[GRASS-SVN] r50981 -
grass/branches/releasebranch_6_4/vector/v.out.ascii
svn_grass at osgeo.org
Sun Mar 4 06:37:09 EST 2012
Author: martinl
Date: 2012-03-04 03:37:09 -0800 (Sun, 04 Mar 2012)
New Revision: 50981
grass/branches/releasebranch_6_4/vector/v.out.ascii/b2a.c
grass/branches/releasebranch_6_4/vector/v.out.ascii/out.c
#1470 (v.out.ascii with sql where option exports only centroids and not areas)
(merge r48914 from devbr6)
Modified: grass/branches/releasebranch_6_4/vector/v.out.ascii/b2a.c
--- grass/branches/releasebranch_6_4/vector/v.out.ascii/b2a.c 2012-03-03 14:54:22 UTC (rev 50980)
+++ grass/branches/releasebranch_6_4/vector/v.out.ascii/b2a.c 2012-03-04 11:37:09 UTC (rev 50981)
@@ -5,16 +5,17 @@
#include "local_proto.h"
static int srch(const void *pa, const void *pb);
+static int check_cat(const struct line_cats *, const int *, int);
int bin_to_asc(FILE *ascii,
FILE *att, struct Map_info *Map, int ver,
int format, int dp, char *fs, int region_flag,
int field, char* where, char **columns)
- int type, ctype, i, cat, proj;
+ int type, ctype, i, cat, line, left, right, found;
double *xptr, *yptr, *zptr, x, y;
static struct line_pnts *Points;
- struct line_cats *Cats;
+ struct line_cats *Cats, *ACats;
char *xstring = NULL, *ystring = NULL, *zstring = NULL;
struct Cell_head window;
struct ilist *fcats;
@@ -62,16 +63,16 @@
Points = Vect_new_line_struct(); /* init line_pnts struct */
Cats = Vect_new_cats_struct();
+ ACats = Vect_new_cats_struct();
fcats = Vect_new_list();
- proj = Vect_get_proj(Map);
/* by default, read_next_line will NOT read Dead lines */
/* but we can override that (in Level I only) by specifying */
/* the type -1, which means match all line types */
Vect_rewind(Map);
+ line = 0;
while (1) {
if (-1 == (type = Vect_read_next_line(Map, Points, Cats))) {
if (columns) {
@@ -90,22 +91,30 @@
return 0;
+ line++;
if (format == FORMAT_POINT && !(type & GV_POINTS))
continue;
- if (cats) {
- /* check category */
- for (i = 0; i < Cats->n_cats; i++) {
- if ((int *)bsearch((void *) &(Cats->cat[i]), cats, ncats, sizeof(int),
- srch)) {
- /* found */
- break;
+ found = check_cat(Cats, cats, ncats);
+ if (!found && type == GV_BOUNDARY && Vect_level(Map) > 1) {
+ Vect_get_line_areas(Map, line, &left, &right);
+ if (left < 0)
+ left = Vect_get_isle_area(Map, abs(left));
+ if (left > 0) {
+ Vect_get_area_cats(Map, left, ACats);
+ found = check_cat(ACats, cats, ncats);
- if (i == Cats->n_cats)
- continue;
+ if (right < 0)
+ right = Vect_get_isle_area(Map, abs(right));
+ if (!found && right > 0) {
+ Vect_get_area_cats(Map, right, ACats);
+ if (!found)
+ continue;
if (ver < 5) {
Vect_cat_get(Cats, 1, &cat);
@@ -300,7 +309,6 @@
/* not reached */
@@ -315,3 +323,24 @@
return 1;
return 0;
+/* check category */
+int check_cat(const struct line_cats *Cats, const int *cats, int ncats)
+ int i;
+ if (cats) {
+ for (i = 0; i < Cats->n_cats; i++) {
+ if ((int *)bsearch((void *) &(Cats->cat[i]), cats, ncats, sizeof(int),
+ srch)) {
+ /* found */
+ break;
+ if (i == Cats->n_cats)
+ return FALSE;
+ return TRUE;
Modified: grass/branches/releasebranch_6_4/vector/v.out.ascii/out.c
--- grass/branches/releasebranch_6_4/vector/v.out.ascii/out.c 2012-03-03 14:54:22 UTC (rev 50980)
+++ grass/branches/releasebranch_6_4/vector/v.out.ascii/out.c 2012-03-04 11:37:09 UTC (rev 50981)
@@ -141,10 +141,18 @@
- Vect_set_open_level(1); /* only need level I */
- if (Vect_open_old(&Map, input->answer, "") < 0)
- G_fatal_error(_("Unable to open vector map <%s>"),
+ /* open with topology only if needed */
+ if (format == FORMAT_ALL && where_opt->answer) {
+ if (Vect_open_old(&Map, input->answer, "") < 2) /* topology required for areas */
+ G_warning(_("Unable to open vector map <%s> at topology level. "
+ "Areas will not be processed."),
input->answer);
+ else {
+ Vect_set_open_level(1); /* topology not needed */
+ if (Vect_open_old(&Map, input->answer, "") < 0)
+ G_fatal_error(_("Unable to open vector map <%s>"), input->answer);
if (output->answer) {
if (ver == 4) {
