[GRASS-SVN] r52166 - in grass/trunk/gui/wxpython: core gui_core lmgr
svn_grass at osgeo.org
Wed Jun 20 06:43:48 PDT 2012
Author: annakrat
Date: 2012-06-20 06:43:47 -0700 (Wed, 20 Jun 2012)
New Revision: 52166
grass/trunk/gui/wxpython/core/settings.py
grass/trunk/gui/wxpython/core/utils.py
grass/trunk/gui/wxpython/gui_core/dialogs.py
grass/trunk/gui/wxpython/gui_core/forms.py
grass/trunk/gui/wxpython/gui_core/goutput.py
grass/trunk/gui/wxpython/gui_core/preferences.py
grass/trunk/gui/wxpython/lmgr/frame.py
grass/trunk/gui/wxpython/lmgr/layertree.py
wxGUI/settings: added possibility to set default vector layer appearance
Modified: grass/trunk/gui/wxpython/core/settings.py
--- grass/trunk/gui/wxpython/core/settings.py 2012-06-20 11:21:28 UTC (rev 52165)
+++ grass/trunk/gui/wxpython/core/settings.py 2012-06-20 13:43:47 UTC (rev 52166)
@@ -27,7 +27,7 @@
from core import globalvar
from core.gcmd import GException, GError
-from core.utils import GetSettingsPath, PathJoin
+from core.utils import GetSettingsPath, PathJoin, rgb2str
class Settings:
"""!Generic class where to store settings"""
@@ -242,15 +242,48 @@
'verbosity' : {
'selection' : 'grassenv'
- # d.rast
- 'rasterOpaque' : {
+ 'addNewLayer' : {
+ 'enabled' : True,
+ 'interactiveInput' : {
+ 'enabled' : True,
+ # d.rast
+ 'rasterLayer': {
+ 'opaque': {
'enabled' : False
- 'rasterColorTable' : {
- 'enabled' : False,
- 'selection' : 'rainbow',
+ 'colorTable': {
+ 'enabled' : False,
+ 'selection' : 'rainbow'
- # d.vect
+ # d.vect
+ 'vectorLayer': {
+ 'featureColor': {
+ 'color' : (0, 0, 0),
+ 'transparent' : {
+ 'enabled': False
+ 'areaFillColor': {
+ 'color' : (200, 200, 200),
+ 'transparent' : {
+ 'enabled': False
+ 'line': {
+ 'width' : 0,
+ 'point': {
+ 'symbol': 'basic/x',
+ 'size' : 5,
'showType': {
'point' : {
'enabled' : True
@@ -271,12 +304,6 @@
'enabled' : True
- 'addNewLayer' : {
- 'enabled' : True,
- 'interactiveInput' : {
- 'enabled' : True,
# vdigit
@@ -1098,3 +1125,27 @@
self.userSettings[key] = copy.deepcopy(self.defaultSettings[key])
UserSettings = Settings()
+def GetDisplayVectSettings():
+ settings = list()
+ if not UserSettings.Get(group = 'vectorLayer', key = 'featureColor', subkey = ['transparent', 'enabled']):
+ featureColor = UserSettings.Get(group = 'vectorLayer', key = 'featureColor', subkey = 'color')
+ settings.append('color=%s' % rgb2str.get(featureColor, ':'.join(map(str,featureColor))))
+ else:
+ settings.append('color=none')
+ if not UserSettings.Get(group = 'vectorLayer', key = 'areaFillColor', subkey = ['transparent', 'enabled']):
+ fillColor = UserSettings.Get(group = 'vectorLayer', key = 'areaFillColor', subkey = 'color')
+ settings.append('fcolor=%s' % rgb2str.get(fillColor, ':'.join(map(str,fillColor))))
+ else:
+ settings.append('fcolor=none')
+ settings.append('width=%s' % UserSettings.Get(group = 'vectorLayer', key = 'line', subkey = 'width'))
+ settings.append('icon=%s' % UserSettings.Get(group = 'vectorLayer', key = 'point', subkey = 'symbol'))
+ settings.append('size=%s' % UserSettings.Get(group = 'vectorLayer', key = 'point', subkey = 'size'))
+ types = []
+ for ftype in ['point', 'line', 'boundary', 'centroid', 'area', 'face']:
+ if UserSettings.Get(group = 'vectorLayer', key = 'showType', subkey = [ftype, 'enabled']):
+ types.append(ftype)
+ settings.append('type=%s' % ','.join(types))
+ return settings
Modified: grass/trunk/gui/wxpython/core/utils.py
--- grass/trunk/gui/wxpython/core/utils.py 2012-06-20 11:21:28 UTC (rev 52165)
+++ grass/trunk/gui/wxpython/core/utils.py 2012-06-20 13:43:47 UTC (rev 52166)
@@ -28,6 +28,7 @@
from core.gcmd import RunCommand
from core.debug import Debug
+# from core.settings import UserSettings
def normalize_whitespace(text):
"""!Remove redundant whitespace from a string"""
@@ -745,3 +746,42 @@
return os.path.join(os.getenv('APPDATA'), 'grass%d' % version)
return os.path.join(os.getenv('HOME'), '.grass%d' % version)
+# From lib/gis/col_str.c, except purple which is mentioned
+# there but not given RGB values
+str2rgb = {'aqua': (100, 128, 255),
+ 'black': (0, 0, 0),
+ 'blue': (0, 0, 255),
+ 'brown': (180, 77, 25),
+ 'cyan': (0, 255, 255),
+ 'gray': (128, 128, 128),
+ 'green': (0, 255, 0),
+ 'grey': (128, 128, 128),
+ 'indigo': (0, 128, 255),
+ 'magenta': (255, 0, 255),
+ 'orange': (255, 128, 0),
+ 'purple': (128, 0, 128),
+ 'red': (255, 0, 0),
+ 'violet': (128, 0, 255),
+ 'white': (255, 255, 255),
+ 'yellow': (255, 255, 0)}
+rgb2str = {}
+for (s,r) in str2rgb.items():
+ rgb2str[ r ] = s
+def color_resolve(color):
+ if len(color) > 0 and color[0] in "0123456789":
+ rgb = tuple(map(int, color.split(':')))
+ label = color
+ else:
+ # Convert color names to RGB
+ try:
+ rgb = str2rgb[color]
+ label = color
+ except KeyError:
+ rgb = (200, 200, 200)
+ label = _('Select Color')
+ return (rgb, label)
Modified: grass/trunk/gui/wxpython/gui_core/dialogs.py
--- grass/trunk/gui/wxpython/gui_core/dialogs.py 2012-06-20 11:21:28 UTC (rev 52165)
+++ grass/trunk/gui/wxpython/gui_core/dialogs.py 2012-06-20 13:43:47 UTC (rev 52166)
@@ -51,7 +51,7 @@
from gui_core.forms import GUI
from gui_core.widgets import SingleSymbolPanel, EVT_SYMBOL_SELECTION_CHANGED
from core.utils import GetListOfMapsets, GetLayerNameFromCmd, GetValidLayerName
-from core.settings import UserSettings
+from core.settings import UserSettings, GetDisplayVectSettings
wxApplyMapLayers, EVT_APPLY_MAP_LAYERS= NewEvent()
@@ -1743,7 +1743,7 @@
if self.importType == 'gdal':
cmd = ['d.rast',
'map=%s' % name]
- if UserSettings.Get(group = 'cmd', key = 'rasterOpaque', subkey = 'enabled'):
+ if UserSettings.Get(group = 'rasterLayer', key = 'opaque', subkey = 'enabled'):
cmd.append('-n')
item = maptree.AddLayer(ltype = 'raster',
@@ -1753,7 +1753,7 @@
item = maptree.AddLayer(ltype = 'vector',
lname = name, lchecked = False,
lcmd = ['d.vect',
- 'map=%s' % name],
+ 'map=%s' % name] + GetDisplayVectSettings(),
multiple = False)
maptree.mapdisplay.MapWindow.ZoomToMap()
Modified: grass/trunk/gui/wxpython/gui_core/forms.py
--- grass/trunk/gui/wxpython/gui_core/forms.py 2012-06-20 11:21:28 UTC (rev 52165)
+++ grass/trunk/gui/wxpython/gui_core/forms.py 2012-06-20 13:43:47 UTC (rev 52166)
@@ -93,27 +93,6 @@
wxUpdateDialog, EVT_DIALOG_UPDATE = NewEvent()
-# From lib/gis/col_str.c, except purple which is mentioned
-# there but not given RGB values
-str2rgb = {'aqua': (100, 128, 255),
- 'black': (0, 0, 0),
- 'blue': (0, 0, 255),
- 'brown': (180, 77, 25),
- 'cyan': (0, 255, 255),
- 'gray': (128, 128, 128),
- 'green': (0, 255, 0),
- 'grey': (128, 128, 128),
- 'indigo': (0, 128, 255),
- 'magenta': (255, 0, 255),
- 'orange': (255, 128, 0),
- 'purple': (128, 0, 128),
- 'red': (255, 0, 0),
- 'violet': (128, 0, 255),
- 'white': (255, 255, 255),
- 'yellow': (255, 255, 0)}
-rgb2str = {}
-for (s,r) in str2rgb.items():
- rgb2str[ r ] = s
"""!Hide some options in the GUI"""
#_blackList = { 'enabled' : False,
@@ -122,19 +101,6 @@
'items' : {} }
-def color_resolve(color):
- if len(color) > 0 and color[0] in "0123456789":
- rgb = tuple(map(int, color.split(':')))
- label = color
- else:
- # Convert color names to RGB
- try:
- rgb = str2rgb[color]
- label = color
- except KeyError:
- rgb = (200, 200, 200)
- label = _('Select Color')
- return (rgb, label)
def text_beautify(someString , width = 70):
"""!Make really long texts shorter, clean up whitespace and remove
@@ -1340,9 +1306,9 @@
default_color = (200,200,200)
label_color = _("Select Color")
if p.get('default','') != '':
- default_color, label_color = color_resolve(p['default'])
- if p.get('value','') != '': # parameter previously set
- default_color, label_color = color_resolve(p['value'])
+ default_color, label_color = utils.color_resolve(p['default'])
+ if p.get('value','') != '' and p.get('value','') != 'none': # parameter previously set
+ default_color, label_color = utils.color_resolve(p['value'])
if prompt == 'color_none':
this_sizer = wx.BoxSizer(orient = wx.HORIZONTAL)
else:
@@ -1358,7 +1324,7 @@
btn_colour.Bind(csel.EVT_COLOURSELECT, self.OnColorChange)
none_check = wx.CheckBox(which_panel, wx.ID_ANY, _("Transparent"))
- if p.get('value','') != '' and p.get('value',[''])[0] == "none":
+ if p.get('value','') == "none":
none_check.SetValue(True)
else:
none_check.SetValue(False)
@@ -1806,7 +1772,7 @@
new_color = colorchooser.GetValue()[:]
# This is weird: new_color is a 4-tuple and new_color[:] is a 3-tuple
# under wx2.8.1
- new_label = rgb2str.get(new_color, ':'.join(map(str,new_color)))
+ new_label = utils.rgb2str.get(new_color, ':'.join(map(str,new_color)))
colorchooser.SetLabel(new_label)
colorchooser.SetColour(new_color)
colorchooser.Refresh()
@@ -2238,7 +2204,7 @@
"gisprompt" : False,
"multiple" : "yes",
# values must be an array of strings
- "values" : str2rgb.keys() + map(str, str2rgb.values())
+ "values" : utils.str2rgb.keys() + map(str, utils.str2rgb.values())
"name" : "a_file",
"description" : "A file selector",
Modified: grass/trunk/gui/wxpython/gui_core/goutput.py
--- grass/trunk/gui/wxpython/gui_core/goutput.py 2012-06-20 11:21:28 UTC (rev 52165)
+++ grass/trunk/gui/wxpython/gui_core/goutput.py 2012-06-20 13:43:47 UTC (rev 52166)
@@ -44,7 +44,7 @@
from gui_core.prompt import GPromptSTC
-from core.settings import UserSettings, Settings
+from core.settings import UserSettings, Settings, GetDisplayVectSettings
from gui_core.ghelp import SearchModuleWindow
wxCmdOutput, EVT_CMD_OUTPUT = NewEvent()
@@ -139,9 +139,9 @@
time.sleep(.1)
# set default color table for raster data
- if UserSettings.Get(group = 'cmd', key = 'rasterColorTable', subkey = 'enabled') and \
+ if UserSettings.Get(group = 'rasterLayer', key = 'colorTable', subkey = 'enabled') and \
args[0][0][:2] == 'r.':
- colorTable = UserSettings.Get(group = 'cmd', key = 'rasterColorTable', subkey = 'selection')
+ colorTable = UserSettings.Get(group = 'rasterLayer', key = 'colorTable', subkey = 'selection')
mapName = None
if args[0][0] == 'r.mapcalc':
try:
@@ -950,8 +950,9 @@
lcmd = ['d.rast',
'map=%s' % name]
else:
+ defaultParams = GetDisplayVectSettings()
lcmd = ['d.vect',
- 'map=%s' % name]
+ 'map=%s' % name] + defaultParams
mapTree.AddLayer(ltype = prompt,
lcmd = lcmd,
lname = name)
Modified: grass/trunk/gui/wxpython/gui_core/preferences.py
--- grass/trunk/gui/wxpython/gui_core/preferences.py 2012-06-20 11:21:28 UTC (rev 52165)
+++ grass/trunk/gui/wxpython/gui_core/preferences.py 2012-06-20 13:43:47 UTC (rev 52166)
@@ -48,6 +48,7 @@
from core.utils import ListOfMapsets, GetColorTables, ReadEpsgCodes, GetSettingsPath
+from gui_core.dialogs import SymbolDialog
wxSettingsChanged, EVT_SETTINGS_CHANGED = NewEvent()
@@ -189,6 +190,8 @@
value = win.IsChecked()
elif win.GetName() == 'GetStringSelection':
value = win.GetStringSelection()
+ elif win.GetName() == 'GetLabel':
+ value = win.GetLabel()
elif win.GetName() == 'GetColour':
value = tuple(win.GetValue())
else:
@@ -244,6 +247,7 @@
self._createAppearancePage(self.notebook)
self._createDisplayPage(self.notebook)
self._createCmdPage(self.notebook)
+ self._createLayersPage(self.notebook)
self._createAttributeManagerPage(self.notebook)
self._createProjectionPage(self.notebook)
@@ -821,10 +825,20 @@
sizer.Add(item = gridSizer, proportion = 1, flag = wx.ALL | wx.EXPAND, border = 5)
border.Add(item = sizer, proportion = 0, flag = wx.ALL | wx.EXPAND, border = 3)
+ panel.SetSizer(border)
+ return panel
+ def _createLayersPage(self, notebook):
+ """!Create notebook page for layer settings"""
+ panel = wx.Panel(parent = notebook, id = wx.ID_ANY)
+ notebook.AddPage(page = panel, text = _("Layers"))
+ border = wx.BoxSizer(wx.VERTICAL)
# raster settings
- box = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Raster settings"))
+ box = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Default raster settings"))
sizer = wx.StaticBoxSizer(box, wx.VERTICAL)
gridSizer = wx.GridBagSizer (hgap = 3, vgap = 3)
@@ -837,8 +851,8 @@
rasterOpaque = wx.CheckBox(parent = panel, id = wx.ID_ANY,
label = _("Make null cells opaque"),
name = 'IsChecked')
- rasterOpaque.SetValue(self.settings.Get(group = 'cmd', key = 'rasterOpaque', subkey = 'enabled'))
- self.winId['cmd:rasterOpaque:enabled'] = rasterOpaque.GetId()
+ rasterOpaque.SetValue(self.settings.Get(group = 'rasterLayer', key = 'opaque', subkey = 'enabled'))
+ self.winId['rasterLayer:opaque:enabled'] = rasterOpaque.GetId()
gridSizer.Add(item = rasterOpaque,
pos = (row, 0), span = (1, 2))
@@ -848,8 +862,8 @@
rasterCTCheck = wx.CheckBox(parent = panel, id = wx.ID_ANY,
label = _("Default color table"),
name = 'IsChecked')
- rasterCTCheck.SetValue(self.settings.Get(group = 'cmd', key = 'rasterColorTable', subkey = 'enabled'))
- self.winId['cmd:rasterColorTable:enabled'] = rasterCTCheck.GetId()
+ rasterCTCheck.SetValue(self.settings.Get(group = 'rasterLayer', key = 'colorTable', subkey = 'enabled'))
+ self.winId['rasterLayer:colorTable:enabled'] = rasterCTCheck.GetId()
rasterCTCheck.Bind(wx.EVT_CHECKBOX, self.OnCheckColorTable)
gridSizer.Add(item = rasterCTCheck,
@@ -858,8 +872,8 @@
rasterCTName = wx.Choice(parent = panel, id = wx.ID_ANY, size = (200, -1),
choices = GetColorTables(),
name = "GetStringSelection")
- rasterCTName.SetStringSelection(self.settings.Get(group = 'cmd', key = 'rasterColorTable', subkey = 'selection'))
- self.winId['cmd:rasterColorTable:selection'] = rasterCTName.GetId()
+ rasterCTName.SetStringSelection(self.settings.Get(group = 'rasterLayer', key = 'colorTable', subkey = 'selection'))
+ self.winId['rasterLayer:colorTable:selection'] = rasterCTName.GetId()
if not rasterCTCheck.IsChecked():
rasterCTName.Enable(False)
@@ -872,10 +886,10 @@
# vector settings
- box = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Vector settings"))
+ box = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Default vector settings"))
- gridSizer = wx.FlexGridSizer (cols = 7, hgap = 3, vgap = 3)
+ gridSizer = wx.FlexGridSizer (cols = 7, hgap = 10, vgap = 3)
gridSizer.Add(item = wx.StaticText(parent = panel, id = wx.ID_ANY,
label = _("Display:")),
@@ -884,12 +898,100 @@
for type in ('point', 'line', 'centroid', 'boundary',
'area', 'face'):
chkbox = wx.CheckBox(parent = panel, label = type)
- checked = self.settings.Get(group = 'cmd', key = 'showType',
+ checked = self.settings.Get(group = 'vectorLayer', key = 'showType',
subkey = [type, 'enabled'])
chkbox.SetValue(checked)
- self.winId['cmd:showType:%s:enabled' % type] = chkbox.GetId()
+ self.winId['vectorLayer:showType:%s:enabled' % type] = chkbox.GetId()
gridSizer.Add(item = chkbox)
+ sizer.Add(item = gridSizer, proportion = 0, flag = wx.ALL | wx.EXPAND, border = 5)
+ row = col = 0
+ gridSizer = wx.GridBagSizer (hgap = 3, vgap = 3)
+ gridSizer.AddGrowableCol(0)
+ gridSizer.AddGrowableCol(3)
+ # feature color
+ gridSizer.Add(item = wx.StaticText(parent = panel, id = wx.ID_ANY,
+ label = _("Feature color:")),
+ flag = wx.ALIGN_CENTER_VERTICAL, pos = (row, 0))
+ featureColor = csel.ColourSelect(parent = panel, id = wx.ID_ANY,
+ colour = self.settings.Get(group = 'vectorLayer',
+ key = 'featureColor',
+ subkey = 'color'),
+ size = globalvar.DIALOG_COLOR_SIZE)
+ featureColor.SetName('GetColour')
+ self.winId['vectorLayer:featureColor:color'] = featureColor.GetId()
+ gridSizer.Add(item = featureColor, pos = (row, col + 2), flag = wx.ALIGN_RIGHT)
+ transpFeature = wx.CheckBox(parent = panel, id = wx.ID_ANY,
+ label = _("Transparent"), name = "IsChecked")
+ transpFeature.SetValue(self.settings.Get(group = 'vectorLayer', key = 'featureColor',
+ subkey = ['transparent', 'enabled']))
+ self.winId['vectorLayer:featureColor:transparent:enabled'] = transpFeature.GetId()
+ gridSizer.Add(item = transpFeature, pos = (row, col + 1), flag = wx.ALIGN_CENTER_VERTICAL)
+ # area fill color
+ row += 1
+ label = _("Area fill color:")),
+ flag = wx.ALIGN_CENTER_VERTICAL, pos = (row, col))
+ fillColor = csel.ColourSelect(parent = panel, id = wx.ID_ANY,
+ key = 'areaFillColor',
+ fillColor.SetName('GetColour')
+ self.winId['vectorLayer:areaFillColor:color'] = fillColor.GetId()
+ gridSizer.Add(item = fillColor, pos = (row, col + 2), flag = wx.ALIGN_RIGHT)
+ transpArea = wx.CheckBox(parent = panel, id = wx.ID_ANY,
+ transpArea.SetValue(self.settings.Get(group = 'vectorLayer', key = 'areaFillColor',
+ self.winId['vectorLayer:areaFillColor:transparent:enabled'] = transpArea.GetId()
+ gridSizer.Add(item = transpArea, pos = (row, col + 1), flag = wx.ALIGN_CENTER_VERTICAL)
+ # line
+ row += 1
+ label = _("Line width:")),
+ hlWidth = wx.SpinCtrl(parent = panel, id = wx.ID_ANY, size = (50, -1),
+ initial = self.settings.Get(group = 'vectorLayer', key = 'line', subkey = 'width'),
+ min = 1, max = 1e6, name = "GetValue")
+ self.winId['vectorLayer:line:width'] = hlWidth.GetId()
+ gridSizer.Add(item = hlWidth, pos = (row, col + 1), span = (1, 2), flag = wx.ALIGN_RIGHT)
+ # symbol
+ row = 0
+ col = 4
+ label = _("Symbol size:")),
+ ptSize = wx.SpinCtrl(parent = panel, id = wx.ID_ANY, size = (50, -1),
+ initial = self.settings.Get(group = 'vectorLayer', key = 'point', subkey = 'size'),
+ self.winId['vectorLayer:point:size'] = ptSize.GetId()
+ gridSizer.Add(item = ptSize, pos = (row, col + 2), flag = wx.ALIGN_RIGHT)
+ row += 1
+ label = _("Symbol:")),
+ symbolPath = self.settings.Get(group = 'vectorLayer', key = 'point', subkey = 'symbol')
+ symbolLabel = wx.StaticText(parent = panel, id = wx.ID_ANY,
+ label = symbolPath, name = 'GetLabel')
+ symbolLabel.SetMinSize((150, -1))
+ self.winId['vectorLayer:point:symbol'] = symbolLabel.GetId()
+ gridSizer.Add(item = symbolLabel, flag = wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT, pos = (row, col + 1))
+ bitmap = wx.Bitmap(os.path.join(globalvar.ETCSYMBOLDIR, symbolPath) + '.png')
+ bb = wx.BitmapButton(parent = panel, id = wx.ID_ANY, bitmap = bitmap, name = "symbolButton")
+ bb.Bind(wx.EVT_BUTTON, self.OnSetSymbol)
+ gridSizer.Add(item = bb, pos = (row, col + 2))
border.Add(item = sizer, proportion = 0, flag = wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border = 3)
@@ -1163,7 +1265,7 @@
def OnCheckColorTable(self, event):
"""!Set/unset default color table"""
- win = self.FindWindowById(self.winId['cmd:rasterColorTable:selection'])
+ win = self.FindWindowById(self.winId['rasterLayer:colorTable:selection'])
if event.IsChecked():
win.Enable()
else:
@@ -1288,6 +1390,18 @@
event.Skip()
+ def OnSetSymbol(self, event):
+ """!Opens symbol dialog"""
+ winId = self.winId['vectorLayer:point:symbol']
+ label = self.FindWindowById(winId)
+ bb = self.FindWindowByName('symbolButton')
+ dlg = SymbolDialog(self, symbolPath = globalvar.ETCSYMBOLDIR,
+ currentSymbol = label.GetLabel())
+ if dlg.ShowModal() == wx.ID_OK:
+ img = dlg.GetSelectedSymbol(fullPath = True)
+ label.SetLabel(dlg.GetSelectedSymbol(fullPath = False))
+ bb.SetBitmapLabel(wx.Bitmap(img + '.png'))
def OnEnableWheelZoom(self, event):
"""!Enable/disable wheel zoom mode control"""
checkId = self.winId['display:mouseWheelZoom:enabled']
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py 2012-06-20 11:21:28 UTC (rev 52165)
+++ grass/trunk/gui/wxpython/lmgr/frame.py 2012-06-20 13:43:47 UTC (rev 52166)
@@ -39,7 +39,7 @@
from grass.script import core as grass
from core.gcmd import RunCommand, GError, GMessage
from gui_core.preferences import MapsetAccess, PreferencesDialog, EVT_SETTINGS_CHANGED
from lmgr.layertree import LayerTree, LMIcons
from lmgr.menudata import ManagerData
@@ -1434,7 +1434,7 @@
cmd = ['d.rast3d', 'map=%s' % layerName]
wxType = '3d-raster'
elif ltype == 'vect':
- cmd = ['d.vect', 'map=%s' % layerName]
+ cmd = ['d.vect', 'map=%s' % layerName] + GetDisplayVectSettings()
wxType = 'vector'
else:
GError(parent = self,
Modified: grass/trunk/gui/wxpython/lmgr/layertree.py
--- grass/trunk/gui/wxpython/lmgr/layertree.py 2012-06-20 11:21:28 UTC (rev 52165)
+++ grass/trunk/gui/wxpython/lmgr/layertree.py 2012-06-20 13:43:47 UTC (rev 52166)
@@ -38,7 +38,7 @@
from core.utils import GetLayerNameFromCmd
from wxplot.profile import ProfileFrame
from vdigit.main import haveVDigit
from core.gcmd import GWarning
from gui_core.toolbars import BaseIcons
@@ -986,7 +986,7 @@
self.GetPyData(layer)[0]['cmd'] = module.GetCmd()
elif ltype == 'raster':
cmd = ['d.rast']
cmd.append('-n')
elif ltype == '3d-raster':
@@ -994,7 +994,7 @@
elif ltype == 'rgb':
cmd = ['d.rgb']
cmd.append('-n')
elif ltype == 'his':
@@ -1010,13 +1010,8 @@
cmd = ['d.rast.num']
elif ltype == 'vector':
- types = list()
- for ftype in ['point', 'line', 'boundary', 'centroid', 'area', 'face']:
- if UserSettings.Get(group = 'cmd', key = 'showType', subkey = [ftype, 'enabled']):
- types.append(ftype)
+ cmd = ['d.vect'] + GetDisplayVectSettings()
- cmd = ['d.vect', 'type=%s' % ','.join(types)]
elif ltype == 'thememap':
# -s flag requested, otherwise only first thematic category is displayed
# should be fixed by C-based d.thematic.* modules
