[GRASS-SVN] r52213 - grass/branches/develbranch_6/lib/python
Mon Jun 25 20:05:59 PDT 2012
Author: hamish
Date: 2012-06-25 20:05:58 -0700 (Mon, 25 Jun 2012)
New Revision: 52213
   grass/branches/develbranch_6/lib/python/vector.py
expand/fix vector_db_select() example (merge from trunk)
Modified: grass/branches/develbranch_6/lib/python/vector.py
--- grass/branches/develbranch_6/lib/python/vector.py	2012-06-26 03:05:11 UTC (rev 52212)
+++ grass/branches/develbranch_6/lib/python/vector.py	2012-06-26 03:05:58 UTC (rev 52213)
@@ -176,8 +176,12 @@
     key column value. Example:
     \code
-    >>> print grass.vector_select('lakes')['values'][3]
+    >>> print grass.vector_db_select('lakes')['columns']
+    ['cat', 'AREA', 'PERIMETER', 'FULL_HYDRO', 'FULL_HYDR2', 'FTYPE', 'FCODE', 'NAME']
+    >>> print grass.vector_db_select('lakes')['values'][3]
     ['3', '19512.86146', '708.44683', '4', '55652', 'LAKE/POND', '39000', '']
+    >>> print grass.vector_db_select('lakes', column = 'FTYPE')['values'][3]
+    ['LAKE/POND']
     \endcode
     @param map map name
@@ -205,7 +209,7 @@
                        **kwargs)
     if not ret:
-        error(_('vector_select() failed'))
+        error(_('vector_db_select() failed'))
         return { 'columns' : [], 'values' : {} }
     columns = []
