[GRASS-SVN] r52191 - grass/branches/develbranch_6/scripts/r.blend
svn_grass at osgeo.org
Sat Jun 23 01:47:48 PDT 2012
Author: hamish
Date: 2012-06-23 01:47:47 -0700 (Sat, 23 Jun 2012)
New Revision: 52191
grass/branches/develbranch_6/scripts/r.blend/description.html
fix html bug (merge from trunk)
Modified: grass/branches/develbranch_6/scripts/r.blend/description.html
--- grass/branches/develbranch_6/scripts/r.blend/description.html 2012-06-23 08:46:23 UTC (rev 52190)
+++ grass/branches/develbranch_6/scripts/r.blend/description.html 2012-06-23 08:47:47 UTC (rev 52191)
@@ -3,16 +3,18 @@
<em>r.blend</em> blends color components of 2 raster maps by a
specificed percentage of the first map.
<h2>EXAMPLE</h2>
Blending the aspect map with the elevation map for a shaded map
(North Carolina sample dataset):
-<p>
<div class="code"><pre>
g.region rast=aspect -p
r.blend first=aspect second=elevation output_prefix=elev_shade_blend
d.mon x0
d.rgb blue=elev_shade_blend.b green=elev_shade_blend.g red=elev_shade_blend.r
+</pre></div>
<h2>SEE ALSO</h2>
@@ -24,6 +26,7 @@
<a href="r.support.html">r.support</a>
</em>
<h2>AUTHOR</h2>
Unknown: probably CERL<br>
