[GRASS-SVN] r50972 - grass/trunk/lib/python
svn_grass at osgeo.org
Fri Mar 2 12:24:25 EST 2012
Author: glynn
Date: 2012-03-02 09:24:25 -0800 (Fri, 02 Mar 2012)
New Revision: 50972
grass/trunk/lib/python/core.py
Use KeyValue object for key-value data
(allows use of e.g. region.rows as an alternative to region['rows'])
Modified: grass/trunk/lib/python/core.py
--- grass/trunk/lib/python/core.py 2012-03-02 16:55:37 UTC (rev 50971)
+++ grass/trunk/lib/python/core.py 2012-03-02 17:24:25 UTC (rev 50972)
@@ -486,6 +486,27 @@
return tmp
+class KeyValue(dict):
+ """A general-purpose key-value store.
+ KeyValue is a subclass of dict, but also allows entries to be read and
+ written using attribute syntax. Example:
+ \code
+ >>> region = grass.region()
+ >>> region['rows']
+ 477
+ >>> region.rows
+ 477
+ \endcode
+ def __getattr__(self, key):
+ return self[key]
+ def __setattr__(self, key, value):
+ self[key] = value
# key-value parsers
def parse_key_val(s, sep = '=', dflt = None, val_type = None, vsep = None):
@@ -500,7 +521,7 @@
@return parsed input (dictionary of keys/values)
- result = {}
+ result = KeyValue()
if not s:
return result
