[GRASS-SVN] r52153 - in grass-addons/grass7/raster: . r.ht
Wed Jun 20 01:00:10 PDT 2012
Author: wenzeslaus
Date: 2012-06-20 01:00:10 -0700 (Wed, 20 Jun 2012)
New Revision: 52153
Added:
   grass-addons/grass7/raster/r.ht/
   grass-addons/grass7/raster/r.ht/Makefile
   grass-addons/grass7/raster/r.ht/extract_line.cpp
   grass-addons/grass7/raster/r.ht/extract_line.h
   grass-addons/grass7/raster/r.ht/hough.cpp
   grass-addons/grass7/raster/r.ht/hough.h
   grass-addons/grass7/raster/r.ht/houghtransform.cpp
   grass-addons/grass7/raster/r.ht/houghtransform.h
   grass-addons/grass7/raster/r.ht/main.cpp
   grass-addons/grass7/raster/r.ht/matrix.cpp
   grass-addons/grass7/raster/r.ht/matrix.h
   grass-addons/grass7/raster/r.ht/r.ht.html
extracting line segments using hough transform: initial version
Added: grass-addons/grass7/raster/r.ht/Makefile
--- grass-addons/grass7/raster/r.ht/Makefile	                        (rev 0)
+++ grass-addons/grass7/raster/r.ht/Makefile	2012-06-20 08:00:10 UTC (rev 52153)
@@ -0,0 +1,20 @@
+# fix this relative to include/
+# or use absolute path to the GRASS source code
+MODULE_TOPDIR = ../..
+PGM = r.ht
+LIBES = $(VECTORLIB) $(GISLIB) $(RASTERLIB)  $(GMATHLIB)
+DEPENDENCIES = $(VECTORDEP) $(GISDEP) $(RASTERDEP)
+EXTRA_INC = $(VECT_INC)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+EXTRA_CFLAGS = $(VECT_CFLAGS) -Wno-sign-compare -Wall -Wextra -O0
+LINK = $(CXX)
+#ifneq ($(strip $(CXX)),)
+default: cmd
+#endif
Added: grass-addons/grass7/raster/r.ht/extract_line.cpp
--- grass-addons/grass7/raster/r.ht/extract_line.cpp	                        (rev 0)
+++ grass-addons/grass7/raster/r.ht/extract_line.cpp	2012-06-20 08:00:10 UTC (rev 52153)
@@ -0,0 +1,257 @@
+#include "extract_line.h"
+#include "matrix.h"
+#include <stdio.h>
+#include <cmath>
+#include <vector>
+#include <list>
+using namespace matrix;
+struct Point
+    int x;
+    int y;
+double segmentLenght(const Segment& segment)
+    double x = segment.first.first - segment.second.first;
+    double y = segment.first.second - segment.second.second;
+    return std::sqrt(x*x + y*y);
+bool checkBounds(int y, int x, int cols, int rows)
+    if ( y < 0 || y >= cols || x < 0 || x >= rows )
+        return false;
+    return true;
+bool isData(const Matrix &I, const std::vector<int> &y, const std::vector<int> &x, const int cols, const int rows)
+    for (size_t k = 0; k < y.size(); k++)
+        if (checkBounds(y.at(k), x.at(k), cols, rows) && I(x.at(k), y.at(k)))
+            return true;
+    return false;
+void remove_points(LineCoordinates& lineCoordinates, const std::vector<int>& indicesI, const std::vector<int>& indicesJ)
+    for (size_t i = 0; i < indicesI.size(); ++i)
+        std::pair<int, int> coords;
+        coords.second = indicesI[i];
+        coords.first = indicesJ[i];
+        lineCoordinates.remove(coords);
+void find_indices(std::vector<int>& indicesI, std::vector<int>& indicesJ,
+                  const int shift, const bool xflag, const int x, const int y,
+                  const int line_width)
+    if (xflag)
+        int tmp1, tmp2;
+        indicesJ[0] = x;
+        tmp1 = y >> shift;
+        tmp2 = tmp1;
+        indicesI[0] = tmp1;
+        for (int l = 1; l < line_width; l += 2)
+            indicesJ[l] = x;
+            indicesJ[l + 1] = x;
+            indicesI[l] = --tmp1;
+            indicesI[l + 1] = ++tmp2;
+    else
+        int tmp1, tmp2;
+        indicesI[0] = y;
+        tmp1 = x >> shift;
+        tmp2 = tmp1;
+        indicesJ[0] = tmp1;
+            indicesI[l] = y;
+            indicesI[l + 1] = y;
+            indicesJ[l] = --tmp1;
+            indicesJ[l + 1] = ++tmp2;
+bool segmentContainsPoint(Segment segment, std::pair<int, int> p, bool xFlag, int tol)
+  int min, max;
+  if (xFlag)
+    min = segment.first.first;
+    max = segment.second.first;
+    if (segment.first.first > segment.second.first)
+      min = segment.second.first;
+      max = segment.first.first;
+    if (p.first > min + tol && p.first <= max - tol)
+      return true;
+  else
+    min = segment.first.second;
+    max = segment.second.second;
+    if (segment.first.second > segment.second.second)
+      min = segment.second.second;
+      max = segment.first.second;
+    if (p.second > min + tol && p.second <= max - tol)
+      return true;
+  return false;
+void extract(const Matrix& I,
+             float orient, const int lineGap, const int lineLength,
+             LineCoordinates lineCoordinates, SegmentList& segments)
+    const int rows = I.rows ();
+    const int cols = I.columns ();
+    float rho = 1.0;
+    float irho = 1./rho;
+    bool xflag;
+    std::vector<Point> line_end(2);
+    SegmentList newSegments;
+    // from the current point walk in each direction
+    // along the found line and extract the line segment
+    float a = -(float)(sin(orient) * irho); //-trigtab[theta_n*2+1];
+    float b = (float)(cos(orient) * irho); //trigtab[theta_n*2];
+    int dx0, dy0;
+    int line_width = 3;
+    const int shift = 16;
+    std::vector<int> indicesI(line_width);
+    std::vector<int> indicesJ(line_width);
+    int lineNum = 0;
+    while (!lineCoordinates.empty())
+        lineNum++;
+        std::pair<int, int> startCoordinates = lineCoordinates.front();
+        int x0 = startCoordinates.first;
+        int y0 = startCoordinates.second;
+        if ( fabs(a) > fabs(b) )
+            xflag = 1;
+            dx0 = a > 0 ? 1 : -1;
+            dy0 = (int)( b*(1 << shift)/fabs(a) + 0.5);
+            y0 = (y0 << shift) + (1 << (shift-1));
+        else
+            xflag = 0;
+            dy0 = b > 0 ? 1 : -1;
+            dx0 = (int)( a*(1 << shift)/fabs(b) + 0.5);
+            x0 = (x0 << shift) + (1 << (shift-1));
+        int numOfGaps = 0;
+        bool useLine = true;
+        for ( int k = 0; k < 2; k++ )
+            int gap = 0, x = x0, y = y0, dx = dx0, dy = dy0;
+            if ( k > 0 )
+                dx = -dx, dy = -dy;
+            // walk along the line using fixed-point arithmetics,
+            // stop at the image border or in case of too big gap
+            for ( ;; x += dx, y += dy )
+                find_indices(indicesI, indicesJ, shift, xflag, x, y, line_width);
+                remove_points(lineCoordinates, indicesI, indicesJ);
+                // for each non-zero point:
+                //    update line end,
+                //    clear the mask element
+                //    reset the gap
+                if ( isData(I, indicesI, indicesJ, cols, rows) )
+                    if (gap > 5)
+                        numOfGaps++;
+                        if (numOfGaps > 5)
+                            useLine = false;
+                            break;
+                    gap = 0;
+                    line_end[k].y = indicesI[0];
+                    line_end[k].x = indicesJ[0];
+                else if ( ++gap > lineGap )
+                    break;
+        bool good_line = abs(line_end[1].x - line_end[0].x) >= lineLength ||
+                abs(line_end[1].y - line_end[0].y) >= lineLength;
+        if (good_line && useLine)
+            Segment newSegment;
+            newSegment.first.first = line_end[0].x;
+            newSegment.first.second = line_end[0].y;
+            newSegment.second.first = line_end[1].x;
+            newSegment.second.second = line_end[1].y;
+            int limit = 5;
+            bool add = true;
+            if (!newSegments.empty())
+                add = false;
+                const Segment lastSegment = newSegments.back();
+                if (!segmentContainsPoint(lastSegment, newSegment.first, xflag, limit) &&
+                    !segmentContainsPoint(lastSegment, newSegment.second, xflag, limit) &&
+                    !segmentContainsPoint(newSegment, lastSegment.first, xflag, limit) &&
+                    !segmentContainsPoint(newSegment, lastSegment.second, xflag, limit))
+                    add = true;
+                if (add == false)
+                    if (segmentLenght(lastSegment) < segmentLenght(newSegment))
+                        newSegments.pop_back();
+                        add = true;
+            if (add)
+                newSegments.push_back(newSegment);
+    segments.insert(segments.end(), newSegments.begin(), newSegments.end());
Added: grass-addons/grass7/raster/r.ht/extract_line.h
--- grass-addons/grass7/raster/r.ht/extract_line.h	                        (rev 0)
+++ grass-addons/grass7/raster/r.ht/extract_line.h	2012-06-20 08:00:10 UTC (rev 52153)
@@ -0,0 +1,16 @@
+#ifndef EXTRACT_LINE_H
+#define EXTRACT_LINE_H
+#include <vector>
+#include <list>
+typedef std::pair<int, int> Coordinates;
+typedef std::pair< Coordinates, Coordinates > Segment;
+typedef std::vector< Segment > SegmentList;
+typedef std::list< std::pair<int, int> > LineCoordinates;
+void extract(const matrix::Matrix& I, const float orient, const int lineGap, const int lineLength, LineCoordinates lineCoordinates, SegmentList& segments);
+#endif // EXTRACT_LINE_H
Added: grass-addons/grass7/raster/r.ht/hough.cpp
--- grass-addons/grass7/raster/r.ht/hough.cpp	                        (rev 0)
+++ grass-addons/grass7/raster/r.ht/hough.cpp	2012-06-20 08:00:10 UTC (rev 52153)
@@ -0,0 +1,179 @@
+#include "houghtransform.h"
+#include"extract_line.h"
+extern "C" {
+namespace grass {
+#include <grass/gis.h>
+#include <grass/raster.h>
+#include <grass/vector.h>
+#include <grass/glocale.h>
+#include <grass/gmath.h>
+using grass::DCELL;
+using grass::CELL;
+using grass::G__calloc;
+using grass::Cell_head;
+using grass::Map_info;
+using grass::Vect_new_cats_struct;
+using grass::Vect_new_line_struct;
+using grass::Rast_allocate_d_input_buf;
+using grass::Rast_open_old;
+using grass::Rast_get_row;
+using grass::Rast_close;
+using grass::G_gettext;
+using grass::G_fatal_error;
+using grass::G_debug;
+using grass::G_free;
+/** Loads map into memory.
+  \param[out] mat map in a matrix (row order), field have to be allocated
+void read_raster_map(const char *name, const char *mapset, int nrows,
+                            int ncols, Matrix& mat)
+    int r, c;
+    int map_fd;
+    DCELL *row_buffer;
+    DCELL cell_value;
+    row_buffer = Rast_allocate_d_input_buf();
+    /* load map */
+    map_fd = Rast_open_old(name, mapset);
+    if (map_fd < 0) {
+        G_fatal_error(_("Error opening first raster map <%s>"), name);
+    G_debug(1, "fd %d %s %s", map_fd, name, mapset);
+    //    if ((first_map_R_type =
+    //         Rast_map_type(templName, mapset)) < 0)
+    //        G_fatal_error(_("Error getting first raster map type"));
+    for (r = 0; r < nrows; r++) {
+        Rast_get_row(map_fd, row_buffer, r, DCELL_TYPE);
+        for (c = 0; c < ncols; c++) {
+            cell_value = row_buffer[c];
+            if (!Rast_is_d_null_value(&cell_value))
+                mat(r, c) = cell_value;
+            else
+                mat(r, c) = 0.0;
+    G_free(row_buffer);
+    Rast_close(map_fd);
+  \param cellhd raster map header, used for converting rows/cols to easting/northing
+void create_vector_map(const char * name, const SegmentList& segments,
+                       const Cell_head* cellhd)
+    struct Map_info Map;
+    Vect_open_new(&Map, name, 0);
+    struct grass::line_cats *Cats;
+    Cats = Vect_new_cats_struct();
+    for (size_t i = 0; i < segments.size(); ++i)
+        const Segment& seg = segments[i];
+        struct grass::line_pnts *points = Vect_new_line_struct();
+        double y1 = Rast_row_to_northing(seg.first.first, cellhd);
+        double x1 = Rast_col_to_easting(seg.first.second, cellhd);
+        double y2 = Rast_row_to_northing(seg.second.first, cellhd);
+        double x2 = Rast_col_to_easting(seg.second.second, cellhd);
+        Vect_cat_set(Cats, 1, i+1); // cat is segment number (counting from one)
+        Vect_append_point(points, x1, y1, 0);
+        Vect_append_point(points, x2, y2, 0);
+        Vect_write_line(&Map, GV_LINE, points, Cats);
+    Vect_build(&Map);
+    Vect_close(&Map);
+void extract_line_segments(const Matrix &I,
+                           const HoughTransform::Peaks& peaks,
+                           const HoughTransform::TracebackMap& houghMap,
+                           int gap,
+                           int minSegmentLength,
+                           SegmentList& segments)
+    for (size_t i = 0; i < peaks.size(); ++i)
+        const HoughTransform::Peak& peak = peaks[i];
+        double theta = peak.coordinates.second;
+        HoughTransform::TracebackMap::const_iterator coordsIt =
+                houghMap.find(peak.coordinates);
+        if (coordsIt != houghMap.end())
+            const HoughTransform::CoordinatesList& lineCoordinates = coordsIt->second;
+            extract(I, (theta-90)/180*M_PI, gap, minSegmentLength, lineCoordinates, segments);
+        else
+            // logic error
+void hough_peaks(int maxPeaks, int threshold, int sizeOfNeighbourhood,
+                 int gap, int minSegmentLength,
+                 const char *name, const char *mapset, size_t nrows, size_t ncols,
+                 const char *anglesMapName, int angleWidth,
+                 const char *result)
+    Matrix I(nrows, ncols);
+    read_raster_map(name, mapset, nrows, ncols, I);
+    HoughTransform hough(I);
+    if (anglesMapName != NULL)
+        Matrix angles(nrows, ncols);
+        read_raster_map(anglesMapName, mapset, nrows, ncols, angles);
+        hough.compute(angles, angleWidth);
+    else
+        hough.compute();
+    hough.findPeaks(maxPeaks, threshold, sizeOfNeighbourhood);
+    const HoughTransform::Peaks& peaks = hough.getPeaks();
+    const HoughTransform::TracebackMap& houghMap = hough.getHoughMap();
+    SegmentList segments;
+    extract_line_segments(I, peaks, houghMap, gap, minSegmentLength, segments);
+    Cell_head cellhd;
+    Rast_get_window(&cellhd);
+    create_vector_map(result, segments, &cellhd);
Added: grass-addons/grass7/raster/r.ht/hough.h
--- grass-addons/grass7/raster/r.ht/hough.h	                        (rev 0)
+++ grass-addons/grass7/raster/r.ht/hough.h	2012-06-20 08:00:10 UTC (rev 52153)
@@ -0,0 +1,11 @@
+#ifndef HOUGH_H
+#define HOUGH_H
+extern "C" {
+void hough_peaks(int maxPeaks, int threshold, int sizeOfNeighbourhood, int gap, int minSegmentLength, const char * name, const char* mapset, size_t nrows, size_t ncols, const char * angleMapName, int angleWidth, const char * result);
+#endif // HOUGH_H
Added: grass-addons/grass7/raster/r.ht/houghtransform.cpp
--- grass-addons/grass7/raster/r.ht/houghtransform.cpp	                        (rev 0)
+++ grass-addons/grass7/raster/r.ht/houghtransform.cpp	2012-06-20 08:00:10 UTC (rev 52153)
@@ -0,0 +1,239 @@
+/* helpers */
+struct SortByX
+    bool operator()(const HoughTransform::Coordinates& c1, const HoughTransform::Coordinates& c2) const
+        return c1.first < c2.first;
+struct SortByY
+        return c1.second < c2.second;
+/* ctors */
+HoughTransform::HoughTransform(const Matrix &matrix):
+    mOriginalMatrix(matrix)
+    mNumR = mOriginalMatrix.rows();
+    mNumC = mOriginalMatrix.columns();
+    mThetas = ColumnVector(matrix::Range(-M_PI/2.0, M_PI/2.0, M_PI/180.0).matrix_value ());
+    const float diag_length = std::sqrt(mNumR*mNumR + mNumC*mNumC);
+    mNumBins = ceil(diag_length) - 1;
+    mHoughMatrix = Matrix(mNumBins, mThetas.length(), 0.0);
+    c2 = ceil(mNumC/2.);
+    r2 = ceil(mNumR/2.);
+    bins0 = 1 - ceil(mNumBins/2.0);
+/* functions */
+void HoughTransform::compute()
+    for (int x = 0; x < mNumR; x++)
+        for (int y = 0; y < mNumC; y++)
+            if (mOriginalMatrix(x, y) == 1)
+                computeHoughForXY(x, y, 0, mThetas.length());
+void HoughTransform::computeHoughForXY(int x, int y, size_t minIndex, size_t maxIndex)
+    for (size_t i = minIndex; i < maxIndex; i++)
+        const double theta = mThetas(i);
+        const double cT = cos(theta);
+        const double sT = sin(theta);
+        const int rho = (int) floor(cT*(x - c2) + sT*(y - r2) + 0.5);
+        const int bin = (int) (rho - bins0);
+        if ((bin > 0) && (bin < mNumBins))
+            mHoughMatrix(bin, i)++;
+            mHoughMap[Coordinates(bin, i)].push_back(Coordinates(x, y));
+            mOriginalMap[Coordinates(x, y)].push_back(Coordinates(bin, i));
+  Expecting angles to be in degrees in range [0,180).
+  Size of agles matrix must be the same as size of input edge matrix.
+  mNumR != angles.rows() && mNumC != angles.columns()
+void HoughTransform::compute(const Matrix& angles, double angleWith)
+                double angle = angles(x, y);
+                if (angle < 0)
+                    angle = std::abs(angle);
+                else if (angle > 0)
+                    angle = 180 - angle;
+                // converting angle [0,180) to index
+                // in internal table of angles
+                // assuming that table size is 180
+                // TODO: angleIndex = mThetas.length() * angle/180
+                int angleIndex = angle;
+                int angleShift = angleWith/2 + 0.5;
+                 // FIXME: magic number
+                int minIndex = angleIndex - angleShift;
+                int maxIndex = angleIndex + angleShift;
+                if (minIndex < 0) {
+                    computeHoughForXY(x, y, 0, maxIndex);
+                    minIndex = 180 + minIndex;
+                    computeHoughForXY(x, y, minIndex, 180);
+                else if (maxIndex > 180)
+                    maxIndex = maxIndex - 180;
+                else
+                    computeHoughForXY(x, y, minIndex, maxIndex);
+void HoughTransform::findPeaks(int maxPeakNumber, int threshold, int sizeOfNeighbourhood)
+    int maxIt = mHoughMatrix.rows() * mHoughMatrix.columns();
+    int peaksFound = 0;
+    for (int i = 0; i < maxIt; i++)
+        Coordinates coordinates;
+        int maxValue = findMax(mHoughMatrix, coordinates);
+        if (maxValue < threshold || peaksFound == maxPeakNumber )
+            break;
+        CoordinatesList neighbours(neighbourhood(coordinates, sizeOfNeighbourhood));
+        Coordinates beginLine, endLine;
+        removePeakEffect(neighbours, beginLine, endLine);
+        Peak peak(coordinates, maxValue, beginLine, endLine);
+        mPeaks.push_back(peak);
+        peaksFound++;
+HoughTransform::CoordinatesList HoughTransform::neighbourhood(Coordinates &coordinates, const int sizeOfNeighbourhood)
+    CoordinatesList list;
+    const int x = coordinates.first;
+    const int y = coordinates.second;
+    for (int i = -sizeOfNeighbourhood; i <= sizeOfNeighbourhood; i++)
+        for (int j = -sizeOfNeighbourhood; j <= sizeOfNeighbourhood; j++)
+            list.push_back(Coordinates(x + i, y + j));
+    return list;
+void HoughTransform::removePeakEffect(const CoordinatesList &neighbours, Coordinates &beginLine, Coordinates &endLine)
+    CoordinatesList lineList;
+    for (CoordinatesList::const_iterator it = neighbours.begin(), end = neighbours.end(); it != end; ++it)
+        CoordinatesList &toRemove = mHoughMap[*it];
+        for (CoordinatesList::const_iterator it1 = toRemove.begin(), end = toRemove.end(); it1 != end; ++it1)
+            if ( mOriginalMap.find(*it1) != mOriginalMap.end() )
+                CoordinatesList &toDecrease = mOriginalMap[*it1];
+                for (CoordinatesList::const_iterator it2 = toDecrease.begin(), end = toDecrease.end(); it2 != end; ++it2)
+                    mHoughMatrix(it2->first, it2->second)--;
+                mOriginalMap.erase(*it1);
+               lineList.push_back(*it1);
+    int angle = neighbours.front().second;
+    // what to do if find endpoints finds nothing reasonable?
+    findEndPoints( lineList, beginLine, endLine, angle);
+bool HoughTransform::findEndPoints(CoordinatesList list, Coordinates &beginLine, Coordinates &endLine, const int angle )
+    if (angle > 45 && angle <= 135)
+        list.sort(SortByY());
+    else
+        list.sort(SortByX());
+    beginLine = list.front();
+    endLine = list.back();
+    return true;
+int HoughTransform::findMax(const Matrix& matrix, Coordinates &coordinates)
+    size_t rowIndex = 0;
+    size_t colIndex;
+    std::vector<size_t> colIndexes;
+    std::vector<double> rowMax = matrix.row_max(colIndexes);
+    int max = 0;
+    for (size_t i = 0; i < rowMax.size(); i++)
+        int tmp = rowMax[i];
+        if (tmp > max)
+            max = tmp;
+            rowIndex = i;
+    colIndex = colIndexes[rowIndex];
+    coordinates.first = rowIndex;
+    coordinates.second = colIndex;
+    return max;
Added: grass-addons/grass7/raster/r.ht/houghtransform.h
--- grass-addons/grass7/raster/r.ht/houghtransform.h	                        (rev 0)
+++ grass-addons/grass7/raster/r.ht/houghtransform.h	2012-06-20 08:00:10 UTC (rev 52153)
@@ -0,0 +1,103 @@
+#ifndef HOUGHTRANSFORM_H
+#define HOUGHTRANSFORM_H
+#include <cmath>
+#include <vector>
+#include <list>
+#include <set>
+#include <map>
+#include <limits>
+#include <algorithm>
+#include <stdio.h>
+class HoughTransform
+public:
+    /* typedefs */
+    template <typename T>
+    class MyVector: public std::vector<T>
+    public:
+        template <typename Comp>
+        void sort(Comp comp)
+            std::sort(this->begin(), this->end(), comp);
+        operator std::list<T>() const
+            std::list<T> tmp;
+            tmp.insert(tmp.begin(), this->begin(), this->end());
+            return tmp;
+    typedef std::pair<int, int> Coordinates;
+    typedef MyVector<Coordinates> CoordinatesList;
+    typedef std::map<Coordinates, CoordinatesList> TracebackMap;
+    struct Peak
+        Peak(Coordinates coordinates, int value, Coordinates begin, Coordinates end)
+            : coordinates(coordinates), value(value), beginLine(begin), endLine(end)
+        int value;
+        Coordinates beginLine;
+        Coordinates endLine;
+    typedef std::vector<Peak> Peaks;
+    /* functions */
+    HoughTransform(const Matrix &matrix);
+    void compute();
+    void compute(const Matrix& angles, double angleWith);
+    void findPeaks(int maxPeakNumber, int threshold,
+                   const int sizeOfNeighbourhood);
+    /* getters */
+    const Matrix & getHoughMatrix() { return mHoughMatrix; }
+    const Matrix & getOrigMatrix() { return mOriginalMatrix; }
+    const Peaks & getPeaks() const { return mPeaks; }
+    const TracebackMap & getHoughMap() { return mHoughMap; }
+private:
+    /* functions */
+    CoordinatesList neighbourhood(Coordinates &coordinates, const int sizeOfNeighbourhood);
+    void removePeakEffect(const CoordinatesList &neighbours, Coordinates &beginLine, Coordinates &endLine);
+    bool findEndPoints(CoordinatesList list, Coordinates &beginLine, Coordinates &endLine, const int angle );
+    int findMax(const Matrix& matrix, Coordinates &coordinates);
+    void addToMaps(const std::vector<std::pair<Coordinates, Coordinates> > &pairs);
+    void computeHoughForXY(int x, int y, size_t minIndex, size_t maxIndex);
+    /* data members */
+    const Matrix& mOriginalMatrix;
+    Matrix mHoughMatrix;
+    TracebackMap mOriginalMap;
+    TracebackMap mHoughMap;
+    Peaks mPeaks;
+    int mNumR;
+    int mNumC;
+    ColumnVector mThetas;
+    int mNumBins;
+    int c2;
+    int r2;
+    int bins0;
+#endif // HOUGHTRANSFORM_H
Added: grass-addons/grass7/raster/r.ht/main.cpp
--- grass-addons/grass7/raster/r.ht/main.cpp	                        (rev 0)
+++ grass-addons/grass7/raster/r.ht/main.cpp	2012-06-20 08:00:10 UTC (rev 52153)
@@ -0,0 +1,171 @@
+ * MODULE:       r.ht
+ * AUTHOR(S):    Anna Kratochvilova - kratochanna gmail.com
+ *               Vaclav Petras - wenzeslaus gmail.com
+ * PURPOSE:      Detects line segments using Hough transform.
+ * COPYRIGHT:    (C) 2012 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *   	    	 License (>=v2). Read the file COPYING that comes with GRASS
+ *   	    	 for details.
+#include "hough.h"
+extern "C" {
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <math.h>
+  \todo Floats are used instead of doubles.
+  \todo Be able to work with FCELL (and CELL?).
+int main(int argc, char *argv[])
+    struct Cell_head cell_head;	/* it stores region information,
+				   and header information of rasters */
+    char *name;			/* input raster name */
+    char *mapset;		/* mapset name */
+    char *result;		/* output raster name */
+    int nrows, ncols;
+    struct GModule *module;	/* GRASS module for parsing arguments */
+    /* options */
+    struct Option *input, *output, *anglesOption,
+        *maxLinesOption, *maxGapOption, *minSegmentLengthOption,
+            *angleWidthOption;
+    /* initialize GIS environment */
+    G_gisinit(argv[0]);		/* reads grass env, stores program name to G_program_name() */
+    /* initialize module */
+    module = G_define_module();
+    G_add_keyword(_("raster"));
+    G_add_keyword(_("hought"));
+    G_add_keyword(_(""));
+    module->description =
+	_("Canny edge detector. Region shall be set to input map."
+	  "Can work only on small images since map is loaded into memory.");
+    /* Define the different options as defined in gis.h */
+    input = G_define_standard_option(G_OPT_R_INPUT);
+    output = G_define_standard_option(G_OPT_V_OUTPUT);
+    anglesOption = G_define_standard_option(G_OPT_R_INPUT);
+    anglesOption->key = "angles";
+    anglesOption->required = NO;
+    anglesOption->description = _("Approximate number of line segments.");
+    // this option will become max peaks number to find in HT
+    maxLinesOption = G_define_option();
+    maxLinesOption->key = "lines_number";
+    maxLinesOption->type = TYPE_INTEGER;
+    maxLinesOption->required = NO;
+    maxLinesOption->multiple = NO;
+    maxLinesOption->description = _("Approximate number of line segments."
+                                    " Actually, this option will become"
+                                    " maximal number of line candidates"
+                                    " detected in Hough transform image."
+                                    " Final number of line segments can be"
+                                    " smaller or greater."
+    maxLinesOption->answer = const_cast<char *>("20");
+    maxGapOption = G_define_option();
+    maxGapOption->key = "max_gap";
+    maxGapOption->type = TYPE_INTEGER;
+    maxGapOption->required = NO;
+    maxGapOption->multiple = NO;
+    maxGapOption->description = _("Maximum gap in pixels");
+    maxGapOption->answer = const_cast<char *>("5");
+    minSegmentLengthOption = G_define_option();
+    minSegmentLengthOption->key = "min_segment_length";
+    minSegmentLengthOption->type = TYPE_INTEGER;
+    minSegmentLengthOption->required = NO;
+    minSegmentLengthOption->multiple = NO;
+    minSegmentLengthOption->description = _("Minimal length of line segment");
+    minSegmentLengthOption->answer = const_cast<char *>("50");
+    angleWidthOption = G_define_option();
+    angleWidthOption->key = "angle_width";
+    angleWidthOption->type = TYPE_INTEGER;
+    angleWidthOption->required = NO;
+    angleWidthOption->multiple = NO;
+    angleWidthOption->description = _("Width of circle sector (only when you provide angle map).");
+    angleWidthOption->answer = const_cast<char *>("5");
+    /* options and flags parser */
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    /* stores options and flags to variables */
+    result = output->answer;
+    name = input->answer;
+    int maxPeaks = atoi(maxLinesOption->answer);
+    int threshold = 10;
+    int gap = atoi(maxGapOption->answer);
+    int minSegmentLength = atoi(minSegmentLengthOption->answer);
+    int sizeOfNeighbourhood = 1;
+    int angleWidth = atoi(angleWidthOption->answer);
+    /* returns NULL if the map was not found in any mapset,
+     * mapset name otherwise */
+    mapset = (char *)G_find_raster2(name, "");
+    if (mapset == NULL)
+	G_fatal_error(_("Raster map <%s> not found"), name);
+    /* determine the inputmap type (CELL/FCELL/DCELL) */
+    //data_type = Rast_map_type(name, mapset);
+    //    struct Cell_head templCellhd;
+    //    Rast_get_cellhd(name, mapset, &cellhd);
+    //    Rast_get_cellhd(first_map_R_name, first_map_R_mapset, &cellhd_zoom1);
+    /* controlling, if we can open input raster */
+    Rast_get_cellhd(name, mapset, &cell_head);
+    G_debug(3, "number of rows %d", cell_head.rows);
+    nrows = Rast_window_rows();
+    ncols = Rast_window_cols();
+    hough_peaks(maxPeaks, threshold, sizeOfNeighbourhood, gap, minSegmentLength, name, mapset, nrows, ncols, anglesOption->answer, angleWidth, result);
+    /* memory cleanup */
+    G_free(name);
+    /* add command line incantation to history file */
+    //    Rast_short_history(templName, "raster", &history);
+    //    Rast_command_history(&history);
+    //    Rast_write_history(templName, &history);
+    exit(EXIT_SUCCESS);
Added: grass-addons/grass7/raster/r.ht/matrix.cpp
Added: grass-addons/grass7/raster/r.ht/matrix.h
--- grass-addons/grass7/raster/r.ht/matrix.h	                        (rev 0)
+++ grass-addons/grass7/raster/r.ht/matrix.h	2012-06-20 08:00:10 UTC (rev 52153)
@@ -0,0 +1,221 @@
+#ifndef MATRIX_H
+#define MATRIX_H
+#include <vector>
+#include <limits>
+#include <cmath>
+/* mimics Octave matrices and other classes */
+namespace matrix {
+class Matrix
+public:
+    Matrix(size_t r, size_t c, double val = 0)
+        resize(r, c, val);
+    Matrix() {}
+    void resize(size_t r, size_t c, double val = 0)
+        std::vector<double> row;
+        row.resize(c, val);
+        mat.resize(r, row);
+    double& operator ()(size_t r, size_t c)
+        if (r > rows() || c > columns())
+            // FIXME: fatal error
+        return mat[r][c];
+    const double& operator ()(size_t r, size_t c) const
+        return mat[r][c];
+    size_t rows() const { return mat.size(); }
+    size_t columns() const
+        if (!mat.empty())
+            return mat[0].size();
+        return 0;
+    std::vector<double> row_max(std::vector<size_t>& colIndexes) const
+        std::vector<double> ret;
+        for (size_t i = 0; i < rows(); ++i)
+            std::vector<double>::const_iterator maxe = std::max_element(mat[i].begin(), mat[i].end());
+            double max = *maxe;
+            size_t maxi = maxe - mat[i].begin();
+            ret.push_back(max);
+            colIndexes.push_back(maxi);
+        return ret;
+private:
+    std::vector< std::vector<double> > mat;
+class ColumnVector
+public:
+    ColumnVector(Matrix mat)
+        for (size_t i = 0; i < mat.columns(); ++i)
+            vec.push_back(mat(0, i));
+    ColumnVector() {}
+    double& operator ()(size_t i)
+        return vec[i];
+    const double& operator ()(size_t i) const
+        return vec[i];
+    size_t length() { return vec.size(); }
+private:
+    std::vector<double> vec;
+class RowVector
+public:
+    RowVector(Matrix mat)
+    RowVector() {}
+        return vec[i];
+        return vec[i];
+    RowVector operator -(double d)
+        RowVector ret(*this);
+        for (size_t i = 0; i < ret.length(); ++i)
+            ret(i) = ret(i) - d;
+        return ret;
+private:
+class Range
+public:
+    Range (double b, double l, double i)
+        : rng_base(b), rng_limit(l), rng_inc(i), rng_nelem(nelem_internal())
+    Range (double b, double l)
+      : rng_base(b), rng_limit(l), rng_inc(1),
+        rng_nelem(nelem_internal()) { }
+    Matrix matrix_value() const
+        Matrix cache;
+        //if (rng_nelem > 0 && cache.nelem () == 0)
+            cache.resize(1, rng_nelem);
+            double b = rng_base;
+            double increment = rng_inc;
+            for (size_t i = 0; i < rng_nelem; i++)
+              cache(0, i) = b + i * increment;
+            // On some machines (x86 with extended precision floating point
+            // arithmetic, for example) it is possible that we can overshoot
+            // the limit by approximately the machine precision even though
+            // we were very careful in our calculation of the number of
+            // elements.
+            if ((rng_inc > 0 && cache(0, rng_nelem-1) > rng_limit)
+                || (rng_inc < 0 && cache(0, rng_nelem-1) < rng_limit))
+              cache(0, rng_nelem-1) = rng_limit;
+        return cache;
+private:
+    /* from Octave source codes */
+    size_t nelem_internal() const
+      size_t retval = -1;
+      if (rng_inc == 0
+          || (rng_limit > rng_base && rng_inc < 0)
+          || (rng_limit < rng_base && rng_inc > 0))
+          retval = 0;
+      else
+          // double ct = 3.0 * std::numeric_limits<double>::epsilon(); // FIXME: not used
+          // was DBL_EPSILON;
+          // double tmp = tfloor ((rng_limit - rng_base + rng_inc) / rng_inc, ct); // octave code
+          double tmp = floor ((rng_limit - rng_base + rng_inc) / rng_inc);
+          size_t n_elt = (tmp > 0.0 ? static_cast<size_t> (tmp) : 0);
+          // If the final element that we would compute for the range is
+          // equal to the limit of the range, or is an adjacent floating
+          // point number, accept it.  Otherwise, try a range with one
+          // fewer element.  If that fails, try again with one more
+          // element.
+          // I'm not sure this is very good, but it seems to work better than
+          // just using tfloor as above.  For example, without it, the
+          // expression 1.8:0.05:1.9 fails to produce the expected result of
+          // [1.8, 1.85, 1.9].
+          // octave code
+          // if (! teq (rng_base + (n_elt - 1) * rng_inc, rng_limit))
+          //     if (teq (rng_base + (n_elt - 2) * rng_inc, rng_limit))
+          //       n_elt--;
+          //     else if (teq (rng_base + n_elt * rng_inc, rng_limit))
+          //       n_elt++;
+          retval = (n_elt >= std::numeric_limits<size_t>::max () - 1) ? -1 : n_elt;
+      return retval;
+ double rng_base;
+ double rng_limit;
+ double rng_inc;
+ size_t rng_nelem;
+#endif // MATRIX_H
Added: grass-addons/grass7/raster/r.ht/r.ht.html
--- grass-addons/grass7/raster/r.ht/r.ht.html	                        (rev 0)
+++ grass-addons/grass7/raster/r.ht/r.ht.html	2012-06-20 08:00:10 UTC (rev 52153)
@@ -0,0 +1,18 @@
+<h2>DESCRIPTION</h2>
+<em>r.example</em> does practically do nothing, except
+for illustrating GRASS raster programming. It copies
+over an existing raster map to a new raster map.
+See the source code for details.
+<h2>SEE ALSO</h2>
+<em><a href="r.stats.html">r.stats</A></em><br>
+<em><a href="http://grass.itc.it/devel/index.php#prog">GRASS Programmer's Manual</A></em>
+<h2>AUTHOR</h2>
+GRASS Development Team
+<p><i>Last changed: $Date: 2011-09-29 21:18:47 +0200 (Thu, 29 Sep 2011) $</i>
