[GRASS-SVN] r52193 - grass/branches/develbranch_6/scripts/r.colors.stddev
svn_grass at osgeo.org
Sat Jun 23 04:28:29 PDT 2012
Author: hamish
Date: 2012-06-23 04:28:29 -0700 (Sat, 23 Jun 2012)
New Revision: 52193
grass/branches/develbranch_6/scripts/r.colors.stddev/r.colors.stddev
take advantage of modern r.univar functionality to only need to run it once, speeding up zero-crossing mode by 3 or 4 times
Modified: grass/branches/develbranch_6/scripts/r.colors.stddev/r.colors.stddev
--- grass/branches/develbranch_6/scripts/r.colors.stddev/r.colors.stddev 2012-06-23 09:18:34 UTC (rev 52192)
+++ grass/branches/develbranch_6/scripts/r.colors.stddev/r.colors.stddev 2012-06-23 11:28:29 UTC (rev 52193)
@@ -6,7 +6,7 @@
# New Zealand
# PURPOSE: Set color rules based on stddev from a map's mean value.
-# COPYRIGHT: (c) 2007 Hamish Bowman, and the GRASS Development Team
+# COPYRIGHT: (c) 2007-2012 Hamish Bowman, and the GRASS Development Team
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
# for details.
@@ -45,16 +45,15 @@
fi
-eval `r.univar -g "$GIS_OPT_INPUT"`
-# $? is result of the eval not r.univar (???)
-#if [ $? -ne 0 ] ; then
-# g.region -e "Problem running r.univar"
-# exit 1
-#fi
+if [ $GIS_FLAG_Z -eq 0 ] ; then
+ eval `r.univar -g "$GIS_OPT_INPUT"`
+ # $? is result of the eval not r.univar (???)
+ #if [ $? -ne 0 ] ; then
+ # g.message -e "Problem running r.univar"
+ # exit 1
+ #fi
-if [ $GIS_FLAG_Z -eq 0 ] ; then
MEAN_MINUS_2STDEV=`echo "$mean $stddev" | awk '{print $1 - 2*$2}'`
MEAN_PLUS_2STDEV=`echo "$mean $stddev" | awk '{print $1 + 2*$2}'`
@@ -102,9 +101,17 @@
r.mapcalc "r_col_stdev_abs_$$ = abs($GIS_OPT_INPUT)"
eval `r.info -r "r_col_stdev_abs_$$"`
- # current r.univar truncates percentage to the base integer
- STDDEV2=`r.univar -eg "r_col_stdev_abs_$$" perc=95.4500 | grep ^percentile | cut -f2 -d=`
+ SIGMA1=68.2689
+ SIGMA2=95.4500
+ SIGMA3=99.7300
+ eval `r.univar -eg "r_col_stdev_abs_$$" perc="$SIGMA1,$SIGMA2,$SIGMA3" | grep '^percentile'`
+ STDDEV1="$percentile_68_2689"
+ STDDEV2="$percentile_95_45"
+ STDDEV3="$percentile_99_73"
if [ $GIS_FLAG_B -eq 0 ] ; then
# zero centered smooth blue/white/red
r.colors "$GIS_OPT_INPUT" color=rules << EOF
@@ -117,10 +124,6 @@
else
# zero centered banded black/red/yellow/green/yellow/red/black
- STDDEV1=`r.univar -eg "r_col_stdev_abs_$$" perc=68.2689 | grep ^percentile | cut -f2 -d=`
- STDDEV3=`r.univar -eg "r_col_stdev_abs_$$" perc=99.7300 | grep ^percentile | cut -f2 -d=`
# >3 S.D. outliers colored black so they show up in d.histogram w/ white background
-$max black
