.digit/vertex.c:669
+msgid "Quit tool"
+msgstr ""
+#: ../vector/v.digit/line.c:191
+msgid "Out of memory! Point not added."
+msgstr ""
+#: ../vector/v.digit/line.c:246
+msgid "Less than 2 points for line -> nothing written"
+msgstr ""
+msgid "Undo last point"
+msgstr ""
+#: ../vector/v.digit/line.c:253 ../vector/v.digit/line.c:337
+#: ../vector/v.digit/line.c:386
+msgid "Close line"
+msgstr ""
+#: ../vector/v.digit/line.c:337 ../vector/v.digit/line.c:386
+#: ../vector/v.digit/line.c:407
+msgid "New Point"
+msgstr ""
+msgid "Undo Last Point"
+msgstr ""
+msgid "Delete line and exit"
+msgstr ""
+#: ../vector/v.digit/line.c:480
+msgid "Delete point, line, boundary, or centroid:"
+msgstr ""
+#: ../vector/v.digit/line.c:481 ../vector/v.digit/line.c:566
+#: ../vector/v.digit/line.c:620 ../vector/v.digit/line.c:705
+#: ../vector/v.digit/attr.c:403 ../vector/v.digit/vertex.c:36
+#: ../vector/v.digit/vertex.c:56 ../vector/v.digit/vertex.c:152
+#: ../vector/v.digit/vertex.c:373 ../vector/v.digit/vertex.c:516
+#: ../vector/v.digit/vertex.c:570 ../vector/v.digit/vertex.c:669
+msgid "Select"
+msgstr ""
+#: ../vector/v.digit/line.c:566 ../vector/v.digit/line.c:671
+#: ../vector/v.digit/vertex.c:130 ../vector/v.digit/vertex.c:303
+#: ../vector/v.digit/vertex.c:471 ../vector/v.digit/vertex.c:633
+msgid "Unselect"
+msgstr ""
+#: ../vector/v.digit/line.c:564 ../vector/v.digit/vertex.c:130
+#: ../vector/v.digit/vertex.c:303
+msgid "Confirm and select next"
+msgstr ""
+#: ../vector/v.digit/line.c:619
+msgid "Move point, line, boundary, or centroid:"
+msgstr ""
+#: ../vector/v.digit/line.c:671 ../vector/v.digit/vertex.c:633
+msgid "New location"
+msgstr ""
+#: ../vector/v.digit/generate.c:77
+msgid "Cannot open driver"
+msgstr ""
+#: ../vector/v.digit/generate.c:78
+#, c-format
+msgid "Cannot open driver '%s'<BR>"
+msgstr ""
+#: ../vector/v.digit/generate.c:89
+msgid "Cannot open database"
+msgstr ""
+#: ../vector/v.digit/generate.c:91
+#, c-format
+msgid "Cannot open database '%s' by driver '%s'<BR>"
+msgstr ""
+#: ../vector/v.digit/generate.c:106
+msgid "Cannot open select cursor"
+msgstr ""
+#: ../vector/v.digit/generate.c:110
+#, c-format
+msgid ""
+"Cannot open select cursor:<BR>'%s'<BR>on database '%s' by driver '%s'<BR>"
+msgstr ""
+#: ../vector/v.digit/generate.c:121
+msgid "Cannot fetch next record"
+msgstr ""
+#: ../vector/v.digit/generate.c:130
+msgid "No database record"
+msgstr ""
+#: ../vector/v.digit/generate.c:223
+#, c-format
+msgid "<HR>   Assume data encoding as:<BR><BR><SELECT NAME=%s SIZE=4><HR><BR>"
+msgstr ""
+#: ../vector/v.digit/var.c:80 ../vector/v.digit/var.c:101
+#: ../vector/v.digit/var.c:122
+#, c-format
+msgid "Cannot set variable code = %d"
+msgstr ""
+#: ../vector/v.digit/var.c:143
+#, c-format
+msgid "Cannot get type of variable %s"
+msgstr ""
+#: ../vector/v.digit/var.c:164
+#, c-format
+msgid "Cannot get code of variable %s"
+msgstr ""
+#: ../vector/v.digit/var.c:184
+#, c-format
+msgid "Cannot get name of variable %d"
+msgstr ""
+#: ../vector/v.digit/var.c:199 ../vector/v.digit/var.c:215
+#: ../vector/v.digit/var.c:231
+#, c-format
+msgid "Cannot get value of variable code = %d"
+msgstr ""
+#: ../vector/v.digit/centre.c:56
+msgid "Select tool"
+msgstr ""
+#: ../vector/v.digit/centre.c:178
+msgid "Region restored to original extent."
+msgstr ""
+#: ../vector/v.digit/attr.c:94
+msgid "Cannot create new record."
+msgstr ""
+#: ../vector/v.digit/attr.c:127
+msgid "Database table for this layer is not defined"
+msgstr ""
+#: ../vector/v.digit/attr.c:145 ../vector/v.digit/attr.c:659
+#, c-format
+msgid "Cannot select record from table %s"
+msgstr ""
+#: ../vector/v.digit/attr.c:191
+msgid "Display categories:"
+msgstr ""
+#: ../vector/v.digit/attr.c:192 ../vector/v.digit/attr.c:463
+msgid "Select line"
+msgstr ""
+#: ../vector/v.digit/attr.c:301 ../vector/v.digit/attr.c:406
+msgid "Copy attributes:"
+msgstr ""
+#: ../vector/v.digit/attr.c:302 ../vector/v.digit/attr.c:407
+msgid "Select source object"
+msgstr ""
+#: ../vector/v.digit/attr.c:396 ../vector/v.digit/attr.c:402
+msgid "Select the target object"
+msgstr ""
+#: ../vector/v.digit/attr.c:397
+msgid "Conform and select next"
+msgstr ""
+msgid "Deselect Target"
+msgstr ""
+msgid "Deselect Source"
+msgstr ""
+#: ../vector/v.digit/attr.c:462
+msgid "Display attributes:"
+msgstr ""
+#: ../vector/v.digit/attr.c:542
+#, c-format
+msgid "layer: %d<BR>category: %d<BR>"
+msgstr ""
+#: ../vector/v.digit/attr.c:549
+msgid "Database connection not defined<BR>"
+msgstr ""
+#: ../vector/v.digit/attr.c:553
+#, c-format
+msgid "driver: %s<BR>database: %s<BR>table: %s<BR>key column: %s<BR>"
+msgstr ""
+#: ../vector/v.digit/attr.c:571
+#, c-format
+msgid "Line %d"
+msgstr ""
+#: ../vector/v.digit/attr.c:577
+msgid "No categories"
+msgstr ""
+#: ../vector/v.digit/attr.c:668
+#, c-format
+msgid ""
+"There are no more features with category %d (layer %d) in the map, but there "
+"is record in the table. Delete this record?"
+msgstr ""
+#: ../vector/v.digit/attr.c:680
+#, c-format
+msgid "Cannot delete record: %s"
+msgstr ""
+#: ../vector/v.digit/vertex.c:35
+msgid "Split line:"
+msgstr ""
+#: ../vector/v.digit/vertex.c:199
+msgid "Remove vertex:"
+msgstr ""
+#: ../vector/v.digit/vertex.c:325
+msgid "Select vertex"
+msgstr ""
+#: ../vector/v.digit/vertex.c:372
+msgid "Add vertex:"
+msgstr ""
+msgid "New vertex"
+msgstr ""
+#: ../vector/v.digit/vertex.c:569
+msgid "Move vertex:"
+msgstr ""
+#: ../vector/v.digit/main.c:104
+msgid "vector, editing, digitization"
+msgstr ""
+#: ../vector/v.digit/main.c:106
+msgid "Interactive editing and digitization of vector maps."
+msgstr ""
+#: ../vector/v.digit/main.c:117 ../raster/r.digit/main.c:56
+msgid "Display commands to be used for canvas backdrop (separated by ';')"
+msgstr ""
+#: ../vector/v.digit/main.c:121
+msgid "Create new file if it does not exist."
+msgstr ""
+#: ../vector/v.digit/main.c:150
+msgid "New empty map created."
+msgstr ""
+#: ../vector/v.digit/main.c:157
+#, c-format
+msgid ""
+"Map <%s> does not exist in current mapset. Add flag -n to create a new map."
+msgstr ""
+#: ../vector/v.support/main.c:40
+msgid "vector, metadata"
+msgstr ""
+#: ../vector/v.support/main.c:41
+msgid "Updates vector map metadata."
+msgstr ""
+#: ../vector/v.support/main.c:52
+msgid "Organization where vector map was created"
+msgstr ""
+#: ../vector/v.support/main.c:61
+msgid "Date of vector map digitization (e.g., \"15 Mar 2007\")"
+msgstr ""
+#: ../vector/v.support/main.c:68
+msgid "Person who created vector map"
+msgstr ""
+#: ../vector/v.support/main.c:75
+msgid "Vector map title"
+msgstr ""
+#: ../vector/v.support/main.c:83
+msgid "Date when the source map was originally produced"
+msgstr ""
+#: ../vector/v.support/main.c:89
+msgid "Vector map scale number (e.g., 24000)"
+msgstr ""
+#: ../vector/v.support/main.c:95
+msgid "Vector map projection zone"
+msgstr ""
+#: ../vector/v.support/main.c:102
+msgid "Vector map digitizing threshold number (e.g., 0.5)"
+msgstr ""
+#: ../vector/v.support/main.c:110
+msgid "Text to append to the comment line of the map's metadata file"
+msgstr ""
+#: ../vector/v.support/main.c:118
+msgid ""
+"Command line to store into vector map history file (used for vector scripts)"
+msgstr ""
+#: ../vector/v.support/main.c:122
+msgid "Replace comment instead of appending it"
+msgstr ""
+#: ../vector/v.support/main.c:188
+#, c-format
+msgid "Unable to open history file for vector map <%s>"
+msgstr ""
+#: ../vector/v.net.path/path.c:82
+#, c-format
+msgid "[%d] points without category (nfield: [%d])"
+msgstr ""
+#: ../vector/v.net.path/path.c:168 ../vector/v.net.path/path.c:186
+#, c-format
+msgid "No point with category [%d]"
+msgstr ""
+#: ../vector/v.net.path/path.c:205
+#, c-format
+msgid "Point with category [%d] is not reachable from point with category [%d]"
+msgstr ""
+#: ../vector/v.net.path/path.c:262
+#, c-format
+msgid "Point %f,%f is not reachable from point %f,%f"
+msgstr ""
+#: ../vector/v.net.path/path.c:327
+#, c-format
+msgid "[%d] input format errors"
+msgstr ""
+#: ../vector/v.net.path/path.c:329
+#, c-format
+msgid "[%d] points of given category missing"
+msgstr ""
+#: ../vector/v.net.path/path.c:331
+#, c-format
+msgid "%d destination(s) unreachable (including points out of threshold)"
+msgstr ""
+#: ../vector/v.net.path/main.c:42
+msgid "Finds shortest path on vector network."
+msgstr ""
+#: ../vector/v.net.path/main.c:65
+msgid ""
+"Name of file containing start and end points. If not given, read from stdin"
+msgstr ""
+#: ../vector/v.net.path/main.c:85 ../display/d.path/main.c:94
+msgid "Node cost column"
+msgstr ""
+#: ../vector/v.net.path/main.c:92
+msgid "Maximum distance to the network"
+msgstr ""
+#: ../vector/v.net.path/main.c:93
+msgid ""
+"If start/end are given as coordinates. If start/end point is outside this "
+"threshold, the path is not found and error message is printed. To speed up "
+"the process, keep this value as low as possible."
+msgstr ""
+#: ../vector/v.net.path/main.c:106
+msgid "Write output as original input segments, not each path as one line."
+msgstr ""
+#: ../vector/v.net.bridge/main.c:45
+msgid "vector, network, articulation points"
+msgstr ""
+#: ../vector/v.net.bridge/main.c:47
+msgid "Computes bridges and articulation points in the network."
+msgstr ""
+#: ../vector/v.net.bridge/main.c:61
+msgid "bridge;Finds bridges;articulation;Finds articulation points;"
+msgstr ""
+#: ../vector/v.label.sa/labels.c:73
+#, c-format
+msgid "Cannot allocate %d bytes of memory"
+msgstr ""
+#: ../vector/v.label.sa/labels.c:92 ../display/d.text.freetype/main.c:327
+msgid "Unable to initialise FreeType"
+msgstr ""
+#: ../vector/v.label.sa/labels.c:95
+#, c-format
+msgid "Unable to find font '%s'\n"
+msgstr ""
+#: ../vector/v.label.sa/labels.c:97
+#, c-format
+msgid "Font '%s' is not a FreeType font\n"
+msgstr ""
+#: ../vector/v.label.sa/labels.c:101
+msgid "Font file format is not supported by FreeType"
+msgstr ""
+#: ../vector/v.label.sa/labels.c:103
+msgid "Font file can not be loaded"
+msgstr ""
+#: ../vector/v.label.sa/labels.c:112
+msgid "Unable to set font size"
+msgstr ""
+#: ../vector/v.label.sa/labels.c:133
+msgid "Cannot allocate more memory"
+msgstr ""
+#: ../vector/v.label.sa/labels.c:223
+#, c-format
+msgid ""
+"Cannot load overlap weights. Column %s is not of numeric type in table <%s>"
+msgstr ""
+#: ../vector/v.label.sa/labels.c:281
+#, c-format
+msgid "Cannot load glyph for '%c'"
+msgstr ""
+#: ../vector/v.label.sa/font.c:55
+#, c-format
+msgid "%s: Unable to read font definition file; use the default"
+msgstr ""
+#: ../vector/v.label.sa/font.c:61
+#, c-format
+msgid "%s: No font definition file"
+msgstr ""
+#: ../vector/v.label.sa/main.c:56
+msgid "Create optimally placed labels for vector map(s)"
+msgstr ""
+#: ../vector/v.label.sa/main.c:117
+msgid "Name of TrueType font (as listed in the fontcap)"
+msgstr ""
+#: ../vector/v.label.sa/main.c:130
+msgid "Icon size of point features (in map-units)"
+msgstr ""
+#: ../vector/v.label.sa/main.c:200
+msgid "Border width (only for ps.map output)"
+msgstr ""
+#: ../vector/v.label.sa/main.c:207
+msgid ""
+"Numeric column to give precedence in case of overlapping labels. The label "
+"with a smaller weight is hidden."
+msgstr ""
+#: ../vector/v.delaunay2/memory.c:64 ../vector/v.delaunay2/memory.c:70
+#: ../vector/v.delaunay2/memory.c:74 ../vector/v.delaunay2/memory.c:84
+#: ../vector/v.delaunay2/memory.c:92 ../vector/v.delaunay2/memory.c:104
+#: ../vector/v.delaunay2/memory.c:108
+msgid "Not enough memory."
+msgstr ""
+#: ../vector/v.delaunay2/memory.c:124
+msgid "All allocated edges have been used."
+msgstr ""
+#: ../vector/v.delaunay2/main.c:141
+msgid "no points to triangulate"
+msgstr ""
+#: ../vector/v.delaunay2/main.c:149
+msgid "Delaunay triangulation..."
+msgstr ""
+#: ../vector/v.delaunay2/main.c:152
+msgid "Writing edges..."
+msgstr ""
+#: ../vector/v.delaunay2/main.c:162
+msgid "Calculate area centroids..."
+msgstr ""
+#: ../vector/v.delaunay2/main.c:178
+msgid "Unable to calculate area centroid z coordinate"
+msgstr ""
+#: ../doc/vector/v.example/main.c:50
+msgid "vector, keyword2, keyword3"
+msgstr ""
+#: ../doc/vector/v.example/main.c:51
+msgid "My first vector module"
+msgstr ""
+#: ../doc/vector/v.example/main.c:79
+msgid "Unable to set predetermined vector open level"
+msgstr ""
+#: ../doc/vector/v.example/main.c:167
+#, c-format
+msgid "Unable to get attribute data for cat %d"
+msgstr ""
+#: ../doc/vector/v.example/main.c:176
+#, c-format
+msgid "Error while retrieving database record for cat %d"
+msgstr ""
+#: ../doc/vector/v.example/main.c:209
+#, c-format
+msgid "Unable to copy attribute table to vector map <%s>"
+msgstr ""
+#: ../doc/raster/r.example/main.c:85
+msgid "raster, keyword2, keyword3"
+msgstr ""
+#: ../doc/raster/r.example/main.c:86
+msgid "My first raster module"
+msgstr ""
+#: ../doc/raster/r.example/main.c:127
+#, c-format
+msgid "Unable to read file header of <%s>"
+msgstr ""
+#: ../doc/raster/r.example/main.c:181 ../raster/r.composite/main.c:258
+#, c-format
+msgid "Failed writing raster map <%s>"
+msgstr ""
+#: ../display/d.save/main.c:79 ../display/d.info/main.c:34
+msgid "display, metadata"
+msgstr ""
+#: ../display/d.save/main.c:81
+msgid "Creates a list of commands for recreating screen graphics."
+msgstr ""
+#: ../display/d.save/main.c:86
+msgid "Name of frame(s) to save"
+msgstr ""
+#: ../display/d.save/main.c:126
+msgid ""
+"List of object numbers to remove which are displayed after \"#\". -1 for the "
+"last object."
+msgstr ""
+#: ../display/d.save/main.c:134
+msgid ""
+"List of object numbers to move (\"from\" to \"to\"). remove= option will be "
+"done first, if any."
+msgstr ""
+#: ../display/d.save/main.c:143
+msgid "Save current frame"
+msgstr ""
+#: ../display/d.save/main.c:148
+msgid "Save all the frames"
+msgstr ""
+#: ../display/d.save/main.c:154
+msgid "Only map objects without extra header and tailer"
+msgstr ""
+#: ../display/d.save/main.c:162
+msgid "No monitor selected"
+msgstr ""
+#: ../display/d.save/main.c:481 ../display/d.save/main.c:516
+#, c-format
+msgid "Unknown item type in pad: %s"
+msgstr ""
+#: ../display/d.geodesic/main.c:45 ../display/d.rhumbline/main.c:45
+msgid "display, distance"
+msgstr ""
+#: ../display/d.geodesic/main.c:47
+msgid ""
+"Displays a geodesic line, tracing the shortest distance between two "
+"geographic points along a great circle, in a longitude/latitude data set."
+msgstr ""
+#: ../display/d.geodesic/main.c:56 ../display/d.path/main.c:66
+#: ../display/d.rhumbline/main.c:55
+msgid "Starting and ending coordinates"
+msgstr ""
+#: ../display/d.geodesic/main.c:62 ../display/d.rhumbline/main.c:61
+msgid "Line color"
+msgstr ""
+#: ../display/d.geodesic/main.c:70
+msgid "Text color or \"none\""
+msgstr ""
+#: ../display/d.geodesic/main.c:78 ../display/d.rhumbline/main.c:79
+#, c-format
+msgid "Location is not %s"
+msgstr ""
+#: ../display/d.geodesic/main.c:83 ../display/d.path/main.c:143
+#: ../display/d.rhumbline/main.c:85
+msgid "No coordinates given"
+msgstr ""
+#: ../display/d.geodesic/main.c:87 ../display/d.geodesic/main.c:91
+#: ../display/d.geodesic/main.c:95 ../display/d.geodesic/main.c:99
+#: ../display/d.rhumbline/main.c:89 ../display/d.rhumbline/main.c:93
+#: ../display/d.rhumbline/main.c:98 ../display/d.rhumbline/main.c:102
+#, c-format
+msgid "%s - illegal longitude"
+msgstr ""
+#: ../display/d.graph/graphics.c:60 ../display/d.graph/do_graph.c:136
+#: ../display/d.graph/do_graph.c:213 ../display/d.graph/do_graph.c:234
+#: ../display/d.graph/do_graph.c:292 ../display/d.graph/do_graph.c:363
+#, c-format
+msgid "Problem parsing command [%s]"
+msgstr ""
+#: ../display/d.graph/do_graph.c:54 ../display/d.graph/do_graph.c:83
+#, c-format
+msgid "Problem parsing coordinates [%s]"
+msgstr ""
+#: ../display/d.graph/do_graph.c:105
+msgid "Unable to read color"
+msgstr ""
+#: ../display/d.graph/do_graph.c:112 ../display/d.graph/do_graph.c:393
+#: ../display/d.graph/do_graph.c:408 ../display/d.graph/main.c:103
+#: ../display/d.rast/display.c:32 ../display/d.text.freetype/main.c:842
+#: ../display/d.text/main.c:147 ../display/d.paint.labels/color.c:66
+#: ../raster/r.out.png/r.out.png.c:196
+#, c-format
+msgid "[%s]: No such color"
+msgstr ""
+#: ../display/d.graph/main.c:54 ../display/d.grid/main.c:51
+#: ../display/d.legend/main.c:86 ../display/d.title/main.c:45
+#: ../display/d.vect.chart/main.c:63 ../display/d.barscale/main.c:56
+#: ../display/d.linegraph/linegraph.c:113 ../display/d.mapgraph/main.c:48
+#: ../display/d.text.freetype/main.c:138 ../display/d.thematic.area/main.c:78
+#: ../display/d.text.new/main.c:142 ../display/d.text/main.c:66
+msgid "display, cartography"
+msgstr ""
+#: ../display/d.graph/main.c:56
+msgid ""
+"Program for generating and displaying simple graphics on the display monitor."
+msgstr ""
+#: ../display/d.graph/main.c:63
+msgid ""
+"Name of file containing graphics commands, if not given reads from standard "
+"input"
+msgstr ""
+#: ../display/d.graph/main.c:71
+msgid "Color to draw with, either a standard GRASS color or R:G:B triplet"
+msgstr ""
+#: ../display/d.graph/main.c:78
+msgid "Coordinates are given in map units"
+msgstr ""
+#: ../display/d.graph/main.c:89
+#, c-format
+msgid "Graph file <%s> not found"
+msgstr ""
+#: ../display/d.graph/main.c:119 ../display/d.legend/main.c:277
+#: ../display/d.barscale/main.c:137 ../display/d.rast.arrow/arrow.c:248
+#: ../display/d.rast.num/number.c:166 ../display/d.info/main.c:103
+#: ../display/d.info/main.c:129 ../display/d.text.freetype/main.c:316
+#: ../display/d.text.new/main.c:309 ../display/d.text/main.c:152
+#: ../display/d.paint.labels/main.c:124
+msgid "No current window"
+msgstr ""
+#: ../display/d.graph/main.c:122 ../display/d.legend/main.c:280
+#: ../display/d.barscale/main.c:140 ../display/d.rast.arrow/arrow.c:251
+#: ../display/d.rast.num/number.c:169 ../display/d.info/main.c:105
+#: ../display/d.info/main.c:131 ../display/d.text.freetype/main.c:318
+#: ../display/d.text.new/main.c:312 ../display/d.text/main.c:155
+#: ../display/d.paint.labels/main.c:127
+msgid "Current window not available"
+msgstr ""
+#: ../display/d.graph/main.c:125 ../display/d.barscale/main.c:163
+#: ../display/d.rast.arrow/arrow.c:264 ../display/d.rast.num/number.c:184
+#: ../display/d.info/main.c:113 ../display/d.info/main.c:138
+#: ../display/d.paint.labels/main.c:137
+msgid "Getting screen window"
+msgstr ""
+#: ../display/d.grid/plot.c:315
+msgid ""
+"WGS84 grid output not possible as this location does not contain\n"
+"datum transformation parameters. Try running g.setproj."
+msgstr ""
+#: ../display/d.grid/plot.c:487
+msgid "Error in pj_do_proj1"
+msgstr ""
+#: ../display/d.grid/plot.c:493
+msgid "Error in pj_do_proj2"
+msgstr ""
+#: ../display/d.grid/plot.c:497
+msgid "Error in pj_do_proj3"
+msgstr ""
+#: ../display/d.grid/plot.c:505
+msgid "Error in pj_do_proj5"
+msgstr ""
+#: ../display/d.grid/plot.c:509
+msgid "Error in pj_do_proj6"
+msgstr ""
+#: ../display/d.grid/fiducial.c:52
+msgid "Reading symbol"
+msgstr ""
+#: ../display/d.grid/main.c:53
+msgid ""
+"Overlays a user-specified grid in the active display frame on the graphics "
+"monitor."
+msgstr ""
+#: ../display/d.grid/main.c:61
+msgid "Size of grid to be drawn"
+msgstr ""
+#: ../display/d.grid/main.c:62
+msgid "In map units or DDD:MM:SS format. Example: \"1000\" or \"0:10\""
+msgstr ""
+#: ../display/d.grid/main.c:71
+msgid "Lines of the grid pass through this coordinate"
+msgstr ""
+#: ../display/d.grid/main.c:75
+msgid "Grid color"
+msgstr ""
+#: ../display/d.grid/main.c:95 ../display/d.barscale/main.c:106
+msgid "Font size for gridline coordinate labels"
+msgstr ""
+#: ../display/d.grid/main.c:100
+msgid "Draw geographic grid (referenced to current ellipsoid)"
+msgstr ""
+#: ../display/d.grid/main.c:105
+msgid "Draw geographic grid (referenced to WGS84 ellipsoid)"
+msgstr ""
+#: ../display/d.grid/main.c:109
+msgid "Draw '+' marks instead of grid lines"
+msgstr ""
+#: ../display/d.grid/main.c:113
+msgid "Draw fiducial marks instead of grid lines"
+msgstr ""
+#: ../display/d.grid/main.c:117
+msgid "Disable grid drawing"
+msgstr ""
+#: ../display/d.grid/main.c:118 ../display/d.grid/main.c:123
+#: ../display/d.grid/main.c:128
+msgid "Disable"
+msgstr ""
+#: ../display/d.grid/main.c:122
+msgid "Disable border drawing"
+msgstr ""
+#: ../display/d.grid/main.c:127
+msgid "Disable text drawing"
+msgstr ""
+#: ../display/d.grid/main.c:137
+msgid "Both grid and border drawing are disabled"
+msgstr ""
+#: ../display/d.grid/main.c:141
+msgid "Geo-Grid option is not available for LL projection"
+msgstr ""
+#: ../display/d.grid/main.c:143
+msgid "Geo-Grid option is not available for XY projection"
+msgstr ""
+#: ../display/d.grid/main.c:154
+msgid "Choose a single mark style"
+msgstr ""
+#: ../display/d.grid/main.c:164
+#, c-format
+msgid "Invalid geo-grid size <%s>"
+msgstr ""
+#: ../display/d.grid/main.c:169
+#, c-format
+msgid "Invalid grid size <%s>"
+msgstr ""
+#: ../display/d.grid/main.c:175 ../raster/r.in.bin/main.c:437
+#, c-format
+msgid "Illegal east coordinate <%s>"
+msgstr ""
+#: ../display/d.grid/main.c:181 ../raster/r.in.bin/main.c:433
+#, c-format
+msgid "Illegal north coordinate <%s>"
+msgstr ""
+#: ../display/d.profile/What.c:29
+msgid "Error reading raster map"
+msgstr ""
+#: ../display/d.profile/Range.c:87
+msgid "one moment ..."
+msgstr ""
+#: ../display/d.profile/utils.c:8
+#, c-format
+msgid "%s: 'is_null_value()' got NULL pointer!"
+msgstr ""
+#: ../display/d.profile/utils.c:11
+#, c-format
+msgid "%s: 'is_null_value()' got negative column index"
+msgstr ""
+#: ../display/d.profile/utils.c:22
+#, c-format
+msgid "%s: 'is_null_value()' Unknown RASTER_MAP_TYPE '%d'"
+msgstr ""
+#: ../display/d.profile/main.c:61
+msgid "display, raster, profile"
+msgstr ""
+#: ../display/d.profile/main.c:63
+msgid "Interactive profile plotting utility with optional output."
+msgstr ""
+#: ../display/d.profile/main.c:71
+msgid "Raster map to be profiled"
+msgstr ""
+#: ../display/d.profile/main.c:78
+msgid "Optional display raster"
+msgstr ""
+#: ../display/d.profile/main.c:85
+msgid "Output profile data to file(s) with prefix 'name'"
+msgstr ""
+#: ../display/d.profile/main.c:106
+#, c-format
+msgid "Display raster [%s] not found. Using profile raster."
+msgstr ""
+#: ../display/d.profile/main.c:130
+msgid ""
+"\n"
+"\n"
+"Use mouse to choose action"
+msgstr ""
+#: ../display/d.profile/main.c:199 ../display/d.profile/main.c:393
+msgid "Use 'd.frame -e' to remove left over frames"
+msgstr ""
+#: ../display/d.profile/main.c:283
+msgid "Error opening cell-file"
+msgstr ""
+#: ../display/d.profile/main.c:285
+msgid "Error reading from cell-file"
+msgstr ""
+#: ../display/d.profile/main.c:287
+msgid "Mysterious window inconsistancy error"
+msgstr ""
+#: ../display/d.profile/main.c:430
+#, c-format
+msgid "%s: Couldn't open raster <%s@%s>"
+msgstr ""
+#: ../display/d.profile/main.c:434
+#, c-format
+msgid "%s: Couldn't read color table for <%s@%s>"
+msgstr ""
+#: ../display/d.rast.edit/cell.c:35 ../display/d.barscale/main.c:156
+#: ../display/d.rast.arrow/arrow.c:257 ../display/d.rast.num/number.c:176
+#: ../display/d.info/main.c:111 ../display/d.info/main.c:136
+#: ../display/d.paint.labels/main.c:130
+msgid "Setting map window"
+msgstr ""
+#: ../display/d.rast.edit/cell.c:38 ../display/d.barscale/main.c:159
+#: ../display/d.rast.arrow/arrow.c:260 ../display/d.rast.num/number.c:179
+#: ../display/d.paint.labels/main.c:133
+msgid "Current window not settable"
+msgstr ""
+#: ../display/d.rast.edit/cell.c:43
+msgid "Can't clear current graphics window"
+msgstr ""
+#: ../display/d.rast.edit/cell.c:51 ../display/d.rgb/main.c:105
+#: ../display/d.legend/main.c:259 ../display/d.rast/display.c:21
+#: ../display/d.his/main.c:152 ../display/d.his/main.c:171
+#: ../display/d.his/main.c:196 ../display/d.rast.num/number.c:278
+#: ../display/d.histogram/main.c:165 ../raster/r.out.ppm3/main.c:131
+#: ../raster/r.his/main.c:142 ../raster/r.his/main.c:161
+#: ../raster/r.his/main.c:186
+#, c-format
+msgid "Color file for <%s> not available"
+msgstr ""
+#: ../display/d.rast.edit/cell.c:86 ../display/d.rast/display.c:75
+msgid "Cannot use current window"
+msgstr ""
+#: ../display/d.measure/main.c:49
+msgid "display, geometry"
+msgstr ""
+#: ../display/d.measure/main.c:51
+msgid ""
+"Measures the lengths and areas of features drawn by the user in the active "
+"display frame on the graphics monitor."
+msgstr ""
+#: ../display/d.measure/main.c:57
+msgid "Line color 1"
+msgstr ""
+#: ../display/d.measure/main.c:65
+msgid "Line color 2"
+msgstr ""
+#: ../display/d.measure/main.c:73
+msgid "Suppress clear screen"
+msgstr ""
+#: ../display/d.measure/main.c:77
+msgid "Output in meters only"
+msgstr ""
+#: ../display/d.measure/main.c:81
+msgid "Output in kilometers as well"
+msgstr ""
+#: ../display/d.measure/main.c:90 ../display/d.colortable/main.c:140
+#: ../display/d.erase/main.c:62
+msgid "No current frame"
+msgstr ""
+#: ../display/d.measure/main.c:93 ../display/d.colortable/main.c:142
+#: ../display/d.erase/main.c:64
+msgid "Current frame not available"
+msgstr ""
+#: ../display/d.what.vect/openvect.c:11
+#, c-format
+msgid "warning: %s - vector map not found\n"
+msgstr ""
+#: ../display/d.what.vect/what.c:237
+#, c-format
+msgid "Line: %d  Type: %s  Left: %d  Right: %d  "
+msgstr ""
+#: ../display/d.what.vect/what.c:257
+#, c-format
+msgid "  Node[%d]: %d  Number of lines: %d  Coordinates: %.6f, %.6f, %.6f\n"
+msgstr ""
+#: ../display/d.what.vect/what.c:266
+#, c-format
+msgid "    Line: %5d  Angle: %.8f\n"
+msgstr ""
+#: ../display/d.what.vect/what.c:275
+#, c-format
+msgid "length %f\n"
+msgstr ""
+#: ../display/d.what.vect/what.c:322
+#, c-format
+msgid "Line height min: %f max: %f\n"
+msgstr ""
+#: ../display/d.what.vect/what.c:343
+#, c-format
+msgid "Area height: %f\n"
+msgstr ""
+#: ../display/d.what.vect/what.c:352
+#, c-format
+msgid "Area\n"
+msgstr ""
+#: ../display/d.what.vect/what.c:374
+#, c-format
+msgid "Area: %d  Number of isles: %d\n"
+msgstr ""
+#: ../display/d.what.vect/what.c:379
+#, c-format
+msgid "  Isle[%d]: %d\n"
+msgstr ""
+#: ../display/d.what.vect/what.c:386
+#, c-format
+msgstr ""
+#: ../display/d.what.vect/what.c:393 ../display/d.what.vect/what.c:401
+#, c-format
+msgid "Size - Sq Meters: %.3f\t\tHectares: %.3f\n"
+msgstr ""
+#: ../display/d.what.vect/what.c:397 ../display/d.what.vect/what.c:405
+#, c-format
+msgid "           Acres: %.3f\t\tSq Miles: %.4f\n"
+msgstr ""
+#: ../display/d.what.vect/what.c:433
+#, c-format
+msgid ""
+"Layer: %d\n"
+"category: %d\n"
+msgstr ""
+#: ../display/d.what.vect/what.c:458
+#, c-format
+msgid ""
+"driver: %s\n"
+"database: %s\n"
+"table: %s\n"
+"key column: %s\n"
+msgstr ""
+#: ../display/d.what.vect/what.c:523
+#, c-format
+msgid ""
+"\n"
+"Click mouse button on desired location\n"
+"\n"
+msgstr ""
+#: ../display/d.what.vect/what.c:528
+#, c-format
+msgid "Buttons\n"
+msgstr ""
+#: ../display/d.what.vect/what.c:529
+#, c-format
+msgid " Left:  what's here\n"
+msgstr ""
+#: ../display/d.what.vect/what.c:531
+#, c-format
+msgid " Middle: toggle flash color\n"
+msgstr ""
+#: ../display/d.what.vect/what.c:536
+#, c-format
+msgid " Right: quit\n"
+msgstr ""
+#: ../display/d.what.vect/main.c:54 ../display/d.extract/main.c:50
+#: ../display/d.vect/main.c:78
+msgid "display, vector"
+msgstr ""
+#: ../display/d.what.vect/main.c:56
+msgid ""
+"Allows the user to interactively query a vector map layer at user-selected "
+"locations within the current geographic region."
+msgstr ""
+#: ../display/d.what.vect/main.c:74 ../display/d.what.rast/main.c:94
+msgid "Identify just one location"
+msgstr ""
+#: ../display/d.what.vect/main.c:85
+msgid "Name of existing vector map"
+msgstr ""
+#: ../display/d.what.vect/main.c:89 ../display/d.what.rast/main.c:98
+msgid "Terse output. For parsing by programs"
+msgstr ""
+#: ../display/d.what.vect/main.c:94
+msgid "Print information as plain text to terminal window"
+msgstr ""
+#: ../display/d.what.vect/main.c:102
+msgid "Enable flashing (slower)"
+msgstr ""
+#: ../display/d.what.vect/main.c:106
+msgid "Open form in edit mode"
+msgstr ""
+#: ../display/d.what.vect/main.c:151
+#, c-format
+msgid "%s: You must build topology on vector map"
+msgstr ""
+#: ../display/d.what.vect/main.c:172 ../raster/r.support/front/front.c:367
+msgid "Done."
+msgstr ""
+#: ../display/d.extend/main.c:52
+msgid "No raster or vector map displayed"
+msgstr ""
+#: ../display/d.rgb/main.c:54
+msgid "display, raster, RGB"
+msgstr ""
+#: ../display/d.rgb/main.c:56
+msgid ""
+"Displays three user-specified raster maps as red, green, and blue overlays "
+"in the active graphics frame."
+msgstr ""
+#: ../display/d.rgb/main.c:61 ../display/d.rast/main.c:88
+msgid "Overlay (non-null values only)"
+msgstr ""
+#: ../display/d.rgb/main.c:65 ../display/d.erase/main.c:52
+msgid "Don't add to list of commands in monitor"
+msgstr ""
+#: ../display/d.rgb/main.c:70
+#, c-format
+msgid "Name of raster map to be used for '%s'"
+msgstr ""
+#: ../display/d.rgb/main.c:119
+msgid "Error reading row of data"
+msgstr ""
+#: ../display/d.legend/main.c:88
+msgid ""
+"Displays a legend for a raster map in the active frame of the graphics "
+"monitor."
+msgstr ""
+#: ../display/d.legend/main.c:99
+msgid "Sets the legend's text color"
+msgstr ""
+#: ../display/d.legend/main.c:107
+msgid "Number of text lines (useful for truncating long legends)"
+msgstr ""
+#: ../display/d.legend/main.c:116
+msgid "Thinning factor (thin=10 gives cats 0,10,20...)"
+msgstr ""
+#: ../display/d.legend/main.c:124
+msgid "Number of text labels for smooth gradient legend"
+msgstr ""
+#: ../display/d.legend/main.c:134
+msgid "Placement as percentage of screen coordinates (0,0 is lower left)"
+msgstr ""
+#: ../display/d.legend/main.c:144
+msgid "List of discrete category numbers/values for legend"
+msgstr ""
+#: ../display/d.legend/main.c:154
+msgid "Use a subset of the map range for the legend (min,max)"
+msgstr ""
+#: ../display/d.legend/main.c:160
+msgid "Use mouse to size & place legend"
+msgstr ""
+#: ../display/d.legend/main.c:164
+msgid "Do not show category labels"
+msgstr ""
+#: ../display/d.legend/main.c:169
+msgid "Do not show category numbers"
+msgstr ""
+#: ../display/d.legend/main.c:174
+msgid "Skip categories with no label"
+msgstr ""
+#: ../display/d.legend/main.c:179
+msgid "Draw smooth gradient"
+msgstr ""
+#: ../display/d.legend/main.c:205 ../display/d.menu/main.c:113
+#: ../display/d.menu/main.c:119 ../display/d.menu/main.c:125
+#, c-format
+msgid "Don't know the color %s"
+msgstr ""
+#: ../display/d.legend/main.c:340
+msgid "Legend box lies outside of frame. Text may not display properly."
+msgstr ""
+#: ../display/d.legend/main.c:344
+msgid "Drawing horizontal legend as box width exceeds height"
+msgstr ""
+#: ../display/d.legend/main.c:355
+#, c-format
+msgid "Range information for <%s> not available (run r.support)"
+msgstr ""
+#: ../display/d.legend/main.c:360
+msgid "Input map contains no data"
+msgstr ""
+#: ../display/d.legend/main.c:373 ../display/d.legend/main.c:531
+msgid "Color range exceeds lower limit of actual data"
+msgstr ""
+#: ../display/d.legend/main.c:379 ../display/d.legend/main.c:535
+msgid "Color range exceeds upper limit of actual data"
+msgstr ""
+#: ../display/d.legend/main.c:436
+#, c-format
+msgid "use=%s out of range [%d,%d] (extend with range= ?)"
+msgstr ""
+#: ../display/d.legend/main.c:477
+msgid "Nothing to draw! (no categories with labels? out of range?)"
+msgstr ""
+#: ../display/d.legend/main.c:487
+msgid "Forcing a smooth legend: too many categories for current window height"
+msgstr ""
+#: ../display/d.legend/main.c:517 ../display/d.histogram/main.c:171
+#, c-format
+msgid "Range information for <%s> not available"
+msgstr ""
+#: ../display/d.legend/main.c:542
+#, c-format
+msgid "use=%s out of range [%.3f, %.3f] (extend with range= ?)"
+msgstr ""
+#: ../display/d.legend/main.c:901
+msgid "Nothing to draw! (no categories with labels?)"
+msgstr ""
+#: ../display/d.extract/main.c:52
+msgid "Selects and extracts vectors with mouse into new vector map."
+msgstr ""
+#: ../display/d.extract/main.c:65 ../display/d.path/main.c:100
+msgid "Original line color"
+msgstr ""
+#: ../display/d.extract/main.c:71 ../display/d.path/main.c:108
+msgid "Highlight color"
+msgstr ""
+#: ../display/d.extract/main.c:117
+msgid "Copying tables..."
+msgstr ""
+#: ../display/d.extract/main.c:125
+msgid "Cannot get db link info -> cannot copy table."
+msgstr ""
+#: ../display/d.extract/extract.c:44
+msgid "Select vector(s) with mouse"
+msgstr ""
+#: ../display/d.extract/extract.c:45
+msgid " - L: draw box with left mouse button to select"
+msgstr ""
+#: ../display/d.extract/extract.c:46
+msgid " - M: draw box with middle mouse button to remove from display"
+msgstr ""
+#: ../display/d.extract/extract.c:47
+msgid " - R: quit and save selected vectors to new map\n"
+msgstr ""
+#: ../display/d.extract/extract.c:49
+msgid "L: add  M: remove  R: quit and save\n"
+msgstr ""
+#: ../display/d.rast/main.c:52
+msgid "Displays user-specified raster map in the active graphics frame."
+msgstr ""
+#: ../display/d.rast/main.c:65
+msgid "List of categories to be displayed (INT maps)"
+msgstr ""
+#: ../display/d.rast/main.c:74
+msgid "List of values to be displayed (FP maps)"
+msgstr ""
+#: ../display/d.rast/main.c:83
+msgid "Background color (for null)"
+msgstr ""
+#: ../display/d.rast/main.c:84 ../display/d.rast/main.c:89
+msgid "Null cells"
+msgstr ""
+#: ../display/d.rast/main.c:93
+msgid "Invert catlist"
+msgstr ""
+#: ../display/d.rast/main.c:99
+msgid "Don't add to list of rasters and commands in monitor"
+msgstr ""
+#: ../display/d.rast/main.c:119
+msgid "Ignoring catlist: map is floating point (please use 'val=')"
+msgstr ""
+#: ../display/d.rast/main.c:125
+msgid "Ignoring vallist: map is integer (please use 'cat=')"
+msgstr ""
+#: ../display/d.title/main.c:47
+msgid ""
+"Create a TITLE for a raster map in a form suitable for display with d.text."
+msgstr ""
+#: ../display/d.title/main.c:58
+msgid "Sets the text color"
+msgstr ""
+#: ../display/d.title/main.c:66
+msgid "Sets the text size as percentage of the frame's height"
+msgstr ""
+#: ../display/d.title/main.c:70
+msgid "Draw title on current display"
+msgstr ""
+#: ../display/d.title/main.c:74
+msgid "Do a fancier title"
+msgstr ""
+#: ../display/d.title/main.c:79
+msgid "Do a simple title"
+msgstr ""
+#: ../display/d.title/main.c:97
+msgid "Title can be fancy or simple, not both"
+msgstr ""
+#: ../display/d.title/main.c:100
+msgid "No map name given"
+msgstr ""
+#: ../display/d.title/main.c:112 ../raster/r.mapcalc/map.c:92
+#: ../raster/r.mapcalc/map3.c:186 ../raster/r.report/parse.c:264
+#: ../raster/r.support/front/front.c:230 ../raster/r.statistics/main.c:91
+#: ../raster/r.cats/main.c:155 ../raster/r.cats/main.c:213
+#, c-format
+msgid "Unable to read category file of raster map <%s@%s>"
+msgstr ""
+#: ../display/d.vect.chart/main.c:65
+msgid ""
+"Displays charts of vector data in the active frame on the graphics monitor."
+msgstr ""
+#: ../display/d.vect.chart/main.c:82
+msgid "Chart type"
+msgstr ""
+#: ../display/d.vect.chart/main.c:83 ../display/d.vect.chart/main.c:97
+#: ../display/d.vect.chart/main.c:105 ../display/d.vect.chart/main.c:112
+#: ../display/d.vect.chart/main.c:120 ../display/d.vect.chart/main.c:129
+#: ../display/d.vect.chart/main.c:135
+msgid "Chart properties"
+msgstr ""
+#: ../display/d.vect.chart/main.c:90
+msgid "Attribute columns containing data"
+msgstr ""
+#: ../display/d.vect.chart/main.c:96
+msgid "Column used for pie chart size"
+msgstr ""
+#: ../display/d.vect.chart/main.c:104
+msgid "Size of chart (diameter for pie, total width for bar)"
+msgstr ""
+#: ../display/d.vect.chart/main.c:111
+msgid "Scale for size (to get size in pixels)"
+msgstr ""
+#: ../display/d.vect.chart/main.c:118
+msgid "Outline color"
+msgstr ""
+#: ../display/d.vect.chart/main.c:127
+msgid "Colors used to fill charts"
+msgstr ""
+#: ../display/d.vect.chart/main.c:134
+msgid "Center the bar chart around a data point"
+msgstr ""
+#: ../display/d.vect.chart/main.c:143
+msgid "Maximum value used for bar plot reference"
+msgstr ""
+#: ../display/d.vect.chart/main.c:148 ../display/d.thematic.area/main.c:174
+msgid "Create legend information and send to stdout"
+msgstr ""
+#: ../display/d.his/main.c:65
+msgid "display, color transformation"
+msgstr ""
+#: ../display/d.his/main.c:67
+msgid ""
+"Displays the result obtained by combining hue, intensity, and saturation "
+"(his) values from user-specified input raster map layers."
+msgstr ""
+#: ../display/d.his/main.c:76 ../raster/r.his/main.c:74
+msgid "Name of layer to be used for HUE"
+msgstr ""
+#: ../display/d.his/main.c:83 ../raster/r.his/main.c:81
+msgid "Name of layer to be used for INTENSITY"
+msgstr ""
+#: ../display/d.his/main.c:90 ../raster/r.his/main.c:88
+msgid "Name of layer to be used for SATURATION"
+msgstr ""
+#: ../display/d.his/main.c:95
+msgid "Percent to brighten intensity channel"
+msgstr ""
+#: ../display/d.his/main.c:101 ../raster/r.his/main.c:113
+msgid "Respect NULL values while drawing"
+msgstr ""
+#: ../display/d.his/main.c:120 ../display/d.what.rast/main.c:119
+msgid "No current graphics window"
+msgstr ""
+#: ../display/d.his/main.c:123 ../display/d.what.rast/main.c:122
+msgid "Current graphics window not available"
+msgstr ""
+#: ../display/d.his/main.c:219
+msgid "Error reading hue data"
+msgstr ""
+#: ../display/d.his/main.c:224
+msgid "Error reading intensity data"
+msgstr ""
+#: ../display/d.his/main.c:229
+msgid "Error reading saturation data"
+msgstr ""
+#: ../display/d.ask/main.c:36
+msgid "display, map management"
+msgstr ""
+#: ../display/d.ask/main.c:38
+msgid ""
+"Prompts the user to select a GRASS data base file from among files displayed "
+"in a menu on the graphics monitor."
+msgstr ""
+#: ../display/d.ask/main.c:46
+msgid "Database element, one word description"
+msgstr ""
+#: ../display/d.ask/main.c:52
+msgid "Short user prompt message"
+msgstr ""
+#: ../display/d.ask/main.c:85
+#, c-format
+msgid "** no %s files found **\n"
+msgstr ""
+#: ../display/d.ask/main.c:86
+#, c-format
+msgid "Click here to CONTINUE\n"
+msgstr ""
+#: ../display/d.font.freetype/main.c:61 ../display/d.font/main.c:48
+msgid ""
+"Selects the font in which text will be displayed on the user's graphics "
+"monitor."
+msgstr ""
+#: ../display/d.font.freetype/main.c:68
+msgid "Font name or pathname of TTF file"
+msgstr ""
+#: ../display/d.font.freetype/main.c:75 ../display/d.font/main.c:71
+msgid "Character encoding"
+msgstr ""
+#: ../display/d.font.freetype/main.c:173
+msgid "Setting release of FreeType"
+msgstr ""
+#: ../display/d.colortable/main.c:62
+msgid "Displays the color table associated with a raster map layer."
+msgstr ""
+#: ../display/d.colortable/main.c:66
+msgid "Name of raster map whose color table is to be displayed"
+msgstr ""
+#: ../display/d.colortable/main.c:74
+msgid "Color of lines separating the colors of the color table"
+msgstr ""
+#: ../display/d.colortable/main.c:80
+msgid "Number of lines to appear in the color table"
+msgstr ""
+#: ../display/d.colortable/main.c:86
+msgid "Number of columns to appear in the color table"
+msgstr ""
+#: ../display/d.colortable/main.c:111
+#, c-format
+msgid ""
+"<%s> is a floating point map. Ignoring [lines] and drawing continuous color "
+"ramp"
+msgstr ""
+#: ../display/d.colortable/main.c:125
+#, c-format
+msgid ""
+"<%s> is a floating point map. Ignoring [cols] and drawing continuous color "
+"ramp"
+msgstr ""
+#: ../display/d.colortable/main.c:134
+#, c-format
+msgid "R_color file for [%s] not available"
+msgstr ""
+#: ../display/d.colortable/main.c:136
+#, c-format
+msgid "Range file for [%s] not available"
+msgstr ""
+#: ../display/d.colortable/main.c:149
+msgid "Data range is empty"
+msgstr ""
+#: ../display/d.vect/plot1.c:219 ../display/d.thematic.area/plot1.c:207
+msgid "Color definition column not specified"
+msgstr ""
+#: ../display/d.vect/plot1.c:230 ../display/d.vect/area.c:83
+#, c-format
+msgid ""
+"Color definition column ('%s') not a string. Column must be of form 'RRR:GGG:"
+"BBB' where RGB values range 0-255. You can use '%s' module to define color "
+"rules. Unable to colorize features."
+msgstr ""
+#: ../display/d.vect/plot1.c:240 ../display/d.vect/plot1.c:281
+#: ../display/d.vect/plot1.c:324 ../display/d.vect/plot1.c:367
+#: ../display/d.vect/area.c:93 ../display/d.vect/area.c:136
+#: ../display/d.thematic.area/plot1.c:222
+#: ../display/d.thematic.area/plot1.c:250
+#: ../display/d.thematic.area/main.c:255
+#, c-format
+msgid "Cannot select data (%s) from table"
+msgstr ""
+#: ../display/d.vect/plot1.c:258 ../display/d.vect/area.c:113
+#: ../display/d.thematic.area/plot1.c:235
+msgid "Line width column not specified."
+msgstr ""
+#: ../display/d.vect/plot1.c:273
+#, c-format
+msgid "Line width column (%s) is not numeric."
+msgstr ""
+#: ../display/d.vect/plot1.c:301
+msgid "Symbol size column not specified."
+msgstr ""
+#: ../display/d.vect/plot1.c:316
+#, c-format
+msgid "Symbol size column (%s) is not numeric."
+msgstr ""
+#: ../display/d.vect/plot1.c:344
+msgid "Symbol rotation column not specified."
+msgstr ""
+#: ../display/d.vect/plot1.c:359
+#, c-format
+msgid "Symbol rotation column (%s) is not numeric."
+msgstr ""
+#: ../display/d.vect/plot1.c:385 ../display/d.vect/plot1.c:686
+msgid "Unable to read symbol, unable to display points"
+msgstr ""
+#: ../display/d.vect/plot1.c:508
+#, c-format
+msgid ""
+"Error in color definition column '%s', feature id %d with cat %d: "
+"colorstring '%s'"
+msgstr ""
+#: ../display/d.vect/plot1.c:516
+#, c-format
+msgid "Error in color definition column '%s', feature id %d with cat %d"
+msgstr ""
+#: ../display/d.vect/plot1.c:584 ../display/d.vect/area.c:369
+#: ../display/d.thematic.area/plot1.c:441
+#, c-format
+msgid ""
+"Error in line width column (%s), element %d with cat %d: line width [%d]"
+msgstr ""
+#: ../display/d.vect/plot1.c:638
+#, c-format
+msgid ""
+"Error in symbol size column (%s), element %d with cat %d: symbol size [%f]"
+msgstr ""
+#: ../display/d.vect/plot1.c:726
+#, c-format
+msgid "Error in color definition column '%s': %d features affected"
+msgstr ""
+#: ../display/d.vect/dir.c:31 ../display/d.vect/label.c:28
+#: ../display/d.vect/attr.c:53
+msgid "Can't read vector map"
+msgstr ""
+#: ../display/d.vect/topo.c:39 ../display/d.thematic.area/plot1.c:291
+#, c-format
+msgid ""
+"\n"
+"ERROR: vector map - can't read\n"
+msgstr ""
+#: ../display/d.vect/attr.c:30
+msgid "attrcol not specified, cannot display attributes"
+msgstr ""
+#: ../display/d.vect/attr.c:129
+#, c-format
+msgid "No attribute found for cat %d: %s"
+msgstr ""
+#: ../display/d.vect/area.c:72
+msgid "Color definition column not specified."
+msgstr ""
+#: ../display/d.vect/area.c:128 ../display/d.thematic.area/plot1.c:246
+#, c-format
+msgid "Line width column (%s) not a number."
+msgstr ""
+#: ../display/d.vect/area.c:302
+#, c-format
+msgid ""
+"Error in color definition column (%s), area %d with cat %d: colorstring [%s]"
+msgstr ""
+#: ../display/d.vect/area.c:308
+#, c-format
+msgid "Error in color definition column (%s), area %d with cat %d"
+msgstr ""
+#: ../display/d.vect/main.c:79
+msgid "Displays user-specified vector map in the active graphics frame."
+msgstr ""
+#: ../display/d.vect/main.c:91
+msgid "Display"
+msgstr ""
+#: ../display/d.vect/main.c:92
+msgid ""
+"shape;Display geometry of features;cat;Display category numbers of features;"
+"topo;Display topology information (nodes, edges);dir;Display direction of "
+"linear features;attr;Display selected attribute based on 'attrcol';zcoor;"
+"Display z-coordinate of features (only for 3D vector maps)"
+msgstr ""
+#: ../display/d.vect/main.c:107
+msgid "Layer number (if -1, all layers are displayed)"
+msgstr ""
+#: ../display/d.vect/main.c:122
+msgid "Feature color"
+msgstr ""
+#: ../display/d.vect/main.c:126 ../display/d.vect/main.c:136
+#: ../display/d.vect/main.c:239 ../display/d.vect/main.c:249
+msgid "Either a standard GRASS color, R:G:B triplet, or \"none\""
+msgstr ""
+#: ../display/d.vect/main.c:132
+msgid "Area fill color"
+msgstr ""
+#: ../display/d.vect/main.c:141
+msgid "Name of color definition column (for use with -a flag)"
+msgstr ""
+#: ../display/d.vect/main.c:149
+msgid "Type of color table (for use with -z flag)"
+msgstr ""
+#: ../display/d.vect/main.c:158 ../display/d.vect/main.c:163
+#: ../display/d.vect/main.c:171
+msgid "Lines"
+msgstr ""
+#: ../display/d.vect/main.c:159
+msgid "Line width"
+msgstr ""
+#: ../display/d.vect/main.c:165
+msgid "Name of column for line widths (these values will be scaled by wscale)"
+msgstr ""
+#: ../display/d.vect/main.c:172
+msgid "Scale factor for wcolumn"
+msgstr ""
+#: ../display/d.vect/main.c:180 ../display/d.vect/main.c:190
+#: ../display/d.vect/main.c:197 ../display/d.vect/main.c:203
+msgid "Symbols"
+msgstr ""
+#: ../display/d.vect/main.c:184
+msgid "Point and centroid symbol"
+msgstr ""
+#: ../display/d.vect/main.c:191
+msgid "Symbol size"
+msgstr ""
+#: ../display/d.vect/main.c:193
+msgid "When used with the size_column option this becomes the scale factor"
+msgstr ""
+#: ../display/d.vect/main.c:199
+msgid "Name of numeric column containing symbol size"
+msgstr ""
+#: ../display/d.vect/main.c:205
+msgid "Name of numeric column containing symbol rotation angle"
+msgstr ""
+#: ../display/d.vect/main.c:207
+msgid "Measured in degrees CCW from east"
+msgstr ""
+#: ../display/d.vect/main.c:212 ../display/d.vect/main.c:219
+#: ../display/d.vect/main.c:227 ../display/d.vect/main.c:235
+#: ../display/d.vect/main.c:245 ../display/d.vect/main.c:255
+#: ../display/d.vect/main.c:261 ../display/d.vect/main.c:267
+#: ../display/d.vect/main.c:275
+msgid "Labels"
+msgstr ""
+#: ../display/d.vect/main.c:214
+msgid "Layer number for labels (default: the given layer number)"
+msgstr ""
+#: ../display/d.vect/main.c:220
+msgid "Name of column to be displayed"
+msgstr ""
+#: ../display/d.vect/main.c:226
+msgid "Label color"
+msgstr ""
+#: ../display/d.vect/main.c:229
+msgid "Either a standard color name or R:G:B triplet"
+msgstr ""
+#: ../display/d.vect/main.c:236
+msgid "Label background color"
+msgstr ""
+#: ../display/d.vect/main.c:246
+msgid "Label border color"
+msgstr ""
+#: ../display/d.vect/main.c:256
+msgid "Label size (pixels)"
+msgstr ""
+#: ../display/d.vect/main.c:270
+msgid "Label horizontal justification"
+msgstr ""
+#: ../display/d.vect/main.c:278
+msgid "Label vertical justification"
+msgstr ""
+#: ../display/d.vect/main.c:285
+msgid ""
+"Minimum region size (average from height and width) when map is displayed"
+msgstr ""
+#: ../display/d.vect/main.c:293
+msgid ""
+"Maximum region size (average from height and width) when map is displayed"
+msgstr ""
+#: ../display/d.vect/main.c:303 ../display/d.thematic.area/main.c:158
+msgid "Rendering method for filled polygons"
+msgstr ""
+#: ../display/d.vect/main.c:305
+msgid ""
+"g;use the libgis render functions (features: clipping);r;use the raster "
+"graphics library functions (features: polylines);d;use the display library "
+"basic functions (features: polylines);c;use the display library clipping "
+"functions (features: clipping);l;use the display library culling functions "
+"(features: culling, polylines)"
+msgstr ""
+#: ../display/d.vect/main.c:314 ../raster/r.cost/main.c:217
+#: ../raster/wildfire/r.spreadpath/main.c:110
+#: ../raster/wildfire/r.ros/main.c:301
+msgid "Run verbosely"
+msgstr ""
+#: ../display/d.vect/main.c:321
+msgid "Get colors from map table column (of form RRR:GGG:BBB)"
+msgstr ""
+#: ../display/d.vect/main.c:327
+msgid ""
+"Random colors according to category number (or layer number if 'layer=-1' is "
+"given)"
+msgstr ""
+#: ../display/d.vect/main.c:334
+msgid "Use values from 'cats' option as feature id"
+msgstr ""
+#: ../display/d.vect/main.c:339
+msgid ""
+"Don't add to list of vectors and commands in monitor (it won't be drawn if "
+"the monitor is refreshed)"
+msgstr ""
+#: ../display/d.vect/main.c:344
+msgid "Colorize polygons according to z height"
+msgstr ""
+#: ../display/d.vect/main.c:387 ../display/d.paint.labels/main.c:102
+msgid "Region size is lower than minreg, nothing displayed."
+msgstr ""
+#: ../display/d.vect/main.c:396 ../display/d.paint.labels/main.c:111
+msgid "Region size is greater than maxreg, nothing displayed."
+msgstr ""
+#: ../display/d.vect/main.c:411
+msgid ""
+"The '-c' and '-a' flags cannot be used together, the '-c' flag will be "
+"ignored!"
+msgstr ""
+#: ../display/d.vect/main.c:427 ../display/d.thematic.area/main.c:318
+#, c-format
+msgid "Unknown color: [%s]"
+msgstr ""
+#: ../display/d.vect/main.c:442
+#, c-format
+msgid "Unknown color: '%s'"
+msgstr ""
+#: ../display/d.vect/main.c:490
+msgid "'layer' must be > 0 for 'cats'."
+msgstr ""
+#: ../display/d.vect/main.c:494
+#, c-format
+msgid "%d errors in cat option"
+msgstr ""
+#: ../display/d.vect/main.c:583 ../display/d.thematic.area/main.c:402
+msgid "Plotting ..."
+msgstr ""
+#: ../display/d.vect/main.c:591 ../display/d.thematic.area/main.c:409
+msgid ""
+"The bounding box of the map is outside the current region, nothing drawn."
+msgstr ""
+#: ../display/d.vect/main.c:625
+msgid "Unable to display areas, topology not available"
+msgstr ""
+#: ../display/d.vect/main.c:630
+msgid "Unable to display lines by id, topology not available"
+msgstr ""
+#: ../display/d.vect/main.c:673
+msgid "Unable to display topology, not available"
+msgstr ""
+#: ../display/d.path/select.c:35
+msgid ""
+"\n"
+"Mouse Buttons:"
+msgstr ""
+#: ../display/d.path/select.c:36
+#, c-format
+msgid "Left:   Select From\n"
+msgstr ""
+#: ../display/d.path/select.c:37
+#, c-format
+msgid "Middle: Select To\n"
+msgstr ""
+#: ../display/d.path/select.c:38
+#, c-format
+msgid ""
+"Right:  Quit\n"
+"\n"
+msgstr ""
+#: ../display/d.path/select.c:65 ../display/d.path/select.c:242
+#: ../display/d.path/select.c:259
+#, c-format
+msgid "Node %d: %f %f\n"
+msgstr ""
+#: ../display/d.path/select.c:149 ../display/d.path/select.c:280
+#, c-format
+msgid "Destination unreachable\n"
+msgstr ""
+#: ../display/d.path/select.c:153 ../display/d.path/select.c:283
+#, c-format
+msgid "Costs on the network = %f\n"
+msgstr ""
+#: ../display/d.path/select.c:154 ../display/d.path/select.c:284
+#, c-format
+msgid ""
+"  Distance to the network = %f, distance from the network = %f\n"
+"\n"
+msgstr ""
+#: ../display/d.path/main.c:50
+msgid "display, networking"
+msgstr ""
+#: ../display/d.path/main.c:52
+msgid "Finds shortest path for selected starting and ending node."
+msgstr ""
+#: ../display/d.path/main.c:102 ../display/d.path/main.c:110
+#: ../display/d.path/main.c:118 ../display/d.path/main.c:128
+msgid "Rendering"
+msgstr ""
+#: ../display/d.path/main.c:127
+msgid "Render bold lines"
+msgstr ""
+#: ../display/d.path/main.c:146 ../display/d.path/main.c:150
+#, c-format
+msgid "%s - illegal x value"
+msgstr ""
+#: ../display/d.path/main.c:148 ../display/d.path/main.c:152
+#, c-format
+msgid "%s - illegal y value"
+msgstr ""
+#: ../display/drivers/XDRIVER/Get_w_box.c:34
+#: ../display/drivers/XDRIVER/Get_w_pointer.c:21
+#: ../display/drivers/XDRIVER/Get_w_line.c:35
+msgid "Monitor: interactive command in redraw"
+msgstr ""
+#: ../display/drivers/XDRIVER/Graph_set.c:110
+#, c-format
+msgid "found %d visuals of type TrueColor"
+msgstr ""
+#: ../display/drivers/XDRIVER/Graph_set.c:112
+msgid "searching for highest bit depth"
+msgstr ""
+#: ../display/drivers/XDRIVER/Graph_set.c:128
+#, c-format
+msgid "selected %d bit depth"
+msgstr ""
+#: ../display/drivers/XDRIVER/Graph_set.c:188
+#, c-format
+msgid "using default visual which is %s"
+msgstr ""
+#: ../display/drivers/XDRIVER/Serve_Xevent.c:125
+#, c-format
+msgid "Monitor: waitpid: expected %d but got %d"
+msgstr ""
+#: ../display/drivers/XDRIVER/Serve_Xevent.c:331
+msgid "Monitor: XGetWMName failed"
+msgstr ""
+#: ../display/drivers/XDRIVER/Serve_Xevent.c:336
+msgid "Monitor: XGetWMName: bad result"
+msgstr ""
+#: ../display/d.frame/frame.c:62
+msgid "Manages display frames on the user's graphics monitor."
+msgstr ""
+#: ../display/d.frame/frame.c:66
+msgid "Create a new frame"
+msgstr ""
+#: ../display/d.frame/frame.c:70
+msgid "Select a frame"
+msgstr ""
+#: ../display/d.frame/frame.c:74 ../display/d.erase/main.c:47
+msgid "Remove all frames and erase the screen"
+msgstr ""
+#: ../display/d.frame/frame.c:78
+msgid "Print name of current frame"
+msgstr ""
+#: ../display/d.frame/frame.c:82
+msgid "Print names of all frames"
+msgstr ""
+#: ../display/d.frame/frame.c:86
+msgid "List map names displayed in GRASS monitor"
+msgstr ""
+#: ../display/d.frame/frame.c:90
+msgid "Debugging output"
+msgstr ""
+#: ../display/d.frame/frame.c:95
+msgid "name"
+msgstr ""
+#: ../display/d.frame/frame.c:98
+msgid "Frame to be created/selected"
+msgstr ""
+#: ../display/d.frame/frame.c:102
+msgid "bottom,top,left,right"
+msgstr ""
+#: ../display/d.frame/frame.c:107
+msgid "Where to place the frame, values in percent (implies -c)"
+msgstr ""
+#: ../display/d.frame/select.c:41
+#, c-format
+msgid "Error choosing frame [%s]\n"
+msgstr ""
+#: ../display/d.frame/select.c:51
+#, c-format
+msgid ""
+"\n"
+"Buttons:\n"
+msgstr ""
+#: ../display/d.frame/select.c:52
+#, c-format
+msgid "Left:   Select frame\n"
+msgstr ""
+#: ../display/d.frame/select.c:53
+#, c-format
+msgid "Middle: Keep original frame\n"
+msgstr ""
+#: ../display/d.frame/select.c:54
+#, c-format
+msgid "Right:  Accept frame\n"
+msgstr ""
+#: ../display/d.barscale/main.c:57
+msgid "Displays a barscale on the graphics monitor."
+msgstr ""
+#: ../display/d.barscale/main.c:61
+msgid "Use mouse to interactively place scale"
+msgstr ""
+#: ../display/d.barscale/main.c:65
+msgid "Use feet/miles instead of meters"
+msgstr ""
+#: ../display/d.barscale/main.c:69
+msgid "Draw a line scale instead of a bar scale"
+msgstr ""
+#: ../display/d.barscale/main.c:73
+msgid "Write text on top of the scale, not to the right"
+msgstr ""
+#: ../display/d.barscale/main.c:77
+msgid "Draw a north arrow only"
+msgstr ""
+#: ../display/d.barscale/main.c:81
+msgid "Draw a scale bar only"
+msgstr ""
+#: ../display/d.barscale/main.c:98
+msgid ""
+"The screen coordinates for top-left corner of label ([0,0] is top-left of "
+"frame)"
+msgstr ""
+#: ../display/d.barscale/main.c:114
+#, c-format
+msgid "%s does not work with a latitude-longitude location"
+msgstr ""
+#: ../display/d.barscale/main.c:122
+msgid "Choose either -n or -s flag"
+msgstr ""
+#: ../display/d.barscale/main.c:165 ../display/d.rast.arrow/arrow.c:266
+#: ../display/d.what.rast/main.c:137 ../display/d.rast.num/number.c:186
+#: ../display/d.info/main.c:115 ../display/d.info/main.c:140
+#: ../display/d.paint.labels/main.c:139
+msgid "Error in calculating conversions"
+msgstr ""
+#: ../display/d.rast.arrow/arrow.c:112
+msgid ""
+"Draws arrows representing cell aspect direction for a raster map containing "
+"aspect data."
+msgstr ""
+#: ../display/d.rast.arrow/arrow.c:121
+msgid "Name of raster aspect map to be displayed"
+msgstr ""
+#: ../display/d.rast.arrow/arrow.c:129
+msgid "Type of existing raster aspect map"
+msgstr ""
+#: ../display/d.rast.arrow/arrow.c:137
+msgid "Color for drawing arrows"
+msgstr ""
+#: ../display/d.rast.arrow/arrow.c:145
+msgid "Color for drawing grid or \"none\""
+msgstr ""
+#: ../display/d.rast.arrow/arrow.c:153
+msgid "Color for drawing X's (Null values)"
+msgstr ""
+#: ../display/d.rast.arrow/arrow.c:161
+msgid "Color for showing unknown information"
+msgstr ""
+#: ../display/d.rast.arrow/arrow.c:168
+msgid "Draw arrow every Nth grid cell"
+msgstr ""
+#: ../display/d.rast.arrow/arrow.c:177
+msgid "Raster map containing values used for arrow length"
+msgstr ""
+#: ../display/d.rast.arrow/arrow.c:184
+msgid "Scale factor for arrows (magnitude map)"
+msgstr ""
+#: ../display/d.rast.arrow/arrow.c:224
+msgid "Illegal value for scale factor"
+msgstr ""
+#: ../display/d.rast.arrow/arrow.c:228
+msgid "Illegal value for skip factor"
+msgstr ""
+#: ../display/d.rast.arrow/arrow.c:233
+msgid "Magnitude is only supported for GRASS and compass aspect maps."
+msgstr ""
+#: ../display/d.rast.arrow/arrow.c:240
+msgid "Scale option requires magnitude_map"
+msgstr ""
+#: ../display/d.rast.arrow/arrow.c:313
+msgid "Problem reading range file"
+msgstr ""
+#: ../display/d.rast.arrow/arrow.c:368
+msgid "No raster map exists in the current window"
+msgstr ""
+#: ../display/d.what.rast/what.c:57
+msgid "You are clicking outside the map"
+msgstr ""
+#: ../display/d.what.rast/main.c:54
+msgid ""
+"Allows the user to interactively query the category contents of multiple "
+"raster map layers at user specified locations within the current geographic "
+"region."
+msgstr ""
+#: ../display/d.what.rast/main.c:81 ../raster/r.compress/main.c:73
+msgid "Name of existing raster map(s)"
+msgstr ""
+#: ../display/d.what.rast/main.c:89
+msgid "Field separator (terse mode only)"
+msgstr ""
+#: ../display/d.what.rast/main.c:103
+msgid "Print out col/row for the entire map in grid resolution of the region"
+msgstr ""
+#: ../display/d.what.rast/main.c:128
+msgid "Setting graphics window"
+msgstr ""
+#: ../display/d.what.rast/main.c:131
+msgid "Can't set current graphics window"
+msgstr ""
+#: ../display/d.what.rast/main.c:135
+msgid "Getting graphics window coordinates"
+msgstr ""
+#: ../display/d.zoom/zoom.c:15 ../display/d.zoom/pan.c:17
+#, c-format
+msgid ""
+"\n"
+"\n"
+"Buttons:\n"
+msgstr ""
+#: ../display/d.zoom/zoom.c:16
+#, c-format
+msgid "Left:   Zoom menu\n"
+msgstr ""
+#: ../display/d.zoom/zoom.c:17
+#, c-format
+msgid "Middle: Pan\n"
+msgstr ""
+#: ../display/d.zoom/zoom.c:18
+#, c-format
+msgid "Right:  Quit menu\n"
+msgstr ""
+#: ../display/d.zoom/zoom.c:40
+#, c-format
+msgid ""
+"This region now saved as current region.\n"
+"\n"
+msgstr ""
+#: ../display/d.zoom/zoom.c:42
+#, c-format
+msgid "Note: run 'd.erase' for the new region to affect the graphics.\n"
+msgstr ""
+#: ../display/d.zoom/pan.c:18
+#, c-format
+msgid "Left:   Pan\n"
+msgstr ""
+#: ../display/d.zoom/pan.c:19
+#, c-format
+msgid "Right:  Quit\n"
+msgstr ""
+#: ../display/d.zoom/main.c:57
+msgid "display, zoom"
+msgstr ""
+#: ../display/d.zoom/main.c:59
+msgid ""
+"Allows the user to change the current geographic region settings "
+"interactively, with a mouse."
+msgstr ""
+#: ../display/d.zoom/main.c:108
+msgid "Magnification: >1.0 zooms in, <1.0 zooms out"
+msgstr ""
+#: ../display/d.zoom/main.c:118
+msgid "Full menu (zoom + pan) & Quit menu"
+msgstr ""
+#: ../display/d.zoom/main.c:122
+msgid "Pan mode"
+msgstr ""
+#: ../display/d.zoom/main.c:126
+msgid "Handheld mode"
+msgstr ""
+#: ../display/d.zoom/main.c:130
+msgid "Just redraw given maps using default colors"
+msgstr ""
+#: ../display/d.zoom/main.c:134
+msgid "Return to previous zoom"
+msgstr ""
+#: ../display/d.zoom/main.c:145
+msgid "Please choose only one mode of operation"
+msgstr ""
+#: ../display/d.zoom/main.c:162
+msgid "ERROR: can not get \"list\" items"
+msgstr ""
+#: ../display/d.zoom/main.c:163
+msgid "-j flag forced"
+msgstr ""
+#: ../display/d.zoom/main.c:196
+msgid "No map is displayed in GRASS monitor"
+msgstr ""
+#: ../display/d.zoom/main.c:298
+#, c-format
+msgid "%d raster%s, %d vector%s\n"
+msgstr ""
+#: ../display/d.zoom/main.c:307
+msgid "No previous zoom available"
+msgstr ""
+#: ../display/d.zoom/main.c:311
+msgid "Returning to previous zoom"
+msgstr ""
+#: ../display/d.zoom/main.c:352
+msgid "Zooming complete."
+msgstr ""
+#: ../display/d.nviz/main.c:69
+msgid "display, visualization, raster, vector, raster3d"
+msgstr ""
+#: ../display/d.nviz/main.c:70
+msgid "Creates fly-through script to run in NVIZ."
+msgstr ""
+#: ../display/d.nviz/main.c:75
+msgid "Name of output script"
+msgstr ""
+#: ../display/d.nviz/main.c:81
+msgid "Prefix of output images (default = NVIZ)"
+msgstr ""
+#: ../display/d.nviz/main.c:89
+msgid "Route coordinates (east,north)"
+msgstr ""
+#: ../display/d.nviz/main.c:95
+msgid "Camera layback distance (in map units)"
+msgstr ""
+#: ../display/d.nviz/main.c:101
+msgid "Camera height above terrain"
+msgstr ""
+#: ../display/d.nviz/main.c:107
+msgid "Number of frames"
+msgstr ""
+#: ../display/d.nviz/main.c:113
+msgid "Start frame number (default=0)"
+msgstr ""
+#: ../display/d.nviz/main.c:118
+msgid "Interactively select route"
+msgstr ""
+#: ../display/d.nviz/main.c:122
+msgid "Full render -- Save images"
+msgstr ""
+#: ../display/d.nviz/main.c:126
+msgid "Fly at constant elevation (ht)"
+msgstr ""
+#: ../display/d.nviz/main.c:131
+msgid "Include command in the script to output a KeyFrame file"
+msgstr ""
+#: ../display/d.nviz/main.c:135
+msgid "Render images off-screen"
+msgstr ""
+#: ../display/d.nviz/main.c:139
+msgid "Enable vector and sites drawing"
+msgstr ""
+#: ../display/d.nviz/main.c:147
+msgid "Either -i flag and/or route parameter must be used"
+msgstr ""
+#: ../display/d.nviz/main.c:171
+msgid "Off-screen only available with full render mode"
+msgstr ""
+#: ../display/d.nviz/main.c:282
+msgid "You must select more than one point"
+msgstr ""
+#: ../display/d.nviz/main.c:300
+msgid "You must select at least four points"
+msgstr ""
+#: ../display/d.nviz/main.c:317
+#, c-format
+msgid "You must provide at least four points %d"
+msgstr ""
+#: ../display/d.nviz/main.c:391
+#, c-format
+msgid "Created NVIZ script <%s>."
+msgstr ""
+#: ../display/d.nviz/main.c:538
+msgid ""
+"Skipping this point, selected point is outside region. Perhaps the camera "
+"setback distance puts it beyond the edge?"
+msgstr ""
+#: ../display/d.where/main.c:42
+msgid "display, position, querying"
+msgstr ""
+#: ../display/d.where/main.c:44
+msgid ""
+"Identifies the geographic coordinates associated with point locations in the "
+"active frame on the graphics monitor."
+msgstr ""
+#: ../display/d.where/main.c:49
+msgid "One mouse click only"
+msgstr ""
+#: ../display/d.where/main.c:53
+msgid "Output lat/long in decimal degree"
+msgstr ""
+#: ../display/d.where/main.c:58
+msgid "Output lat/long referenced to current ellipsoid"
+msgstr ""
+#: ../display/d.where/main.c:63
+msgid ""
+"Output lat/long referenced to WGS84 ellipsoid using datum transformation "
+"parameters defined in current location (if available)"
+msgstr ""
+#: ../display/d.where/main.c:69
+msgid "Output frame coordinates of current display monitor (percentage)"
+msgstr ""
+#: ../display/d.where/main.c:77
+msgid "Ambiguous request for lat/long ellipsoids"
+msgstr ""
+#: ../display/d.where/main.c:80
+msgid "Please specify a lat/long ellipsoid with -l or -w"
+msgstr ""
+#: ../display/d.where/main.c:122
+msgid ""
+"WGS84 output not possible as this location does not contain\n"
+msgstr ""
+#: ../display/d.linegraph/linegraph.c:115
+msgid ""
+"Generates and displays simple line graphs in the active graphics monitor "
+"display frame."
+msgstr ""
+#: ../display/d.linegraph/linegraph.c:119
+msgid "Name of data file for X axis of graph"
+msgstr ""
+#: ../display/d.linegraph/linegraph.c:125
+msgid "Name of data file(s) for Y axis of graph"
+msgstr ""
+#: ../display/d.linegraph/linegraph.c:132
+msgid "Path to file location"
+msgstr ""
+#: ../display/d.linegraph/linegraph.c:139
+msgid "Color for Y data"
+msgstr ""
+#: ../display/d.linegraph/linegraph.c:148
+msgid "Color for axis, tics, numbers, and title"
+msgstr ""
+#: ../display/d.linegraph/linegraph.c:156
+msgid "Title for X data"
+msgstr ""
+#: ../display/d.linegraph/linegraph.c:163
+msgid "Title for Y data"
+msgstr ""
+#: ../display/d.linegraph/linegraph.c:170
+msgid "Title for Graph"
+msgstr ""
+#: ../display/d.linegraph/linegraph.c:209
+msgid "Maximum of 10 Y data files exceeded"
+msgstr ""
+#: ../display/d.linegraph/linegraph.c:238
+#, c-format
+msgid "Only <%d> colors given for <%d> lines"
+msgstr ""
+#: ../display/d.linegraph/linegraph.c:290
+#, c-format
+msgid "Y input file <%s> contains %s data points than the X input file"
+msgstr ""
+#: ../display/d.linegraph/linegraph.c:295
+#, c-format
+msgid "The last %d point(s) will be ignored"
+msgstr ""
+#: ../display/d.linegraph/linegraph.c:355
+#, c-format
+msgid "Problem reading X data file at line %d"
+msgstr ""
+#: ../display/d.linegraph/linegraph.c:366
+#, c-format
+msgid "Problem reading <%s> data file at line %d"
+msgstr ""
+#: ../display/d.erase/main.c:34
+msgid "Erase the contents of the active display frame with user defined color"
+msgstr ""
+#: ../display/d.erase/main.c:42
+msgid ""
+"Color to erase with, either a standard GRASS color or R:G:B triplet "
+"(separated by colons)"
+msgstr ""
+#: ../display/d.rast.num/number.c:86
+msgid ""
+"Overlays cell category values on a raster map layer displayed to the "
+"graphics monitor."
+msgstr ""
+#: ../display/d.rast.num/number.c:100
+msgid "Color for drawing grid, or \"none\""
+msgstr ""
+#: ../display/d.rast.num/number.c:110
+msgid "Color for drawing text"
+msgstr ""
+#: ../display/d.rast.num/number.c:124
+msgid "Get text color from cell color value"
+msgstr ""
+#: ../display/d.rast.num/number.c:138
+msgid "No raster map exists in current window"
+msgstr ""
+#: ../display/d.rast.num/number.c:209
+#, c-format
+msgid ""
+"Current region size: %d rows X %d cols\n"
+"Your current region setting may be too large. Cells displayed on your "
+"graphics window may be too small for cell category number to be visible."
+msgstr ""
+#: ../display/d.rast.num/number.c:216
+msgid "Aborting (region larger then 200 rows X 200 cols is not allowed)"
+msgstr ""
+#: ../display/d.rhumbline/main.c:47
+msgid ""
+"Displays the rhumbline joining two user-specified points, in the active "
+"frame on the user's graphics monitor."
+msgstr ""
+#: ../display/d.font/main.c:56
+msgid "Choose new current font"
+msgstr ""
+#: ../display/d.font/main.c:63
+msgid "Path to Freetype-compatible font including file name"
+msgstr ""
+#: ../display/d.font/main.c:75
+msgid "List fonts"
+msgstr ""
+#: ../display/d.font/main.c:79
+msgid "List fonts verbosely"
+msgstr ""
+#: ../display/d.font/main.c:105
+#, c-format
+msgid "Unable to access font path %s: %s"
+msgstr ""
+#: ../display/d.font/main.c:109
+#, c-format
+msgid "Font path %s is not a file"
+msgstr ""
+#: ../display/d.font/main.c:126
+#, c-format
+msgid ""
+"Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
+msgstr ""
+#: ../display/d.histogram/main.c:71
+msgid "display, histogram, statistics"
+msgstr ""
+#: ../display/d.histogram/main.c:73
+msgid ""
+"Displays a histogram in the form of a pie or bar chart for a user-specified "
+"raster map."
+msgstr ""
+#: ../display/d.histogram/main.c:77
+msgid "Raster map for which histogram will be displayed"
+msgstr ""
+#: ../display/d.histogram/main.c:81
+msgid "Indicate if a pie or bar chart is desired"
+msgstr ""
+#: ../display/d.histogram/main.c:90
+msgid "Color for text and axes"
+msgstr ""
+#: ../display/d.histogram/main.c:98
+msgid "Indicate if cell counts or map areas should be displayed"
+msgstr ""
+#: ../display/d.histogram/main.c:108
+msgid "Number of steps to divide the data range into (fp maps only)"
+msgstr ""
+#: ../display/d.histogram/main.c:115
+msgid "Display information for null cells"
+msgstr ""
+#: ../display/d.histogram/main.c:119
+msgid "Gather the histogram quietly"
+msgstr ""
+#: ../display/d.histogram/main.c:124
+msgid "Report for ranges defined in cats file (fp maps only)"
+msgstr ""
+#: ../display/d.histogram/main.c:149
+#, c-format
+msgid "Invalid number of steps: %s"
+msgstr ""
+#: ../display/d.histogram/main.c:154
+msgid "When -C flag is set, the nsteps argument is ignored"
+msgstr ""
+#: ../display/d.info/main.c:36
+msgid "Display information about the active display monitor"
+msgstr ""
+#: ../display/d.info/main.c:41
+msgid "Display screen rectangle (left, right, top, bottom)"
+msgstr ""
+#: ../display/d.info/main.c:45
+msgid "Display screen dimensions (width, height)"
+msgstr ""
+#: ../display/d.info/main.c:49
+msgid "Display active frame rectangle"
+msgstr ""
+#: ../display/d.info/main.c:53
+msgid "Display screen rectangle of current region"
+msgstr ""
+#: ../display/d.info/main.c:58
+msgid "Display geographic coordinates and resolution of entire screen"
+msgstr ""
+#: ../display/d.info/main.c:62
+msgid "Display number of colors"
+msgstr ""
+#: ../display/d.mapgraph/main.c:50
+msgid ""
+"Generates and displays simple graphics on map layers drawn in the active "
+"graphics monitor display frame."
+msgstr ""
+#: ../display/d.mapgraph/main.c:57
+msgid ""
+"Unix file containg graphing instructions, if not given reads from standard "
+"input"
+msgstr ""
+#: ../display/d.mapgraph/main.c:67
+msgid ""
+"Color to draw with, either a standard GRASS color or R:G:B triplet "
+msgstr ""
+#: ../display/d.text.freetype/main.c:140
+msgid ""
+"Draws text in the graphics monitor's active display frame using TrueType "
+"fonts."
+msgstr ""
+#: ../display/d.text.freetype/main.c:146 ../display/d.text.new/main.c:150
+msgid "Text to display"
+msgstr ""
+#: ../display/d.text.freetype/main.c:154
+msgid "Screen position (percentage, [0,0] is bottom left)"
+msgstr ""
+#: ../display/d.text.freetype/main.c:176
+msgid "Path to TrueType font (including file name)"
+msgstr ""
+#: ../display/d.text.freetype/main.c:192 ../display/d.text.new/main.c:167
+#: ../display/d.text/main.c:85
+msgid "Text color, either a standard GRASS color or R:G:B triplet"
+msgstr ""
+#: ../display/d.text.freetype/main.c:201
+msgid "Height of letters (in percent of available frame height)"
+msgstr ""
+#: ../display/d.text.freetype/main.c:209 ../display/d.text.new/main.c:200
+msgid "Text alignment"
+msgstr ""
+#: ../display/d.text.freetype/main.c:217 ../display/d.text.new/main.c:208
+#: ../display/d.text/main.c:110
+msgid "Rotation angle in degrees (counter-clockwise)"
+msgstr ""
+#: ../display/d.text.freetype/main.c:224 ../display/d.text.new/main.c:215
+msgid "Line spacing"
+msgstr ""
+#: ../display/d.text.freetype/main.c:228 ../display/d.text.new/main.c:243
+msgid "Screen position in pixels ([0,0] is top left)"
+msgstr ""
+#: ../display/d.text.freetype/main.c:232 ../display/d.text.new/main.c:247
+msgid "Screen position in geographic coordinates"
+msgstr ""
+#: ../display/d.text.freetype/main.c:236 ../display/d.text.new/main.c:251
+#: ../display/d.text/main.c:114
+msgid "Use bold text"
+msgstr ""
+#: ../display/d.text.freetype/main.c:240 ../display/d.text.new/main.c:255
+msgid "Use radians instead of degrees for rotation"
+msgstr ""
+#: ../display/d.text.freetype/main.c:244 ../display/d.text.new/main.c:259
+msgid "Font size is height in pixels"
+msgstr ""
+#: ../display/d.text.freetype/main.c:248
+msgid "Command mode (Compatibility with d.text)"
+msgstr ""
+#: ../display/d.text.freetype/main.c:255
+msgid "Either text or -c should be given"
+msgstr ""
+#: ../display/d.text.freetype/main.c:260
+msgid "Choose only one coordinate system for placement"
+msgstr ""
+#: ../display/d.text.freetype/main.c:265 ../display/d.text.freetype/main.c:268
+#: ../display/d.text.freetype/main.c:606
+msgid "No font selected"
+msgstr ""
+#: ../display/d.text.freetype/main.c:277 ../display/d.text.freetype/main.c:440
+#, c-format
+msgid "Invalid font: %s"
+msgstr ""
+#: ../display/d.text.freetype/main.c:331 ../display/d.text.freetype/main.c:458
+msgid "Unable to create face"
+msgstr ""
+#: ../display/d.text.freetype/main.c:334 ../display/d.text.freetype/main.c:461
+#: ../display/d.text.freetype/main.c:478
+msgid "Unable to set size"
+msgstr ""
+#: ../display/d.text.freetype/main.c:349 ../display/d.text.freetype/main.c:568
+msgid "Unable to create text conversion context"
+msgstr ""
+#: ../display/d.text.freetype/main.c:351 ../display/d.text.freetype/main.c:570
+msgid "Text conversion error"
+msgstr ""
+#: ../display/d.text.freetype/main.c:415
+msgid "Unable to write the temporary file"
+msgstr ""
+#: ../display/d.text.freetype/main.c:435
+msgid "No predefined font"
+msgstr ""
+#: ../display/d.text.freetype/main.c:451
+#, c-format
+msgid "%s: Unable to read font"
+msgstr ""
+#: ../display/d.text.freetype/main.c:645
+#, c-format
+msgid "%s: Unable to read FreeType definition file; use the default"
+msgstr ""
+#: ../display/d.text.freetype/main.c:651
+#, c-format
+msgid "%s: No FreeType definition file"
+msgstr ""
+#: ../display/d.text.freetype/main.c:655
+#, c-format
+msgid "%s: Unable to read FreeType definition file"
+msgstr ""
+#: ../display/d.thematic.area/plot1.c:217
+#, c-format
+msgid ""
+"Color definition column (%s) not a string. Column must be of form RRR:GGG:"
+"BBB where RGB values range 0-255."
+msgstr ""
+#: ../display/d.thematic.area/plot1.c:366
+#, c-format
+msgid ""
+"Error in color definition column (%s), element %d with cat %d: colorstring "
+"[%s]"
+msgstr ""
+#: ../display/d.thematic.area/plot1.c:373
+#, c-format
+msgid "Error in color definition column (%s), element %d with cat %d"
+msgstr ""
+#: ../display/d.thematic.area/main.c:80
+msgid ""
+"Displays a thematic vector area map in the active frame on the graphics "
+"monitor."
+msgstr ""
+#: ../display/d.thematic.area/main.c:90
+msgid "Data to be classified: column name or expression"
+msgstr ""
+#: ../display/d.thematic.area/main.c:97
+msgid "Class breaks, without minimum and maximum"
+msgstr ""
+#: ../display/d.thematic.area/main.c:124
+msgid "Colors (one per class)."
+msgstr ""
+#: ../display/d.thematic.area/main.c:130
+msgid "Layer number. If -1, all layers are displayed."
+msgstr ""
+#: ../display/d.thematic.area/main.c:140 ../display/d.thematic.area/main.c:148
+msgid "Boundaries"
+msgstr ""
+#: ../display/d.thematic.area/main.c:141
+msgid "Boundary width"
+msgstr ""
+#: ../display/d.thematic.area/main.c:147
+msgid "Boundary color"
+msgstr ""
+#: ../display/d.thematic.area/main.c:160
+msgid ""
+"d;use the display library basic functions (features: polylines);c;use the "
+"display library clipping functions (features: clipping);l;use the display "
+"library culling functions (features: culling, polylines)"
+msgstr ""
+#: ../display/d.thematic.area/main.c:168
+msgid "File in which to save d.graph instructions for legend display"
+msgstr ""
+#: ../display/d.thematic.area/main.c:179
+msgid ""
+"When printing legend info , include extended statistical info from "
+"classification algorithm"
+msgstr ""
+#: ../display/d.thematic.area/main.c:183
+msgid "Do not draw map, only output the legend"
+msgstr ""
+#: ../display/d.thematic.area/main.c:196
+#, c-format
+msgid "Invalid rendering method <%s>"
+msgstr ""
+#: ../display/d.thematic.area/main.c:218
+#, c-format
+msgid "%s: You must build topology on vector map. Run v.build."
+msgstr ""
+#: ../display/d.thematic.area/main.c:225
+msgid "'layer' must be > 0"
+msgstr ""
+#: ../display/d.thematic.area/main.c:251
+#, c-format
+msgid "Data (%s) not numeric. Column must be numeric."
+msgstr ""
+#: ../display/d.thematic.area/main.c:329
+msgid ""
+"You gave both manual breaks and a classification algorithm or a number of "
+"classes. The manual breaks have precedence and will thus be used."
+msgstr ""
+#: ../display/d.thematic.area/main.c:366
+msgid "You must either give classbreaks or a classification algorithm"
+msgstr ""
+#: ../display/d.thematic.area/main.c:379
+#, c-format
+msgid ""
+"Not enough colors or error in color specifications.\n"
+"Need %i colors."
+msgstr ""
+#: ../display/d.thematic.area/main.c:384
+#, c-format
+msgid "Error interpreting color %s"
+msgstr ""
+#: ../display/d.thematic.area/main.c:458
+#, c-format
+msgid ""
+"\n"
+"Total number of records: %.0f\n"
+msgstr ""
+#: ../display/d.thematic.area/main.c:460
+#, c-format
+msgid "Classification of %s into %i classes\n"
+msgstr ""
+#: ../display/d.thematic.area/main.c:468
+#, c-format
+msgid "Last chi2 = %f\n"
+msgstr ""
+#: ../display/d.text.new/main.c:144 ../display/d.text/main.c:68
+msgid ""
+"Draws text in the active display frame on the graphics monitor using the "
+"current font."
+msgstr ""
+#: ../display/d.text.new/main.c:159 ../display/d.text/main.c:77
+msgid "Height of letters in percentage of available frame height"
+msgstr ""
+#: ../display/d.text.new/main.c:175
+msgid "Text background color, either a standard GRASS color or R:G:B triplet"
+msgstr ""
+#: ../display/d.text.new/main.c:184 ../display/d.text/main.c:94
+msgid "The screen line number on which text will begin to be drawn"
+msgstr ""
+#: ../display/d.text.new/main.c:192 ../display/d.text/main.c:103
+msgid ""
+"Screen position at which text will begin to be drawn (percentage, [0,0] is "
+"lower left)"
+msgstr ""
+#: ../display/d.text.new/main.c:227
+msgid "Path to font file"
+msgstr ""
+#: ../display/d.text.new/main.c:235
+msgid "Text encoding (only applicable to TrueType fonts)"
+msgstr ""
+#: ../display/d.text.new/main.c:239
+msgid "Use mouse to interactively place text"
+msgstr ""
+#: ../display/d.text.new/main.c:263
+msgid "Ignored (compatibility with d.text.freetype)"
+msgstr ""
+#: ../display/d.text.new/main.c:275 ../display/d.text/main.c:122
+msgid "Please choose only one placement method"
+msgstr ""
+#: ../display/d.text.new/main.c:345
+msgid "Invalid coordinates"
+msgstr ""
+#: ../display/d.text.new/main.c:413
+#, c-format
+msgid ""
+"\n"
+"Please enter text instructions.  Enter EOF (ctrl-d) on last line to quit\n"
+msgstr ""
+#: ../display/d.text.new/main.c:612
+#, c-format
+msgid "[%s]: No such color. Use '%s'"
+msgstr ""
+#: ../display/d.text.new/main.c:632
+#, c-format
+msgid "Click!\n"
+msgstr ""
+#: ../display/d.text.new/main.c:633
+#, c-format
+msgid " Left:    Place text here\n"
+msgstr ""
+#: ../display/d.text.new/main.c:634
+#, c-format
+msgid " Right:   Quit\n"
+msgstr ""
+#: ../display/d.text/main.c:177
+#, c-format
+msgid "value [%.0f,%.0f] out of range [0-100]"
+msgstr ""
+#: ../display/d.paint.labels/do_labels.c:142
+#, c-format
+msgid "Error: %s\n"
+msgstr ""
+#: ../display/d.paint.labels/main.c:46
+msgid "display, paint labels"
+msgstr ""
+#: ../display/d.paint.labels/main.c:48
+msgid ""
+"Displays text labels (created with v.label) to the active frame on the "
+msgstr ""
+#: ../display/d.paint.labels/main.c:54
+msgid "Ignore rotation setting and draw horizontally"
+msgstr ""
+#: ../display/d.paint.labels/main.c:61
+msgid "Name of label file"
+msgstr ""
+#: ../display/d.paint.labels/main.c:68
+msgid "Minimum region size (diagonal) when labels are displayed"
+msgstr ""
+#: ../display/d.paint.labels/main.c:75
+msgid "Maximum region size (diagonal) when labels are displayed"
+msgstr ""
+#: ../display/d.paint.labels/main.c:87
+#, c-format
+msgid "Label file <%s> not found"
+msgstr ""
+#: ../display/d.mon/pgms/release.c:41 ../display/d.mon/pgms/stop.c:33
+#, c-format
+msgid "%s: -%c unrecognized option"
+msgstr ""
+#: ../display/d.mon/pgms/release.c:68
+#, c-format
+msgid "Monitor <%s> released"
+msgstr ""
+#: ../display/d.mon/pgms/release.c:71
+#, c-format
+msgid "Monitor <%s> in use by another user"
+msgstr ""
+#: ../display/d.mon/pgms/release.c:74 ../display/d.mon/pgms/stop.c:76
+#: ../display/d.mon/pgms/select.c:27
+#, c-format
+msgid "No such monitor as <%s>"
+msgstr ""
+#: ../display/d.mon/pgms/release.c:77
+msgid "Failed testing lock mechanism"
+msgstr ""
+#: ../display/d.mon/pgms/release.c:88
+#, c-format
+msgid "Usage:  %s [-fv] [name]"
+msgstr ""
+#: ../display/d.mon/pgms/start.c:68 ../display/d.mon/pgms/select.c:18
+#, c-format
+msgid "Usage:  %s monitor_name"
+msgstr ""
+#: ../display/d.mon/pgms/stop.c:49
+#, c-format
+msgid "Usage: %s [-f] monitor_name"
+msgstr ""
+#: ../display/d.mon/pgms/stop.c:70
+#, c-format
+msgid "Monitor '%s' terminated"
+msgstr ""
+#: ../display/d.mon/pgms/stop.c:73
+#, c-format
+msgid "Error - Monitor '%s' was not running"
+msgstr ""
+#: ../display/d.mon/pgms/stop.c:79
+#, c-format
+msgid "Error - Monitor '%s' in use by another user"
+msgstr ""
+#: ../display/d.mon/pgms/stop.c:82
+msgid "Error - Locking mechanism failed"
+msgstr ""
+#: ../display/d.mon/cmd/main.c:51
+msgid "To establish and control use of a graphics display monitor."
+msgstr ""
+#: ../display/d.mon/cmd/main.c:57
+msgid "Name of graphics monitor to start"
+msgstr ""
+#: ../display/d.mon/cmd/main.c:63
+msgid "Name of graphics monitor to stop"
+msgstr ""
+#: ../display/d.mon/cmd/main.c:69
+msgid "Name of graphics monitor to select"
+msgstr ""
+#: ../display/d.mon/cmd/main.c:75
+msgid "Name of graphics monitor to unlock"
+msgstr ""
+#: ../display/d.mon/cmd/main.c:79
+msgid "List all monitors"
+msgstr ""
+#: ../display/d.mon/cmd/main.c:83
+msgid "List all monitors (with current status)"
+msgstr ""
+#: ../display/d.mon/cmd/main.c:87
+msgid "Print name of currently selected monitor"
+msgstr ""
+#: ../display/d.mon/cmd/main.c:91
+msgid "Release currently selected monitor"
+msgstr ""
+#: ../display/d.mon/cmd/main.c:96
+msgid "Do not automatically select when starting"
+msgstr ""
+#: ../display/d.mon/cmd/main.c:134
+#, c-format
+msgid "Problem selecting %s. Will try once more"
+msgstr ""
+#: ../display/d.menu/main.c:66
+msgid "display, menu"
+msgstr ""
+#: ../display/d.menu/main.c:68
+msgid ""
+"Creates and displays a menu within the active frame on the graphics monitor."
+msgstr ""
+#: ../display/d.menu/main.c:77
+msgid "Sets the color of the menu background"
+msgstr ""
+#: ../display/d.menu/main.c:85
+msgid "Sets the color of the menu text"
+msgstr ""
+#: ../display/d.menu/main.c:93
+msgid "Sets the color dividing lines of text"
+msgstr ""
+#: ../display/d.menu/main.c:101
+msgid "Sets the menu text size (in percent)"
+msgstr ""
+#: ../display/d.menu/main.c:186
+msgid "Menu must contain a title and at least one option"
+msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:118
+msgid "raster, flow, hydrology"
+msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:120
+msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
+msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:125
+#: ../raster/simwe/r.sim.sediment/main.c:118
+msgid "Name of the elevation raster map [m]"
+msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:130
+#: ../raster/simwe/r.sim.sediment/main.c:128
+msgid "Name of the x-derivatives raster map [m/m]"
+msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:135
+#: ../raster/simwe/r.sim.sediment/main.c:133
+msgid "Name of the y-derivatives raster map [m/m]"
+msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:142
+msgid "Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]"
+msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:151
+msgid "Rainfall excess rate unique value [mm/hr]"
+msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:158
+msgid "Name of the runoff infiltration rate raster map [mm/hr]"
+msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:167
+msgid "Runoff infiltration rate unique value [mm/hr]"
+msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:173
+#: ../raster/simwe/r.sim.sediment/main.c:157
+msgid "Name of the Mannings n raster map"
+msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:181
+msgid "Mannings n unique value"
+msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:188
+msgid "Name of the flow controls raster map (permeability ratio 0-1)"
+msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:203
+msgid "Output water depth raster map [m]"
+msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:204
+#: ../raster/simwe/r.sim.water/main.c:210
+#: ../raster/simwe/r.sim.water/main.c:216
+#: ../raster/simwe/r.sim.sediment/main.c:181
+#: ../raster/simwe/r.sim.sediment/main.c:188
+#: ../raster/simwe/r.sim.sediment/main.c:195
+#: ../raster/simwe/r.sim.sediment/main.c:201
+#: ../raster/simwe/r.sim.sediment/main.c:208
+msgid "Output"
+msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:209
+msgid "Output water discharge raster map [m3/s]"
+msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:215
+msgid "Output simulation error raster map [m]"
+msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:232
+msgid "Number of walkers, default is twice the no. of cells"
+msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:240
+#: ../raster/simwe/r.sim.sediment/main.c:222
+msgid "Time used for iterations [minutes]"
+msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:249
+#: ../raster/simwe/r.sim.sediment/main.c:231
+msgid "Time interval for creating output maps [minutes]"
+msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:267
+#: ../raster/simwe/r.sim.sediment/main.c:249
+msgid "Water diffusion constant"
+msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:276
+msgid ""
+"Threshold water depth [m] (diffusion increases after this water depth is "
+"reached)"
+msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:284
+msgid "Diffusion increase constant"
+msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:293
+msgid "Weighting factor for water flow velocity vector"
+msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:298
+msgid "Time-series output"
+msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:444
+#: ../raster/simwe/r.sim.sediment/main.c:331
+msgid "More than 100 files are going to be created !!!!!"
+msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:450
+#: ../raster/simwe/r.sim.sediment/main.c:337
+#, c-format
+msgid "default nwalk=%d, rwalk=%f"
+msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:460
+#: ../raster/simwe/r.sim.sediment/main.c:346
+#, c-format
+msgid "Using metric conversion factor %f, step=%f"
+msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:477
+msgid "You are not outputting any raster maps"
+msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:527
+#: ../raster/simwe/r.sim.sediment/main.c:417
+msgid "Cannot write raster maps"
+msgstr ""
+#: ../raster/simwe/simlib/input.c:409
+#, c-format
+msgid ""
+"Raster map <%s> not found, and manin_val undefined, choose one to be allowed "
+"to process"
+msgstr ""
+#: ../raster/simwe/simlib/input.c:541
+msgid "Zero value in Mannings n"
+msgstr ""
+#: ../raster/simwe/simlib/input.c:592
+msgid "Infiltration exceeds the rainfall rate everywhere! No overland flow."
+msgstr ""
+#: ../raster/simwe/simlib/input.c:616
+#, c-format
+msgid ""
+"Min elevation \t= %.2f m\n"
+"Max elevation \t= %.2f m\n"
+msgstr ""
+#: ../raster/simwe/simlib/input.c:618
+#, c-format
+msgid "Mean Source Rate (rainf. excess or sediment) \t= %f m/s or kg/m2s \n"
+msgstr ""
+#: ../raster/simwe/simlib/input.c:620
+#, c-format
+msgid "Mean flow velocity \t= %f m/s\n"
+msgstr ""
+#: ../raster/simwe/simlib/input.c:621
+#, c-format
+msgid "Mean Mannings \t= %f\n"
+msgstr ""
+#: ../raster/simwe/simlib/input.c:625
+#, c-format
+msgid "Number of iterations \t= %d cells\n"
+msgstr ""
+#: ../raster/simwe/simlib/input.c:626
+#, c-format
+msgid "Time step \t= %.2f s\n"
+msgstr ""
+#: ../raster/simwe/simlib/input.c:628
+#, c-format
+msgid ""
+"Sigmax \t= %f\n"
+"Max velocity \t= %f m/s\n"
+msgstr ""
+#: ../raster/simwe/simlib/input.c:630
+#, c-format
+msgid "Time step used \t= %.2f s\n"
+msgstr ""
+#: ../raster/simwe/simlib/input.c:682
+msgid "Unable to write et file"
+msgstr ""
+#: ../raster/simwe/simlib/hydro.c:211
+#, c-format
+msgid "nwalk (%d) > maxw (%d)!"
+msgstr ""
+#: ../raster/simwe/simlib/hydro.c:431
+msgid "Unable to write raster maps"
+msgstr ""
+#: ../raster/simwe/r.sim.sediment/main.c:111
+msgid "raster, sediment flow, erosion, deposition"
+msgstr ""
+#: ../raster/simwe/r.sim.sediment/main.c:113
+msgid ""
+"Sediment transport and erosion/deposition simulation using path sampling "
+"method (SIMWE)."
+msgstr ""
+#: ../raster/simwe/r.sim.sediment/main.c:123
+msgid "Name of the water depth raster map [m]"
+msgstr ""
+#: ../raster/simwe/r.sim.sediment/main.c:139
+msgid "Name of the detachment capacity coefficient raster map [s/m]"
+msgstr ""
+#: ../raster/simwe/r.sim.sediment/main.c:145
+msgid "Name of the transport capacity coefficient raster map [s]"
+msgstr ""
+#: ../raster/simwe/r.sim.sediment/main.c:151
+msgid "Name of the critical shear stress raster map [Pa]"
+msgstr ""
+#: ../raster/simwe/r.sim.sediment/main.c:165
+msgid "Name of the Mannings n value"
+msgstr ""
+#: ../raster/simwe/r.sim.sediment/main.c:180
+msgid "Output transport capacity raster map [kg/ms]"
+msgstr ""
+#: ../raster/simwe/r.sim.sediment/main.c:187
+msgid "Output transp.limited erosion-deposition raster map [kg/m2s]"
+msgstr ""
+#: ../raster/simwe/r.sim.sediment/main.c:194
+msgid "Output sediment concentration raster map [particle/m3]"
+msgstr ""
+#: ../raster/simwe/r.sim.sediment/main.c:200
+msgid "Output sediment flux raster map [kg/ms]"
+msgstr ""
+#: ../raster/simwe/r.sim.sediment/main.c:207
+msgid "Output erosion-deposition raster map [kg/m2s]"
+msgstr ""
+#: ../raster/simwe/r.sim.sediment/main.c:214
+msgid "Number of walkers"
+msgstr ""
+#: ../raster/simwe/r.sim.sediment/main.c:355
+msgid "You are not outputting any raster or site files"
+msgstr ""
+#: ../raster/r.to.vect/lines.c:69
+msgid "Extracting lines..."
+msgstr ""
+#: ../raster/r.to.vect/lines.c:493
+msgid ""
+"Raster map is not thinned properly.\n"
+"Please run r.thin."
+msgstr ""
+#: ../raster/r.to.vect/lines.c:567
+msgid "join_lines: p front pointer not NULL!"
+msgstr ""
+#: ../raster/r.to.vect/lines.c:573
+msgid "join_lines: q front pointer not NULL!"
+msgstr ""
+#: ../raster/r.to.vect/lines.c:591
+msgid "extend line:  p is NULL"
+msgstr ""
+#: ../raster/r.to.vect/lines.c:617
+msgid "extend_lines: p front pointer not NULL!"
+msgstr ""
+#: ../raster/r.to.vect/lines.c:624
+msgid "extend_lines: q back pointer not NULL!"
+msgstr ""
+#: ../raster/r.to.vect/points.c:35
+msgid "Extracting points..."
+msgstr ""
+#: ../raster/r.to.vect/areas.c:119
+msgid "Extracting areas..."
+msgstr ""
+#: ../raster/r.to.vect/areas_io.c:105
+#, c-format
+msgid ""
+"Line terminated unexpectedly\n"
+"previous (%d) point %p (%d,%d,%d) %p %p"
+msgstr ""
+#: ../raster/r.to.vect/lines_io.c:76
+msgid "write_line:  found half a loop!"
+msgstr ""
+#: ../raster/r.to.vect/lines_io.c:128
+#, c-format
+msgid ""
+"write_line: line terminated unexpectedly\n"
+"  previous (%d) point %p (%d,%d,%d) %p %p"
+msgstr ""
+#: ../raster/r.to.vect/main.c:50
+msgid "raster, conversion, vectorization"
+msgstr ""
+#: ../raster/r.to.vect/main.c:51
+msgid "Converts a raster map into a vector map layer."
+msgstr ""
+#: ../raster/r.to.vect/main.c:68
+msgid "Smooth corners of area features"
+msgstr ""
+#: ../raster/r.to.vect/main.c:73
+msgid "Use raster values as categories instead of unique sequence (CELL only)"
+msgstr ""
+#: ../raster/r.to.vect/main.c:79
+msgid ""
+"Write raster values as z coordinate. Table is not created. Currently "
+"supported only for points."
+msgstr ""
+#: ../raster/r.to.vect/main.c:86
+msgid "Do not build vector topology (use with care for massive point export)"
+msgstr ""
+#: ../raster/r.to.vect/main.c:91
+msgid "Quiet - Do not show progress"
+msgstr ""
+#: ../raster/r.to.vect/main.c:109
+msgid "z flag is supported only for points"
+msgstr ""
+#: ../raster/r.to.vect/main.c:123
+msgid ""
+"Raster is not CELL, '-v' flag ignored, raster values will be written to the "
+"table."
+msgstr ""
+#: ../raster/r.to.vect/main.c:273
+#, c-format
+msgid "Unable to insert into table: %s"
+msgstr ""
+#: ../raster/r.in.bin/main.c:49 ../raster/r.in.bin/main.c:58
+#: ../raster/r.in.bin/main.c:510
+msgid "Error reading data"
+msgstr ""
+#: ../raster/r.in.bin/main.c:236
+msgid "Import a binary raster file into a GRASS raster map."
+msgstr ""
+#: ../raster/r.in.bin/main.c:241
+msgid "Import as floating-point data (default: integer)"
+msgstr ""
+#: ../raster/r.in.bin/main.c:246
+msgid "Import as double-precision floating-point data (default: integer)"
+msgstr ""
+#: ../raster/r.in.bin/main.c:250
+msgid "Signed data (two's complement)"
+msgstr ""
+#: ../raster/r.in.bin/main.c:255
+msgid "Byte Swap the Data During Import"
+msgstr ""
+#: ../raster/r.in.bin/main.c:260
+msgid "Get region info from GMT style header"
+msgstr ""
+#: ../raster/r.in.bin/main.c:267
+msgid "Binary raster file to be imported"
+msgstr ""
+#: ../raster/r.in.bin/main.c:277 ../raster/r.external/main.c:550
+#: ../raster/r.in.gdal/main.c:121 ../raster/r.in.poly/main.c:44
+#: ../raster/r.in.arc/main.c:87 ../raster/r.in.ascii/main.c:85
+msgid "Title for resultant raster map"
+msgstr ""
+#: ../raster/r.in.bin/main.c:284 ../raster/r.out.bin/main.c:310
+msgid "Number of bytes per cell"
+msgstr ""
+#: ../raster/r.in.bin/main.c:292 ../raster/r.out.bin/main.c:317
+msgid "Output byte order"
+msgstr ""
+#: ../raster/r.in.bin/main.c:300
+msgid "Northern limit of geographic region (outer edge)"
+msgstr ""
+#: ../raster/r.in.bin/main.c:308
+msgid "Southern limit of geographic region (outer edge)"
+msgstr ""
+#: ../raster/r.in.bin/main.c:316
+msgid "Eastern limit of geographic region (outer edge)"
+msgstr ""
+#: ../raster/r.in.bin/main.c:324
+msgid "Western limit of geographic region (outer edge)"
+msgstr ""
+#: ../raster/r.in.bin/main.c:331
+msgid "Number of rows"
+msgstr ""
+#: ../raster/r.in.bin/main.c:338
+msgid "Number of columns"
+msgstr ""
+#: ../raster/r.in.bin/main.c:345
+msgid "Set Value to NULL"
+msgstr ""
+#: ../raster/r.in.bin/main.c:366
+msgid "order= and -b are mutually exclusive"
+msgstr ""
+#: ../raster/r.in.bin/main.c:381
+msgid "-f and -d are mutually exclusive"
+msgstr ""
+#: ../raster/r.in.bin/main.c:385
+#, c-format
+msgid "-f incompatible with bytes=%d; must be 4 or 8"
+msgstr ""
+#: ../raster/r.in.bin/main.c:393
+#, c-format
+msgid "-d incompatible with bytes=%d; must be 8"
+msgstr ""
+#: ../raster/r.in.bin/main.c:400
+msgid "bytes= required for integer data"
+msgstr ""
+#: ../raster/r.in.bin/main.c:404
+msgid "Integer input doesn't support size=8 in this build"
+msgstr ""
+#: ../raster/r.in.bin/main.c:408
+msgid "bytes= must be 1, 2, 4 or 8"
+msgstr ""
+#: ../raster/r.in.bin/main.c:421
+msgid "Either -h or rows= and cols= must be given"
+msgstr ""
+#: ../raster/r.in.bin/main.c:426
+msgid "Either all or none of north=, south=, east= and west= must be given"
+msgstr ""
+#: ../raster/r.in.bin/main.c:435
+#, c-format
+msgid "Illegal south coordinate <%s>"
+msgstr ""
+#: ../raster/r.in.bin/main.c:439
+#, c-format
+msgid "Illegal west coordinate <%s>"
+msgstr ""
+#: ../raster/r.in.bin/main.c:445
+#, c-format
+msgid "Unable to open <%s>"
+msgstr ""
+#: ../raster/r.in.bin/main.c:464
+#, c-format
+msgid ""
+"East-West (ewres: %f) and North-South (nwres: %f) resolution differ "
+"significantly. Did you assign east= and west= correctly?"
+msgstr ""
+#: ../raster/r.in.bin/main.c:487
+msgid "File Size %"
+msgstr ""
+#: ../raster/r.in.bin/main.c:489
+msgid "Bytes do not match file size"
+msgstr ""
+#: ../raster/r.external/main.c:54
+#, c-format
+msgid "Supported Formats:\n"
+msgstr ""
+#: ../raster/r.external/main.c:83 ../raster/r.in.gdal/main.c:341
+msgid ""
+"Unable to convert input raster map projection information to GRASS format "
+"for checking"
+msgstr ""
+#: ../raster/r.external/main.c:112 ../raster/r.in.gdal/main.c:372
+msgid "Location PROJ_INFO is:\n"
+msgstr ""
+#: ../raster/r.external/main.c:123 ../raster/r.in.gdal/main.c:383
+msgid "Dataset PROJ_INFO is:\n"
+msgstr ""
+#: ../raster/r.external/main.c:172
+msgid ""
+"\n"
+"You can use the -o flag to r.external to override this check and use the "
+"location definition for the dataset.\n"
+msgstr ""
+#: ../raster/r.external/main.c:175 ../raster/r.in.gdal/main.c:435
+msgid ""
+"Consider generating a new location from the input dataset using the "
+"'location' parameter.\n"
+msgstr ""
+#: ../raster/r.external/main.c:202
+msgid ""
+"Input raster map is rotated - cannot import. You may use 'gdalwarp' to "
+"transform the map to North-up."
+msgstr ""
+#: ../raster/r.external/main.c:310
+msgid "Complex types not supported"
+msgstr ""
+#: ../raster/r.external/main.c:325
+#, c-format
+msgid "Copying color table for %s"
+msgstr ""
+#: ../raster/r.external/main.c:343
+#, c-format
+msgid "Setting grey color table for <%s> (full 8bit range)"
+msgstr ""
+#: ../raster/r.external/main.c:349
+#, c-format
+msgid "Setting grey color table for <%s> (data range)"
+msgstr ""
+#: ../raster/r.external/main.c:363
+#, c-format
+msgid "Unable to create cell/%s file"
+msgstr ""
+#: ../raster/r.external/main.c:372
+#, c-format
+msgid "Unable to create fcell/%s file"
+msgstr ""
+#: ../raster/r.external/main.c:404
+#, c-format
+msgid "Unable to create cell_misc/%s/gdal file"
+msgstr ""
+#: ../raster/r.external/main.c:407
+#, c-format
+msgid "Error writing cell_misc/%s/gdal file"
+msgstr ""
+#: ../raster/r.external/main.c:432
+#, c-format
+msgid "Unable to create cell_misc/%s/f_format file"
+msgstr ""
+#: ../raster/r.external/main.c:435
+#, c-format
+msgid "Error writing cell_misc/%s/f_format file"
+msgstr ""
+#: ../raster/r.external/main.c:450
+msgid "Unable to write quant file"
+msgstr ""
+#: ../raster/r.external/main.c:483
+#, c-format
+msgid "Creating support files for %s"
+msgstr ""
+#: ../raster/r.external/main.c:496
+#, c-format
+msgid "Link to raster map <%s> created"
+msgstr ""
+#: ../raster/r.external/main.c:522
+msgid "Link GDAL supported raster file to a binary raster map layer."
+msgstr ""
+#: ../raster/r.external/main.c:525
+msgid "Raster file to be linked"
+msgstr ""
+#: ../raster/r.external/main.c:531
+msgid "Name of non-file GDAL data source"
+msgstr ""
+#: ../raster/r.external/main.c:543
+msgid "Band to select (default: all)"
+msgstr ""
+#: ../raster/r.external/main.c:556 ../raster/r.in.gdal/main.c:134
+msgid "Override projection (use location's projection)"
+msgstr ""
+#: ../raster/r.external/main.c:566
+msgid "Require exact range"
+msgstr ""
+#: ../raster/r.external/main.c:595
+msgid "Name for input source not specified"
+msgstr ""
+#: ../raster/r.external/main.c:598
+msgid "input= and source= are mutually exclusive"
+msgstr ""
+#: ../raster/r.external/main.c:601 ../raster/r.in.gdal/main.c:222
+msgid "Name for output raster map not specified"
+msgstr ""
+#: ../raster/r.external/main.c:623
+msgid "Unable to set window"
+msgstr ""
+#: ../raster/r.external/main.c:630 ../raster/r.in.gdal/main.c:446
+msgid "Proceeding with import..."
+msgstr ""
+#: ../raster/r.external/main.c:634
+#, c-format
+msgid "Imagery group <%s> already exists and will be overwritten."
+msgstr ""
+#: ../raster/r.external/main.c:645 ../raster/r.in.gdal/main.c:472
+#, c-format
+msgid "Selected band (%d) does not exist"
+msgstr ""
+#: ../raster/r.external/main.c:674
+#, c-format
+msgid "Imagery group <%s> created"
+msgstr ""
+#: ../raster/r.digit/digitize.c:49
+msgid "Quit without creating a map?? "
+msgstr ""
+#: ../raster/r.digit/get_label.c:31
+#, c-format
+msgid "Enter the category number for this %s: "
+msgstr ""
+#: ../raster/r.digit/get_label.c:46
+#, c-format
+msgid "Enter a label for category %ld [%s] "
+msgstr ""
+#: ../raster/r.digit/get_label.c:68
+msgid "Look ok? "
+msgstr ""
+#: ../raster/r.digit/get_type.c:31
+#, c-format
+msgid "Please choose one of the following\n"
+msgstr ""
+#: ../raster/r.digit/get_type.c:32
+#, c-format
+msgid "   A define an area\n"
+msgstr ""
+#: ../raster/r.digit/get_type.c:33
+#, c-format
+msgid "   C define a circle\n"
+msgstr ""
+#: ../raster/r.digit/get_type.c:34
+#, c-format
+msgid "   L define a line\n"
+msgstr ""
+#: ../raster/r.digit/get_type.c:35
+#, c-format
+msgid "   X exit (and create map)\n"
+msgstr ""
+#: ../raster/r.digit/get_type.c:36
+#, c-format
+msgid "   Q quit (without creating map)\n"
+msgstr ""
+#: ../raster/r.digit/main.c:45 ../raster/r.circle/dist.c:51
+#: ../raster/r.grow2/main.c:128 ../raster/r.grow.distance/main.c:130
+#: ../raster/r.patch/main.c:53
+msgid "raster, geometry"
+msgstr ""
+#: ../raster/r.digit/main.c:47
+msgid ""
+"Interactive tool used to draw and save vector features on a graphics monitor "
+"using a pointing device (mouse) and save to a raster map."
+msgstr ""
+#: ../raster/r.digit/main.c:79
+msgid "No graphics device selected!"
+msgstr ""
+#: ../raster/r.digit/main.c:98
+msgid "No map created"
+msgstr ""
+#: ../raster/r.buffer/execute.c:34
+msgid "Finding buffer zones..."
+msgstr ""
+#: ../raster/r.buffer/read_map.c:53
+#, c-format
+msgid "Reading input raster map <%s>..."
+msgstr ""
+#: ../raster/r.buffer/write_map.c:48
+#, c-format
+msgid "Writing output raster map <%s>..."
+msgstr ""
+#: ../raster/r.buffer/parse_dist.c:54
+#, c-format
+msgid "%s: %s - illegal distance specification"
+msgstr ""
+#: ../raster/r.buffer/main.c:69
+msgid "raster, buffer"
+msgstr ""
+#: ../raster/r.buffer/main.c:71
+msgid ""
+"Creates a raster map layer showing buffer zones surrounding cells that "
+"contain non-NULL category values."
+msgstr ""
+#: ../raster/r.buffer/main.c:83
+msgid "Distance zone(s)"
+msgstr ""
+#: ../raster/r.buffer/main.c:90
+msgid "Units of distance"
+msgstr ""
+#: ../raster/r.buffer/main.c:96
+msgid "Ignore zero (0) data cells instead of NULL cells"
+msgstr ""
+#: ../raster/r.buffer/main.c:149
+msgid "Parse distances error"
+msgstr ""
+#: ../raster/r.buffer/main.c:168
+#, c-format
+msgid "Pass %d (of %d)"
+msgstr ""
+#: ../raster/r.univar2/r.univar_main.c:37
+msgid "Raster map used for zoning, must be of type CELL"
+msgstr ""
+#: ../raster/r.univar2/r.univar_main.c:55
+#: ../raster/r.univar2/r3.univar_main.c:56
+msgid "Special characters: space, comma, tab"
+msgstr ""
+#: ../raster/r.univar2/r.univar_main.c:68
+#: ../raster/r.univar2/r3.univar_main.c:69
+msgid "Table output format instead of standard output format"
+msgstr ""
+#: ../raster/r.univar2/r.univar_main.c:99
+msgid ""
+"Calculates univariate statistics from the non-null cells of a raster map."
+msgstr ""
+#: ../raster/r.univar2/r.univar_main.c:183 ../raster/r.out.png/r.out.png.c:300
+#, c-format
+msgid "Raster <%s> type mismatch"
+msgstr ""
+#: ../raster/r.univar2/r.univar_main.c:274
+#: ../raster/r.univar2/r.univar_main.c:277
+#, c-format
+msgid "Reading row %d"
+msgstr ""
+#: ../raster/r.univar2/r3.univar_main.c:38
+msgid "3D Raster map used for zoning, must be of type CELL"
+msgstr ""
+#: ../raster/r.univar2/r3.univar_main.c:102
+msgid ""
+"Calculates univariate statistics from the non-null 3d cells of a raster3d "
+"map."
+msgstr ""
+#: ../raster/r.univar2/r3.univar_main.c:163
+msgid "Unable to load 3D raster range"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:153
+msgid "raster, terrain"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:154
+msgid ""
+"Generates raster maps of slope, aspect, curvatures and partial derivatives "
+"from a elevation raster map."
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:156
+msgid "Aspect is calculated counterclockwise from east."
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:163
+msgid "Name for output slope raster map"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:169
+msgid "Name for output aspect raster map"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:178
+msgid "Format for reporting the slope"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:188
+msgid "Type of output aspect and slope maps"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:195
+msgid "Name for output profile curvature raster map"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:202
+msgid "Name for output tangential curvature raster map"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:209
+msgid ""
+"Name for output first order partial derivative dx (E-W slope) raster map"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:216
+msgid ""
+"Name for output first order partial derivative dy (N-S slope) raster map"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:223
+msgid "Name for output second order partial derivative dxx raster map"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:230
+msgid "Name for output second order partial derivative dyy raster map"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:237
+msgid "Name for output second order partial derivative dxy raster map"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:243
+msgid "Multiplicative factor to convert elevation units to meters"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:252
+msgid "Minimum slope val. (in percent) for which aspect is computed"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:266
+msgid "Do not align the current region to the elevation layer"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:327
+#, c-format
+msgid "%s=%s - must be a positive number"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:333
+#, c-format
+msgid "%s=%s - must be a non-negative number"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:348
+#, c-format
+msgid ""
+"You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <"
+"%s>, <%s>, <%s>, <%s> or <%s>"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:378
+#, c-format
+msgid "Wrong raster type: %s"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:566 ../raster/r.series/main.c:261
+#: ../raster/r.patch/main.c:152
+msgid "Percent complete..."
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:990
+#, c-format
+msgid "Elevation products for mapset <%s> in <%s>"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:1009
+#, c-format
+msgid "Min computed aspect %.4f, max computed aspect %.4f"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:1071
+#, c-format
+msgid "Aspect raster map <%s> complete"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:1113
+#, c-format
+msgid "Min computed slope %.4f, max computed slope %.4f"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:1164
+#, c-format
+msgid "Slope raster map <%s> complete"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:1235
+#, c-format
+msgid "Profile curve raster map <%s> complete"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:1261
+#, c-format
+msgid "Tangential curve raster map <%s> complete"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:1285
+#, c-format
+msgid "E-W slope raster map <%s> complete"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:1309
+#, c-format
+msgid "N-S slope raster map <%s> complete"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:1333
+#, c-format
+msgid "Dxx raster map <%s> complete"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:1357
+#, c-format
+msgid "Dyy raster map <%s> complete"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:1381
+#, c-format
+msgid "Dxy raster map <%s> complete"
+msgstr ""
+#: ../raster/r.lake/main.c:79
+#, c-format
+msgid "Failed writing output raster map row %d"
+msgstr ""
+#: ../raster/r.lake/main.c:148 ../raster/r.flow/calc.c:411
+#: ../raster/r.fill.dir/main.c:84 ../raster/r.basins.fill/main.c:53
+#: ../raster/r.drain/main.c:94 ../raster/r.topidx/main.c:37
+#: ../raster/r.water.outlet/main.c:47 ../raster/r.carve/main.c:77
+#: ../raster/r.topmodel/main.c:55 ../raster/r.gwflow/main.c:189
+#: ../raster/r.watershed/front/main.c:56
+msgid "raster, hydrology"
+msgstr ""
+#: ../raster/r.lake/main.c:149
+msgid "Fills lake at given point to given level."
+msgstr ""
+#: ../raster/r.lake/main.c:154
+msgid "Name of terrain raster map (DEM)"
+msgstr ""
+#: ../raster/r.lake/main.c:161
+msgid "Water level"
+msgstr ""
+#: ../raster/r.lake/main.c:168
+msgid "Name for output raster map with lake"
+msgstr ""
+#: ../raster/r.lake/main.c:175
+msgid "Seed point coordinates"
+msgstr ""
+#: ../raster/r.lake/main.c:185
+msgid "Name of raster map with given starting point(s) (at least 1 cell > 0)"
+msgstr ""
+#: ../raster/r.lake/main.c:193
+msgid "Use negative depth values for lake raster map"
+msgstr ""
+#: ../raster/r.lake/main.c:198
+msgid "Overwrite seed map with result (lake) map"
+msgstr ""
+#: ../raster/r.lake/main.c:206
+msgid "Both seed map and coordinates cannot be specified"
+msgstr ""
+#: ../raster/r.lake/main.c:209
+msgid "Seed map or seed coordinates must be set!"
+msgstr ""
+#: ../raster/r.lake/main.c:212
+msgid "Seed coordinates and output map lake= must be set!"
+msgstr ""
+#: ../raster/r.lake/main.c:215
+msgid "Both lake and overwrite cannot be specified"
+msgstr ""
+#: ../raster/r.lake/main.c:218
+msgid "Output lake map or overwrite flag must be set!"
+msgstr ""
+#: ../raster/r.lake/main.c:248
+msgid "Seed point outside the current region"
+msgstr ""
+#: ../raster/r.lake/main.c:277
+msgid "G_malloc: out of memory"
+msgstr ""
+#: ../raster/r.lake/main.c:303
+msgid ""
+"Given water level at seed point is below earth surface. Increase water level "
+"or move seed point."
+msgstr ""
+#: ../raster/r.lake/main.c:386
+#, c-format
+msgid "Lake depth from %f to %f"
+msgstr ""
+#: ../raster/r.lake/main.c:387
+#, c-format
+msgid "Lake area %f square meters"
+msgstr ""
+#: ../raster/r.lake/main.c:388
+#, c-format
+msgid "Lake volume %f cubic meters"
+msgstr ""
+#: ../raster/r.lake/main.c:389
+msgid "Volume is correct only if lake depth (terrain raster map) is in meters"
+msgstr ""
+#: ../raster/r.lake/main.c:407 ../raster/r.composite/main.c:167
+#, c-format
+msgid "Unable to read color file of raster map <%s>"
+msgstr ""
+#: ../raster/r.out.mpeg/write.c:81 ../raster/r.out.mpeg/write.c:178
+msgid "Size mismatch error!"
+msgstr ""
+#: ../raster/r.out.mpeg/write.c:139 ../raster/r.out.mpeg/write.c:181
+msgid "Unable to open output file"
+msgstr ""
+#: ../raster/r.out.mpeg/write.c:215
+msgid "Unable to create temporary files."
+msgstr ""
+#: ../raster/r.out.mpeg/main.c:88
+msgid "Either mpeg_encode or ppmtompeg must be installed"
+msgstr ""
+#: ../raster/r.out.mpeg/main.c:213
+msgid "Reading file"
+msgstr ""
+#: ../raster/r.out.mpeg/main.c:282 ../raster/r.out.mpeg/main.c:312
+msgid "mpeg_encode ERROR"
+msgstr ""
+#: ../raster/r.out.mpeg/main.c:385
+msgid "Raster File Series to MPEG Conversion."
+msgstr ""
+#: ../raster/r.out.mpeg/main.c:416
+msgid "Quality factor (1 = highest quality, lowest compression)"
+msgstr ""
+#: ../raster/r.out.mpeg/main.c:420
+msgid "Quiet - suppress progress report"
+msgstr ""
+#: ../raster/r.out.mpeg/main.c:425
+msgid ""
+"Convert on the fly, use less disk space\n"
+"\t(requires r.out.ppm with stdout option)"
+msgstr ""
+#: ../raster/r.region/main.c:54 ../raster/r.info/main.c:69
+#: ../raster/r.support/front/front.c:54 ../raster/r.describe/main.c:59
+msgid "raster, metadata"
+msgstr ""
+#: ../raster/r.region/main.c:56
+msgid "Sets the boundary definitions for a raster map."
+msgstr ""
+#: ../raster/r.region/main.c:66
+msgid "Set from current region"
+msgstr ""
+#: ../raster/r.region/main.c:81
+msgid "Raster map to change"
+msgstr ""
+#: ../raster/r.region/main.c:89
+msgid "Set region from named region"
+msgstr ""
+#: ../raster/r.region/main.c:157
+msgid "Raster map to align to"
+msgstr ""
+#: ../raster/r.region/main.c:241
+#, c-format
+msgid "Unable to open vector map <%s> in <%s>"
+msgstr ""
+#: ../raster/r.region/main.c:368
+msgid "Unable to update boundaries"
+msgstr ""
+#: ../raster/r.proj/bordwalk.c:182 ../raster/r.proj.seg/bordwalk.c:182
+msgid "Input raster map is outside current region"
+msgstr ""
+#: ../raster/r.proj/main.c:130 ../raster/r.proj.seg/main.c:139
+msgid "raster, projection, transformation"
+msgstr ""
+#: ../raster/r.proj/main.c:132 ../raster/r.proj.seg/main.c:141
+msgid "Re-projects a raster map from one location to the current location."
+msgstr ""
+#: ../raster/r.proj/main.c:135 ../raster/r.proj.seg/main.c:144
+msgid "Name of input raster map to re-project"
+msgstr ""
+#: ../raster/r.proj/main.c:143 ../raster/r.proj.seg/main.c:152
+msgid "Location containing input raster map"
+msgstr ""
+#: ../raster/r.proj/main.c:151 ../raster/r.proj.seg/main.c:160
+msgid "Mapset containing input raster map"
+msgstr ""
+#: ../raster/r.proj/main.c:167 ../raster/r.proj.seg/main.c:176
+msgid "Name for output raster map (default: input)"
+msgstr ""
+#: ../raster/r.proj/main.c:185 ../raster/r.proj.seg/main.c:200
+msgid "Resolution of output map"
+msgstr ""
+#: ../raster/r.proj/main.c:190 ../raster/r.proj.seg/main.c:205
+msgid "List raster maps in input location and exit"
+msgstr ""
+#: ../raster/r.proj/main.c:194 ../raster/r.proj.seg/main.c:209
+msgid "Do not perform region cropping optimization"
+msgstr ""
+#: ../raster/r.proj/main.c:228 ../raster/r.proj.seg/main.c:263
+msgid "Unable to get projection info of output raster map"
+msgstr ""
+#: ../raster/r.proj/main.c:231 ../raster/r.proj.seg/main.c:266
+msgid "Unable to get projection units of output raster map"
+msgstr ""
+#: ../raster/r.proj/main.c:234 ../raster/r.proj.seg/main.c:269
+msgid "Unable to get projection key values of output raster map"
+msgstr ""
+#: ../raster/r.proj/main.c:243 ../raster/r.proj.seg/main.c:278
+#, c-format
+msgid "Mapset <%s> in input location <%s> - %s"
+msgstr ""
+#: ../raster/r.proj/main.c:267 ../raster/r.proj.seg/main.c:302
+#, c-format
+msgid "Raster map <%s> in location <%s> in mapset <%s> not found"
+msgstr ""
+#: ../raster/r.proj/main.c:275 ../raster/r.proj.seg/main.c:310
+msgid "Unable to get projection info of input map"
+msgstr ""
+#: ../raster/r.proj/main.c:278 ../raster/r.proj.seg/main.c:313
+msgid "Unable to get projection units of input map"
+msgstr ""
+#: ../raster/r.proj/main.c:281 ../raster/r.proj.seg/main.c:316
+msgid "Unable to get projection key values of input map"
+msgstr ""
+#: ../raster/r.proj/main.c:296 ../raster/r.proj.seg/main.c:330
+msgid "Unable to work with unprojected data (xy location)"
+msgstr ""
+#: ../raster/r.proj/main.c:370 ../raster/r.proj.seg/main.c:438
+msgid "Input:"
+msgstr ""
+#: ../raster/r.proj/main.c:371 ../raster/r.proj/main.c:382
+#: ../raster/r.proj.seg/main.c:439 ../raster/r.proj.seg/main.c:450
+#, c-format
+msgid "Cols: %d (%d)"
+msgstr ""
+#: ../raster/r.proj/main.c:372 ../raster/r.proj/main.c:383
+#: ../raster/r.proj.seg/main.c:440 ../raster/r.proj.seg/main.c:451
+#, c-format
+msgid "Rows: %d (%d)"
+msgstr ""
+#: ../raster/r.proj/main.c:373 ../raster/r.proj/main.c:384
+#: ../raster/r.proj.seg/main.c:441 ../raster/r.proj.seg/main.c:452
+#, c-format
+msgid "North: %f (%f)"
+msgstr ""
+#: ../raster/r.proj/main.c:374 ../raster/r.proj/main.c:385
+#: ../raster/r.proj.seg/main.c:442 ../raster/r.proj.seg/main.c:453
+#, c-format
+msgid "South: %f (%f)"
+msgstr ""
+#: ../raster/r.proj/main.c:375 ../raster/r.proj/main.c:386
+#: ../raster/r.proj.seg/main.c:443 ../raster/r.proj.seg/main.c:454
+#, c-format
+msgid "West: %f (%f)"
+msgstr ""
+#: ../raster/r.proj/main.c:376 ../raster/r.proj/main.c:387
+#: ../raster/r.proj.seg/main.c:444 ../raster/r.proj.seg/main.c:455
+#, c-format
+msgid "East: %f (%f)"
+msgstr ""
+#: ../raster/r.proj/main.c:377 ../raster/r.proj/main.c:388
+#: ../raster/r.proj.seg/main.c:445 ../raster/r.proj.seg/main.c:456
+#, c-format
+msgid "EW-res: %f"
+msgstr ""
+#: ../raster/r.proj/main.c:378 ../raster/r.proj/main.c:389
+#: ../raster/r.proj.seg/main.c:446 ../raster/r.proj.seg/main.c:457
+#, c-format
+msgid "NS-res: %f"
+msgstr ""
+#: ../raster/r.proj/main.c:381 ../raster/r.proj.seg/main.c:449
+msgid "Output:"
+msgstr ""
+#: ../raster/r.proj/main.c:417 ../raster/r.proj.seg/main.c:485
+msgid "Projecting..."
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:138
+msgid "The number of input and elevation maps is not equal"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:171 ../raster/r.to.rast3/main.c:378
+msgid "Unable to close input map"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:183 ../raster/r.to.rast3/main.c:58
+msgid "Could not close the map"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:211
+msgid "The value to fill the upper cells, default is null"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:218
+msgid "The value to fill the lower cells, default is null"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:223
+msgid "Use the input map values to fill the upper cells"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:228
+msgid "Use the input map values to fill the lower cells"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:232
+msgid "Use G3D mask (if exists) with input map"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:276
+msgid "Could not get raster row from input map"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:278
+msgid "Could not get raster row from elev map"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:326 ../raster/r.to.rast3elev/main.c:360
+msgid "Error writing G3D double data"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:400
+msgid "raster, raster3d, voxel, conversion"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:402
+msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:433
+msgid "The upper value is not valid"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:444
+msgid "The lower value is not valid"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:462 ../raster/r.to.rast3/main.c:222
+msgid ""
+"The 2d and 3d region settings are different. I will use the g3d settings to "
+"adjust the 2d region."
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:483 ../raster/r.to.rast3/main.c:309
+msgid "Error opening 3d raster map"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:498 ../raster/r.to.rast3/main.c:285
+msgid "Creating 3D raster map"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:546 ../raster/r.to.rast3/main.c:341
+msgid "Error closing 3d raster map"
+msgstr ""
+#: ../raster/r.flow/precomp.c:47
+msgid "Precomputing: e/w distances"
+msgstr ""
+#: ../raster/r.flow/precomp.c:49
+msgid "Precomputing: quantization tolerances"
+msgstr ""
+#: ../raster/r.flow/precomp.c:52
+msgid "Precomputing: inverted elevations"
+msgstr ""
+#: ../raster/r.flow/precomp.c:56
+msgid "Precomputing: interpolated border elevations"
+msgstr ""
+#: ../raster/r.flow/precomp.c:62
+msgid "Precomputing: re-oriented aspects"
+msgstr ""
+#: ../raster/r.flow/precomp.c:66
+msgid "Precomputing: aspects"
+msgstr ""
+#: ../raster/r.flow/precomp.c:110
+#, c-format
+msgid ""
+"Resolution too unbalanced:\n"
+"atan2(%f deg, %f deg) =%f < %f tolerance\n"
+"please resample input map"
+msgstr ""
+#: ../raster/r.flow/precomp.c:115
+#, c-format
+msgid "Resolution too unbalanced (%f x %f); please resample input map"
+msgstr ""
+#: ../raster/r.flow/mem.c:39
+#, c-format
+msgid "Unable to write segment file for %s"
+msgstr ""
+#: ../raster/r.flow/calc.c:303
+msgid "Calculating maps ..."
+msgstr ""
+#: ../raster/r.flow/calc.c:408
+msgid "Unable to get current region"
+msgstr ""
+#: ../raster/r.flow/calc.c:413
+msgid ""
+"Construction of slope curves (flowlines), flowpath lengths, and flowline "
+"densities (upslope areas) from a raster digital elevation model (DEM)."
+msgstr ""
+#: ../raster/r.flow/calc.c:451
+msgid "Input elevation raster map"
+msgstr ""
+#: ../raster/r.flow/calc.c:458
+msgid "Input aspect raster map"
+msgstr ""
+#: ../raster/r.flow/calc.c:465
+msgid "Input barrier raster map"
+msgstr ""
+#: ../raster/r.flow/calc.c:472
+msgid "Number of cells between flowlines"
+msgstr ""
+#: ../raster/r.flow/calc.c:480
+msgid "Maximum number of segments per flowline"
+msgstr ""
+#: ../raster/r.flow/calc.c:488
+msgid "Output flowline vector map"
+msgstr ""
+#: ../raster/r.flow/calc.c:495
+msgid "Output flowpath length raster map"
+msgstr ""
+#: ../raster/r.flow/calc.c:502
+msgid "Output flowline density raster map"
+msgstr ""
+#: ../raster/r.flow/calc.c:507
+msgid "Compute upslope flowlines instead of default downhill flowlines"
+msgstr ""
+#: ../raster/r.flow/calc.c:511
+msgid "3-D lengths instead of 2-D"
+msgstr ""
+#: ../raster/r.flow/calc.c:515
+msgid "Use less memory, at a performance penalty"
+msgstr ""
+#: ../raster/r.flow/calc.c:533
+msgid "You must select one or more output maps (flout, lgout, dsout)"
+msgstr ""
+#: ../raster/r.flow/calc.c:549
+msgid ""
+"lat/long projection not supported by r.flow. Please use 'r.watershed' for "
+"calculating flow accumulation."
+msgstr ""
+#: ../raster/r.flow/io.c:68
+#, c-format
+msgid "Unable to get header for %s"
+msgstr ""
+#: ../raster/r.flow/io.c:85
+msgid "Reading input files: elevation"
+msgstr ""
+#: ../raster/r.flow/io.c:89
+msgid "Elevation file's resolution differs from current region resolution"
+msgstr ""
+#: ../raster/r.flow/io.c:101
+msgid "Reading input files: aspect"
+msgstr ""
+#: ../raster/r.flow/io.c:104
+msgid "Resolution of aspect file differs from current region resolution"
+msgstr ""
+#: ../raster/r.flow/io.c:118
+msgid "Reading input files: barrier"
+msgstr ""
+#: ../raster/r.flow/io.c:146
+#, c-format
+msgid "Cannot create segment file %s"
+msgstr ""
+#: ../raster/r.flow/io.c:151
+#, c-format
+msgid "Cannot format segment file %s"
+msgstr ""
+#: ../raster/r.flow/io.c:157
+#, c-format
+msgid "Cannot open segment file %s"
+msgstr ""
+#: ../raster/r.flow/io.c:203
+msgid "Cannot reset current region"
+msgstr ""
+#: ../raster/r.flow/io.c:205
+msgid "Writing density file"
+msgstr ""
+#: ../raster/r.flow/io.c:228
+#, c-format
+msgid "Unable to find file %s"
+msgstr ""
+#: ../raster/r.regression.line/main.c:44
+msgid "Calculates linear regression from two raster maps: y = a + b*x."
+msgstr ""
+#: ../raster/r.regression.line/main.c:49
+msgid "Map for x coefficient"
+msgstr ""
+#: ../raster/r.regression.line/main.c:53
+msgid "Map for y coefficient"
+msgstr ""
+#: ../raster/r.regression.line/main.c:59
+msgid ""
+"ASCII file for storing regression coefficients (output to screen if file not "
+"specified)."
+msgstr ""
+#: ../raster/r.regression.line/main.c:67
+msgid "Slower but accurate (applies to FP maps only"
+msgstr ""
+#: ../raster/r.out.png/r.out.png.c:110
+msgid "raster, export, png"
+msgstr ""
+#: ../raster/r.out.png/r.out.png.c:112
+msgid "Export GRASS raster as non-georeferenced PNG image."
+msgstr ""
+#: ../raster/r.out.png/r.out.png.c:119
+msgid "Name for new PNG file (use out=- for stdout)"
+msgstr ""
+#: ../raster/r.out.png/r.out.png.c:127
+msgid "Compression level of PNG file"
+msgstr ""
+#: ../raster/r.out.png/r.out.png.c:128
+msgid "(0 = none, 1 = fastest, 9 = best)"
+msgstr ""
+#: ../raster/r.out.png/r.out.png.c:140
+msgid "Make NULL cells transparent"
+msgstr ""
+#: ../raster/r.out.png/r.out.png.c:144
+msgid "Output world file"
+msgstr ""
+#: ../raster/r.out.png/r.out.png.c:233 ../raster/r.out.pov/main.c:186
+#: ../raster/r.colors.out/main.c:101 ../raster/r.out.mat/main.c:115
+#, c-format
+msgid "Unable to open output file <%s>"
+msgstr ""
+#: ../raster/r.out.png/r.out.png.c:285
+#, c-format
+msgid "Converting <%s>..."
+msgstr ""
+#: ../raster/r.out.png/r.out.png.c:452
+msgid "Writing world file"
+msgstr ""
+#: ../raster/r.out.png/r.out.png.c:455 ../raster/r.out.tiff/r.out.tiff.c:417
+msgid "Got null file name"
+msgstr ""
+#: ../raster/r.out.png/r.out.png.c:457 ../raster/r.out.tiff/r.out.tiff.c:419
+msgid "Got null region struct"
+msgstr ""
+#: ../raster/r.out.png/r.out.png.c:459
+msgid "Unable to open world file for writing"
+msgstr ""
+#: ../raster/r.covar/main.c:55
+msgid ""
+"Outputs a covariance/correlation matrix for user-specified raster map layer"
+"(s)."
+msgstr ""
+#: ../raster/r.covar/main.c:62
+msgid "Print correlation matrix"
+msgstr ""
+#: ../raster/r.covar/main.c:104
+#, c-format
+msgid "%s: complete ... "
+msgstr ""
+#: ../raster/r.covar/main.c:129
+msgid "No non-null values"
+msgstr ""
+#: ../raster/r.surf.idw/main.c:69 ../raster/r.surf.idw2/main.c:60
+#: ../raster/r.surf.contour/main.c:52
+msgid "raster, interpolation"
+msgstr ""
+#: ../raster/r.surf.idw/main.c:71
+msgid "Surface interpolation utility for raster map."
+msgstr ""
+#: ../raster/r.surf.idw/main.c:86
+msgid "Output is the interpolation error"
+msgstr ""
+#: ../raster/r.surf.idw/main.c:92
+#, c-format
+msgid "Illegal value for '%s' (%s)"
+msgstr ""
+#: ../raster/r.surf.idw/main.c:233
+#, c-format
+msgid "Interpolating raster map <%s> (%d rows)... "
+msgstr ""
+#: ../raster/r.surf.idw/main.c:241
+msgid "Cannot read row"
+msgstr ""
+#: ../raster/r.surf.idw/main.c:685 ../raster/r.cost/main.c:393
+#: ../raster/r.cost/main.c:602 ../raster/r.surf.idw2/read_cell.c:38
+#: ../raster/r.colors/stats.c:41 ../raster/r.colors/stats.c:107
+#: ../raster/r.series/main.c:214
+#, c-format
+msgid "Reading raster map <%s>..."
+msgstr ""
+#: ../raster/r.walk/main.c:174 ../raster/r.cost/main.c:124
+msgid "raster, cost surface, cumulative costs"
+msgstr ""
+#: ../raster/r.walk/main.c:176
+msgid ""
+"Outputs a raster map layer showing the anisotropic cumulative cost of moving "
+"between different geographic locations on an input elevation raster map "
+"layer whose cell category values represent elevation combined with an input "
+"raster map layer whose cell values represent friction cost."
+msgstr ""
+#: ../raster/r.walk/main.c:188
+msgid "Name of elevation input raster map"
+msgstr ""
+#: ../raster/r.walk/main.c:196
+msgid "Name of input raster map containing friction costs"
+msgstr ""
+#: ../raster/r.walk/main.c:203 ../raster/r.water.outlet/main.c:62
+msgid "Name of raster map to contain results"
+msgstr ""
+#: ../raster/r.walk/main.c:210
+msgid "Starting points vector map"
+msgstr ""
+#: ../raster/r.walk/main.c:217
+msgid "Stop points vector map"
+msgstr ""
+#: ../raster/r.walk/main.c:225
+msgid "The map E and N grid coordinates of a starting point (E,N)"
+msgstr ""
+#: ../raster/r.walk/main.c:233
+msgid "The map E and N grid coordinates of a stopping point (E,N)"
+msgstr ""
+#: ../raster/r.walk/main.c:241
+msgid "An optional maximum cumulative cost"
+msgstr ""
+#: ../raster/r.walk/main.c:249 ../raster/r.cost/main.c:189
+msgid "Cost assigned to null cells. By default, null cells are excluded"
+msgstr ""
+#: ../raster/r.walk/main.c:257 ../raster/r.cost/main.c:198
+#: ../raster/r.in.xyz/main.c:235
+msgid "Percent of map to keep in memory"
+msgstr ""
+#: ../raster/r.walk/main.c:266
+msgid "Number of the segment to create (segment library)"
+msgstr ""
+#: ../raster/r.walk/main.c:276
+msgid "Coefficients for walking energy formula parameters a,b,c,d"
+msgstr ""
+#: ../raster/r.walk/main.c:285
+msgid "Lambda coefficients for combining walking energy and friction cost"
+msgstr ""
+#: ../raster/r.walk/main.c:294
+msgid "Slope factor determines travel energy cost per height step"
+msgstr ""
+#: ../raster/r.walk/main.c:299 ../raster/r.cost/main.c:203
+msgid "Use the 'Knight's move'; slower, but more accurate"
+msgstr ""
+#: ../raster/r.walk/main.c:303
+msgid "Keep null values in output map"
+msgstr ""
+#: ../raster/r.walk/main.c:307 ../raster/r.cost/main.c:211
+msgid "Start with values in raster map"
+msgstr ""
+#: ../raster/r.walk/main.c:322 ../raster/r.cost/main.c:238
+#: ../raster/r.water.outlet/main.c:85 ../raster/wildfire/r.spread/main.c:338
+msgid "Unable to read current window parameters"
+msgstr ""
+#: ../raster/r.walk/main.c:351 ../raster/r.cost/main.c:284
+#, c-format
+msgid "Inappropriate maximum cost: %d"
+msgstr ""
+#: ../raster/r.walk/main.c:355 ../raster/r.cost/main.c:288
+#, c-format
+msgid "Inappropriate percent memory: %d"
+msgstr ""
+#: ../raster/r.walk/main.c:360
+#, c-format
+msgid "Missing required value: got %d instead of 4"
+msgstr ""
+#: ../raster/r.walk/main.c:364
+#, c-format
+msgid "Walking costs are a=%lf b=%lf c=%lf d=%lf"
+msgstr ""
+#: ../raster/r.walk/main.c:369 ../raster/r.walk/main.c:377
+#: ../raster/r.walk/main.c:384
+#, c-format
+msgid "Missing required value: %d"
+msgstr ""
+#: ../raster/r.walk/main.c:372
+#, c-format
+msgid "Lambda is %lf"
+msgstr ""
+#: ../raster/r.walk/main.c:380
+#, c-format
+msgid "Slope_factor is %lf"
+msgstr ""
+#: ../raster/r.walk/main.c:387
+#, c-format
+msgid "Nseg is %d"
+msgstr ""
+#: ../raster/r.walk/main.c:393
+msgid "Null cells excluded from cost evaluation."
+msgstr ""
+#: ../raster/r.walk/main.c:397
+msgid "Input null cell will be retained into output map"
+msgstr ""
+#: ../raster/r.walk/main.c:409
+#, c-format
+msgid "Unable to find starting vector <%s> "
+msgstr ""
+#: ../raster/r.walk/main.c:456
+#, c-format
+msgid "Unable to find stop vector <%s>"
+msgstr ""
+#: ../raster/r.walk/main.c:495
+msgid "Warning: assigning negative cost to null cell. Null cells excluded."
+msgstr ""
+#: ../raster/r.walk/main.c:556 ../raster/r.walk/main.c:558
+#, c-format
+msgid "Unable to read %s"
+msgstr ""
+#: ../raster/r.walk/main.c:563
+msgid "Map with different projection"
+msgstr ""
+#: ../raster/r.walk/main.c:575
+msgid "DTM_Source map is: Integer cell type"
+msgstr ""
+#: ../raster/r.walk/main.c:578
+msgid "DTM_Source map is: Floating point (float) cell type"
+msgstr ""
+#: ../raster/r.walk/main.c:581
+msgid "DTM_Source map is: Floating point (double) cell type"
+msgstr ""
+#: ../raster/r.walk/main.c:584 ../raster/r.walk/main.c:599
+#: ../raster/r.walk/main.c:636
+#, c-format
+msgid " %d rows, %d cols"
+msgstr ""
+#: ../raster/r.walk/main.c:590
+msgid "COST_Source map is: Integer cell type"
+msgstr ""
+#: ../raster/r.walk/main.c:593
+msgid "COST_Source map is: Floating point (float) cell type"
+msgstr ""
+#: ../raster/r.walk/main.c:596
+msgid "COST_Source map is: Floating point (double) cell type"
+msgstr ""
+#: ../raster/r.walk/main.c:627
+msgid "Output map is: Integer cell type"
+msgstr ""
+#: ../raster/r.walk/main.c:630
+msgid "Output map is: Floating point (float) cell type"
+msgstr ""
+#: ../raster/r.walk/main.c:633
+msgid "Output map is: Floating point (double) cell type"
+msgstr ""
+#: ../raster/r.walk/main.c:638
+#, c-format
+msgid " EW resolution %s (%lf)"
+msgstr ""
+#: ../raster/r.walk/main.c:640
+#, c-format
+msgid " NS resolution %s (%lf)"
+msgstr ""
+#: ../raster/r.walk/main.c:654 ../raster/r.cost/main.c:372
+msgid "Creating some temporary files..."
+msgstr ""
+#: ../raster/r.walk/main.c:682 ../raster/r.walk/main.c:744
+#: ../raster/r.sum/main.c:74 ../raster/wildfire/r.spread/main.c:514
+#, c-format
+msgid "Reading %s..."
+msgstr ""
+#: ../raster/r.walk/main.c:812
+msgid "Initializing output "
+msgstr ""
+#: ../raster/r.walk/main.c:820
+msgid "Unable to allocate memory for segment fbuff == NULL"
+msgstr ""
+#: ../raster/r.walk/main.c:849
+#, c-format
+msgid "Raster output map <%s> not found (no start_points given)"
+msgstr ""
+#: ../raster/r.walk/main.c:864
+#, c-format
+msgid "Memory allocation error on reading start points from raster map %s"
+msgstr ""
+#: ../raster/r.walk/main.c:867
+#, c-format
+msgid "Reading %s... "
+msgstr ""
+#: ../raster/r.walk/main.c:914 ../raster/r.cost/main.c:650
+msgid "Specified starting location outside database window"
+msgstr ""
+#: ../raster/r.walk/main.c:931
+msgid "Finding cost path"
+msgstr ""
+#: ../raster/r.walk/main.c:1378
+msgid "End of map!"
+msgstr ""
+#: ../raster/r.walk/main.c:1382 ../raster/r.cost/main.c:895
+msgid "Error, ct == pres_cell"
+msgstr ""
+#: ../raster/r.walk/main.c:1396
+#, c-format
+msgid "Writing output raster map %s... "
+msgstr ""
+#: ../raster/r.walk/main.c:1400
+msgid "Will copy input map null values into output map"
+msgstr ""
+#: ../raster/r.walk/main.c:1407
+msgid ""
+"Integer cell type.\n"
+"Writing..."
+msgstr ""
+#: ../raster/r.walk/main.c:1442
+msgid ""
+"Float cell type.\n"
+"Writing..."
+msgstr ""
+#: ../raster/r.walk/main.c:1477
+msgid ""
+"Double cell type.\n"
+"Writing..."
+msgstr ""
+#: ../raster/r.walk/main.c:1513
+#, c-format
+msgid "Peak cost value: %f"
+msgstr ""
+#: ../raster/r.walk/main.c:1564 ../raster/r.cost/main.c:1058
+#, c-format
+msgid "Illegal x coordinate <%s>"
+msgstr ""
+#: ../raster/r.walk/main.c:1566 ../raster/r.cost/main.c:1060
+#, c-format
+msgid "Illegal y coordinate <%s>"
+msgstr ""
+#: ../raster/r.walk/main.c:1570 ../raster/r.cost/main.c:1064
+#, c-format
+msgid "Warning, ignoring point outside window: %.4f,%.4f"
+msgstr ""
+#: ../raster/r.surf.fractal/interface.c:36
+msgid "raster, DEM, fractal"
+msgstr ""
+#: ../raster/r.surf.fractal/interface.c:38
+msgid "Creates a fractal surface of a given fractal dimension."
+msgstr ""
+#: ../raster/r.surf.fractal/interface.c:49
+msgid "Fractal dimension of surface (2 < D < 3)"
+msgstr ""
+#: ../raster/r.surf.fractal/interface.c:56
+msgid "Number of intermediate images to produce"
+msgstr ""
+#: ../raster/r.surf.fractal/interface.c:88
+#, c-format
+msgid "Fractal dimension of %.2lf must be between 2 and 3."
+msgstr ""
+#: ../raster/r.surf.fractal/process.c:53
+msgid "Unable to allocate data buffer. Check current region with g.region."
+msgstr ""
+#: ../raster/r.surf.fractal/spec_syn.c:61
+msgid "Preliminary surface calculations..."
+msgstr ""
+#: ../raster/r.surf.fractal/spec_syn.c:120
+#, c-format
+msgid "Calculating surface %d (of %d)..."
+msgstr ""
+#: ../raster/r.surf.fractal/main.c:39 ../raster/r.circle/dist.c:155
+#: ../raster/r.in.gdal/main.c:969 ../raster/r.composite/main.c:273
+#: ../raster/r.recode/main.c:109
+#, c-format
+msgid "Raster map <%s> created."
+msgstr ""
+#: ../raster/r.sum/main.c:47
+msgid "Sums up the raster cell values."
+msgstr ""
+#: ../raster/r.sum/main.c:54
+msgid "Name of incidence or density file."
+msgstr ""
+#: ../raster/r.resample/main.c:54 ../raster/r.resamp.interp/main.c:72
+#: ../raster/r.resamp.rst/main.c:156 ../raster/r.resamp.stats/main.c:259
+#: ../raster/r.bilinear/main.c:42
+msgid "raster, resample"
+msgstr ""
+#: ../raster/r.resample/main.c:56
+msgid "GRASS raster map layer data resampling capability."
+msgstr ""
+#: ../raster/r.resample/main.c:65
+msgid "Name of an input layer"
+msgstr ""
+#: ../raster/r.resample/main.c:72
+msgid "Name of an output layer"
+msgstr ""
+#: ../raster/r.resample/main.c:152 ../raster/r.cross/main.c:194
+#: ../raster/r.basins.fill/main.c:155
+#, c-format
+msgid "Creating support files for <%s>..."
+msgstr ""
+#: ../raster/r.resample/main.c:165
+msgid "Creating new cats file..."
+msgstr ""
+#: ../raster/r.circle/dist.c:53
+msgid "Creates a raster map containing concentric rings around a given point."
+msgstr ""
+#: ../raster/r.circle/dist.c:63
+msgid "The coordinate of the center (east,north)"
+msgstr ""
+#: ../raster/r.circle/dist.c:69
+msgid "Minimum radius for ring/circle map (in meters)"
+msgstr ""
+#: ../raster/r.circle/dist.c:75
+msgid "Maximum radius for ring/circle map (in meters)"
+msgstr ""
+#: ../raster/r.circle/dist.c:81
+msgid "Data value multiplier"
+msgstr ""
+#: ../raster/r.circle/dist.c:85
+msgid "Generate binary raster map"
+msgstr ""
+#: ../raster/r.circle/dist.c:108
+msgid "Please specify a radius in which min < max"
+msgstr ""
+#: ../raster/r.circle/dist.c:116
+msgid "Please specify min and/or max radius when using the binary flag"
+msgstr ""
+#: ../raster/r.median/read_stats.c:14 ../raster/r.statistics/read_stats.c:20
+msgid "Reading r.stats output"
+msgstr ""
+#: ../raster/r.median/main.c:48
+msgid ""
+"Finds the median of values in a cover map within areas assigned the same "
+"category value in a user-specified base map."
+msgstr ""
+#: ../raster/r.median/main.c:54
+msgid "Name of base raster map"
+msgstr ""
+#: ../raster/r.median/main.c:58 ../raster/r.random/main.c:62
+msgid "Name of cover raster map"
+msgstr ""
+#: ../raster/r.median/main.c:71
+#, c-format
+msgid "Base raster map <%s> not found"
+msgstr ""
+#: ../raster/r.median/main.c:79
+#, c-format
+msgid "Base map and output map <%s> must be different"
+msgstr ""
+#: ../raster/r.median/main.c:82
+#, c-format
+msgid "Unable to read category labels of raster map <%s>"
+msgstr ""
+#: ../raster/r.out.tiff/r.out.tiff.c:101
+msgid ""
+"Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
+"resolution of the currently defined region."
+msgstr ""
+#: ../raster/r.out.tiff/r.out.tiff.c:111
+msgid "Name for new TIFF file"
+msgstr ""
+#: ../raster/r.out.tiff/r.out.tiff.c:118
+msgid "TIFF file compression"
+msgstr ""
+#: ../raster/r.out.tiff/r.out.tiff.c:123
+msgid "TIFF Palette output (8bit instead of 24bit)."
+msgstr ""
+#: ../raster/r.out.tiff/r.out.tiff.c:127
+msgid "Output TIFF world file"
+msgstr ""
+#: ../raster/r.out.tiff/r.out.tiff.c:131
+msgid "Output Tiled TIFF"
+msgstr ""
+#: ../raster/r.out.tiff/r.out.tiff.c:173 ../raster/r.in.arc/main.c:132
+#: ../raster/r.in.ascii/main.c:190
+msgid "Can't set window"
+msgstr ""
+#: ../raster/r.out.tiff/r.out.tiff.c:177
+#, c-format
+msgid ""
+"Raster map <%s> in mapset <%s> is a floating point map. Decimal values will "
+"be rounded to integer!"
+msgstr ""
+#: ../raster/r.out.tiff/r.out.tiff.c:183
+msgid ""
+"Color map for palette must have less than 256 colors for the available range "
+"of data"
+msgstr ""
+#: ../raster/r.out.tiff/r.out.tiff.c:198
+#, c-format
+msgid "Unable to open TIFF file <%s>"
+msgstr ""
+#: ../raster/r.out.tiff/r.out.tiff.c:414
+msgid "Writing TIFF World file"
+msgstr ""
+#: ../raster/r.out.tiff/r.out.tiff.c:422
+msgid "Unable to open TIFF world file for writing"
+msgstr ""
+#: ../raster/r.le/r.le.patch/main.c:47 ../raster/r.le/r.le.setup/main.c:61
+#: ../raster/r.le/r.le.trace/main.c:57 ../raster/r.le/r.le.pixel/main.c:45
+#: ../raster/r.li/r.li.mpa/mpa.c:38 ../raster/r.li/r.li.mps/mps.c:40
+#: ../raster/r.li/r.li.padsd/padsd.c:36
+#: ../raster/r.li/r.li.patchdensity/main.c:34
+#: ../raster/r.li/r.li.shape/main.c:33 ../raster/r.li/r.li.patchnum/main.c:35
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:38
+#: ../raster/r.li/r.li.padcv/padcv.c:38 ../raster/r.li/r.li.cwed/cwed.c:45
+#: ../raster/r.li/r.li.padrange/padrange.c:38
+msgid "raster, landscape structure analysis, patch index"
+msgstr ""
+#: ../raster/r.le/r.le.patch/main.c:49
+msgid ""
+"Calculates attribute, patch size, core (interior) size, shape, fractal "
+"dimension, and perimeter measures for sets of patches in a landscape."
+msgstr ""
+#: ../raster/r.le/r.le.setup/sample.c:1050
+msgid "Cannot read vector"
+msgstr ""
+#: ../raster/r.le/r.le.setup/main.c:63
+msgid ""
+"Interactive tool used to setup the sampling and analysis framework that will "
+"be used by the other r.le programs."
+msgstr ""
+#: ../raster/r.le/r.le.setup/main.c:67
+msgid "Raster map to use to setup sampling"
+msgstr ""
+#: ../raster/r.le/r.le.setup/main.c:71
+msgid "Vector map to overlay"
+msgstr ""
+#: ../raster/r.le/r.le.trace/main.c:59
+msgid ""
+"Displays the boundary of each r.le patch and shows how the boundary is "
+"traced, displays the attribute, size, perimeter and shape indices for each "
+"patch and saves the data in an output file."
+msgstr ""
+#: ../raster/r.le/r.le.pixel/main.c:47
+msgid ""
+"Contains a set of measures for attributes, diversity, texture, "
+"juxtaposition, and edge."
+msgstr ""
+#: ../raster/r.grow2/main.c:130
+msgid "Generates a raster map layer with contiguous areas grown by one cell."
+msgstr ""
+#: ../raster/r.grow2/main.c:141
+msgid "Radius of buffer in raster cells"
+msgstr ""
+#: ../raster/r.grow2/main.c:148 ../raster/r.grow.distance/main.c:150
+msgid "Metric"
+msgstr ""
+#: ../raster/r.grow2/main.c:157
+msgid "Value to write for input cells which are non-NULL (-1 => NULL)"
+msgstr ""
+#: ../raster/r.grow2/main.c:163
+msgid "Value to write for \"grown\" cells"
+msgstr ""
+#: ../raster/r.grow2/main.c:199 ../raster/r.grow.distance/main.c:173
+#, c-format
+msgid "Unknown metric: [%s]."
+msgstr ""
+#: ../raster/r.grow2/main.c:212 ../raster/r.average/main.c:82
+#, c-format
+msgid "Error reading category file for <%s>"
+msgstr ""
+#: ../raster/r.grow2/main.c:217
+#, c-format
+msgid "Error in reading color file for <%s>"
+msgstr ""
+#: ../raster/r.grow2/main.c:301
+#, c-format
+msgid "Error writing category file for <%s>"
+msgstr ""
+#: ../raster/r.grow2/main.c:305
+#, c-format
+msgid "Error writing color file for <%s>"
+msgstr ""
+#: ../raster/r.info/main.c:71
+msgid "Output basic information about a raster map layer."
+msgstr ""
+#: ../raster/r.info/main.c:82
+msgid "Print raster map resolution (NS-res, EW-res) only"
+msgstr ""
+#: ../raster/r.info/main.c:86
+msgid "Print raster map type only"
+msgstr ""
+#: ../raster/r.info/main.c:94
+msgid "Print raster history instead of info"
+msgstr ""
+#: ../raster/r.info/main.c:98
+msgid "Print raster map data units only"
+msgstr ""
+#: ../raster/r.info/main.c:102
+msgid "Print raster map vertical datum only"
+msgstr ""
+#: ../raster/r.info/main.c:111
+msgid "Print raster map timestamp (day.month.year hour:minute:seconds) only"
+msgstr ""
+#: ../raster/r.info/main.c:142
+msgid "Unable to read range file"
+msgstr ""
+#: ../raster/r.kappa/stats.c:13 ../raster/r.report/stats.c:99
+msgid "Problem reading r.stats output"
+msgstr ""
+#: ../raster/r.kappa/prt_mat.c:39
+#, c-format
+msgid "Cannot open file <%s> to write cats and counts (error matrix)"
+msgstr ""
+#: ../raster/r.kappa/prt_label.c:16
+#, c-format
+msgid "Can't open file <%s> to write label"
+msgstr ""
+#: ../raster/r.kappa/calc_kappa.c:32
+#, c-format
+msgid "Cannot open file <%s> to write kappa and relevant parameters"
+msgstr ""
+#: ../raster/r.kappa/prt_hdr.c:17
+#, c-format
+msgid "Cannot open file <%s> to write header"
+msgstr ""
+#: ../raster/r.kappa/main.c:69
+msgid ""
+"Calculate error matrix and kappa parameter for accuracy assessment of "
+"classification result."
+msgstr ""
+#: ../raster/r.kappa/main.c:75
+msgid "Name of raster map containing classification result"
+msgstr ""
+#: ../raster/r.kappa/main.c:80
+msgid "Name of raster map containing reference classes"
+msgstr ""
+#: ../raster/r.kappa/main.c:85
+msgid "Name for output file containing error matrix and kappa"
+msgstr ""
+#: ../raster/r.kappa/main.c:91
+msgid "Title for error matrix and kappa"
+msgstr ""
+#: ../raster/r.kappa/main.c:96
+msgid "Wide report"
+msgstr ""
+#: ../raster/r.kappa/main.c:97
+msgid "132 columns (default: 80)"
+msgstr ""
+#: ../raster/r.kappa/main.c:106
+msgid "No header in the report"
+msgstr ""
+#: ../raster/r.kappa/main.c:133 ../raster/r.out.ppm/main.c:81
+#: ../raster/r.mfilter/main.c:104 ../raster/r.mfilter.fp/main.c:109
+msgid ""
+"The '-q' flag is superseded and will be removed in future. Please use '--"
+"quiet' instead"
+msgstr ""
+#: ../raster/r.li/r.li.mpa/mpa.c:37
+msgid "Calculates mean pixel attribute index on a raster map"
+msgstr ""
+#: ../raster/r.li/r.li.mpa/mpa.c:45 ../raster/r.li/r.li.renyi/renyi.c:54
+#: ../raster/r.li/r.li.mps/mps.c:47 ../raster/r.li/r.li.shannon/shannon.c:46
+#: ../raster/r.li/r.li.padsd/padsd.c:42
+#: ../raster/r.li/r.li.patchdensity/main.c:42
+#: ../raster/r.li/r.li.shape/main.c:41
+#: ../raster/r.li/r.li.richness/richness.c:47
+#: ../raster/r.li/r.li.dominance/dominance.c:46
+#: ../raster/r.li/r.li.patchnum/main.c:43
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:46
+#: ../raster/r.li/r.li.padcv/padcv.c:44
+#: ../raster/r.li/r.li.simpson/simpson.c:47 ../raster/r.li/r.li.cwed/cwed.c:53
+#: ../raster/r.li/r.li.pielou/pielou.c:67
+#: ../raster/r.li/r.li.padrange/padrange.c:44
+msgid "Configuration file"
+msgstr ""
+#: ../raster/r.li/r.li.renyi/renyi.c:44
+msgid "Calculates Renyi's diversity index on a raster map"
+msgstr ""
+#: ../raster/r.li/r.li.renyi/renyi.c:46
+#: ../raster/r.li/r.li.shannon/shannon.c:38
+#: ../raster/r.li/r.li.dominance/dominance.c:38
+#: ../raster/r.li/r.li.simpson/simpson.c:39
+#: ../raster/r.li/r.li.pielou/pielou.c:59
+msgid "raster, landscape structure analysis, diversity index"
+msgstr ""
+#: ../raster/r.li/r.li.renyi/renyi.c:62
+msgid "Alpha value is the order of the generalized entropy"
+msgstr ""
+#: ../raster/r.li/r.li.mps/mps.c:39
+msgid ""
+"Calculates mean patch size index on a raster map, using a 4 neighbour "
+"algorithm"
+msgstr ""
+#: ../raster/r.li/r.li.shannon/shannon.c:36
+msgid "Calculates Shannon's diversity index on a raster map"
+msgstr ""
+#: ../raster/r.li/r.li.padsd/padsd.c:35
+msgid "Calculates standard deviation of patch area a raster map"
+msgstr ""
+#: ../raster/r.li/r.li.patchdensity/main.c:33
+msgid ""
+"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
+msgstr ""
+#: ../raster/r.li/r.li.shape/main.c:32
+msgid "Calculates shape index on a raster map"
+msgstr ""
+#: ../raster/r.li/r.li.richness/richness.c:37
+#: ../raster/r.li/r.li.dominance/dominance.c:36
+msgid "Calculates dominance's diversity index on a raster map"
+msgstr ""
+#: ../raster/r.li/r.li.richness/richness.c:39
+msgid "raster, landscape structure analysis, dominance index"
+msgstr ""
+#: ../raster/r.li/r.li.patchnum/main.c:34
+msgid ""
+"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+msgstr ""
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:37
+msgid ""
+"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:82
+msgid "Error in pipe creation"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:90
+#, c-format
+msgid "Error opening channel %i"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:137
+msgid "Cannot create random access file"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:145
+#, c-format
+msgid "Cannot create %s/.r.li/ directory"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:149
+#, c-format
+msgid "Cannot create %s/.r.li/output/ directory"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:247
+#: ../raster/r.li/r.li.daemon/daemon.c:270
+#, c-format
+msgid "r.li.worker (pid %i) exited with abnormal status: %i"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:250
+#: ../raster/r.li/r.li.daemon/daemon.c:273
+#, c-format
+msgid "r.li.worker (pid %i) terminated successfully"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:255
+#, c-format
+msgid "Cannot close %s file (PIPE)"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:257
+#, c-format
+msgid "Cannot delete %s file (PIPE)"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:278
+#, c-format
+msgid "Cannot close %s file (PIPE2)"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:280
+#, c-format
+msgid "Cannot delete %s file (PIPE2)"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:299
+msgid "Cannot close receive channel file"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:302
+#, c-format
+msgid "Cannot delete %s file"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:321
+#, c-format
+msgid "Cannot find configuration file <%s>"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:328
+#: ../raster/r.li/r.li.daemon/daemon.c:332
+msgid "Cannot read setup file"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:336
+msgid "Unable to parse configuration file"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:346
+msgid "Cannot read raster header file"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:489
+msgid "Irregular maskedoverlay areas definition"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:492
+#, c-format
+msgid "The configuration file can be used only with \t\t\t%s rasterfile"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:499
+msgid "Illegal configuration file (sample area)"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:533
+msgid "Too many units to place"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:602
+msgid "Too many strats for raster map"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:636
+msgid "Illegal areas disposition"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:705
+msgid "Cannot make lseek"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/ipc.c:48
+#, c-format
+msgid ""
+"\t\t\t\tAREA MESSAGE: \n"
+" \t\t\t\taid = %i \n"
+" \t\t\t\tx = %i \n"
+" \t\t\t\ty = %i \n"
+" \t\t\t\trl = %i \n"
+" \t\t\t\tcl = %i \n"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/ipc.c:57
+#, c-format
+msgid ""
+" \t\t\t\tMASKEDAREA MESSAGE: \n"
+" \t\t\t\tmask = %s \n"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/ipc.c:68
+#, c-format
+msgid ""
+" \t\t\t\tDONE MESSAGE: \n"
+" \t\t\t\tpid = %i \n"
+" \t\t\t\tresult = %f \n"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/ipc.c:75
+#, c-format
+msgid ""
+" \t\t\t\tERROR MESSAGE: \n"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/ipc.c:81
+#, c-format
+msgid ""
+" \t\t\t\tTERM MESSAGE: \n"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/worker.c:66
+#, c-format
+msgid "CHILD[pid = %i] cannot open raster map"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/worker.c:104
+#: ../raster/r.li/r.li.daemon/worker.c:111
+#, c-format
+msgid "CHILD[pid = %i] cannot open receive channel"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/worker.c:140
+#: ../raster/r.li/r.li.daemon/worker.c:150
+#, c-format
+msgid "CHILD[pid = %i]: unable to open <%s> mask ... continuing without!"
+msgstr ""
+#: ../raster/r.li/r.li.padcv/padcv.c:37
+msgid "Calculates coefficient of variation of patch area on a raster map"
+msgstr ""
+#: ../raster/r.li/r.li.simpson/simpson.c:37
+msgid "Calculates Simpson's diversity index on a raster map"
+msgstr ""
+#: ../raster/r.li/r.li.cwed/cwed.c:44
+msgid "Calculates contrast weighted edge density index on a raster map"
+msgstr ""
+#: ../raster/r.li/r.li.pielou/pielou.c:57
+msgid "Calculates Pielou's diversity index on a raster map"
+msgstr ""
+#: ../raster/r.li/r.li.padrange/padrange.c:37
+msgid "Calculates range of patch area size on a raster map"
+msgstr ""
+#: ../raster/r.what/main.c:91 ../raster/r.what.color/main.c:88
+msgid "raster, querying"
+msgstr ""
+#: ../raster/r.what/main.c:93
+msgid "Queries raster map layers on their category values and category labels."
+msgstr ""
+#: ../raster/r.what/main.c:101
+msgid "Name of existing raster map(s) to query"
+msgstr ""
+#: ../raster/r.what/main.c:108
+msgid "Size of point cache"
+msgstr ""
+#: ../raster/r.what/main.c:131
+msgid "Output header row"
+msgstr ""
+#: ../raster/r.what/main.c:135
+msgid "Show the category labels of the grid cell(s)"
+msgstr ""
+#: ../raster/r.what/main.c:139
+msgid "Output color values as RRR:GGG:BBB"
+msgstr ""
+#: ../raster/r.what/main.c:143
+msgid "Output integer category values, not cell values"
+msgstr ""
+#: ../raster/r.what/main.c:147
+msgid "Turn on cache reporting"
+msgstr ""
+#: ../raster/r.what/main.c:194
+#, c-format
+msgid "%s: can only do up to %d raster maps, sorry\n"
+msgstr ""
+#: ../raster/r.cross/renumber.c:32
+#, c-format
+msgid "%s: STEP 3 ... "
+msgstr ""
+#: ../raster/r.cross/main.c:77
+msgid ""
+"Creates a cross product of the category values from multiple raster map "
+"layers."
+msgstr ""
+#: ../raster/r.cross/main.c:86
+#, c-format
+msgid "Names of 2-%d input raster maps"
+msgstr ""
+#: ../raster/r.cross/main.c:95
+msgid "Non-zero data only"
+msgstr ""
+#: ../raster/r.cross/main.c:122
+#, c-format
+msgid "More than %d files not allowed"
+msgstr ""
+#: ../raster/r.cross/main.c:140
+msgid "Must specify 2 or more input maps"
+msgstr ""
+#: ../raster/r.cross/main.c:161
+#, c-format
+msgid "%s: STEP 2 ..."
+msgstr ""
+#: ../raster/r.cross/main.c:204
+#, c-format
+msgid "%ld categories"
+msgstr ""
+#: ../raster/r.cross/cross.c:52
+#, c-format
+msgid "%s: STEP 1 ... "
+msgstr ""
+#: ../raster/r.neighbors/readweights.c:18
+#, c-format
+msgid "Unable to open weights file %s"
+msgstr ""
+#: ../raster/r.neighbors/readweights.c:23
+#, c-format
+msgid "Error reading weights file %s"
+msgstr ""
+#: ../raster/r.neighbors/main.c:110
+msgid ""
+"Makes each cell category value a function of the category values assigned to "
+"the cells around it, and stores new cell values in an output raster map "
+"layer."
+msgstr ""
+#: ../raster/r.neighbors/main.c:133
+msgid "Neighborhood operation"
+msgstr ""
+#: ../raster/r.neighbors/main.c:134 ../raster/r.neighbors/main.c:142
+#: ../raster/r.neighbors/main.c:176
+msgid "Neighborhood"
+msgstr ""
+#: ../raster/r.neighbors/main.c:140
+msgid "Neighborhood size"
+msgstr ""
+#: ../raster/r.neighbors/main.c:149
+msgid "Title of the output raster map"
+msgstr ""
+#: ../raster/r.neighbors/main.c:156
+msgid "File containing weights"
+msgstr ""
+#: ../raster/r.neighbors/main.c:162
+msgid "Sigma (in cells) for Gaussian filter"
+msgstr ""
+#: ../raster/r.neighbors/main.c:166
+msgid "Do not align output with the input"
+msgstr ""
+#: ../raster/r.neighbors/main.c:175
+msgid "Use circular neighborhood"
+msgstr ""
+#: ../raster/r.neighbors/main.c:183
+msgid "Neighborhood size must be positive"
+msgstr ""
+#: ../raster/r.neighbors/main.c:185
+msgid "Neighborhood size must be odd"
+msgstr ""
+#: ../raster/r.neighbors/main.c:189
+msgid "weight= and -c are mutually exclusive"
+msgstr ""
+#: ../raster/r.neighbors/main.c:201
+msgid "weight= and gauss= are mutually exclusive"
+msgstr ""
+#: ../raster/r.neighbors/main.c:255
+#, c-format
+msgid "Method %s not compatible with Gaussian filter"
+msgstr ""
+#: ../raster/r.out.ppm3/main.c:59
+msgid ""
+"Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
+"resolution of the CURRENTLY DEFINED REGION."
+msgstr ""
+#: ../raster/r.out.ppm3/main.c:65 ../raster/r.composite/main.c:88
+#, c-format
+msgid "Name of raster map to be used for <%s>"
+msgstr ""
+#: ../raster/r.out.ppm3/main.c:85
+msgid "Name for new PPM file. (use out=- for stdout)"
+msgstr ""
+#: ../raster/r.out.ppm3/main.c:94
+msgid "Add comments to describe the region"
+msgstr ""
+#: ../raster/r.out.ppm3/main.c:109 ../raster/r.out.ppm/main.c:110
+#, c-format
+msgid "rows = %d, cols = %d"
+msgstr ""
+#: ../raster/r.out.ppm3/main.c:176
+msgid "Converting ... "
+msgstr ""
+#: ../raster/r.out.vtk/parameters.c:46
+msgid "Elevation raster map"
+msgstr ""
+#: ../raster/r.out.vtk/parameters.c:52
+msgid "Value to represent no data cell"
+msgstr ""
+#: ../raster/r.out.vtk/parameters.c:60
+msgid "Elevation (if no elevation map is specified)"
+msgstr ""
+#: ../raster/r.out.vtk/parameters.c:66
+msgid ""
+"Create VTK point data instead of VTK cell data (if no elevation map is given)"
+msgstr ""
+#: ../raster/r.out.vtk/parameters.c:76
+msgid ""
+"Three (r,g,b) raster maps to create rgb values [redmap,greenmap,bluemap]"
+msgstr ""
+#: ../raster/r.out.vtk/parameters.c:86
+msgid "Three (x,y,z) raster maps to create vector values [xmap,ymap,zmap]"
+msgstr ""
+#: ../raster/r.out.vtk/parameters.c:111
+msgid "Use structured grid for elevation (not recommended)"
+msgstr ""
+#: ../raster/r.out.vtk/parameters.c:117
+msgid "Use polydata-trianglestrips for elevation grid creation"
+msgstr ""
+#: ../raster/r.out.vtk/parameters.c:123
+msgid ""
+"Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
+msgstr ""
+#: ../raster/r.out.vtk/parameters.c:129
+msgid "Scale factor effects the origin (if no elevation map is given)"
+msgstr ""
+#: ../raster/r.out.vtk/writeascii.c:74
+msgid "write_vtk_normal_header: Writing VTK-Header"
+msgstr ""
+#: ../raster/r.out.vtk/writeascii.c:107
+msgid "write_vtk_structured_elevation_header: Writing VTK-Header"
+msgstr ""
+#: ../raster/r.out.vtk/writeascii.c:123
+msgid "write_vtk_polygonal_elevation_header: Writing VTK-Header"
+msgstr ""
+#: ../raster/r.out.vtk/writeascii.c:138
+msgid "write_vtk_celldata_header: Writing VTK-DataHeader"
+msgstr ""
+#: ../raster/r.out.vtk/writeascii.c:147
+msgid "writeVTKPointHeader: Writing VTK-DataHeader"
+msgstr ""
+#: ../raster/r.out.vtk/writeascii.c:168
+msgid "write_vtk_structured_coordinates: Writing Coordinates"
+msgstr ""
+#: ../raster/r.out.vtk/writeascii.c:184 ../raster/r.out.vtk/writeascii.c:245
+#: ../raster/r.out.vtk/writeascii.c:357 ../raster/r.out.vtk/writeascii.c:404
+#: ../raster/r.out.vtk/writeascii.c:408 ../raster/r.out.vtk/writeascii.c:412
+#: ../raster/r.out.vtk/writeascii.c:471 ../raster/r.out.vtk/writeascii.c:475
+#: ../raster/r.out.vtk/writeascii.c:479
+#, c-format
+msgid "Unable to read row %i\n"
+msgstr ""
+#: ../raster/r.out.vtk/writeascii.c:227
+msgid "write_vtk_polygonal_coordinates: Writing VTK Polygonal data"
+msgstr ""
+#: ../raster/r.out.vtk/writeascii.c:339
+msgid "write_vtk_data: Writing VTK-Data"
+msgstr ""
+#: ../raster/r.out.vtk/writeascii.c:392
+msgid "write_vtk_rgb_image_data: Writing VTK-ImageData"
+msgstr ""
+#: ../raster/r.out.vtk/writeascii.c:429
+msgid "Wrong map values! Values should in between 0 and 255!\n"
+msgstr ""
+#: ../raster/r.out.vtk/writeascii.c:459
+msgid "write_vtk_vector_data: Writing VTK-vector data"
+msgstr ""
+#: ../raster/r.out.vtk/main.c:79
+#, c-format
+msgid "RGB raster map <%s> not found"
+msgstr ""
+#: ../raster/r.out.vtk/main.c:86
+msgid "Cannot create RGB data, please provide three maps [r,g,b]"
+msgstr ""
+#: ../raster/r.out.vtk/main.c:102
+#, c-format
+msgid "Vector cell map <%s> not found"
+msgstr ""
+#: ../raster/r.out.vtk/main.c:109
+msgid "Cannot create vector data, please provide three maps [x,y,z]"
+msgstr ""
+#: ../raster/r.out.vtk/main.c:149
+msgid "Converts raster maps into the VTK-Ascii format"
+msgstr ""
+#: ../raster/r.out.vtk/main.c:215 ../raster/r.out.vtk/main.c:280
+#: ../raster/r.out.vtk/main.c:307 ../raster/r.out.vtk/main.c:353
+#, c-format
+msgid "Open Raster file %s"
+msgstr ""
+#: ../raster/r.out.vtk/main.c:324
+msgid "Writing VTK ImageData\n"
+msgstr ""
+#: ../raster/r.out.vtk/main.c:334
+msgid "Wrong RGB maps. Maps should have the same type! RGB output not added!"
+msgstr ""
+#: ../raster/r.out.vtk/main.c:371
+msgid "Writing VTK Vector Data\n"
+msgstr ""
+#: ../raster/r.out.vtk/main.c:381
+msgid ""
+"Wrong vector maps. Maps should have the same type! Vector output not added!"
+msgstr ""
+#: ../raster/r.out.vtk/main.c:393
+msgid "Error closing VTK-ASCII file"
+msgstr ""
+#: ../raster/r.mapcalc/evaluate.c:91 ../raster/r.mapcalc/evaluate.c:206
+#: ../raster/r.mapcalc/map.c:280 ../raster/r.mapcalc/map3.c:348
+#, c-format
+msgid "Unknown type: %d"
+msgstr ""
+#: ../raster/r.mapcalc/evaluate.c:120
+#, c-format
+msgid "Invalid type: %d"
+msgstr ""
+#: ../raster/r.mapcalc/evaluate.c:151
+#, c-format
+msgid "Too few arguments for function '%s'"
+msgstr ""
+#: ../raster/r.mapcalc/evaluate.c:155
+#, c-format
+msgid "Too many arguments for function '%s'"
+msgstr ""
+#: ../raster/r.mapcalc/evaluate.c:159
+#, c-format
+msgid "Invalid argument type for function '%s'"
+msgstr ""
+#: ../raster/r.mapcalc/evaluate.c:163
+#, c-format
+msgid "Invalid return type for function '%s'"
+msgstr ""
+#: ../raster/r.mapcalc/evaluate.c:167
+#, c-format
+msgid "Unknown type for function '%s'"
+msgstr ""
+#: ../raster/r.mapcalc/evaluate.c:170
+#, c-format
+msgid "Number of arguments for function '%s'"
+msgstr ""
+#: ../raster/r.mapcalc/evaluate.c:174
+#, c-format
+msgid "Unknown error for function '%s'"
+msgstr ""
+#: ../raster/r.mapcalc/map.c:83 ../raster/r.mapcalc/map3.c:177
+#, c-format
+msgid "Unable to read color file for raster map <%s@%s>"
+msgstr ""
+#: ../raster/r.mapcalc/map.c:96 ../raster/r.mapcalc/map3.c:190
+#, c-format
+msgid "Unable to create btree for raster map <%s@%s>"
+msgstr ""
+#: ../raster/r.mapcalc/map.c:141 ../raster/r.mapcalc/map.c:353
+#: ../raster/r.mapcalc/map.c:394 ../raster/r.mapcalc/map.c:484
+#: ../raster/r.mapcalc/expression.c:356 ../raster/r.mapcalc/map3.c:235
+#: ../raster/r.mapcalc/map3.c:417 ../raster/r.mapcalc/map3.c:461
+#: ../raster/r.mapcalc/map3.c:552
+#, c-format
+msgid "Invalid map modifier: '%c'"
+msgstr ""
+#: ../raster/r.mapcalc/map.c:249
+msgid "Rowio_setup failed"
+msgstr ""
+#: ../raster/r.mapcalc/map.c:292
+msgid "Rowio_get failed"
+msgstr ""
+#: ../raster/r.mapcalc/map.c:309 ../raster/r.mapcalc/map3.c:367
+#, c-format
+msgid "Unable to close raster map <%s@%s>"
+msgstr ""
+#: ../raster/r.mapcalc/map.c:515
+msgid "Failed writing raster map row"
+msgstr ""
+#: ../raster/r.mapcalc/expression.c:204
+#, c-format
+msgid "Undefined variable '%s'"
+msgstr ""
+#: ../raster/r.mapcalc/expression.c:219
+#, c-format
+msgid "Invalid map <%s>"
+msgstr ""
+#: ../raster/r.mapcalc/expression.c:261
+#, c-format
+msgid "Undefined function '%s'"
+msgstr ""
+#: ../raster/r.mapcalc/expression.c:266
+#, c-format
+msgid "Too few arguments (%d) to function %s()"
+msgstr ""
+#: ../raster/r.mapcalc/expression.c:270
+#, c-format
+msgid "Too many arguments (%d) to function %s()"
+msgstr ""
+#: ../raster/r.mapcalc/expression.c:274
+#, c-format
+msgid "Incorrect argument types to function %s()"
+msgstr ""
+#: ../raster/r.mapcalc/expression.c:277
+#, c-format
+msgid "Internal error for function %s()"
+msgstr ""
+#: ../raster/r.mapcalc/expression.c:447
+#, c-format
+msgid "Illegal number of arguments (%d) for operator '%s'"
+msgstr ""
+#: ../raster/r.mapcalc/expression.c:487
+#, c-format
+msgid "Format_expression_prec: unknown type: %d"
+msgstr ""
+#: ../raster/r.mapcalc/map3.c:124 ../raster/r.mapcalc/map3.c:138
+#: ../raster/r.mapcalc/map3.c:152 ../raster/r.out.bin/main.c:53
+#: ../raster/r.out.bin/main.c:62 ../raster/r.out.bin/main.c:461
+msgid "Error writing data"
+msgstr ""
+#: ../raster/r.mapcalc/map3.c:605
+msgid "Unable to close output raster map"
+msgstr ""
+#: ../raster/r.mapcalc/function.c:93
+#, c-format
+msgid "Known functions:"
+msgstr ""
+#: ../raster/r.mapcalc/main.c:145
+msgid "Floating point error(s) occured in the calculation"
+msgstr ""
+#: ../raster/r.mapcalc/main.c:150
+msgid "Overflow occured in the calculation"
+msgstr ""
+#: ../raster/r.null/null.c:58
+msgid "raster, null data"
+msgstr ""
+#: ../raster/r.null/null.c:59
+msgid "Manages NULL-values of given raster map."
+msgstr ""
+#: ../raster/r.null/null.c:62
+msgid "Name of raster map for which to edit null file"
+msgstr ""
+#: ../raster/r.null/null.c:71 ../raster/r.null/null.c:79
+msgid "Modify"
+msgstr ""
+#: ../raster/r.null/null.c:83
+msgid "Only do the work if the map is floating-point"
+msgstr ""
+#: ../raster/r.null/null.c:84 ../raster/r.null/null.c:89
+#: ../raster/r.null/null.c:95
+msgid "Check"
+msgstr ""
+#: ../raster/r.null/null.c:88
+msgid "Only do the work if the map is integer"
+msgstr ""
+#: ../raster/r.null/null.c:94
+msgid "Only do the work if the map doesn't have a NULL-value bitmap file"
+msgstr ""
+#: ../raster/r.null/null.c:100
+msgid "Create NULL-value bitmap file validating all data cells"
+msgstr ""
+#: ../raster/r.null/null.c:104
+msgid "Remove NULL-value bitmap file"
+msgstr ""
+#: ../raster/r.null/null.c:123
+#, c-format
+msgid ""
+"Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy "
+"with r.mapcalc. Exiting."
+msgstr ""
+#: ../raster/r.null/null.c:129
+#, c-format
+msgid "Raster map <%s> is not in your mapset <%s>"
+msgstr ""
+#: ../raster/r.null/null.c:136
+#, c-format
+msgid "%s is illegal entry for null"
+msgstr ""
+#: ../raster/r.null/null.c:143
+#, c-format
+msgid "Raster map <%s> already has a null bitmap file"
+msgstr ""
+#: ../raster/r.null/null.c:147
+#, c-format
+msgid "<%s> is integer raster map (CELL)"
+msgstr ""
+#: ../raster/r.null/null.c:151
+#, c-format
+msgid "<%s> is integer raster map (CELL). Using null=%d."
+msgstr ""
+#: ../raster/r.null/null.c:157
+#, c-format
+msgid "<%s> is floating pointing raster map"
+msgstr ""
+#: ../raster/r.null/null.c:175
+#, c-format
+msgid "Writing new null file for raster map <%s>..."
+msgstr ""
+#: ../raster/r.null/null.c:182
+#, c-format
+msgid "Error writing null row %d"
+msgstr ""
+#: ../raster/r.null/null.c:187 ../raster/r.null/null.c:200
+#, c-format
+msgid "Raster map <%s> modified."
+msgstr ""
+#: ../raster/r.null/null.c:194
+#, c-format
+msgid "Removing null file for raster map <%s>..."
+msgstr ""
+#: ../raster/r.null/null.c:264
+#, c-format
+msgid "%s: %s: illegal value spec"
+msgstr ""
+#: ../raster/r.null/null.c:333
+#, c-format
+msgid "Writing new data for raster map <%s>..."
+msgstr ""
+#: ../raster/r.transect/main.c:54
+msgid "raster, transect"
+msgstr ""
+#: ../raster/r.transect/main.c:56
+msgid ""
+"Outputs raster map layer values lying along user defined transect line(s)."
+msgstr ""
+#: ../raster/r.transect/main.c:60
+msgid "Raster map to be queried"
+msgstr ""
+#: ../raster/r.transect/main.c:76
+msgid "Transect definition"
+msgstr ""
+#: ../raster/r.transect/main.c:97 ../raster/r.profile/main.c:97
+msgid "Output easting and northing in first two columns of four column output"
+msgstr ""
+#: ../raster/r.transect/main.c:155
+#, c-format
+msgid "End coordinate: %.15g, %.15g"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:81
+msgid "Import GDAL supported raster file into a binary raster map layer."
+msgstr ""
+#: ../raster/r.in.gdal/main.c:87
+msgid "Raster file to be imported"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:100
+msgid "Band to select (default is all bands)"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:106 ../raster/r.proj.seg/main.c:194
+msgid "Cache size (MiB)"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:113
+msgid "Name of location to read projection from for GCPs transformation"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:150
+msgid "Force Lat/Lon maps to fit into geographic coordinates (90N,S; 180E,W)"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:176
+msgid "You have to specify a target location different from output location"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:180
+msgid "The '-l' flag only works in Lat/Lon locations"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:198
+msgid "Available GDAL Drivers:"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:233 ../raster/r.basins.fill/main.c:99
+#, c-format
+msgid "Raster map <%s> already exists"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:250
+msgid ""
+"The polynomial rectification used in i.rectify does not work well with NOAA/"
+"AVHRR data. Try using gdalwarp with thin plate spline rectification instead. "
+"(-tps)"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:266
+msgid ""
+"Input raster map is flipped or rotated - cannot import. You may use "
+"'gdalwarp' to transform the map to North-up."
+msgstr ""
+#: ../raster/r.in.gdal/main.c:308
+msgid ""
+"Map bounds have been constrained to geographic coordinates. You will almost "
+"certainly want to check map bounds and resolution with r.info and reset them "
+"with r.region before going any further."
+msgstr ""
+#: ../raster/r.in.gdal/main.c:328
+msgid ""
+"Unable to convert input map projection to GRASS format; cannot create new "
+"location."
+msgstr ""
+#: ../raster/r.in.gdal/main.c:334
+#, c-format
+msgid "Location <%s> created"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:432
+msgid ""
+"\n"
+"You can use the -o flag to r.in.gdal to override this check and use the "
+"location definition for the dataset.\n"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:551
+#, c-format
+msgid "Copying %d GCPS in points file for <%s>"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:556
+msgid "GCPs have the following OpenGIS WKT Coordinate System:"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:563
+msgid "Re-projecting GCPs table:"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:564
+#, c-format
+msgid "* Input projection for GCP table: %s"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:566
+#, c-format
+msgid "* Output projection for GCP table: %s"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:583
+#, c-format
+msgid "Error in pj_do_proj (can't re-projection GCP %i)"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:652
+msgid "Unable to translate projection key values of input GCPs"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:668
+msgid "Unable to get projection info of target location"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:670
+msgid "Unable to get projection units of target location"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:672
+msgid "Unable to get projection key values of target location"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:945
+#, c-format
+msgid "Setting grey color table for <%s> (8bit, full range)"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:958
+#, c-format
+msgid "Setting grey color table for <%s> (16bit, image range)"
+msgstr ""
+#: ../raster/r.fill.dir/resolve.c:135
+#, c-format
+msgid "Downward pass %d"
+msgstr ""
+#: ../raster/r.fill.dir/resolve.c:172
+#, c-format
+msgid "Upward pass %d"
+msgstr ""
+#: ../raster/r.fill.dir/dopolys.c:83
+#, c-format
+msgid "Found %d unresolved areas"
+msgstr ""
+#: ../raster/r.fill.dir/wtrshed.c:94
+#, c-format
+msgid "wtrshed pass %d"
+msgstr ""
+#: ../raster/r.fill.dir/main.c:86
+msgid ""
+"Filters and generates a depressionless elevation map and a flow direction "
+"map from a given elevation raster map."
+msgstr ""
+#: ../raster/r.fill.dir/main.c:91
+msgid "Name of existing raster map containing elevation surface"
+msgstr ""
+#: ../raster/r.fill.dir/main.c:98
+msgid "Output elevation raster map after filling"
+msgstr ""
+#: ../raster/r.fill.dir/main.c:105
+msgid "Output direction raster map"
+msgstr ""
+#: ../raster/r.fill.dir/main.c:112
+msgid "Output raster map of problem areas"
+msgstr ""
+#: ../raster/r.fill.dir/main.c:119
+msgid "Output aspect direction format (agnps, answers, or grass)"
+msgstr ""
+#: ../raster/r.fill.dir/main.c:127
+msgid "Find unresolved areas only"
+msgstr ""
+#: ../raster/r.fill.dir/main.c:212
+msgid "Reading map..."
+msgstr ""
+#: ../raster/r.fill.dir/main.c:220
+msgid "Filling sinks..."
+msgstr ""
+#: ../raster/r.fill.dir/main.c:224
+msgid "Determining flow directions for ambiguous cases..."
+msgstr ""
+#: ../raster/r.fill.dir/main.c:237
+msgid "Repeat to get the final directions..."
+msgstr ""
+#: ../raster/r.surf.gauss/main.c:48
+msgid ""
+"GRASS module to produce a raster map layer of gaussian deviates whose mean "
+"and standard deviation can be expressed by the user. It uses a gaussian "
+"random number generator."
+msgstr ""
+#: ../raster/r.surf.gauss/main.c:55
+msgid "Name of the output random surface"
+msgstr ""
+#: ../raster/r.surf.gauss/main.c:59
+msgid "Distribution mean"
+msgstr ""
+#: ../raster/r.surf.gauss/main.c:65
+msgid "Standard deviation"
+msgstr ""
+#: ../raster/r.cost/btree.c:58
+#, c-format
+msgid "NULL value computed (row %d, col %d)"
+msgstr ""
+#: ../raster/r.cost/btree.c:146
+#, c-format
+msgid "Unable to find row %d, col %d: %f"
+msgstr ""
+#: ../raster/r.cost/btree.c:185
+msgid "Illegal delete request"
+msgstr ""
+#: ../raster/r.cost/btree.c:403
+msgid "Bad start cell"
+msgstr ""
+#: ../raster/r.cost/btree.c:417
+#, c-format
+msgid "%s %f-%f lower cost higher or equal"
+msgstr ""
+#: ../raster/r.cost/btree.c:423
+#, c-format
+msgid "%s lower above pointer wrong"
+msgstr ""
+#: ../raster/r.cost/btree.c:430
+#, c-format
+msgid "%s %f-%f higher cost lower"
+msgstr ""
+#: ../raster/r.cost/btree.c:436
+#, c-format
+msgid "%s higher above pointer wrong"
+msgstr ""
+#: ../raster/r.cost/main.c:126
+msgid ""
+"Creates a raster map showing the cumulative cost of moving between different "
+"geographic locations on an input raster map whose cell category values "
+"represent cost."
+msgstr ""
+#: ../raster/r.cost/main.c:133
+msgid "Name of raster map containing grid cell cost information"
+msgstr ""
+#: ../raster/r.cost/main.c:140
+msgid "Name of starting vector points map"
+msgstr ""
+#: ../raster/r.cost/main.c:141 ../raster/r.cost/main.c:153
+#: ../raster/r.cost/main.c:162 ../raster/r.cost/main.c:212
+#: ../raster/r.drain/main.c:110 ../raster/r.drain/main.c:116
+msgid "Start"
+msgstr ""
+#: ../raster/r.cost/main.c:146
+msgid "Name of stop vector points map"
+msgstr ""
+#: ../raster/r.cost/main.c:147 ../raster/r.cost/main.c:171
+msgid "Stop"
+msgstr ""
+#: ../raster/r.cost/main.c:152
+msgid "Name of starting raster points map"
+msgstr ""
+#: ../raster/r.cost/main.c:161
+msgid "Map grid coordinates of a starting point (E,N)"
+msgstr ""
+#: ../raster/r.cost/main.c:170
+msgid "Map grid coordinates of a stopping point (E,N)"
+msgstr ""
+#: ../raster/r.cost/main.c:180
+msgid "Optional maximum cumulative cost"
+msgstr ""
+#: ../raster/r.cost/main.c:207
+msgid "Keep null values in output raster map"
+msgstr ""
+#: ../raster/r.cost/main.c:272
+msgid "Must specify exactly one of start_points, start_rast or coordinate"
+msgstr ""
+#: ../raster/r.cost/main.c:277 ../raster/r.cost/main.c:529
+#: ../raster/r.cost/main.c:635
+msgid "No start points"
+msgstr ""
+#: ../raster/r.cost/main.c:306
+msgid "Assigning negative cost to null cell. Null cells excluded."
+msgstr ""
+#: ../raster/r.cost/main.c:457
+msgid "Initializing output..."
+msgstr ""
+#: ../raster/r.cost/main.c:496 ../raster/r.drain/main.c:208
+msgid "Failed to guess site file format"
+msgstr ""
+#: ../raster/r.cost/main.c:546
+msgid "Failed to guess site file format\n"
+msgstr ""
+#: ../raster/r.cost/main.c:666
+msgid "Finding cost path..."
+msgstr ""
+#: ../raster/r.cost/main.c:891
+msgid "No data"
+msgstr ""
+#: ../raster/r.cost/main.c:1036
+#, c-format
+msgid "Peak cost value: %f."
+msgstr ""
+#: ../raster/r.random.surface/init.c:40
+msgid "Name for output raster map(s)"
+msgstr ""
+#: ../raster/r.random.surface/init.c:58
+msgid "Maximum distance of spatial correlation (value >= 0.0)"
+msgstr ""
+#: ../raster/r.random.surface/init.c:67
+msgid "Distance decay exponent (value > 0.0)"
+msgstr ""
+#: ../raster/r.random.surface/init.c:76
+msgid "Distance filter remains flat before beginning exponent"
+msgstr ""
+#: ../raster/r.random.surface/init.c:84
+msgid "Random seed (SEED_MIN >= value >= SEED_MAX) (default: random)"
+msgstr ""
+#: ../raster/r.random.surface/init.c:91
+msgid "Maximum cell value of distribution"
+msgstr ""
+#: ../raster/r.random.surface/init.c:96
+msgid "Uniformly distributed cell values"
+msgstr ""
+#: ../raster/r.random.surface/init.c:101
+msgid "No (quiet) description during run"
+msgstr ""
+#: ../raster/r.random.surface/init.c:163
+#, c-format
+msgid "High (%d) must be greater than 1"
+msgstr ""
+#: ../raster/r.random.surface/init.c:173
+#, c-format
+msgid "Rastar map <%s> repeated, maps must be unique"
+msgstr ""
+#: ../raster/r.random.surface/init.c:183
+msgid "Output raster map required"
+msgstr ""
+#: ../raster/r.random.surface/init.c:205
+#, c-format
+msgid "Seed (%d) larger than maximum (%d)"
+msgstr ""
+#: ../raster/r.random.surface/init.c:208 ../raster/r.random.surface/init.c:217
+#, c-format
+msgid " seed is set to %d"
+msgstr ""
+#: ../raster/r.random.surface/init.c:213
+#, c-format
+msgid "Seed (%d) smaller than minimum (%d)"
+msgstr ""
+#: ../raster/r.random.surface/init.c:256
+#, c-format
+msgid "Distance value (%d): %lf must be >= 0.0"
+msgstr ""
+#: ../raster/r.random.surface/init.c:285
+#, c-format
+msgid "Exponent value (%lf) must be > 0.0"
+msgstr ""
+#: ../raster/r.random.surface/init.c:309
+#, c-format
+msgid "Flat value (%lf) must be less than distance value (%lf)"
+msgstr ""
+#: ../raster/r.random.surface/init.c:330
+msgid "Must have a distance value for each filter"
+msgstr ""
+#: ../raster/r.random.surface/init.c:362
+msgid "Must have a exponent value for each filter"
+msgstr ""
+#: ../raster/r.random.surface/init.c:379
+msgid "Must have a weight value for each filter"
+msgstr ""
+#: ../raster/r.random.surface/init.c:425
+#, c-format
+msgid "<%s> is an ilegal name"
+msgstr ""
+#: ../raster/r.random.surface/main.c:43
+msgid "raster, random, surface"
+msgstr ""
+#: ../raster/r.random.surface/main.c:45
+msgid "Generates random surface(s) with spatial dependence."
+msgstr ""
+#: ../raster/r.random.surface/main.c:57 ../raster/r.random.cells/init.c:115
+#, c-format
+msgid "Generating raster map <%s>..."
+msgstr ""
+#: ../raster/r.random.cells/init.c:34
+msgid "Maximum distance of spatial correlation (value(s) >= 0.0)"
+msgstr ""
+#: ../raster/r.random.cells/init.c:41
+msgid "Random seed (SEED_MIN >= value >= SEED_MAX) (default [random])"
+msgstr ""
+#: ../raster/r.random.cells/init.c:96
+msgid "Distance must be >= 0.0"
+msgstr ""
+#: ../raster/r.random.cells/random.c:51
+#, c-format
+msgid "RAN1: j == %d shouldn't happen"
+msgstr ""
+#: ../raster/r.random.cells/main.c:35
+msgid "raster, random, cell"
+msgstr ""
+#: ../raster/r.random.cells/main.c:37
+msgid "Generates random cell values with spatial dependence."
+msgstr ""
+#: ../raster/r.grow.distance/main.c:132
+msgid "Generates a raster map layer of distance to features in input layer."
+msgstr ""
+#: ../raster/r.grow.distance/main.c:139
+msgid "Name for distance output map"
+msgstr ""
+#: ../raster/r.grow.distance/main.c:144
+msgid "Name for value output map"
+msgstr ""
+#: ../raster/r.grow.distance/main.c:162
+msgid "At least one of distance= and value= must be given"
+msgstr ""
+#: ../raster/r.grow.distance/main.c:182
+#, c-format
+msgid "Unable to create distance map <%s>"
+msgstr ""
+#: ../raster/r.grow.distance/main.c:188
+#, c-format
+msgid "Unable to create value map <%s>"
+msgstr ""
+#: ../raster/r.grow.distance/main.c:194
+#, c-format
+msgid "Unable to create temporary file <%s>"
+msgstr ""
+#: ../raster/r.grow.distance/main.c:322 ../raster/r.colors/main.c:390
+#: ../raster/r.colors.out/main.c:91
+#, c-format
+msgid "Unable to read color table for raster map <%s>"
+msgstr ""
+#: ../raster/r.what.color/main.c:89
+msgid "Queries colors for a raster map layer."
+msgstr ""
+#: ../raster/r.what.color/main.c:97
+msgid "Name of existing raster map to query colors"
+msgstr ""
+#: ../raster/r.what.color/main.c:104
+msgid "Values to query colors for"
+msgstr ""
+#: ../raster/r.what.color/main.c:111
+msgid "Output format (printf-style)"
+msgstr ""
+#: ../raster/r.what.color/main.c:115
+msgid "Read values from stdin"
+msgstr ""
+#: ../raster/r.what.color/main.c:121
+msgid "Either \"-i\" or \"value=\" must be given"
+msgstr ""
+#: ../raster/r.proj.seg/readcell.c:80
+msgid "Error reading input"
+msgstr ""
+#: ../raster/r.proj.seg/main.c:214
+msgid "Print input map's bounds in the current projection and exit"
+msgstr ""
+#: ../raster/r.proj.seg/main.c:220
+msgid ""
+"Print input map's bounds in the current projection and exit (shell style)"
+msgstr ""
+#: ../raster/r.proj.seg/main.c:253
+msgid "Input and output locations are the same"
+msgstr ""
+#: ../raster/r.proj.seg/main.c:349
+#, c-format
+msgid "Input map <%s@%s> in location <%s>:"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:61
+msgid "Converts a raster map layer into an ASCII text file."
+msgstr ""
+#: ../raster/r.out.ascii/main.c:70 ../raster/r.out.pov/main.c:131
+msgid "Name of an existing raster map"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:78
+msgid "Name for output ASCII grid map (use out=- for stdout)"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:92
+msgid ""
+"Number of values printed before wrapping a line (only SURFER or MODFLOW "
+"format)"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:100
+msgid "String to represent null cell (GRASS grid only)"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:108
+msgid "Write SURFER (Golden Software) ASCII grid"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:112
+msgid "Write MODFLOW (USGS) ASCII array"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:116
+msgid "Force output of integer values"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:123
+msgid "Failed to interpret dp as an integer"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:131
+msgid "Failed to interpret width as an integer"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:137
+msgid "Both -s and -h doesn't make sense"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:140
+msgid "Use -M or -s, not both"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:181
+#, c-format
+msgid "Unable to read fp range for <%s>"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:197
+#, c-format
+msgid "Read failed at row %d"
+msgstr ""
+#: ../raster/r.basins.fill/main.c:55
+msgid "Generates watershed subbasins raster map."
+msgstr ""
+#: ../raster/r.basins.fill/main.c:59
+msgid "Name of input coded stream network raster map"
+msgstr ""
+#: ../raster/r.basins.fill/main.c:63
+msgid "Name of input thinned ridge network raster map"
+msgstr ""
+#: ../raster/r.basins.fill/main.c:72
+msgid "Number of passes through the dataset"
+msgstr ""
+#: ../raster/r.basins.fill/main.c:131
+msgid "Forward sweep complete"
+msgstr ""
+#: ../raster/r.basins.fill/main.c:148
+msgid "Reverse sweep complete"
+msgstr ""
+#: ../raster/r.stats/cell_stats.c:51
+#, c-format
+msgid "Unable to read raster <map %d of %d> row %d"
+msgstr ""
+#: ../raster/r.stats/main.c:105
+msgid "Generates area statistics for raster map layers."
+msgstr ""
+#: ../raster/r.stats/main.c:127 ../raster/r.describe/main.c:72
+msgid "String representing no data cell value"
+msgstr ""
+#: ../raster/r.stats/main.c:136 ../raster/r.report/parse.c:91
+msgid "Number of fp subranges to collect stats from"
+msgstr ""
+#: ../raster/r.stats/main.c:142
+msgid "One cell (range) per line"
+msgstr ""
+#: ../raster/r.stats/main.c:146
+msgid "Print averaged values instead of intervals"
+msgstr ""
+#: ../raster/r.stats/main.c:151
+msgid "Print area totals"
+msgstr ""
+#: ../raster/r.stats/main.c:156
+msgid "Print cell counts"
+msgstr ""
+#: ../raster/r.stats/main.c:162
+msgid "Print APPROXIMATE percents (total percent may not be 100%)"
+msgstr ""
+#: ../raster/r.stats/main.c:167
+msgid "Print category labels"
+msgstr ""
+#: ../raster/r.stats/main.c:172
+msgid "Print grid coordinates (east and north)"
+msgstr ""
+#: ../raster/r.stats/main.c:177
+msgid "Print x and y (column and row)"
+msgstr ""
+#: ../raster/r.stats/main.c:182
+msgid "Print raw indexes of fp ranges (fp maps only)"
+msgstr ""
+#: ../raster/r.stats/main.c:187 ../raster/r.describe/main.c:94
+msgid "Suppress reporting of any NULLs"
+msgstr ""
+#: ../raster/r.stats/main.c:192
+msgid "Suppress reporting of NULLs when all values are NULL"
+msgstr ""
+#: ../raster/r.stats/main.c:196 ../raster/r.report/parse.c:122
+msgid "Report for cats fp ranges (fp maps only)"
+msgstr ""
+#: ../raster/r.stats/main.c:200 ../raster/r.report/parse.c:127
+msgid "Read fp map as integer (use map's quant rules)"
+msgstr ""
+#: ../raster/r.stats/main.c:214
+#, c-format
+msgid "'%s' must be greater than zero; using %s=255"
+msgstr ""
+#: ../raster/r.stats/main.c:261 ../raster/r.series/main.c:202
+msgid "Raster map not found"
+msgstr ""
+#: ../raster/r.stats/main.c:284
+#, c-format
+msgid ""
+"Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option "
+"will be ignored."
+msgstr ""
+#: ../raster/r.stats/main.c:301
+#, c-format
+msgid ""
+"Cats for raster map <%s> are either missing or have no explicit labels. "
+"Using %s=%d."
+msgstr ""
+#: ../raster/r.stats/main.c:308
+#, c-format
+msgid ""
+"Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' "
+"option"
+msgstr ""
+#: ../raster/r.stats/main.c:315 ../raster/r.contour/main.c:165
+#: ../raster/r.recode/read_rules.c:19
+#, c-format
+msgid "Unable to read fp range of raster map <%s>"
+msgstr ""
+#: ../raster/r.stats/main.c:342
+#, c-format
+msgid "Unable to read range for map <%s>"
+msgstr ""
+#: ../raster/r.in.poly/get_item.c:75
+#, c-format
+msgid "Illegal coordinate <%s, %s>, skipping."
+msgstr ""
+#: ../raster/r.in.poly/get_item.c:80
+#, c-format
+msgid "Illegal north coordinate <%s>, skipping."
+msgstr ""
+#: ../raster/r.in.poly/get_item.c:85
+#, c-format
+msgid "Illegal east coordinate <%s>, skipping."
+msgstr ""
+#: ../raster/r.in.poly/poly2rast.c:36
+#, c-format
+msgid "Can't create raster map <%s>"
+msgstr ""
+#: ../raster/r.in.poly/poly2rast.c:56 ../raster/r.in.xyz/main.c:528
+#, c-format
+msgid "Pass #%d (of %d) ..."
+msgstr ""
+#: ../raster/r.in.poly/main.c:31
+msgid "Creates raster maps from ASCII polygon/line/point data files."
+msgstr ""
+#: ../raster/r.in.poly/main.c:35
+msgid "Name of input file; or \"-\" to read from stdin"
+msgstr ""
+#: ../raster/r.in.poly/main.c:59
+msgid "Minimum number of rows to hold in memory is 1"
+msgstr ""
+#: ../raster/r.drain/main.c:96
+msgid "Traces a flow through an elevation model on a raster map."
+msgstr ""
+#: ../raster/r.drain/main.c:109
+msgid "Map coordinates of starting point(s) (E,N)"
+msgstr ""
+#: ../raster/r.drain/main.c:115
+msgid "Name of vector map(s) containing starting point(s)"
+msgstr ""
+#: ../raster/r.drain/main.c:120
+msgid "Copy input cell values on output"
+msgstr ""
+#: ../raster/r.drain/main.c:124
+msgid "Accumulate input values along the path"
+msgstr ""
+#: ../raster/r.drain/main.c:128
+msgid "Count cell numbers along the path"
+msgstr ""
+#: ../raster/r.drain/main.c:149
+msgid "Specify just one of the -c, -a and -n flags"
+msgstr ""
+#: ../raster/r.drain/main.c:168
+msgid "Metrics allocation"
+msgstr ""
+#: ../raster/r.drain/main.c:179
+#, c-format
+msgid "Starting point %d is outside the current region"
+msgstr ""
+#: ../raster/r.drain/main.c:187 ../raster/r.drain/main.c:228
+msgid "Too many start points"
+msgstr ""
+#: ../raster/r.drain/main.c:234
+#, c-format
+msgid "Starting vector map <%s> contains no points in the current region"
+msgstr ""
+#: ../raster/r.drain/main.c:240
+msgid "No start/stop point(s) specified"
+msgstr ""
+#: ../raster/r.drain/main.c:300
+msgid "Calculating flow directions..."
+msgstr ""
+#: ../raster/r.out.ppm/main.c:56
+msgid ""
+"Converts a GRASS raster map to a PPM image file at the pixel resolution of "
+"the currently defined region."
+msgstr ""
+#: ../raster/r.out.ppm/main.c:64
+msgid "Name for new PPM file (use '-' for stdout)"
+msgstr ""
+#: ../raster/r.out.ppm/main.c:73
+msgid "Output greyscale instead of color"
+msgstr ""
+#: ../raster/r.out.ppm/main.c:138
+#, c-format
+msgid "Unable to open file <%s> for write"
+msgstr ""
+#: ../raster/r.out.ppm/main.c:167
+msgid "Converting..."
+msgstr ""
+#: ../raster/r.out.ppm/main.c:250
+#, c-format
+msgid "File <%s> created"
+msgstr ""
+#: ../raster/r.out.bin/main.c:139
+#, c-format
+msgid "Header File = %s"
+msgstr ""
+#: ../raster/r.out.bin/main.c:144 ../raster/r.out.bin/main.c:228
+#: ../raster/r.out.bin/main.c:407
+#, c-format
+msgid "Unable to create file <%s>"
+msgstr ""
+#: ../raster/r.out.bin/main.c:223
+#, c-format
+msgid "World File = %s"
+msgstr ""
+#: ../raster/r.out.bin/main.c:280
+msgid "Exports a GRASS raster map to a binary array."
+msgstr ""
+#: ../raster/r.out.bin/main.c:296
+msgid "Name for output binary map (use output=- for stdout)"
+msgstr ""
+#: ../raster/r.out.bin/main.c:303
+msgid "Value to write out for null"
+msgstr ""
+#: ../raster/r.out.bin/main.c:322
+msgid "Generate integer output"
+msgstr ""
+#: ../raster/r.out.bin/main.c:326
+msgid "Generate floating-point output"
+msgstr ""
+#: ../raster/r.out.bin/main.c:330
+msgid "Export array with GMT compatible header"
+msgstr ""
+#: ../raster/r.out.bin/main.c:334
+msgid "Generate BIL world and header files"
+msgstr ""
+#: ../raster/r.out.bin/main.c:338
+msgid "Byte swap output"
+msgstr ""
+#: ../raster/r.out.bin/main.c:344
+msgid "Invalid value for null (integers only)"
+msgstr ""
+#: ../raster/r.out.bin/main.c:366
+msgid "order= and -s are mutually exclusive"
+msgstr ""
+#: ../raster/r.out.bin/main.c:375
+msgid "-i and -f are mutually exclusive"
+msgstr ""
+#: ../raster/r.out.bin/main.c:394
+msgid "Floating-point output requires bytes=4 or bytes=8"
+msgstr ""
+#: ../raster/r.out.bin/main.c:398
+msgid "Integer output doesn't support bytes=8 in this build"
+msgstr ""
+#: ../raster/r.out.bin/main.c:412
+msgid "GMT grid doesn't support 64-bit integers"
+msgstr ""
+#: ../raster/r.out.bin/main.c:418
+msgid "Creating BIL support files..."
+msgstr ""
+#: ../raster/r.out.bin/main.c:435
+#, c-format
+msgid "Exporting raster as floating values (bytes=%d)"
+msgstr ""
+#: ../raster/r.out.bin/main.c:437
+msgid "Writing GMT float format ID=1"
+msgstr ""
+#: ../raster/r.out.bin/main.c:440
+#, c-format
+msgid "Exporting raster as integer values (bytes=%d)"
+msgstr ""
+#: ../raster/r.out.bin/main.c:442
+msgid "Writing GMT integer format ID=2"
+msgstr ""
+#: ../raster/r.out.bin/main.c:445
+msgid "Using the current region settings..."
+msgstr ""
+#: ../raster/r.out.bin/main.c:446
+#, c-format
+msgid "north=%f"
+msgstr ""
+#: ../raster/r.out.bin/main.c:447
+#, c-format
+msgid "south=%f"
+msgstr ""
+#: ../raster/r.out.bin/main.c:448
+#, c-format
+msgid "east=%f"
+msgstr ""
+#: ../raster/r.out.bin/main.c:449
+#, c-format
+msgid "west=%f"
+msgstr ""
+#: ../raster/r.out.bin/main.c:450
+#, c-format
+msgid "r=%d"
+msgstr ""
+#: ../raster/r.out.bin/main.c:451
+#, c-format
+msgid "c=%d"
+msgstr ""
+#: ../raster/r.resamp.interp/main.c:74
+msgid "Resamples raster map layers to a finer grid using interpolation."
+msgstr ""
+#: ../raster/r.resamp.interp/main.c:320 ../raster/r.resamp.stats/main.c:374
+#, c-format
+msgid "Unable to read color table for %s"
+msgstr ""
+#: ../raster/r.resamp.interp/main.c:323 ../raster/r.resamp.stats/main.c:378
+#, c-format
+msgid "Unable to write color table for %s"
+msgstr ""
+#: ../raster/r.topidx/file_io.c:37
+#, c-format
+msgid ""
+"The current region resolution [%s x %s] is finer than the input map's "
+"resolution [%s x %s]. The current region resolution must be identical to, or "
+"coarser than, the input map's resolution."
+msgstr ""
+#: ../raster/r.topidx/file_io.c:44
+msgid "Reading elevation map..."
+msgstr ""
+#: ../raster/r.topidx/file_io.c:98
+msgid "Writing topographic index map..."
+msgstr ""
+#: ../raster/r.topidx/main.c:39
+msgid "Creates topographic index map from elevation raster map."
+msgstr ""
+#: ../raster/r.topidx/main.c:46
+msgid "Output topographic index map"
+msgstr ""
+#: ../raster/r.topidx/main.c:53 ../raster/r.gwflow/main.c:201
+#, c-format
+msgid "Lat/Long location is not supported by %s. Please reproject map first."
+msgstr ""
+#: ../raster/r.sun/main.c:173 ../raster/r.sun2/main.c:227
+msgid "raster, sun energy"
+msgstr ""
+#: ../raster/r.sun/main.c:174 ../raster/r.sun2/main.c:228
+msgid "Solar irradiance and irradiation model."
+msgstr ""
+#: ../raster/r.sun/main.c:176 ../raster/r.sun2/main.c:230
+msgid ""
+"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
+"for given day, latitude, surface and atmospheric conditions. Solar "
+"parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
+"irradiance, daylight length) are saved in the map history file. "
+"Alternatively, a local time can be specified to compute solar incidence "
+"angle and/or irradiance raster maps. The shadowing effect of the topography "
+"is optionally incorporated."
+msgstr ""
+#: ../raster/r.sun/main.c:206 ../raster/r.horizon/main.c:225
+#: ../raster/r.sun2/main.c:244
+msgid "Name of the input elevation raster map [meters]"
+msgstr ""
+#: ../raster/r.sun/main.c:207 ../raster/r.sun/main.c:216
+#: ../raster/r.sun/main.c:226 ../raster/r.sun/main.c:235
+#: ../raster/r.sun/main.c:243 ../raster/r.sun/main.c:255
+#: ../raster/r.sun/main.c:263 ../raster/r.sun/main.c:275
+#: ../raster/r.sun/main.c:282 ../raster/r.sun/main.c:294
+#: ../raster/r.sun/main.c:303 ../raster/r.horizon/main.c:226
+#: ../raster/r.horizon/main.c:235 ../raster/r.horizon/main.c:243
+#: ../raster/r.horizon/main.c:251 ../raster/r.horizon/main.c:259
+#: ../raster/r.horizon/main.c:267 ../raster/r.horizon/main.c:275
+#: ../raster/r.horizon/main.c:283 ../raster/r.horizon/main.c:291
+#: ../raster/r.sun2/main.c:245 ../raster/r.sun2/main.c:254
+#: ../raster/r.sun2/main.c:263 ../raster/r.sun2/main.c:272
+#: ../raster/r.sun2/main.c:280 ../raster/r.sun2/main.c:289
+#: ../raster/r.sun2/main.c:299 ../raster/r.sun2/main.c:309
+#: ../raster/r.sun2/main.c:319 ../raster/r.sun2/main.c:329
+#: ../raster/r.sun2/main.c:338 ../raster/r.sun2/main.c:347
+#: ../raster/r.sun2/main.c:356 ../raster/r.sun2/main.c:364
+#: ../raster/r.sun2/main.c:372 ../raster/r.watershed/front/main.c:62
+#: ../raster/r.watershed/front/main.c:68 ../raster/r.watershed/front/main.c:74
+#: ../raster/r.watershed/front/main.c:83 ../raster/r.watershed/front/main.c:90
+#: ../raster/r.watershed/front/main.c:151
+#: ../raster/r.watershed/front/main.c:159
+msgid "Input_options"
+msgstr ""
+#: ../raster/r.sun/main.c:215 ../raster/r.sun2/main.c:253
+msgid ""
+"Name of the input aspect map (terrain aspect or azimuth of the solar panel) "
+"[decimal degrees]"
+msgstr ""
+#: ../raster/r.sun/main.c:225 ../raster/r.sun2/main.c:271
+msgid ""
+"Name of the input slope raster map (terrain slope or solar panel "
+"inclination) [decimal degrees]"
+msgstr ""
+#: ../raster/r.sun/main.c:234 ../raster/r.sun2/main.c:288
+msgid ""
+"Name of the Linke atmospheric turbidity coefficient input raster map [-]"
+msgstr ""
+#: ../raster/r.sun/main.c:245 ../raster/r.sun2/main.c:298
+msgid "A single value of the Linke atmospheric turbidity coefficient [-]"
+msgstr ""
+#: ../raster/r.sun/main.c:254 ../raster/r.sun2/main.c:308
+msgid "Name of the ground albedo coefficient input raster map [-]"
+msgstr ""
+#: ../raster/r.sun/main.c:265 ../raster/r.sun2/main.c:318
+msgid "A single value of the ground albedo coefficient [-]"
+msgstr ""
+#: ../raster/r.sun/main.c:274
+msgid "Name of the latitudes input raster map [decimal degrees]"
+msgstr ""
+#: ../raster/r.sun/main.c:284
+msgid "A single value of latitude [decimal degrees]"
+msgstr ""
+#: ../raster/r.sun/main.c:293
+msgid "Name of real-sky beam radiation coefficient raster map [-]"
+msgstr ""
+#: ../raster/r.sun/main.c:302
+msgid "Name of real-sky diffuse radiation coefficient raster map [-]"
+msgstr ""
+#: ../raster/r.sun/main.c:311 ../raster/r.sun2/main.c:380
+msgid "Output incidence angle raster map (mode 1 only)"
+msgstr ""
+#: ../raster/r.sun/main.c:320 ../raster/r.sun2/main.c:389
+msgid ""
+"Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
+"day-1] (mode 2)"
+msgstr ""
+#: ../raster/r.sun/main.c:329 ../raster/r.sun2/main.c:398
+msgid "Output insolation time raster map [h] (mode 2 only)"
+msgstr ""
+#: ../raster/r.sun/main.c:338 ../raster/r.sun2/main.c:407
+msgid ""
+"Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
+"day-1] (mode 2)"
+msgstr ""
+#: ../raster/r.sun/main.c:347 ../raster/r.sun2/main.c:416
+msgid ""
+"Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster "
+"map [Wh.m-2.day-1] (mode 2)"
+msgstr ""
+#: ../raster/r.sun/main.c:354 ../raster/r.sun2/main.c:432
+msgid "No. of day of the year (1-365)"
+msgstr ""
+#: ../raster/r.sun/main.c:362 ../raster/r.sun2/main.c:441
+msgid "Time step when computing all-day radiation sums [decimal hours]"
+msgstr ""
+#: ../raster/r.sun/main.c:369 ../raster/r.sun2/main.c:448
+msgid "Declination value (overriding the internally computed value) [radians]"
+msgstr ""
+#: ../raster/r.sun/main.c:377 ../raster/r.sun2/main.c:456
+msgid "Local (solar) time (to be set for mode 1 only) [decimal hours]"
+msgstr ""
+#: ../raster/r.sun/main.c:382 ../raster/r.sun2/main.c:509
+msgid "Incorporate the shadowing effect of terrain"
+msgstr ""
+#: ../raster/r.sun/main.c:408 ../raster/r.sun2/main.c:592
+msgid "insol_time and incidout are incompatible options"
+msgstr ""
+#: ../raster/r.sun/main.c:416
+msgid "time and insol_time are incompatible options"
+msgstr ""
+#: ../raster/r.sun/main.c:417
+msgid ""
+"Mode 1: instantaneous solar incidence angle & irradiance given a set local "
+"time"
+msgstr ""
+#: ../raster/r.sun/main.c:422 ../raster/r.sun2/main.c:623
+msgid "incidout requires time parameter to be set"
+msgstr ""
+#: ../raster/r.sun/main.c:423 ../raster/r.sun2/main.c:625
+msgid "Mode 2: integrated daily irradiation for a given day of the year"
+msgstr ""
+#: ../raster/r.sun/main.c:472 ../raster/r.horizon/main.c:479
+msgid ""
+"Can't get projection info of current location: please set latitude via 'lat' "
+"or 'latin' option!"
+msgstr ""
+#: ../raster/r.sun/main.c:527
+#, c-format
+msgid "elevin raster map <%s> not found"
+msgstr ""
+#: ../raster/r.sun/main.c:530
+#, c-format
+msgid "aspin raster map <%s> not found"
+msgstr ""
+#: ../raster/r.sun/main.c:533
+#, c-format
+msgid "slopein raster map <%s> not found"
+msgstr ""
+#: ../raster/r.sun/main.c:546
+#, c-format
+msgid "linkein raster map <%s> not found"
+msgstr ""
+#: ../raster/r.sun/main.c:558
+#, c-format
+msgid "albedo raster map <%s> not found"
+msgstr ""
+#: ../raster/r.sun/main.c:570
+#, c-format
+msgid "latin raster map <%s> not found"
+msgstr ""
+#: ../raster/r.sun/main.c:582
+#, c-format
+msgid "coefbh raster map <%s> not found"
+msgstr ""
+#: ../raster/r.sun/main.c:594
+#, c-format
+msgid "coefdh raster map <%s> not found"
+msgstr ""
+#: ../raster/r.sun/main.c:734 ../raster/r.sun/main.c:741
+#: ../raster/r.sun/main.c:748 ../raster/r.sun/main.c:755
+#: ../raster/r.sun/main.c:762 ../raster/r.horizon/main.c:618
+#, c-format
+msgid "Unable to create raster map %s"
+msgstr ""
+#: ../raster/r.sun/main.c:770
+#, c-format
+msgid "rows changed from %d to %d"
+msgstr ""
+#: ../raster/r.sun/main.c:773
+#, c-format
+msgid "cols changed from %d to %d"
+msgstr ""
+#: ../raster/r.surf.idw2/main.c:61
+msgid "Surface generation program."
+msgstr ""
+#: ../raster/r.surf.idw2/main.c:80
+msgid ""
+"Lat/long databases not supported by r.surf.idw2. Use r.surf.idw instead!"
+msgstr ""
+#: ../raster/r.surf.idw2/main.c:96
+#, c-format
+msgid "%s: no data points found"
+msgstr ""
+#: ../raster/r.surf.idw2/main.c:114
+#, c-format
+msgid "Interpolating raster map <%s>... %d rows... "
+msgstr ""
+#: ../raster/r.surf.idw2/main.c:123
+msgid "Cannot get row"
+msgstr ""
+#: ../raster/r.los/main.c:82
+msgid "raster, viewshed"
+msgstr ""
+#: ../raster/r.los/main.c:83
+msgid "Line-of-sight raster analysis program."
+msgstr ""
+#: ../raster/r.los/main.c:97
+msgid "Coordinate identifying the viewing position"
+msgstr ""
+#: ../raster/r.los/main.c:102
+msgid "Binary (1/0) raster map to use as a mask"
+msgstr ""
+#: ../raster/r.los/main.c:109
+msgid "Viewing position height above the ground"
+msgstr ""
+#: ../raster/r.los/main.c:117
+msgid "Maximum distance from the viewing point (meters)"
+msgstr ""
+#: ../raster/r.los/main.c:123
+msgid "Consider earth curvature (current ellipsoid)"
+msgstr ""
+#: ../raster/r.los/main.c:150
+msgid "Lat/Long support is not (yet) implemented for this module."
+msgstr ""
+#: ../raster/r.los/main.c:155
+msgid "Specified observer coordinate is outside current region bounds."
+msgstr ""
+#: ../raster/r.los/main.c:177 ../raster/r.los/main.c:182
+#: ../raster/r.resamp.rst/main.c:405 ../raster/r.resamp.rst/main.c:428
+#, c-format
+msgid "[%s]: Cannot read map header"
+msgstr ""
+#: ../raster/r.los/main.c:211
+msgid "Pattern map should be a binary 0/1 CELL map"
+msgstr ""
+#: ../raster/r.los/main.c:245
+msgid ""
+"Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"
+msgstr ""
+#: ../raster/r.los/main.c:250
+#, c-format
+msgid "Using maximum distance from the viewing point (meters): %f"
+msgstr ""
+#: ../raster/r.colors/stats.c:79
+msgid "Unable to use logarithmic scaling if range includes zero"
+msgstr ""
+#: ../raster/r.colors/rules.c:42
+#, c-format
+msgid "Enter rules, \"end\" when done, \"help\" if you need it.\n"
+msgstr ""
+#: ../raster/r.colors/rules.c:51
+#, c-format
+msgid "fp: Data range is %s to %s\n"
+msgstr ""
+#: ../raster/r.colors/rules.c:55 ../raster/r.reclass/main.c:110
+#, c-format
+msgid "Data range is %ld to %ld\n"
+msgstr ""
+#: ../raster/r.colors/rules.c:66
+#, c-format
+msgid ""
+"Your color rules do not cover the whole range of data!\n"
+" (rules %f to %f but data %f to %f)"
+msgstr ""
+#: ../raster/r.colors/rules.c:106 ../raster/r.reclass/parse.c:40
+#, c-format
+msgid "Enter a rule in one of these formats:\n"
+msgstr ""
+#: ../raster/r.colors/rules.c:107
+#, c-format
+msgid " val color\n"
+msgstr ""
+#: ../raster/r.colors/rules.c:108
+#, c-format
+msgid " n%% color\n"
+msgstr ""
+#: ../raster/r.colors/rules.c:109
+#, c-format
+msgid " nv color\n"
+msgstr ""
+#: ../raster/r.colors/rules.c:110
+#, c-format
+msgid " default color\n"
+msgstr ""
+#: ../raster/r.colors/rules.c:111
+#, c-format
+msgid "color can be one of:\n"
+msgstr ""
+#: ../raster/r.colors/rules.c:113
+#, c-format
+msgid "or an R:G:B triplet, e.g.: 0:127:255\n"
+msgstr ""
+#: ../raster/r.colors/rules.c:134
+#, c-format
+msgid "bad rule (%s); rule not added"
+msgstr ""
+#: ../raster/r.colors/rules.c:136
+#, c-format
+msgid "bad rule (%s): [%s]"
+msgstr ""
+#: ../raster/r.colors/main.c:177
+msgid "Creates/modifies the color table associated with a raster map layer."
+msgstr ""
+#: ../raster/r.colors/main.c:206
+msgid "Path to rules file (\"-\" to read rules from stdin)"
+msgstr ""
+#: ../raster/r.colors/main.c:211
+msgid "Remove existing color table"
+msgstr ""
+#: ../raster/r.colors/main.c:216
+msgid "Only write new color table if one doesn't already exist"
+msgstr ""
+#: ../raster/r.colors/main.c:220
+msgid "List available rules then exit"
+msgstr ""
+#: ../raster/r.colors/main.c:229
+msgid "Logarithmic scaling"
+msgstr ""
+#: ../raster/r.colors/main.c:234
+msgid "Logarithmic-absolute scaling"
+msgstr ""
+#: ../raster/r.colors/main.c:239
+msgid "Histogram equalization"
+msgstr ""
+#: ../raster/r.colors/main.c:244
+msgid "Enter rules interactively"
+msgstr ""
+#: ../raster/r.colors/main.c:278
+msgid "No raster map specified"
+msgstr ""
+#: ../raster/r.colors/main.c:281
+msgid ""
+"One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must be "
+"specified!"
+msgstr ""
+#: ../raster/r.colors/main.c:284
+msgid ""
+"Interactive mode is incompatible with \"color\", \"rules\", and \"raster\" "
+"options"
+msgstr ""
+#: ../raster/r.colors/main.c:291
+msgid "\"color\", \"rules\", and \"raster\" options are mutually exclusive"
+msgstr ""
+#: ../raster/r.colors/main.c:302
+msgid "-g and -a flags are mutually exclusive"
+msgstr ""
+#: ../raster/r.colors/main.c:312
+#, c-format
+msgid "Unable to remove color table of raster map <%s>"
+msgstr ""
+#: ../raster/r.colors/main.c:314
+#, c-format
+msgid "Color table of raster map <%s> not found"
+msgstr ""
+#: ../raster/r.colors/main.c:324
+msgid "Color table exists. Exiting."
+msgstr ""
+#: ../raster/r.colors/main.c:344
+msgid "Color table 'random' is not supported for floating point raster map"
+msgstr ""
+#: ../raster/r.colors/main.c:349
+msgid "Color table 'grey.eq' is not supported for floating point raster map"
+msgstr ""
+#: ../raster/r.colors/main.c:356
+msgid "Color table 'grey.log' is not supported for floating point raster map"
+msgstr ""
+#: ../raster/r.colors/main.c:369
+#, c-format
+msgid "Unknown color request '%s'"
+msgstr ""
+#: ../raster/r.colors/main.c:380
+#, c-format
+msgid "Unable to load rules file <%s>"
+msgstr ""
+#: ../raster/r.colors/main.c:427
+#, c-format
+msgid "Color table for raster map <%s> set to '%s'"
+msgstr ""
+#: ../raster/r.timestamp/main.c:35
+msgid "raster, metadata, timestamp"
+msgstr ""
+#: ../raster/r.timestamp/main.c:36
+msgid "Modifies a timestamp for a raster map."
+msgstr ""
+#: ../raster/r.timestamp/main.c:37
+msgid "Print/add/remove a timestamp for a raster map."
+msgstr ""
+#: ../raster/r.timestamp/main.c:46
+msgid "Datetime, datetime1/datetime2, or 'none' to remove"
+msgstr ""
+#: ../raster/r.timestamp/main.c:47
+msgid "Format: '15 jan 1994' (absolute) or '2 years' (relative)"
+msgstr ""
+#: ../raster/r.timestamp/main.c:82
+msgid "Invalid timestamp"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:158
+msgid ""
+"Reinterpolates and optionally computes topographic analysis from input "
+"raster map to a new raster map (possibly with different resolution) using "
+"regularized spline with tension and smoothing."
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:169
+msgid "Desired east-west resolution"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:175
+msgid "Desired north-south resolution"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:182
+msgid "Output z-file (elevation) map"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:190
+msgid "Output slope map (or fx)"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:198
+msgid "Output aspect map (or fy)"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:206
+msgid "Output profile curvature map (or fxx)"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:214
+msgid "Output tangential curvature map (or fyy)"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:222
+msgid "Output mean curvature map (or fxy)"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:230
+msgid "Name of raster map containing smoothing"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:238
+msgid "Name of raster map to be used as mask"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:246
+msgid "Rows/columns overlap for segmentation"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:254
+msgid "Multiplier for z-values"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:262
+msgid "Spline tension value"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:269
+msgid "Anisotropy angle (in degrees)"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:270 ../raster/r.resamp.rst/main.c:277
+msgid "Anisotropy"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:281
+msgid "Use dnorm independent tension"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:321
+msgid "Cannot read ew_res value"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:324
+msgid "Cannot read ns_res value"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:327
+msgid "Invalid value for tension"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:330
+msgid "Invalid value for zmult"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:333
+msgid "Invalid value for overlap"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:337
+msgid "Invalid value for theta"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:341
+msgid "Invalid value for scalex"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:343
+msgid "When using anisotropy both theta and scalex must be specified"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:408
+#, c-format
+msgid "[%s]: Map is the wrong resolution"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:416
+msgid "Smoothing values can not be negative or NULL"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:431
+msgid "Input map resolution differs from current region resolution!"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:451
+msgid "Processing all selected output files will require"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:452
+#, c-format
+msgid "%d bytes of disk space for temp files."
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:477
+#, c-format
+msgid "Cannot get row %d (error = %d)"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:487
+msgid "Maximum value of a raster map is NULL."
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:515
+msgid "Temporarily changing the region to desired resolution ..."
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:521
+msgid "Changing back to the original region ..."
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:523
+msgid "Cannot set region to back to the initial region !!!"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:539
+#, c-format
+msgid "dnorm in mainc after grid before out1= %f"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:556
+#, c-format
+msgid "dnorm in mainc after grid before out2= %f"
+msgstr ""
+#: ../raster/r.water.outlet/main.c:48
+msgid "Watershed basin creation program."
+msgstr ""
+#: ../raster/r.water.outlet/main.c:70
+msgid "The map E grid coordinates"
+msgstr ""
+#: ../raster/r.water.outlet/main.c:78
+msgid "The map N grid coordinates"
+msgstr ""
+#: ../raster/r.water.outlet/main.c:92
+#, c-format
+msgid "Illegal east coordinate <%s>\n"
+msgstr ""
+#: ../raster/r.water.outlet/main.c:97
+#, c-format
+msgid "Illegal north coordinate <%s>\n"
+msgstr ""
+#: ../raster/r.water.outlet/main.c:104
+#, c-format
+msgid ""
+"Warning, ignoring point outside window: \n"
+"    %.4f,%.4f\n"
+msgstr ""
+#: ../raster/r.water.outlet/main.c:121
+msgid "Unable to open drainage pointer map"
+msgstr ""
+#: ../raster/r.water.outlet/main.c:146
+msgid "Unable to open new basin map"
+msgstr ""
+#: ../raster/r.water.outlet/main.c:159
+msgid "Unable to close new basin map layer"
+msgstr ""
+#: ../raster/r.his/main.c:63
+msgid "raster, color transformation"
+msgstr ""
+#: ../raster/r.his/main.c:65
+msgid ""
+"Generates red, green and blue raster map layers combining hue, intensity and "
+"saturation (HIS) values from user-specified input raster map layers."
+msgstr ""
+#: ../raster/r.his/main.c:95
+msgid "Name of output layer to be used for RED"
+msgstr ""
+#: ../raster/r.his/main.c:102
+msgid "Name of output layer to be used for GREEN"
+msgstr ""
+#: ../raster/r.his/main.c:109
+msgid "Name of output layer to be used for BLUE"
+msgstr ""
+#: ../raster/r.his/main.c:243
+msgid "Error reading 'hue' map"
+msgstr ""
+#: ../raster/r.his/main.c:247
+msgid "Error reading 'intensity' map"
+msgstr ""
+#: ../raster/r.his/main.c:251
+msgid "Error reading 'saturation' map"
+msgstr ""
+#: ../raster/r.mode/read_stats.c:14
+msgid "reading r.stats output"
+msgstr ""
+#: ../raster/r.mode/main.c:52
+msgid ""
+"Finds the mode of values in a cover map within areas assigned the same "
+"category value in a user-specified base map."
+msgstr ""
+#: ../raster/r.mode/main.c:58
+msgid "Base map to be reclassified"
+msgstr ""
+#: ../raster/r.mode/main.c:65
+msgid "Coverage map"
+msgstr ""
+#: ../raster/r.mode/main.c:72
+msgid "Output map"
+msgstr ""
+#: ../raster/r.mode/main.c:86
+#, c-format
+msgid "%s: base raster map not found"
+msgstr ""
+#: ../raster/r.mode/main.c:91
+#, c-format
+msgid "%s: cover raster map not found"
+msgstr ""
+#: ../raster/r.mode/main.c:97
+#, c-format
+msgid "%s: base map and output map must be different"
+msgstr ""
+#: ../raster/r.mode/main.c:101
+#, c-format
+msgid "%s: Unable to read category labels"
+msgstr ""
+#: ../raster/r.bitpattern/main.c:62 ../raster/r.mfilter/main.c:51
+#: ../raster/r.mfilter.fp/main.c:58
+msgid "raster, map algebra"
+msgstr ""
+#: ../raster/r.bitpattern/main.c:63
+msgid "Compares bit patterns with a raster map."
+msgstr ""
+#: ../raster/r.bitpattern/main.c:75
+msgid "Bit pattern position(s)"
+msgstr ""
+#: ../raster/r.bitpattern/main.c:81
+msgid "Bit pattern value"
+msgstr ""
+#: ../raster/r.bitpattern/main.c:151
+#, c-format
+msgid "Unable to write to <%s>"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:159
+msgid "raster, import, LIDAR"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:161
+msgid ""
+"Create a raster map from an assemblage of many coordinates using univariate "
+"statistics."
+msgstr ""
+#: ../raster/r.in.xyz/main.c:165
+msgid "ASCII file containing input data (or \"-\" to read from stdin)"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:173
+msgid "Statistic to use for raster values"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:177 ../raster/r.in.xyz/main.c:243
+#: ../raster/r.in.xyz/main.c:252
+msgid "Statistic"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:185 ../raster/r.in.arc/main.c:80
+msgid "Storage type for resultant raster map"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:196
+msgid "Column number of x coordinates in input file (first column is 1)"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:204
+msgid "Column number of y coordinates in input file"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:212
+msgid "Column number of data values in input file"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:220
+msgid "Filter range for z data (min,max)"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:227
+msgid "Scale to apply to z data"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:242
+msgid "pth percentile of the values"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:251
+msgid ""
+"Discard <trim> percent of the smallest and <trim> percent of the largest "
+"observations"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:256
+msgid "Scan data file for extent then exit"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:261
+msgid "In scan mode, print using shell script style"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:265
+msgid "Ignore broken lines"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:291
+msgid "Please specify a reasonable column number."
+msgstr ""
+#: ../raster/r.in.xyz/main.c:302
+msgid "Invalid zrange"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:389
+msgid "Unable to calculate percentile without the pth option specified!"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:401
+msgid "Unable to calculate trimmed mean without the trim option specified!"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:477
+msgid ""
+"If input is not from a file it is only possible to perform a single pass."
+msgstr ""
+#: ../raster/r.in.xyz/main.c:483
+msgid "zrange will not be taken into account during scan"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:521
+msgid "Reading data ..."
+msgstr ""
+#: ../raster/r.in.xyz/main.c:599 ../raster/r.in.xyz/main.c:607
+#: ../raster/r.in.xyz/main.c:1103 ../raster/r.in.xyz/main.c:1111
+#, c-format
+msgid ""
+"Not enough data columns. Incorrect delimiter or column number? Found the "
+"following character(s) in row %lu:\n"
+"[%s]"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:603 ../raster/r.in.xyz/main.c:1107
+msgid "Line ignored as requested"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:622 ../raster/r.in.xyz/main.c:1141
+#, c-format
+msgid "Bad y-coordinate line %lu column %d. <%s>"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:629 ../raster/r.in.xyz/main.c:1126
+#, c-format
+msgid "Bad x-coordinate line %lu column %d. <%s>"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:636 ../raster/r.in.xyz/main.c:1156
+#, c-format
+msgid "Bad z-coordinate line %lu column %d. <%s>"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:718
+msgid "Writing to map ..."
+msgstr ""
+#: ../raster/r.in.xyz/main.c:1014
+#, c-format
+msgid "Writing map, row %d"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:1061
+#, c-format
+msgid "%lu points found in region."
+msgstr ""
+#: ../raster/r.in.xyz/main.c:1088
+msgid "Scanning data ..."
+msgstr ""
+#: ../raster/r.in.xyz/main.c:1176
+#, c-format
+msgid "Range:     min         max\n"
+msgstr ""
+#: ../raster/r.report/stats.c:65
+#, c-format
+msgid "Unable to open result file <%s>"
+msgstr ""
+#: ../raster/r.report/parse.c:37
+msgid "Raster map(s) to report on"
+msgstr ""
+#: ../raster/r.report/parse.c:46
+msgid ""
+"mi;miles;me;meters;k;kilometers;a;acres;h;hectares;c;cell counts;p;percent "
+"cover"
+msgstr ""
+#: ../raster/r.report/parse.c:56
+msgid "Character representing no data cell value"
+msgstr ""
+#: ../raster/r.report/parse.c:57 ../raster/r.report/parse.c:66
+#: ../raster/r.report/parse.c:75 ../raster/r.report/parse.c:100
+#: ../raster/r.report/parse.c:105 ../raster/r.report/parse.c:110
+msgid "Formatting"
+msgstr ""
+#: ../raster/r.report/parse.c:63
+#, c-format
+msgid "Page length (default: %d lines)"
+msgstr ""
+#: ../raster/r.report/parse.c:72
+#, c-format
+msgid "Page width (default: %d characters)"
+msgstr ""
+#: ../raster/r.report/parse.c:82
+msgid "Name of an output file to hold the report"
+msgstr ""
+#: ../raster/r.report/parse.c:99
+msgid "Suppress page headers"
+msgstr ""
+#: ../raster/r.report/parse.c:104
+msgid "Use formfeeds between pages"
+msgstr ""
+#: ../raster/r.report/parse.c:109
+msgid "Scientific format"
+msgstr ""
+#: ../raster/r.report/parse.c:114
+msgid "Filter out all no data cells"
+msgstr ""
+#: ../raster/r.report/parse.c:118
+msgid "Filter out cells where all maps have no data"
+msgstr ""
+#: ../raster/r.report/parse.c:170
+msgid "nsteps has to be > 0; using nsteps=255"
+msgstr ""
+#: ../raster/r.report/parse.c:177
+msgid "Illegal page length"
+msgstr ""
+#: ../raster/r.report/parse.c:184
+msgid "Illegal page width"
+msgstr ""
+#: ../raster/r.report/parse.c:223
+#, c-format
+msgid "Only %d unit%s allowed"
+msgstr ""
+#: ../raster/r.report/parse.c:256
+#, c-format
+msgid "Unable to read fp range for raster map <%s>"
+msgstr ""
+#: ../raster/r.report/main.c:65
+msgid "Reports statistics for raster map layers."
+msgstr ""
+#: ../raster/r.support/modhist/modhist.c:38
+msgid "Which raster map needs an updated history? "
+msgstr ""
+#: ../raster/r.support/modhist/modhist.c:46
+#, c-format
+msgid "Raster file [%s] not found. Exiting."
+msgstr ""
+#: ../raster/r.support/modhist/modhist.c:51
+#, c-format
+msgid "History file for [%s] updated."
+msgstr ""
+#: ../raster/r.support/modhist/modhist.c:53
+#, c-format
+msgid "History file for [%s] not updated."
+msgstr ""
+#: ../raster/r.support/modhead/modhead.c:70
+#, c-format
+msgid "Edit header for [%s]\n"
+msgstr ""
+#: ../raster/r.support/modhead/modhead.c:73
+#, c-format
+msgid "[%s] cannot be found!"
+msgstr ""
+#: ../raster/r.support/modhead/modhead.c:76
+msgid "For what layer shall the header file be edited? "
+msgstr ""
+#: ../raster/r.support/modhead/modhead.c:86
+#, c-format
+msgid "[%s] is a reclass of [%s] - cannot edit header! Run support on [%s]."
+msgstr ""
+#: ../raster/r.support/modhead/modhead.c:90
+#, c-format
+msgid "[%s] is a reclass of [%s in %s] - cannot edit header!"
+msgstr ""
+#: ../raster/r.support/modhead/modhead.c:96
+#, c-format
+msgid "Cannot open raster map [%s]!"
+msgstr ""
+#: ../raster/r.support/modhead/modhead.c:101
+#, c-format
+msgid "Raster file [%s] is empty."
+msgstr ""
+#: ../raster/r.support/modhead/modhead.c:103
+#, c-format
+msgid "Error reading raster map [%s]."
+msgstr ""
+#: ../raster/r.support/modhead/modhead.c:191
+#, c-format
+msgid "cellhd compression: %d\n"
+msgstr ""
+#: ../raster/r.support/modhead/modhead.c:192
+#, c-format
+msgid "3.0 compression %sindicated\n"
+msgstr ""
+#: ../raster/r.support/modhead/modhead.c:194
+#, c-format
+msgid "Pre 3.0 compression %sindicated\n"
+msgstr ""
+#: ../raster/r.support/modhead/modhead.c:201
+#, c-format
+msgid "[%s] appears to be compressed. Is it? "
+msgstr ""
+#: ../raster/r.support/modhead/modhead.c:207
+msgid "Please indicate the type of compression:\n"
+msgstr ""
+#: ../raster/r.support/modhead/modhead.c:208
+msgid "  1. Pre 3.0 compression\n"
+msgstr ""
+#: ../raster/r.support/modhead/modhead.c:209
+msgid "  2. 3.0 compression\n"
+msgstr ""
+#: ../raster/r.support/modhead/modhead.c:245
+#, c-format
+msgid "The header for [%s] says the file is not compressed. "
+msgstr ""
+#: ../raster/r.support/modhead/modhead.c:247
+msgid "The file appears to be compressed.\n"
+msgstr ""
+#: ../raster/r.support/modhead/modhead.c:248
+#: ../raster/r.support/modhead/modhead.c:257
+msgid "Most likely the header is wrong, but I want you to decide.\n"
+msgstr ""
+#: ../raster/r.support/modhead/modhead.c:254
+#, c-format
+msgid "The header for [%s] says the file is compressed. "
+msgstr ""
+#: ../raster/r.support/modhead/modhead.c:256
+msgid "The file does NOT appear to be compressed.\n"
+msgstr ""
+#: ../raster/r.support/modhead/modhead.c:271
+#, c-format
+msgid ""
+"Header indicates %d row%s in the raster map, but the actual file format "
+"indicates %d row%s"
+msgstr ""
+#: ../raster/r.support/modhead/modhead.c:303
+#, c-format
+msgid "Unable to write header for [%s]."
+msgstr ""
+#: ../raster/r.support/modhead/modhead.c:305
+#, c-format
+msgid "Header for raster map [%s] updated."
+msgstr ""
+#: ../raster/r.support/modhead/hitreturn.c:12
+msgid ""
+"\n"
+"hit RETURN to continue -->"
+msgstr ""
+#: ../raster/r.support/modhead/ask_format.c:24
+#, c-format
+msgid "Please enter the following information for [%s]:"
+msgstr ""
+#: ../raster/r.support/modhead/ask_format.c:29
+msgid "        Number of rows"
+msgstr ""
+#: ../raster/r.support/modhead/ask_format.c:30
+msgid "        Number of cols"
+msgstr ""
+#: ../raster/r.support/modhead/ask_format.c:32
+msgid "        Number of bytes per cell"
+msgstr ""
+#: ../raster/r.support/modhead/ask_format.c:33
+msgid "        Floating point map"
+msgstr ""
+#: ../raster/r.support/modhead/ask_format.c:51
+#, c-format
+msgid "rows * cols * bytes per cell must be same as file size (%lu)"
+msgstr ""
+#: ../raster/r.support/modhead/ask_format.c:55
+msgid "If you need help figuring them out, just hit ESC"
+msgstr ""
+#: ../raster/r.support/modhead/ask_format.c:76
+msgid "** Negative values not allowed!"
+msgstr ""
+#: ../raster/r.support/modhead/ask_format.c:79
+msgid "** Positive values only please!"
+msgstr ""
+#: ../raster/r.support/front/check.c:29
+#, c-format
+msgid "Update the statistics (histogram, range) for [%s]? "
+msgstr ""
+#: ../raster/r.support/front/check.c:35
+#, c-format
+msgid ""
+"\n"
+"  Updating statistics for [%s]"
+msgstr ""
+#: ../raster/r.support/front/check.c:77
+#, c-format
+msgid ""
+"   Updating the number of categories for [%s]\n"
+"\n"
+msgstr ""
+#: ../raster/r.support/front/hitreturn.c:15
+msgid ""
+"\n"
+"Hit RETURN to continue -->"
+msgstr ""
+#: ../raster/r.support/front/front.c:55
+msgid "Allows creation and/or modification of raster map layer support files."
+msgstr ""
+#: ../raster/r.support/front/front.c:65
+msgid "Text to use for map title"
+msgstr ""
+#: ../raster/r.support/front/front.c:73
+msgid "Text to append to the next line of the map's metadata file"
+msgstr ""
+#: ../raster/r.support/front/front.c:79
+msgid "Text to use for map data units"
+msgstr ""
+#: ../raster/r.support/front/front.c:85
+msgid "Text to use for map vertical datum"
+msgstr ""
+#: ../raster/r.support/front/front.c:92
+msgid "Text to use for data source, line 1"
+msgstr ""
+#: ../raster/r.support/front/front.c:99
+msgid "Text to use for data source, line 2"
+msgstr ""
+#: ../raster/r.support/front/front.c:107
+msgid "Text to use for data description or keyword(s)"
+msgstr ""
+#: ../raster/r.support/front/front.c:114 ../raster/r.cats/main.c:78
+msgid "Raster map from which to copy category table"
+msgstr ""
+#: ../raster/r.support/front/front.c:125 ../raster/r.cats/main.c:136
+#, c-format
+msgid "Raster map <%s> not found in current mapset"
+msgstr ""
+#: ../raster/r.support/front/front.c:143
+msgid "Not enough room in history file"
+msgstr ""
+#: ../raster/r.support/front/front.c:234
+#, c-format
+msgid "cats table for [%s] set to %s"
+msgstr ""
+#: ../raster/r.support/front/front.c:248
+#, c-format
+msgid "Edit header for [%s]? "
+msgstr ""
+#: ../raster/r.support/front/front.c:250
+#, c-format
+msgid ""
+"\n"
+"NOTE: [%s] is a reclass of [%s in %s]"
+msgstr ""
+#: ../raster/r.support/front/front.c:264
+msgid "Canceling from edit header."
+msgstr ""
+#: ../raster/r.support/front/front.c:271
+#, c-format
+msgid "Edit the category file for [%s]? "
+msgstr ""
+#: ../raster/r.support/front/front.c:281
+#, c-format
+msgid "Create/Update the color table for [%s]? "
+msgstr ""
+#: ../raster/r.support/front/front.c:292
+#, c-format
+msgid "Edit the history file for [%s]? "
+msgstr ""
+#: ../raster/r.support/front/front.c:302
+#, c-format
+msgid ""
+"\n"
+"The null file for [%s] may indicate that some cells contain\n"
+" no data. If the null file for [%s] doesn't exist, zero cells in\n"
+" it are treated by GRASS application programs as no data."
+msgstr ""
+#: ../raster/r.support/front/front.c:308
+#, c-format
+msgid ""
+"\n"
+"Do you want to create/reset the null file for [%s] so that null cell values "
+"are considered valid data? "
+msgstr ""
+#: ../raster/r.support/front/front.c:317 ../raster/r.support/front/front.c:354
+#, c-format
+msgid "[%s] is a reclass of another map. Exiting."
+msgstr ""
+#: ../raster/r.support/front/front.c:329
+#, c-format
+msgid "Writing new null file for [%s]... "
+msgstr ""
+#: ../raster/r.support/front/front.c:334
+#, c-format
+msgid "Error writing null row [%d]."
+msgstr ""
+#: ../raster/r.support/front/front.c:346
+#, c-format
+msgid ""
+"\n"
+"Do you want to delete the null file for [%s]\n"
+"(all zero cells will then be considered no data)? "
+msgstr ""
+#: ../raster/r.support/front/front.c:360
+#, c-format
+msgid "Removing null file for [%s]...\n"
+msgstr ""
+#: ../raster/r.support/modcolr/modcolr.c:38
+msgid "Which raster map needs a color table"
+msgstr ""
+#: ../raster/r.support/modcolr/modcolr.c:53
+#, c-format
+msgid "Color table for <%s> updated"
+msgstr ""
+#: ../raster/r.support/modcats/modcats.c:46
+msgid "Which vector map needs updated categories?"
+msgstr ""
+#: ../raster/r.support/modcats/modcats.c:49
+msgid "Which raster map needs updated categories?"
+msgstr ""
+#: ../raster/r.support/modcats/modcats.c:53
+#: ../raster/r.support/modcats/modcats.c:62
+#, c-format
+msgid "%s map <%s> not found"
+msgstr ""
+#: ../raster/r.support/modcats/modcats.c:74
+#: ../raster/r.support/modcats/modcats.c:81
+#, c-format
+msgid "Category file for <%s> not updated"
+msgstr ""
+#: ../raster/r.support/modcats/modcats.c:92
+#, c-format
+msgid "Category file for <%s> updated"
+msgstr ""
+#: ../raster/r.distance/parse.c:41
+msgid "Maps for computing inter-class distances"
+msgstr ""
+#: ../raster/r.distance/parse.c:54
+msgid "Include category labels in the output"
+msgstr ""
+#: ../raster/r.distance/parse.c:59
+msgid "Report zero distance if rasters are overlapping"
+msgstr ""
+#: ../raster/r.distance/edges.c:42
+#, c-format
+msgid "Reading map %s ..."
+msgstr ""
+#: ../raster/r.distance/distance.c:99
+#, c-format
+msgid "Reading maps  <%s,%s> while finding 0 distance ..."
+msgstr ""
+#: ../raster/r.distance/report.c:41
+msgid "Processing..."
+msgstr ""
+#: ../raster/r.distance/main.c:38
+msgid "raster, distance"
+msgstr ""
+#: ../raster/r.distance/main.c:40
+msgid "Locates the closest points between objects in two raster maps."
+msgstr ""
+#: ../raster/r.resamp.stats/main.c:261
+msgid "Resamples raster map layers to a coarser grid using aggregation."
+msgstr ""
+#: ../raster/r.resamp.stats/main.c:271
+msgid "Aggregation method"
+msgstr ""
+#: ../raster/r.resamp.stats/main.c:277 ../raster/r.series/main.c:180
+msgid "Propagate NULLs"
+msgstr ""
+#: ../raster/r.resamp.stats/main.c:281
+msgid "Weight according to area (slower)"
+msgstr ""
+#: ../raster/r.resamp.stats/main.c:290 ../raster/r.series/main.c:101
+#, c-format
+msgid "Unknown method <%s>"
+msgstr ""
+#: ../raster/r.in.arc/gethead.c:88
+msgid "Illegal line in header"
+msgstr ""
+#: ../raster/r.in.arc/gethead.c:160 ../raster/r.in.ascii/gethead.c:251
+#, c-format
+msgid "Duplicate \"%s\" field in header"
+msgstr ""
+#: ../raster/r.in.arc/gethead.c:165
+#, c-format
+msgid "Illegal \"%s\" value in header: \"%s\""
+msgstr ""
+#: ../raster/r.in.arc/gethead.c:173 ../raster/r.in.ascii/gethead.c:264
+#, c-format
+msgid "\"%s\" field missing from header"
+msgstr ""
+#: ../raster/r.in.arc/main.c:61
+msgid ""
+"Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster "
+"map layer."
+msgstr ""
+#: ../raster/r.in.arc/main.c:69
+msgid "ARC/INFO ASCII raster file (GRID) to be imported"
+msgstr ""
+#: ../raster/r.in.arc/main.c:94 ../raster/r.in.ascii/main.c:92
+msgid "Multiplier for ASCII data"
+msgstr ""
+#: ../raster/r.in.arc/main.c:127 ../raster/r.in.ascii/main.c:185
+msgid "Can't get cell header"
+msgstr ""
+#: ../raster/r.in.arc/main.c:135 ../raster/r.in.ascii/main.c:193
+#: ../raster/r.horizon/main.c:623
+#, c-format
+msgid "OOPS: rows changed from %d to %d"
+msgstr ""
+#: ../raster/r.in.arc/main.c:138 ../raster/r.in.ascii/main.c:196
+#: ../raster/r.horizon/main.c:627
+#, c-format
+msgid "OOPS: cols changed from %d to %d"
+msgstr ""
+#: ../raster/r.in.arc/main.c:161 ../raster/r.in.ascii/main.c:212
+#, c-format
+msgid "Data conversion failed at row %d, col %d"
+msgstr ""
+#: ../raster/r.in.arc/main.c:228
+msgid "Failed to copy file"
+msgstr ""
+#: ../raster/r.sunmask/g_solposition.c:66
+msgid ""
+"Unable to calculate sun position in un-projected locations. Specify "
+"sunposition directly."
+msgstr ""
+#: ../raster/r.sunmask/g_solposition.c:88
+#, c-format
+msgid ""
+"Specified point %f, %f outside of current region, is that intended? Anyway, "
+"it will be used."
+msgstr ""
+#: ../raster/r.sunmask/g_solposition.c:98
+msgid "Unable to get projection info of current location"
+msgstr ""
+#: ../raster/r.sunmask/g_solposition.c:101
+msgid "Unable to get projection units of current location"
+msgstr ""
+#: ../raster/r.sunmask/g_solposition.c:104
+msgid "Unable to get projection key values of current location"
+msgstr ""
+#: ../raster/r.sunmask/solpos00.c:949
+#, c-format
+msgid "S_decode ==> Please fix the year: %d [1950-2050]"
+msgstr ""
+#: ../raster/r.sunmask/solpos00.c:952
+#, c-format
+msgid "S_decode ==> Please fix the month: %d"
+msgstr ""
+#: ../raster/r.sunmask/solpos00.c:954
+#, c-format
+msgid "S_decode ==> Please fix the day-of-month: %d"
+msgstr ""
+#: ../raster/r.sunmask/solpos00.c:957
+#, c-format
+msgid "S_decode ==> Please fix the day-of-year: %d"
+msgstr ""
+#: ../raster/r.sunmask/solpos00.c:960
+#, c-format
+msgid "S_decode ==> Please fix the hour: %d"
+msgstr ""
+#: ../raster/r.sunmask/solpos00.c:962
+#, c-format
+msgid "S_decode ==> Please fix the minute: %d"
+msgstr ""
+#: ../raster/r.sunmask/solpos00.c:964
+#, c-format
+msgid "S_decode ==> Please fix the second: %d"
+msgstr ""
+#: ../raster/r.sunmask/solpos00.c:966
+#, c-format
+msgid "S_decode ==> Please fix the time zone: %f"
+msgstr ""
+#: ../raster/r.sunmask/solpos00.c:969
+#, c-format
+msgid "S_decode ==> Please fix the interval: %d"
+msgstr ""
+#: ../raster/r.sunmask/solpos00.c:972
+#, c-format
+msgid "S_decode ==> Please fix the latitude: %f"
+msgstr ""
+#: ../raster/r.sunmask/solpos00.c:975
+#, c-format
+msgid "S_decode ==> Please fix the longitude: %f"
+msgstr ""
+#: ../raster/r.sunmask/solpos00.c:978
+#, c-format
+msgid "S_decode ==> Please fix the temperature: %f"
+msgstr ""
+#: ../raster/r.sunmask/solpos00.c:981
+#, c-format
+msgid "S_decode ==> Please fix the pressure: %f"
+msgstr ""
+#: ../raster/r.sunmask/solpos00.c:983
+#, c-format
+msgid "S_decode ==> Please fix the tilt: %f"
+msgstr ""
+#: ../raster/r.sunmask/solpos00.c:985
+#, c-format
+msgid "S_decode ==> Please fix the aspect: %f"
+msgstr ""
+#: ../raster/r.sunmask/solpos00.c:987
+#, c-format
+msgid "S_decode ==> Please fix the shadowband width: %f"
+msgstr ""
+#: ../raster/r.sunmask/solpos00.c:990
+#, c-format
+msgid "S_decode ==> Please fix the shadowband radius: %f"
+msgstr ""
+#: ../raster/r.sunmask/solpos00.c:993
+#, c-format
+msgid "S_decode ==> Please fix the shadowband sky factor: %f"
+msgstr ""
+#: ../raster/r.sunmask/main.c:115 ../raster/r.horizon/main.c:177
+msgid "raster, sun position"
+msgstr ""
+#: ../raster/r.sunmask/main.c:116
+msgid ""
+"Calculates cast shadow areas from sun position and elevation raster map."
+msgstr ""
+#: ../raster/r.sunmask/main.c:117
+msgid ""
+"Either exact sun position (A) is specified, or date/time to calculate the "
+"sun position (B) by r.sunmask itself."
+msgstr ""
+#: ../raster/r.sunmask/main.c:131
+msgid "Altitude of the sun above horizon, degrees (A)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:132 ../raster/r.sunmask/main.c:141
+#: ../raster/r.sunmask/main.c:208 ../raster/r.sunmask/main.c:218
+msgid "Position"
+msgstr ""
+#: ../raster/r.sunmask/main.c:140
+msgid "Azimuth of the sun from the north, degrees (A)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:147
+msgid "Year (B)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:149 ../raster/r.sunmask/main.c:157
+#: ../raster/r.sunmask/main.c:165 ../raster/r.sunmask/main.c:173
+#: ../raster/r.sunmask/main.c:181 ../raster/r.sunmask/main.c:189
+#: ../raster/r.sunmask/main.c:198
+msgid "Time"
+msgstr ""
+#: ../raster/r.sunmask/main.c:155
+msgid "Month (B)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:163
+msgid "Day (B)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:171
+msgid "Hour (B)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:179
+msgid "Minutes (B)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:187
+msgid "Seconds (B)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:196
+msgid "Timezone"
+msgstr ""
+#: ../raster/r.sunmask/main.c:197
+msgid "East positive, offset from GMT, also use to adjust daylight savings"
+msgstr ""
+#: ../raster/r.sunmask/main.c:206
+msgid "Easting coordinate (point of interest)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:207 ../raster/r.sunmask/main.c:217
+msgid "Default: map center"
+msgstr ""
+#: ../raster/r.sunmask/main.c:216
+msgid "Northing coordinate (point of interest)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:222
+msgid "Don't ignore zero elevation"
+msgstr ""
+#: ../raster/r.sunmask/main.c:227
+msgid "Verbose output (also print out sun position etc.)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:231
+msgid "Calculate sun position only and exit"
+msgstr ""
+#: ../raster/r.sunmask/main.c:237
+msgid "Print the sun position output in shell script style"
+msgstr ""
+#: ../raster/r.sunmask/main.c:251
+#, c-format
+msgid "Using map center coordinates: %f %f"
+msgstr ""
+#: ../raster/r.sunmask/main.c:258
+msgid "Empty east coordinate specified"
+msgstr ""
+#: ../raster/r.sunmask/main.c:260
+msgid "Empty north coordinate specified"
+msgstr ""
+#: ../raster/r.sunmask/main.c:279
+msgid "Either define sun position or location/date/time parameters"
+msgstr ""
+#: ../raster/r.sunmask/main.c:282
+msgid ""
+"Neither sun position nor east/north, date/time/timezone definition are "
+"complete"
+msgstr ""
+#: ../raster/r.sunmask/main.c:286
+#, c-format
+msgid "Calculating sun position... (using solpos (V. %s) from NREL)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:291
+msgid ""
+"Using user defined sun azimuth, altitude settings (ignoring eventual other "
+"values)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:397
+msgid "Please correct settings"
+msgstr ""
+#: ../raster/r.sunmask/main.c:411
+#, c-format
+msgid "Time (%02i:%02i:%02i) is before sunrise (%02d:%02d:%02d)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:415
+#, c-format
+msgid "Time (%02i:%02i:%02i) is before sunrise"
+msgstr ""
+#: ../raster/r.sunmask/main.c:418 ../raster/r.sunmask/main.c:428
+msgid "Nothing to calculate. Please verify settings."
+msgstr ""
+#: ../raster/r.sunmask/main.c:422
+#, c-format
+msgid "Time (%02i:%02i:%02i) is after sunset (%02d:%02d:%02d)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:426
+#, c-format
+msgid "Time (%02i:%02i:%02i) is after sunset"
+msgstr ""
+#: ../raster/r.sunmask/main.c:437
+msgid "You already know the sun position"
+msgstr ""
+#: ../raster/r.sunmask/main.c:442
+#, c-format
+msgid "Option <%s> required"
+msgstr ""
+#: ../raster/r.sunmask/main.c:459
+#, c-format
+msgid "Unable to open range file for raster map <%s>"
+msgstr ""
+#: ../raster/r.sunmask/main.c:475
+msgid "Calculating shadows from DEM..."
+msgstr ""
+#: ../raster/r.out.pov/main.c:123
+msgid "Converts a raster map layer into a height-field file for POVRAY."
+msgstr ""
+#: ../raster/r.out.pov/main.c:138
+msgid "Name of output povray file (TGA height field file)"
+msgstr ""
+#: ../raster/r.out.pov/main.c:145
+msgid "Height-field type (0=actual heights 1=normalized)"
+msgstr ""
+#: ../raster/r.out.pov/main.c:151
+msgid "Elevation bias"
+msgstr ""
+#: ../raster/r.out.pov/main.c:157 ../raster/r.param.scale/interface.c:114
+msgid "Vertical scaling factor"
+msgstr ""
+#: ../raster/r.out.pov/main.c:183
+#, c-format
+msgid "Invalid output filename <%s>"
+msgstr ""
+#: ../raster/r.out.pov/main.c:193
+#, c-format
+msgid "Raster map is too big! Exceeds %d columns or %d rows"
+msgstr ""
+#: ../raster/r.out.pov/main.c:214
+msgid "Negative elevation values in input"
+msgstr ""
+#: ../raster/r.mfilter/getrow.c:12 ../raster/r.mfilter.fp/getrow.c:12
+#, c-format
+msgid "Cannot read raster row %d"
+msgstr ""
+#: ../raster/r.mfilter/getrow.c:23 ../raster/r.mfilter.fp/getrow.c:23
+msgid "Error reading temporary file"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:26 ../raster/r.mfilter.fp/getfilt.c:27
+#, c-format
+msgid "Cannot open filter file '%s'"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:46 ../raster/r.mfilter.fp/getfilt.c:47
+msgid "Illegal filter matrix size specified"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:49 ../raster/r.mfilter.fp/getfilt.c:50
+msgid "Even filter matrix size specified"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:71 ../raster/r.mfilter.fp/getfilt.c:72
+msgid "Illegal filter matrix"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:79 ../raster/r.mfilter/getfilt.c:105
+#: ../raster/r.mfilter/getfilt.c:122 ../raster/r.mfilter.fp/getfilt.c:80
+#: ../raster/r.mfilter.fp/getfilt.c:107 ../raster/r.mfilter.fp/getfilt.c:124
+msgid "Filter file format error"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:82 ../raster/r.mfilter.fp/getfilt.c:83
+msgid "Duplicate filter divisor specified"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:99 ../raster/r.mfilter.fp/getfilt.c:101
+msgid "Illegal divisor matrix"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:108 ../raster/r.mfilter.fp/getfilt.c:110
+msgid "Duplicate filter type specified"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:115 ../raster/r.mfilter.fp/getfilt.c:117
+msgid "Illegal filter type specified"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:125 ../raster/r.mfilter.fp/getfilt.c:127
+msgid "Duplicate filter start specified"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:133 ../raster/r.mfilter.fp/getfilt.c:135
+#, c-format
+msgid "Filter start %s ignored, using UL"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:155 ../raster/r.mfilter.fp/getfilt.c:157
+msgid "Illegal filter file format"
+msgstr ""
+#: ../raster/r.mfilter/perform.c:43 ../raster/r.mfilter/perform.c:54
+#: ../raster/r.mfilter.fp/perform.c:43 ../raster/r.mfilter.fp/perform.c:54
+msgid "Unable to create temporary file"
+msgstr ""
+#: ../raster/r.mfilter/perform.c:87 ../raster/r.mfilter.fp/perform.c:87
+#, c-format
+msgid "Writing raster map <%s>"
+msgstr ""
+#: ../raster/r.mfilter/main.c:52
+msgid "Performs raster map matrix filter."
+msgstr ""
+#: ../raster/r.mfilter/main.c:63
+msgid "Path to filter file"
+msgstr ""
+#: ../raster/r.mfilter/main.c:71 ../raster/r.mfilter.fp/main.c:78
+msgid "Number of times to repeat the filter"
+msgstr ""
+#: ../raster/r.mfilter/main.c:72 ../raster/r.mfilter/main.c:96
+msgid "Filter"
+msgstr ""
+#: ../raster/r.mfilter/main.c:78 ../raster/r.mfilter.fp/main.c:84
+msgid "Output raster map title"
+msgstr ""
+#: ../raster/r.mfilter/main.c:95
+msgid "Apply filter only to zero data values"
+msgstr ""
+#: ../raster/r.mfilter/main.c:133 ../raster/r.mfilter.fp/main.c:138
+msgid "Raster map too small for the size of the filter"
+msgstr ""
+#: ../raster/r.random/count.c:74
+msgid "Collecting Stats..."
+msgstr ""
+#: ../raster/r.random/count.c:78
+#, c-format
+msgid "Cannot read raster row [%d]"
+msgstr ""
+#: ../raster/r.random/count.c:82
+#, c-format
+msgid "Cannot read cover raster row [%d]"
+msgstr ""
+#: ../raster/r.random/count.c:131
+msgid "Programmer error in get_stats/switch"
+msgstr ""
+#: ../raster/r.random/random.c:100
+msgid "Cannot create new table"
+msgstr ""
+#: ../raster/r.random/random.c:110
+#, c-format
+msgid "Writing raster map <%s> and vector map <%s> ..."
+msgstr ""
+#: ../raster/r.random/random.c:113
+#, c-format
+msgid "Writing raster map <%s> ..."
+msgstr ""
+#: ../raster/r.random/random.c:115
+#, c-format
+msgid "Writing vector map <%s> ..."
+msgstr ""
+#: ../raster/r.random/random.c:129
+#, c-format
+msgid "Cannot read raster row [%d] from raster map <%s>"
+msgstr ""
+#: ../raster/r.random/random.c:135
+#, c-format
+msgid "Cannot read raster row [%d] from cover raster map <%s>"
+msgstr ""
+#: ../raster/r.random/random.c:246
+#, c-format
+msgid "Only [%ld] random points created"
+msgstr ""
+#: ../raster/r.random/main.c:51 ../raster/r.surf.random/main.c:44
+msgid "raster, random"
+msgstr ""
+#: ../raster/r.random/main.c:53
+msgid ""
+"Creates a raster map layer and vector point map containing randomly located "
+"points."
+msgstr ""
+#: ../raster/r.random/main.c:69
+msgid "The number of points to allocate"
+msgstr ""
+#: ../raster/r.random/main.c:81
+msgid "Generate points also for NULL category"
+msgstr ""
+#: ../raster/r.random/main.c:86
+msgid "Report information about input raster and exit"
+msgstr ""
+#: ../raster/r.random/main.c:90
+msgid "Generate vector points as 3D points"
+msgstr ""
+#: ../raster/r.random/main.c:142
+#, c-format
+msgid "Note: one (or both) of %s and %s must be specified"
+msgstr ""
+#: ../raster/r.random/main.c:160
+#, c-format
+msgid "<%s=%s> invalid percentage"
+msgstr ""
+#: ../raster/r.random/main.c:167
+#, c-format
+msgid "<%s=%s> invalid number of points"
+msgstr ""
+#: ../raster/r.random/main.c:180
+#, c-format
+msgid "There aren't [%ld] cells in the current region"
+msgstr ""
+#: ../raster/r.random/main.c:183
+#, c-format
+msgid "There aren't [%ld] non-NULL cells in the current region"
+msgstr ""
+#: ../raster/r.random/main.c:188
+msgid "There are no valid locations in the current region"
+msgstr ""
+#: ../raster/r.rescale.eq/get_stats.c:19 ../raster/r.rescale/get_range.c:25
+#, c-format
+msgid "Reading %s ..."
+msgstr ""
+#: ../raster/r.rescale.eq/main.c:52 ../raster/r.rescale/main.c:50
+msgid "raster, rescale"
+msgstr ""
+#: ../raster/r.rescale.eq/main.c:54
+msgid ""
+"Rescales histogram equalized the range of category values in a raster map "
+"layer."
+msgstr ""
+#: ../raster/r.rescale.eq/main.c:64 ../raster/r.rescale/main.c:61
+msgid "The name of the raster map to be rescaled"
+msgstr ""
+#: ../raster/r.rescale.eq/main.c:72 ../raster/r.rescale/main.c:69
+msgid "The input data range to be rescaled (default: full range of input map)"
+msgstr ""
+#: ../raster/r.rescale.eq/main.c:79 ../raster/r.rescale/main.c:76
+msgid "The resulting raster map name"
+msgstr ""
+#: ../raster/r.rescale.eq/main.c:86 ../raster/r.rescale/main.c:83
+msgid "The output data range"
+msgstr ""
+#: ../raster/r.rescale.eq/main.c:93 ../raster/r.rescale/main.c:90
+msgid "Title for new raster map"
+msgstr ""
+#: ../raster/r.rescale.eq/main.c:146
+#, c-format
+msgid "Rescale %s[%d,%d] to %s[%d,%d]"
+msgstr ""
+#: ../raster/r.quantile/main.c:62
+msgid "Computing histogram"
+msgstr ""
+#: ../raster/r.quantile/main.c:96
+msgid "Computing bins"
+msgstr ""
+#: ../raster/r.quantile/main.c:133
+msgid "Binning data"
+msgstr ""
+#: ../raster/r.quantile/main.c:178
+msgid "Sorting bins"
+msgstr ""
+#: ../raster/r.quantile/main.c:188
+msgid "Computing quantiles"
+msgstr ""
+#: ../raster/r.quantile/main.c:255
+msgid "Compute quantiles using two passes."
+msgstr ""
+#: ../raster/r.quantile/main.c:263
+msgid "Number of quantiles"
+msgstr ""
+#: ../raster/r.quantile/main.c:271
+msgid "List of percentiles"
+msgstr ""
+#: ../raster/r.quantile/main.c:277
+msgid "Number of bins to use"
+msgstr ""
+#: ../raster/r.quantile/main.c:282
+msgid "Generate recode rules based on quantile-defined intervals."
+msgstr ""
+#: ../raster/r.to.rast3/main.c:77
+msgid "2d raster maps which represent the slices"
+msgstr ""
+#: ../raster/r.to.rast3/main.c:83
+msgid "Use G3D mask (if exists) with output map"
+msgstr ""
+#: ../raster/r.to.rast3/main.c:117
+msgid "Could not get raster row"
+msgstr ""
+#: ../raster/r.to.rast3/main.c:194
+msgid "raster, volume, conversion"
+msgstr ""
+#: ../raster/r.to.rast3/main.c:196
+msgid "Converts 2D raster map slices to one 3D raster volume map."
+msgstr ""
+#: ../raster/r.to.rast3/main.c:208
+msgid "No output map"
+msgstr ""
+#: ../raster/r.to.rast3/main.c:260
+msgid "Cell file not found"
+msgstr ""
+#: ../raster/r.to.rast3/main.c:268
+#, c-format
+msgid "Open raster map %s - one time for each depth (%d/%d)"
+msgstr ""
+#: ../raster/r.to.rast3/main.c:281
+msgid "Input maps have to be from the same type. CELL, FCELL or DCELL!"
+msgstr ""
+#: ../raster/r.carve/lobf.c:74
+msgid "trying to divide by zero...no unique solution for system...skipping..."
+msgstr ""
+#: ../raster/r.carve/enforce_ds.c:81
+msgid "Processing lines... "
+msgstr ""
+#: ../raster/r.carve/enforce_ds.c:173
+msgid ""
+"Vect runs out of region and re-enters - this case is not yet implemented."
+msgstr ""
+#: ../raster/r.carve/main.c:78
+msgid ""
+"Takes vector stream data, transforms it to raster and subtracts depth from "
+"the output DEM."
+msgstr ""
+#: ../raster/r.carve/main.c:83
+msgid "Name of input raster elevation map"
+msgstr ""
+#: ../raster/r.carve/main.c:88
+msgid "Name of vector input map containing stream(s)"
+msgstr ""
+#: ../raster/r.carve/main.c:96
+msgid "Name for output vector map for adjusted stream points"
+msgstr ""
+#: ../raster/r.carve/main.c:101
+msgid "Stream width (in meters). Default is raster cell width"
+msgstr ""
+#: ../raster/r.carve/main.c:107
+msgid "Additional stream depth (in meters)"
+msgstr ""
+#: ../raster/r.carve/main.c:111
+msgid "No flat areas allowed in flow direction"
+msgstr ""
+#: ../raster/r.carve/main.c:148
+#, c-format
+msgid "Invalid width value '%s' - using default."
+msgstr ""
+#: ../raster/r.carve/main.c:162
+#, c-format
+msgid "Invalid depth value '%s' - using default."
+msgstr ""
+#: ../raster/r.carve/main.c:231
+msgid "lat/lon projection not supported at this time."
+msgstr ""
+#: ../raster/r.contour/cont.c:81
+#, c-format
+msgid "Writing vector contours (total levels %d)..."
+msgstr ""
+#: ../raster/r.contour/cont.c:211
+#, c-format
+msgid "%d crossings founds"
+msgstr ""
+#: ../raster/r.contour/cont.c:262
+msgid "Illegal edge number"
+msgstr ""
+#: ../raster/r.contour/cont.c:370
+msgid "Edge number out of range"
+msgstr ""
+#: ../raster/r.contour/main.c:91
+msgid "raster, DEM, contours, vector"
+msgstr ""
+#: ../raster/r.contour/main.c:92
+msgid "Produces a vector map of specified contours from a raster map."
+msgstr ""
+#: ../raster/r.contour/main.c:104
+msgid "List of contour levels"
+msgstr ""
+#: ../raster/r.contour/main.c:110
+msgid "Minimum contour level"
+msgstr ""
+#: ../raster/r.contour/main.c:116
+msgid "Maximum contour level"
+msgstr ""
+#: ../raster/r.contour/main.c:122
+msgid "Increment between contour levels"
+msgstr ""
+#: ../raster/r.contour/main.c:130
+msgid "Minimum number of points for a contour line (0 -> no limit)"
+msgstr ""
+#: ../raster/r.contour/main.c:138
+msgid "Suppress single crossing error messages"
+msgstr ""
+#: ../raster/r.contour/main.c:147
+msgid ""
+"The '-q' and '-n' flag is superseded and will be removed in future. Please "
+"use '--quiet' instead."
+msgstr ""
+#: ../raster/r.contour/main.c:152
+msgid "Neither \"levels\" nor \"step\" parameter specified."
+msgstr ""
+#: ../raster/r.contour/main.c:270
+#, c-format
+msgid "Range of data: min=%f, max=%f"
+msgstr ""
+#: ../raster/r.contour/main.c:272
+msgid "Range of data: empty"
+msgstr ""
+#: ../raster/r.contour/main.c:299 ../raster/r.contour/main.c:303
+msgid "This step value is not allowed"
+msgstr ""
+#: ../raster/r.contour/main.c:327
+#, c-format
+msgid "Range of levels: min = %f, max = %f"
+msgstr ""
+#: ../raster/r.contour/main.c:356
+msgid "Displacing data..."
+msgstr ""
+#: ../raster/r.average/main.c:53
+msgid ""
+"Finds the average of values in a cover map within areas assigned the same "
+msgstr ""
+#: ../raster/r.average/main.c:66 ../raster/r.statistics/main.c:73
+msgid "Cover values extracted from the category labels of the cover map"
+msgstr ""
+#: ../raster/r.average/main.c:93
+#, c-format
+msgid "%s: ERROR running %s command"
+msgstr ""
+#: ../raster/r.average/main.c:102 ../raster/r.statistics/o_sum.c:43
+#: ../raster/r.statistics/o_average.c:41 ../raster/r.statistics/o_distrib.c:39
+#, c-format
+msgid "%s: unable to open temporary file"
+msgstr ""
+#: ../raster/r.surf.area/main.c:87
+msgid "Surface area estimation for rasters."
+msgstr ""
+#: ../raster/r.surf.area/main.c:95
+msgid "Raster file for surface"
+msgstr ""
+#: ../raster/r.surf.area/main.c:102
+msgid "Vertical scale"
+msgstr ""
+#: ../raster/r.volume/main.c:57
+msgid "raster, volume"
+msgstr ""
+#: ../raster/r.volume/main.c:59
+msgid ""
+"Calculates the volume of data \"clumps\", and (optionally) produces a GRASS "
+"vector points map containing the calculated centroids of these clumps."
+msgstr ""
+#: ../raster/r.volume/main.c:69
+msgid "Existing raster map representing data that will be summed within clumps"
+msgstr ""
+#: ../raster/r.volume/main.c:77
+msgid "Existing raster map, preferably the output of r.clump"
+msgstr ""
+#: ../raster/r.volume/main.c:84
+msgid "Vector points map to contain clump centroids"
+msgstr ""
+#: ../raster/r.volume/main.c:88
+msgid "Generate unformatted report"
+msgstr ""
+#: ../raster/r.volume/main.c:117
+msgid "No data map specified"
+msgstr ""
+#: ../raster/r.volume/main.c:128
+msgid "No clump map specified and MASK not set."
+msgstr ""
+#: ../raster/r.volume/main.c:133
+msgid "Unable to find data map"
+msgstr ""
+#: ../raster/r.volume/main.c:141
+msgid "Unable to find clump map"
+msgstr ""
+#: ../raster/r.volume/main.c:149
+msgid "Unable to open centroids vector points map"
+msgstr ""
+#: ../raster/r.volume/main.c:171
+msgid "Data or Clump file not open"
+msgstr ""
+#: ../raster/r.compress/main.c:64
+msgid "raster, map management"
+msgstr ""
+#: ../raster/r.compress/main.c:65
+msgid "Compresses and decompresses raster maps."
+msgstr ""
+#: ../raster/r.compress/main.c:77
+msgid "Uncompress the map"
+msgstr ""
+#: ../raster/r.compress/main.c:117
+#, c-format
+msgid "[%s] not found"
+msgstr ""
+#: ../raster/r.compress/main.c:123
+#, c-format
+msgid "[%s] is a reclass file of map <%s> in mapset <%s> - can't uncompress"
+msgstr ""
+#: ../raster/r.compress/main.c:125
+#, c-format
+msgid "[%s] is a reclass file of map <%s> in mapset <%s> - can't compress"
+msgstr ""
+#: ../raster/r.compress/main.c:168
+#, c-format
+msgid "DONE: uncompressed file is %lu bytes smaller"
+msgstr ""
+#: ../raster/r.compress/main.c:169
+#, c-format
+msgid "DONE: compressed file is %lu bytes smaller"
+msgstr ""
+#: ../raster/r.compress/main.c:173
+#, c-format
+msgid "DONE: uncompressed file is %lu bytes bigger"
+msgstr ""
+#: ../raster/r.compress/main.c:174
+#, c-format
+msgid "DONE: compressed file is %lu bytes bigger"
+msgstr ""
+#: ../raster/r.compress/main.c:196
+#, c-format
+msgid "[%s] already uncompressed"
+msgstr ""
+#: ../raster/r.compress/main.c:200
+#, c-format
+msgid "[%s] already compressed"
+msgstr ""
+#: ../raster/r.compress/main.c:204
+#, c-format
+msgid ""
+"\n"
+"%sCOMPRESS [%s]"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:34
+msgid "input file is not a Surfer ascii grid file"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:40
+msgid "error reading the column and row dimension from the Surfer grid file"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:46
+msgid "error reading the X range from the Surfer grid file"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:52
+msgid "error reading the Y range from the Surfer grid file"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:58
+msgid "error reading the Z range from the Surfer grid file"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:105
+msgid "error getting file position"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:164
+msgid "illegal type field: using type int"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:169
+msgid "ignoring type filed in header, type is set on command line"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:176
+msgid "illegal multiplier field: using 1.0"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:181
+msgid "ignoring multiplier filed in header, multiplier is set on command line"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:189
+msgid "ignoring null filed in header, null string is set on command line"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:218
+msgid "error in ascii data format"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:256
+#, c-format
+msgid "Illegal \"%s\" value in header: %s"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:68
+msgid "raster, import, conversion"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:70
+msgid "Converts ASCII raster file to binary raster map layer."
+msgstr ""
+#: ../raster/r.in.ascii/main.c:74
+msgid ""
+"ASCII raster file to be imported. If not given reads from standard input"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:100
+msgid "String representing NULL value data cell"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:104
+msgid "Integer values are imported"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:108
+msgid "Floating point values are imported"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:112
+msgid "Double floating point values are imported"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:117
+msgid "SURFER (Golden Software) ASCII file will be imported"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:135
+#, c-format
+msgid "Wrong entry for multiplier: %s"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:158
+msgid "Unable to read input from stdin"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:165
+#, c-format
+msgid "Unable to read input from <%s>"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:285
+msgid "Unable to write to file"
+msgstr ""
+#: ../raster/r.bilinear/main.c:44
+msgid "Bilinear interpolation utility for raster map layers."
+msgstr ""
+#: ../raster/r.bilinear/main.c:54 ../raster/r.bilinear/main.c:61
+msgid ""
+"Specific input value to be assigned to the north and/or south poles for "
+"longitude-latitude grids"
+msgstr ""
+#: ../raster/r.bilinear/main.c:67
+msgid "This module is deprecated. Please use 'r.resamp.interp' instead."
+msgstr ""
+#: ../raster/r.topmodel/main.c:57
+msgid "Simulates TOPMODEL which is a physically based hydrologic model."
+msgstr ""
+#: ../raster/r.topmodel/main.c:63
+msgid "(i)   Basin map created by r.water.outlet (MASK)"
+msgstr ""
+#: ../raster/r.topmodel/main.c:70
+msgid "(i)   Elevation map"
+msgstr ""
+#: ../raster/r.topmodel/main.c:77
+msgid "(o)   Depressionless elevation map"
+msgstr ""
+#: ../raster/r.topmodel/main.c:85
+msgid "(o)   Direction map for depressionless elevation map"
+msgstr ""
+#: ../raster/r.topmodel/main.c:92
+msgid "(o/i) Basin elevation map (MASK applied)"
+msgstr ""
+#: ../raster/r.topmodel/main.c:100
+msgid "(o)   Topographic index ln(a/tanB) map (MASK applied)"
+msgstr ""
+#: ../raster/r.topmodel/main.c:108
+msgid "(i)   Number of topographic index classes"
+msgstr ""
+#: ../raster/r.topmodel/main.c:116
+msgid "(o/i) Topographic index statistics file"
+msgstr ""
+#: ../raster/r.topmodel/main.c:122
+msgid "(i)   TOPMODEL Parameters file"
+msgstr ""
+#: ../raster/r.topmodel/main.c:129
+msgid "(i)   Rainfall and potential evapotranspiration data file"
+msgstr ""
+#: ../raster/r.topmodel/main.c:135
+msgid "(o)   Output file"
+msgstr ""
+#: ../raster/r.topmodel/main.c:141
+msgid "(i)   OPTIONAL Observed flow file"
+msgstr ""
+#: ../raster/r.topmodel/main.c:148
+msgid "(i)   OPTIONAL Output for given time step"
+msgstr ""
+#: ../raster/r.topmodel/main.c:155
+msgid "(i)   OPTIONAL Output for given topographic index class"
+msgstr ""
+#: ../raster/r.topmodel/main.c:163
+msgid "Input data given for (o/i)"
+msgstr ""
+#: ../raster/r.colors.out/main.c:63
+msgid "raster, export, color table"
+msgstr ""
+#: ../raster/r.colors.out/main.c:65
+msgid "Exports the color table associated with a raster map layer."
+msgstr ""
+#: ../raster/r.colors.out/main.c:71
+msgid "Path to output rules file"
+msgstr ""
+#: ../raster/r.colors.out/main.c:72
+msgid "\"-\" to write to stdout"
+msgstr ""
+#: ../raster/r.colors.out/main.c:77
+msgid "Output values as percentages"
+msgstr ""
+#: ../raster/r.coin/make_coin.c:44
+#, c-format
+msgid "Tabulating Coincidence between '%s' and '%s'"
+msgstr ""
+#: ../raster/r.coin/make_coin.c:54
+msgid "Unable to create any tempfiles"
+msgstr ""
+#: ../raster/r.coin/make_coin.c:58
+msgid "Unable to run r.stats"
+msgstr ""
+#: ../raster/r.coin/make_coin.c:67
+msgid "Unexpected output from r.stats"
+msgstr ""
+#: ../raster/r.coin/make_coin.c:78
+msgid "Unable to open tempfile"
+msgstr ""
+#: ../raster/r.coin/inter.c:34
+msgid "GIS Coincidence Tabulation Facility\n"
+msgstr ""
+#: ../raster/r.coin/inter.c:35
+msgid ""
+"This utility will allow you to compare the coincidence of two map layers\n"
+msgstr ""
+#: ../raster/r.coin/inter.c:52
+msgid "The report can be made in one of 8 units."
+msgstr ""
+#: ../raster/r.coin/inter.c:53
+msgid "Please choose a unit by entering one of the following letter codes:"
+msgstr ""
+#: ../raster/r.coin/inter.c:55
+msgid "     'c': cells"
+msgstr ""
+#: ../raster/r.coin/inter.c:56
+msgid "     'p': percent cover of region"
+msgstr ""
+#: ../raster/r.coin/inter.c:57
+#, c-format
+msgid "     'x': percent of '%s' category (column)"
+msgstr ""
+#: ../raster/r.coin/inter.c:58
+#, c-format
+msgid "     'y': percent of '%s' category (row)"
+msgstr ""
+#: ../raster/r.coin/inter.c:59
+msgid "     'a': acres"
+msgstr ""
+#: ../raster/r.coin/inter.c:60
+msgid "     'h': hectares"
+msgstr ""
+#: ../raster/r.coin/inter.c:61
+msgid "     'k': square kilometers"
+msgstr ""
+#: ../raster/r.coin/inter.c:62
+msgid "     'm': square miles\n"
+msgstr ""
+#: ../raster/r.coin/inter.c:63
+msgid "     'Q': quit"
+msgstr ""
+#: ../raster/r.coin/inter.c:95
+#, c-format
+msgid "Do you wish to save this report in a file? (y/n) [n] "
+msgstr ""
+#: ../raster/r.coin/inter.c:103
+#, c-format
+msgid ""
+"Enter the file name or path\n"
+msgstr ""
+#: ../raster/r.coin/inter.c:108
+#, c-format
+msgid "'%s' being saved\n"
+msgstr ""
+#: ../raster/r.coin/inter.c:117
+#, c-format
+msgid ""
+"Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "
+msgstr ""
+#: ../raster/r.coin/inter.c:126
+#, c-format
+msgid ""
+"Do you wish it printed in 80 or 132 columns?\n"
+msgstr ""
+#: ../raster/r.coin/inter.c:142
+#, c-format
+msgid ""
+"Do you wish to run this report with a different unit of measure? (y/n) [y] "
+msgstr ""
+#: ../raster/r.coin/print_coin.c:44
+#, c-format
+msgid "Preparing report ..."
+msgstr ""
+#: ../raster/r.coin/main.c:68
+msgid ""
+"Tabulates the mutual occurrence (coincidence) of categories for two raster "
+"map layers."
+msgstr ""
+#: ../raster/r.coin/main.c:76
+msgid "Name of first raster map"
+msgstr ""
+#: ../raster/r.coin/main.c:83
+msgid "Name of second raster map"
+msgstr ""
+#: ../raster/r.coin/main.c:89
+msgid "Unit of measure"
+msgstr ""
+#: ../raster/r.coin/main.c:91
+msgid ""
+"c(ells), p(ercent), x(percent of category [column]), y(percent of category "
+"[row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
+msgstr ""
+#: ../raster/r.coin/main.c:98
+msgid "Wide report, 132 columns (default: 80)"
+msgstr ""
+#: ../raster/r.param.scale/write_cats.c:47
+#, c-format
+msgid "Cannot write category file for raster map <%s>"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:54
+msgid "raster, geomorphology"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:55
+msgid "Extracts terrain parameters from a DEM."
+msgstr ""
+#: ../raster/r.param.scale/interface.c:56
+msgid ""
+"Uses a multi-scale approach by taking fitting quadratic parameters to any "
+"size window (via least squares)."
+msgstr ""
+#: ../raster/r.param.scale/interface.c:74
+msgid "Output raster layer containing morphometric parameter"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:78
+msgid "Slope tolerance that defines a 'flat' surface (degrees)"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:85
+msgid "Curvature tolerance that defines 'planar' surface"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:90
+#, c-format
+msgid "Size of processing window (odd number only, max: %i)"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:100
+msgid "Morphometric parameter in 'size' window to calculate"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:108
+msgid "Exponent for distance weighting (0.0-4.0)"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:120
+msgid "Constrain model through central window cell"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:163
+msgid "Morphometric parameter not recognised. Assuming 'Elevation'"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:190
+msgid "Inappropriate window size (too big or even)"
+msgstr ""
+#: ../raster/r.param.scale/process.c:73
+msgid "E-W and N-S grid resolutions are different. Taking average."
+msgstr ""
+#: ../raster/r.param.scale/main.c:45
+msgid "Lat/Long location is not supported"
+msgstr ""
+#: ../raster/r.out.vrml/put_grid.c:37
+msgid "Writing vertices..."
+msgstr ""
+#: ../raster/r.out.vrml/put_grid.c:82
+msgid "Writing color file..."
+msgstr ""
+#: ../raster/r.out.vrml/main.c:47
+msgid "raster, export, VRML"
+msgstr ""
+#: ../raster/r.out.vrml/main.c:49
+msgid "Export a raster map to the Virtual Reality Modeling Language (VRML)"
+msgstr ""
+#: ../raster/r.out.vrml/main.c:56
+msgid "Name of elevation map"
+msgstr ""
+#: ../raster/r.out.vrml/main.c:63
+msgid "Name of color file"
+msgstr ""
+#: ../raster/r.out.vrml/main.c:77
+msgid "Name for new VRML file"
+msgstr ""
+#: ../raster/r.out.vrml/main.c:163
+#, c-format
+msgid "Opening %s for writing... "
+msgstr ""
+#: ../raster/r.reclass/parse.c:41
+msgid "poor quality"
+msgstr ""
+#: ../raster/r.reclass/parse.c:43
+msgid "medium quality"
+msgstr ""
+#: ../raster/r.reclass/parse.c:58
+msgid "Can't have null on the left-hand side of the rule"
+msgstr ""
+#: ../raster/r.reclass/parse.c:87 ../raster/r.reclass/parse.c:99
+msgid "Can't have null on the right-hand side of the rule"
+msgstr ""
+#: ../raster/r.reclass/parse.c:195
+#, c-format
+msgid "%f rounded up to %d\n"
+msgstr ""
+#: ../raster/r.reclass/reclass.c:49 ../raster/r.reclass/reclass.c:109
+msgid "Too many categories"
+msgstr ""
+#: ../raster/r.reclass/reclass.c:214
+#, c-format
+msgid "Cannot read header file of <%s@%s>"
+msgstr ""
+#: ../raster/r.reclass/reclass.c:229
+#, c-format
+msgid "Cannot create reclass file of <%s>"
+msgstr ""
+#: ../raster/r.reclass/reclass.c:242
+#, c-format
+msgid "Cannot create category file of <%s>"
+msgstr ""
+#: ../raster/r.reclass/main.c:49 ../raster/r.clump/main.c:49
+msgid "raster, statistics, reclass"
+msgstr ""
+#: ../raster/r.reclass/main.c:51
+msgid ""
+"Creates a new map layer whose category values are based upon a "
+"reclassification of the categories in an existing raster map layer."
+msgstr ""
+#: ../raster/r.reclass/main.c:56
+msgid "Raster map to be reclassified"
+msgstr ""
+#: ../raster/r.reclass/main.c:63
+msgid "File containing reclass rules"
+msgstr ""
+#: ../raster/r.reclass/main.c:71
+msgid "Title for the resulting raster map"
+msgstr ""
+#: ../raster/r.reclass/main.c:85 ../raster/r.recode/main.c:87
+msgid "Input map can NOT be the same as output map"
+msgstr ""
+#: ../raster/r.reclass/main.c:91
+#, c-format
+msgid "Cannot open rules file <%s>"
+msgstr ""
+#: ../raster/r.reclass/main.c:105
+#, c-format
+msgid "Enter rule(s), \"end\" when done, \"help\" if you need it\n"
+msgstr ""
+#: ../raster/r.reclass/main.c:107
+#, c-format
+msgid "fp: Data range is %.25f to %.25f\n"
+msgstr ""
+#: ../raster/r.reclass/main.c:118
+#, c-format
+msgid "Illegal reclass rule -"
+msgstr ""
+#: ../raster/r.reclass/main.c:119
+#, c-format
+msgid " ignored\n"
+msgstr ""
+#: ../raster/r.reclass/main.c:122
+msgid " - invalid reclass rule"
+msgstr ""
+#: ../raster/r.reclass/main.c:138
+#, c-format
+msgid "No rules specified. Raster map <%s> not created"
+msgstr ""
+#: ../raster/r.reclass/main.c:141 ../raster/r.recode/main.c:102
+msgid "No rules specified"
+msgstr ""
+#: ../raster/r.rescale/main.c:52
+msgid "Rescales the range of category values in a raster map layer."
+msgstr ""
+#: ../raster/r.rescale/main.c:95
+msgid "Quietly"
+msgstr ""
+#: ../raster/r.rescale/main.c:141
+#, c-format
+msgid "Rescale %s[%ld,%ld] to %s[%ld,%ld]"
+msgstr ""
+#: ../raster/r.in.gridatb/file_io.c:33
+msgid "Setting window header failed"
+msgstr ""
+#: ../raster/r.in.gridatb/file_io.c:36 ../raster/r.out.gridatb/file_io.c:41
+msgid "Rows changed"
+msgstr ""
+#: ../raster/r.in.gridatb/file_io.c:39 ../raster/r.out.gridatb/file_io.c:44
+msgid "Cols changed"
+msgstr ""
+#: ../raster/r.in.gridatb/main.c:43
+msgid "Imports GRIDATB.FOR map file (TOPMODEL) into GRASS raster map"
+msgstr ""
+#: ../raster/r.in.gridatb/main.c:47 ../raster/r.out.gridatb/main.c:57
+msgid "GRIDATB i/o map file"
+msgstr ""
+#: ../raster/r.in.gridatb/main.c:67
+#, c-format
+msgid "File not found: %s"
+msgstr ""
+#: ../raster/r.describe/main.c:61
+msgid "Prints terse list of category values found in a raster map layer."
+msgstr ""
+#: ../raster/r.describe/main.c:80
+msgid "Number of quantization steps"
+msgstr ""
+#: ../raster/r.describe/main.c:86
+msgid "Print the output one value per line"
+msgstr ""
+#: ../raster/r.describe/main.c:90
+msgid "Only print the range of the data"
+msgstr ""
+#: ../raster/r.describe/main.c:98
+msgid "Use the current region"
+msgstr ""
+#: ../raster/r.describe/main.c:102
+msgid "Read fp map as integer"
+msgstr ""
+#: ../raster/r.describe/main.c:126
+#, c-format
+msgid "%s = %s -- must be greater than zero"
+msgstr ""
+#: ../raster/r.describe/main.c:137
+#, c-format
+msgid "%s: [%s] not found"
+msgstr ""
+#: ../raster/r.horizon/main.c:179
+msgid "Horizon angle computation from a digital elevation model."
+msgstr ""
+#: ../raster/r.horizon/main.c:181
+msgid ""
+"Computes horizon angle height from a digital elevation model. The module has "
+"two different modes of operation:  1. Computes the entire horizon around a "
+"single point whose coordinates are given with the 'coord' option. The "
+"horizon height (in radians). 2. Computes one or more raster maps of the "
+"horizon height in a single direction.  The input for this is the angle (in "
+"degrees), which is measured  counterclockwise with east=0, north=90 etc. The "
+"output is the horizon height in radians."
+msgstr ""
+#: ../raster/r.horizon/main.c:234
+msgid "Direction in which you want to know the horizon height"
+msgstr ""
+#: ../raster/r.horizon/main.c:242 ../raster/r.sun2/main.c:371
+msgid "Angle step size for multidirectional horizon [degrees]"
+msgstr ""
+#: ../raster/r.horizon/main.c:250
+msgid ""
+"For horizon rasters, read from the DEM an extra buffer around the present "
+"region"
+msgstr ""
+#: ../raster/r.horizon/main.c:258
+msgid ""
+"For horizon rasters, read from the DEM an extra buffer eastward the present "
+"region"
+msgstr ""
+#: ../raster/r.horizon/main.c:266
+msgid ""
+"For horizon rasters, read from the DEM an extra buffer westward the present "
+"region"
+msgstr ""
+#: ../raster/r.horizon/main.c:274
+msgid ""
+"For horizon rasters, read from the DEM an extra buffer northward the present "
+"region"
+msgstr ""
+#: ../raster/r.horizon/main.c:282
+msgid ""
+"For horizon rasters, read from the DEM an extra buffer southward the present "
+"region"
+msgstr ""
+#: ../raster/r.horizon/main.c:290
+msgid "The maximum distance to consider when finding the horizon height"
+msgstr ""
+#: ../raster/r.horizon/main.c:299
+msgid "Prefix of the horizon raster output maps"
+msgstr ""
+#: ../raster/r.horizon/main.c:309
+msgid "Coordinate for which you want to calculate the horizon"
+msgstr ""
+#: ../raster/r.horizon/main.c:317 ../raster/r.sun2/main.c:479
+msgid "Sampling distance step coefficient (0.5-1.5)"
+msgstr ""
+#: ../raster/r.horizon/main.c:324
+msgid "Write output in degrees (default is radians)"
+msgstr ""
+#: ../raster/r.horizon/main.c:361
+msgid "You didn't specify a direction value or step size. Aborting."
+msgstr ""
+#: ../raster/r.horizon/main.c:367
+msgid "You didn't specify a horizon raster name. Aborting."
+msgstr ""
+#: ../raster/r.horizon/main.c:378
+msgid "You didn't specify an angle step size. Aborting."
+msgstr ""
+#: ../raster/r.horizon/main.c:392
+msgid "Could not read bufferzone size. Aborting."
+msgstr ""
+#: ../raster/r.horizon/main.c:398
+msgid "Could not read east bufferzone size. Aborting."
+msgstr ""
+#: ../raster/r.horizon/main.c:404
+msgid "Could not read west bufferzone size. Aborting."
+msgstr ""
+#: ../raster/r.horizon/main.c:411
+msgid "Could not read south bufferzone size. Aborting."
+msgstr ""
+#: ../raster/r.horizon/main.c:420
+msgid "Could not read north bufferzone size. Aborting."
+msgstr ""
+#: ../raster/r.horizon/main.c:426
+msgid "Could not read maximum distance. Aborting."
+msgstr ""
+#: ../raster/r.horizon/main.c:1134
+#, c-format
+msgid "Calculating map %01d of %01d (angle %lf, raster map <%s>)"
+msgstr ""
+#: ../raster/r.clump/clump.c:98
+#, c-format
+msgid "Pass %d..."
+msgstr ""
+#: ../raster/r.clump/clump.c:101
+#, c-format
+msgid "Unable to read raster map row %d "
+msgstr ""
+#: ../raster/r.clump/clump.c:238
+#, c-format
+msgid "Failed writing raster map row %d"
+msgstr ""
+#: ../raster/r.clump/main.c:51
+msgid ""
+"Recategorizes data in a raster map by grouping cells that form physically "
+"discrete areas into unique categories."
+msgstr ""
+#: ../raster/r.clump/main.c:63 ../raster/r.recode/main.c:60
+msgid "Title for output raster map"
+msgstr ""
+#: ../raster/r.clump/main.c:120
+#, c-format
+msgid "%d clumps."
+msgstr ""
+#: ../raster/r.sun2/main.c:262
+msgid "A single value of the orientation (aspect), 270 is south"
+msgstr ""
+#: ../raster/r.sun2/main.c:279
+msgid "A single value of inclination (slope)"
+msgstr ""
+#: ../raster/r.sun2/main.c:328
+msgid "Name of input raster map containing latitudes [decimal degrees]"
+msgstr ""
+#: ../raster/r.sun2/main.c:337
+msgid "Name of input raster map containing longitudes [decimal degrees]"
+msgstr ""
+#: ../raster/r.sun2/main.c:346
+msgid "Name of real-sky beam radiation coefficient input raster map [-]"
+msgstr ""
+#: ../raster/r.sun2/main.c:355
+msgid "Name of real-sky diffuse radiation coefficient input raster map [-]"
+msgstr ""
+#: ../raster/r.sun2/main.c:363
+msgid "The horizon information input map prefix"
+msgstr ""
+#: ../raster/r.sun2/main.c:425
+msgid ""
+"Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/"
+"irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr ""
+#: ../raster/r.sun2/main.c:487
+msgid "Read the input files in this number of chunks"
+msgstr ""
+#: ../raster/r.sun2/main.c:494
+msgid "Civil time zone value, if none, the time will be local solar time"
+msgstr ""
+#: ../raster/r.sun2/main.c:514
+msgid "Use the low-memory version of the program"
+msgstr ""
+#: ../raster/r.sun2/main.c:561
+msgid "You must give the longitude raster if you use civil time"
+msgstr ""
+#: ../raster/r.sun2/main.c:564
+msgid "Error reading civil time zone value"
+msgstr ""
+#: ../raster/r.sun2/main.c:567
+msgid "Invalid civil time zone value"
+msgstr ""
+#: ../raster/r.sun2/main.c:597
+msgid "Error reading time step size"
+msgstr ""
+#: ../raster/r.sun2/main.c:599
+msgid "Invalid time step size"
+msgstr ""
+#: ../raster/r.sun2/main.c:603
+msgid "Error reading horizon step size"
+msgstr ""
+#: ../raster/r.sun2/main.c:607
+msgid "The horizon step size must be greater than 0."
+msgstr ""
+#: ../raster/r.sun2/main.c:610
+msgid ""
+"If you use the horizon option you must also set the 'horizonstep' parameter."
+msgstr ""
+#: ../raster/r.sun2/main.c:616
+msgid "Time and insol_time are incompatible options"
+msgstr ""
+#: ../raster/r.sun2/main.c:618
+msgid ""
+"Mode 1: instantaneous solar incidence angle & irradiance using a set local "
+"time"
+msgstr ""
+#: ../raster/r.sun2/main.c:671
+msgid "If you use -s and no horizon rasters, numpartitions must be =1"
+msgstr ""
+#: ../raster/r.sun2/main.c:683
+msgid ""
+"If you want to save memory and to use shadows, you must use pre-calculated "
+"horizons."
+msgstr ""
+#: ../raster/r.sun2/main.c:750
+msgid "latin and longin raster maps have no effect when in a Lat/Lon location"
+msgstr ""
+#: ../raster/r.sun2/main.c:755
+msgid "Both latin and longin raster maps must be given, or neither"
+msgstr ""
+#: ../raster/r.sun2/main.c:949
+#, c-format
+msgid "Horizon file no. %d <%s> not found"
+msgstr ""
+#: ../raster/r.quant/read_rules.c:49
+msgid "Old data range is empty"
+msgstr ""
+#: ../raster/r.quant/read_rules.c:55
+#, c-format
+msgid "Old data range is %s to %s"
+msgstr ""
+#: ../raster/r.quant/read_rules.c:58
+msgid "Old integer data range is empty"
+msgstr ""
+#: ../raster/r.quant/read_rules.c:60
+#, c-format
+msgid "Old integer data range is %d to %d"
+msgstr ""
+#: ../raster/r.quant/main.c:41
+msgid "raster, quantization"
+msgstr ""
+#: ../raster/r.quant/main.c:43
+msgid "Produces the quantization file for a floating-point map."
+msgstr ""
+#: ../raster/r.quant/main.c:51
+msgid "Base map to take quant rules from"
+msgstr ""
+#: ../raster/r.quant/main.c:59
+msgid "Raster map(s) to be quantized"
+msgstr ""
+#: ../raster/r.quant/main.c:64
+msgid "Floating point range: dmin,dmax"
+msgstr ""
+#: ../raster/r.quant/main.c:72
+msgid "Integer range: min,max"
+msgstr ""
+#: ../raster/r.quant/main.c:79
+msgid "Truncate floating point data"
+msgstr ""
+#: ../raster/r.quant/main.c:83
+msgid "Round floating point data"
+msgstr ""
+#: ../raster/r.quant/main.c:111
+msgid "Truncating..."
+msgstr ""
+#: ../raster/r.quant/main.c:116
+msgid "Rounding..."
+msgstr ""
+#: ../raster/r.quant/main.c:144
+#, c-format
+msgid "Setting quant rules for input map(s) to (%f %f) -> (%d,%d)"
+msgstr ""
+#: ../raster/r.quant/main.c:154
+msgid "No rules specified. Quant table(s) not changed."
+msgstr ""
+#: ../raster/r.quant/main.c:164
+#, c-format
+msgid "Quant table not changed for %s"
+msgstr ""
+#: ../raster/r.quant/main.c:166
+#, c-format
+msgid "New quant table created for %s"
+msgstr ""
+#: ../raster/r.gwflow/main.c:55
+msgid "The initial piezometric head in [m]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:60
+msgid "Boundary condition status, 0-inactive, 1-active, 2-dirichlet"
+msgstr ""
+#: ../raster/r.gwflow/main.c:65
+msgid "X-part of the hydraulic conductivity tensor in [m/s]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:70
+msgid "Y-part of the hydraulic conductivity tensor in [m/s]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:75
+msgid "Water sources and sinks in [m^3/s]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:79
+msgid "Specific yield in [1/m]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:84
+msgid "Recharge"
+msgstr ""
+#: ../raster/r.gwflow/main.c:86
+msgid "Recharge map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:90
+msgid "Top surface of the aquifer in [m]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:94
+msgid "Bottom surface of the aquifer in [m]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:98
+msgid "The map storing the numerical result [m]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:104
+msgid ""
+"Calculate the groundwater filter velocity vector field [m/s]\n"
+"and write the x, and y components to maps named name_[xy]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:113
+msgid "The type of groundwater flow"
+msgstr ""
+#: ../raster/r.gwflow/main.c:120
+msgid "The height of the river bed in [m]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:127
+msgid "Water level (head) of the river with leakage connection in [m]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:134
+msgid "The leakage coefficient of the river bed in [1/s]."
+msgstr ""
+#: ../raster/r.gwflow/main.c:140
+msgid "The height of the drainage bed in [m]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:147
+msgid "The leakage coefficient of the drainage bed in [1/s]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:159
+msgid "Use a sparse matrix, only available with iterative solvers"
+msgstr ""
+#: ../raster/r.gwflow/main.c:191
+msgid ""
+"Numerical calculation program for transient, confined and unconfined "
+"groundwater flow in two dimensions."
+msgstr ""
+#: ../raster/r.gwflow/main.c:216
+msgid "Please provide river_head, river_leak and river_bed maps"
+msgstr ""
+#: ../raster/r.gwflow/main.c:228
+msgid "Please provide drain_head and drain_leak maps"
+msgstr ""
+#: ../raster/r.gwflow/main.c:244
+msgid "The direct cholesky solver do not work with sparse matrices"
+msgstr ""
+#: ../raster/r.gwflow/main.c:360
+#, c-format
+msgid "Calculation of unconfined groundwater flow loop %i\n"
+msgstr ""
+#: ../raster/r.gwflow/main.c:383
+#, c-format
+msgid "Maximum difference between this and last increment: %g"
+msgstr ""
+#: ../raster/wildfire/r.spreadpath/main.c:72
+#: ../raster/wildfire/r.ros/main.c:212 ../raster/wildfire/r.spread/main.c:101
+msgid "raster, fire"
+msgstr ""
+#: ../raster/wildfire/r.spreadpath/main.c:74
+msgid ""
+"Recursively traces the least cost path backwards to cells from which the "
+"cumulative cost was determined."
+msgstr ""
+#: ../raster/wildfire/r.spreadpath/main.c:83
+msgid "Name of raster map containing back-path easting information"
+msgstr ""
+#: ../raster/wildfire/r.spreadpath/main.c:91
+msgid "Name of raster map containing back-path northing information"
+msgstr ""
+#: ../raster/wildfire/r.spreadpath/main.c:99
+msgid "The map E and N grid coordinates of starting points"
+msgstr ""
+#: ../raster/wildfire/r.spreadpath/main.c:106
+msgid "Name of spread path raster map"
+msgstr ""
+#: ../raster/wildfire/r.ros/main.c:214
+msgid ""
+"Generates three, or four raster map layers showing 1) the base "
+"(perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the "
+"direction of the maximum ROS, and optionally 4) the maximum potential "
+"spotting distance."
+msgstr ""
+#: ../raster/wildfire/r.ros/main.c:224
+msgid "Name of raster map containing fuel MODELs"
+msgstr ""
+#: ../raster/wildfire/r.ros/main.c:231
+msgid "Name of raster map containing the 1-HOUR fuel MOISTURE (%)"
+msgstr ""
+#: ../raster/wildfire/r.ros/main.c:238
+msgid "Name of raster map containing the 10-HOUR fuel MOISTURE (%)"
+msgstr ""
+#: ../raster/wildfire/r.ros/main.c:245
+msgid "Name of raster map containing the 100-HOUR fuel MOISTURE (%)"
+msgstr ""
+#: ../raster/wildfire/r.ros/main.c:253
+msgid "Name of raster map containing LIVE fuel MOISTURE (%)"
+msgstr ""
+#: ../raster/wildfire/r.ros/main.c:260
+msgid "Name of raster map containing midflame wind VELOCITYs (ft/min)"
+msgstr ""
+#: ../raster/wildfire/r.ros/main.c:267
+msgid "Name of raster map containing wind DIRECTIONs (degree)"
+msgstr ""
+#: ../raster/wildfire/r.ros/main.c:274
+msgid "Name of raster map containing SLOPE (degree)"
+msgstr ""
+#: ../raster/wildfire/r.ros/main.c:281
+msgid "Name of raster map containing ASPECT (degree, anti-clockwise from E)"
+msgstr ""
+#: ../raster/wildfire/r.ros/main.c:288
+msgid "Name of raster map containing ELEVATION (m) (required w/ -s)"
+msgstr ""
+#: ../raster/wildfire/r.ros/main.c:296
+msgid "Name of raster map to contain results (several new layers)"
+msgstr ""
+#: ../raster/wildfire/r.ros/main.c:305
+msgid "Also produce maximum SPOTTING distance"
+msgstr ""
+#: ../raster/wildfire/r.ros/main.c:424 ../raster/wildfire/r.ros/main.c:428
+#: ../raster/wildfire/r.ros/main.c:432 ../raster/wildfire/r.ros/main.c:439
+#: ../raster/wildfire/r.spread/main.c:384
+#: ../raster/wildfire/r.spread/main.c:393
+#: ../raster/wildfire/r.spread/main.c:403
+#, c-format
+msgid "Raster map <%s> already exists in mapset <%s>, select another name"
+msgstr ""
+#: ../raster/wildfire/r.ros/main.c:640
+msgid "Percent Completed ... "
+msgstr ""
+#: ../raster/wildfire/r.spread/main.c:103
+msgid ""
+"Simulates elliptically anisotropic spread on a graphics window and generates "
+"a raster map of the cumulative time of spread, given raster maps containing "
+"the rates of spread (ROS), the ROS directions and the spread origins."
+msgstr ""
+#: ../raster/wildfire/r.spread/main.c:108
+msgid ""
+"It optionally produces raster maps to contain backlink UTM coordinates for "
+"tracing spread paths."
+msgstr ""
+#: ../raster/wildfire/r.spread/main.c:116
+#: ../raster/wildfire/r.spread/main.c:125
+#: ../raster/wildfire/r.spread/main.c:134
+#: ../raster/wildfire/r.spread/main.c:143
+#: ../raster/wildfire/r.spread/main.c:151
+#: ../raster/wildfire/r.spread/main.c:159
+#: ../raster/wildfire/r.spread/main.c:167
+msgid "Input_maps"
+msgstr ""
+#: ../raster/wildfire/r.spread/main.c:118
+msgid "Name of raster map containing MAX rate of spread (ROS) (cm/min)"
+msgstr ""
+#: ../raster/wildfire/r.spread/main.c:127
+msgid "Name of raster map containing DIRections of max ROS (degree)"
+msgstr ""
+#: ../raster/wildfire/r.spread/main.c:136
+msgid "Name of raster map containing BASE ROS (cm/min)"
+msgstr ""
+#: ../raster/wildfire/r.spread/main.c:145
+msgid "Name of raster map containing STARTing sources"
+msgstr ""
+#: ../raster/wildfire/r.spread/main.c:153
+msgid ""
+"Name of raster map containing max SPOTting DISTance (m) (required w/ -s)"
+msgstr ""
+#: ../raster/wildfire/r.spread/main.c:161
+msgid ""
+"Name of raster map containing midflame Wind SPEED (ft/min) (required w/ -s)"
+msgstr ""
+#: ../raster/wildfire/r.spread/main.c:169
+msgid ""
+"Name of raster map containing fine Fuel MOISture of the cell receiving a "
+"spotting firebrand (%) (required w/ -s)"
+msgstr ""
+#: ../raster/wildfire/r.spread/main.c:177
+msgid "Basic sampling window SIZE needed to meet certain accuracy (3)"
+msgstr ""
+#: ../raster/wildfire/r.spread/main.c:184
+msgid "Sampling DENSity for additional COMPutin (range: 0.0 - 1.0 (0.5))"
+msgstr ""
+#: ../raster/wildfire/r.spread/main.c:191
+msgid "INITial TIME for current simulation (0) (min)"
+msgstr ""
+#: ../raster/wildfire/r.spread/main.c:198
+msgid "Simulating time duration LAG (fill the region) (min)"
+msgstr ""
+#: ../raster/wildfire/r.spread/main.c:205
+msgid "Name of raster map as a display backdrop"
+msgstr ""
+#: ../raster/wildfire/r.spread/main.c:212
+#: ../raster/wildfire/r.spread/main.c:220
+#: ../raster/wildfire/r.spread/main.c:228
+msgid "Output_maps"
+msgstr ""
+#: ../raster/wildfire/r.spread/main.c:214
+msgid "Name of raster map to contain OUTPUT spread time (min)"
+msgstr ""
+#: ../raster/wildfire/r.spread/main.c:222
+msgid "Name of raster map to contain X_BACK coordinates"
+msgstr ""
+#: ../raster/wildfire/r.spread/main.c:230
+msgid "Name of raster map to contain Y_BACK coordinates"
+msgstr ""
+#: ../raster/wildfire/r.spread/main.c:235
+msgid "Run VERBOSELY"
+msgstr ""
+#: ../raster/wildfire/r.spread/main.c:239
+msgid "DISPLAY 'live' spread process on screen"
+msgstr ""
+#: ../raster/wildfire/r.spread/main.c:243
+msgid "For wildfires: consider SPOTTING effect"
+msgstr ""
+#: ../raster/wildfire/r.spread/main.c:463
+msgid "Reading inputs..."
+msgstr ""
+#: ../raster/r.surf.random/main.c:46
+msgid ""
+"Produces a raster map of uniform random deviates whose range can be "
+"expressed by the user."
+msgstr ""
+#: ../raster/r.surf.random/main.c:53
+msgid "Minimum random value"
+msgstr ""
+#: ../raster/r.surf.random/main.c:59
+msgid "Maximum random value"
+msgstr ""
+#: ../raster/r.surf.random/main.c:65
+msgid "Create an integer raster map"
+msgstr ""
+#: ../raster/r.surf.random/main.c:79
+#, c-format
+msgid "Raster map <%s> generated."
+msgstr ""
+#: ../raster/r.composite/main.c:72
+msgid "raster, composite"
+msgstr ""
+#: ../raster/r.composite/main.c:74
+msgid ""
+"Combines red, green and blue raster maps into a single composite raster map."
+msgstr ""
+#: ../raster/r.composite/main.c:100
+msgid "Number of levels to be used for each component"
+msgstr ""
+#: ../raster/r.composite/main.c:101 ../raster/r.composite/main.c:119
+msgid "Levels"
+msgstr ""
+#: ../raster/r.composite/main.c:116
+#, c-format
+msgid "Number of levels to be used for <%s>"
+msgstr ""
+#: ../raster/r.composite/main.c:126
+msgid "Dither"
+msgstr ""
+#: ../raster/r.composite/main.c:130
+msgid "Use closest color"
+msgstr ""
+#: ../raster/r.composite/main.c:210
+#, c-format
+msgid "Error reading raster map <%s>"
+msgstr ""
+#: ../raster/r.composite/main.c:297
+msgid "Creating color table for output raster map..."
+msgstr ""
+#: ../raster/r.out.arc/main.c:62
+msgid "Converts a raster map layer into an ESRI ARCGRID file."
+msgstr ""
+#: ../raster/r.out.arc/main.c:70
+msgid "Name of an output ARC-GRID map (use out=- for stdout)"
+msgstr ""
+#: ../raster/r.out.arc/main.c:77
+msgid "Number of decimal places"
+msgstr ""
+#: ../raster/r.out.arc/main.c:87
+msgid "List one entry per line instead of full row"
+msgstr ""
+#: ../raster/r.out.arc/main.c:93
+msgid "Use cell center reference in header instead of cell corner"
+msgstr ""
+#: ../raster/r.out.gridatb/file_io.c:38
+msgid "Setting window header"
+msgstr ""
+#: ../raster/r.out.gridatb/main.c:46
+msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)"
+msgstr ""
+#: ../raster/r.out.gridatb/main.c:50
+msgid "Input map"
+msgstr ""
+#: ../raster/r.out.gridatb/main.c:63
+msgid "Overwrite output map file"
+msgstr ""
+#: ../raster/r.mfilter.fp/main.c:59
+msgid "Raster map matrix filter."
+msgstr ""
+#: ../raster/r.mfilter.fp/main.c:70
+msgid "Name of filter file"
+msgstr ""
+#: ../raster/r.mfilter.fp/main.c:101
+msgid "Apply filter only to null data values"
+msgstr ""
+#: ../raster/r.texture/h_measure.c:84
+msgid ""
+"Negative or no data pixel found. This module is not yet able to process no "
+"data holes in a map, please fill with r.fillnulls or other algorithms"
+msgstr ""
+#: ../raster/r.texture/h_measure.c:88
+#, c-format
+msgid ""
+"Too many categories (found: %i, max: %i). Try to rescale or reclassify the "
+"map"
+msgstr ""
+#: ../raster/r.texture/h_measure.c:937
+#, c-format
+msgid "Too many iterations to required to find %s - giving up"
+msgstr ""
+#: ../raster/r.texture/main.c:76
+msgid "Generate images with textural features from a raster map."
+msgstr ""
+#: ../raster/r.texture/main.c:87
+msgid "Prefix for output raster map(s)"
+msgstr ""
+#: ../raster/r.texture/main.c:94
+msgid "The size of sliding window (odd and >= 3)"
+msgstr ""
+#: ../raster/r.texture/main.c:104
+msgid "The distance between two samples (>= 1)"
+msgstr ""
+#: ../raster/r.texture/main.c:122
+msgid "Angular Second Moment"
+msgstr ""
+#: ../raster/r.texture/main.c:123 ../raster/r.texture/main.c:128
+#: ../raster/r.texture/main.c:133 ../raster/r.texture/main.c:138
+#: ../raster/r.texture/main.c:143 ../raster/r.texture/main.c:148
+#: ../raster/r.texture/main.c:153 ../raster/r.texture/main.c:158
+#: ../raster/r.texture/main.c:163 ../raster/r.texture/main.c:168
+#: ../raster/r.texture/main.c:173 ../raster/r.texture/main.c:178
+#: ../raster/r.texture/main.c:183 ../raster/r.texture/main.c:188
+msgid "Features"
+msgstr ""
+#: ../raster/r.texture/main.c:127
+msgid "Contrast"
+msgstr ""
+#: ../raster/r.texture/main.c:132
+msgid "Correlation"
+msgstr ""
+#: ../raster/r.texture/main.c:137
+msgid "Variance"
+msgstr ""
+#: ../raster/r.texture/main.c:142
+msgid "Inverse Diff Moment"
+msgstr ""
+#: ../raster/r.texture/main.c:147
+msgid "Sum Average"
+msgstr ""
+#: ../raster/r.texture/main.c:152
+msgid "Sum Variance"
+msgstr ""
+#: ../raster/r.texture/main.c:157
+msgid "Sum Entropy"
+msgstr ""
+#: ../raster/r.texture/main.c:162
+msgid "Entropy"
+msgstr ""
+#: ../raster/r.texture/main.c:167
+msgid "Difference Variance"
+msgstr ""
+#: ../raster/r.texture/main.c:172
+msgid "Difference Entropy"
+msgstr ""
+#: ../raster/r.texture/main.c:177
+msgid "Measure of Correlation-1"
+msgstr ""
+#: ../raster/r.texture/main.c:182
+msgid "Measure of Correlation-2"
+msgstr ""
+#: ../raster/r.texture/main.c:187
+msgid "Max Correlation Coeff"
+msgstr ""
+#: ../raster/r.texture/main.c:216
+msgid "Nothing to compute. Use at least one of the flags."
+msgstr ""
+#: ../raster/r.texture/main.c:373
+#, c-format
+msgid "Calculated measure #%d <%s> (56 measures available)"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:24
+#, c-format
+msgid "Data range of raster map <%s> is empty"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:31
+#, c-format
+msgid "Data range of raster map <%s> is %s to %s (entire map)"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:36
+#, c-format
+msgid "Unable to read range of raster map <%s>"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:41
+#, c-format
+msgid "Integer data range of raster map <%s> is empty"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:44
+#, c-format
+msgid "Integer data range of raster mao <%s> is %d to %d"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:63
+msgid "Enter the rule or 'help' for the format description"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:87
+msgid "Enter a rule in one of these formats:"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:89
+msgid "old_low:old_high:new_low:new_high"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:90
+msgid "old_low:old_high:new_val      (i.e. new_high == new_low)"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:91
+msgid "*:old_val:new_val             (interval [inf, old_val])"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:92
+msgid "old_val:*:new_val             (interval [old_val, inf])"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:94
+msgid "When finished type \"end\"."
+msgstr ""
+#: ../raster/r.recode/read_rules.c:134
+#, c-format
+msgid "'%s' is not a valid rule"
+msgstr ""
+#: ../raster/r.recode/main.c:41
+msgid "raster, recode category"
+msgstr ""
+#: ../raster/r.recode/main.c:42
+msgid "Recodes categorical raster maps."
+msgstr ""
+#: ../raster/r.recode/main.c:45
+msgid "Name of raster map to be recoded"
+msgstr ""
+#: ../raster/r.recode/main.c:52
+msgid "File containing recode rules"
+msgstr ""
+#: ../raster/r.recode/main.c:53
+msgid "\"-\" to read from stdin"
+msgstr ""
+#: ../raster/r.recode/main.c:64
+msgid "Align the current region to the input raster map"
+msgstr ""
+#: ../raster/r.recode/main.c:68
+msgid "Force output to 'double' raster map type (DCELL)"
+msgstr ""
+#: ../raster/r.recode/main.c:99
+#, c-format
+msgid "No rules specified. Raster map <%s> not created."
+msgstr ""
+#: ../raster/r.in.mat/main.c:94
+msgid "Imports a binary MAT-File(v4) to a GRASS raster."
+msgstr ""
+#: ../raster/r.in.mat/main.c:103
+msgid "Name of an existing MAT-File(v4)"
+msgstr ""
+#: ../raster/r.in.mat/main.c:110
+msgid "Name for the output raster map (override)"
+msgstr ""
+#: ../raster/r.in.mat/main.c:168
+msgid "Reading MAT-File..."
+msgstr ""
+#: ../raster/r.in.mat/main.c:194
+msgid "Array contains no data"
+msgstr ""
+#: ../raster/r.in.mat/main.c:199
+msgid "Array contains imaginary data"
+msgstr ""
+#: ../raster/r.in.mat/main.c:205
+msgid "Invalid array name"
+msgstr ""
+#: ../raster/r.in.mat/main.c:225
+msgid "Invalid 'map_name' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:235
+msgid "Error reading 'map_name' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:246
+msgid "Invalid 'map_northern_edge' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:255
+msgid "Invalid 'map_southern_edge' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:264
+msgid "Invalid 'map_eastern_edge' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:273
+msgid "Invalid 'map_western_edge' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:281
+msgid "Invalid 'map_title' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:291
+msgid "Error reading 'map_title' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:304
+msgid "Invalid 'map_data' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:330 ../raster/r.in.mat/main.c:468
+#: ../raster/r.in.mat/main.c:550
+msgid "Please contact the GRASS development team"
+msgstr ""
+#: ../raster/r.in.mat/main.c:335
+#, c-format
+msgid "Skipping unknown array '%s'"
+msgstr ""
+#: ../raster/r.in.mat/main.c:363
+#, c-format
+msgid "No 'map_data' array found in <%s>"
+msgstr ""
+#: ../raster/r.in.mat/main.c:370
+#, c-format
+msgid "Setting map name to <%s> which overrides <%s>"
+msgstr ""
+#: ../raster/r.in.mat/main.c:377
+#, c-format
+msgid "Setting map name to <%s>"
+msgstr ""
+#: ../raster/r.in.mat/main.c:381
+msgid "No 'map_name' array found; using <MatFile>"
+msgstr ""
+#: ../raster/r.in.mat/main.c:394
+msgid "Missing bound"
+msgstr ""
+#: ../raster/r.in.mat/main.c:398
+msgid "Using default bounds"
+msgstr ""
+#: ../raster/r.in.mat/main.c:414
+#, c-format
+msgid "Map <%s> bounds set to:"
+msgstr ""
+#: ../raster/r.in.mat/main.c:415 ../raster/r.out.mat/main.c:198
+#, c-format
+msgid "northern edge=%f"
+msgstr ""
+#: ../raster/r.in.mat/main.c:416 ../raster/r.out.mat/main.c:199
+#, c-format
+msgid "southern edge=%f"
+msgstr ""
+#: ../raster/r.in.mat/main.c:417 ../raster/r.out.mat/main.c:200
+#, c-format
+msgid "eastern edge=%f"
+msgstr ""
+#: ../raster/r.in.mat/main.c:418 ../raster/r.out.mat/main.c:201
+#, c-format
+msgid "western edge=%f"
+msgstr ""
+#: ../raster/r.in.mat/main.c:419 ../raster/r.out.mat/main.c:202
+#, c-format
+msgid "nsres=%f"
+msgstr ""
+#: ../raster/r.in.mat/main.c:420 ../raster/r.out.mat/main.c:203
+#, c-format
+msgid "ewres=%f"
+msgstr ""
+#: ../raster/r.in.mat/main.c:421 ../raster/r.out.mat/main.c:204
+#, c-format
+msgid "rows=%d"
+msgstr ""
+#: ../raster/r.in.mat/main.c:422 ../raster/r.out.mat/main.c:205
+#, c-format
+msgid "cols=%d"
+msgstr ""
+#: ../raster/r.in.mat/main.c:433
+msgid "Writing new raster map..."
+msgstr ""
+#: ../raster/r.in.mat/main.c:491
+#, c-format
+msgid "Writing raster map, row %d"
+msgstr ""
+#: ../raster/r.series/main.c:133
+msgid "raster, series"
+msgstr ""
+#: ../raster/r.series/main.c:135
+msgid ""
+"Makes each output cell value a function of the values assigned to the "
+"corresponding cells in the input raster map layers."
+msgstr ""
+#: ../raster/r.series/main.c:149
+msgid "Aggregate operation"
+msgstr ""
+#: ../raster/r.series/main.c:156
+msgid "Quantile to calculate for method=quantile"
+msgstr ""
+#: ../raster/r.series/main.c:164
+msgid "Threshold to calculate for method=threshold"
+msgstr ""
+#: ../raster/r.series/main.c:176
+msgid "Ignore values outside this range"
+msgstr ""
+#: ../raster/r.series/main.c:228
+msgid "output= and method= must have the same number of values"
+msgstr ""
+#: ../raster/r.support.stats/check.c:42
+#, c-format
+msgid "Updating statistics for [%s]..."
+msgstr ""
+#: ../raster/r.support.stats/check.c:55
+msgid "Updating histogram range..."
+msgstr ""
+#: ../raster/r.support.stats/check.c:87
+#, c-format
+msgid "Updating the number of categories for [%s]..."
+msgstr ""
+#: ../raster/r.support.stats/main.c:38
+msgid "Update raster map statistics"
+msgstr ""
+#: ../raster/r.support.stats/main.c:53
+#, c-format
+msgid "Statistics for <%s> updated"
+msgstr ""
+#: ../raster/r.profile/input.c:29 ../raster/r.profile/input.c:46
+#: ../raster/r.profile/input.c:59
+msgid "One coordinate pair per line, please"
+msgstr ""
+#: ../raster/r.profile/main.c:53
+msgid "raster, profile"
+msgstr ""
+#: ../raster/r.profile/main.c:55
+msgid "Outputs the raster map layer values lying on user-defined line(s)."
+msgstr ""
+#: ../raster/r.profile/main.c:66
+msgid "Name of file for output (use output=- for stdout)"
+msgstr ""
+#: ../raster/r.profile/main.c:74
+msgid "Profile coordinate pairs"
+msgstr ""
+#: ../raster/r.profile/main.c:81
+msgid "Resolution along profile (default = current region resolution)"
+msgstr ""
+#: ../raster/r.profile/main.c:88
+msgid "Character to represent no data cell"
+msgstr ""
+#: ../raster/r.profile/main.c:92
+msgid "Interactively select End-Points"
+msgstr ""
+#: ../raster/r.profile/main.c:102
+msgid "Output RRR:GGG:BBB color values for each profile point"
+msgstr ""
+#: ../raster/r.profile/main.c:121
+#, c-format
+msgid "Illegal resolution! [%g]"
+msgstr ""
+#: ../raster/r.profile/main.c:130
+#, c-format
+msgid "Using resolution [%g]"
+msgstr ""
+#: ../raster/r.profile/main.c:176
+msgid "Output Format:"
+msgstr ""
+#: ../raster/r.profile/main.c:179
+#, c-format
+msgid "[Easting] [Northing] [Along Track Dist.(m)] [Elevation]"
+msgstr ""
+#: ../raster/r.profile/main.c:181
+#, c-format
+msgid "[Along Track Dist.(m)] [Elevation]"
+msgstr ""
+#: ../raster/r.profile/main.c:183
+msgid " [RGB Color]"
+msgstr ""
+#: ../raster/r.profile/main.c:193
+#, c-format
+msgid "Invalid coordinates %s %s"
+msgstr ""
+#: ../raster/r.profile/main.c:209
+#, c-format
+msgid "Use mouse to select Start Point\n"
+msgstr ""
+#: ../raster/r.profile/main.c:214
+#, c-format
+msgid ""
+"\n"
+"Use mouse to draw profile line\n"
+msgstr ""
+#: ../raster/r.profile/main.c:215
+#, c-format
+msgid "Buttons:\n"
+msgstr ""
+#: ../raster/r.profile/main.c:216
+#, c-format
+msgid "Left:   Mark next point\n"
+msgstr ""
+#: ../raster/r.profile/main.c:217
+#, c-format
+msgid "Middle: Mark next point\n"
+msgstr ""
+#: ../raster/r.profile/main.c:218
+#, c-format
+msgid ""
+"Right:  Finish profile and exit\n"
+"\n"
+msgstr ""
+#: ../raster/r.profile/main.c:305
+#, c-format
+msgid "Approx. transect length [%f] m"
+msgstr ""
+#: ../raster/r.profile/main.c:308
+msgid "Endpoint coordinates are outside of current region settings"
+msgstr ""
+#: ../raster/r.statistics/o_adev.c:97
+msgid "o_adev: No data in array"
+msgstr ""
+#: ../raster/r.statistics/o_skew.c:97
+msgid "o_skew: No data in array"
+msgstr ""
+#: ../raster/r.statistics/o_sum.c:35 ../raster/r.statistics/o_average.c:33
+#: ../raster/r.statistics/o_distrib.c:31
+#, c-format
+msgid "%s: running %s command"
+msgstr ""
+#: ../raster/r.statistics/o_var.c:100 ../raster/r.statistics/o_sdev.c:100
+msgid "o_var: No data in array"
+msgstr ""
+#: ../raster/r.statistics/o_kurt.c:96
+msgid "o_kurto: No data in array"
+msgstr ""
+#: ../raster/r.statistics/main.c:44
+msgid "Calculates category or object oriented statistics."
+msgstr ""
+#: ../raster/r.statistics/main.c:62
+msgid "Method of object-based statistic"
+msgstr ""
+#: ../raster/r.statistics/main.c:67
+msgid "Resultant raster map (not used with 'distribution')"
+msgstr ""
+#: ../raster/r.statistics/main.c:82 ../raster/r.statistics/main.c:88
+msgid "This module currently only works for integer (CELL) maps"
+msgstr ""
+#: ../raster/r.statistics/main.c:110
+#, c-format
+msgid "Output map <%s> ignored"
+msgstr ""
+#: ../raster/r.statistics/main.c:177
+msgid "Not yet implemented!"
+msgstr ""
+#: ../raster/r.statistics/main.c:187
+#, c-format
+msgid "An output raster map needs to be defined with method '%s'"
+msgstr ""
+#: ../raster/r.out.mat/main.c:65
+msgid "Exports a GRASS raster to a binary MAT-File."
+msgstr ""
+#: ../raster/r.out.mat/main.c:76
+msgid "Name for the output binary MAT-File"
+msgstr ""
+#: ../raster/r.out.mat/main.c:137
+#, c-format
+msgid "Exporting <%s>"
+msgstr ""
+#: ../raster/r.out.mat/main.c:197
+msgid "Using the Current Region settings:"
+msgstr ""
+#: ../raster/r.out.mat/main.c:272
+msgid "Exporting raster as integer values"
+msgstr ""
+#: ../raster/r.out.mat/main.c:277
+msgid "Exporting raster as floating point values"
+msgstr ""
+#: ../raster/r.out.mat/main.c:282
+msgid "Exporting raster as double FP values"
+msgstr ""
+#: ../raster/r.out.mat/main.c:325
+msgid "Reading in map ... "
+msgstr ""
+#: ../raster/r.out.mat/main.c:339
+msgid "Writing out map..."
+msgstr ""
+#: ../raster/r.out.mat/main.c:399
+#, c-format
+msgid "%ld bytes written to '%s'"
+msgstr ""
+#: ../raster/r.cats/cats.c:35
+#, c-format
+msgid "Cannot read header of raster map <%s> in <%s>"
+msgstr ""
+#: ../raster/r.cats/cats.c:43
+#, c-format
+msgid "Cannot open cell file of raster map <%s> in <%s>"
+msgstr ""
+#: ../raster/r.cats/cats.c:51
+#, c-format
+msgid "Reading <%s> in <%s>"
+msgstr ""
+#: ../raster/r.cats/main.c:51
+msgid "raster, category"
+msgstr ""
+#: ../raster/r.cats/main.c:53
+msgid ""
+"Manages category values and labels associated with user-specified raster map "
+"layers."
+msgstr ""
+#: ../raster/r.cats/main.c:66
+msgid "Comma separated value list"
+msgstr ""
+#: ../raster/r.cats/main.c:67
+msgid "Example: 1.4,3.8,13"
+msgstr ""
+#: ../raster/r.cats/main.c:84
+msgid "File containing category label rules (or \"-\" to read from stdin)"
+msgstr ""
+#: ../raster/r.cats/main.c:91
+msgid "Default label or format string for dynamic labeling"
+msgstr ""
+#: ../raster/r.cats/main.c:93
+msgid "Used when no explicit label exists for the category"
+msgstr ""
+#: ../raster/r.cats/main.c:101
+msgid "Dynamic label coefficients"
+msgstr ""
+#: ../raster/r.cats/main.c:103
+msgid "Two pairs of category multiplier and offsets, for $1 and $2"
+msgstr ""
+#: ../raster/r.cats/main.c:159
+#, c-format
+msgid "Category table for <%s> set from <%s>"
+msgstr ""
+#: ../raster/r.cats/main.c:197 ../raster/r.cats/main.c:243
+#, c-format
+msgid "Cannot create category file for <%s>"
+msgstr ""
+#: ../raster/r.cats/main.c:252
+#, c-format
+msgid "Unable to read category file of raster map <%s> in <%s>"
+msgstr ""
+#: ../raster/r.cats/main.c:268
+msgid "The map is floating point! Ignoring cats list, using vals list"
+msgstr ""
+#: ../raster/r.cats/main.c:285
+msgid "vals argument is required for floating point map!"
+msgstr ""
+#: ../raster/r.patch/main.c:55
+msgid ""
+"Creates a composite raster map layer by using known category values from one "
+"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
+msgstr ""
+#: ../raster/r.patch/main.c:62
+msgid "Name of raster maps to be patched together"
+msgstr ""
+#: ../raster/r.patch/main.c:65
+msgid "Name for resultant raster map"
+msgstr ""
+#: ../raster/r.patch/main.c:77
+msgid "Use zero (0) for transparency instead of NULL"
+msgstr ""
+#: ../raster/r.patch/main.c:102
+msgid "The minimum number of input raster maps is two"
+msgstr ""
+#: ../raster/r.patch/main.c:139
+msgid "One or more input raster maps not found"
+msgstr ""
+#: ../raster/r.patch/main.c:181
+#, c-format
+msgid "Creating support files for raster map <%s>"
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:65
+#: ../raster/r.out.gdal/export_band.c:373
+msgid "Unable to allocate buffer for reading raster map"
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:186
+#, c-format
+msgid ""
+"Input raster map contains cells with NULL-value (no-data). The value %d will "
+"be used to represent no-data values in the input map. You can specify a "
+"nodata value with the %s option."
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:191
+#, c-format
+msgid ""
+"Input raster map contains cells with NULL-value (no-data). The value %f will "
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:201
+#, c-format
+msgid ""
+"The default nodata value is present in rasterband <%s> and would lead to "
+"data loss. Please specify a custom nodata value with the %s parameter."
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:208
+#, c-format
+msgid ""
+"The user given nodata value %g is present in rasterband <%s> and would lead "
+"to data loss. Please specify a different nodata value with the %s parameter."
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:254
+msgid "Unable to get raster band"
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:414
+#: ../raster/r.out.gdal/export_band.c:447
+#: ../raster/r.out.gdal/export_band.c:480
+msgid "Unable to write GDAL raster file"
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:498
+#: ../raster/r.out.gdal/export_band.c:510
+#: ../raster/r.out.gdal/export_band.c:523
+#: ../raster/r.out.gdal/export_band.c:536
+#: ../raster/r.out.gdal/export_band.c:548
+#: ../raster/r.out.gdal/export_band.c:561
+#: ../raster/r.out.gdal/export_band.c:575 ../raster/r.out.gdal/main.c:631
+#: ../raster/r.out.gdal/main.c:643 ../raster/r.out.gdal/main.c:656
+#: ../raster/r.out.gdal/main.c:669 ../raster/r.out.gdal/main.c:681
+#: ../raster/r.out.gdal/main.c:694
+msgid "Selected GDAL datatype does not cover data range."
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:499
+#: ../raster/r.out.gdal/export_band.c:511
+#: ../raster/r.out.gdal/export_band.c:524
+#: ../raster/r.out.gdal/export_band.c:537 ../raster/r.out.gdal/main.c:632
+#: ../raster/r.out.gdal/main.c:644 ../raster/r.out.gdal/main.c:657
+#: ../raster/r.out.gdal/main.c:670
+#, c-format
+msgid "GDAL datatype: %s, range: %d - %d"
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:502
+#: ../raster/r.out.gdal/export_band.c:514
+#: ../raster/r.out.gdal/export_band.c:527
+#: ../raster/r.out.gdal/export_band.c:540
+#: ../raster/r.out.gdal/export_band.c:552
+#: ../raster/r.out.gdal/export_band.c:565
+#: ../raster/r.out.gdal/export_band.c:579
+#, c-format
+msgid "Raster map <%s> range: %g - %g"
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:549 ../raster/r.out.gdal/main.c:682
+#, c-format
+msgid "GDAL datatype: %s, range: %u - %u"
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:562
+#: ../raster/r.out.gdal/export_band.c:576 ../raster/r.out.gdal/main.c:695
+#, c-format
+msgid "GDAL datatype: %s, range: %g - %g"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:49
+#, c-format
+msgid "Supported formats:\n"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:127
+msgid "Exports GRASS raster maps into GDAL supported formats."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:137
+msgid "Do not write GDAL standard colortable"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:138
+msgid "Only applicable to Byte or UInt16 data types."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:142
+msgid "Force raster export despite any warnings of data loss"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:143
+msgid "Overrides nodata safety check."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:147
+msgid "Name of raster map (or group) to export"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:183
+msgid "Name for output raster file"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:190
+msgid "Creation option(s) to pass to the output format driver"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:199
+msgid "Metadata key(s) and value(s) to include"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:201
+msgid ""
+"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. "
+"Not supported by all output format drivers."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:210
+msgid "Assign a specified nodata value to output bands"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:243
+#, c-format
+msgid "Raster map or group <%s> not found"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:247
+#, c-format
+msgid "No raster maps in group <%s>"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:261
+#, c-format
+msgid "Unable to get <%s> driver"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:267
+#, c-format
+msgid ""
+"Driver <%s> does not support direct writing. Using MEM driver for "
+"intermediate dataset."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:272
+msgid "Unable to get in-memory raster driver"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:276
+#, c-format
+msgid "Driver <%s> does not support creating rasters"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:352
+#, c-format
+msgid "Could not read data range of raster <%s>"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:409
+#, c-format
+msgid "Exporting to GDAL data type: %s"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:424
+msgid "Raster export would result in complete data loss, aborting."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:435
+#, c-format
+msgid ""
+"Precision loss: Raster map <%s> of type %s to be exported as %s. This can be "
+"avoided by using %s."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:446
+#, c-format
+msgid ""
+"Precision loss: The range of <%s> can not be accurately preserved with GDAL "
+"datatype Float32. This can be avoided by exporting to Int32 or Float64."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:454
+#, c-format
+msgid ""
+"Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. "
+"This can be avoided by using Float64"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:482 ../raster/r.out.gdal/main.c:511
+#: ../raster/r.out.gdal/main.c:515
+msgid "Raster export aborted."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:492
+msgid "Checking GDAL data type and nodata value"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:495
+#, c-format
+msgid "Checking options for raster map <%s> (band %d)..."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:509
+msgid "Forcing raster export."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:536
+msgid "Output file name not specified"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:542
+msgid "Unable to create dataset using memory raster driver"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:551
+#, c-format
+msgid "Unable to create <%s> dataset using <%s> driver"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:566
+msgid "Unable to set geo transform"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:574
+msgid "Unable to set projection"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:580
+msgid "Exporting to GDAL raster"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:583
+#, c-format
+msgid "Exporting raster map <%s> (band %d)..."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:596
+#, c-format
+msgid "Unable to export raster map <%s>"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:608
+#, c-format
+msgid "Unable to create raster map <%s> using driver <%s>"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:635 ../raster/r.out.gdal/main.c:647
+#: ../raster/r.out.gdal/main.c:660 ../raster/r.out.gdal/main.c:673
+#: ../raster/r.out.gdal/main.c:685
+#, c-format
+msgid "Range to be exported: %f - %f"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:698
+#, c-format
+msgid "Range to be exported: %g - %g"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:722 ../raster/r.out.gdal/main.c:735
+#: ../raster/r.out.gdal/main.c:749 ../raster/r.out.gdal/main.c:762
+#: ../raster/r.out.gdal/main.c:777
+#, c-format
+msgid ""
+"Mismatch between metadata nodata value and actual nodata value in exported "
+"raster: specified nodata value %f gets converted to %d by selected GDAL "
+"datatype."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:725 ../raster/r.out.gdal/main.c:752
+#: ../raster/r.out.gdal/main.c:780
+#, c-format
+msgid "GDAL datatype: %s, valid range: %d - %d"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:738 ../raster/r.out.gdal/main.c:765
+#, c-format
+msgid "GDAL datatype: %s, valid range: %u - %u"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:791
+#, c-format
+msgid ""
+"raster: specified nodata value %g gets converted to %g by selected GDAL "
+"datatype."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:794
+#, c-format
+msgid "GDAL datatype: %s, valid range: %g - %g"
+msgstr ""
+#: ../raster/r.surf.contour/main.c:54
+msgid "Surface generation program from rasterized contours."
+msgstr ""
+#: ../raster/r.surf.contour/main.c:61
+msgid "Name of existing raster map containing contours"
+msgstr ""
+#: ../raster/r.surf.contour/main.c:68
+msgid "Output elevation raster map"
+msgstr ""
+#: ../raster/r.surf.contour/main.c:72
+msgid "Unused; retained for compatibility purposes, will be removed in future"
+msgstr ""
+#: ../raster/r.surf.contour/main.c:77
+msgid ""
+"Invoke slow, but memory frugal operation (generally not needed, will be "
+"removed in future)"
+msgstr ""
+#: ../raster/r.watershed/ram/sg_factor.c:13
+#: ../raster/r.watershed/seg/sg_factor.c:12
+msgid "SECTION 4: RUSLE LS and/or S factor determination."
+msgstr ""
+#: ../raster/r.watershed/ram/init_vars.c:103
+#, c-format
+msgid "SECTION 1a (of %1d): Initiating Memory."
+msgstr ""
+#: ../raster/r.watershed/ram/init_vars.c:150
+#: ../raster/r.watershed/seg/init_vars.c:191
+msgid "unable to open elevation map layer"
+msgstr ""
+#: ../raster/r.watershed/ram/init_vars.c:218
+msgid "unable to open runoff map layer"
+msgstr ""
+#: ../raster/r.watershed/ram/init_vars.c:241
+#: ../raster/r.watershed/seg/init_vars.c:278
+msgid "unable to open depression map layer"
+msgstr ""
+#: ../raster/r.watershed/ram/init_vars.c:258
+#: ../raster/r.watershed/seg/init_vars.c:307
+msgid "unable to open blocking map layer"
+msgstr ""
+#: ../raster/r.watershed/ram/init_vars.c:275
+msgid "unable to open rill map layer"
+msgstr ""
+#: ../raster/r.watershed/ram/init_vars.c:303
+#: ../raster/r.watershed/seg/init_vars.c:366
+#, c-format
+msgid "SECTION 1b (of %1d): Determining Offmap Flow."
+msgstr ""
+#: ../raster/r.watershed/ram/usage.c:9 ../raster/r.watershed/seg/usage.c:9
+#, c-format
+msgid ""
+"USAGE for basin delineation:\n"
+"%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] "
+"[dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] "
+"[di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
+"\n"
+"USAGE for ARMSED FILE creation:\n"
+"%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] "
+"[di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] "
+"ha=half_basin_map ar=ARMSED_file_name\n"
+"\n"
+"USAGE for slope length determination:\n"
+"%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] "
+"[de=depression_map] [ac=accumulation_map] [di=display_map] "
+"[ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] "
+"LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or map]"
+msgstr ""
+#: ../raster/r.watershed/ram/do_astar.c:26
+#: ../raster/r.watershed/seg/do_astar.c:30
+msgid "SECTION 2: A * Search."
+msgstr ""
+#: ../raster/r.watershed/ram/do_astar.c:160
+#: ../raster/r.watershed/seg/do_astar.c:161
+msgid "heapsize too large"
+msgstr ""
+#: ../raster/r.watershed/ram/do_cum.c:16 ../raster/r.watershed/seg/do_cum.c:17
+msgid "SECTION 3: Accumulating Surface Flow with SFD."
+msgstr ""
+#: ../raster/r.watershed/ram/do_cum.c:117
+#: ../raster/r.watershed/seg/do_cum.c:121
+msgid "SECTION 3: Accumulating Surface Flow with MFD."
+msgstr ""
+#: ../raster/r.watershed/ram/do_cum.c:312
+#: ../raster/r.watershed/seg/do_cum.c:326
+#, c-format
+msgid "MFD: cumulative proportion of flow distribution not 1.0 but %f"
+msgstr ""
+#: ../raster/r.watershed/ram/do_cum.c:367
+#: ../raster/r.watershed/seg/do_cum.c:385
+#, c-format
+msgid "MFD: A * path already processed when distributing flow: %d of %d cells"
+msgstr ""
+#: ../raster/r.watershed/ram/close_maps.c:30
+#: ../raster/r.watershed/ram/close_maps.c:165
+#: ../raster/r.watershed/seg/close_maps.c:28
+msgid "unable to open new accum map layer."
+msgstr ""
+#: ../raster/r.watershed/ram/close_maps.c:66
+#: ../raster/r.watershed/ram/close_maps.c:153
+#: ../raster/r.watershed/ram/close_maps.c:186
+#: ../raster/r.watershed/ram/close_maps.c:211
+#: ../raster/r.watershed/ram/close_maps.c:231
+#: ../raster/r.watershed/ram/close_maps.c:251
+#: ../raster/r.watershed/seg/close_maps.c:44
+msgid "Close failed."
+msgstr ""
+#: ../raster/r.watershed/ram/close_maps.c:142
+msgid "unable to open new aspect map layer."
+msgstr ""
+#: ../raster/r.watershed/ram/close_maps.c:201
+msgid "unable to open new LS factor map layer."
+msgstr ""
+#: ../raster/r.watershed/ram/close_maps.c:219
+msgid "unable to open new slope length map layer."
+msgstr ""
+#: ../raster/r.watershed/ram/close_maps.c:241
+msgid "unable to open new S factor map layer."
+msgstr ""
+#: ../raster/r.watershed/ram/main.c:79 ../raster/r.watershed/ram/main.c:95
+#: ../raster/r.watershed/seg/main.c:84 ../raster/r.watershed/seg/main.c:95
+#, c-format
+msgid "SECTION %d: Closing Maps."
+msgstr ""
+#: ../raster/r.watershed/ram/main.c:93 ../raster/r.watershed/seg/main.c:93
+#, c-format
+msgid "SECTION %d: Watershed determination."
+msgstr ""
+#: ../raster/r.watershed/front/main.c:57
+msgid "Watershed basin analysis program."
+msgstr ""
+#: ../raster/r.watershed/front/main.c:61
+msgid "Input map: elevation on which entire analysis is based"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:66
+msgid "Input map: locations of real depressions"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:72
+msgid "Input map: amount of overland flow per cell"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:79
+msgid "Input map or value: percent of disturbed land, for USLE"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:88
+msgid "Input map: terrain blocking overland surface flow, for USLE"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:95
+msgid "Output map: number of cells that drain through each cell"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:101
+msgid "Output map: drainage direction"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:108
+msgid "Output map: unique label for each watershed basin"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:114
+msgid "Output map: stream segments"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:121
+msgid "Output map: each half-basin is given a unique value"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:128
+msgid "Output map: useful for visual display of results"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:135
+msgid "Output map: slope length and steepness (LS) factor for USLE"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:141
+msgid "Output map: slope steepness (S) factor for USLE"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:148
+msgid "Input value: minimum size of exterior watershed basin"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:156
+msgid "Input value: maximum length of surface flow, for USLE"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:166
+msgid "Convergence factor for MFD (1-10)"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:168
+msgid "1 = most diverging flow, 10 = most converging flow. Recommended: 5"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:175
+msgid "Maximum memory to be used with -m flag (in MB)"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:179
+msgid "Enable MFD flow (default is SFD (D8))"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:181
+msgid "SFD: single flow direction, MFD: multiple flow direction"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:186
+msgid "Allow only horizontal and vertical flow of water"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:191
+msgid "Enable disk swap memory option: Operation is slow"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:193
+msgid ""
+"Only needed if memory requirements exceed available RAM; see manual on how "
+"to calculate memory requirements"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:198
+msgid "Use positive flow accumulation even for likely underestimates"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:200
+msgid "See manual for a detailed description of flow accumulation output"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:217
+msgid "Sorry, you must choose an output map."
+msgstr ""
+#: ../raster/r.watershed/front/main.c:233
+msgid ""
+"Sorry, if any of the following options are set:\n"
+"    basin, stream, half.basin, length.slope, or slope.steepness\n"
+"    you MUST provide a value for the basin threshold parameter."
+msgstr ""
+#: ../raster/r.watershed/front/main.c:388
+#, c-format
+msgid "Subprocess failed with exit code %d"
+msgstr ""
+#: ../raster/r.watershed/shed/intro.c:8
+#, c-format
+msgid "%s provides a text-based user-interface to the %s program."
+msgstr ""
+#: ../raster/r.watershed/shed/intro.c:10
+#, c-format
+msgid "%s also allows the user to prepare a report of map layers for each"
+msgstr ""
+#: ../raster/r.watershed/shed/intro.c:12
+#, c-format
+msgid "watershed basin determined in %s.\n"
+msgstr ""
+#: ../raster/r.watershed/shed/intro.c:14
+#, c-format
+msgid "%s will help the user determine which options to use for the"
+msgstr ""
+#: ../raster/r.watershed/shed/intro.c:16
+#, c-format
+msgid "%s program.  %s will then ask for map layers that will be"
+msgstr ""
+#: ../raster/r.watershed/shed/intro.c:18
+#, c-format
+msgid "divided by basin. %s will then run %s and create the report."
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:12
+msgid ""
+"\n"
+"\n"
+"Please indicate which map layers you wish to use in the lumped"
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:13
+msgid "parameter hydrologic/soil erosion model.  Continue inputing cell map"
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:14
+msgid "layers, one at a time, until all desired map layers are in."
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:15
+#, c-format
+msgid "You can have %s include a list of categories in each."
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:17
+#, c-format
+msgid ""
+"\n"
+"Hit <return> at the map prompt to continue with %s"
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:36
+#, c-format
+msgid ""
+"\n"
+"The output from %s will be divided into watershed"
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:38
+msgid "basins.  There are two possible methods of tabulating the information:"
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:39
+msgid "1) by only including data pertaining to the basin itself, or 2) using"
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:40
+msgid "data from the basin, and all basins upstream of it."
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:43
+msgid ""
+"\n"
+"Would you like the data organized:"
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:44
+msgid ""
+"1) Basin only\n"
+"2) Upstream only\n"
+"3) Both\n"
+"OR 0) to cancel program"
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:45
+#, c-format
+msgid ""
+"\n"
+"Your choice: "
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:69
+#: ../raster/r.watershed/shed/basin_maps.c:73
+#, c-format
+msgid ""
+"\n"
+"OK, %s should start running now using the following form:\n"
+"%s"
+msgstr ""
+#: ../raster/r.watershed/shed/valid.c:24
+msgid "accum file missing in valid_basins()"
+msgstr ""
+#: ../raster/r.watershed/shed/valid.c:28
+msgid "unable to open accum file in valid_basins()"
+msgstr ""
+#: ../raster/r.watershed/shed/read.c:23
+msgid "unable to open basin/half basin map"
+msgstr ""
+#: ../raster/r.watershed/shed/file_in.c:15
+msgid "unable to open ARMSED file"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:23
+msgid ""
+"\n"
+"This set of questions will organize the command line for the"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:24
+#, c-format
+msgid "%s program to run properly for your application."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:26
+#, c-format
+msgid "The first question is whether you want %s to run"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:28
+#, c-format
+msgid "in its fast mode or its slow mode.  If you run %s"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:30
+msgid "in the fast mode, the computer will finish about 10 times faster"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:31
+msgid "than in the slow mode, but will not allow other programs to run"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:32
+msgid "at the same time.  The fast mode also places all of the data into"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:33
+msgid "RAM, which limits the size of window that can be run.  The slow"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:34
+msgid "mode uses disk space in the same hard disk partition as where GRASS is"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:35
+msgid "stored.  Thus, if the program does not work in the slow mode, you will"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:36
+msgid "need to remove unnecessary files from that partition.  The slow mode"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:37
+#, c-format
+msgid "will allow other processes to run concurrently with %s.\n"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:69
+#: ../raster/r.watershed/shed/com_line.c:182
+msgid ""
+"\n"
+"If you hit <return> by itself for the next question, this"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:70
+#: ../raster/r.watershed/shed/com_line.c:183
+msgid "program will terminate."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:81
+#, c-format
+msgid ""
+"\n"
+"One of the options for %s is a `depression map'.  A"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:83
+msgid ""
+"depression map indicates all the locations in the current map window where"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:84
+msgid ""
+"water accumulates and does not leave by the edge of the map. Lakes without"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:85
+msgid ""
+"outlet streams and sinkholes are examples of `depressions'.  If you wish to"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:86
+msgid "have a depression map, prepare a map where non-zero values indicate the"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:87
+msgid "locations where depressions occur.\n"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:88
+msgid ""
+"Hit <return> by itself for the next question if there is no depression map."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:99
+#, c-format
+msgid ""
+"\n"
+"The %s program will divide the elevation map into a number of"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:101
+msgid ""
+"watershed basins.  The number of watershed basins is indirectly determined"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:102
+msgid ""
+"by the `basin threshold' value.  The basin threshold is the area necessary "
+"for"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:103
+#, c-format
+msgid "%s to define a unique watershed basin.  This area only applies to"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:105
+msgid ""
+"`exterior drainage basins'.  An exterior drainage basin does not have any"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:106
+msgid ""
+"drainage basins flowing into it.  Interior drainage basin size is determined"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:107
+msgid ""
+"by the surface flow going into stream segments between stream interceptions."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:108
+#, c-format
+msgid "Thus interior drainage basins can be of any size.  The %s program"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:110
+msgid "also allows the user to relate basin size to potential overland flow"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:111
+msgid ""
+"(i.e., areas with low infiltration capacities will need smaller areas to"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:112
+msgid ""
+"develop stream channels than neighboring areas with high infiltration rates)."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:113
+msgid ""
+"The user can create a map layer with potential overland flow values, and"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:114
+#, c-format
+msgid "%s will accumulate those values instead of area.\n"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:116
+msgid "What unit of measure will you use for the basin threshold:"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:119
+msgid " 1) acres,          2) meters sq., 3) miles sq., 4) hectares,"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:120
+msgid " 5) kilometers sq., 6) map cells,  7) overland flow units"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:121
+#, c-format
+msgid "Choose 1-7 or 0 to exit this program: "
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:131
+msgid ""
+"\n"
+"How large an area (or how many overland flow units) must a drainage basin"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:132
+#, c-format
+msgid "be for it to be an exterior drainage basin: "
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:201
+#, c-format
+msgid ""
+"\n"
+"%s must create a map layer of watershed basins"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:203
+#: ../raster/r.watershed/shed/com_line.c:224
+#, c-format
+msgid "before %s can run properly."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:222
+#, c-format
+msgid ""
+"\n"
+"%s must create a file of watershed basin relationships"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:228
+#: ../raster/r.watershed/shed/com_line.c:263
+#, c-format
+msgid ""
+"\n"
+"Please name this file:"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:257
+#, c-format
+msgid ""
+"\n"
+"%s will generate a lot of output.  Indicate a file"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:259
+#, c-format
+msgid "name for %s to send the output to."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:277
+#, c-format
+msgid ""
+"\n"
+"The accumulation map from %s must be present for"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:279
+#, c-format
+msgid "%s to work properly."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:290
+#, c-format
+msgid ""
+"\n"
+"%s can produce several maps not necessary for"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:292
+#, c-format
+msgid "%s to function (stream channels, overland flow aspect, and"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:294
+#, c-format
+msgid "a display version of the accumulation map).  %s also has the"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:296
+msgid ""
+"ability to generate several variables in the Revised Universal Soil Loss"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:297
+msgid "Equation (Rusle): Slope Length (LS), and Slope Steepness (S).\n"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:348
+msgid ""
+"\n"
+"The Slope Length factor (LS) and Slope Steepness (S) are influenced by"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:349
+#, c-format
+msgid "disturbed land.  %s reflects this with an optional map layer or value"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:351
+msgid ""
+"where the value indicates the percent of disturbed (barren) land in that "
+"cell."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:352
+msgid "Type <return> if you do not have a disturbed land map layer."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:364
+msgid ""
+"\n"
+"Type the value indicating the percent of disturbed land.  This value will"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:365
+msgid "be used for every cell in the current region."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:368
+#, c-format
+msgid ""
+"\n"
+"Input value here [0-100]: "
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:379
+msgid ""
+"\n"
+"Overland surface flow only occurs for a set distance before swales form."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:380
+#, c-format
+msgid "Because of digital terrain model limitations, %s cannot pick up"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:382
+#, c-format
+msgid "these swales.  %s allows for an input (warning: kludge factor)"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:384
+msgid ""
+"that prevents the surface flow distance from getting too long.  Normally,"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:385
+msgid "maximum slope length is around 600 feet (about 183 meters)."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:400
+msgid ""
+"\n"
+"Roads, ditches, changes in ground cover, and other factors will stop"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:401
+msgid ""
+"slope length.  You may input a raster map indicating the locations of these"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:402
+msgid "blocking factors.\n"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:403
+msgid ""
+"Hit <return> by itself for the next question if there is no blocking map."
+msgstr ""
+#: ../raster/r.watershed/shed/main.c:41
+msgid "Slow version of water analysis program starting now"
+msgstr ""
+#: ../raster/r.watershed/shed/main.c:46 ../raster/r.watershed/shed/main.c:55
+#, c-format
+msgid "<<%s>> command line failed"
+msgstr ""
+#: ../raster/r.watershed/shed/main.c:72
+msgid "unable to open output file"
+msgstr ""
+#: ../raster/r.watershed/seg/init_vars.c:114
+#, c-format
+msgid "SECTION 1 beginning: Initiating Variables. %d sections total."
+msgstr ""
+#: ../raster/r.watershed/seg/init_vars.c:150
+msgid ""
+"Maximum memory to be used was smaller than 3 MB, set to default = 300 MB."
+msgstr ""
+#: ../raster/r.watershed/seg/close_maps.c:52
+msgid "unable to open flow accumulation map layer"
+msgstr ""
+#: ../raster/r.thin/thin_lines.c:67
+#, c-format
+msgid "%s: Unable to find bounding box for lines"
+msgstr ""
+#: ../raster/r.thin/thin_lines.c:70
+#, c-format
+msgid "Bounding box:  l = %d, r = %d, t = %d, b = %d"
+msgstr ""
+#: ../raster/r.thin/thin_lines.c:119
+#, c-format
+msgid "Pass number %d"
+msgstr ""
+#: ../raster/r.thin/thin_lines.c:170
+#, c-format
+msgid "Deleted %d  pixels "
+msgstr ""
+#: ../raster/r.thin/thin_lines.c:174
+msgid "Thinning completed successfully."
+msgstr ""
+#: ../raster/r.thin/thin_lines.c:176
+msgid "Thinning not completed, consider to increase 'iterations' parameter."
+msgstr ""
+#: ../raster/r.thin/io.c:105
+#, c-format
+msgid "File %s -- %d rows X %d columns"
+msgstr ""
+#: ../raster/r.thin/io.c:115
+#, c-format
+msgid "%s: Unable to create temporary file <%s> -- errno = %d"
+msgstr ""
+#: ../raster/r.thin/io.c:124 ../raster/r.thin/io.c:136
+#: ../raster/r.thin/io.c:147
+#, c-format
+msgid "%s: Error writing temporary file"
+msgstr ""
+#: ../raster/r.thin/io.c:131
+#, c-format
+msgid "%s: Error reading from raster map <%s> in mapset <%s>"
+msgstr ""
+#: ../raster/r.thin/io.c:173
+#, c-format
+msgid "Output file %d rows X %d columns"
+msgstr ""
+#: ../raster/r.thin/io.c:174
+#, c-format
+msgid "Window %d rows X %d columns"
+msgstr ""
+#: ../raster/r.thin/main.c:55
+msgid "raster, thin"
+msgstr ""
+#: ../raster/r.thin/main.c:57
+msgid "Thins non-zero cells that denote linear features in a raster map."
+msgstr ""
+#: ../raster/r.thin/main.c:69
+msgid "Maximal number of iterations"
+msgstr ""
Added: grass/branches/releasebranch_6_4/locale/po/grassnviz_nl.po
--- grass/branches/releasebranch_6_4/locale/po/grassnviz_nl.po	                        (rev 0)
+++ grass/branches/releasebranch_6_4/locale/po/grassnviz_nl.po	2012-06-19 22:28:16 UTC (rev 52142)
@@ -0,0 +1,2479 @@
+# SOME DESCRIPTIVE TITLE.
+# Copyright (C) YEAR THE PACKAGE'S COPYRIGHT HOLDER
+# This file is distributed under the same license as the PACKAGE package.
+# FIRST AUTHOR <EMAIL at ADDRESS>, YEAR.
+#, fuzzy
+msgid ""
+msgstr ""
+"Project-Id-Version: PACKAGE VERSION\n"
+"Report-Msgid-Bugs-To: \n"
+"POT-Creation-Date: 2012-06-19 23:46+0200\n"
+"PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
+"Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
+"Language-Team: LANGUAGE <LL at li.org>\n"
+"Language: \n"
+"MIME-Version: 1.0\n"
+"Content-Type: text/plain; charset=CHARSET\n"
+"Content-Transfer-Encoding: 8bit\n"
+#: ../visualization/nviz/scripts/script_get_line:15
+#: ../visualization/nviz/scripts/nviz2.2_script:431
+msgid "Add Script Line"
+msgstr ""
+#: ../visualization/nviz/scripts/script_get_line:18
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:466
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:553
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:858
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:1126
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:1708
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:1910
+#: ../visualization/nviz/scripts/wirecolorPopup.tcl:80
+#: ../visualization/nviz/scripts/script_file_tools:113
+#: ../visualization/nviz/scripts/nviz2.2_script:926
+#: ../visualization/nviz/scripts/panel_animation.tcl:577
+#: ../visualization/nviz/scripts/panel_animation.tcl:755
+#: ../visualization/nviz/scripts/panel_animation.tcl:801
+msgid "Ok"
+msgstr ""
+#: ../visualization/nviz/scripts/script_get_line:19
+#: ../visualization/nviz/scripts/filemapBrowser.tcl:173
+#: ../visualization/nviz/scripts/ACS_utils.tcl:312
+#: ../visualization/nviz/scripts/ACS_utils.tcl:354
+#: ../visualization/nviz/scripts/ACS_utils.tcl:375
+#: ../visualization/nviz/scripts/ACS_utils.tcl:430
+#: ../visualization/nviz/scripts/ACS_utils.tcl:475
+#: ../visualization/nviz/scripts/ACS_utils.tcl:569
+#: ../visualization/nviz/scripts/ACS_utils.tcl:641
+#: ../visualization/nviz/scripts/attPopup.tcl:133
+#: ../visualization/nviz/scripts/attPopup.tcl:475
+#: ../visualization/nviz/scripts/attPopup.tcl:523
+#: ../visualization/nviz/scripts/mapBrowser.tcl:229
+#: ../visualization/nviz/scripts/wirecolorPopup.tcl:83
+#: ../visualization/nviz/scripts/attIsosurfPopup.tcl:125
+#: ../visualization/nviz/scripts/attIsosurfPopup.tcl:410
+#: ../visualization/nviz/scripts/attIsosurfPopup.tcl:456
+#: ../visualization/nviz/scripts/script_file_tools:575
+#: ../visualization/nviz/scripts/script_file_tools:888
+#: ../visualization/nviz/scripts/panel_main.tcl:112
+#: ../visualization/nviz/scripts/fileBrowser.tcl:115
+#: ../visualization/nviz/scripts/script_tools:111
+#: ../visualization/nviz/scripts/multimapBrowser.tcl:172
+msgid "Cancel"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vect.tcl:55
+msgid "Vector Lines/3D Polygons"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vect.tcl:60
+msgid "Vector Lines Panel"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vect.tcl:65
+#: ../visualization/nviz/scripts/panel_surf.tcl:68
+#: ../visualization/nviz/scripts/fileBrowser.tcl:119
+#: ../visualization/nviz/scripts/panel_site.tcl:55
+#: ../visualization/nviz/scripts/panel_vol.tcl:51
+msgid "Current:"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vect.tcl:69
+#: ../visualization/nviz/scripts/panel_surf.tcl:70
+#: ../visualization/nviz/scripts/panel_site.tcl:58
+#: ../visualization/nviz/scripts/site_attr.tcl:1271
+msgid "New"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vect.tcl:70
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:131
+#: ../visualization/nviz/scripts/panel_surf.tcl:71
+#: ../visualization/nviz/scripts/script_file_tools:45
+#: ../visualization/nviz/scripts/panel_site.tcl:59
+#: ../visualization/nviz/scripts/panel_vol.tcl:494
+#: ../visualization/nviz/scripts/panel_vol.tcl:862
+#: ../visualization/nviz/scripts/panel_legend.tcl:170
+msgid "Delete"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vect.tcl:80
+#: ../visualization/nviz/scripts/panel_pos.tcl:125
+#: ../visualization/nviz/scripts/panel_lights.tcl:83
+#: ../visualization/nviz/scripts/panel_color.tcl:53
+#: ../visualization/nviz/scripts/panel_sdiff.tcl:69
+#: ../visualization/nviz/scripts/panel_fringe.tcl:82
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:111
+#: ../visualization/nviz/scripts/panel_surf.tcl:184
+#: ../visualization/nviz/scripts/panel_surf.tcl:726
+#: ../visualization/nviz/scripts/panel_vquery.tcl:144
+#: ../visualization/nviz/scripts/panel_scale.tcl:94
+#: ../visualization/nviz/scripts/nviz2.2_script:821
+#: ../visualization/nviz/scripts/panel_label.tcl:96
+#: ../visualization/nviz/scripts/panel_site.tcl:114
+#: ../visualization/nviz/scripts/script_tools:47
+#: ../visualization/nviz/scripts/panel_vol.tcl:1170
+#: ../visualization/nviz/scripts/panel_legend.tcl:138
+#: ../visualization/nviz/scripts/panel_cutplane.tcl:186
+#: ../visualization/nviz/scripts/panel_resize.tcl:58
+#: ../visualization/nviz/scripts/panel_tst.tcl:53
+#: ../visualization/nviz/scripts/panel_arrow.tcl:93
+#: ../visualization/nviz/scripts/panel_rquery.tcl:88
+#: ../visualization/nviz/scripts/panel_animation.tcl:203
+msgid "Close"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vect.tcl:82
+#: ../visualization/nviz/scripts/panel_surf.tcl:185
+#: ../visualization/nviz/scripts/panel_site.tcl:118
+#: ../visualization/nviz/scripts/panel_vol.tcl:115
+msgid "DRAW CURRENT"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vect.tcl:95
+msgid "line width"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vect.tcl:106
+#: ../visualization/nviz/scripts/panel_fringe.tcl:69
+#: ../visualization/nviz/scripts/panel_scale.tcl:60
+#: ../visualization/nviz/scripts/panel_scale.tcl:79
+#: ../visualization/nviz/scripts/panel_label.tcl:70
+#: ../visualization/nviz/scripts/panel_site.tcl:149
+#: ../visualization/nviz/scripts/panel_arrow.tcl:61
+#: ../visualization/nviz/scripts/panel_arrow.tcl:78
+msgid "Color"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vect.tcl:110
+msgid "display flat"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vect.tcl:113
+#: ../visualization/nviz/scripts/panel_site.tcl:166
+msgid "display on surface(s):"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vect.tcl:117
+msgid ""
+"vector height\n"
+"above surface"
+msgstr ""
+#: ../visualization/nviz/scripts/filemapBrowser.tcl:98
+#: ../visualization/nviz/scripts/multimapBrowser.tcl:99
+msgid "Remove"
+msgstr ""
+#: ../visualization/nviz/scripts/filemapBrowser.tcl:104
+#: ../visualization/nviz/scripts/mapBrowser.tcl:150
+#: ../visualization/nviz/scripts/multimapBrowser.tcl:105
+msgid "MAPSETS"
+msgstr ""
+#: ../visualization/nviz/scripts/filemapBrowser.tcl:118
+#: ../visualization/nviz/scripts/mapBrowser.tcl:168
+#: ../visualization/nviz/scripts/fileBrowser.tcl:99
+#: ../visualization/nviz/scripts/multimapBrowser.tcl:119
+msgid "FILES"
+msgstr ""
+#: ../visualization/nviz/scripts/filemapBrowser.tcl:148
+#: ../visualization/nviz/scripts/multimapBrowser.tcl:149
+msgid "Map Type:"
+msgstr ""
+#: ../visualization/nviz/scripts/filemapBrowser.tcl:151
+#: ../visualization/nviz/scripts/mapBrowser.tcl:207
+#: ../visualization/nviz/scripts/multimapBrowser.tcl:152
+msgid "Map Type"
+msgstr ""
+#: ../visualization/nviz/scripts/filemapBrowser.tcl:154
+#: ../visualization/nviz/scripts/mapBrowser.tcl:210
+#: ../visualization/nviz/scripts/multimapBrowser.tcl:155
+msgid "Raster"
+msgstr ""
+#: ../visualization/nviz/scripts/filemapBrowser.tcl:156
+#: ../visualization/nviz/scripts/mapBrowser.tcl:212
+#: ../visualization/nviz/scripts/multimapBrowser.tcl:157
+msgid "Vector"
+msgstr ""
+#: ../visualization/nviz/scripts/filemapBrowser.tcl:158
+#: ../visualization/nviz/scripts/mapBrowser.tcl:214
+#: ../visualization/nviz/scripts/multimapBrowser.tcl:159
+msgid "Site"
+msgstr ""
+#: ../visualization/nviz/scripts/filemapBrowser.tcl:160
+#: ../visualization/nviz/scripts/mapBrowser.tcl:216
+#: ../visualization/nviz/scripts/multimapBrowser.tcl:161
+msgid "Surf"
+msgstr ""
+#: ../visualization/nviz/scripts/filemapBrowser.tcl:162
+#: ../visualization/nviz/scripts/mapBrowser.tcl:220
+#: ../visualization/nviz/scripts/multimapBrowser.tcl:163
+msgid "Regions"
+msgstr ""
+#: ../visualization/nviz/scripts/filemapBrowser.tcl:164
+#: ../visualization/nviz/scripts/mapBrowser.tcl:222
+#: ../visualization/nviz/scripts/panel_main.tcl:158
+#: ../visualization/nviz/scripts/panel_label.tcl:60
+#: ../visualization/nviz/scripts/multimapBrowser.tcl:165
+msgid "Labels"
+msgstr ""
+#: ../visualization/nviz/scripts/filemapBrowser.tcl:167
+#: ../visualization/nviz/scripts/mapBrowser.tcl:225
+#: ../visualization/nviz/scripts/multimapBrowser.tcl:168
+msgid "Icons"
+msgstr ""
+#: ../visualization/nviz/scripts/filemapBrowser.tcl:170
+msgid "Blank"
+msgstr ""
+#: ../visualization/nviz/scripts/filemapBrowser.tcl:171
+msgid "Previous"
+msgstr ""
+#: ../visualization/nviz/scripts/filemapBrowser.tcl:172
+#: ../visualization/nviz/scripts/script_file_tools:54
+#: ../visualization/nviz/scripts/multimapBrowser.tcl:171
+#: ../visualization/nviz/scripts/panel_legend.tcl:171
+msgid "Done"
+msgstr ""
+#: ../visualization/nviz/scripts/filemapBrowser.tcl:201
+#: ../visualization/nviz/scripts/mapBrowser.tcl:141
+#: ../visualization/nviz/scripts/multimapBrowser.tcl:200
+msgid "Map Browser"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_pos.tcl:28
+#: ../visualization/nviz/scripts/panel_surf.tcl:92
+#: ../visualization/nviz/scripts/panel_vol.tcl:82
+msgid "Position"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_pos.tcl:34
+msgid "Position Panel"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_pos.tcl:45
+msgid "From (eye):"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_pos.tcl:46
+msgid "To (surface):"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_pos.tcl:49
+msgid "Range/bearing:"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_pos.tcl:52
+msgid "East"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_pos.tcl:56
+msgid "Range"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_pos.tcl:60
+msgid "North"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_pos.tcl:64
+msgid "Bearing"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_pos.tcl:68
+#: ../visualization/nviz/scripts/nviz2.2_script:805
+msgid "Height"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_pos.tcl:72
+msgid "Elev"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_pos.tcl:83
+msgid "Eye to surface"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_pos.tcl:84
+msgid "Surface to eye"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_pos.tcl:85
+msgid "Calculate"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_pos.tcl:95
+#: ../visualization/nviz/scripts/panel_resize.tcl:55
+msgid "Refresh"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_pos.tcl:109
+#: ../visualization/nviz/scripts/site_attr.tcl:472
+msgid "Apply"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_lights.tcl:25
+msgid "Lighting"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_lights.tcl:30
+msgid "Lighting Panel"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_lights.tcl:43
+msgid " Light source position"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_lights.tcl:58
+msgid "Follow surface viewpoint"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_lights.tcl:60
+msgid "Show lighting model"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_lights.tcl:66
+msgid "Light color"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_lights.tcl:70
+msgid "Light intensity"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_lights.tcl:81
+#: ../visualization/nviz/scripts/panel_surf.tcl:725
+#: ../visualization/nviz/scripts/nviz2.2_script:377
+#: ../visualization/nviz/scripts/nviz2.2_script:925
+#: ../visualization/nviz/scripts/panel_vol.tcl:1169
+#: ../visualization/nviz/scripts/panel_cutplane.tcl:182
+#: ../visualization/nviz/scripts/site_attr.tcl:483
+#: ../visualization/nviz/scripts/panel_rquery.tcl:64
+msgid "Reset"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_animation.tcl:955
+msgid "OK"
+msgstr ""
+#: ../visualization/nviz/scripts/ACS_utils.tcl:331
+msgid "ok"
+msgstr ""
+msgid "dismiss"
+msgstr ""
+#: ../visualization/nviz/scripts/attPopup.tcl:45
+#: ../visualization/nviz/scripts/attPopup.tcl:46
+#: ../visualization/nviz/scripts/panel_surf.tcl:671
+#: ../visualization/nviz/scripts/attIsosurfPopup.tcl:36
+#: ../visualization/nviz/scripts/attIsosurfPopup.tcl:37
+#: ../visualization/nviz/scripts/panel_vol.tcl:1115
+msgid "Attribute"
+msgstr ""
+#: ../visualization/nviz/scripts/attPopup.tcl:88
+#: ../visualization/nviz/scripts/attIsosurfPopup.tcl:80
+#, tcl-format
+msgid "Change attribute: %s"
+msgstr ""
+#: ../visualization/nviz/scripts/attPopup.tcl:92
+#: ../visualization/nviz/scripts/attIsosurfPopup.tcl:85
+msgid "New map"
+msgstr ""
+#: ../visualization/nviz/scripts/attPopup.tcl:97
+#: ../visualization/nviz/scripts/attIsosurfPopup.tcl:89
+msgid "Remove mask"
+msgstr ""
+#: ../visualization/nviz/scripts/attPopup.tcl:98
+#: ../visualization/nviz/scripts/attIsosurfPopup.tcl:90
+msgid "invert mask"
+msgstr ""
+#: ../visualization/nviz/scripts/attPopup.tcl:106
+#: ../visualization/nviz/scripts/attPopup.tcl:115
+#: ../visualization/nviz/scripts/attIsosurfPopup.tcl:98
+#: ../visualization/nviz/scripts/attIsosurfPopup.tcl:107
+msgid "New constant"
+msgstr ""
+#: ../visualization/nviz/scripts/attPopup.tcl:107
+msgid "use as color"
+msgstr ""
+#: ../visualization/nviz/scripts/attPopup.tcl:113
+msgid "Constant not supported"
+msgstr ""
+#: ../visualization/nviz/scripts/attPopup.tcl:122
+#: ../visualization/nviz/scripts/attIsosurfPopup.tcl:114
+msgid "Curr. value: "
+msgstr ""
+#: ../visualization/nviz/scripts/attPopup.tcl:128
+#: ../visualization/nviz/scripts/attPopup.tcl:474
+#: ../visualization/nviz/scripts/attPopup.tcl:522
+#: ../visualization/nviz/scripts/mapBrowser.tcl:227
+#: ../visualization/nviz/scripts/attIsosurfPopup.tcl:123
+#: ../visualization/nviz/scripts/attIsosurfPopup.tcl:409
+#: ../visualization/nviz/scripts/attIsosurfPopup.tcl:455
+#: ../visualization/nviz/scripts/script_file_tools:574
+#: ../visualization/nviz/scripts/script_file_tools:887
+#: ../visualization/nviz/scripts/fileBrowser.tcl:113
+#: ../visualization/nviz/scripts/script_tools:110
+msgid "Accept"
+msgstr ""
+#: ../visualization/nviz/scripts/attPopup.tcl:319
+msgid "Surface Color"
+msgstr ""
+#: ../visualization/nviz/scripts/attPopup.tcl:462
+#: ../visualization/nviz/scripts/attPopup.tcl:512
+#: ../visualization/nviz/scripts/attIsosurfPopup.tcl:399
+#: ../visualization/nviz/scripts/attIsosurfPopup.tcl:445
+msgid "Constant"
+msgstr ""
+#: ../visualization/nviz/scripts/attPopup.tcl:468
+msgid "Enter value:"
+msgstr ""
+#: ../visualization/nviz/scripts/attPopup.tcl:516
+msgid "Use slider to set value"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_color.tcl:38
+msgid "Background Color"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_color.tcl:44
+msgid "Background Color Panel"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_color.tcl:46
+msgid "Background"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_sdiff.tcl:39
+msgid "Scaled Difference"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_sdiff.tcl:45
+msgid "Scaled Difference Panel"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_sdiff.tcl:54
+msgid "Reference surface:"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_sdiff.tcl:58
+msgid "Set difference between reference surface and others"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_sdiff.tcl:64
+#: ../visualization/nviz/scripts/panel_main.tcl:109
+#: ../visualization/nviz/scripts/site_attr.tcl:1437
+#: ../visualization/nviz/scripts/panel_rquery.tcl:66
+msgid "Clear"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_sdiff.tcl:66
+msgid "unselect reference surface"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_sdiff.tcl:124
+msgid "None selected"
+msgstr ""
+#: ../visualization/nviz/scripts/mapBrowser.tcl:204
+msgid "Map type:"
+msgstr ""
+#: ../visualization/nviz/scripts/mapBrowser.tcl:218
+msgid "3d.view"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_fringe.tcl:43
+#: ../visualization/nviz/scripts/panel_main.tcl:164
+msgid "Fringe"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_fringe.tcl:45
+msgid "Fringe Panel"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_fringe.tcl:48
+msgid "Edges with fringe: "
+msgstr ""
+#: ../visualization/nviz/scripts/panel_fringe.tcl:51
+msgid "N&W"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_fringe.tcl:54
+msgid "N&E"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_fringe.tcl:57
+msgid "S&W"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_fringe.tcl:60
+msgid "S&E"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_fringe.tcl:68
+msgid "Elevation of fringe bottom: "
+msgstr ""
+#: ../visualization/nviz/scripts/panel_fringe.tcl:80
+msgid "Draw Fringe"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:79
+msgid "Keyframe Animation"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:80
+msgid "Keyframe Animation Panel"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:96
+msgid "Framerate :"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:105
+msgid "File: "
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:106
+#: ../visualization/nviz/scripts/site_attr.tcl:1434
+msgid "Save"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:107
+msgid "Load"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:109
+msgid "Animation: "
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:110
+msgid "Run and Save"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:130
+#: ../visualization/nviz/scripts/script_file_tools:44
+#: ../visualization/nviz/scripts/panel_vol.tcl:492
+#: ../visualization/nviz/scripts/panel_vol.tcl:860
+#: ../visualization/nviz/scripts/panel_legend.tcl:169
+msgid "Add"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:132
+msgid "New Key Time:"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:143
+msgid "Show Feature"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:146
+msgid "Path"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:148
+msgid "Vect Lines/Polygons"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:150
+msgid "Vect Points"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:152
+msgid "Volume"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:154
+msgid "Labels/Legend"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:159
+msgid "Interp."
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:162
+#: ../visualization/nviz/scripts/panel_animation.tcl:185
+msgid "linear"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:165
+#: ../visualization/nviz/scripts/panel_animation.tcl:189
+msgid "spline"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:168
+msgid "tension"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:230
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:1249
+#: ../visualization/nviz/scripts/nviz2.2_script:414
+msgid "On"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:447
+msgid "New Key Time"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:451
+msgid "Minute:"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:452
+msgid "Second:"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:453
+msgid "Frame:"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:496
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:504
+msgid "KeyTime Error"
+msgstr ""
+msgid "Error - All values must be at least zero."
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:497
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:505
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:577
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:678
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:873
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:1007
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:1872
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:1925
+#: ../visualization/nviz/scripts/script_play:32
+#: ../visualization/nviz/scripts/nviz2.2_script:1056
+#: ../visualization/nviz/scripts/panel_animation.tcl:603
+#: ../visualization/nviz/scripts/panel_animation.tcl:644
+msgid "Dismiss"
+msgstr ""
+msgid "Error - Frame number must be less than frame rate."
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:540
+msgid "New Frame Rate"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:544
+msgid "Framerate:"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:576
+msgid "Frame Rate Error"
+msgstr ""
+msgid "Error - Frame rate must be at least 1."
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:676
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:871
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:1005
+#: ../visualization/nviz/scripts/panel_animation.tcl:601
+#: ../visualization/nviz/scripts/panel_animation.tcl:642
+msgid "Internal Error"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:677
+#, tcl-format
+msgid "Internal Error - Can't find channel %s for keyframe %s"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:856
+msgid "Delete Keys"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:857
+msgid "Delete the selected keys?"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:872
+#: ../visualization/nviz/scripts/panel_animation.tcl:602
+msgid "Internal Error - Failed to delete keyframe in GK key list"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:1006
+#: ../visualization/nviz/scripts/panel_animation.tcl:643
+msgid "Internal Error - Failed to move keyframe in GK key list"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:1124
+#: ../visualization/nviz/scripts/panel_animation.tcl:753
+msgid "Replace Key"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:1125
+msgid "There is already a keyframe at this time, replace it?"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:1221
+msgid "Keyframe Attributes"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:1699
+msgid "Enter a base name:"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:1702
+msgid "Render:"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:1703
+msgid "Wireframe"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:1705
+msgid "Full Rendering"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:1710
+msgid "Image:"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:1712
+#: ../visualization/nviz/scripts/panel_animation.tcl:941
+msgid "PPM"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:1713
+#: ../visualization/nviz/scripts/panel_animation.tcl:942
+msgid "TIFF"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:1714
+#: ../visualization/nviz/scripts/panel_animation.tcl:943
+msgid "MPEG-1"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:1716
+msgid "Start Frame:"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:1718
+msgid "Off-Screen"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:1908
+#: ../visualization/nviz/scripts/script_file_tools:111
+#: ../visualization/nviz/scripts/panel_animation.tcl:576
+#: ../visualization/nviz/scripts/panel_animation.tcl:800
+msgid "Verify"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:1909
+msgid "Warning - Current animation has not been saved, continue?"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:1923
+#: ../visualization/nviz/scripts/script_play:30
+#: ../visualization/nviz/scripts/nviz2.2_script:1055
+msgid "File Error"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_kanimator.tcl:1924
+#, tcl-format
+msgid "Error - Could not open file %s for reading"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_surf.tcl:51
+msgid "Raster Surfaces"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_surf.tcl:58
+msgid "Surface Panel"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_surf.tcl:79
+msgid "Surface attributes..."
+msgstr ""
+#: ../visualization/nviz/scripts/panel_surf.tcl:88
+msgid "Wire Color"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_surf.tcl:96
+msgid "Mask zeros:"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_surf.tcl:97
+msgid "by elevation"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_surf.tcl:99
+msgid "by color"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_surf.tcl:109
+msgid "Draw mode..."
+msgstr ""
+#: ../visualization/nviz/scripts/panel_surf.tcl:112
+msgid "Coarse"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_surf.tcl:114
+msgid "Fine"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_surf.tcl:116
+msgid "Both"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_surf.tcl:120
+msgid "Coarse style..."
+msgstr ""
+#: ../visualization/nviz/scripts/panel_surf.tcl:123
+msgid "Wire"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_surf.tcl:125
+#: ../visualization/nviz/scripts/script_file_tools:543
+#: ../visualization/nviz/scripts/panel_main.tcl:142
+msgid "Surface"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_surf.tcl:128
+#: ../visualization/nviz/scripts/panel_vol.tcl:73
+msgid "Shading..."
+msgstr ""
+#: ../visualization/nviz/scripts/panel_surf.tcl:132
+#: ../visualization/nviz/scripts/panel_vol.tcl:76
+msgid "Flat"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_surf.tcl:134
+#: ../visualization/nviz/scripts/panel_vol.tcl:78
+msgid "Gouraud"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_surf.tcl:141
+msgid "Resolution:"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_surf.tcl:143
+#: ../visualization/nviz/scripts/panel_animation.tcl:949
+msgid "coarse"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_surf.tcl:153
+#: ../visualization/nviz/scripts/panel_animation.tcl:950
+msgid "fine"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_surf.tcl:166
+msgid "Set resolution for:"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_surf.tcl:167
+msgid "current surface"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_surf.tcl:169
+msgid "all surfaces"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_surf.tcl:670
+msgid "Position Surface"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_surf.tcl:701
+#: ../visualization/nviz/scripts/panel_vol.tcl:1145
+msgid "Z:"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_surf.tcl:702
+#: ../visualization/nviz/scripts/panel_vol.tcl:1146
+#: ../visualization/nviz/scripts/panel_cutplane.tcl:114
+msgid "X:"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_surf.tcl:703
+#: ../visualization/nviz/scripts/panel_vol.tcl:1147
+#: ../visualization/nviz/scripts/panel_cutplane.tcl:115
+msgid "Y:"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vquery.tcl:51
+msgid "Vector Query"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vquery.tcl:57
+msgid "Vector Query Panel"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vquery.tcl:83
+#: ../visualization/nviz/scripts/panel_rquery.tcl:62
+msgid "query on/off"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vquery.tcl:86
+msgid "Choose map(s)"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vquery.tcl:88
+msgid "Select/unselect vector map(s) to query"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vquery.tcl:98
+msgid "Set threshold distance for selecting objects"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vquery.tcl:100
+msgid "threshold dist"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vquery.tcl:104
+msgid "show hyperlink"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vquery.tcl:113
+msgid "Highlight queried vector points with..."
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vquery.tcl:118
+msgid "color"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vquery.tcl:122
+msgid "Choose color to indicate point queried"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vquery.tcl:124
+msgid "icon size  X"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vquery.tcl:130
+msgid "Choose size in multiples of default to indicate point queried"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vquery.tcl:137
+msgid "specific icon"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vquery.tcl:208
+msgid "Select vectors to query"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vquery.tcl:209
+msgid "vectors displayed"
+msgstr ""
+msgid "vectors to query"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vquery.tcl:410
+#, tcl-format
+msgid "Map: %s"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vquery.tcl:426
+#: ../visualization/nviz/scripts/panel_cutplane.tcl:98
+msgid "clear"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vquery.tcl:496
+msgid "Clear Window?"
+msgstr ""
+msgid "Yes"
+msgstr ""
+msgid "No"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vquery.tcl:619
+msgid "set icon"
+msgstr ""
+#: ../visualization/nviz/scripts/script_play:31
+#, tcl-format
+msgid "Script file %s does not exist"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_scale.tcl:45
+msgid "Scale bar"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_scale.tcl:47
+msgid "Scale Bar Panel"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_scale.tcl:51
+msgid "Scale bar: "
+msgstr ""
+#: ../visualization/nviz/scripts/panel_scale.tcl:54
+msgid "length (in map units) "
+msgstr ""
+#: ../visualization/nviz/scripts/panel_scale.tcl:71
+msgid "Scale text: "
+msgstr ""
+#: ../visualization/nviz/scripts/panel_scale.tcl:74
+msgid "size "
+msgstr ""
+#: ../visualization/nviz/scripts/panel_scale.tcl:90
+msgid "Place scale"
+msgstr ""
+#: ../visualization/nviz/scripts/flythrough.tcl:60
+#: ../visualization/nviz/scripts/flythrough.tcl:141
+msgid "fly"
+msgstr ""
+#: ../visualization/nviz/scripts/flythrough.tcl:67
+#: ../visualization/nviz/scripts/flythrough.tcl:270
+msgid "none"
+msgstr ""
+#: ../visualization/nviz/scripts/flythrough.tcl:70
+#: ../visualization/nviz/scripts/flythrough.tcl:149
+#: ../visualization/nviz/scripts/flythrough.tcl:271
+msgid "basic"
+msgstr ""
+#: ../visualization/nviz/scripts/flythrough.tcl:71
+#: ../visualization/nviz/scripts/flythrough.tcl:157
+msgid "simple"
+msgstr ""
+#: ../visualization/nviz/scripts/flythrough.tcl:72
+#: ../visualization/nviz/scripts/flythrough.tcl:165
+msgid "orbit"
+msgstr ""
+#: ../visualization/nviz/scripts/flythrough.tcl:83
+msgid "Coarse Draw"
+msgstr ""
+#: ../visualization/nviz/scripts/flythrough.tcl:86
+msgid "fly help"
+msgstr ""
+#: ../visualization/nviz/scripts/flythrough.tcl:114
+msgid "Interactively set view position"
+msgstr ""
+#: ../visualization/nviz/scripts/flythrough.tcl:135
+msgid "flythrough help"
+msgstr ""
+#: ../visualization/nviz/scripts/flythrough.tcl:174
+msgid "move"
+msgstr ""
+#: ../visualization/nviz/scripts/flythrough.tcl:196
+msgid "turn"
+msgstr ""
+#: ../visualization/nviz/scripts/wirecolorPopup.tcl:30
+msgid "Select Wire Color"
+msgstr ""
+#: ../visualization/nviz/scripts/wirecolorPopup.tcl:57
+msgid "use surface color"
+msgstr ""
+#: ../visualization/nviz/scripts/attIsosurfPopup.tcl:99
+msgid "use volume as color"
+msgstr ""
+#: ../visualization/nviz/scripts/attIsosurfPopup.tcl:275
+msgid "remove mask"
+msgstr ""
+#: ../visualization/nviz/scripts/attIsosurfPopup.tcl:403
+msgid "Enter value: "
+msgstr ""
+#: ../visualization/nviz/scripts/attIsosurfPopup.tcl:449
+msgid "Use slider to select constant value :"
+msgstr ""
+#: ../visualization/nviz/scripts/script_file_tools:36
+msgid "Map Object File Sequencing"
+msgstr ""
+#: ../visualization/nviz/scripts/script_file_tools:43
+msgid "Fields:"
+msgstr ""
+#: ../visualization/nviz/scripts/script_file_tools:46
+msgid "State File: None"
+msgstr ""
+#: ../visualization/nviz/scripts/script_file_tools:53
+msgid "Options:"
+msgstr ""
+#: ../visualization/nviz/scripts/script_file_tools:55
+msgid "Add To Script"
+msgstr ""
+#: ../visualization/nviz/scripts/script_file_tools:56
+msgid "Build Script..."
+msgstr ""
+msgid "Load Fields..."
+msgstr ""
+#: ../visualization/nviz/scripts/script_file_tools:58
+msgid "Save Fields..."
+msgstr ""
+#: ../visualization/nviz/scripts/script_file_tools:75
+msgid "Frame"
+msgstr ""
+msgid "Current fields have not been saved, really load new fields?"
+msgstr ""
+#: ../visualization/nviz/scripts/script_file_tools:126
+#: ../visualization/nviz/scripts/nviz2.2_script:873
+#: ../visualization/nviz/scripts/nviz2.2_script:1027
+#, tcl-format
+msgid "Error while opening file: %s"
+msgstr ""
+#: ../visualization/nviz/scripts/script_file_tools:135
+#, tcl-format
+msgid "While reading state_file: %s"
+msgstr ""
+#: ../visualization/nviz/scripts/script_file_tools:142
+#, tcl-format
+msgid "While reading number of fields: %s"
+msgstr ""
+#: ../visualization/nviz/scripts/script_file_tools:151
+#, tcl-format
+msgid "While reading field type: %s"
+msgstr ""
+#: ../visualization/nviz/scripts/script_file_tools:157
+#, tcl-format
+msgid "While reading field attribute: %s"
+msgstr ""
+#: ../visualization/nviz/scripts/script_file_tools:542
+msgid "Field Type: "
+msgstr ""
+#: ../visualization/nviz/scripts/script_file_tools:554
+msgid "Field Attribute: "
+msgstr ""
+#: ../visualization/nviz/scripts/script_file_tools:555
+msgid "Topography"
+msgstr ""
+#: ../visualization/nviz/scripts/script_file_tools:566
+msgid "Use Nviz Map: "
+msgstr ""
+#: ../visualization/nviz/scripts/script_file_tools:567
+#: ../visualization/nviz/scripts/script_file_tools:676
+#: ../visualization/nviz/scripts/panel_legend.tcl:183
+#: ../visualization/nviz/scripts/panel_cutplane.tcl:61
+#: ../visualization/nviz/scripts/panel_cutplane.tcl:67
+#: ../visualization/nviz/scripts/panel_cutplane.tcl:290
+msgid "None"
+msgstr ""
+#: ../visualization/nviz/scripts/script_file_tools:853
+#, tcl-format
+msgid "State File: %s"
+msgstr ""
+#: ../visualization/nviz/scripts/script_file_tools:885
+msgid "Enter an image root name"
+msgstr ""
+#: ../visualization/nviz/scripts/colorPopup.tcl:17
+msgid "Choose color"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:86
+msgid "Main"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:104
+msgid "DRAW"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:107
+msgid "Draw selected features"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:110
+msgid "Clear NVIZ display"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:113
+msgid "Cancel current draw"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:119
+msgid "Automatically render display:"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:123
+msgid "Automatically render display after changing parameters"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:128
+msgid "Show features:"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:131
+msgid "Main features..."
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:136
+msgid "Decorations..."
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:145
+msgid "Vectors"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:148
+msgid "Sites"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:151
+#: ../visualization/nviz/scripts/panel_vol.tcl:40
+msgid "Volumes"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:156
+#: ../visualization/nviz/scripts/panel_legend.tcl:63
+msgid "Legend"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:160
+msgid "North Arrow"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:162
+msgid "Scale Bar"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:175
+msgid "View method:"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:177
+msgid "eye"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:181
+#: ../visualization/nviz/scripts/panel_main.tcl:220
+msgid "center"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:186
+msgid "Change view by moving eye position"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:187
+msgid "Change view by moving scene center position"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:196
+msgid "Change view using mouse to control fly-through"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:205
+#: ../visualization/nviz/scripts/panel_main.tcl:206
+msgid "Set vertical exaggeration"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:207
+#: ../visualization/nviz/scripts/panel_main.tcl:208
+msgid "Set eye height"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:213
+msgid "Look"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:214
+msgid "here"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:215
+msgid "Center view at point marked with mouse click"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:221
+msgid "Center view at center of displayed surface"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:225
+msgid "top"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:226
+msgid "View directly from above"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:246
+msgid "perspective"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:247
+msgid "twist"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:249
+msgid "Set field of view size (degrees)"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:250
+msgid "Set twist angle (degrees)"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:253
+msgid "reset"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:255
+msgid "Reset view to default"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:416
+#: ../visualization/nviz/scripts/widgets.tcl:334
+msgid "z-exag"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:432
+#: ../visualization/nviz/scripts/widgets.tcl:329
+#: ../visualization/nviz/scripts/panel_vol.tcl:457
+#: ../visualization/nviz/scripts/panel_vol.tcl:460
+#: ../visualization/nviz/scripts/panel_vol.tcl:735
+#: ../visualization/nviz/scripts/panel_vol.tcl:738
+#: ../visualization/nviz/scripts/panel_resize.tcl:43
+msgid "height"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:517
+msgid "Set eye position"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_main.tcl:522
+msgid "Set center of view position"
+msgstr ""
+#: ../visualization/nviz/scripts/nviz2.2_script:197
+msgid "Show Panels"
+msgstr ""
+#: ../visualization/nviz/scripts/nviz2.2_script:204
+#: ../visualization/nviz/scripts/nviz2.2_script:327
+#: ../visualization/nviz/scripts/nviz2.2_script:688
+msgid "Hide Panels"
+msgstr ""
+#: ../visualization/nviz/scripts/nviz2.2_script:246
+msgid "Start"
+msgstr ""
+#: ../visualization/nviz/scripts/nviz2.2_script:267
+#: ../visualization/nviz/scripts/nviz2.2_script:274
+#: ../visualization/nviz/scripts/nviz2.2_script:281
+#: ../visualization/nviz/scripts/nviz2.2_script:289
+msgid "Togl canvas initialization failed. Is Your OpenGL working fine?"
+msgstr ""
+#: ../visualization/nviz/scripts/nviz2.2_script:349
+msgid "Please Wait..."
+msgstr ""
+#: ../visualization/nviz/scripts/nviz2.2_script:355
+msgid "Help"
+msgstr ""
+#: ../visualization/nviz/scripts/nviz2.2_script:356
+msgid "NVIZ Help"
+msgstr ""
+msgid "About NVIZ"
+msgstr ""
+msgid "NVIZ - Bugs / ToDo"
+msgstr ""
+#: ../visualization/nviz/scripts/nviz2.2_script:368
+msgid "File"
+msgstr ""
+#: ../visualization/nviz/scripts/nviz2.2_script:369
+msgid "Load State"
+msgstr ""
+msgid "Save State"
+msgstr ""
+#: ../visualization/nviz/scripts/nviz2.2_script:371
+msgid "Set Canvas Size"
+msgstr ""
+#: ../visualization/nviz/scripts/nviz2.2_script:373
+msgid "Load 3d Settings"
+msgstr ""
+msgid "Save 3d Settings"
+msgstr ""
+#: ../visualization/nviz/scripts/nviz2.2_script:375
+msgid "Save image as..."
+msgstr ""
+msgid "Quit"
+msgstr ""
+#: ../visualization/nviz/scripts/nviz2.2_script:410
+msgid "Scripting"
+msgstr ""
+#: ../visualization/nviz/scripts/nviz2.2_script:420
+msgid "Create New Scriptfile"
+msgstr ""
+#: ../visualization/nviz/scripts/nviz2.2_script:423
+msgid "Open and Play Script"
+msgstr ""
+#: ../visualization/nviz/scripts/nviz2.2_script:426
+msgid "Close Script"
+msgstr ""
+#: ../visualization/nviz/scripts/nviz2.2_script:434
+msgid "Add Script Command"
+msgstr ""
+#: ../visualization/nviz/scripts/nviz2.2_script:439
+msgid "Script Tools"
+msgstr ""
+#: ../visualization/nviz/scripts/nviz2.2_script:484
+msgid "PPM Image"
+msgstr ""
+#: ../visualization/nviz/scripts/nviz2.2_script:486
+msgid "TIFF Image"
+msgstr ""
+#: ../visualization/nviz/scripts/nviz2.2_script:500
+msgid "Maximum Resolution PPM"
+msgstr ""
+#: ../visualization/nviz/scripts/nviz2.2_script:646
+msgid "Visualize"
+msgstr ""
+#: ../visualization/nviz/scripts/nviz2.2_script:680
+msgid "Appearance"
+msgstr ""
+#: ../visualization/nviz/scripts/nviz2.2_script:800
+msgid "Set Size of Display Canvas"
+msgstr ""
+#: ../visualization/nviz/scripts/nviz2.2_script:803
+msgid "Width"
+msgstr ""
+#: ../visualization/nviz/scripts/nviz2.2_script:811
+msgid "Unconstrained"
+msgstr ""
+msgid "Really reset Nviz?"
+msgstr ""
+#: ../visualization/nviz/scripts/fileBrowser.tcl:82
+msgid "DIRECTORIES"
+msgstr ""
+#: ../visualization/nviz/scripts/fileBrowser.tcl:154
+msgid "File Browser"
+msgstr ""
+#: ../visualization/nviz/scripts/config.tcl:125
+msgid "x"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:77
+msgid "sphere"
+msgstr ""
+msgid "diamond"
+msgstr ""
+msgid "cube"
+msgstr ""
+msgid "box"
+msgstr ""
+msgid "gyro"
+msgstr ""
+msgid "aster"
+msgstr ""
+msgid "histogram"
+msgstr ""
+#: ../visualization/nviz/scripts/widgets.tcl:70
+msgid "E"
+msgstr ""
+#: ../visualization/nviz/scripts/widgets.tcl:71
+msgid "W"
+msgstr ""
+#: ../visualization/nviz/scripts/widgets.tcl:72
+msgid "N"
+msgstr ""
+#: ../visualization/nviz/scripts/widgets.tcl:73
+msgid "S"
+msgstr ""
+#: ../visualization/nviz/scripts/widgets.tcl:596
+msgid "None Loaded"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_label.tcl:62
+msgid "Labels Panel"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_label.tcl:67
+#: ../visualization/nviz/scripts/panel_legend.tcl:77
+#: ../visualization/nviz/scripts/panel_arrow.tcl:73
+msgid "Font"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_label.tcl:69
+#: ../visualization/nviz/scripts/panel_arrow.tcl:75
+msgid "Select font family, size, and style"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_label.tcl:73
+msgid "Choose font color"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_label.tcl:83
+msgid "Label text: "
+msgstr ""
+#: ../visualization/nviz/scripts/panel_label.tcl:90
+msgid "Place label"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_label.tcl:91
+msgid "Click with mouse to place label"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_label.tcl:92
+msgid "Erase last"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_label.tcl:93
+msgid "Erase most recent label placed"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_label.tcl:94
+msgid "Erase all"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_label.tcl:95
+msgid "Erase all labels"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_label.tcl:177
+#: ../visualization/nviz/scripts/panel_legend.tcl:220
+#: ../visualization/nviz/scripts/panel_arrow.tcl:119
+msgid "The quick brown fox jumps over the lazy dog"
+msgstr ""
+msgid "Select font"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_site.tcl:44
+msgid "Vector Points"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_site.tcl:51
+msgid "Vector Points Panel"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_site.tcl:133
+msgid "icon size"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_site.tcl:153
+msgid "icon type"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_site.tcl:162
+msgid "3D points"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_site.tcl:182
+msgid "thematic mapping for vector points"
+msgstr ""
+#: ../visualization/nviz/scripts/script_tools:32
+msgid "Open Loop"
+msgstr ""
+#: ../visualization/nviz/scripts/script_tools:33
+msgid "Close Loop"
+msgstr ""
+#: ../visualization/nviz/scripts/script_tools:37
+msgid "Open File Seq. Loop"
+msgstr ""
+#: ../visualization/nviz/scripts/script_tools:38
+msgid "Close File Seq. Loop"
+msgstr ""
+#: ../visualization/nviz/scripts/script_tools:42
+msgid "File Sequence Tool"
+msgstr ""
+#: ../visualization/nviz/scripts/script_tools:104
+msgid "Loop Start Value"
+msgstr ""
+#: ../visualization/nviz/scripts/script_tools:106
+msgid "Loop End Value"
+msgstr ""
+#: ../visualization/nviz/scripts/script_tools:108
+msgid "Loop Increment Value"
+msgstr ""
+msgid "Volume Panel"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vol.tcl:63
+msgid "Visualization type..."
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vol.tcl:66
+msgid "isosurfaces"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vol.tcl:69
+msgid "slices"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vol.tcl:88
+msgid "Polygon resolution: "
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vol.tcl:441
+msgid "X-axis"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vol.tcl:443
+msgid "Y-axis"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vol.tcl:445
+msgid "Z-axis"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vol.tcl:449
+msgid "Transparency"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vol.tcl:455
+#: ../visualization/nviz/scripts/panel_vol.tcl:733
+msgid "azimuth"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vol.tcl:456
+#: ../visualization/nviz/scripts/panel_vol.tcl:461
+#: ../visualization/nviz/scripts/panel_vol.tcl:734
+#: ../visualization/nviz/scripts/panel_vol.tcl:739
+msgid "length"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vol.tcl:459
+#: ../visualization/nviz/scripts/panel_vol.tcl:737
+msgid "tilt"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vol.tcl:493
+msgid "Add new slice"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vol.tcl:495
+msgid "Delete selected slice"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vol.tcl:497
+#: ../visualization/nviz/scripts/panel_vol.tcl:865
+msgid "Move Up"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vol.tcl:498
+msgid "Move slice up in list"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vol.tcl:499
+#: ../visualization/nviz/scripts/panel_vol.tcl:867
+msgid "Move Down"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vol.tcl:500
+msgid "Move slice down in list"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vol.tcl:830
+msgid "Isosurface attributes..."
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vol.tcl:839
+msgid "toggle normal direction"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vol.tcl:861
+msgid "Add new isosurface"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vol.tcl:863
+msgid "Delete selected isosurface"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vol.tcl:866
+msgid "Move isosurface up in list"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vol.tcl:868
+msgid "Move isosurface down in list"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_vol.tcl:1114
+msgid "Position Volume"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_legend.tcl:65
+msgid "Legends Panel"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_legend.tcl:71
+msgid "reverse legend"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_legend.tcl:73
+msgid "show values"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_legend.tcl:75
+msgid "show labels"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_legend.tcl:79
+msgid "Select font family, size, and style for legend text"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_legend.tcl:86
+msgid "set value range "
+msgstr ""
+#: ../visualization/nviz/scripts/panel_legend.tcl:91
+msgid "min "
+msgstr ""
+#: ../visualization/nviz/scripts/panel_legend.tcl:94
+msgid " max "
+msgstr ""
+#: ../visualization/nviz/scripts/panel_legend.tcl:107
+msgid "discrete categories"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_legend.tcl:131
+msgid "Place legend"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_legend.tcl:133
+msgid ""
+"Use mouse to place legend; left button defines first corner,  right button "
+"defines opposite corner."
+msgstr ""
+#: ../visualization/nviz/scripts/panel_legend.tcl:135
+msgid "Erase legend"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_legend.tcl:137
+msgid "Erase all legends"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_legend.tcl:166
+msgid "Category Values"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_cutplane.tcl:48
+msgid "Cutting Planes"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_cutplane.tcl:50
+msgid "Cutting Planes Panel"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_cutplane.tcl:60
+msgid "Active cutting plane: "
+msgstr ""
+#: ../visualization/nviz/scripts/panel_cutplane.tcl:68
+msgid "Plane 0"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_cutplane.tcl:69
+msgid "Plane 1"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_cutplane.tcl:70
+msgid "Plane 2"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_cutplane.tcl:71
+msgid "Plane 3"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_cutplane.tcl:72
+msgid "Plane 4"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_cutplane.tcl:73
+msgid "Plane 5"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_cutplane.tcl:87
+msgid "set shading"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_cutplane.tcl:90
+msgid "top color"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_cutplane.tcl:92
+msgid "bottom color"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_cutplane.tcl:94
+msgid "blend"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_cutplane.tcl:96
+msgid "shaded"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_cutplane.tcl:139
+msgid "Z coord"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_cutplane.tcl:151
+msgid "Rotate"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_cutplane.tcl:163
+msgid "Tilt"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_cutplane.tcl:184
+msgid "All Off"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_cutplane.tcl:292
+#, tcl-format
+msgid "Plane %s"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:411
+msgid ""
+"Fill 2 or more entry fields with  desired min and max values, then press "
+"[Apply].  Or press [Auto] to automatically  generate a range of symbol sizes."
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:422
+msgid ""
+"Fill 2 or more entry fields with desired colors, then press [Apply]. Or "
+"press [Auto] to automatically generate a color table."
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:428
+#, tcl-format
+msgid "WARNING: No thematic mapping preferences set for %s!"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:447
+#, tcl-format
+msgid "Vary point %s"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:451
+#, tcl-format
+msgid "GIS attribute: %s"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:460
+#, tcl-format
+msgid "Attribute type: %s"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:474
+msgid "Apply current thematic preferences to point display"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:477
+msgid "Auto"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:479
+msgid ""
+"Automatically generate a color  table distributed across range of attribute "
+"values"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:485
+msgid "Clear all thematic settings"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:495
+msgid "Load/save theme preferences"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:528
+msgid "Select thematic prefs to use"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:531
+msgid "current prefs"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:536
+msgid "prefs. from file"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:542
+msgid "(preserves current prefs.)"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:553
+msgid "no prefs loaded"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:558
+msgid "View loaded thematic prefs"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:570
+msgid "Load and save prefs."
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:572
+msgid "Load prefs"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:574
+msgid "Replace current themes with prefs loaded from file"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:580
+msgid "Save prefs"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:582
+msgid "Copy current themes to prefs loaded from file"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:860
+#: ../visualization/nviz/scripts/site_attr.tcl:915
+msgid "Too few values: at least 2!"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:1107
+#: ../visualization/nviz/scripts/site_attr.tcl:1197
+msgid "No prefs file loaded"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:1138
+msgid "No prefs"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:1146
+msgid "Thematic prefs and attribute have different types"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:1207
+msgid "Thematic prefs and attributes have different types"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:1408
+#, tcl-format
+msgid "WARNING: No attribute behaviour for %s!"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:1418
+#, tcl-format
+msgid "Thematic prefs file %s"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:1422
+#, tcl-format
+msgid "Name: %s"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:1430
+#, tcl-format
+msgid "Type: %s"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:1436
+msgid "Save thematic prefs in file"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:1439
+msgid "Clear current thematic prefs"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:1493
+msgid "Load Thematic Prefs"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:1497
+msgid "Load file"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:1577
+msgid "Save thematic prefs"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:1582
+#, tcl-format
+msgid "Old LUT \"%s\" deleted"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:1607
+#, tcl-format
+msgid "Thematic preferences file \"%s\" saved"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:1616
+msgid "Load thematic prefs"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:1622
+#, tcl-format
+msgid "*** WARNING *** File \"%s\" is unavailable"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:1627
+#, tcl-format
+msgid "*** ERROR *** Some thematic pref component are missing in file \"%s\""
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:1700
+#, tcl-format
+msgid "WARNING: Unknown Tag \"%s\" in file \"%s\""
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:1770
+#: ../visualization/nviz/scripts/site_attr.tcl:1852
+#, tcl-format
+msgid "WARNING: Unknown attribute %s!"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:1791
+#, tcl-format
+msgid "WARNING: field %s NOT FOUND"
+msgstr ""
+#: ../visualization/nviz/scripts/site_attr.tcl:1798
+#, tcl-format
+msgid "WARNING: lut file %s NOT FOUND"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_resize.tcl:27
+msgid "Resize Draw Area"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_resize.tcl:33
+msgid "Resize Panel"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_resize.tcl:39
+msgid "Resize: "
+msgstr ""
+#: ../visualization/nviz/scripts/panel_resize.tcl:42
+msgid "width"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_resize.tcl:52
+msgid "Resize"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_tst.tcl:21
+#: ../visualization/nviz/scripts/panel_animation.tcl:275
+msgid "Test"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_tst.tcl:31
+msgid "Test Panel"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_arrow.tcl:47
+msgid "North arrow"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_arrow.tcl:49
+msgid "North Arrow Panel"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_arrow.tcl:53
+msgid "Arrow: "
+msgstr ""
+#: ../visualization/nviz/scripts/panel_arrow.tcl:56
+msgid "size (in map units) "
+msgstr ""
+#: ../visualization/nviz/scripts/panel_arrow.tcl:72
+msgid "North text: "
+msgstr ""
+#: ../visualization/nviz/scripts/panel_arrow.tcl:89
+msgid "Place arrow"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_rquery.tcl:41
+msgid "Send results to: (no file selected)"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_rquery.tcl:52
+msgid "Raster Query"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_rquery.tcl:58
+msgid "Raster Query Panel"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_rquery.tcl:65
+msgid "Reset most recent query"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_rquery.tcl:67
+msgid "Clear all queries"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_rquery.tcl:68
+msgid "Attributes"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_rquery.tcl:78
+msgid "Map name"
+msgstr ""
+msgid "Easting"
+msgstr ""
+msgid "Northing"
+msgstr ""
+msgid "Elevation"
+msgstr ""
+msgid "Category of color map"
+msgstr ""
+msgid "XY dist from prev"
+msgstr ""
+msgid "XYZ dist from prev"
+msgstr ""
+msgid "Dist along surface"
+msgstr ""
+msgid "Dist along exag surface"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_rquery.tcl:93
+msgid "Select file to receive all future query results"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_rquery.tcl:126
+#, tcl-format
+msgid "Send results to: %s"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_rquery.tcl:152
+#: ../visualization/nviz/scripts/panel_rquery.tcl:153
+msgid "Point not on surface\n"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_rquery.tcl:164
+#, tcl-format
+msgid "Easting: %15.4f\n"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_rquery.tcl:171
+#, tcl-format
+msgid "Northing: %15.4f\n"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_rquery.tcl:178
+#, tcl-format
+msgid "Elevation: %15.4f\n"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_rquery.tcl:186
+#: ../visualization/nviz/scripts/panel_rquery.tcl:187
+#, tcl-format
+msgid "Surf map: %s"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_rquery.tcl:202
+msgid "constant"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_rquery.tcl:204
+#: ../visualization/nviz/scripts/panel_rquery.tcl:205
+#, tcl-format
+msgid "Color map: %s"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_rquery.tcl:224
+#, tcl-format
+msgid "XY distance from previous: \t%15.4f\n"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_rquery.tcl:232
+#, tcl-format
+msgid "XYZ distance from previous: \t%15.4f\n"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_rquery.tcl:241
+#, tcl-format
+msgid "Distance along surface: \t%15.4f\n"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_rquery.tcl:252
+#, tcl-format
+msgid "Distance along exag. surface:%15.4f\n"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_animation.tcl:100
+msgid "Simple Animation"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_animation.tcl:104
+msgid "Simple Keyframe Animation Panel"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_animation.tcl:111
+msgid "Step backward frame by frame"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_animation.tcl:114
+msgid "Pause playback"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_animation.tcl:117
+msgid "Step forward frame by frame"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_animation.tcl:120
+msgid "Run animation from beginning"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_animation.tcl:122
+msgid " set max frames:"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_animation.tcl:136
+msgid "Key Frames"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_animation.tcl:145
+msgid "Current frame:"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_animation.tcl:148
+msgid "Selected key frame:"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_animation.tcl:159
+msgid "Add frame"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_animation.tcl:161
+msgid "Clear all"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_animation.tcl:170
+msgid "Show: "
+msgstr ""
+#: ../visualization/nviz/scripts/panel_animation.tcl:171
+msgid "path"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_animation.tcl:173
+msgid "lines"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_animation.tcl:175
+msgid "points"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_animation.tcl:177
+msgid "volumes"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_animation.tcl:184
+msgid "Interpolation: "
+msgstr ""
+#: ../visualization/nviz/scripts/panel_animation.tcl:200
+msgid "Run and save"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_animation.tcl:202
+msgid "Run animation and save frames"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_animation.tcl:222
+msgid "spline tension"
+msgstr ""
+msgid "Do you really want to delete this keyframe?"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_animation.tcl:754
+msgid "There is already a keyframe at this time, do you wish to replace it?"
+msgstr ""
+msgid "Do you really want to delete all keyframes?"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_animation.tcl:928
+msgid "Save Animation Frames"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_animation.tcl:934
+msgid "Prefix for images: "
+msgstr ""
+#: ../visualization/nviz/scripts/panel_animation.tcl:935
+msgid "Enter a prefix name for images to be created from animation frames"
+msgstr ""
+#: ../visualization/nviz/scripts/panel_animation.tcl:940
+msgid "Output format: "
+msgstr ""
+#: ../visualization/nviz/scripts/panel_animation.tcl:948
+msgid "Rendering mode: "
+msgstr ""
Added: grass/branches/releasebranch_6_4/locale/po/grasstcl_nl.po
--- grass/branches/releasebranch_6_4/locale/po/grasstcl_nl.po	                        (rev 0)
+++ grass/branches/releasebranch_6_4/locale/po/grasstcl_nl.po	2012-06-19 22:28:16 UTC (rev 52142)
@@ -0,0 +1,6610 @@
+# SOME DESCRIPTIVE TITLE.
+# Copyright (C) YEAR THE PACKAGE'S COPYRIGHT HOLDER
+# This file is distributed under the same license as the PACKAGE package.
+# FIRST AUTHOR <EMAIL at ADDRESS>, YEAR.
+#, fuzzy
+msgid ""
+msgstr ""
+"Project-Id-Version: PACKAGE VERSION\n"
+"Report-Msgid-Bugs-To: \n"
+"POT-Creation-Date: 2012-06-19 23:46+0200\n"
+"PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
+"Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
+"Language-Team: LANGUAGE <LL at li.org>\n"
+"Language: \n"
+"MIME-Version: 1.0\n"
+"Content-Type: text/plain; charset=CHARSET\n"
+"Content-Transfer-Encoding: 8bit\n"
+#: ../gui/tcltk/gis.m/raster.tcl:87 ../gui/tcltk/gis.m/raster.tcl:480
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:228 ../gui/tcltk/gis.m/mapcanvas.tcl:238
+#: ../gui/tcltk/gis.m/cmd.tcl:75 ../gui/tcltk/gis.m/cmd.tcl:206
+#: ../gui/tcltk/gis.m/legend.tcl:95 ../gui/tcltk/gis.m/legend.tcl:505
+#: ../gui/tcltk/gis.m/dtext.tcl:94 ../gui/tcltk/gis.m/dtext.tcl:407
+#: ../gui/tcltk/gis.m/chart.tcl:91 ../gui/tcltk/gis.m/chart.tcl:468
+#: ../gui/tcltk/gis.m/gridline.tcl:103 ../gui/tcltk/gis.m/gridline.tcl:416
+#: ../gui/tcltk/gis.m/frames.tcl:78 ../gui/tcltk/gis.m/frames.tcl:275
+#: ../gui/tcltk/gis.m/rgbhis.tcl:83 ../gui/tcltk/gis.m/rgbhis.tcl:362
+#: ../gui/tcltk/gis.m/thematic.tcl:111 ../gui/tcltk/gis.m/thematic.tcl:640
+#: ../gui/tcltk/gis.m/thematic.tcl:713 ../gui/tcltk/gis.m/georect.tcl:409
+#: ../gui/tcltk/gis.m/labels.tcl:78 ../gui/tcltk/gis.m/labels.tcl:279
+#: ../gui/tcltk/gis.m/vector.tcl:196 ../gui/tcltk/gis.m/vector.tcl:876
+#: ../gui/tcltk/gis.m/barscale.tcl:91 ../gui/tcltk/gis.m/barscale.tcl:401
+#: ../gui/tcltk/gis.m/histogram.tcl:85 ../gui/tcltk/gis.m/histogram.tcl:370
+#: ../gui/tcltk/gis.m/rules.tcl:207 ../gui/tcltk/gis.m/rastnums.tcl:81
+#: ../gui/tcltk/gis.m/rastnums.tcl:375 ../gui/tcltk/gis.m/rastarrows.tcl:88
+#: ../gui/tcltk/gis.m/rastarrows.tcl:372 ../gui/tcltk/gis.m/animate.tcl:91
+#: ../gui/tcltk/gis.m/mapprint.tcl:197 ../gui/tcltk/gis.m/mapprint.tcl:204
+msgid "Error creating tempfile"
+msgstr ""
+#: ../gui/tcltk/gis.m/raster.tcl:115 ../gui/tcltk/gis.m/rastnums.tcl:105
+#: ../gui/tcltk/d.m/menu.tcl:77 ../gui/tcltk/d.m/menu.tcl:113
+msgid "Raster map"
+msgstr ""
+#: ../gui/tcltk/gis.m/raster.tcl:128
+msgid "Raster drape map"
+msgstr ""
+#: ../gui/tcltk/gis.m/raster.tcl:145 ../gui/tcltk/gis.m/raster.tcl:161
+#: ../gui/tcltk/gis.m/chart.tcl:130 ../gui/tcltk/gis.m/chart.tcl:151
+#: ../gui/tcltk/gis.m/thematic.tcl:173 ../gui/tcltk/gis.m/thematic.tcl:194
+#: ../gui/tcltk/gis.m/vector.tcl:247 ../gui/tcltk/gis.m/vector.tcl:269
+#: ../gui/tcltk/gis.m/vector.tcl:302
+msgid "This action requires map name to be set"
+msgstr ""
+#: ../gui/tcltk/gis.m/raster.tcl:178
+msgid "Display raster maps"
+msgstr ""
+#: ../gui/tcltk/gis.m/raster.tcl:185 ../gui/tcltk/gis.m/cmd.tcl:105
+#: ../gui/tcltk/gis.m/legend.tcl:200 ../gui/tcltk/gis.m/dtext.tcl:168
+#: ../gui/tcltk/gis.m/chart.tcl:192 ../gui/tcltk/gis.m/gridline.tcl:151
+#: ../gui/tcltk/gis.m/rgbhis.tcl:143 ../gui/tcltk/gis.m/thematic.tcl:251
+#: ../gui/tcltk/gis.m/labels.tcl:118 ../gui/tcltk/gis.m/vector.tcl:344
+#: ../gui/tcltk/gis.m/barscale.tcl:160 ../gui/tcltk/gis.m/histogram.tcl:146
+#: ../gui/tcltk/gis.m/rastnums.tcl:148 ../gui/tcltk/gis.m/rastarrows.tcl:152
+msgid "Opaque "
+msgstr ""
+#: ../gui/tcltk/gis.m/raster.tcl:189 ../gui/tcltk/gis.m/cmd.tcl:109
+#: ../gui/tcltk/gis.m/legend.tcl:204 ../gui/tcltk/gis.m/dtext.tcl:172
+#: ../gui/tcltk/gis.m/chart.tcl:196 ../gui/tcltk/gis.m/gridline.tcl:155
+#: ../gui/tcltk/gis.m/rgbhis.tcl:147 ../gui/tcltk/gis.m/thematic.tcl:255
+#: ../gui/tcltk/gis.m/labels.tcl:122 ../gui/tcltk/gis.m/barscale.tcl:164
+#: ../gui/tcltk/gis.m/histogram.tcl:150 ../gui/tcltk/gis.m/rastnums.tcl:152
+#: ../gui/tcltk/gis.m/rastarrows.tcl:156
+msgid " Transparent"
+msgstr ""
+#: ../gui/tcltk/gis.m/raster.tcl:195
+msgid "Base map:\t"
+msgstr ""
+#: ../gui/tcltk/gis.m/raster.tcl:198
+msgid "base raster map to display"
+msgstr ""
+#: ../gui/tcltk/gis.m/raster.tcl:203 ../gui/tcltk/gis.m/raster.tcl:207
+msgid "base map info"
+msgstr ""
+#: ../gui/tcltk/gis.m/raster.tcl:209 ../gui/tcltk/gis.m/raster.tcl:213
+#: ../gui/tcltk/gis.m/runandoutput.tcl:47 ../gui/tcltk/gis.m/legend.tcl:219
+#: ../gui/tcltk/gis.m/legend.tcl:222 ../gui/tcltk/gis.m/dtext.tcl:179
+#: ../gui/tcltk/gis.m/dtext.tcl:183 ../gui/tcltk/gis.m/chart.tcl:210
+#: ../gui/tcltk/gis.m/chart.tcl:214 ../gui/tcltk/gis.m/gridline.tcl:166
+#: ../gui/tcltk/gis.m/gridline.tcl:218 ../gui/tcltk/gis.m/gridline.tcl:249
+#: ../gui/tcltk/gis.m/frames.tcl:118 ../gui/tcltk/gis.m/frames.tcl:122
+#: ../gui/tcltk/gis.m/rgbhis.tcl:156 ../gui/tcltk/gis.m/rgbhis.tcl:165
+#: ../gui/tcltk/gis.m/thematic.tcl:269 ../gui/tcltk/gis.m/thematic.tcl:273
+#: ../gui/tcltk/gis.m/georect.tcl:708 ../gui/tcltk/gis.m/georect.tcl:712
+#: ../gui/tcltk/gis.m/georect.tcl:1142 ../gui/tcltk/gis.m/georect.tcl:1146
+#: ../gui/tcltk/gis.m/labels.tcl:136 ../gui/tcltk/gis.m/labels.tcl:140
+#: ../gui/tcltk/gis.m/vector.tcl:368 ../gui/tcltk/gis.m/vector.tcl:372
+#: ../gui/tcltk/gis.m/barscale.tcl:180 ../gui/tcltk/gis.m/barscale.tcl:184
+#: ../gui/tcltk/gis.m/profile.tcl:131 ../gui/tcltk/gis.m/profile.tcl:135
+#: ../gui/tcltk/gis.m/dnviz.tcl:208 ../gui/tcltk/gis.m/dnviz.tcl:212
+#: ../gui/tcltk/gis.m/histogram.tcl:163 ../gui/tcltk/gis.m/histogram.tcl:166
+#: ../gui/tcltk/gis.m/rules.tcl:139 ../gui/tcltk/gis.m/rules.tcl:143
+#: ../gui/tcltk/gis.m/rastnums.tcl:165 ../gui/tcltk/gis.m/rastnums.tcl:168
+#: ../gui/tcltk/gis.m/rastarrows.tcl:169 ../gui/tcltk/gis.m/rastarrows.tcl:172
+#: ../gui/tcltk/gis.m/animate.tcl:408 ../gui/tcltk/gis.m/animate.tcl:412
+#: ../gui/tcltk/gis.m/animate.tcl:481 ../gui/tcltk/gis.m/animate.tcl:484
+#: ../gui/tcltk/d.m/raster.tcl:90 ../gui/tcltk/d.m/raster.tcl:94
+#: ../gui/tcltk/d.m/legend.tcl:86 ../gui/tcltk/d.m/legend.tcl:90
+#: ../gui/tcltk/d.m/dtext.tcl:75 ../gui/tcltk/d.m/dtext.tcl:79
+#: ../gui/tcltk/d.m/chart.tcl:96 ../gui/tcltk/d.m/chart.tcl:100
+#: ../gui/tcltk/d.m/gridline.tcl:81 ../gui/tcltk/d.m/gridline.tcl:120
+#: ../gui/tcltk/d.m/gridline.tcl:150 ../gui/tcltk/d.m/frames.tcl:66
+#: ../gui/tcltk/d.m/frames.tcl:70 ../gui/tcltk/d.m/rgbhis.tcl:130
+#: ../gui/tcltk/d.m/rgbhis.tcl:137 ../gui/tcltk/d.m/fttext.tcl:83
+#: ../gui/tcltk/d.m/fttext.tcl:87 ../gui/tcltk/d.m/thematic.tcl:121
+#: ../gui/tcltk/d.m/thematic.tcl:125 ../gui/tcltk/d.m/labels.tcl:70
+#: ../gui/tcltk/d.m/labels.tcl:74 ../gui/tcltk/d.m/vector.tcl:202
+#: ../gui/tcltk/d.m/vector.tcl:206 ../gui/tcltk/d.m/barscale.tcl:74
+#: ../gui/tcltk/d.m/barscale.tcl:78 ../lib/gis/gui.tcl:509
+#: ../lib/init/gis_set.tcl:531
+msgid "Help"
+msgstr ""
+#: ../gui/tcltk/gis.m/raster.tcl:219
+msgid "\tvalues to display"
+msgstr ""
+#: ../gui/tcltk/gis.m/raster.tcl:226
+msgid "\tOptional color draping. Use base map for shading,"
+msgstr ""
+#: ../gui/tcltk/gis.m/raster.tcl:231
+msgid "\tdrape map for color in color relief map or data fusion"
+msgstr ""
+#: ../gui/tcltk/gis.m/raster.tcl:236
+msgid "\tdrape map:  "
+msgstr ""
+#: ../gui/tcltk/gis.m/raster.tcl:239
+msgid "raster map to drape over base map"
+msgstr ""
+#: ../gui/tcltk/gis.m/raster.tcl:244 ../gui/tcltk/gis.m/raster.tcl:248
+msgid "drape map info"
+msgstr ""
+#: ../gui/tcltk/gis.m/raster.tcl:254
+msgid "\tdrape map brightness adjustment\t "
+msgstr ""
+#: ../gui/tcltk/gis.m/raster.tcl:256
+msgid "Adjust brightness of drape map"
+msgstr ""
+#: ../gui/tcltk/gis.m/raster.tcl:263 ../gui/tcltk/gis.m/rgbhis.tcl:220
+#: ../gui/tcltk/d.m/raster.tcl:143 ../gui/tcltk/d.m/rgbhis.tcl:147
+msgid "overlay maps from other layers (transparent null value cells)"
+msgstr ""
+#: ../gui/tcltk/gis.m/raster.tcl:270
+msgid " Set background color (colored null value cells)"
+msgstr ""
+#: ../gui/tcltk/gis.m/raster.tcl:273 ../gui/tcltk/gis.m/legend.tcl:262
+#: ../gui/tcltk/gis.m/chart.tcl:292 ../gui/tcltk/gis.m/gridline.tcl:227
+#: ../gui/tcltk/gis.m/gridline.tcl:233 ../gui/tcltk/gis.m/gridline.tcl:258
+#: ../gui/tcltk/gis.m/rastnums.tcl:179 ../gui/tcltk/gis.m/rastnums.tcl:196
+#: ../gui/tcltk/gis.m/rastarrows.tcl:201 ../gui/tcltk/gis.m/rastarrows.tcl:208
+#: ../gui/tcltk/gis.m/rastarrows.tcl:220 ../gui/tcltk/gis.m/rastarrows.tcl:227
+msgid "white"
+msgstr ""
+msgid "grey"
+msgstr ""
+msgid "gray"
+msgstr ""
+msgid "black"
+msgstr ""
+msgid "brown"
+msgstr ""
+msgid "red"
+msgstr ""
+msgid "orange"
+msgstr ""
+msgid "yellow"
+msgstr ""
+msgid "green"
+msgstr ""
+msgid "aqua"
+msgstr ""
+msgid "cyan"
+msgstr ""
+msgid "indigo"
+msgstr ""
+msgid "blue"
+msgstr ""
+msgid "purple"
+msgstr ""
+msgid "violet"
+msgstr ""
+msgid "magenta"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:493 ../gui/tcltk/gis.m/profile.tcl:412
+msgid "g.proj or projection error"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:584
+msgid "Maximum zoom-in reached"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:660
+msgid "Error setting region 1"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:669
+msgid "please wait..."
+msgstr ""
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:826 ../gui/tcltk/gis.m/mapcanvas.tcl:2149
+msgid "You have to select map layer first"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:827 ../gui/tcltk/gis.m/mapcanvas.tcl:2150
+msgid "No map layer selected"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:899
+msgid "Save Region"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:902
+msgid "Save current display geometry to named region"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:908
+msgid "Enter region name"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:921 ../gui/tcltk/gis.m/gm.tcl:468
+#: ../gui/tcltk/gis.m/gm.tcl:543 ../gui/tcltk/gis.m/georect.tcl:703
+#: ../gui/tcltk/gis.m/dnviz.tcl:230 ../gui/tcltk/gis.m/rules.tcl:172
+#: ../gui/tcltk/gis.m/animate.tcl:538 ../lib/gtcltk/select.tcl:210
+#: ../lib/init/epsg_option.tcl:165 ../lib/init/epsg_option.tcl:312
+#: ../lib/init/file_option.tcl:114 ../lib/init/file_option.tcl:266
+msgid "Cancel"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:925 ../gui/tcltk/gis.m/gmmenu.tcl:88
+#: ../gui/tcltk/d.m/menu.tcl:174
+msgid "Save"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:943
+#, tcl-format
+msgid ""
+"Region file %s already exists. \n"
+"Do you want to overwrite it?"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1296
+#, tcl-format
+msgid "Display: rows=%d  cols=%d  N-S res=%s  E-W res=%s"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1299
+#, tcl-format
+msgid "Display: rows=%d  cols=%d  N-S res=%g  E-W res=%g"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1374
+msgid "Error setting region (Problem with g.region?)"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1440 ../gui/tcltk/gis.m/mapcanvas.tcl:1445
+msgid "Error reading current resolution with g.region"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1477
+msgid "Error setting region 2"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1503 ../gui/tcltk/gis.m/georect.tcl:2029
+msgid "Drag or click mouse to zoom"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1505 ../gui/tcltk/gis.m/georect.tcl:2031
+msgid "Drag or click mouse to unzoom"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1808 ../gui/tcltk/gis.m/georect.tcl:2229
+msgid "Drag with mouse to pan"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1940
+msgid "Measurement"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1965
+msgid "Draw measure line with mouse"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:2120
+msgid "Click to query feature"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:2188
+msgid "This layer type does not support queries"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:2189
+msgid "Query not supported"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:2195 ../gui/tcltk/gis.m/maptool.tcl:229
+#: ../gui/tcltk/gis.m/gmmenu.tcl:644 ../gui/tcltk/d.m/menu.tcl:560
+msgid "Query"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:2196
+msgid "You must select a map to query\n"
+msgstr ""
+#: ../gui/tcltk/gis.m/runandoutput.tcl:44
+#: ../gui/tcltk/gis.m/runandoutput.tcl:118 ../lib/gis/gui.tcl:508
+msgid "Run"
+msgstr ""
+#: ../gui/tcltk/gis.m/runandoutput.tcl:48 ../gui/tcltk/gis.m/gmmenu.tcl:90
+#: ../gui/tcltk/gis.m/mapprint.tcl:372 ../gui/tcltk/d.m/menu.tcl:176
+#: ../gui/tcltk/d.m/print.tcl:281 ../lib/gis/gui.tcl:511
+#: ../lib/init/epsg_option.tcl:392 ../lib/init/epsg_option.tcl:436
+msgid "Close"
+msgstr ""
+#: ../gui/tcltk/gis.m/runandoutput.tcl:121
+msgid "Run (background)"
+msgstr ""
+#: ../gui/tcltk/gis.m/runandoutput.tcl:124
+msgid "Run (GUI)"
+msgstr ""
+#: ../gui/tcltk/gis.m/runandoutput.tcl:136
+msgid " Save "
+msgstr ""
+#: ../gui/tcltk/gis.m/runandoutput.tcl:138
+msgid " Clear "
+msgstr ""
+#: ../gui/tcltk/gis.m/runandoutput.tcl:159
+msgid "Output - GIS.m"
+msgstr ""
+#: ../gui/tcltk/gis.m/runandoutput.tcl:261
+msgid "X Windows not available"
+msgstr ""
+#: ../gui/tcltk/gis.m/runandoutput.tcl:262
+msgid "Functions that require X Windows are not available in Windows"
+msgstr ""
+#: ../gui/tcltk/gis.m/runandoutput.tcl:277
+#: ../gui/tcltk/gis.m/runandoutput.tcl:283 ../gui/tcltk/gis.m/gmlib.tcl:141
+#: ../gui/tcltk/gis.m/grassabout.tcl:94 ../lib/gis/gui.tcl:11
+#: ../lib/gis/gui.tcl:15 ../lib/gis/gui.tcl:19 ../lib/gis/gui.tcl:310
+msgid "Error"
+msgstr ""
+#: ../gui/tcltk/gis.m/runandoutput.tcl:284
+msgid "This module requires X11 support, but no xmons were found"
+msgstr ""
+#: ../gui/tcltk/gis.m/cmd.tcl:115 ../gui/tcltk/d.m/cmd.tcl:52
+msgid "Command:"
+msgstr ""
+#: ../gui/tcltk/gis.m/legend.tcl:149
+msgid "Raster map for legend"
+msgstr ""
+#: ../gui/tcltk/gis.m/legend.tcl:152
+#, tcl-format
+msgid "legend for %s"
+msgstr ""
+#: ../gui/tcltk/gis.m/legend.tcl:193
+msgid "Display legend for raster map using cat values and labels"
+msgstr ""
+#: ../gui/tcltk/gis.m/legend.tcl:210
+msgid "Raster map: "
+msgstr ""
+#: ../gui/tcltk/gis.m/legend.tcl:229
+#, tcl-format
+msgid "Legend placement and size as 0-100% of display"
+msgstr ""
+#: ../gui/tcltk/gis.m/legend.tcl:235
+#, tcl-format
+msgid "    x,y of lower left corner (in % from display top left)"
+msgstr ""
+#: ../gui/tcltk/gis.m/legend.tcl:238 ../gui/tcltk/gis.m/dtext.tcl:201
+#: ../gui/tcltk/gis.m/maptext.tcl:154 ../gui/tcltk/gis.m/barscale.tcl:191
+msgid "place with mouse"
+msgstr ""
+#: ../gui/tcltk/gis.m/legend.tcl:246
+msgid "    legend height "
+msgstr ""
+#: ../gui/tcltk/gis.m/legend.tcl:248
+#, tcl-format
+msgid "Legend height (% of display)"
+msgstr ""
+#: ../gui/tcltk/gis.m/legend.tcl:249
+msgid "%  width"
+msgstr ""
+#: ../gui/tcltk/gis.m/legend.tcl:251
+#, tcl-format
+msgid "Legend width (% of display)"
+msgstr ""
+#: ../gui/tcltk/gis.m/legend.tcl:258
+msgid "Legend appearance: text color"
+msgstr ""
+#: ../gui/tcltk/gis.m/legend.tcl:263
+msgid "  legend text font "
+msgstr ""
+#: ../gui/tcltk/gis.m/legend.tcl:265 ../gui/tcltk/gis.m/dtext.tcl:232
+#: ../gui/tcltk/gis.m/gridline.tcl:191 ../gui/tcltk/gis.m/maptext.tcl:186
+#: ../gui/tcltk/gis.m/barscale.tcl:204 ../gui/tcltk/gis.m/histogram.tcl:179
+#: ../gui/tcltk/gis.m/rastnums.tcl:184
+msgid "select font for text"
+msgstr ""
+#: ../gui/tcltk/gis.m/legend.tcl:274
+msgid "do not display labels"
+msgstr ""
+#: ../gui/tcltk/gis.m/legend.tcl:276
+msgid "do not display values"
+msgstr ""
+#: ../gui/tcltk/gis.m/legend.tcl:283
+msgid "    number of lines (0=display all):"
+msgstr ""
+#: ../gui/tcltk/gis.m/legend.tcl:285
+msgid "Lines to display"
+msgstr ""
+#: ../gui/tcltk/gis.m/legend.tcl:287
+msgid "invert legend"
+msgstr ""
+#: ../gui/tcltk/gis.m/legend.tcl:294
+msgid "    interval between categories (integer maps)"
+msgstr ""
+#: ../gui/tcltk/gis.m/legend.tcl:296
+msgid "Thinning interval"
+msgstr ""
+#: ../gui/tcltk/gis.m/legend.tcl:303
+msgid "draw smooth gradient (fp maps)"
+msgstr ""
+#: ../gui/tcltk/gis.m/legend.tcl:305
+msgid "with maximum of"
+msgstr ""
+#: ../gui/tcltk/gis.m/legend.tcl:307
+msgid "Maximum lines to display for gradient"
+msgstr ""
+#: ../gui/tcltk/gis.m/legend.tcl:308 ../gui/tcltk/gis.m/chart.tcl:222
+#: ../gui/tcltk/d.m/chart.tcl:108 ../gui/tcltk/d.m/vector.tcl:229
+msgid "lines"
+msgstr ""
+#: ../gui/tcltk/gis.m/legend.tcl:314
+msgid "Display legend for subset of raster values"
+msgstr ""
+#: ../gui/tcltk/gis.m/legend.tcl:321
+msgid "skip categories with no labels"
+msgstr ""
+#: ../gui/tcltk/gis.m/legend.tcl:328
+msgid "    legend for only these categories     "
+msgstr ""
+#: ../gui/tcltk/gis.m/legend.tcl:335
+msgid "    legend for only this range of values"
+msgstr ""
+#: ../gui/tcltk/gis.m/dtext.tcl:161
+msgid "Display text"
+msgstr ""
+#: ../gui/tcltk/gis.m/dtext.tcl:178
+msgid "Text to display: "
+msgstr ""
+#: ../gui/tcltk/gis.m/dtext.tcl:190 ../gui/tcltk/gis.m/maptext.tcl:143
+msgid "Text placement: x,y coordinates (from upper left) "
+msgstr ""
+#: ../gui/tcltk/gis.m/dtext.tcl:196 ../gui/tcltk/gis.m/maptext.tcl:150
+msgid "     coordinate type for text placement "
+msgstr ""
+#: ../gui/tcltk/gis.m/dtext.tcl:199 ../gui/tcltk/gis.m/maptext.tcl:153
+msgid "pixels"
+msgstr ""
+msgid "percent"
+msgstr ""
+msgid "geographic"
+msgstr ""
+#: ../gui/tcltk/gis.m/dtext.tcl:209 ../gui/tcltk/gis.m/maptext.tcl:162
+msgid "     align text with coordinate point  "
+msgstr ""
+#: ../gui/tcltk/gis.m/dtext.tcl:213 ../gui/tcltk/gis.m/maplabels.tcl:200
+#: ../gui/tcltk/gis.m/maptext.tcl:166
+msgid "lower left"
+msgstr ""
+#: ../gui/tcltk/gis.m/dtext.tcl:213 ../gui/tcltk/gis.m/maptext.tcl:166
+msgid "bottom center"
+msgstr ""
+msgid "lower right"
+msgstr ""
+msgid "center left"
+msgstr ""
+#: ../gui/tcltk/gis.m/maplabels.tcl:221 ../gui/tcltk/gis.m/maptext.tcl:166
+#: ../gui/tcltk/gis.m/maptext.tcl:175 ../gui/tcltk/gis.m/vector.tcl:483
+#: ../gui/tcltk/gis.m/vector.tcl:488
+msgid "center"
+msgstr ""
+msgid "center right"
+msgstr ""
+msgid "upper left"
+msgstr ""
+msgid "top center"
+msgstr ""
+msgid "upper right"
+msgstr ""
+#: ../gui/tcltk/gis.m/dtext.tcl:220
+msgid "     text rotation (degrees)"
+msgstr ""
+#: ../gui/tcltk/gis.m/dtext.tcl:229
+msgid "Text options: font "
+msgstr ""
+#: ../gui/tcltk/gis.m/dtext.tcl:234 ../gui/tcltk/gis.m/maplabels.tcl:274
+#: ../gui/tcltk/gis.m/maptext.tcl:190 ../gui/tcltk/d.m/fttext.tcl:149
+msgid "  color"
+msgstr ""
+#: ../gui/tcltk/gis.m/dtext.tcl:236 ../gui/tcltk/d.m/dtext.tcl:106
+#: ../gui/tcltk/d.m/fttext.tcl:151
+msgid "bold text"
+msgstr ""
+#: ../gui/tcltk/gis.m/dtext.tcl:243
+msgid "     text height in pixels "
+msgstr ""
+#: ../gui/tcltk/gis.m/dtext.tcl:245
+msgid "  line spacing"
+msgstr ""
+#: ../gui/tcltk/gis.m/maptool.tcl:41 ../gui/tcltk/gis.m/georecttool.tcl:40
+msgid "Display active layers"
+msgstr ""
+#: ../gui/tcltk/gis.m/maptool.tcl:48
+msgid "Redraw all layers"
+msgstr ""
+#: ../gui/tcltk/gis.m/maptool.tcl:55
+msgid "Start NVIZ using active layers in current region"
+msgstr ""
+#: ../gui/tcltk/gis.m/maptool.tcl:61
+msgid "Create flythough path for NVIZ"
+msgstr ""
+#: ../gui/tcltk/gis.m/maptool.tcl:68 ../gui/tcltk/gis.m/georecttool.tcl:47
+#: ../gui/tcltk/d.m/tool1.tcl:40
+msgid "Erase to white"
+msgstr ""
+#: ../gui/tcltk/gis.m/maptool.tcl:94
+msgid "Pointer"
+msgstr ""
+#: ../gui/tcltk/gis.m/maptool.tcl:113 ../gui/tcltk/gis.m/georecttool.tcl:92
+msgid "Zoom In"
+msgstr ""
+#: ../gui/tcltk/gis.m/maptool.tcl:132 ../gui/tcltk/gis.m/georecttool.tcl:111
+msgid "Zoom Out"
+msgstr ""
+#: ../gui/tcltk/gis.m/maptool.tcl:151 ../gui/tcltk/gis.m/georecttool.tcl:130
+#: ../vector/v.digit/toolbox.tcl:212
+msgid "Pan"
+msgstr ""
+#: ../gui/tcltk/gis.m/maptool.tcl:165 ../gui/tcltk/gis.m/georecttool.tcl:144
+#: ../gui/tcltk/d.m/tool1.tcl:87
+msgid "Return to previous zoom"
+msgstr ""
+#: ../gui/tcltk/gis.m/maptool.tcl:185
+msgid "Zoom display to selected map"
+msgstr ""
+#: ../gui/tcltk/gis.m/maptool.tcl:188
+msgid "Zoom display to saved region"
+msgstr ""
+#: ../gui/tcltk/gis.m/maptool.tcl:191
+msgid "Save display extents to named region"
+msgstr ""
+#: ../gui/tcltk/gis.m/maptool.tcl:194
+msgid "Zoom display to computational region (set with g.region)"
+msgstr ""
+#: ../gui/tcltk/gis.m/maptool.tcl:197
+msgid "Zoom display to default region"
+msgstr ""
+#: ../gui/tcltk/gis.m/maptool.tcl:200
+msgid "Set computational region extents to match display"
+msgstr ""
+#: ../gui/tcltk/gis.m/maptool.tcl:248
+msgid "Measure"
+msgstr ""
+#: ../gui/tcltk/gis.m/maptool.tcl:255
+msgid "Create profile of raster map"
+msgstr ""
+#: ../gui/tcltk/gis.m/maptool.tcl:272
+msgid "Print raster & vector maps to eps file"
+msgstr ""
+#: ../gui/tcltk/gis.m/maptool.tcl:291
+msgid "low quality (50)"
+msgstr ""
+#: ../gui/tcltk/gis.m/maptool.tcl:293
+msgid "mid quality (75)"
+msgstr ""
+#: ../gui/tcltk/gis.m/maptool.tcl:295
+msgid "high quality (95)"
+msgstr ""
+#: ../gui/tcltk/gis.m/maptool.tcl:297
+msgid "very high resolution (300% your current resolution)"
+msgstr ""
+#: ../gui/tcltk/gis.m/maptool.tcl:302
+msgid "(* requires gdal)"
+msgstr ""
+#: ../gui/tcltk/gis.m/maptool.tcl:327 ../gui/tcltk/gis.m/rastnums.tcl:288
+msgid "Constrain map to region geometry"
+msgstr ""
+#: ../gui/tcltk/gis.m/maptool.tcl:346
+msgid "Map fills display window"
+msgstr ""
+#: ../gui/tcltk/gis.m/maptool.tcl:397
+msgid "Could not create BMP"
+msgstr ""
+#: ../gui/tcltk/gis.m/maptool.tcl:409 ../gui/tcltk/gis.m/maptool.tcl:414
+msgid "Could not create JPG"
+msgstr ""
+#: ../gui/tcltk/gis.m/maptool.tcl:427
+msgid "Could not create PNG"
+msgstr ""
+#: ../gui/tcltk/gis.m/maptool.tcl:442
+msgid "Could not create TIF"
+msgstr ""
+#: ../gui/tcltk/gis.m/chart.tcl:113
+msgid "Vector map for chart"
+msgstr ""
+#: ../gui/tcltk/gis.m/chart.tcl:116
+#, tcl-format
+msgid "chart for %s"
+msgstr ""
+#: ../gui/tcltk/gis.m/chart.tcl:136 ../gui/tcltk/gis.m/chart.tcl:157
+#: ../gui/tcltk/gis.m/thematic.tcl:179 ../gui/tcltk/gis.m/thematic.tcl:200
+#: ../gui/tcltk/gis.m/vector.tcl:253 ../gui/tcltk/gis.m/vector.tcl:275
+#: ../gui/tcltk/gis.m/vector.tcl:308
+msgid "You must provide valid vector layer number"
+msgstr ""
+#: ../gui/tcltk/gis.m/chart.tcl:185
+msgid ""
+"Display pie and bar charts of attribute values at vector object locations"
+msgstr ""
+#: ../gui/tcltk/gis.m/chart.tcl:202 ../gui/tcltk/d.m/chart.tcl:91
+msgid "Vector map to chart:"
+msgstr ""
+#: ../gui/tcltk/gis.m/chart.tcl:205
+msgid "vector map to chart"
+msgstr ""
+#: ../gui/tcltk/gis.m/chart.tcl:220 ../gui/tcltk/d.m/chart.tcl:106
+msgid "Vector type:"
+msgstr ""
+#: ../gui/tcltk/gis.m/chart.tcl:221 ../gui/tcltk/d.m/chart.tcl:107
+#: ../gui/tcltk/d.m/vector.tcl:227
+msgid "points"
+msgstr ""
+#: ../gui/tcltk/gis.m/chart.tcl:223 ../gui/tcltk/d.m/chart.tcl:109
+#: ../gui/tcltk/d.m/vector.tcl:231
+msgid "boundaries"
+msgstr ""
+#: ../gui/tcltk/gis.m/chart.tcl:224 ../gui/tcltk/d.m/chart.tcl:110
+#: ../gui/tcltk/d.m/vector.tcl:233
+msgid "centroids"
+msgstr ""
+#: ../gui/tcltk/gis.m/chart.tcl:225 ../gui/tcltk/d.m/chart.tcl:111
+#: ../gui/tcltk/d.m/vector.tcl:235
+msgid "areas"
+msgstr ""
+#: ../gui/tcltk/gis.m/chart.tcl:231
+msgid "Attributes to chart: attribute layer"
+msgstr ""
+#: ../gui/tcltk/gis.m/chart.tcl:238
+msgid "     show attribute columns"
+msgstr ""
+#: ../gui/tcltk/gis.m/chart.tcl:239 ../gui/tcltk/gis.m/thematic.tcl:299
+#: ../gui/tcltk/gis.m/vector.tcl:533 ../gui/tcltk/d.m/chart.tcl:121
+#: ../gui/tcltk/d.m/thematic.tcl:151 ../gui/tcltk/d.m/vector.tcl:349
+msgid "columns"
+msgstr ""
+#: ../gui/tcltk/gis.m/chart.tcl:243 ../gui/tcltk/gis.m/thematic.tcl:303
+#: ../gui/tcltk/gis.m/vector.tcl:537 ../gui/tcltk/d.m/chart.tcl:125
+#: ../gui/tcltk/d.m/thematic.tcl:155 ../gui/tcltk/d.m/vector.tcl:353
+msgid "Show columns"
+msgstr ""
+#: ../gui/tcltk/gis.m/chart.tcl:244
+msgid "   show attribute data"
+msgstr ""
+#: ../gui/tcltk/gis.m/chart.tcl:245 ../gui/tcltk/gis.m/thematic.tcl:305
+#: ../gui/tcltk/gis.m/vector.tcl:539 ../gui/tcltk/d.m/thematic.tcl:157
+#: ../gui/tcltk/d.m/vector.tcl:355
+msgid "data"
+msgstr ""
+#: ../gui/tcltk/gis.m/chart.tcl:249 ../gui/tcltk/gis.m/thematic.tcl:309
+#: ../gui/tcltk/gis.m/vector.tcl:543 ../gui/tcltk/d.m/thematic.tcl:161
+#: ../gui/tcltk/d.m/vector.tcl:359
+msgid "Show data"
+msgstr ""
+#: ../gui/tcltk/gis.m/chart.tcl:255
+msgid "\tcolumns to chart (col1,col2,...)  "
+msgstr ""
+#: ../gui/tcltk/gis.m/chart.tcl:262
+msgid "\tcolors for columns (clr1,clr2,...)"
+msgstr ""
+#: ../gui/tcltk/gis.m/chart.tcl:269
+msgid "\tcolumn for variable chart size"
+msgstr ""
+#: ../gui/tcltk/gis.m/chart.tcl:271
+msgid "  scale factor"
+msgstr ""
+#: ../gui/tcltk/gis.m/chart.tcl:278 ../gui/tcltk/d.m/chart.tcl:158
+msgid "Chart type:"
+msgstr ""
+#: ../gui/tcltk/gis.m/chart.tcl:280 ../gui/tcltk/gis.m/histogram.tcl:175
+msgid "pie"
+msgstr ""
+msgid "bar"
+msgstr ""
+#: ../gui/tcltk/gis.m/chart.tcl:281
+msgid "\tfixed chart size (if size column not used)"
+msgstr ""
+#: ../gui/tcltk/gis.m/chart.tcl:288
+msgid "\tchart outline color:"
+msgstr ""
+msgid "none"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:85 ../gui/tcltk/d.m/menu.tcl:75
+msgid "&File"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:86
+msgid "Workspace"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:87 ../gui/tcltk/d.m/menu.tcl:173
+msgid "Open..."
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:89 ../gui/tcltk/d.m/menu.tcl:175
+msgid "Save as..."
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:93
+msgid "Import raster map"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:94 ../gui/tcltk/gis.m/gmmenu.tcl:133
+#: ../gui/tcltk/d.m/menu.tcl:78 ../gui/tcltk/d.m/menu.tcl:114
+msgid "Multiple formats using GDAL"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:95
+msgid "Multiple formats using GDAL (link into instead of import)"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:97
+msgid "Aggregate ASCII xyz"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:98 ../gui/tcltk/gis.m/gmmenu.tcl:135
+msgid "ASCII grid"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:99
+msgid "ASCII polygons and lines"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:101 ../gui/tcltk/gis.m/gmmenu.tcl:142
+msgid "Binary"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:102
+msgid "ESRI grid"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:103 ../gui/tcltk/gis.m/gmmenu.tcl:139
+msgid "GRIDATB.FOR"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:104 ../gui/tcltk/gis.m/gmmenu.tcl:140
+msgid "MAT-File (v.4)"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:105
+msgid "SPOT NDVI"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:106
+msgid "SRTM hgt"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:107
+msgid "Terra ASTER"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:109 ../gui/tcltk/d.m/menu.tcl:92
+msgid "Web Mapping Server"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:111
+msgid "Import vector map"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:112 ../gui/tcltk/gis.m/gmmenu.tcl:154
+msgid "Multiple formats using OGR"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:114 ../gui/tcltk/gis.m/gmmenu.tcl:156
+msgid "ASCII points or GRASS ASCII vector"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:115
+msgid "ASCII points as vector lines"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:116
+msgid "Old GRASS vector"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:118 ../gui/tcltk/gis.m/gmmenu.tcl:157
+msgid "DXF"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:119
+msgid "ESRI e00"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:120
+msgid "Garmin GPS"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:121
+msgid "GPSBabel GPS"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:122
+msgid "Geonames"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:123
+msgid "GEOnet"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:124
+msgid "Matlab and MapGen"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:126
+msgid "Import grid 3D volume"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:127 ../gui/tcltk/gis.m/gmmenu.tcl:164
+msgid "ASCII 3D"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:128 ../gui/tcltk/gis.m/gmmenu.tcl:165
+msgid "Vis5D"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:130
+msgid "Import data table"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:132
+msgid "Export raster map"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:136
+msgid "ASCII x,y,z"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:138
+msgid "ESRI ASCII grid"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:144
+msgid "MPEG-1"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:145
+msgid "PNG"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:146
+msgid "PPM"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:147
+msgid "PPM from RGB"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:148 ../gui/tcltk/gis.m/gmmenu.tcl:159
+msgid "POV-Ray"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:149
+msgid "TIFF"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:150
+msgid "VRML"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:151 ../gui/tcltk/gis.m/gmmenu.tcl:161
+#: ../gui/tcltk/gis.m/gmmenu.tcl:166
+msgid "VTK"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:153
+msgid "Export vector map"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:158 ../gui/tcltk/d.m/menu.tcl:139
+msgid "Multiple GPS formats using GPSBabel"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:160 ../gui/tcltk/d.m/menu.tcl:141
+msgid "SVG"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:163
+msgid "Export grid 3D volume"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:168
+msgid "Export data table"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:170 ../gui/tcltk/d.m/menu.tcl:151
+msgid "Manage maps and volumes"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:171 ../lib/gis/gui.tcl:469
+msgid "Copy"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:173
+msgid "List"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:174
+msgid "List filtered"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:176
+msgid "Rename"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:178 ../vector/v.digit/cats.tcl:20
+msgid "Delete"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:179
+msgid "Delete filtered"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:181 ../gui/tcltk/d.m/menu.tcl:159
+msgid "Map type conversions"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:182
+msgid "Raster to vector"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:183
+msgid "Raster series to volume"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:184
+msgid "Raster 2.5D to volume"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:186 ../gui/tcltk/d.m/menu.tcl:163
+msgid "Vector to raster"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:187
+msgid "Vector to volume"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:188
+msgid "Sites to vector"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:190
+msgid "Volume to raster series"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:193
+msgid "Georectify"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:195
+msgid "Animate raster maps"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:197
+msgid "Bearing/distance to coordinates"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:199
+msgid "3D rendering"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:200
+msgid "NVIZ"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:201
+msgid "NVIZ fly through path"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:203
+msgid "PostScript plot"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:205
+msgid "Exit &GRASS"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:206
+msgid "&Quit GIS Manager"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:208 ../gui/tcltk/d.m/menu.tcl:188
+msgid "&Config"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:209 ../gui/tcltk/d.m/menu.tcl:189
+msgid "Region"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:210 ../gui/tcltk/d.m/menu.tcl:190
+msgid "Display region settings"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:211 ../gui/tcltk/d.m/menu.tcl:191
+msgid "Change region settings"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:213 ../gui/tcltk/d.m/menu.tcl:194
+msgid "GRASS working environment"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:214
+msgid "Mapset access"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:215
+msgid "Change working environment"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:216
+msgid "User access"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:217
+msgid "Show settings"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:218
+msgid "Change settings"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:219 ../gui/tcltk/d.m/menu.tcl:200
+msgid "Change default GUI"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:220 ../gui/tcltk/d.m/menu.tcl:201
+msgid "Show current GRASS version"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:222 ../gui/tcltk/gis.m/gmmenu.tcl:223
+#: ../gui/tcltk/d.m/menu.tcl:203
+msgid "Manage projections"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:224
+msgid "Projection for current location"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:226
+msgid "Convert coordinates"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:228
+msgid "Display font"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:230 ../gui/tcltk/d.m/menu.tcl:221
+msgid "&Raster"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:231 ../gui/tcltk/gis.m/gmmenu.tcl:438
+#: ../gui/tcltk/d.m/menu.tcl:222 ../gui/tcltk/d.m/menu.tcl:381
+msgid "Develop map"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:232 ../gui/tcltk/d.m/menu.tcl:223
+msgid "Digitize raster"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:238
+msgid "Compress/decompress"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:240
+msgid "Boundaries"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:241
+msgid "Null values"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:242
+msgid "Quantization"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:243
+msgid "Timestamps"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:245 ../gui/tcltk/d.m/menu.tcl:234
+msgid "Resample using aggregate statistics"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:246
+msgid "Resample using multiple methods"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:247
+msgid "Resample using nearest neighbor"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:248
+msgid "Resample using spline tension"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:250
+msgid "Support file maintenance"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:251
+msgid "Update map statistics"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:253
+msgid "Reproject"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:254
+msgid "Tiling"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:256 ../gui/tcltk/d.m/menu.tcl:243
+msgid "Manage map colors"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:257
+msgid "Color tables"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:258
+msgid "Color tables (stddev)"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:259
+msgid "Color rules"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:261
+msgid "Blend"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:262
+msgid "Create RGB"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:263 ../gui/tcltk/gis.m/gmmenu.tcl:561
+msgid "HIS to RGB"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:265
+msgid "Query raster color"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:268 ../gui/tcltk/d.m/menu.tcl:253
+#: ../gui/tcltk/d.m/menu.tcl:409
+msgid "Query by coordinate(s)"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:270
+msgid "Buffers"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:271
+msgid "Closest points"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:272
+msgid "MASK"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:273 ../gui/tcltk/d.m/menu.tcl:258
+msgid "Map calculator"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:274 ../gui/tcltk/d.m/menu.tcl:259
+#: ../gui/tcltk/d.m/menu.tcl:419
+msgid "Neighborhood analysis"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:275
+msgid "Moving window"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:276
+msgid "Neighborhood points"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:278 ../gui/tcltk/gis.m/gmmenu.tcl:504
+#: ../gui/tcltk/d.m/menu.tcl:263 ../gui/tcltk/d.m/menu.tcl:433
+msgid "Overlay maps"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:279 ../gui/tcltk/d.m/menu.tcl:264
+msgid "Cross product"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:280
+msgid "Map series"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:281 ../gui/tcltk/d.m/menu.tcl:266
+msgid "Patch maps"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:283
+msgid "Statistical overlay"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:285 ../gui/tcltk/d.m/menu.tcl:270
+msgid "Solar radiance and shadows"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:286
+msgid "Solar irradiance irradiation"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:287
+msgid "Shadows map"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:289 ../gui/tcltk/d.m/menu.tcl:274
+msgid "Terrain analysis"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:290
+msgid "Cumulative movement costs"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:291 ../gui/tcltk/d.m/menu.tcl:276
+msgid "Cost surface"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:292 ../gui/tcltk/d.m/menu.tcl:277
+msgid "Least cost route or flow"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:294
+msgid "Shaded relief"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:296 ../gui/tcltk/d.m/menu.tcl:280
+msgid "Slope and aspect"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:297 ../gui/tcltk/d.m/menu.tcl:281
+msgid "Terrain parameters"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:298 ../gui/tcltk/d.m/menu.tcl:282
+msgid "Textural features"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:300
+msgid "Visibility"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:301 ../gui/tcltk/d.m/menu.tcl:284
+msgid "Distance to features"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:303
+msgid "Horizon"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:305 ../gui/tcltk/d.m/menu.tcl:286
+msgid "Transform features"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:306
+msgid "Clump"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:307
+msgid "Grow"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:308
+msgid "Thin"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:311 ../gui/tcltk/d.m/menu.tcl:292
+msgid "Hydrologic modeling"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:312
+msgid "Carve stream channels"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:313
+msgid "Fill lake"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:315
+msgid "Depressionless map and flowlines"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:316
+msgid "Flow accumulation"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:317
+msgid "Flow lines"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:319 ../gui/tcltk/gis.m/gmmenu.tcl:612
+msgid "Groundwater flow model"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:321 ../gui/tcltk/d.m/menu.tcl:298
+msgid "SIMWE overland flow modeling"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:322
+msgid "SIMWE sediment flux modeling"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:324 ../gui/tcltk/d.m/menu.tcl:300
+msgid "Topographic index map"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:325 ../gui/tcltk/d.m/menu.tcl:301
+msgid "TOPMODEL simulation"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:327 ../gui/tcltk/d.m/menu.tcl:302
+msgid "Watershed subbasins"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:328 ../gui/tcltk/d.m/menu.tcl:303
+msgid "Watershed analysis"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:329 ../gui/tcltk/d.m/menu.tcl:304
+msgid "Watershed basin creation"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:331 ../gui/tcltk/d.m/menu.tcl:306
+msgid "Landscape structure modeling"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:332
+msgid "Set up"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:338
+msgid "Analyze landscape"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:339
+msgid "Analyze patches"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:340
+msgid "Summary and display"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:346
+msgid "Landscape patch analysis"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:347 ../gui/tcltk/d.m/menu.tcl:307
+msgid "Set up sampling and analysis framework"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:349
+msgid "Edge density"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:350
+msgid "Contrast weighted edge density"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:352
+msgid "Patch size mean"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:353
+msgid "Patch area range"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:354
+msgid "Patch area Std Dev"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:355
+msgid "Patch area Coeff Var"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:356
+msgid "Patch density"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:357
+msgid "Patch number"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:359
+msgid "Dominance's diversity"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:360
+msgid "Shannon's diversity"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:361
+msgid "Simpson's diversity"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:363
+msgid "Richness"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:364
+msgid "Shape index"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:366 ../gui/tcltk/d.m/menu.tcl:313
+msgid "Wildfire modeling"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:367
+msgid "Rate of spread"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:368
+msgid "Least-cost spread paths"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:369
+msgid "Anisotropic spread simulation"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:372 ../gui/tcltk/d.m/menu.tcl:319
+msgid "Change category values and labels"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:373
+msgid "Interactively edit category values"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:375
+msgid "Reclassify by size"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:376
+msgid "Reclassify interactively"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:377 ../gui/tcltk/gis.m/gmmenu.tcl:512
+msgid "Reclassify using rules file"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:379
+msgid "Recode interactively"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:380
+msgid "Recode using rules file"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:382
+msgid "Rescale"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:383
+msgid "Rescale with histogram"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:386
+msgid "Concentric circles"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:387 ../gui/tcltk/d.m/menu.tcl:336
+msgid "Generate random cells"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:388
+msgid "Random cells"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:389
+msgid "Random cells and vector points"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:391 ../gui/tcltk/d.m/menu.tcl:339
+msgid "Generate surfaces"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:392
+msgid "Fractal surface"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:394
+msgid "Gausian kernal density surface"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:395
+msgid "Gaussian deviates surface"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:397
+msgid "Plane"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:399
+msgid "Random deviates surface"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:400
+msgid "Random surface with spatial dependence"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:402
+msgid "Contour lines"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:403 ../gui/tcltk/d.m/menu.tcl:348
+msgid "Interpolate surfaces"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:404
+msgid "Bilinear from raster points"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:405
+msgid "Bilinear and bicubic from vector points"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:407
+msgid "IDW from raster points"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:408
+msgid "IDW from vector points"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:410
+msgid "Raster contours"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:411
+msgid "Regularized spline tension"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:413
+msgid "Fill NULL cells"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:416 ../gui/tcltk/gis.m/gmmenu.tcl:539
+#: ../gui/tcltk/gis.m/gmmenu.tcl:598 ../gui/tcltk/d.m/menu.tcl:359
+#: ../gui/tcltk/d.m/menu.tcl:465 ../gui/tcltk/d.m/menu.tcl:521
+msgid "Reports and statistics"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:417 ../gui/tcltk/d.m/menu.tcl:360
+#: ../gui/tcltk/d.m/menu.tcl:522
+msgid "Report basic file information"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:418
+msgid "Manage category information"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:420 ../gui/tcltk/gis.m/gmmenu.tcl:616
+#: ../gui/tcltk/d.m/menu.tcl:363
+msgid "General statistics"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:421
+msgid "Quantiles for large data sets"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:422
+msgid "Range of category values"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:423
+msgid "Sum cell category values"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:424 ../gui/tcltk/d.m/menu.tcl:366
+msgid "Sum area by map and category"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:425
+msgid "Statistics for clumped cells (works with r.clump)"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:426 ../gui/tcltk/d.m/menu.tcl:368
+msgid "Total surface area corrected for topography"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:427 ../gui/tcltk/gis.m/gmmenu.tcl:617
+#: ../gui/tcltk/gis.m/gmmenu.tcl:655 ../gui/tcltk/d.m/menu.tcl:369
+#: ../gui/tcltk/d.m/menu.tcl:469
+msgid "Univariate statistics"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:429
+msgid "Sample transects"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:430
+msgid "Sample transects (bearing/distance)"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:432 ../gui/tcltk/d.m/menu.tcl:375
+msgid "Covariance/correlation"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:433
+msgid "Linear regression"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:434
+msgid "Mutual category occurences"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:437 ../gui/tcltk/d.m/menu.tcl:380
+msgid "&Vector"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:439 ../gui/tcltk/d.m/menu.tcl:382
+msgid "Digitize"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:440
+msgid "Edit features"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:442 ../gui/tcltk/d.m/menu.tcl:384
+msgid "Create/rebuild topology"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:443
+msgid "Clean vector"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:444
+msgid "Smooth or simplify"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:446
+msgid "Convert object types"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:448
+msgid "Add centroids"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:450
+msgid "Build polylines"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:451
+msgid "Split polylines"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:452
+msgid "Split lines to segments"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:453
+msgid "Parallel lines"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:455
+msgid "Dissolve boundaries"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:457
+msgid "Create 3D vector over raster"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:458
+msgid "Extrude 3D vector"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:460
+msgid "Link to OGR"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:462
+msgid "Create labels"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:463
+msgid "Create optimally placed labels"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:464
+msgid "Assign colors"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:466
+msgid "Reposition vector"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:467
+msgid "Reproject vector"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:469
+msgid "Metadata support"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:473
+msgid "Query with attributes"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:474
+msgid "Query with coordinate(s)"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:475
+msgid "Query with another map"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:477
+msgid "Buffer vectors"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:478
+msgid "Lidar analysis"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:479
+msgid "Detect edges"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:480
+msgid "Detect interiors"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:481
+msgid "Correct and reclassify objects"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:483
+msgid "Linear referencing"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:484
+msgid "Create LRS"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:485
+msgid "Create stationing"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:486
+msgid "Create points/segments"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:487
+msgid "Find ID and offset"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:489
+msgid "Nearest features"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:490 ../gui/tcltk/d.m/menu.tcl:424
+msgid "Network analysis"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:491 ../gui/tcltk/d.m/menu.tcl:425
+msgid "Allocate subnets"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:492 ../gui/tcltk/d.m/menu.tcl:426
+msgid "Network maintenance"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:493
+msgid "Visibility network"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:494 ../gui/tcltk/d.m/menu.tcl:427
+msgid "Shortest route"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:495
+msgid "Display shortest route"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:500
+msgid "Split net"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:501 ../gui/tcltk/d.m/menu.tcl:430
+msgid "Steiner tree"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:502 ../gui/tcltk/d.m/menu.tcl:431
+msgid "Traveling salesman analysis"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:505
+msgid "Overlay"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:506
+msgid "Patch (combine)"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:509 ../gui/tcltk/d.m/menu.tcl:440
+msgid "Change attributes"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:510
+msgid "Manage or report categories"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:511
+msgid "Reclassify objects interactively"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:515
+msgid "Generate area for current region"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:516 ../gui/tcltk/d.m/menu.tcl:451
+msgid "Generate areas from points"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:517
+msgid "Convex hull"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:518
+msgid "Delaunay triangles"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:519
+msgid "Voronoi diagram/Thiessen polygons"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:521
+msgid "Generate grid"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:522 ../gui/tcltk/d.m/menu.tcl:446
+msgid "Generate points"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:523
+msgid "Generate points from database"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:524
+msgid "Generate points along lines"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:525 ../gui/tcltk/d.m/menu.tcl:448
+msgid "Generate random points"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:526
+msgid "Perturb points"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:529
+msgid "Remove outliers in point sets"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:530
+msgid "Test/training sets"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:532
+msgid "Update area attributes from raster"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:533
+msgid "Update point attributes from areas"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:534
+msgid "Update point attributes from raster"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:535 ../gui/tcltk/d.m/menu.tcl:458
+msgid "Sample raster map at point locations"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:536 ../gui/tcltk/d.m/menu.tcl:459
+msgid "Sample raster neighborhood around points"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:540 ../gui/tcltk/gis.m/gmmenu.tcl:615
+#: ../gui/tcltk/d.m/menu.tcl:466
+msgid "Basic information"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:542
+msgid "Report topology by category"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:543
+msgid "Upload or report topology"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:545
+msgid "Univariate attribute statistics"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:546
+msgid "Attribute classification"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:548
+msgid "Quadrat indices"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:549
+msgid "Test normality"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:552 ../gui/tcltk/d.m/menu.tcl:476
+msgid "&Imagery"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:553 ../gui/tcltk/d.m/menu.tcl:477
+msgid "Develop images and groups"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:554
+msgid "Create/edit group"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:555
+msgid "Target group"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:557
+msgid "Mosaic images"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:559 ../gui/tcltk/d.m/menu.tcl:483
+msgid "Manage image colors"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:560
+msgid "Color balance for RGB"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:562
+msgid "RGB to HIS"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:564 ../gui/tcltk/d.m/menu.tcl:494
+msgid "Ortho photo rectification"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:570
+msgid "Brovey sharpening"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:571 ../gui/tcltk/d.m/menu.tcl:498
+msgid "Classify image"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:572 ../gui/tcltk/d.m/menu.tcl:499
+msgid "Clustering input for unsupervised classification"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:574 ../gui/tcltk/d.m/menu.tcl:501
+msgid "Maximum likelihood classification (MLC)"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:575 ../gui/tcltk/d.m/menu.tcl:502
+msgid "Sequential maximum a posteriory classification (SMAP)"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:577 ../gui/tcltk/d.m/menu.tcl:504
+msgid "Interactive input for supervised classification"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:582
+msgid "Input for supervised MLC"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:583
+msgid "Input for supervised SMAP"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:585 ../gui/tcltk/d.m/menu.tcl:508
+msgid "Filter image"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:586
+msgid "Edge detection"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:587
+msgid "Matrix/convolving filter"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:589 ../gui/tcltk/d.m/menu.tcl:512
+msgid "Spectral response"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:590 ../gui/tcltk/d.m/menu.tcl:513
+msgid "Tassled cap vegetation index"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:591 ../gui/tcltk/d.m/menu.tcl:514
+msgid "Transform image"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:592
+msgid "Canonical correlation"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:593
+msgid "Principal components"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:594
+msgid "Fast Fourier"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:595
+msgid "Inverse Fast Fourier"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:599
+msgid "Bit pattern comparison"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:600
+msgid "Kappa analysis"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:601
+msgid "OIF for LandSat TM"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:604
+msgid "&Volumes"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:605 ../gui/tcltk/d.m/menu.tcl:531
+msgid "Develop grid3D volumes"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:606 ../gui/tcltk/d.m/menu.tcl:532
+msgid "Manage nulls for grid3D volume"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:607 ../gui/tcltk/d.m/menu.tcl:533
+msgid "Manage timestamp for grid3D volume"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:609
+msgid "3D MASK"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:610
+msgid "3D Map calculator"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:611
+msgid "Cross section from volume"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:613
+msgid "Interpolate volume from vector points"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:614 ../gui/tcltk/gis.m/gmmenu.tcl:654
+#: ../gui/tcltk/d.m/menu.tcl:539
+msgid "Report and Statistics"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:620 ../gui/tcltk/d.m/menu.tcl:543
+msgid "&Databases"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:621 ../gui/tcltk/d.m/menu.tcl:553
+msgid "Database information"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:622 ../gui/tcltk/d.m/menu.tcl:554
+msgid "Describe table"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:623 ../gui/tcltk/d.m/menu.tcl:555
+msgid "List columns"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:624 ../gui/tcltk/d.m/menu.tcl:556
+msgid "List drivers"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:625 ../gui/tcltk/d.m/menu.tcl:557
+msgid "List tables"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:628 ../gui/tcltk/d.m/menu.tcl:544
+msgid "Manage database"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:629 ../gui/tcltk/d.m/menu.tcl:545
+msgid "Connect to database"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:630 ../gui/tcltk/d.m/menu.tcl:546
+msgid "Login to database"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:632 ../gui/tcltk/d.m/menu.tcl:548
+msgid "Copy table"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:633
+msgid "New table"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:634
+msgid "Remove table"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:636
+msgid "Add columns"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:637
+msgid "Change values"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:638
+msgid "Drop column"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:639
+msgid "Rename a column"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:641 ../gui/tcltk/d.m/menu.tcl:551
+msgid "Test database"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:645
+msgid "Query any table"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:646
+msgid "Query vector attribute table"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:647
+msgid "SQL statement"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:649 ../gui/tcltk/d.m/menu.tcl:402
+msgid "Vector<->database connections"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:650
+msgid "Reconnect vector to database"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:651
+msgid "Set vector - database connection"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:658 ../gui/tcltk/d.m/menu.tcl:565
+msgid "&Help"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:659 ../gui/tcltk/d.m/menu.tcl:566
+msgid "GRASS help"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:660 ../gui/tcltk/d.m/menu.tcl:567
+msgid "GIS Manager &help"
+msgstr ""
+msgid "GIS Manager help"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:661 ../gui/tcltk/d.m/menu.tcl:568
+msgid "About &GRASS"
+msgstr ""
+msgid "About GRASS"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:662 ../gui/tcltk/d.m/menu.tcl:569
+msgid "About &System"
+msgstr ""
+msgid "About System"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmmenu.tcl:670 ../gui/tcltk/d.m/menu.tcl:577
+msgid "&Xtns"
+msgstr ""
+#: ../gui/tcltk/gis.m/gridline.tcl:144
+msgid "Display grid lines, and geodesic lines or rhumblines"
+msgstr ""
+#: ../gui/tcltk/gis.m/gridline.tcl:161
+msgid "Grid options: "
+msgstr ""
+#: ../gui/tcltk/gis.m/gridline.tcl:162 ../gui/tcltk/d.m/gridline.tcl:77
+msgid "draw grid"
+msgstr ""
+#: ../gui/tcltk/gis.m/gridline.tcl:163
+msgid "geodetic grid  "
+msgstr ""
+#: ../gui/tcltk/gis.m/gridline.tcl:165
+msgid "grid color "
+msgstr ""
+#: ../gui/tcltk/gis.m/gridline.tcl:170 ../gui/tcltk/d.m/gridline.tcl:85
+msgid "Help for grids"
+msgstr ""
+#: ../gui/tcltk/gis.m/gridline.tcl:176
+msgid "    grid size (map units)"
+msgstr ""
+#: ../gui/tcltk/gis.m/gridline.tcl:178
+msgid " grid origin (east, north)"
+msgstr ""
+#: ../gui/tcltk/gis.m/gridline.tcl:186
+msgid "draw border text "
+msgstr ""
+#: ../gui/tcltk/gis.m/gridline.tcl:188
+msgid "text color "
+msgstr ""
+#: ../gui/tcltk/gis.m/gridline.tcl:193
+msgid "text font "
+msgstr ""
+#: ../gui/tcltk/gis.m/gridline.tcl:194
+msgid "  text size"
+msgstr ""
+#: ../gui/tcltk/gis.m/gridline.tcl:196
+msgid "Grid text size in points"
+msgstr ""
+#: ../gui/tcltk/gis.m/gridline.tcl:203
+msgid "draw grid border "
+msgstr ""
+#: ../gui/tcltk/gis.m/gridline.tcl:205
+msgid "border color "
+msgstr ""
+#: ../gui/tcltk/gis.m/gridline.tcl:210
+msgid "Geodesic and rhumblines for latlong locations only"
+msgstr ""
+#: ../gui/tcltk/gis.m/gridline.tcl:217 ../gui/tcltk/d.m/gridline.tcl:119
+msgid "draw geodesic line"
+msgstr ""
+#: ../gui/tcltk/gis.m/gridline.tcl:222 ../gui/tcltk/d.m/gridline.tcl:124
+msgid "Help for geodesic lines"
+msgstr ""
+#: ../gui/tcltk/gis.m/gridline.tcl:223 ../gui/tcltk/gis.m/gridline.tcl:254
+msgid " line color"
+msgstr ""
+#: ../gui/tcltk/gis.m/gridline.tcl:229
+msgid " text color"
+msgstr ""
+#: ../gui/tcltk/gis.m/gridline.tcl:240 ../gui/tcltk/gis.m/gridline.tcl:265
+msgid "     line endpoints (x1,y1,x2,y2)"
+msgstr ""
+#: ../gui/tcltk/gis.m/gridline.tcl:248 ../gui/tcltk/d.m/gridline.tcl:149
+msgid "draw rhumbline"
+msgstr ""
+#: ../gui/tcltk/gis.m/gridline.tcl:253 ../gui/tcltk/d.m/gridline.tcl:154
+msgid "Help for rhumblines"
+msgstr ""
+#: ../gui/tcltk/gis.m/tksys.tcl:57
+msgid ""
+"\n"
+"***** Please wait *****"
+msgstr ""
+#: ../gui/tcltk/gis.m/tksys.tcl:58
+msgid "Gathering information about your system"
+msgstr ""
+#: ../gui/tcltk/gis.m/tksys.tcl:230
+msgid "***** Done *****"
+msgstr ""
+#: ../gui/tcltk/gis.m/gm.tcl:75
+msgid ""
+"GISDBASE or LOCATION_NAME or MAPSET is empty.  This is a fatal error. gis.m "
+"can not work without proper settings."
+msgstr ""
+#: ../gui/tcltk/gis.m/gm.tcl:219 ../gui/tcltk/d.m/d.m.tcl:314
+msgid "Loading GIS Manager"
+msgstr ""
+#: ../gui/tcltk/gis.m/gm.tcl:226
+msgid "Creating MainFrame..."
+msgstr ""
+#: ../gui/tcltk/gis.m/gm.tcl:266 ../gui/tcltk/d.m/d.m.tcl:404
+msgid "Done"
+msgstr ""
+#: ../gui/tcltk/gis.m/gm.tcl:268
+msgid "Welcome to GRASS GIS"
+msgstr ""
+#: ../gui/tcltk/gis.m/gm.tcl:305
+#, tcl-format
+msgid "Map Display %d"
+msgstr ""
+#: ../gui/tcltk/gis.m/gm.tcl:330
+#, tcl-format
+msgid "GRASS%s GIS Manager - %s"
+msgstr ""
+#: ../gui/tcltk/gis.m/gm.tcl:405
+msgid "Select GRASS display font"
+msgstr ""
+#: ../gui/tcltk/gis.m/gm.tcl:419
+msgid "Font: "
+msgstr ""
+#: ../gui/tcltk/gis.m/gm.tcl:458
+msgid "Character encoding: "
+msgstr ""
+#: ../gui/tcltk/gis.m/gm.tcl:465 ../gui/tcltk/gis.m/dnviz.tcl:228
+#: ../gui/tcltk/gis.m/rules.tcl:170 ../gui/tcltk/gis.m/animate.tcl:536
+#: ../lib/init/epsg_option.tcl:309 ../lib/init/file_option.tcl:263
+#: ../vector/v.digit/settings.tcl:174
+msgid "OK"
+msgstr ""
+#: ../gui/tcltk/gis.m/gm.tcl:539
+msgid "End current GRASS session"
+msgstr ""
+#: ../gui/tcltk/gis.m/gm.tcl:540
+msgid ""
+"Do you really want to terminate current GRASS session?\n"
+"\n"
+"This action will close all sessions gis.m instances.\n"
+"\n"
+"If You have running some  GRASS module from comandline, GRASS will terminate "
+"after it finishes to run."
+msgstr ""
+msgid "Terminate current GRASS session"
+msgstr ""
+#: ../gui/tcltk/gis.m/gm.tcl:550
+msgid "Not supported"
+msgstr ""
+#: ../gui/tcltk/gis.m/gm.tcl:551
+msgid ""
+"We sorry. Your shell does not support this feature. \n"
+" You have to type 'exit' in terminal manually."
+msgstr ""
+#: ../gui/tcltk/gis.m/gm.tcl:573
+#, tcl-format
+msgid "GRASS%s GIS Manager - %s %s"
+msgstr ""
+#: ../gui/tcltk/gis.m/frames.tcl:105
+msgid "Divide map display into frames for displaying multiple maps"
+msgstr ""
+#: ../gui/tcltk/gis.m/frames.tcl:112 ../gui/tcltk/d.m/frames.tcl:60
+msgid "create and select frame"
+msgstr ""
+#: ../gui/tcltk/gis.m/frames.tcl:114 ../gui/tcltk/d.m/frames.tcl:62
+msgid "select frame"
+msgstr ""
+#: ../gui/tcltk/gis.m/frames.tcl:116
+msgid "remove all frames   "
+msgstr ""
+#: ../gui/tcltk/gis.m/frames.tcl:128
+msgid "Frame name (optional): "
+msgstr ""
+#: ../gui/tcltk/gis.m/frames.tcl:135
+#, tcl-format
+msgid "Set frame borders at 0-100% from lower left corner of display "
+msgstr ""
+#: ../gui/tcltk/gis.m/frames.tcl:141
+msgid "     set borders (bottom,top,left,right): "
+msgstr ""
+#: ../gui/tcltk/gis.m/rgbhis.tcl:104
+msgid "Raster map for red or hue channel"
+msgstr ""
+#: ../gui/tcltk/gis.m/rgbhis.tcl:107
+#, tcl-format
+msgid "RGB-HIS %s"
+msgstr ""
+#: ../gui/tcltk/gis.m/rgbhis.tcl:114
+msgid "Raster map for green or intensity channel"
+msgstr ""
+#: ../gui/tcltk/gis.m/rgbhis.tcl:122
+msgid "Raster map for blue or saturation channel"
+msgstr ""
+#: ../gui/tcltk/gis.m/rgbhis.tcl:136
+msgid ""
+"Display 3 raster maps as Red/Green/Blue or Hue/Intensity/Saturation channels"
+msgstr ""
+#: ../gui/tcltk/gis.m/rgbhis.tcl:155 ../gui/tcltk/d.m/rgbhis.tcl:128
+msgid "display maps as RGB"
+msgstr ""
+#: ../gui/tcltk/gis.m/rgbhis.tcl:160 ../gui/tcltk/d.m/rgbhis.tcl:134
+msgid "Help for RGB"
+msgstr ""
+#: ../gui/tcltk/gis.m/rgbhis.tcl:164 ../gui/tcltk/d.m/rgbhis.tcl:135
+msgid "display maps as HIS"
+msgstr ""
+#: ../gui/tcltk/gis.m/rgbhis.tcl:169 ../gui/tcltk/d.m/rgbhis.tcl:141
+msgid "Help for HIS"
+msgstr ""
+#: ../gui/tcltk/gis.m/rgbhis.tcl:175
+msgid "red (RGB) or hue (HIS): "
+msgstr ""
+#: ../gui/tcltk/gis.m/rgbhis.tcl:178
+msgid "raster map for red or hue channel (HIS drape)"
+msgstr ""
+#: ../gui/tcltk/gis.m/rgbhis.tcl:187
+msgid "green (RGB) or intensity (HIS): "
+msgstr ""
+#: ../gui/tcltk/gis.m/rgbhis.tcl:190
+msgid "raster map for green or intensity channel (HIS relief)"
+msgstr ""
+#: ../gui/tcltk/gis.m/rgbhis.tcl:199
+msgid "blue (RGB) or saturation (HIS): "
+msgstr ""
+#: ../gui/tcltk/gis.m/rgbhis.tcl:202
+msgid "raster map for blue or saturation channel"
+msgstr ""
+#: ../gui/tcltk/gis.m/rgbhis.tcl:211
+msgid "HIS brightness adjustment\t "
+msgstr ""
+#: ../gui/tcltk/gis.m/rgbhis.tcl:213
+msgid "Adjusts the HIS intensity channel brightness"
+msgstr ""
+#: ../gui/tcltk/gis.m/maplabels.tcl:127
+msgid "Label file"
+msgstr ""
+#: ../gui/tcltk/gis.m/maplabels.tcl:140 ../gui/tcltk/gis.m/thematic.tcl:145
+#: ../gui/tcltk/gis.m/thematic.tcl:152 ../gui/tcltk/gis.m/thematic.tcl:158
+#: ../gui/tcltk/gis.m/maptext.tcl:83
+msgid "This is font sample text."
+msgstr ""
+#: ../gui/tcltk/gis.m/maplabels.tcl:140 ../gui/tcltk/gis.m/maptext.tcl:83
+msgid "Select label font"
+msgstr ""
+#: ../gui/tcltk/gis.m/maplabels.tcl:163
+msgid "Create postscript labels for vector objects from v.labels file"
+msgstr ""
+#: ../gui/tcltk/gis.m/maplabels.tcl:170
+msgid "  (for postscript eps, pdf, and print output only)"
+msgstr ""
+#: ../gui/tcltk/gis.m/maplabels.tcl:177 ../gui/tcltk/gis.m/labels.tcl:128
+msgid "Labels file:"
+msgstr ""
+#: ../gui/tcltk/gis.m/maplabels.tcl:180 ../gui/tcltk/gis.m/labels.tcl:131
+msgid "labels file to display"
+msgstr ""
+#: ../gui/tcltk/gis.m/maplabels.tcl:189
+msgid "Override offset, alignment, and color settings in v.labels file: "
+msgstr ""
+#: ../gui/tcltk/gis.m/maplabels.tcl:196
+msgid "Align label with vector object: "
+msgstr ""
+#: ../gui/tcltk/gis.m/maplabels.tcl:200
+msgid "lower center"
+msgstr ""
+msgid "upper center"
+msgstr ""
+#: ../gui/tcltk/gis.m/maplabels.tcl:206
+msgid "Offset label from vector object: "
+msgstr ""
+#: ../gui/tcltk/gis.m/maplabels.tcl:207
+msgid "x offset"
+msgstr ""
+#: ../gui/tcltk/gis.m/maplabels.tcl:210
+msgid "y offset"
+msgstr ""
+#: ../gui/tcltk/gis.m/maplabels.tcl:218
+msgid "Justification: "
+msgstr ""
+#: ../gui/tcltk/gis.m/maplabels.tcl:221 ../gui/tcltk/gis.m/maptext.tcl:175
+#: ../gui/tcltk/gis.m/vector.tcl:483
+msgid "left"
+msgstr ""
+msgid "right"
+msgstr ""
+#: ../gui/tcltk/gis.m/maplabels.tcl:222
+msgid " Label line max length: "
+msgstr ""
+#: ../gui/tcltk/gis.m/maplabels.tcl:229
+msgid "Enclose label in box: "
+msgstr ""
+#: ../gui/tcltk/gis.m/maplabels.tcl:231
+msgid "Draw label background: "
+msgstr ""
+#: ../gui/tcltk/gis.m/maplabels.tcl:233
+msgid "Background color:"
+msgstr ""
+#: ../gui/tcltk/gis.m/maplabels.tcl:240
+msgid "Draw box outline: "
+msgstr ""
+#: ../gui/tcltk/gis.m/maplabels.tcl:242
+msgid "Border width:"
+msgstr ""
+#: ../gui/tcltk/gis.m/maplabels.tcl:245
+msgid "Border color:"
+msgstr ""
+#: ../gui/tcltk/gis.m/maplabels.tcl:252
+msgid "Distance between label and enclosing box. Horizontal: "
+msgstr ""
+#: ../gui/tcltk/gis.m/maplabels.tcl:255
+msgid " Vertical: "
+msgstr ""
+#: ../gui/tcltk/gis.m/maplabels.tcl:263
+msgid "Font"
+msgstr ""
+#: ../gui/tcltk/gis.m/maplabels.tcl:266
+msgid "select font for label"
+msgstr ""
+#: ../gui/tcltk/gis.m/maplabels.tcl:268
+msgid "family:"
+msgstr ""
+#: ../gui/tcltk/gis.m/maplabels.tcl:271
+msgid "size:"
+msgstr ""
+#: ../gui/tcltk/gis.m/maplabels.tcl:281 ../gui/tcltk/gis.m/labels.tcl:164
+msgid "Launch v.label to create labels file"
+msgstr ""
+#: ../gui/tcltk/gis.m/maplabels.tcl:282 ../gui/tcltk/gis.m/labels.tcl:165
+msgid "v.label"
+msgstr ""
+#: ../gui/tcltk/gis.m/maplabels.tcl:329
+msgid "Could not open labels file "
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:133 ../gui/tcltk/gis.m/vector.tcl:222
+#: ../gui/tcltk/d.m/menu.tcl:94 ../gui/tcltk/d.m/menu.tcl:134
+msgid "Vector map"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:136
+#, tcl-format
+msgid "thematic map for %s"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:145 ../gui/tcltk/gis.m/thematic.tcl:152
+#: ../gui/tcltk/gis.m/thematic.tcl:158
+msgid "Select font"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:222 ../gui/tcltk/gis.m/vector.tcl:319
+msgid "Vector point symbol"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:238
+msgid "Display vector maps thematically by graduate colors (all types)"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:244
+msgid "  or by graduated sizes (points and lines)"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:261 ../gui/tcltk/gis.m/vector.tcl:354
+#: ../gui/tcltk/d.m/thematic.tcl:116
+msgid "Vector map:"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:264
+msgid "vector for thematic mapping"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:279 ../gui/tcltk/d.m/thematic.tcl:131
+msgid "    vector type"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:282
+msgid "area"
+msgstr ""
+msgid "point"
+msgstr ""
+msgid "centroid"
+msgstr ""
+msgid "line"
+msgstr ""
+msgid "boundary"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:284
+msgid " attribute layer"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:291
+msgid "    NUMERIC attribute column to use for thematic map"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:298 ../gui/tcltk/d.m/thematic.tcl:150
+#: ../gui/tcltk/d.m/vector.tcl:348
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:304
+msgid "   show data"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:315 ../gui/tcltk/d.m/thematic.tcl:168
+msgid "Thematic map: type"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:318
+msgid "graduated colors"
+msgstr ""
+msgid "graduated points"
+msgstr ""
+msgid "graduated lines"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:320 ../gui/tcltk/d.m/thematic.tcl:171
+msgid " map by"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:323
+msgid "interval"
+msgstr ""
+msgid "std deviation"
+msgstr ""
+msgid "quartiles"
+msgstr ""
+msgid "custom breaks"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:330
+msgid "    number of intervals to map (interval themes):"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:338
+msgid "    custom breakpoints (val val ...)  "
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:345
+msgid "    query with SQL where clause   "
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:352
+msgid "Graduated points & lines: "
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:353 ../gui/tcltk/d.m/thematic.tcl:205
+#: ../gui/tcltk/d.m/vector.tcl:245
+msgid "icon"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:357 ../gui/tcltk/d.m/thematic.tcl:210
+msgid "point color"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:359 ../gui/tcltk/d.m/thematic.tcl:212
+msgid "line color"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:366
+msgid "    size/min size (graduated pts/lines)"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:368
+msgid "icon size/min size (graduated pts/lines)"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:369
+msgid "max size (graduated pts)"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:371
+msgid " max size (graduated pts/lines)"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:377
+msgid "Graduated colors: preset color schemes"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:380
+msgid "blue red"
+msgstr ""
+msgid "red blue"
+msgstr ""
+msgid "green red"
+msgstr ""
+msgid "red green"
+msgstr ""
+msgid "blue green"
+msgstr ""
+msgid "green blue"
+msgstr ""
+msgid "cyan yellow"
+msgstr ""
+msgid "yellow cyan"
+msgstr ""
+msgid "custom gradient"
+msgstr ""
+msgid "single color"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:387
+msgid "    custom color scheme - start color"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:389
+msgid " end color"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:391 ../gui/tcltk/d.m/thematic.tcl:243
+msgid "draw border"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:398 ../gui/tcltk/d.m/thematic.tcl:250
+msgid "save thematic colors to GRASSRGB column of vector file"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:405
+msgid "Legend: title font "
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:408
+msgid "title font for legend"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:412 ../gui/tcltk/gis.m/thematic.tcl:438
+msgid " font color"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:419
+msgid "    subtitle font    "
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:422
+msgid "subtitle font for legend"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:431
+msgid "    label font       "
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:434
+msgid "label font for legend"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:446 ../gui/tcltk/d.m/thematic.tcl:260
+msgid "use math notation in legend"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:453
+msgid "Name for ps.map instruction files"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:663
+#, tcl-format
+msgid "Legend for Map %d, %s"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:686
+msgid "clear"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:688
+msgid "Clear legend"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:689
+msgid "save"
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:691
+msgid "Save legend to EPS file"
+msgstr ""
+#: ../gui/tcltk/gis.m/georecttool.tcl:73
+msgid "Set ground control points"
+msgstr ""
+#: ../gui/tcltk/gis.m/georecttool.tcl:151
+msgid "Zoom to map"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:285
+msgid ""
+"There is no raster group file (REF). You must select the 'create/edit group' "
+"option to create a group file."
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:307
+msgid ""
+"There is no vector group file (VREF). You must select the 'create/edit "
+"group' option to create a group file."
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:388
+msgid "Select mapset of raster to georectify"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:436
+msgid "Create a group REF file and directory for vectors"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:449
+msgid "Create/replace vector group"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:475
+msgid "group name"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:477
+msgid "Select existing vector group or name new group"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:487
+msgid "vector"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:489
+msgid "Select xy vector(s) for group"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:499
+msgid "Vector group"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:616
+msgid "GRASS Georectifier"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:627
+msgid "Set up environment for georectifying rasters or vectors"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:636
+msgid "Georeference raster"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:640
+msgid "Georeference vector"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:647
+msgid "1. Select mapset"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:649
+msgid "Mapset of xy raster group"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:659
+msgid "2. Create/edit group"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:661
+msgid "Create/edit group (rasters or vectors to georectify)"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:669
+msgid "3. Select group"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:671
+msgid "Select existing group to georectify"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:681
+msgid "4. Select map"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:683
+msgid ""
+"Select non-georectified raster or vector to display for marking ground "
+"control points"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:693
+msgid "5. Start georectifying"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:695
+msgid "Start georectifying"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:705
+msgid "Cancel georectification"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:802
+msgid "Displaying xy map to be georectified"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:1010
+msgid "Select rectification method for rasters"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:1013
+msgid "1st order"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:1014
+msgid "affine transformation  (rasters & vectors). Requires 3+ GCPs."
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:1019
+msgid "2nd order"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:1020
+msgid "polynomial transformation  (rasters only). Requires 6+ GCPs."
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:1024
+msgid "3rd order"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:1025
+msgid "polynomial transformation  (rasters only). Requires 10+ GCPs."
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:1028
+msgid "Clip map/image to target region"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:1038
+msgid "Use"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:1040
+msgid "xy coordinates"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:1042
+msgid "geographic coordinates"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:1044
+msgid "forward error"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:1046
+msgid "backward error"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:1087
+msgid "Manage ground control points (GCPs)"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:1112
+msgid "Save GCPs to POINTS file"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:1119
+msgid "Clear all unchecked GCP entries"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:1126
+msgid "Calculate RMS error"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:1133
+msgid "Rectify maps in group"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:1136
+msgid "Quit"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:1140
+msgid "Exit georectifier"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:1323
+msgid ""
+"There is no POINTS file of ground control points for group. You must create "
+"ground control points before georectifying map."
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:1353
+msgid ""
+"Insufficient ground control points for georectification method. You need at "
+"least 3 points for 1st order, 6 points for 2nd order and 10 points for 3rd "
+"order."
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:1384
+msgid ""
+"No valid ground control points in GCP file. You must create valid ground "
+"control points before georectifying map."
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:1587
+msgid "Error setting region"
+msgstr ""
+#: ../gui/tcltk/gis.m/georect.tcl:1596
+msgid "Please wait..."
+msgstr ""
+#: ../gui/tcltk/gis.m/maptext.tcl:129
+msgid ""
+"Create postscript text object (for postscript eps, pdf, and print output "
+"only)"
+msgstr ""
+#: ../gui/tcltk/gis.m/maptext.tcl:136
+msgid "Text to display:"
+msgstr ""
+#: ../gui/tcltk/gis.m/maptext.tcl:172
+msgid "     justification"
+msgstr ""
+#: ../gui/tcltk/gis.m/maptext.tcl:176
+msgid "  line width"
+msgstr ""
+#: ../gui/tcltk/gis.m/maptext.tcl:183 ../gui/tcltk/d.m/fttext.tcl:144
+msgid "Font:"
+msgstr ""
+#: ../gui/tcltk/gis.m/labels.tcl:96
+msgid "Labels for vectors"
+msgstr ""
+#: ../gui/tcltk/gis.m/labels.tcl:111
+msgid "Display labels for vector objects (created with v.label)"
+msgstr ""
+#: ../gui/tcltk/gis.m/labels.tcl:146 ../gui/tcltk/d.m/labels.tcl:80
+msgid "Display constraints:"
+msgstr ""
+#: ../gui/tcltk/gis.m/labels.tcl:147
+msgid "min"
+msgstr ""
+#: ../gui/tcltk/gis.m/labels.tcl:149
+msgid "max"
+msgstr ""
+#: ../gui/tcltk/gis.m/labels.tcl:151 ../gui/tcltk/d.m/labels.tcl:85
+msgid "region size"
+msgstr ""
+#: ../gui/tcltk/gis.m/labels.tcl:157 ../gui/tcltk/d.m/labels.tcl:91
+msgid " ignore rotation setting and draw horizontally"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:231
+msgid "Vector output map"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:337
+msgid "Display vector maps"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:348
+msgid "Transparent"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:357
+msgid "vector map to display"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:362 ../gui/tcltk/gis.m/vector.tcl:366
+msgid "Vector Info"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:378
+msgid "Display: "
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:379
+msgid "Shapes "
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:381
+msgid "Categories "
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:383
+msgid "Topology "
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:385
+msgid "Line directions "
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:393
+msgid "Points "
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:395
+msgid "Lines "
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:397
+msgid "Boundaries "
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:399
+msgid "Areas "
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:401
+msgid "Centroids "
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:403
+msgid "Faces "
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:411
+msgid "Point symbols:"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:412
+msgid "Icon"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:416
+msgid "   Size"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:418
+msgid "Icon size"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:423
+msgid "Attribute column for size"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:425
+msgid "Attribute column for rotation"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:433 ../gui/tcltk/d.m/vector.tcl:259
+msgid "Draw lines:"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:436 ../gui/tcltk/gis.m/vector.tcl:452
+msgid "Color"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:439
+msgid "   Width"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:441
+msgid "Line width"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:443
+msgid "(pixels) "
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:449 ../gui/tcltk/d.m/vector.tcl:275
+msgid "Fill areas:"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:456
+msgid "Random colors "
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:458 ../gui/tcltk/d.m/vector.tcl:284
+msgid "GRASSRGB column colors"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:465 ../gui/tcltk/d.m/vector.tcl:291
+msgid "Label vectors:"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:466 ../gui/tcltk/d.m/vector.tcl:292
+msgid "label"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:468
+msgid " Text color"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:471
+msgid "   Text size"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:473 ../gui/tcltk/d.m/vector.tcl:299
+msgid "text size"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:480
+msgid "Label part to align with vector point "
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:485
+msgid "   Justification"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:488
+msgid "top"
+msgstr ""
+msgid "bottom"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:495
+msgid "     Layer for labels"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:497
+msgid "   Attribute column for labels"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:504
+msgid "Query vectors for display: "
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:505 ../gui/tcltk/d.m/vector.tcl:327
+msgid "layer for query"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:513
+msgid "Query cat values"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:524
+msgid "Use SQL query"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:532
+msgid "    Show attribute columns"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:538
+msgid "      Show attribute data"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:550
+msgid "Save displayed objects to new vector file "
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:552
+msgid "Overwrite existing"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:559
+msgid "     New vector"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:563
+msgid "Select existing vector for saving queried objects"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:571 ../gui/tcltk/d.m/vector.tcl:376
+msgid "Display when avg. region dimension is"
+msgstr ""
+#: ../gui/tcltk/gis.m/vector.tcl:574
+msgid " or <"
+msgstr ""
+#: ../gui/tcltk/gis.m/barscale.tcl:153
+msgid "Display scale and north arrow"
+msgstr ""
+#: ../gui/tcltk/gis.m/barscale.tcl:170
+#, tcl-format
+msgid "Scale placement: 0-100% from top left of display"
+msgstr ""
+#: ../gui/tcltk/gis.m/barscale.tcl:176
+msgid "\t enter x,y of scale/arrow upper left corner"
+msgstr ""
+#: ../gui/tcltk/gis.m/barscale.tcl:179
+msgid "    "
+msgstr ""
+#: ../gui/tcltk/gis.m/barscale.tcl:190
+msgid "\t "
+msgstr ""
+#: ../gui/tcltk/gis.m/barscale.tcl:199
+msgid "Scale appearance:  text color"
+msgstr ""
+#: ../gui/tcltk/gis.m/barscale.tcl:201
+msgid "  font "
+msgstr ""
+#: ../gui/tcltk/gis.m/barscale.tcl:211
+msgid "\tbackground color "
+msgstr ""
+#: ../gui/tcltk/gis.m/barscale.tcl:214 ../gui/tcltk/gis.m/histogram.tcl:191
+msgid "transparent background"
+msgstr ""
+#: ../gui/tcltk/gis.m/barscale.tcl:222
+msgid "display N. arrow only"
+msgstr ""
+#: ../gui/tcltk/gis.m/barscale.tcl:224 ../gui/tcltk/d.m/barscale.tcl:94
+msgid "display scale only"
+msgstr ""
+#: ../gui/tcltk/gis.m/barscale.tcl:232 ../gui/tcltk/d.m/barscale.tcl:103
+msgid "text on top of scale, instead of to right"
+msgstr ""
+#: ../gui/tcltk/gis.m/barscale.tcl:240
+msgid "line scale instead of bar"
+msgstr ""
+#: ../gui/tcltk/gis.m/barscale.tcl:242 ../gui/tcltk/d.m/barscale.tcl:110
+msgid "use feet/miles instead of meters"
+msgstr ""
+#: ../gui/tcltk/gis.m/profile.tcl:54
+msgid "Raster map for profile"
+msgstr ""
+#: ../gui/tcltk/gis.m/profile.tcl:77
+msgid "Profile Window"
+msgstr ""
+#: ../gui/tcltk/gis.m/profile.tcl:110
+msgid ""
+"Select raster map to profile.\n"
+"Currently selected raster is default."
+msgstr ""
+#: ../gui/tcltk/gis.m/profile.tcl:115
+msgid "Draw profile transect in map display"
+msgstr ""
+#: ../gui/tcltk/gis.m/profile.tcl:120
+msgid "Draw profile"
+msgstr ""
+#: ../gui/tcltk/gis.m/profile.tcl:125
+msgid "Clear profile"
+msgstr ""
+#: ../gui/tcltk/gis.m/profile.tcl:130
+msgid "Save profile to EPS file"
+msgstr ""
+#: ../gui/tcltk/gis.m/profile.tcl:177
+msgid "r.univar error"
+msgstr ""
+#: ../gui/tcltk/gis.m/profile.tcl:433
+msgid "You must select a raster to profile"
+msgstr ""
+#: ../gui/tcltk/gis.m/profile.tcl:434
+msgid "No raster map selected"
+msgstr ""
+#: ../gui/tcltk/gis.m/profile.tcl:440
+msgid "You must draw a transect to profile"
+msgstr ""
+#: ../gui/tcltk/gis.m/profile.tcl:441
+msgid "No transect drawn"
+msgstr ""
+#: ../gui/tcltk/gis.m/profile.tcl:446
+msgid "Please wait while profile elevations are calculated"
+msgstr ""
+#: ../gui/tcltk/gis.m/profile.tcl:451
+msgid ""
+"Elevation range for selected raster is zero.\n"
+"No profile can be created."
+msgstr ""
+#: ../gui/tcltk/gis.m/profile.tcl:452
+msgid "Zero elevation range"
+msgstr ""
+#: ../gui/tcltk/gis.m/profile.tcl:539
+msgid "Error reading region values"
+msgstr ""
+#: ../gui/tcltk/gis.m/profile.tcl:563 ../gui/tcltk/gis.m/profile.tcl:648
+msgid "r.profile error"
+msgstr ""
+#: ../gui/tcltk/gis.m/dnviz.tcl:49 ../gui/tcltk/gis.m/rules.tcl:35
+msgid "Select input map"
+msgstr ""
+#: ../gui/tcltk/gis.m/dnviz.tcl:106
+msgid "NVIZ flythrough path"
+msgstr ""
+#: ../gui/tcltk/gis.m/dnviz.tcl:122
+msgid "Create flythough path for NVIZ display"
+msgstr ""
+#: ../gui/tcltk/gis.m/dnviz.tcl:129
+msgid "Raster surface map "
+msgstr ""
+#: ../gui/tcltk/gis.m/dnviz.tcl:140
+msgid "Output script file "
+msgstr ""
+#: ../gui/tcltk/gis.m/dnviz.tcl:151
+msgid "Flythrough path "
+msgstr ""
+#: ../gui/tcltk/gis.m/dnviz.tcl:157
+msgid "Create path with mouse in map display"
+msgstr ""
+#: ../gui/tcltk/gis.m/dnviz.tcl:160
+msgid "Coordinate pairs for flythrough path (x1,y1,x2,y2,...)"
+msgstr ""
+#: ../gui/tcltk/gis.m/dnviz.tcl:169
+msgid "Flythrough images prefix "
+msgstr ""
+#: ../gui/tcltk/gis.m/dnviz.tcl:170
+msgid "Prefix for image series created by flythough"
+msgstr ""
+#: ../gui/tcltk/gis.m/dnviz.tcl:177
+msgid "Camera layback "
+msgstr ""
+#: ../gui/tcltk/gis.m/dnviz.tcl:178
+msgid "Camera layback distance (in map units)"
+msgstr ""
+#: ../gui/tcltk/gis.m/dnviz.tcl:180
+msgid "Camera height "
+msgstr ""
+#: ../gui/tcltk/gis.m/dnviz.tcl:181
+msgid "Camera height above terrain"
+msgstr ""
+#: ../gui/tcltk/gis.m/dnviz.tcl:188
+msgid "Number of frames "
+msgstr ""
+#: ../gui/tcltk/gis.m/dnviz.tcl:189
+msgid "Number of frames to create for flythrough"
+msgstr ""
+#: ../gui/tcltk/gis.m/dnviz.tcl:191
+msgid "Start frame "
+msgstr ""
+#: ../gui/tcltk/gis.m/dnviz.tcl:192
+msgid "Starting frame number..."
+msgstr ""
+#: ../gui/tcltk/gis.m/dnviz.tcl:199
+msgid "Enable vector rendering"
+msgstr ""
+#: ../gui/tcltk/gis.m/dnviz.tcl:201
+msgid "Full render (save images)"
+msgstr ""
+#: ../gui/tcltk/gis.m/dnviz.tcl:203
+msgid "Render images offscreen"
+msgstr ""
+#: ../gui/tcltk/gis.m/dnviz.tcl:215
+msgid "Height value is elevation"
+msgstr ""
+#: ../gui/tcltk/gis.m/dnviz.tcl:217
+msgid "Output keyframe file"
+msgstr ""
+#: ../gui/tcltk/gis.m/dnviz.tcl:219 ../gui/tcltk/gis.m/rules.tcl:147
+msgid "Overwrite existing file"
+msgstr ""
+#: ../gui/tcltk/gis.m/dnviz.tcl:224
+msgid "Reset"
+msgstr ""
+#: ../gui/tcltk/gis.m/dnviz.tcl:226
+msgid "Clear all path coordinates"
+msgstr ""
+#: ../gui/tcltk/gis.m/dnviz.tcl:232 ../gui/tcltk/gis.m/rules.tcl:174
+#: ../gui/tcltk/gis.m/animate.tcl:540
+msgid "Apply"
+msgstr ""
+#: ../gui/tcltk/gis.m/dnviz.tcl:359 ../gui/tcltk/gis.m/rules.tcl:194
+msgid "You must select an input map"
+msgstr ""
+#: ../gui/tcltk/gis.m/dnviz.tcl:360 ../gui/tcltk/gis.m/rules.tcl:194
+msgid "No input map selected"
+msgstr ""
+#: ../gui/tcltk/gis.m/dnviz.tcl:365
+msgid "You must specify an output file"
+msgstr ""
+#: ../gui/tcltk/gis.m/dnviz.tcl:366
+msgid "No output file specified"
+msgstr ""
+#: ../gui/tcltk/gis.m/dnviz.tcl:374
+msgid "You must specify at least 4 points (x,y coordinate pairs)"
+msgstr ""
+#: ../gui/tcltk/gis.m/dnviz.tcl:375
+msgid "Insufficient coordinates specified"
+msgstr ""
+#: ../gui/tcltk/gis.m/histogram.tcl:108
+msgid "Raster map for histogram"
+msgstr ""
+#: ../gui/tcltk/gis.m/histogram.tcl:111
+#, tcl-format
+msgid "histogram of %s"
+msgstr ""
+#: ../gui/tcltk/gis.m/histogram.tcl:139
+msgid "Draw histogram of values from raster map or image"
+msgstr ""
+#: ../gui/tcltk/gis.m/histogram.tcl:156
+msgid "Raster to histogram: "
+msgstr ""
+#: ../gui/tcltk/gis.m/histogram.tcl:172
+msgid "Graph style"
+msgstr ""
+#: ../gui/tcltk/gis.m/histogram.tcl:176
+msgid "\ttext font "
+msgstr ""
+#: ../gui/tcltk/gis.m/histogram.tcl:186
+msgid "Histogram color: text & frame"
+msgstr ""
+#: ../gui/tcltk/gis.m/histogram.tcl:188
+msgid "  background"
+msgstr ""
+#: ../gui/tcltk/gis.m/histogram.tcl:198
+msgid "Steps/bins for values (fp maps only)"
+msgstr ""
+#: ../gui/tcltk/gis.m/histogram.tcl:202
+msgid "include null values"
+msgstr ""
+#: ../gui/tcltk/gis.m/histogram.tcl:265
+msgid "r.info error"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmlib.tcl:85 ../gui/tcltk/gis.m/gmlib.tcl:114
+msgid "Map Resource File"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmlib.tcl:86 ../gui/tcltk/gis.m/gmlib.tcl:116
+msgid "All Files"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmlib.tcl:90
+msgid "Open File"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmlib.tcl:115
+msgid "DM Resource File"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmlib.tcl:119 ../lib/gis/gui.tcl:229
+msgid "Save File"
+msgstr ""
+#: ../gui/tcltk/gis.m/rules.tcl:97
+msgid "Interactive rules entry"
+msgstr ""
+#: ../gui/tcltk/gis.m/rules.tcl:199
+msgid "You must specify an output map"
+msgstr ""
+msgid "No output map specified"
+msgstr ""
+#: ../gui/tcltk/gis.m/rules.tcl:221
+msgid "Error creating rules file"
+msgstr ""
+#: ../gui/tcltk/gis.m/rastnums.tcl:108
+#, tcl-format
+msgid "cell values for %s"
+msgstr ""
+#: ../gui/tcltk/gis.m/rastnums.tcl:136
+msgid "Display cell values from raster map or image"
+msgstr ""
+#: ../gui/tcltk/gis.m/rastnums.tcl:142
+msgid "  (resolution must be 100x100 or less)"
+msgstr ""
+#: ../gui/tcltk/gis.m/rastnums.tcl:158
+msgid "Raster to display: "
+msgstr ""
+#: ../gui/tcltk/gis.m/rastnums.tcl:174
+msgid "Color for cell grid:       "
+msgstr ""
+#: ../gui/tcltk/gis.m/rastnums.tcl:181
+msgid "  cell values font "
+msgstr ""
+#: ../gui/tcltk/gis.m/rastnums.tcl:191
+msgid "Color for cell values:   "
+msgstr ""
+#: ../gui/tcltk/gis.m/rastnums.tcl:198
+msgid "use raster colors for cell values"
+msgstr ""
+#: ../gui/tcltk/gis.m/rastnums.tcl:280
+msgid ""
+"Cell values can only be displayed\n"
+"for regions of < 10,000 cells"
+msgstr ""
+#: ../gui/tcltk/gis.m/rastnums.tcl:285
+msgid "Constrain map to region geometry?"
+msgstr ""
+#: ../gui/tcltk/gis.m/rastnums.tcl:286
+msgid ""
+"Cell values can only be displayed for \n"
+"regions of < 10,000 cells. Map in explore mode may contain more than 10,000 "
+"cells.\n"
+"\n"
+" It's suggested to constrain map to region geometry to display cell values."
+msgstr ""
+#: ../gui/tcltk/gis.m/rastnums.tcl:288
+msgid "Leave in explore mode"
+msgstr ""
+#: ../gui/tcltk/gis.m/rastarrows.tcl:111
+msgid "Aspect map"
+msgstr ""
+#: ../gui/tcltk/gis.m/rastarrows.tcl:114 ../gui/tcltk/gis.m/rastarrows.tcl:126
+#, tcl-format
+msgid "arrows for %s"
+msgstr ""
+#: ../gui/tcltk/gis.m/rastarrows.tcl:123
+msgid "Slope/intensity map"
+msgstr ""
+#: ../gui/tcltk/gis.m/rastarrows.tcl:139
+msgid "Display arrows whose orientations are based on raster aspect map"
+msgstr ""
+#: ../gui/tcltk/gis.m/rastarrows.tcl:145
+msgid "  (optionally, arrow lengths are based on slope or intensity map)"
+msgstr ""
+#: ../gui/tcltk/gis.m/rastarrows.tcl:162
+msgid "Aspect map: "
+msgstr ""
+#: ../gui/tcltk/gis.m/rastarrows.tcl:178
+msgid "    aspect value type"
+msgstr ""
+#: ../gui/tcltk/gis.m/rastarrows.tcl:181
+msgid "grass"
+msgstr ""
+msgid "compass"
+msgstr ""
+msgid "agnps"
+msgstr ""
+msgid "answers"
+msgstr ""
+#: ../gui/tcltk/gis.m/rastarrows.tcl:188
+msgid "    draw arrows every Nth grid cell"
+msgstr ""
+#: ../gui/tcltk/gis.m/rastarrows.tcl:196
+msgid "    arrow color      "
+msgstr ""
+#: ../gui/tcltk/gis.m/rastarrows.tcl:203
+msgid "     cell grid color"
+msgstr ""
+#: ../gui/tcltk/gis.m/rastarrows.tcl:215
+msgid "    null value color"
+msgstr ""
+#: ../gui/tcltk/gis.m/rastarrows.tcl:234
+msgid "Slope/intensity map: "
+msgstr ""
+#: ../gui/tcltk/gis.m/rastarrows.tcl:245
+msgid "    scale factor for computing arrow length"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmtool2.tcl:26 ../gui/tcltk/d.m/tool2.tcl:100
+msgid "Scalebar and north arrow"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmtool2.tcl:32 ../gui/tcltk/d.m/tool2.tcl:105
+msgid "Overlay grids and lines"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmtool2.tcl:39 ../gui/tcltk/d.m/tool2.tcl:116
+msgid "Add command layer"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmtool2.tcl:59 ../gui/tcltk/d.m/tool2.tcl:130
+msgid "Add group"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmtool2.tcl:65 ../gui/tcltk/d.m/tool2.tcl:135
+msgid "Duplicate Layer"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmtool2.tcl:70 ../gui/tcltk/d.m/tool2.tcl:139
+msgid "Delete layer"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmtool2.tcl:84 ../gui/tcltk/d.m/tool1.tcl:121
+msgid "Create new workspace file (erase current workspace settings first)"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmtool2.tcl:90 ../gui/tcltk/d.m/tool1.tcl:124
+msgid "Open existing workspace file"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmtool2.tcl:96 ../gui/tcltk/d.m/tool1.tcl:127
+msgid "Save workspace file"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmtool2.tcl:111 ../gui/tcltk/d.m/tool1.tcl:66
+msgid "Animate raster map series"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmtool2.tcl:127 ../gui/tcltk/d.m/tool2.tcl:153
+msgid "Digitize map (select or create new map first)"
+msgstr ""
+#: ../gui/tcltk/gis.m/animate.tcl:299
+msgid "Select maps to animate"
+msgstr ""
+#: ../gui/tcltk/gis.m/animate.tcl:313
+msgid "Rewind animation"
+msgstr ""
+#: ../gui/tcltk/gis.m/animate.tcl:319
+msgid "Replay animation"
+msgstr ""
+#: ../gui/tcltk/gis.m/animate.tcl:325
+msgid "Step backwards through animation"
+msgstr ""
+#: ../gui/tcltk/gis.m/animate.tcl:331
+msgid "Stop animation"
+msgstr ""
+#: ../gui/tcltk/gis.m/animate.tcl:337
+msgid "Step forwards through animation"
+msgstr ""
+#: ../gui/tcltk/gis.m/animate.tcl:343
+msgid "Play animation"
+msgstr ""
+#: ../gui/tcltk/gis.m/animate.tcl:356
+msgid "Slower animation"
+msgstr ""
+#: ../gui/tcltk/gis.m/animate.tcl:362
+msgid "Faster animation"
+msgstr ""
+#: ../gui/tcltk/gis.m/animate.tcl:372
+msgid "Continuously loop through animation"
+msgstr ""
+#: ../gui/tcltk/gis.m/animate.tcl:380
+msgid "Run animation alternately forward and backward"
+msgstr ""
+#: ../gui/tcltk/gis.m/animate.tcl:391
+msgid "Show map names in animation window"
+msgstr ""
+#: ../gui/tcltk/gis.m/animate.tcl:404
+msgid "Quit animation"
+msgstr ""
+#: ../gui/tcltk/gis.m/animate.tcl:435
+msgid "Select maps"
+msgstr ""
+#: ../gui/tcltk/gis.m/animate.tcl:463
+msgid "Maps for Animation"
+msgstr ""
+#: ../gui/tcltk/gis.m/animate.tcl:479
+msgid "Select maps to animate in one or more frames (1 frame required)"
+msgstr ""
+#: ../gui/tcltk/gis.m/animate.tcl:492
+msgid "Maps for frame 1 (required): "
+msgstr ""
+#: ../gui/tcltk/gis.m/animate.tcl:503
+msgid "Maps for frame 2 (optional): "
+msgstr ""
+#: ../gui/tcltk/gis.m/animate.tcl:514
+msgid "Maps for frame 3 (optional): "
+msgstr ""
+#: ../gui/tcltk/gis.m/animate.tcl:525
+msgid "Maps for frame 4 (optional): "
+msgstr ""
+#: ../gui/tcltk/gis.m/animate.tcl:563
+msgid "You must select maps to animate for frame 1"
+msgstr ""
+#: ../gui/tcltk/gis.m/animate.tcl:564
+msgid "No maps selected"
+msgstr ""
+#: ../gui/tcltk/gis.m/animate.tcl:1031
+msgid "Animation Window"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmtool1.tcl:28
+msgid "Start new map display monitor"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmtool1.tcl:42 ../gui/tcltk/d.m/tool2.tcl:22
+msgid "Add raster layer"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmtool1.tcl:49 ../gui/tcltk/d.m/tool2.tcl:28
+msgid "Add RGB or HIS layer"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmtool1.tcl:56
+msgid "Add histogram layer"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmtool1.tcl:63
+msgid "Add cell values layer"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmtool1.tcl:70
+msgid "Add directional arrows layer"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmtool1.tcl:76
+msgid "Add raster legend layer"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmtool1.tcl:92 ../gui/tcltk/d.m/tool2.tcl:48
+msgid "Add vector layer"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmtool1.tcl:99 ../gui/tcltk/d.m/tool2.tcl:62
+msgid "Add thematic map layer"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmtool1.tcl:108 ../gui/tcltk/d.m/tool2.tcl:54
+msgid "Add thematic charts layer"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmtool1.tcl:121
+msgid "Add raster labels layer (using v.labels file)"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmtool1.tcl:128 ../gui/tcltk/d.m/tool2.tcl:88
+msgid "Add text layer"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmtool1.tcl:135
+msgid "Add postscript labels layer (using v.labels file)"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmtool1.tcl:142
+msgid "Add postscript text layer"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmtree.tcl:69
+#, tcl-format
+msgid "Map Layers for Display %s"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmtree.tcl:308
+msgid "You must open a display before adding map layers"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmtree.tcl:483 ../gui/tcltk/gis.m/gmtree.tcl:631
+#: ../gui/tcltk/gis.m/gmtree.tcl:1152 ../gui/tcltk/gis.m/gmtree.tcl:1158
+msgid "No layer selected"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmtree.tcl:867
+msgid "Loading layers..."
+msgstr ""
+#: ../gui/tcltk/gis.m/gmtree.tcl:1052
+msgid "Layers loaded"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmtree.tcl:1168
+msgid "Selected raster layer is empty"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmtree.tcl:1179
+msgid "Selected vector layer is empty"
+msgstr ""
+#: ../gui/tcltk/gis.m/gmtree.tcl:1185
+msgid "You can digitize raster or vector maps only"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapprint.tcl:112
+msgid "Ghostscript not available"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapprint.tcl:254
+msgid "Postscript and LPR printing of map display"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapprint.tcl:268
+msgid "Preset paper type"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapprint.tcl:272
+msgid "letter"
+msgstr ""
+msgid "A4"
+msgstr ""
+msgid "legal"
+msgstr ""
+msgid "11x17"
+msgstr ""
+msgid "A3"
+msgstr ""
+msgid "ledger"
+msgstr ""
+msgid "A0"
+msgstr ""
+msgid "A1"
+msgstr ""
+msgid "A2"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapprint.tcl:281
+msgid "Custom paper size"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapprint.tcl:282 ../gui/tcltk/d.m/print.tcl:181
+msgid "width:"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapprint.tcl:284
+msgid "  height:"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapprint.tcl:291
+msgid "Margins  left:"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapprint.tcl:293
+msgid " right:"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapprint.tcl:295
+msgid " top:"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapprint.tcl:297
+msgid " bottom:"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapprint.tcl:305
+msgid "Resolution (dpi) for printing and PDF "
+msgstr ""
+#: ../gui/tcltk/gis.m/mapprint.tcl:323
+msgid "Print on LPR printer"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapprint.tcl:331
+msgid "Print on postscript device* "
+msgstr ""
+#: ../gui/tcltk/gis.m/mapprint.tcl:342
+msgid "Save to PDF file*              "
+msgstr ""
+#: ../gui/tcltk/gis.m/mapprint.tcl:345 ../gui/tcltk/gis.m/mapprint.tcl:357
+#: ../gui/tcltk/d.m/print.tcl:212 ../gui/tcltk/d.m/print.tcl:223
+#: ../gui/tcltk/d.m/print.tcl:234 ../gui/tcltk/d.m/print.tcl:261
+msgid "Browse"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapprint.tcl:355
+msgid "Save to EPS file               "
+msgstr ""
+#: ../gui/tcltk/gis.m/mapprint.tcl:363
+msgid "*requires ghostscript to be installed and in path"
+msgstr ""
+#: ../gui/tcltk/gis.m/mapprint.tcl:371 ../gui/tcltk/d.m/print.tcl:279
+msgid "Print"
+msgstr ""
+#: ../gui/tcltk/d.m/raster.tcl:85
+msgid "Raster name:"
+msgstr ""
+#: ../gui/tcltk/d.m/raster.tcl:108
+msgid "show legend in selected display monitor"
+msgstr ""
+#: ../gui/tcltk/d.m/raster.tcl:111 ../gui/tcltk/d.m/raster.tcl:136
+msgid " thin legend by "
+msgstr ""
+#: ../gui/tcltk/d.m/raster.tcl:118
+msgid "Raster to drape over 1st map:"
+msgstr ""
+#: ../gui/tcltk/d.m/raster.tcl:132
+msgid "show legend for drape map in monitor"
+msgstr ""
+#: ../gui/tcltk/d.m/legend.tcl:81
+msgid "Raster map for legend:"
+msgstr ""
+#: ../gui/tcltk/d.m/legend.tcl:96
+msgid "Display legend in monitor: "
+msgstr ""
+#: ../gui/tcltk/d.m/legend.tcl:99
+msgid " erase monitor before drawing legend"
+msgstr ""
+#: ../gui/tcltk/d.m/legend.tcl:106 ../gui/tcltk/d.m/barscale.tcl:67
+msgid "Text color: "
+msgstr ""
+#: ../gui/tcltk/d.m/legend.tcl:164
+msgid "do not show cat labels"
+msgstr ""
+#: ../gui/tcltk/d.m/legend.tcl:166
+msgid "do not show cat numbers"
+msgstr ""
+#: ../gui/tcltk/d.m/legend.tcl:173
+msgid "skip cats with no labels"
+msgstr ""
+#: ../gui/tcltk/d.m/legend.tcl:175
+msgid "draw smooth gradient"
+msgstr ""
+#: ../gui/tcltk/d.m/legend.tcl:177
+msgid "flip legend"
+msgstr ""
+#: ../gui/tcltk/d.m/legend.tcl:185 ../gui/tcltk/d.m/barscale.tcl:118
+msgid "place with mouse (cannot save placement with group)"
+msgstr ""
+#: ../gui/tcltk/d.m/dtext.tcl:101
+msgid "Text options: color"
+msgstr ""
+#: ../gui/tcltk/d.m/chart.tcl:120
+msgid "  show attribute columns"
+msgstr ""
+#: ../gui/tcltk/d.m/chart.tcl:169
+msgid "    chart outline color:"
+msgstr ""
+#: ../gui/tcltk/d.m/gridline.tcl:78
+msgid "geodetic grid"
+msgstr ""
+#: ../gui/tcltk/d.m/gridline.tcl:80
+msgid " grid color "
+msgstr ""
+#: ../gui/tcltk/d.m/gridline.tcl:86
+msgid " grid color"
+msgstr ""
+#: ../gui/tcltk/d.m/gridline.tcl:92
+msgid "     "
+msgstr ""
+#: ../gui/tcltk/d.m/gridline.tcl:93
+msgid "draw grid border"
+msgstr ""
+#: ../gui/tcltk/d.m/gridline.tcl:94
+msgid "draw border text"
+msgstr ""
+#: ../gui/tcltk/d.m/gridline.tcl:95
+msgid " border & text color"
+msgstr ""
+#: ../gui/tcltk/d.m/frames.tcl:64
+msgid "remove all frames"
+msgstr ""
+#: ../gui/tcltk/d.m/rgbhis.tcl:96
+msgid "red (RGB) or hue (HIS):"
+msgstr ""
+#: ../gui/tcltk/d.m/rgbhis.tcl:107
+msgid "green (RGB) or intensity (HIS):"
+msgstr ""
+#: ../gui/tcltk/d.m/rgbhis.tcl:118
+msgid "blue (RGB) or saturation (HIS):"
+msgstr ""
+#: ../gui/tcltk/d.m/tool2.tcl:33
+msgid "Add legend"
+msgstr ""
+#: ../gui/tcltk/d.m/tool2.tcl:76
+msgid "Add paint labels layer (from directory paint/labels)"
+msgstr ""
+#: ../gui/tcltk/d.m/tool2.tcl:82
+msgid "Add freetype text layer"
+msgstr ""
+#: ../gui/tcltk/d.m/tool2.tcl:110
+msgid "Create or select display frame"
+msgstr ""
+#: ../gui/tcltk/d.m/fttext.tcl:102
+msgid "     (leave blank to place with mouse; position will not save)"
+msgstr ""
+#: ../gui/tcltk/d.m/fttext.tcl:108
+msgid "     coordinate type"
+msgstr ""
+#: ../gui/tcltk/d.m/fttext.tcl:111
+msgid "  align text with coordinate point"
+msgstr ""
+#: ../gui/tcltk/d.m/fttext.tcl:120
+#, tcl-format
+msgid ""
+"     (for coordinates, % is from bottom left of display, pixels from top "
+"left)"
+msgstr ""
+#: ../gui/tcltk/d.m/fttext.tcl:126
+msgid "     text rotation (degrees counterclockwise)"
+msgstr ""
+#: ../gui/tcltk/d.m/fttext.tcl:129
+msgid "rotation in radians"
+msgstr ""
+#: ../gui/tcltk/d.m/fttext.tcl:164
+msgid "height in pixels instead of %"
+msgstr ""
+#: ../gui/tcltk/d.m/monitorsel.tcl:33
+msgid "x0"
+msgstr ""
+#: ../gui/tcltk/d.m/monitorsel.tcl:35
+msgid "Start/select display monitor x0"
+msgstr ""
+#: ../gui/tcltk/d.m/monitorsel.tcl:38
+msgid "x1"
+msgstr ""
+#: ../gui/tcltk/d.m/monitorsel.tcl:40
+msgid "Start/select display monitor x1"
+msgstr ""
+#: ../gui/tcltk/d.m/monitorsel.tcl:43
+msgid "x2"
+msgstr ""
+#: ../gui/tcltk/d.m/monitorsel.tcl:45
+msgid "Start/select display monitor x2"
+msgstr ""
+#: ../gui/tcltk/d.m/monitorsel.tcl:48
+msgid "x3"
+msgstr ""
+#: ../gui/tcltk/d.m/monitorsel.tcl:50
+msgid "Start/select display monitor x3"
+msgstr ""
+#: ../gui/tcltk/d.m/monitorsel.tcl:53
+msgid "x4"
+msgstr ""
+#: ../gui/tcltk/d.m/monitorsel.tcl:55
+msgid "Start/select display monitor x4"
+msgstr ""
+#: ../gui/tcltk/d.m/monitorsel.tcl:58
+msgid "x5"
+msgstr ""
+#: ../gui/tcltk/d.m/monitorsel.tcl:60
+msgid "Start/select display monitor x5"
+msgstr ""
+#: ../gui/tcltk/d.m/monitorsel.tcl:63
+msgid "x6"
+msgstr ""
+#: ../gui/tcltk/d.m/monitorsel.tcl:65
+msgid "Start/select display monitor x6"
+msgstr ""
+#: ../gui/tcltk/d.m/thematic.tcl:156 ../gui/tcltk/d.m/vector.tcl:354
+msgid "     show data"
+msgstr ""
+#: ../gui/tcltk/d.m/thematic.tcl:230
+msgid "Graduate colors: preset color schemes"
+msgstr ""
+#: ../gui/tcltk/d.m/thematic.tcl:258
+msgid "create graphic legend"
+msgstr ""
+#: ../gui/tcltk/d.m/thematic.tcl:267
+msgid "    select monitor for legend"
+msgstr ""
+#: ../gui/tcltk/d.m/labels.tcl:65
+msgid "Labels name:"
+msgstr ""
+#: ../gui/tcltk/d.m/vector.tcl:197
+msgid "Vector name:"
+msgstr ""
+#: ../gui/tcltk/d.m/vector.tcl:212
+msgid "Display:"
+msgstr ""
+#: ../gui/tcltk/d.m/vector.tcl:213
+msgid "shapes"
+msgstr ""
+#: ../gui/tcltk/d.m/vector.tcl:215
+msgid "categories"
+msgstr ""
+#: ../gui/tcltk/d.m/vector.tcl:217
+msgid "topology"
+msgstr ""
+#: ../gui/tcltk/d.m/vector.tcl:219
+msgid "line directions"
+msgstr ""
+#: ../gui/tcltk/d.m/vector.tcl:226
+msgid "            "
+msgstr ""
+#: ../gui/tcltk/d.m/vector.tcl:237
+msgid "faces"
+msgstr ""
+#: ../gui/tcltk/d.m/vector.tcl:262 ../gui/tcltk/d.m/vector.tcl:278
+#: ../gui/tcltk/d.m/vector.tcl:294
+msgid "color"
+msgstr ""
+#: ../gui/tcltk/d.m/vector.tcl:281
+msgid "  "
+msgstr ""
+#: ../gui/tcltk/d.m/vector.tcl:282
+msgid "random colors"
+msgstr ""
+#: ../gui/tcltk/d.m/vector.tcl:297
+msgid " size"
+msgstr ""
+#: ../gui/tcltk/d.m/vector.tcl:301
+msgid " align with pt"
+msgstr ""
+#: ../gui/tcltk/d.m/vector.tcl:315
+msgid "     layer for labels"
+msgstr ""
+#: ../gui/tcltk/d.m/vector.tcl:318
+msgid " attribute col for labels"
+msgstr ""
+#: ../gui/tcltk/d.m/vector.tcl:326
+msgid "Query vectors: "
+msgstr ""
+#: ../gui/tcltk/d.m/vector.tcl:330
+msgid " query cat values"
+msgstr ""
+#: ../gui/tcltk/d.m/vector.tcl:333
+msgid "SQL query"
+msgstr ""
+#: ../gui/tcltk/d.m/vector.tcl:340
+msgid "     SQL where statement"
+msgstr ""
+#: ../gui/tcltk/d.m/vector.tcl:366
+msgid "Mouse query setup:"
+msgstr ""
+#: ../gui/tcltk/d.m/vector.tcl:367
+msgid "edit attributes (form mode)"
+msgstr ""
+#: ../gui/tcltk/d.m/vector.tcl:369
+msgid "results as text in terminal"
+msgstr ""
+#: ../gui/tcltk/d.m/vector.tcl:386
+msgid "Line width for ps.map print output:"
+msgstr ""
+#: ../gui/tcltk/d.m/vector.tcl:388
+msgid "Line width used for printing"
+msgstr ""
+#: ../gui/tcltk/d.m/barscale.tcl:69
+msgid " Background color: "
+msgstr ""
+#: ../gui/tcltk/d.m/barscale.tcl:71
+msgid "no background color"
+msgstr ""
+#: ../gui/tcltk/d.m/barscale.tcl:73
+msgid " "
+msgstr ""
+#: ../gui/tcltk/d.m/barscale.tcl:92
+msgid "display N. arrow only "
+msgstr ""
+#: ../gui/tcltk/d.m/barscale.tcl:101
+msgid "line scale instead of bar scale "
+msgstr ""
+#: ../gui/tcltk/d.m/tool1.tcl:22
+msgid "Display active layers in current region"
+msgstr ""
+#: ../gui/tcltk/d.m/tool1.tcl:28
+msgid "Display active layers in default region"
+msgstr ""
+#: ../gui/tcltk/d.m/tool1.tcl:34
+msgid "Display active layers in saved region setting"
+msgstr ""
+#: ../gui/tcltk/d.m/tool1.tcl:54
+msgid "NVIZ - n dimensional visualization"
+msgstr ""
+#: ../gui/tcltk/d.m/tool1.tcl:60
+msgid "Fly through path for NVIZ"
+msgstr ""
+#: ../gui/tcltk/d.m/tool1.tcl:81
+msgid "Zoom"
+msgstr ""
+#: ../gui/tcltk/d.m/tool1.tcl:93
+msgid "Pan and recenter"
+msgstr ""
+#: ../gui/tcltk/d.m/tool1.tcl:99
+msgid "Query map (select map first)"
+msgstr ""
+#: ../gui/tcltk/d.m/tool1.tcl:104
+msgid "Measure lengths and areas"
+msgstr ""
+#: ../gui/tcltk/d.m/tool1.tcl:109
+msgid "Geographical position"
+msgstr ""
+#: ../gui/tcltk/d.m/tool1.tcl:130
+msgid "Print raster & vector maps using ps.map"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:76
+msgid "Import"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:80
+msgid "Aggregate ASCII xyz data into raster grid"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:81
+msgid "ASCII GRID (includes GRASS ASCII)"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:82
+msgid "Polygons and lines from ASCII file"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:84
+msgid "Binary file (includes GTOPO30 format)"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:85
+msgid "ESRI Arc/Info ASCII grid"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:86 ../gui/tcltk/d.m/menu.tcl:120
+msgid "GRIDATB.FOR map file (TOPMODEL)"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:87 ../gui/tcltk/d.m/menu.tcl:121
+msgid "MAT-File (v.4) array (Matlab or Octave)"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:88
+msgid "SPOT vegetation NDVI data sets"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:89
+msgid "SRTM hgt files"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:90
+msgid "Terra ASTER HDF files"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:95
+msgid "Various formats using OGR"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:97
+msgid "ASCII points file or GRASS ASCII vector file"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:98
+msgid "Import old GRASS vector format"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:100
+msgid "DXF file"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:101
+msgid "ESRI e00 format"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:102
+msgid "Garmin GPS Waypoints/Routes/Tracks"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:103
+msgid "GPS Waypoints/Routes/Tracks  from many formats using GPSBabel"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:104
+msgid "GEOnet Name server country files (US-NGA GNS)"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:105
+msgid "Matlab and MapGen files"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:107 ../gui/tcltk/d.m/menu.tcl:144
+msgid "Grid 3D"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:108 ../gui/tcltk/d.m/menu.tcl:145
+msgid "ASCII 3D file"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:109 ../gui/tcltk/d.m/menu.tcl:146
+msgid "Vis5D file"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:112
+msgid "Export"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:116
+msgid "ASCII grid (for GRASS, Surfer, Modflow, etc)"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:117
+msgid "ASCII x,y,z values of cell centers"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:119
+msgid "ESRI ARC/INFO ASCII grid"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:123
+msgid "Binary file"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:125
+msgid "MPEG-1 animations"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:126
+msgid "PNG image (not georeferenced)"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:127
+msgid "PPM image (24bit)"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:128
+msgid "PPM image from red, green, blue raster maps"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:129
+msgid "POVray height-field"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:130
+msgid "TIFF image (8/24bit)"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:131
+msgid "VRML file"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:132 ../gui/tcltk/d.m/menu.tcl:142
+#: ../gui/tcltk/d.m/menu.tcl:147
+msgid "VTK ASCII file"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:135
+msgid "Various formats using OGR (SHAPE, MapInfo etc)"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:137
+msgid "DXF file (ASCII)"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:138
+msgid "ASCII vector or point file/old GRASS ASCII vector file"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:140
+msgid "POV-Ray format"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:152
+msgid "Copy maps"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:153
+msgid "List maps"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:154
+msgid "List maps using expressions and 'wildcards'"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:155
+msgid "Rename maps"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:156
+msgid "Remove maps"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:157
+msgid "Remove maps using expressions and 'wildcards'"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:160
+msgid "Raster to vector map"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:161
+msgid "Raster map series to volume"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:162
+msgid "Raster 2.5D map to volume"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:164
+msgid "Vector to vector"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:165
+msgid "Vector lines to points"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:166
+msgid "Vector 3D points to volume voxels"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:167
+msgid "Sites (GRASS 5.x) to vector"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:168
+msgid "Volumes to raster map series"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:171
+msgid "Groups"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:172
+msgid "New"
+msgstr ""
+msgid "Create new group file"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:173
+msgid "Open group file"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:174
+msgid "Save group file"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:175
+msgid "Save group file as name"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:176
+msgid "Close group"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:179
+msgid "Save display to image file"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:180
+msgid "XWD (Save display, selected with mouse, to map.xwd in home directory )"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:181
+msgid "Save displays to multiple graphic file formats"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:183
+msgid "Save map to Postscript file"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:184
+msgid "Print to default printer"
+msgstr ""
+msgid "print"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:186
+msgid "E&xit"
+msgstr ""
+msgid "Exit Display Manager"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:192
+msgid "Zoom to maximum extent of all displayed maps"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:195
+msgid "Access other mapsets in current location"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:196
+msgid "Change current working session to new mapset, location, or GISDBASE"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:197
+msgid "Modify access by other users to current mapset"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:198
+msgid "Show current GRASS environment settings"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:199
+msgid "Set GRASS environment settings"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:204
+msgid "Create/edit projection information for current location"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:205
+msgid "Show projection information and create projection files"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:207
+msgid "Convert coordinates from one projection to another"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:209
+msgid "Text"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:210
+msgid "Select default text font"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:211
+msgid "Select default freetype text font"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:213
+msgid "X-monitor displays"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:214
+msgid "Configure xmonitor displays"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:215
+msgid "Configure frames for xmonitors"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:216
+msgid "Start/restart xmonitor at specified window size"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:217
+msgid "Set active xmonitor to specified size"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:218
+msgid "Display information about active xmonitor"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:225
+msgid "Compress/decompress raster file"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:226
+msgid "Manage boundary definitions"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:227
+msgid "Manage null values"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:228
+msgid "Manage timestamps for files"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:229
+msgid "Quantization for floating-point maps"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:231
+msgid "Resample (change resolution)"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:232
+msgid "Resample using nearest neighbor method"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:233
+msgid "Resample using various interpolation methods"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:235
+msgid "Resample using regularized spline with tension method"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:238
+msgid "Support file creation and maintenance"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:240
+msgid "Reproject raster from other location"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:241
+msgid "Generate tiling for other projection"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:244
+msgid "Set colors to predefined color tables"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:245
+msgid "Set colors based on standard deviations"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:246
+msgid "Set colors using color rules"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:248
+msgid "Blend 2 color maps to produce 3 RGB files"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:249
+msgid "Create color image from RGB files"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:250
+msgid ""
+"Create 3 RGB (red, green, blue) maps from 3 HIS (hue, intensity, saturation) "
+"maps"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:255
+msgid "Create raster buffers"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:256
+msgid "Create raster MASK"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:257
+msgid "Locate closest points between areas in 2 raster maps"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:260
+msgid "Moving window analysis of raster cells"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:261
+msgid "Analyze vector points in neighborhood of raster cells"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:265
+msgid "Function of map series (time series)"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:268
+msgid "Statistical calculations for cover map over base map"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:271
+msgid "Solar irradiance and daily irradiation"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:272
+msgid "Shadows map for sun position or date/time"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:275
+msgid "Calculate cumulative movement costs between locales"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:278
+msgid "Profile analysis"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:279
+msgid "Shaded relief map"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:283
+msgid "Visibility/line of sight"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:287
+msgid "Clump small areas (statistics calculated by r.volume)"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:288
+msgid "Grow areas"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:289
+msgid "Thin linear features"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:293
+msgid "Carve stream channels into elevation map using vector streams map"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:294
+msgid "Depressionless elevation map and flowline map"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:295
+msgid "Fill lake from seed point to specified level"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:296
+msgid "Flow accumulation for massive grids"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:297
+msgid "Generate flow lines for raster map"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:299
+msgid "SIMWE sediment erosion, transport, & deposition modeling"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:309
+msgid "Analyze landscape characteristics"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:310
+msgid "Analyze landscape patch characteristics"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:311
+msgid "Output landscape patch information"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:314
+msgid "Generate rate of spread (ROS) maps"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:315
+msgid "Generate least-cost spread paths"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:316
+msgid "Simulate anisotropic spread phenomena"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:320
+msgid "Edit category values of individual cells for displayed raster map"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:323
+msgid "Reclassify categories for areas of specified sizes"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:324
+msgid "Reclassify categories using rules"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:325
+msgid "Reclassify categories using rules file"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:327
+msgid "Recode categories using rules (create new map)"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:328
+msgid "Recode categories using rules file (create new map)"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:330
+msgid "Rescale categories (create new map)"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:331
+msgid "Rescale categories with equalized histogram (create new map)"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:334
+msgid "Generate concentric circles around points"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:335
+msgid "Generate random raster cells"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:337
+msgid "Generate random cells and vector points from raster map"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:340
+msgid "Generate density surface using moving Gausian kernal"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:341
+msgid "Generate fractal surface"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:342
+msgid "Generate gaussian deviates surface"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:343
+msgid "Generate plane"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:344
+msgid "Generate random deviates surface"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:345
+msgid "Generate random surface with spatial dependence"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:347
+msgid "Generate vector contour lines"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:349
+msgid "Bilinear interpolation from raster points"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:350
+msgid "Inverse distance weighted interpolation from raster points"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:351
+msgid "Interpolation from raster contours"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:353
+msgid "Inverse distance weighted interpolation from vector points"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:354
+msgid "Regularized spline tension interpolation from vector points or contours"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:356
+msgid "Fill NULL cells by interpolation using regularized spline tension"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:361
+msgid "Manage category labels and values"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:364
+msgid "Range of all category values"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:365
+msgid "Sum all cell category values"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:367
+msgid "Summary statistics for clumped cells (works with r.clump)"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:370
+msgid "Univariate statistics (script version)"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:372
+msgid "Sample values along transects"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:373
+msgid "Sample values along transects (use azimuth, distance)"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:376
+msgid "Linear regression between 2 maps"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:377
+msgid "Mutual category occurences (coincidence)"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:385
+msgid "Clean vector files"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:386
+msgid "Add missing centroids"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:388
+msgid "Build polylines from adjacent segments"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:389
+msgid "Split polylines into segments"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:390
+msgid "Create lines parallel to existing lines"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:391
+msgid "Dissolve common boundaries"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:393
+msgid "Convert vector feature types"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:394
+msgid "Convert 2D vector to 3D by sampling raster"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:395
+msgid "Extrude 2D vector into 3D vector"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:397
+msgid "Create text label file for vector features"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:398
+msgid "Assign colors from a numeric attribute column"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:400
+msgid "Reproject vector from other location"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:403
+msgid "Create new vector as link to external OGR layer"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:404
+msgid "Set database connection for vector attributes"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:406
+msgid "Rectify and georeference vector map"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:408
+msgid "Query by attributes"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:410
+msgid "Query by map features"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:412
+msgid "Create vector buffers"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:413
+msgid "Linear referencing for vectors"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:414
+msgid "Create linear reference system"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:415
+msgid "Create stationing from imput lines, and linear reference system"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:416
+msgid ""
+"Create points/segments from input lines, linear reference system and "
+"positions read from stdin"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:417
+msgid ""
+"Find line id and real km+offset for given points in vector map using linear "
+"reference system"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:420
+msgid "Locate nearest features to points or centroids"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:421
+msgid "Generate Thiessen polygons around points (Voronoi diagram)"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:422
+msgid "Connect points to create Delaunay triangles"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:428
+msgid "Shortest route (visualization only)"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:429
+msgid "Split net to bands between cost isolines"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:434
+msgid "Overlay/combine 2 vector maps"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:435
+msgid "Patch multiple maps (combine)"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:437
+msgid "Generate area feature for extent of current region"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:438
+msgid "Generate rectangular vector grid"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:441
+msgid "Attach, delete, or report categories"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:442
+msgid "Reclassify features using rules file"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:445
+msgid "Work with vector points"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:447
+msgid "Generate points from database with x/y coordinates"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:449
+msgid "Random location perturbations of points"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:452
+msgid "Generate convex hull for point set"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:453
+msgid "Generate Delaunay triangles for point set"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:454
+msgid "Generate Voronoi diagram/Thiessen polygons for point set"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:456
+msgid "Sample raster maps"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:457
+msgid "Calculate statistics for raster map overlain by vector map"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:461
+msgid "Partition points into test/training sets for k-fold cross validatation"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:462
+msgid "Transfer attribute data from queried vector map to points"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:467
+msgid "Load vector attributes to database or create reports"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:468
+msgid "Report areas for vector attribute categories"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:471
+msgid "Test normality of point distribution"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:472
+msgid "Calculate stats for raster map underlying vector objects"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:473
+msgid "Indices of point counts in quadrats"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:478
+msgid "Create/edit imagery group"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:479
+msgid "Target imagery group"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:481
+msgid "Mosaic up to 4 adjacent images"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:484
+msgid ""
+"Color balance and enhance color tables of multiband imagery for rgb display"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:485
+msgid ""
+"Transform HIS (Hue/Intensity/Saturation) color image to RGB (Red/Green/Blue)"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:486
+msgid ""
+"Transform RGB (Red/Green/Blue) color image to HIS (Hue/Intensity/Saturation)"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:488
+msgid "Rectify and georeference image group"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:489
+msgid "Set ground control points (GCP's) from raster map or keyboard entry"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:491
+msgid "Set ground control points (GCP's) from vector map or keyboard entry"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:493
+msgid "Affine and Polynomial rectification (rubber sheet)"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:497
+msgid "Brovey transformation and pan sharpening"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:505
+msgid "Non-interactive input for supervised classification (MLC)"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:506
+msgid "Non-interactive input for supervised classification (SMAP)"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:509
+msgid "Zero edge crossing detection"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:510
+msgid "User defined matrix/convolving filter"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:515
+msgid "Canonical component"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:516
+msgid "Principal component"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:517
+msgid "Fast Fourier Transform"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:518
+msgid "Inverse Fast Fourier Transform"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:523
+msgid "Range of image values"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:525
+msgid "Bit pattern comparison for ID of low quality pixels"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:526
+msgid "Kappa classification accuracy assessment"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:527
+msgid "Optimum index factor for LandSat TM"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:530
+msgid "&Grid3D"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:535
+msgid "Create 3D mask for grid3D operations"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:536
+msgid "Create 2D raster cross section from grid3d volume"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:537
+msgid "Map calculator for grid3D operations"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:538
+msgid "Interpolate volume from vector points using splines"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:540
+msgid "Display information about grid3D volume"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:549
+msgid "Add columns to table"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:550
+msgid "Change values in a column"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:561
+msgid "Query data (SQL select)"
+msgstr ""
+#: ../gui/tcltk/d.m/menu.tcl:562
+msgid "Execute SQL statement"
+msgstr ""
+#: ../gui/tcltk/d.m/d.m.tcl:406
+msgid "Welcome to the GRASS GIS manager"
+msgstr ""
+#: ../gui/tcltk/d.m/print.tcl:169
+msgid "Paper format"
+msgstr ""
+#: ../gui/tcltk/d.m/print.tcl:180
+msgid "Custom"
+msgstr ""
+#: ../gui/tcltk/d.m/print.tcl:184
+msgid "height:"
+msgstr ""
+#: ../gui/tcltk/d.m/print.tcl:191
+msgid "left:"
+msgstr ""
+#: ../gui/tcltk/d.m/print.tcl:193
+msgid "right:"
+msgstr ""
+#: ../gui/tcltk/d.m/print.tcl:195
+msgid "top:"
+msgstr ""
+#: ../gui/tcltk/d.m/print.tcl:197
+msgid "bottom:"
+msgstr ""
+#: ../gui/tcltk/d.m/print.tcl:210
+msgid "PS file:"
+msgstr ""
+#: ../gui/tcltk/d.m/print.tcl:221
+msgid "PDF file:"
+msgstr ""
+#: ../gui/tcltk/d.m/print.tcl:232
+msgid "PNG file:"
+msgstr ""
+#: ../gui/tcltk/d.m/print.tcl:241
+msgid "PNG file resolution (points/inch):"
+msgstr ""
+#: ../gui/tcltk/d.m/print.tcl:250
+msgid "Printer:"
+msgstr ""
+#: ../gui/tcltk/d.m/print.tcl:259
+msgid "Script file:"
+msgstr ""
+#: ../gui/tcltk/d.m/print.tcl:280
+msgid "Preview"
+msgstr ""
+#: ../lib/gtcltk/select.tcl:107
+msgid "Select item"
+msgstr ""
+#: ../lib/gtcltk/select.tcl:209
+msgid "Ok"
+msgstr ""
+#: ../lib/gis/gui.tcl:231
+msgid "Load File"
+msgstr ""
+#: ../lib/gis/gui.tcl:295 ../lib/gis/gui.tcl:485
+msgid "Output"
+msgstr ""
+#: ../lib/gis/gui.tcl:355
+msgid "Options"
+msgstr ""
+#: ../lib/gis/gui.tcl:361
+msgid "Required"
+msgstr ""
+#: ../lib/gis/gui.tcl:510
+msgid "Clear"
+msgstr ""
+#: ../lib/gis/gui.tcl:582
+msgid "required"
+msgstr ""
+msgid "optional"
+msgstr ""
+#: ../lib/gis/gui.tcl:583
+msgid "multiple"
+msgstr ""
+#: ../lib/init/epsg_option.tcl:91
+msgid "WARNING: cant get environmental variable"
+msgstr ""
+#: ../lib/init/epsg_option.tcl:92
+msgid ""
+"Warning: Unable to get environmental variable GRASS_PROJSHARE. \n"
+"This is a GRASS installation error. \n"
+"Set environmental variable GRASS_PROJSHARE to point to directory with Proj4 "
+"EPSG file. "
+msgstr ""
+#: ../lib/init/epsg_option.tcl:101
+msgid "Define location using EPSG projection codes"
+msgstr ""
+#: ../lib/init/epsg_option.tcl:120 ../lib/init/file_option.tcl:92
+msgid "Name of new location"
+msgstr ""
+#: ../lib/init/epsg_option.tcl:123
+msgid "Enter name for location to be created"
+msgstr ""
+#: ../lib/init/epsg_option.tcl:127 ../lib/init/epsg_option.tcl:130
+msgid "Path to the EPSG-codes file"
+msgstr ""
+#: ../lib/init/epsg_option.tcl:133 ../lib/init/epsg_option.tcl:146
+#: ../lib/init/file_option.tcl:105 ../lib/init/gis_set.tcl:267
+msgid "Browse..."
+msgstr ""
+#: ../lib/init/epsg_option.tcl:134
+msgid "Browse to locate EPSG file"
+msgstr ""
+#: ../lib/init/epsg_option.tcl:141
+msgid "EPSG code number of projection"
+msgstr ""
+#: ../lib/init/epsg_option.tcl:144
+msgid "Enter EPSG code for selected projection"
+msgstr ""
+#: ../lib/init/epsg_option.tcl:147
+msgid "View EPSG codes and projection information."
+msgstr ""
+#: ../lib/init/epsg_option.tcl:153
+msgid "WARNING: epsg-codes file not found"
+msgstr ""
+#: ../lib/init/epsg_option.tcl:154
+msgid "WARNING: The epsg-codes file was not found!"
+msgstr ""
+#: ../lib/init/epsg_option.tcl:162 ../lib/init/file_option.tcl:111
+msgid "Define location"
+msgstr ""
+#: ../lib/init/epsg_option.tcl:185
+msgid "Invalid EPSG Code!"
+msgstr ""
+#: ../lib/init/epsg_option.tcl:186
+#, tcl-format
+msgid "ERROR: Invalid EPSG code %s: should be an integer."
+msgstr ""
+#: ../lib/init/epsg_option.tcl:196
+msgid "Location Exists!"
+msgstr ""
+#: ../lib/init/epsg_option.tcl:197
+#, tcl-format
+msgid "WARNING: Location '%s' already exists: please try another name."
+msgstr ""
+#: ../lib/init/epsg_option.tcl:234 ../lib/init/epsg_option.tcl:261
+#: ../lib/init/file_option.tcl:185 ../lib/init/file_option.tcl:212
+msgid "Error creating location!"
+msgstr ""
+#: ../lib/init/epsg_option.tcl:235 ../lib/init/epsg_option.tcl:262
+#: ../lib/init/file_option.tcl:186 ../lib/init/file_option.tcl:213
+#, tcl-format
+msgid ""
+"g.proj returned the following message:\n"
+"%s"
+msgstr ""
+#: ../lib/init/epsg_option.tcl:242 ../lib/init/epsg_option.tcl:266
+#: ../lib/init/file_option.tcl:193 ../lib/init/file_option.tcl:217
+msgid "Informational output from g.proj"
+msgstr ""
+#: ../lib/init/epsg_option.tcl:243 ../lib/init/epsg_option.tcl:267
+#: ../lib/init/file_option.tcl:194 ../lib/init/file_option.tcl:218
+#, tcl-format
+msgid ""
+"g.proj returned the following informational message:\n"
+"%s"
+msgstr ""
+#: ../lib/init/epsg_option.tcl:286 ../lib/init/file_option.tcl:240
+msgid "Select datum transformation parameters:"
+msgstr ""
+#: ../lib/init/epsg_option.tcl:290 ../lib/init/file_option.tcl:244
+msgid ""
+"Continue without specifying parameters - if used when creating a location, "
+"other GRASS modules will use the \"default\" (likely non-optimum) parameters "
+"for this datum if necessary in the future."
+msgstr ""
+#: ../lib/init/epsg_option.tcl:342
+msgid "You can select EPSG code (in <braces>) and copy it for later use."
+msgstr ""
+#: ../lib/init/epsg_option.tcl:379
+msgid "GUESS THAT IS NOT THE EPSG FILE"
+msgstr ""
+#: ../lib/init/epsg_option.tcl:385 ../lib/init/epsg_option.tcl:414
+#: ../lib/init/epsg_option.tcl:433
+msgid "Search"
+msgstr ""
+#: ../lib/init/epsg_option.tcl:387
+msgid "Grab code"
+msgstr ""
+#: ../lib/init/epsg_option.tcl:420
+msgid "Search text: "
+msgstr ""
+#: ../lib/init/epsg_option.tcl:421
+msgid "Search for entered text in EPSG file"
+msgstr ""
+#: ../lib/init/epsg_option.tcl:426
+msgid "forward search"
+msgstr ""
+#: ../lib/init/epsg_option.tcl:427
+msgid "backward search"
+msgstr ""
+#: ../lib/init/file_option.tcl:72
+msgid "Define location using projection information in georeferenced file"
+msgstr ""
+#: ../lib/init/file_option.tcl:95
+msgid "Enter name of location to be created"
+msgstr ""
+#: ../lib/init/file_option.tcl:99
+msgid "Path to georeferenced file"
+msgstr ""
+#: ../lib/init/file_option.tcl:102
+msgid "Path to georeferenced file (format must be readable by GDAL/OGR)"
+msgstr ""
+#: ../lib/init/file_option.tcl:106
+msgid "Browse to locate georeferenced file"
+msgstr ""
+#: ../lib/init/file_option.tcl:131 ../lib/init/file_option.tcl:134
+msgid "Choose georeferenced file"
+msgstr ""
+#: ../lib/init/file_option.tcl:152
+msgid ""
+"WARNING: Please supply a\n"
+"valid georeferenced file"
+msgstr ""
+#: ../lib/init/gis_set.tcl:111
+msgid "WARNING: can not save"
+msgstr ""
+#: ../lib/init/gis_set.tcl:112
+#, tcl-format
+msgid ""
+"Warning: unable to save data to <%s> file.\n"
+"Error message: %s"
+msgstr ""
+#: ../lib/init/gis_set.tcl:131 ../lib/init/gis_set.tcl:403
+#: ../lib/init/gis_set.tcl:509 ../lib/init/gis_set.tcl:641
+#: ../lib/init/gis_set.tcl:662 ../lib/init/gis_set.tcl:680
+#: ../lib/init/gis_set.tcl:708
+msgid "WARNING: invalid location"
+msgstr ""
+#: ../lib/init/gis_set.tcl:132
+#, tcl-format
+msgid ""
+"Warning: location <%s> at GISDBASE <%s> is not a directory or does not exist."
+msgstr ""
+#: ../lib/init/gis_set.tcl:183
+#, tcl-format
+msgid "GRASS %s Startup"
+msgstr ""
+#: ../lib/init/gis_set.tcl:225
+msgid "Welcome to GRASS GIS Version"
+msgstr ""
+#: ../lib/init/gis_set.tcl:227
+msgid ""
+"The world's leading open source GIS\n"
+"\n"
+msgstr ""
+#: ../lib/init/gis_set.tcl:229
+msgid "Select an existing project location and mapset\n"
+msgstr ""
+#: ../lib/init/gis_set.tcl:230
+msgid "or define a new location\n"
+msgstr ""
+#: ../lib/init/gis_set.tcl:253
+msgid "GIS Data Directory: "
+msgstr ""
+#: ../lib/init/gis_set.tcl:269
+msgid "New GIS data directory"
+msgstr ""
+#: ../lib/init/gis_set.tcl:292
+msgid "Project Location (projection/coordinate system)"
+msgstr ""
+#: ../lib/init/gis_set.tcl:325
+msgid "Accessible Mapsets (directories of GIS files)"
+msgstr ""
+#: ../lib/init/gis_set.tcl:382
+msgid "Create new mapset in selected location"
+msgstr ""
+#: ../lib/init/gis_set.tcl:390
+msgid "Create new mapset"
+msgstr ""
+#: ../lib/init/gis_set.tcl:395
+msgid "WARNING: invalid mapset name"
+msgstr ""
+#: ../lib/init/gis_set.tcl:396
+#, tcl-format
+msgid ""
+"Warning: Mapset with name <%s> already exists. \n"
+"New mapset is NOT created. \n"
+"Choose different mapset name and try again."
+msgstr ""
+#: ../lib/init/gis_set.tcl:404
+#, tcl-format
+msgid ""
+"Warning: selected location <%s> is not valid. \n"
+" New mapset is NOT created. \n"
+" Select valid location and try again."
+msgstr ""
+#: ../lib/init/gis_set.tcl:411
+msgid "WARNING: unable to mkdir"
+msgstr ""
+#: ../lib/init/gis_set.tcl:412
+#, tcl-format
+msgid ""
+"Warning: Unable to create directory for new mapset. \n"
+msgstr ""
+#: ../lib/init/gis_set.tcl:437
+msgid "Define new location with..."
+msgstr ""
+#: ../lib/init/gis_set.tcl:441
+msgid "Georeferenced file"
+msgstr ""
+#: ../lib/init/gis_set.tcl:454
+msgid "EPSG codes"
+msgstr ""
+#: ../lib/init/gis_set.tcl:467
+msgid "Projection values"
+msgstr ""
+#: ../lib/init/gis_set.tcl:505
+msgid "Enter GRASS"
+msgstr ""
+#: ../lib/init/gis_set.tcl:510
+#, tcl-format
+msgid ""
+msgstr ""
+#: ../lib/init/gis_set.tcl:515 ../lib/init/gis_set.tcl:686
+msgid "WARNING: invalid mapset"
+msgstr ""
+#: ../lib/init/gis_set.tcl:516
+#, tcl-format
+msgid "Warning: <%s> is not a valid mapset"
+msgstr ""
+#: ../lib/init/gis_set.tcl:536
+msgid "Help already opened"
+msgstr ""
+#: ../lib/init/gis_set.tcl:549
+msgid "Exit"
+msgstr ""
+#: ../lib/init/gis_set.tcl:583
+msgid "Starting GRASS for the first time"
+msgstr ""
+#: ../lib/init/gis_set.tcl:584
+msgid ""
+"GRASS needs a directory in which to store its data.  Create one now if you "
+"have not already done so.  A popular choice is \"grassdata\", located in "
+"your home directory."
+msgstr ""
+#: ../lib/init/gis_set.tcl:589
+msgid "Select GIS data directory"
+msgstr ""
+#: ../lib/init/gis_set.tcl:594
+msgid "WARNING: Invalid Database"
+msgstr ""
+#: ../lib/init/gis_set.tcl:595
+msgid "WARNING: Invalid database. Finding first valid directory in parent tree"
+msgstr ""
+#: ../lib/init/gis_set.tcl:642 ../lib/init/gis_set.tcl:663
+#: ../lib/init/gis_set.tcl:681 ../lib/init/gis_set.tcl:709
+#, tcl-format
+msgid ""
+"Warning: selected location <%%s> is not valid. \n"
+msgstr ""
+#: ../lib/init/gis_set.tcl:687
+#, tcl-format
+msgid "Warning: <%%s> is not a valid mapset"
+msgstr ""
+#: ../lib/init/gis_set.tcl:781
+msgid "WARNING: change directory failed"
+msgstr ""
+#: ../lib/init/gis_set.tcl:782
+#, tcl-format
+msgid ""
+"Warning: could not change directory to <%s>.\n"
+"Check directory permissions."
+msgstr ""
+#: ../lib/init/gis_set.tcl:936
+#, tcl-format
+msgid ""
+"Something went wrong while processing GISRC file named \"%s\".\n"
+"It's a fatal error. GRASS will not start till issue with GISRC file is fixed."
+msgstr ""
+#: ../lib/init/gis_set.tcl:938
+msgid ""
+"\n"
+"\n"
+"On MS-Windows systems failure might be caused by non-latin letter in GISRC "
+"file path.  Check that Your username doesn't contain non-latin letters.  Due "
+"to non-latin letter encoding handling in MS-Windows, it's not possible to "
+"run GRASS if username contains non-latin letters."
+msgstr ""
+#: ../lib/init/gis_set.tcl:942
+msgid "ERROR: unable to read GISRC"
+msgstr ""
+#: ../vector/v.digit/cats.tcl:34
+msgid "Categories already opened"
+msgstr ""
+#: ../vector/v.digit/cats.tcl:42
+msgid "Categories"
+msgstr ""
+#: ../vector/v.digit/cats.tcl:53
+msgid "Layer:"
+msgstr ""
+#: ../vector/v.digit/cats.tcl:55
+msgid "   Category:"
+msgstr ""
+#: ../vector/v.digit/cats.tcl:62
+msgid "Insert new record to table"
+msgstr ""
+#: ../vector/v.digit/cats.tcl:63
+msgid "Add new"
+msgstr ""
+#: ../vector/v.digit/toolbox.tcl:20
+msgid "Welcome to v.digit"
+msgstr ""
+#: ../vector/v.digit/toolbox.tcl:21
+msgid "Left button"
+msgstr ""
+#: ../vector/v.digit/toolbox.tcl:22
+msgid "Middle button"
+msgstr ""
+#: ../vector/v.digit/toolbox.tcl:23
+msgid "Right button"
+msgstr ""
+#: ../vector/v.digit/toolbox.tcl:98
+msgid "  Layer"
+msgstr ""
+#: ../vector/v.digit/toolbox.tcl:102
+msgid "  Category"
+msgstr ""
+#: ../vector/v.digit/toolbox.tcl:106
+msgid "  Mode "
+msgstr ""
+#: ../vector/v.digit/toolbox.tcl:118
+msgid "Insert new record into table"
+msgstr ""
+#: ../vector/v.digit/toolbox.tcl:135
+msgid "Digitize new point"
+msgstr ""
+#: ../vector/v.digit/toolbox.tcl:140
+msgid "Digitize new line"
+msgstr ""
+#: ../vector/v.digit/toolbox.tcl:145
+msgid "Digitize new boundary"
+msgstr ""
+#: ../vector/v.digit/toolbox.tcl:150
+msgid "Digitize new centroid"
+msgstr ""
+#: ../vector/v.digit/toolbox.tcl:156
+msgid "Move vertex"
+msgstr ""
+#: ../vector/v.digit/toolbox.tcl:161
+msgid "Add vertex"
+msgstr ""
+#: ../vector/v.digit/toolbox.tcl:166
+msgid "Remove vertex"
+msgstr ""
+#: ../vector/v.digit/toolbox.tcl:171
+msgid "Split line"
+msgstr ""
+#: ../vector/v.digit/toolbox.tcl:176
+msgid "Edit line/boundary"
+msgstr ""
+#: ../vector/v.digit/toolbox.tcl:181
+msgid "Move point, line, boundary, or centroid"
+msgstr ""
+#: ../vector/v.digit/toolbox.tcl:186
+msgid "Delete point, line, boundary, or centroid"
+msgstr ""
+#: ../vector/v.digit/toolbox.tcl:197
+msgid "Redraw"
+msgstr ""
+#: ../vector/v.digit/toolbox.tcl:202
+msgid "Zoom in by window"
+msgstr ""
+#: ../vector/v.digit/toolbox.tcl:207
+msgid "Zoom out"
+msgstr ""
+#: ../vector/v.digit/toolbox.tcl:217
+msgid "Zoom to default region"
+msgstr ""
+#: ../vector/v.digit/toolbox.tcl:230
+msgid "Zoom to saved region"
+msgstr ""
+#: ../vector/v.digit/toolbox.tcl:236
+msgid "Display categories"
+msgstr ""
+#: ../vector/v.digit/toolbox.tcl:241
+msgid "Copy categories"
+msgstr ""
+#: ../vector/v.digit/toolbox.tcl:246
+msgid "Display attributes"
+msgstr ""
+#: ../vector/v.digit/toolbox.tcl:258
+msgid "Open settings"
+msgstr ""
+#: ../vector/v.digit/toolbox.tcl:264
+msgid "Save and exit"
+msgstr ""
+#: ../vector/v.digit/toolbox.tcl:275
+msgid "mouse button actions (left, middle, right)"
+msgstr ""
+#: ../vector/v.digit/settings.tcl:75
+msgid "Add new column"
+msgstr ""
+#: ../vector/v.digit/settings.tcl:78
+msgid "Create table"
+msgstr ""
+#: ../vector/v.digit/settings.tcl:111
+msgid "Add command"
+msgstr ""
+#: ../vector/v.digit/settings.tcl:149
+msgid "Table successfully created"
+msgstr ""
+#: ../vector/v.digit/settings.tcl:165
+msgid "Settings already opened"
+msgstr ""
+#: ../vector/v.digit/settings.tcl:183
+msgid "Symbology"
+msgstr ""
+#: ../vector/v.digit/settings.tcl:187 ../vector/v.digit/settings.tcl:340
+msgid "Background"
+msgstr ""
+#: ../vector/v.digit/settings.tcl:194
+msgid "Highlight"
+msgstr ""
+#: ../vector/v.digit/settings.tcl:201
+msgid "Point"
+msgstr ""
+#: ../vector/v.digit/settings.tcl:210
+msgid "Line"
+msgstr ""
+#: ../vector/v.digit/settings.tcl:219
+msgid "Boundary (no area)"
+msgstr ""
+#: ../vector/v.digit/settings.tcl:227
+msgid "Boundary (1 area)"
+msgstr ""
+#: ../vector/v.digit/settings.tcl:235
+msgid "Boundary (2 areas)"
+msgstr ""
+#: ../vector/v.digit/settings.tcl:244
+msgid "Centroid (in area)"
+msgstr ""
+#: ../vector/v.digit/settings.tcl:252
+msgid "Centroid (outside area)"
+msgstr ""
+#: ../vector/v.digit/settings.tcl:260
+msgid "Centroid (duplicate in area)"
+msgstr ""
+#: ../vector/v.digit/settings.tcl:269
+msgid "Node (1 line)"
+msgstr ""
+#: ../vector/v.digit/settings.tcl:277
+msgid "Node (2 lines)"
+msgstr ""
+#: ../vector/v.digit/settings.tcl:287
+msgid "Settings"
+msgstr ""
+#: ../vector/v.digit/settings.tcl:292
+msgid "Snapping threshold in screen pixels"
+msgstr ""
+#: ../vector/v.digit/settings.tcl:302
+msgid "Snapping threshold in map units"
+msgstr ""
+#: ../vector/v.digit/settings.tcl:319
+msgid "Line width in screen pixels"
+msgstr ""
+#: ../vector/v.digit/settings.tcl:321
+msgid "Set line width in pixels"
+msgstr ""
+#: ../vector/v.digit/settings.tcl:329
+msgid "Table"
+msgstr ""
Added: grass/branches/releasebranch_6_4/locale/po/grasswxpy_nl.po
--- grass/branches/releasebranch_6_4/locale/po/grasswxpy_nl.po	                        (rev 0)
+++ grass/branches/releasebranch_6_4/locale/po/grasswxpy_nl.po	2012-06-19 22:28:16 UTC (rev 52142)
@@ -0,0 +1,12312 @@
+# SOME DESCRIPTIVE TITLE.
+# Copyright (C) YEAR THE PACKAGE'S COPYRIGHT HOLDER
+# This file is distributed under the same license as the PACKAGE package.
+# FIRST AUTHOR <EMAIL at ADDRESS>, YEAR.
+#, fuzzy
+msgid ""
+msgstr ""
+"Project-Id-Version: PACKAGE VERSION\n"
+"Report-Msgid-Bugs-To: \n"
+"POT-Creation-Date: 2012-06-19 23:46+0200\n"
+"PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
+"Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
+"Language-Team: LANGUAGE <LL at li.org>\n"
+"Language: \n"
+"MIME-Version: 1.0\n"
+"Content-Type: text/plain; charset=CHARSET\n"
+"Content-Transfer-Encoding: 8bit\n"
+#: ../gui/wxpython/lmgr/layertree.py:50 ../gui/wxpython/menustrings.py:29
+#: ../gui/wxpython/gui_core/dialogs.py:1673
+msgid "Import raster data"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:52 ../gui/wxpython/menustrings.py:150
+#: ../gui/wxpython/gui_core/dialogs.py:1671
+msgid "Link external raster data"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:54
+msgid "Set raster output format"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:56 ../gui/wxpython/menustrings.py:56
+#: ../gui/wxpython/gui_core/dialogs.py:1667
+msgid "Import vector data"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:58 ../gui/wxpython/menustrings.py:152
+#: ../gui/wxpython/gui_core/dialogs.py:1665
+msgid "Link external vector data"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:60
+msgid "Set vector output format"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:62
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:64
+#: ../gui/wxpython/gui_core/toolbars.py:66
+msgid "Quit"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:66
+msgid "Add RGB map layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:68
+msgid "Add HIS map layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:70
+msgid "Add shaded relief map layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:72
+msgid "Add raster flow arrows"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:74
+msgid "Add raster cell numbers"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:76
+msgid "Add thematic area (choropleth) map layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:78
+msgid "Add thematic chart layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:80
+msgid "Add grid layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:82
+msgid "Add geodesic line layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:84
+msgid "Add rhumbline layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:86
+msgid "Add labels"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:88
+msgid "Add 3D raster map layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:89
+msgid "Note that 3D raster data are rendered only in 3D view mode"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:91
+#: ../gui/wxpython/gui_core/dialogs.py:520
+msgid "Set options"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:157
+#, python-format
+msgid "GRASS GIS Map Display: %(id)d  - Location: %(loc)s"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:167
+msgid "Map Layers"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:313
+#: ../gui/wxpython/gmodeler/frame.py:1177
+msgid "Remove"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:317 ../gui/wxpython/menustrings.py:161
+msgid "Rename"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:325
+msgid "Change opacity level"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:327
+#: ../gui/wxpython/gmodeler/frame.py:1209
+msgid "Properties"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:335
+msgid "3D view properties"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:339
+msgid "Zoom to selected map(s)"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:341
+msgid "Set computational region from selected map(s)"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:353 ../gui/wxpython/lmgr/layertree.py:426
+msgid "Export"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:360 ../gui/wxpython/lmgr/layertree.py:432
+msgid "Set color table"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:363
+msgid "Show attribute data"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:366
+msgid "Start editing"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:367
+msgid "Stop editing"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:378
+msgid "Use as background vector map for digitizer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:385
+msgid "Rebuild topology"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:407 ../gui/wxpython/lmgr/layertree.py:440
+#: ../gui/wxpython/gmodeler/preferences.py:428
+msgid "Metadata"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:420
+msgid "Zoom to selected map(s) (ignore NULLs)"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:422
+msgid "Set computational region from selected map(s) (ignore NULLs)"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:434 ../gui/wxpython/menustrings.py:716
+msgid "Histogram"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:436 ../gui/wxpython/menustrings.py:505
+msgid "Univariate raster statistics"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:438 ../gui/wxpython/wxplot/dialogs.py:502
+msgid "Profile"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:529
+msgid "Unable to create profile of raster map."
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:531 ../gui/wxpython/wxplot/profile.py:340
+#: ../gui/wxpython/gmodeler/frame.py:882 ../gui/wxpython/psmap/dialogs.py:3951
+#: ../gui/wxpython/vdigit/dialogs.py:241 ../gui/wxpython/vdigit/dialogs.py:433
+#: ../gui/wxpython/location_wizard/wizard.py:525
+#: ../gui/wxpython/location_wizard/wizard.py:710
+#: ../gui/wxpython/location_wizard/wizard.py:1432
+#: ../gui/wxpython/location_wizard/wizard.py:1490
+#: ../gui/wxpython/location_wizard/dialogs.py:114
+#: ../gui/wxpython/location_wizard/dialogs.py:131
+#: ../gui/wxpython/location_wizard/dialogs.py:438
+#: ../gui/wxpython/gui_core/preferences.py:200
+#: ../gui/wxpython/gui_core/preferences.py:1191
+#: ../gui/wxpython/gui_core/preferences.py:1220
+#: ../gui/wxpython/gui_core/preferences.py:1229
+#: ../gui/wxpython/gui_core/preferences.py:1238
+#: ../gui/wxpython/core/gcmd.py:108 ../gui/wxpython/core/workspace.py:997
+#: ../gui/wxpython/gis_set.py:204 ../gui/wxpython/gis_set.py:447
+#: ../gui/wxpython/gis_set.py:483 ../gui/wxpython/gis_set.py:549
+#: ../gui/wxpython/gis_set.py:712 ../gui/wxpython/mapdisp/mapwindow.py:1631
+msgid "Error"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:565
+msgid "Unable to display histogram of raster map. No map name defined."
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:645
+#, python-format
+msgid "Set opacity of <%s>"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:737
+msgid "Layer group:"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:742
+#: ../gui/wxpython/lmgr/layertree.py:1307
+msgid "Click to edit layer settings"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:783
+msgid "(double click to set properties)"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:786 ../gui/wxpython/gcp/manager.py:314
+#: ../gui/wxpython/gmodeler/frame.py:1285 ../gui/wxpython/psmap/dialogs.py:695
+#: ../gui/wxpython/gui_core/dialogs.py:1240
+msgid "raster"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:789
+msgid "3D raster"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:792
+msgid "RGB"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:795
+msgid "HIS"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:798
+msgid "shaded relief"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:801
+msgid "raster cell numbers"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:804
+msgid "raster flow arrows"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:807 ../gui/wxpython/gcp/manager.py:314
+#: ../gui/wxpython/gmodeler/frame.py:1286 ../gui/wxpython/psmap/dialogs.py:696
+msgid "vector"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:810
+msgid "thematic map"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:813
+msgid "thematic charts"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:816
+msgid "grid"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:819
+msgid "geodesic line"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:822
+msgid "rhumbline"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:825
+msgid "vector labels"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:1062
+#: ../gui/wxpython/lmgr/layertree.py:1111
+msgid "Please wait, updating data..."
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:1391
+msgid "opacity:"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:1408
+#, python-format
+msgid "Map <%s> not found."
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:50
+msgid "Start new map display"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:52
+msgid "Create new workspace (Ctrl+N)"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:54
+msgid "Open existing workspace file (Ctrl+O)"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:56
+msgid "Save current workspace to file (Ctrl+S)"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:85
+msgid "Add multiple raster or vector map layers (Ctrl+Shift+L)"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:86
+msgid "Add raster map layer (Ctrl+Shift+R)"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:88
+msgid "Add various raster map layers (RGB, HIS, shaded relief...)"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:89
+msgid "Add vector map layer (Ctrl+Shift+V)"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:91
+msgid "Add various vector map layers (thematic, chart...)"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:93
+msgid "Add group"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:95
+msgid "Add grid or vector labels overlay"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:97
+msgid "Delete selected map layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:134
+msgid "Import/link raster or vector data"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:136
+msgid "Raster Map Calculator"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:138
+msgid "Graphical Modeler"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:140
+msgid "Georectifier"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:142 ../gui/wxpython/menustrings.py:196
+msgid "Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:173
+msgid "GUI settings"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:174
+msgid "GRASS manual"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:199
+msgid "Edit vector maps"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:201
+msgid "Show attribute table"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:230
+msgid "Generate command for m.nviz.image"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:231
+msgid "Generate command for m.nviz.image based on current state"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:233
+msgid "3D view mode settings"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:234
+msgid "Show 3D view mode settings dialog"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:236
+msgid "Show 3D view mode manual"
+msgstr ""
+#: ../gui/wxpython/lmgr/pyshell.py:35
+#, python-format
+msgid "Welcome to wxGUI Interactive Python Shell %s"
+msgstr ""
+#: ../gui/wxpython/lmgr/pyshell.py:36
+#, python-format
+msgid "Type %s for more GRASS scripting related information."
+msgstr ""
+#: ../gui/wxpython/lmgr/pyshell.py:37
+#, python-format
+msgid "Type %s to add raster or vector to the layer tree."
+msgstr ""
+#: ../gui/wxpython/lmgr/pyshell.py:46
+msgid "Delete all text from the shell"
+msgstr ""
+#: ../gui/wxpython/lmgr/pyshell.py:96
+#, python-format
+msgid "Raster or vector map <%s> not found"
+msgstr ""
+#: ../gui/wxpython/lmgr/pyshell.py:103
+#, python-format
+msgid "Raster map <%s> added"
+msgstr ""
+#: ../gui/wxpython/lmgr/pyshell.py:105
+#, python-format
+msgid "Vector map <%s> added"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:74
+msgid "GRASS GIS Layer Manager"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:117
+msgid "Workspace Toolbar"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:120
+msgid "Data Toolbar"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:123
+msgid "Misc Toolbar"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:126
+msgid "Tools Toolbar"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:129
+msgid "Vector Toolbar"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:132
+msgid "3D view Toolbar"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:226 ../gui/wxpython/lmgr/frame.py:1095
+msgid "Rename Map Display"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:254
+msgid "Map layers"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:258 ../gui/wxpython/lmgr/frame.py:437
+msgid "Command console"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:264
+#: ../gui/wxpython/gui_core/preferences.py:293
+msgid "Search module"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:271
+#: ../gui/wxpython/gui_core/preferences.py:303
+msgid "Python shell"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:301 ../gui/wxpython/mapdisp/toolbars.py:84
+msgid "3D view"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:335
+#, python-format
+msgid ""
+"Location <%s> created.\n"
+"\n"
+"Do you want to switch to the new location?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:338
+msgid "Switch to new location?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:351 ../gui/wxpython/lmgr/frame.py:658
+#, python-format
+msgid ""
+"Current location is <%(loc)s>.\n"
+"Current mapset is <%(mapset)s>."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:392
+msgid "Choose model to run"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:394 ../gui/wxpython/gmodeler/frame.py:366
+#: ../gui/wxpython/gmodeler/frame.py:410
+msgid "GRASS Model File (*.gxm)|*.gxm"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:451 ../gui/wxpython/lmgr/frame.py:1722
+msgid "Do you want to save changes in the workspace?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:453 ../gui/wxpython/lmgr/frame.py:1724
+msgid "Do you want to store current settings to workspace file?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:461
+#, python-format
+msgid "Close Map Display %s"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:560 ../gui/wxpython/lmgr/frame.py:1339
+msgid "Selected map layer is not vector."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:565
+msgid "Editing is allowed only for vector maps from the current mapset."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:580
+msgid "Choose script file to run"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:582
+msgid "Python script (*.py)|*.py|Bash script (*.sh)|*.sh"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:593
+#, python-format
+msgid "Script file '%s' doesn't exist. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:600
+#, python-format
+msgid ""
+"Script <%s> is not executable. Do you want to set the permissions that "
+"allows you to run this script (note that you must be the owner of the file)?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:605
+msgid "Set permission?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:614
+msgid "Unable to set permission. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:625
+#, python-format
+msgid ""
+"Directory '%s' is not defined in GRASS_ADDON_PATH. Do you want add this "
+"directory to GRASS_ADDON_PATH?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:628
+msgid "Update Addons path?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:634
+#, python-format
+msgid "Launching script '%s'..."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:646
+msgid "No location/mapset provided. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:665 ../gui/wxpython/gis_set.py:692
+msgid "Enter name for new mapset:"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:666 ../gui/wxpython/menustrings.py:227
+#: ../gui/wxpython/gis_set.py:693
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:672 ../gui/wxpython/lmgr/frame.py:693
+msgid "No mapset provided. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:681 ../gui/wxpython/lmgr/frame.py:700
+#, python-format
+msgid "Current mapset is <%s>."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:768
+msgid ""
+"Current workspace is not empty. Do you want to store current settings to "
+"workspace file?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:771
+msgid "Create new workspace?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:797
+msgid "Choose workspace file"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:798 ../gui/wxpython/lmgr/frame.py:989
+msgid "GRASS Workspace File (*.gxw)|*.gxw"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:833
+#, python-format
+msgid ""
+"Reading workspace file <%s> failed.\n"
+"Invalid file, unable to parse XML document."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:837 ../gui/wxpython/lmgr/frame.py:966
+msgid "Please wait, loading workspace..."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:950
+msgid "Choose GRC file to load"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:951
+msgid "Old GRASS Workspace File (*.grc)|*.grc"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:988
+msgid "Choose file to save current workspace"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1003 ../gui/wxpython/lmgr/frame.py:1019
+#, python-format
+msgid "Workspace file <%s> already exists. Do you want to overwrite this file?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1005 ../gui/wxpython/lmgr/frame.py:1022
+#: ../gui/wxpython/menustrings.py:9
+msgid "Save workspace"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1043
+msgid "Writing current settings to workspace file failed."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1054 ../gui/wxpython/wxplot/profile.py:339
+#: ../gui/wxpython/gmodeler/frame.py:881
+#, python-format
+msgid "Unable to open file <%s> for writing."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1094
+msgid "Enter new name:"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1100
+#, python-format
+msgid "GRASS GIS Map Display: %(name)s  - Location: %(loc)s"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1312
+msgid "Nothing to import. No WMS layer selected."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1348
+msgid "Please wait, loading attribute data..."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1427
+msgid "Add selected map layers into layer tree"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1452
+#, python-format
+msgid "Unsupported map layer type <%s>."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1577
+msgid ""
+"Note that cell values can only be displayed for regions of less than 10,000 "
+"cells."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1659
+#, python-format
+msgid ""
+"Do you want to remove map layer(s)\n"
+"%s\n"
+"from layer tree?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1662
+msgid "Do you want to remove selected map layer(s) from layer tree?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1666
+msgid "Remove map layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1731
+msgid "Quit GRASS GUI"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1760
+msgid "No map layer selected. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1761 ../gui/wxpython/gui_core/ghelp.py:274
+#: ../gui/wxpython/core/gcmd.py:142 ../gui/wxpython/gis_set.py:435
+#: ../gui/wxpython/gis_set.py:470
+msgid "Message"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1770
+msgid ""
+"Display resolution is currently not constrained to computational settings. "
+"It's suggested to constrain map to region geometry. Do you want to constrain "
+"the resolution?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1779
+msgid "Constrain map to region geometry?"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:83
+#, python-format
+msgid "Unable to load icon theme. Reason: %s"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:45
+msgid "GRASS GIS Manage Ground Control Points"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:151
+msgid "GCP List"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:156
+msgid "Source Display"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:160
+msgid "Target Display"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:222 ../gui/wxpython/mapdisp/frame.py:376
+msgid "Map Toolbar"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:235
+msgid "GCP Display toolbar"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:248
+msgid "GCP Manager toolbar"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:440 ../gui/wxpython/mapdisp/frame.py:549
+msgid "Nothing to render (empty map). Operation canceled."
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:455 ../gui/wxpython/gmodeler/frame.py:543
+#: ../gui/wxpython/modules/histogram.py:414
+#: ../gui/wxpython/mapdisp/frame.py:564
+msgid "Choose a file name to save the image (no need to add extension)"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:484 ../gui/wxpython/wxplot/base.py:504
+#: ../gui/wxpython/modules/histogram.py:443
+#: ../gui/wxpython/psmap/toolbars.py:60 ../gui/wxpython/mapdisp/frame.py:593
+msgid "Page setup"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:488 ../gui/wxpython/wxplot/base.py:505
+#: ../gui/wxpython/modules/histogram.py:447
+#: ../gui/wxpython/mapdisp/frame.py:597
+msgid "Print preview"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:492 ../gui/wxpython/wxplot/base.py:506
+#: ../gui/wxpython/modules/histogram.py:451
+#: ../gui/wxpython/gui_core/toolbars.py:60
+#: ../gui/wxpython/mapdisp/frame.py:601
+msgid "Print display"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:577 ../gui/wxpython/mapdisp/frame.py:1222
+msgid "Zoom to computational region (set with g.region)"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:581 ../gui/wxpython/mapdisp/frame.py:1226
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:585 ../gui/wxpython/mapdisp/frame.py:1230
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:589
+msgid "Set computational region from display"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:593 ../gui/wxpython/mapdisp/frame.py:1238
+msgid "Save display geometry to named region"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:129
+msgid "Setup for georectification"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:162 ../gui/wxpython/gcp/manager.py:166
+msgid "Georectifying setup canceled."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:299
+msgid "Select map type and location/mapset"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:313
+msgid "Map type to georectify"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:321
+msgid "Select source location:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:330
+msgid "Select source mapset:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:383
+msgid "You must select a valid location before selecting a mapset"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:396
+msgid "You must select a valid location and mapset in order to continue"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:415
+msgid "Select image/map group to georectify"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:434
+msgid "Select group:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:445
+msgid "Create group if none exists"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:449
+msgid "Create/edit group..."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:450
+msgid "Add vector map to group..."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:462 ../gui/wxpython/gcp/manager.py:2614
+msgid "Extension for output maps:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:521
+msgid "You must select a valid image/map group in order to continue"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:528
+msgid "You must enter an map name extension in order to continue"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:594
+msgid "Select maps to display for ground control point (GCP) creation"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:602 ../gui/wxpython/gcp/manager.py:2556
+msgid "Select source map to display:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:613 ../gui/wxpython/gcp/manager.py:2561
+msgid "Select target map to display:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:669
+msgid "You must select a source map in order to continue"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:693
+#, python-format
+msgid ""
+"No maps in selected group <%s>.\n"
+"Please edit group or select another group."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:719
+msgid "Manage Ground Control Points"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:950
+#, python-format
+msgid "At least %d GCPs required. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1037
+msgid "mapwin not defined for "
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1107
+msgid "source"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1109
+msgid "target"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1111
+msgid "Set GCP coordinates"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1112
+#, python-format
+msgid ""
+"Set %(coor)s coordinates for GCP No. %(key)s? \n"
+"\n"
+"East: %(coor0)s \n"
+"North: %(coor1)s"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1176
+msgid "Writing POINTS file failed"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1185
+#, python-format
+msgid "POINTS file saved for group <%s>"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1201
+msgid "source mapwin not defined"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1206
+msgid "target mapwin not defined"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1234
+msgid "Reading POINTS file failed"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1305
+msgid ""
+"Insufficient points defined and active (checked) for selected rectification "
+"method.\n"
+"3+ points needed for 1st order,\n"
+"6+ points for 2nd order, and\n"
+"10+ points for 3rd order."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1332
+msgid "Rectifying images, please wait..."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1384
+#, python-format
+msgid "Transforming <%s>..."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1401 ../gui/wxpython/gcp/manager.py:1472
+#, python-format
+msgid "Georectification of vector map <%s> failed"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1443
+#, python-format
+msgid ""
+"Vector map <%s> already exists. Change extension name and georectify again."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1453
+msgid "For all vector maps georectified successfully,"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1454
+msgid "you will need to copy any attribute tables"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1455
+msgid "and reconnect them to the georectified vectors"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1478
+msgid "GCP Manager settings"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1523
+msgid "Quit GCP Manager"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1524
+msgid "Save ground control points?"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1603
+msgid ""
+"Could not calculate RMS Error.\n"
+"Possible error with g.transform."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1728
+msgid ""
+"Could not calculate new extends.\n"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1859
+msgid "Adjust source display to target display"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1863
+msgid "Adjust target display to source display"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1924 ../gui/wxpython/gcp/manager.py:1941
+msgid "use"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1925 ../gui/wxpython/gcp/manager.py:1942
+msgid "source E"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1926 ../gui/wxpython/gcp/manager.py:1943
+msgid "source N"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1927 ../gui/wxpython/gcp/manager.py:1944
+msgid "target E"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1928 ../gui/wxpython/gcp/manager.py:1945
+msgid "target N"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1929 ../gui/wxpython/gcp/manager.py:1946
+msgid "Forward error"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1930 ../gui/wxpython/gcp/manager.py:1947
+msgid "Backward error"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2074
+msgid "Invalid coordinate value. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2113
+msgid "Create vector map group"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2186
+msgid "Select vector map(s) to add to group:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2233
+msgid "Edit GCP"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2244
+msgid "Ground Control Point No."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2263
+msgid "source E:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2264
+msgid "target E:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2265
+msgid "source N:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2266
+msgid "target N:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2366 ../gui/wxpython/wxplot/dialogs.py:373
+#: ../gui/wxpython/wxplot/dialogs.py:728
+#: ../gui/wxpython/gui_core/preferences.py:86
+msgid "Apply changes for the current session"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2368 ../gui/wxpython/wxplot/dialogs.py:378
+#: ../gui/wxpython/wxplot/dialogs.py:730
+#: ../gui/wxpython/gui_core/preferences.py:88
+msgid ""
+"Apply and save changes to user settings file (default for next sessions)"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2370
+#: ../gui/wxpython/modules/ogc_services.py:76
+#: ../gui/wxpython/gui_core/dialogs.py:1513
+msgid "Close dialog"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2392 ../gui/wxpython/psmap/dialogs.py:1953
+#: ../gui/wxpython/vdigit/preferences.py:80
+msgid "Symbology"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2401
+msgid "Highlight highest RMS error only"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2407
+msgid "Highlight RMS error > M + SD * factor:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2408
+msgid ""
+"Highlight GCPs with an RMS error larger than \n"
+"mean + standard deviation * given factor. \n"
+"Recommended values for this factor are between 1 and 2."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2424
+msgid "Symbol settings"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2433 ../gui/wxpython/nviz/tools.py:1128
+#: ../gui/wxpython/nviz/tools.py:1680 ../gui/wxpython/nviz/tools.py:1799
+#: ../gui/wxpython/nviz/preferences.py:333
+#: ../gui/wxpython/nviz/preferences.py:490
+#: ../gui/wxpython/nviz/preferences.py:544
+#: ../gui/wxpython/psmap/dialogs.py:1776 ../gui/wxpython/psmap/dialogs.py:1879
+#: ../gui/wxpython/gui_core/preferences.py:926
+msgid "Color:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2450
+msgid "Color for high RMS error:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2467
+msgid "Color for selected GCP:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2484
+msgid "Color for unused GCPs:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2500
+msgid "Show unused GCPs"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2509
+msgid "Symbol size:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2524 ../gui/wxpython/psmap/dialogs.py:4896
+msgid "Line width:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2581
+msgid "Rectification"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2587
+msgid "Select rectification order"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2588
+msgid "1st order"
+msgstr ""
+msgid "2nd order"
+msgstr ""
+msgid "3rd order"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2597
+msgid "Select interpolation method:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2608
+msgid "clip to computational region in target location"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2647
+msgid "RMS threshold factor must be > 0"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2650
+msgid ""
+"RMS threshold factor is < 1\n"
+"Too many points might be highlighted"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2769
+#, python-format
+msgid "GCP Manager settings saved to file '%s'."
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:30 ../gui/wxpython/nviz/wxnviz.py:32
+msgid ""
+"This module requires the NumPy module, which could not be imported. It "
+"probably is not installed (it's not part of the standard Python "
+"distribution). See the Numeric Python site (http://numpy.scipy.org) for "
+"information on downloading source or binaries."
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:52
+msgid "GRASS Profile Analysis Tool"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:63 ../gui/wxpython/wxplot/profile.py:144
+msgid "Profile of"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:77
+#, python-format
+msgid "Distance (%s)"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:79
+msgid "Distance along transect"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:80
+msgid "Cell values"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:205
+msgid "Raster values"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:256
+msgid "You must draw a transect to profile in the map display window."
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:257
+msgid "Nothing to profile"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:324
+msgid "Comma separated value (*.csv)|*.csv"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:327
+msgid "Path and prefix (for raster name) to save profile values..."
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:353
+msgid "Statistics for Profile(s)"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:32
+msgid "Select raster maps to profile"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:61
+msgid "Select raster map(s) to profile:"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:108
+msgid "Statistics"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:159
+msgid "C&opy"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:160
+msgid "Copy regression statistics the clipboard (Ctrl+C)"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:189
+msgid "Regression statistics copied to clipboard"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:244 ../gui/wxpython/wxplot/base.py:428
+msgid "Text settings"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:251
+msgid "Profile title:"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:261
+msgid "Title font size (pts):"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:272
+msgid "X-axis label:"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:282
+msgid "Y-axis label:"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:292
+msgid "Label font size (pts):"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:307 ../gui/wxpython/psmap/dialogs.py:2787
+#: ../gui/wxpython/psmap/dialogs.py:3265 ../gui/wxpython/psmap/dialogs.py:3721
+#: ../gui/wxpython/gui_core/preferences.py:391
+#: ../gui/wxpython/gui_core/preferences.py:564
+#: ../gui/wxpython/gui_core/preferences.py:1337
+msgid "Font settings"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:315
+msgid "Font family:"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:329
+msgid "Style:"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:343
+msgid "Weight:"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:375
+msgid "Apply changes for the current session and close dialog"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:380 ../gui/wxpython/wxplot/dialogs.py:733
+#: ../gui/wxpython/gmodeler/preferences.py:452
+#: ../gui/wxpython/psmap/dialogs.py:354
+#: ../gui/wxpython/vdigit/preferences.py:58
+#: ../gui/wxpython/gui_core/preferences.py:91
+msgid "Close dialog and ignore changes"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:431 ../gui/wxpython/wxplot/dialogs.py:781
+#, python-format
+msgid "Profile settings saved to file '%s'."
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:492
+msgid "Profile line settings"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:507
+msgid "Line color"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:514
+#: ../gui/wxpython/vdigit/preferences.py:130
+msgid "Line width"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:524 ../gui/wxpython/psmap/dialogs.py:2114
+#: ../gui/wxpython/psmap/dialogs.py:4893
+msgid "Line style"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:533 ../gui/wxpython/wxplot/dialogs.py:585
+#: ../gui/wxpython/psmap/toolbars.py:79
+msgid "Legend"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:557
+msgid "Transect segment marker settings"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:562 ../gui/wxpython/nviz/tools.py:774
+#: ../gui/wxpython/nviz/tools.py:2252
+#: ../gui/wxpython/gmodeler/preferences.py:88
+#: ../gui/wxpython/gmodeler/preferences.py:326
+#: ../gui/wxpython/psmap/dialogs.py:4593 ../gui/wxpython/psmap/dialogs.py:4848
+msgid "Color"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:568 ../gui/wxpython/psmap/dialogs.py:1995
+#: ../gui/wxpython/psmap/dialogs.py:2706 ../gui/wxpython/psmap/dialogs.py:3471
+msgid "Size"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:577 ../gui/wxpython/wxplot/dialogs.py:623
+#: ../gui/wxpython/psmap/dialogs.py:3524
+msgid "Style"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:592 ../gui/wxpython/dbmgr/manager.py:896
+#: ../gui/wxpython/gmodeler/preferences.py:207
+msgid "Type"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:607
+msgid "Axis settings"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:613
+msgid "X-Axis"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:614
+msgid "Y-Axis"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:632
+msgid "Custom min"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:640
+msgid "Custom max"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:648
+msgid "Log scale"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:672
+msgid "Grid and Legend settings"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:677
+msgid "Grid color"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:684
+msgid "Show grid"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:690
+msgid "Legend font size"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:700
+msgid "Show legend"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:35
+msgid "Draw/re-draw plot"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:37
+msgid "Draw transect in map display window to profile"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:39
+msgid "Plot options"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:41
+msgid "Plot statistics"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:43
+msgid "Save profile data to CSV file"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:44
+msgid "Quit plot tool"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:399
+msgid "Left Mouse Down at Point:"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:432 ../gui/wxpython/wxplot/base.py:489
+msgid "Plot settings"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:445
+msgid "This feature is not yet functional"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:446
+msgid "Under Construction"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:475
+msgid "Histogram text settings"
+msgstr ""
+#: ../gui/wxpython/nviz/wxnviz.py:49
+#, python-format
+msgid "3D view mode: %s\n"
+msgstr ""
+#: ../gui/wxpython/nviz/wxnviz.py:321 ../gui/wxpython/nviz/wxnviz.py:332
+#: ../gui/wxpython/modules/histogram.py:343
+#, python-format
+msgid "Raster map <%s> not found"
+msgstr ""
+#: ../gui/wxpython/nviz/wxnviz.py:409
+#, python-format
+msgid "Vector map <%s> not found"
+msgstr ""
+#: ../gui/wxpython/nviz/wxnviz.py:474 ../gui/wxpython/nviz/wxnviz.py:486
+#, python-format
+msgid "3d raster map <%s> not found"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:82 ../gui/wxpython/nviz/preferences.py:55
+#: ../gui/wxpython/nviz/preferences.py:60
+msgid "View"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:86
+#: ../gui/wxpython/gmodeler/preferences.py:202
+msgid "Data"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:90
+#: ../gui/wxpython/gui_core/preferences.py:387
+msgid "Appearance"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:94
+msgid "Analysis"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:97 ../gui/wxpython/nviz/tools.py:367
+msgid "Animation"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:217
+msgid "Control View"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:242 ../gui/wxpython/nviz/preferences.py:68
+msgid "Perspective:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:253 ../gui/wxpython/nviz/preferences.py:131
+msgid "Twist:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:270 ../gui/wxpython/nviz/tools.py:1022
+#: ../gui/wxpython/nviz/tools.py:1658
+#: ../gui/wxpython/gmodeler/preferences.py:176
+#: ../gui/wxpython/gmodeler/preferences.py:295
+#: ../gui/wxpython/gmodeler/preferences.py:380
+#: ../gui/wxpython/psmap/dialogs.py:2734 ../gui/wxpython/psmap/dialogs.py:2872
+#: ../gui/wxpython/psmap/dialogs.py:3477
+#: ../gui/wxpython/gui_core/dialogs.py:2170
+msgid "Height:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:276 ../gui/wxpython/nviz/preferences.py:149
+msgid "Z-exag:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:289
+msgid "Look:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:292
+msgid "here"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:298
+msgid "center"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:304
+msgid "top"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:310
+msgid "reset"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:311
+msgid "Reset to default view"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:329 ../gui/wxpython/nviz/preferences.py:171
+msgid "Image Appearance"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:337 ../gui/wxpython/nviz/preferences.py:178
+#: ../gui/wxpython/gui_core/preferences.py:653
+msgid "Background color:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:374
+msgid ""
+"Press 'Record' button and start changing the view. It is recommended to use "
+"fly-through mode (Map Display toolbar) to achieve smooth motion."
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:385
+msgid "Record"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:387
+msgid "Play"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:389
+msgid "Pause"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:391
+msgid "Stop"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:403
+msgid "Total number of frames :"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:407
+msgid "Frame rate (FPS):"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:413
+msgid "Frames are recorded with given frequency (FPS). "
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:456
+msgid "Save image sequence"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:463 ../gui/wxpython/psmap/dialogs.py:4119
+msgid "Choose a directory:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:464
+msgid "Choose a directory for images"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:465 ../gui/wxpython/psmap/dialogs.py:1971
+#: ../gui/wxpython/psmap/dialogs.py:2160 ../gui/wxpython/psmap/dialogs.py:4121
+#: ../gui/wxpython/location_wizard/wizard.py:98
+#: ../gui/wxpython/location_wizard/wizard.py:1102
+#: ../gui/wxpython/location_wizard/wizard.py:1176
+#: ../gui/wxpython/location_wizard/wizard.py:1259
+#: ../gui/wxpython/gui_core/forms.py:1289
+#: ../gui/wxpython/gui_core/dialogs.py:1799
+#: ../gui/wxpython/gui_core/gselect.py:877
+#: ../gui/wxpython/gui_core/gselect.py:1175
+#: ../gui/wxpython/gui_core/gselect.py:1184
+#: ../gui/wxpython/gui_core/gselect.py:1193
+#: ../gui/wxpython/gui_core/gselect.py:1508
+#: ../gui/wxpython/gui_core/gselect.py:1696
+msgid "Browse"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:468
+msgid "File prefix:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:472
+msgid ""
+"Generated files names will look like this: prefix_1.ppm, prefix_2.ppm, ..."
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:473
+msgid "File format:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:531 ../gui/wxpython/nviz/tools.py:1748
+#: ../gui/wxpython/nviz/preferences.py:360
+msgid "Surface"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:537 ../gui/wxpython/nviz/tools.py:1064
+msgid "Constant surface"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:542 ../gui/wxpython/nviz/preferences.py:462
+msgid "Vector"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:548
+msgid "Volume"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:583 ../gui/wxpython/nviz/preferences.py:252
+msgid "Lighting"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:588
+msgid "Fringe"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:595
+msgid "Decorations"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:615 ../gui/wxpython/nviz/tools.py:927
+msgid "Cutting planes"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:637 ../gui/wxpython/nviz/mapwindow.py:1619
+#: ../gui/wxpython/psmap/dialogs.py:1143
+msgid "Raster map"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:660 ../gui/wxpython/nviz/tools.py:1452
+#: ../gui/wxpython/nviz/preferences.py:367
+msgid "Draw"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:667 ../gui/wxpython/nviz/tools.py:1459
+#: ../gui/wxpython/nviz/preferences.py:373
+msgid "Mode:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:670 ../gui/wxpython/nviz/preferences.py:376
+msgid "coarse"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:671 ../gui/wxpython/nviz/preferences.py:377
+msgid "fine"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:672 ../gui/wxpython/nviz/preferences.py:378
+msgid "both"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:681 ../gui/wxpython/nviz/tools.py:943
+#: ../gui/wxpython/nviz/tools.py:1473
+msgid "Shading:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:684 ../gui/wxpython/nviz/tools.py:1239
+#: ../gui/wxpython/nviz/tools.py:1476
+msgid "flat"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:685 ../gui/wxpython/nviz/tools.py:1477
+msgid "gouraud"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:693
+msgid "Set to all"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:694
+msgid "Use draw settings for all loaded surfaces"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:702 ../gui/wxpython/nviz/preferences.py:405
+msgid "Coarse mode:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:705 ../gui/wxpython/nviz/tools.py:745
+#: ../gui/wxpython/nviz/preferences.py:392
+#: ../gui/wxpython/nviz/preferences.py:409
+msgid "resolution:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:718 ../gui/wxpython/nviz/preferences.py:421
+msgid "style:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:721 ../gui/wxpython/nviz/preferences.py:424
+msgid "wire"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:722 ../gui/wxpython/nviz/preferences.py:425
+msgid "surface"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:734
+msgid "Change wire color"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:741 ../gui/wxpython/nviz/preferences.py:388
+msgid "Fine mode:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:766
+msgid "Surface attributes"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:775 ../gui/wxpython/nviz/tools.py:2253
+#: ../gui/wxpython/menustrings.py:311 ../gui/wxpython/psmap/dialogs.py:1726
+msgid "Mask"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:776 ../gui/wxpython/nviz/tools.py:2254
+msgid "Transparency"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:777 ../gui/wxpython/nviz/tools.py:2255
+msgid "Shininess"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:783 ../gui/wxpython/nviz/tools.py:2266
+msgid "map"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:786 ../gui/wxpython/nviz/tools.py:2271
+msgid "unset"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:791 ../gui/wxpython/nviz/tools.py:2276
+msgid "constant"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:842 ../gui/wxpython/nviz/tools.py:1568
+#: ../gui/wxpython/psmap/dialogs.py:2704 ../gui/wxpython/psmap/dialogs.py:3246
+#: ../gui/wxpython/psmap/dialogs.py:3441 ../gui/wxpython/psmap/dialogs.py:3815
+#: ../gui/wxpython/psmap/dialogs.py:3819 ../gui/wxpython/psmap/dialogs.py:4221
+#: ../gui/wxpython/psmap/dialogs.py:4226 ../gui/wxpython/psmap/dialogs.py:4675
+#: ../gui/wxpython/psmap/dialogs.py:4680
+msgid "Position"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:857 ../gui/wxpython/nviz/tools.py:1040
+#: ../gui/wxpython/nviz/tools.py:1583 ../gui/wxpython/nviz/tools.py:2436
+msgid "Reset"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:858 ../gui/wxpython/nviz/tools.py:1584
+msgid "Reset to default position"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:933
+msgid "Active cutting plane:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:945
+msgid "clear"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:946
+msgid "top color"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:947
+msgid "bottom color"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:948
+msgid "blend"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:949
+msgid "shaded"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:961
+msgid "Horizontal X:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:976
+msgid "Horizontal Y:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:992 ../gui/wxpython/gui_core/dialogs.py:753
+msgid "Rotation:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1007
+msgid "Tilt:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1075 ../gui/wxpython/menustrings.py:4
+#: ../gui/wxpython/menustrings.py:855
+msgid "New"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1079 ../gui/wxpython/nviz/tools.py:1865
+#: ../gui/wxpython/menustrings.py:163 ../gui/wxpython/psmap/dialogs.py:1316
+msgid "Delete"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1092
+msgid "Fine resolution:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1104
+msgid "Value:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1116 ../gui/wxpython/nviz/tools.py:2425
+msgid "Transparency:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1158 ../gui/wxpython/psmap/dialogs.py:2618
+msgid "Vector map"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1182
+msgid "Show vector lines"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1192 ../gui/wxpython/nviz/preferences.py:468
+msgid "Vector lines"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1199
+msgid "Line:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1202
+msgid "width:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1218 ../gui/wxpython/nviz/tools.py:1324
+msgid "color:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1233
+#: ../gui/wxpython/vdigit/preferences.py:125
+msgid "Display"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1238
+msgid "on surface(s):"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1248 ../gui/wxpython/nviz/tools.py:1375
+msgid "Height above surface:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1283
+msgid "Show vector points"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1292 ../gui/wxpython/nviz/preferences.py:508
+msgid "Vector points"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1303
+msgid "Icon:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1306 ../gui/wxpython/psmap/dialogs.py:2000
+msgid "size:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1356 ../gui/wxpython/psmap/dialogs.py:1958
+msgid "symbol:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1372
+msgid "Display on surface(s):"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1429
+msgid "3D raster map"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1462
+msgid "isosurfaces"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1463
+msgid "slices"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1486
+msgid "Resolution:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1508 ../gui/wxpython/nviz/tools.py:3485
+msgid "List of isosurfaces"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1624
+msgid "Show light model"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1637
+msgid "Light source position"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1676
+msgid "Light color and intensity"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1690 ../gui/wxpython/nviz/preferences.py:306
+msgid "Brightness:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1700 ../gui/wxpython/nviz/preferences.py:320
+msgid "Ambient:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1762
+msgid "Edges with fringe"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1764
+msgid "N && W"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1765
+msgid "N && E"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1766
+msgid "S && W"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1767
+msgid "S && E"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1781 ../gui/wxpython/gui_core/toolbars.py:77
+#: ../gui/wxpython/gui_core/gselect.py:1101
+msgid "Settings"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1787
+msgid "Elevation of fringe from bottom:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1835 ../gui/wxpython/psmap/toolbars.py:85
+#: ../gui/wxpython/psmap/dialogs.py:4490
+#: ../gui/wxpython/mapdisp/toolbars.py:35
+msgid "North Arrow"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1840
+msgid "Arrow length (in map units):"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1850
+msgid "Arrow color:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1859
+msgid "Place arrow"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1877 ../gui/wxpython/psmap/toolbars.py:81
+msgid "Scale bar"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1882
+msgid "Scale bar length (in map units):"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1892
+msgid "Scale bar color:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1901
+msgid "Place scalebar"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1907
+msgid "Delete last"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1940
+msgid "Do you want to record new animation without saving the previous one?"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1943
+msgid "Animation already axists"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2105
+msgid "No file prefix given."
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2109
+#, python-format
+msgid "Directory %s does not exist."
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2128 ../gui/wxpython/nviz/tools.py:2173
+#: ../gui/wxpython/nviz/tools.py:4258 ../gui/wxpython/nviz/mapwindow.py:2118
+#: ../gui/wxpython/nviz/mapwindow.py:2136
+msgid "constant#"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2239
+msgid "Isosurface attributes"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2245
+msgid "toggle normal direction"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2251
+msgid "Isosurface value"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2354
+msgid "Slice attributes"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2360
+msgid "Slice parallel to axis:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2491
+msgid "W"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2492
+msgid "N"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2493
+msgid "S"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2494
+msgid "E"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2495
+msgid "NW"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2496
+msgid "NE"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2497
+msgid "SE"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2498
+msgid "SW"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2980 ../gui/wxpython/nviz/tools.py:3672
+#: ../gui/wxpython/nviz/tools.py:3674 ../gui/wxpython/nviz/tools.py:4591
+msgid "Level"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:3491
+msgid "List of slices"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:3681 ../gui/wxpython/nviz/tools.py:3683
+#: ../gui/wxpython/nviz/tools.py:3960 ../gui/wxpython/nviz/tools.py:4604
+msgid "Slice parallel to"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4264
+msgid "None"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4266 ../gui/wxpython/menustrings.py:461
+msgid "Plane"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4454
+msgid "Vector map is 3D"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4457
+msgid "Vector map is 2D"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4459
+#, python-format
+msgid "%(features)d features (%(points)d points)"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4624
+msgid "range:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4692 ../gui/wxpython/nviz/tools.py:4703
+msgid "North edge:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4693 ../gui/wxpython/nviz/tools.py:4704
+msgid "South edge:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4694 ../gui/wxpython/nviz/tools.py:4701
+#: ../gui/wxpython/nviz/tools.py:4710
+msgid "West edge:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4695 ../gui/wxpython/nviz/tools.py:4702
+#: ../gui/wxpython/nviz/tools.py:4711
+msgid "East edge:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4697 ../gui/wxpython/nviz/tools.py:4708
+#: ../gui/wxpython/nviz/tools.py:4716
+msgid "Northing (Y):"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4698 ../gui/wxpython/nviz/tools.py:4707
+#: ../gui/wxpython/nviz/tools.py:4717
+msgid "Height (Z):"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4699 ../gui/wxpython/nviz/tools.py:4706
+#: ../gui/wxpython/nviz/tools.py:4715
+msgid "Easting (X):"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4712
+msgid "Bottom edge:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4713
+msgid "Top edge:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:31
+msgid "3D view settings"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:48
+msgid "Revert settings to default, changes are not applied"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:71
+#: ../gui/wxpython/nviz/preferences.py:134
+#: ../gui/wxpython/nviz/preferences.py:152
+msgid "value:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:83
+msgid "step:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:98
+#: ../gui/wxpython/nviz/preferences.py:265
+msgid "Position:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:101
+#: ../gui/wxpython/nviz/preferences.py:268
+msgid "x:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:204
+msgid "Fly-through"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:208
+#: ../gui/wxpython/mapdisp/toolbars.py:56
+msgid "Fly-through mode"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:215
+msgid "Move exag:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:227
+msgid "Turn exag:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:257
+msgid "Light"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:292
+msgid "z:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:436
+msgid "wire color:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:475
+#: ../gui/wxpython/gmodeler/preferences.py:158
+#: ../gui/wxpython/gmodeler/preferences.py:277
+#: ../gui/wxpython/gmodeler/preferences.py:362
+#: ../gui/wxpython/psmap/dialogs.py:2722
+#: ../gui/wxpython/gui_core/dialogs.py:2166
+msgid "Width:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:515
+msgid "Size:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:530
+msgid "Marker:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:628
+#, python-format
+msgid "3D view settings saved to file <%s>."
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:506
+#, python-format
+msgid ""
+"Image is too large, your OpenGL implementation supports maximum texture size "
+"%d px."
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1013
+msgid "Easting"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1014
+msgid "Northing"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1015
+msgid "Elevation"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1022
+msgid "Surface map name"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1023
+msgid "Surface map elevation"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1024
+msgid "Surface map color"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1033
+msgid "XY distance from previous"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1034
+msgid "XYZ distance from previous"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1035
+msgid "Distance along surface"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1040
+msgid "Distance along exag. surface"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1047
+msgid "No point on surface"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1497
+msgid "Loading raster map"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1501
+msgid "Loading 3d raster map"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1507
+msgid "failed"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1509
+#, python-format
+msgid "Unsupported layer type '%s'"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1618
+msgid "Unable to unload raster map"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1623
+msgid "Unable to unload 3d raster map"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1624
+msgid "3d raster map"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1634
+msgid "unloaded successfully"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1686
+#, python-format
+msgid "Loading vector map <%(name)s> (%(type)s) failed"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1745
+#, python-format
+msgid "Unable to unload vector map <%(name)s> (%(type)s)"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1748
+#, python-format
+msgid "Vector map <%(name)s> (%(type)s) unloaded successfully"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:2081
+#, python-format
+msgid "Vector point layer not found (id = %d)"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:2083
+#, python-format
+msgid "Unable to set data layer properties (id = %d)"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:2086
+#, python-format
+msgid ""
+"Setting data layer properties failed.\n"
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:2193
+msgid "At least one raster map required"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:145
+msgid "Loading data..."
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:152
+#, python-format
+msgid ""
+"Attribute table <%s> not found. For creating the table switch to 'Manage "
+"layers' tab."
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:163
+#, python-format
+msgid "Column <%(column)s> not found in in the table <%(table)s>."
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:234
+msgid "Can display only 256 columns."
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:250
+msgid "Limit 100000 records."
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:267 ../gui/wxpython/dbmgr/manager.py:821
+#: ../gui/wxpython/dbmgr/manager.py:1155 ../gui/wxpython/dbmgr/manager.py:1812
+#: ../gui/wxpython/dbmgr/manager.py:1834 ../gui/wxpython/dbmgr/manager.py:1978
+#, python-format
+msgid "Number of loaded records: %d"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:291
+msgid "Unknown value"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:297 ../gui/wxpython/dbmgr/vinfo.py:42
+msgid "Unable to decode value. Set encoding in GUI preferences ('Attributes')."
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:306
+#, python-format
+msgid ""
+"Error loading attribute data. Record number: %(rec)d. Unable to convert "
+"value '%(val)s' in key column (%(key)s) to integer.\n"
+"\n"
+"Details: %(detail)s"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:388
+msgid "Sort ascending"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:389
+msgid "Sort descending"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:392
+msgid "Calculate (only numeric columns)"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:398
+msgid "Area size"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:399
+msgid "Line length"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:400
+msgid "Compactness of an area"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:401
+msgid "Fractal dimension of boundary defining a polygon"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:402
+msgid "Perimeter length of an area"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:403
+msgid "Number of features for each category"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:404
+msgid "Slope steepness of 3D line"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:405
+msgid "Line sinuousity"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:406
+msgid "Line azimuth"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:565 ../gui/wxpython/dbmgr/manager.py:3091
+msgid "GRASS GIS Attribute Table Manager"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:595
+#, python-format
+msgid ""
+"Database connection for vector map <%s> is not defined in DB file. You can "
+"define new connection in 'Manage layers' tab."
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:621
+msgid "Browse data"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:627
+msgid "Manage tables"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:635
+msgid "Manage layers"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:652
+msgid "Close Attribute Table Manager"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:654
+msgid "Reload attribute data (selected layer only)"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:684
+msgid "Attribute data - right-click to edit/manage records"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:697 ../gui/wxpython/dbmgr/manager.py:837
+#: ../gui/wxpython/dbmgr/manager.py:2302 ../gui/wxpython/dbmgr/manager.py:2432
+#: ../gui/wxpython/dbmgr/manager.py:2686
+msgid "Table"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:699 ../gui/wxpython/dbmgr/manager.py:839
+#: ../gui/wxpython/dbmgr/manager.py:1009
+msgid " (readonly)"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:707
+msgid "SQL Query"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:726
+msgid "Apply SELECT statement and reload data records"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:728 ../gui/wxpython/dbmgr/manager.py:2035
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:454
+msgid "SQL Builder"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:732
+msgid "Simple"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:735
+msgid "Advanced"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:749 ../gui/wxpython/dbmgr/manager.py:755
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:108
+#, python-format
+msgid "Example: %s"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:850 ../gui/wxpython/dbmgr/sqlbuilder.py:87
+msgid "Database connection"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:862
+#, python-format
+msgid "Table <%s> - right-click to delete column(s)"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:873
+#: ../gui/wxpython/modules/colorrules.py:979
+msgid "Add column"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:881 ../gui/wxpython/dbmgr/manager.py:932
+msgid "Column"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:908
+msgid "Length"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:924 ../gui/wxpython/menustrings.py:837
+msgid "Rename column"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:944
+#: ../gui/wxpython/gmodeler/dialogs.py:265
+msgid "To"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:951
+msgid "&Rename"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:1007
+msgid "Layers of vector map"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:1020
+msgid "List of layers"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:1120 ../gui/wxpython/core/settings.py:714
+msgid "Edit selected record"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:1124 ../gui/wxpython/dbmgr/manager.py:1365
+msgid "Insert new record"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:1125
+msgid "Delete selected record(s)"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:1126
+msgid "Delete all records"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:1132
+#: ../gui/wxpython/gui_core/dialogs.py:1341
+#: ../gui/wxpython/gui_core/dialogs.py:1935
+msgid "Select all"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:1133
+#: ../gui/wxpython/gui_core/dialogs.py:1343
+#: ../gui/wxpython/gui_core/dialogs.py:1936
+msgid "Deselect all"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:1135
+msgid "Highlight selected features"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:1136
+msgid "Highlight selected features and zoom"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:1140 ../gui/wxpython/dbmgr/manager.py:2077
+msgid "Extract selected features"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:1141
+msgid "Delete selected features"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:1149 ../gui/wxpython/dbmgr/manager.py:1664
+#: ../gui/wxpython/gmodeler/dialogs.py:731
+#: ../gui/wxpython/gmodeler/dialogs.py:906
+#: ../gui/wxpython/vdigit/dialogs.py:278
+msgid "Reload"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:1181
+#, python-format
+msgid ""
+"Selected data records (%d) will be permanently deleted from table. Do you "
+"want to delete them?"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:1184 ../gui/wxpython/dbmgr/manager.py:1230
+#: ../gui/wxpython/gmodeler/dialogs.py:851
+msgid "Delete records"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:1227
+#, python-format
+msgid ""
+"All data records (%d) will be permanently deleted from table. Do you want to "
+"delete them?"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:1376
+#, python-format
+msgid "Record with category number %d already exists in the table."
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:1386
+#, python-format
+msgid "Category number (column %s) is missing."
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:1400 ../gui/wxpython/dbmgr/manager.py:1509
+#, python-format
+msgid "Value '%(value)s' needs to be entered as %(type)s."
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:1411
+#, python-format
+msgid ""
+"Unable to insert new record.\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:1482
+msgid "Update existing record"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:1522
+#, python-format
+msgid ""
+"Unable to update existing record.\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:1608
+msgid "Unable to rename column. No column name defined."
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:1616
+#, python-format
+msgid ""
+"Unable to rename column <%(column)s> to <%(columnTo)s>. Column already "
+"exists in the table <%(table)s>."
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:1632
+#, python-format
+msgid ""
+"Unable to rename column. Column <%(column)s> doesn't exist in the table <"
+"%(table)s>."
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:1659
+msgid "Drop selected column"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:1662
+msgid "Drop all columns"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:1677
+#, python-format
+msgid ""
+"Selected column '%s' will PERMANENTLY removed from table. Do you want to "
+"drop the column?"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:1680 ../gui/wxpython/dbmgr/manager.py:1717
+msgid "Drop column(s)"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:1714
+#, python-format
+msgid ""
+"Selected columns\n"
+"%s\n"
+"will PERMANENTLY removed from table. Do you want to drop the columns?"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:1752
+msgid "Unable to add column to the table. No column name defined."
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:1773
+#, python-format
+msgid "Column <%(column)s> already exists in table <%(table)s>."
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:1940 ../gui/wxpython/dbmgr/manager.py:1963
+#, python-format
+msgid ""
+"Loading attribute data failed.\n"
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:1951
+#, python-format
+msgid ""
+"Invalid SQL select statement.\n"
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:2073
+msgid "Nothing to extract."
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:2103
+msgid "Nothing to delete."
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:2193 ../gui/wxpython/dbmgr/manager.py:2608
+#: ../gui/wxpython/dbmgr/manager.py:3028
+#, python-format
+msgid "Drop also linked attribute table (%s)"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:2248
+msgid "Column name"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1273
+#: ../gui/wxpython/gmodeler/frame.py:1323
+msgid "Data type"
+msgstr ""
+msgid "Data length"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:2302 ../gui/wxpython/dbmgr/manager.py:2415
+#: ../gui/wxpython/dbmgr/manager.py:2666 ../gui/wxpython/dbmgr/dialogs.py:481
+#: ../gui/wxpython/vdigit/preferences.py:362
+#: ../gui/wxpython/vdigit/preferences.py:364
+#: ../gui/wxpython/vdigit/dialogs.py:111 ../gui/wxpython/vdigit/dialogs.py:555
+msgid "Layer"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:2302 ../gui/wxpython/dbmgr/manager.py:2421
+#: ../gui/wxpython/dbmgr/manager.py:2674
+msgid "Driver"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:2302 ../gui/wxpython/dbmgr/manager.py:2426
+#: ../gui/wxpython/dbmgr/manager.py:2680
+#: ../gui/wxpython/gui_core/gselect.py:1130
+msgid "Database"
+msgstr ""
+msgid "Key"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:2378
+msgid ""
+"Unknown default DB connection. Please define DB connection using db.connect "
+"module."
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:2397
+msgid "Add layer"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:2407
+msgid "Layer description"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:2437 ../gui/wxpython/dbmgr/manager.py:2475
+#: ../gui/wxpython/dbmgr/manager.py:2692
+msgid "Key column"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:2442
+msgid "Insert record for each category into table"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:2457
+msgid "You need to add categories by v.category module."
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:2462
+msgid "Table description"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:2470
+msgid "Table name"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:2483
+msgid "&Create table"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:2487
+msgid "&Add layer"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:2491
+msgid "&Set default"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:2591
+msgid "Remove layer"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:2594
+msgid "Layer to remove"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:2615
+msgid "&Remove layer"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:2659
+msgid "Modify layer"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:2731
+msgid "&Modify layer"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:2779
+msgid ""
+"Unable to get list of tables.\n"
+"Please use db.connect to set database parameters."
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:2876
+msgid "Unable to create new table. Table name or key column name is missing."
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:2882
+#, python-format
+msgid "Unable to create new table. Table <%s> already exists in the database."
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:2919
+#, python-format
+msgid ""
+"Unable to add new layer to vector map <%(vector)s>. Layer %(layer)d already "
+"exists."
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:68
+#, python-format
+msgid "GRASS SQL Builder (%(type)s): vector map <%(map)s>"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:75
+msgid "SQL statement not verified"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:99 ../gui/wxpython/menustrings.py:819
+msgid "Query"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:117
+msgid "Set SQL statement to default"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:119
+msgid "Verify"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:120
+msgid "Verify SQL statement"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:122
+msgid "Apply SQL statement and close the dialog"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:124
+msgid "Close the dialog"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:173
+msgid "Columns"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:183
+msgid "Add on double-click"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:184
+msgid "columns"
+msgstr ""
+msgid "values"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:195
+msgid "Values"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:204
+msgid "Get all values"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:207
+msgid "Get sample"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:227
+msgid "Close dialog on apply"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:423
+msgid "SQL statement is not valid"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:425
+#, python-format
+msgid ""
+"SQL statement is not valid.\n"
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:427
+msgid "SQL statement is valid"
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:71
+#, python-format
+msgid ""
+"No attribute table found.\n"
+"\n"
+"Do you want to create a new attribute table and defined a link to vector map "
+"<%s>?"
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:74
+msgid "Create table?"
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:94
+msgid "Close dialog on submit"
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:106
+msgid "No attributes found"
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:112 ../gui/wxpython/menustrings.py:649
+msgid "Update attributes"
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:114
+msgid "Define attributes"
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:116
+msgid "Display attributes"
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:120
+msgid "&Reload"
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:121 ../gui/wxpython/dbmgr/dialogs.py:585
+msgid "&Submit"
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:139 ../gui/wxpython/vdigit/dialogs.py:166
+msgid "Feature id:"
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:226
+#, python-format
+msgid "Column <%(col)s>: Value '%(value)s' needs to be entered as %(type)s."
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:424
+msgid "Unknown"
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:482 ../gui/wxpython/dbmgr/dialogs.py:600
+#: ../gui/wxpython/vdigit/dialogs.py:118 ../gui/wxpython/vdigit/dialogs.py:556
+msgid "Category"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2 ../gui/wxpython/menustrings.py:854
+msgid "&File"
+msgstr ""
+msgid "Workspace"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:5
+msgid "Create new workspace"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:6 ../gui/wxpython/menustrings.py:857
+msgid "Open"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:7
+msgid "Load workspace from file"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:8 ../gui/wxpython/menustrings.py:859
+#: ../gui/wxpython/modules/colorrules.py:406
+msgid "Save"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:10 ../gui/wxpython/menustrings.py:861
+msgid "Save as"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:11
+msgid "Save workspace to file"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:12 ../gui/wxpython/menustrings.py:863
+msgid "Close"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:13
+msgid "Close workspace file"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:14
+msgid "Load GRC file (Tcl/Tk GUI)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:15
+msgid "Load map layers from GRC file to layer tree"
+msgstr ""
+msgid "Map display"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:17
+msgid "Add raster"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:18
+msgid "Add raster map layer to current display"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:19
+msgid "Add vector"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:20
+msgid "Add vector map layer to current display"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:21
+msgid "Add multiple rasters or vectors"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:22
+msgid "Add multiple raster or vector map layers to current display"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:23
+msgid "New map display window"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:24
+msgid "Open new map display window"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:25 ../gui/wxpython/menustrings.py:26
+msgid "Close current map display window"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:27 ../gui/wxpython/menustrings.py:28
+msgid "Close all open map display windows"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:30
+msgid "Common formats import"
+msgstr ""
+msgid "Import raster data into a GRASS map layer using GDAL."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:32
+msgid "ASCII x,y,z point import and gridding"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:33
+msgid ""
+"Create a raster map from an assemblage of many coordinates using univariate "
+"statistics."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:34
+msgid "ASCII grid import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:35
+msgid "Converts ASCII raster file to binary raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:36
+msgid "ASCII polygons and lines import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:37
+msgid "Creates raster maps from ASCII polygon/line/point data files."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:38
+msgid "Binary file import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:39
+msgid "Import a binary raster file into a GRASS raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:40
+msgid "ESRI ASCII grid import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:41
+msgid ""
+"Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster "
+"map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:42
+msgid "GRIDATB.FOR import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:43
+msgid "Imports GRIDATB.FOR map file (TOPMODEL) into GRASS raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:44
+msgid "Matlab 2D array import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:45
+msgid "Imports a binary MAT-File(v4) to a GRASS raster."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:46
+msgid "SPOT NDVI import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:47
+msgid "Import of SPOT VGT NDVI file into a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:48
+msgid "SRTM HGT import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:49
+msgid "Import SRTM HGT files into GRASS"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:50
+msgid "Terra ASTER HDF import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:51
+msgid ""
+"Georeference, rectify and import Terra-ASTER imagery and relative DEM's "
+"using gdalwarp."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:52
+msgid "WMS import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:53
+msgid "Downloads and imports data from WMS servers"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:54
+msgid "Unpack raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:55
+msgid "Unpacks a raster map packed with r.pack."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:57
+msgid "Common import formats"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:58
+msgid "Converts vector layers into a GRASS vector map using OGR."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:59
+msgid "ASCII points/GRASS ASCII vector import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:60
+msgid "Creates a vector map from ASCII points file or ASCII vector file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:61
+msgid "ASCII points as a vector lines"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:62
+msgid "Import ASCII x,y[,z] coordinates as a series of lines."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:63
+msgid "Historical GRASS vector import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:64
+msgid "Imports older versions of GRASS vector maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:65
+msgid "Historical GRASS vector import (all maps)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:66
+msgid ""
+"Converts all older versions of GRASS vector maps in current mapset to "
+"current format."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:67
+msgid "DXF import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:68
+msgid "Converts files in DXF format to GRASS vector map format."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:69
+msgid "WFS"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:70
+msgid "Import GetFeature from WFS"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:71
+msgid "ESRI e00 import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:72
+msgid "Import E00 file into a vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:73
+msgid "Garmin GPS import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:74
+msgid ""
+"Download waypoints, routes, and tracks from a Garmin GPS receiver into a "
+"vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:75
+msgid "GPSBabel GPS import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:76
+msgid ""
+"Import waypoints, routes, and tracks from a GPS receiver or GPS download "
+"file into a vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:77
+msgid "Geonames import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:78
+msgid "Imports geonames.org country files into a GRASS vector points map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:79
+msgid "GEOnet import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:80
+msgid ""
+"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
+"points map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:81
+msgid "Matlab array or Mapgen format import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:82
+msgid "Imports Mapgen or Matlab-ASCII vector maps into GRASS."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:83
+msgid "Import 3D raster data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:84
+msgid "ASCII 3D import"
+msgstr ""
+msgid ""
+"Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:86
+msgid "Vis5D import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:87
+msgid ""
+"Imports 3-dimensional Vis5D files (i.e. the V5D file with 1 variable and 1 "
+"time step)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:88
+msgid "Import database table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:89
+msgid "Multiple import formats using OGR"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:90
+msgid "Imports attribute tables in various formats."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:91
+msgid "Export raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:92 ../gui/wxpython/menustrings.py:125
+msgid "Common export formats"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:93
+msgid "Exports GRASS raster maps into GDAL supported formats."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:94
+msgid "ASCII grid export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:95
+msgid "Converts a raster map layer into an ASCII text file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:96
+msgid "ASCII x,y,z points export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:97
+msgid ""
+"Export a raster map to a text file as x,y,z values based on cell centers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:98
+msgid "ESRI ASCII grid export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:99
+msgid "Converts a raster map layer into an ESRI ARCGRID file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:100
+msgid "GRIDATB.FOR export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:101
+msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:102
+msgid "Matlab 2D array export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:103
+msgid "Exports a GRASS raster to a binary MAT-File."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:104
+msgid "Raw binary array export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:105
+msgid "Exports a GRASS raster map to a binary array."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:106
+msgid "MPEG-1 export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:107
+msgid "Raster File Series to MPEG Conversion."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:108
+msgid "PNG export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:109
+msgid "Export GRASS raster as non-georeferenced PNG image."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:110
+msgid "PPM export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:111
+msgid ""
+"Converts a GRASS raster map to a PPM image file at the pixel resolution of "
+"the currently defined region."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:112
+msgid "PPM from RGB export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:113
+msgid ""
+"Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
+"resolution of the CURRENTLY DEFINED REGION."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:114 ../gui/wxpython/menustrings.py:133
+msgid "POV-Ray export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:115
+msgid "Converts a raster map layer into a height-field file for POVRAY."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:116
+msgid "TIFF export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:117
+msgid ""
+"Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
+"resolution of the currently defined region."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:118
+msgid "VRML export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:119
+msgid "Export a raster map to the Virtual Reality Modeling Language (VRML)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:120 ../gui/wxpython/menustrings.py:137
+#: ../gui/wxpython/menustrings.py:144
+msgid "VTK export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:121
+msgid "Converts raster maps into the VTK-Ascii format"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:122
+msgid "Pack raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:123
+msgid "Packs up a raster map and support files for copying."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:124
+msgid "Export vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:126
+msgid "Converts GRASS vector map to one of the supported OGR vector formats."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:127
+msgid "ASCII points/GRASS ASCII vector export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:128
+msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:129
+msgid "DXF export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:130
+msgid "Exports GRASS vector map layers to DXF file format."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:131
+msgid "Multiple GPS export formats using GPSBabel"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:132
+msgid ""
+"Exports a vector map to a GPS receiver or file format supported by GpsBabel."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:134
+msgid "Converts to POV-Ray format, GRASS x,y,z -> POV-Ray x,z,y"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:135
+msgid "SVG export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:136
+msgid "Exports a GRASS vector map to SVG."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:138
+msgid "Converts a GRASS binary vector map to VTK ASCII output."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:139
+msgid "Export 3D raster maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:140
+msgid "ASCII 3D export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:141
+msgid "Converts a 3D raster map layer into an ASCII text file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:142
+msgid "Vis5D export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:143
+msgid "Exports GRASS 3D raster map to 3-dimensional Vis5D file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:145
+msgid "Converts 3D raster maps into the VTK-ASCII format."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:146
+msgid "Export database table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:147
+msgid "Common export formats using OGR"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:148
+msgid "Exports attribute tables into various formats."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:149
+msgid "Link external formats"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:151
+msgid "Link GDAL supported raster data as a pseudo GRASS raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:153
+msgid "Creates a new pseudo-vector map as a link to an OGR-supported layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:154
+msgid "Manage maps and volumes"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:155
+msgid "Copy"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:156
+msgid ""
+"Copies available data files in the user's current mapset search path and "
+"location to the appropriate element directories under the user's current "
+"mapset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:157
+msgid "List"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:158
+msgid "Lists available GRASS data base files of the user-specified data type."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:159
+msgid "List filtered"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:160
+msgid ""
+"Lists available GRASS data base files of the user-specified data type "
+"optionally using the search pattern."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:162
+msgid "Renames data base element files in the user's current mapset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:164 ../gui/wxpython/menustrings.py:166
+msgid "Removes data base element files from the user's current mapset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:165
+msgid "Delete filtered"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:167 ../gui/wxpython/menustrings.py:298
+#: ../gui/wxpython/menustrings.py:577 ../gui/wxpython/menustrings.py:776
+msgid "Map type conversions"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:168 ../gui/wxpython/menustrings.py:299
+msgid "Raster to vector"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:169 ../gui/wxpython/menustrings.py:300
+msgid "Converts a raster map into a vector map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:170 ../gui/wxpython/menustrings.py:301
+msgid "Raster series to volume"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:171 ../gui/wxpython/menustrings.py:302
+msgid "Converts 2D raster map slices to one 3D raster volume map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:172 ../gui/wxpython/menustrings.py:303
+msgid "Raster 2.5D to volume"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:173 ../gui/wxpython/menustrings.py:304
+msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:174 ../gui/wxpython/menustrings.py:578
+msgid "Vector to raster"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:175 ../gui/wxpython/menustrings.py:579
+msgid "Converts (rasterize) a vector map into a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:176 ../gui/wxpython/menustrings.py:580
+msgid "Vector to volume"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:177 ../gui/wxpython/menustrings.py:581
+msgid ""
+"Converts a binary GRASS vector map (only points) layer into a 3D GRASS "
+"raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:178 ../gui/wxpython/menustrings.py:582
+msgid "2D vector to 3D vector"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:179 ../gui/wxpython/menustrings.py:583
+msgid "Performs transformation of 2D vector features to 3D."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:180 ../gui/wxpython/menustrings.py:584
+msgid "Sites to vector"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:181 ../gui/wxpython/menustrings.py:585
+msgid "Converts a GRASS site_lists file into a vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:182 ../gui/wxpython/menustrings.py:777
+msgid "Volume to raster series"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:183 ../gui/wxpython/menustrings.py:778
+msgid "Converts 3D raster maps to 2D raster maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:184
+msgid "Georectify"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:185
+msgid "Manage Ground Control Points for Georectification"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:186
+msgid "Graphical modeler"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:187
+msgid "Launch Graphical modeler"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:188 ../gui/wxpython/menustrings.py:891
+msgid "Run model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:189
+msgid "Run model prepared by Graphical modeler"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:190
+msgid "NVIZ (requires Tcl/Tk)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:191
+msgid "nviz - Visualization and animation tool for GRASS data."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:192
+msgid "3D image rendering"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:193
+msgid "Creates a 3D rendering of GIS data."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:194
+msgid "Bearing/distance to coordinates"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:195
+msgid ""
+"A simple utility for converting bearing and distance measurements to "
+"coordinates and vice versa."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:197
+msgid "Launch Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:198
+msgid "Launch script"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:199
+msgid "Launches script file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:200
+msgid "Exit GUI"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:201
+msgid "Quit wxGUI session"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:202 ../gui/wxpython/menustrings.py:871
+msgid "&Settings"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:203
+msgid "Region"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:204
+msgid "Display region"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:205 ../gui/wxpython/menustrings.py:207
+msgid "Manages the boundary definitions for the geographic region."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:206
+msgid "Set region"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:208
+msgid "GRASS working environment"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:209
+msgid "Mapset access"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:210
+msgid "Set/unset access to other mapsets in current location"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:211
+msgid "User access"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:212
+msgid "Controls access to the current mapset for other users on the system."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:213
+msgid "Change working environment"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:214
+msgid "Changes current mapset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:215
+msgid "Change location and mapset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:216
+msgid "Change current location and mapset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:217
+msgid "Change mapset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:218
+msgid "Change current mapset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:219
+msgid "Show settings"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:220 ../gui/wxpython/menustrings.py:222
+msgid "Outputs and modifies the user's current GRASS variable settings."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:221
+msgid "Change settings"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:223
+msgid "Change default GUI"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:224
+msgid "Changes the default GRASS graphical user interface (GUI) setting."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:225
+msgid "Create new location"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:226
+msgid "Launches location wizard to create new GRASS location."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:228
+msgid "Creates new mapset in the current location, changes current mapset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:229
+msgid "Version"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:230
+msgid "Displays version and copyright information."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:231
+msgid "Map projections"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:232
+msgid "Display map projection"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:233
+msgid "Print projection information (in conventional GRASS format)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:234
+msgid "Manage projections"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:235
+msgid ""
+"Converts co-ordinate system descriptions (i.e. projection information) "
+"between various formats (including GRASS format)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:236
+msgid "Change projection for current location"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:237
+msgid "Interactively reset the location's projection settings."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:238
+msgid "Convert coordinates"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:239
+msgid "Convert coordinates from one projection to another (cs2cs frontend)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:240
+msgid "Install extension from add-ons"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:241
+msgid "Installs new extension from GRASS AddOns SVN repository."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:242
+msgid "Update installed extensions"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:243
+msgid "Rebuilds all locally installed GRASS Addons extensions."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:244
+#: ../gui/wxpython/modules/extensions.py:461
+msgid "Remove extension"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:245
+msgid "Removes installed GRASS AddOns extension."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:246 ../gui/wxpython/menustrings.py:872
+msgid "Preferences"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:247
+msgid "User GUI preferences (display font, commands, digitizer, etc.)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:248
+msgid "&Raster"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:249
+msgid "Develop raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:250
+msgid "Digitize raster (requires XTerm)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:251
+msgid ""
+"Interactive tool used to draw and save vector features on a graphics monitor "
+"using a pointing device (mouse) and save to a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:252
+msgid "Compress/decompress"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:253
+msgid "Compresses and decompresses raster maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:254
+msgid "Region boundaries"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:255
+msgid "Sets the boundary definitions for a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:256
+msgid "Manage NULL values"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:257
+msgid "Manages NULL-values of given raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:258
+msgid "Quantization"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:259
+msgid "Produces the quantization file for a floating-point map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:260
+msgid "Timestamp"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:261
+msgid "Modifies a timestamp for a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:262
+msgid "Resample using aggregate statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:263
+msgid "Resamples raster map layers to a coarser grid using aggregation."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:264
+msgid "Resample using multiple methods"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:265
+msgid "Resamples raster map layers to a finer grid using interpolation."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:266
+msgid "Resample using nearest neighbor"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:267
+msgid "GRASS raster map layer data resampling capability."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:268
+msgid "Resample using spline tension"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:269
+msgid ""
+"Reinterpolates and optionally computes topographic analysis from input "
+"raster map to a new raster map (possibly with different resolution) using "
+"regularized spline with tension and smoothing."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:270 ../gui/wxpython/menustrings.py:543
+msgid "Support file maintenance"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:271
+msgid "Allows creation and/or modification of raster map layer support files."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:272
+msgid "Update map statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:273
+msgid "Update raster map statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:274
+msgid "Reproject raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:275
+msgid "Re-projects a raster map from one location to the current location."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:276
+msgid "Tiling"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:277
+msgid ""
+"Produces tilings of the source projection for use in the destination region "
+"and projection."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:278 ../gui/wxpython/menustrings.py:562
+msgid "Manage colors"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:279 ../gui/wxpython/menustrings.py:563
+msgid "Color tables"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:280
+msgid "Creates/modifies the color table associated with a raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:281
+msgid "Color tables (stddev)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:282
+msgid "Set color rules based on stddev from a map's mean value."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:283 ../gui/wxpython/menustrings.py:565
+msgid "Color rules"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:284
+msgid "Interactive management of raster color tables."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:285
+msgid "Export color table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:286
+msgid "Exports the color table associated with a raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:287
+msgid "Blend 2 color rasters"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:288
+msgid "Blends color components of two raster maps by a given ratio."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:289
+msgid "Create RGB"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:290
+msgid ""
+"Combines red, green and blue raster maps into a single composite raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:291 ../gui/wxpython/menustrings.py:712
+msgid "RGB to HIS"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:292
+msgid ""
+"Generates red, green and blue raster map layers combining hue, intensity and "
+"saturation (HIS) values from user-specified input raster map layers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:293
+msgid "Query raster maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:294
+msgid "Query values by coordinates"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:295
+msgid "Queries raster map layers on their category values and category labels."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:296
+msgid "Query colors by value"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:297
+msgid "Queries colors for a raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:305
+msgid "Buffer rasters"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:306
+msgid ""
+"Creates a raster map layer showing buffer zones surrounding cells that "
+"contain non-NULL category values."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:307
+msgid "Concentric circles"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:308
+msgid "Creates a raster map containing concentric rings around a given point."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:309
+msgid "Closest points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:310
+msgid "Locates the closest points between objects in two raster maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:312
+msgid "Creates a MASK for limiting raster operation."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:313
+msgid "Raster map calculator"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:314
+msgid "Map calculator for raster map algebra."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:315
+msgid "Neighborhood analysis"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:316
+msgid "Moving window"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:317
+msgid ""
+"Makes each cell category value a function of the category values assigned to "
+"the cells around it, and stores new cell values in an output raster map "
+"layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:318
+msgid "Neighborhood points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:319
+msgid ""
+"Makes each cell value a function of the attribute values assigned to the "
+"vector points or centroids around it, and stores new cell values in an "
+"output raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:320
+msgid "Overlay rasters"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:321
+msgid "Cross product"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:322
+msgid ""
+"Creates a cross product of the category values from multiple raster map "
+"layers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:323
+msgid "Raster series"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:324
+msgid ""
+"Makes each output cell value a function of the values assigned to the "
+"corresponding cells in the input raster map layers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:325
+msgid "Patch raster maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:326
+msgid ""
+"Creates a composite raster map layer by using known category values from one "
+"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:327
+msgid "Statistical overlay"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:328
+msgid "Calculates category or object oriented statistics."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:329
+msgid "Solar radiance and shadows"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:330
+msgid "Solar irradiance and irradiation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:331
+msgid "Solar irradiance and irradiation model."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:332
+msgid "Shadows map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:333
+msgid ""
+"Calculates cast shadow areas from sun position and elevation raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:334
+msgid "Terrain analysis"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:335
+msgid "Generate contour lines"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:336
+msgid "Produces a vector map of specified contours from a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:337
+msgid "Cost surface"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:338
+msgid ""
+"Creates a raster map showing the cumulative cost of moving between different "
+"geographic locations on an input raster map whose cell category values "
+"represent cost."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:339
+msgid "Cumulative movement costs"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:340
+msgid ""
+"Outputs a raster map layer showing the anisotropic cumulative cost of moving "
+"between different geographic locations on an input elevation raster map "
+"layer whose cell category values represent elevation combined with an input "
+"raster map layer whose cell values represent friction cost."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:341
+msgid "Least cost route or flow"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:342
+msgid "Traces a flow through an elevation model on a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:343
+msgid "Shaded relief"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:344
+msgid "Creates shaded relief map from an elevation map (DEM)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:345
+msgid "Slope and aspect"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:346
+msgid ""
+"Generates raster maps of slope, aspect, curvatures and partial derivatives "
+"from a elevation raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:347
+msgid "Terrain parameters"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:348
+msgid "Extracts terrain parameters from a DEM."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:349
+msgid "Textural features"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:350
+msgid "Generate images with textural features from a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:351
+msgid "Visibility"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:352
+msgid "Line-of-sight raster analysis program."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:353
+msgid "Distance to features"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:354
+msgid "Generates a raster map layer of distance to features in input layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:355
+msgid "Horizon angle"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:356
+msgid "Horizon angle computation from a digital elevation model."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:357
+msgid "Transform features"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:358
+msgid "Clump"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:359
+msgid ""
+"Recategorizes data in a raster map by grouping cells that form physically "
+"discrete areas into unique categories."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:360
+msgid "Grow"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:361
+msgid "Generates a raster map layer with contiguous areas grown by one cell."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:362
+msgid "Thin"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:363
+msgid "Thins non-zero cells that denote linear features in a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:364
+msgid "Hydrologic modeling"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:365
+msgid "Carve stream channels"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:366
+msgid ""
+"Takes vector stream data, transforms it to raster and subtracts depth from "
+"the output DEM."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:367
+msgid "Fill lake"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:368
+msgid "Fills lake from seed at given level."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:369
+msgid "Depressionless map and flowlines"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:370
+msgid ""
+"Filters and generates a depressionless elevation map and a flow direction "
+"map from a given elevation raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:371
+msgid "Flow accumulation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:372
+msgid "Flow computation for massive grids (float version)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:373
+msgid "Flow lines"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:374
+msgid ""
+"Construction of slope curves (flowlines), flowpath lengths, and flowline "
+"densities (upslope areas) from a raster digital elevation model (DEM)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:375
+msgid "Watershed analysis"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:376
+msgid "Watershed basin analysis program."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:377
+msgid "Watershed subbasins"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:378
+msgid "Generates watershed subbasins raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:379
+msgid "Watershed basin creation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:380
+msgid "Watershed basin creation program."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:381 ../gui/wxpython/menustrings.py:785
+msgid "Groundwater modeling"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:382
+msgid ""
+"Numerical calculation program for transient, confined and unconfined "
+"groundwater flow in two dimensions."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:383
+msgid "SIMWE Overland flow modeling"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:384
+msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:385
+msgid "SIMWE Sediment flux modeling"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:386
+msgid ""
+"Sediment transport and erosion/deposition simulation using path sampling "
+"method (SIMWE)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:387
+msgid "Topographic index map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:388
+msgid "Creates topographic index map from elevation raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:389
+msgid "TOPMODEL simulation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:390
+msgid "Simulates TOPMODEL which is a physically based hydrologic model."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:391
+msgid "Landscape structure modeling"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:392
+msgid "Set up (requires XTerm)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:393
+msgid ""
+"Interactive tool used to setup the sampling and analysis framework that will "
+"be used by the other r.le programs."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:394
+msgid "Analyze landscape"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:395
+msgid ""
+"Contains a set of measures for attributes, diversity, texture, "
+"juxtaposition, and edge."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:396
+msgid "Analyze patches"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:397
+msgid ""
+"Calculates attribute, patch size, core (interior) size, shape, fractal "
+"dimension, and perimeter measures for sets of patches in a landscape."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:398
+msgid "Summary and display (requires XTerm)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:399
+msgid ""
+"Displays the boundary of each r.le patch and shows how the boundary is "
+"traced, displays the attribute, size, perimeter and shape indices for each "
+"patch and saves the data in an output file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:400
+msgid "Landscape patch analysis"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:401
+msgid "Set up sampling and analysis framework"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:402
+msgid "Configuration editor for r.li.'index'"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:403
+msgid "Edge density"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:404
+msgid ""
+"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:405
+msgid "Contrast weighted edge density"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:406
+msgid "Calculates contrast weighted edge density index on a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:407
+msgid "Patch area mean"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:408
+msgid ""
+"Calculates mean patch size index on a raster map, using a 4 neighbour "
+"algorithm"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:409
+msgid "Patch area range"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:410
+msgid "Calculates range of patch area size on a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:411
+msgid "Patch area Std Dev"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:412
+msgid "Calculates standard deviation of patch area a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:413
+msgid "Patch area Coeff Var"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:414
+msgid "Calculates coefficient of variation of patch area on a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:415
+msgid "Patch density"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:416
+msgid ""
+"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:417
+msgid "Patch number"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:418
+msgid ""
+"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:419
+msgid "Dominance's diversity"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:420 ../gui/wxpython/menustrings.py:426
+msgid "Calculates dominance's diversity index on a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:421
+msgid "Shannon's diversity"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:422
+msgid "Calculates Shannon's diversity index on a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:423
+msgid "Simpson's diversity"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:424
+msgid "Calculates Simpson's diversity index on a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:425
+msgid "Richness"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:427
+msgid "Shape index"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:428
+msgid "Calculates shape index on a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:429
+msgid "Wildfire modeling"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:430
+msgid "Rate of spread"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:431
+msgid ""
+"Generates three, or four raster map layers showing 1) the base "
+"(perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the "
+"direction of the maximum ROS, and optionally 4) the maximum potential "
+"spotting distance."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:432
+msgid "Least-cost spread paths"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:433
+msgid ""
+"Recursively traces the least cost path backwards to cells from which the "
+"cumulative cost was determined."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:434
+msgid "Anisotropic spread simulation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:435
+msgid ""
+"Simulates elliptically anisotropic spread on a graphics window and generates "
+"a raster map of the cumulative time of spread, given raster maps containing "
+"the rates of spread (ROS), the ROS directions and the spread origins."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:436
+msgid "Change category values and labels"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:437
+msgid "Interactively edit category values"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:438
+msgid "Interactively edit cell values in a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:439
+msgid "Reclassify by size"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:440
+msgid ""
+"Reclasses a raster map greater or less than user specified area size (in "
+"hectares)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:441 ../gui/wxpython/menustrings.py:647
+msgid "Reclassify"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:442
+msgid ""
+"Creates a new map layer whose category values are based upon a "
+"reclassification of the categories in an existing raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:443
+msgid "Recode"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:444
+msgid "Recodes categorical raster maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:445
+msgid "Rescale"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:446
+msgid "Rescales the range of category values in a raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:447
+msgid "Rescale with histogram"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:448
+msgid ""
+"Rescales histogram equalized the range of category values in a raster map "
+"layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:449
+msgid "Generate random cells"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:450
+msgid "Random cells"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:451
+msgid "Generates random cell values with spatial dependence."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:452
+msgid "Random cells and vector points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:453
+msgid ""
+"Creates a raster map layer and vector point map containing randomly located "
+"points."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:454
+msgid "Generate surfaces"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:455
+msgid "Fractal surface"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:456
+msgid "Creates a fractal surface of a given fractal dimension."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:457
+msgid "Gaussian kernel density surface"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:458
+msgid ""
+"Generates a raster density map from vector point data using a moving kernel "
+"or optionally generates a vector density map on a vector network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:459
+msgid "Gaussian deviates surface"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:460
+msgid ""
+"GRASS module to produce a raster map layer of gaussian deviates whose mean "
+"and standard deviation can be expressed by the user. It uses a gaussian "
+"random number generator."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:462
+msgid ""
+"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
+"point."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:463
+msgid "Random deviates surface"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:464
+msgid ""
+"Produces a raster map of uniform random deviates whose range can be "
+"expressed by the user."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:465
+msgid "Random surface with spatial dependence"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:466
+msgid "Generates random surface(s) with spatial dependence."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:467
+msgid "Interpolate surfaces"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:468
+msgid "Bilinear from raster points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:469
+msgid "Bilinear interpolation utility for raster map layers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:470
+msgid "Bilinear and bicubic from vector points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:471
+msgid "Bicubic or bilinear spline interpolation with Tykhonov regularization."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:472
+msgid "IDW from raster points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:473
+msgid "Surface interpolation utility for raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:474
+msgid "IDW from raster points (alternate method for sparse points)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:475
+msgid "Surface generation program."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:476
+msgid "IDW from vector points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:477
+msgid ""
+"Surface interpolation from vector point data by Inverse Distance Squared "
+"Weighting."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:478
+msgid "Raster contours"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:479
+msgid "Surface generation program from rasterized contours."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:480
+msgid "Regularized spline tension"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:481
+msgid ""
+"Spatial approximation and topographic analysis from given point or isoline "
+"data in vector format to floating point raster format using regularized "
+"spline with tension."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:482
+msgid "Ordinary or block kriging"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:483
+msgid "Performs ordinary or block kriging."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:484
+msgid "Fill NULL cells"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:485
+msgid "Fills no-data areas in raster maps using spline interpolation."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:486 ../gui/wxpython/menustrings.py:763
+msgid "Report and statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:487
+msgid "Basic raster metadata"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:488
+msgid "Output basic information about a raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:489
+msgid "Manage category information"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:490
+msgid ""
+"Manages category values and labels associated with user-specified raster map "
+"layers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:491
+msgid "General statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:492
+msgid "Generates area statistics for raster map layers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:493
+msgid "Quantiles for large data sets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:494
+msgid "Compute quantiles using two passes."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:495
+msgid "Range of category values"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:496
+msgid "Prints terse list of category values found in a raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:497
+msgid "Sum category values"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:498
+msgid "Sums up the raster cell values."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:499
+msgid "Sum area by raster map and category"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:500
+msgid "Reports statistics for raster map layers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:501
+msgid "Statistics for clumped cells"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:502
+msgid ""
+"Calculates the volume of data \"clumps\", and (optionally) produces a GRASS "
+"vector points map containing the calculated centroids of these clumps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:503
+msgid "Total corrected area"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:504
+msgid "Surface area estimation for rasters."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:506
+msgid ""
+"Calculates univariate statistics from the non-null cells of a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:507
+msgid "Sample transects"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:508
+msgid "Outputs the raster map layer values lying on user-defined line(s)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:509
+msgid "Sample transects (bearing/distance)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:510
+msgid ""
+"Outputs raster map layer values lying along user defined transect line(s)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:511
+msgid "Covariance/correlation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:512
+msgid ""
+"Outputs a covariance/correlation matrix for user-specified raster map layer"
+"(s)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:513
+msgid "Linear regression"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:514
+msgid "Calculates linear regression from two raster maps: y = a + b*x."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:515
+msgid "Mutual category occurrences"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:516
+msgid ""
+"Tabulates the mutual occurrence (coincidence) of categories for two raster "
+"map layers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:517
+msgid "&Vector"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:518
+msgid "Develop vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:519 ../gui/wxpython/gui_core/dialogs.py:221
+#: ../gui/wxpython/gui_core/dialogs.py:334
+msgid "Create new vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:520
+msgid "Create new empty vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:521
+msgid "Digitize vector map using Tcl/Tk digitizer"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:522
+msgid "Interactive editing and digitization of vector maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:523
+msgid "Edit vector map (non-interactively)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:524
+msgid ""
+"Edits a vector map, allows adding, deleting and modifying selected vector "
+"features."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:525
+msgid "Convert object types"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:526
+msgid "Change the type of geometry elements."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:527
+msgid "Parallel lines"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:528
+msgid "Creates parallel line to input vector lines."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:529
+msgid "Dissolve boundaries"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:530
+msgid ""
+"Dissolves boundaries between adjacent areas sharing a common category number "
+"or attribute."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:531
+msgid "Create 3D vector over raster"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:532
+msgid "Converts vector map to 3D by sampling of elevation raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:533
+msgid "Extrude 3D vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:534
+msgid "Extrudes flat vector object to 3D with defined height."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:535
+msgid "Create labels"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:536
+msgid "Creates paint labels for a vector map from attached attributes."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:537
+msgid "Create optimally placed labels"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:538
+msgid "Create optimally placed labels for vector map(s)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:539
+msgid "Reposition vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:540
+msgid ""
+"Performs an affine transformation (shift, scale and rotate, or GPCs) on "
+"vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:541
+msgid "Reproject vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:542
+msgid "Re-projects a vector map from one location to the current location."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:544
+msgid "Updates vector map metadata."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:545
+msgid "Topology maintenance"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:546
+msgid "Create or rebuild topology"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:547
+msgid "Creates topology for GRASS vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:548
+msgid "Rebuild topology on all vector maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:549
+msgid "Rebuilds topology on all vector maps in the current mapset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:550
+msgid "Build polylines"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:551
+msgid "Builds polylines from lines or boundaries."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:552
+msgid "Split lines"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:553
+msgid "Split lines to shorter segments."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:554
+msgid "Split polylines"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:555
+msgid "Creates points/segments from input vector lines and positions."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:556
+msgid "Clean vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:557
+msgid "Toolset for cleaning topology of vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:558
+msgid "Smooth or simplify"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:559
+msgid "Vector based generalization."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:560
+msgid "Add centroids"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:561
+msgid "Adds missing centroids to closed boundaries."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:564
+msgid ""
+"Set color rules for features in a vector using a numeric attribute column."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:566
+msgid "Interactive management of vector color tables."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:567
+msgid "Query vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:568
+msgid "Query with coordinate(s)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:569
+msgid "Queries a vector map layer at given locations."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:570 ../gui/wxpython/menustrings.py:822
+msgid "Query vector attribute data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:571 ../gui/wxpython/menustrings.py:823
+msgid "Prints vector map attributes."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:572
+msgid "Feature selection"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:573
+msgid "Attribute query"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:574
+msgid ""
+"Selects vector objects from an existing vector map and creates a new map "
+"containing only the selected objects."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:575
+msgid "Spatial query"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:576
+msgid ""
+"Selects features from vector map (A) by features from other vector map (B)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:586
+msgid "Buffer vectors"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:587
+msgid ""
+"Creates a buffer around features of given type (areas must contain centroid)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:588
+msgid "Lidar analysis"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:589
+msgid "Detect edges"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:590
+msgid "Detects the object's edges from a LIDAR data set."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:591
+msgid "Detect interiors"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:592
+msgid ""
+"Building contour determination and Region Growing algorithm for determining "
+"the building inside"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:593
+msgid "Correct and reclassify objects"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:594
+msgid ""
+"Correction of the v.lidar.growing output. It is the last of the three "
+"algorithms for LIDAR filtering."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:595
+msgid "Linear referencing"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:596
+msgid "Create LRS"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:597
+msgid "Create Linear Reference System"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:598
+msgid "Create stationing"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:599
+msgid "Create stationing from input lines, and linear reference system"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:600
+msgid "Create points/segments"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:601
+msgid ""
+"Creates points/segments from input lines, linear reference system and "
+"positions read from stdin or a file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:602
+msgid "Find line id and offset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:603
+msgid ""
+"Finds line id and real km+offset for given points in vector map using linear "
+"reference system."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:604
+msgid "Nearest features"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:605
+msgid ""
+"Finds the nearest element in vector map 'to' for elements in vector map "
+"'from'."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:606
+msgid "Network analysis"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:607
+msgid "Network maintenance"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:608
+msgid "Performs network maintenance."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:609
+msgid "Allocate subnets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:610
+msgid "Allocate subnets for nearest centres (direction from centre)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:611
+msgid "Split net"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:612
+msgid "Splits net by cost isolines."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:613
+msgid "Shortest path"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:614
+msgid "Finds shortest path on vector network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:615
+msgid "Shortest path for sets of features"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:616
+msgid ""
+"Computes shortest distance via the network between the given sets of "
+"features."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:617
+msgid "Shortest path using timetables"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:618
+msgid "Finds shortest path using timetables."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:619
+msgid "Shortest path for all pairs"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:620
+msgid "Computes the shortest path between all pairs of nodes in the network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:621
+msgid "Visibility network"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:622
+msgid "Visibility graph construction."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:623
+msgid "Bridges and articulation points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:624
+msgid "Computes bridges and articulation points in the network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:625
+msgid "Maximum flow"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:626
+msgid "Computes the maximum flow between two sets of nodes in the network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:627
+msgid "Vertex connectivity"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:628
+msgid "Computes vertex connectivity between two sets of nodes in the network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:629
+msgid "Components"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:630
+msgid "Computes strongly and weakly connected components in the network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:631
+msgid "Centrality"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:632
+msgid ""
+"Computes degree, centrality, betweeness, closeness and eigenvector "
+"centrality measures in the network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:633
+msgid "Steiner tree"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:634
+msgid "Create Steiner tree for the network and given terminals"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:635
+msgid "Minimum spanning tree"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:636
+msgid "Computes minimum spanning tree for the network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:637
+msgid "Traveling salesman analysis"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:638
+msgid "Creates a cycle connecting given nodes (Traveling salesman problem)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:639 ../gui/wxpython/menustrings.py:640
+msgid "Overlay vector maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:641
+msgid "Overlays two vector maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:642
+msgid "Patch vector maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:643
+msgid "Create a new vector map layer by combining other vector map layers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:644
+msgid "Change attributes"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:645
+msgid "Manage or report categories"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:646
+msgid "Attach, delete or report vector categories to map geometry."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:648
+msgid ""
+"Changes vector category values for an existing vector map according to "
+"results of SQL queries or a value in attribute table column."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:650
+msgid "Update area attributes from raster"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:651
+msgid ""
+"Calculates univariate statistics from a raster map based on vector polygons "
+"and uploads statistics to new attribute columns."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:652
+msgid "Update point attributes from areas"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:653
+msgid "Uploads vector values at positions of vector points to the table."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:654
+msgid "Update database values from vector"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:655
+msgid "Populates database values from vector features."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:656
+msgid "Sample raster maps at point locations"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:657
+msgid "Uploads raster values at positions of vector points to the table."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:658
+msgid "Sample raster neighborhood around points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:659
+msgid "Samples a raster map at vector point locations."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:660
+msgid "Generate area for current region"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:661
+msgid "Create a new vector from the current region."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:662
+msgid "Generate areas from points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:663
+msgid "Convex hull"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:664
+msgid "Produces a convex hull for a given vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:665
+msgid "Delaunay triangles"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:666
+msgid ""
+"Creates a Delaunay triangulation from an input vector map containing points "
+"or centroids."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:667
+msgid "Voronoi diagram/Thiessen polygons"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:668
+msgid ""
+"Creates a Voronoi diagram from an input vector map containing points or "
+"centroids."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:669
+msgid "Generate grid"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:670
+msgid "Creates a GRASS vector map of a user-defined grid."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:671
+msgid "Generate points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:672
+msgid "Generate from database"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:673
+msgid ""
+"Creates new vector (points) map from database table containing coordinates."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:674
+msgid "Generate points along lines"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:675
+msgid "Create points along input lines in new vector with 2 layers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:676
+msgid "Generate random points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:677
+msgid "Randomly generate a 2D/3D vector points map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:678
+msgid "Perturb points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:679
+msgid "Random location perturbations of GRASS vector points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:680
+msgid "Remove outliers in point sets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:681
+msgid "Removes outliers from vector point data."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:682
+msgid "Test/training point sets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:683
+msgid "Randomly partition points into test/train sets."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:684
+msgid "Reports and statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:685
+msgid "Basic vector metadata"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:686
+msgid "Outputs basic information about a user-specified vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:687
+msgid "Classify attribute data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:688
+msgid "Classifies attribute data, e.g. for thematic mapping"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:689
+msgid "Report topology by category"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:690
+msgid "Reports geometry statistics for vectors."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:691
+msgid "Univariate attribute statistics for points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:692
+msgid ""
+"Calculates univariate statistics for attribute. Variance and standard "
+"deviation is calculated only for points if specified."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:693
+msgid "Univariate statistics for attribute columns"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:694
+msgid ""
+"Calculates univariate statistics on selected table column for a GRASS vector "
+"map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:695
+msgid "Quadrat indices"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:696
+msgid "Indices for quadrat counts of sites lists."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:697
+msgid "Test normality"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:698
+msgid "Tests for normality for points."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:699
+msgid "&Imagery"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:700
+msgid "Develop images and groups"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:701
+msgid "Create/edit group"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:702
+msgid "Creates, edits, and lists groups of imagery files."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:703
+msgid "Target group"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:704
+msgid "Targets an imagery group to a GRASS location and mapset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:705
+msgid "Mosaic images"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:706
+msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:707
+msgid "Manage image colors"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:708
+msgid "Color balance for RGB"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:709
+msgid "Performs auto-balancing of colors for LANDSAT images."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:710
+msgid "HIS to RGB"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:711
+msgid ""
+"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
+"RGB (Red-Green-Blue) color space."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:713
+msgid ""
+"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
+"Intensity-Saturation) color space."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:714
+msgid "Rectify image or raster"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:715
+msgid ""
+"Rectifies an image by computing a coordinate transformation for each pixel "
+"in the image based on the control points."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:717
+msgid "Generate histogram of image"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:718
+msgid "Spectral response"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:719
+msgid ""
+"Displays spectral response at user specified locations in group or images."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:720
+msgid "Brovey sharpening"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:721
+msgid ""
+"Brovey transform to merge multispectral and high-res panchromatic channels"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:722
+msgid "Classify image"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:723
+msgid "Clustering input for unsupervised classification"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:724
+msgid ""
+"Generates spectral signatures for land cover types in an image using a "
+"clustering algorithm."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:725
+msgid "Input for supervised MLC"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:726
+msgid "Generates statistics for i.maxlik from raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:727
+msgid "Maximum likelihood classification (MLC)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:728
+msgid "Classifies the cell spectral reflectances in imagery data."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:729
+msgid "Interactive input for supervised classification (requires Xterm)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:730
+msgid ""
+"Generates spectral signatures for an image by allowing the user to outline "
+"regions of interest."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:731
+msgid "Input for supervised SMAP"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:732
+msgid "Generates statistics for i.smap from raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:733
+msgid "Sequential maximum a posteriori classification (SMAP)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:734
+msgid ""
+"Performs contextual image classification using sequential maximum a "
+"posteriori (SMAP) estimation."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:735
+msgid "Filter image"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:736
+msgid "Edge detection"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:737
+msgid "Zero-crossing \"edge detection\" raster function for image processing."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:738
+msgid "Matrix/convolving filter"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:739
+msgid "Performs raster map matrix filter."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:740
+msgid "Transform image"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:741
+msgid "Canonical correlation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:742
+msgid "Canonical components analysis (cca) program for image processing."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:743
+msgid "Principal components"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:744
+msgid "Principal components analysis (PCA) for image processing."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:745
+msgid "Fast Fourier"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:746
+msgid "Fast Fourier Transform (FFT) for image processing."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:747
+msgid "Inverse Fast Fourier"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:748
+msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:749
+msgid "Satellite images tools"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:750
+msgid "Landsat DN to radiance/reflectance"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:751
+msgid ""
+"Calculates top-of-atmosphere radiance or reflectance and temperature for "
+"Landsat MSS/TM/ETM+."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:752
+msgid "Landsat cloud cover assessment"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:753
+msgid "Performs Landsat TM/ETM+ Automatic Cloud Cover Assessment (ACCA)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:754
+msgid "Modis quality control"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:755
+msgid "Extracts quality control parameters from Modis QC layers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:756
+msgid "Atmospheric correction"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:757
+msgid "Performs atmospheric correction using the 6S algorithm."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:758
+msgid "Topographic correction"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:759
+msgid "Computes topographic correction of reflectance."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:760
+msgid "Satellite images products"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:761
+msgid "Tasseled cap vegetation index"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:762
+msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:764
+msgid "Bit pattern comparison "
+msgstr ""
+#: ../gui/wxpython/menustrings.py:765
+msgid "Compares bit patterns with a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:766
+msgid "Kappa analysis"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:767
+msgid ""
+"Calculate error matrix and kappa parameter for accuracy assessment of "
+"classification result."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:768
+msgid "OIF for LandSat TM"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:769
+msgid "Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:770
+msgid "V&olumes"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:771
+msgid "Develop volumes"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:772
+msgid "Manage 3D NULL values"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:773
+msgid "Explicitly create the 3D NULL-value bitmap file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:774
+msgid "Manage timestamp"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:775
+msgid "Print/add/remove a timestamp for a 3D raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:779
+msgid "3D Mask"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:780
+msgid "Establishes the current working 3D raster mask."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:781
+msgid "Volume calculator"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:782
+msgid "Map calculator for 3D raster map algebra."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:783
+msgid "Cross section"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:784
+msgid ""
+"Creates cross section 2D raster map from 3D raster map based on 2D elevation "
+"map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:786
+msgid ""
+"Calculates numerically transient, confined groundwater flow in three "
+"dimensions."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:787
+msgid "Interpolate volume from points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:788
+msgid ""
+"Interpolates point data to a 3D raster map using regularized spline with "
+"tension (RST) algorithm."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:789
+msgid "Report and Statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:790
+msgid "Basic volume metadata"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:791
+msgid "Outputs basic information about a user-specified 3D raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:792
+msgid "Voxel statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:793
+msgid "Generates volume statistics for 3D raster maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:794
+msgid "Univariate statistics for volumes"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:795
+msgid ""
+"Calculates univariate statistics from the non-null 3d cells of a raster3d "
+"map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:796
+msgid "&Database"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:797
+msgid "Database information"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:798
+msgid "List drivers"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:799
+msgid "Lists all database drivers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:800
+msgid "List tables"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:801
+msgid "Lists all tables for a given database."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:802
+msgid "Describe table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:803
+msgid "Describes a table in detail."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:804
+msgid "List columns"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:805
+msgid "List all columns for a given table."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:806
+msgid "Manage databases"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:807
+msgid "Connect"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:808
+msgid "Prints/sets general DB connection for current mapset and exits."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:809
+msgid "Login"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:810
+msgid "Sets user/password for driver/database."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:811
+msgid "Drop table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:812
+msgid "Drops an attribute table."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:813
+msgid "Copy table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:814
+msgid "Copy a table."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:815 ../gui/wxpython/menustrings.py:835
+msgid "Drop column"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:816
+msgid "Drops a column from selected attribute table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:817
+msgid "Test"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:818
+msgid "Test database driver, database must exist and set by db.connect."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:820
+msgid "Query any table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:821
+msgid "Selects data from attribute table (performs SQL query statement(s))."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:824
+msgid "SQL statement"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:825
+msgid "Executes any SQL statement."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:826
+msgid "Vector database connections"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:827
+msgid "New table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:828
+msgid ""
+"Creates and connects a new attribute table to a given layer of an existing "
+"vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:829
+msgid "Remove table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:830
+msgid "Removes existing attribute table of a vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:831
+msgid "Join table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:832
+msgid "Allows to join a table to a vector map table."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:833
+msgid "Add columns"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:834
+msgid ""
+"Adds one or more columns to the attribute table connected to a given vector "
+"map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:836
+msgid ""
+"Drops a column from the attribute table connected to a given vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:838
+msgid ""
+"Renames a column in the attribute table connected to a given vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:839
+msgid "Change values"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:840
+msgid ""
+"Allows to update a column in the attribute table connected to a vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:841
+msgid "Reconnect vectors to database"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:842
+msgid "Reconnects vectors to a new database."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:843
+msgid "Set vector map - database connection"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:844
+msgid "Prints/sets DB connection for a vector map to attribute table."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:845 ../gui/wxpython/menustrings.py:895
+msgid "&Help"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:846
+msgid "GRASS help"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:847 ../gui/wxpython/menustrings.py:849
+msgid "Display the HTML man pages of GRASS"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:848
+msgid "GUI help"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:850 ../gui/wxpython/menustrings.py:851
+#: ../gui/wxpython/gui_core/ghelp.py:384
+msgid "About GRASS GIS"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:856
+msgid "Create new model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:858
+msgid "Load model from file"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:860 ../gui/wxpython/gmodeler/frame.py:392
+msgid "Save model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:862
+msgid "Save model to file"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:864
+msgid "Close model file"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:865
+msgid "Export to image"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:866
+msgid "Export model to image"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:867
+msgid "Export to Python"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:868
+msgid "Export model to Python script"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:869
+msgid "Quit modeler"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:870
+msgid "Close modeler window"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:873
+#: ../gui/wxpython/gmodeler/preferences.py:28
+msgid "Modeler settings"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:874
+msgid "&Model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:875
+msgid "Add command"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:876
+msgid "Add action (GRASS command) to model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:877
+msgid "Add data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:878
+msgid "Add data item to model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:879
+msgid "Define relation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:880
+msgid "Define relation between data and action items"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:881
+msgid "Add loop / series"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:882
+msgid "Adds loop (series) to model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:883
+msgid "Add condition"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:884
+msgid "Adds condition (if/else) to model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:885
+msgid "Remove item"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:886
+msgid "Remove action/data from model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:887
+#: ../gui/wxpython/gmodeler/preferences.py:421
+msgid "Model properties"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:888
+msgid "Model properties (name, purpose, etc.)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:889
+msgid "Delete intermediate data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:890
+msgid "Delete intermediate data defined in the model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:892
+msgid "Run entire model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:893
+msgid "Validate model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:894
+msgid "Validate entire model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:896
+msgid "Help"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:897
+msgid "Display the HTML man pages of Graphical modeler"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:898
+msgid "About Graphical Modeler"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:899
+msgid "Display information about Graphical Modeler"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:58
+msgid "model"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:59
+msgid "Script generated by wxGUI Graphical Modeler."
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:388 ../gui/wxpython/gmodeler/model.py:450
+#, python-format
+msgid "undefined variable '%s'"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:483
+msgid "Running model..."
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:502
+msgid "Model is empty. Nothing to run."
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:511 ../gui/wxpython/gmodeler/frame.py:501
+msgid "Validating model..."
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:517
+#, python-format
+msgid ""
+"Model is not valid. Do you want to run the model anyway?\n"
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:519
+msgid "Run model?"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:554
+msgid "Variables below not defined:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:662
+msgid "Raster maps"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:665
+msgid "3D raster maps"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:668 ../gui/wxpython/psmap/dialogs.py:1270
+msgid "Vector maps"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:927 ../gui/wxpython/gmodeler/model.py:994
+#: ../gui/wxpython/gui_core/goutput.py:841
+msgid "unknown"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:1242
+msgid "<not defined>"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:1352
+msgid "Condition: "
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:1354
+msgid "Condition: not defined"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:1415
+msgid "loop"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:1456
+msgid "if-else"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:2148
+msgid "Model parameters"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:2165
+msgid "Delete intermediate data when finish"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:2173
+#: ../gui/wxpython/gmodeler/frame.py:1455
+#: ../gui/wxpython/modules/mcalc_builder.py:127
+#: ../gui/wxpython/modules/vclean.py:156 ../gui/wxpython/gui_core/ghelp.py:210
+#: ../gui/wxpython/gui_core/forms.py:455 ../gui/wxpython/scripts/vkrige.py:152
+msgid "&Run"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:2217
+#: ../gui/wxpython/gmodeler/frame.py:112
+msgid "Variables"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:45
+#: ../gui/wxpython/vdigit/preferences.py:118
+#: ../gui/wxpython/gui_core/preferences.py:256
+msgid "General"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:50
+msgid "Item properties"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:58
+msgid "Disabled:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:83
+msgid "Action"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:96
+#: ../gui/wxpython/gmodeler/preferences.py:334
+msgid "Valid:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:113
+msgid "Invalid:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:130
+msgid "Running:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:150
+#: ../gui/wxpython/gmodeler/preferences.py:269
+#: ../gui/wxpython/gmodeler/preferences.py:354
+msgid "Shape size"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:215
+msgid "Raster:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:232
+msgid "3D raster:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:249
+msgid "Vector:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:321
+msgid "Loop"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:430
+msgid "Commands"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:442
+#: ../gui/wxpython/modules/vclean.py:135
+#: ../gui/wxpython/gui_core/preferences.py:776
+#: ../gui/wxpython/gui_core/dialogs.py:1503
+#: ../gui/wxpython/scripts/vkrige.py:139
+msgid "Allow output files to overwrite existing files"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:450
+msgid "Apply properties"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:464
+#: ../gui/wxpython/gui_core/gselect.py:1229
+#: ../gui/wxpython/gui_core/gselect.py:1232
+#: ../gui/wxpython/gui_core/gselect.py:1241
+#: ../gui/wxpython/gui_core/gselect.py:1381
+msgid "Name:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:473
+msgid "Description:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:482
+msgid "Author(s):"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:47
+msgid "Data properties"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:73
+msgid "Name of raster map:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:75
+msgid "Name of vector map:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:78
+msgid "Name of element:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:118
+msgid "Add new GRASS module to the model"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:136
+#: ../gui/wxpython/gmodeler/dialogs.py:392
+#: ../gui/wxpython/gmodeler/dialogs.py:494
+#: ../gui/wxpython/gui_core/preferences.py:761
+msgid "Command"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:205
+msgid ""
+"Command not defined.\n"
+"\n"
+"Unable to add new action to the model."
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:211
+#, python-format
+msgid ""
+"'%s' is not a GRASS module.\n"
+"\n"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:246
+msgid "Relation properties"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:263
+msgid "From"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:307
+#, python-format
+msgid "Data: %s"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:313
+msgid "Command:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:319
+msgid "Option:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:334
+msgid ""
+"Relation doesn't start with data item.\n"
+"Unable to add relation."
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:341
+msgid ""
+"Relation doesn't point to GRASS command.\n"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:354
+msgid ""
+"No relevant option found.\n"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:385
+msgid "Condition"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:391
+#: ../gui/wxpython/gmodeler/dialogs.py:493
+#: ../gui/wxpython/gmodeler/frame.py:1418
+msgid "ID"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1273
+#: ../gui/wxpython/gmodeler/frame.py:1316
+#: ../gui/wxpython/gui_core/ghelp.py:640 ../gui/wxpython/gui_core/ghelp.py:642
+#: ../gui/wxpython/gui_core/ghelp.py:702
+msgid "Name"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:410
+msgid "Loop properties"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:416
+msgid "List of items in loop"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:419
+msgid "Series"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:420
+msgid "Define map series as condition for the loop"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:464
+msgid "Define series of maps"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:479
+msgid "If-else properties"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:485
+msgid "List of items in 'if' block"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:490
+msgid "List of items in 'else' block"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:654
+#, python-format
+msgid "Variable <%s> already exists in the model. Adding variable failed."
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:683
+msgid "Do you want to delete all variables from the model?"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:685
+msgid "Delete variables"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:724
+#: ../gui/wxpython/gmodeler/dialogs.py:898
+#: ../gui/wxpython/vdigit/dialogs.py:272
+msgid "Delete selected"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:725
+#: ../gui/wxpython/gmodeler/dialogs.py:899
+#: ../gui/wxpython/vdigit/dialogs.py:276
+msgid "Delete all"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:848
+#, python-format
+msgid ""
+"Selected data records (%d) will permanently deleted from table. Do you want "
+"to delete them?"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:905
+msgid "Normalize"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:59
+msgid "GRASS GIS Graphical Modeler (experimental prototype)"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:110
+msgid "Model"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:111
+msgid "Items"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:113
+msgid "Python editor"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:114 ../gui/wxpython/gui_core/forms.py:783
+#: ../gui/wxpython/scripts/vkrige.py:108
+msgid "Command output"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:179
+#: ../gui/wxpython/gui_core/goutput.py:1326
+msgid "Python script contains local modifications"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:181
+#: ../gui/wxpython/gmodeler/frame.py:1602
+msgid "Python script is up-to-date"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:196
+msgid "Redrawing model..."
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:231
+msgid "Do you want to save changes in the model?"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:233
+msgid "Do you want to store current model settings to model file?"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:239
+msgid "Quit Graphical Modeler"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:300
+msgid "No intermediate data to delete."
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:304
+#, python-format
+msgid "Do you want to permanently delete data?%s"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:305
+msgid "Delete intermediate data?"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:319
+#, python-format
+msgid "%d maps deleted from current mapset"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:334 ../gui/wxpython/gmodeler/frame.py:449
+msgid ""
+"Current model is not empty. Do you want to store current settings to model "
+"file?"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:337 ../gui/wxpython/gmodeler/frame.py:452
+msgid "Create new model?"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:364
+msgid "Choose model file"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:382
+#, python-format
+msgid "%(items)d items (%(actions)d actions) loaded into model"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:389 ../gui/wxpython/gmodeler/frame.py:426
+#, python-format
+msgid "Model file <%s> already exists. Do you want to overwrite this file?"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:399 ../gui/wxpython/gmodeler/frame.py:439
+#, python-format
+msgid "File <%s> saved"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:408
+msgid "Choose file to save current model"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:428
+msgid "File already exists"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:497
+msgid "Model is empty. Nothing to validate."
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:507
+#, python-format
+msgid ""
+"Model is not valid.\n"
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:510
+msgid "Model is valid."
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:571 ../gui/wxpython/gmodeler/frame.py:578
+#, python-format
+msgid "Model exported to <%s>"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:704
+msgid "wxGUI Graphical Modeler"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:707
+#, python-format
+msgid ""
+"(C) 2010-%s by the GRASS Development Team\n"
+"\n"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:708 ../gui/wxpython/psmap/frame.py:1021
+msgid ""
+"This program is free software under the GNU General Public License(>=v2). "
+"Read the file COPYING that comes with GRASS for details."
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:805
+#, python-format
+msgid ""
+"Reading model file <%s> failed.\n"
+"Invalid file, unable to parse XML document."
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:811
+msgid "Please wait, loading model..."
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:871
+msgid "Writing current settings to model file failed."
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1181
+msgid "Disable"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1184
+msgid "Enable"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1189
+msgid "Add control point"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1191
+msgid "Remove control point"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1198
+msgid "Intermediate"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1270
+msgid "List of variables - right-click to delete"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1274
+#: ../gui/wxpython/gmodeler/frame.py:1329
+msgid "Default value"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1336
+#: ../gui/wxpython/location_wizard/wizard.py:337
+#: ../gui/wxpython/location_wizard/wizard.py:838
+#: ../gui/wxpython/location_wizard/wizard.py:1001
+#: ../gui/wxpython/location_wizard/wizard.py:1266
+msgid "Description"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1278
+msgid "Add new variable"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1282
+msgid "integer"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1283
+msgid "float"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1284
+msgid "string"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1287
+msgid "mapset"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1288
+msgid "file"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1295
+msgid "Add new variable to the model"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1415
+msgid "List of items - right-click to delete"
+msgstr ""
+msgid "In block"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1419
+msgid "Command / Condition"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1452
+msgid "Python script"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1456
+msgid "Run python script"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1459
+msgid "Save python script to file"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1462
+msgid ""
+"Refresh python script based on the model.\n"
+"It will discards all local changes."
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1500
+#, python-format
+msgid "Unable to launch Python script. %s"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1525
+msgid "Choose file to save"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1527
+msgid "Python script (*.py)|*.py"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1541
+#, python-format
+msgid "File <%s> already exists. Do you want to overwrite this file?"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1543
+msgid "Save file"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1578
+msgid ""
+"Python script is locally modificated. Refresh will discard all changes. Do "
+"you really want to continue?"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1581
+msgid "Update"
+msgstr ""
+#: ../gui/wxpython/modules/histogram.py:176
+#: ../gui/wxpython/mapdisp/mapwindow.py:438
+msgid "Please wait, exporting image..."
+msgstr ""
+#: ../gui/wxpython/modules/histogram.py:266
+msgid "GRASS GIS Histogramming Tool (d.histogram)"
+msgstr ""
+#: ../gui/wxpython/modules/histogram.py:368
+msgid "Select font for histogram text"
+msgstr ""
+#: ../gui/wxpython/modules/ogc_services.py:37
+msgid "Import data from WMS server"
+msgstr ""
+#: ../gui/wxpython/modules/ogc_services.py:53
+msgid " Server settings "
+msgstr ""
+#: ../gui/wxpython/modules/ogc_services.py:55
+msgid "Server:"
+msgstr ""
+#: ../gui/wxpython/modules/ogc_services.py:62
+msgid " List of layers "
+msgstr ""
+#: ../gui/wxpython/modules/ogc_services.py:68
+#: ../gui/wxpython/gui_core/dialogs.py:1681
+#: ../gui/wxpython/gui_core/dialogs.py:1804
+msgid "Add imported layers into layer tree"
+msgstr ""
+#: ../gui/wxpython/modules/ogc_services.py:78
+msgid "&Connect"
+msgstr ""
+#: ../gui/wxpython/modules/ogc_services.py:79
+msgid "Connect to the server"
+msgstr ""
+#: ../gui/wxpython/modules/ogc_services.py:84
+#: ../gui/wxpython/gui_core/dialogs.py:1516
+#: ../gui/wxpython/gui_core/dialogs.py:1693
+msgid "&Import"
+msgstr ""
+#: ../gui/wxpython/modules/ogc_services.py:85
+#: ../gui/wxpython/gui_core/dialogs.py:1517
+#: ../gui/wxpython/gui_core/dialogs.py:1694
+msgid "Import selected layers"
+msgstr ""
+#: ../gui/wxpython/modules/ogc_services.py:239
+msgid "Layer / Style"
+msgstr ""
+#: ../gui/wxpython/modules/ogc_services.py:240
+msgid "Title"
+msgstr ""
+#: ../gui/wxpython/modules/ogc_services.py:250
+msgid "Layers"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:51
+msgid "GRASS GIS Raster Map Calculator"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:54
+msgid "GRASS GIS 3D Raster Map Calculator"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:65
+msgid "mapcalc statement"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:116
+msgid "Operators"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:118
+msgid "Operands"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:120
+msgid "Expression"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:132
+msgid "Save expression to file"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:134
+#: ../gui/wxpython/gui_core/forms.py:1315
+msgid "&Load"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:135
+msgid "Load expression from file"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:139
+msgid "exponent"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:141
+msgid "divide"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:143
+msgid "add"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:145
+msgid "subtract"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:147
+msgid "modulus"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:149
+msgid "multiply"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:154
+msgid "left shift"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:156
+msgid "right shift"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:158
+msgid "right shift (unsigned)"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:160
+msgid "greater than"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:162
+msgid "greater than or equal to"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:164
+msgid "less than"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:166
+msgid "less than or equal to"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:168
+msgid "equal to"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:170
+msgid "not equal to"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:173
+msgid "one's complement"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:175
+msgid "NOT"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:177
+msgid "bitwise AND"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:179
+msgid "bitwise OR"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:181
+msgid "logical AND"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:183
+msgid "logical AND (ignores NULLs)"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:185
+msgid "logical OR"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:187
+msgid "logical OR (ignores NULLs)"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:189
+msgid "conditional"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:202
+msgid "Name for new 3D raster map to create"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:204
+msgid "Name for new raster map to create"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:208
+msgid "Insert existing 3D raster map"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:210
+msgid "Insert existing raster map"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:214
+msgid "Insert mapcalc function"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:221
+msgid "Add created raster map into layer tree"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:438
+msgid "You must enter the name of a new raster map to create."
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:445
+msgid "You must enter an expression to create a new raster map."
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:480
+msgid "Choose a file name to save the expression"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:481
+#: ../gui/wxpython/modules/mcalc_builder.py:502
+msgid "Expression file (*)|*"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:501
+msgid "Choose a file name to load the expression"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:71
+msgid "Check all"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:74
+msgid "Clear all"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:130
+msgid "Enter vector attribute values"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:287
+msgid "Bad color format. Use color format '0:0:0'"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:369
+msgid "Select raster map:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:371
+msgid "Select vector map:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:388
+msgid "Import or export color table:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:393
+msgid "Load color table from file:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:394
+msgid "Choose file to load color table"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:395
+msgid "Load"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:396
+msgid "Type filename or click to choose file and load color table"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:402
+msgid "Save color table to file:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:403
+msgid "Choose file to save color table"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:404
+msgid "Type filename or click to choose file and save color table"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:410
+msgid "Reload default table"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:500
+msgid "Preview"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:504
+msgid "Show preview of map (current Map Display extent is used)."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:534
+msgid "No valid color rules given."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:567
+#: ../gui/wxpython/gui_core/forms.py:1529
+msgid "Nothing to save."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:600
+msgid "Invalid color table format"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:677
+#, python-format
+msgid "Invalid rule value '%s'. Unable to apply color table."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:752
+msgid "Create new color table for raster map"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:830
+msgid "Enter raster category values or percents"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:834
+#: ../gui/wxpython/modules/colorrules.py:1450
+#: ../gui/wxpython/modules/colorrules.py:1453
+#: ../gui/wxpython/psmap/dialogs.py:2561
+msgid "range"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:836
+msgid "fp range"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:837
+#, python-format
+msgid "Enter raster category values or percents (%(range)s = %(min)d-%(max)d)"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:926
+msgid "Create new color rules for vector map"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:937
+#: ../gui/wxpython/modules/colorrules.py:1462
+msgid "Enter vector attribute values or percents:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:939
+#: ../gui/wxpython/modules/colorrules.py:1464
+msgid "Enter vector attribute values:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:950
+msgid "Select vector columns"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:952
+msgid "Layer:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:954
+msgid "Attribute column:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:957
+msgid "Load color from column:"
+msgstr ""
+msgid "Save color to column:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:959
+msgid "Load size from column:"
+msgstr ""
+msgid "Save size to column:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:961
+msgid "Load width from column:"
+msgstr ""
+msgid "Save width to column:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:965
+msgid "Use color column instead of color table:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:980
+msgid "Add GRASSRGB column to current attribute table."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1035
+#: ../gui/wxpython/modules/colorrules.py:1084
+msgid "Import or export color table"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1096
+#, python-format
+msgid ""
+"Database connection for vector map <%s> is not defined in DB file.  Do you "
+"want to create and connect new attribute table?"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1099
+msgid "No database connection defined"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1171
+#, python-format
+msgid ""
+"Selected map <%(map)s> is not in current mapset <%(mapset)s>. Color rules "
+"cannot be edited."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1176
+#, python-format
+msgid ""
+"Selected map <%(map)s> is not in current mapset <%(mapset)s>. Attribute "
+"table cannot be edited."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1318
+#, python-format
+msgid "%s column already exists."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1350
+msgid "Please wait, loading data from attribute table..."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1411
+#, python-format
+msgid ""
+"Number of loaded records reached %d, displaying all the records will be time-"
+"consuming and may lead to computer freezing, do you still want to continue?"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1415
+msgid "Too many records"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1457
+#, python-format
+msgid "Enter vector attribute values or percents %s:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1459
+#, python-format
+msgid "Enter vector attribute values %s:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1596
+msgid "Please select column to save values to."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1633
+msgid "No color column defined. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:42
+msgid "Fetch & install extension from GRASS Addons"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:52
+msgid "Repository"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:54
+msgid "List of extensions"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:58
+msgid "Fetch full info including description and keywords"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:67
+#: ../gui/wxpython/gui_core/dialogs.py:1475
+msgid "Options"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:93
+msgid "&Fetch"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:94
+msgid "Fetch list of available modules from GRASS Addons SVN repository"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:97
+msgid "&Install"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:98
+msgid "Install selected add-ons GRASS module"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:101
+#: ../gui/wxpython/modules/extensions.py:404
+#: ../gui/wxpython/gui_core/dialogs.py:1523
+msgid "Command dialog"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:102
+#: ../gui/wxpython/modules/extensions.py:405
+#: ../gui/wxpython/gui_core/dialogs.py:1689
+#: ../gui/wxpython/gui_core/dialogs.py:1691
+#: ../gui/wxpython/gui_core/dialogs.py:1696
+#: ../gui/wxpython/gui_core/dialogs.py:1698
+#, python-format
+msgid "Open %s dialog"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:171
+msgid "Extension not defined"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:185
+msgid "Fetch list of available extensions by clicking on 'Fetch' button"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:193
+#, python-format
+msgid "%d items match"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:206
+msgid "Fetching list of modules from GRASS-Addons SVN (be patient)..."
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:312
+#: ../gui/wxpython/gui_core/widgets.py:348
+msgid "Menu tree"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:386
+msgid "Uninstall GRASS Addons extensions"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:395
+msgid "List of installed extensions"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:401
+msgid "&Uninstall"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:402
+msgid "Uninstall selected AddOns extensions"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:449
+msgid "No extension selected for removal. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:458
+#, python-format
+msgid ""
+"List of files to be removed:\n"
+"%(files)s\n"
+"\n"
+"Do you want really to remove <%(ext)s> extension?"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:486
+msgid "Extension"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:31 ../gui/wxpython/modules/vclean.py:113
+msgid "Set up vector cleaning tools"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:68
+msgid "break lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:69
+msgid "remove duplicates"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:70
+msgid "remove dangles"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:71
+msgid "change boundary dangles to lines"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:72
+msgid "remove bridges"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:73
+msgid "change bridges to lines"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:74
+msgid "snap lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:75
+msgid "remove duplicate area centroids"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:76
+msgid "break polygons"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:77
+msgid "prune lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:78
+msgid "remove small areas"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:79
+msgid "remove lines/boundaries of zero length"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:80
+msgid "remove small angles at nodes"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:115
+msgid "Choose cleaning tools and set thresholds"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:119
+msgid "Select input vector map:"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:125
+msgid " Feature type: "
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:129
+msgid "Select output vector map:"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:159 ../gui/wxpython/gui_core/forms.py:462
+msgid "Copy the current command string to the clipboard (Ctrl+C)"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:194 ../gui/wxpython/psmap/utils.py:92
+msgid "point"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:195
+msgid "line"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:196
+msgid "boundary"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:197
+msgid "centroid"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:198
+#: ../gui/wxpython/vdigit/preferences.py:417
+msgid "area"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:199
+msgid "face"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:355
+#, python-format
+msgid "%s. cleaning tool removed, will be ignored"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:357
+msgid "Please select a cleaning tool to remove"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:378
+#, python-format
+msgid "%s. cleaning tool moved up"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:380
+msgid "1. cleaning tool can not be moved up "
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:382
+msgid "Please select a cleaning tool to move up"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:405
+#, python-format
+msgid "%s. cleaning tool moved down"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:407
+msgid "Last cleaning tool can not be moved down "
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:409
+msgid "Please select a cleaning tool to move down"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:420
+#, python-format
+msgid "cleaning tool: '%s'"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:428
+#, python-format
+msgid "Threshold for %(num)s. tool '%(tool)s': %(thresh)s"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:456
+msgid "Name of input vector map"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:457
+msgid "Name for output vector map"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:458
+msgid "Tools"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:459
+msgid "Threshold"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:461
+#, python-format
+msgid "'%s' not defined"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:463
+#, python-format
+msgid ""
+"Some parameters not defined. Operation canceled.\n"
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:468
+msgid "Executing selected cleaning operations..."
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:524
+msgid "Vector cleaning command copied to clipboard"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:52
+msgid "Generate text file with mapping instructions"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:54
+msgid "Load text file with mapping instructions"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:56
+msgid "Generate PostScript output"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:58
+msgid "Generate PDF output"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:61
+msgid "Specify paper size, margins and orientation"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:63
+msgid "Full extent"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:64
+msgid "Zoom to full extent"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:66 ../gui/wxpython/psmap/dialogs.py:618
+#: ../gui/wxpython/psmap/dialogs.py:673
+msgid "Map frame"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:67
+msgid "Click and drag to place map frame"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:69
+msgid "Delete selected object"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:71
+msgid "Show preview"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:73
+msgid "Quit Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:75 ../gui/wxpython/psmap/dialogs.py:3705
+#: ../gui/wxpython/psmap/dialogs.py:3710
+msgid "Text"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:77
+msgid "Map info"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:83 ../gui/wxpython/psmap/dialogs.py:4061
+#: ../gui/wxpython/psmap/dialogs.py:4109
+msgid "Image"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:87
+msgid "Add simple graphics"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:89 ../gui/wxpython/psmap/dialogs.py:4522
+#: ../gui/wxpython/vdigit/preferences.py:516
+msgid "Point"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:91
+#: ../gui/wxpython/vdigit/preferences.py:517
+msgid "Line"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:93
+msgid "Rectangle"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:91
+msgid "inch"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:93
+msgid "centimeter"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:94
+msgid "millimeter"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:95
+msgid "meters"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:96
+msgid "kilometers"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:97
+msgid "feet"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:98
+msgid "miles"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:99 ../gui/wxpython/psmap/utils.py:103
+msgid "nautical miles"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:101
+msgid "pixel"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:102
+msgid "meter"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:104
+msgid "degree"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:344
+msgid "Unable to run `ps.map -b`"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:197
+msgid "Units:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:206
+msgid ""
+"Position of the top left corner\n"
+"from the top left edge of the paper"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:207
+msgid "X:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:208
+msgid "Y:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:220
+msgid "Position is given:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:221
+msgid "relatively to paper"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:222
+msgid "by map coordinates"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:238
+msgid ""
+"Position from the top left\n"
+"edge of the paper"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:290
+msgid "Font:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:291 ../gui/wxpython/psmap/dialogs.py:3555
+#: ../gui/wxpython/gui_core/preferences.py:1386
+msgid "Font size:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:304
+msgid "Choose color:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:352
+msgid "Close dialog and apply changes"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:358 ../gui/wxpython/vdigit/dialogs.py:142
+msgid "Apply changes"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:383
+msgid "Units"
+msgstr ""
+msgid "Format"
+msgstr ""
+msgid "Orientation"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:383 ../gui/wxpython/psmap/dialogs.py:2084
+msgid "Width"
+msgstr ""
+msgid "Height"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:384
+msgid "Left"
+msgstr ""
+msgid "Right"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:231
+msgid "Top"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:239
+msgid "Bottom"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:439
+msgid "Literal is not allowed!"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:439 ../gui/wxpython/psmap/dialogs.py:1034
+#: ../gui/wxpython/psmap/dialogs.py:1056 ../gui/wxpython/psmap/dialogs.py:1106
+#: ../gui/wxpython/psmap/dialogs.py:3637
+msgid "Invalid input"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:448
+msgid "Page size"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:450
+msgid "Margins"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:454
+msgid "Portrait"
+msgstr ""
+msgid "Landscape"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:506 ../gui/wxpython/psmap/dialogs.py:527
+#: ../gui/wxpython/location_wizard/wizard.py:1667
+msgid "custom"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:556
+msgid "Map settings"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:562
+msgid "Map frame settings"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:679
+msgid "Map frame options:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:680
+msgid "fit frame to match selected map"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:681
+msgid "fit frame to match saved region"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:682
+msgid "fit frame to match current computational region"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:683
+msgid "fixed scale and map center"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:691 ../gui/wxpython/psmap/dialogs.py:859
+msgid "Map selection"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:699 ../gui/wxpython/psmap/dialogs.py:1283
+msgid "Map:"
+msgstr ""
+msgid "Region:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:718
+msgid "Map scale and center"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:723
+msgid "Center:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:724
+msgid "E:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:725
+msgid "N:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:728 ../gui/wxpython/psmap/dialogs.py:4166
+msgid "Scale:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:729
+msgid "1 :"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:749
+msgid "Map max resolution (dpi):"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:762 ../gui/wxpython/psmap/dialogs.py:2653
+msgid "Border"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:766
+msgid "draw border around map frame"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:772
+msgid "border color:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:773
+msgid "border width (pts):"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:867
+msgid ""
+"Region is set to match this map,\n"
+"raster or vector map must be added later"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:874
+msgid "Region selection"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1033
+msgid "No map selected!"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1055
+msgid "No region selected!"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1105
+msgid "Invalid scale or map center!"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1165
+msgid "Choose raster map"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1169
+msgid "no raster map"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1170
+msgid "raster:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1210 ../gui/wxpython/psmap/frame.py:548
+#: ../gui/wxpython/psmap/frame.py:571
+msgid "Please, create map frame first."
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1279
+msgid "Add map"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1287 ../gui/wxpython/psmap/dialogs.py:1651
+msgid "points"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1287 ../gui/wxpython/psmap/dialogs.py:1653
+msgid "lines"
+msgstr ""
+msgid "areas"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1289
+msgid "Data Type"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1292
+msgid "Add"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1304
+msgid "Manage vector maps"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1312
+msgid "The topmost vector map overlaps the others"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1314 ../gui/wxpython/psmap/dialogs.py:2636
+msgid "Up"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1315 ../gui/wxpython/psmap/dialogs.py:2637
+msgid "Down"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1317
+msgid "Properties..."
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1517
+msgid "Raster map settings"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1554
+msgid "Vector maps settings"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1589
+#, python-format
+msgid "%s properties"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1640
+msgid "Data selection"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1647
+msgid "Feature type"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1651
+msgid "centroids"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1653
+msgid "boundaries"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1669
+msgid "Layer selection"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1675
+msgid "Database connection is not defined in DB file."
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1676
+msgid "Select layer:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1699
+msgid "list of categories (e.g. 1,3,5-7)"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1729
+msgid "Use current mask"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1746 ../gui/wxpython/psmap/dialogs.py:1845
+msgid "Colors"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1751 ../gui/wxpython/psmap/dialogs.py:1850
+msgid "Outline"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1755 ../gui/wxpython/psmap/dialogs.py:1859
+msgid "draw outline"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1758 ../gui/wxpython/psmap/dialogs.py:1863
+#: ../gui/wxpython/psmap/dialogs.py:3750 ../gui/wxpython/psmap/dialogs.py:3755
+msgid "Width (pts):"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1795 ../gui/wxpython/psmap/dialogs.py:1899
+msgid "Fill"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1799
+msgid "fill color"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1802 ../gui/wxpython/psmap/dialogs.py:1905
+msgid "choose color:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1814 ../gui/wxpython/psmap/dialogs.py:1918
+msgid "color from map table column:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1861
+msgid "No effect for fill color from table column"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1903
+msgid "Color of lines:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1948 ../gui/wxpython/psmap/dialogs.py:2079
+#: ../gui/wxpython/psmap/dialogs.py:2148
+msgid "Size and style"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1967
+msgid "eps file:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1971 ../gui/wxpython/psmap/dialogs.py:2160
+msgid "Type filename or click browse to choose file"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1972 ../gui/wxpython/psmap/dialogs.py:2161
+msgid "Choose a file"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2002
+msgid "size from map table column:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2004
+msgid "scale:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2036
+msgid "Rotation"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2042
+msgid "rotate symbols:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2043
+msgid "counterclockwise in degrees:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2045
+msgid "from map table column:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2088
+msgid "Set width (pts):"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2097
+msgid "multiply width by category value"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2118
+msgid "Choose line style:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2128
+msgid "Choose linecap:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2153
+msgid "Pattern"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2158
+msgid "use pattern:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2159
+msgid "Choose pattern file:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2163
+msgid "pattern line width (pts):"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2165
+msgid "pattern scale factor:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2481
+msgid "Raster legend"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2485
+msgid "Show raster legend"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2491
+msgid "Source raster"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2496
+msgid "current raster"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2497
+msgid "select raster"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2504 ../gui/wxpython/psmap/dialogs.py:3190
+#, python-format
+msgid "%(rast)s: type %(type)s"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2523
+msgid "Type of legend"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2527
+msgid "discrete legend (categorical maps)"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2529
+msgid "continuous color gradient legend (floating point map)"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2540
+msgid "Advanced legend settings"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2544
+msgid "draw \"no data\" box"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2550
+msgid "draw ticks across color table"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2598
+msgid "Vector legend"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2602
+msgid "Show vector legend"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2608
+msgid "Source vector maps"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2614
+msgid "Choose vector maps and their order in legend"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2619
+msgid "Label"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2638 ../gui/wxpython/psmap/dialogs.py:2944
+msgid "Edit label"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2657
+msgid "draw border around legend"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2694
+msgid "Size and position"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2728
+msgid "Leave the edit field empty, to use default values."
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2750
+msgid ""
+"Width of the color symbol (for lines)\n"
+"in front of the legend text"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2756 ../gui/wxpython/psmap/dialogs.py:2861
+msgid "Columns:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2760
+msgid "column span:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2762
+msgid ""
+"Column separation distance between the left edges\n"
+"of two columns in a multicolumn legend"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2944
+msgid "Edit legend label:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2985
+msgid "No raster map selected!"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2986
+msgid "No raster"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3221
+msgid "Mapinfo settings"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3283
+msgid "Color settings"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3289
+msgid "use border color:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3290
+msgid "use background color:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3430
+msgid ""
+"Units of current projection are not supported,\n"
+" meters will be used!"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3431
+msgid "Unsupported units"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3476
+msgid "Length:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3480
+msgid "Scalebar length is given in map units"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3483
+msgid "Scalebar height is real height on paper"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3485
+msgid "default"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3529
+msgid "Type:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3545
+msgid "Number of segments:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3549
+msgid "Label every "
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3550
+msgid "segments"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3559
+msgid "transparent text background"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3636
+msgid "Length of scale bar is not defined"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3713
+#: ../gui/wxpython/gui_core/dialogs.py:737
+msgid "Enter text:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3739
+msgid "Text effects"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3744
+msgid "text background"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3747
+msgid "highlight"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3752
+msgid "text border"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3829
+msgid "Offset"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3832
+msgid "horizontal (pts):"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3833
+msgid "vertical (pts):"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3846
+msgid " Reference point"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3872
+msgid "Text rotation"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3875
+msgid "rotate text (counterclockwise)"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3951
+msgid "No text entered!"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4120
+msgid "Choose a directory with images"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4152
+msgid "Note: only EPS format supported"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4161
+msgid "Scale And Rotation"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4192 ../gui/wxpython/psmap/dialogs.py:4650
+msgid "Rotation angle (deg):"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4201 ../gui/wxpython/psmap/dialogs.py:4659
+msgid "Counterclockwise rotation in degrees"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4299
+msgid ""
+"PIL\n"
+"missing"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4316
+#, python-format
+msgid "Unable to read file %s"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4374
+#, python-format
+msgid "size: %(width)s x %(height)s pts"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4396
+msgid "No image selected."
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4493
+msgid "North Arrow settings"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4504
+msgid "Compute convergence"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4560
+msgid "Symbol"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4566
+msgid "Select symbol:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4580
+msgid ""
+"Note: Selected symbol is not displayed\n"
+"in draft mode (only in preview mode)"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4598 ../gui/wxpython/psmap/dialogs.py:4852
+msgid "Outline color:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4600 ../gui/wxpython/psmap/dialogs.py:4615
+#: ../gui/wxpython/psmap/dialogs.py:4854 ../gui/wxpython/psmap/dialogs.py:4875
+#: ../gui/wxpython/gui_core/dialogs.py:2027
+msgid "transparent"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4613 ../gui/wxpython/psmap/dialogs.py:4873
+msgid "Fill color:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4636
+msgid "Size and Rotation"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4641
+msgid "Size (pt):"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4643
+msgid "Symbol size in points"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4817
+msgid "Rectangle settings"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4819
+msgid "Line settings"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4905
+msgid "Line width in points"
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:133
+#, python-format
+msgid ""
+"Unable to open file\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:460
+#, python-format
+msgid "Instruction file will be loaded with following region: %s\n"
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:465
+#, python-format
+msgid ""
+"Region cannot be set\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:604
+#: ../gui/wxpython/psmap/instructions.py:754
+#: ../gui/wxpython/psmap/instructions.py:870
+#: ../gui/wxpython/psmap/instructions.py:928
+#: ../gui/wxpython/psmap/instructions.py:1069
+#: ../gui/wxpython/psmap/instructions.py:1124
+#: ../gui/wxpython/psmap/instructions.py:1183
+#: ../gui/wxpython/psmap/instructions.py:1252
+#: ../gui/wxpython/psmap/instructions.py:1358
+#: ../gui/wxpython/psmap/instructions.py:1483
+#: ../gui/wxpython/psmap/instructions.py:1534
+#, python-format
+msgid "Failed to read instruction %s"
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:618
+#, python-format
+msgid ""
+"Scale has changed, old value: %(old)s\n"
+"new value: %(new)s"
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:621
+#, python-format
+msgid ""
+"Failed to read instruction %s.\n"
+"Use 1:25000 notation."
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:629
+#, python-format
+msgid ""
+"Map frame position changed, old value: %(old1)s %(old2)s\n"
+"new value: %(new1)s %(new2)s"
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:637
+#, python-format
+msgid ""
+"Map frame size changed, old value: %(old1)s %(old2)s\n"
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:684
+#, python-format
+msgid ""
+"Failed to read instruction %(file)s.\n"
+"Unknown format %(for)s"
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:697
+#, python-format
+msgid "Failed to read instruction %s."
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:811
+#: ../gui/wxpython/psmap/instructions.py:1693
+#, python-format
+msgid ""
+"Characters on position %s are not supported by ISO-8859-1 (Latin 1) encoding "
+"which is required by module ps.map."
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:815
+#: ../gui/wxpython/psmap/instructions.py:1697
+msgid ""
+"Not all characters are supported by ISO-8859-1 (Latin 1) encoding which is "
+"required by module ps.map."
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:931
+#, python-format
+msgid "Failed to read instruction %(inst)s: file %(file)s not found."
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:50
+msgid "GRASS GIS Cartographic Composer (experimental prototype)"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:179
+msgid ""
+"Python Imaging Library is not available.\n"
+"'Preview' functionality won't work."
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:230
+msgid "Program ps2pdf is not available. Please install it first to create PDF."
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:274
+msgid "Generating PDF..."
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:276
+msgid "Generating PostScript..."
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:278
+msgid "Generating preview..."
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:288
+#, python-format
+msgid "Ps.map exited with return code %s"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:303
+#, python-format
+msgid "ps2pdf exited with return code %s"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:307
+#, python-format
+msgid ""
+"Program ps2pdf is not available. Please install it to create PDF.\n"
+"\n"
+" %s"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:324
+#, python-format
+msgid "Unable to generate preview. %s"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:333
+msgid "Preview generated"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:361
+msgid "Save file as"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:399
+#, python-format
+msgid "Failed to read file %s."
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:587
+msgid "Scalebar is not appropriate for this projection"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:1018
+msgid "wxGUI Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:1020
+msgid ""
+"(C) 2011 by the GRASS Development Team\n"
+"\n"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:1324
+msgid "Click and drag to resize object"
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdisplay.py:869
+#, python-format
+msgid ""
+"Topology for vector map <%s> is not available. Topology is required by "
+"digitizer. Do you want to rebuild topology (takes some time) and open the "
+"vector map for editing?"
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdisplay.py:873
+msgid "Topology missing"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:84
+msgid "Digitize new point"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:85 ../gui/wxpython/vdigit/toolbars.py:94
+#: ../gui/wxpython/vdigit/toolbars.py:97
+msgid "Left: new point"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:87
+msgid "Digitize new line"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:88 ../gui/wxpython/vdigit/toolbars.py:91
+#: ../gui/wxpython/vdigit/toolbars.py:112
+msgid "Left: new point; Ctrl+Left: undo last point; Right: close line"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:90
+msgid "Digitize new boundary"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:93
+msgid "Digitize new centroid"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:96
+msgid ""
+"Digitize new area (composition of boundaries without category and one "
+"centroid with category)"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:99
+msgid "Add new vertex"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:100
+#: ../gui/wxpython/vdigit/toolbars.py:103
+#: ../gui/wxpython/vdigit/toolbars.py:115
+#: ../gui/wxpython/vdigit/toolbars.py:118
+#: ../gui/wxpython/vdigit/toolbars.py:121
+#: ../gui/wxpython/vdigit/toolbars.py:130
+msgid "Left: Select; Ctrl+Left: Unselect; Right: Confirm"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:102
+msgid "Delete feature(s)"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:105
+msgid "Display/update attributes"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:106
+#: ../gui/wxpython/vdigit/toolbars.py:109
+msgid "Left: Select"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:108
+msgid "Display/update categories"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:111
+msgid "Edit line/boundary"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:114
+msgid "Move feature(s)"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:117
+msgid "Move vertex"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:120
+msgid "Remove vertex"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:122
+#: ../gui/wxpython/vdigit/toolbars.py:377
+msgid "Digitization settings"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:123
+msgid "Quit digitizer"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:124
+msgid "Quit digitizer and save changes"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:125
+msgid "Vector Digitizer manual"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:126
+msgid "Show Vector Digitizer manual"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:128
+msgid "Additional tools (copy, flip, connect, etc.)"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:132
+msgid "Undo"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:133
+msgid "Undo previous changes"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:393
+msgid "Break selected lines/boundaries at intersection"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:395
+msgid "Connect selected lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:397
+msgid "Copy categories"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:399
+msgid "Copy features from (background) vector map"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:401
+msgid "Copy attributes"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:403
+msgid "Feature type conversion"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:405
+msgid "Flip selected lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:407
+msgid "Merge selected lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:409
+msgid "Snap selected lines/boundaries (only to nodes)"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:411
+msgid "Split line/boundary"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:413
+msgid "Query features"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:415
+msgid "Z bulk-labeling of 3D lines"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:571
+msgid "Vector map is not 3D. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:640
+#: ../gui/wxpython/vdigit/toolbars.py:723
+#: ../gui/wxpython/vdigit/toolbars.py:802
+msgid "Select vector map"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:678
+#, python-format
+msgid "Please wait, opening vector map <%s> for editing..."
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:695
+#: ../gui/wxpython/mapdisp/toolbars.py:98
+msgid "Digitize"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:731
+#, python-format
+msgid "Do you want to save changes in vector map <%s>?"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:733
+msgid "Save changes?"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:740
+#, python-format
+msgid "Please wait, closing and rebuilding topology of vector map <%s>..."
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:750
+#, python-format
+msgid "Editing of vector map <%s> successfully finished"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:808
+#: ../gui/wxpython/vdigit/toolbars.py:813
+msgid "New vector map"
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:50
+msgid "Digitization Error"
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:55
+#, python-format
+msgid "Unable to open vector map <%s>."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:57
+msgid "No vector map open for editing."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:58
+msgid "Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:65
+msgid "Writing new feature failed. Operation cancelled."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:73
+#, python-format
+msgid "Reading feature id %d failed. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:81
+#, python-format
+msgid "Database link %d not available. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:89
+#, python-format
+msgid "Unable to start database driver <%s>. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:97
+#, python-format
+msgid ""
+"Unable to open database <%(db)s> by driver <%(driver)s>. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:105
+#, python-format
+msgid "Unable to execute SQL query '%s'. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:113
+#, python-format
+msgid "Feature id %d is marked as dead. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:121
+#, python-format
+msgid "Unsupported feature type %d. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:467
+#, python-format
+msgid "Unknown feature type '%s'"
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:472
+msgid "Not enough points for line"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:53
+msgid "Apply changes for this session"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:56
+msgid "Close dialog and save changes to user settings file"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:148
+msgid "Snapping"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:154
+msgid "Snapping threshold"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:161
+msgid "screen pixels"
+msgstr ""
+msgid "map units"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:170
+msgid "Snap also to vertex"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:175
+#: ../gui/wxpython/vdigit/preferences.py:603
+#: ../gui/wxpython/vdigit/preferences.py:617
+#: ../gui/wxpython/vdigit/preferences.py:621
+#, python-format
+msgid "Snapping threshold is %(value).1f %(units)s"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:188
+msgid "Select vector features"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:205
+msgid "Select threshold"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:218
+msgid "Select only features inside of selection bounding box"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:220
+msgid ""
+"By default are selected all features overlapping selection bounding box "
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:223
+msgid "Check for duplicates"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:235
+msgid "Digitize line features"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:238
+msgid "Break lines at intersection"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:248
+msgid "Save changes"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:251
+msgid "Save changes on exit"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:263
+msgid "Query tool"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:270
+msgid "Choose query tool"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:275
+msgid "Select by box"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:284
+#: ../gui/wxpython/vdigit/preferences.py:416
+msgid "length"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:289
+msgid "Select lines"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:291
+#: ../gui/wxpython/vdigit/preferences.py:314
+msgid "shorter than"
+msgstr ""
+msgid "longer than"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:307
+msgid "dangle"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:312
+msgid "Select dangles"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:344
+#: ../gui/wxpython/gui_core/preferences.py:912
+msgid "Attributes"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:351
+msgid "Digitize new feature"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:356
+msgid "Add new record into table"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:362
+msgid "Mode"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:384
+msgid "Next to use"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:372
+msgid "Category number"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:382
+msgid "Category mode"
+msgstr ""
+msgid "Manual entry"
+msgstr ""
+msgid "No category"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:397
+msgid "Delete existing feature(s)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:402
+msgid "Delete record from table"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:412
+msgid "Geometry attributes"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:418
+msgid "perimeter"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:484
+msgid ""
+"Note: These settings are stored in the workspace not in the vector digitizer "
+"preferences."
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:512
+msgid "Digitize new line segment"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:513
+msgid "Digitize new line/boundary"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:514
+msgid "Highlight"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:515
+msgid "Highlight (duplicates)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:518
+msgid "Boundary (no area)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:519
+msgid "Boundary (one area)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:520
+msgid "Boundary (two areas)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:521
+msgid "Centroid (in area)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:522
+msgid "Centroid (outside area)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:523
+msgid "Centroid (duplicate in area)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:524
+msgid "Node (one line)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:525
+msgid "Node (two lines)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:526
+msgid "Vertex"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:527
+msgid "Area (closed boundary + centroid)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:528
+msgid "Direction"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:596
+msgid "Snapping disabled"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:598
+#, python-format
+msgid "Snapping threshold is %(value).1f %(units)s (based on comp. resolution)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:654
+#, python-format
+msgid "Vector digitizer settings saved to file <%s>."
+msgstr ""
+#: ../gui/wxpython/vdigit/mapwindow.py:371
+msgid "Update categories"
+msgstr ""
+#: ../gui/wxpython/vdigit/mapwindow.py:494
+#: ../gui/wxpython/vdigit/mapwindow.py:859
+msgid "No vector map selected for editing."
+msgstr ""
+#: ../gui/wxpython/vdigit/mapwindow.py:502
+msgid "Nothing to do. Choose appropriate tool from digitizer toolbar."
+msgstr ""
+#: ../gui/wxpython/vdigit/mapwindow.py:992
+msgid "Z bulk-labeling dialog"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:74
+msgid "List of categories - right-click to delete"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:105
+msgid "Add new category"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:144
+msgid "Ignore changes and close dialog"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:146
+msgid "Apply changes and close dialog"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:236 ../gui/wxpython/vdigit/dialogs.py:455
+#, python-format
+msgid ""
+"Unable to add new layer/category <%(layer)s/%(category)s>.\n"
+"Layer and category number must be integer.\n"
+"Layer number must be greater than zero."
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:432
+msgid "Unable to update vector map."
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:592
+#, python-format
+msgid "%d lines selected for z bulk-labeling"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:595
+msgid "Set value"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:602
+msgid "Starting value"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:611
+msgid "Step"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:641
+msgid "List of duplicates"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:737
+msgid "Feature id"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:738
+msgid "Layer (Categories)"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:91
+msgid "Define GRASS Database and Location Name"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:107
+#: ../gui/wxpython/gis_set.py:107
+msgid "GIS Data Directory:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:123
+msgid "Project Location"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:134
+msgid "Location Title"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:164
+msgid "Choose GRASS data directory:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:175
+#: ../gui/wxpython/location_wizard/wizard.py:1931
+msgid "Location already exists in GRASS Database."
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:179
+msgid "Unable to create location"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:192
+msgid ""
+"Title of the location is limited only to one line and 256 characters. The "
+"rest of the text will be ignored."
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:199
+msgid "Choose method for creating a new location"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:206
+msgid "Select coordinate system parameters from a list"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:209
+msgid "Select EPSG code of spatial reference system"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:211
+msgid "Read projection and datum terms from a georeferenced data file"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:214
+msgid "Read projection and datum terms from a WKT or PRJ file"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:217
+msgid "Specify projection and datum terms using custom PROJ.4 parameters"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:220
+msgid "Create a generic Cartesian coordinate system (XY)"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:321
+msgid "Choose projection"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:337
+#: ../gui/wxpython/location_wizard/wizard.py:838
+#: ../gui/wxpython/location_wizard/wizard.py:1001
+#: ../gui/wxpython/location_wizard/wizard.py:1266
+msgid "Code"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:342
+msgid "Projection code:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:350
+#: ../gui/wxpython/location_wizard/wizard.py:852
+#: ../gui/wxpython/location_wizard/wizard.py:1014
+msgid "Search in description:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:524
+#, python-format
+msgid "Unable to read list: %s"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:627
+msgid "Choose projection parameters"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:643
+msgid "Select datum or ellipsoid (next page)"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:649
+msgid "Datum with associated ellipsoid"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:652
+msgid "Ellipsoid only"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:709
+#, python-format
+msgid "You must enter a value for %s"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:721
+#: ../gui/wxpython/location_wizard/wizard.py:739
+#, python-format
+msgid " Enter parameters for %s projection "
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:762
+msgid "No"
+msgstr ""
+msgid "Yes"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:816
+msgid "Specify geodetic datum"
+msgstr ""
+msgid "Ellipsoid"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:843
+msgid "Datum code:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:978
+msgid "Specify ellipsoid"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1006
+msgid "Ellipsoid code:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1095
+#: ../gui/wxpython/location_wizard/wizard.py:1155
+msgid "Select georeferenced file"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1100
+msgid "Georeferenced file:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1169
+#: ../gui/wxpython/location_wizard/wizard.py:1226
+msgid "Select WKT file"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1174
+msgid "WKT file:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1240
+msgid "Choose EPSG Code"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1248
+msgid "Path to the EPSG-codes file:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1250
+#: ../gui/wxpython/gui_core/preferences.py:1057
+msgid "EPSG code:"
+msgstr ""
+msgid "Parameters"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1402
+msgid "Choose EPSG codes file"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1431
+#, python-format
+msgid "Unable to read EPGS codes: %s"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1449
+msgid "Choose method of specifying georeferencing parameters"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1457
+msgid "Enter PROJ.4 parameters string:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1505
+#: ../gui/wxpython/location_wizard/wizard.py:1509
+msgid "Datum transform is required."
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1531
+msgid "Summary"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1576
+msgid "GRASS Database:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1582
+msgid "Location Name:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1588
+msgid "Location Title:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1594
+msgid "Projection:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1600
+msgid "PROJ.4 definition:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1673
+#, python-format
+msgid "Do you want to create GRASS location <%s>?"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1674
+msgid "Create new location?"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1714
+msgid "Define new GRASS Location"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1799
+msgid "Do you want to set the default region extents and resolution now?"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1801
+#, python-format
+msgid "Location <%s> created"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1814
+#, python-format
+msgid ""
+"Unable to create new location. Location <%(loc)s> not created.\n"
+"\n"
+"Details: %(err)s"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1822
+msgid "Location wizard canceled. Location not created."
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1929
+msgid "Unable to create new location"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1948
+#, python-format
+msgid ""
+"Location <%(loc)s> will be created in GIS data directory <%(dir)s>. You will "
+"need to change the default GIS data directory in the GRASS startup screen."
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1953
+msgid "New GIS data directory"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1978
+msgid "EPSG code missing."
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1988
+#: ../gui/wxpython/location_wizard/wizard.py:1997
+#, python-format
+msgid "File <%s> not found."
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:36
+msgid "Set default region extent and resolution"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:83
+msgid "&Set region"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:113
+msgid "Invalid location selected."
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:130
+msgid "Invalid region"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:160
+msgid "Click here to show 3D settings"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:161
+msgid "Click here to hide 3D settings"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:184
+#: ../gui/wxpython/location_wizard/dialogs.py:465
+#, python-format
+msgid "Rows: %d"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:185
+#: ../gui/wxpython/location_wizard/dialogs.py:466
+#, python-format
+msgid "Cols: %d"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:186
+#: ../gui/wxpython/location_wizard/dialogs.py:467
+#, python-format
+msgid "Cells: %d"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:227
+#: ../gui/wxpython/location_wizard/dialogs.py:469
+#, python-format
+msgid "Depth: %d"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:228
+#: ../gui/wxpython/location_wizard/dialogs.py:470
+#, python-format
+msgid "3D Cells: %d"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:247
+msgid "T-B resolution"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:310
+msgid "North"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:318
+msgid "West"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:338
+msgid "East"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:347
+msgid "South"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:351
+msgid "N-S resolution"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:359
+msgid "E-W resolution"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:437
+#, python-format
+msgid "Invalid value: %s"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:521
+msgid "Select datum transformation"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:546
+msgid "Select from list of datum transformations"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:56 ../gui/wxpython/gui_core/ghelp.py:64
+msgid "description"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:57 ../gui/wxpython/gui_core/ghelp.py:66
+msgid "command"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:58 ../gui/wxpython/gui_core/ghelp.py:65
+msgid "keywords"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:61
+msgid "Find module(s)"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:133 ../gui/wxpython/gui_core/ghelp.py:166
+#, python-format
+msgid "%d modules found"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:201
+msgid "Menu tree (double-click to run command)"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:211
+msgid "Run selected command"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:272
+msgid "You must run this command from the menu or command line"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:327
+#: ../gui/wxpython/gui_core/goutput.py:696
+#, python-format
+msgid "%d modules match"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:417
+msgid "Official GRASS site:"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:428
+msgid "SVN Revision:"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:439
+msgid "GIS Library Revision:"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:451
+msgid "Python:"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:462
+msgid "wxPython:"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:477
+msgid "Language:"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:493
+msgid "Info"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:494
+msgid "Copyright"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:495
+msgid "License"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:496
+msgid "Authors"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:497
+msgid "Contributors"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:498
+msgid "Extra contributors"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:499
+msgid "Translators"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:533 ../gui/wxpython/gui_core/ghelp.py:557
+#: ../gui/wxpython/gui_core/ghelp.py:580 ../gui/wxpython/gui_core/ghelp.py:635
+#: ../gui/wxpython/gui_core/ghelp.py:694
+#, python-format
+msgid "%s file missing"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:622 ../gui/wxpython/gui_core/ghelp.py:681
+#, python-format
+msgid "Error when reading file '%s'."
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:623 ../gui/wxpython/gui_core/ghelp.py:682
+msgid "Lines:"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:640 ../gui/wxpython/gui_core/ghelp.py:642
+#: ../gui/wxpython/gui_core/ghelp.py:704
+msgid "E-mail"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:642
+msgid "Country"
+msgstr ""
+msgid "OSGeo_ID"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:706
+msgid "Language"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:846
+msgid "&Next"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:849
+msgid "&Previous"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:31
+msgid "Display map"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:32
+msgid "Re-render modified map layers only"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:34
+msgid "Render map"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:35
+msgid "Force re-rendering all map layers"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:37
+msgid "Erase display"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:38
+msgid "Erase display canvas with given background color"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:40
+msgid "Pointer"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:42
+msgid "Zoom in"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:43
+msgid "Drag or click mouse to zoom"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:45
+msgid "Zoom out"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:46
+msgid "Drag or click mouse to unzoom"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:48
+msgid "Return to previous zoom"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:50
+msgid "Various zoom options"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:51
+msgid "Zoom to computational, default, saved region, ..."
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:53
+msgid "Zoom to selected map layer(s)"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:55
+msgid "Pan"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:56
+msgid "Drag with mouse to pan"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:58
+msgid "Save display to graphic file"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:62
+msgid "Select font"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:64
+msgid "Show manual"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:68
+msgid "Add raster map layer"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:70
+msgid "Add vector map layer"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:72
+msgid "Add map elements"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:73
+msgid "Overlay elements like scale and legend onto map"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:75
+msgid "Create histogram with d.histogram"
+msgstr ""
+#: ../gui/wxpython/gui_core/prompt.py:393
+#, python-format
+msgid "Warning: flag <%(flag)s> not found in '%(module)s'"
+msgstr ""
+#: ../gui/wxpython/gui_core/prompt.py:396
+#, python-format
+msgid "Warning: option <%(param)s> not found in '%(module)s'"
+msgstr ""
+#: ../gui/wxpython/gui_core/prompt.py:638
+msgid "Type GRASS command and run by pressing ENTER"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:56
+msgid "User settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:76
+msgid "Set to default"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:84
+msgid "Revert settings to default and apply changes"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:147
+msgid "Settings applied to current session but not saved"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:165
+#, python-format
+msgid "Settings saved to file '%s'."
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:199
+msgid "Key column cannot be empty string."
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:236
+msgid "GUI Settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:262
+msgid "Layer Manager settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:273
+msgid "Ask when removing map layer from layer tree"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:283
+msgid "Ask when quiting wxGUI or closing display"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:293
+#: ../gui/wxpython/gui_core/preferences.py:303
+#, python-format
+msgid "Hide '%s' tab (requires GUI restart)"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:316
+msgid "Automatically copy selected text to clipboard (in Command console)"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:330
+msgid "Workspace settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:338
+msgid "Suppress positioning Map Display Window(s)"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:350
+msgid "Suppress positioning Layer Manager window"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:361
+msgid "Save current window layout as default"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:364
+msgid ""
+"Save current position and size of Layer Manager window and opened Map "
+"Display window(s) and use as default for next sessions."
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:405
+msgid "Font for command output:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:410
+#: ../gui/wxpython/gui_core/preferences.py:580
+#: ../gui/wxpython/gui_core/dialogs.py:766
+msgid "Set font"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:419
+msgid "Language settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:429
+msgid "Choose language (requires to save and GRASS restart):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:449
+msgid "Appearance settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:460
+msgid "Element list:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:482
+msgid "Menu style (requires to save and GUI restart):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:506
+msgid "Height of map selection popup window (in pixels):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:530
+msgid "Icon theme (requires GUI restart):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:560
+msgid "Map Display"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:575
+msgid "Default font for GRASS displays:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:592
+msgid "Default display settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:604
+msgid "Display driver:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:633
+msgid "Statusbar mode:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:672
+#: ../gui/wxpython/mapdisp/statusbar.py:435
+msgid "Align region extent based on display size"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:685
+#: ../gui/wxpython/mapdisp/statusbar.py:455
+msgid "Constrain display resolution to computational settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:698
+msgid "Enable auto-rendering"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:711
+msgid "Enable auto-zooming to selected map layer"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:724
+msgid "Enable zooming by mouse wheel"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:764
+msgid "Command dialog settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:786
+msgid "Close dialog when command is successfully finished"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:796
+#: ../gui/wxpython/gui_core/dialogs.py:254
+msgid "Add created map into layer tree"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:807
+msgid "Allow interactive input"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:817
+msgid "Verbosity level:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:836
+msgid "Raster settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:847
+msgid "Overlay raster maps"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:858
+msgid "Default color table"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:884
+msgid "Vector settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:890
+msgid "Display:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:920
+msgid "Highlighting"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:936
+msgid "Line width (in pixels):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:959
+msgid "Data browser"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:964
+msgid "Left mouse double click:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:976
+msgid "Encoding (e.g. utf-8, ascii, iso8859-1, koi8-r):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:987
+msgid "Ask when deleting data record(s) from table"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1008
+msgid "Create table"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1015
+#: ../gui/wxpython/gui_core/dialogs.py:284
+msgid "Key column:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1041
+#: ../gui/wxpython/mapdisp/statusbar.py:681
+msgid "Projection"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1048
+msgid "Projection statusbar settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1074
+msgid "Proj.4 string (required):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1090
+msgid "EPSG file:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1105
+msgid ""
+"Load EPSG codes (be patient), enter EPSG code or insert Proj.4 string "
+"directly."
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1113
+msgid "&Load EPSG codes"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1124
+msgid "Coordinates format"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1133
+msgid "LL projections"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1152
+msgid "Precision:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1190
+#, python-format
+msgid "Unable to read EPSG codes: %s"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1219
+#: ../gui/wxpython/gui_core/preferences.py:1228
+#: ../gui/wxpython/gui_core/preferences.py:1237
+#, python-format
+msgid "EPSG code %s not found"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1245
+msgid "Select default display font"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1270
+msgid "Select output font"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1344
+msgid "Select font:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1368
+msgid "Character encoding:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1484
+msgid "Manage access to mapsets"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1497
+msgid ""
+"Check a mapset to make it accessible, uncheck it to hide it.\n"
+"  Notes:\n"
+"    - The current mapset is always accessible.\n"
+"    - You may only write to the current mapset.\n"
+"    - You may only write to mapsets which you own."
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1571
+#: ../gui/wxpython/gui_core/gselect.py:346
+msgid "Mapset"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1572
+msgid "Owner"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:134
+#: ../gui/wxpython/gui_core/forms.py:1248
+msgid "Select Color"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:424
+msgid "Enter parameters for '"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:435
+msgid "Close this window without executing the command (Ctrl+Q)"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:456
+msgid "Run the command (Ctrl+R)"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:476
+msgid "Show manual page of the command (Ctrl+H)"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:497
+msgid "Add created map(s) into layer tree"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:512
+msgid "Close dialog on finish"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:514
+msgid ""
+"Close dialog when command is successfully finished. Change this settings in "
+"Preferences dialog ('Command' tab)."
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:681
+#, python-format
+msgid "'%s' copied to clipboard"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:744 ../gui/wxpython/gui_core/forms.py:757
+msgid "Required"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:747 ../gui/wxpython/gui_core/forms.py:757
+msgid "Optional"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:791
+msgid "Manual"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:831
+#: ../gui/wxpython/gui_core/forms.py:1340
+msgid "Parameterized in model"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:906
+msgid "[multiple]"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:953
+msgid "valid range"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1267
+msgid "Transparent"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1287
+#, python-format
+msgid "Choose %s"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1288
+#: ../gui/wxpython/gui_core/gselect.py:1122
+msgid "File"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1321
+msgid "or enter values interactively"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1501
+msgid "Nothing to load."
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1533
+msgid "Save input as..."
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1767
+#, python-format
+msgid "Error in %s"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1871
+#, python-format
+msgid "Unable to parse command '%s'"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1877
+#, python-format
+msgid "%(cmd)s: parameter '%(key)s' not available"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1984
+#, python-format
+msgid "usage: %s <grass command>"
+msgstr ""
+#: ../gui/wxpython/gui_core/mapdisp.py:84 ../gui/wxpython/core/render.py:434
+#, python-format
+msgid "GRASS module '%s' not found. Unable to start map display window."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:111
+msgid "Type of element:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:142
+msgid "Select GRASS location and mapset"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:143
+msgid "Name of GRASS location:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:163
+#: ../gui/wxpython/gui_core/dialogs.py:195
+msgid "Name of mapset:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:193
+msgid "Select mapset in GRASS location"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:236
+msgid "Name for new vector map:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:242
+msgid "Create attribute table"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:359
+#, python-format
+msgid "Unable to create vector map <%s>."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:364
+#, python-format
+msgid ""
+"Invalid or empty key column.\n"
+"Unable to create vector map <%s>."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:381
+#, python-format
+msgid ""
+"Vector map <%s> already exists in the current mapset. Do you want to "
+"overwrite it?"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:384
+msgid "Overwrite?"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:431
+#, python-format
+msgid "New vector map <%s> created"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:453
+msgid "Load region:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:457
+msgid "Save region:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:526
+msgid "Set size and position"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:527
+msgid ""
+"Click and drag on the map display to set legend size and position and then "
+"press OK"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:538
+#, python-format
+msgid ""
+"Drag %s with mouse in pointer mode to position.\n"
+"Double-click to change options."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:541
+msgid ""
+"\n"
+"Define raster map name for legend in properties dialog."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:590
+#, python-format
+msgid "Legend of raster map <%s>"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:727
+msgid "Show text object"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:777
+msgid ""
+"Drag text with mouse in pointer mode to position.\n"
+"Double-click to change options"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:858
+msgid "Create or edit imagery groups"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:876
+msgid "Apply changes to selected group and close dialog"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:877
+msgid "Apply changes to selected group"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:878
+msgid "Close dialog, changes are not applied"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:919
+msgid "Select the group you want to edit or enter name of new group:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:930
+msgid "Layers in selected group:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:942
+msgid "Select map layers and add them to the list."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:946
+msgid "Remove selected layer(s) from list."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:956
+msgid "Define also sub-group (same name as group)"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:971
+msgid "Add selected map layers into group"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1005
+#, python-format
+msgid "Group <%s> was changed, do you want to apply changes?"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1007
+msgid "Unapplied changes"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1089
+#, python-format
+msgid "No changes to apply in group <%s>."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1092
+#, python-format
+msgid "Group <%s> was successfully created."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1094
+#, python-format
+msgid "Group <%s> was successfully changed."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1097
+#, python-format
+msgid "Creating of new group <%s> failed."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1099
+#, python-format
+msgid "Changing of group <%s> failed."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1128
+msgid "No group selected."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1190
+msgid "Use fully-qualified map names"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1197
+#, python-format
+msgid "Dynamic series (%s)"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1235
+msgid "Map type:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1258
+msgid "Select toggle"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1265
+msgid "Mapset:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1275
+msgid "Pattern:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1287
+msgid "List of maps:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1342
+msgid "Invert selection"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1449
+msgid "Multiple import"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1463
+#, python-format
+msgid " List of %s layers "
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1468
+msgid "Layer id"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1469
+msgid "Layer name"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1470
+msgid "Name for GRASS map (editable)"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1679
+msgid "Add linked layers into layer tree"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1686
+msgid "&Link"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1687
+msgid "Link selected layers"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1707
+msgid "No layers selected. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1794
+msgid "Import DXF layers"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1798
+msgid "Choose DXF file to import"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2003
+msgid "Set Map Layer Opacity"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2030
+msgid "opaque"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2118
+msgid "Set image size"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2127
+msgid "Image size"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2174
+msgid "Template:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2215
+msgid "Symbols"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2242
+msgid "Symbol directory:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2250
+msgid "Symbol name:"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:234
+msgid "Click here to show search module engine"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:235
+msgid "Click here to hide search module engine"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:253
+msgid "Output window"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:255
+msgid "Command prompt"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:259
+msgid "Clear output window content"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:261
+msgid "Clear command prompt content"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:263
+msgid "Save output window content to the file"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:265
+msgid "Abort running command"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:268
+msgid "&Protocol"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:270
+msgid ""
+"Toggle to save list of executed commands into file; content saved when "
+"switching off."
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:487
+#: ../gui/wxpython/gui_core/goutput.py:668
+#: ../gui/wxpython/gui_core/goutput.py:781
+#, python-format
+msgid ""
+"Unable to write file '%s'.\n"
+"\n"
+"Details: %s"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:523
+#, python-format
+msgid ""
+"Command '%s' not yet implemented in the WxGUI. Try adding it as a command "
+"layer instead."
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:564
+#, python-format
+msgid ""
+"Unable to run command:\n"
+"%(cmd)s\n"
+"\n"
+"Option <%(opt)s>: read from standard input is not supported by wxGUI"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:654
+#: ../gui/wxpython/gui_core/goutput.py:798
+msgid "Save file as..."
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:656
+#: ../gui/wxpython/gui_core/goutput.py:800
+#, python-format
+msgid "%s (*.txt)|*.txt|%s (*)|*"
+msgstr ""
+msgid "Text files"
+msgstr ""
+msgid "Files"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:671
+#, python-format
+msgid "Commands output saved into '%s'"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:785
+#, python-format
+msgid "Commands protocol saved into '%s'"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:834
+#, python-format
+msgid "%d sec"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:837
+#, python-format
+msgid "%(min)d min %(sec)d sec"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:845
+msgid ""
+"Please note that the data are left in inconsistent state and may be corrupted"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:847
+msgid "Command aborted"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:849
+msgid "Command finished"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:325
+msgid "Not selectable element"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:370
+#, python-format
+msgid "GSelect: invalid item: %s"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:876 ../gui/wxpython/gis_set.py:676
+msgid "Choose GIS Data Directory"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1105
+msgid "Output settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1107
+msgid "Source settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1118
+msgid "Native"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1126
+msgid "Directory"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1134
+msgid "Protocol"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1148
+msgid "Save current settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1151
+msgid "Delete currently selected settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1157
+msgid "Output type"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1159
+msgid "Source type"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1167
+#: ../gui/wxpython/gui_core/gselect.py:1170
+#: ../gui/wxpython/gui_core/gselect.py:1501
+#: ../gui/wxpython/gui_core/gselect.py:1503
+#: ../gui/wxpython/gui_core/gselect.py:1689
+#: ../gui/wxpython/gui_core/gselect.py:1691
+msgid "All files"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1174
+#: ../gui/wxpython/gui_core/gselect.py:1507
+msgid "Choose file to import"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1183
+msgid "Choose input directory"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1192
+#: ../gui/wxpython/gui_core/gselect.py:1695
+msgid "Choose file"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1226
+msgid "File:"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1235
+msgid "Protocol:"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1262
+msgid "Extension:"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1290
+msgid "Load settings:"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1311
+msgid "Format:"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1333
+msgid "Creation options:"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1370
+#, python-format
+msgid "Settings <%s> not found"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1382
+#: ../gui/wxpython/gui_core/gselect.py:1403
+msgid "Save settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1389
+msgid "Name not given, settings is not saved."
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1394
+msgid "No data source defined, settings is not saved."
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1401
+#, python-format
+msgid "Settings <%s> already exists. Do you want to overwrite the settings?"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1423
+msgid "No settings is defined. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1442
+msgid "Unable to save settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1587
+#, python-format
+msgid "Database <%s> not accessible."
+msgstr ""
+#: ../gui/wxpython/core/gcmd.py:80 ../gui/wxpython/core/settings.py:65
+#, python-format
+msgid "ERROR: %s\n"
+msgstr ""
+#: ../gui/wxpython/core/gcmd.py:121
+msgid "Reason"
+msgstr ""
+#: ../gui/wxpython/core/gcmd.py:133 ../gui/wxpython/core/workspace.py:1013
+#: ../gui/wxpython/mapdisp/mapwindow.py:1663
+msgid "Warning"
+msgstr ""
+#: ../gui/wxpython/core/gcmd.py:383
+msgid "Execution failed:"
+msgstr ""
+#: ../gui/wxpython/core/gcmd.py:386 ../gui/wxpython/core/render.py:643
+#: ../gui/wxpython/core/render.py:646
+msgid "Details:"
+msgstr ""
+#: ../gui/wxpython/core/gcmd.py:388 ../gui/wxpython/core/gcmd.py:392
+msgid "Error: "
+msgstr ""
+#: ../gui/wxpython/core/gcmd.py:467
+#, python-format
+msgid "Unable to exectute command: '%s'"
+msgstr ""
+#: ../gui/wxpython/core/menudata.py:84
+msgid "Unknow tag"
+msgstr ""
+#: ../gui/wxpython/core/utils.py:302
+#, python-format
+msgid "Vector map <%(map)s>: %(msg)s\n"
+msgstr ""
+#: ../gui/wxpython/core/utils.py:525
+#, python-format
+msgid "failed to open '%s'"
+msgstr ""
+#: ../gui/wxpython/core/utils.py:760
+#, python-format
+msgid "ERROR: Unable to determine GRASS version. Details: %s"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:459
+msgid "Segment break"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:526
+msgid "animation"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:707
+msgid "Collapse all except PERMANENT and current"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:708
+msgid "Collapse all except PERMANENT"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:709
+msgid "Collapse all except current"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:710
+msgid "Collapse all"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:711
+msgid "Expand all"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:715
+msgid "Display selected"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:725
+msgid "Classic (labels only)"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:726
+msgid "Combined (labels and module names)"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:727
+msgid "Professional (module names only)"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:734
+msgid "Scroll forward to zoom in"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:735
+msgid "Scroll back to zoom in"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:768
+msgid "box"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:769
+msgid "sphere"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:770
+msgid "cube"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:771
+msgid "diamond"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:772
+msgid "dtree"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:773
+msgid "ctree"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:774
+msgid "aster"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:775
+msgid "gyro"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:776
+msgid "histogram"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:813
+#, python-format
+msgid "Unable to read settings file <%s>\n"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:837
+#, python-format
+msgid ""
+"Error: Reading settings from file <%(file)s> failed.\n"
+"\t\tDetails: %(detail)s\n"
+"\t\tLine: '%(line)s'\n"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:856
+msgid "Unable to create settings directory"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:892
+#, python-format
+msgid ""
+"Writing settings to file <%(file)s> failed.\n"
+"\n"
+"Details: %(detail)s"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:991
+msgid "Unable to set "
+msgstr ""
+#: ../gui/wxpython/core/settings.py:1017 ../gui/wxpython/core/settings.py:1023
+#, python-format
+msgid "Unable to parse settings '%s'"
+msgstr ""
+#: ../gui/wxpython/core/workspace.py:996
+#, python-format
+msgid "Unable to open file <%s> for reading."
+msgstr ""
+#: ../gui/wxpython/core/workspace.py:1009
+#, python-format
+msgid ""
+"Some lines were skipped when reading settings from file <%(file)s>.\n"
+"See 'Command output' window for details.\n"
+"\n"
+"Number of skipped lines: %(line)d"
+msgstr ""
+#: ../gui/wxpython/core/workspace.py:1227
+#, python-format
+msgid " row %d:"
+msgstr ""
+#: ../gui/wxpython/core/render.py:125
+#, python-format
+msgid "<%(name)s>: layer type <%(type)s> is not supported"
+msgstr ""
+#: ../gui/wxpython/core/render.py:180
+#, python-format
+msgid "Command '%s' failed\n"
+msgstr ""
+#: ../gui/wxpython/core/render.py:181
+#, python-format
+msgid "Details: %s\n"
+msgstr ""
+#: ../gui/wxpython/core/render.py:280
+#, python-format
+msgid "Unsupported map layer type '%s'"
+msgstr ""
+#: ../gui/wxpython/core/render.py:421
+msgid "GISBASE not set. You must be in GRASS GIS to run this program."
+msgstr ""
+#: ../gui/wxpython/core/render.py:466
+#, python-format
+msgid "Error: Unable to open '%(file)s'. Reason: %(ret)s. wxGUI exited.\n"
+msgstr ""
+#: ../gui/wxpython/core/render.py:642
+#, python-format
+msgid "Unable to zoom to raster map <%s>."
+msgstr ""
+#: ../gui/wxpython/core/render.py:645
+#, python-format
+msgid "Unable to zoom to vector map <%s>."
+msgstr ""
+#: ../gui/wxpython/core/render.py:648
+msgid ""
+"Unable to get current geographic extent. Force quiting wxGUI. Please "
+"manually run g.region to fix the problem."
+msgstr ""
+#: ../gui/wxpython/core/render.py:931
+#, python-format
+msgid "ERROR: Rendering failed. Details: %s"
+msgstr ""
+#: ../gui/wxpython/core/render.py:980 ../gui/wxpython/core/render.py:1064
+#, python-format
+msgid "Unable to render map layer <%s>."
+msgstr ""
+#: ../gui/wxpython/core/render.py:1173 ../gui/wxpython/core/render.py:1212
+#, python-format
+msgid "Unable to render overlay <%s>."
+msgstr ""
+#: ../gui/wxpython/scripts/p.vect.py:356 ../gui/wxpython/scripts/p.rast.py:99
+#: ../gui/wxpython/scripts/p.cmd.py:53
+msgid "GRASS_PYCMDFILE - File not found. Run p.mon."
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:33
+msgid "No GRASS-python library found."
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:65
+msgid "Input Data"
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:71
+msgid "Point dataset:"
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:83
+msgid "Numeric column:"
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:94
+msgid "Kriging"
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:114
+msgid "Output"
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:118
+msgid "Name for the output raster map:"
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:126
+msgid "Export variance map as well: "
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:267
+msgid "Kriging Module"
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:271
+msgid "Ready."
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:295
+msgid "Variogram fitting"
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:305
+msgid "Plot/refresh variogram"
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:316
+msgid ":"
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:341
+msgid "Kriging techniques"
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:355
+msgid "Block size:"
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:388
+msgid "Auto-fit variogram"
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:412
+msgid "Model: "
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:496
+msgid "Work in progress! No functionality provided."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:94
+msgid "Choose project location and mapset"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:97
+msgid "Manage"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:99
+#, python-format
+msgid ""
+"Welcome to GRASS GIS %s\n"
+"The world's leading open source GIS"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:103
+msgid ""
+"Select an existing project location and mapset\n"
+"or define a new location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:109
+msgid ""
+"Project location\n"
+"(projection/coordinate system)"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:112
+msgid ""
+"Accessible mapsets\n"
+"(directories of GIS files)"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:115
+msgid ""
+"Create new mapset\n"
+"in selected location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:118
+msgid "Define new location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:121
+msgid ""
+"Rename/delete selected\n"
+"mapset or location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:126
+msgid "Start &GRASS"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:132
+msgid "&Browse"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:134
+msgid "&Create mapset"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:136
+msgid "&Location wizard"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:138
+msgid "Rename mapset"
+msgstr ""
+msgid "Rename location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:139
+msgid "Delete mapset"
+msgstr ""
+msgid "Delete location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:181
+msgid "Welcome to GRASS GIS"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:189
+msgid "Enter GRASS session"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:205 ../gui/wxpython/gis_set.py:550
+msgid "Unable to set GRASS database. Check your locale settings."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:223
+#, python-format
+msgid "ERROR: Location <%s> not found"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:235
+#, python-format
+msgid "ERROR: Mapset <%s> not found"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:419
+msgid ""
+"Mapset <PERMANENT> is required for valid GRASS location.\n"
+"\n"
+"This mapset cannot be renamed."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:424 ../gui/wxpython/gis_set.py:459
+#, python-format
+msgid ""
+"Current name: %s\n"
+"\n"
+"Enter new name:"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:425
+msgid "Rename selected mapset"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:436
+#, python-format
+msgid ""
+"Unable to rename mapset.\n"
+"\n"
+"Mapset <%s> already exists in location."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:448
+#, python-format
+msgid ""
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:460
+msgid "Rename selected location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:471
+#, python-format
+msgid ""
+"Unable to rename location.\n"
+"\n"
+"Location <%s> already exists in GRASS database."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:484
+#, python-format
+msgid ""
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:496
+msgid ""
+"\n"
+"This mapset cannot be deleted."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:500
+#, python-format
+msgid ""
+"Do you want to continue with deleting mapset <%(mapset)s> from location <"
+"%(location)s>?\n"
+"\n"
+"ALL MAPS included in this mapset will be PERMANENTLY DELETED!"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:505
+msgid "Delete selected mapset"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:514
+msgid "Unable to delete mapset"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:525
+#, python-format
+msgid ""
+"Do you want to continue with deleting location <%s>?\n"
+"\n"
+"ALL MAPS included in this location will be PERMANENTLY DELETED!"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:529
+msgid "Delete selected location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:540
+msgid "Unable to delete location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:699
+#, python-format
+msgid "Mapset <%s> already exists."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:711
+#, python-format
+msgid "Unable to create new mapset: %s"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:730
+#, python-format
+msgid ""
+"GRASS is already running in selected mapset <%(mapset)s>\n"
+"(file %(lock)s found).\n"
+"\n"
+"Concurrent use not allowed.\n"
+"\n"
+"Do you want to try to remove .gislock (note that you need permission for "
+"this operation) and continue?"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:736 ../gui/wxpython/gis_set.py:748
+msgid "Lock file found"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:744
+msgid ""
+"ARE YOU REALLY SURE?\n"
+"\n"
+"If you really are running another GRASS session doing this could corrupt "
+"your data. Have another look in the processor manager just to be sure..."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:759
+#, python-format
+msgid ""
+"Unable to remove '%(lock)s'.\n"
+"\n"
+"Details: %(reason)s"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:787
+msgid "GRASS Quickstart"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:860
+msgid "Starting GRASS for the first time"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:861
+msgid ""
+"GRASS needs a directory in which to store its data. Create one now if you "
+"have not already done so. A popular choice is \"grassdata\", located in your "
+"home directory."
+msgstr ""
+#: ../gui/wxpython/mapdisp/main.py:116
+#, python-format
+msgid "Starting map display <%s>..."
+msgstr ""
+#: ../gui/wxpython/mapdisp/main.py:123
+msgid "GRASS GIS Map Display: "
+msgstr ""
+#: ../gui/wxpython/mapdisp/main.py:129
+#, python-format
+msgid "Stopping map display <%s>..."
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:28
+msgid "Query raster/vector map(s)"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:29
+msgid "Query selected raster/vector map(s)"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:31
+msgid "Add scalebar and north arrow"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:33
+msgid "Add legend"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:37
+msgid "Analyze map"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:38
+msgid "Measuring, profiling, histogramming, ..."
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:40
+msgid "Measure distance"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:42
+msgid "Profile surface map"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:44
+msgid "Create bivariate scatterplot of raster maps"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:46
+#: ../gui/wxpython/mapdisp/frame.py:1131
+msgid "Add text layer"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:48
+msgid "Create histogram of raster map"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:53
+msgid "Rotate 3D scene"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:54
+msgid "Drag with mouse to rotate 3D scene"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:57
+msgid ""
+"Drag with mouse, hold Ctrl down for different mode or Shift to accelerate"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:59
+msgid "Click mouse to zoom"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:60
+msgid "Click mouse to unzoom"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:78 ../gui/wxpython/mapdisp/frame.py:197
+#: ../gui/wxpython/mapdisp/frame.py:208 ../gui/wxpython/mapdisp/frame.py:260
+#: ../gui/wxpython/mapdisp/frame.py:407
+msgid "2D view"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:88
+msgid "3D view mode not available"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:89
+#: ../gui/wxpython/mapdisp/toolbars.py:106
+#, python-format
+msgid "Reason: %s"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:90
+msgid ""
+"Note that the wxGUI's 3D view mode is currently disabled on MS Windows "
+"(hopefully this will be fixed soon). Please keep an eye out for updated "
+"versions of GRASS. In the meantime you can use \"NVIZ\" from the File menu."
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:105
+msgid "Vector digitizer not available"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:107
+msgid ""
+"Note that the wxGUI's vector digitizer is currently disabled (hopefully this "
+"will be fixed soon). Please keep an eye out for updated versions of GRASS. "
+"In the meantime you can use \"v.digit\" from the Develop Vector menu."
+msgstr ""
+#: ../gui/wxpython/mapdisp/gprint.py:285
+msgid ""
+"There was a problem printing.\n"
+"Perhaps your current printer is not set correctly?"
+msgstr ""
+#: ../gui/wxpython/mapdisp/mapwindow.py:1621
+msgid "Zoom to saved region extents"
+msgstr ""
+#: ../gui/wxpython/mapdisp/mapwindow.py:1630
+#, python-format
+msgid "Region <%s> not found. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/mapdisp/mapwindow.py:1651
+msgid "Save display extents to region file"
+msgstr ""
+#: ../gui/wxpython/mapdisp/mapwindow.py:1661
+#, python-format
+msgid "Region file <%s> already exists. Do you want to overwrite it?"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:62
+msgid "GRASS GIS - Map display"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:193
+#, python-format
+msgid ""
+"Unable to start wxGUI vector digitizer.\n"
+"Do you want to start TCL/TK digitizer (v.digit) instead?\n"
+"\n"
+"Details: %s"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:200
+msgid "Vector digitizer failed"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:241
+msgid "Vector Digitizer Toolbar"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:262
+#, python-format
+msgid ""
+"Unable to switch to 3D display mode.\n"
+"The Nviz python extension was not found or loaded properly.\n"
+"Switching back to 2D display mode.\n"
+"\n"
+"Details: %s"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:287
+msgid "Starting 3D view mode..."
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:289
+msgid "Please wait, loading data..."
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:345
+msgid "Please wait, unloading data..."
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:346
+msgid "Switching back to 2D view mode..."
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:651
+msgid "No raster or vector map layer selected for querying."
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:697
+#, python-format
+msgid "Vector map <%s> opened for editing - skipped."
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:702
+msgid "Nothing to query."
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:752
+msgid "No map layer selected for querying."
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:789
+msgid "Nothing found."
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:918
+#, python-format
+msgid ""
+"Click and drag with left mouse button to measure.%sDouble click with left "
+"button to clear."
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:924
+msgid "Measuring distance"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:927
+msgid "Measuring distance:"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:937
+#, python-format
+msgid ""
+"Geodesic distance is not yet supported by this tool.\n"
+"Reason: %s"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:965 ../gui/wxpython/mapdisp/frame.py:971
+msgid "segment"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:966 ../gui/wxpython/mapdisp/frame.py:972
+msgid "total distance"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:967
+msgid "bearing"
+msgstr ""
+msgid "deg"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:1072
+msgid "Scale and North arrow"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:1078
+msgid "Show/hide scale and North arrow"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:1079
+msgid "scale object"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:1108
+msgid "Show/hide legend"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:1109
+msgid "legend object"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:1234
+msgid "Set computational region from display extent"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:357
+msgid "Render"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:363
+msgid "Enable/disable auto-rendering"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:385
+msgid "Show comp. extent"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:388
+msgid "Show computational extent"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:392
+msgid ""
+"Show/hide computational region extent (set with g.region). Display region "
+"drawn as a blue box inside the computational region, computational region "
+"inside a display region as a red box)."
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:432
+msgid "Display mode"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:439
+msgid ""
+"Align region extent based on display size from center point. Default value "
+"for new map displays can be set up in 'User GUI settings' dialog."
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:452
+msgid "Display resolution"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:459
+msgid ""
+"Constrain display resolution to computational region settings. Default value "
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:483
+msgid "Map scale"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:497
+msgid ""
+"As everyone's monitors and resolutions are set differently these values are "
+"not true map scales, but should get you into the right neighborhood."
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:550
+msgid "Go to"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:571
+#: ../gui/wxpython/mapdisp/statusbar.py:635
+#: ../gui/wxpython/mapdisp/statusbar.py:808
+#: ../gui/wxpython/mapdisp/statusbar.py:874
+msgid "Projection not defined (check the settings)"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:649
+#: ../gui/wxpython/mapdisp/statusbar.py:821
+#: ../gui/wxpython/mapdisp/statusbar.py:904
+msgid "Error in projection (check the settings)"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:683
+msgid "Use defined projection"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:695
+msgid ""
+"Reproject coordinates displayed in the statusbar. Projection can be defined "
+"in GUI preferences dialog (tab 'Projection')"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:720
+msgid "MASK"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:763
+msgid "Display geometry"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:779
+msgid "Coordinates"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:833
+msgid "Extent"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:928
+msgid "Comp. region"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:977
+msgid "Go to GCP No."
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:993
+msgid "Valid Range:"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:1053
+msgid "RMS error"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:1056
+#, python-format
+msgid "Forward: %(forw)s, Backward: %(back)s"
+msgstr ""
