[GRASS-SVN] r52160 - grass/trunk/raster/r.in.xyz
svn_grass at osgeo.org
Wed Jun 20 03:03:25 PDT 2012
Author: hamish
Date: 2012-06-20 03:03:24 -0700 (Wed, 20 Jun 2012)
New Revision: 52160
grass/trunk/raster/r.in.xyz/local_proto.h
grass/trunk/raster/r.in.xyz/main.c
grass/trunk/raster/r.in.xyz/r.in.xyz.html
add support for reading from alternate value column while filtering on z
Modified: grass/trunk/raster/r.in.xyz/local_proto.h
--- grass/trunk/raster/r.in.xyz/local_proto.h 2012-06-20 09:33:07 UTC (rev 52159)
+++ grass/trunk/raster/r.in.xyz/local_proto.h 2012-06-20 10:03:24 UTC (rev 52160)
@@ -38,7 +38,7 @@
#define METHOD_TRIMMEAN 13
/* main.c */
-int scan_bounds(FILE *, int, int, int, char *, int, int, double);
+int scan_bounds(FILE *, int, int, int, int, char *, int, int, double, double);
/* support.c */
int blank_array(void *, int, int, RASTER_MAP_TYPE, int);
Modified: grass/trunk/raster/r.in.xyz/main.c
--- grass/trunk/raster/r.in.xyz/main.c 2012-06-20 09:33:07 UTC (rev 52159)
+++ grass/trunk/raster/r.in.xyz/main.c 2012-06-20 10:03:24 UTC (rev 52160)
@@ -3,7 +3,7 @@
* Calculates univariate statistics from the non-null cells of a GRASS raster map
- * Copyright 2006 by M. Hamish Bowman, and The GRASS Development Team
+ * Copyright 2006-2012 by M. Hamish Bowman, and The GRASS Development Team
* Author: M. Hamish Bowman, University of Otago, Dunedin, New Zealand
* Extended 2007 by Volker Wichmann to support the aggregate functions
@@ -98,11 +98,11 @@
FILE *in_fp;
int out_fd;
char *infile, *outmap;
- int xcol, ycol, zcol, max_col, percent;
- int do_zfilter;
+ int xcol, ycol, zcol, vcol, max_col, percent;
+ int do_zfilter, do_vfilter;
int method = -1;
int bin_n, bin_min, bin_max, bin_sum, bin_sumsq, bin_index;
- double zrange_min, zrange_max, d_tmp;
+ double zrange_min, zrange_max, vrange_min, vrange_max, d_tmp;
char *fs; /* field delim */
off_t filesize;
int linesize;
@@ -133,6 +133,7 @@
double min = 0.0 / 0.0; /* init as nan */
double max = 0.0 / 0.0; /* init as nan */
double zscale = 1.0;
+ double vscale = 1.0;
size_t offset, n_offset;
int n = 0;
double sum = 0.;
@@ -149,7 +150,7 @@
struct Option *input_opt, *output_opt, *delim_opt, *percent_opt,
*type_opt;
struct Option *method_opt, *xcol_opt, *ycol_opt, *zcol_opt, *zrange_opt,
- *zscale_opt;
+ *zscale_opt, *vcol_opt, *vrange_opt, *vscale_opt;
struct Option *trim_opt, *pth_opt;
struct Flag *scan_flag, *shell_style, *skipline;
@@ -212,7 +213,10 @@
zcol_opt->type = TYPE_INTEGER;
zcol_opt->required = NO;
zcol_opt->answer = "3";
- zcol_opt->description = _("Column number of data values in input file");
+ zcol_opt->label = _("Column number of data values in input file");
+ zcol_opt->description =
+ _("If a separate value column is given, this option refers to the "
+ "z-coordinate column to be filtered by the zrange option");
zcol_opt->guisection = _("Input");
zrange_opt = G_define_option();
@@ -229,6 +233,31 @@
zscale_opt->answer = "1.0";
zscale_opt->description = _("Scale to apply to z data");
+ vcol_opt = G_define_option();
+ vcol_opt->key = "value_column";
+ vcol_opt->type = TYPE_INTEGER;
+ vcol_opt->required = NO;
+ vcol_opt->answer = "0";
+ vcol_opt->label = _("Alternate column number of data values in input file");
+ vcol_opt->description = _("If not given (or set to 0) the z-column data is used");
+ vcol_opt->guisection = _("Advanced Input");
+ vrange_opt = G_define_option();
+ vrange_opt->key = "vrange";
+ vrange_opt->type = TYPE_DOUBLE;
+ vrange_opt->required = NO;
+ vrange_opt->key_desc = "min,max";
+ vrange_opt->description = _("Filter range for alternate value column data (min,max)");
+ vrange_opt->guisection = _("Advanced Input");
+ vscale_opt = G_define_option();
+ vscale_opt->key = "vscale";
+ vscale_opt->type = TYPE_DOUBLE;
+ vscale_opt->required = NO;
+ vscale_opt->answer = "1.0";
+ vscale_opt->description = _("Scale to apply to alternate value column data");
+ vscale_opt->guisection = _("Advanced Input");
percent_opt = G_define_option();
percent_opt->key = "percent";
percent_opt->type = TYPE_INTEGER;
@@ -292,15 +321,19 @@
xcol = atoi(xcol_opt->answer);
ycol = atoi(ycol_opt->answer);
zcol = atoi(zcol_opt->answer);
- if ((xcol < 0) || (ycol < 0) || (zcol < 0))
+ vcol = atoi(vcol_opt->answer);
+ if ((xcol < 0) || (ycol < 0) || (zcol < 0) || (vcol < 0))
G_fatal_error(_("Please specify a reasonable column number."));
max_col = (xcol > ycol) ? xcol : ycol;
max_col = (zcol > max_col) ? zcol : max_col;
+ if(vcol)
+ max_col = (vcol > max_col) ? vcol : max_col;
percent = atoi(percent_opt->answer);
zscale = atof(zscale_opt->answer);
+ vscale = atof(vscale_opt->answer);
- /* parse zrange */
+ /* parse zrange and vrange */
do_zfilter = FALSE;
if (zrange_opt->answer != NULL) {
if (zrange_opt->answers[0] == NULL)
@@ -317,6 +350,22 @@
+ do_vfilter = FALSE;
+ if (vrange_opt->answer != NULL) {
+ if (vrange_opt->answers[0] == NULL)
+ G_fatal_error(_("Invalid vrange"));
+ sscanf(vrange_opt->answers[0], "%lf", &vrange_min);
+ sscanf(vrange_opt->answers[1], "%lf", &vrange_max);
+ do_vfilter = TRUE;
+ if (vrange_min > vrange_max) {
+ d_tmp = vrange_max;
+ vrange_max = vrange_min;
+ vrange_min = d_tmp;
/* figure out what maps we need in memory */
/* n n
min min
@@ -484,11 +533,11 @@
if (scan_flag->answer) {
- if (zrange_opt->answer)
- G_warning(_("zrange will not be taken into account during scan"));
+ if (zrange_opt->answer || vrange_opt->answer)
+ G_warning(_("range filters will not be taken into account during scan"));
- scan_bounds(in_fp, xcol, ycol, zcol, fs, shell_style->answer,
- skipline->answer, zscale);
+ scan_bounds(in_fp, xcol, ycol, zcol, vcol, fs, shell_style->answer,
+ skipline->answer, zscale, vscale);
if (!from_stdin)
fclose(in_fp);
@@ -638,7 +687,6 @@
if (1 != sscanf(tokens[zcol - 1], "%lf", &z))
G_fatal_error(_("Bad z-coordinate line %lu column %d. <%s>"),
line, zcol, tokens[zcol - 1]);
z = z * zscale;
if (zrange_opt->answer) {
@@ -648,8 +696,23 @@
+ if(vcol) {
+ if (1 != sscanf(tokens[vcol - 1], "%lf", &z))
+ G_fatal_error(_("Bad data value line %lu column %d. <%s>"),
+ line, vcol, tokens[vcol - 1]);
+ /* we're past the zrange check, so pass over control of the variable */
+ z = z * vscale;
+ if (vrange_opt->answer) {
+ if (z < vrange_min || z > vrange_max) {
+ G_free_tokens(tokens);
+ continue;
count++;
- /* G_debug(5, "x: %f, y: %f, z: %f", x, y, z); */
+ /* G_debug(5, "x: %f, y: %f, z: %f", x, y, z); */
/* find the bin in the current array box */
@@ -1066,19 +1129,21 @@
-int scan_bounds(FILE * fp, int xcol, int ycol, int zcol, char *fs,
- int shell_style, int skipline, double zscale)
+int scan_bounds(FILE * fp, int xcol, int ycol, int zcol, int vcol, char *fs,
+ int shell_style, int skipline, double zscale, double vscale)
unsigned long line;
int first, max_col;
char buff[BUFFSIZE];
- double min_x, max_x, min_y, max_y, min_z, max_z;
+ double min_x, max_x, min_y, max_y, min_z, max_z, min_v, max_v;
char **tokens;
int ntokens; /* number of tokens */
- double x, y, z;
+ double x, y, z, v;
+ if(vcol)
line = 0;
first = TRUE;
@@ -1157,7 +1222,8 @@
if (first) {
min_z = z;
max_z = z;
- first = FALSE;
+ if(!vcol)
+ first = FALSE;
else {
if (z < min_z)
@@ -1166,22 +1232,47 @@
max_z = z;
+ if(vcol) {
+ if (1 != sscanf(tokens[vcol - 1], "%lf", &v))
+ G_fatal_error(_("Bad data value line %lu column %d. <%s>"), line,
+ vcol, tokens[vcol - 1]);
+ if (first) {
+ min_v = v;
+ max_v = v;
+ first = FALSE;
+ else {
+ if (v < min_v)
+ min_v = v;
+ if (v > max_v)
+ max_v = v;
if (!shell_style) {
fprintf(stderr, _("Range: min max\n"));
- fprintf(stdout, "x: %11f %11f\n", min_x, max_x);
- fprintf(stdout, "y: %11f %11f\n", min_y, max_y);
- fprintf(stdout, "z: %11f %11f\n", min_z * zscale, max_z * zscale);
+ fprintf(stdout, "x: %11.15g %11.15g\n", min_x, max_x);
+ fprintf(stdout, "y: %11.15g %11.15g\n", min_y, max_y);
+ fprintf(stdout, "z: %11.15g %11.15g\n", min_z * zscale, max_z * zscale);
+ if(vcol)
+ fprintf(stdout, "v: %11.15g %11.15g\n", min_v * vscale, max_v * vscale);
- else
- fprintf(stdout, "n=%f s=%f e=%f w=%f b=%f t=%f\n",
+ else {
+ fprintf(stdout, "n=%.15g s=%.15g e=%.15g w=%.15g b=%.15g t=%.15g",
max_y, min_y, max_x, min_x, min_z * zscale, max_z * zscale);
+ if(vcol)
+ fprintf(stdout, " min=%.15g max=%.15g\n", min_v * vscale,
+ max_v * vscale);
+ else
+ fprintf(stdout, "\n");
G_debug(1, "Processed %lu lines.", line);
- G_debug(1, "region template: g.region n=%f s=%f e=%f w=%f",
+ G_debug(1, "region template: g.region n=%.15g s=%.15g e=%.15g w=%.15g",
max_y, min_y, max_x, min_x);
return 0;
Modified: grass/trunk/raster/r.in.xyz/r.in.xyz.html
--- grass/trunk/raster/r.in.xyz/r.in.xyz.html 2012-06-20 09:33:07 UTC (rev 52159)
+++ grass/trunk/raster/r.in.xyz/r.in.xyz.html 2012-06-20 10:03:24 UTC (rev 52160)
@@ -9,10 +9,10 @@
for example raw LIDAR or sidescan sonar swath data. It has been tested with
datasets as large as tens of billion of points (705GB in a single file).
<!-- Doug Newcomb, US Fish & Wildlife Service -->
<p>
Available statistics for populating the raster are:<br>
-<ul>
-<li>
+<blockquote>
<table>
<tr><td><em>n</em></td> <td>number of points in cell</td></tr>
<tr><td><em>min</em></td> <td>minimum value of points in cell</td></tr>
@@ -29,13 +29,21 @@
<tr><td><em>skewness</em></td> <td>skewness of points in cell</td></tr>
<tr><td><em>trimmean</em></td> <td>trimmed mean of points in cell</td></tr>
</table><br>
+</blockquote>
+<ul>
<li><em>Variance</em> and derivatives use the biased estimator (n). [subject to change]
<li><em>Coefficient of variance</em> is given in percentage and defined as
<tt>(stddev/mean)*100</tt>.
</ul>
<br>
+<p>
+It is also possible to bin and store another data column (e.g. backscatter)
+while simultaneously filtering and scaling both the data column values and
+the z range.
<h2>NOTES</h2>
<h3>Gridded data</h3>
@@ -82,6 +90,7 @@
If reading data from a <tt>stdin</tt> stream, the program can only run using
a single pass.
<h3>Setting region bounds and resolution</h3>
You can use the <b>-s</b> scan flag to find the extent of the input data
@@ -140,6 +149,18 @@
<em>r.neighbors</em> to smooth the stddev map before further use.]
+<h3>Alternate value column</h3>
+The <b>value_column</b> parameter can be used in specialized cases when you
+want to filter by z-range but bin and store another column's data. For
+example if you wanted to look at backscatter values between 1000 and 1500
+meters elevation. This is particularly useful when using <em>r.in.xyz</em>
+to prepare depth slices for a 3D raster — the <b>zrange</b> option defines
+the depth slice but the data values stored in the voxels describe an
+additional dimension. As with the z column, a filtering range and scaling
+factor may be applied.
<h3>Reprojection</h3>
If the raster map is to be reprojected, it may be more appropriate to reproject
@@ -166,6 +187,7 @@
</pre></div>
<br>
<h2>EXAMPLE</h2>
Import the <a href="http://www.grassbook.org/data_menu2nd.phtml">Jockey's
@@ -203,12 +225,16 @@
<ul>
<li> Support for multiple map output from a single run.<br>
- <tt>method=string[,string,...] output=name[,name,...]</tt>
+ <tt>method=string[,string,...] output=name[,name,...]</tt><br>
+ This can be easily handled by a wrapper script, with the added
+ benefit of it being very simple to parallelize that way.
<li> Add two new flags for support for direct binary input from libLAS
for LIDAR data and MB-System's mbio for multi-beam bathymetry data.
<!-- Bob Covill has supplied patches for MBIO interface already -->
+ <br><i>note</i>: See the new <em>r.in.lidar</em> module for this.
</ul>
<h2>BUGS</h2>
<ul>
@@ -229,6 +255,7 @@
If you encounter any problems (or solutions!) please contact the GRASS
Development Team.
<h2>SEE ALSO</h2>
<i>
@@ -236,6 +263,8 @@
<a href="m.proj.html">m.proj</a><br>
<a href="r.fillnulls.html">r.fillnulls</a><br>
<a href="r.in.ascii.html">r.in.ascii</a><br>
+<a href="r.in.lidar.html">r.in.lidar</a><br>
+<a href="r3.in.xyz.html">r3.in.xyz</a><br>
<a href="r.mapcalc.html">r.mapcalc</a><br>
<a href="r.neighbors.html">r.neighbors</a><br>
<a href="r.out.xyz.html">r.out.xyz</a><br>
