[GRASS-SVN] r52151 - in grass/branches/develbranch_6: gui/wxpython/gui_core lib/python
Wed Jun 20 00:58:28 PDT 2012
Author: annakrat
Date: 2012-06-20 00:58:28 -0700 (Wed, 20 Jun 2012)
New Revision: 52151
   grass/branches/develbranch_6/gui/wxpython/gui_core/goutput.py
   grass/branches/develbranch_6/lib/python/db.py
wxGUI: fix gettext warnings (merge from trunk, r52149)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_core/goutput.py
--- grass/branches/develbranch_6/gui/wxpython/gui_core/goutput.py	2012-06-20 07:58:15 UTC (rev 52150)
+++ grass/branches/develbranch_6/gui/wxpython/gui_core/goutput.py	2012-06-20 07:58:28 UTC (rev 52151)
@@ -477,13 +477,14 @@
         # update history file
         env = grass.gisenv()
         try:
-            fileHistory = codecs.open(os.path.join(env['GISDBASE'],
-                                                   env['LOCATION_NAME'],
-                                                   env['MAPSET'],
-                                                   '.bash_history'),
-                                      encoding = 'utf-8', mode = 'a')
+            filePath = os.path.join(env['GISDBASE'],
+                                    env['LOCATION_NAME'],
+                                    env['MAPSET'],
+                                    '.bash_history')
+            fileHistory = codecs.open(filePath, encoding = 'utf-8', mode = 'a')
         except IOError, e:
-            GError(_("Unable to write file '%s'.\n\nDetails: %s") % (path, e),
+            GError(_("Unable to write file '%(filePath)s'.\n\nDetails: %(error)s") %
+                    {filePath: filePath, error : e },
                    parent = self.parent)
             fileHistory = None
@@ -653,7 +654,8 @@
         dlg = wx.FileDialog(self, message = _("Save file as..."),
                             defaultFile = "grass_cmd_output.txt",
-                            wildcard = _("%s (*.txt)|*.txt|%s (*)|*") % (_("Text files"), _("Files")),
+                            wildcard = _("%(txt)s (*.txt)|*.txt|%(files)s (*)|*") %
+                            {txt: _("Text files"), files: _("Files")},
                             style = wx.SAVE | wx.FD_OVERWRITE_PROMPT)
         # Show the dialog and retrieve the user response. If it is the OK response,
@@ -665,7 +667,7 @@
                 output = open(path, "w")
                 output.write(text)
             except IOError, e:
-                GError(_("Unable to write file '%s'.\n\nDetails: %s") % (path, e))
+                GError(_("Unable to write file '%(path)s'.\n\nDetails: %(error)s") % {path: path, error: e})
             finally:
                 output.close()
             self.parent.SetStatusText(_("Commands output saved into '%s'") % path)
@@ -778,7 +780,8 @@
             if len(cmds) > 0:
                 output.write('\n')
         except IOError, e:
+                    {filePath: self.cmdFileProtocol, error: e})
         finally:
             output.close()
@@ -797,7 +800,8 @@
             # ask for the file
                                 defaultFile = "grass_cmd_protocol.txt",
             if dlg.ShowModal() == wx.ID_OK:
                 self.cmdFileProtocol = dlg.GetPath()
Modified: grass/branches/develbranch_6/lib/python/db.py
--- grass/branches/develbranch_6/lib/python/db.py	2012-06-20 07:58:15 UTC (rev 52150)
+++ grass/branches/develbranch_6/lib/python/db.py	2012-06-20 07:58:28 UTC (rev 52151)
@@ -123,8 +123,8 @@
     elif table:
         args['table'] = table
     else:
-        fatal(_("Programmer error: '%s', '%s', or '%s' must be provided") %
-              'sql', 'filename', 'table')
+        fatal(_("Programmer error: '%(sql)s', '%(filename)s', or '%(table)s' must be provided") %
+              {sql: 'sql', filename: 'filename', table: 'table'} )
     if 'fs' not in args:
         args['fs'] = '|'
