[GRASS-SVN] r52252 - grass/trunk/temporal/t.vect.observe.strds
Thu Jun 28 15:43:03 PDT 2012
Author: huhabla
Date: 2012-06-28 15:43:02 -0700 (Thu, 28 Jun 2012)
New Revision: 52252
   grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py
   grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.relative.sh
   grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.sh
More robust implementation and bug fixing
Modified: grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py
--- grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py	2012-06-28 16:09:07 UTC (rev 52251)
+++ grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py	2012-06-28 22:43:02 UTC (rev 52252)
@@ -27,6 +27,14 @@
 #% key: strds
 #%end
+#%option G_OPT_STVDS_OUTPUT
+#%end
+#%option G_OPT_V_OUTPUT
+#% key: vector_output
+#% description: Name of the new created vector map that stores the sampled values
+#%end
 #%option
 #% key: column
 #% type: string
@@ -35,13 +43,6 @@
 #% multiple: no
 #%end
-#%option
-#% key: output
-#% type: string
-#% description: Name the new created space time vector dataset and the new vector map
-#% required: yes
-#% multiple: no
-#%end
 #%option G_OPT_DB_WHERE
 #%end
@@ -61,6 +62,7 @@
     # Get the options
     input = options["input"]
     output = options["output"]
+    vector_output = options["vector_output"]
     strds = options["strds"]
     where = options["where"]
     column = options["column"]
@@ -114,35 +116,46 @@
         dbif.close()
         grass.fatal(_("Space time vector dataset <%s> is empty") % out_sp.get_id())
-    # Create the output space time vector dataset
+    num_rows = len(rows)
-    out_sp.set_initial_values(strds_sp.get_temporal_type(), \
-                              strds_sp.get_semantic_type(),\
-                              _("Observaion of space time raster dataset <%s>")%(strds_id),\
-                              _("Observation of space time raster dataset <%s> with vector map <%s>")%(strds_id, input))
+    # Get the layer and database connections of the input vector
+    vector_db = grass.vector.vector_db(input)
-    out_sp.insert(dbif)
-    num_rows = len(rows)
     # We copy the vector table and create the new layers
-    layers= ""
+    if vector_db:
+	# Use the first layer to copy the categories from
+        layers= "1,"
+    else:
+        layers= ""
     first = True
     for layer in range(num_rows):
         layer += 1
+        # Skip existing layer
+	if vector_db and vector_db.has_key(layer) and vector_db[layer]["layer"] == layer:
+	    continue
         if first:
             layers += "%i"%(layer)
             first = False
         else:
             layers += ",%i"%(layer)
-    print layers
-    vectmap = output
+    # Use the name of the space time vector dataset as new vector name
+    vectmap = vector_output
+    # We create a new vector map using the categories of the original map
     ret = grass.run_command("v.category", input=input, layer=layers, output=vectmap, option="transfer", overwrite=grass.overwrite())
     if ret != 0:
         grass.fatal(_("Unable to create new layers for vector map <%s>") % (vectmap))
+    # Create the output space time vector dataset
+    out_sp.set_initial_values(strds_sp.get_temporal_type(), \
+                              strds_sp.get_semantic_type(),\
+                              _("Observaion of space time raster dataset <%s>")%(strds_id),\
+                              _("Observation of space time raster dataset <%s> with vector map <%s>")%(strds_id, input))
+    out_sp.insert(dbif)
     dummy = out_sp.get_new_map_instance(None)
     # Sample the space time raster dataset with the vector map at specific layer with v.what.rast
@@ -165,14 +178,18 @@
 	    coltype = "INT"
         # Try to add a column
-	ret = grass.run_command("v.db.addcolumn", map=vectmap, layer=count, column="%s %s" % (col_name, coltype), overwrite=grass.overwrite())
-	if ret != 0:
+	if vector_db and vector_db.has_key(count) and vector_db[count]["table"]:
+	    ret = grass.run_command("v.db.addcolumn", map=vectmap, layer=count, column="%s %s" % (col_name, coltype), overwrite=grass.overwrite())
+	    if ret != 0:
+	        dbif.close()
+	        grass.fatal(_("Unable to add column %s to vector map <%s> with layer %i")%(col_name, vectmap, count))
+        else:
             # Try to add a new table
             grass.message("Add table to layer %i"%(count))
 	    ret = grass.run_command("v.db.addtable", map=vectmap, layer=count, columns="%s %s" % (col_name, coltype), overwrite=grass.overwrite())
 	    if ret != 0:
 	        dbif.close()
-	        grass.fatal(_("Unable to add column %s to vector map <%s> with layer %i")%(col_name, vectmap, count))
+	        grass.fatal(_("Unable to add table to vector map <%s> with layer %i")%(vectmap, count))
 	# Call v.what.rast
 	ret = grass.run_command("v.what.rast", map=vectmap, layer=count, raster=rastmap, column=col_name, where=where)
Modified: grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.relative.sh
--- grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.relative.sh	2012-06-28 16:09:07 UTC (rev 52251)
+++ grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.relative.sh	2012-06-28 22:43:02 UTC (rev 52252)
@@ -19,10 +19,11 @@
 t.register -i input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start=0 increment=1 unit=months
 # The @test
-t.vect.observe.strds input=prec strds=precip_abs1 output=prec_observer
+t.vect.observe.strds input=prec strds=precip_abs1 output=prec_observer vector=prec_observer
 v.info prec_observer
 t.info type=stvds input=prec_observer
 t.vect.list input=prec_observer
+t.vect.db.select input=prec_observer
 # @postprocess
 t.unregister type=rast maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
Modified: grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.sh
--- grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.sh	2012-06-28 16:09:07 UTC (rev 52251)
+++ grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.sh	2012-06-28 22:43:02 UTC (rev 52252)
@@ -12,22 +12,32 @@
 r.mapcalc --o expr="prec_5 = 500.0"
 r.mapcalc --o expr="prec_6 = 600.0"
-v.random --o -z output=prec n=5 seed=1
+v.random --o output=prec n=5 seed=1
+v.random --o -z output=test_1 column=test n=5 seed=1
 t.create --o type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
 t.register -i input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-03-01 00:00:00" increment="1 months"
 # The @test
+t.vect.observe.strds input=prec strds=precip_abs1 output=prec_observer vector=prec_observer column="test_val"
+t.vect.observe.strds input=test_1 strds=precip_abs1 output=test_1_observer vector=test_1_observer
+v.info test_1_observer
+t.info type=stvds input=test_1_observer
+t.vect.list input=test_1_observer
+t.vect.db.select input=test_1_observer
 # @postprocess
 t.remove type=strds input=precip_abs1
-t.remove type=stvds input=prec_observer
+t.remove type=stvds input=prec_observer,test_1_observer
 t.unregister type=vect maps=prec_observer:1,prec_observer:2,prec_observer:3,prec_observer:4,prec_observer:5,prec_observer:6
+t.unregister type=vect maps=test_1_observer:1,test_1_observer:2,test_1_observer:3,test_1_observer:4,test_1_observer:5,test_1_observer:6
-g.remove vect=prec_observer,test_extract
+g.remove vect=prec_observer,test_1_observer
 g.remove rast=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
