[GRASS-SVN] r52164 - grass/trunk/scripts/r3.in.xyz
Wed Jun 20 03:55:45 PDT 2012
Author: hamish
Date: 2012-06-20 03:55:44 -0700 (Wed, 20 Jun 2012)
New Revision: 52164
   grass/trunk/scripts/r3.in.xyz/r3.in.xyz.html
   grass/trunk/scripts/r3.in.xyz/r3.in.xyz.py
add support for data aggregation from non-spatial data columns
Modified: grass/trunk/scripts/r3.in.xyz/r3.in.xyz.html
--- grass/trunk/scripts/r3.in.xyz/r3.in.xyz.html	2012-06-20 10:29:46 UTC (rev 52163)
+++ grass/trunk/scripts/r3.in.xyz/r3.in.xyz.html	2012-06-20 10:55:44 UTC (rev 52164)
@@ -11,6 +11,12 @@
 The map is created using the rows, columns, and depths set by
 current region settings. Be sure to check and adjust these with
 the <em>g.region</em> module before performing the import.
+<p>
+You may either use the z-value as the data value for the voxel
+(e.g. with the 'n' statistic), or alternately scan another
+column for the data values to bin into the voxels. This alternate
+data column can be both filtered by range and have a scaling
+factor applied to it.
 <h2>NOTES</h2>
@@ -19,10 +25,12 @@
 EXAMPLES section below.
 <p>
 Unlike <em>r.in.xyz</em>, reading from stdin and z-scaling are not
-possible.
+possible. Filtering by z-range is accomplished by setting the 3D region.
 <p>
 To enable parallel processing support, set the <b>workers=</b> option
 to match the number of CPUs or CPU-cores avaiable on your system.
+Alternatively, the <tt>WORKERS</tt> environment variable can be set
+to the number of concurrent processes desired.
 <p>
 Points falling exactly on a vertical bound will belong to the depth
 band below them, except for points exactly on the top bound, which will
@@ -50,31 +58,15 @@
      method=mean x=1 y=2 z=3 fs=space type=float
 </pre></div>
+The same, but aggregate and store backscatter strength from column 5
+into voxels in instead of the z-value:
+<div class="code"><pre>
+  r3.in.xyz in=Serpent_Mound_Model_LAS_Data.txt out=serpent3D.bakscat \
+     method=mean x=1 y=2 z=3 val=5 fs=space type=float
+</pre></div>
-<h2>TODO</h2>
-Currently this module stores only the z-value into the voxel,
-which is perhaps a little monochromatic. The 'n' statistic
-and simple presence,absence may still be of interest though.
-<p>
-Possible ideas for adding full <tt>x,y,z,value</tt> support
-to the module include piping the input file through a z-range
-gate filter in Python while simultaneously setting the
-<em>r.in.xyz</em> module's <tt>z=</tt> option to be the
-column of the value to be stored. This will be slower than a
-dedicated <tt>r.in.xyzv</tt> module would be, but less memory
-intensive and less complicated to code (fewer bugs). The question
-is how much slower would it be, and if that is acceptable. It
-seems like a reasonable approach for experimenting with a
-working prototype though.
-<p>
-Another idea (which is likely the way I'll go) is to add a
-new extra-column filter option to <em>r.in.xyz</em>. The
-data can then be filtered by z-range while simultaneously
-storing the data of another (possibly gate-ranged itself)
-column.
 <h2>BUGS</h2>
 <em>r.to.rast3</em> always creates a <tt>double</tt> output map
Modified: grass/trunk/scripts/r3.in.xyz/r3.in.xyz.py
--- grass/trunk/scripts/r3.in.xyz/r3.in.xyz.py	2012-06-20 10:29:46 UTC (rev 52163)
+++ grass/trunk/scripts/r3.in.xyz/r3.in.xyz.py	2012-06-20 10:55:44 UTC (rev 52164)
@@ -111,7 +111,7 @@
 #% guisection: Input
 #%End
 #%Option
-#% key: value
+#% key: value_column
 #% type: integer
 #% required: no
 #% multiple: no
@@ -125,9 +125,16 @@
 #% type: double
 #% required: no
 #% key_desc: min,max
-#% description: Filter range for value data (min,max)
-#% guisection: Input
+#% description: Filter range for value column data (min,max)
 #%End
+#%option
+#% key: vscale
+#% type: double
+#% required: no
+#% multiple: no
+#% description: Scaling factor to apply to value column data
+#% answer: 1.0
+#%end
 #%Option
 #% key: percent
 #% type: integer
@@ -187,8 +194,9 @@
     x = options['x']
     y = options['y']
     z = options['z']
-    value = int(options['value'])
+    value_column = options['value_column']
     vrange = options['vrange']
+    vscale = options['vscale']
     percent = options['percent']
     pth = options['pth']
     trim = options['trim']
@@ -203,25 +211,32 @@
     if not os.path.exists(infile):
 	grass.fatal(_("Unable to read input file <%s>") % infile)
-    if value is not 0:
-	grass.fatal(_("This functionality is not yet operational."))
+    addl_opts = {}
+    if pth:
+        addl_opts['pth'] = '%s' % pth
+    if trim:
+        addl_opts['trim'] = '%s' % trim
+    if value_column:
+        addl_opts['value_column'] = '%s' % value_column
+    if vrange:
+        addl_opts['vrange'] = '%s' % vrange
+    if vscale:
+        addl_opts['vscale'] = '%s' % vscale
+    if ignore_broken:
+        addl_opts['flags'] = 'i'
     if scan_only or shell_style:
         if shell_style:
 	    doShell = 'g'
 	else:
 	    doShell = ''
         grass.run_command('r.in.xyz', flags = 's' + doShell, input = infile,
-			  output = 'dummy', fs = fs, x = x, y = y, z = z)
+			  output = 'dummy', fs = fs, x = x, y = y, z = z,
+			  **addl_opts)
 	sys.exit()
-    addl_opts = {}
-    if pth:
-        addl_opts['pth'] = '%s' % pth
-    if trim:
-        addl_opts['trim'] = '%s' % trim
-    if ignore_broken:
-        addl_opts['flags'] = 'i'
     if dtype is 'float':
        data_type = 'FCELL'
@@ -269,16 +284,12 @@
         grass.message(_("Processing horizontal slice %d of %d [%.15g,%.15g) ...")
 		        % (i, region['depths'], zrange_min, zrange_max))
-	#if not value:
 	proc[i] = grass.start_command('r.in.xyz', input = infile, output = tmp_layer_name,
 				      fs = fs, method = method, x = x, y = y, z = z,
 				      percent = percent, type = data_type,
 				      zrange = '%.15g,%.15g' % (zrange_min, zrange_max),
 				      **addl_opts)
-	#else:
-	#    use new alternate gate-range filter option in r.in.xyz
 	grass.debug("i=%d, %%=%d  (workers=%d)" % (i, i % workers, workers))
 	#print sys.getsizeof(proc)  # sizeof(proc array)  [not so big]
