[GRASS-SVN] r52232 - grass-addons/grass7/imagery/i.segment
svn_grass at osgeo.org
Tue Jun 26 15:53:05 PDT 2012
Author: momsen
Date: 2012-06-26 15:53:04 -0700 (Tue, 26 Jun 2012)
New Revision: 52232
Added:
grass-addons/grass7/imagery/i.segment/flag.h
grass-addons/grass7/imagery/i.segment/flag_clr_all.c
grass-addons/grass7/imagery/i.segment/flag_create.c
grass-addons/grass7/imagery/i.segment/flag_destroy.c
grass-addons/grass7/imagery/i.segment/flag_get.c
grass-addons/grass7/imagery/i.segment/flag_set.c
grass-addons/grass7/imagery/i.segment/flag_unset.c
grass-addons/grass7/imagery/i.segment/create_isegs.c
grass-addons/grass7/imagery/i.segment/iseg.h
grass-addons/grass7/imagery/i.segment/main.c
grass-addons/grass7/imagery/i.segment/open_files.c
grass-addons/grass7/imagery/i.segment/parse_args.c
grass-addons/grass7/imagery/i.segment/write_output.c
general clean up, using TRUE/FALSE instead of 1/0, and other suggestions from Hamish.
Modified: grass-addons/grass7/imagery/i.segment/create_isegs.c
--- grass-addons/grass7/imagery/i.segment/create_isegs.c 2012-06-26 11:55:52 UTC (rev 52231)
+++ grass-addons/grass7/imagery/i.segment/create_isegs.c 2012-06-26 22:53:04 UTC (rev 52232)
@@ -4,7 +4,7 @@
#include <stdlib.h>
#include <float.h> /* to get value of LDBL_MAX -> change this if there is a more usual grass way */
- /* #include <math.h> *//* for sqrt() and pow() */
+ /* #include <math.h> *//* for sqrt() and pow() */
#include <grass/gis.h>
#include <grass/glocale.h>
#include <grass/raster.h>
@@ -13,6 +13,7 @@
#include "iseg.h"
#define LINKM
+#define REVERSE
int create_isegs(struct files *files, struct functions *functions)
@@ -32,11 +33,10 @@
lower_bound = upper_bound = 0;
} /* just one time through loop */
else {
- if (Rast_read_range(files->bounds_map, files->bounds_mapset, &range) <
- 0) {
- G_fatal_error(_("Unable to read fp range for raster map <%s>"),
+ if (Rast_read_range(files->bounds_map, files->bounds_mapset, &range) != 1) { /* returns -1 on error, 2 on empty range, quiting either way. */
+ G_fatal_error(_("No min/max found in raster map <%s>"),
files->bounds_map);
- } /* TODO, still should close files? */
Rast_get_range_min_max(&range, &lower_bound, &upper_bound); /* todo, faster way to do this? maybe do it manually when open and write to the segment file? But it is just once.... */
@@ -75,7 +75,6 @@
G_verbose_message("writing scaled input (layer 1) to output file");
G_verbose_message("weighted flag = %d", files->weighted);
for (row = 0; row < files->nrows; row++) {
- G_percent(row, files->nrows, 1); /* TODO this didn't get displayed in the output??? Does it get erased when done? */
for (col = 0; col < files->ncols; col++) {
/*files->out_val[0] = files->out_val[0]; *//*segment number *//* just copying the map for testing. */
/* files->out_val[0] = col + row; */
@@ -85,6 +84,7 @@
files->out_val[1] = 1; /*processing flag */
segment_put(&files->out_seg, (void *)files->out_val, row, col);
+ G_percent(row, files->nrows, 1);
/*speed test... showed a difference of 1min 9s for G_malloc and 34s for linkm. (with i < 2000000000 */
@@ -111,7 +111,7 @@
#endif
G_message("end speed test");
- return 0;
+ return TRUE;
int ll_test(struct files *files, struct functions *functions)
@@ -230,13 +230,13 @@
G_message("writing fake data to segmentation file");
- files->out_val[1] = 1; /*processing flag */
+ files->out_val[1] = TRUE; /*processing flag */
/*test how many pixels can be made and disposed of */
@@ -264,7 +264,7 @@
G_message("after link_cleanup(Rkn_token)");
G_message("end linked list test");
- return 0;
+ return TRUE;
int test_pass_token(struct pixels **head, struct files *files)
@@ -282,7 +282,7 @@
G_message("Added: Rin %d: row: %d, col: %d", n,
newpixel->row, newpixel->col);
- return 0;
+ return TRUE;
@@ -327,7 +327,7 @@
threshold = functions->threshold; /* TODO, consider making this a function of t. */
- endflag = 1;
+ endflag = TRUE;
/* Set candidate flag to true/1 for all pixels TODO: for polygon/vector constraint, need to just set to true for those being processed */
if (files->bounds_map == NULL) { /*normal processing */
@@ -338,7 +338,7 @@
/* TODO: if we are starting from seeds...and only allow merges between unassigned pixels
* and seeds/existing segments, then this needs an if (and will be very inefficient)
* maybe consider the sorted array, btree, map... but the number of seeds could still be high for a large map */
- files->out_val[1] = 1; /*candidate pixel flag */
+ files->out_val[1] = TRUE; /*candidate pixel flag */
col);
@@ -355,9 +355,9 @@
col);
if (files->bounds_val == files->current_bound) /*TODO could move this if statement one line up, and only set "1" flags if we can assume all flags are already zero. (i.e. only get/put the ones we want to set to 1.) */
else
- files->out_val[1] = 0;
+ files->out_val[1] = FALSE;
col);
@@ -373,24 +373,22 @@
/*process candidate pixels */
G_verbose_message("Row percent complete for pass number %d: ", t);
/*check each pixel, start the processing only if it is a candidate pixel */
/* for validation, select one of the two... could make this IFDEF or input parameter */
/* reverse order
+#ifdef REVERSE
for (row = files->nrows; row >= 0; row--) {
- for (col = files->ncols; col >= 0 ; col--) {
- G_percent(files->nrows-row, files->nrows, 1);
-end reverse order */
-/* "normal" order */
+ for (col = files->ncols; col >= 0; col--) {
+#else
- G_percent(row, files->nrows, 1); /*end normal order */ /* TODO, can a message be included with G_percent? */
+#endif
G_debug(4,
"Next starting pixel from next row/col, not from Rk");
segment_get(&files->out_seg, (void *)files->out_val, row, col); /*TODO small time savings - if candidate_count reaches zero, bail out of these loops too? */
- if (files->out_val[1] == 1 && files->out_val != NULL) { /* out_val[1] is the candidate pixel flag, want to process the 1's */ /*TODO MASK handling - checking if we have a segment ID already, in open_files() we will put nulls in [0] slot... better/faster way to do this?*/
+ if (files->out_val[1] == TRUE && files->out_val != NULL) { /* out_val[1] is the candidate pixel flag, want to process the 1's *//*TODO MASK handling - checking if we have a segment ID already, in open_files() we will put nulls in [0] slot... better/faster way to do this? */
G_debug(4, "going to free memory on linked lists...");
/*free memory for linked lists */
my_dispose_list(files->token, &Ri_head);
@@ -408,9 +406,9 @@
newpixel->col = col;
Ri_head = newpixel;
- pathflag = 1;
+ pathflag = TRUE;
- // while (pathflag == 1 && files->candidate_count > 0) { /*if don't find mutual neighbors on first try, will use Rk as next Ri. */
+ // while (pathflag == TRUE && files->candidate_count > 0) { /*if don't find mutual neighbors on first try, will use Rk as next Ri. */
G_debug(4, "Next starting pixel: row, %d, col, %d",
Ri_head->row, Ri_head->col);
@@ -436,13 +434,13 @@
/* find segment neighbors */
if (find_segment_neighbors
(&Ri_head, &Rin_head, &Ri_count, files,
- functions) != 0) {
+ functions) != TRUE) {
G_fatal_error("find_segment_neighbors() failed");
} /* TODO - shouldn't be just fatal error - need to still close_files(). Just put that here then fatal error? */
if (Rin_head == NULL) {
G_debug(4, "2a, Segment had no valid neighbors"); /*this could happen if there is a segment surrounded by pixels that have already been processed */
- pathflag = 0;
+ pathflag = FALSE;
Ri_count = 0;
set_candidate_flag(Ri_head, 0, files); /* TODO: error trap? */
files->candidate_count++; /* already counted out Ri[0]; */
@@ -480,7 +478,7 @@
G_debug(4,
"simularity = %g for neighbor : row: %d, col %d.",
tempsim, current->row, current->col);
if (tempsim < Ri_similarity) {
Ri_similarity = tempsim;
Ri_bestn = current; /*TODO want to point to the current pixel...confirm when current changes need this to stay put! */
@@ -491,18 +489,20 @@
- if (Ri_bestn != NULL){
+ if (Ri_bestn != NULL) {
G_debug(4,
"Lowest Ri_similarity = %g, for neighbor pixel row: %d col: %d",
Ri_similarity, Ri_bestn->row,
Ri_bestn->col);
- segment_get(&files->out_seg, (void *)files->out_val, Ri_bestn->row, Ri_bestn->col);
- if (files->out_val[1] == 0)
+ segment_get(&files->out_seg,
+ (void *)files->out_val, Ri_bestn->row,
+ Ri_bestn->col);
+ if (files->out_val[1] == FALSE)
/* this check is important:
* best neighbor is not a valid candidate, was already merged earlier in this time step */
Ri_similarity = threshold + 1;
if (Ri_bestn != NULL && Ri_similarity < threshold) { /* small TODO: should this be < or <= for threshold? */
/* we'll have the neighbor pixel to start with. */
@@ -542,7 +542,7 @@
for (current = Rkn_head; current != NULL; current = current->next) { /* for each of Rk's neighbors */
tempsim = functions->calculate_similarity(Rk_head, current, files, functions); /*TODO: need an error trap here, if something goes wrong with calculating similarity? */
if (tempsim < Rk_similarity) {
Rk_similarity = tempsim;
break; /* exit for Rk's neighbors loop here, we know that Ri and Rk aren't mutually best neighbors */
@@ -551,8 +551,8 @@
if (Rk_similarity == Ri_similarity) { /* so they agree, both are mutually most similar neighbors, none of Rk's other neighbors were more similar */
merge_values(Ri_head, Rk_head, Ri_count, Rk_count, files); /* TODO error trap */
- endflag = 0; /* we've made at least one merge, so need another t iteration */
- pathflag = 0; /* go to next row,column pixel - end of Rk -> Ri chain since we found mutual best neighbors */
+ endflag = FALSE; /* we've made at least one merge, so need another t iteration */
+ pathflag = FALSE; /* go to next row,column pixel - end of Rk -> Ri chain since we found mutual best neighbors */
else { /* they weren't mutually best neighbors */
G_debug(4,
@@ -583,27 +583,35 @@
* thus Ri can not be the mutually best neighbor later on during this pass
* unfortunately this does happen sometimes */
- files->candidate_count++; /*first pixel was already set*/
+ files->candidate_count++; /*first pixel was already set */
G_debug(4,
"3b Rk didn't didn't exist, was not valid candidate, or similarity was > threshold");
- } /*end else - Ri's best neighbor was not a candidate */
+ } /*end else - Ri's best neighbor was not a candidate */
} /* end else - Ri did have neighbors */
// } /*end pathflag do loop */
} /*end if pixel is candidate pixel */
} /*next column */
+#ifdef REVERSE
+ G_percent(files->nrows - row, files->nrows, 1);
+#else
+ G_percent(row, files->nrows, 1); /* TODO, can a message be included with G_percent? */
+#endif
+ /* TODO, the REVERSE version gets printed on a new line, and isnt' covered. The else version is. ? */
+ /* TODO, shows up in CLI, not in GUI */
} /*next row */
/* finished one pass for processing candidate pixels */
G_debug(4, "Finished one pass, t was = %d", t);
t++;
- } while (t <= functions->end_t && endflag == 0);
+ } while (t <= functions->end_t && endflag == FALSE);
/*end t loop *//*TODO, should there be a max t that it can iterate for? Include t in G_message? */
/* free memory *//*TODO: anything ? */
- return 0;
+ return TRUE;
int find_segment_neighbors(struct pixels **R_head,
@@ -639,7 +647,7 @@
/*initialize data.... TODO: maybe remember min max row/col that was looked at each time, initialize in open_files, and reset smaller region at end of this functions */
for (n = 0; n < files->nrows; n++) {
for (m = 0; m < files->ncols; m++) {
- val_no_check = 0;
+ val_no_check = FALSE;
segment_put(&files->no_check, &val_no_check, n, m);
@@ -708,14 +716,14 @@
"\twith pixel neigh %d, row: %d col: %d, val_no_check = %d",
n, pixel_neighbors[n][0], pixel_neighbors[n][1],
val_no_check);
- if (val_no_check == 0) { /* want to check this neighbor */
+ if (val_no_check == FALSE) { /* want to check this neighbor */
val_no_check = 1;
segment_put(&files->no_check, &val_no_check, pixel_neighbors[n][0], pixel_neighbors[n][1]); /* don't check it again */
segment_get(&files->out_seg, (void *)files->out_val, pixel_neighbors[n][0], pixel_neighbors[n][1]); /*TODO : do I need a second "out_val" data structure? */
- if (files->out_val[1] == 1 || files->out_val[1] == 0) { /* all pixels, not just valid pixels */
- /* TODO: use -1 for NULL/MASKED pixels? */
+ if (files->out_val[1] == TRUE || files->out_val[1] == FALSE) { /* all pixels, not just valid pixels */
+ /* TODO: use -1 for NULL/MASKED pixels? */
G_debug(5, "\tfiles->out_val[0] = %d Ri_seg_ID = %d",
files->out_val[0], Ri_seg_ID);
@@ -765,7 +773,7 @@
G_debug(5, "\t### end of pixel neighors");
} /* while to_check has more elements */
- return 0;
+ return TRUE;
int find_four_pixel_neighbors(int p_row, int p_col, int pixel_neighbors[8][2],
@@ -805,7 +813,7 @@
pixel_neighbors[3][1] = p_col;
/*TODO: seems there should be a more elegent way to do this... */
- return 0;
+ return TRUE;
int find_eight_pixel_neighbors(int p_row, int p_col,
@@ -817,7 +825,7 @@
/* get the 4 diagonal neighbors */
G_warning("Diagonal neighbors Not Implemented");
/*TODO... continue as above */
- return 0;
+ return TRUE;
/* similarity / distance between two points based on their input raster values */
@@ -869,7 +877,7 @@
segment_get(&files->out_seg, (void *)files->out_val, Ri_head->row,
Ri_head->col);
- files->out_val[1] = 0; /*candidate pixel flag, only one merge allowed per t iteration */
+ files->out_val[1] = FALSE; /*candidate pixel flag, only one merge allowed per t iteration */
/* if separate out candidate flag, can do all changes with helper function...otherwise remember: */
@@ -899,7 +907,7 @@
files->candidate_count++; /* had already counted down the starting pixel Ri[0] at the beginning... */
G_debug(4, "line 522, \t\t\t\tcc = %d", files->candidate_count);
- return 0;
+ return TRUE;
/* TODO.. helper function, maybe make more general? */
@@ -923,7 +931,7 @@
G_debug(4, "line 544, \t\t\t\tcc = %d", files->candidate_count);
- return 0;
+ return TRUE;
/* let memory manager know space is available again and reset head to NULL */
@@ -937,5 +945,5 @@
link_dispose(token, (VOID_T *) current); /* remove "old" head */
- return 0;
+ return TRUE;
Added: grass-addons/grass7/imagery/i.segment/flag.h
--- grass-addons/grass7/imagery/i.segment/flag.h (rev 0)
+++ grass-addons/grass7/imagery/i.segment/flag.h 2012-06-26 22:53:04 UTC (rev 52232)
@@ -0,0 +1,77 @@
+#ifndef __FLAG_H__
+#define __FLAG_H__
+/* flag.[ch] is a set of routines which will set up an array of bits
+ ** that allow the programmer to "flag" cells in a raster map.
+ ** FLAG *
+ ** flag_create(nrows,ncols)
+ ** int nrows, ncols;
+ ** opens the structure flag.
+ ** The flag structure will be a two dimensional array of bits the
+ ** size of nrows by ncols. Will initalize flags to zero (unset).
+ ** flag_destroy(flags)
+ ** FLAG *flags;
+ ** closes flags and gives the memory back to the system.
+ ** flag_clear_all(flags)
+ ** FLAG *flags;
+ ** sets all values in flags to zero.
+ ** flag_unset(flags, row, col)
+ ** FLAG *flags;
+ ** int row, col;
+ ** sets the value of (row, col) in flags to zero.
+ ** flag_set(flags, row, col)
+ ** FLAG *flags;
+ ** int row, col;
+ ** will set the value of (row, col) in flags to one.
+ ** int
+ ** flag_get(flags, row, col)
+ ** FLAG *flags;
+ ** int row, col;
+ ** returns the value in flags that is at (row, col).
+ ** idea by Michael Shapiro
+ ** code by Chuck Ehlschlaeger
+ ** April 03, 1989
+#define FLAG struct _flagsss_
+FLAG {
+ int nrows, ncols, leng;
+ unsigned char **array;
+#define FLAG_UNSET(flags,row,col) \
+ (flags)->array[(row)][(col)>>3] &= ~(1<<((col) & 7))
+#define FLAG_SET(flags,row,col) \
+ (flags)->array[(row)][(col)>>3] |= (1<<((col) & 7))
+#define FLAG_GET(flags,row,col) \
+ (flags)->array[(row)][(col)>>3] & (1<<((col) & 7))
+/* flag_clr_all.c */
+int flag_clear_all(FLAG *);
+/* flag_create.c */
+FLAG *flag_create(int, int);
+/* flag_destroy.c */
+int flag_destroy(FLAG *);
+/* flag_get.c */
+int flag_get(FLAG *, int, int);
+/* flag_set.c */
+int flag_set(FLAG *, int, int);
+/* flag_unset.c */
+int flag_unset(FLAG *, int, int);
+#endif /* __FLAG_H__ */
Added: grass-addons/grass7/imagery/i.segment/flag_clr_all.c
--- grass-addons/grass7/imagery/i.segment/flag_clr_all.c (rev 0)
+++ grass-addons/grass7/imagery/i.segment/flag_clr_all.c 2012-06-26 22:53:04 UTC (rev 52232)
@@ -0,0 +1,14 @@
+#include "flag.h"
+int flag_clear_all(FLAG * flags)
+ register int r, c;
+ for (r = 0; r < flags->nrows; r++) {
+ for (c = 0; c < flags->leng; c++) {
+ flags->array[r][c] = 0;
+ return 0;
Added: grass-addons/grass7/imagery/i.segment/flag_create.c
--- grass-addons/grass7/imagery/i.segment/flag_create.c (rev 0)
+++ grass-addons/grass7/imagery/i.segment/flag_create.c 2012-06-26 22:53:04 UTC (rev 52232)
@@ -0,0 +1,27 @@
+#include <grass/gis.h>
+#include "flag.h"
+FLAG *flag_create(int nrows, int ncols)
+ unsigned char *temp;
+ FLAG *new_flag;
+ register int i;
+ new_flag = (FLAG *) G_malloc(sizeof(FLAG));
+ new_flag->nrows = nrows;
+ new_flag->ncols = ncols;
+ new_flag->leng = (ncols + 7) / 8;
+ new_flag->array =
+ (unsigned char **)G_malloc(nrows * sizeof(unsigned char *));
+ temp =
+ (unsigned char *)G_malloc(nrows * new_flag->leng *
+ sizeof(unsigned char));
+ for (i = 0; i < nrows; i++) {
+ new_flag->array[i] = temp;
+ temp += new_flag->leng;
+ return (new_flag);
Added: grass-addons/grass7/imagery/i.segment/flag_destroy.c
--- grass-addons/grass7/imagery/i.segment/flag_destroy.c (rev 0)
+++ grass-addons/grass7/imagery/i.segment/flag_destroy.c 2012-06-26 22:53:04 UTC (rev 52232)
@@ -0,0 +1,11 @@
+#include "flag.h"
+int flag_destroy(FLAG * flags)
+ G_free(flags->array[0]);
+ G_free(flags->array);
+ G_free(flags);
+ return 0;
Added: grass-addons/grass7/imagery/i.segment/flag_get.c
--- grass-addons/grass7/imagery/i.segment/flag_get.c (rev 0)
+++ grass-addons/grass7/imagery/i.segment/flag_get.c 2012-06-26 22:53:04 UTC (rev 52232)
@@ -0,0 +1,6 @@
+#include "flag.h"
+int flag_get(FLAG * flags, int row, int col)
+ return (flags->array[row][col >> 3] & (1 << (col & 7)));
Added: grass-addons/grass7/imagery/i.segment/flag_set.c
--- grass-addons/grass7/imagery/i.segment/flag_set.c (rev 0)
+++ grass-addons/grass7/imagery/i.segment/flag_set.c 2012-06-26 22:53:04 UTC (rev 52232)
@@ -0,0 +1,8 @@
+#include "flag.h"
+int flag_set(FLAG * flags, int row, int col)
+ flags->array[row][col >> 3] |= (1 << (col & 7));
+ return 0;
Added: grass-addons/grass7/imagery/i.segment/flag_unset.c
--- grass-addons/grass7/imagery/i.segment/flag_unset.c (rev 0)
+++ grass-addons/grass7/imagery/i.segment/flag_unset.c 2012-06-26 22:53:04 UTC (rev 52232)
@@ -0,0 +1,8 @@
+#include "flag.h"
+int flag_unset(FLAG * flags, int row, int col)
+ flags->array[row][col >> 3] &= ~(1 << (col & 7));
+ return 0;
Modified: grass-addons/grass7/imagery/i.segment/iseg.h
--- grass-addons/grass7/imagery/i.segment/iseg.h 2012-06-26 11:55:52 UTC (rev 52231)
+++ grass-addons/grass7/imagery/i.segment/iseg.h 2012-06-26 22:53:04 UTC (rev 52232)
@@ -34,9 +34,9 @@
int nrows, ncols;
/* files *//* TODO, for all map names, is this better for any reason, saw it in manual example: char name[GNAME_MAX]; */
- char *out_name; /* name of output raster map */
+ char *out_name; /* name of output raster map */
char *seeds, *bounds_map, *bounds_mapset; /* optional segment seeds and polygon constraints/boundaries */
- char *out_band; /* for debug */
+ char *out_band; /* for debug */
/* file processing */
int nbands; /* number of rasters in the image group */
@@ -84,8 +84,8 @@
int (*find_pixel_neighbors) (int, int, int[8][2], struct files *); /*parameters: row, col, pixel_neighbors */
double (*calculate_similarity) (struct pixels *, struct pixels *, struct files *, struct functions *); /*parameters: two points (row,col) to compare */
- /* for debug */
- int end_t;
+ /* for debug */
+ int end_t;
@@ -102,7 +102,8 @@
int ll_test(struct files *, struct functions *);
int test_pass_token(struct pixels **, struct files *);
int region_growing(struct files *, struct functions *);
-int find_segment_neighbors(struct pixels **, struct pixels **, int *, struct files *, struct functions *);
+int find_segment_neighbors(struct pixels **, struct pixels **, int *,
+ struct files *, struct functions *);
int set_candidate_flag(struct pixels *, int, struct files *);
int merge_values(struct pixels *, struct pixels *, int, int, struct files *);
int find_four_pixel_neighbors(int, int, int[][2], struct files *);
Modified: grass-addons/grass7/imagery/i.segment/main.c
--- grass-addons/grass7/imagery/i.segment/main.c 2012-06-26 11:55:52 UTC (rev 52231)
+++ grass-addons/grass7/imagery/i.segment/main.c 2012-06-26 22:53:04 UTC (rev 52232)
@@ -37,29 +37,24 @@
module->description =
_("Outputs a single segmented map (raster) based on input values in an image group.");
- if (parse_args(argc, argv, &files, &functions) != 0)
- G_debug(1, "Error in parse_args()"); /* TODO: should these be debug or G_fatal_error() or nested if statement? want to clean up mem and temp files */
+ if (parse_args(argc, argv, &files, &functions) != TRUE)
+ G_fatal_error(_("Error in parse_args()"));
G_debug(1, "Main: starting open_files()");
- if (open_files(&files) != 0)
- G_debug(1, "Error in open_files()");
+ if (open_files(&files) != TRUE)
+ G_fatal_error(_("Error in open_files()"));
G_debug(1, "Main: starting create_isegs()");
- if (create_isegs(&files, &functions) != 0)
- G_debug(1, "Error in create_isegs()");
+ if (create_isegs(&files, &functions) != TRUE)
+ G_fatal_error(_("Error in create_isegs()"));
G_debug(1, "Main: starting write_output()");
- if (write_output(&files) != 0)
- G_debug(1, "Error in write_output()");
+ if (write_output(&files) != TRUE)
+ G_fatal_error(_("Error in write_output()"));
G_debug(1, "Main: starting close_files()");
close_files(&files);
- /* TODO - G_fatal_error() called in sub routines - do I need to run close_files() before quitting?
- * http://rackerhacker.com/2010/03/18/sigterm-vs-sigkill/
- * "Standard C applications have a header file that contains the steps that the process should follow if it receives a particular signal. "
G_done_msg("Number of segments created: TODO");
exit(EXIT_SUCCESS);
Modified: grass-addons/grass7/imagery/i.segment/open_files.c
--- grass-addons/grass7/imagery/i.segment/open_files.c 2012-06-26 11:55:52 UTC (rev 52231)
+++ grass-addons/grass7/imagery/i.segment/open_files.c 2012-06-26 22:53:04 UTC (rev 52232)
@@ -22,7 +22,7 @@
/* ****** open the input rasters ******* */
- /* TODO: I confirmed, the API does not check this. Should this be checked in parse_args / validation ? Or best to do here where I want to use the REF data? */
+ /* TODO: I confirmed, the API does not check this. Should this be checked in parse_args / validation ? Or best to do here where I want to use the REF data? */
if (!I_get_group_ref(files->image_group, &Ref))
G_fatal_error(_("Unable to read REF file for group <%s>"),
files->image_group);
@@ -47,15 +47,15 @@
/* Get min/max values of each input raster for scaling */
- if (files->weighted == 0) { /*default, we will scale */
+ if (files->weighted == FALSE) { /*default, we will scale */
for (n = 0; n < Ref.nfiles; n++) {
- if (Rast_read_fp_range
- (Ref.file[n].name, Ref.file[n].mapset, &fp_range[n]) < 0)
- G_fatal_error(_("Unable to read fp range for raster map <%s>"), Ref.file[n].name); /* TODO, still should free memory and close files? */
+ if (Rast_read_fp_range(Ref.file[n].name, Ref.file[n].mapset, &fp_range[n]) != 1) /* returns -1 on error, 2 on empty range, quiting either way. */
+ Ref.file[n].name);
Rast_get_fp_range_min_max(&(fp_range[n]), &min[n], &max[n]);
G_debug(1, "scaling, for first layer, min: %f, max: %f",
- min[0], max[0]);
+ min[0], max[0]);
/* ********** find out file segmentation size ************ */
@@ -91,7 +91,7 @@
if (segment_open
(&files->bands_seg, G_tempfile(), files->nrows, files->ncols, srows,
- scols, inlen, nseg) != 1)
+ scols, inlen, nseg) != TRUE)
G_fatal_error("Unable to create input temporary files");
/* G_debug(1, "finished segment_open(...bands_seg...)"); */
@@ -99,10 +99,10 @@
/* TODO: signed integer gives a 2 billion segment limit, depending on how the initialization is done, this means 2 billion max input pixels. */
if (segment_open
(&files->out_seg, G_tempfile(), files->nrows, files->ncols, srows,
- scols, outlen, nseg) != 1)
+ scols, outlen, nseg) != TRUE)
G_fatal_error("Unable to create output temporary files");
- if (segment_open(&files->no_check, G_tempfile(), files->nrows, files->ncols, srows, scols, sizeof(int), nseg) != 1) /* todo could make this smaller ? just need 0 or 1 */
+ if (segment_open(&files->no_check, G_tempfile(), files->nrows, files->ncols, srows, scols, sizeof(int), nseg) != TRUE) /* todo could make this smaller ? just need 0 or 1 */
G_fatal_error("Unable to create flag temporary files");
/* load input bands to segment structure and initialize output segmentation file */
@@ -111,49 +111,48 @@
files->bands_val = (double *)G_malloc(inlen);
files->second_val = (double *)G_malloc(inlen);
files->out_val = (int *)G_malloc(2 * sizeof(int));
- s = 1; /* initial segment ID */
+ s = 1; /* initial segment ID */
Rast_get_d_row(in_fd[n], inbuf[n], row);
- /*tempval = 0; Doesn't work, no "null" for doubles in c */ /* want a number, not null */
- null_check = 1; /*Assume there is data*/
+ /*tempval = 0; Doesn't work, no "null" for doubles in c *//* want a number, not null */
+ null_check = 1; /*Assume there is data */
- /*tempval += inbuf[n][col]; */ /* if mask/null, adding a null value should set tempval to NULL */
- if(Rast_is_d_null_value(&inbuf[n][col]))
- null_check=-1;
- if (files->weighted == 1)
+ /*tempval += inbuf[n][col]; *//* if mask/null, adding a null value should set tempval to NULL */
+ if (Rast_is_d_null_value(&inbuf[n][col]))
+ null_check = -1;
+ if (files->weighted == TRUE)
files->bands_val[n] = inbuf[n][col]; /*unscaled */
else
files->bands_val[n] = (inbuf[n][col] - min[n]) / (max[n] - min[n]); /*scaled version */
- segment_put(&files->bands_seg, (void *)files->bands_val, row,
- col); /* store input bands */
- if (null_check != -1){ /*good pixel*/
+ segment_put(&files->bands_seg, (void *)files->bands_val, row, col); /* store input bands */
+ if (null_check != -1) { /*good pixel */
files->out_val[0] = s; /*starting segment number TODO: for seeds this will be different */
- files->out_val[1] = 0; /*flag */
- else /*don't use this pixel*/
- files->out_val[0] = -1; /*starting segment number*/
- files->out_val[1] = -1; /*flag */
- segment_put(&files->out_seg, (void *)files->out_val, row, col); /* initialize input */
+ files->out_val[1] = TRUE; /*flag */
+ else { /*don't use this pixel */
+ files->out_val[0] = -1; /*starting segment number */
+ files->out_val[1] = -1; /*flag */
+ segment_put(&files->out_seg, (void *)files->out_val, row, col); /* initialize input */
s++; /* sequentially number all pixels with their own segment ID */
/* bounds/constraints */
/* TODO: You should also handle NULL cells in the bounds
- * raster map, I would suggest to replace NULL with min(bounds) - 1 or
- +* max(bounds) + 1. */
+ * raster map, I would suggest to replace NULL with min(bounds) - 1 or
+ +* max(bounds) + 1. */
if (files->bounds_map != NULL) {
if (segment_open
(&files->bounds_seg, G_tempfile(), files->nrows, files->ncols,
- srows, scols, sizeof(int), nseg) != 1)
+ srows, scols, sizeof(int), nseg) != TRUE)
G_fatal_error("Unable to create bounds temporary files");
boundsbuf = Rast_allocate_c_buf();
@@ -184,7 +183,7 @@
/* Free memory */
- /* G_free(inbuf[n]); TODO - didn't have this line to start with, but should it be added? */
+ G_free(inbuf[n]);
Rast_close(in_fd[n]);
@@ -195,5 +194,5 @@
G_free(max);
/* Need to clean up anything else? */
- return 0;
+ return TRUE;
Modified: grass-addons/grass7/imagery/i.segment/parse_args.c
--- grass-addons/grass7/imagery/i.segment/parse_args.c 2012-06-26 11:55:52 UTC (rev 52231)
+++ grass-addons/grass7/imagery/i.segment/parse_args.c 2012-06-26 22:53:04 UTC (rev 52232)
@@ -13,8 +13,8 @@
/* reference: http://grass.osgeo.org/programming7/gislib.html#Command_Line_Parsing */
struct Option *group, *seeds, *bounds, *output, *method, *threshold; /* Establish an Option pointer for each option */
- struct Flag *diagonal, *weighted; /* Establish a Flag pointer for each option */
- struct Option *outband, *endt; /* debugging parameters... TODO: leave in code or remove? hidden options? */
+ struct Flag *diagonal, *weighted; /* Establish a Flag pointer for each option */
+ struct Option *outband, *endt; /* debugging parameters... TODO: leave in code or remove? hidden options? */
/* required parameters */
group = G_define_standard_option(G_OPT_I_GROUP); /* TODO: OK to require the user to create a group? Otherwise later add an either/or option to give just a single raster map... */
@@ -50,14 +50,12 @@
/* Using raster for seeds, Low priority TODO: allow vector points/centroids seed input. */
seeds = G_define_standard_option(G_OPT_R_INPUT);
seeds->key = "seeds";
- seeds->type = TYPE_STRING;
seeds->required = NO;
seeds->description = _("Optional raster map with starting seeds.");
/* Polygon constraints. */
bounds = G_define_standard_option(G_OPT_R_INPUT);
bounds->key = "bounds";
- bounds->type = TYPE_STRING;
bounds->required = NO;
bounds->description =
_("Optional bounding/constraining raster map, must be integer values, each area will be segmented independent of the others.");
@@ -70,17 +68,16 @@
/* TODO input for distance function */
- /* debug parameters */
+ /* debug parameters */
endt = G_define_option();
endt->key = "endt";
endt->type = TYPE_INTEGER;
- endt->required = YES; /* TODO, could put as optional, and if not supplied put in something large. */
+ endt->required = YES; /* TODO, could put as optional, and if not supplied put in something large. */
endt->description = _("Maximum number of time steps to complete.");
- outband = G_define_standard_option(G_OPT_R_INPUT);
+ outband = G_define_standard_option(G_OPT_R_OUTPUT);
outband->key = "final_mean";
- outband->type = TYPE_STRING;
- outband->required = YES;
+ outband->required = NO;
outband->description =
_("debug - save band mean, currently implemented for only 1 band.");
@@ -100,20 +97,18 @@
files->image_group = group->answer;
- if (G_legal_filename(output->answer) == 1)
+ if (G_legal_filename(output->answer) == TRUE)
files->out_name = output->answer; /* name of output raster map */
else
G_fatal_error("Invalid output raster name.");
- /* TODO: I'm assuming threshold is already validated as a number. Is this OK, or is there a better way to cast the input? */
- /* reference r.cost line 313
- if (sscanf(opt5->answer, "%d", &maxcost) != 1 || maxcost < 0)
- G_fatal_error(_("Inappropriate maximum cost: %d"), maxcost); */
- sscanf(threshold->answer, "%f", &functions->threshold); /* Note: this threshold is scaled after we know more at the beginning of create_isegs() */
+ functions->threshold = atof(threshold->answer); /* Note: this threshold is scaled after we know more at the beginning of create_isegs() */
+ if (weighted->answer == TRUE &&
+ (functions->threshold <= 0 || functions->threshold >= 1))
+ G_fatal_error(_("threshold should be >= 0 and <= 1")); /* TODO OK to have fatal error here, seems this would be an invalid entry. */
/* segmentation methods: 0 = debug, 1 = region growing */
/* TODO, instead of string compare, does the Option structure have these already numbered? */
if (strncmp(method->answer, "io_debug", 5) == 0)
functions->method = 0;
else if (strncmp(method->answer, "region_growing", 10) == 0)
@@ -125,12 +120,12 @@
G_debug(1, "segmentation method: %d", functions->method);
- if (diagonal->answer == 0) {
+ if (diagonal->answer == FALSE) {
functions->find_pixel_neighbors = &find_four_pixel_neighbors;
functions->num_pn = 4;
G_debug(1, "four pixel neighborhood");
- else if (diagonal->answer == 1) {
+ else if (diagonal->answer == TRUE) {
functions->find_pixel_neighbors = &find_eight_pixel_neighbors;
functions->num_pn = 8;
G_debug(1, "eight (3x3) pixel neighborhood");
@@ -146,12 +141,13 @@
files->bounds_map = NULL;
else { /* polygon constraints given */
- files->bounds_map = bounds->answer;
+ files->bounds_map = bounds->answer;
if ((files->bounds_mapset = G_find_raster(files->bounds_map, "")) == NULL) { /* TODO, warning here: parse_args.c:149:27: warning: assignment discards ‘const’ qualifier from pointer target type [enabled by default] */
G_fatal_error(_("Segmentation constraint/boundary map not found."));
- if (Rast_map_type(files->bounds_map, files->bounds_mapset) != CELL_TYPE) {
- G_fatal_error(_("Segmentation constraint map must be CELL type (integers)"));
+ if (Rast_map_type(files->bounds_map, files->bounds_mapset) !=
+ CELL_TYPE) {
+ G_fatal_error(_("Segmentation constraint map must be CELL type (integers)"));
@@ -159,13 +155,17 @@
files->nrows = Rast_window_rows();
files->ncols = Rast_window_cols();
- /* debug help */
- if (G_legal_filename(outband->answer) == 1)
- files->out_band = outband->answer; /* name of current means */
- else
- G_fatal_error("Invalid output raster name for means.");
+ /* debug help */
+ if (outband->answer == NULL)
+ files->out_band = NULL;
+ else {
+ if (G_legal_filename(outband->answer) == TRUE)
+ files->out_band = outband->answer; /* name of current means */
+ else
+ G_fatal_error("Invalid output raster name for means.");
- sscanf(endt->answer, "%d", &functions->end_t); /* Note: this threshold is scaled after we know more at the beginning of create_isegs() */
+ functions->end_t = atoi(endt->answer); /* Note: this threshold is scaled after we know more at the beginning of create_isegs() */
- return 0;
+ return TRUE;
Modified: grass-addons/grass7/imagery/i.segment/write_output.c
--- grass-addons/grass7/imagery/i.segment/write_output.c 2012-06-26 11:55:52 UTC (rev 52231)
+++ grass-addons/grass7/imagery/i.segment/write_output.c 2012-06-26 22:53:04 UTC (rev 52232)
@@ -7,65 +7,71 @@
#include <grass/segment.h> /* segmentation library */
#include "iseg.h"
+/* TODO some time delay here with meanbuf, etc being processed. I only put if statements on the actual files
+ * to try and keep the code more clear. Need to see if this raster makes stats processing easier? Or IFDEF it out?
int write_output(struct files *files)
- int out_fd, mean_fd, row, col; /* mean_fd for validiating/debug of means, todo, could add array... */
+ int out_fd, mean_fd, row, col; /* mean_fd for validiating/debug of means, todo, could add array... */
CELL *outbuf;
DCELL *meanbuf;
outbuf = Rast_allocate_c_buf(); /*hold one row of data to put into raster */
- meanbuf = Rast_allocate_d_buf();
+ meanbuf = Rast_allocate_d_buf();
/* Todo: return codes are 1 for these, need to check and react to errors? programmer's manual didn't include it... */
segment_flush(&files->out_seg); /* force all data to disk */
- segment_flush(&files->bands_seg); /* TODO use IFDEF or just delete for all these parts? for debug/validation output */
+ segment_flush(&files->bands_seg); /* TODO use IFDEF or just delete for all these parts? for debug/validation output */
G_debug(1, "preparing output raster");
/* open output raster map */
out_fd = Rast_open_new(files->out_name, CELL_TYPE);
+ if (files->out_band != NULL)
mean_fd = Rast_open_new(files->out_band, DCELL_TYPE);
G_debug(1, "start data transfer from segmentation file to raster");
/* transfer data from segmentation file to raster */
/* output segmentation file: each element includes the segment ID then processing flag(s). So just need the first part of it. */
- Rast_set_c_null_value(outbuf, files->ncols); /*set buffer to NULLs, only write those that weren't originally masked */
+ Rast_set_c_null_value(outbuf, files->ncols); /*set buffer to NULLs, only write those that weren't originally masked */
Rast_set_d_null_value(meanbuf, files->ncols);
+ segment_get(&files->bands_seg, (void *)files->bands_val, row,
+ col);
G_debug(5, "outval[0] = %i", files->out_val[0]);
- if(files->out_val[0] >= 0) /* only write positive segment ID's, using -1 as indicator of Null/Masked pixels. TODO: OK to use -1 as flag for this? */
- {outbuf[col] = files->out_val[0]; /*just want segment assignment, not the other processing flag(s) */
- // meanbuf[col] = files->out_val[0];
+ if (files->out_val[0] >= 0) { /* only write positive segment ID's, using -1 as indicator of Null/Masked pixels. TODO: OK to use -1 as flag for this? */
+ outbuf[col] = files->out_val[0]; /*just want segment assignment, not the other processing flag(s) */
+ meanbuf[col] = files->out_val[0];
- segment_get(&files->bands_seg, (void *)files->bands_val, row, col);
- meanbuf[col] = files->bands_val[0];
Rast_put_row(out_fd, outbuf, CELL_TYPE);
- Rast_put_row(mean_fd, meanbuf, DCELL_TYPE);
+ Rast_put_row(mean_fd, meanbuf, DCELL_TYPE);
-/* TODO: I don't understand the header/history/etc for raster storage. Can/should we save any information about the segmentation
- * settings used to create the raster? What the input image group was? Anything else the statistics module would need?
+ /* TODO: I don't understand the header/history/etc for raster storage. Can/should we save any information about the segmentation
+ * settings used to create the raster? What the input image group was? Anything else the statistics module would need?
+ * check it with r.info to see what we have by default.
-/* TODO after we have a count of create segments... if(total segments == 0) G_warning(_("No segments were created. Verify threshold and region settings.")); */
+ /* TODO after we have a count of create segments... if(total segments == 0) G_warning(_("No segments were created. Verify threshold and region settings.")); */
/* close and save file */
Rast_close(out_fd);
- Rast_close(mean_fd);
+ Rast_close(mean_fd);
- /* free memory */
- G_free(outbuf);
- G_free(meanbuf);
+ /* free memory */
+ G_free(outbuf);
+ G_free(meanbuf);
- return 0;
+ return TRUE;
int close_files(struct files *files)
@@ -89,5 +95,5 @@
/* anything else left to clean up? */
- return 0;
+ return TRUE;
