[GRASS-SVN] r50992 - grass/branches/releasebranch_6_4/locale/po
svn_grass at osgeo.org
Mon Mar 5 03:10:55 EST 2012
Author: neteler
Date: 2012-03-05 00:10:54 -0800 (Mon, 05 Mar 2012)
New Revision: 50992
grass/branches/releasebranch_6_4/locale/po/grasslibs_ja.po
grass/branches/releasebranch_6_4/locale/po/grassmods_ja.po
grass/branches/releasebranch_6_4/locale/po/grassnviz_ja.po
grass/branches/releasebranch_6_4/locale/po/grasstcl_ja.po
grass/branches/releasebranch_6_4/locale/po/grasswxpy_ja.po
Naoki Ueda and team: cont'ed
Modified: grass/branches/releasebranch_6_4/locale/po/grasslibs_ja.po
--- grass/branches/releasebranch_6_4/locale/po/grasslibs_ja.po 2012-03-04 12:43:05 UTC (rev 50991)
+++ grass/branches/releasebranch_6_4/locale/po/grasslibs_ja.po 2012-03-05 08:10:54 UTC (rev 50992)
@@ -1,6 +1,6 @@
# translation of grasslibs_ja.po to Japanese
# This file is distributed under the same license as the GRASS package.
-# Copyright (C) 2005,2010 GRASS Development Team
+# Copyright (C) 2005,2010,2012 GRASS Development Team
# Shinji Masumoto <masumoto at sci.osaka-cu.ac.jp>, 2004
# Susumu Nonogaki <nonogaki at sci.osaka-cu.ac.jp>, 2005
@@ -13,8 +13,8 @@
"Project-Id-Version: grasslibs_ja\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2012-02-01 08:43+0100\n"
-"PO-Revision-Date: 2011-11-15 15:01+0900\n"
-"Last-Translator: ueda <nao at locapoint.com>\n"
+"PO-Revision-Date: 2012-03-05 12:14+0900\n"
+"Last-Translator: Naoki Ueda <nao at locapoint.com>\n"
"Language-Team: Japanese <grass-translations at lists.osgeo.org>\n"
"Language: ja\n"
"MIME-Version: 1.0\n"
@@ -80,11 +80,8 @@
#: ../lib/symbol/read.c:259
#, c-format
-msgid ""
-"Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
-msgstr ""
-"ä¸é©å½ãªã·ã³ãã«åã§ã: '%s' (group/name ã¾ã㯠group/name at mapsetã«ãã¦ãã ã"
-"ã)"
+msgid "Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
+msgstr "ä¸é©å½ãªã·ã³ãã«åã§ã: '%s' (group/name ã¾ã㯠group/name at mapsetã«ãã¦ãã ãã)"
#: ../lib/symbol/read.c:283
#, c-format
@@ -119,12 +116,8 @@
msgstr "ã¿ã¤ã ã¹ã¿ã³ãå²ãå½ã¦ã«ãããã¡ã¢ãªã¨ã©ã¼"
#: ../lib/sites/sites.c:348 ../lib/sites/sites.c:478
-msgid ""
-"Dev note: Adapted sites library used for vector points. (module should be "
-"updated to GRASS 6 vector library)"
-msgstr ""
-"Dev note: ãã¯ãã«ãã¤ã³ãã«ä½¿ç¨ãããé©åããããµã¤ãã©ã¤ãã©ãª. (ã¢ã¸ã¥ã¼ã«"
-"ãGRASS 6 ãã¯ãã«ã©ã¤ãã©ãªã«ã¢ãããã¼ãããå¿
è¦ãããã¾ã)"
+msgid "Dev note: Adapted sites library used for vector points. (module should be updated to GRASS 6 vector library)"
+msgstr "Dev note: ãã¯ãã«ãã¤ã³ãã«ä½¿ç¨ãããé©åããããµã¤ãã©ã¤ãã©ãª. (ã¢ã¸ã¥ã¼ã«ãGRASS 6 ãã¯ãã«ã©ã¤ãã©ãªã«ã¢ãããã¼ãããå¿
è¦ãããã¾ã)"
#: ../lib/sites/sites.c:372 ../lib/vector/neta/utils.c:116
#: ../lib/vector/neta/timetables.c:133 ../lib/vector/Vlib/map.c:271
@@ -266,12 +259,8 @@
#: ../lib/ogsf/gsd_prim.c:630
#, c-format
-msgid ""
-"gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please "
-"advise GRASS developers of this error"
-msgstr ""
-"gsd_rot(): 䏿£ãªè»¸%cãæå®ããã¦ãã¾ã. ãã¼ãã¼ã·ã§ã³ã¯ç¡è¦ããã¾ãã. ãã®"
-"ã¨ã©ã¼ãGRASSéçºè
ã«å ±åãã¦ãã ãã"
+msgid "gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please advise GRASS developers of this error"
+msgstr "gsd_rot(): 䏿£ãªè»¸%cãæå®ããã¦ãã¾ã. ãã¼ãã¼ã·ã§ã³ã¯ç¡è¦ããã¾ãã. ãã®ã¨ã©ã¼ãGRASSéçºè
ã«å ±åãã¦ãã ãã"
#: ../lib/ogsf/gsd_img_tif.c:64 ../lib/ogsf/GK2.c:219
#: ../lib/ogsf/gsd_img_ppm.c:53 ../lib/ogsf/gsd_img_ppm.c:96
@@ -289,8 +278,7 @@
#: ../lib/ogsf/gsd_surf.c:1742
msgid "Cut-plane points mis-match between surfaces. Check resolution(s)."
-msgstr ""
-"ã«ããå¹³é¢ã®ãã¤ã³ãã¯ãµã¼ãã§ã¹ã®éã§ä¸è´ãã¾ãã. 解決çã確èªãã¦ãã ãã."
+msgstr "ã«ããå¹³é¢ã®ãã¤ã³ãã¯ãµã¼ãã§ã¹ã®éã§ä¸è´ãã¾ãã. 解決çã確èªãã¦ãã ãã."
#: ../lib/ogsf/gsdrape.c:207
msgid "Unable to process vector map - out of memory"
@@ -453,8 +441,7 @@
#: ../lib/ogsf/Gs3.c:1020
msgid "View not saved by this program,there may be some inconsistancies"
-msgstr ""
-"ãã®ããã°ã©ã ã«ãã¥ã¼ã¯ä¿åããã¦ãã¾ãã,ãä¸ä¸è´ãããå¯è½æ§ãããã¾ã"
+msgstr "ãã®ããã°ã©ã ã«ãã¥ã¼ã¯ä¿åããã¦ãã¾ãã,ãä¸ä¸è´ãããå¯è½æ§ãããã¾ã"
#: ../lib/ogsf/gsds.c:109
msgid "Maximum number of datasets exceeded"
@@ -475,11 +462,8 @@
#: ../lib/proj/convert.c:127
#, c-format
-msgid ""
-"OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
-msgstr ""
-"OGR ã¯PROJ.4-styleãã©ã¡ã¼ã¿ã®æååãè§£æã§ãã¾ãã: %s (OGR ã¨ã©ã¼ã³ã¼ã "
-"%d)"
+msgid "OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
+msgstr "OGR ã¯PROJ.4-styleãã©ã¡ã¼ã¿ã®æååãè§£æã§ãã¾ãã: %s (OGR ã¨ã©ã¼ã³ã¼ã %d)"
#: ../lib/proj/convert.c:133
#, c-format
@@ -493,26 +477,17 @@
#: ../lib/proj/convert.c:426
#, c-format
msgid "Datum <%s> not recognised by GRASS and no parameters found"
-msgstr ""
-"ãã¼ã¿ã <%s> ã¯GRASSã«èªèããã¦ãã¾ãã ããã¦ãã©ã¡ã¼ã¿ãè¦ã¤ããã¾ãã"
+msgstr "ãã¼ã¿ã <%s> ã¯GRASSã«èªèããã¦ãã¾ãã ããã¦ãã©ã¡ã¼ã¿ãè¦ã¤ããã¾ãã"
#: ../lib/proj/convert.c:442
#, c-format
-msgid ""
-"Datum <%s> apparently recognised by GRASS but no parameters found. You may "
-"want to look into this."
-msgstr ""
-"ãã¼ã¿ã <%s> ã¯GRASSã«èªèããã¦ããããã§ããã ãã©ã¡ã¼ã¿ãè¦ã¤ããã¾ã"
-"ããã調ã¹ã¦ãã ããã"
+msgid "Datum <%s> apparently recognised by GRASS but no parameters found. You may want to look into this."
+msgstr "ãã¼ã¿ã <%s> ã¯GRASSã«èªèããã¦ããããã§ããã ãã©ã¡ã¼ã¿ãè¦ã¤ããã¾ãããã調ã¹ã¦ãã ããã"
#: ../lib/proj/convert.c:446
#, c-format
-msgid ""
-"Invalid transformation number %d; valid range is 1 to %d. Leaving datum "
-"transform parameters unspecified."
-msgstr ""
-"ç¡å¹ãªå¤ææ°ã§ã %d; æå¹ãªç¯å²ã¯1ãã %dã§ãããã¼ã¿ã 夿ãã©ã¡ã¼ã¿ã詳細ä¸"
-"æã®ã¾ã¾ã«ãã¦ããã¦ãã ããã"
+msgid "Invalid transformation number %d; valid range is 1 to %d. Leaving datum transform parameters unspecified."
+msgstr "ç¡å¹ãªå¤ææ°ã§ã %d; æå¹ãªç¯å²ã¯1ãã %dã§ãããã¼ã¿ã 夿ãã©ã¡ã¼ã¿ãè©³ç´°ä¸æã®ã¾ã¾ã«ãã¦ããã¦ãã ããã"
#: ../lib/proj/datum.c:251
msgid "Unable to open temporary file"
@@ -812,23 +787,19 @@
msgstr "ã°ã«ã¼ã <%s> ã¯æ¬¡ã®ã©ã¹ã¿ã¼ããããåç
§ãã¾ã\n"
#: ../lib/imagery/sigsetfile.c:41
-#, fuzzy, c-format
-msgid ""
-"Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> "
-"is not current mapset"
-msgstr ""
-"ã°ã«ã¼ã [%s in %s] ã® ãµãã°ã«ã¼ã [%s] ã®ãã¡ã¤ã« [%s] ã使ã§ãã¾ãã"
+#, c-format
+msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> is not current mapset"
+msgstr "ç½²åãã¡ã¤ã« <%s> ã使ã§ãã¾ããã ãµãã°ã«ã¼ãï¼ <%s> ãã°ã«ã¼ãï¼ <%s> - <%s> ã¯ç¾å¨ã®ãããã»ããã«ããã¾ãã"
#: ../lib/imagery/sigsetfile.c:57
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s>"
-msgstr ""
+msgstr "ç½²åãã¡ã¤ã« <%s> ã使ã§ãã¾ããã ãµãã°ã«ã¼ãï¼ <%s> ãã°ã«ã¼ãï¼ <%s>"
#: ../lib/imagery/sigsetfile.c:86
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open signature file <%s> for subgroup <%s> of group <%s@%s>"
-msgstr "ã°ã«ã¼ã [%s in %s] ã® ãµãã°ã«ã¼ã [%s] ã®ãã¡ã¤ã« [%s] ãéãã¾ãã"
+msgstr "ç½²åãã¡ã¤ã« <%s> ãéãã¾ããã ãµãã°ã«ã¼ãï¼ <%s> ãã°ã«ã¼ãï¼<%s@%s>"
#: ../lib/imagery/fopen.c:23
#, c-format
@@ -848,8 +819,7 @@
#: ../lib/imagery/fopen.c:79
#, c-format
msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
+msgstr "ã°ã«ã¼ã [%s in %s] ã® ãµãã°ã«ã¼ã [%s] ã®ãã¡ã¤ã« [%s] ã使ã§ãã¾ãã"
#: ../lib/imagery/fopen.c:101 ../lib/imagery/fopen.c:127
#, c-format
@@ -859,8 +829,7 @@
#: ../lib/imagery/fopen.c:116
#, c-format
msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-"ã°ã«ã¼ã [%s in %s] ã®ãµãã°ã«ã¼ã [%s] ã®ãã¡ã¤ã« [%s] ãè¦ã¤ããã¾ãã "
+msgstr "ã°ã«ã¼ã [%s in %s] ã®ãµãã°ã«ã¼ã [%s] ã®ãã¡ã¤ã« [%s] ãè¦ã¤ããã¾ãã "
#: ../lib/imagery/list_subgp.c:36
#, c-format
@@ -946,8 +915,7 @@
#: ../lib/gmath/la.c:531
msgid "Matrix (or submatrix is singular). Solution undetermined"
-msgstr ""
-"ãããªãã¯ã¹ (,ã¾ãã¯ãµããããªãã¯ã¹ã¯åæ°ã§ã). 解決çã¯ç¢ºå®ãã¦ãã¾ãã"
+msgstr "ãããªãã¯ã¹ (,ã¾ãã¯ãµããããªãã¯ã¹ã¯åæ°ã§ã). 解決çã¯ç¢ºå®ãã¦ãã¾ãã"
#: ../lib/gmath/la.c:535
msgid "Problem in LA routine."
@@ -1087,8 +1055,7 @@
#: ../lib/driver/parse_ftcap.c:32
#, c-format
msgid "%s: Unable to read font definition file; use the default"
-msgstr ""
-"%s:ãã©ã³ãã®å®ç¾©ãã¡ã¤ã«ãèªã¿åãã¾ãã; ããã©ã«ãå¤ã使ç¨ãã¦ãã ãã"
+msgstr "%s:ãã©ã³ãã®å®ç¾©ãã¡ã¤ã«ãèªã¿åãã¾ãã; ããã©ã«ãå¤ã使ç¨ãã¦ãã ãã"
#: ../lib/driver/parse_ftcap.c:38
#, c-format
@@ -1152,8 +1119,7 @@
msgstr "䏿¬¡æ¹ç¨å¼ã·ã¹ãã ã解決ã§ãã¾ãã"
#: ../lib/gpde/N_parse_options.c:59
-msgid ""
-"The type of solver which should solve the symmetric linear equation system"
+msgid "The type of solver which should solve the symmetric linear equation system"
msgstr "対称ç·å½¢æ¹ç¨å¼ç³»ã解決ãã¹ãã½ã«ãã¼ã®ã¿ã¤ã"
#: ../lib/gpde/N_parse_options.c:71
@@ -1165,16 +1131,12 @@
msgstr "䏿¬¡æ¹ç¨å¼ã·ã¹ãã ã«ä½¿ç¨ãããã½ã«ãã¼ã¤ãã¬ã¼ã·ã§ã³ã®æå¤§é度æ°"
#: ../lib/gpde/N_parse_options.c:89
-msgid ""
-"Error break criteria for iterative solvers (jacobi, sor, cg or bicgstab)"
+msgid "Error break criteria for iterative solvers (jacobi, sor, cg or bicgstab)"
msgstr "åå¾©è§£æ³ (ã¤ã³ãæ³, SORæ³, CGæ³ ã¾ã㯠BiCGStabæ³)ã®ã¨ã©ã¼ãã¬ã¼ã¯æ¡ä»¶"
#: ../lib/gpde/N_parse_options.c:98
-msgid ""
-"The relaxation parameter used by the jacobi and sor solver for speedup or "
-"stabilizing"
-msgstr ""
-"é«éåã¾ãã¯å®å®åã®ããã¤ã³ãæ³ã¨SORæ³ã«ãã£ã¦ä½¿ç¨ãããç·©åãã©ã¡ã¼ã¿ã¼"
+msgid "The relaxation parameter used by the jacobi and sor solver for speedup or stabilizing"
+msgstr "é«éåã¾ãã¯å®å®åã®ããã¤ã³ãæ³ã¨SORæ³ã«ãã£ã¦ä½¿ç¨ãããç·©åãã©ã¡ã¼ã¿ã¼"
#: ../lib/gpde/N_parse_options.c:106
msgid "The calculation time in seconds"
@@ -1622,12 +1584,8 @@
#: ../lib/arraystats/class.c:221
#, c-format
-msgid ""
-"There are classbreaks outside the range min-max. Number of classes reduced "
-"to %i, but using probabilities for %i classes."
-msgstr ""
-"min-maxç¯å²å¤ã«åé¡åºåãããã¾ã. ã¯ã©ã¹ã®æ°ã¯ %i ã«æ¸ãããã¦ãã¾ã åé¡ç"
-"ã«ã¯ã¨ãã¦%i ãé©ãã¦ãã¾ã"
+msgid "There are classbreaks outside the range min-max. Number of classes reduced to %i, but using probabilities for %i classes."
+msgstr "min-maxç¯å²å¤ã«åé¡åºåãããã¾ã. ã¯ã©ã¹ã®æ°ã¯ %i ã«æ¸ãããã¦ãã¾ã åé¡çã«ã¯ã¨ãã¦%i ãé©ãã¦ãã¾ã"
#: ../lib/vector/neta/utils.c:219 ../lib/vector/neta/utils.c:232
#, c-format
@@ -1636,8 +1594,7 @@
#: ../lib/vector/neta/utils.c:221
msgid "'where' and 'cats' parameters were supplied, cat will be ignored"
-msgstr ""
-"'where' 㨠'cats' ã®ãã©ã¡ã¼ã¿ã¼ãå®ç¾©ããã¾ããã®ã§, cat ã¯ç¡è¦ããã¾ãã"
+msgstr "'where' 㨠'cats' ã®ãã©ã¡ã¼ã¿ã¼ãå®ç¾©ããã¾ããã®ã§, cat ã¯ç¡è¦ããã¾ãã"
#: ../lib/vector/neta/utils.c:225
msgid "Unable to load data from database"
@@ -1668,12 +1625,8 @@
#: ../lib/vector/diglib/plus_node.c:217
#, c-format
-msgid ""
-"Attempt to read line angle for the line which is not connected to the node: "
-"node %d, line %d"
-msgstr ""
-"ãã¼ãã«æ¥ç¶ããã¦ããªãã©ã¤ã³ã®ç·è§ãèªã¿åããã¨ãã¦ãã¾ã: ãã¼ã %d, ã©ã¤"
-"ã³ %d"
+msgid "Attempt to read line angle for the line which is not connected to the node: node %d, line %d"
+msgstr "ãã¼ãã«æ¥ç¶ããã¦ããªãã©ã¤ã³ã®ç·è§ãèªã¿åããã¨ãã¦ãã¾ã: ãã¼ã %d, ã©ã¤ã³ %d"
#: ../lib/vector/diglib/file.c:157
msgid "Writing to file loaded to memory not supported"
@@ -1685,8 +1638,7 @@
#: ../lib/vector/diglib/file.c:215
msgid "Vector memory mode not supported, using 'AUTO'"
-msgstr ""
-"ãã¯ãã«ã¡ã¢ãªã¼ã¢ã¼ãã¯ãµãã¼ãããã¦ãã¾ããã, 'AUTO'ã使ç¨ãã¦ãã ãã"
+msgstr "ãã¯ãã«ã¡ã¢ãªã¼ã¢ã¼ãã¯ãµãã¼ãããã¦ãã¾ããã, 'AUTO'ã使ç¨ãã¦ãã ãã"
#: ../lib/vector/diglib/plus.c:288
msgid "Unable read topology for nodes"
@@ -1795,9 +1747,7 @@
#: ../lib/vector/diglib/plus_area.c:394
#, c-format
msgid "Dead centroid %d registered for area (bug in the vector library)"
-msgstr ""
-"ã¨ãªã¢ã«ä¸å¿
è¦ãªã»ã³ããã¤ãã %d åè¨é²ããã¾ãã (ãã¯ãã«ã©ã¤ãã©ãªå
ã®ã"
-"ã°)"
+msgstr "ã¨ãªã¢ã«ä¸å¿
ã®ãã°)"
#: ../lib/vector/diglib/plus_area.c:418
#, c-format
@@ -1825,8 +1775,7 @@
#: ../lib/vector/Vlib/legal_vname.c:48
#, c-format
msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
-msgstr ""
-"ç¡å¹ãªãã¯ãã«ãããåã§ã<%s>. '.' ããã㯠'NULL'.ãå«ã¾ãã¦ãã¾ããã"
+msgstr "ç¡å¹ãªãã¯ãã«ãããåã§ã<%s>. '.' ããã㯠'NULL'.ãå«ã¾ãã¦ãã¾ããã"
#: ../lib/vector/Vlib/legal_vname.c:55
#, c-format
@@ -1840,11 +1789,8 @@
#: ../lib/vector/Vlib/legal_vname.c:70
#, c-format
-msgid ""
-"Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
-msgstr ""
-"ç¡å¹ãªãã¯ãã«ãããåã§ã <%s>. SQLãã¼ã¯ã¼ãã¯ãã¯ãã«ãããåã¨ãã¦ä½¿ãã¾"
-"ãã"
+msgid "Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
+msgstr "ç¡å¹ãªãã¯ãã«ãããåã§ã <%s>. SQLãã¼ã¯ã¼ãã¯ãã¯ãã«ãããåã¨ãã¦ä½¿ãã¾ãã"
#: ../lib/vector/Vlib/legal_vname.c:101 ../lib/vector/Vlib/legal_vname.c:105
#, c-format
@@ -1984,13 +1930,11 @@
#: ../lib/vector/Vlib/overlay.c:123
msgid "Overlay: line/boundary types not supported by AND operator"
-msgstr ""
-"ãªã¼ãã¼ã¬ã¤: ã©ã¤ã³/å¢çã¿ã¤ãã¯ANDæ¼ç®åã«ãã£ã¦ãµãã¼ãããã¦ãã¾ãã"
+msgstr "ãªã¼ãã¼ã¬ã¤: ã©ã¤ã³/å¢çã¿ã¤ãã¯ANDæ¼ç®åã«ãã£ã¦ãµãã¼ãããã¦ãã¾ãã"
#: ../lib/vector/Vlib/overlay.c:126
msgid "Overlay: area x area types not supported by AND operator"
-msgstr ""
-"ãªã¼ãã¼ã¬ã¤: é å x é åã¿ã¤ãã¯ANDæ¼ç®åã«ãã£ã¦ãµãã¼ãããã¦ãã¾ãã"
+msgstr "ãªã¼ãã¼ã¬ã¤: é å x é åã¿ã¤ãã¯ANDæ¼ç®åã«ãã£ã¦ãµãã¼ãããã¦ãã¾ãã"
#: ../lib/vector/Vlib/level.c:38
msgid "Map structure was never initialized"
@@ -2134,12 +2078,8 @@
#: ../lib/vector/Vlib/geos.c:56
#, c-format
-msgid ""
-"Vect_read_line_geos(): feature id %d is not reasonable (max features in "
-"vector map <%s>: %d)"
-msgstr ""
-"Vect_read_line(): ãã£ã¼ãã£ã¼ID %d ã¯é©åã§ã¯ããã¾ãã (ãã¯ãã«ããã <"
-"%s> ã«ãããæå¤§ã®ãã£ã¼ãã£: %d)"
+msgid "Vect_read_line_geos(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
+msgstr "Vect_read_line(): ãã£ã¼ãã£ã¼ID %d ã¯é©åã§ã¯ããã¾ãã (ãã¯ãã«ããã <%s> ã«ãããæå¤§ã®ãã£ã¼ãã£: %d)"
#: ../lib/vector/Vlib/geos.c:61
msgid "only native format supported"
@@ -2172,12 +2112,8 @@
#: ../lib/vector/Vlib/read.c:102
#, c-format
-msgid ""
-"Vect_read_line(): feature id %d is not reasonable (max features in vector "
-"map <%s>: %d)"
-msgstr ""
-"Vect_read_line(): ãã£ã¼ãã£ã¼ id %d ã¯é©åã§ã¯ããã¾ãã (ãã¯ãã«ããã <"
+msgid "Vect_read_line(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
+msgstr "Vect_read_line(): ãã£ã¼ãã£ã¼ id %d ã¯é©åã§ã¯ããã¾ãã (ãã¯ãã«ããã <%s> ã«ãããæå¤§ã®ãã£ã¼ãã£: %d)"
#: ../lib/vector/Vlib/sindex.c:97
msgid "not implemented"
@@ -2189,12 +2125,8 @@
msgstr "ã¢ã¤ãã %d ã空éã¤ã³ããã¯ã¹ããåé¤ã§ãã¾ãã"
#: ../lib/vector/Vlib/sindex.c:127
-msgid ""
-"Unable to build spatial index from topology, vector map is not opened at "
-"topo level 2"
-msgstr ""
-"ãããã¸ã¼ãã空éã¤ã³ããã¯ã¹ã使ã§ãã¾ãã, ãã¯ãã«ãããããããã¸ã¼ã¬"
-"ãã« 2ã§éããã¦ãã¾ãã"
+msgid "Unable to build spatial index from topology, vector map is not opened at topo level 2"
+msgstr "ãããã¸ã¼ãã空éã¤ã³ããã¯ã¹ã使ã§ãã¾ãã, ãã¯ãã«ãããããããã¸ã¼ã¬ãã« 2ã§éããã¦ãã¾ãã"
#: ../lib/vector/Vlib/sindex.c:168
msgid "BUG (Vect_build_sidx_from_topo): node does not exist"
@@ -2228,11 +2160,8 @@
msgstr "OGR ã®å·®å使ã¯ãµãã¼ãããã¦ãã¾ãã"
#: ../lib/vector/Vlib/build_ogr.c:342
-msgid ""
-"Random read is not supported by OGR for this layer, cannot build support"
-msgstr ""
-"ãã®ã¬ã¤ã¤ã¼ã®ã©ã³ãã ãªèªã¿è¾¼ã¿ã¯OGRã«ãµãã¼ãããã¦ãã¾ãã, ãµãã¼ã使ä¸"
-"å¯"
+msgid "Random read is not supported by OGR for this layer, cannot build support"
+msgstr "ãã®ã¬ã¤ã¤ã¼ã®ã©ã³ãã ãªèªã¿è¾¼ã¿ã¯OGRã«ãµãã¼ãããã¦ãã¾ãã, ãµãã¼ã使ä¸å¯"
#: ../lib/vector/Vlib/build_ogr.c:349
msgid "Feature: "
@@ -2273,9 +2202,7 @@
#: ../lib/vector/Vlib/net.c:366
#, c-format
msgid "Data type of column <%s> not supported (must be numeric)"
-msgstr ""
-"ãã¼ã¿å of å <%s> ã®ãã¼ã¿ã¿ã¤ãã¯ãµãã¼ãããã¦ãã¾ãã (æ°åã§ãªããã°ãª"
-"ããªã)"
+msgstr "ãã¼ã¿å of å <%s> ã®ãã¼ã¿ã¿ã¤ãã¯ãµãã¼ãããã¦ãã¾ãã (æ°åã§ãªããã°ãªããªã)"
#: ../lib/vector/Vlib/net.c:226
msgid "Registering arcs..."
@@ -2283,21 +2210,13 @@
#: ../lib/vector/Vlib/net.c:254
#, c-format
-msgid ""
-"Database record for line %d (cat = %d, forward/both direction(s)) not found "
-"(forward/both direction(s) of line skipped)"
-msgstr ""
-"ã©ã¤ã³ %d (ã«ã¿ãã° = %d, å/å¾ã®ä¸¡æ¹å) ã®ãã¼ã¿ãã¼ã¹ ã¬ã³ã¼ãã¯è¦ã¤ããã¾"
-"ããã§ãã (ã¹ããããããå/å¾ã®ä¸¡æ¹åã¨ã)"
+msgid "Database record for line %d (cat = %d, forward/both direction(s)) not found (forward/both direction(s) of line skipped)"
+msgstr "ã©ã¤ã³ %d (ã«ã¿ãã° = %d, å/å¾ã®ä¸¡æ¹å) ã®ãã¼ã¿ãã¼ã¹ ã¬ã³ã¼ãã¯è¦ã¤ããã¾ããã§ãã (ã¹ããããããå/å¾ã®ä¸¡æ¹åã¨ã)"
#: ../lib/vector/Vlib/net.c:273
#, c-format
-msgid ""
-"Database record for line %d (cat = %d, backword direction) not found"
-"(direction of line skipped)"
-msgstr ""
-"ã©ã¤ã³ %d (cat = %d, backword direction) ã®ãã¼ã¿ãã¼ã¹ã¬ã³ã¼ãã¯è¦ã¤ããã¾ã"
-"ãã§ãã(ã©ã¤ã³ã®æ¹åã¯ã¹ãããããã¾ãã)"
+msgid "Database record for line %d (cat = %d, backword direction) not found(direction of line skipped)"
+msgstr "ã©ã¤ã³ %d (cat = %d, backword direction) ã®ãã¼ã¿ãã¼ã¹ã¬ã³ã¼ãã¯è¦ã¤ããã¾ããã§ãã(ã©ã¤ã³ã®æ¹åã¯ã¹ãããããã¾ãã)"
#: ../lib/vector/Vlib/net.c:322
msgid "Cannot add network arc"
@@ -2310,9 +2229,7 @@
#: ../lib/vector/Vlib/net.c:402
#, c-format
msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
-msgstr ""
-"ãã¼ã %d (cat = %d) ã®ãã¼ã¿ãã¼ã¹ã¬ã³ã¼ãã¯è¦ã¤ããã¾ããã§ãã (ã³ã¹ãã¯0"
-"ã«ã»ããããã¦ãã¾ã)"
+msgstr "ãã¼ã %d (cat = %d) ã®ãã¼ã¿ãã¼ã¹ã¬ã³ã¼ãã¯è¦ã¤ããã¾ããã§ãã (ã³ã¹ãã¯0ã«ã»ããããã¦ãã¾ã)"
#: ../lib/vector/Vlib/net.c:429
msgid "Flattening the graph..."
@@ -2333,13 +2250,11 @@
#: ../lib/vector/Vlib/build_nat.c:93
msgid "Unable to add area (map closed, topo saved)"
-msgstr ""
-"é åã追å ã§ãã¾ãã (ãããã¯éãããã¦ãã¾ã, topoã¯ä¿åããã¦ãã¾ã)"
+msgstr "é åã追å ã§ãã¾ãã (ãããã¯éãããã¦ãã¾ã, topoã¯ä¿åããã¦ãã¾ã)"
#: ../lib/vector/Vlib/build_nat.c:102
msgid "Unable to add isle (map closed, topo saved)"
-msgstr ""
-"ã¢ã¤ã«ã追å ã§ãã¾ãã (ãããã¯éãããã¦ãã¾ã, topoã¯ä¿åããã¦ãã¾ã)"
+msgstr "ã¢ã¤ã«ã追å ã§ãã¾ãã (ãããã¯éãããã¦ãã¾ã, topoã¯ä¿åããã¦ãã¾ã)"
#: ../lib/vector/Vlib/build_nat.c:112
msgid "Area of size = 0.0 ignored"
@@ -2417,36 +2332,23 @@
#: ../lib/vector/Vlib/open_ogr.c:147
#, c-format
-msgid ""
-"Feature index format version %d.%d is not supported by this release. Try to "
-"rebuild topology or upgrade GRASS."
-msgstr ""
-"ãã£ã¼ãã£ã¼ç´¢å¼ãã©ã¼ããããã¼ã¸ã§ã³ %d.ã%d ã¯ãã®ãªãªã¼ã¹ã§ãµãã¼ãããã¦"
-"ãã¾ãã. ãããã¸ã¼ãå使ãããGRASSãã¢ãããã¼ããã¦ãã ãã."
+msgid "Feature index format version %d.%d is not supported by this release. Try to rebuild topology or upgrade GRASS."
+msgstr "ãã£ã¼ãã£ã¼ç´¢å¼ãã©ã¼ããããã¼ã¸ã§ã³ %d.ã%d ã¯ãã®ãªãªã¼ã¹ã§ãµãã¼ãããã¦ãã¾ãã. ãããã¸ã¼ãå使ãããGRASSãã¢ãããã¼ããã¦ãã ãã."
#: ../lib/vector/Vlib/open_ogr.c:152
#, c-format
-msgid ""
-"Your GRASS version does not fully support feature index format %d.%d of the "
-"vector. Consider to rebuild topology or upgrade GRASS."
-msgstr ""
-"使ç¨ãã¦ããGRASS ãã¼ã¸ã§ã³ã¯ãã¯ãã«ã®ç´¢å¼ãã©ã¼ããã %d.%d ãååã«ãµãã¼"
-"ããã¦ãã¾ãã. ãããã¸ã¼ãå使ãããGRASSãã¢ãããã¼ããã¦ãã ãã."
+msgid "Your GRASS version does not fully support feature index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
+msgstr "使ç¨ãã¦ããGRASS ãã¼ã¸ã§ã³ã¯ãã¯ãã«ã®ç´¢å¼ãã©ã¼ããã %d.%d ãååã«ãµãã¼ããã¦ãã¾ãã. ãããã¸ã¼ãå使ãããGRASSãã¢ãããã¼ããã¦ãã ãã."
#: ../lib/vector/Vlib/open_nat.c:145
#, c-format
-msgid ""
-"Coor files of vector map <%s@%s> is larger than it should be (%ld bytes "
-"excess)"
+msgid "Coor files of vector map <%s@%s> is larger than it should be (%ld bytes excess)"
msgstr "ãã¯ãã«ããã <%s@%s> ã®åº§æ¨ãã¡ã¤ã«ã大ãããã¾ã(%ld ãã¤ãè¶
é)"
#: ../lib/vector/Vlib/open_nat.c:149
#, c-format
-msgid ""
-"Coor files of vector <%s@%s> is shorter than it should be (%ld bytes "
-"missing)."
-msgstr ""
-"ãã¯ãã« <%s@%s> ã®åº§æ¨ãã¡ã¤ã«ãå°ãããã¾ã (%ld ãã¤ããä¸è¶³ãã¦ãã¾ã)."
+msgid "Coor files of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
+msgstr "ãã¯ãã« <%s@%s> ã®åº§æ¨ãã¡ã¤ã«ãå°ãããã¾ã (%ld ãã¤ããä¸è¶³ãã¦ãã¾ã)."
#: ../lib/vector/Vlib/open.c:100
#, c-format
@@ -2454,19 +2356,14 @@
msgstr "ããã°ã©ãã¼ã¯ä¸æãªãªã¼ãã³ã¬ãã« %d ãè¦æ±ãã¾ãã"
#: ../lib/vector/Vlib/open.c:179
-msgid ""
-"Vector map which is not in the current mapset cannot be opened for update"
+msgid "Vector map which is not in the current mapset cannot be opened for update"
msgstr "ç¾å¨ã®ãããã»ããã«ãªããã¯ãã«ãããã¯æ´æ°ã§ãã¾ãã"
#: ../lib/vector/Vlib/open.c:211 ../lib/vector/Vlib/open.c:279
#: ../lib/vector/Vlib/open.c:299
#, c-format
-msgid ""
-"Unable to open vector map <%s> on level %d. Try to rebuild vector topology "
-"by v.build."
-msgstr ""
-"ãã¯ãã«ããã <%s> ãã¬ãã« %d ã§éãã¾ãã. v.build.ã§ãã¯ãã«ãããã¸ã¼ã"
-"å使ãã¦ãã ãã"
+msgid "Unable to open vector map <%s> on level %d. Try to rebuild vector topology by v.build."
+msgstr "ãã¯ãã«ããã <%s> ãã¬ãã« %d ã§éãã¾ãã. v.build.ã§ãã¯ãã«ãããã¸ã¼ãå使ãã¦ãã ãã"
#: ../lib/vector/Vlib/open.c:214
msgid "Unable to read head file"
@@ -2574,9 +2471,7 @@
#: ../lib/vector/Vlib/buffer2.c:598 ../lib/vector/Vlib/buffer2.c:609
msgid "Next edge was visited but it is not the first one !!! breaking loop"
-msgstr ""
-"Next ã¨ã㸠was visited but it is not the first one !!! ã«ã¼ããåæãã¦ãã¾"
-"ã"
+msgstr "Next ã¨ã㸠was visited but it is not the first one !!! ã«ã¼ããåæãã¦ãã¾ã"
#: ../lib/vector/Vlib/buffer2.c:657
msgid "side != 0 feature not implemented"
@@ -2637,19 +2532,13 @@
#: ../lib/vector/Vlib/write.c:219
#, c-format
-msgid ""
-"Unable to delete feature %d, vector map <%s> is not opened on topology level"
-msgstr ""
-"ãã£ã¼ãã£ã¼ %d ãåé¤ã§ãã¾ãã, ãã¯ãã«ããã <%s> ãä½ç¸å¹¾ä½ã¬ãã«ã§éã"
-"ãã¦ãã¾ãã"
+msgid "Unable to delete feature %d, vector map <%s> is not opened on topology level"
+msgstr "ãã£ã¼ãã£ã¼ %d ãåé¤ã§ãã¾ãã, ãã¯ãã«ããã <%s> ãä½ç¸å¹¾ä½ã¬ãã«ã§éããã¦ãã¾ãã"
#: ../lib/vector/Vlib/write.c:225
#, c-format
-msgid ""
-"Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
-msgstr ""
-"ãã£ã¼ãã£ã¼ %d ãåé¤ã§ãã¾ãã, ãã¯ãã«ããã <%s> ã¯'æ¸ãè¾¼ã¿'ã¢ã¼ãã§é"
-"ããã¦ãã¾ãã"
+msgid "Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
+msgstr "ãã£ã¼ãã£ã¼ %d ãåé¤ã§ãã¾ãã, ãã¯ãã«ããã <%s> ã¯'æ¸ãè¾¼ã¿'ã¢ã¼ãã§éããã¦ãã¾ãã"
#: ../lib/vector/Vlib/write.c:239
#, c-format
@@ -2658,19 +2547,13 @@
#: ../lib/vector/Vlib/write.c:265
#, c-format
-msgid ""
-"Unable to restore feature %d, vector map <%s> is not opened on topology level"
-msgstr ""
-"ãã£ã¼ãã£ã¼ %d ã修復ã§ãã¾ãã, ãã¯ãã«ããã <%s> ãä½ç¸å¹¾ä½å¦ã¬ãã«ã§é"
-"ããã¦ãã¾ãã"
+msgid "Unable to restore feature %d, vector map <%s> is not opened on topology level"
+msgstr "ãã£ã¼ãã£ã¼ %d ã修復ã§ãã¾ãã, ãã¯ãã«ããã <%s> ãä½ç¸å¹¾ä½å¦ã¬ãã«ã§éããã¦ãã¾ãã"
#: ../lib/vector/Vlib/write.c:271
#, c-format
-msgid ""
-"Unable to restore feature %d, vector map <%s> is not opened in 'write' mode"
-msgstr ""
-"ãã£ã¼ãã£ã¼ %d ã修復ã§ãã¾ãã, ãã¯ãã«ããã <%s> ã'æ¸ãè¾¼ã¿' ã¢ã¼ãã§é"
-"ããã¦ãã¾ãã"
+msgid "Unable to restore feature %d, vector map <%s> is not opened in 'write' mode"
+msgstr "ãã£ã¼ãã£ã¼ %d ã修復ã§ãã¾ãã, ãã¯ãã«ããã <%s> ã'æ¸ãè¾¼ã¿' ã¢ã¼ãã§éããã¦ãã¾ãã"
#: ../lib/vector/Vlib/write.c:285
#, c-format
@@ -2693,9 +2576,7 @@
#: ../lib/vector/Vlib/cindex.c:107
msgid "Invalid layer index (index < 0 or index >= number of layers)"
-msgstr ""
-"䏿£ãªã¬ã¤ã¤ã¼ã¤ã³ããã¯ã¹ (ã¤ã³ããã¯ã¹ < 0 ã¾ã㯠ã¤ã³ããã¯ã¹ >= ã¬ã¤ã¤ã¼"
-"ã®æ°)"
+msgstr "䏿£ãªã¬ã¤ã¤ã¼ã¤ã³ããã¯ã¹ (ã¤ã³ããã¯ã¹ < 0 ã¾ã㯠ã¤ã³ããã¯ã¹ >= ã¬ã¤ã¤ã¼ã®æ°)"
#: ../lib/vector/Vlib/cindex.c:232
msgid "Layer or category index out of range"
@@ -2726,8 +2607,7 @@
#: ../lib/vector/Vlib/field.c:98
msgid "Unable to add database link, map is not opened in WRITE mode"
-msgstr ""
-"ãã¼ã¿ãã¼ã¹ãªã³ã¯ã追å ã§ãã¾ãã, ããããWRITE ã¢ã¼ãã§éããã¦ãã¾ãã"
+msgstr "ãã¼ã¿ãã¼ã¹ãªã³ã¯ã追å ã§ãã¾ãã, ããããWRITE ã¢ã¼ãã§éããã¦ãã¾ãã"
#: ../lib/vector/Vlib/field.c:104
msgid "Unable to add database link"
@@ -2771,12 +2651,8 @@
msgstr "OGR DBMI ãã©ã¤ãã¼ãéãã¾ãã"
#: ../lib/vector/Vlib/field.c:551
-msgid ""
-"All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' "
-"available in OGR DB table"
-msgstr ""
-"å
¨ã¦ã®FIDãã¹ãã¯å¤±æãã¾ãã. OGR DBãã¼ãã«ã«ã¯ 'FID' ã 'ogc_fid' ã "
-"'ogr_fid' ã 'gid' ããã¾ãã "
+msgid "All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' available in OGR DB table"
+msgstr "å
¨ã¦ã®FIDãã¹ãã¯å¤±æãã¾ãã. OGR DBãã¼ãã«ã«ã¯ 'FID' ã 'ogc_fid' ã 'ogr_fid' ã 'gid' ããã¾ãã "
#: ../lib/vector/Vlib/field.c:606
#, c-format
@@ -2839,21 +2715,13 @@
msgstr "䏿ãªåãåãããã¼ã«"
#: ../lib/rst/interp_float/segmen2d.c:111
-msgid ""
-"Taking too long to find points for interpolation - please change the region "
-"to area where your points are. Continuing calculations..."
-msgstr ""
-"è£éã®ãã¤ã³ããè¦ã¤ããã®ã«æéããããããã¦ãã¾ã--é åããã¤ã³ãã®ããã¨"
-"ãªã¢ã«å¤æ´ãã¦ãã ãã. å¼ãç¶ãè¨ç®ãã¾ã..."
+msgid "Taking too long to find points for interpolation - please change the region to area where your points are. Continuing calculations..."
+msgstr "è£éã®ãã¤ã³ããè¦ã¤ããã®ã«æéããããããã¦ãã¾ã--é åããã¤ã³ãã®ããã¨ãªã¢ã«å¤æ´ãã¦ãã ãã. å¼ãç¶ãè¨ç®ãã¾ã..."
#: ../lib/rst/interp_float/interp2d.c:212
#, c-format
-msgid ""
-"Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) "
-"cell. Z-value %f, zmin %f, zmax %f."
-msgstr ""
-"ãªã¼ãã¼ã·ã¥ã¼ã - å¼µåãå¢å ãã¦ãã¾ã.ãªã¼ãã¼ã·ã¥ã¼ãã¯æ¬¡ã®ã¨ããã§èµ·ãã£"
-"ã¦ãã¾ã (%d,%d) ã»ã«. Z-å¤ %f, zæå°å¤ %f, zæå¤§å¤ %f."
+msgid "Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) cell. Z-value %f, zmin %f, zmax %f."
+msgstr "ãªã¼ãã¼ã·ã¥ã¼ã - å¼µåãå¢å ãã¦ãã¾ã.ãªã¼ãã¼ã·ã¥ã¼ãã¯æ¬¡ã®ã¨ããã§èµ·ãã£ã¦ãã¾ã (%d,%d) ã»ã«. Z-å¤ %f, zæå°å¤ %f, zæå¤§å¤ %f."
#: ../lib/rst/interp_float/input2d.c:47
#, c-format
@@ -2916,8 +2784,7 @@
#: ../lib/rst/interp_float/vinput2d.c:328
#, c-format
msgid "There are points outside specified 2D/3D region - %d points ignored"
-msgstr ""
-"æå®ããã2D/3D é åå¤ã«ãã¤ã³ããããã¾ã-- %d ã®ãã¤ã³ãç¡è¦ããã¾ãã"
+msgstr "æå®ããã2D/3D é åå¤ã«ãã¤ã³ããããã¾ã-- %d ã®ãã¤ã³ãç¡è¦ããã¾ãã"
#: ../lib/rst/interp_float/vinput2d.c:331
#, c-format
@@ -2926,11 +2793,8 @@
#: ../lib/rst/interp_float/vinput2d.c:335
#, c-format
-msgid ""
-"%d points given for interpolation (after thinning) is less than given NPMIN="
-"%d"
-msgstr ""
-"è£é ã«ä¸ãããã %d ãã¤ã³ã(è²èåå¾) 㯠ä¸ããããNPMIN=%dãããå°ãªãã§ã"
+msgid "%d points given for interpolation (after thinning) is less than given NPMIN=%d"
+msgstr "è£é ã«ä¸ãããã %d ãã¤ã³ã(è²èåå¾) 㯠ä¸ããããNPMIN=%dãããå°ãªãã§ã"
#: ../lib/rst/interp_float/vinput2d.c:340
msgid "Zero points in the given region"
@@ -2938,22 +2802,13 @@
#: ../lib/rst/interp_float/vinput2d.c:345
#, c-format
-msgid ""
-"Segmentation parameters set to invalid values: npmin= %d, segmax= %d for "
-"smooth connection of segments, npmin > segmax (see manual)"
-msgstr ""
-"ã»ã°ã¡ã³ãåã®ãã©ã¡ã¼ã¿ã«ä¸æ£ãªå¤ãããã¾ã: npmin= %d, segmax= %d ã»ã°ã¡ã³"
-"ãã¯ã¹ã ã¼ãºã«æ¥ç¶ãããªããã°ãªãã¾ãã, npmin > segmax (ããã¥ã¢ã«ãåç
§ã"
-"ã¦ãã ãã)"
+msgid "Segmentation parameters set to invalid values: npmin= %d, segmax= %d for smooth connection of segments, npmin > segmax (see manual)"
+msgstr "ã»ã°ã¡ã³ãåã®ãã©ã¡ã¼ã¿ã«ä¸æ£ãªå¤ãããã¾ã: npmin= %d, segmax= %d ã»ã°ã¡ã³ãã¯ã¹ã ã¼ãºã«æ¥ç¶ãããªããã°ãªãã¾ãã, npmin > segmax (ããã¥ã¢ã«ãåç
§ãã¦ãã ãã)"
#: ../lib/rst/interp_float/vinput2d.c:351
#, c-format
-msgid ""
-"There are less than %d points for interpolation. No segmentation is "
-"necessary, to run the program faster set segmax=%d (see manual)"
-msgstr ""
-"è£éã®ãã¤ã³ã㯠%d 以ä¸ã§ã. ããéãã»ããsegmax=%d (ããã¥ã¢ã«åç
§)ã§ã®ã"
-"ãã°ã©ã å®è¡ã«ã»ã°ã¡ã³ãåã¯å¿
è¦ã§ã¯ããã¾ãã"
+msgid "There are less than %d points for interpolation. No segmentation is necessary, to run the program faster set segmax=%d (see manual)"
+msgstr "è£éã®ãã¤ã³ã㯠%d 以ä¸ã§ã. ããéãã»ããsegmax=%d (ããã¥ã¢ã«åç
§)ã§ã®ããã°ã©ã å®è¡ã«ã»ã°ã¡ã³ãåã¯å¿
è¦ã§ã¯ããã¾ãã"
#: ../lib/rst/interp_float/vinput2d.c:355
#, c-format
@@ -3238,12 +3093,8 @@
msgstr "%s è¨å®ããã¦ãã¾ãã"
#: ../lib/gis/gisinit.c:54 ../lib/gis/gisinit.c:90
-msgid ""
-"Incompatible library version for module. You need to rebuild GRASS or "
-"untangle multiple installations."
-msgstr ""
-"äºææ§ã®ãªãã©ã¤ãã©ãªãã¼ã¸ã§ã³ã§ããGRASSã復å
ããããè¤åã¤ã³ã¹ãã¼ã«ãè§£"
-"決ããå¿
è¦ãããã¾ãã"
+msgid "Incompatible library version for module. You need to rebuild GRASS or untangle multiple installations."
+msgstr "äºææ§ã®ãªãã©ã¤ãã©ãªãã¼ã¸ã§ã³ã§ããGRASSã復å
ããããè¤åã¤ã³ã¹ãã¼ã«ã解決ããå¿
è¦ãããã¾ãã"
#: ../lib/gis/gisinit.c:63
#, c-format
@@ -3257,9 +3108,7 @@
#: ../lib/gis/gisinit.c:110
msgid "System not initialized. Programmer forgot to call G_gisinit()."
-msgstr ""
-"ã·ã¹ãã ãåæåããã¾ããã ããã°ã©ãã¼ã G_gisinit()ãå¼ã³åºãã®ãå¿ãã¦ã"
-"ã¾ãã"
+msgstr "ã·ã¹ãã ãåæåããã¾ããã ããã°ã©ãã¼ã G_gisinit()ãå¼ã³åºãã®ãå¿ãã¦ãã¾ãã"
#: ../lib/gis/color_read.c:116
#, c-format
@@ -3552,12 +3401,8 @@
msgstr "ã¬ã¤ã¤ã¼æ°"
#: ../lib/gis/parser.c:596
-msgid ""
-"A single vector map can be connected to multiple database tables. This "
-"number determines which table to use."
-msgstr ""
-"åç¬ã®ãã¯ãã«ãããã¯è¤æ°ã®ãã¼ã¿ãã¼ã¹ãã¼ãã«ã¨æ¥ç¶ããã¾ãããã®æ°ã¯ä½¿ç¨"
-"ãããã¼ãã«ã«ãã£ã¦æ±ºå®ãã¾ãã"
+msgid "A single vector map can be connected to multiple database tables. This number determines which table to use."
+msgstr "åç¬ã®ãã¯ãã«ãããã¯è¤æ°ã®ãã¼ã¿ãã¼ã¹ãã¼ãã«ã¨æ¥ç¶ããã¾ãããã®æ°ã¯ä½¿ç¨ãããã¼ãã«ã«ãã£ã¦æ±ºå®ãã¾ãã"
#: ../lib/gis/parser.c:605
msgid "Category value"
@@ -3945,11 +3790,8 @@
"ç¡å¹ãªæå½±æ³\n"
#: ../lib/gis/set_window.c:76
-msgid ""
-"G_set_window(): projection/zone differs from that of currently open raster "
-"maps"
-msgstr ""
-"G_set_window(): æå½±æ³/ã¾ã¼ã³ã¯ç¾å¨éãã¦ããã©ã¹ã¿ã¼ãããã¨ç°ãªãã¾ã"
+msgid "G_set_window(): projection/zone differs from that of currently open raster maps"
+msgstr "G_set_window(): æå½±æ³/ã¾ã¼ã³ã¯ç¾å¨éãã¦ããã©ã¹ã¿ã¼ãããã¨ç°ãªãã¾ã"
#: ../lib/gis/home.c:39
msgid "unable to determine user's home directory"
@@ -4176,9 +4018,7 @@
#: ../lib/gis/put_row.c:215
#, c-format
msgid "G_put_map_row: %s is not integer! Use G_put_[f/d]_raster_row()!"
-msgstr ""
-"G_put_map_row: %s ã¯æ´æ°ã§ã¯ããã¾ãã! G_put_[f/d]_raster_row()ã使ç¨ãã¦ã"
-"ã ãã!"
+msgstr "G_put_map_row: %s ã¯æ´æ°ã§ã¯ããã¾ãã! G_put_[f/d]_raster_row()ã使ç¨ãã¦ãã ãã!"
#: ../lib/gis/put_row.c:251
#, c-format
@@ -4188,14 +4028,12 @@
#: ../lib/gis/put_row.c:259
#, c-format
msgid "%s: map [%s] not open for random write - request ignored"
-msgstr ""
-"%s: ããã [%s] ã¯ã©ã³ãã ã®æ¸ãè¾¼ã¿ç¨ã«éããã¨ãã§ãã¾ãã - ç¡è¦ãã¾ãã"
+msgstr "%s: ããã [%s] ã¯ã©ã³ãã ã®æ¸ãè¾¼ã¿ç¨ã«éããã¨ãã§ãã¾ãã - ç¡è¦ãã¾ãã"
#: ../lib/gis/put_row.c:266
#, c-format
msgid "%s: map [%s] not open for sequential write - request ignored"
-msgstr ""
-"%s:ããã [%s] ã¯é æ¬¡ã®æ¸ãè¾¼ã¿ç¨ã«éããã¨ãã§ãã¾ãã - ç¡è¦ãã¾ãã"
+msgstr "%s:ããã [%s] ã¯é æ¬¡ã®æ¸ãè¾¼ã¿ç¨ã«éããã¨ãã§ãã¾ãã - ç¡è¦ãã¾ãã"
#: ../lib/gis/put_row.c:270
#, c-format
@@ -4380,12 +4218,8 @@
#: ../lib/gis/opencell.c:188
#, c-format
-msgid ""
-"Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@"
-"%s> which does not exist"
-msgstr ""
-"ã©ã¹ã¿ã¼ããããéãã¾ãã <%s@%s> åå¨ããªãã©ã¹ã¿ã¼ããã<%s@%s> ã®ååé¡ã"
-"ã"
+msgid "Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@%s> which does not exist"
+msgstr "ã©ã¹ã¿ã¼ããããéãã¾ãã <%s@%s> åå¨ããªãã©ã¹ã¿ã¼ããã<%s@%s> ã®ååé¡ãã"
#: ../lib/gis/opencell.c:212
#, c-format
@@ -4394,18 +4228,13 @@
#: ../lib/gis/opencell.c:219
#, c-format
-msgid ""
-"Raster map <%s@%s> is in different projection than current region. Found "
-"raster map <%s@%s>, should be <%s>."
-msgstr ""
-"ã©ã¹ã¿ã¼ããã <%s@%s> ã¯ç¾å¨ã®ç¯å²ã§ã¯ãªãéãæå½±æ³ã«ããã¾ãã è¦ã¤ãã£ã"
-"ã©ã¹ã¿ã¼ããã<%s@%s>㯠<%s>ã§ãã"
+msgid "Raster map <%s@%s> is in different projection than current region. Found raster map <%s@%s>, should be <%s>."
+msgstr "ã©ã¹ã¿ã¼ããã <%s@%s> ã¯ç¾å¨ã®ç¯å²ã§ã¯ãªãéãæå½±æ³ã«ããã¾ãã è¦ã¤ãã£ãã©ã¹ã¿ã¼ããã<%s@%s>㯠<%s>ã§ãã"
#: ../lib/gis/opencell.c:226
#, c-format
msgid "Raster map <%s@%s> is in different zone (%d) than current region (%d)"
-msgstr ""
-"ã©ã¹ã¿ã¼ããã <%s@%s> ã¯ç¾å¨ã®ç¯å²(%d)ã§ã¯ãªããéãã¾ã¼ã³ã«ããã¾ã (%d) ã"
+msgstr "ã©ã¹ã¿ã¼ããã <%s@%s> ã¯ç¾å¨ã®ç¯å²(%d)ã§ã¯ãªããéãã¾ã¼ã³ã«ããã¾ã (%d) ã"
#: ../lib/gis/opencell.c:233
#, c-format
@@ -4415,9 +4244,7 @@
#: ../lib/gis/opencell.c:262
#, c-format
msgid "map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
-msgstr ""
-"ããã <%s@%s> ã¯GDAL ãªã³ã¯ ã§ããã GRASSã¯GDALã®ãµãã¼ããªãã§ã³ã³ãã¤ã«ã"
-"ãã¾ãã"
+msgstr "ããã <%s@%s> ã¯GDAL ãªã³ã¯ ã§ããã GRASSã¯GDALã®ãµãã¼ããªãã§ã³ã³ãã¤ã«ããã¾ãã"
#: ../lib/gis/opencell.c:642
#, c-format
@@ -4439,10 +4266,8 @@
msgstr "G__open_raster_new():䏿ãã¡ã¤ã«ãå©ç¨ã§ãã¾ãã"
#: ../lib/gis/opencell.c:736
-msgid ""
-"Unable to write embedded null values for raster map open for random access"
-msgstr ""
-"ã©ã³ãã ã¢ã¯ã»ã¹ç¨ã®ã©ã¹ã¿ã¼ãããã«ãåãè¾¼ã¾ããNULLå¤ãæ¸ãè¾¼ãã¾ãã"
+msgid "Unable to write embedded null values for raster map open for random access"
+msgstr "ã©ã³ãã ã¢ã¯ã»ã¹ç¨ã®ã©ã¹ã¿ã¼ãããã«ãåãè¾¼ã¾ããNULLå¤ãæ¸ãè¾¼ãã¾ãã"
#: ../lib/gis/opencell.c:941
msgid "G_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
@@ -4479,8 +4304,7 @@
msgstr "ã©ã¹ã¿ã¼ããã<%s>ã¯xdrã§ã¯ããã¾ãã: ãã¤ãé : %s"
#: ../lib/gis/opencell.c:1179
-msgid ""
-"G_set_quant_rules() can be called only for raster maps opened for reading"
+msgid "G_set_quant_rules() can be called only for raster maps opened for reading"
msgstr "G_set_quant_rules() èªã¿åãç¨ã«éãããã©ã¹ã¿ã¼ãããã®ã¿å¼ã³åºãã¾ã"
#: ../lib/gis/sample.c:71
@@ -4553,8 +4377,7 @@
#: ../lib/gis/alloc.c:76
#, c-format
msgid "G_calloc: unable to allocate %lu * %lu bytes at %s:%d"
-msgstr ""
-"G_calloc: ã¡ã¢ãªã確ä¿ã§ãã¾ãã %lu * %lu ãã¤ããã¤ãå å ´æï¼ %s:%d ï¼"
+msgstr "G_calloc: ã¡ã¢ãªã確ä¿ã§ãã¾ãã %lu * %lu ãã¤ããã¤ãå å ´æï¼ %s:%d ï¼"
#: ../lib/gis/alloc.c:114
#, c-format
@@ -4564,8 +4387,7 @@
#: ../lib/gis/open_misc.c:45
#, c-format
msgid "G__open_misc(read): mapset <%s> doesn't match xmapset <%s>"
-msgstr ""
-"G__open_misc(èªã¿åã): ãããã»ãã <%s>㯠xmapsetã¨ä¸è´ãã¦ãã¾ãã <%s>"
+msgstr "G__open_misc(èªã¿åã): ãããã»ãã <%s>㯠xmapsetã¨ä¸è´ãã¦ãã¾ãã <%s>"
#: ../lib/gis/open_misc.c:67
#, c-format
@@ -4765,11 +4587,8 @@
#: ../lib/gis/view.c:550
#, c-format
-msgid ""
-" Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
-msgstr ""
-" ã¦ã£ã³ãã¦ã® %d%% ã®ã¿ä¿åã§ãã¾ã \"%s\" ç¾å¨ã®GRASSã¦ã£ã³ãã¦ã¨éè¤ãã¦ã"
-"ã¾ã"
+msgid " Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
+msgstr " ã¦ã£ã³ãã¦ã® %d%% ã®ã¿ä¿åã§ãã¾ã \"%s\" ç¾å¨ã®GRASSã¦ã£ã³ãã¦ã¨éè¤ãã¦ãã¾ã"
#: ../lib/gis/ask_cell.c:54 ../lib/gis/ask_cell.c:72 ../lib/gis/ask_cell.c:91
#: ../lib/gis/ask_cell.c:96
@@ -4837,12 +4656,8 @@
#: ../lib/gis/distance.c:160
#, c-format
-msgid ""
-"G_distance_point_to_line_segment: shouldn't happen: code=%d P=(%f,%f) S=(%f,"
-"%f)(%f,%f)"
-msgstr ""
-"G_distance_point_to_line_segment: èµ·ãããã¾ãã: ã³ã¼ã=%d P=(%f,%f) S=(%f,"
-"%f)(%f,%f)"
+msgid "G_distance_point_to_line_segment: shouldn't happen: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
+msgstr "G_distance_point_to_line_segment: èµ·ãããã¾ãã: ã³ã¼ã=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
#: ../lib/gis/debug.c:74
#, c-format
@@ -4936,8 +4751,7 @@
#: ../lib/db/dbmi_base/legal_dbname.c:25
#, c-format
msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'.\n"
-msgstr ""
-"䏿£ãªãã¼ãã«å <%s>.ã'.' ã¾ã㯠'NULL'ãå«ãã§ããªãå¯è½æ§ãããã¾ã.\n"
+msgstr "䏿£ãªãã¼ãã«å <%s>.ã'.' ã¾ã㯠'NULL'ãå«ãã§ããªãå¯è½æ§ãããã¾ã.\n"
#: ../lib/db/dbmi_base/legal_dbname.c:33
#, c-format
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_ja.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_ja.po 2012-03-04 12:43:05 UTC (rev 50991)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_ja.po 2012-03-05 08:10:54 UTC (rev 50992)
@@ -14,7 +14,7 @@
"Project-Id-Version: grassmods_ja\n"
-"PO-Revision-Date: 2012-02-01 16:13+0900\n"
+"PO-Revision-Date: 2012-03-05 11:56+0900\n"
"Language: ja\n"
@@ -95,11 +95,8 @@
#: ../raster/r.out.tiff/r.out.tiff.c:144 ../raster/r.out.mat/main.c:90
#: ../raster/r.in.mat/main.c:125 ../display/d.vect/main.c:411
#: ../display/d.mon/pgms/release.c:36
-msgid ""
-"The '-v' flag is superseded and will be removed in future. Please use '--"
-"verbose' instead."
-msgstr ""
-"ãªãã·ã§ã³ '-v'ã¯ããããã使ããªããªãã¾ã '--verbose' ã使ç¨ãã¦ãã ãã "
+msgid "The '-v' flag is superseded and will be removed in future. Please use '--verbose' instead."
+msgstr "ãªãã·ã§ã³ '-v'ã¯ããããã使ããªããªãã¾ã '--verbose' ã使ç¨ãã¦ãã ãã "
#: ../visualization/nviz/src/nviz_init.c:287
msgid "Number of elevation files does not match number of colors files"
@@ -714,12 +711,8 @@
msgstr "ã©ã¹ã¿ã¼3Dããã¯ã»ã«ãã¤ã³ãã¼ã"
#: ../raster3d/r3.in.v5d/main.c:193
-msgid ""
-"Imports 3-dimensional Vis5D files (i.e. the V5D file with 1 variable and 1 "
-"time step)."
-msgstr ""
-"3次å
Vis5Dãã¡ã¤ã«ãã¤ã³ãã¼ãï¼ä¾ 1ã¤ã®å¤æ°ã¨1ã¤ã®æéã¹ããããå«ãV5Dãã¡"
-"ã¤ã«ï¼"
+msgid "Imports 3-dimensional Vis5D files (i.e. the V5D file with 1 variable and 1 time step)."
+msgstr "3次å
Vis5Dãã¡ã¤ã«ãã¤ã³ãã¼ãï¼ä¾ 1ã¤ã®å¤æ°ã¨1ã¤ã®æéã¹ããããå«ãV5Dãã¡ã¤ã«ï¼"
#: ../raster3d/r3.in.v5d/main.c:213 ../raster3d/r3.in.ascii/main.c:268
msgid "Unable to open 3D raster map"
@@ -740,8 +733,7 @@
#: ../raster3d/r3.gwflow/main.c:63
msgid "The status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
-msgstr ""
-"åã»ã«ã®ã¹ãã¼ã¿ã¹ = 0 - ã¤ã³ã¢ã¯ãã£ã, 1 - ã¢ã¯ãã£ã, 2 - ãã£ãªã¯ã¬ "
+msgstr "åã»ã«ã®ã¹ãã¼ã¿ã¹ = 0 - ã¤ã³ã¢ã¯ãã£ã, 1 - ã¢ã¯ãã£ã, 2 - ãã£ãªã¯ã¬ "
#: ../raster3d/r3.gwflow/main.c:71
msgid "The x-part of the hydraulic conductivity tensor in [m/s]"
@@ -768,9 +760,7 @@
msgstr "ã©ã¹ã¿ã¼ãããã¸ã®åæå
¥m^3/s"
#: ../raster3d/r3.gwflow/main.c:116
-msgid ""
-"The piezometric head result of the numerical calculation will be written to "
-"this map"
+msgid "The piezometric head result of the numerical calculation will be written to this map"
msgstr "ãã¨ã¾æ°´é ã®æ°å¤è¨ç®çµæããã®ãããã«æ¸ãè¾¼ã¾ãã¾ã"
#: ../raster3d/r3.gwflow/main.c:123
@@ -778,17 +768,14 @@
"Calculate the groundwater distance velocity vector field \n"
"and write the x, y, and z components to maps named name_[xyz].\n"
"Name is basename for the new 3D raster maps."
-msgstr ""
-"å°ä¸æ°´ã®è·é¢ã®é度ãã¯ãã«æ
å ±ãè¨ç®ããxãyãï½æ§æè¦ç´ ã¨ã㦠åå_ [xyz]ã§"
-"åºåããã¾ããååã¯ãæ°ããã©ã¹ã¿ã¼3Dãããã®ãã¼ã¹åã§ã"
+msgstr "å°ä¸æ°´ã®è·é¢ã®é度ãã¯ãã«æ
å ±ãè¨ç®ããxãyãï½æ§æè¦ç´ ã¨ã㦠åå_ [xyz]ã§åºåããã¾ããååã¯ãæ°ããã©ã¹ã¿ã¼3Dãããã®ãã¼ã¹åã§ã"
#: ../raster3d/r3.gwflow/main.c:136 ../raster3d/r3.out.vtk/parameters.c:117
msgid "Use 3D raster mask (if exists) with input maps"
msgstr "å
¥åãããã«3Dã°ãªãããã¹ã¯ã使ã"
#: ../raster3d/r3.gwflow/main.c:141
-msgid ""
-"Use a sparse linear equation system, only available with iterative solvers"
+msgid "Use a sparse linear equation system, only available with iterative solvers"
msgstr "çè¡åé£ç«ä¸æ¬¡æ¹ç¨å¼ã使ç¨, ç¹°ãè¿ãã½ã«ãã¼ã§ã®ã¿å©ç¨å¯è½"
#: ../raster3d/r3.gwflow/main.c:169 ../raster3d/r3.mkdspf/main.c:75
@@ -799,9 +786,7 @@
msgstr "ã©ã¹ã¿ã¼3Dããã¯ã»ã«"
#: ../raster3d/r3.gwflow/main.c:171
-msgid ""
-"Calculates numerically transient, confined groundwater flow in three "
-"dimensions."
+msgid "Calculates numerically transient, confined groundwater flow in three dimensions."
msgstr "3次å
ã®å°ä¸æ°´ã®æµãã«éå®ãã䏿çãªæ°å¤è¨ç®ããã°ã©ã "
#: ../raster3d/r3.gwflow/main.c:189 ../raster/r.gwflow/main.c:240
@@ -833,12 +818,8 @@
msgstr "3Dã©ã¹ã¿ã¼ããã <%s>ããéããã¾ãã"
#: ../raster3d/r3.mkdspf/main.c:77
-msgid ""
-"Creates a display file from an existing grid3 file according to specified "
-"threshold levels."
-msgstr ""
-"æå®ããããããå¤ã¬ãã«ãå©ç¨ãã¦ã 3Dã°ãªãããã¡ã¤ã«ãã表示ç¨ãã¡ã¤ã«ãä½"
-"æ"
+msgid "Creates a display file from an existing grid3 file according to specified threshold levels."
+msgstr "æå®ããããããå¤ã¬ãã«ãå©ç¨ãã¦ã 3Dã°ãªãããã¡ã¤ã«ãã表示ç¨ãã¡ã¤ã«ã使"
#: ../raster3d/r3.mkdspf/main.c:85
msgid "Name of an existing 3d raster map"
@@ -1181,12 +1162,8 @@
msgstr "çµæã©ã¹ã¿ã¼ã¹ã©ã¤ã¹ãããã®ãã¼ã¹å"
#: ../raster3d/r3.to.rast/main.c:95
-msgid ""
-"Use the same resolution as the input 3D raster map for the 2D outputmaps, "
-"independent of the current region settings"
-msgstr ""
-"ç¾å¨ã®é åã®è¨å®ã¨ã¯ç¡é¢ä¿ã«ãåºåãã2Dãããã«å
¥å3Dã°ãªãããããã¨åãè§£"
-"å度ã使ãã¾ãã"
+msgid "Use the same resolution as the input 3D raster map for the 2D outputmaps, independent of the current region settings"
+msgstr "ç¾å¨ã®é åã®è¨å®ã¨ã¯ç¡é¢ä¿ã«ãåºåãã2Dãããã«å
¥å3Dã°ãªãããããã¨åãè§£å度ã使ãã¾ãã"
#: ../raster3d/r3.to.rast/main.c:152 ../raster3d/r3.to.rast/main.c:159
#: ../raster3d/r3.cross.rast/main.c:230 ../raster3d/r3.cross.rast/main.c:237
@@ -1213,12 +1190,8 @@
msgstr "ã¨ã©ã¼:3Dã©ã¹ã¿ã¼ããã <%s> ãéãã¾ãã"
#: ../raster3d/r3.to.rast/main.c:267 ../raster3d/r3.out.vtk/main.c:451
-msgid ""
-"The 2D and 3D region settings are different. Using the 2D window settings to "
-"adjust the 2D part of the 3D region."
-msgstr ""
-"2Dã¨3Dã®é åè¨å®ãç°ãªã£ã¦ãã¾ãã3Dé åã®2Dé¨åã®è¨å®ã«2Dã¦ã£ã³ãã¦ã®è¨å®ã"
-"使ç¨ãã¾ã"
+msgid "The 2D and 3D region settings are different. Using the 2D window settings to adjust the 2D part of the 3D region."
+msgstr "2Dã¨3Dã®é åè¨å®ãç°ãªã£ã¦ãã¾ãã3Dé åã®2Dé¨åã®è¨å®ã«2Dã¦ã£ã³ãã¦ã®è¨å®ã使ç¨ãã¾ã"
#: ../raster3d/r3.to.rast/main.c:299 ../raster/r.gwflow/main.c:350
#: ../raster/r.to.rast3/main.c:236 ../raster/r.li/r.li.daemon/list.c:49
@@ -1292,19 +1265,12 @@
msgstr "æ¨é«ã©ã¹ã¿ã¼ã®è¡ãåå¾ã§ãã¾ãã"
#: ../raster3d/r3.cross.rast/main.c:272
-msgid ""
-"Creates cross section 2D raster map from 3D raster map based on 2D elevation "
-"map."
-msgstr ""
-"2Dæ¨é«ãããã«åºã¥ãã3Dã©ã¹ã¿ã¼ããããããã¯ãã¹ã»ã¯ã·ã§ã³2Dã©ã¹ã¿ã¼ããã"
-"ã使ãã¾ãã"
+msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map."
+msgstr "2Dæ¨é«ãããã«åºã¥ãã3Dã©ã¹ã¿ã¼ããããããã¯ãã¹ã»ã¯ã·ã§ã³2Dã©ã¹ã¿ã¼ãããã使ãã¾ãã"
#: ../raster3d/r3.cross.rast/main.c:298
-msgid ""
-"The 2D and 3D region settings are different. Using the 3D raster map "
-"settings to adjust the 2D region."
-msgstr ""
-"2Dã¨3Dã®é åè¨å®ãç°ãªã£ã¦ãã¾ãã3Dã°ãªããã®è¨å®ã2Dã®è¨å®ã«ä½¿ç¨ãã¾ã"
+msgid "The 2D and 3D region settings are different. Using the 3D raster map settings to adjust the 2D region."
+msgstr "2Dã¨3Dã®é åè¨å®ãç°ãªã£ã¦ãã¾ãã3Dã°ãªããã®è¨å®ã2Dã®è¨å®ã«ä½¿ç¨ãã¾ã"
#: ../raster3d/r3.cross.rast/main.c:333
msgid "Elevation map not found"
@@ -1384,25 +1350,16 @@
msgstr "ä¸ã®æ²é¢2Dã©ã¹ã¿ã¼ããã"
#: ../raster3d/r3.out.vtk/parameters.c:71
-msgid ""
-"Create 3d elevation output with a top and a bottom surface, both raster maps "
-"are required."
-msgstr ""
-"ä¸ã®æ²é¢ã¨ä¸ã®æ²é¢ãã3Dæ¨é«ãããã使ãã¾ãã両æ¹ã®ã©ã¹ã¿ã¼ããããå¿
è¦ã§"
-"ã"
+msgid "Create 3d elevation output with a top and a bottom surface, both raster maps are required."
+msgstr "ä¸ã®æ²é¢ã¨ä¸ã®æ²é¢ãã3Dæ¨é«ãããã使ãã¾ãã両æ¹ã®ã©ã¹ã¿ã¼ããããå¿
è¦ã§ã"
#: ../raster3d/r3.out.vtk/parameters.c:82
-msgid ""
-"Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
-msgstr ""
-"RGBå¤ã使ããã«ã¯ãï¼ã¤ã®(r,g,b) 3Dã©ã¹ã¿ã¼ããããå¿
è¦ã§ã [redmap,"
-"greenmap,bluemap]"
+msgid "Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
+msgstr "RGBå¤ã使ããã«ã¯ãï¼ã¤ã®(r,g,b) 3Dã©ã¹ã¿ã¼ããããå¿
è¦ã§ã [redmap,greenmap,bluemap]"
#: ../raster3d/r3.out.vtk/parameters.c:92
msgid "Three (x,y,z) 3D raster maps to create vector values [xmap,ymap,zmap]"
-msgstr ""
-"ãã¯ãã«å¤ã使ããã«ã¯ãï¼ã¤ã® (x,y,z) 3Dã©ã¹ã¿ã¼ããããå¿
è¦ã§ãã[xmap,"
-"ymap,zmap]"
+msgstr "ãã¯ãã«å¤ã使ããã«ã¯ãï¼ã¤ã® (x,y,z) 3Dã©ã¹ã¿ã¼ããããå¿
è¦ã§ãã[xmap,ymap,zmap]"
#: ../raster3d/r3.out.vtk/parameters.c:99 ../raster/r.out.vtk/parameters.c:93
#: ../vector/v.out.vtk/main.c:75
@@ -1458,12 +1415,8 @@
msgstr "ä¸ã¤ã®3Dã°ãªãããã¯ãã«ããããç¨æãã¦ãã ãã [x,y,z]"
#: ../raster3d/r3.out.vtk/main.c:178
-msgid ""
-"No 3D raster data, RGB or xyz-vector maps are provided. Will only write the "
-"geometry"
-msgstr ""
-"3Dã°ãªãããã¼ã¿ãRGBãxyzãã¯ãã«ãããã®ããããæä¾ããã¦ãã¾ãããã¸ãªã¡"
-"ããªã¼ã®ã¿ãæ¸åºãã¾ã"
+msgid "No 3D raster data, RGB or xyz-vector maps are provided. Will only write the geometry"
+msgstr "3Dã°ãªãããã¼ã¿ãRGBãxyzãã¯ãã«ãããã®ããããæä¾ããã¦ãã¾ãããã¸ãªã¡ããªã¼ã®ã¿ãæ¸åºãã¾ã"
#: ../raster3d/r3.out.vtk/main.c:211
msgid "No RGB Data will be created"
@@ -1495,9 +1448,7 @@
#: ../raster3d/r3.out.vtk/main.c:546
msgid "Unable to close 3D raster map, the VTK file may be incomplete"
-msgstr ""
-"3D ã©ã¹ã¿ã¼ããããéãããã¾ãããVTKãã¡ã¤ã«ã¯æ£å¸¸ã«çµäºãã¦ããªãå¯è½æ§ã"
-"ããã¾ã"
+msgstr "3D ã©ã¹ã¿ã¼ããããéãããã¾ãããVTKãã¡ã¤ã«ã¯æ£å¸¸ã«çµäºãã¦ããªãå¯è½æ§ãããã¾ã"
#: ../raster3d/r3.out.vtk/main.c:561
msgid "Unable to close VTK-ASCII file"
@@ -1505,8 +1456,7 @@
#: ../raster3d/r3.out.vtk/writeVTKHead.c:39
msgid "write_vtk_structured_point_header: Writing VTKStructuredPoint-Header"
-msgstr ""
-"write_vtk_structured_point_header: VTKæ§é ãã¤ã³ãã®ãããã¼ãæ¸åºãã¾ã"
+msgstr "write_vtk_structured_point_header: VTKæ§é ãã¤ã³ãã®ãããã¼ãæ¸åºãã¾ã"
#: ../raster3d/r3.out.vtk/writeVTKHead.c:95
msgid "write_vtk_structured_grid_header: Writing VTKStructuredGrid-Header"
@@ -1514,8 +1464,7 @@
#: ../raster3d/r3.out.vtk/writeVTKHead.c:116
msgid "write_vtk_unstructured_grid_header: Writing VTKUnstructuredGrid-Header"
-msgstr ""
-"write_vtk_unstructured_grid_header: VTKéæ§é ã°ãªããã®ããããæ¸åºãã¾ã"
+msgstr "write_vtk_unstructured_grid_header: VTKéæ§é ã°ãªããã®ããããæ¸åºãã¾ã"
#: ../raster3d/r3.in.ascii/main.c:79
msgid "ASCII raster map to be imported"
@@ -1536,17 +1485,12 @@
#: ../raster3d/r3.in.ascii/main.c:209
#, c-format
-msgid ""
-"Data exists in input file after fully importing expected data. [%.4f ...]"
-msgstr ""
-"äºæ³ããããã¼ã¿ã¯å
¨ã¦ã¤ã³ãã¼ããã¾ããããå
¥åãã¡ã¤ã«ã«ãã¼ã¿ãåå¨ãã¾ã "
-"[%.4f ...]"
+msgid "Data exists in input file after fully importing expected data. [%.4f ...]"
+msgstr "äºæ³ããããã¼ã¿ã¯å
¨ã¦ã¤ã³ãã¼ããã¾ããããå
¥åãã¡ã¤ã«ã«ãã¼ã¿ãåå¨ãã¾ã [%.4f ...]"
#: ../raster3d/r3.in.ascii/main.c:242
-msgid ""
-"Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
-msgstr ""
-"3DASCIIå½¢å¼ã©ã¹ã¿ã¼ãã¡ã¤ã«ã(ãã¤ããª)3Dã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ã«å¤æãã¾ã"
+msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
+msgstr "3DASCIIå½¢å¼ã©ã¹ã¿ã¼ãã¡ã¤ã«ã(ãã¤ããª)3Dã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ã«å¤æãã¾ã"
#: ../raster3d/r3.in.ascii/main.c:284
msgid "Unable to close ASCII file"
@@ -1819,8 +1763,7 @@
msgstr "ã©ã¤ãå¨è¾º"
#: ../misc/m.nviz.image/args.c:603
-msgid ""
-"nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East edge"
+msgid "nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East edge"
msgstr "nw;å西端;ne;åæ±ç«¯;sw;å西端;se;åæ±ç«¯"
#: ../misc/m.nviz.image/args.c:607
@@ -1903,10 +1846,8 @@
msgstr "3å Matlabãã¼ã¿ãã3Dãã¯ãã«ãã¤ã³ããããã使ãã"
#: ../misc/m.nviz.image/main.c:50
-msgid ""
-"Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster "
-"data) in 3D."
-msgstr ""
+msgid "Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster data) in 3D."
+msgstr "æ²é¢ï¼ã©ã¹ã¿ã¼ãã¼ã¿ï¼ã2D/3Dãã¯ãã«ãã¼ã¿ãä½ç©ï¼3Dã©ã¹ã¿ã¼ãã¼ã¿ï¼ãã¬ã³ããªã³ã°ãã"
#: ../misc/m.nviz.image/main.c:128
#, c-format
@@ -1956,12 +1897,8 @@
msgstr "MISC."
#: ../misc/m.cogo/main.c:226
-msgid ""
-"A simple utility for converting bearing and distance measurements to "
-"coordinates and vice versa."
-msgstr ""
-"å°å¿åº§æ¨ï¼æ¥µåº§æ¨ï¼ããã«ã«ã座æ¨ï¼ç·¯åº¦/çµåº¦ï¼ã¸å¤æï¼é夿ï¼ããåç´ã¦ã¼ãã£"
-"ãªãã£"
+msgid "A simple utility for converting bearing and distance measurements to coordinates and vice versa."
+msgstr "å°å¿åº§æ¨ï¼æ¥µåº§æ¨ï¼ããã«ã«ã座æ¨ï¼ç·¯åº¦/çµåº¦ï¼ã¸å¤æï¼é夿ï¼ããåç´ã¦ã¼ãã£ãªãã£"
#: ../misc/m.cogo/main.c:228
msgid "It assumes a cartesian coordinate system"
@@ -2008,11 +1945,8 @@
msgstr "ãµãã¼ãããã¦ãããã©ã¼ãããï¼\n"
#: ../raster/r.external/main.c:83 ../raster/r.in.gdal/main.c:341
-msgid ""
-"Unable to convert input raster map projection information to GRASS format "
-"for checking"
-msgstr ""
-"å
¥åã©ã¹ã¿ã¼ãããã®æå½±æ
å ±ããã§ãã¯ç¨ã®GRASSãã©ã¼ãããã«å¤æã§ãã¾ãã"
+msgid "Unable to convert input raster map projection information to GRASS format for checking"
+msgstr "å
#: ../raster/r.external/main.c:99 ../raster/r.in.gdal/main.c:357
#: ../vector/v.in.ogr/main.c:511
@@ -2044,20 +1978,14 @@
#: ../raster/r.external/main.c:172
msgid ""
"\n"
-"You can use the -o flag to r.external to override this check and use the "
-"location definition for the dataset.\n"
+"You can use the -o flag to r.external to override this check and use the location definition for the dataset.\n"
msgstr ""
"\n"
-"ãã®ãã§ãã¯ããªã¼ãã¼ã©ã¤ãããã¼ã¿ã»ããã«ãã±ã¼ã·ã§ã³å®ç¾©ã使ç¨ãããã r."
-"external ã¸ã® -o ãã©ã㰠使ç¨ãå¯è½ã§ã.\n"
+"ãã®ãã§ãã¯ããªã¼ãã¼ã©ã¤ãããã¼ã¿ã»ããã«ãã±ã¼ã·ã§ã³å®ç¾©ã使ç¨ãããã r.external ã¸ã® -o ãã©ã㰠使ç¨ãå¯è½ã§ã.\n"
#: ../raster/r.external/main.c:175 ../raster/r.in.gdal/main.c:435
-msgid ""
-"Consider generating a new location from the input dataset using the "
-"'location' parameter.\n"
-msgstr ""
-"location'ãã©ã¡ã¼ã¿ãç¨ãã¦ãå
¥åãã¼ã¿ã»ããããã®æ°è¦ãã±ã¼ã·ã§ã³ä½æãæ¤è¨"
-"ãã¦ä¸ãã .\n"
+msgid "Consider generating a new location from the input dataset using the 'location' parameter.\n"
+msgstr "location'ãã©ã¡ã¼ã¿ãç¨ãã¦ãå
¥åãã¼ã¿ã»ããããã®æ°è¦ãã±ã¼ã·ã§ã³ä½æãæ¤è¨ãã¦ä¸ãã .\n"
#: ../raster/r.external/main.c:180 ../raster/r.in.gdal/main.c:440
#: ../vector/v.in.ogr/main.c:594
@@ -2065,24 +1993,18 @@
msgstr "å
¥åãã¼ã¿ã»ããã¨ç¾å¨é åã®æå½±ã¯æ´åãã¦ããããã§ã"
#: ../raster/r.external/main.c:202
-msgid ""
-"Input raster map is rotated - cannot import. You may use 'gdalwarp' to "
-"transform the map to North-up."
-msgstr ""
-"å
¥åããã©ã¹ã¿ã¼ãããã¯å転ãã¦ãã¦å
¥åã§ãã¾ããã 'gdalwarp' ãç¨ããã¨"
-"ãããããã¼ã¹ã¢ããã«å¤æã§ããã§ããã"
+msgid "Input raster map is rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
+msgstr "å
¥åã§ãã¾ããã 'gdalwarp' ãç¨ããã¨ãããããã¼ã¹ã¢ããã«å¤æã§ããã§ããã"
#: ../raster/r.external/main.c:264 ../raster/r.in.gdal/main.c:621
#: ../vector/v.in.ogr/main.c:1201
-#, fuzzy
msgid "Default region for this location updated"
-msgstr "æå½±æ
å ±ã¯ã¢ãããã¼ãããã¾ãã! "
+msgstr "ãã®ãã±ã¼ã·ã§ã³ã®ããã©ã«ãé åãæ´æ°ããã¾ãã "
#: ../raster/r.external/main.c:267 ../raster/r.in.gdal/main.c:624
#: ../vector/v.in.ogr/main.c:1204
-#, fuzzy
msgid "Region for the current mapset updated"
-msgstr "<%s> ã¯ãã§ã«ç¾åã®ãããã»ããã§ã"
+msgstr "ç¾å¨ã®ãããã»ããã®é åãæ´æ°ããã¾ãã"
#: ../raster/r.external/main.c:310
msgid "Complex types not supported"
@@ -2157,9 +2079,7 @@
#: ../raster/r.external/main.c:522
msgid "Link GDAL supported raster file to a binary raster map layer."
-msgstr ""
-"GDALãµãã¼ãããã¦ããã©ã¹ã¿ã¼ãã¡ã¤ã«ããã¤ããªã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ã«ãªã³"
-"ã¯ãã¾ã"
+msgstr "GDALãµãã¼ãããã¦ããã©ã¹ã¿ã¼ãã¡ã¤ã«ããã¤ããªã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ã«ãªã³ã¯ãã¾ã"
#: ../raster/r.external/main.c:525
msgid "Raster file to be linked"
@@ -2198,14 +2118,13 @@
#: ../raster/r.external/main.c:560 ../raster/r.in.gdal/main.c:138
#: ../vector/v.in.ogr/main.c:231
-#, fuzzy
msgid "Extend region extents based on new dataset"
-msgstr "ãã¼ã¿ã»ããããã¨ã«ãã±ã¼ã·ã§ã³ãæ¡å¼µ"
+msgstr "æ°ãããã¼ã¿ã»ããããã¨ã«ãã±ã¼ã·ã§ã³ãæ¡å¼µ"
#: ../raster/r.external/main.c:562 ../raster/r.in.gdal/main.c:140
#: ../vector/v.in.ogr/main.c:233
msgid "Also updates the default region if in the PERMANENT mapset"
-msgstr ""
+msgstr "PERMANENTãããã»ããã®ããã©ã«ãé åãæ´æ°ãã¾ãã"
#: ../raster/r.external/main.c:566
msgid "Require exact range"
@@ -2292,15 +2211,12 @@
msgstr "ã©ã¹ã¿ã¼ãããç¨ã®åç·è£å®ã¦ã¼ãã£ãªãã£"
#: ../raster/r.bilinear/main.c:54 ../raster/r.bilinear/main.c:61
-msgid ""
-"Specific input value to be assigned to the north and/or south poles for "
-"longitude-latitude grids"
+msgid "Specific input value to be assigned to the north and/or south poles for longitude-latitude grids"
msgstr "緯度çµåº¦ã°ãªããã§ã¯ãç¹å®ã®å
¥åå¤ã¯å極ã¾ãã¯å極ã«å²ãå½ã¦ããã¾ã"
#: ../raster/r.bilinear/main.c:67
msgid "This module is deprecated. Please use 'r.resamp.interp' instead."
-msgstr ""
-"ãã®ã¢ã¸ã¥ã¼ã«ã¯å°æ¥å»æ¢ãããäºå®ã§ã. 'r.resamp.interp' ã使ç¨ãã¦ãã ãã"
+msgstr "ãã®ã¢ã¸ã¥ã¼ã«ã¯å°æ¥å»æ¢ãããäºå®ã§ã. 'r.resamp.interp' ã使ç¨ãã¦ãã ãã"
#: ../raster/r.mode/main.c:50 ../raster/r.cross/main.c:75
#: ../raster/r.statistics/main.c:42 ../raster/r.kappa/main.c:67
@@ -2317,12 +2233,8 @@
msgstr "ã©ã¹ã¿ã¼ãçµ±è¨"
#: ../raster/r.mode/main.c:52
-msgid ""
-"Finds the mode of values in a cover map within areas assigned the same "
-"category value in a user-specified base map."
-msgstr ""
-"ã¦ã¼ã¶ã¼æå®ã®ãã¼ã¹ãããã«ãããåãã«ãã´ãªã¼å¤ãå²ãå½ã¦ãããã¨ãªã¢å
ã®"
-"ã«ãã¼ãããã«ãããå¤ã®ã¢ã¼ããæ¢ãã¾ã"
+msgid "Finds the mode of values in a cover map within areas assigned the same category value in a user-specified base map."
+msgstr "ã¦ã¼ã¶ã¼æå®ã®ãã¼ã¹ãããã«ãããåãã«ãã´ãªã¼å¤ãå²ãå½ã¦ãããã¨ãªã¢å
ã®ã«ãã¼ãããã«ãããå¤ã®ã¢ã¼ããæ¢ãã¾ã"
#: ../raster/r.mode/main.c:58
msgid "Base map to be reclassified"
@@ -2500,20 +2412,8 @@
msgstr "å¤ªé½æ¾å°è¼åº¦ã¨ç
§å°ã¢ãã«"
#: ../raster/r.sun2/main.c:230 ../raster/r.sun/main.c:176
-msgid ""
-"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
-"for given day, latitude, surface and atmospheric conditions. Solar "
-"parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
-"irradiance, daylight length) are saved in the map history file. "
-"Alternatively, a local time can be specified to compute solar incidence "
-"angle and/or irradiance raster maps. The shadowing effect of the topography "
-"is optionally incorporated."
-msgstr ""
-"æå®ããæ¥ãç·¯åº¦ãæ²é¢ãããã³å¤§æ°ç¶æ
ã«ããããç´å°ï¼ãã¼ã ï¼ãæ¡æ£ãããã³"
-"åå°ã®å¤ªé½ç
§å°ã©ã¹ã¿ã¼ããããè¨ç®ãã¾ãã太é½ãã©ã¡ã¼ã¿ã¼ï¼ä¾ æ¥ã®åºæå»ãæ¥"
-"ã®å
¥ãæå»ã赤緯ãå°çå¤ç
§åº¦ãæ¼éã®é·ãï¼ã¯ãããå±¥æ´ãã¡ã¤ã«ã«ä¿åããã¾"
-"ããã¾ãã太é½ã®å
¥å°è§ãç
§åº¦ã©ã¹ã¿ã¼ããããè¨ç®ããçºã«ãã¼ã«ã«æéãæå®ã"
-"ããã¨ãã§ãã¾ããå°å½¢ã®é°å½±å¹æã¯ãªãã·ã§ã³ã¨ãã¦çµã¿è¾¼ã¾ãã¦ãã¾ãã"
+msgid "Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in the map history file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
+msgstr "æå®ããæ¥ãç·¯åº¦ãæ²é¢ãããã³å¤§æ°ç¶æ
ã«ããããç´å°ï¼ãã¼ã ï¼ãæ¡æ£ãããã³åå°ã®å¤ªé½ç
§å°ã©ã¹ã¿ã¼ããããè¨ç®ãã¾ãã太é½ãã©ã¡ã¼ã¿ã¼ï¼ä¾ æ¥ã®åºæå»ãæ¥ã®å
¥ãæå»ã赤緯ãå°çå¤ç
§åº¦ãæ¼éã®é·ãï¼ã¯ãããå±¥æ´ãã¡ã¤ã«ã«ä¿åããã¾ããã¾ãã太é½ã®å
¥å°è§ãç
§åº¦ã©ã¹ã¿ã¼ããããè¨ç®ããçºã«ãã¼ã«ã«æéãæå®ãããã¨ãã§ãã¾ããå°å½¢ã®é°å½±å¹æã¯ãªãã·ã§ã³ã¨ãã¦çµã¿è¾¼ã¾ãã¦ãã¾ãã"
#: ../raster/r.sun2/main.c:244 ../raster/r.sun/main.c:206
#: ../raster/r.horizon/main.c:225
@@ -2546,9 +2446,7 @@
msgstr "å
¥åãªãã·ã§ã³ "
#: ../raster/r.sun2/main.c:253 ../raster/r.sun/main.c:215
-msgid ""
-"Name of the input aspect map (terrain aspect or azimuth of the solar panel) "
-"[decimal degrees]"
+msgid "Name of the input aspect map (terrain aspect or azimuth of the solar panel) [decimal degrees]"
msgstr "å
¥åæ¹ä½ãããå"
#: ../raster/r.sun2/main.c:262
@@ -2556,9 +2454,7 @@
msgstr "ãªãªã¨ã³ãã¼ã·ã§ã³ãåã¯270"
#: ../raster/r.sun2/main.c:271 ../raster/r.sun/main.c:225
-msgid ""
-"Name of the input slope raster map (terrain slope or solar panel "
-"inclination) [decimal degrees]"
+msgid "Name of the input slope raster map (terrain slope or solar panel inclination) [decimal degrees]"
msgstr "å
¥åãã徿ã©ã¹ã¿ã¼ããã(å°å½¢å¾æã¾ãã¯ã½ã¼ã©ã¼ããã«å¾æ)[åä½(°)]"
#: ../raster/r.sun2/main.c:279
@@ -2566,8 +2462,7 @@
msgstr "徿ï¼ã¹ãã¼ãï¼ã®åä¸å¤ "
#: ../raster/r.sun2/main.c:288 ../raster/r.sun/main.c:234
-msgid ""
-"Name of the Linke atmospheric turbidity coefficient input raster map [-]"
+msgid "Name of the Linke atmospheric turbidity coefficient input raster map [-]"
msgstr "ãªã³ã±å¤§æ°æ··æ¿åº¦ä¿æ°å
¥åç¨ã®ã©ã¹ã¿ã¼ãããå [-]"
#: ../raster/r.sun2/main.c:298 ../raster/r.sun/main.c:245
@@ -2636,40 +2531,24 @@
msgstr "åºåãªãã·ã§ã³ "
#: ../raster/r.sun2/main.c:389 ../raster/r.sun/main.c:320
-msgid ""
-"Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
-"day-1] (mode 2)"
-msgstr ""
-"ãã¼ã æ¾å°è¼åº¦ [W.m-2] (ã¢ã¼ã 1) ã¾ã㯠ç
§å°ã©ã¹ã¿-ããã [Wh.m-2.day-1] "
-"(ã¢ã¼ã 2) ãåºå"
+msgid "Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr "ãã¼ã æ¾å°è¼åº¦ [W.m-2] (ã¢ã¼ã 1) ã¾ã㯠ç
§å°ã©ã¹ã¿-ããã [Wh.m-2.day-1] (ã¢ã¼ã 2) ãåºå"
#: ../raster/r.sun2/main.c:398 ../raster/r.sun/main.c:329
msgid "Output insolation time raster map [h] (mode 2 only)"
msgstr "éé¢ã¿ã¤ã ã©ã¹ã¿ã¼ããããåºå"
#: ../raster/r.sun2/main.c:407 ../raster/r.sun/main.c:338
-msgid ""
-"Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
-"day-1] (mode 2)"
-msgstr ""
-"æ¡æ£æ¾å°è¼åº¦ [W.m-2] (ã¢ã¼ã 1) ã¾ã㯠ç
§å°ã©ã¹ã¿-ããã [Wh.m-2.day-1] (ã¢ã¼"
-"ã 2) ãåºå"
+msgid "Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr "æ¡æ£æ¾å°è¼åº¦ [W.m-2] (ã¢ã¼ã 1) ã¾ã㯠ç
#: ../raster/r.sun2/main.c:416 ../raster/r.sun/main.c:347
-msgid ""
-"Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster "
-"map [Wh.m-2.day-1] (mode 2)"
-msgstr ""
-"å°è¡¨åå°æ¾å°è¼åº¦ [W.m-2] (ã¢ã¼ã 1) ã¾ã㯠ç
-"(ã¢ã¼ã 2) ãåºå"
+msgid "Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr "å°è¡¨åå°æ¾å°è¼åº¦ [W.m-2] (ã¢ã¼ã 1) ã¾ã㯠ç
#: ../raster/r.sun2/main.c:425
-msgid ""
-"Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/"
-"irradiation raster map [Wh.m-2.day-1] (mode 2)"
-msgstr ""
-"åè¨æ¾å°è¼åº¦ [W.m-2] (ã¢ã¼ã 1)ã¾ãã¯æ¾å°è¼åº¦/ç
§å°ã©ã¹ã¿-ããã [Wh.m-2."
-"day-1] (ã¢ã¼ã 2) ãåºå"
+msgid "Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr "åè¨æ¾å°è¼åº¦ [W.m-2] (ã¢ã¼ã 1)ã¾ãã¯æ¾å°è¼åº¦/ç
#: ../raster/r.sun2/main.c:432 ../raster/r.sun/main.c:354
msgid "No. of day of the year (1-365)"
@@ -2751,8 +2630,7 @@
msgstr "æ°´å¹³ã¹ããããµã¤ãºã¯0以ä¸ã§ãã "
#: ../raster/r.sun2/main.c:610
-msgid ""
-"If you use the horizon option you must also set the 'horizonstep' parameter."
+msgid "If you use the horizon option you must also set the 'horizonstep' parameter."
msgstr "ãã©ã¤ãºã³ãªãã·ã§ã³ã使ãã«ã¯ã 'horizonstep' ã®æå®ãå¿
è¦ã§ã"
#: ../raster/r.sun2/main.c:616
@@ -2760,9 +2638,7 @@
msgstr "Time' 㨠'insol_time' ã¯ä½µç¨ã§ãã¾ãã"
#: ../raster/r.sun2/main.c:618
-msgid ""
-"Mode 1: instantaneous solar incidence angle & irradiance using a set local "
-"time"
+msgid "Mode 1: instantaneous solar incidence angle & irradiance using a set local time"
msgstr "ã¢ã¼ã 1: å°æ¹æã使ã£ãç¬é太é½å
¥å°è§ã¨ç
§å°"
#: ../raster/r.sun2/main.c:623 ../raster/r.sun/main.c:422
@@ -2775,17 +2651,11 @@
#: ../raster/r.sun2/main.c:671
msgid "If you use -s and no horizon rasters, numpartitions must be =1"
-msgstr ""
-"-s ããã©ã¤ãºã³ã©ã¹ã¿ã¼ãç¨ããã«ä½¿ç¨ããã«ã¯ãæ°å¤ãã¼ãã£ã·ã§ã³ ã¯ï¼ã§ãªã"
-"ãã°ãªãã¾ãã"
+msgstr "-s ããã©ã¤ãºã³ã©ã¹ã¿ã¼ãç¨ããã«ä½¿ç¨ããã«ã¯ãæ°å¤ãã¼ãã£ã·ã§ã³ ã¯ï¼ã§ãªããã°ãªãã¾ãã"
#: ../raster/r.sun2/main.c:683
-msgid ""
-"If you want to save memory and to use shadows, you must use pre-calculated "
-"horizons."
-msgstr ""
-"ã¡ã¢ãªãç¯ç´ããªããé°å½±ã使ç¨ããã¨ãã¯ãäºãè¨ç®æ¸ã¿ã®ãã©ã¤ãºã³ã使ãå¿
è¦"
-"ãããã¾ã"
+msgid "If you want to save memory and to use shadows, you must use pre-calculated horizons."
+msgstr "ã¡ã¢ãªãç¯ç´ããªããé°å½±ã使ç¨ããã¨ãã¯ãäºãè¨ç®æ¸ã¿ã®ãã©ã¤ãºã³ã使ãå¿
è¦ãããã¾ã"
#: ../raster/r.sun2/main.c:728 ../display/d.where/main.c:93
#: ../general/g.region/printwindow.c:247 ../general/g.region/printwindow.c:503
@@ -2817,14 +2687,11 @@
#: ../raster/r.sun2/main.c:750
msgid "latin and longin raster maps have no effect when in a Lat/Lon location"
-msgstr ""
-"緯度/çµåº¦ã®ãã±ã¼ã·ã§ã³ã®æã¯ç·¯åº¦ã©ã¹ã¿ã¼ã¾ãã¯çµåº¦ã©ã¹ã¿ã¼ã¯å½±é¿ãã¾ãã"
+msgstr "緯度/çµåº¦ã®ãã±ã¼ã·ã§ã³ã®æã¯ç·¯åº¦ã©ã¹ã¿ã¼ã¾ãã¯çµåº¦ã©ã¹ã¿ã¼ã¯å½±é¿ãã¾ãã"
#: ../raster/r.sun2/main.c:755
msgid "Both latin and longin raster maps must be given, or neither"
-msgstr ""
-"緯度ããã³çµåº¦ã©ã¹ã¿ã¼ãããã®ä¸¡æ¹ãæå®ããããã©ã¡ããæå®ããªãå¿
è¦ããã"
-"ã¾ã"
+msgstr "緯度ããã³çµåº¦ã©ã¹ã¿ã¼ãããã®ä¸¡æ¹ãæå®ããããã©ã¡ããæå®ããªãå¿
è¦ãããã¾ã"
#: ../raster/r.sun2/main.c:949
#, c-format
@@ -2916,22 +2783,22 @@
#, c-format
msgid ""
"USAGE for basin delineation:\n"
-"%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] "
-"[dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] "
-"[di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
+"%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
"\n"
"USAGE for ARMSED FILE creation:\n"
-"%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] "
-"[di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] "
-"ha=half_basin_map ar=ARMSED_file_name\n"
+"%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] ha=half_basin_map ar=ARMSED_file_name\n"
"\n"
"USAGE for slope length determination:\n"
-"%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] "
-"[de=depression_map] [ac=accumulation_map] [di=display_map] "
-"[ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] "
-"LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or map]"
+"%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or map]"
msgstr ""
+"ä½¿ç¨æ¹æ³ãçå°æç»:\n"
+"\n"
+"ä½¿ç¨æ¹æ³ ARMSEDãã¡ã¤ã«ã®ä½æ:\n"
+"\n"
+"ä½¿ç¨æ¹æ³ for ã¹ãã¼ãé·æ±ºå®:\n"
#: ../raster/r.watershed/ram/close_maps.c:30
#: ../raster/r.watershed/ram/close_maps.c:165
@@ -2971,8 +2838,7 @@
msgstr "ã»ã¯ã·ã§ã³ 1 éå§: 夿°ã®åæå è¨ã%d ã®ã»ã¯ã·ã§ã³"
#: ../raster/r.watershed/seg/init_vars.c:150
-msgid ""
-"Maximum memory to be used was smaller than 3 MB, set to default = 300 MB."
+msgid "Maximum memory to be used was smaller than 3 MB, set to default = 300 MB."
msgstr "使ç¨ãããæå¤§ã¡ã¢ãªã¼ã3MBããå°ãªãã§ããæ¢å®å¤ã®300MBã«ã»ãããã¾ã"
#: ../raster/r.watershed/seg/close_maps.c:52
@@ -3020,9 +2886,7 @@
#: ../raster/r.watershed/shed/com_line.c:34
msgid "mode uses disk space in the same hard disk partition as where GRASS is"
-msgstr ""
-"GRASSã®ããã«ãåããã¼ããã£ã¹ã¯ãã¼ãã£ã·ã§ã³ã«ãããã£ã¹ã¯ç©ºã容éã使ç¨ã"
-"ãã¢ã¼ã"
+msgstr "GRASSã®ããã«ãåããã¼ããã£ã¹ã¯ãã¼ãã£ã·ã§ã³ã«ãããã£ã¹ã¯ç©ºã容éã使ç¨ããã¢ã¼ã"
#: ../raster/r.watershed/shed/com_line.c:35
msgid "stored. Thus, if the program does not work in the slow mode, you will"
@@ -3061,18 +2925,15 @@
" %s ã®ãªãã·ã§ã³ã®ä¸ã¤ã¯ ãå¹å°ããããã§ã. "
#: ../raster/r.watershed/shed/com_line.c:83
-msgid ""
-"depression map indicates all the locations in the current map window where"
+msgid "depression map indicates all the locations in the current map window where"
msgstr "å¹å°ãããã¯ãæ°´ãèç©ããããã®ç«¯ããåºãªãç¾å¨ã®ãããã¦ã£ã³ãã¦ã®ã"
#: ../raster/r.watershed/shed/com_line.c:84
-msgid ""
-"water accumulates and does not leave by the edge of the map. Lakes without"
+msgid "water accumulates and does not leave by the edge of the map. Lakes without"
msgstr "å
¨ãã±ã¼ã·ã§ã³ã表示ãã¾ãã"
#: ../raster/r.watershed/shed/com_line.c:85
-msgid ""
-"outlet streams and sinkholes are examples of `depressions'. If you wish to"
+msgid "outlet streams and sinkholes are examples of `depressions'. If you wish to"
msgstr "ææ°´ã®æ°´æµã¨çªªã¿ã¯å¹å°ã®ä¾"
#: ../raster/r.watershed/shed/com_line.c:86
@@ -3084,8 +2945,7 @@
msgstr "ããããæºåãã¾ãã\n"
#: ../raster/r.watershed/shed/com_line.c:88
-msgid ""
-"Hit <return> by itself for the next question if there is no depression map."
+msgid "Hit <return> by itself for the next question if there is no depression map."
msgstr "å¹å°ããããç¡ãã¨ãã¯<ãªã¿ã¼ã³> ãæ¼ãã¦æ¬¡ã®è³ªåã«çãã¾ã"
#: ../raster/r.watershed/shed/com_line.c:99
@@ -3098,14 +2958,11 @@
" %s ã®ããã°ã©ã ã¯æ¨é«ãããã夿°ã®åæ°´åã«åå²ãã¾ã"
#: ../raster/r.watershed/shed/com_line.c:101
-msgid ""
-"watershed basins. The number of watershed basins is indirectly determined"
+msgid "watershed basins. The number of watershed basins is indirectly determined"
msgstr "åæ°´åã®æ°ã¯ãçå°é¾å¤ããç¨ãã¦éæ¥çã«æ±ºå®ããã¾ãã "
#: ../raster/r.watershed/shed/com_line.c:102
-msgid ""
-"by the `basin threshold' value. The basin threshold is the area necessary "
-"for"
+msgid "by the `basin threshold' value. The basin threshold is the area necessary for"
msgstr "çå°é¾å¤ã¯"
#: ../raster/r.watershed/shed/com_line.c:103
@@ -3114,18 +2971,15 @@
msgstr "åºæã®åæ°´åãå®ç¾©ãã %s ã«å¿
è¦ãªã¨ãªã¢ã§ããã®ã¨ãªã¢ã¯"
#: ../raster/r.watershed/shed/com_line.c:105
-msgid ""
-"`exterior drainage basins'. An exterior drainage basin does not have any"
+msgid "`exterior drainage basins'. An exterior drainage basin does not have any"
msgstr "ãå¤é¨æµåãã«ã®ã¿é©ç¨ããã¾ããå¤é¨æµåã¯ææ°´æµãå«ã¿ã¾ããã"
#: ../raster/r.watershed/shed/com_line.c:106
-msgid ""
-"drainage basins flowing into it. Interior drainage basin size is determined"
+msgid "drainage basins flowing into it. Interior drainage basin size is determined"
msgstr "å
鍿µåã®ãµã¤ãºã¯ã"
#: ../raster/r.watershed/shed/com_line.c:107
-msgid ""
-"by the surface flow going into stream segments between stream interceptions."
+msgid "by the surface flow going into stream segments between stream interceptions."
msgstr "æ°´æµã®åæµç¹ã®éã®æ°´æµã»ã°ã¡ã³ãã«æµãè¾¼ã表層æµã«ãã£ã¦æ±ºå®ããã¾ãã"
#: ../raster/r.watershed/shed/com_line.c:108
@@ -3138,20 +2992,16 @@
msgstr "ã¯çå°ãµã¤ãºãæ½å¨å°è¡¨æµã«é¢é£ä»ãããã¨ãã§ãã¾ã"
#: ../raster/r.watershed/shed/com_line.c:111
-msgid ""
-"(i.e., areas with low infiltration capacities will need smaller areas to"
+msgid "(i.e., areas with low infiltration capacities will need smaller areas to"
msgstr "ï¼ä¾ï¼ä½æµ¸æ½¤å®¹éã®ã¨ãªã¢ã§ã¯ã飿¥ãã髿¹¿æ½¤çã®ã¨ãªã¢ããã"
#: ../raster/r.watershed/shed/com_line.c:112
-msgid ""
-"develop stream channels than neighboring areas with high infiltration rates)."
+msgid "develop stream channels than neighboring areas with high infiltration rates)."
msgstr "ããçãã¨ãªã¢ã§ã®æ°´æµãã£ã³ãã«ã使ããå¿
è¦ãããã¾ããï¼"
#: ../raster/r.watershed/shed/com_line.c:113
-msgid ""
-"The user can create a map layer with potential overland flow values, and"
-msgstr ""
-"ã¦ã¼ã¶ã¼ã¯æ½å¨å°è¡¨æµã®å¤ãå©ç¨ãã¦ãã¬ã¤ã¤ã¼ã使ãããã¨ãã§ãã¾ããã¾ã"
+msgid "The user can create a map layer with potential overland flow values, and"
+msgstr "ã¦ã¼ã¶ã¼ã¯æ½å¨å°è¡¨æµã®å¤ãå©ç¨ãã¦ãã¬ã¤ã¤ã¼ã使ãããã¨ãã§ãã¾ããã¾ã"
#: ../raster/r.watershed/shed/com_line.c:114
#, c-format
@@ -3270,8 +3120,7 @@
msgstr "使ãããã¨ãã§ãã¾ãã %s ã¯ã¾ããæ¹å®æ±ç¨å壿µåº"
#: ../raster/r.watershed/shed/com_line.c:296
-msgid ""
-"ability to generate several variables in the Revised Universal Soil Loss"
+msgid "ability to generate several variables in the Revised Universal Soil Loss"
msgstr "ï¼Revised Universal Soil Lossï¼ã®å¤æ°ã使ãããã¨ãã§ãã¾ãã"
#: ../raster/r.watershed/shed/com_line.c:297
@@ -3292,9 +3141,7 @@
msgstr " %s ã¯ãªãã·ã§ã³ã®ãããã¬ã¤ã¤ã¼ãããã¯"
#: ../raster/r.watershed/shed/com_line.c:351
-msgid ""
-"where the value indicates the percent of disturbed (barren) land in that "
-"cell."
+msgid "where the value indicates the percent of disturbed (barren) land in that cell."
msgstr "ã»ã«å
ã®èå°ã®ãã¼ã»ã³ãã¼ã¸ã示ãå¤ã§ããã示ãã¾ã"
#: ../raster/r.watershed/shed/com_line.c:352
@@ -3341,8 +3188,7 @@
msgstr " %s ã¯å°è¡¨æµè·é¢ãé·ããªããããã®ãé²ã"
#: ../raster/r.watershed/shed/com_line.c:384
-msgid ""
-"that prevents the surface flow distance from getting too long. Normally,"
+msgid "that prevents the surface flow distance from getting too long. Normally,"
msgstr "å
¥åãå¯è½ã«ãã¾ã(è¦å: ãã®å ´ãã®ãã®è§£æ±ºæ³)"
#: ../raster/r.watershed/shed/com_line.c:385
@@ -3358,8 +3204,7 @@
"éè·¯ã æ°´è·¯ï¼æºï¼ã¯åå°è¢«è¦ã®å¤æ´ã ãã®ä»ã®ãã¡ã¯ã¿ã¼ã¯"
#: ../raster/r.watershed/shed/com_line.c:401
-msgid ""
-"slope length. You may input a raster map indicating the locations of these"
+msgid "slope length. You may input a raster map indicating the locations of these"
msgstr "徿é·ã忢ãã¾ãããããã®ããããã³ã°ãã¡ã¯ã¿ã¼ã®å ´æã示ã"
#: ../raster/r.watershed/shed/com_line.c:402
@@ -3367,8 +3212,7 @@
msgstr "ã©ã¹ã¿ã¼ããããæå®ãããã¨ãã§ãã¾ã.\n"
#: ../raster/r.watershed/shed/com_line.c:403
-msgid ""
-"Hit <return> by itself for the next question if there is no blocking map."
+msgid "Hit <return> by itself for the next question if there is no blocking map."
msgstr "ããããã³ã°ãããããªãå ´åã¯ã <return> ãæ¼ãã¦ã次ã®è³ªåã«çãã¾ã"
#: ../raster/r.watershed/shed/basin_maps.c:12
@@ -3472,8 +3316,7 @@
#: ../raster/r.watershed/shed/intro.c:8
#, c-format
msgid "%s provides a text-based user-interface to the %s program."
-msgstr ""
-"%s ã¯%s ããã°ã©ã ã«ããã¹ããã¼ã¹ã®ã¦ã¼ã¶ã¼ã¤ã³ã¿ã¼ãã§ã¼ã¹ãæä¾ãã¾ã "
+msgstr "%s ã¯%s ããã°ã©ã ã«ããã¹ããã¼ã¹ã®ã¦ã¼ã¶ã¼ã¤ã³ã¿ã¼ãã§ã¼ã¹ãæä¾ãã¾ã "
#: ../raster/r.watershed/shed/intro.c:10
#, c-format
@@ -3483,8 +3326,7 @@
#: ../raster/r.watershed/shed/intro.c:12
#, c-format
msgid "watershed basin determined in %s.\n"
-msgstr ""
-" %sã§æ±ºå®ãããååæ°´åã®ãããã¬ã¤ã¤ã¼ã®ã¬ãã¼ããæºåããå¿
è¦ãããã¾ã\n"
+msgstr " %sã§æ±ºå®ãããååæ°´åã®ãããã¬ã¤ã¤ã¼ã®ã¬ãã¼ããæºåããå¿
è¦ãããã¾ã\n"
#: ../raster/r.watershed/shed/intro.c:14
#, c-format
@@ -3628,12 +3470,8 @@
msgstr "ä»®æ³ã¡ã¢ãªãä½¿ç¨ "
#: ../raster/r.watershed/front/main.c:193
-msgid ""
-"Only needed if memory requirements exceed available RAM; see manual on how "
-"to calculate memory requirements"
-msgstr ""
-"ã¡ã¢ãªè¦æ±ãå©ç¨å¯è½ãªRAMãè¶ããå ´åã®ã¿å¿
è¦; ã¡ã¢ãªè¦æ±ã®è¨ç®æ¹æ³ã¯ããã¥ã¢"
-"ã«ãåç
§ãã¦ãã ãã"
+msgid "Only needed if memory requirements exceed available RAM; see manual on how to calculate memory requirements"
+msgstr "ã¡ã¢ãªè¦æ±ãå©ç¨å¯è½ãªRAMãè¶ããå ´åã®ã¿å¿
è¦; ã¡ã¢ãªè¦æ±ã®è¨ç®æ¹æ³ã¯ããã¥ã¢ã«ãåç
§ãã¦ãã ãã"
#: ../raster/r.watershed/front/main.c:198
msgid "Use positive flow accumulation even for likely underestimates"
@@ -3798,12 +3636,8 @@
msgstr "DEM ããå°å½¢ãã©ã¡ã¼ã¿ã¼ãæ½åºãã¾ã"
#: ../raster/r.param.scale/interface.c:56
-msgid ""
-"Uses a multi-scale approach by taking fitting quadratic parameters to any "
-"size window (via least squares)."
-msgstr ""
-"é©åãªäºæ¬¡ãã©ã¡ã¼ã¿ã¼ããããªããµã¤ãºã®ã¦ã¤ã³ãã¦ã®å½¢ãã¨ããã¨ã«ãã£ã¦ãã«"
-"ãã¹ã±ã¼ã«ã使ç¨ãã¾ã"
+msgid "Uses a multi-scale approach by taking fitting quadratic parameters to any size window (via least squares)."
+msgstr "é©åãªäºæ¬¡ãã©ã¡ã¼ã¿ã¼ããããªããµã¤ãºã®ã¦ã¤ã³ãã¦ã®å½¢ãã¨ããã¨ã«ãã£ã¦ãã«ãã¹ã±ã¼ã«ã使ç¨ãã¾ã"
#: ../raster/r.param.scale/interface.c:74
msgid "Output raster layer containing morphometric parameter"
@@ -3853,9 +3687,7 @@
#: ../raster/r.in.gridatb/main.c:43
msgid "Imports GRIDATB.FOR map file (TOPMODEL) into GRASS raster map"
-msgstr ""
-"GRIDATB.FORå½¢å¼(TOPMODEL)ã®ããããã¡ã¤ã«ãã©ã¹ã¿ã¼ãããã¨ãã¦ã¤ã³ãã¼ããã¾"
-"ã "
+msgstr "GRIDATB.FORå½¢å¼(TOPMODEL)ã®ããããã¡ã¤ã«ãã©ã¹ã¿ã¼ãããã¨ãã¦ã¤ã³ãã¼ããã¾ã "
#: ../raster/r.in.gridatb/main.c:47 ../raster/r.out.gridatb/main.c:57
msgid "GRIDATB i/o map file"
@@ -4011,12 +3843,8 @@
#: ../raster/r.support/modhead/modhead.c:271
#, c-format
-msgid ""
-"Header indicates %d row%s in the raster map, but the actual file format "
-"indicates %d row%s"
-msgstr ""
-"ã©ã¹ã¿ã¼ãããã®ãããã¼ã¯ %d è¡ã%s ã§ãããå®éã®ãã¡ã¤ã«ãã©ã¼ããã㯠%d "
-"è¡ %s "
+msgid "Header indicates %d row%s in the raster map, but the actual file format indicates %d row%s"
+msgstr "ã©ã¹ã¿ã¼ãããã®ãããã¼ã¯ %d è¡ã%s ã§ãããå®éã®ãã¡ã¤ã«ãã©ã¼ããã㯠%d è¡ %s "
#: ../raster/r.support/modhead/modhead.c:303
#, c-format
@@ -4235,12 +4063,10 @@
#, c-format
msgid ""
"\n"
-"Do you want to create/reset the null file for [%s] so that null cell values "
-"are considered valid data? "
+"Do you want to create/reset the null file for [%s] so that null cell values are considered valid data? "
msgstr ""
"\n"
-"null ã»ã«ã®å¤ãæå¹å¤ã«ããããã«ã[%s] ã® null ãã¡ã¤ã«ã使ï¼ãªã»ããï¼ã"
-"ã¾ãã? "
+"null ã»ã«ã®å¤ãæå¹å¤ã«ããããã«ã[%s] ã® null ãã¡ã¤ã«ã使ï¼ãªã»ããï¼ãã¾ãã? "
#: ../raster/r.support/front/front.c:317 ../raster/r.support/front/front.c:354
#, c-format
@@ -4356,12 +4182,8 @@
msgstr "%s: ã¹ããã 1 ... "
#: ../raster/r.cross/main.c:77
-msgid ""
-"Creates a cross product of the category values from multiple raster map "
-"layers."
-msgstr ""
-"è¤æ°ã®ã©ã¹ã¿ã¼ãããã®ã«ãã´ãªã¼å¤ãæãåããã¦æ°ããªã©ã¹ã¿ã¼ãããã使ã"
-"ã¾ã"
+msgid "Creates a cross product of the category values from multiple raster map layers."
+msgstr "è¤æ°ã®ã©ã¹ã¿ã¼ãããã®ã«ãã´ãªã¼å¤ãæãåããã¦æ°ããªã©ã¹ã¿ã¼ãããã使ãã¾ã"
#: ../raster/r.cross/main.c:86
#, c-format
@@ -4396,9 +4218,7 @@
#: ../raster/r.neighbors/main.c:292 ../raster/r.texture/main.c:221
#: ../raster/r.covar/main.c:75 ../vector/v.mkgrid/main.c:141
#: ../vector/v.qcount/main.c:117
-msgid ""
-"The '-q' flag is superseded and will be removed in future. Please use '--"
-"quiet' instead."
+msgid "The '-q' flag is superseded and will be removed in future. Please use '--quiet' instead."
msgstr "-q' ãã©ãã°ã¯å°æ¥å»æ¢ããã¾ãã'--quiet' ãã©ãã°ã使ç¨ãã¦ãã ããã"
#: ../raster/r.cross/main.c:122
@@ -4473,8 +4293,7 @@
#: ../raster/r.out.mpeg/main.c:88
msgid "Either mpeg_encode or ppmtompeg must be installed"
-msgstr ""
-"mpeg_encode ã ppmtompeg ã®ã©ã¡ãããã¤ã³ã¹ãã¼ã«ããã¦ããå¿
è¦ãããã¾ã"
+msgstr "mpeg_encode ã ppmtompeg ã®ã©ã¡ãããã¤ã³ã¹ãã¼ã«ããã¦ããå¿
è¦ãããã¾ã"
#: ../raster/r.out.mpeg/main.c:213
msgid "Reading file"
@@ -4539,12 +4358,8 @@
msgstr "ã©ã¹ã¿ã¼ãç»å"
#: ../raster/r.patch/main.c:55
-msgid ""
-"Creates a composite raster map layer by using known category values from one "
-"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
-msgstr ""
-"æ¢ç¥ã®ã«ãã´ãªã¼å¤ãç¨ããä¸ã¤ä»¥ä¸ã®ãããã¬ã¤ã¤ã¼ããä»ã®ãããã¬ã¼ã¤ã¼ã®"
-"\"no data\"ã¨ãªã¢ãåããåæã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ã使ãã¾ã"
+msgid "Creates a composite raster map layer by using known category values from one (or more) map layer(s) to fill in areas of \"no data\" in another map layer."
+msgstr "æ¢ç¥ã®ã«ãã´ãªã¼å¤ãç¨ããä¸ã¤ä»¥ä¸ã®ãããã¬ã¤ã¤ã¼ããä»ã®ãããã¬ã¼ã¤ã¼ã®\"no data\"ã¨ãªã¢ãåããåæã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ã使ãã¾ã"
#: ../raster/r.patch/main.c:62
msgid "Name of raster maps to be patched together"
@@ -4696,10 +4511,7 @@
msgstr "ã©ã¹ã¿ã¼ãã³ã¹ãæ²é¢ãç´¯ç©ã³ã¹ã"
#: ../raster/r.cost/main.c:126
-msgid ""
-"Creates a raster map showing the cumulative cost of moving between different "
-"geographic locations on an input raster map whose cell category values "
-"represent cost."
+msgid "Creates a raster map showing the cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
msgstr "ç´¯ç©ã³ã¹ãã表ãã©ã¹ã¿ã¼ãããã使ãã¾ã "
#: ../raster/r.cost/main.c:133
@@ -4851,8 +4663,7 @@
#: ../raster/r.grow2/main.c:130
msgid "Generates a raster map layer with contiguous areas grown by one cell."
-msgstr ""
-"ä¸ã¤ã®ã»ã«ããæ¡å¤§ããè¿æ¥ã¨ãªã¢ãæã¤ã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ã使ãã¾ã "
+msgstr "ä¸ã¤ã®ã»ã«ããæ¡å¤§ããè¿æ¥ã¨ãªã¢ãæã¤ã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ã使ãã¾ã "
#: ../raster/r.grow2/main.c:141
msgid "Radius of buffer in raster cells"
@@ -4961,21 +4772,16 @@
msgstr "æ¨é« (æ¨é«ãããã®æå®ç¡ãã®å ´å) "
#: ../raster/r.out.vtk/parameters.c:66
-msgid ""
-"Create VTK point data instead of VTK cell data (if no elevation map is given)"
-msgstr ""
-"VTK ãã¤ã³ããã¼ã¿ã VTK ã»ã«ãã¼ã¿ã®ä»£ããã«ä½æï¼æ¨é«ãããããªãå ´åï¼"
+msgid "Create VTK point data instead of VTK cell data (if no elevation map is given)"
+msgstr "VTK ãã¤ã³ããã¼ã¿ã VTK ã»ã«ãã¼ã¿ã®ä»£ããã«ä½æï¼æ¨é«ãããããªãå ´åï¼"
#: ../raster/r.out.vtk/parameters.c:76
-msgid ""
-"Three (r,g,b) raster maps to create rgb values [redmap,greenmap,bluemap]"
-msgstr ""
-"RGB å¤ [redmap,greenmap,bluemap] ã使ããããã®ï¼ã¤ã®ã©ã¹ã¿ã¼ããã (r,g,b)"
+msgid "Three (r,g,b) raster maps to create rgb values [redmap,greenmap,bluemap]"
+msgstr "RGB å¤ [redmap,greenmap,bluemap] ã使ããããã®ï¼ã¤ã®ã©ã¹ã¿ã¼ããã (r,g,b)"
#: ../raster/r.out.vtk/parameters.c:86
msgid "Three (x,y,z) raster maps to create vector values [xmap,ymap,zmap]"
-msgstr ""
-"ãã¯ãã«å¤ [xmap,ymap,zmap] ã使ããããã®ï¼ã¤ã®ã©ã¹ã¿ã¼ããã (x,y,z) "
+msgstr "ãã¯ãã«å¤ [xmap,ymap,zmap] ã使ããããã®ï¼ã¤ã®ã©ã¹ã¿ã¼ããã (x,y,z) "
#: ../raster/r.out.vtk/parameters.c:111
msgid "Use structured grid for elevation (not recommended)"
@@ -4986,8 +4792,7 @@
msgstr "ãã©ã¤ã¢ã³ã°ã«ã¹ãã©ã¤ãã®ããªãã¼ã¿ãæ¨é«ã®ã°ãªãã使ã«ä½¿ç¨"
#: ../raster/r.out.vtk/parameters.c:123
-msgid ""
-"Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
+msgid "Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
msgstr "æé«ç¹ã®ããªãã¼ã¿ãæ¨é«ã®ã°ãªããã®ä½æã«ä½¿ç¨ (vtkDelauny2D ãä½µç¨) "
#: ../raster/r.out.vtk/parameters.c:129
@@ -5010,8 +4815,7 @@
#: ../raster/r.out.vtk/main.c:109
msgid "Cannot create vector data, please provide three maps [x,y,z]"
-msgstr ""
-"ãã¯ãã«ãã¼ã¿ã使ã§ãã¾ãã, ï¼ã¤ã®ããã [x,y,z] ãç¨æãã¦ãã ãã"
+msgstr "ãã¯ãã«ãã¼ã¿ã使ã§ãã¾ãã, ï¼ã¤ã®ããã [x,y,z] ãç¨æãã¦ãã ãã"
#: ../raster/r.out.vtk/main.c:149
msgid "Converts raster maps into the VTK-Ascii format"
@@ -5029,20 +4833,15 @@
#: ../raster/r.out.vtk/main.c:334
msgid "Wrong RGB maps. Maps should have the same type! RGB output not added!"
-msgstr ""
-"䏿£ãª RGB ãããã§ãï¼ ãããã¯åãã¿ã¤ãã§ãªãã¦ãªããã¾ããï¼ RGB åºåã¯è¿½"
-"å ããã¾ããï¼"
+msgstr "䏿£ãª RGB ãããã§ãï¼ ãããã¯åãã¿ã¤ãã§ãªãã¦ãªããã¾ããï¼ RGB åºåã¯è¿½å ããã¾ããï¼"
#: ../raster/r.out.vtk/main.c:371
msgid "Writing VTK Vector Data\n"
msgstr "VTK ãã¯ãã«ãã¼ã¿ãæ¸ãè¾¼ã¿ä¸\n"
#: ../raster/r.out.vtk/main.c:381
-msgid ""
-"Wrong vector maps. Maps should have the same type! Vector output not added!"
-msgstr ""
-"䏿£ãªãã¯ãã«ãããã§ãï¼ãããã¯åãã¿ã¤ãã§ãªãã¦ã¯ããã¾ããï¼ ãã¯ãã«ã®"
-"åºåã¯è¿½å ããã¾ããï¼"
+msgid "Wrong vector maps. Maps should have the same type! Vector output not added!"
+msgstr "䏿£ãªãã¯ãã«ãããã§ãï¼ãããã¯åãã¿ã¤ãã§ãªãã¦ã¯ããã¾ããï¼ ãã¯ãã«ã®åºåã¯è¿½å ããã¾ããï¼"
#: ../raster/r.out.vtk/main.c:393
msgid "Error closing VTK-ASCII file"
@@ -5243,11 +5042,8 @@
msgstr "ã©ã¹ã¿ã¼ï¼åãµã³ããªã³ã°"
#: ../raster/r.rescale.eq/main.c:54
-msgid ""
-"Rescales histogram equalized the range of category values in a raster map "
-"layer."
-msgstr ""
-"ãã¹ãã°ã©ã ãã©ã¹ã¿ã¼ãããã®ã¬ã¤ã¤ã¼ã®ã«ãã´ãªã¼å¤ã®ç¯å²ã¨ä¸è´ããã "
+msgid "Rescales histogram equalized the range of category values in a raster map layer."
+msgstr "ãã¹ãã°ã©ã ãã©ã¹ã¿ã¼ãããã®ã¬ã¤ã¤ã¼ã®ã«ãã´ãªã¼å¤ã®ç¯å²ã¨ä¸è´ããã "
#: ../raster/r.rescale.eq/main.c:64 ../raster/r.rescale/main.c:61
msgid "The name of the raster map to be rescaled"
@@ -5326,10 +5122,8 @@
msgstr "ãã¿ã¼ã³ãããã¯ãã¤ããª(0/1)ã»ã«ãããã§ãªããã°ããã¾ãã "
#: ../raster/r.los/main.c:245
-msgid ""
-"Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"
-msgstr ""
-"ç¾å¨ã®æ¥å使
å ±ã®åå¾ã§åé¡ãçºçãã¾ãããåç (6370997.0) ã使ç¨ãã¾ãã "
+msgid "Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"
+msgstr "ç¾å¨ã®æ¥å使
#: ../raster/r.los/main.c:250
#, c-format
@@ -5349,9 +5143,7 @@
msgstr "夿ã使ä¸ã«ã¨ã©ã¼"
#: ../raster/r.his/main.c:65
-msgid ""
-"Generates red, green and blue raster map layers combining hue, intensity and "
-"saturation (HIS) values from user-specified input raster map layers."
+msgid "Generates red, green and blue raster map layers combining hue, intensity and saturation (HIS) values from user-specified input raster map layers."
msgstr "ã©ã¹ã¿ã¼ãããã®Rï¼Gï¼Bã¬ã¤ã¤ã¼ãè²ç¸/ç
§åº¦/彩度ã«å¯¾å¿ããã¦åæãã¾ã"
#: ../raster/r.his/main.c:74 ../display/d.his/main.c:76
@@ -5415,9 +5207,7 @@
msgstr "ã©ã¹ã¿ã¼ããããã¡"
#: ../raster/r.buffer/main.c:71
-msgid ""
-"Creates a raster map layer showing buffer zones surrounding cells that "
-"contain non-NULL category values."
+msgid "Creates a raster map layer showing buffer zones surrounding cells that contain non-NULL category values."
msgstr "ãããã¡ã¼ã¾ã¼ã³ãç¤ºãæ°ããã©ã¹ã¿ã¼ãããã使ãã¾ã "
#: ../raster/r.buffer/main.c:83
@@ -5519,11 +5309,7 @@
msgstr "æå¤§ã»æå°åå¾ã®ã©ã¡ãããæå®ãã¦ãã ããï¼ãã¤ããªãã©ãã°ã®å ´åï¼"
#: ../raster/r.walk/main.c:176
-msgid ""
-"Outputs a raster map layer showing the anisotropic cumulative cost of moving "
-"between different geographic locations on an input elevation raster map "
-"layer whose cell category values represent elevation combined with an input "
-"raster map layer whose cell values represent friction cost."
+msgid "Outputs a raster map layer showing the anisotropic cumulative cost of moving between different geographic locations on an input elevation raster map layer whose cell category values represent elevation combined with an input raster map layer whose cell values represent friction cost."
#: ../raster/r.walk/main.c:188
@@ -5572,8 +5358,7 @@
#: ../raster/r.walk/main.c:294
msgid "Slope factor determines travel energy cost per height step"
-msgstr ""
-"徿ãã¡ã¯ã¿ã¼ã¯é«ãã¹ããããããã®ãã©ãã«ã¨ãã«ã®ã¼ã³ã¹ããæ±ºå®ãã¾ã "
+msgstr "徿ãã¡ã¯ã¿ã¼ã¯é«ãã¹ããããããã®ãã©ãã«ã¨ãã«ã®ã¼ã³ã¹ããæ±ºå®ãã¾ã "
#: ../raster/r.walk/main.c:303
msgid "Keep null values in output map"
@@ -5630,8 +5415,7 @@
#: ../raster/r.walk/main.c:495
msgid "Warning: assigning negative cost to null cell. Null cells excluded."
-msgstr ""
-"è¦åï¼NULLå¤ã»ã«ã«è² ã®å¤ãå²å½ããã¦ãã¾ããNULLå¤ã»ã«ã¯é¤å¤ããã¾ãã "
+msgstr "è¦åï¼NULLå¤ã»ã«ã«è² ã®å¤ãå²å½ããã¦ãã¾ããNULLå¤ã»ã«ã¯é¤å¤ããã¾ãã "
#: ../raster/r.walk/main.c:556 ../raster/r.walk/main.c:558
#, c-format
@@ -5858,12 +5642,8 @@
msgstr "åä¸äº¤å·®ã«é¢ããã¨ã©ã¼ã¡ãã»ã¼ã¸ãåºåããªã "
#: ../raster/r.contour/main.c:147
-msgid ""
-"The '-q' and '-n' flag is superseded and will be removed in future. Please "
-"use '--quiet' instead."
-msgstr ""
-"-q' ãã©ãã°ã'-n' ãã©ãã°ã¯å°æ¥å»æ¢ããã¾ãã'--quiet' ãã©ãã°ã使ç¨ãã¦ã"
-"ã ããã "
+msgid "The '-q' and '-n' flag is superseded and will be removed in future. Please use '--quiet' instead."
+msgstr "-q' ãã©ãã°ã'-n' ãã©ãã°ã¯å°æ¥å»æ¢ããã¾ãã'--quiet' ãã©ãã°ã使ç¨ãã¦ãã ããã "
#: ../raster/r.contour/main.c:152
msgid "Neither \"levels\" nor \"step\" parameter specified."
@@ -5958,11 +5738,8 @@
msgstr "ã©ã¹ã¿ã¼ãã·ãªã¼ãº"
#: ../raster/r.series/main.c:135
-msgid ""
-"Makes each output cell value a function of the values assigned to the "
-"corresponding cells in the input raster map layers."
-msgstr ""
-"ååºåã»ã«å¤ããå
¥åãããã®å¯¾å¿ã»ã«ã«å²ãå½ã¦ãããå¤ã®é¢æ°ã«å¤æãã¾ã"
+msgid "Makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers."
+msgstr "ååºåã»ã«å¤ããå
#: ../raster/r.series/main.c:149
msgid "Aggregate operation"
@@ -6110,9 +5887,7 @@
msgstr "ã©ã¹ã¿ã¼ãã¤ã³ãã¼ããLIDAR"
#: ../raster/r.in.xyz/main.c:161
-msgid ""
-"Create a raster map from an assemblage of many coordinates using univariate "
-"statistics."
+msgid "Create a raster map from an assemblage of many coordinates using univariate statistics."
msgstr "ä¸å¤éã®çµ±è¨ã§ï¼å¤ãã®åº§æ¨ã®éåããã©ã¹ã¿ãããã使"
#: ../raster/r.in.xyz/main.c:165
@@ -6185,11 +5960,8 @@
msgstr "pth ã®ç¾åçå¤"
#: ../raster/r.in.xyz/main.c:251
-msgid ""
-"Discard <trim> percent of the smallest and <trim> percent of the largest "
-"observations"
-msgstr ""
-"観測ãã <trim> ãã¼ã»ã³ãï¼æå°å´ï¼ããã³ <trim> ãã¼ã»ã³ãï¼æå¤§å´ï¼ ã廿£"
+msgid "Discard <trim> percent of the smallest and <trim> percent of the largest observations"
+msgstr "観測ãã <trim> ãã¼ã»ã³ãï¼æå°å´ï¼ããã³ <trim> ãã¼ã»ã³ãï¼æå¤§å´ï¼ ã廿£"
#: ../raster/r.in.xyz/main.c:256
msgid "Scan data file for extent then exit"
@@ -6229,8 +6001,7 @@
msgstr "æå®ããããã¡ã¤ã« <%s> ãéãã¾ãã"
#: ../raster/r.in.xyz/main.c:477
-msgid ""
-"If input is not from a file it is only possible to perform a single pass."
+msgid "If input is not from a file it is only possible to perform a single pass."
msgstr "ãã¡ã¤ã«ããã®å
¥åã§ãªãå ´åï¼åä¸ãã¹ã ããå¯è½ã§ã"
#: ../raster/r.in.xyz/main.c:483
@@ -6250,12 +6021,10 @@
#: ../raster/r.in.xyz/main.c:1103 ../raster/r.in.xyz/main.c:1111
#, c-format
msgid ""
-"Not enough data columns. Incorrect delimiter or column number? Found the "
-"following character(s) in row %lu:\n"
+"Not enough data columns. Incorrect delimiter or column number? Found the following character(s) in row %lu:\n"
"[%s]"
msgstr ""
-"ãã¼ã¿ã®åæ°ãä¸ååã§ããåºåãæåãåæ°ã®ééãï¼è¡ %lu ã§æ¬¡ã®æåãè¦ã¤ã"
-"ã¦ãã ãã:\n"
+"ãã¼ã¿ã®åæ°ãä¸ååã§ããåºåãæåãåæ°ã®ééãï¼è¡ %lu ã§æ¬¡ã®æåãè¦ã¤ãã¦ãã ãã:\n"
"[%s] "
#: ../raster/r.in.xyz/main.c:603 ../raster/r.in.xyz/main.c:1107
@@ -6305,8 +6074,7 @@
msgstr "ã©ã¹ã¿ã¼ãè¤åç©"
#: ../raster/r.composite/main.c:74
-msgid ""
-"Combines red, green and blue raster maps into a single composite raster map."
+msgid "Combines red, green and blue raster maps into a single composite raster map."
msgstr "赤ãç·ãéã®ã©ã¹ã¿ã¼ããããä¸ã¤ã®ã©ã¹ã¿ã¼ãããã«åæãã¾ã"
#: ../raster/r.composite/main.c:88 ../raster/r.out.ppm3/main.c:65
@@ -6354,12 +6122,8 @@
msgstr "ã©ã¹ã¿ã¼å¤"
#: ../raster/r.volume/main.c:59
-msgid ""
-"Calculates the volume of data \"clumps\", and (optionally) produces a GRASS "
-"vector points map containing the calculated centroids of these clumps."
-msgstr ""
-"ãã¼ã¿ \"clumps\"ã®å®¹éãè¨ç®ãã¾ã, ããã¦ãªãã·ã§ã³ã§ãããã®ã¯ã©ã³ãã®äºæ¸¬"
-"ãããã»ã³ããã¤ããå«ãGRASSãã¯ãã«ãã¤ã³ãããããçæãã¾ã."
+msgid "Calculates the volume of data \"clumps\", and (optionally) produces a GRASS vector points map containing the calculated centroids of these clumps."
+msgstr "ãã¼ã¿ \"clumps\"ã®å®¹éãè¨ç®ãã¾ã, ããã¦ãªãã·ã§ã³ã§ãããã®ã¯ã©ã³ãã®äºæ¸¬ãããã»ã³ããã¤ããå«ãGRASSãã¯ãã«ãã¤ã³ãããããçæãã¾ã."
#: ../raster/r.volume/main.c:69
msgid "Existing raster map representing data that will be summed within clumps"
@@ -6482,18 +6246,13 @@
msgstr "çè¡åã使ã. ã¤ã³ã¿ã©ã¯ãã£ããªã½ã«ãã¼ã§ã®ã¿ä½¿ç¨ã§ãã¾ã"
#: ../raster/r.gwflow/main.c:191
-msgid ""
-"Numerical calculation program for transient, confined and unconfined "
-"groundwater flow in two dimensions."
-msgstr ""
-"äºæ¬¡å
ã§ã®éå®å¸¸å°ä¸æ°´ã被å§å°ä¸æ°´ãä¸å§å°ä¸æ°´ããè¨ç®ããæ°å¤è¨ç®ããã°ã©ã "
+msgid "Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions."
+msgstr "äºæ¬¡å
#: ../raster/r.gwflow/main.c:201 ../raster/r.topidx/main.c:53
#, c-format
msgid "Lat/Long location is not supported by %s. Please reproject map first."
-msgstr ""
-"緯度/çµåº¦ãã±ã¼ã·ã§ã³ã¯ %s ã«ãã£ã¦ãµãã¼ãããã¦ãã¾ãã. ã¾ãããããåæå½±"
-"ãã¦ãã ãã."
+msgstr "緯度/çµåº¦ãã±ã¼ã·ã§ã³ã¯ %s ã«ãã£ã¦ãµãã¼ãããã¦ãã¾ãã. ã¾ãããããåæå½±ãã¦ãã ãã."
#: ../raster/r.gwflow/main.c:216
msgid "Please provide river_head, river_leak and river_bed maps"
@@ -6519,9 +6278,7 @@
#: ../raster/r.topidx/main.c:39
msgid "Creates topographic index map from elevation raster map."
-msgstr ""
-"æ¨é«ãããããããã°ã©ãã£ãã¯ã¤ã³ããã¯ã¹ [ln(a/tan(beta))] ããã ã使ã"
-"ã¾ã. "
+msgstr "æ¨é«ãããããããã°ã©ãã£ãã¯ã¤ã³ããã¯ã¹ [ln(a/tan(beta))] ããã ã使ãã¾ã. "
#: ../raster/r.topidx/main.c:42
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:3
@@ -6542,13 +6299,8 @@
#: ../raster/r.topidx/file_io.c:32
#, c-format
-msgid ""
-"Current region resolution [%.2fx%.2f] lower than input map resolution [%.2fx"
-"%.2f]! Needs to be at least identical or the current region resolution lower "
-"than the input map resolution"
-msgstr ""
-"ç¾é åã®è§£å度 [%.2fx%.2f] ã¯å
¥åãããè§£å度 [%.2fx%.2f] ããä½ãã§ã! å°ãª"
-"ãã¨ãåããç¾é ã®è§£å度ã¯å
¥åãããè§£å度ããä½ãå¿
è¦ãããã¾ã"
+msgid "Current region resolution [%.2fx%.2f] lower than input map resolution [%.2fx%.2f]! Needs to be at least identical or the current region resolution lower than the input map resolution"
+msgstr "ç¾é åã®è§£å度 [%.2fx%.2f] ã¯å
¥åãããè§£å度 [%.2fx%.2f] ããä½ãã§ã! å°ãªãã¨ãåããç¾é ã®è§£å度ã¯å
¥åãããè§£å度ããä½ãå¿
è¦ãããã¾ã"
#: ../raster/r.topidx/file_io.c:36
msgid "Reading elevation map..."
@@ -6559,12 +6311,8 @@
msgstr "ããã°ã©ãã£ã¼ã®ã¤ã³ããã¯ã¹ããããæ¸ãè¾¼ãã§ãã¾ã..."
#: ../raster/r.in.arc/main.c:61
-msgid ""
-"Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster "
-"map layer."
-msgstr ""
-"ESRI ARC/INFO ascii ã©ã¹ã¿ã¼ãã¡ã¤ã« (GRID) ã (ãã¤ããª) ã©ã¹ã¿ã¼ãããã¬ã¤"
-"ã¤ã¼ã«å¤æãã¾ã."
+msgid "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster map layer."
+msgstr "ESRI ARC/INFO ascii ã©ã¹ã¿ã¼ãã¡ã¤ã« (GRID) ã (ãã¤ããª) ã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ã«å¤æãã¾ã."
#: ../raster/r.in.arc/main.c:69
msgid "ARC/INFO ASCII raster file (GRID) to be imported"
@@ -6645,12 +6393,8 @@
msgstr "åæ°´çãã¹ %d "
#: ../raster/r.fill.dir/main.c:86
-msgid ""
-"Filters and generates a depressionless elevation map and a flow direction "
-"map from a given elevation raster map."
-msgstr ""
-"æå®ãããæ¨é«ã¬ã¤ã¤ã¼ããã£ã«ã¿ãªã³ã°ãï¼å¹ã¿ã®ãªãæ¨é«ãããã¨æµãæ¹åãã"
-"ãã使"
+msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map."
+msgstr "æå®ãããæ¨é«ã¬ã¤ã¤ã¼ããã£ã«ã¿ãªã³ã°ãï¼å¹ã¿ã®ãªãæ¨é«ãããã¨æµãæ¹åãããã使"
#: ../raster/r.fill.dir/main.c:91
msgid "Name of existing raster map containing elevation surface"
@@ -6757,9 +6501,7 @@
#: ../raster/r.mfilter/main.c:104 ../raster/r.mfilter.fp/main.c:109
#: ../raster/r.kappa/main.c:133 ../raster/r.out.ppm/main.c:81
-msgid ""
-"quiet' instead"
+msgid "The '-q' flag is superseded and will be removed in future. Please use '--quiet' instead"
#: ../raster/r.mfilter/main.c:133 ../raster/r.mfilter.fp/main.c:138
@@ -6883,12 +6625,8 @@
msgstr "ã©ã¹ã¿ã¼ï¼çµ±è¨ï¼ååé¡"
#: ../raster/r.clump/main.c:51
-msgid ""
-"Recategorizes data in a raster map by grouping cells that form physically "
-"discrete areas into unique categories."
-msgstr ""
-"ç©ççã«åããããã¨ãªã¢ã®ã»ã«ãä¸ã¤ã®ã«ãã´ãªã¼ã«ã°ã«ã¼ãåãã¦ï¼ã©ã¹ã¿ã¼"
-"ãããå
ã®ãã¼ã¿ãååé¡"
+msgid "Recategorizes data in a raster map by grouping cells that form physically discrete areas into unique categories."
+msgstr "ç©ççã«åããããã¨ãªã¢ã®ã»ã«ãä¸ã¤ã®ã«ãã´ãªã¼ã«ã°ã«ã¼ãåãã¦ï¼ã©ã¹ã¿ã¼ãããå
ã®ãã¼ã¿ãååé¡"
#: ../raster/r.clump/main.c:63
msgid "Title, in quotes"
@@ -6981,19 +6719,12 @@
msgstr "ã©ã¹ã¿ã¼ããããæå®ããã¦ãã¾ãã"
#: ../raster/r.colors/main.c:281
-msgid ""
-"One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must be "
-"specified!"
-msgstr ""
-"\"-i\" ã¾ã㯠\"-r\" ãã©ãã°ãã\"color\"ã\"rast\"ã\"rules\" ãªãã·ã§ã³ã®"
-"æå®ãå¿
è¦ã§ã"
+msgid "One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must be specified!"
+msgstr "\"-i\" ã¾ã㯠\"-r\" ãã©ãã°ãã\"color\"ã\"rast\"ã\"rules\" ãªãã·ã§ã³ã®æå®ãå¿
è¦ã§ã"
#: ../raster/r.colors/main.c:284
-msgid ""
-"Interactive mode is incompatible with \"color\", \"rules\", and \"raster\" "
-"options"
-msgstr ""
-"対話ã¢ã¼ãã§ã¯ \"color\"ã\"rules\"ã\"raster\"ããªãã·ã§ã³ã¯ä½¿ãã¾ãã"
+msgid "Interactive mode is incompatible with \"color\", \"rules\", and \"raster\" options"
+msgstr "対話ã¢ã¼ãã§ã¯ \"color\"ã\"rules\"ã\"raster\"ããªãã·ã§ã³ã¯ä½¿ãã¾ãã"
#: ../raster/r.colors/main.c:291
msgid "\"color\", \"rules\", and \"raster\" options are mutually exclusive"
@@ -7019,20 +6750,15 @@
#: ../raster/r.colors/main.c:344
msgid "Color table 'random' is not supported for floating point raster map"
-msgstr ""
-"ã«ã©ã¼ãã¼ãã«ãã©ã³ãã ãã¯ï¼æµ®åå°æ°ã®ã©ã¹ã¿ã¼ãããã§ã¯ãµãã¼ãããã¦ãã¾"
-"ãã"
+msgstr "ã«ã©ã¼ãã¼ãã«ãã©ã³ãã ãã¯ï¼æµ®åå°æ°ã®ã©ã¹ã¿ã¼ãããã§ã¯ãµãã¼ãããã¦ãã¾ãã"
#: ../raster/r.colors/main.c:349
msgid "Color table 'grey.eq' is not supported for floating point raster map"
-msgstr ""
-"ã«ã©ã¼ãã¼ãã«ãã°ã¬ã¤ã¹ã±ã¼ã«ãã¯æµ®åå°æ°ã®ã©ã¹ã¿ã¼ãããã§ã¯ãµãã¼ãããã¦"
-"ãã¾ãã"
+msgstr "ã«ã©ã¼ãã¼ãã«ãã°ã¬ã¤ã¹ã±ã¼ã«ãã¯æµ®åå°æ°ã®ã©ã¹ã¿ã¼ãããã§ã¯ãµãã¼ãããã¦ãã¾ãã"
#: ../raster/r.colors/main.c:356
msgid "Color table 'grey.log' is not supported for floating point raster map"
-msgstr ""
-"è²ãã¼ãã« 'grey.log' ã¯æµ®åå°æ°ç¹å¤ã©ã¹ã¿ã¼ãããã§ã¯ãµãã¼ãããã¦ãã¾ãã"
+msgstr "è²ãã¼ãã« 'grey.log' ã¯æµ®åå°æ°ç¹å¤ã©ã¹ã¿ã¼ãããã§ã¯ãµãã¼ãããã¦ãã¾ãã"
#: ../raster/r.colors/main.c:369
#, c-format
@@ -7151,11 +6877,8 @@
msgstr "åºåããããããã¾ãã"
#: ../raster/r.to.rast3/main.c:222 ../raster/r.to.rast3elev/main.c:462
-msgid ""
-"The 2d and 3d region settings are different. I will use the g3d settings to "
-"adjust the 2d region."
-msgstr ""
+msgid "The 2d and 3d region settings are different. I will use the g3d settings to adjust the 2d region."
#: ../raster/r.to.rast3/main.c:260
msgid "Cell file not found"
@@ -7168,8 +6891,7 @@
#: ../raster/r.to.rast3/main.c:281
msgid "Input maps have to be from the same type. CELL, FCELL or DCELL!"
-msgstr ""
-"å
¥åãããã¯åãåããã§ãªããã°ã°ãã¾ãã. CELL, FCELL ã¾ã㯠DCELL! "
+msgstr "å
#: ../raster/r.to.rast3/main.c:285 ../raster/r.to.rast3elev/main.c:498
msgid "Creating 3D raster map"
@@ -7208,18 +6930,12 @@
#: ../raster/r.sun/main.c:417
-msgid ""
-"Mode 1: instantaneous solar incidence angle & irradiance given a set local "
-"time"
+msgid "Mode 1: instantaneous solar incidence angle & irradiance given a set local time"
msgstr "ã¢ã¼ã 1: ç¬éã®å¤ªé½å
¥å°è§ã¨ç
§åº¦ããã¼ã«ã«ã¿ã¤ã ããåå¾"
#: ../raster/r.sun/main.c:472 ../raster/r.horizon/main.c:479
-msgid ""
-"Can't get projection info of current location: please set latitude via 'lat' "
-"or 'latin' option!"
-msgstr ""
-"ç¾å¨å°ã®æå½±æ
å ±ãåå¾ã§ãã¾ããã'lat' ã¾ã㯠'latin' ãªãã·ã§ã³ã§ç·¯åº¦ãæå®"
-"ãã¦ãã ãã"
+msgid "Can't get projection info of current location: please set latitude via 'lat' or 'latin' option!"
+msgstr "ç¾å¨å°ã®æå½±æ
å ±ãåå¾ã§ãã¾ããã'lat' ã¾ã㯠'latin' ãªãã·ã§ã³ã§ç·¯åº¦ãæå®ãã¦ãã ãã"
#: ../raster/r.sun/main.c:527
#, c-format
@@ -7307,29 +7023,16 @@
msgstr "ã©ã¹ã¿ã¼ï¼ å°å½¢æ§é è§£æï¼ãããã¤ã³ããã¯ã¹ "
#: ../raster/r.le/r.le.patch/main.c:49
-msgid ""
-"Calculates attribute, patch size, core (interior) size, shape, fractal "
-"dimension, and perimeter measures for sets of patches in a landscape."
-msgstr ""
-"ã©ã³ãã¹ã±ã¼ãå
ã®ãããã»ããã®å±æ§ãããããµã¤ãºãã³ã¢ãµã¤ãºãã·ã§ã¤ããã"
-"ã©ã¯ã¿ã«æ¬¡å
ãå¢çã¡ã¸ã£ã¼ãè¨ç®ãã"
+msgid "Calculates attribute, patch size, core (interior) size, shape, fractal dimension, and perimeter measures for sets of patches in a landscape."
+msgstr "ã©ã³ãã¹ã±ã¼ãå
ã®ãããã»ããã®å±æ§ãããããµã¤ãºãã³ã¢ãµã¤ãºãã·ã§ã¤ãããã©ã¯ã¿ã«æ¬¡å
#: ../raster/r.le/r.le.trace/main.c:59
-msgid ""
-"Displays the boundary of each r.le patch and shows how the boundary is "
-"traced, displays the attribute, size, perimeter and shape indices for each "
-"patch and saves the data in an output file."
-msgstr ""
-"r.le åãããã®å¢çç·ãå¢çç·ã®ãã¬ã¼ã¹æ¹æ³ã屿§ããµã¤ãºããã©ã¡ã¼ã¿ãã·ã§ã¼"
-"ãã¤ã³ããã¯ã¹ã表示ãåºåãã¡ã¤ã«ã«ä¿å"
+msgid "Displays the boundary of each r.le patch and shows how the boundary is traced, displays the attribute, size, perimeter and shape indices for each patch and saves the data in an output file."
+msgstr "r.le åãããã®å¢çç·ãå¢çç·ã®ãã¬ã¼ã¹æ¹æ³ã屿§ããµã¤ãºããã©ã¡ã¼ã¿ãã·ã§ã¼ãã¤ã³ããã¯ã¹ã表示ãåºåãã¡ã¤ã«ã«ä¿å"
#: ../raster/r.le/r.le.setup/main.c:63
-msgid ""
-"Interactive tool used to setup the sampling and analysis framework that will "
-"be used by the other r.le programs."
-msgstr ""
-"ä»ã® r.le ããã°ã©ã ã§ä½¿ããããµã³ããªã³ã°ã¨åæã®ãã¬ã¼ã ã¯ã¼ã¯ãè¨å®ããã¤"
-"ã³ã¿ã©ã¯ãã£ããªãã¼ã«"
+msgid "Interactive tool used to setup the sampling and analysis framework that will be used by the other r.le programs."
+msgstr "ä»ã® r.le ããã°ã©ã ã§ä½¿ããããµã³ããªã³ã°ã¨åæã®ãã¬ã¼ã ã¯ã¼ã¯ãè¨å®ããã¤ã³ã¿ã©ã¯ãã£ããªãã¼ã«"
#: ../raster/r.le/r.le.setup/main.c:67
msgid "Raster map to use to setup sampling"
@@ -7344,9 +7047,7 @@
msgstr "ãã¯ãã«ãèªåãã§ãã¾ãã "
#: ../raster/r.le/r.le.pixel/main.c:47
-msgid ""
-"Contains a set of measures for attributes, diversity, texture, "
-"juxtaposition, and edge."
+msgid "Contains a set of measures for attributes, diversity, texture, juxtaposition, and edge."
msgstr "屿§ããã¤ãã¼ã·ãã£ããã¯ã¹ãã£ã並置ãã¨ãã¸ã®çºã®ã¡ã¸ã£ã¼ãå«ã"
#: ../raster/r.digit/get_label.c:31
@@ -7364,12 +7065,8 @@
msgstr "調ã¹ã¾ãã? "
#: ../raster/r.digit/main.c:47
-msgid ""
-"Interactive tool used to draw and save vector features on a graphics monitor "
-"using a pointing device (mouse) and save to a raster map."
-msgstr ""
-"ä½ç½®æç¤ºè£
ç½® ï¼ãã¦ã¹ï¼ã使ç¨ãã©ã¹ã¿ã¼ãããã«ä¿åããã°ã©ãã£ãã¯ã¢ãã¿ã¼ã®"
-"ãã¯ãã«ãã£ã¼ãã£ã®ä½æã¨ä¿åã«ä½¿ç¨ãããã¤ã³ã¿ã©ã¯ãã£ããã¼ã«"
+msgid "Interactive tool used to draw and save vector features on a graphics monitor using a pointing device (mouse) and save to a raster map."
+msgstr "ä½ç½®æç¤ºè£
ç½® ï¼ãã¦ã¹ï¼ã使ç¨ãã©ã¹ã¿ã¼ãããã«ä¿åããã°ã©ãã£ãã¯ã¢ãã¿ã¼ã®ãã¯ãã«ãã£ã¼ãã£ã®ä½æã¨ä¿åã«ä½¿ç¨ãããã¤ã³ã¿ã©ã¯ãã£ããã¼ã«"
#: ../raster/r.digit/main.c:56 ../vector/v.digit/main.c:117
msgid "Display commands to be used for canvas backdrop (separated by ';')"
@@ -7439,12 +7136,8 @@
msgstr "使ç¨ããã¾ããï¼ äºææ§ãä¿æã®ããï¼ããã¯å°æ¥åé¤ããã¾ã"
#: ../raster/r.surf.contour/main.c:77
-msgid ""
-"Invoke slow, but memory frugal operation (generally not needed, will be "
-"removed in future)"
-msgstr ""
-"å¦çãé
ããªãã¾ãï¼ ãããã¡ã¢ãªã¼ãç¯ç´ããæ¼ç®ã§ã (é常ã¯å¿
è¦ãªãããï¼å°"
-"æ¥åé¤ããã¾ã) "
+msgid "Invoke slow, but memory frugal operation (generally not needed, will be removed in future)"
+msgstr "å¦çãé
è¦ãªãããï¼å°æ¥åé¤ããã¾ã) "
#: ../raster/r.in.bin/main.c:49 ../raster/r.in.bin/main.c:58
#: ../raster/r.in.bin/main.c:510
@@ -7465,7 +7158,7 @@
#: ../raster/r.in.bin/main.c:250
msgid "Signed data (two's complement)"
-msgstr ""
+msgstr "ç½²åæ¸ã¿ãã¼ã¿(2ã®è£æ°)"
#: ../raster/r.in.bin/main.c:251 ../raster/r.in.bin/main.c:256
#: ../raster/r.in.bin/main.c:285 ../raster/r.in.bin/main.c:346
@@ -7627,11 +7320,8 @@
#: ../raster/r.in.bin/main.c:464
#, c-format
-msgid ""
-"East-West (ewres: %f) and North-South (nwres: %f) resolution differ "
-"significantly. Did you assign east= and west= correctly?"
-msgstr ""
-"æ±è¥¿ (ewres: %f) 㨠åå (nwres: %f)ã® è§£å度ãä¸é©åã§ã. é©åãªå¤ã§ãã? "
+msgid "East-West (ewres: %f) and North-South (nwres: %f) resolution differ significantly. Did you assign east= and west= correctly?"
+msgstr "æ±è¥¿ (ewres: %f) 㨠åå (nwres: %f)ã® è§£å度ãä¸é©åã§ã. é©åãªå¤ã§ãã? "
#: ../raster/r.in.bin/main.c:487
msgid "File Size %"
@@ -7652,11 +7342,8 @@
msgstr "ã©ãã«ã®æ¸ãè¾¼ã¿ã«ãã¡ã¤ã« <%s> ãéãã¾ãã"
#: ../raster/r.kappa/main.c:69
-msgid ""
-"Calculate error matrix and kappa parameter for accuracy assessment of "
-"classification result."
-msgstr ""
-"åé¡çµæã®ç²¾åº¦æ»å®ã®ããã¨ã©ã¼ãããªãã¯ã¹ã¨kappaãã©ã¡ã¼ã¿ãç®å®ãã¾ã"
+msgid "Calculate error matrix and kappa parameter for accuracy assessment of classification result."
+msgstr "åé¡çµæã®ç²¾åº¦æ»å®ã®ããã¨ã©ã¼ãããªãã¯ã¹ã¨kappaãã©ã¡ã¼ã¿ãç®å®ãã¾ã"
#: ../raster/r.kappa/main.c:75
msgid "Name of raster map containing classification result"
@@ -7698,15 +7385,12 @@
#: ../raster/r.kappa/calc_kappa.c:32
#, c-format
msgid "Cannot open file <%s> to write kappa and relevant parameters"
-msgstr ""
-"kappaããã¦é¢é£ãããã©ã¡ã¼ã¿ã¼ã®æ¸ãè¾¼ã¿ã«ãã¡ã¤ã«ãã¡ã¤ã« <%s> ãéãã¾ãã"
+msgstr "kappaããã¦é¢é£ãããã©ã¡ã¼ã¿ã¼ã®æ¸ãè¾¼ã¿ã«ãã¡ã¤ã«ãã¡ã¤ã« <%s> ãéãã¾ãã"
#: ../raster/r.kappa/prt_mat.c:39
#, c-format
msgid "Cannot open file <%s> to write cats and counts (error matrix)"
-msgstr ""
-"ã«ãã´ãªã¼ã¨ã«ã¦ã³ãã®æ¸ãè¾¼ã¿ã«ãã¡ã¤ã« <%s> ãéãã¾ãã(ã¨ã©ã¼ãããªãã¯"
-"ã¹) "
+msgstr "ã«ãã´ãªã¼ã¨ã«ã¦ã³ãã®æ¸ãè¾¼ã¿ã«ãã¡ã¤ã« <%s> ãéãã¾ãã(ã¨ã©ã¼ãããªãã¯ã¹) "
#: ../raster/r.out.png/r.out.png.c:110
msgid "raster, export, png"
@@ -7784,14 +7468,8 @@
msgstr "TIFFã¯ã¼ã«ããã¡ã¤ã«ãåºåã§ãã¾ãã"
#: ../raster/r.resamp.rst/main.c:158
-msgid ""
-"Reinterpolates and optionally computes topographic analysis from input "
-"raster map to a new raster map (possibly with different resolution) using "
-"regularized spline with tension and smoothing."
-msgstr ""
-"ãã³ã·ã§ã³ã¨å¹³æ»åã®æ£è¦åã¹ãã©ã¤ã³ã«ããåè£éã¨å°å½¢å¦çè§£æãè¡ãï¼å
¥å"
-"ï¼æå®ããï¼ã©ã¹ã¿ã¼ãããããæ°ããªã©ã¹ã¿ã¼ãããï¼ã§ããã°ç°ãªãè§£å度ï¼ã"
-"使"
+msgid "Reinterpolates and optionally computes topographic analysis from input raster map to a new raster map (possibly with different resolution) using regularized spline with tension and smoothing."
+msgstr "ãã³ã·ã§ã³ã¨å¹³æ»åã®æ£è¦åã¹ãã©ã¤ã³ã«ããåè£éã¨å°å½¢å¦çè§£æãè¡ãï¼å
¥åï¼æå®ããï¼ã©ã¹ã¿ã¼ãããããæ°ããªã©ã¹ã¿ã¼ãããï¼ã§ããã°ç°ãªãè§£å度ï¼ã使"
#: ../raster/r.resamp.rst/main.c:169
msgid "Desired east-west resolution"
@@ -8210,8 +7888,7 @@
msgstr "æå®ãããã±ã¼ã·ã§ã³ä¸ã®ãã¯ãã«ãããããªã¹ããã¦çµäº"
#: ../raster/r.proj.seg/main.c:220
-msgid ""
-"Print input map's bounds in the current projection and exit (shell style)"
+msgid "Print input map's bounds in the current projection and exit (shell style)"
msgstr "å
¨ã¦ã®ãããæ¥ç¶ãã©ã¡ã¼ã¿ã¼ãã·ã§ã«ã¹ã¯ãªããå½¢å¼ã«åºåãã¦çµäº"
#: ../raster/r.proj.seg/main.c:245 ../raster/r.proj/main.c:217
@@ -8275,8 +7952,7 @@
#: ../raster/r.proj.seg/main.c:302 ../raster/r.proj/main.c:267
#, c-format
msgid "Raster map <%s> in location <%s> in mapset <%s> not found"
-msgstr ""
-"ã©ã¹ã¿ã¼ããã <%s> ï¼ãã±ã¼ã·ã§ã³ <%s> ï¼ãããã»ãã <%s> ãè¦ã¤ããã¾ãã"
+msgstr "ã©ã¹ã¿ã¼ããã <%s> ï¼ãã±ã¼ã·ã§ã³ <%s> ï¼ãããã»ãã <%s> ãè¦ã¤ããã¾ãã"
#: ../raster/r.proj.seg/main.c:310 ../raster/r.proj/main.c:275
msgid "Unable to get projection info of input map"
@@ -8386,9 +8062,7 @@
#: ../raster/r.support.stats/check.c:87
#, c-format
msgid "Updating the number of categories for [%s]..."
-msgstr ""
-"Updating the number of categories for [%s] ã®ã«ãã´ãªã¼æ°ãã¢ãããã¼ããã¦ã"
-"ã¾ã... "
+msgstr "Updating the number of categories for [%s] ã®ã«ãã´ãªã¼æ°ãã¢ãããã¼ããã¦ãã¾ã... "
#: ../raster/r.support.stats/main.c:38
msgid "Update raster map statistics"
@@ -8465,12 +8139,8 @@
msgstr "è£éã«ç¨ããè¿åç¹ "
#: ../raster/r.random/main.c:53
-msgid ""
-"Creates a raster map layer and vector point map containing randomly located "
-"points."
-msgstr ""
-"ã©ã³ãã ã«é
ç½®ããããã¤ã³ããå«ããã¯ãã«ãã¤ã³ããããã¨ã©ã¹ã¿ã¼ãããã¬ã¤"
-"ã¤ã¼ã使ãã¾ã"
+msgid "Creates a raster map layer and vector point map containing randomly located points."
+msgstr "ã©ã³ãã ã«é
ç½®ããããã¤ã³ããå«ããã¯ãã«ãã¤ã³ããããã¨ã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ã使ãã¾ã"
#: ../raster/r.random/main.c:57 ../raster/r.water.outlet/main.c:55
#: ../raster/r.out.bin/main.c:289 ../imagery/i.zc/main.c:69
@@ -8555,21 +8225,12 @@
msgstr "ã©ã¹ã¿ã¼ãã¤ã³ãã¼ã"
#: ../raster/wildfire/r.spread/main.c:103
-msgid ""
-"Simulates elliptically anisotropic spread on a graphics window and generates "
-"a raster map of the cumulative time of spread, given raster maps containing "
-"the rates of spread (ROS), the ROS directions and the spread origins."
-msgstr ""
-"ã°ã©ãã£ãã¯ã¦ã£ã³ãã¦ä¸ã§æ¥åéçæ¹æ¡æ£ãã·ãã¥ã¬ã¼ãããã æ¡æ£ã®ç´¯ç©æéã"
-"æ¡æ£ç(ROS: Rate of Spread)ãROSæ¹åãæ¡æ£æºã®ã©ã¹ã¿ã¼ããããããã使ãã"
+msgid "Simulates elliptically anisotropic spread on a graphics window and generates a raster map of the cumulative time of spread, given raster maps containing the rates of spread (ROS), the ROS directions and the spread origins."
+msgstr "ã°ã©ãã£ãã¯ã¦ã£ã³ãã¦ä¸ã§æ¥åéçæ¹æ¡æ£ãã·ãã¥ã¬ã¼ãããã æ¡æ£ã®ç´¯ç©æéãæ¡æ£ç(ROS: Rate of Spread)ãROSæ¹åãæ¡æ£æºã®ã©ã¹ã¿ã¼ããããããã使ãã"
#: ../raster/wildfire/r.spread/main.c:108
-msgid ""
-"It optionally produces raster maps to contain backlink UTM coordinates for "
-"tracing spread paths."
-msgstr ""
-"æ¡æ£ãã¹ããã¬ã¼ã¹ããUTM座æ¨ã¸ã®ããã¯ãªã³ã¯ãå«ãã©ã¹ã¿ã¼ãããã使ãã¾ã"
-"(ãªãã·ã§ã³ï¼"
+msgid "It optionally produces raster maps to contain backlink UTM coordinates for tracing spread paths."
+msgstr "æ¡æ£ãã¹ããã¬ã¼ã¹ããUTM座æ¨ã¸ã®ããã¯ãªã³ã¯ãå«ãã©ã¹ã¿ã¼ãããã使ãã¾ã(ãªãã·ã§ã³ï¼"
#: ../raster/wildfire/r.spread/main.c:116
#: ../raster/wildfire/r.spread/main.c:125
@@ -8598,23 +8259,16 @@
msgstr "éå§ã½ã¼ã¹ãå«ãã©ã¹ã¿ã¼ãããå"
#: ../raster/wildfire/r.spread/main.c:153
-msgid ""
-"Name of raster map containing max SPOTting DISTance (m) (required w/ -s)"
-msgstr ""
-"æå¤§ã¹ãããã£ã³ã°ï¼SPOTtingï¼è·é¢ãå«ãã©ã¹ã¿ã¼ãããå (m) (required w/ -"
-"s) "
+msgid "Name of raster map containing max SPOTting DISTance (m) (required w/ -s)"
+msgstr "æå¤§ã¹ãããã£ã³ã°ï¼SPOTtingï¼è·é¢ãå«ãã©ã¹ã¿ã¼ãããå (m) (required w/ -s) "
#: ../raster/wildfire/r.spread/main.c:161
-msgid ""
-"Name of raster map containing midflame Wind SPEED (ft/min) (required w/ -s)"
+msgid "Name of raster map containing midflame Wind SPEED (ft/min) (required w/ -s)"
msgstr "風éãå«ãã©ã¹ã¿ã¼ããããã¡ã¤ã«å (ft/min) (required w/ -s)"
#: ../raster/wildfire/r.spread/main.c:169
-msgid ""
-"Name of raster map containing fine Fuel MOISture of the cell receiving a "
-"spotting firebrand (%) (required w/ -s)"
-msgstr ""
-"é£ã³ç«ãåããã»ã«ã®å¾®ç´°å¯çç©æ¹¿åº¦(%)ãå«ãã©ã¹ã¿ã¼ãããå (w/ -s ã§å¿
é ) "
+msgid "Name of raster map containing fine Fuel MOISture of the cell receiving a spotting firebrand (%) (required w/ -s)"
+msgstr "é£ã³ç«ãåããã»ã«ã®å¾®ç´°å¯çç©æ¹¿åº¦(%)ãå«ãã©ã¹ã¿ã¼ãããå (w/ -s ã§å¿
é ) "
#: ../raster/wildfire/r.spread/main.c:177
msgid "Basic sampling window SIZE needed to meet certain accuracy (3)"
@@ -8622,9 +8276,7 @@
#: ../raster/wildfire/r.spread/main.c:184
msgid "Sampling DENSity for additional COMPutin (range: 0.0 - 1.0 (0.5))"
-msgstr ""
-"追å è¨ç®(COMPutin )ã®ãµã³ããªã³ã°å¯åº¦(DENSity). ç¯å²ã¯range: 0.0 - 1.0 "
-"(0.5) "
+msgstr "追å è¨ç®(COMPutin )ã®ãµã³ããªã³ã°å¯åº¦(DENSity). ç¯å²ã¯range: 0.0 - 1.0 (0.5) "
#: ../raster/wildfire/r.spread/main.c:191
msgid "INITial TIME for current simulation (0) (min)"
@@ -8675,23 +8327,15 @@
#: ../raster/wildfire/r.ros/main.c:439
#, c-format
msgid "Raster map <%s> already exists in mapset <%s>, select another name"
-msgstr ""
-"ã©ã¹ã¿ã¼ããã<%s>æ¢ã«ãããã»ãã<%s>ã«åå¨ãã¾ã. å¥ã®ååãä»ãã¦ä¸ãã"
+msgstr "ã©ã¹ã¿ã¼ããã<%s>æ¢ã«ãããã»ãã<%s>ã«åå¨ãã¾ã. å¥ã®ååãä»ãã¦ä¸ãã"
#: ../raster/wildfire/r.spread/main.c:463
msgid "Reading inputs..."
msgstr "èªè¾¼ä¸ ... "
#: ../raster/wildfire/r.ros/main.c:214
-msgid ""
-"Generates three, or four raster map layers showing 1) the base "
-"(perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the "
-"direction of the maximum ROS, and optionally 4) the maximum potential "
-"spotting distance."
-msgstr ""
-"ï¼ã¤ã¾ãã¯ï¼ã¤ã®ã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ã使ãã¾ã 1) ãã¼ã¹ï¼åç´ï¼æ¡æ£ã¬ã¼"
-"ã(ROSï¼Rate of Spread)ã 2)æå¤§(é æ¹å)ROSã 3) æå¤§ROSã®æ¹åãããã¨æå¤§æ½"
-"å¨ã¹ãããã£ã³ã°è·é¢(ãªãã·ã§ã³ï¼"
+msgid "Generates three, or four raster map layers showing 1) the base (perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the direction of the maximum ROS, and optionally 4) the maximum potential spotting distance."
+msgstr "ï¼ã¤ã¾ãã¯ï¼ã¤ã®ã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ã使ãã¾ã 1) ãã¼ã¹ï¼åç´ï¼æ¡æ£ã¬ã¼ã(ROSï¼Rate of Spread)ã 2)æå¤§(é æ¹å)ROSã 3) æå¤§ROSã®æ¹åãããã¨æå¤§æ½å¨ã¹ãããã£ã³ã°è·é¢(ãªãã·ã§ã³ï¼"
#: ../raster/wildfire/r.ros/main.c:224
msgid "Name of raster map containing fuel MODELs"
@@ -8746,12 +8390,8 @@
msgstr "å®äºçï¼ï¼
ï¼"
#: ../raster/wildfire/r.spreadpath/main.c:74
-msgid ""
-"Recursively traces the least cost path backwards to cells from which the "
-"cumulative cost was determined."
-msgstr ""
-"ç´¯ç©ã³ã¹ãè¨ç®ã®èµ·ç¹ã¨ãªã£ãã»ã«ã¾ã§ãå帰çã«æå°ã³ã¹ããã¹ãéæ¹åãã¬ã¼ã¹"
-"ãã"
+msgid "Recursively traces the least cost path backwards to cells from which the cumulative cost was determined."
+msgstr "ç´¯ç©ã³ã¹ãè¨ç®ã®èµ·ç¹ã¨ãªã£ãã»ã«ã¾ã§ãå帰çã«æå°ã³ã¹ããã¹ãéæ¹åãã¬ã¼ã¹ãã"
#: ../raster/wildfire/r.spreadpath/main.c:83
msgid "Name of raster map containing back-path easting information"
@@ -8771,7 +8411,7 @@
#: ../raster/r.univar2/r.univar_main.c:37
msgid "Raster map used for zoning, must be of type CELL"
-msgstr ""
+msgstr "ã¾ã¼ãã³ã°ã«ä½¿ç¨ãããDã©ã¹ã¿ã¼ãããã¯CELLã¿ã¤ãã§ãªããã°ãªãã¾ãã"
#: ../raster/r.univar2/r.univar_main.c:42
#: ../raster/r.univar2/r3.univar_main.c:43 ../raster/r.stats/main.c:114
@@ -8809,8 +8449,7 @@
msgstr "æ¨æºãã©ã¼ãããã®ä»£ããã«ãã¼ãã«åºåãã©ã¼ãããã使ç¨"
#: ../raster/r.univar2/r.univar_main.c:99
-msgid ""
-"Calculates univariate statistics from the non-null cells of a raster map."
+msgid "Calculates univariate statistics from the non-null cells of a raster map."
msgstr "ã©ã¹ã¿ã¼ãããã®éNULLã»ã«ããåå¤éçµ±è¨ãè¨ç®ãã¾ã"
#: ../raster/r.univar2/r.univar_main.c:110
@@ -8829,12 +8468,10 @@
#: ../raster/r.univar2/r3.univar_main.c:38
msgid "3D Raster map used for zoning, must be of type CELL"
-msgstr "ã¾ã¼ãã³ã°ã«ä½¿ç¨ããã3Dã©ã¹ã¿ã¼ããã, ã¿ã¤ãCELLã§ãªããã°ãªãã¾ãã"
+msgstr "ã¾ã¼ãã³ã°ã«ä½¿ç¨ããã3Dã©ã¹ã¿ã¼ãããã¯CELLã¿ã¤ãã§ãªããã°ãªãã¾ãã"
#: ../raster/r.univar2/r3.univar_main.c:102
-msgid ""
-"Calculates univariate statistics from the non-null 3d cells of a raster3d "
-"map."
+msgid "Calculates univariate statistics from the non-null 3d cells of a raster3d map."
msgstr "ã©ã¹ã¿ã¼3Dãããã®éNULL3Dã»ã«ããåå¤éçµ±è¨ãè¨ç®ãã¾ã"
#: ../raster/r.univar2/r3.univar_main.c:163
@@ -8885,12 +8522,8 @@
msgstr "åä½"
#: ../raster/r.report/parse.c:46
-msgid ""
-"mi;miles;me;meters;k;kilometers;a;acres;h;hectares;c;cell counts;p;percent "
-"cover"
-msgstr ""
-"mi;ãã¤ã«;me;ã¡ã¼ãã«;k;ããã¡ã¼ãã«;a;ã¨ã¼ã«ã¼;h;ãã¯ã¿ã¼ã«;c;ã»ã«ã«ã¦ã³ã;"
-"p;ãã¼ã»ã³ãã«ãã¼"
+msgid "mi;miles;me;meters;k;kilometers;a;acres;h;hectares;c;cell counts;p;percent cover"
+msgstr "mi;ãã¤ã«;me;ã¡ã¼ãã«;k;ããã¡ã¼ãã«;a;ã¨ã¼ã«ã¼;h;ãã¯ã¿ã¼ã«;c;ã»ã«ã«ã¦ã³ã;p;ãã¼ã»ã³ãã«ãã¼"
#: ../raster/r.report/parse.c:56
msgid "Character representing no data cell value"
@@ -8977,8 +8610,7 @@
#: ../raster/r.out.pov/main.c:123
msgid "Converts a raster map layer into a height-field file for POVRAY."
-msgstr ""
-"ã©ã¹ã¿ã¼ããããPOVRAYç¨ã®é«åº¦ãã£ã¼ã«ããã¡ã¤ã«ã¨ãã¦ã¨ã¯ã¹ãã¼ããã¾ã "
+msgstr "ã©ã¹ã¿ã¼ããããPOVRAYç¨ã®é«åº¦ãã£ã¼ã«ããã¡ã¤ã«ã¨ãã¦ã¨ã¯ã¹ãã¼ããã¾ã "
#: ../raster/r.out.pov/main.c:131 ../raster/r.out.ascii/main.c:70
msgid "Name of an existing raster map"
@@ -9068,21 +8700,15 @@
msgstr "ã©ã¤ã³ãå¦çãã¦ãã¾ã... "
#: ../raster/r.carve/enforce_ds.c:173
-msgid ""
-"Vect runs out of region and re-enters - this case is not yet implemented."
-msgstr ""
-"ãã¯ãã«ã¯é åã使ãæããåå
¥åãã¾ã - ãã®ã±ã¼ã¹ã¯ã¾ã å®è¡ããã¦ãã¾ãã"
+msgid "Vect runs out of region and re-enters - this case is not yet implemented."
+msgstr "ãã¯ãã«ã¯é åã使ãæããåå
#: ../raster/r.carve/lobf.c:74
msgid "trying to divide by zero...no unique solution for system...skipping..."
-msgstr ""
-"ã¼ãã§ã®åå²ã試ã¿ã¦ãã¾ã...ã·ã¹ãã ã®å¯ä¸ã®è§£æ±ºçã¯ããã¾ãã...ã¹ãããã"
-"ã¦ãã¾ã... "
+msgstr "ã¼ãã§ã®åå²ã試ã¿ã¦ãã¾ã...ã·ã¹ãã ã®å¯ä¸ã®è§£æ±ºçã¯ããã¾ãã...ã¹ããããã¦ãã¾ã... "
#: ../raster/r.carve/main.c:78
-msgid ""
-"Takes vector stream data, transforms it to raster and subtracts depth from "
-"the output DEM."
+msgid "Takes vector stream data, transforms it to raster and subtracts depth from the output DEM."
msgstr "ãã¯ãã«æ²³å·ãã¼ã¿ãã©ã¹ã¿ã¼ã«å¤æãåºåDEMããæ·±åº¦ãæ¸ç®ãã"
#: ../raster/r.carve/main.c:83
@@ -9124,9 +8750,7 @@
msgstr "緯度/çµåº¦æå½±ã¯ãã®æç¹ã§ã¯ãµãã¼ãããã¦ãã¾ãã. "
#: ../raster/r.out.tiff/r.out.tiff.c:101
-msgid ""
-"Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
-"resolution of the currently defined region."
+msgid "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel resolution of the currently defined region."
msgstr "GRASS ã©ã¹ã¿ã¼ãããã 8/24 ãããã® TIFF ç»åãã¡ã¤ã«ã¸ã¨ã¯ã¹ãã¼ã"
#: ../raster/r.out.tiff/r.out.tiff.c:111
@@ -9159,19 +8783,12 @@
#: ../raster/r.out.tiff/r.out.tiff.c:177
#, c-format
-msgid ""
-"Raster map <%s> in mapset <%s> is a floating point map. Decimal values will "
-"be rounded to integer!"
-msgstr ""
-"ã©ã¹ã¿ããã <%s> ï¼ãããã»ãã <%s> å
ã®ï¼ 㯠浮åå°æ°ç¹ãã¤ã³ããããã§"
-"ãï¼å°æ°ç¹ä»¥ä¸ã®æ°å¤ã¯ä¸¸ãããã¦æ´æ°åã«ããã¾ãï¼"
+msgid "Raster map <%s> in mapset <%s> is a floating point map. Decimal values will be rounded to integer!"
+msgstr "ã©ã¹ã¿ããã <%s> ï¼ãããã»ãã <%s> å
ã®ï¼ 㯠浮åå°æ°ç¹ãã¤ã³ããããã§ãï¼å°æ°ç¹ä»¥ä¸ã®æ°å¤ã¯ä¸¸ãããã¦æ´æ°åã«ããã¾ãï¼"
#: ../raster/r.out.tiff/r.out.tiff.c:183
-msgid ""
-"Color map for palette must have less than 256 colors for the available range "
-"of data"
-msgstr ""
-"å¯è½ãªãã¼ã¿ã®ç¯å²å
ã§ï¼ãã¬ããã®ã«ã©ã¼ãããã¯256è²æªæºã§ãªãã¦ã¯ããã¾ãã"
+msgid "Color map for palette must have less than 256 colors for the available range of data"
+msgstr "å¯è½ãªãã¼ã¿ã®ç¯å²å
#: ../raster/r.out.tiff/r.out.tiff.c:198
#, c-format
@@ -9234,12 +8851,8 @@
#: ../raster/r.null/null.c:123
#, c-format
-msgid ""
-"Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy "
-"with r.mapcalc. Exiting."
-msgstr ""
-"ã©ã¹ã¿ã¼ããã <%s> 㯠ããã <%s@%s> ã®ååé¡ï¼r.mapcalc ã¨å
±ã«ã³ãã¼ã使"
-"ãããã¨ãèæ
®ãã¦ä¸ããï¼çµäºãã¦ãã¾ã"
+msgid "Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy with r.mapcalc. Exiting."
+msgstr "ã©ã¹ã¿ã¼ããã <%s> 㯠ããã <%s@%s> ã®ååé¡ï¼r.mapcalc ã¨å
±ã«ã³ãã¼ã使ãããã¨ãèæ
#: ../raster/r.null/null.c:129
#, c-format
@@ -9340,11 +8953,8 @@
msgstr "è£éã«ç¨ãããã¤ã³ãæ°"
#: ../raster/r.surf.idw2/main.c:80
-msgid ""
-"Lat/long databases not supported by r.surf.idw2. Use r.surf.idw instead!"
-msgstr ""
-"Lat/Long ãã¼ã¿ãã¼ã¹ã¯ r.surf.idw2 ã§ã¯ãµãã¼ãããã¦ãã¾ããã r.surf.idw "
-"ã使ç¨ãã¦ãã ããï¼"
+msgid "Lat/long databases not supported by r.surf.idw2. Use r.surf.idw instead!"
+msgstr "Lat/Long ãã¼ã¿ãã¼ã¹ã¯ r.surf.idw2 ã§ã¯ãµãã¼ãããã¦ãã¾ããã r.surf.idw ã使ç¨ãã¦ãã ããï¼"
#: ../raster/r.surf.idw2/main.c:87 ../vector/v.surf.idw/main.c:141
#, c-format
@@ -9424,28 +9034,18 @@
#: ../raster/r.stats/main.c:284
#, c-format
-msgid ""
-"Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option "
-"will be ignored."
-msgstr ""
-"ã©ã¹ã¿ã¼ããã <%s> ã¯æ´æ°å¤ã«ãªã£ã¦ãã¾ã! ãã©ãã° '-%c' 㨠'%s' ã®ãªãã·ã§"
-"ã³ã¯ç¡è¦ããã¾ã"
+msgid "Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option will be ignored."
+msgstr "ã©ã¹ã¿ã¼ããã <%s> ã¯æ´æ°å¤ã«ãªã£ã¦ãã¾ã! ãã©ãã° '-%c' 㨠'%s' ã®ãªãã·ã§ã³ã¯ç¡è¦ããã¾ã"
#: ../raster/r.stats/main.c:301
#, c-format
-msgid ""
-"Cats for raster map <%s> are either missing or have no explicit labels. "
-"Using %s=%d."
+msgid "Cats for raster map <%s> are either missing or have no explicit labels. Using %s=%d."
msgstr "ã©ã¹ã¿ã¼ããã <%s> ã®ã«ãã´ãªã¼ã«ã©ãã«ãããã¾ããã %s=%d ã使ç¨ä¸"
#: ../raster/r.stats/main.c:308
#, c-format
-msgid ""
-"Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' "
-"option"
-msgstr ""
-"ãã©ãã° '-%c' ãã©ã¹ã¿ããã <%s> ã®ã«ãã´ãªã¼ã®fpã¬ã³ã¸ããä¸ãããã¾ã"
-"ãï¼ '%s' ãªãã·ã§ã³ã¯ç¡è¦"
+msgid "Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' option"
+msgstr "ãã©ãã° '-%c' ãã©ã¹ã¿ããã <%s> ã®ã«ãã´ãªã¼ã®fpã¬ã³ã¸ããä¸ãããã¾ããï¼ '%s' ãªãã·ã§ã³ã¯ç¡è¦"
#: ../raster/r.stats/main.c:342
#, c-format
@@ -9677,19 +9277,13 @@
msgstr "%ld ãã¤ãã '%s' ã«æ¸åºãã¾ãã "
#: ../raster/r.sunmask/g_solposition.c:66
-msgid ""
-"Unable to calculate sun position in un-projected locations. Specify "
-"sunposition directly."
-msgstr ""
-"æå½±ããã¦ããªããã±ã¼ã·ã§ã³ã§ã®å¤ªé½ã®ä½ç½®ãè¨ç®ã§ãã¾ããã太é½ã®ä½ç½®ãç´æ¥"
-"æå®ãã¦ãã ããã"
+msgid "Unable to calculate sun position in un-projected locations. Specify sunposition directly."
+msgstr "æå½±ããã¦ããªããã±ã¼ã·ã§ã³ã§ã®å¤ªé½ã®ä½ç½®ãè¨ç®ã§ãã¾ããã太é½ã®ä½ç½®ãç´æ¥æå®ãã¦ãã ããã"
#: ../raster/r.sunmask/g_solposition.c:88
#, c-format
-msgid ""
-"Specified point %f, %f outside of current region, is that intended? Anyway, "
-"it will be used."
-msgstr ""
+msgid "Specified point %f, %f outside of current region, is that intended? Anyway, it will be used."
+msgstr "æå®ããããã¤ã³ã %f, %f ã¯ç¾å¨ã®é åå¤ã§ããé©ç¨ããã¾ãããæå³çã«æå®ããã¾ãããï¼"
#: ../raster/r.sunmask/g_solposition.c:98
msgid "Unable to get projection info of current location"
@@ -9708,17 +9302,12 @@
msgstr "ã©ã¹ã¿ã¼ãæå½±æ³"
#: ../raster/r.sunmask/main.c:116
-msgid ""
-"Calculates cast shadow areas from sun position and elevation raster map."
+msgid "Calculates cast shadow areas from sun position and elevation raster map."
msgstr "ã©ã¹ã¿ã¼ãããä¸ã®ï¼ã³ã³ãã©ã¹ãå éã¨ãã¸å¯åº¦ãè¨ç®"
#: ../raster/r.sunmask/main.c:117
-msgid ""
-"Either exact sun position (A) is specified, or date/time to calculate the "
-"sun position (B) by r.sunmask itself."
-msgstr ""
-"太é½ä½ç½®ã¨ DEM ããã¨ã«é°å½±é åãè¨ç®ï¼r.sunmask èªèº«ããï¼A: æ£ç¢ºãªå¤ªé½ä½ç½®"
-"ã®æå®ï¼ã¾ã㯠B: 太é½ä½ç½®ãè¨ç®ããããã®æ¥ä»/æå»ãæå®"
+msgid "Either exact sun position (A) is specified, or date/time to calculate the sun position (B) by r.sunmask itself."
+msgstr "太é½ä½ç½®ã¨ DEM ããã¨ã«é°å½±é åãè¨ç®ï¼r.sunmask èªèº«ããï¼A: æ£ç¢ºãªå¤ªé½ä½ç½®ã®æå®ï¼ã¾ã㯠B: 太é½ä½ç½®ãè¨ç®ããããã®æ¥ä»/æå»ãæå®"
#: ../raster/r.sunmask/main.c:131
msgid "Altitude of the sun above horizon, degrees (A)"
@@ -9818,12 +9407,8 @@
msgstr "太é½ã®ä½ç½®ãã座æ¨/æ¥ä»/æå»ã®ãã©ã¡ã¼ã¿ã®ã©ã¡ãããè¨å®ãã¦ãã ãã"
#: ../raster/r.sunmask/main.c:282
-msgid ""
-"Neither sun position nor east/north, date/time/timezone definition are "
-"complete"
-msgstr ""
-"太é½ã®ä½ç½®ãæ±è¥¿/åå座æ¨/æ¥ä»/æå»/ã¿ã¤ã ã¾ã¼ã³ã®ã©ã¡ããè¨å®ãå®äºãã¦ãã¾"
-"ãã"
+msgid "Neither sun position nor east/north, date/time/timezone definition are complete"
+msgstr "太é½ã®ä½ç½®ãæ±è¥¿/åå座æ¨/æ¥ä»/æå»/ã¿ã¤ã ã¾ã¼ã³ã®ã©ã¡ããè¨å®ãå®äºãã¦ãã¾ãã"
#: ../raster/r.sunmask/main.c:286
#, c-format
@@ -9831,9 +9416,7 @@
msgstr "太é½ä½ç½®ãè¨ç®ãã¦ãã¾ã... (NRELããsolpos (V. %s)ã使ç¨)"
#: ../raster/r.sunmask/main.c:291
-msgid ""
-"Using user defined sun azimuth, altitude settings (ignoring eventual other "
-"values)"
+msgid "Using user defined sun azimuth, altitude settings (ignoring eventual other values)"
msgstr "ã¦ã¼ã¶ã¼å®ç¾©ã®å¤ªé½ã®æ¹ä½, é«åº¦è¨å® (åä½ãã¨ã®ä»ã®å¤ã¯ç¡è¦)"
#: ../raster/r.sunmask/main.c:397
@@ -9985,12 +9568,8 @@
msgstr "yä¿æ°ã®ããã"
#: ../raster/r.regression.line/main.c:59
-msgid ""
-"ASCII file for storing regression coefficients (output to screen if file not "
-"specified)."
-msgstr ""
-"åå¸°ä¿æ°ãä¿åããASCII ãã¡ã¤ã« (ãã¡ã¤ã«ãç¹å®ããã¦ããªãå ´åã¹ã¯ãªã¼ã³ã«"
-"åºå). "
+msgid "ASCII file for storing regression coefficients (output to screen if file not specified)."
+msgstr "åå¸°ä¿æ°ãä¿åããASCII ãã¡ã¤ã« (ãã¡ã¤ã«ãç¹å®ããã¦ããªãå ´åã¹ã¯ãªã¼ã³ã«åºå). "
#: ../raster/r.regression.line/main.c:63 ../general/g.region/main.c:147
#: ../locale/scriptstrings/i.oif_to_translate.c:9
@@ -10136,11 +9715,8 @@
msgstr "c=%d "
#: ../raster/r.surf.random/main.c:46
-msgid ""
-"Produces a raster map of uniform random deviates whose range can be "
-"expressed by the user."
-msgstr ""
-"ã¦ã¼ã¶ã¼æå®ã§è¡¨ç¾ãããã¬ã³ã¸ã®ï¼ä¸æ§ä¹±æ°åå·®ã®ã©ã¹ã¿ã¼ããã ã¬ã¤ã¤ã¼ã使"
+msgid "Produces a raster map of uniform random deviates whose range can be expressed by the user."
+msgstr "ã¦ã¼ã¶ã¼æå®ã§è¡¨ç¾ãããã¬ã³ã¸ã®ï¼ä¸æ§ä¹±æ°åå·®ã®ã©ã¹ã¿ã¼ããã ã¬ã¤ã¤ã¼ã使"
#: ../raster/r.surf.random/main.c:53
msgid "Minimum random value"
@@ -10315,8 +9891,7 @@
#: ../raster/r.li/r.li.patchnum/main.c:34
-msgid ""
-"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
msgstr "åè¿åæ³ãç¨ãã¦ï¼ã©ã¹ã¿ã¼ãããä¸ã®ï¼ãããçªå·ã¤ã³ããã¯ã¹ãè¨ç®"
#: ../raster/r.li/r.li.simpson/simpson.c:37
@@ -10341,9 +9916,7 @@
msgstr "ã©ã¹ã¿ã¼ãããä¸ã® Simpson å¯åº¦ã¤ã³ããã¯ã¹ãè¨ç®"
#: ../raster/r.li/r.li.mps/mps.c:39
-msgid ""
-"Calculates mean patch size index on a raster map, using a 4 neighbour "
-"algorithm"
+msgid "Calculates mean patch size index on a raster map, using a 4 neighbour algorithm"
msgstr "åè¿åæ³ãç¨ãã¦ï¼ã©ã¹ã¿ã¼ãããä¸ã®ï¼ããããµã¤ãº ã¤ã³ããã¯ã¹ãè¨ç®"
#: ../raster/r.li/r.li.shannon/shannon.c:36
@@ -10363,8 +9936,7 @@
msgstr "ã¢ã«ãã¡å¤ã¯ä¸è¬åã¨ã³ãããã¼ã®æ¬¡æ°ã§ã"
#: ../raster/r.li/r.li.edgedensity/edgedensity.c:37
-msgid ""
-"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
msgstr "åè¿åæ³ãç¨ãã¦ï¼ã©ã¹ã¿ã¼ãããä¸ã®ï¼ã¨ãã¸å¯åº¦ã¤ã³ããã¯ã¹ãè¨ç®"
#: ../raster/r.li/r.li.padrange/padrange.c:37
@@ -10591,17 +10163,12 @@
msgstr "ã©ã¹ã¿ã¼ãããä¸ã®ãããã¨ãªã¢ã®å¤åä¿æ°ãè¨ç®ãã¾ã"
#: ../raster/r.li/r.li.patchdensity/main.c:33
-msgid ""
-"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
+msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
msgstr "åè¿åæ³ãç¨ãã¦ï¼ã©ã¹ã¿ã¼ãããä¸ã®ï¼ãããå¯åº¦ã¤ã³ããã¯ã¹ãè¨ç®"
#: ../raster/r.out.ppm/main.c:56
-msgid ""
-"Converts a GRASS raster map to a PPM image file at the pixel resolution of "
-"the currently defined region."
-msgstr ""
-"ã©ã¹ã¿ã¼ãããããç¾å¨ã®å®ç¾©é åã®ãã¯ã»ã«è§£å度ã®PPMç»åãã¡ã¤ã«ã«ã¨ã¯ã¹ãã¼"
-"ããã¾ã"
+msgid "Converts a GRASS raster map to a PPM image file at the pixel resolution of the currently defined region."
+msgstr "ã©ã¹ã¿ã¼ãããããç¾å¨ã®å®ç¾©é åã®ãã¯ã»ã«è§£å度ã®PPMç»åãã¡ã¤ã«ã«ã¨ã¯ã¹ãã¼ããã¾ã"
#: ../raster/r.out.ppm/main.c:64
msgid "Name for new PPM file (use '-' for stdout)"
@@ -10693,9 +10260,7 @@
msgstr "åºåããã¢ã¹ãã¼ã°ãªãããããå "
#: ../raster/r.out.ascii/main.c:92
-msgid ""
-"Number of values printed before wrapping a line (only SURFER or MODFLOW "
-"format)"
+msgid "Number of values printed before wrapping a line (only SURFER or MODFLOW format)"
msgstr "æ¹è¡åã«åºåããå¤ã®æ°èªã¿è¾¼ãæ¡æ° "
#: ../raster/r.out.ascii/main.c:100
@@ -10745,12 +10310,8 @@
msgstr "ã©ã¹ã¿ã¼ãåã³ã¼ãã«ãã´ãªã¼"
#: ../raster/r.cats/main.c:53
-msgid ""
-"Manages category values and labels associated with user-specified raster map "
-"layers."
-msgstr ""
-"ã¦ã¼ã¶ã¼æå®ã®ã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ã¨é¢é£ã¥ããããã«ãã´ãªã¼å¤ã¨ã©ãã«ãå¦"
-"çãã¾ã"
+msgid "Manages category values and labels associated with user-specified raster map layers."
+msgstr "ã¦ã¼ã¶ã¼æå®ã®ã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ã¨é¢é£ã¥ããããã«ãã´ãªã¼å¤ã¨ã©ãã«ãå¦çãã¾ã"
#: ../raster/r.cats/main.c:66
msgid "Comma separated value list"
@@ -10762,8 +10323,7 @@
#: ../raster/r.cats/main.c:84
msgid "File containing category label rules (or \"-\" to read from stdin)"
-msgstr ""
-"ã«ãã´ãªã¼ã©ãã«ã«ã¼ã«ãå«ããã¡ã¤ã« (ã¾ã㯠\"-\" æ¨æºå
¥åããèªã¿è¾¼ã¿)"
+msgstr "ã«ãã´ãªã¼ã©ãã«ã«ã¼ã«ãå«ããã¡ã¤ã« (ã¾ã㯠\"-\" æ¨æºå
¥åããèªã¿è¾¼ã¿)"
#: ../raster/r.cats/main.c:91
msgid "Default label or format string for dynamic labeling"
@@ -10824,12 +10384,8 @@
msgstr "ã©ã¹ã¿ã¼ãå°å½¢"
#: ../raster/r.slope.aspect/main.c:154
-msgid ""
-"Generates raster maps of slope, aspect, curvatures and partial derivatives "
-"from a elevation raster map."
-msgstr ""
-"çã®æ¨é«å¤ã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ãããæé¢ãæ¹ä½ãæ²é¢ãåå°é¢æ°ã®ã©ã¹ã¿ã¼"
-"ãããã使ãã¾ã.ãæ¹ä½ã¯æ±ããåæè¨åãã«è¨ç®ãã¾ã"
+msgid "Generates raster maps of slope, aspect, curvatures and partial derivatives from a elevation raster map."
+msgstr "çã®æ¨é«å¤ã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ãããæé¢ãæ¹ä½ãæ²é¢ãåå°é¢æ°ã®ã©ã¹ã¿ã¼ãããã使ãã¾ã.ãæ¹ä½ã¯æ±ããåæè¨åãã«è¨ç®ãã¾ã"
#: ../raster/r.slope.aspect/main.c:156
msgid "Aspect is calculated counterclockwise from east."
@@ -10873,13 +10429,11 @@
msgstr "æ£æ¥æ²çãåºåãããã¡ã¤ã« "
#: ../raster/r.slope.aspect/main.c:209
-msgid ""
-"Name for output first order partial derivative dx (E-W slope) raster map"
+msgid "Name for output first order partial derivative dx (E-W slope) raster map"
msgstr "䏿¬¡å°é¢æ° dx (æ±-西 徿)ã®ã©ã¹ã¿ãããå"
#: ../raster/r.slope.aspect/main.c:216
-msgid ""
-"Name for output first order partial derivative dy (N-S slope) raster map"
+msgid "Name for output first order partial derivative dy (N-S slope) raster map"
msgstr "䏿¬¡å°é¢æ° dx (å-å 徿)ã®ã©ã¹ã¿ãããå"
#: ../raster/r.slope.aspect/main.c:223
@@ -10918,12 +10472,8 @@
#: ../raster/r.slope.aspect/main.c:348
#, c-format
-msgid ""
-"You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <"
-"%s>, <%s>, <%s>, <%s> or <%s>"
-msgstr ""
-"次ã®ãã¡å°ãªãã¨ãä¸ã¤ã®å¼æ°ãå¿
è¦ã§ã: <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <"
-"%s>, <%s>, <%s> "
+msgid "You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s> or <%s>"
+msgstr "次ã®ãã¡å°ãªãã¨ãä¸ã¤ã®å¼æ°ãå¿
è¦ã§ã: <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s> "
#: ../raster/r.slope.aspect/main.c:378
#, c-format
@@ -11084,8 +10634,7 @@
#: ../raster/r.to.vect/main.c:73
msgid "Use raster values as categories instead of unique sequence (CELL only)"
-msgstr ""
-"ã¦ãã¼ã¯ãªã·ã¼ã±ã³ã¹ã®ä»£ããã«ã©ã¹ã¿ã¼å¤ãã«ãã´ãªã¼ã¨ãã¦ä½¿ç¨ (ã»ã« ã®ã¿) "
+msgstr "ã¦ãã¼ã¯ãªã·ã¼ã±ã³ã¹ã®ä»£ããã«ã©ã¹ã¿ã¼å¤ãã«ãã´ãªã¼ã¨ãã¦ä½¿ç¨ (ã»ã« ã®ã¿) "
#: ../raster/r.to.vect/main.c:74 ../raster/r.to.vect/main.c:81
#: ../vector/v.in.ogr/main.c:193 ../vector/v.in.ogr/main.c:216
@@ -11098,12 +10647,8 @@
msgstr "屿§"
#: ../raster/r.to.vect/main.c:79
-msgid ""
-"Write raster values as z coordinate. Table is not created. Currently "
-"supported only for points."
-msgstr ""
-"ã©ã¹ã¿å¤ãz座æ¨ã¨ãã¦æ¸ãè¾¼ã. ãã¼ãã«ã¯ä½æããã¦ãã¾ãã. ç¾å¨ã¯ãã¤ã³ãã®"
-"ã¿ãµãã¼ãããã¦ãã¾ã. "
+msgid "Write raster values as z coordinate. Table is not created. Currently supported only for points."
+msgstr "ã©ã¹ã¿å¤ãz座æ¨ã¨ãã¦æ¸ãè¾¼ã. ãã¼ãã«ã¯ä½æããã¦ãã¾ãã. ç¾å¨ã¯ãã¤ã³ãã®ã¿ãµãã¼ãããã¦ãã¾ã. "
#: ../raster/r.to.vect/main.c:86
msgid "Do not build vector topology (use with care for massive point export)"
@@ -11118,12 +10663,8 @@
msgstr "zãã©ãã°ã¯ãã¤ã³ãã®ã¿ã«ãµãã¼ãããã¦ãã¾ã"
#: ../raster/r.to.vect/main.c:123
-msgid ""
-"Raster is not CELL, '-v' flag ignored, raster values will be written to the "
-"table."
-msgstr ""
-"ã©ã¹ã¿ã¼ã¯ã»ã«ã§ã¯ããã¾ãã, '-v' ãã©ãã°ã¯ç¡è¦ããã¾ãã, ã©ã¹ã¿ã¼å¤ã¯è¡¨ã«"
-"æ¸ãè¾¼ã¾ãã¾ã. "
+msgid "Raster is not CELL, '-v' flag ignored, raster values will be written to the table."
+msgstr "ã©ã¹ã¿ã¼ã¯ã»ã«ã§ã¯ããã¾ãã, '-v' ãã©ãã°ã¯ç¡è¦ããã¾ãã, ã©ã¹ã¿ã¼å¤ã¯è¡¨ã«æ¸ãè¾¼ã¾ãã¾ã. "
#: ../raster/r.to.vect/main.c:194 ../vector/v.random/main.c:193
#: ../vector/v.lrs/v.lrs.create/main.c:325 ../vector/v.in.ascii/in.c:386
@@ -11161,9 +10702,7 @@
msgstr "ãã¤ã³ããæ½åºãã¦ãã¾ã"
#: ../raster/r.out.ppm3/main.c:59
-msgid ""
-"Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
-"resolution of the CURRENTLY DEFINED REGION."
+msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION."
msgstr "ã©ã¹ã¿ã¼ããããPPMãã¡ã¤ã«ã¨ãã¦ã¨ã¯ã¹ãã¼ããã¾ã "
#: ../raster/r.out.ppm3/main.c:85
@@ -11191,8 +10730,7 @@
#: ../raster/r.transect/main.c:56
-msgid ""
-"Outputs raster map layer values lying along user defined transect line(s)."
+msgid "Outputs raster map layer values lying along user defined transect line(s)."
msgstr "æå®ããç´ç·ä¸ã§ã®ã©ã¹ã¿ã¼ãããã®å¤ãæ±ãã¾ã "
#: ../raster/r.transect/main.c:60
@@ -11231,11 +10769,8 @@
msgstr "è¡ãèªãã¾ãã "
#: ../raster/r.median/main.c:48
-msgid ""
-"Finds the median of values in a cover map within areas assigned the same "
-"category value in a user-specified base map."
-msgstr ""
-"ã¦ã¼ã¶ã¼æå®ãã¼ã¹ãããã¨åãã«ãã´ãªã¼å¤ããã¤ã«ãã¼ãããã®å¹³åå¤ãæ±ãã"
+msgid "Finds the median of values in a cover map within areas assigned the same category value in a user-specified base map."
+msgstr "ã¦ã¼ã¶ã¼æå®ãã¼ã¹ãããã¨åãã«ãã´ãªã¼å¤ããã¤ã«ãã¼ãããã®å¹³åå¤ãæ±ãã"
#: ../raster/r.median/main.c:54
msgid "Name of base raster map"
@@ -11269,13 +10804,8 @@
msgstr "éç´ã¹ã±ã¼ã« "
#: ../raster/r.neighbors/main.c:110
-msgid ""
-"Makes each cell category value a function of the category values assigned to "
-"the cells around it, and stores new cell values in an output raster map "
-"layer."
-msgstr ""
-"åã»ã«ã«ãã´ãªã¼å¤ããã®å¨ãã«å²ãå½ã¦ãããã«ãã´ãªã¼å¤ã®æ©è½ã«ããåºåã©ã¹"
-"ã¿ã¼ãããã¬ã¤ã¤ã¼ã«æ°ããã»ã«å¤ãä¿åãã¾ã"
+msgid "Makes each cell category value a function of the category values assigned to the cells around it, and stores new cell values in an output raster map layer."
+msgstr "åã»ã«ã«ãã´ãªã¼å¤ããã®å¨ãã«å²ãå½ã¦ãããã«ãã´ãªã¼å¤ã®æ©è½ã«ããåºåã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ã«æ°ããã»ã«å¤ãä¿åãã¾ã"
#: ../raster/r.neighbors/main.c:133
msgid "Neighborhood operation"
@@ -11343,8 +10873,7 @@
#: ../raster/r.resamp.interp/main.c:74
msgid "Resamples raster map layers to a finer grid using interpolation."
-msgstr ""
-"åãµã³ããªã³ã°ã§ã©ã¹ã¿ã¼ããã ã¬ã¤ã¤ã¼ãè£éãã¦ããç´°ããã°ãªããã«ãã"
+msgstr "åãµã³ããªã³ã°ã§ã©ã¹ã¿ã¼ããã ã¬ã¤ã¤ã¼ãè£éãã¦ããç´°ããã°ãªããã«ãã"
#: ../raster/r.resamp.interp/main.c:83
msgid "Interpolation method"
@@ -11415,12 +10944,8 @@
msgstr "<%s> ã®ã«ãã´ãªã¼ãã¡ã¤ã«ã使ã§ãã¾ãã "
#: ../raster/r.reclass/main.c:51
-msgid ""
-"Creates a new map layer whose category values are based upon a "
-"reclassification of the categories in an existing raster map layer."
-msgstr ""
-"åå¨ããã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ã®ã«ãã´ãªã¼ååé¡ã«åºã¥ãã«ãã´ãªã¼å¤ã®æ°ãã"
-"ãããã¬ã¤ã¤ã¼ä½æãã¾ã"
+msgid "Creates a new map layer whose category values are based upon a reclassification of the categories in an existing raster map layer."
+msgstr "åå¨ããã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ã®ã«ãã´ãªã¼ååé¡ã«åºã¥ãã«ãã´ãªã¼å¤ã®æ°ãããããã¬ã¤ã¤ã¼ä½æãã¾ã"
#: ../raster/r.reclass/main.c:56
msgid "Raster map to be reclassified"
@@ -11490,9 +11015,7 @@
msgstr "%f ã %dã«åæ¨äºå
¥ãã¾ãã\n"
#: ../raster/r.coin/main.c:68
-msgid ""
-"Tabulates the mutual occurrence (coincidence) of categories for two raster "
-"map layers."
+msgid "Tabulates the mutual occurrence (coincidence) of categories for two raster map layers."
msgstr "2ã¤ã®ã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ã®ã«ãã´ãªã¼ã®ç¸äºçºçã表ã«ãã¾ã"
#: ../raster/r.coin/main.c:76
@@ -11508,12 +11031,8 @@
msgstr "測å®åä½ "
#: ../raster/r.coin/main.c:91
-msgid ""
-"c(ells), p(ercent), x(percent of category [column]), y(percent of category "
-"[row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
-msgstr ""
-"c(ells), p(ercent), x(percent of category [å]), y(ã«ãã´ãªã¼ã®ãã¼ã»ã³ã "
-"[è¡]), a(cres), h(ectares), k(å¹³æ¹ããã¡ã¼ãã«), m(å¹³æ¹ãã¤ã«) "
+msgid "c(ells), p(ercent), x(percent of category [column]), y(percent of category [row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
+msgstr "c(ells), p(ercent), x(percent of category [å]), y(ã«ãã´ãªã¼ã®ãã¼ã»ã³ã [è¡]), a(cres), h(ectares), k(å¹³æ¹ããã¡ã¼ãã«), m(å¹³æ¹ãã¤ã«) "
#: ../raster/r.coin/main.c:98
msgid "Wide report, 132 columns (default: 80)"
@@ -11545,8 +11064,7 @@
msgstr "GISã³ã¤ã³ã·ãã³ã¹ä½è¡¨è¨å\n"
#: ../raster/r.coin/inter.c:35
-msgid ""
-"This utility will allow you to compare the coincidence of two map layers\n"
+msgid "This utility will allow you to compare the coincidence of two map layers\n"
msgstr "ãã®ã¦ã¼ãã£ãªãã£ã¼ã§2ã¤ã®ãããã¬ã¤ã¤ã¼ã®ä¸è´ãæ¯è¼ã§ãã¾ã\n"
#: ../raster/r.coin/inter.c:52
@@ -11616,10 +11134,8 @@
#: ../raster/r.coin/inter.c:117
#, c-format
-msgid ""
-"Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "
-msgstr ""
-"ãã®ã¬ãã¼ããåºåãã¾ãã (UNIX lpr ã³ãã³ããå¿
è¦ã¨ãã¾ã)? (y/n) [n] "
+msgid "Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "
+msgstr "ãã®ã¬ãã¼ããåºåãã¾ãã (UNIX lpr ã³ãã³ããå¿
#: ../raster/r.coin/inter.c:126
#, c-format
@@ -11632,8 +11148,7 @@
#: ../raster/r.coin/inter.c:142
#, c-format
-msgid ""
-"Do you wish to run this report with a different unit of measure? (y/n) [y] "
+msgid "Do you wish to run this report with a different unit of measure? (y/n) [y] "
msgstr "ãã®ã¬ãã¼ããå¥ã®è¨æ¸¬åä½ã§å®è¡ãã¾ãã? (y/n) [y] "
#: ../raster/r.coin/print_coin.c:44
@@ -11642,22 +11157,13 @@
msgstr "ã¬ãã¼ããæºåãã¦ãã¾ã "
#: ../raster/r.texture/h_measure.c:84
-msgid ""
-"Negative or no data pixel found. This module is not yet able to process no "
-"data holes in a map, please fill with r.fillnulls or other algorithms"
-msgstr ""
-"è² å¤ã¾ãã¯ãã¼ã¿ç¡ãã®ãã¯ã»ã«ãè¦ã¤ããã¾ããï¼ãã¼ã¿ç¡ãã®ãã¼ã«ããããå
-"ã«ããï¼ãã®ã¢ã¸ã¥ã¼ã«ã¯ã¾ã å¦çã§ãã¾ããï¼r.fillnulls ã¾ãã¯ä»ã®ã¢ã«ã´ãªãº"
-"ã ã使ç¨ãã¦ãã¼ã¿ãè©°ãã¦ãã ãã"
+msgid "Negative or no data pixel found. This module is not yet able to process no data holes in a map, please fill with r.fillnulls or other algorithms"
+msgstr "è² å¤ã¾ãã¯ãã¼ã¿ç¡ãã®ãã¯ã»ã«ãè¦ã¤ããã¾ããï¼ãã¼ã¿ç¡ãã®ãã¼ã«ããããå
ã«ããï¼ãã®ã¢ã¸ã¥ã¼ã«ã¯ã¾ã å¦çã§ãã¾ããï¼r.fillnulls ã¾ãã¯ä»ã®ã¢ã«ã´ãªãºã ã使ç¨ãã¦ãã¼ã¿ãè©°ãã¦ãã ãã"
#: ../raster/r.texture/h_measure.c:88
#, c-format
-msgid ""
-"Too many categories (found: %i, max: %i). Try to rescale or reclassify the "
-"map"
-msgstr ""
-"ã«ãã´ãªã¼ãå¤ããã¾ã (æå®æ°ï¼%i, æå¤§ï¼ %i)ï¼ ãããã®ç¸®å°ºã夿´ãããåå"
-"é¡ããã¦ã¿ã¦ãã ãã"
+msgid "Too many categories (found: %i, max: %i). Try to rescale or reclassify the map"
+msgstr "ã«ãã´ãªã¼ãå¤ããã¾ã (æå®æ°ï¼%i, æå¤§ï¼ %i)ï¼ ãããã®ç¸®å°ºã夿´ãããååé¡ããã¦ã¿ã¦ãã ãã"
#: ../raster/r.texture/h_measure.c:937
#, c-format
@@ -11757,9 +11263,7 @@
#: ../raster/r.in.gdal/main.c:81
msgid "Import GDAL supported raster file into a binary raster map layer."
-msgstr ""
-"GDALã§ãµãã¼ãããã¦ããã©ã¹ã¿ã¼ãã¡ã¤ã«ããã¤ããªã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ã«ã¤"
-"ã³ãã¼ããã¾ã"
+msgstr "GDALã§ãµãã¼ãããã¦ããã©ã¹ã¿ã¼ãã¡ã¤ã«ããã¤ããªã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ã«ã¤ã³ãã¼ããã¾ã"
#: ../raster/r.in.gdal/main.c:87
msgid "Raster file to be imported"
@@ -11804,39 +11308,20 @@
msgstr "ã©ã¹ã¿ã¼ããã <%s> ã¯åå¨ãã¾ãã䏿¸ãããã¾ã"
#: ../raster/r.in.gdal/main.c:250
-msgid ""
-"The polynomial rectification used in i.rectify does not work well with NOAA/"
-"AVHRR data. Try using gdalwarp with thin plate spline rectification instead. "
-"(-tps)"
-msgstr ""
-"(-tps)"
+msgid "The polynomial rectification used in i.rectify does not work well with NOAA/AVHRR data. Try using gdalwarp with thin plate spline rectification instead. (-tps)"
+msgstr "The polynomial rectification used in i.rectify does not work well with NOAA/AVHRR data. Try using gdalwarp with thin plate spline rectification instead. (-tps)"
#: ../raster/r.in.gdal/main.c:266
-msgid ""
-"Input raster map is flipped or rotated - cannot import. You may use "
-"'gdalwarp' to transform the map to North-up."
-msgstr ""
-"å
¥åããã©ã¹ã¿ã¼ãããã¯å転ãã¦ãã¦å
¥åã§ãã¾ããã 'gdalwarp' ãç¨ããã¨"
-"ãããããã¼ã¹ã¢ããã«å¤æã§ããã§ããã"
+msgid "Input raster map is flipped or rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
+msgstr "å
¥åã§ãã¾ããã 'gdalwarp' ãç¨ããã¨ãããããã¼ã¹ã¢ããã«å¤æã§ããã§ããã"
#: ../raster/r.in.gdal/main.c:308
-msgid ""
-"Map bounds have been constrained to geographic coordinates. You will almost "
-"certainly want to check map bounds and resolution with r.info and reset them "
-"with r.region before going any further."
-msgstr ""
-"ãããå¢çç·ã¯å°ç座æ¨ã«å¶éããã¦ãã¾ããæ¬¡ã¸é²ãåã«r.infoã§ãããå¢çç·ã¨"
-"è§£å度ã調ã¹ã¦r.regionã§ãªã»ãããã¾ãã"
+msgid "Map bounds have been constrained to geographic coordinates. You will almost certainly want to check map bounds and resolution with r.info and reset them with r.region before going any further."
+msgstr "ãããå¢çç·ã¯å°ç座æ¨ã«å¶éããã¦ãã¾ããæ¬¡ã¸é²ãåã«r.infoã§ãããå¢çç·ã¨è§£å度ã調ã¹ã¦r.regionã§ãªã»ãããã¾ãã"
#: ../raster/r.in.gdal/main.c:328
-msgid ""
-"Unable to convert input map projection to GRASS format; cannot create new "
-"location."
-msgstr ""
-"å
¥åãããã®æå½±ãGRASSãã©ã¼ãããã«å¤æã§ãã¾ãããæ°è¦ã®ãã±ã¼ã·ã§ã³ã使"
-"ã§ãã¾ãã"
+msgid "Unable to convert input map projection to GRASS format; cannot create new location."
+msgstr "å
¥åãããã®æå½±ãGRASSãã©ã¼ãããã«å¤æã§ãã¾ãããæ°è¦ã®ãã±ã¼ã·ã§ã³ã使ã§ãã¾ãã"
#: ../raster/r.in.gdal/main.c:334
#, c-format
@@ -11846,12 +11331,10 @@
#: ../raster/r.in.gdal/main.c:432
msgid ""
"\n"
-"You can use the -o flag to r.in.gdal to override this check and use the "
-"location definition for the dataset.\n"
+"You can use the -o flag to r.in.gdal to override this check and use the location definition for the dataset.\n"
msgstr ""
"\n"
-"ãã®ãã§ãã¯ããªã¼ãã¼ã©ã¤ããããã¼ã¿ã»ããã®ãã±ã¼ã·ã§ã³å®ç¾©ã使ãã«ã¯ãr."
-"in.gdal ã³ãã³ãã« -o ãã©ãã°ã使ãã¾ã\n"
+"ãã®ãã§ãã¯ããªã¼ãã¼ã©ã¤ããããã¼ã¿ã»ããã®ãã±ã¼ã·ã§ã³å®ç¾©ã使ãã«ã¯ãr.in.gdal ã³ãã³ãã« -o ãã©ãã°ã使ãã¾ã\n"
#: ../raster/r.in.gdal/main.c:551
#, c-format
@@ -11918,59 +11401,32 @@
msgstr "ãã¸ã¿ã«æ¨é«ã¢ãã«ããã®å°å¹³ç·è§åº¦ã®ç®å®. "
#: ../raster/r.horizon/main.c:181
-msgid ""
-"Computes horizon angle height from a digital elevation model. The module has "
-"two different modes of operation: 1. Computes the entire horizon around a "
-"single point whose coordinates are given with the 'coord' option. The "
-"horizon height (in radians). 2. Computes one or more raster maps of the "
-"horizon height in a single direction. The input for this is the angle (in "
-"degrees), which is measured counterclockwise with east=0, north=90 etc. The "
-"output is the horizon height in radians."
-msgstr ""
-"ãã¸ã¿ã«æ¨é«ã¢ãã«ããæ°´å¹³è§åº¦ã®é«ããç®å®. ã¢ã¸ã¥ã¼ã«ã«ã¯2ã¤ã®ç°ãªãæä½ã¢ã¼"
-"ããããã¾ã: 1.'coord' ãªãã·ã§ã³ãä¸ãããã¦ãã座æ¨ããã¤1ã¤ã®ãã¤ã³ãã"
-"ä¸å¿ã«å
¨æ°´å¹³ãç®å®. æ°´å¹³ã®é«ã (ã©ã¸ã¢ã³ã§). 2. 1æ¹åã«ãããæ°´å¹³ã®é«ãã®1ã¤"
-"ã¾ãã¯ãã以ä¸ã®ã©ã¹ã¿ã¼ãããã®ç®å®. ãã®å
¥åã¯æ±=0, å=90 ãªã©ã§åæè¨ã¾ã"
-"ãã«æ¸¬å®ãããè§åº¦ï¼åº¦æ°ï¼ã§ã. åºåã¯ã©ã¸ã¢ã³ã§ã®æ°´å¹³ã®é«ãã§ã."
+msgid "Computes horizon angle height from a digital elevation model. The module has two different modes of operation: 1. Computes the entire horizon around a single point whose coordinates are given with the 'coord' option. The horizon height (in radians). 2. Computes one or more raster maps of the horizon height in a single direction. The input for this is the angle (in degrees), which is measured counterclockwise with east=0, north=90 etc. The output is the horizon height in radians."
+msgstr "ãã¸ã¿ã«æ¨é«ã¢ãã«ããæ°´å¹³è§åº¦ã®é«ããç®å®. ã¢ã¸ã¥ã¼ã«ã«ã¯2ã¤ã®ç°ãªãæä½ã¢ã¼ããããã¾ã: 1.'coord' ãªãã·ã§ã³ãä¸ãããã¦ãã座æ¨ããã¤1ã¤ã®ãã¤ã³ããä¸å¿ã«å
¨æ°´å¹³ãç®å®. æ°´å¹³ã®é«ã (ã©ã¸ã¢ã³ã§). 2. 1æ¹åã«ãããæ°´å¹³ã®é«ãã®1ã¤ã¾ãã¯ãã以ä¸ã®ã©ã¹ã¿ã¼ãããã®ç®å®. ãã®å
¥åã¯æ±=0, å=90 ãªã©ã§åæè¨ã¾ããã«æ¸¬å®ãããè§åº¦ï¼åº¦æ°ï¼ã§ã. åºåã¯ã©ã¸ã¢ã³ã§ã®æ°´å¹³ã®é«ãã§ã."
#: ../raster/r.horizon/main.c:234
msgid "Direction in which you want to know the horizon height"
msgstr "æ°´å¹³ã®é«ããç¥ãããæ¹å"
#: ../raster/r.horizon/main.c:250
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer around the present "
-"region"
-msgstr ""
-"æ°´å¹³ã©ã¹ã¿ã¼ç¨ã«, DEMããç¾é åãä¸å¿ã«ä½åãªãããã¢ã¼ãèªã¿è¾¼ãã§ãã¾ã"
+msgid "For horizon rasters, read from the DEM an extra buffer around the present region"
+msgstr "æ°´å¹³ã©ã¹ã¿ã¼ç¨ã«, DEMããç¾é åãä¸å¿ã«ä½åãªãããã¢ã¼ãèªã¿è¾¼ãã§ãã¾ã"
#: ../raster/r.horizon/main.c:258
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer eastward the present "
-"region"
-msgstr ""
-"æ°´å¹³ã©ã¹ã¿ã¼ã®ãããDEM ä½åãªãããã¡ æ±æ¹ã®ç¾å¨ã®é åããèªã¿è¾¼ã¿ã¾ã"
+msgid "For horizon rasters, read from the DEM an extra buffer eastward the present region"
+msgstr "æ°´å¹³ã©ã¹ã¿ã¼ã®ãããDEM ä½åãªãããã¡ æ±æ¹ã®ç¾å¨ã®é åããèªã¿è¾¼ã¿ã¾ã"
#: ../raster/r.horizon/main.c:266
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer westward the present "
-"region"
-msgstr ""
-"æ°´å¹³ã©ã¹ã¿ã¼ã®ãã, DEM ä½åãªããã㡠西æ¹ã®ç¾å¨ã®é åããèªã¿è¾¼ã¿ã¾ã "
+msgid "For horizon rasters, read from the DEM an extra buffer westward the present region"
+msgstr "æ°´å¹³ã©ã¹ã¿ã¼ã®ãã, DEM ä½åãªããã㡠西æ¹ã®ç¾å¨ã®é åããèªã¿è¾¼ã¿ã¾ã "
#: ../raster/r.horizon/main.c:274
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer northward the present "
-"region"
-msgstr ""
-"æ°´å¹³ã©ã¹ã¿ã¼ã®ãã, DEM ä½åãªãããã¡ åæ¹ã®ç¾å¨ã®é åããèªã¿è¾¼ã¿ã¾ã "
+msgid "For horizon rasters, read from the DEM an extra buffer northward the present region"
+msgstr "æ°´å¹³ã©ã¹ã¿ã¼ã®ãã, DEM ä½åãªãããã¡ åæ¹ã®ç¾å¨ã®é åããèªã¿è¾¼ã¿ã¾ã "
#: ../raster/r.horizon/main.c:282
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer southward the present "
-"region"
-msgstr ""
+msgid "For horizon rasters, read from the DEM an extra buffer southward the present region"
#: ../raster/r.horizon/main.c:290
msgid "The maximum distance to consider when finding the horizon height"
@@ -12034,12 +11490,8 @@
msgstr "ã©ã¹ã¿ã¼, åç æµ, ä¾µé£, å ç©"
#: ../raster/simwe/r.sim.sediment/main.c:113
-msgid ""
-"Sediment transport and erosion/deposition simulation using path sampling "
-"method (SIMWE)."
-msgstr ""
-"çµè·¯ãµã³ããªã³ã°ã¡ã½ãã (SIMWE) ãç¨ããåç æµéãä¾µé£/å ç©ã®ã·ãã¥ã¬ã¼ã·ã§"
-"ã³"
+msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)."
+msgstr "çµè·¯ãµã³ããªã³ã°ã¡ã½ãã (SIMWE) ãç¨ããåç æµéãä¾µé£/å ç©ã®ã·ãã¥ã¬ã¼ã·ã§ã³"
#: ../raster/simwe/r.sim.sediment/main.c:118
#: ../raster/simwe/r.sim.water/main.c:125
@@ -12233,9 +11685,7 @@
msgstr "ã¦ã©ã¼ã«ã¼ã®æ°. ããã©ã«ãå¤ã¯ã»ã«æ°ã®äºå"
#: ../raster/simwe/r.sim.water/main.c:276
-msgid ""
-"Threshold water depth [m] (diffusion increases after this water depth is "
-"reached)"
+msgid "Threshold water depth [m] (diffusion increases after this water depth is reached)"
msgstr "é¾å¤æ°´æ·± [m] (ãã®æ°´æ·±ã«éããã¨æ¡æ£ãå¢ãã¾ã) "
#: ../raster/simwe/r.sim.water/main.c:284
@@ -12265,12 +11715,8 @@
#: ../raster/simwe/simlib/input.c:409
#, c-format
-msgid ""
-"Raster map <%s> not found, and manin_val undefined, choose one to be allowed "
-"to process"
-msgstr ""
-"ã©ã¹ã¿ã¼ããã <%s> ãã¿ã¤ããã¾ãã. ã¾ããmanin_val ãå®ç¾©ããã¦ãã¾ããã"
-"ã©ã¡ãããè¡ã£ã¦ä¸ãã"
+msgid "Raster map <%s> not found, and manin_val undefined, choose one to be allowed to process"
+msgstr "ã©ã¹ã¿ã¼ããã <%s> ãã¿ã¤ããã¾ãã. ã¾ããmanin_val ãå®ç¾©ããã¦ãã¾ãããã©ã¡ãããè¡ã£ã¦ä¸ãã"
#: ../raster/simwe/simlib/input.c:541
msgid "Zero value in Mannings n"
@@ -12338,9 +11784,7 @@
#: ../raster/r.thin/main.c:57
msgid "Thins non-zero cells that denote linear features in a raster map."
-msgstr ""
-"ã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ã«ãããç·åãã£ã¼ãã£ã表示ãããã³ã¼ãã»ã«ãç´°ç·åã"
-"ã¾ã"
+msgstr "ã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ã«ãããç·åãã£ã¼ãã£ã表示ãããã³ã¼ãã»ã«ãç´°ç·åãã¾ã"
#: ../raster/r.thin/main.c:69
msgid "Maximal number of iterations"
@@ -12406,9 +11850,7 @@
msgstr "ç´°ç·åã¯çµäºãã¦ãã¾ãã, 'å復' ãã©ã¡ã¼ã¿ã¼ãå¢å ãã¦ãã ãã. "
#: ../raster/r.covar/main.c:55
-msgid ""
-"Outputs a covariance/correlation matrix for user-specified raster map layer"
-"(s)."
+msgid "Outputs a covariance/correlation matrix for user-specified raster map layer(s)."
msgstr "ã©ã¹ã¿ã¼ãããã®å
±åæ£ã¨ç¸é¢ãæ±ãã¾ã "
#: ../raster/r.covar/main.c:62
@@ -12431,43 +11873,23 @@
#: ../raster/r.out.gdal/export_band.c:186
#, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %d will "
-"be used to represent no-data values in the input map. You can specify a "
-"nodata value with the %s option."
-msgstr ""
-"å
¥åããã©ã¹ã¿ã¼ãããã¯NULLå¤ï¼ãã¼ã¿ç¡ãï¼ã»ã«ãå«ãã§ãã¾ãï¼ãã®æå®ãã"
-"ããããã§å¤ %d ã¯ãã¼ã¿ç¡ãå¤ã示ãã¾ãï¼%s ãã©ã¡ã¼ã¿ã¼ã§ãã¼ã¿ç¡ãå¤ãæå®"
-"ã§ãã¾ã"
+msgid "Input raster map contains cells with NULL-value (no-data). The value %d will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
+msgstr "å
¥åããã©ã¹ã¿ã¼ãããã¯NULLå¤ï¼ãã¼ã¿ç¡ãï¼ã»ã«ãå«ãã§ãã¾ãï¼ãã®æå®ããããããã§å¤ %d ã¯ãã¼ã¿ç¡ãå¤ã示ãã¾ãï¼%s ãã©ã¡ã¼ã¿ã¼ã§ãã¼ã¿ç¡ãå¤ãæå®ã§ãã¾ã"
#: ../raster/r.out.gdal/export_band.c:191
#, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %f will "
-msgstr ""
-"å
-"ããããã§å¤ %f ã¯ãã¼ã¿ç¡ãå¤ã示ãã¾ãï¼%s ãã©ã¡ã¼ã¿ã¼ã§ãã¼ã¿ç¡ãå¤ãæå®"
-"ã§ãã¾ã"
+msgid "Input raster map contains cells with NULL-value (no-data). The value %f will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
+msgstr "å
¥åããã©ã¹ã¿ã¼ãããã¯NULLå¤ï¼ãã¼ã¿ç¡ãï¼ã»ã«ãå«ãã§ãã¾ãï¼ãã®æå®ããããããã§å¤ %f ã¯ãã¼ã¿ç¡ãå¤ã示ãã¾ãï¼%s ãã©ã¡ã¼ã¿ã¼ã§ãã¼ã¿ç¡ãå¤ãæå®ã§ãã¾ã"
#: ../raster/r.out.gdal/export_band.c:201
#, c-format
-msgid ""
-"The default nodata value is present in rasterband <%s> and would lead to "
-"data loss. Please specify a custom nodata value with the %s parameter."
-msgstr ""
-"ããã©ã«ãã®ãã¼ã¿ãªãå¤ã¯rasterband <%s>ã«åå¨ãããã¼ã¿ã®æå¤±ãå¼ãèµ·ããã¾"
-"ãã%sãã©ã¡ã¼ã¿ã§ã«ã¹ã¿ã ã®ãã¼ã¿ãªãå¤ãæå®ãã¦ãã ããã"
+msgid "The default nodata value is present in rasterband <%s> and would lead to data loss. Please specify a custom nodata value with the %s parameter."
+msgstr "ããã©ã«ãã®ãã¼ã¿ãªãå¤ã¯rasterband <%s>ã«åå¨ãããã¼ã¿ã®æå¤±ãå¼ãèµ·ããã¾ãã%sãã©ã¡ã¼ã¿ã§ã«ã¹ã¿ã ã®ãã¼ã¿ãªãå¤ãæå®ãã¦ãã ããã"
#: ../raster/r.out.gdal/export_band.c:208
#, c-format
-msgid ""
-"The user given nodata value %g is present in rasterband <%s> and would lead "
-"to data loss. Please specify a different nodata value with the %s parameter."
-msgstr ""
-"ã¦ã¼ã¶ã¼æå®ã®ãã¼ã¿ãªãå¤ %g ã¯rasterband <%s>ã«åå¨ãããã¼ã¿ã®æå¤±ãå¼ãèµ·"
-"ããã¾ãã%sãã©ã¡ã¼ã¿ã§å¥ã®ãã¼ã¿ãªãå¤ãæå®ãã¦ãã ããã"
+msgid "The user given nodata value %g is present in rasterband <%s> and would lead to data loss. Please specify a different nodata value with the %s parameter."
+msgstr "ã¦ã¼ã¶ã¼æå®ã®ãã¼ã¿ãªãå¤ %g ã¯rasterband <%s>ã«åå¨ãããã¼ã¿ã®æå¤±ãå¼ãèµ·ããã¾ãã%sãã©ã¡ã¼ã¿ã§å¥ã®ãã¼ã¿ãªãå¤ãæå®ãã¦ãã ããã"
#: ../raster/r.out.gdal/export_band.c:254
msgid "Unable to get raster band"
@@ -12579,20 +12001,15 @@
#: ../raster/r.out.gdal/main.c:192
#: ../locale/scriptstrings/d.out.file_to_translate.c:21
msgid "In the form of \"NAME=VALUE\", separate multiple entries with a comma."
-msgstr ""
-"ãªãã·ã§ã³ã®æå®ã¯\"NAME=VALUE\"ã®å½¢å¼ã§ãè¤æ°æå®ã®å ´åã¯ã«ã³ãã§åºåã"
+msgstr "ãªãã·ã§ã³ã®æå®ã¯\"NAME=VALUE\"ã®å½¢å¼ã§ãè¤æ°æå®ã®å ´åã¯ã«ã³ãã§åºåã"
#: ../raster/r.out.gdal/main.c:199
msgid "Metadata key(s) and value(s) to include"
msgstr "ä»»æã®ã¡ã¿ãã¼ã¿ãæå®"
#: ../raster/r.out.gdal/main.c:201
-msgid ""
-"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. "
-"Not supported by all output format drivers."
-msgstr ""
-" \"META-TAG=VALUE\" ã®å½¢å¼ã§ãè¤æ°æå®ã®å ´åã¯ã«ã³ãã§åºåãããµãã¼ããã¦ã"
-"ãªãåºåãã©ã¤ããããã¾ã"
+msgid "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. Not supported by all output format drivers."
+msgstr " \"META-TAG=VALUE\" ã®å½¢å¼ã§ãè¤æ°æå®ã®å ´åã¯ã«ã³ãã§åºåãããµãã¼ããã¦ããªãåºåãã©ã¤ããããã¾ã"
#: ../raster/r.out.gdal/main.c:210
msgid "Assign a specified nodata value to output bands"
@@ -12615,12 +12032,8 @@
#: ../raster/r.out.gdal/main.c:267
#, c-format
-msgid ""
-"Driver <%s> does not support direct writing. Using MEM driver for "
-"intermediate dataset."
-msgstr ""
-"ãã©ã¤ã <%s> ã¯ãã¤ã¬ã¯ãåºåããµãã¼ããã¦ãã¾ãããä¸éãã¼ã¿ã»ããã«ã¯MEM"
-"ãã©ã¤ãã使ç¨ãã¦ãã ãã"
+msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
+msgstr "ãã©ã¤ã <%s> ã¯ãã¤ã¬ã¯ãåºåããµãã¼ããã¦ãã¾ãããä¸éãã¼ã¿ã»ããã«ã¯MEMãã©ã¤ãã使ç¨ãã¦ãã ãã"
#: ../raster/r.out.gdal/main.c:272
msgid "Unable to get in-memory raster driver"
@@ -12647,28 +12060,18 @@
#: ../raster/r.out.gdal/main.c:435
#, c-format
-msgid ""
-"Precision loss: Raster map <%s> of type %s to be exported as %s. This can be "
-"avoided by using %s."
-msgstr ""
-"精度ã失ããã¾ãï¼ã©ã¹ã¿ã¼ããã <%s> ï¼ã¿ã¤ã %sï¼ã¯ %sãã¨ãã¦ã¨ã¯ã¹ãã¼ã"
-"ããã¾ããã %sãã使ããã¨ã§åé¿ã§ãã¾ãã"
+msgid "Precision loss: Raster map <%s> of type %s to be exported as %s. This can be avoided by using %s."
+msgstr "精度ã失ããã¾ãï¼ã©ã¹ã¿ã¼ããã <%s> ï¼ã¿ã¤ã %sï¼ã¯ %sãã¨ãã¦ã¨ã¯ã¹ãã¼ãããã¾ããã %sãã使ããã¨ã§åé¿ã§ãã¾ãã"
#: ../raster/r.out.gdal/main.c:446
#, c-format
-msgid ""
-"Precision loss: The range of <%s> can not be accurately preserved with GDAL "
-"datatype Float32. This can be avoided by exporting to Int32 or Float64."
-msgstr ""
+msgid "Precision loss: The range of <%s> can not be accurately preserved with GDAL datatype Float32. This can be avoided by exporting to Int32 or Float64."
+msgstr "精度ã失ããã¾ãï¼ã¬ã³ã¸ <%s> GDALãã¼ã¿ã¿ã¤ã Float32ã§ã¯æ¸©åããã¾ããã Int32ãããã¯Float64ã§ã¨ã¯ã¹ãã¼ããããã¨ã§åé¿ã§ãã¾ãã"
#: ../raster/r.out.gdal/main.c:454
#, c-format
-msgid ""
-"Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. "
-"This can be avoided by using Float64"
-msgstr ""
-"精度ã失ããã¾ãï¼Float32ã¯ã©ã¹ã¿ã¼ããã %s ã®DCELLã®ç²¾åº¦ãä¿æã§ãã¾ããã "
-"Float64 ã使ããã¨ã§åé¿ã§ãã¾ãã"
+msgid "Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. This can be avoided by using Float64"
+msgstr "精度ã失ããã¾ãï¼Float32ã¯ã©ã¹ã¿ã¼ããã %s ã®DCELLã®ç²¾åº¦ãä¿æã§ãã¾ããã Float64 ã使ããã¨ã§åé¿ã§ãã¾ãã"
#: ../raster/r.out.gdal/main.c:482 ../raster/r.out.gdal/main.c:511
#: ../raster/r.out.gdal/main.c:515
@@ -12743,15 +12146,9 @@
#: ../raster/r.out.gdal/main.c:722 ../raster/r.out.gdal/main.c:735
#: ../raster/r.out.gdal/main.c:749 ../raster/r.out.gdal/main.c:762
#: ../raster/r.out.gdal/main.c:777
-#, fuzzy, c-format
-msgid ""
-"Mismatch between metadata nodata value and actual nodata value in exported "
-"raster: specified nodata value %f gets converted to %d by selected GDAL "
-"datatype."
-msgstr ""
-"ã¨ã¯ã¹ãã¼ããããã©ã¹ã¿ã¼ã«ãããã¡ã¿ãã¼ã¿ã®ãã¼ã¿ãªãå¤ã¨å®éã®ãã¼ã¿ãªã"
-"å¤ã®éã®ä¸ä¸è´: æå®ã®ãã¼ã¿ãªãå¤%ï½ã¯é¸æãããGDALãã¼ã¿ã¿ã¤ãã«ãã£ã¦%dã¸"
-"ã¨å¤æããã¾ã"
+#, c-format
+msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %f gets converted to %d by selected GDAL datatype."
+msgstr "ã¨ã¯ã¹ãã¼ããããã©ã¹ã¿ã¼ã«ãããã¡ã¿ãã¼ã¿ã®ãã¼ã¿ãªãå¤ã¨å®éã®ãã¼ã¿ãªãå¤ã®éã®ä¸ä¸è´: æå®ã®ãã¼ã¿ãªãå¤ %fã¯é¸æãããGDALãã¼ã¿ã¿ã¤ãã«ãã£ã¦ %d ã¸ã¨å¤æããã¾ã"
#: ../raster/r.out.gdal/main.c:725 ../raster/r.out.gdal/main.c:752
#: ../raster/r.out.gdal/main.c:780
@@ -12766,14 +12163,8 @@
#: ../raster/r.out.gdal/main.c:791
#, c-format
-msgid ""
-"raster: specified nodata value %g gets converted to %g by selected GDAL "
-"datatype."
-msgstr ""
-"å¤ã®éã®ä¸ä¸è´: æå®ã®ãã¼ã¿ãªãå¤%gã¯é¸æãããGDALãã¼ã¿ã¿ã¤ãã«ãã£ã¦%gã¸"
-"ã¨å¤æããã¾ã"
+msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %g by selected GDAL datatype."
+msgstr "ã¨ã¯ã¹ãã¼ããããã©ã¹ã¿ã¼ã«ãããã¡ã¿ãã¼ã¿ã®ãã¼ã¿ãªãå¤ã¨å®éã®ãã¼ã¿ãªãå¤ã®éã®ä¸ä¸è´: æå®ã®ãã¼ã¿ãªãå¤%gã¯é¸æãããGDALãã¼ã¿ã¿ã¤ãã«ãã£ã¦%gã¸ã¨å¤æããã¾ã"
#: ../raster/r.out.gdal/main.c:794
#, c-format
@@ -12846,12 +12237,8 @@
msgstr "G_malloc: ã¡ã¢ãªãããã¾ãã"
#: ../raster/r.lake/main.c:303
-msgid ""
-"Given water level at seed point is below earth surface. Increase water level "
-"or move seed point."
-msgstr ""
-"ã·ã¼ããã¤ã³ãã®æ¹æ°´ã¬ãã«ãå°è¡¨ããä¸ãæ°´ä½ãä¸ãããã·ã¼ããã¤ã³ããç§»åã"
-"ã¦ãã ãã "
+msgid "Given water level at seed point is below earth surface. Increase water level or move seed point."
+msgstr "ã·ã¼ããã¤ã³ãã®æ¹æ°´ã¬ãã«ãå°è¡¨ããä¸ãæ°´ä½ãä¸ãããã·ã¼ããã¤ã³ããç§»åãã¦ãã ãã "
#: ../raster/r.lake/main.c:386
#, c-format
@@ -12873,13 +12260,8 @@
msgstr "æ¹æ°´æ·±åº¦ (å°å½¢ã©ã¹ã¿ã¼ããã) ãã¡ã¼ãã«æ³ã®å ´åã®ã¿ããªã¥ã¼ã ãä¿®æ£"
#: ../raster/r.surf.gauss/main.c:48
-msgid ""
-"GRASS module to produce a raster map layer of gaussian deviates whose mean "
-"and standard deviation can be expressed by the user. It uses a gaussian "
-"random number generator."
-msgstr ""
-"ã¦ã¼ã¶ã¼ãæå®ããå¹³åå¤ã¨æ¨æºåå·®ã®ã¬ã¦ã¹åå·®ã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ã使ã"
-"ãGRASS ã¢ã¸ã¥ã¼ã«ãã¬ã¦ã¹ä¹±æ°çºçã使ç¨ãã¾ã"
+msgid "GRASS module to produce a raster map layer of gaussian deviates whose mean and standard deviation can be expressed by the user. It uses a gaussian random number generator."
+msgstr "ã¦ã¼ã¶ã¼ãæå®ããå¹³åå¤ã¨æ¨æºåå·®ã®ã¬ã¦ã¹åå·®ã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ã使ããGRASS ã¢ã¸ã¥ã¼ã«ãã¬ã¦ã¹ä¹±æ°çºçã使ç¨ãã¾ã"
#: ../raster/r.surf.gauss/main.c:55
msgid "Name of the output random surface"
@@ -12935,14 +12317,11 @@
#: ../raster/r.in.ascii/main.c:70
msgid "Converts ASCII raster file to binary raster map layer."
-msgstr ""
-"ASCIIå½¢å¼ã®ã©ã¹ã¿ã¼ãã¡ã¤ã«ããã¤ããªã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ã«å¤æãã¾ã"
+msgstr "ASCIIå½¢å¼ã®ã©ã¹ã¿ã¼ãã¡ã¤ã«ããã¤ããªã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ã«å¤æãã¾ã"
#: ../raster/r.in.ascii/main.c:74
-msgid ""
-"ASCII raster file to be imported. If not given reads from standard input"
-msgstr ""
-"ã¤ã³ãã¼ãããASCII ã©ã¹ã¿ã¼ãã¡ã¤ã«. ãªããã°æ¨æºå
¥åããèªã¿è¾¼ã¿ã¾ã "
+msgid "ASCII raster file to be imported. If not given reads from standard input"
+msgstr "ã¤ã³ãã¼ãããASCII ã©ã¹ã¿ã¼ãã¡ã¤ã«. ãªããã°æ¨æºå
¥åããèªã¿è¾¼ã¿ã¾ã "
#: ../raster/r.in.ascii/main.c:100
msgid "String representing NULL value data cell"
@@ -13012,9 +12391,7 @@
#: ../raster/r.in.ascii/gethead.c:169
msgid "ignoring type filed in header, type is set on command line"
-msgstr ""
-"ãããã¼ã«ãããã¿ã¤ããã£ã¼ã«ããç¡è¦ãã¦ãã¾ããã¿ã¤ãã¯ã³ãã³ãã©ã¤ã³ã«è¨"
-"å®ããã¦ãã¾ã"
+msgstr "ãããã¼ã«ãããã¿ã¤ããã£ã¼ã«ããç¡è¦ãã¦ãã¾ããã¿ã¤ãã¯ã³ãã³ãã©ã¤ã³ã«è¨å®ããã¦ãã¾ã"
#: ../raster/r.in.ascii/gethead.c:176
msgid "illegal multiplier field: using 1.0"
@@ -13022,15 +12399,11 @@
#: ../raster/r.in.ascii/gethead.c:181
msgid "ignoring multiplier filed in header, multiplier is set on command line"
-msgstr ""
-"ãããã¼ã«ããã乿°ãã£ã¼ã«ããç¡è¦ãã¦ãã¾ãã乿°ã¯ã³ãã³ãã©ã¤ã³ã«è¨å®ã"
-"ãã¦ãã¾ã"
+msgstr "ãããã¼ã«ããã乿°ãã£ã¼ã«ããç¡è¦ãã¦ãã¾ãã乿°ã¯ã³ãã³ãã©ã¤ã³ã«è¨å®ããã¦ãã¾ã"
#: ../raster/r.in.ascii/gethead.c:189
msgid "ignoring null filed in header, null string is set on command line"
-msgstr ""
-"ãããã¼ã«ããNULLãã£ã¼ã«ããç¡è¦ãã¦ãã¾ã, NULLã¹ããªã³ã°ã¯ã³ãã³ãã©ã¤ã³"
-"ã«è¨å®ããã¦ãã¾ã"
+msgstr "ãããã¼ã«ããNULLãã£ã¼ã«ããç¡è¦ãã¦ãã¾ã, NULLã¹ããªã³ã°ã¯ã³ãã³ãã©ã¤ã³ã«è¨å®ããã¦ãã¾ã"
#: ../raster/r.in.ascii/gethead.c:218
msgid "error in ascii data format"
@@ -13100,9 +12473,7 @@
#: ../raster/r.surf.fractal/process.c:53
msgid "Unable to allocate data buffer. Check current region with g.region."
-msgstr ""
-"ãã¼ã¿ãããã¡ãå²ãå½ã¦ããã¾ãã. g.region ã³ãã³ãã§ç¾å¨é åããã§ãã¯ã"
-"ã¦ä¸ãã"
+msgstr "ãã¼ã¿ãããã¡ãå²ãå½ã¦ããã¾ãã. g.region ã³ãã³ãã§ç¾å¨é åããã§ãã¯ãã¦ä¸ãã"
#: ../raster/r.surf.fractal/spec_syn.c:61
msgid "Preliminary surface calculations..."
@@ -13135,11 +12506,8 @@
msgstr "ãã©ã¯ã¿ã«æ¬¡å
æ° %.2lf ã¯2ã¨3ã®éã§ãªããã°ããã¾ãã"
#: ../raster/r.average/main.c:53
-msgid ""
-"Finds the average of values in a cover map within areas assigned the same "
-msgstr ""
-"ãã¼ã¹ãããã«ãããåä¸ã«ãã´ãªã¼å
ã§ã®ã«ãã¼ãããã®å¹³åå¤ãè¨ç®ãã¾ã "
+msgid "Finds the average of values in a cover map within areas assigned the same category value in a user-specified base map."
+msgstr "ãã¼ã¹ãããã«ãããåä¸ã«ãã´ãªã¼å
#: ../raster/r.average/main.c:93
#, c-format
@@ -13401,9 +12769,7 @@
#: ../raster/r.flow/precomp.c:115
#, c-format
msgid "Resolution too unbalanced (%f x %f); please resample input map"
-msgstr ""
-"è§£å度ã®ãã©ã³ã¹ãæªããã¾ã (%f x %f); å
¥åããããå度ãµã³ããªã³ã°ãã¦ãã "
-"ãã"
+msgstr "è§£å度ã®ãã©ã³ã¹ãæªããã¾ã (%f x %f); å
¥åããããå度ãµã³ããªã³ã°ãã¦ãã ãã"
#: ../raster/r.flow/calc.c:303
msgid "Calculating maps ..."
@@ -13414,12 +12780,8 @@
msgstr "ç¾å¨ã®é åãåå¾ã§ãã¾ãã"
#: ../raster/r.flow/calc.c:413
-msgid ""
-"Construction of slope curves (flowlines), flowpath lengths, and flowline "
-"densities (upslope areas) from a raster digital elevation model (DEM)."
-msgstr ""
-"徿ã«ã¼ãã®å»ºç¯ï¼ããã¼ã©ã¤ã³ï¼ãããã¼ãã¹ã®é·ããããã¦ã©ã¹ã¿ã¼ãã¸ã¿ã«æ¨"
-"é«ã¢ãã«ï¼DEMï¼ããã®ããã¼ã©ã¤ã³å¯åº¦ï¼ä¸ãåã¨ãªã¢ï¼ "
+msgid "Construction of slope curves (flowlines), flowpath lengths, and flowline densities (upslope areas) from a raster digital elevation model (DEM)."
+msgstr "徿ã«ã¼ãã®å»ºç¯ï¼ããã¼ã©ã¤ã³ï¼ãããã¼ãã¹ã®é·ããããã¦ã©ã¹ã¿ã¼ãã¸ã¿ã«æ¨é«ã¢ãã«ï¼DEMï¼ããã®ããã¼ã©ã¤ã³å¯åº¦ï¼ä¸ãåã¨ãªã¢ï¼ "
#: ../raster/r.flow/calc.c:451
msgid "Input elevation raster map"
@@ -13467,16 +12829,11 @@
#: ../raster/r.flow/calc.c:533
msgid "You must select one or more output maps (flout, lgout, dsout)"
-msgstr ""
-"1ã¤ã¾ãã¯ãã以ä¸ã®åºåãããã鏿ãã¦ãã ãã (flout, lgout, dsout) "
+msgstr "1ã¤ã¾ãã¯ãã以ä¸ã®åºåãããã鏿ãã¦ãã ãã (flout, lgout, dsout) "
#: ../raster/r.flow/calc.c:549
-msgid ""
-"lat/long projection not supported by r.flow. Please use 'r.watershed' for "
-"calculating flow accumulation."
-msgstr ""
-"r.flow ã«ãµãã¼ãããã¦ããªã緯度/çµåº¦æå½±. ç´¯ç©æµéã®è¨ç®ã«ã¯ 'r.watershed' "
-"ã使ç¨ãã¦ãã ãã."
+msgid "lat/long projection not supported by r.flow. Please use 'r.watershed' for calculating flow accumulation."
+msgstr "r.flow ã«ãµãã¼ãããã¦ããªã緯度/çµåº¦æå½±. ç´¯ç©æµéã®è¨ç®ã«ã¯ 'r.watershed' ã使ç¨ãã¦ãã ãã."
#: ../raster/r.flow/io.c:68
#, c-format
@@ -13693,9 +13050,7 @@
msgstr "ç»åãåé¡ã管çãSMAP"
#: ../imagery/i.smap/shapiro/main.c:40
-msgid ""
-"Performs contextual image classification using sequential maximum a "
-"posteriori (SMAP) estimation."
+msgid "Performs contextual image classification using sequential maximum a posteriori (SMAP) estimation."
msgstr "é æ¬¡æå¤§äºå¾è©ä¾¡ï¼SMAPï¼ã使ç¨ãã¦ããæèä¸ã®ç»ååé¡ãæ©è½ãã"
#: ../imagery/i.smap/shapiro/parse.c:21 ../imagery/i.maxlik/main.c:79
@@ -13764,12 +13119,8 @@
msgstr "ç»åãã¼ã¿ã®ã»ã«ã¹ãã¯ãã«åå°çãåé¡ãã"
#: ../imagery/i.maxlik/main.c:67
-msgid ""
-"Classification is based on the spectral signature information generated by "
-"either i.cluster, i.class, or i.gensig."
-msgstr ""
-"i.clusterã i.classã ããã³ i.gensigã§ä½æãããã¹ãã¯ãã«ã·ã°ããã£æ
å ±ã"
-"ãã¼ã¹ã¨ããåé¡"
+msgid "Classification is based on the spectral signature information generated by either i.cluster, i.class, or i.gensig."
+msgstr "i.clusterã i.classã ããã³ i.gensigã§ä½æãããã¹ãã¯ãã«ã·ã°ããã£æ
å ±ããã¼ã¹ã¨ããåé¡"
#: ../imagery/i.maxlik/main.c:80
msgid "Generated by either i.cluster, i.class, or i.gensig"
@@ -13790,21 +13141,13 @@
#: ../imagery/i.maxlik/open.c:26
#, c-format
-msgid ""
-"Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must "
-"have at least 2 raster maps."
-msgstr ""
-"ã°ã«ã¼ã <%s> ã®ãµãã°ã«ã¼ã <%s> ã«ã¯ã©ã¹ã¿ã¼ãããã¯ããã¾ããããµãã°ã«ã¼"
-"ãã«2ã¤ä»¥ä¸ã®ã©ã¹ã¿ã¼ããããå¿
è¦ã§ãã "
+msgid "Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must have at least 2 raster maps."
+msgstr "ã°ã«ã¼ã <%s> ã®ãµãã°ã«ã¼ã <%s> ã«ã¯ã©ã¹ã¿ã¼ãããã¯ããã¾ããããµãã°ã«ã¼ãã«2ã¤ä»¥ä¸ã®ã©ã¹ã¿ã¼ããããå¿
è¦ã§ãã "
#: ../imagery/i.maxlik/open.c:29
#, c-format
-msgid ""
-"Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at "
-"least 2 raster maps."
-msgstr ""
-"ã°ã«ã¼ã <%s>ã®ãµãã°ã«ã¼ã<%s> ã«ã¯1ã¤ããã©ã¹ã¿ã¼ããããããã¾ããããµãã°"
-"ã«ã¼ãã«ã¯2ã¤ä»¥ä¸ã®ã©ã¹ã¿ã¼ããããå¿
è¦ã§ãã"
+msgid "Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at least 2 raster maps."
+msgstr "ã°ã«ã¼ã <%s>ã®ãµãã°ã«ã¼ã<%s> ã«ã¯1ã¤ããã©ã¹ã¿ã¼ããããããã¾ããããµãã°ã«ã¼ãã«ã¯2ã¤ä»¥ä¸ã®ã©ã¹ã¿ã¼ããããå¿
è¦ã§ãã"
#: ../imagery/i.maxlik/open.c:48
#, c-format
@@ -13923,20 +13266,12 @@
msgstr "ç»å, åé¡, MLC"
#: ../imagery/i.class/main.c:55
-msgid ""
-"Generates spectral signatures for an image by allowing the user to outline "
-"regions of interest."
-msgstr ""
-"ã¦ã¼ã¶ã¼ã«é¢å¿é åã®ã¢ã¦ãã©ã¤ã³ã許å¯ãããã¨ã«ãã£ã¦ã¹ãã¯ãã«ã·ã°ããã£ã"
-"使ãã"
+msgid "Generates spectral signatures for an image by allowing the user to outline regions of interest."
+msgstr "ã¦ã¼ã¶ã¼ã«é¢å¿é åã®ã¢ã¦ãã©ã¤ã³ã許å¯ãããã¨ã«ãã£ã¦ã¹ãã¯ãã«ã·ã°ããã£ã使ãã"
#: ../imagery/i.class/main.c:58
-msgid ""
-"The resulting signature file can be used as input for i.maxlik or as a seed "
-"signature file for i.cluster."
-msgstr ""
-"çµæã·ã°ããã£ãã¡ã¤ã«ã¯i.maxlik ããã³ i.clusterã®ã·ã¼ãã·ã°ããã£ãã¡ã¤ã«ã¨"
-"ãã¦ä½¿ç¨ããã¾ã"
+msgid "The resulting signature file can be used as input for i.maxlik or as a seed signature file for i.cluster."
+msgstr "çµæã·ã°ããã£ãã¡ã¤ã«ã¯i.maxlik ããã³ i.clusterã®ã·ã¼ãã·ã°ããã£ãã¡ã¤ã«ã¨ãã¦ä½¿ç¨ããã¾ã"
#: ../imagery/i.class/main.c:62 ../display/d.rast/main.c:57
msgid "Name of raster map to be displayed"
@@ -14188,9 +13523,7 @@
#: ../imagery/i.gensig/get_train.c:53 ../imagery/i.gensigset/get_train.c:57
#, c-format
msgid "Training class %d only has one cell - this class will be ignored"
-msgstr ""
-"ãã¬ã¼ãã³ã°ã¯ã©ã¹ %d ã¯1ã¤ã®ã»ã«ããããã¾ãã - ãã®ã¯ã©ã¹ã¯ç¡è¦ãã¦ãã ã"
-"ã"
+msgstr "ãã¬ã¼ãã³ã°ã¯ã©ã¹ %d ã¯1ã¤ã®ã»ã«ããããã¾ãã - ãã®ã¯ã©ã¹ã¯ç¡è¦ãã¦ãã ãã"
#: ../imagery/i.gensig/get_train.c:58 ../imagery/i.gensigset/get_train.c:62
msgid "Training map has no classes"
@@ -14233,9 +13566,7 @@
msgstr "ç»åãã«ã©ã¼å¤æã赤ç·éãHIS"
#: ../imagery/i.his.rgb/h2rmain.c:47
-msgid ""
-"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
-"RGB (Red-Green-Blue) color space."
+msgid "Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to RGB (Red-Green-Blue) color space."
msgstr "ã©ã¹ã¿ã¼ããããHIS(è²ç¸ï¼è¼åº¦ï¼å½©åº¦)è²ç©ºéããRGB(赤ç·é)è²ç©ºéã¸å¤æ"
#: ../imagery/i.his.rgb/h2rmain.c:53
@@ -14307,12 +13638,8 @@
msgstr "ç»åãä¿®æ£"
#: ../imagery/i.rectify/main.c:92
-msgid ""
-"Rectifies an image by computing a coordinate transformation for each pixel "
-"in the image based on the control points."
-msgstr ""
-"ã³ã³ããã¼ã«ãã¤ã³ãããã¼ã¹ã¨ããç»åã®åãã¯ã»ã«ã®åº§æ¨è¨ç®ã«ãã£ã¦ç»åãä¿®"
-"æ£ãã"
+msgid "Rectifies an image by computing a coordinate transformation for each pixel in the image based on the control points."
+msgstr "ã³ã³ããã¼ã«ãã¤ã³ãããã¼ã¹ã¨ããç»åã®åãã¯ã»ã«ã®åº§æ¨è¨ç®ã«ãã£ã¦ç»åãä¿®æ£ãã"
#: ../imagery/i.rectify/main.c:106
#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:100
@@ -14326,7 +13653,7 @@
#: ../imagery/i.rectify/main.c:118
#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:106
msgid "Target resolution (ignored if -c flag used)"
-msgstr ""
+msgstr "ç®æ¨ç²¾åº¦(-c ãã©ã°ãããã°ç¡è¦ããã¾ã)"
#: ../imagery/i.rectify/main.c:126
#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:114
@@ -14335,8 +13662,7 @@
#: ../imagery/i.rectify/main.c:141
#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:134
-msgid ""
-"Use current region settings in target location (def.=calculate smallest area)"
+msgid "Use current region settings in target location (def.=calculate smallest area)"
msgstr "ã¿ã¼ã²ãããã±ã¼ã·ã§ã³ã«ç¾å¨ã®é åè¨å®ãä½¿ç¨ (def.=æå°ã¨ãªã¢ãè¨ç®)"
#: ../imagery/i.rectify/main.c:145
@@ -14378,7 +13704,7 @@
#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:291
#, c-format
msgid "target LOCATION %s, MAPSET %s:"
-msgstr ""
+msgstr "ç®æ¨ããã±ã¼ã·ã§ã³ %sããããã»ãã %s:"
#: ../imagery/i.rectify/main.c:273
#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:285
@@ -14392,7 +13718,7 @@
#: ../imagery/i.rectify/main.c:288
#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:309
msgid "Target resolution must be > 0, ignored"
-msgstr ""
+msgstr "ç®æ¨ç²¾åº¦ã¯ã¼ã以ä¸ã§ããå¿
è¦ãããã¾ããå¤ã¯ç¡è¦ããã¾ããã"
#: ../imagery/i.rectify/main.c:306
#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:316
@@ -14468,9 +13794,7 @@
#: ../imagery/i.rectify/cp.c:21
#, c-format
msgid "Not enough active control points for current order, %d are required."
-msgstr ""
-"ç¾å¨ã®é ã§ã¢ã¯ãã£ãã³ã³ããã¼ã«ãã¤ã³ãã¯ä¸ååã§ãã %d ãè¦æ±ããã¦ãã¾"
-"ãã"
+msgstr "ç¾å¨ã®é ã§ã¢ã¯ãã£ãã³ã³ããã¼ã«ãã¤ã³ãã¯ä¸ååã§ãã %d ãè¦æ±ããã¦ãã¾ãã"
#: ../imagery/i.rectify/cp.c:25
msgid "Poorly placed control points."
@@ -14518,8 +13842,7 @@
#: ../imagery/i.target/main.c:67
msgid "Set current location and mapset as target for of imagery group"
-msgstr ""
-"ç»åã°ã«ã¼ãã®ã¿ã¼ã²ããã¨ãã¦ç¾å¨ã®ãã±ã¼ã·ã§ã³ã¨ãããã»ãããè¨å®ããã"
+msgstr "ç»åã°ã«ã¼ãã®ã¿ã¼ã²ããã¨ãã¦ç¾å¨ã®ãã±ã¼ã·ã§ã³ã¨ãããã»ãããè¨å®ããã"
#: ../imagery/i.target/main.c:89 ../imagery/i.target/main.c:106
#: ../imagery/i.target/main.c:115
@@ -14548,11 +13871,8 @@
msgstr "è¨å·ãèªã¿è¾¼ãã¾ããããã¤ã³ãã表示ã§ãã¾ãã"
#: ../imagery/i.vpoints/main.c:96
-msgid ""
-"Set registration points for an imagery group from a vector map or keyboard "
-"entry."
-msgstr ""
-"ãã¯ãã«ããããããã¯ãã¼ãã¼ãå
¥åããç»åã°ã«ã¼ãã®ç»é²ãã¤ã³ããè¨å®"
+msgid "Set registration points for an imagery group from a vector map or keyboard entry."
+msgstr "ãã¯ãã«ããããããã¯ãã¼ãã¼ãå
#: ../imagery/i.topo.corr/correction.c:100
#, c-format
@@ -14638,20 +13958,12 @@
msgstr "å
¥åããã©ã¹ã¿ã¼ãããå (ç»å fft, èæ°é¨å"
#: ../imagery/i.ifft/ifftmain.c:101
-msgid ""
-"Unable to open real-image in the 'cell_misc' directory. Raster map probably "
-"wasn't created by i.fft"
-msgstr ""
-"cell_misc'ãã£ã¬ã¯ããªã®å®æ°ç»åãéãã¾ãããã©ã¹ã¿ã¼ããã㯠i.fftã§ä½æã"
-"ãã¦ãã¾ããã§ããã"
+msgid "Unable to open real-image in the 'cell_misc' directory. Raster map probably wasn't created by i.fft"
+msgstr "cell_misc'ãã£ã¬ã¯ããªã®å®æ°ç»åãéãã¾ãããã©ã¹ã¿ã¼ããã㯠i.fftã§ä½æããã¦ãã¾ããã§ããã"
#: ../imagery/i.ifft/ifftmain.c:111
-msgid ""
-"Unable to open imaginary-image in the 'cell_misc' directory. Raster map "
-"probably wasn't created by i.fft"
-msgstr ""
-"cell_misc'ãã£ã¬ã¯ããªã®èæ°ç»åãéãã¾ãããã©ã¹ã¿ã¼ãããã¯i.fftã§ä½æãã"
-"ã¦ãã¾ããã§ããã "
+msgid "Unable to open imaginary-image in the 'cell_misc' directory. Raster map probably wasn't created by i.fft"
+msgstr "cell_misc'ãã£ã¬ã¯ããªã®èæ°ç»åãéãã¾ãããã©ã¹ã¿ã¼ãããã¯i.fftã§ä½æããã¦ãã¾ããã§ããã "
#: ../imagery/i.ifft/ifftmain.c:134
#, c-format
@@ -14701,8 +14013,7 @@
#: ../imagery/i.fft/fftmain.c:115
msgid "Raster MASK found, consider to remove (see man-page). Will continue..."
-msgstr ""
-"ã©ã¹ã¿ã¼MASKãè¦ã¤ããã¾ãããåé¤ãã¦ãã ãã (man-pageåç
§)ãç¶è¡... "
+msgstr "ã©ã¹ã¿ã¼MASKãè¦ã¤ããã¾ãããåé¤ãã¦ãã ãã (man-pageåç
§)ãç¶è¡... "
#: ../imagery/i.fft/fftmain.c:129
msgid "Range less than or equal to zero not allowed"
@@ -14783,8 +14094,7 @@
#: ../imagery/i.gensigset/subcluster.c:547
msgid "Unreliable clustering. Try a smaller initial number of clusters"
-msgstr ""
-"ä¿¡é ¼ã§ããªãã¯ã©ã¹ã¿ãªã³ã°ãå°ããåæã®ã¯ã©ã¹ã¿ã¼æ°ã§å試è¡ãã¦ãã ãã"
+msgstr "ä¿¡é ¼ã§ããªãã¯ã©ã¹ã¿ãªã³ã°ãå°ããåæã®ã¯ã©ã¹ã¿ã¼æ°ã§å試è¡ãã¦ãã ãã"
#: ../imagery/i.gensigset/subcluster.c:556
#, c-format
@@ -15005,20 +14315,12 @@
msgstr "ç»åãåé¡ãã·ã°ããã£"
#: ../imagery/i.cluster/main.c:82
-msgid ""
-"Generates spectral signatures for land cover types in an image using a "
-"clustering algorithm."
-msgstr ""
-"ã¯ã©ã¹ã¿ãªã³ã°ã¢ã«ã´ãªãºã ã使ç¨ããç»åã®åå°è¢«è¦ã¿ã¤ãã®ã¹ãã¯ãã«ã·ã°ã"
-"ãã£ã使ãã"
+msgid "Generates spectral signatures for land cover types in an image using a clustering algorithm."
+msgstr "ã¯ã©ã¹ã¿ãªã³ã°ã¢ã«ã´ãªãºã ã使ç¨ããç»åã®åå°è¢«è¦ã¿ã¤ãã®ã¹ãã¯ãã«ã·ã°ããã£ã使ãã"
#: ../imagery/i.cluster/main.c:85
-msgid ""
-"The resulting signature file is used as input for i.maxlik, to generate an "
-"unsupervised image classification."
-msgstr ""
-"æå¸«ãªãç»ååé¡ã使ããããã«i.maxlikã«å
¥åã¨ãã¦çµæã·ã°ããã£ãã¡ã¤ã«ã"
-"使ç¨ããã¾ãã"
+msgid "The resulting signature file is used as input for i.maxlik, to generate an unsupervised image classification."
+msgstr "æå¸«ãªãç»ååé¡ã使ããããã«i.maxlikã«å
¥åã¨ãã¦çµæã·ã°ããã£ãã¡ã¤ã«ã使ç¨ããã¾ãã"
#: ../imagery/i.cluster/main.c:104
msgid "Initial number of classes"
@@ -15211,18 +14513,12 @@
msgstr "ãµã³ãã«ãµã¤ãº: %d ãã¤ã³ã\n"
#: ../imagery/i.cluster/main.c:306
-msgid ""
-"Not enough sample points. Please run again and choose a larger sample size."
-msgstr ""
-"ãµã³ãã«ãã¤ã³ããä¸ååã§ããå試è¡ãã大ãããµã³ãã«ãµã¤ãºã鏿ãã¦ãã ã"
-"ãã"
+msgid "Not enough sample points. Please run again and choose a larger sample size."
+msgstr "ãµã³ãã«ãã¤ã³ããä¸ååã§ããå試è¡ãã大ãããµã³ãã«ãµã¤ãºã鏿ãã¦ãã ããã"
#: ../imagery/i.cluster/main.c:310
-msgid ""
-"Not enough non-zero sample data points. Check your current region (and mask)."
-msgstr ""
-"ã¼ãã§ãªããµã³ãã«ãã¼ã¿ãã¤ã³ããä¸ååã§ããç¾å¨ã®é åï¼ã¨maskï¼ã確èªãã¦"
-"ãã ããã"
+msgid "Not enough non-zero sample data points. Check your current region (and mask)."
+msgstr "ã¼ãã§ãªããµã³ãã«ãã¼ã¿ãã¤ã³ããä¸ååã§ããç¾å¨ã®é åï¼ã¨maskï¼ã確èªãã¦ãã ããã"
#: ../imagery/i.cluster/main.c:323
#, c-format
@@ -15241,8 +14537,7 @@
#: ../imagery/i.cluster/main.c:335
#, c-format
msgid "Unable to create signature file <%s> for group <%s>, subsgroup <%s>"
-msgstr ""
-"ã°ã«ã¼ã<%s>ã«ã·ã°ããã£ãã¡ã¤ã«<%s>ã使ã§ãã¾ããããµãã°ã«ã¼ã <%s>"
+msgstr "ã°ã«ã¼ã<%s>ã«ã·ã°ããã£ãã¡ã¤ã«<%s>ã使ã§ãã¾ããããµãã°ã«ã¼ã <%s>"
#: ../imagery/i.cluster/main.c:340
#, c-format
@@ -15359,8 +14654,7 @@
#: ../imagery/i.pca/main.c:219
msgid "Scale range length should be > 0. Using default values: 0,255."
-msgstr ""
-"è¨ã£ãé åã®é·ã㯠> 0ã§ãªããã°ãªãã¾ãããããã©ã«ãå¤ã使ç¨: 0,255. "
+msgstr "è¨ã£ãé åã®é·ã㯠> 0ã§ãªããã°ãªãã¾ãããããã©ã«ãå¤ã使ç¨: 0,255. "
#: ../imagery/i.pca/main.c:256 ../imagery/i.pca/main.c:305
#: ../imagery/i.pca/main.c:438
@@ -15396,9 +14690,7 @@
msgstr "ç¯å²ã«åè¨æ¸¬ <%s> %d,%d..."
#: ../imagery/i.rgb.his/r2hmain.c:47
-msgid ""
-"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
-"Intensity-Saturation) color space."
+msgid "Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-Intensity-Saturation) color space."
msgstr "ã©ã¹ã¿ã¼ããããRGB(赤ç·é)è²ç©ºéããHIS(è²ç¸ï¼è¼åº¦ï¼å½©åº¦)è²ç©ºéã¸å¤æ"
#: ../imagery/i.rgb.his/r2hmain.c:53
@@ -15427,7 +14719,7 @@
#: ../imagery/i.ortho.photo/i.photo.rectify/angle.c:36
msgid "Calculating camera angle to local surface..."
-msgstr "centrality measures ãè¨ç®ãã¦ãã¾ã..."
+msgstr "ãã¼ã«ã«ã®å°è¡¨ã«å¯¾ããã«ã¡ã©ã¢ã³ã°ã«ãè¨ç®ãã¦ãã¾ã..."
#: ../imagery/i.ortho.photo/i.photo.rectify/angle.c:51
#: ../imagery/i.ortho.photo/i.photo.rectify/exec.c:43
@@ -15455,14 +14747,12 @@
msgstr "ç»åããªã«ã½ä¿®æ£"
#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:88
-msgid ""
-"Orthorectifies an image by using the image to photo coordinate "
-"transformation matrix."
+msgid "Orthorectifies an image by using the image to photo coordinate transformation matrix."
msgstr "ç»åã使ã£ã¦ãã©ã座æ¨å¤æè¡åã¸ã¨ç»åããªã«ã½è£æ£ãã"
#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:129
msgid "Raster map with camera angle relative to ground surface"
-msgstr ""
+msgstr "å°é¢ã¨ç¸å¯¾çãªã«ã¡ã©ã¢ã³ã°ã«å¤ãæã¤ã©ã¹ã¿ã¼ããã"
#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:181
#, c-format
@@ -15515,7 +14805,7 @@
#: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:24
msgid "Run OPTION 7 of i.ortho.photo again!\n"
-msgstr ""
+msgstr "i.ortho.photo ã®ãªãã·ã§ã³7ãå度å®è¡ãã¦ãã ãã\n"
#: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:27
msgid "No active Control Points!\n"
@@ -15523,14 +14813,16 @@
#: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:29
msgid "Run OPTION 7 of i.ortho.photo!\n"
-msgstr ""
+msgstr "i.ortho.photo ã®ãªãã·ã§ã³7ãå®è¡ãã¦ãã ãã\n"
#: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:45
-#, fuzzy, c-format
+#, c-format
msgid ""
"Reference Point file for group [%s] in [%s] \n"
" \n"
-msgstr "ã°ã«ã¼ãã®ã³ã³ããã¼ã«ãã¤ã³ããã¡ã¤ã« <%s@%s> - "
+msgstr ""
+"ã°ã«ã¼ã [%s]ï¼[%s]ä¸ï¼ã®åç
§ç¹ãã¡ã¤ã« \n"
+" \n"
#: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:51
msgid "Poorly placed Reference Points!\n"
@@ -15538,7 +14830,7 @@
#: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:53
msgid "Run OPTION 5 of i.ortho.photo again!\n"
-msgstr ""
+msgstr "i.ortho.photo ã®ãªãã·ã§ã³5ãå度å®è¡ãã¦ãã ãã\n"
#: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:57
msgid "No active Reference Points!\n"
@@ -15546,7 +14838,7 @@
#: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:59
msgid "Run OPTION 5 of i.ortho.photo!\n"
-msgstr ""
+msgstr "i.ortho.photo ã®ãªãã·ã§ã³5ãå®è¡ãã¦ãã ãã\n"
#: ../imagery/i.ortho.photo/i.photo.elev/main.c:64
msgid "Interactively select or modify the target elevation model."
@@ -15623,11 +14915,12 @@
msgstr "ãã®ã°ã«ã¼ãå
ã«ãã¡ã¤ã«ãããã¾ãã!"
#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:61
-#, fuzzy
msgid ""
"\n"
"Rectify all images in the group? "
-msgstr "ã°ã«ã¼ãã®å
¨ã©ã¹ã¿ã¼ããããä¿®æ£ãã"
+msgstr ""
+"\n"
+"ã°ã«ã¼ãã®å
¨ã©ã¹ã¿ã¼ããããä¿®æ£ãã¾ããï¼"
#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:71
#, c-format
@@ -15747,12 +15040,8 @@
msgstr " ãã±ã¼ã·ã§ã³ [%s]ã®å¯¾è±¡ã«ãªã£ãã°ã«ã¼ã [%s], ãããã»ãã [%s]"
#: ../imagery/i.ortho.photo/i.photo.init/main.c:46
-msgid ""
-"Interactively creates or modifies entries in a camera initial exposure "
-"station file for imagery group referenced by a sub-block."
-msgstr ""
-"ãµããããã¯ã«ãã£ã¦åç
§ãããç»åã°ã«ã¼ãã®ããã«ã«ã¡ã©åææ´é²å ´ãã¡ã¤ã«ã®"
-"é
ç®ã対話形å¼ã«ä½æãããã¯ä¿®æ£ãã"
+msgid "Interactively creates or modifies entries in a camera initial exposure station file for imagery group referenced by a sub-block."
+msgstr "ãµããããã¯ã«ãã£ã¦åç
§ãããç»åã°ã«ã¼ãã®ããã«ã«ã¡ã©åææ´é²å ´ãã¡ã¤ã«ã®é
#: ../imagery/i.ortho.photo/i.photo.init/main.c:64
#: ../imagery/i.ortho.photo/i.photo.2target/main.c:102
@@ -15769,8 +15058,7 @@
msgstr "æåã«ã¹ã¯ãªã¼ã³ã«æç»ãããä¿®æ£ãããç»åå"
#: ../imagery/i.ortho.photo/i.photo.2target/main.c:72
-msgid ""
-"Name of a map from target mapset which will be initially drawn on screen"
+msgid "Name of a map from target mapset which will be initially drawn on screen"
msgstr "æåã«ã¹ã¯ãªã¼ã³ã«è¡¨ç¤ºãããã¿ã¼ã²ãããããã»ããããã®ãããå"
#: ../imagery/i.ortho.photo/i.photo.2target/main.c:114
@@ -15825,8 +15113,7 @@
msgstr "ç»åã°ã«ã¼ã [%s] ãè¦ã¤ããã¾ãã"
#: ../imagery/i.ortho.photo/i.photo.camera/main.c:57
-msgid ""
-"Interactively select and modify the imagery group camera reference file."
+msgid "Interactively select and modify the imagery group camera reference file."
msgstr "ç»åã°ã«ã¼ãã«ã¡ã©åç
§ãã¡ã¤ã«ã対話形å¼ã«é¸æãä¿®æ£ãã"
#: ../imagery/i.ortho.photo/i.photo.camera/main.c:68
@@ -15840,9 +15127,7 @@
#: ../imagery/i.ortho.photo/i.photo.camera/main.c:101
#, c-format
msgid "Group [%s] in location [%s] mapset [%s] now has camera file [%s]"
-msgstr ""
-"ãã±ã¼ã·ã§ã³ [%s] ãããã»ãã [%s] ã®ã°ã«ã¼ã [%s] ã«ç¾å¨ã«ã¡ã©ãã¡ã¤ã« [%s]"
-"ã¯ããã¾ã "
+msgstr "ãã±ã¼ã·ã§ã³ [%s] ãããã»ãã [%s] ã®ã°ã«ã¼ã [%s] ã«ç¾å¨ã«ã¡ã©ãã¡ã¤ã« [%s]ã¯ããã¾ã "
#: ../ps/ps.map/r_info.c:48 ../ps/ps.map/r_colortable.c:61
#: ../ps/ps.map/r_vlegend.c:49
@@ -15952,12 +15237,8 @@
#: ../ps/ps.map/r_vpoints.c:244
#, c-format
-msgid ""
-"The mapping instruction <%s> will be renamed to <%s> in future versions of "
-"GRASS. Please use <%s> instead."
-msgstr ""
-"æ°ãã GRASS ã®ãã¼ã¸ã§ã³ã§ã¯ï¼ãããã³ã°å½ä»¤ <%s> 㯠<%s> ã«åç§°å¤æ´ããã¾"
-"ãï¼ä»£ããã« <%s> ã使ç¨ãã¦ä¸ãã"
+msgid "The mapping instruction <%s> will be renamed to <%s> in future versions of GRASS. Please use <%s> instead."
+msgstr "æ°ãã GRASS ã®ãã¼ã¸ã§ã³ã§ã¯ï¼ãããã³ã°å½ä»¤ <%s> 㯠<%s> ã«åç§°å¤æ´ããã¾ãï¼ä»£ããã« <%s> ã使ç¨ãã¦ä¸ãã"
#: ../ps/ps.map/ps_outline.c:41
#, c-format
@@ -16091,21 +15372,15 @@
#: ../ps/ps.map/main.c:115
msgid "Create EPS (Encapsulated PostScript) instead of PostScript file"
-msgstr ""
-"ãã¹ãã¹ã¯ãªãããã¡ã¤ã«ã®ä»£ããã« EPS (Encapsulated PostScript) ã使"
+msgstr "ãã¹ãã¹ã¯ãªãããã¡ã¤ã«ã®ä»£ããã« EPS (Encapsulated PostScript) ã使"
#: ../ps/ps.map/main.c:120
-msgid ""
-"Describe map-box's position on the page and exit (inches from top-left of "
-"paper)"
-msgstr ""
-"ãã¼ã¸ä¸ã®ããã-ããã¯ã¹ã®ä½ç½®ã説æãã¦çµäºï¼ç¨ç´ã®å·¦ä¸ããæ°ã¤ã³ãï¼"
+msgid "Describe map-box's position on the page and exit (inches from top-left of paper)"
+msgstr "ãã¼ã¸ä¸ã®ããã-ããã¯ã¹ã®ä½ç½®ã説æãã¦çµäºï¼ç¨ç´ã®å·¦ä¸ããæ°ã¤ã³ãï¼"
#: ../ps/ps.map/main.c:126
-msgid ""
-"File containing mapping instructions (or use input=- to enter from keyboard)"
-msgstr ""
-"ãããã³ã°å½ä»¤ã«é¢ãããã¡ã¤ã« ï¼ã¾ãã¯ãã¼ãã¼ãå
¥åã«ã¯ input=- ã使ç¨ï¼"
+msgid "File containing mapping instructions (or use input=- to enter from keyboard)"
+msgstr "ãããã³ã°å½ä»¤ã«é¢ãããã¡ã¤ã« ï¼ã¾ãã¯ãã¼ãã¼ãå
#: ../ps/ps.map/main.c:134
msgid "PostScript output file"
@@ -16121,13 +15396,8 @@
#: ../ps/ps.map/main.c:241
#, c-format
-msgid ""
-"Using <%s> from the command line is depreciated. Please use the <%s> mapping "
-"instruction instead. The parameter <%s> will be removed in future versions "
-"of GRASS."
-msgstr ""
-"ã³ãã³ãã©ã¤ã³ã§ã® <%s> ã®ä½¿ç¨ã¯ç¡ããªãäºå®ã§ãï¼ä»£ããã« <%s> ãããã³ã°å½"
-"令ã使ç¨ãã¦ä¸ããï¼å¤æ° <%s> ã¯GRASSã®æ°ãããã¼ã¸ã§ã³ããåé¤ããã¾ã"
+msgid "Using <%s> from the command line is depreciated. Please use the <%s> mapping instruction instead. The parameter <%s> will be removed in future versions of GRASS."
+msgstr "ã³ãã³ãã©ã¤ã³ã§ã® <%s> ã®ä½¿ç¨ã¯ç¡ããªãäºå®ã§ãï¼ä»£ããã« <%s> ãããã³ã°å½ä»¤ã使ç¨ãã¦ä¸ããï¼å¤æ° <%s> ã¯GRASSã®æ°ãããã¼ã¸ã§ã³ããåé¤ããã¾ã"
#: ../ps/ps.map/main.c:267
#, c-format
@@ -16147,14 +15417,8 @@
msgstr "æå¾ã® 'end' å½ä»¤ã®å¾ãã«ãã¼ã¿ãããã¾ãï¼ "
#: ../ps/ps.map/main.c:324
-msgid ""
-"GRASS environment variable GRASS_VERBOSE is overwritten by VERBOSE mapping "
-"instruction. This mapping instruction is superseded and will be removed in "
-"future versions of GRASS. Please use --verbose instead."
-msgstr ""
-"GRASS ç°å¢å¤æ° GRASS_VERBOSE 㯠VERBOSE ãããã³ã°å½ä»¤ã§ä¸æ¸ãããã¾ãï¼ãã®"
-"ãããã³ã°å½ä»¤ã¯æ°ãã GRASS ã®ãã¼ã¸ã§ã³ããåé¤ããã¾ãï¼ãããã« --"
-"verbose ã使ç¨ãã¦ä¸ãã"
+msgid "GRASS environment variable GRASS_VERBOSE is overwritten by VERBOSE mapping instruction. This mapping instruction is superseded and will be removed in future versions of GRASS. Please use --verbose instead."
+msgstr "GRASS ç°å¢å¤æ° GRASS_VERBOSE 㯠VERBOSE ãããã³ã°å½ä»¤ã§ä¸æ¸ãããã¾ãï¼ãã®ãããã³ã°å½ä»¤ã¯æ°ãã GRASS ã®ãã¼ã¸ã§ã³ããåé¤ããã¾ãï¼ãããã« --verbose ã使ç¨ãã¦ä¸ãã"
#: ../ps/ps.map/main.c:331
msgid "Cannot set GRASS_VERBOSE variable."
@@ -16200,15 +15464,8 @@
msgstr " <%s> ã®ã«ãã´ãªã¼ãã¡ã¤ã«ã¯å©ç¨ä¸å¯ã§ã"
#: ../ps/ps.map/ps_clrtbl.c:54
-msgid ""
-"Your cats/ file is invalid. A cats/ file with categories and labels is "
-"required for 'colortable' when using categorical legends; see the r.category "
-"help page. Colortable creation has been skipped."
-msgstr ""
-"ã«ãã´ãªã¼/ãã¡ã¤ã« ãæ£ããããã¾ããï¼ã«ãã´ãªã¼ã®å¡ä¾ã使ç¨ã®éã¯ï¼ã«ãã´"
-"ãªã¼ã¨ãã¼ãã«ä»ãã®ã«ãã´ãªã¼/ãã¡ã¤ã«ã«ã¯ 'colortable' ãå¿
è¦ã§ãï¼ r."
-"category ãã«ãã®ãã¼ã¸ãåç
§ãã¦ä¸ããï¼ã«ã©ã¼ãã¼ãã«ã®ä½æã¯ã¹ãããããã¾"
-"ãã"
+msgid "Your cats/ file is invalid. A cats/ file with categories and labels is required for 'colortable' when using categorical legends; see the r.category help page. Colortable creation has been skipped."
+msgstr "ã«ãã´ãªã¼/ãã¡ã¤ã« ãæ£ããããã¾ããï¼ã«ãã´ãªã¼ã®å¡ä¾ã使ç¨ã®éã¯ï¼ã«ãã´ãªã¼ã¨ãã¼ãã«ä»ãã®ã«ãã´ãªã¼/ãã¡ã¤ã«ã«ã¯ 'colortable' ãå¿
è¦ã§ãï¼ r.category ãã«ãã®ãã¼ã¸ãåç
§ãã¦ä¸ããï¼ã«ã©ã¼ãã¼ãã«ã®ä½æã¯ã¹ãããããã¾ãã"
#: ../ps/ps.map/do_plt.c:41
msgid "Reading point/line file ..."
@@ -16224,12 +15481,8 @@
msgstr "ãã¯ãã«ã対象ããã "
#: ../display/d.paint.labels/main.c:48
-msgid ""
-"Displays text labels (created with v.label) to the active frame on the "
-"graphics monitor."
-msgstr ""
-"ã°ã©ãã£ãã¯ã¢ãã¿ã¼ã®ä½åä¸ã®ãã¬ã¼ã ã«ããã¹ãã©ãã« (v.label使ç¨) ã表示ã"
-"ã¾ã."
+msgid "Displays text labels (created with v.label) to the active frame on the graphics monitor."
+msgstr "ã°ã©ãã£ãã¯ã¢ãã¿ã¼ã®ä½åä¸ã®ãã¬ã¼ã ã«ããã¹ãã©ãã« (v.label使ç¨) ã表示ãã¾ã."
#: ../display/d.paint.labels/main.c:54
msgid "Ignore rotation setting and draw horizontally"
@@ -16315,12 +15568,8 @@
msgstr "ã©ã¹ã¿ã¼ãçµ±è¨"
#: ../display/d.histogram/main.c:73
-msgid ""
-"Displays a histogram in the form of a pie or bar chart for a user-specified "
-"raster map."
-msgstr ""
-"ã¦ã¼ã¶ã¼æå®ãããã©ã¹ã¿ã¼ãããã®ãããã¤ã¾ãã¯ãã¼ã°ã©ãã§ãã¹ãã°ã©ã ã表"
-"示ãã¾ã"
+msgid "Displays a histogram in the form of a pie or bar chart for a user-specified raster map."
+msgstr "ã¦ã¼ã¶ã¼æå®ãããã©ã¹ã¿ã¼ãããã®ãããã¤ã¾ãã¯ãã¼ã°ã©ãã§ãã¹ãã°ã©ã ã表示ãã¾ã"
#: ../display/d.histogram/main.c:77
msgid "Raster map for which histogram will be displayed"
@@ -16404,21 +15653,15 @@
#: ../display/d.vect/main.c:123
msgid "Displays user-specified vector map in the active graphics frame."
-msgstr ""
-"ã¦ã¼ã¶ã¼æå®ãããï¼ã¤ã®ã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ãã赤ãç·ãéã®ãªã¼ãã¼ã¬ã¤ã¨"
-"ãã¦åä½ä¸ã®ã°ã©ãã£ãã¯ãã¬ã¼ã ã«è¡¨ç¤ºãã¾ã."
+msgstr "ã¦ã¼ã¶ã¼æå®ãããï¼ã¤ã®ã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ãã赤ãç·ãéã®ãªã¼ãã¼ã¬ã¤ã¨ãã¦åä½ä¸ã®ã°ã©ãã£ãã¯ãã¬ã¼ã ã«è¡¨ç¤ºãã¾ã."
#: ../display/d.vect/main.c:135
msgid "Display"
msgstr "表示"
#: ../display/d.vect/main.c:136
-msgid ""
-"shape;Display geometry of features;cat;Display category numbers of features;"
-"topo;Display topology information (nodes, edges);dir;Display direction of "
-"linear features;attr;Display selected attribute based on 'attrcol';zcoor;"
-"Display z-coordinate of features (only for 3D vector maps)"
-msgstr ""
+msgid "shape;Display geometry of features;cat;Display category numbers of features;topo;Display topology information (nodes, edges);dir;Display direction of linear features;attr;Display selected attribute based on 'attrcol';zcoor;Display z-coordinate of features (only for 3D vector maps)"
+msgstr "shape;ãã£ã¼ãã£ã¼ã®ã¸ãªã¡ããªã表示;cat;ãã£ã¼ãã£ã¼ã®ã«ãã´ãªæ°ã表示;topo;ãããã¸ã¼æ
å ±ã表示(nodesãedges);dir;ç·å½¢ãã£ã¼ãã£ã¼ã®æ¹åã表示;attr;'attcol'ã§æå®ãã屿§ã表示;zcoor;ãã£ã¼ãã£ã¼ã®Z軸ã表示(3Dãã¯ãã«ãããã®ã¿)"
#: ../display/d.vect/main.c:147 ../display/d.vect/main.c:153
#: ../display/d.vect/main.c:156 ../display/d.vect/main.c:159
@@ -16507,8 +15750,7 @@
#: ../display/d.vect/main.c:237
msgid "When used with the size_column option this becomes the scale factor"
-msgstr ""
-"size_columnãªãã·ã§ã³ã¨ä½¿ç¨ãããå ´åãããã¯ã¹ã±ã¼ã«ãã¡ã¯ã¿ã«ãªãã¾ã"
+msgstr "size_columnãªãã·ã§ã³ã¨ä½¿ç¨ãããå ´åãããã¯ã¹ã±ã¼ã«ãã¡ã¯ã¿ã«ãªãã¾ã"
#: ../display/d.vect/main.c:243
msgid "Name of numeric column containing symbol size"
@@ -16572,13 +15814,11 @@
msgstr "ã©ãã«ç¸¦æ¹åã®è¡æã "
#: ../display/d.vect/main.c:329
-msgid ""
-"Minimum region size (average from height and width) when map is displayed"
+msgid "Minimum region size (average from height and width) when map is displayed"
msgstr "ããã表示æã®æå°é åãµã¤ãº(é«ãã¨å¹
ã®å¹³å)"
#: ../display/d.vect/main.c:337
-msgid ""
-"Maximum region size (average from height and width) when map is displayed"
+msgid "Maximum region size (average from height and width) when map is displayed"
msgstr "ããã表示æã®æå¤§é åãµã¤ãº(é«ãã¨å¹
ã®å¹³å)"
#: ../display/d.vect/main.c:347 ../display/d.thematic.area/main.c:158
@@ -16586,52 +15826,32 @@
msgstr "å¡ãã¤ã¶ãããããªã´ã³ã®ããã®ã¬ã³ããªã³ã°ã¡ã½ãã"
#: ../display/d.vect/main.c:349
-msgid ""
-"g;use the libgis render functions (features: clipping);r;use the raster "
-"graphics library functions (features: polylines);d;use the display library "
-"basic functions (features: polylines);c;use the display library clipping "
-"functions (features: clipping);l;use the display library culling functions "
-"(features: culling, polylines)"
-msgstr ""
-"g;libgisã¬ã³ãã¼æ©è½ãä½¿ç¨ (ãã£ã¼ãã£: ã¯ãªãã);r;ã©ã¹ã¿ã¼ã°ã©ãã£ãã¯ã©ã¤"
-"ãã©ãªæ©è½ (ãã£ã¼ãã£: ããªã©ã¤ã³);d;表示ã©ã¤ãã©ãªãã¼ã·ãã¯æ©è½ãä½¿ç¨ "
-"(ãã£ã¼ãã£: ããªã©ã¤ã³);c;表示ã©ã¤ãã©ãªã¯ãªããæ©è½ãä½¿ç¨ (ãã£ã¼ãã£: ã¯"
-"ãªãã);l;表示ã©ã¤ãã©ãªã«ãªã³ã°æ©è½ãä½¿ç¨ (ãã£ã¼ãã£: ã«ãªã³ã°, ããªã©ã¤ã³)"
+msgid "g;use the libgis render functions (features: clipping);r;use the raster graphics library functions (features: polylines);d;use the display library basic functions (features: polylines);c;use the display library clipping functions (features: clipping);l;use the display library culling functions (features: culling, polylines)"
+msgstr "g;libgisã¬ã³ãã¼æ©è½ãä½¿ç¨ (ãã£ã¼ãã£: ã¯ãªãã);r;ã©ã¹ã¿ã¼ã°ã©ãã£ãã¯ã©ã¤ãã©ãªæ©è½ (ãã£ã¼ãã£: ããªã©ã¤ã³);d;表示ã©ã¤ãã©ãªãã¼ã·ãã¯æ©è½ãä½¿ç¨ (ãã£ã¼ãã£: ããªã©ã¤ã³);c;表示ã©ã¤ãã©ãªã¯ãªããæ©è½ãä½¿ç¨ (ãã£ã¼ãã£: ã¯ãªãã);l;表示ã©ã¤ãã©ãªã«ãªã³ã°æ©è½ãä½¿ç¨ (ãã£ã¼ãã£: ã«ãªã³ã°, ããªã©ã¤ã³)"
#: ../display/d.vect/main.c:365
msgid "Get colors from map table column (of form RRR:GGG:BBB)"
msgstr "ããããã¼ãã«åããè²ãåå¾ãã¾ã (RRR:GGG:BBBã®å½¢ã§) "
#: ../display/d.vect/main.c:371
-msgid ""
-"Random colors according to category number (or layer number if 'layer=-1' is "
-"given)"
-msgstr ""
-"å顿°ã«ããã©ã³ãã è² (ã¾ãã¯ã¬ã¤ã¤ã¼æ° 'ã¬ã¤ã¤ã¼=-1' ãä¸ãããã¦ããå ´"
-"å) "
+msgid "Random colors according to category number (or layer number if 'layer=-1' is given)"
+msgstr "å顿°ã«ããã©ã³ãã è² (ã¾ãã¯ã¬ã¤ã¤ã¼æ° 'ã¬ã¤ã¤ã¼=-1' ãä¸ãããã¦ããå ´å) "
#: ../display/d.vect/main.c:378
msgid "Use values from 'cats' option as feature id"
msgstr "ãã£ã¼ãã£ã¼ id ã¨ã㦠'cats' ãªãã·ã§ã³ããå¤ã使ç¨ãã¦ãã ãã"
#: ../display/d.vect/main.c:383
-msgid ""
-"Don't add to list of vectors and commands in monitor (it won't be drawn if "
-"the monitor is refreshed)"
-msgstr ""
-"ã¢ãã¿ã¼ã®ãã¯ãã«ã¨ã³ãã³ãã®ãªã¹ãã«è¿½å ããªãã§ãã ãã (ã¢ãã¿ã¼ããªã"
-"ã¬ãã·ã¥ãããå ´åæãããªãå ´åãããã¾ã) "
+msgid "Don't add to list of vectors and commands in monitor (it won't be drawn if the monitor is refreshed)"
+msgstr "ã¢ãã¿ã¼ã®ãã¯ãã«ã¨ã³ãã³ãã®ãªã¹ãã«è¿½å ããªãã§ãã ãã (ã¢ãã¿ã¼ããªãã¬ãã·ã¥ãããå ´åæãããªãå ´åãããã¾ã) "
#: ../display/d.vect/main.c:388
msgid "Colorize polygons according to z height"
msgstr "zé«åº¦ã«æºãã¦ããªã´ã³ãã«ã©ã¼åãã¦ãã ãã "
#: ../display/d.vect/main.c:455
-msgid ""
-"The '-c' and '-a' flags cannot be used together, the '-c' flag will be "
-"ignored!"
-msgstr ""
-"-c' 㨠'-a' ãã©ãã°ã¯ä¸ç·ã«ä½¿ç¨ã§ãã¾ãã, '-c' ãã©ãã° ã¯ç¡è¦ããã¾ã! "
+msgid "The '-c' and '-a' flags cannot be used together, the '-c' flag will be ignored!"
+msgstr "-c' 㨠'-a' ãã©ãã°ã¯ä¸ç·ã«ä½¿ç¨ã§ãã¾ãã, '-c' ãã©ãã° ã¯ç¡è¦ããã¾ã! "
#: ../display/d.vect/main.c:471 ../display/d.thematic.area/main.c:318
#, c-format
@@ -16675,8 +15895,7 @@
msgstr "åºåãã¦ãã¾ã ..."
#: ../display/d.vect/main.c:660 ../display/d.thematic.area/main.c:409
-msgid ""
-"The bounding box of the map is outside the current region, nothing drawn."
+msgid "The bounding box of the map is outside the current region, nothing drawn."
msgstr "ãããã®å¢çç·ã¯ç¾å¨ã®é åå¤ã§ããä½ãæããã¾ãã"
#: ../display/d.vect/main.c:694
@@ -16698,12 +15917,8 @@
#: ../display/d.vect/area.c:79 ../display/d.vect/plot1.c:226
#: ../display/d.thematic.area/plot1.c:217
#, c-format
-msgid ""
-"Color definition column (%s) not a string. Column must be of form RRR:GGG:"
-"BBB where RGB values range 0-255."
-msgstr ""
-"ã¹ããªã³ã°ã§ã¯ãªãã«ã©ã¼å®ç¾©ãã¡ã¤ã«å (%s). åã¯RGBå¤ã 0-255ã®ç¯å²ã§ãã"
-"RRR:GGG:BBBããã§ãªããã°ãªãã¾ãã."
+msgid "Color definition column (%s) not a string. Column must be of form RRR:GGG:BBB where RGB values range 0-255."
+msgstr "ã¹ããªã³ã°ã§ã¯ãªãã«ã©ã¼å®ç¾©ãã¡ã¤ã«å (%s). åã¯RGBå¤ã 0-255ã®ç¯å²ã§ããRRR:GGG:BBBããã§ãªããã°ãªãã¾ãã."
#: ../display/d.vect/area.c:85 ../display/d.vect/area.c:113
#: ../display/d.vect/plot1.c:231 ../display/d.vect/plot1.c:259
@@ -16727,11 +15942,8 @@
#: ../display/d.vect/area.c:278
#, c-format
-msgid ""
-"Error in color definition column (%s), area %d with cat %d: colorstring [%s]"
-msgstr ""
-"ã«ã©ã¼å®ç¾©åã«ãããã¨ã©ã¼ (%s), cat %d ãå«ãã¨ãªã¢ %d : ã«ã©ã¼ã¹ããªã³ã° "
-"[%s]"
+msgid "Error in color definition column (%s), area %d with cat %d: colorstring [%s]"
+msgstr "ã«ã©ã¼å®ç¾©åã«ãããã¨ã©ã¼ (%s), cat %d ãå«ãã¨ãªã¢ %d : ã«ã©ã¼ã¹ããªã³ã° [%s]"
#: ../display/d.vect/area.c:284
#, c-format
@@ -16741,8 +15953,7 @@
#: ../display/d.vect/area.c:345 ../display/d.vect/plot1.c:537
#: ../display/d.thematic.area/plot1.c:441
#, c-format
-msgid ""
-"Error in line width column (%s), element %d with cat %d: line width [%d]"
+msgid "Error in line width column (%s), element %d with cat %d: line width [%d]"
msgstr "ã©ã¤ã³å¹
åã«ãããã¨ã©ã¼ (%s), cat %d ãå«ãè¦ç´ %d: ã©ã¤ã³å¹
[%d]"
#: ../display/d.vect/plot1.c:216 ../display/d.thematic.area/plot1.c:207
@@ -16784,12 +15995,8 @@
#: ../display/d.vect/plot1.c:461
#, c-format
-msgid ""
-"Error in color definition column '%s', feature id %d with cat %d: "
-"colorstring '%s'"
-msgstr ""
-"ã«ã©ã¼å®ç¾©åã«ãããã¨ã©ã¼ '%s', cat %d ããã¤ãã£ã¼ãã£ã¼ id %d : ã«ã©ã¼ã¹ã"
-"ãªã³ã° '%s'"
+msgid "Error in color definition column '%s', feature id %d with cat %d: colorstring '%s'"
+msgstr "ã«ã©ã¼å®ç¾©åã«ãããã¨ã©ã¼ '%s', cat %d ããã¤ãã£ã¼ãã£ã¼ id %d : ã«ã©ã¼ã¹ããªã³ã° '%s'"
#: ../display/d.vect/plot1.c:469
#, c-format
@@ -16798,11 +16005,8 @@
#: ../display/d.vect/plot1.c:591
#, c-format
-msgid ""
-"Error in symbol size column (%s), element %d with cat %d: symbol size [%f]"
-msgstr ""
-"ã·ã³ãã«ãµã¤ãºã®ã¨ã©ã¼ã§ããå(%s)ãè¦ç´ %dãcat %d ãå«ã: ã·ã³ãã«ãµã¤ãº "
-"[%f]"
+msgid "Error in symbol size column (%s), element %d with cat %d: symbol size [%f]"
+msgstr "ã·ã³ãã«ãµã¤ãºã®ã¨ã©ã¼ã§ããå(%s)ãè¦ç´ %dãcat %d ãå«ã: ã·ã³ãã«ãµã¤ãº [%f]"
#: ../display/d.vect/plot1.c:679
#, c-format
@@ -16819,27 +16023,16 @@
msgstr "表示ãããã使"
#: ../display/d.mapgraph/main.c:50
-msgid ""
-"Generates and displays simple graphics on map layers drawn in the active "
-"graphics monitor display frame."
-msgstr ""
-"ä½åãã¦ããã°ã©ãã£ãã¯ã¢ãã¿ã¼è¡¨ç¤ºãã¬ã¼ã ã«ããããããããã¬ã¤ã¤ã¼ã«ãã"
-"ãç°¡åãªã°ã©ãã£ãã¯ãçæããã¦è¡¨ç¤ºãã¾ã"
+msgid "Generates and displays simple graphics on map layers drawn in the active graphics monitor display frame."
+msgstr "ä½åãã¦ããã°ã©ãã£ãã¯ã¢ãã¿ã¼è¡¨ç¤ºãã¬ã¼ã ã«ããããããããã¬ã¤ã¤ã¼ã«ãããç°¡åãªã°ã©ãã£ãã¯ãçæããã¦è¡¨ç¤ºãã¾ã"
#: ../display/d.mapgraph/main.c:57
-msgid ""
-"Unix file containg graphing instructions, if not given reads from standard "
-"input"
-msgstr ""
-"ã°ã©ã使æ¡å
ãå«ãã¦ããã¯ã¹ãã¡ã¤ã«, ãããªããã°æ¨æºå
¥åããèªã¿è¾¼ãã§ã"
-"ã ãã"
+msgid "Unix file containg graphing instructions, if not given reads from standard input"
+msgstr "ã°ã©ã使æ¡å
¥åããèªã¿è¾¼ãã§ãã ãã"
#: ../display/d.mapgraph/main.c:67
-msgid ""
-"Color to draw with, either a standard GRASS color or R:G:B triplet "
-"(separated by colons)"
-msgstr ""
-"æãã®ã«ä½¿ç¨ããã«ã©ã¼, æ¨æºGRASSã«ã©ã¼ã¾ãã¯R:G:B triplet (ã³ãã³ã«ããåºå¥)"
+msgid "Color to draw with, either a standard GRASS color or R:G:B triplet (separated by colons)"
+msgstr "æãã®ã«ä½¿ç¨ããã«ã©ã¼, æ¨æºGRASSã«ã©ã¼ã¾ãã¯R:G:B triplet (ã³ãã³ã«ããåºå¥)"
#: ../display/drivers/XDRIVER/Get_w_pointer.c:21
#: ../display/drivers/XDRIVER/Get_w_line.c:35
@@ -16884,9 +16077,7 @@
msgstr "表示ãã©ã¹ã¿ã¼"
#: ../display/d.rhumbline/main.c:47
-msgid ""
-"Displays the rhumbline joining two user-specified points, in the active "
-"frame on the user's graphics monitor."
+msgid "Displays the rhumbline joining two user-specified points, in the active frame on the user's graphics monitor."
msgstr "æå®ãã2å°ç¹ãçµã¶èªç¨ç·ãæãã¾ã "
#: ../display/d.rhumbline/main.c:55 ../display/d.geodesic/main.c:56
@@ -16927,12 +16118,8 @@
msgstr "表示ããããã¯ã¼ã¯"
#: ../display/d.where/main.c:44
-msgid ""
-"Identifies the geographic coordinates associated with point locations in the "
-"active frame on the graphics monitor."
-msgstr ""
-"ã°ã©ãã£ãã¯ã¢ãã¿ã¼ä¸ã®åä½ä¸ã®ãã¬ã¼ã ã«ããããã¤ã³ããã±ã¼ã·ã§ã³ã«é¢é£ã"
-"ãå°ç座æ¨ãèå¥ãã¦ãã ãã"
+msgid "Identifies the geographic coordinates associated with point locations in the active frame on the graphics monitor."
+msgstr "ã°ã©ãã£ãã¯ã¢ãã¿ã¼ä¸ã®åä½ä¸ã®ãã¬ã¼ã ã«ããããã¤ã³ããã±ã¼ã·ã§ã³ã«é¢é£ããå°ç座æ¨ãèå¥ãã¦ãã ãã"
#: ../display/d.where/main.c:49
msgid "One mouse click only"
@@ -16947,12 +16134,8 @@
msgstr "ç¾å¨ã®æ¥åä½ãåç
§ããåºå緯度/çµåº¦"
#: ../display/d.where/main.c:63
-msgid ""
-"Output lat/long referenced to WGS84 ellipsoid using datum transformation "
-"parameters defined in current location (if available)"
-msgstr ""
-"ç¾å¨ã®ãã±ã¼ã·ã§ã³ã§å®ç¾©ããã¦ãããã¼ã¿å¤æãã©ã¡ã¼ã¿ã¼ãç¨ããWGS84æ¥åä½ã"
-"åç
§ããåºå緯度/çµåº¦ (å©ç¨å¯è½ã§ããã°) "
+msgid "Output lat/long referenced to WGS84 ellipsoid using datum transformation parameters defined in current location (if available)"
+msgstr "ç¾å¨ã®ãã±ã¼ã·ã§ã³ã§å®ç¾©ããã¦ãããã¼ã¿å¤æãã©ã¡ã¼ã¿ã¼ãç¨ããWGS84æ¥åä½ãåç
#: ../display/d.where/main.c:69
msgid "Output frame coordinates of current display monitor (percentage)"
@@ -17115,12 +16298,8 @@
msgstr "è¦å: %s - ãã¯ãã«ãããã¯è¦ã¤ããã¾ãã\n"
#: ../display/d.what.vect/main.c:56
-msgid ""
-"Allows the user to interactively query a vector map layer at user-selected "
-"locations within the current geographic region."
-msgstr ""
-"ç¾å¨ã®å°çé åå
ã®ã¦ã¼ã¶ã¼æå®ã®ãã±ã¼ã·ã§ã³ã«ããã¦ã¦ã¼ã¶ã¼ã¯ã¤ã³ã¿ã©ã¯ãã£"
-"ãã«ãã¯ãã«ãããã¬ã¤ã¤ã¼ãæ¤ç´¢ã§ãã¾ã"
+msgid "Allows the user to interactively query a vector map layer at user-selected locations within the current geographic region."
+msgstr "ç¾å¨ã®å°çé åå
ã®ã¦ã¼ã¶ã¼æå®ã®ãã±ã¼ã·ã§ã³ã«ããã¦ã¦ã¼ã¶ã¼ã¯ã¤ã³ã¿ã©ã¯ãã£ãã«ãã¯ãã«ãããã¬ã¤ã¤ã¼ãæ¤ç´¢ã§ãã¾ã"
#: ../display/d.what.vect/main.c:74 ../display/d.what.rast/main.c:94
msgid "Identify just one location"
@@ -17161,12 +16340,8 @@
msgstr "空éã¤ã³ããã¯ã¹ãæ§ç¯ä¸ããã"
#: ../display/d.text/main.c:68 ../display/d.text.new/main.c:144
-msgid ""
-"Draws text in the active display frame on the graphics monitor using the "
-"current font."
-msgstr ""
-"ç¾å¨ã®ãã©ã³ãã使ç¨ãã¦ã°ã©ãã£ãã¯ã¢ãã¿ã¼ã§ä½åä¸ã®è¡¨ç¤ºãã¬ã¼ã ã«ããã¹ã"
-"ãæãã¾ã"
+msgid "Draws text in the active display frame on the graphics monitor using the current font."
+msgstr "ç¾å¨ã®ãã©ã³ãã使ç¨ãã¦ã°ã©ãã£ãã¯ã¢ãã¿ã¼ã§ä½åä¸ã®è¡¨ç¤ºãã¬ã¼ã ã«ããã¹ããæãã¾ã"
#: ../display/d.text/main.c:77 ../display/d.text.new/main.c:159
msgid "Height of letters in percentage of available frame height"
@@ -17182,11 +16357,8 @@
msgstr "æãããã¹ãã«ãããã¹ã¯ãªã¼ã³ã©ã¤ã³ãã³ãã¼"
#: ../display/d.text/main.c:103 ../display/d.text.new/main.c:192
-msgid ""
-"Screen position at which text will begin to be drawn (percentage, [0,0] is "
-"lower left)"
-msgstr ""
-"ããã¹ããéå§ãããã¹ã¯ãªã¼ã³ãã¸ã·ã§ã³ (ãã¼ã»ã³ã, [0,0] ã¯å·¦ä¸ã§ã)"
+msgid "Screen position at which text will begin to be drawn (percentage, [0,0] is lower left)"
+msgstr "ããã¹ããéå§ãããã¹ã¯ãªã¼ã³ãã¸ã·ã§ã³ (ãã¼ã»ã³ã, [0,0] ã¯å·¦ä¸ã§ã)"
#: ../display/d.text/main.c:110 ../display/d.text.freetype/main.c:217
#: ../display/d.text.new/main.c:208
@@ -17220,20 +16392,12 @@
msgstr "ä¿åãããã¬ã¼ã å"
#: ../display/d.save/main.c:126
-msgid ""
-"List of object numbers to remove which are displayed after \"#\". -1 for the "
-"last object."
-msgstr ""
-"\"#\". -1 for the æå¾ã®ãªãã¸ã§ã¯ãã®\"#\". -1 ã®å¾ã«è¡¨ç¤ºããã¦ãã.é¤å»ãã"
-"ãªãã¸ã§ã¯ãæ°ã®ãªã¹ã "
+msgid "List of object numbers to remove which are displayed after \"#\". -1 for the last object."
+msgstr "\"#\". -1 for the æå¾ã®ãªãã¸ã§ã¯ãã®\"#\". -1 ã®å¾ã«è¡¨ç¤ºããã¦ãã.é¤å»ãããªãã¸ã§ã¯ãæ°ã®ãªã¹ã "
#: ../display/d.save/main.c:134
-msgid ""
-"List of object numbers to move (\"from\" to \"to\"). remove= option will be "
-"done first, if any."
-msgstr ""
-"ç§»åãããªãã¸ã§ã¯ãæ°ã®ãªã¹ã (\"from\" ãã \"to\"ã¸). remove= option ã¯ã"
-"ãã°æåã«å®è¡ããã¾ã. "
+msgid "List of object numbers to move (\"from\" to \"to\"). remove= option will be done first, if any."
+msgstr "ç§»åãããªãã¸ã§ã¯ãæ°ã®ãªã¹ã (\"from\" ãã \"to\"ã¸). remove= option ã¯ããã°æåã«å®è¡ããã¾ã. "
#: ../display/d.save/main.c:143
msgid "Save current frame"
@@ -17278,12 +16442,8 @@
msgstr "ã©ã¹ã¿ã¼ãããã«ããã¦ã»ã«å¤ãã¤ã³ã¿ã©ã¯ãã£ãã«ç·¨éãã¾ã"
#: ../display/d.linegraph/linegraph.c:115
-msgid ""
-"Generates and displays simple line graphs in the active graphics monitor "
-"display frame."
-msgstr ""
-"åä½ãã¦ããã°ã©ãã£ãã¯ã¢ãã¿ã¼è¡¨ç¤ºãã¬ã¼ã ã«ã·ã³ãã«ãªç·ã°ã©ãã使ããã¦"
-"表示ãã¾ã"
+msgid "Generates and displays simple line graphs in the active graphics monitor display frame."
+msgstr "åä½ãã¦ããã°ã©ãã£ãã¯ã¢ãã¿ã¼è¡¨ç¤ºãã¬ã¼ã ã«ã·ã³ãã«ãªç·ã°ã©ãã使ããã¦è¡¨ç¤ºãã¾ã"
#: ../display/d.linegraph/linegraph.c:119
msgid "Name of data file for X axis of graph"
@@ -17329,8 +16489,7 @@
#: ../display/d.linegraph/linegraph.c:290
#, c-format
msgid "Y input file <%s> contains %s data points than the X input file"
-msgstr ""
-"Y å
¥åãã¡ã¤ã« <%s> 㯠X å
¥åãã¡ã¤ã«ãã %s ãã¼ã¿ãã¤ã³ããå«ãã§ãã¾ã"
+msgstr "Y å
¥åãã¡ã¤ã« <%s> 㯠X å
#: ../display/d.linegraph/linegraph.c:295
#, c-format
@@ -17385,9 +16544,7 @@
#: ../display/d.profile/main.c:106
#, c-format
msgid "Display raster [%s] not found. Using profile raster."
-msgstr ""
-"ãã£ã¹ãã¬ã¤ã©ã¹ã¿ã¼ [%s] ã¯è¦ã¤ããã¾ããã§ãã. ãããã¡ã¤ã«ã©ã¹ã¿ã¼ã使ç¨"
-"ãã¦ãã¾ã. "
+msgstr "ãã£ã¹ãã¬ã¤ã©ã¹ã¿ã¼ [%s] ã¯è¦ã¤ããã¾ããã§ãã. ãããã¡ã¤ã«ã©ã¹ã¿ã¼ã使ç¨ãã¦ãã¾ã. "
#: ../display/d.profile/main.c:130
msgid ""
@@ -17438,12 +16595,8 @@
msgstr "ä¸è¬çãª, ããã管ç"
#: ../display/d.ask/main.c:38
-msgid ""
-"Prompts the user to select a GRASS data base file from among files displayed "
-"in a menu on the graphics monitor."
-msgstr ""
-"ã°ã©ãã£ãã¯ã¢ãã¿ã¼ã®ã¡ãã¥ã¼ã«è¡¨ç¤ºããã¦ãããã¡ã¤ã«ããGRASSãã¼ã¿ãã¼ã¹"
-"ãã¡ã¤ã«ãã¦ã¼ã¶ã¼ã«é¸æããã"
+msgid "Prompts the user to select a GRASS data base file from among files displayed in a menu on the graphics monitor."
+msgstr "ã°ã©ãã£ãã¯ã¢ãã¿ã¼ã®ã¡ãã¥ã¼ã«è¡¨ç¤ºããã¦ãããã¡ã¤ã«ããGRASSãã¼ã¿ãã¼ã¹ãã¡ã¤ã«ãã¦ã¼ã¶ã¼ã«é¸æããã"
#: ../display/d.ask/main.c:46
msgid "Database element, one word description"
@@ -17468,13 +16621,8 @@
msgstr "ãããã®å¤ãã¯ãªãã¯ãã¦ãã¾ã"
#: ../display/d.what.rast/main.c:54
-msgid ""
-"Allows the user to interactively query the category contents of multiple "
-"raster map layers at user specified locations within the current geographic "
-"region."
-msgstr ""
-"ç¾å¨ã®å°çé åã§ã¦ã¼ã¶ã¼æå®ã®ãã±ã¼ã·ã§ã³ã«ãããè¤æ°ã®ã©ã¹ã¿ã¼ãããã¬ã¤"
-"ã¤ã¼ã®ã«ãã´ãªã¼å
容ã®ã¤ã³ã¿ã©ã¯ãã£ããªæ¤ç´¢ãã¦ã¼ã¶ã¼ã«è¨±å¯ãã¾ã"
+msgid "Allows the user to interactively query the category contents of multiple raster map layers at user specified locations within the current geographic region."
+msgstr "ç¾å¨ã®å°çé åã§ã¦ã¼ã¶ã¼æå®ã®ãã±ã¼ã·ã§ã³ã«ãããè¤æ°ã®ã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ã®ã«ãã´ãªã¼å
#: ../display/d.what.rast/main.c:89
msgid "Field separator (terse mode only)"
@@ -17533,11 +16681,8 @@
msgstr "è²ã®æ°ã表示ãã¾ã"
#: ../display/d.vect.chart/main.c:65
-msgid ""
-"Displays charts of vector data in the active frame on the graphics monitor."
-msgstr ""
-"ã°ã©ãã£ãã¯ã¢ãã¿ã¼ã®ä½åä¸ã®ãã¬ã¼ã ã«ããããã¯ãã«ãã¼ã¿ã®ãã£ã¼ãã表示"
-"ãã¾ã "
+msgid "Displays charts of vector data in the active frame on the graphics monitor."
+msgstr "ã°ã©ãã£ãã¯ã¢ãã¿ã¼ã®ä½åä¸ã®ãã¬ã¼ã ã«ããããã¯ãã«ãã¼ã¿ã®ãã£ã¼ãã表示ãã¾ã "
#: ../display/d.vect.chart/main.c:82
msgid "Chart type"
@@ -17615,9 +16760,7 @@
msgstr "ã¹ã±ã¼ã«ãã¼ã®ã¿æãã¾ã"
#: ../display/d.barscale/main.c:98
-msgid ""
-"The screen coordinates for top-left corner of label ([0,0] is top-left of "
-"frame)"
+msgid "The screen coordinates for top-left corner of label ([0,0] is top-left of frame)"
msgstr "ã©ãã«ã®å·¦ä¸ã³ã¼ãã¼ã®ã¹ã¯ãªã¼ã³åº§æ¨ ([0,0] ã¯ãã¬ã¼ã ã®å·¦ä¸ã§ã)"
#: ../display/d.barscale/main.c:106 ../display/d.grid/main.c:95
@@ -17648,12 +16791,8 @@
msgstr "ã¦ã¼ã¶ã¼æå®ã®ã«ã©ã¼ãç¨ãã¦åä½ä¸ã®ãã£ã¹ãã¬ã¤ã®å
å®¹ãæ¶å»ãã¾ã"
#: ../display/d.erase/main.c:42
-msgid ""
-"Color to erase with, either a standard GRASS color or R:G:B triplet "
-msgstr ""
-"æ¨æºGRASSã«ã©ã¼ã¾ãã¯R:G:B triplet (ã³ãã³ã§åºå¥) ã®ãããããç¨ãã¦æ¶å»ãã"
-"ã«ã©ã¼"
+msgid "Color to erase with, either a standard GRASS color or R:G:B triplet (separated by colons)"
+msgstr "æ¨æºGRASSã«ã©ã¼ã¾ãã¯R:G:B triplet (ã³ãã³ã§åºå¥) ã®ãããããç¨ãã¦æ¶å»ããã«ã©ã¼"
#: ../display/d.erase/main.c:47 ../display/d.frame/frame.c:74
msgid "Remove all frames and erase the screen"
@@ -17678,11 +16817,8 @@
msgstr "表示ããã¯ãã«"
#: ../display/d.zoom/main.c:59
-msgid ""
-"Allows the user to change the current geographic region settings "
-"interactively, with a mouse."
-msgstr ""
-"ã¦ã¼ã¶ã¼ã¯ç¾å¨ã®å°çé åã®è¨å®ããã¦ã¹ã§ã¤ã³ã¿ã©ã¯ãã£ãã«å¤æ´ã§ãã¾ã."
+msgid "Allows the user to change the current geographic region settings interactively, with a mouse."
+msgstr "ã¦ã¼ã¶ã¼ã¯ç¾å¨ã®å°çé åã®è¨å®ããã¦ã¹ã§ã¤ã³ã¿ã©ã¯ãã£ãã«å¤æ´ã§ãã¾ã."
#: ../display/d.zoom/main.c:90 ../display/d.legend/main.c:92
#: ../locale/scriptstrings/r.univar.sh_to_translate.c:4
@@ -17802,12 +16938,8 @@
msgstr "å³: çµäº\n"
#: ../display/d.rast.num/number.c:86
-msgid ""
-"Overlays cell category values on a raster map layer displayed to the "
-msgstr ""
-"ã°ã©ãã£ãã¯ã¢ãã¿ã¼ã«è¡¨ç¤ºããã¦ããã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ã«ã»ã«ã«ãã´ãªã¼å¤"
-"ãéãåããã¾ã"
+msgid "Overlays cell category values on a raster map layer displayed to the graphics monitor."
+msgstr "ã°ã©ãã£ãã¯ã¢ãã¿ã¼ã«è¡¨ç¤ºããã¦ããã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ã«ã»ã«ã«ãã´ãªã¼å¤ãéãåããã¾ã"
#: ../display/d.rast.num/number.c:99
msgid "Color for drawing grid, or \"none\""
@@ -17842,24 +16974,18 @@
#: ../display/d.rast.num/number.c:210
msgid ""
"\n"
-"Your current window setting may be too large. Cells displayed on your "
-"graphics window may be too small for cell category number to be visible."
+"Your current window setting may be too large. Cells displayed on your graphics window may be too small for cell category number to be visible."
msgstr ""
"\n"
-"ç¾å¨ã®ã¦ã¤ã³ãã¦è¨å®ã¯å¤§ããããããããã¾ãã. ã°ã©ãã£ãã¯ã«è¡¨ç¤ºããã¦ãã"
-"ã»ã«ã¯ã»ã«ã«ãã´ãªã¼æ°ãè¦ããããã«ããã«ã¯å°ããããããããã¾ãã"
+"ç¾å¨ã®ã¦ã¤ã³ãã¦è¨å®ã¯å¤§ããããããããã¾ãã. ã°ã©ãã£ãã¯ã«è¡¨ç¤ºããã¦ããã»ã«ã¯ã»ã«ã«ãã´ãªã¼æ°ãè¦ããããã«ããã«ã¯å°ããããããããã¾ãã"
#: ../display/d.rast.num/number.c:216
msgid "Aborting."
msgstr "䏿ãã¦ãã¾ã. "
#: ../display/d.text.freetype/main.c:140
-msgid ""
-"Draws text in the graphics monitor's active display frame using TrueType "
-"fonts."
-msgstr ""
-"TrueType ãã©ã³ãã使ç¨ãã°ã©ãã£ãã¯ã¢ãã¿ã¼ã®ä½åãã¦ãã表示ãã¬ã¼ã ã«ãã"
-"ã¹ããæãã¾ã"
+msgid "Draws text in the graphics monitor's active display frame using TrueType fonts."
+msgstr "TrueType ãã©ã³ãã使ç¨ãã°ã©ãã£ãã¯ã¢ãã¿ã¼ã®ä½åãã¦ãã表示ãã¬ã¼ã ã«ããã¹ããæãã¾ã"
#: ../display/d.text.freetype/main.c:146 ../display/d.text.new/main.c:150
msgid "Text to display"
@@ -17960,8 +17086,7 @@
#: ../display/d.text.freetype/main.c:645
#, c-format
msgid "%s: Unable to read FreeType definition file; use the default"
-msgstr ""
-"%s: FreeTypeå®ç¾©ãã¡ã¤ã«ãèªã¿è¾¼ãã¾ãã; ããã©ã«ãã使ç¨ãã¦ãã ãã "
+msgstr "%s: FreeTypeå®ç¾©ãã¡ã¤ã«ãèªã¿è¾¼ãã¾ãã; ããã©ã«ãã使ç¨ãã¦ãã ãã "
#: ../display/d.text.freetype/main.c:651
#, c-format
@@ -18002,12 +17127,8 @@
msgstr "pj_do_proj6 ã«ãããã¨ã©ã¼ "
#: ../display/d.grid/main.c:53
-msgid ""
-"Overlays a user-specified grid in the active display frame on the graphics "
-"monitor."
-msgstr ""
-"ã°ã©ãã£ãã¯ã¢ãã¿ã¼ã§ä½åãã¦ãã表示ãã¬ã¼ã ã«ãããã¦ã¼ã¶ã¼æå®ã®ã°ãªãã"
-"ã䏿¸ããã¾ã"
+msgid "Overlays a user-specified grid in the active display frame on the graphics monitor."
+msgstr "ã°ã©ãã£ãã¯ã¢ãã¿ã¼ã§ä½åãã¦ãã表示ãã¬ã¼ã ã«ãããã¦ã¼ã¶ã¼æå®ã®ã°ãªããã䏿¸ããã¾ã"
#: ../display/d.grid/main.c:61
msgid "Size of grid to be drawn"
@@ -18015,8 +17136,7 @@
#: ../display/d.grid/main.c:62
msgid "In map units or DDD:MM:SS format. Example: \"1000\" or \"0:10\""
-msgstr ""
-"ãããåä½ãããã¯DDD:MM:SSãã©ã¼ããã. ä¾: \"1000\" ã¾ã㯠\"0:10\" "
+msgstr "ãããåä½ãããã¯DDD:MM:SSãã©ã¼ããã. ä¾: \"1000\" ã¾ã㯠\"0:10\" "
#: ../display/d.grid/main.c:71
msgid "Lines of the grid pass through this coordinate"
@@ -18210,8 +17330,7 @@
"Please enter text instructions. Enter EOF (ctrl-d) on last line to quit\n"
msgstr ""
"\n"
-"ããã¹ãæ¡å
ãå
¥åãã¦ãã ãã. çµäºããã«ã¯æå¾ã®ã©ã¤ã³ã« EOF (ctrl-d) ãå
-"åãã¾ã\n"
+"ããã¹ãæ¡å
ãå
¥åãã¾ã\n"
#: ../display/d.text.new/main.c:612
#, c-format
@@ -18238,12 +17357,8 @@
#: ../display/d.his/main.c:67
-msgid ""
-"Displays the result obtained by combining hue, intensity, and saturation "
-"(his) values from user-specified input raster map layers."
-msgstr ""
-"ã¦ã¼ã¶ã¼æå®ã®å
¥åã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ããè²ç¸ãè¼åº¦ã彩度 (his) å¤ãçµåã"
-"ã¦å¾ãçµæã表示ãã¾ã"
+msgid "Displays the result obtained by combining hue, intensity, and saturation (his) values from user-specified input raster map layers."
+msgstr "ã¦ã¼ã¶ã¼æå®ã®å
¥åã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ããè²ç¸ãè¼åº¦ã彩度 (his) å¤ãçµåãã¦å¾ãçµæã表示ãã¾ã"
#: ../display/d.his/main.c:95
msgid "Percent to brighten intensity channel"
@@ -18262,12 +17377,8 @@
msgstr "彩度èªã¿è¾¼ã¿ä¸ã®ã¨ã©ã¼"
#: ../display/d.geodesic/main.c:47
-msgid ""
-"Displays a geodesic line, tracing the shortest distance between two "
-"geographic points along a great circle, in a longitude/latitude data set."
-msgstr ""
-"測å°ç·ã表示ãã¾ããçµåº¦/緯度ãã¼ã¿ã»ããã«ããã2ã¤ã®å°çãã¤ã³ãéã®æçè·"
-"é¢ããã¬ã¼ã¹"
+msgid "Displays a geodesic line, tracing the shortest distance between two geographic points along a great circle, in a longitude/latitude data set."
+msgstr "測å°ç·ã表示ãã¾ããçµåº¦/緯度ãã¼ã¿ã»ããã«ããã2ã¤ã®å°çãã¤ã³ãéã®æçè·é¢ããã¬ã¼ã¹"
#: ../display/d.geodesic/main.c:70
msgid "Text color or \"none\""
@@ -18399,16 +17510,12 @@
#: ../display/d.colortable/main.c:111
#, c-format
-msgid ""
-"<%s> is a floating point map. Ignoring [lines] and drawing continuous color "
-"ramp"
+msgid "<%s> is a floating point map. Ignoring [lines] and drawing continuous color ramp"
msgstr "<%s> ã¯æµ®åå°æ°ç¹ãããï¼[lines] ãç¡è¦ãã¦æé¢ãè²ä»ã§è¡¨ç¤º"
#: ../display/d.colortable/main.c:125
#, c-format
-msgid ""
-"<%s> is a floating point map. Ignoring [cols] and drawing continuous color "
-"ramp"
+msgid "<%s> is a floating point map. Ignoring [cols] and drawing continuous color ramp"
msgstr "<%s> ã¯æµ®åå°æ°ç¹ãããï¼[cols] ãç¡è¦ãã¦æé¢ãè²ä»ã§è¡¨ç¤º"
#: ../display/d.colortable/main.c:134
@@ -18427,9 +17534,7 @@
#: ../display/d.rast/main.c:52
msgid "Displays user-specified raster map in the active graphics frame."
-msgstr ""
#: ../display/d.rast/main.c:65
msgid "List of categories to be displayed (INT maps)"
@@ -18461,21 +17566,15 @@
#: ../display/d.rast/main.c:119
msgid "Ignoring catlist: map is floating point (please use 'val=')"
-msgstr ""
-"catlist ãç¡è¦ãã¦ãã¾ã: ãããã¯æµ®åå°æ°ç¹ã§ã ('val=' ã使ç¨ãã¦ãã ã"
-"ã) "
+msgstr "catlist ãç¡è¦ãã¦ãã¾ã: ãããã¯æµ®åå°æ°ç¹ã§ã ('val=' ã使ç¨ãã¦ãã ãã) "
#: ../display/d.rast/main.c:125
msgid "Ignoring vallist: map is integer (please use 'cat=')"
msgstr "vallistãç¡è¦ãã¦ãã¾ã: ãããã¯æ´æ°ã§ã ('cat='ã使ç¨ãã¦ãã ãã) "
#: ../display/d.thematic.area/main.c:80
-msgid ""
-"Displays a thematic vector area map in the active frame on the graphics "
-"monitor."
-msgstr ""
-"ã°ã©ãã£ãã¯ã¢ãã¿ã¼ã§ä½åä¸ã®ãã¬ã¼ã ã«ããã主é¡ãã¯ãã«ã¨ãªã¢ãããã表示"
-"ãã"
+msgid "Displays a thematic vector area map in the active frame on the graphics monitor."
+msgstr "ã°ã©ãã£ãã¯ã¢ãã¿ã¼ã§ä½åä¸ã®ãã¬ã¼ã ã«ããã主é¡ãã¯ãã«ã¨ãªã¢ãããã表示ãã"
#: ../display/d.thematic.area/main.c:90
msgid "Data to be classified: column name or expression"
@@ -18490,9 +17589,7 @@
msgstr "åé¡ã«ä½¿ç¨ããã¢ã«ã´ãªãºã "
#: ../display/d.thematic.area/main.c:106 ../vector/v.class/main.c:69
-msgid ""
-"int;simple intervals;std;standard deviations;qua;quantiles;equ;equiprobable "
-"(normal distribution);"
+msgid "int;simple intervals;std;standard deviations;qua;quantiles;equ;equiprobable (normal distribution);"
msgstr "int;ã·ã³ãã«åºé;std;æ¨æºåå·®;qua;å使°;equ;ç確ç (æ£è¦åå¸); "
#: ../display/d.thematic.area/main.c:117 ../vector/v.class/main.c:80
@@ -18520,23 +17617,15 @@
msgstr "å¢çè²"
#: ../display/d.thematic.area/main.c:160
-msgid ""
-"d;use the display library basic functions (features: polylines);c;use the "
-"display library clipping functions (features: clipping);l;use the display "
-"library culling functions (features: culling, polylines)"
-msgstr ""
-"d;表示ã©ã¤ãã©ãªãã¼ã·ãã¯æ©è½ãä½¿ç¨ (ãã£ã¼ãã£: ããªã©ã¤ã³);c;表示ã©ã¤ãã©"
-"ãªã¯ãªããæ©è½ãä½¿ç¨ (ãã£ã¼ãã£: ã¯ãªãã);l;表示ã©ã¤ãã©ãªã«ãªã³ã°æ©è½ã使"
-"ç¨ (ãã£ã¼ãã£: ã«ãªã³ã°, ããªã©ã¤ã³)"
+msgid "d;use the display library basic functions (features: polylines);c;use the display library clipping functions (features: clipping);l;use the display library culling functions (features: culling, polylines)"
+msgstr "d;表示ã©ã¤ãã©ãªãã¼ã·ãã¯æ©è½ãä½¿ç¨ (ãã£ã¼ãã£: ããªã©ã¤ã³);c;表示ã©ã¤ãã©ãªã¯ãªããæ©è½ãä½¿ç¨ (ãã£ã¼ãã£: ã¯ãªãã);l;表示ã©ã¤ãã©ãªã«ãªã³ã°æ©è½ãä½¿ç¨ (ãã£ã¼ãã£: ã«ãªã³ã°, ããªã©ã¤ã³)"
#: ../display/d.thematic.area/main.c:168
msgid "File in which to save d.graph instructions for legend display"
msgstr "å¡ä¾è¡¨ç¤ºã®ãã d.graph æ¡å
ãä¿åãããã¡ã¤ã«"
#: ../display/d.thematic.area/main.c:179
-msgid ""
-"When printing legend info , include extended statistical info from "
-"classification algorithm"
+msgid "When printing legend info , include extended statistical info from classification algorithm"
msgstr "å¡ä¾æ
å ±ã®åºåã¯ãåé¡ã¢ã«ã´ãªãºã ããæ¡å¼µãããçµ±è¨æ
å ±ãå«ã¿ã¾ã"
#: ../display/d.thematic.area/main.c:183
@@ -18551,9 +17640,7 @@
#: ../display/d.thematic.area/main.c:218
#, c-format
msgid "%s: You must build topology on vector map. Run v.build."
-msgstr ""
-"%s: ãã¯ãã«ãããã«ãããã¸ã¼ã使ããªããã°ãªãã¾ãã. Run v.build ãå®è¡"
-"ãã¦ãã ãã."
+msgstr "%s: ãã¯ãã«ãããã«ãããã¸ã¼ã使ããªããã°ãªãã¾ãã. Run v.build ãå®è¡ãã¦ãã ãã."
#: ../display/d.thematic.area/main.c:225
msgid "'layer' must be > 0"
@@ -18565,12 +17652,8 @@
msgstr "ãã¼ã¿ (%s) ã¯æ°åã§ã¯ããã¾ãã. åã¯æ°åã§ãªããã°ãªãã¾ãã"
#: ../display/d.thematic.area/main.c:329
-msgid ""
-"You gave both manual breaks and a classification algorithm or a number of "
-"classes. The manual breaks have precedence and will thus be used."
-msgstr ""
-"ããã¥ã¢ã«ãã¬ã¼ã¯ã¨åé¡ã¢ã«ã´ãªãºã ã®ä¸¡æ¹ã¾ãã¯ã¯ã©ã¹ã®æ°ãããã¾ã. ããã¥"
-"ã¢ã«ãã¬ã¼ã¯ã¯åªå
çã«ä½¿ç¨ããã. "
+msgid "You gave both manual breaks and a classification algorithm or a number of classes. The manual breaks have precedence and will thus be used."
+msgstr "ããã¥ã¢ã«ãã¬ã¼ã¯ã¨åé¡ã¢ã«ã´ãªãºã ã®ä¸¡æ¹ã¾ãã¯ã¯ã©ã¹ã®æ°ãããã¾ã. ããã¥ã¢ã«ãã¬ã¼ã¯ã¯åªå
çã«ä½¿ç¨ããã. "
#: ../display/d.thematic.area/main.c:366
msgid "You must either give classbreaks or a classification algorithm"
@@ -18626,11 +17709,8 @@
#: ../display/d.thematic.area/plot1.c:366
#, c-format
-msgid ""
-"Error in color definition column (%s), element %d with cat %d: colorstring "
-"[%s]"
-msgstr ""
-"ã«ã©ã¼å®ç¾©åã«ãããã¨ã©ã¼(%s), cat %dããã¤è¦ç´ %d: ã«ã©ã¼ã¹ããªã³ã° [%s] "
+msgid "Error in color definition column (%s), element %d with cat %d: colorstring [%s]"
+msgstr "ã«ã©ã¼å®ç¾©åã«ãããã¨ã©ã¼(%s), cat %dããã¤è¦ç´ %d: ã«ã©ã¼ã¹ããªã³ã° [%s] "
#: ../display/d.thematic.area/plot1.c:373
#, c-format
@@ -18638,11 +17718,8 @@
msgstr "ã«ã©ã¼å®ç¾©åã«ãããã¨ã©ã¼(%s), cat %d ããã¤è¦ç´ %d "
#: ../display/d.font.freetype/main.c:61 ../display/d.font/main.c:48
-msgid ""
-"Selects the font in which text will be displayed on the user's graphics "
-"monitor."
-msgstr ""
-"ã¦ã¼ã¶ã¼ã®ã°ã©ãã£ãã¯ãä¼¼ãã¼ã«è¡¨ç¤ºãããããã¹ãã®ãã©ã³ãã鏿ãã¾ã"
+msgid "Selects the font in which text will be displayed on the user's graphics monitor."
+msgstr "ã¦ã¼ã¶ã¼ã®ã°ã©ãã£ãã¯ãä¼¼ãã¼ã«è¡¨ç¤ºãããããã¹ãã®ãã©ã³ãã鏿ãã¾ã"
#: ../display/d.font.freetype/main.c:68
msgid "Font name or pathname of TTF file"
@@ -18673,17 +17750,12 @@
msgstr "ã³ãã³ã [%s] ãæ¨ªæè§£æã§ãã¾ãã "
#: ../display/d.graph/main.c:56
-msgid ""
-"Program for generating and displaying simple graphics on the display monitor."
+msgid "Program for generating and displaying simple graphics on the display monitor."
msgstr "表示ã¢ãã¿ã¼ã«ç°¡åãªã°ã©ãã£ãã¯ã使ããã¦è¡¨ç¤ºããããã°ã©ã "
#: ../display/d.graph/main.c:63
-msgid ""
-"Name of file containing graphics commands, if not given reads from standard "
-"input"
-msgstr ""
-"ã°ã©ãã£ãã¯ã³ãã³ããå«ããã¡ã¤ã«ã®åå, ãªããã°æ¨æºå
¥åããèªã¿è¾¼ãã§ãã "
-"ãã "
+msgid "Name of file containing graphics commands, if not given reads from standard input"
+msgstr "ã°ã©ãã£ãã¯ã³ãã³ããå«ããã¡ã¤ã«ã®åå, ãªããã°æ¨æºå
¥åããèªã¿è¾¼ãã§ãã ãã "
#: ../display/d.graph/main.c:71
msgid "Color to draw with, either a standard GRASS color or R:G:B triplet"
@@ -18703,12 +17775,8 @@
#: ../display/d.rgb/main.c:56
-msgid ""
-"Displays three user-specified raster maps as red, green, and blue overlays "
-"in the active graphics frame."
-msgstr ""
+msgid "Displays three user-specified raster maps as red, green, and blue overlays in the active graphics frame."
#: ../display/d.rgb/main.c:70
#, c-format
@@ -18862,12 +17930,8 @@
"\n"
#: ../display/d.rast.arrow/arrow.c:112
-msgid ""
-"Draws arrows representing cell aspect direction for a raster map containing "
-"aspect data."
-msgstr ""
-"ã¢ã¹ãã¯ããã¼ã¿ãå«ãã©ã¹ã¿ã¼ãããã®ã»ã«ã¢ã¹ãã¯ãæ¹åã表ãç¢å°ã使ãã¾"
-"ã"
+msgid "Draws arrows representing cell aspect direction for a raster map containing aspect data."
+msgstr "ã¢ã¹ãã¯ããã¼ã¿ãå«ãã©ã¹ã¿ã¼ãããã®ã»ã«ã¢ã¹ãã¯ãæ¹åã表ãç¢å°ã使ãã¾ã"
#: ../display/d.rast.arrow/arrow.c:121
msgid "Name of raster aspect map to be displayed"
@@ -18962,11 +18026,8 @@
msgstr "db ãªã³ã¯æ
å ±ãåå¾ã§ãã¾ãã -> 表ãã³ãã¼ã§ãã¾ãã."
#: ../display/d.legend/main.c:88
-msgid ""
-"Displays a legend for a raster map in the active frame of the graphics "
-"monitor."
-msgstr ""
-"ã°ã©ãã£ãã¯ã¢ãã¿ã¼ã®ä½åä¸ã®ãã¬ã¼ã ã«ãããã©ã¹ã¿ã¼ãããå¡ä¾ã表示ãã¾ã"
+msgid "Displays a legend for a raster map in the active frame of the graphics monitor."
+msgstr "ã°ã©ãã£ãã¯ã¢ãã¿ã¼ã®ä½åä¸ã®ãã¬ã¼ã ã«ãããã©ã¹ã¿ã¼ãããå¡ä¾ã表示ãã¾ã"
#: ../display/d.legend/main.c:99
msgid "Sets the legend's text color"
@@ -19029,9 +18090,7 @@
#: ../display/d.legend/main.c:340
msgid "Legend box lies outside of frame. Text may not display properly."
-msgstr ""
-"å¡ä¾ããã¯ã¹ã¯ãã¬ã¼ã ã®å¤ã«ããã¾ã. ããã¹ãã¯æ£å¸¸ã«è¡¨ç¤ºãããªãããããã¾"
-"ãã. "
+msgstr "å¡ä¾ããã¯ã¹ã¯ãã¬ã¼ã ã®å¤ã«ããã¾ã. ããã¹ãã¯æ£å¸¸ã«è¡¨ç¤ºãããªãããããã¾ãã. "
#: ../display/d.legend/main.c:344
msgid "Drawing horizontal legend as box width exceeds height"
@@ -19065,9 +18124,7 @@
#: ../display/d.legend/main.c:487
msgid "Forcing a smooth legend: too many categories for current window height"
-msgstr ""
-"ã¹ã ã¼ãºå¡ä¾ãå¼·å¶ãã¦ãã¾ã: ç¾å¨ã®ã¦ã¤ã³ãã¦ã®é«ãã«ã¯ã«ãã´ãªã¼ãå¤ããã¾"
-"ã"
+msgstr "ã¹ã ã¼ãºå¡ä¾ãå¼·å¶ãã¦ãã¾ã: ç¾å¨ã®ã¦ã¤ã³ãã¦ã®é«ãã«ã¯ã«ãã´ãªã¼ãå¤ããã¾ã"
#: ../display/d.legend/main.c:542
#, c-format
@@ -19083,10 +18140,8 @@
msgstr "表示ãã»ããã¢ãã"
#: ../display/d.menu/main.c:68
-msgid ""
-"Creates and displays a menu within the active frame on the graphics monitor."
-msgstr ""
-"ã°ã©ãã£ãã¯ã¢ãã¿ã¼ã®åä½ä¸ã®ãã¬ã¼ã å
ã®ã¡ãã¥ã¼ã使ããã¦è¡¨ç¤ºãã¾ã"
+msgid "Creates and displays a menu within the active frame on the graphics monitor."
+msgstr "ã°ã©ãã£ãã¯ã¢ãã¿ã¼ã®åä½ä¸ã®ãã¬ã¼ã å
#: ../display/d.menu/main.c:77
msgid "Sets the color of the menu background"
@@ -19113,9 +18168,7 @@
msgstr "表示ããã¯ãã«"
#: ../display/d.measure/main.c:51
-msgid ""
-"Measures the lengths and areas of features drawn by the user in the active "
-"display frame on the graphics monitor."
+msgid "Measures the lengths and areas of features drawn by the user in the active display frame on the graphics monitor."
msgstr "è·é¢ãé åã®è¨æ¸¬ãè¡ãã¾ã "
#: ../display/d.measure/main.c:57
@@ -19200,8 +18253,7 @@
#: ../display/d.nviz/main.c:147
msgid "Either -i flag and/or route parameter must be used"
-msgstr ""
-"-i ãã©ãã° ããã¦/ã¾ã㯠ã«ã¼ããã©ã¡ã¼ã¿ã¼ã®ããããã使ç¨ãã¦ãã ãã "
+msgstr "-i ãã©ãã° ããã¦/ã¾ã㯠ã«ã¼ããã©ã¡ã¼ã¿ã¼ã®ããããã使ç¨ãã¦ãã ãã "
#: ../display/d.nviz/main.c:171
msgid "Off-screen only available with full render mode"
@@ -19226,20 +18278,15 @@
msgstr "NVIZ ã¹ã¯ãªãã <%s> ã使ãã¾ãã. "
#: ../display/d.nviz/main.c:538
-msgid ""
-"Skipping this point, selected point is outside region. Perhaps the camera "
-"setback distance puts it beyond the edge?"
-msgstr ""
-"ãã®ãã¤ã³ããã¹ããããã¦ãã¾ã, 鏿ããããã¤ã³ãã¯é åå¤ã§ã. ã²ãã£ã¨ã"
-"ãã¨ã«ã¡ã©ã»ããããã¯è·é¢ã¯ç«¯ãããã¦ãããã? "
+msgid "Skipping this point, selected point is outside region. Perhaps the camera setback distance puts it beyond the edge?"
+msgstr "ãã®ãã¤ã³ããã¹ããããã¦ãã¾ã, 鏿ããããã¤ã³ãã¯é åå¤ã§ã. ã²ãã£ã¨ããã¨ã«ã¡ã©ã»ããããã¯è·é¢ã¯ç«¯ãããã¦ãããã? "
#: ../display/d.extend/main.c:52
msgid "No raster or vector map displayed"
msgstr "ã©ã¹ã¿ã¼ããã¯ãã«ãããã表示ããã¾ãã "
#: ../display/d.title/main.c:47
-msgid ""
-"Create a TITLE for a raster map in a form suitable for display with d.text."
+msgid "Create a TITLE for a raster map in a form suitable for display with d.text."
msgstr "d.textã§ã®è¡¨ç¤ºã«é©ããå½¢ã§ã©ã¹ã¿ã¼ãããã®ã¿ã¤ãã«ã使ãã¦ãã ãã."
#: ../display/d.title/main.c:58
@@ -19298,11 +18345,8 @@
#: ../display/d.font/main.c:126
#, c-format
-msgid ""
-"Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
-msgstr ""
-"ãã©ã³ãå <%s> ã¯ä¸æã§ã. ãã©ã³ãåããã§ãã¯ã¾ã㯠'g.mkfontcap' ãå®è¡ã"
-"ã¦ãã ãã "
+msgid "Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
+msgstr "ãã©ã³ãå <%s> ã¯ä¸æã§ã. ãã©ã³ãåããã§ãã¯ã¾ã㯠'g.mkfontcap' ãå®è¡ãã¦ãã ãã "
#: ../general/g.filename/main.c:39 ../general/g.access/main.c:37
#: ../general/g.tempfile/main.c:36 ../general/g.findfile/main.c:35
@@ -19335,8 +18379,7 @@
#: ../general/g.gui/main.c:38
msgid "Launches a GRASS graphical user interface (GUI) session."
-msgstr ""
-"GRASS ã°ã©ãã£ãã¯ã¦ã¼ã¶ã¤ã³ã¿ã¼ãã§ã¼ã¹ (GUI) ã»ãã·ã§ã³ãèµ·åãã¾ã. "
+msgstr "GRASS ã°ã©ãã£ãã¯ã¦ã¼ã¶ã¤ã³ã¿ã¼ãã§ã¼ã¹ (GUI) ã»ãã·ã§ã³ãèµ·åãã¾ã. "
#: ../general/g.gui/main.c:43
msgid "GUI type"
@@ -19347,14 +18390,8 @@
msgstr "æ¢å®å¤: å®ç¾©ããã¦ããã°GRASS_GUI ããã§ãªããã°wxpython"
#: ../general/g.gui/main.c:45
-msgid ""
-"wxpython;wxPython based GUI - wxGUI;tcltk;Tcl/Tk based GUI - GIS Manager "
-"(gis.m);oldtcltk;Old Tcl/Tk based GUI - Display Manager (d.m);text;command "
-"line interface only"
-msgstr ""
-"tcltk;GUI ã«åºã¥ã Tcl/Tk - GIS管çè
(gis.m);oldtcltk;GUI ã«åºã¥ã Old Tcl/"
-"Tk - 表示管çè
(d.m);wxpython;次ä¸ä»£ GUIã«åºã¥ãwxPython;ããã¹ã;ã³ãã³ãã©"
-"ã¤ã³ã¤ã³ã¿ã¼ãã§ã¼ã¹ã®ã¿"
+msgid "wxpython;wxPython based GUI - wxGUI;tcltk;Tcl/Tk based GUI - GIS Manager (gis.m);oldtcltk;Old Tcl/Tk based GUI - Display Manager (d.m);text;command line interface only"
+msgstr "tcltk;GUI ã«åºã¥ã Tcl/Tk - GIS管çè
(gis.m);oldtcltk;GUI ã«åºã¥ã Old Tcl/Tk - 表示管çè
(d.m);wxpython;次ä¸ä»£ GUIã«åºã¥ãwxPython;ããã¹ã;ã³ãã³ãã©ã¤ã³ã¤ã³ã¿ã¼ãã§ã¼ã¹ã®ã¿"
#: ../general/g.gui/main.c:54
msgid "Name of workspace file"
@@ -19426,15 +18463,8 @@
msgstr "æ¹æ£å¤é
å¼ãªã¼ãã¼"
#: ../general/g.transform/main.c:339
-msgid ""
-"idx;point index;src;source coordinates;dst;destination coordinates;fwd;"
-"forward coordinates (destination);rev;reverse coordinates (source);fxy;"
-"forward coordinates difference (destination);rxy;reverse coordinates "
-"difference (source);fd;forward error (destination);rd;reverse error (source)"
-msgstr ""
-"idx;ãã¤ã³ãã¤ã³ããã¯ã¹;src;ã½ã¼ã¹åº§æ¨;dst;ç®çå°åº§æ¨;fwd;æååãåº§æ¨ (ç®ç"
-"å°);rev;éåº§æ¨ (ã½ã¼ã¹);fxy;æååã座æ¨å·®ç° (ç®çå°);rxy;é座æ¨å·®ç° (ã½ã¼"
-"ã¹);fd;æååãã¨ã©ã¼ (ç®çå°);rd;éã¨ã©ã¼ (ã½ã¼ã¹)"
+msgid "idx;point index;src;source coordinates;dst;destination coordinates;fwd;forward coordinates (destination);rev;reverse coordinates (source);fxy;forward coordinates difference (destination);rxy;reverse coordinates difference (source);fd;forward error (destination);rd;reverse error (source)"
+msgstr "idx;ãã¤ã³ãã¤ã³ããã¯ã¹;src;ã½ã¼ã¹åº§æ¨;dst;ç®çå°åº§æ¨;fwd;æååãåº§æ¨ (ç®çå°);rev;éåº§æ¨ (ã½ã¼ã¹);fxy;æååã座æ¨å·®ç° (ç®çå°);rxy;é座æ¨å·®ç° (ã½ã¼ã¹);fd;æååãã¨ã©ã¼ (ç®çå°);rd;éã¨ã©ã¼ (ã½ã¼ã¹)"
#: ../general/g.transform/main.c:349 ../vector/v.out.ascii/out.c:63
msgid "Output format"
@@ -19446,8 +18476,7 @@
#: ../general/g.transform/main.c:359
msgid "File containing coordinates to transform (\"-\" to read from stdin)"
-msgstr ""
-"ã«ãã´ãªã¼ã©ãã«ã«ã¼ã«ãå«ããã¡ã¤ã« (ã¾ã㯠\"-\" æ¨æºå
¥åããèªã¿è¾¼ã¿)"
+msgstr "ã«ãã´ãªã¼ã©ãã«ã«ã¼ã«ãå«ããã¡ã¤ã« (ã¾ã㯠\"-\" æ¨æºå
¥åããèªã¿è¾¼ã¿)"
#: ../general/g.transform/main.c:360
msgid "Local x,y coordinates to target east,north"
@@ -19483,14 +18512,11 @@
#: ../general/g.access/main.c:59
msgid "UNIX filesystem access controls are not supported by MS-Windows"
-msgstr ""
-"UNIX ãã¡ã¤ã«ã·ã¹ãã ã¢ã¯ã»ã¹ã³ã³ããã¼ã«ã¯MS-Windowsã§ãµãã¼ãããã¦ãã¾ãã"
+msgstr "UNIX ãã¡ã¤ã«ã·ã¹ãã ã¢ã¯ã»ã¹ã³ã³ããã¼ã«ã¯MS-Windowsã§ãµãã¼ãããã¦ãã¾ãã"
#: ../general/g.access/main.c:67
msgid "Access to the PERMANENT mapset must be open, nothing changed"
-msgstr ""
-"PERMANENTãããã»ããã¸ã®ã¢ã¯ã»ã¹ã¯éããã¦ãªããã°ãªãã¾ãã, ä½ã夿´ããã¾"
-"ããã§ãã"
+msgstr "PERMANENTãããã»ããã¸ã®ã¢ã¯ã»ã¹ã¯éããã¦ãªããã°ãªãã¾ãã, ä½ã夿´ããã¾ããã§ãã"
#: ../general/g.access/main.c:71
msgid "Unable to determine mapset permissions"
@@ -19498,11 +18524,11 @@
#: ../general/g.access/exp_perms.c:11 ../general/g.access/exp_perms.c:29
msgid "have"
-msgstr ""
+msgstr "ææ"
#: ../general/g.access/exp_perms.c:12
msgid "read "
-msgstr ""
+msgstr "èªè¾¼"
#: ../general/g.access/exp_perms.c:15
msgid "Everyone"
@@ -19510,19 +18536,7 @@
#: ../general/g.access/exp_perms.c:16
msgid "has"
-msgstr ""
-"ãããããããããããããããããããããããããããããããããããããã"
-"ãããããããããããããããããããããããããã"
+msgstr "ææ"
#: ../general/g.access/exp_perms.c:19
msgid "Only users in your group"
@@ -19543,7 +18557,7 @@
#: ../general/g.access/exp_perms.c:32
msgid "will"
-msgstr ""
+msgstr "ä»å¾"
msgid "now"
@@ -19567,24 +18581,16 @@
#: ../general/g.findfile/main.c:79
#, c-format
-msgid ""
-"Parameter 'file' contains reference to <%s> mapset, but mapset parameter <"
-"%s> does not correspond"
-msgstr ""
-"ãã©ã¡ã¼ã¿ 'ãã¡ã¤ã«' 㯠<%s> ãããã»ããã¸ã®åç
§ãå«ãã§ãã¾ãããããã»ã"
-"ããã©ã¡ã¼ã¿ <%s> ã¯ä¸è´ãã¾ãã"
+msgid "Parameter 'file' contains reference to <%s> mapset, but mapset parameter <%s> does not correspond"
+msgstr "ãã©ã¡ã¼ã¿ 'ãã¡ã¤ã«' 㯠<%s> ãããã»ããã¸ã®åç
§ãå«ãã§ãã¾ãããããã»ãããã©ã¡ã¼ã¿ <%s> ã¯ä¸è´ãã¾ãã"
#: ../general/g.proj/main.c:54 ../general/g.setproj/main.c:78
msgid "general, projection"
msgstr "ä¸è¬çãªãæå½±"
#: ../general/g.proj/main.c:56
-msgid ""
-"Converts co-ordinate system descriptions (i.e. projection information) "
-"between various formats (including GRASS format)."
-msgstr ""
-"æ§ã
ãªãã©ã¼ãããé (GRASS ãã©ã¼ããããå«ã) ã®åº§æ¨ã·ã¹ãã è¨è¿° (ä¾ æå½±æ
-"å ±) ã夿ãã¾ã. "
+msgid "Converts co-ordinate system descriptions (i.e. projection information) between various formats (including GRASS format)."
+msgstr "æ§ã
å ±) ã夿ãã¾ã. "
#: ../general/g.proj/main.c:59
msgid "Can also be used to create GRASS locations."
@@ -19611,8 +18617,7 @@
msgstr "ESRI-ã¹ã¿ã¤ã«ãã©ã¼ã¢ããã使ç¨ãã¾ã (WKTåºåã«ã®ã¿é©ç¨) "
#: ../general/g.proj/main.c:94
-msgid ""
-"Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
+msgid "Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
msgstr "æ¹è¡ãªãã®'flat' ãåºå (WKT 㨠PROJ.4 åºåã«é©ç¨) "
#: ../general/g.proj/main.c:103
@@ -19644,9 +18649,7 @@
msgstr "æªæå®ã«ã¯ \"0\" ã¾ã㯠ãªã¹ãã¨çµäºã«ã¯ \"-1\""
#: ../general/g.proj/main.c:145
-msgid ""
-"Force override of datum transformation information in input co-ordinate "
-"system"
+msgid "Force override of datum transformation information in input co-ordinate system"
msgstr "å
¥å座æ¨ã·ã¹ãã ã«ããããã¼ã¿å¤ææ
å ±ã®å¼·å¶ãªã¼ãã¼ã©ã¤ã"
#: ../general/g.proj/main.c:150 ../general/g.proj/main.c:159
@@ -19654,12 +18657,8 @@
msgstr "使/ç·¨é"
#: ../general/g.proj/main.c:151
-msgid ""
-"Create new projection files (modifies current location unless 'location' "
-"option specified)"
-msgstr ""
-"æ°ããæå½±ãã¡ã¤ã«ã使ã§ãã¾ãã ('ãã±ã¼ã·ã§ã³' ãªãã·ã§ã³ãæå®ããã¦ããª"
-"ãéãç¾ãã±ã¼ã·ã§ã³ãä¿®æ£) "
+msgid "Create new projection files (modifies current location unless 'location' option specified)"
+msgstr "æ°ããæå½±ãã¡ã¤ã«ã使ã§ãã¾ãã ('ãã±ã¼ã·ã§ã³' ãªãã·ã§ã³ãæå®ããã¦ããªãéãç¾ãã±ã¼ã·ã§ã³ãä¿®æ£) "
#: ../general/g.proj/main.c:160
msgid "Name of new location to create"
@@ -19710,17 +18709,12 @@
#: ../general/g.proj/input.c:245
#, c-format
msgid "Could not read georeferenced file %s using either OGR nor GDAL"
-msgstr ""
-"OGR 㨠GDAL ã®ã©ã¡ãã使ç¨ãã¦ãå°çåç
§ãã¡ã¤ã« %s ãèªã¿è¾¼ãã¾ããã§ãã"
+msgstr "OGR 㨠GDAL ã®ã©ã¡ãã使ç¨ãã¦ãå°çåç
#: ../general/g.proj/input.c:250
#, c-format
-msgid ""
-"Read of file %s was successful, but it did not contain projection "
-"information. 'XY (unprojected)' will be used"
-msgstr ""
-"ãã¡ã¤ã« %s ã®èªã¿è¾¼ã¿ã¯æåãã¾ãããæå½±æ
å ±ãå«ãã§ãã¾ãã. 'XY (æªæ"
-"å½±)' ã使ç¨ããã¾ã "
+msgid "Read of file %s was successful, but it did not contain projection information. 'XY (unprojected)' will be used"
+msgstr "ãã¡ã¤ã« %s ã®èªã¿è¾¼ã¿ã¯æåãã¾ãããæå½±æ
å ±ãå«ãã§ãã¾ãã. 'XY (æªæå½±)' ã使ç¨ããã¾ã "
#: ../general/g.proj/output.c:141
#, c-format
@@ -19748,12 +18742,8 @@
#: ../general/g.proj/output.c:174
#, c-format
-msgid ""
-"You must select the PERMANENT mapset before updating the current location's "
-"projection. (Current mapset is %s)"
-msgstr ""
-"ç¾å¨ã®ãã±ã¼ã·ã§ã³ã®æå½±ãã¢ãããã¼ã以åã«PERMANENTãããã»ããã鏿ãã¦ã"
-"ã ãã. (ç¾å¨ã®ãããã»ãã㯠%s ã§ã) "
+msgid "You must select the PERMANENT mapset before updating the current location's projection. (Current mapset is %s)"
+msgstr "ç¾å¨ã®ãã±ã¼ã·ã§ã³ã®æå½±ãã¢ãããã¼ã以åã«PERMANENTãããã»ããã鏿ãã¦ãã ãã. (ç¾å¨ã®ãããã»ãã㯠%s ã§ã) "
#: ../general/g.proj/output.c:190
#, c-format
@@ -19779,14 +18769,8 @@
msgstr "PROJ_UNITS æ¸ãè¾¼ã¿ã®ã¨ã©ã¼ "
#: ../general/g.proj/output.c:243
-msgid ""
-"N.B. The default region was updated to the new projection, but if you have "
-"multiple mapsets g.region -d should be run in each to update the region from "
-"the default."
-msgstr ""
-"N.B. ããã©ã«ãã®é åã¯æ°ããæå½±ã«ã¢ãããã¼ãããã¾ããããè¤æ°ã®ãããã»ã"
-"ããæã£ã¦ããå ´åã¯ããã©ã«ãããã®é åãã¢ãããã¼ãããããg.region -d ã"
-"ããããã«ããã¦å®è¡ããå¿
è¦ãããã¾ã."
+msgid "N.B. The default region was updated to the new projection, but if you have multiple mapsets g.region -d should be run in each to update the region from the default."
+msgstr "N.B. ããã©ã«ãã®é åã¯æ°ããæå½±ã«ã¢ãããã¼ãããã¾ããããè¤æ°ã®ãããã»ãããæã£ã¦ããå ´åã¯ããã©ã«ãããã®é åãã¢ãããã¼ãããããg.region -d ãããããã«ããã¦å®è¡ããå¿
è¦ãããã¾ã."
#: ../general/g.proj/output.c:247
msgid "Projection information updated!"
@@ -19844,8 +18828,7 @@
#: ../general/g.mremove/check_reclass.c:18 ../general/manage/cmd/remove.c:41
#, c-format
msgid "[%s@%s] is a base map. Remove reclassed map first: %s"
-msgstr ""
-"[%s@%s] ã¯ãã¼ã¹ãããã§ã. å
ã«ååé¡ãããããããåé¤ãã¦ãã ãã: %s"
+msgstr "[%s@%s] ã¯ãã¼ã¹ãããã§ã. å
#: ../general/g.mremove/check_reclass.c:41
#: ../general/g.mremove/check_reclass.c:55 ../general/manage/cmd/remove.c:63
@@ -19909,11 +18892,8 @@
msgstr "ç¾å¨ã®ãããã»ããã夿´ãã¾ã"
#: ../general/g.mapset/main.c:50
-msgid ""
-"Optionally create new mapset or list available mapsets in given location."
-msgstr ""
-"ãªãã·ã§ã³ã§æ°è¦ãããã»ããã使ã¾ãã¯æå®ããããã±ã¼ã·ã§ã³ã§å©ç¨å¯è½ãª"
-"ãããã»ããããªã¹ãã¢ãã"
+msgid "Optionally create new mapset or list available mapsets in given location."
+msgstr "ãªãã·ã§ã³ã§æ°è¦ãããã»ããã使ã¾ãã¯æå®ããããã±ã¼ã·ã§ã³ã§å©ç¨å¯è½ãªãããã»ããããªã¹ãã¢ãã"
#: ../general/g.mapset/main.c:57
msgid "Name of mapset where to switch"
@@ -19924,8 +18904,7 @@
msgstr "æ°ãããã±ã¼ã·ã§ã³å (ãã±ã¼ã·ã§ã³ãã¹ã§ã¯ããã¾ãã) "
#: ../general/g.mapset/main.c:75
-msgid ""
-"GIS data directory (full path to the directory where the new location is)"
+msgid "GIS data directory (full path to the directory where the new location is)"
msgstr "æ°ããGISDBASE (æ°ãããã±ã¼ã·ã§ã³ã®ãããã£ã¬ã¯ããªã¼ã¸ã®ãã«ãã¹) "
#: ../general/g.mapset/main.c:80
@@ -19966,12 +18945,8 @@
#: ../general/g.mapset/main.c:179
#, c-format
-msgid ""
-"%s is currently running GRASS in selected mapset or lock file cannot be "
-"checked"
-msgstr ""
-"%s ã¯ç¾å¨é¸æããããããã»ããã§GRASSãå®è¡ãã¦ãã¾ã ã¾ãã¯ããã¯ãã¡ã¤ã«ã¯"
-"ãã§ãã¯ã§ãã¾ãã"
+msgid "%s is currently running GRASS in selected mapset or lock file cannot be checked"
+msgstr "%s ã¯ç¾å¨é¸æããããããã»ããã§GRASSãå®è¡ãã¦ãã¾ã ã¾ãã¯ããã¯ãã¡ã¤ã«ã¯ãã§ãã¯ã§ãã¾ãã"
#: ../general/g.mapset/main.c:183
msgid "Erasing monitors..."
@@ -20009,12 +18984,8 @@
msgstr "ç¾å¨ã®ãããã»ãã㯠<%s>ã§ã "
#: ../general/g.mlist/main.c:67
-msgid ""
-"Lists available GRASS data base files of the user-specified data type "
-"optionally using the search pattern."
-msgstr ""
-"æ¨æºåºåã¸ã®ã¦ã¼ã¶ã¼æå®ããããã¼ã¿ã¿ã¤ãã®ç¾å¨ä½¿ç¨ã§ããGRASSãã¼ã¿ãã¼ã¹"
-"ãã¡ã¤ã«ã®ä¸è¦§ã表示ãã¾ã "
+msgid "Lists available GRASS data base files of the user-specified data type optionally using the search pattern."
+msgstr "æ¨æºåºåã¸ã®ã¦ã¼ã¶ã¼æå®ããããã¼ã¿ã¿ã¤ãã®ç¾å¨ä½¿ç¨ã§ããGRASSãã¼ã¿ãã¼ã¹ãã¡ã¤ã«ã®ä¸è¦§ã表示ãã¾ã "
#: ../general/g.mlist/main.c:97
msgid "Map name search pattern (default: all)"
@@ -20043,7 +19014,7 @@
#: ../general/g.mlist/main.c:144
msgid "Print fully-qualified map names (including mapsets)"
-msgstr ""
+msgstr "ï¼ãããã»ãããå«ãï¼å®å
¨ãªãããåãå
¥å"
#: ../general/g.mlist/main.c:149
msgid "Pretty printing in human readable format"
@@ -20111,9 +19082,7 @@
#: ../general/manage/cmd/rename.c:42
msgid "Renames data base element files in the user's current mapset."
-msgstr ""
-"ã¦ã¼ã¶ã¼ã®ç¾å¨ã®ãããã»ããã«ãããã¼ã¿ãã¼ã¹ã¨ã¬ã¡ã³ããã¡ã¤ã«åã夿´ãã¾"
-"ã "
+msgstr "ã¦ã¼ã¶ã¼ã®ç¾å¨ã®ãããã»ããã«ãããã¼ã¿ãã¼ã¹ã¨ã¬ã¡ã³ããã¡ã¤ã«åã夿´ãã¾ã "
#: ../general/manage/cmd/rename.c:57
#, c-format
@@ -20141,18 +19110,11 @@
#: ../general/manage/cmd/list.c:43
msgid "Lists available GRASS data base files of the user-specified data type."
-msgstr ""
#: ../general/manage/cmd/copy.c:41
-msgid ""
-"Copies available data files in the user's current mapset search path and "
-"location to the appropriate element directories under the user's current "
-"mapset."
-msgstr ""
-"ç¾ãããã»ããã«ããé©åãªè¦ç´ ãã£ã¬ã¯ããªã¸ã®ã¦ã¼ã¶ã¼ã®ç¾å¨ã®ãããã»ããæ¤"
-"ç´¢ãã¹ã¨ãã±ã¼ã·ã§ã³ã«ãããå©ç¨å¯è½ãªãã¼ã¿ãã¡ã¤ã«ãã³ãã¼ãã¾ã"
+msgid "Copies available data files in the user's current mapset search path and location to the appropriate element directories under the user's current mapset."
+msgstr "ç¾ãããã»ããã«ããé©åãªè¦ç´ ãã£ã¬ã¯ããªã¸ã®ã¦ã¼ã¶ã¼ã®ç¾å¨ã®ãããã»ããæ¤ç´¢ãã¹ã¨ãã±ã¼ã·ã§ã³ã«ãããå©ç¨å¯è½ãªãã¼ã¿ãã¡ã¤ã«ãã³ãã¼ãã¾ã"
#: ../general/manage/cmd/copy.c:58
#, c-format
@@ -20222,9 +19184,7 @@
msgstr "ã³ã³ãã¼ã¸ã§ã³ã¹è§åº¦ (度 CCW) ã表示"
#: ../general/g.region/main.c:130
-msgid ""
-"The difference between the projection's grid north and true north, measured "
-"at the center coordinates of the current region."
+msgid "The difference between the projection's grid north and true north, measured at the center coordinates of the current region."
msgstr "ç¾å¨ã®ãªã¼ã¸ã§ã³ã®ä¸å¿åº§æ¨ã§è¨æ¸¬ããããæå½±ã®ã°ãªããåã¨çåã®å·®ç°."
#: ../general/g.region/main.c:136
@@ -20236,9 +19196,7 @@
msgstr "WGS84ã®ç·¯åº¦çµåº¦ã§æå¤§å¢çããã¯ã¹ã表示"
#: ../general/g.region/main.c:153
-msgid ""
-"Align region to resolution (default = align to bounds, works only for 2D "
-"resolution)"
+msgid "Align region to resolution (default = align to bounds, works only for 2D resolution)"
msgstr "é åãè§£å度ã«åãããï¼2Dè§£å度ã®ã¿æå¹ï¼"
#: ../general/g.region/main.c:159
@@ -20345,8 +19303,7 @@
#: ../general/g.region/main.c:857
msgid "Unable to change default region. The current mapset is not <PERMANENT>."
-msgstr ""
-"ããã©ã«ãé åã夿´ã§ãã¾ãã. ãã®ãããã»ãã㯠<PERMANENT>ã§ã¯ããã¾ãã."
+msgstr "ããã©ã«ãé åã夿´ã§ãã¾ãã. ãã®ãããã»ãã㯠<PERMANENT>ã§ã¯ããã¾ãã."
#: ../general/g.region/main.c:874
#, c-format
@@ -20377,20 +19334,12 @@
msgstr "ãã§ã«ç·¯åº¦/çµåº¦ã«ããã¾ã. 代ããã« -p flag ã使ç¨ãã¦ãã ãã."
#: ../general/g.region/printwindow.c:412
-msgid ""
-"You are in a simple XY location, projection to Lat/Lon is not possible. Use "
-"the -p flag instead."
-msgstr ""
-"ã·ã³ãã«ãã±ã¼ã·ã§ã³ã«ãã¾ãã緯度/çµåº¦ã¸ã®æå½±ã¯ã§ãã¾ãã. 代ããã« -p "
-"flag ã使ç¨ãã¦ãã ãã"
+msgid "You are in a simple XY location, projection to Lat/Lon is not possible. Use the -p flag instead."
+msgstr "ã·ã³ãã«ãã±ã¼ã·ã§ã³ã«ãã¾ãã緯度/çµåº¦ã¸ã®æå½±ã¯ã§ãã¾ãã. 代ããã« -p flag ã使ç¨ãã¦ãã ãã"
#: ../general/g.region/printwindow.c:637
-msgid ""
-"WGS84 output not possible as this location does not contain datum "
-"transformation parameters. Try running g.setproj."
-msgstr ""
-"ãã®ãã±ã¼ã·ã§ã³ã¯ãã¼ã¿å¤æãã©ã¡ã¼ã¿ã¼ãå«ãã§ããªããããWGS84 åºåã¯åºæ¥"
-"ã¾ãã. g.setproj ãå®è¡ãã¦ã¿ã¦ãã ãã."
+msgid "WGS84 output not possible as this location does not contain datum transformation parameters. Try running g.setproj."
+msgstr "ãã®ãã±ã¼ã·ã§ã³ã¯ãã¼ã¿å¤æãã©ã¡ã¼ã¿ã¼ãå«ãã§ããªããããWGS84 åºåã¯åºæ¥ã¾ãã. g.setproj ãå®è¡ãã¦ã¿ã¦ãã ãã."
#: ../general/g.region/printwindow.c:783
msgid "Lat/Long calculations are not possible from a simple XY system"
@@ -20513,13 +19462,8 @@
msgstr "UTMã¾ã¼ã³æ
å ±ã¯ã¢ãããã¼ãããã¦ãã¾ãã"
#: ../general/g.setproj/main.c:455
-msgid ""
-"But if you change zone, all the existing data will be interpreted by "
-"projection software. GRASS will not automatically re-project or even change "
-"the headers for existing maps."
-msgstr ""
-"ã¾ã¼ã³ã夿´ããã¨ç¾åã®å
¨ã¦ã®ãã¼ã¿ã¯ããã¸ã§ã¯ã·ã§ã³ã½ããã¦ã§ã¢ã«ãã£ã¦è§£"
-"éããã¾ã. GRASSã¯èªåçã«éæå½±ã¾ãã¯ç¾åã®ãããã®ãããã¼ã夿´ãã¾ã. "
+msgid "But if you change zone, all the existing data will be interpreted by projection software. GRASS will not automatically re-project or even change the headers for existing maps."
+msgstr "ã¾ã¼ã³ã夿´ããã¨ç¾åã®å
¨ã¦ã®ãã¼ã¿ã¯ããã¸ã§ã¯ã·ã§ã³ã½ããã¦ã§ã¢ã«ãã£ã¦è§£éããã¾ã. GRASSã¯èªåçã«éæå½±ã¾ãã¯ç¾åã®ãããã®ãããã¼ã夿´ãã¾ã. "
#: ../general/g.setproj/main.c:460
msgid "Would you still like to change the UTM zone?"
@@ -20680,8 +19624,7 @@
msgstr "ä¸è¬çãªãã¹ã¯ãªãã"
#: ../general/g.message/main.c:35
-msgid ""
-"Prints a message, warning, progress info, or fatal error in the GRASS way."
+msgid "Prints a message, warning, progress info, or fatal error in the GRASS way."
msgstr "ã¡ãã»ã¼ã¸ãè¦åãã¾ãã¯GRASSã®è´å½çã¨ã©ã¼ãåºå. "
#: ../general/g.message/main.c:37
@@ -20761,12 +19704,8 @@
msgstr "ç¾å¨ã®ãããã»ããã表示 "
#: ../general/g.mapsets/main.c:61
-msgid ""
-"Affects the user's access to data existing under the other mapsets in the "
-"current location."
-msgstr ""
-"ç¾ãã±ã¼ã·ã§ã³ã«ãããä»GRASSãããã»ããä¸ã«ãããã¼ã¿ã¸ã®ã¦ã¼ã¶ã¼ã®ã¢ã¯ã»ã¹"
-"ã«å½±é¿ãããã¦ã¼ã¶ã¼ã®ç¾ãããã»ããæ¤ç´¢ãã¹ãä¿®æ£ãã¾ã"
+msgid "Affects the user's access to data existing under the other mapsets in the current location."
+msgstr "ç¾ãã±ã¼ã·ã§ã³ã«ãããä»GRASSãããã»ããä¸ã«ãããã¼ã¿ã¸ã®ã¦ã¼ã¶ã¼ã®ã¢ã¯ã»ã¹ã«å½±é¿ãããã¦ã¼ã¶ã¼ã®ç¾ãããã»ããæ¤ç´¢ãã¹ãä¿®æ£ãã¾ã"
#: ../general/g.mapsets/main.c:69
msgid "Name(s) of existing mapset(s)"
@@ -20872,9 +19811,7 @@
msgstr "zå¤ã®ååã¨å (ä¾. æ´æ°å, å精度å) "
#: ../vector/v.random/main.c:121
-msgid ""
-"If type is not given then DOUBLE PRECISION is used. Writes Z data to column "
-"instead of 3D vector."
+msgid "If type is not given then DOUBLE PRECISION is used. Writes Z data to column instead of 3D vector."
msgstr " 3D ãã¯ãã« ã®ä»£ããã«Z ãã¼ã¿ãã³ã©ã ã«æ¸ãè¾¼ã¿ã¾ã"
#: ../vector/v.random/main.c:127 ../vector/v.in.ogr/main.c:211
@@ -20909,12 +19846,8 @@
msgstr "ãã¼ãã«ã¯2ã¤ä»¥ä¸ã®åãå«ãã¾ãã"
#: ../vector/v.random/main.c:234
-msgid ""
-"You have created unsupported column type. This module supports only INTEGER "
-"and DOUBLE PRECISION column types."
-msgstr ""
-"ãµãã¼ãããã¦ããªãååã¯ä½æããã¾ãã. ãã®ã¢ã¸ã¥ã¼ã«ã¯æ´æ°åã¨å精度ã®å"
-"åã®ã¿ãµãã¼ããã¦ãã¾ã. "
+msgid "You have created unsupported column type. This module supports only INTEGER and DOUBLE PRECISION column types."
+msgstr "ãµãã¼ãããã¦ããªãååã¯ä½æããã¾ãã. ãã®ã¢ã¸ã¥ã¼ã«ã¯æ´æ°åã¨å精度ã®ååã®ã¿ãµãã¼ããã¦ãã¾ã. "
#: ../vector/v.random/main.c:264
msgid "Generating points..."
@@ -20929,13 +19862,8 @@
msgstr "ãã¯ãã«, ãããã¯ã¼ã¯"
#: ../vector/v.net.iso/main.c:75
-msgid ""
-"Splits net to bands between cost isolines (direction from centre). Centre "
-"node must be opened (costs >= 0). Costs of centre node are used in "
-"calculation."
-msgstr ""
-"Splits net to bands between ã³ã¹ã çå¤ç· (ä¸å¿ããã®æ¹å). ä¸å¿ãã¼ããéã"
-"ã¦ãã ãã (ã³ã¹ã >= 0). ä¸å¿ãã¼ãã¯è¨ç®ã«ä½¿ç¨ããã¦ãã¾ã. "
+msgid "Splits net to bands between cost isolines (direction from centre). Centre node must be opened (costs >= 0). Costs of centre node are used in calculation."
+msgstr "Splits net to bands between ã³ã¹ã çå¤ç· (ä¸å¿ããã®æ¹å). ä¸å¿ãã¼ããéãã¦ãã ãã (ã³ã¹ã >= 0). ä¸å¿ãã¼ãã¯è¨ç®ã«ä½¿ç¨ããã¦ãã¾ã. "
#: ../vector/v.net.iso/main.c:99 ../vector/v.net.alloc/main.c:92
msgid "Arc forward/both direction(s) cost column (number)"
@@ -20950,13 +19878,8 @@
msgstr "ãã¼ãã³ã¹ãå (æ°)"
#: ../vector/v.net.iso/main.c:113
-msgid ""
-"Categories of centres (points on nodes) to which net will be allocated. "
-"Layer for this categories is given by nlayer option."
-msgstr ""
-"ããããå²ãå½ã¦ãããã§ãããä¸å¿ã®ã«ãã´ãªã¼(ãã¼ãã«ããããã¤ã³ã) to "
-"which net will be allocated. ãã®ã«ãã´ãªã¼ã®ã¬ã¤ã¤ã¼ã¯nã¬ã¤ã¤ã¼ãªãã·ã§ã³ã«"
-"ãã£ã¦ä¸ãããã¦ãã¾ã. "
+msgid "Categories of centres (points on nodes) to which net will be allocated. Layer for this categories is given by nlayer option."
+msgstr "ããããå²ãå½ã¦ãããã§ãããä¸å¿ã®ã«ãã´ãªã¼(ãã¼ãã«ããããã¤ã³ã) to which net will be allocated. ãã®ã«ãã´ãªã¼ã®ã¬ã¤ã¤ã¼ã¯nã¬ã¤ã¤ã¼ãªãã·ã§ã³ã«ãã£ã¦ä¸ãããã¦ãã¾ã. "
#: ../vector/v.net.iso/main.c:122
msgid "Costs for isolines"
@@ -20979,8 +19902,7 @@
#: ../vector/v.net.iso/main.c:171
msgid "Not enough costs, everything reachable falls to first band"
-msgstr ""
-"ã³ã¹ãã¯ååã§ã¯ããã¾ãã, å°éå¯è½ãªãã®ã¯å
¨ã¦æåã®å¨æ³¢æ°å¸¯ã«ä¸ããã¾ã"
+msgstr "ã³ã¹ãã¯ååã§ã¯ããã¾ãã, å°éå¯è½ãªãã®ã¯å
#: ../vector/v.net.iso/main.c:205
msgid "Centre at closed node (costs = -1) ignored"
@@ -21007,13 +19929,11 @@
#: ../vector/v.net.centrality/main.c:95
msgid "vector, network, centrality measures"
-msgstr "centrality measures ãè¨ç®ãã¦ãã¾ã..."
+msgstr "ãã¯ãã«ããããã¯ã¼ã¯ãä¸å¿æ§ãè¨ç®ãã¦ãã¾ã..."
#: ../vector/v.net.centrality/main.c:97
-msgid ""
-"Computes degree, centrality, betweeness, closeness and eigenvector "
-"centrality measures in the network."
-msgstr ""
+msgid "Computes degree, centrality, betweeness, closeness and eigenvector centrality measures in the network."
+msgstr "ãããã¯ã¼ã¯ã®è§åº¦ãä¸å¿æ§ãä¸éæ§ãè¿æ¥æ§ãåºæãã¯ãã«ä¸å¿æ§ãè¨ç®ãã"
#: ../vector/v.net.centrality/main.c:115 ../vector/v.net.allpairs/main.c:73
msgid "Name of arc forward/both direction(s) cost column"
@@ -21157,11 +20077,8 @@
msgstr "ãã¯ãã«ï¼ã¸ãªã¡ããªã¼ï¼ãµã³ããªã³ã°"
#: ../vector/v.voronoi/vo_main.c:121
-msgid ""
-"Creates a Voronoi diagram from an input vector map containing points or "
-"centroids."
-msgstr ""
-"æå®ãããã¯ãã«ãããï¼ãã¤ã³ãã¾ãã¯ã»ã³ããã¤ããå«ãï¼ããVoronoiå³ã使"
+msgid "Creates a Voronoi diagram from an input vector map containing points or centroids."
+msgstr "æå®ãããã¯ãã«ãããï¼ãã¤ã³ãã¾ãã¯ã»ã³ããã¤ããå«ãï¼ããVoronoiå³ã使"
#: ../vector/v.voronoi/vo_main.c:136
msgid "Output tessellation as a graph (lines), not areas"
@@ -21208,12 +20125,8 @@
msgstr "é·ã0ã®ã©ã¤ã³ã¨å¢çãåé¤"
#: ../vector/v.voronoi/dt_main.c:47 ../vector/v.delaunay2/main.c:87
-msgid ""
-"Creates a Delaunay triangulation from an input vector map containing points "
-"or centroids."
-msgstr ""
-"æå®ãããã¯ãã«ãããï¼ãã¤ã³ãã¾ãã¯ã»ã³ããã¤ããå«ãï¼ããDelaunayä¸è§å"
-"岿³ã使"
+msgid "Creates a Delaunay triangulation from an input vector map containing points or centroids."
+msgstr "æå®ãããã¯ãã«ãããï¼ãã¤ã³ãã¾ãã¯ã»ã³ããã¤ããå«ãï¼ããDelaunayä¸è§å岿³ã使"
#: ../vector/v.voronoi/dt_main.c:55 ../vector/v.delaunay2/main.c:95
msgid "Use only points in current region"
@@ -21248,12 +20161,8 @@
msgstr "ãããã¯ã¼ã¯ã¾ãã¯ä¸ãããã端æ«ã®ã·ã¥ã¿ã¤ãã¼æ¨ã使"
#: ../vector/v.net.steiner/main.c:349
-msgid ""
-"Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm "
-"is used in this module so the result may be sub optimal"
-msgstr ""
-"注æï¼ãã®ã¢ã¸ã¥ã¼ã«å
ã§ãæå°ã·ã¥ã¿ã¤ãã¼æ¨ã åé¡ã¯NPå°é£ã§ãã¥ã¼ãªã¹ãã£ã"
-"ã¯ã¢ã«ã´ãªãºã ã使ç¨ããã¾ããï¼ãã£ã¦ãã®çµæã¯åèã§ã"
+msgid "Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm is used in this module so the result may be sub optimal"
+msgstr "注æï¼ãã®ã¢ã¸ã¥ã¼ã«å
ã§ãæå°ã·ã¥ã¿ã¤ãã¼æ¨ã åé¡ã¯NPå°é£ã§ãã¥ã¼ãªã¹ãã£ãã¯ã¢ã«ã´ãªãºã ã使ç¨ããã¾ããï¼ãã£ã¦ãã®çµæã¯åèã§ã"
#: ../vector/v.net.steiner/main.c:369
msgid "Node layer (used for terminals)"
@@ -21286,8 +20195,7 @@
#: ../vector/v.net.steiner/main.c:527
#, c-format
-msgid ""
-"[%d] (not reachable) nodes removed from list of Steiner point candidates"
+msgid "[%d] (not reachable) nodes removed from list of Steiner point candidates"
msgstr "[%d] (å°éä¸è½) ãã¼ãã Steiner ãã¤ã³ãã®åè£ãªã¹ãããé¤å¤"
#: ../vector/v.net.steiner/main.c:532
@@ -21303,8 +20211,7 @@
#: ../vector/v.net.steiner/main.c:559
#, c-format
msgid "Steiner point at node [%d] was added to terminals (MST costs = %f)"
-msgstr ""
-"ãã¼ã [%d] ã® Steiner ãã¤ã³ãã端æ«ã«è¿½å ããã¾ãã (MST ã³ã¹ã = %f) "
+msgstr "ãã¼ã [%d] ã® Steiner ãã¤ã³ãã端æ«ã«è¿½å ããã¾ãã (MST ã³ã¹ã = %f) "
#: ../vector/v.net.steiner/main.c:571
msgid "No Steiner point found -> leaving cycle"
@@ -21380,25 +20287,12 @@
msgstr "æ¼ç®åã¯åºåãããã¯ãã«ãããã«æ¸ãè¾¼ãå°ç©ãå®ç¾©ãã¾ã"
#: ../vector/v.overlay/main.c:98
-msgid ""
-"Feature is written to output if the result of operation 'ainput operator "
-"binput' is true. Input feature is considered to be true, if category of "
-"given layer is defined."
-msgstr ""
-"æ¼ç®çµæ 'ainput operator binput' ãçã§ããã°ï¼å°ç©ã¯åºåã«æ¸ãè¾¼ã¾ãã¾ãï¼"
-"æå®ãããã¬ã¤ã¤ã¼ãå®ç¾©ããã¦ããå ´åï¼å
¥åãããå°ç©ã¯çã¨ã¿ãªããã¾ã"
+msgid "Feature is written to output if the result of operation 'ainput operator binput' is true. Input feature is considered to be true, if category of given layer is defined."
+msgstr "æ¼ç®çµæ 'ainput operator binput' ãçã§ããã°ï¼å°ç©ã¯åºåã«æ¸ãè¾¼ã¾ãã¾ãï¼æå®ãããã¬ã¤ã¤ã¼ãå®ç¾©ããã¦ããå ´åï¼å
#: ../vector/v.overlay/main.c:103
-msgid ""
-"and;also known as 'intersection' in GIS;or;also known as 'union' in GIS "
-"(only for atype=area);not;features from ainput not overlayed by features "
-"from binput;xor;features from either ainput or binput but not those from "
-"ainput overlayed by binput (only for atype=area)"
-msgstr ""
-"andï¼GIS ã§ 'intersection' ã¨ãã¦ç¥ãããï¼orï¼GIS ã§ 'union' ã¨ãã¦ç¥ããã "
-"(åã« atype=area)ï¼notï¼ainput ã®å°ç©ã¯ binputã®å°ç©ã«éãã¾ããï¼xorï¼"
-"ainput ã¾ã㯠binput ã®å°ç©ï¼binput ã«éãããã ainput ã®å°ç©ã§ã¯ãªã (åã« "
-"atype=area) "
+msgid "and;also known as 'intersection' in GIS;or;also known as 'union' in GIS (only for atype=area);not;features from ainput not overlayed by features from binput;xor;features from either ainput or binput but not those from ainput overlayed by binput (only for atype=area)"
+msgstr "andï¼GIS ã§ 'intersection' ã¨ãã¦ç¥ãããï¼orï¼GIS ã§ 'union' ã¨ãã¦ç¥ããã (åã« atype=area)ï¼notï¼ainput ã®å°ç©ã¯ binputã®å°ç©ã«éãã¾ããï¼xorï¼ainput ã¾ã㯠binput ã®å°ç©ï¼binput ã«éãããã ainput ã®å°ç©ã§ã¯ãªã (åã« atype=area) "
#: ../vector/v.overlay/main.c:114
msgid "Output layer for new category, ainput and binput"
@@ -21419,11 +20313,9 @@
msgstr "ãã¯ãã«ãªãã¸ã§ã¯ãããã¯ãã«ããã <%s> ããã³ãã¼ä¸ããã"
#: ../vector/v.overlay/main.c:235
-#, fuzzy, c-format
+#, c-format
msgid "No %s features found in vector map <%s>. Verify '%s' parameter."
-msgstr ""
-"%d ã®ã¨ãªã¢ãããã¾ããã¨ã¯ã¹ãã¼ãã®æå®ãããã¾ããï¼'type' ãã©ã¡ã¼ã¿ã¼ã"
-"確èªãã¦ä¸ãã"
+msgstr "ãã£ã¼ãã£ã¼ %s ããã¯ãã«ããã <%s> ã«åå¨ãã¾ããã'%s' ãã©ã¡ã¼ã¿ã確èªãã¦ãã ãã"
#: ../vector/v.overlay/main.c:269
msgid "Collecting input attributes..."
@@ -21468,13 +20360,8 @@
msgstr "ãã¯ãã«ï¼ã«ã¼ãã«ï¼å¯åº¦"
#: ../vector/v.kernel/main.c:107
-msgid ""
-"Generates a raster density map from vector point data using a moving kernel "
-"or optionally generates a vector density map on a vector network."
-msgstr ""
-"2Då¯åçæ¹æ§ã¬ã¦ã¹åå¸ã«ã¼ãã«ï¼ã¾ãã¯1Dã«ã¼ãã«ãã¯ãã«ãããã¯ã¼ã¯ããéæ"
-"ã«ä½æããããã¯ãã«å¯åº¦ãããã使ç¨ãï¼ãã¯ãã«ãã¤ã³ããã¼ã¿ããã©ã¹ã¿ã¼å¯"
-"度ãããã使"
+msgid "Generates a raster density map from vector point data using a moving kernel or optionally generates a vector density map on a vector network."
+msgstr "2Då¯åçæ¹æ§ã¬ã¦ã¹åå¸ã«ã¼ãã«ï¼ã¾ãã¯1Dã«ã¼ãã«ãã¯ãã«ãããã¯ã¼ã¯ããéæã«ä½æããããã¯ãã«å¯åº¦ãããã使ç¨ãï¼ãã¯ãã«ãã¤ã³ããã¼ã¿ããã©ã¹ã¿ã¼å¯åº¦ãããã使"
#: ../vector/v.kernel/main.c:111
msgid "Input vector with training points"
@@ -21513,9 +20400,7 @@
msgstr "æªè©³ã®ã¡ã½ãã"
#: ../vector/v.kernel/main.c:167
-msgid ""
-"none;No method applied at nodes with more than 2 arcs;split;Equal split "
-"(Okabe 2009) applied at nodes;"
+msgid "none;No method applied at nodes with more than 2 arcs;split;Equal split (Okabe 2009) applied at nodes;"
msgstr "ãªã; å¼§ã2ã¤ä»¥ä¸å«ããã¼ãã§ã¡ã½ããã¯é©ç¨ããã¾ãã"
#: ../vector/v.kernel/main.c:174
@@ -21523,9 +20408,7 @@
msgstr "æ¢ç¥ã®é¢æ°:"
#: ../vector/v.kernel/main.c:182
-msgid ""
-"Try to calculate an optimal standard deviation with 'stddeviation' taken as "
-"maximum (experimental)"
+msgid "Try to calculate an optimal standard deviation with 'stddeviation' taken as maximum (experimental)"
msgstr "stddeviation' ãæå¤§å¤ã¨ãã¦æé©ãªæ¨æºåå·®ãè¨ç®ãã ï¼è©¦è¡ï¼"
#: ../vector/v.kernel/main.c:187
@@ -21533,10 +20416,8 @@
msgstr "æé©ãªæ¨æºåå·®ãè¨ç®ãã¦çµäº (ãããã¯æ¸ãè¾¼ã¾ãªã) "
#: ../vector/v.kernel/main.c:192
-msgid ""
-"In network mode, normalize values by sum of density multiplied by length of "
-"each segment. Integral over the output map then gives 1.0 * mult"
-msgstr ""
+msgid "In network mode, normalize values by sum of density multiplied by length of each segment. Integral over the output map then gives 1.0 * mult"
+msgstr "ãããã¯ã¼ã¯ã¢ã¼ãã§ã¯ãåã»ã°ã¡ã³ãé·ãæããå¯åº¦ã®åè¨ã§å¤ãæ£è¦åãã¾ãã åºåãããã®ç·è¨ã§ã¯1.0ã®ä¿æ°ã«ãªãã¾ãã"
#: ../vector/v.kernel/main.c:197
msgid "In network mode, multiply the result by number of input points."
@@ -21551,19 +20432,12 @@
msgstr "ä¸æãªæå½±"
#: ../vector/v.kernel/main.c:238
-msgid ""
-"Optimal standard deviation calculation is supported only for node method "
-"'none' and kernel function 'gaussian'."
-msgstr ""
-"æé©ãªæ¨æºåå·®è¨ç®ã¯ãã¼ãã¡ã½ãã'none'ã¨ã«ã¼ãã«é¢æ°'gaussian'ã«å¯¾ãã¦ã®ã¿"
-"ãµãã¼ãããã¦ãã¾ã"
+msgid "Optimal standard deviation calculation is supported only for node method 'none' and kernel function 'gaussian'."
+msgstr "æé©ãªæ¨æºåå·®è¨ç®ã¯ãã¼ãã¡ã½ãã'none'ã¨ã«ã¼ãã«é¢æ°'gaussian'ã«å¯¾ãã¦ã®ã¿ãµãã¼ãããã¦ãã¾ã"
#: ../vector/v.kernel/main.c:242
-msgid ""
-"Optimal standard deviation calculation is supported only for kernel function "
-"'gaussian'."
-msgstr ""
-"æé©ãªæ¨æºåå·®è¨ç®ã¯ã«ã¼ãã«é¢æ°'gaussian'ã«å¯¾ãã¦ã®ã¿ãµãã¼ãããã¦ãã¾ã"
+msgid "Optimal standard deviation calculation is supported only for kernel function 'gaussian'."
+msgstr "æé©ãªæ¨æºåå·®è¨ç®ã¯ã«ã¼ãã«é¢æ°'gaussian'ã«å¯¾ãã¦ã®ã¿ãµãã¼ãããã¦ãã¾ã"
#: ../vector/v.kernel/main.c:279
#, c-format
@@ -21577,12 +20451,8 @@
#: ../vector/v.kernel/main.c:334
#, c-format
-msgid ""
-"Automatic choice of smoothing parameter (standard deviation), maximum "
-"possible value of standard deviation is set to %f"
-msgstr ""
-"å¹³æ»åãã©ã¡ã¼ã¿ã¼ï¼æ¨æºåå·®ï¼ãèªåé¸æï¼ æãæå¾
ãããæ¨æºåå·®ãã»ãã "
-"%f "
+msgid "Automatic choice of smoothing parameter (standard deviation), maximum possible value of standard deviation is set to %f"
+msgstr "å¹³æ»åãã©ã¡ã¼ã¿ã¼ï¼æ¨æºåå·®ï¼ãèªåé¸æï¼ æãæå¾
ãããæ¨æºåå·®ãã»ãã %f "
#: ../vector/v.kernel/main.c:341
#, c-format
@@ -21601,11 +20471,8 @@
#: ../vector/v.kernel/main.c:359
#, c-format
-msgid ""
-"Distances between all points are beyond %e (4 * standard deviation), unable "
-"to calculate optimal value."
-msgstr ""
-"å
¨ã¦ã®ãã¤ã³ãéã®è·é¢ã %e (4 * æ¨æºåå·®)ã®ç¯å²å¤ï¼ æé©å¤ãè¨ç®ã§ãã¾ãã "
+msgid "Distances between all points are beyond %e (4 * standard deviation), unable to calculate optimal value."
+msgstr "å
#: ../vector/v.kernel/main.c:370
#, c-format
@@ -21650,7 +20517,7 @@
#: ../vector/v.kernel/function.c:220
msgid "Dimension > 2 supported only by gaussian function"
-msgstr ""
+msgstr "2以ä¸ã®æ¬¡å
ã¯ã¬ã¦ã¹é¢æ°ã®ã¿ã§ãµãã¼ãããã¦ãã¾ã"
#: ../vector/v.in.ogr/main.c:103 ../vector/v.in.dwg/main.c:65
#: ../vector/v.in.ascii/in.c:48 ../vector/v.in.dxf/main.c:60
@@ -21722,13 +20589,8 @@
msgstr "ä»»æã§ããã©ã«ãã®å
¥åã¿ã¤ãã夿´ãã¦ãã ãã"
#: ../vector/v.in.ogr/main.c:164
-msgid ""
-"point;import area centroids as points;line;import area boundaries as lines;"
-"boundary;import lines as area boundaries;centroid;import points as centroids"
-msgstr ""
-"ãã¤ã³ã;ã¨ãªã¢ã»ã³ããã¤ãããã¤ã³ãã¨ãã¦ã¤ã³ãã¼ã;ã©ã¤ã³;ã¨ãªã¢å¢çãã©ã¤"
-"ã³ã¨ãã¦ã¤ã³ãã¼ã;å¢ç;ã©ã¤ã³ãã¨ãªã¢å¢çã¨ãã¦ã¤ã³ãã¼ã;ã»ã³ããã¤ã;ãã¤"
-"ã³ããã»ã³ããã¤ãã¨ãã¦ã¤ã³ãã¼ã"
+msgid "point;import area centroids as points;line;import area boundaries as lines;boundary;import lines as area boundaries;centroid;import points as centroids"
+msgstr "ãã¤ã³ã;ã¨ãªã¢ã»ã³ããã¤ãããã¤ã³ãã¨ãã¦ã¤ã³ãã¼ã;ã©ã¤ã³;ã¨ãªã¢å¢çãã©ã¤ã³ã¨ãã¦ã¤ã³ãã¼ã;å¢ç;ã©ã¤ã³ãã¨ãªã¢å¢çã¨ãã¦ã¤ã³ãã¼ã;ã»ã³ããã¤ã;ãã¤ã³ããã»ã³ããã¤ãã¨ãã¦ã¤ã³ãã¼ã"
#: ../vector/v.in.ogr/main.c:175
msgid "Snapping threshold for boundaries"
@@ -21739,9 +20601,7 @@
msgstr "ã¹ãããç¡ãã¯'-1' "
#: ../vector/v.in.ogr/main.c:191
-msgid ""
-"List of column names to be used instead of original names, first is used for "
-"category column"
+msgid "List of column names to be used instead of original names, first is used for category column"
msgstr "å
ã®ååã®ä»£ããã«ä½¿ç¨ãããååï¼ï¼åç®ã¯ã«ãã´ãªã¼è¡ã¨ãã¦ä½¿ç¨"
#: ../vector/v.in.ogr/main.c:198
@@ -21802,17 +20662,11 @@
msgstr "ã空éããã©ã¡ã¼ã¿ã¼ã«ã¯ï¼å¤æ°ãå¿
è¦"
#: ../vector/v.in.ogr/main.c:484
-msgid ""
-"Unable to convert input map projection to GRASS format; cannot create new "
-"location"
-msgstr ""
-"å
¥åãããæå½±ã GRASS ãã©ã¼ãããã«å¤æã§ãã¾ãã; æ°ãããã±ã¼ã·ã§ã³ã使"
-"ã§ãã¾ãã"
+msgid "Unable to convert input map projection to GRASS format; cannot create new location"
+msgstr "å
¥åãããæå½±ã GRASS ãã©ã¼ãããã«å¤æã§ãã¾ãã; æ°ãããã±ã¼ã·ã§ã³ã使ã§ãã¾ãã"
#: ../vector/v.in.ogr/main.c:496
-msgid ""
-"Unable to convert input map projection information to GRASS format for "
-"checking"
+msgid "Unable to convert input map projection information to GRASS format for checking"
msgstr "å
¥åãããæå½±æ
å ±ããã§ãã¯ã®ããGRASSãã©ã¼ãããã«å¤æã§ãã¾ãã"
#: ../vector/v.in.ogr/main.c:526
@@ -21829,12 +20683,8 @@
"ãã®æå½±ãã§ãã¯ã®ãªã¼ãã¼ã©ã¤ãã« -o ãã©ãã°ãã %s ã¾ã§ä½¿ç¨ã§ãã¾ã.\n"
#: ../vector/v.in.ogr/main.c:589
-msgid ""
-"Consider generating a new location with 'location' parameter from input data "
-"set.\n"
-msgstr ""
-"å
¥åãã¼ã¿ã»ãããã'ãã±ã¼ã·ã§ã³'ãã©ã¡ã¼ã¿ã¼ã®ããæ°ãããã±ã¼ã·ã§ã³ã使"
-"ãã¦ãã ãã.\n"
+msgid "Consider generating a new location with 'location' parameter from input data set.\n"
+msgstr "å
¥åãã¼ã¿ã»ãããã'ãã±ã¼ã·ã§ã³'ãã©ã¡ã¼ã¿ã¼ã®ããæ°ãããã±ã¼ã·ã§ã³ã使ãã¦ãã ãã.\n"
#: ../vector/v.in.ogr/main.c:612
#, c-format
@@ -21854,24 +20704,17 @@
#: ../vector/v.in.ogr/main.c:719
#, c-format
msgid "Writing column <%s> with fixed length %d chars (may be truncated)"
-msgstr ""
-"å<%s>ããåºå®é· %d æåã使ç¨ãã¦æ¸ãè¾¼ãã§ãã¾ã (çç¥ãããå¯è½æ§ãããã¾"
-"ã)"
+msgstr "å<%s>ããåºå®é· %d æåã使ç¨ãã¦æ¸ãè¾¼ãã§ãã¾ã (çç¥ãããå¯è½æ§ãããã¾ã)"
#: ../vector/v.in.ogr/main.c:742
#, c-format
-msgid ""
-"Width for column %s set to 255 (was not specified by OGR), some strings may "
-"be truncated!"
-msgstr ""
-"åã®å¹
㯠%s 255 ã«è¨å®ããã¦ãã¾ã(OGRã«ãã£ã¦æå®ããã¦ãã¾ãã), ããã¤ãã®"
-"ã¹ããªã³ã°ã¯åæãããããããã¾ãã!"
+msgid "Width for column %s set to 255 (was not specified by OGR), some strings may be truncated!"
+msgstr "åã®å¹
㯠%s 255 ã«è¨å®ããã¦ãã¾ã(OGRã«ãã£ã¦æå®ããã¦ãã¾ãã), ããã¤ãã®ã¹ããªã³ã°ã¯åæãããããããã¾ãã!"
#: ../vector/v.in.ogr/main.c:754
#, c-format
msgid "Writing column %s with fixed length %d chars (may be truncated)"
-msgstr ""
-"å %s ããåºå®é· %d æåã使ç¨ãã¦æ¸ãè¾¼ãã§ãã¾ã(çç¥ã®å¯è½æ§ãããã¾ã)"
+msgstr "å %s ããåºå®é· %d æåã使ç¨ãã¦æ¸ãè¾¼ãã§ãã¾ã(çç¥ã®å¯è½æ§ãããã¾ã)"
#: ../vector/v.in.ogr/main.c:758
#, c-format
@@ -21959,15 +20802,8 @@
#: ../vector/v.in.ogr/main.c:1130
#, c-format
-msgid ""
-"%d areas represent more (overlapping) features, because polygons overlap in "
-"input layer(s). Such areas are linked to more than 1 row in attribute table. "
-"The number of features for those areas is stored as category in layer %d"
-msgstr ""
-"%d ã¨ãªã¢ã¯ããå¤ãã® (éè¤ãã¦ãã) ãã£ã¼ãã£ã表ãã¾ã,ããªã´ã³ã¯å
¥åã¬ã¤"
-"ã¤ã¼ã§éè¤ãããã. ãã®ãããªã¨ãªã¢ã¯å±æ§ãã¼ãã«ã«ããã¦1ã¤ä»¥ä¸ã®è¡ã«ãªã³ã¯"
-"ããã¦ãã¾ã. ãããã®ã¨ãªã¢ã®ãã£ã¼ãã£ã®æ°ã¯ã»ã³ããã¤ãã¨ãã¦ã¬ã¤ã¤ã¼ %d "
-"ã«ä¿åããã¦ãã¾ã"
+msgid "%d areas represent more (overlapping) features, because polygons overlap in input layer(s). Such areas are linked to more than 1 row in attribute table. The number of features for those areas is stored as category in layer %d"
+msgstr "%d ã¨ãªã¢ã¯ããå¤ãã® (éè¤ãã¦ãã) ãã£ã¼ãã£ã表ãã¾ã,ããªã´ã³ã¯å
¥åã¬ã¤ã¤ã¼ã§éè¤ãããã. ãã®ãããªã¨ãªã¢ã¯å±æ§ãã¼ãã«ã«ããã¦1ã¤ä»¥ä¸ã®è¡ã«ãªã³ã¯ããã¦ãã¾ã. ãããã®ã¨ãªã¢ã®ãã£ã¼ãã£ã®æ°ã¯ã»ã³ããã¤ãã¨ãã¦ã¬ã¤ã¤ã¼ %d ã«ä¿åããã¦ãã¾ã"
#: ../vector/v.in.ogr/main.c:1140
#, c-format
@@ -22010,12 +20846,8 @@
msgstr "ã«ãã´ãªã¼ã®ãªãé å: %G (%d areas)"
#: ../vector/v.in.ogr/main.c:1208
-msgid ""
-"Input data contains 3D features. Created vector is 2D only, use -z flag to "
-"import 3D vector"
-msgstr ""
-"å
¥åãã¼ã¿ã¯ 3D ãã£ã¼ãã£ã¼ãå«ã¿ã¾ã. 使ããããã¯ãã«ã¯ 2D ã®ã¿ã§ãã "
-"3D ãã¯ãã«ã®ã¤ã³ãã¼ãã« -z ãã©ãã°ã使ç¨ãã¦ãã ãã"
+msgid "Input data contains 3D features. Created vector is 2D only, use -z flag to import 3D vector"
+msgstr "å
¥åãã¼ã¿ã¯ 3D ãã£ã¼ãã£ã¼ãå«ã¿ã¾ã. 使ããããã¯ãã«ã¯ 2D ã®ã¿ã§ãã 3D ãã¯ãã«ã®ã¤ã³ãã¼ãã« -z ãã©ãã°ã使ç¨ãã¦ãã ãã"
#: ../vector/v.in.ogr/geom.c:195
msgid "Cannot read part of geometry"
@@ -22079,17 +20911,8 @@
msgstr "å®è¡ãããªãã¬ã¼ã·ã§ã³"
#: ../vector/v.net/main.c:71
-msgid ""
-"nodes;new point is placed on each node (line end) if doesn't exist;connect;"
-"connect still unconnected points to vector network by inserting new line(s);"
-"report;print to standard output {line_category start_point_category "
-"end_point_category};nreport;print to standard output {point_category "
-"line_category[,line_category...]}"
-msgstr ""
-"ãã¼ã;æ°ãã¤ã³ãã¯ãªããã°åãã¼ãï¼ã©ã¤ã³ã®æå¾ï¼ã«è¨ç½®ããã¦ãã¾ã;æ¥ç¶;æ°"
-"ããã©ã¤ã³ãæ¿å
¥ãæªæ¥ç¶ã®ãã¤ã³ãããã¯ãã«ãããã¯ã¼ã¯ã«æ¥ç¶ãã¾ã;ã¬ãã¼"
-"ã;æ¨æºåºåã¸åºå {line_category start_point_category end_point_category};"
-"nreport;æ¨æºåºåã¸åºå {point_category line_category[,line_category...]}"
+msgid "nodes;new point is placed on each node (line end) if doesn't exist;connect;connect still unconnected points to vector network by inserting new line(s);report;print to standard output {line_category start_point_category end_point_category};nreport;print to standard output {point_category line_category[,line_category...]}"
+msgstr "ãã¼ã;æ°ãã¤ã³ãã¯ãªããã°åãã¼ãï¼ã©ã¤ã³ã®æå¾ï¼ã«è¨ç½®ããã¦ãã¾ã;æ¥ç¶;æ°ããã©ã¤ã³ãæ¿å
¥ãæªæ¥ç¶ã®ãã¤ã³ãããã¯ãã«ãããã¯ã¼ã¯ã«æ¥ç¶ãã¾ã;ã¬ãã¼ã;æ¨æºåºåã¸åºå {line_category start_point_category end_point_category};nreport;æ¨æºåºåã¸åºå {point_category line_category[,line_category...]}"
#: ../vector/v.net/main.c:97
msgid "Required for operation 'connect'. Connect points in given threshold."
@@ -22141,8 +20964,7 @@
#: ../vector/v.net/report.c:67
#, c-format
msgid "Point not found: %.3lf %.3lf %.3lf line category: %d"
-msgstr ""
-"ãã¤ã³ãã¯è¦ã¤ããã¾ããã§ãã: %.3lf %.3lf %.3lf ã©ã¤ã³ã«ãã´ãªã¼: %d "
+msgstr "ãã¤ã³ãã¯è¦ã¤ããã¾ããã§ãã: %.3lf %.3lf %.3lf ã©ã¤ã³ã«ãã´ãªã¼: %d "
#: ../vector/v.net/report.c:70
#, c-format
@@ -22184,8 +21006,7 @@
#: ../vector/v.proj/main.c:188
#, c-format
msgid "Vector map <%s> in location <%s> mapset <%s> not found"
-msgstr ""
-"ãã±ã¼ã·ã§ã³ <%s> ãããã»ãã <%s> ä¸ã«ãã¯ãã«ããã <%s> ãè¦ã¤ããã¾ãã"
+msgstr "ãã±ã¼ã·ã§ã³ <%s> ãããã»ãã <%s> ä¸ã«ãã¯ãã«ããã <%s> ãè¦ã¤ããã¾ãã"
#: ../vector/v.proj/main.c:211
#, c-format
@@ -22297,8 +21118,7 @@
msgstr "ãªãã¼ã¯ããã¯ãã«ã« (èæ¯ã«ã©ã¼ã鏿ããã¦ããå ´åã®ã¿é©å) "
#: ../vector/v.label/main.c:252
-msgid ""
-"size and space options vary significantly which may lead to crummy output"
+msgid "size and space options vary significantly which may lead to crummy output"
msgstr "ãµã¤ãºã¨ã¹ãã¼ã¹ã®ãªãã·ã§ã³ã¯ï¼æå³ã®ãªãåºåã®åå ã«ãªãã§ããã"
#: ../vector/v.label/main.c:260
@@ -22325,11 +21145,8 @@
msgstr "ãã¯ãã«ï¼ãããã¡ã¼"
#: ../vector/v.buffer2/main.c:151 ../vector/v.buffer/main.c:256
-msgid ""
-"Creates a buffer around features of given type (areas must contain centroid)."
-msgstr ""
-"ä¸ããããåã®å°ç©ã®å¨ãã®ãããã¡ã使 (ã¨ãªã¢ã¯ã»ã³ããã¤ããå«ã¾ãªãã¦ã¯"
-"ããã¾ãã)."
+msgid "Creates a buffer around features of given type (areas must contain centroid)."
+msgstr "ä¸ããããåã®å°ç©ã®å¨ãã®ãããã¡ã使 (ã¨ãªã¢ã¯ã»ã³ããã¤ããå«ã¾ãªãã¦ã¯ããã¾ãã)."
#: ../vector/v.buffer2/main.c:169
msgid "Buffer distance along major axis in map units"
@@ -22358,15 +21175,11 @@
msgstr "é«åº¦åã®ã¹ã±ã¼ã«ãã¡ã¯ã¿ã¼å¤"
#: ../vector/v.buffer2/main.c:208 ../vector/v.buffer/main.c:296
-msgid ""
-"Maximum distance between theoretical arc and polygon segments as multiple of "
-"buffer"
+msgid "Maximum distance between theoretical arc and polygon segments as multiple of buffer"
msgstr "ãããã¡ã¼ã®å¤æ§æ§ã¨ãã¦ã®ï¼çè«ä¸ã®å¼§ã¨ããªã´ã³ã»ã°ã¡ã³ãéã®æå¤§è·é¢"
#: ../vector/v.buffer2/main.c:224
-msgid ""
-"This is an alias to the distance option. It is retained for backwards "
-"compatibility"
+msgid "This is an alias to the distance option. It is retained for backwards compatibility"
msgstr "ããã¯è·é¢ãªãã·ã§ã³ã®ã¨ã¤ãªã¢ã¹ï¼ä¸ä½äºææ§ãæ®ãã¾ã"
#: ../vector/v.buffer2/main.c:226 ../vector/v.buffer/main.c:271
@@ -22386,26 +21199,16 @@
msgstr "ãããã¡ã¼è·é¢/ç軸/è§åº¦/åã®ã©ããã鏿 "
#: ../vector/v.buffer2/main.c:250 ../vector/v.buffer/main.c:319
-msgid ""
-"The bufcol option may contain bugs during the cleaning step. If you "
-"encounter problems, use the debug option or clean manually with v.clean "
-"tool=break; v.category step=0; v.extract -d type=area"
-msgstr ""
-"bufcol ãªãã·ã§ã³ã¯ã¯ãªã¼ãã³ã°å¦çä¸ã«ãã°ãå«ãããããã¾ããï¼åé¡ãçºçã"
-"ãã¨ãã¯ï¼debug ãªãã·ã§ã³ã使ããæåã§ãv.clean tool=break; v.category "
-"step=0; v.extract -d type=ã¨ãªã¢ããå®è¡ãã¦ä¸ãã"
+msgid "The bufcol option may contain bugs during the cleaning step. If you encounter problems, use the debug option or clean manually with v.clean tool=break; v.category step=0; v.extract -d type=area"
+msgstr "bufcol ãªãã·ã§ã³ã¯ã¯ãªã¼ãã³ã°å¦çä¸ã«ãã°ãå«ãããããã¾ããï¼åé¡ãçºçããã¨ãã¯ï¼debug ãªãã·ã§ã³ã使ããæåã§ãv.clean tool=break; v.category step=0; v.extract -d type=ã¨ãªã¢ããå®è¡ãã¦ä¸ãã"
#: ../vector/v.buffer2/main.c:261
msgid "The bufcol option requires a valid layer."
msgstr "ã¹ã±ã¼ã«ãªãã·ã§ã³ã¯ magnitude_map ãå¿
è¦ã¨ãã¾ã"
#: ../vector/v.buffer2/main.c:264
-msgid ""
-"The buffer option has been replaced by the distance option and will be "
-"removed in future."
-msgstr ""
-"bufferãªãã·ã§ã³ã¯ distance ãªãã·ã§ã³ã«ç½®ãæãããã¾ãã(buffer ãªãã·ã§ã³"
-"ã¯åé¤ãããäºå®)"
+msgid "The buffer option has been replaced by the distance option and will be removed in future."
+msgstr "bufferãªãã·ã§ã³ã¯ distance ãªãã·ã§ã³ã«ç½®ãæãããã¾ãã(buffer ãªãã·ã§ã³ã¯åé¤ãããäºå®)"
#: ../vector/v.buffer2/main.c:267
msgid "Use the distance option instead of the buffer option."
@@ -22440,12 +21243,8 @@
msgstr "ãã®åã®å½¢å¼ã¯ãµãã¼ããã¦ãã¾ãã"
#: ../vector/v.buffer2/main.c:379
-msgid ""
-"No features available for buffering. Check type option and features "
-"available in the input vector."
-msgstr ""
-"ãã§ãã¯ã¿ã¤ããªãã·ã§ã³ã®ãããã¡ãªã³ã°ã«å©ç¨å¯è½ãªãã£ã¼ãã£ã¯ããã¾ããã"
-"ãã¦å
¥åãã¯ãã«ã®ãã£ã¼ãã£ã¯å©ç¨å¯è½ã§ã"
+msgid "No features available for buffering. Check type option and features available in the input vector."
+msgstr "ãã§ãã¯ã¿ã¤ããªãã·ã§ã³ã®ãããã¡ãªã³ã°ã«å©ç¨å¯è½ãªãã£ã¼ãã£ã¯ããã¾ããããã¦å
#: ../vector/v.buffer2/main.c:394
msgid "Buffering lines..."
@@ -22506,12 +21305,8 @@
msgstr "å¢çãåé¤ãã¦ãã¾ãããã"
#: ../vector/v.univar/main.c:73
-msgid ""
-"Calculates univariate statistics for attribute. Variance and standard "
-"deviation is calculated only for points if specified."
-msgstr ""
-"屿§ã®ä¸å¤éçµ±è¨ãè¨ç®ï¼åæ£ã¨æ£è¦åå¸ã¯ãã¤ã³ããæå®ããå ´åã ãè¨ç®ããã¾"
-"ã"
+msgid "Calculates univariate statistics for attribute. Variance and standard deviation is calculated only for points if specified."
+msgstr "屿§ã®ä¸å¤éçµ±è¨ãè¨ç®ï¼åæ£ã¨æ£è¦åå¸ã¯ãã¤ã³ããæå®ããå ´åã ãè¨ç®ããã¾ã"
#: ../vector/v.univar/main.c:86
msgid "Column name"
@@ -22531,17 +21326,12 @@
"\t(%s)"
#: ../vector/v.univar/main.c:145
-msgid ""
-"Incompatible vector type(s) specified, only number of features, minimum, "
-"maximum and range can be calculated"
-msgstr ""
-"äºææ§ã®ãªããã¯ãã«ã®ã¿ã¤ããæå®ãã¦ãã¾ãï¼ãã£ã¼ãã£ã¼æ°ï¼ æå¤§ï¼æå°ã¾ã"
-"ã¯ç¯å²ã ããè¨ç®å¯è½ã§ã"
+msgid "Incompatible vector type(s) specified, only number of features, minimum, maximum and range can be calculated"
+msgstr "äºææ§ã®ãªããã¯ãã«ã®ã¿ã¤ããæå®ãã¦ãã¾ãï¼ãã£ã¼ãã£ã¼æ°ï¼ æå¤§ï¼æå°ã¾ãã¯ç¯å²ã ããè¨ç®å¯è½ã§ã"
#: ../vector/v.univar/main.c:150
msgid "Extended statistics is currently supported only for points/centroids"
-msgstr ""
-"ç¾å¨ï¼æ¡å¼µãããçµ±è¨ã¯ãã¤ã³ã/ã»ã³ããã¤ãã«ã¤ãã¦ã®ã¿ãµãã¼ããã¦ãã¾ã"
+msgstr "ç¾å¨ï¼æ¡å¼µãããçµ±è¨ã¯ãã¤ã³ã/ã»ã³ããã¤ãã«ã¤ãã¦ã®ã¿ãµãã¼ããã¦ãã¾ã"
#: ../vector/v.univar/main.c:187
#, c-format
@@ -22558,18 +21348,12 @@
msgstr "ãã¯ãã«ãã¤ã³ãã¼ãããµã¤ã"
#: ../vector/v.net.distance/main.c:61
-msgid ""
-"Computes shortest distance via the network between the given sets of "
-"features."
+msgid "Computes shortest distance via the network between the given sets of features."
msgstr "æä¸ã®ãã£ã¼ãã£ã¼ã»ããéã®ãããã¯ã¼ã¯ãçµç±ããæççµè·¯ãè¨ç®"
#: ../vector/v.net.distance/main.c:64
-msgid ""
-"Finds the shortest paths from a feature 'to' to every feature 'from' and "
-"various information about this realtion are uploaded to the attribute table."
-msgstr ""
-"ãã£ã¼ãã£'to'ãã'from'ã¾ã§ã®æçãã¹ãè¦ã¤ããé¢é£ã«é¢ãããã¾ãã¾ãªæ
å ±ã"
-"ãã¼ãã«ã«ã¢ãããã¼ãããã¾ã"
+msgid "Finds the shortest paths from a feature 'to' to every feature 'from' and various information about this realtion are uploaded to the attribute table."
+msgstr "ãã£ã¼ãã£'to'ãã'from'ã¾ã§ã®æçãã¹ãè¦ã¤ããé¢é£ã«é¢ãããã¾ãã¾ãªæ
å ±ããã¼ãã«ã«ã¢ãããã¼ãããã¾ã"
#: ../vector/v.net.distance/main.c:73
msgid "From layer number or name"
@@ -22620,12 +21404,8 @@
msgstr "ãã¯ãã«ï¼ LRS, ãããã¯ã¼ã¯"
#: ../vector/v.lrs/v.lrs.segment/main.c:72
-msgid ""
-"Creates points/segments from input lines, linear reference system and "
-"positions read from stdin or a file."
-msgstr ""
-"æå®ããã©ã¤ã³ï¼ç·å½¢åç
§ç³»ã¨æ¨æºå
¥åï¼ã¾ãã¯ãã¡ã¤ã«ï¼ãããã¤ã³ã/ã»ã°ã¡ã³ã"
-"ã使"
+msgid "Creates points/segments from input lines, linear reference system and positions read from stdin or a file."
+msgstr "æå®ããã©ã¤ã³ï¼ç·å½¢åç
§ç³»ã¨æ¨æºå
¥åï¼ã¾ãã¯ãã¡ã¤ã«ï¼ãããã¤ã³ã/ã»ã°ã¡ã³ãã使"
#: ../vector/v.lrs/v.lrs.segment/main.c:76
#: ../vector/v.lrs/v.lrs.where/main.c:65
@@ -22704,8 +21484,7 @@
"Cannot get point on line: cat = [%d] distance = [%f] (line length = %f)\n"
"%s"
msgstr ""
-"ã©ã¤ã³ä¸ãããã¤ã³ããåå¾ã§ãã¾ããï¼ cat = [%d] è·é¢ = [%f] (ã©ã¤ã³é· = "
-"%f)\n"
+"ã©ã¤ã³ä¸ãããã¤ã³ããåå¾ã§ãã¾ããï¼ cat = [%d] è·é¢ = [%f] (ã©ã¤ã³é· = %f)\n"
"%s "
#: ../vector/v.lrs/v.lrs.segment/main.c:248
@@ -22732,8 +21511,7 @@
"Requested offset for the 1. point not found, using nearest found:\n"
" %s"
msgstr ""
-"1. ã®è¦æ±ããããªãã»ããï¼ãã¤ã³ããè¦ã¤ããã¾ããï¼æå¯ãã®ãã¤ã³ããè¦ã¤ã"
-"ã¾ããï¼\n"
+"1. ã®è¦æ±ããããªãã»ããï¼ãã¤ã³ããè¦ã¤ããã¾ããï¼æå¯ãã®ãã¤ã³ããè¦ã¤ãã¾ããï¼\n"
" %s "
#: ../vector/v.lrs/v.lrs.segment/main.c:268
@@ -22751,8 +21529,7 @@
"Requested offset for the 2. point not found, using nearest found:\n"
" %s"
msgstr ""
-"ã¾ãã:\n"
+"1. ã®è¦æ±ããããªãã»ããï¼ãã¤ã³ããè¦ã¤ããã¾ããï¼æå¯ãã®ãã¤ã³ããè¦ã¤ãã¾ãã:\n"
" %s "
#: ../vector/v.lrs/v.lrs.segment/main.c:277
@@ -22809,12 +21586,8 @@
msgstr "[%d] ã®ã©ã¤ã³ãåºåãããã«æ¸ãè¾¼ã (%d ãç´å¤±)"
#: ../vector/v.lrs/v.lrs.where/main.c:60
-msgid ""
-"Finds line id and real km+offset for given points in vector map using linear "
-"reference system."
-msgstr ""
-"ç·å½¢åç
§ç³»ã§ãã¯ãã«ãããä¸ã®æå®ããããã¤ã³ãã®ã©ã¤ã³IDã¨ãªãã»ãã(km)ã"
-"è¦ã¤ãã"
+msgid "Finds line id and real km+offset for given points in vector map using linear reference system."
+msgstr "ç·å½¢åç
§ç³»ã§ãã¯ãã«ãããä¸ã®æå®ããããã¤ã³ãã®ã©ã¤ã³IDã¨ãªãã»ãã(km)ãè¦ã¤ãã"
#: ../vector/v.lrs/v.lrs.where/main.c:69
msgid "Input vector map containing points"
@@ -22878,8 +21651,7 @@
msgstr "é£ã®ã»ã°ã¡ã³ãã®å§ç¹ã®ãã¤ã«æ¨ã®ãã¤ã³ããå«ãå"
#: ../vector/v.lrs/v.lrs.create/main.c:179
-msgid ""
-"Column containing offset from milepost for the beginning of next segment"
+msgid "Column containing offset from milepost for the beginning of next segment"
msgstr "é£ã®ã»ã°ã¡ã³ãã®å§ã¾ãã®ãã¤ã«æ¨ããã®ãªãã»ãããå«ãå"
#: ../vector/v.lrs/v.lrs.create/main.c:188
@@ -22986,8 +21758,7 @@
#: ../vector/v.lrs/v.lrs.create/main.c:762
#, c-format
msgid "Not enough points (%d) attached to the line (cat %d), line skip."
-msgstr ""
-"ã©ã¤ã³ (ã«ãã´ãªã¼ %d), ã©ã¤ã³ã¹ããã.ã«å ãããã¤ã³ã (%d) ãè¶³ãã¾ãã"
+msgstr "ã©ã¤ã³ (ã«ãã´ãªã¼ %d), ã©ã¤ã³ã¹ããã.ã«å ãããã¤ã³ã (%d) ãè¶³ãã¾ãã"
#: ../vector/v.lrs/v.lrs.create/main.c:767
#, c-format
@@ -23079,9 +21850,7 @@
#: ../vector/v.out.ascii/b2a.c:192
#, c-format
msgid "Feature has more categories. Only first category (%d) is exported."
-msgstr ""
-"ãã£ã¼ãã£ã¼ã¯ããå¤ãã®ã«ãã´ãªã¼ãæã£ã¦ãã¾ã. æåã®ã«ãã´ãªã¼ (%d) ã®ã¿"
-"ã¨ã¯ã¹ãã¼ãããã¦ãã¾ã. "
+msgstr "ãã£ã¼ãã£ã¼ã¯ããå¤ãã®ã«ãã´ãªã¼ãæã£ã¦ãã¾ã. æåã®ã«ãã´ãªã¼ (%d) ã®ã¿ã¨ã¯ã¹ãã¼ãããã¦ãã¾ã. "
#: ../vector/v.out.ascii/b2a.c:202
#, c-format
@@ -23209,11 +21978,8 @@
msgstr "ãããã®ã¡ã¿ãã¼ã¿ãã¡ã¤ã«ã®ã³ã¡ã³ãã©ã¤ã³ã«è¿½å ããããã¹ã"
#: ../vector/v.support/main.c:118
-msgid ""
-"Command line to store into vector map history file (used for vector scripts)"
-msgstr ""
-"ãã¯ãã«ãããã®å±¥æ´ãã¡ã¤ã«ã«æ®ãã³ãã³ãã©ã¤ã³ ï¼ãã¯ãã«ã¹ã¯ãªããã«ä½¿ç¨ã"
-"ããï¼"
+msgid "Command line to store into vector map history file (used for vector scripts)"
+msgstr "ãã¯ãã«ãããã®å±¥æ´ãã¡ã¤ã«ã«æ®ãã³ãã³ãã©ã¤ã³ ï¼ãã¯ãã«ã¹ã¯ãªããã«ä½¿ç¨ãããï¼"
#: ../vector/v.support/main.c:122
msgid "Replace comment instead of appending it"
@@ -23244,17 +22010,11 @@
#: ../vector/v.build/main.c:53
msgid "Build topology or dump topology or spatial index to stdout"
-msgstr ""
-"ãããã¸ã¼ã¾ãã¯ãã³ããããã¸ã¼ã¾ãã¯ç©ºéã¤ã³ããã¯ã¹ãstdoutã«ä½æãã¾ã "
+msgstr "ãããã¸ã¼ã¾ãã¯ãã³ããããã¸ã¼ã¾ãã¯ç©ºéã¤ã³ããã¯ã¹ãstdoutã«ä½æãã¾ã "
#: ../vector/v.build/main.c:55
-msgid ""
-"build;build topology;dump;write topology to stdout;sdump;write spatial index "
-"to stdout;cdump;write category index to stdout"
-msgstr ""
-"build;ãããã¸ã¼ã使;dump;æ¨æºåºåã¸ã®ã«ãããã¸ã¼ã®ãæ¸ãè¾¼ã¿;sdump;æ¨æºåº"
-"åã¸ã®ç©ºéã¤ã³ããã¯ã¹ã®æ¸ãè¾¼ã¿;cdump;æ¨æºåºåã¸ã®ã«ãã´ãªã¼ã¤ã³ããã¯ã¹ã®æ¸"
-"ãè¾¼ã¿"
+msgid "build;build topology;dump;write topology to stdout;sdump;write spatial index to stdout;cdump;write category index to stdout"
+msgstr "build;ãããã¸ã¼ã使;dump;æ¨æºåºåã¸ã®ã«ãããã¸ã¼ã®ãæ¸ãè¾¼ã¿;sdump;æ¨æºåºåã¸ã®ç©ºéã¤ã³ããã¯ã¹ã®æ¸ãè¾¼ã¿;cdump;æ¨æºåºåã¸ã®ã«ãã´ãªã¼ã¤ã³ããã¯ã¹ã®æ¸ãè¾¼ã¿"
#: ../vector/v.edit/args.c:38
msgid "Name of vector map to edit"
@@ -23265,33 +22025,8 @@
msgstr "ãã¼ã«"
#: ../vector/v.edit/args.c:55
-msgid ""
-"create;Create new (empty) vector map;add;Add new features to existing vector "
-"map;delete;Delete selected features from vector map;move;Move selected "
-"features in vector map;vertexmove;Move vertex of selected vector lines;"
-"vertexdel;Remove vertex from selected vector lines;vertexadd;Add new vertex "
-"to selected vector lines;merge;Merge selected vector lines;break;Break/split "
-"vector lines;select;Select lines and print their ID's;catadd;Set new "
-"categories to selected vector features for defined layer;catdel;Delete "
-"categories from selected vector features for defined layer;copy;Copy "
-"selected features;snap;Snap vector features in given threshold;flip;Flip "
-"direction of selected vector lines;connect;Connect two lines;zbulk;Z bulk-"
-"labeling (automated assignment of z coordinate to vector lines);chtype;"
-"Change feature type (point<->centroid, line<->boundary)"
-msgstr ""
-"createï¼æ°è¦ã«ï¼ä¸èº«ã®ãªãï¼ãã¯ãã«ãããã使ï¼addï¼ä»ãããã¯ãã«ãããã¸"
-"æ°è¦ã«ãã£ã¼ãã£ã¼ãå ããï¼deleteï¼ãã¯ãã«ããããã鏿ãããã£ã¼ãã£ã¼ã"
-"åé¤ï¼moveï¼ãã¯ãã«ãããä¸ã®é¸æãããã£ã¼ãã£ã¼ãç§»åï¼vertexmoveï¼é¸æã"
-"ããã¯ãã«ã©ã¤ã³ã®äº¤ç¹ãç§»åï¼vertexdelï¼é¸æãããã¯ãã«ã©ã¤ã³ãã交ç¹ãå"
-"é¤ï¼vertexaddï¼é¸æãããã¯ãã«ã©ã¤ã³ã¸æ°è¦ã«äº¤ç¹ã追å ï¼mergeï¼é¸æãããã¯"
-"ãã«ã©ã¤ã³ããã¼ã¸ï¼break;ãã¯ãã«ã©ã¤ã³ãåæ/åå²ï¼selectï¼ã©ã¤ã³ã鏿ãã"
-"ã®IDãåºåï¼cataddï¼æå®ããã¬ã¤ã¤ã¼ã®é¸æãããã¯ãã«ãã£ã¼ãã£ã¼ã«æ°è¦ã«ã"
-"ã´ãªã¼ãè¨å®ï¼catdelï¼æå®ããã¬ã¤ã¤ã¼ã®é¸æãããã¯ãã«ãã£ã¼ãã£ã¼ã®ã«ãã´"
-"ãªã¼ãåé¤ï¼copyï¼é¸æãããã£ã¼ãã£ã¼ãåé¤ï¼snapï¼æå®ããé¾å¤å
ã®ãã¯ãã«"
-"ãã£ã¼ãã£ã¼ãæ¥åï¼flipï¼é¸æãããã¯ãã«ã©ã¤ã³ã®æ¹åãåå²ï¼connectï¼2æ¬ã®"
-"ã©ã¤ã³ãç¹ããï¼zbulkï¼Z ãã«ã¯ã©ããªã³ã° ï¼ãã¯ãã«ã©ã¤ã³ã¸ z 座æ¨ãèªåè¨"
-"å®ï¼ï¼chtypeï¼ãã£ã¼ãã£ã¼ã¿ã¤ãã夿´ (ãã¤ã³ã <-> ã»ã³ããã¤ãï¼ã©ã¤ã³ <-"
-"> å¢ç) "
+msgid "create;Create new (empty) vector map;add;Add new features to existing vector map;delete;Delete selected features from vector map;move;Move selected features in vector map;vertexmove;Move vertex of selected vector lines;vertexdel;Remove vertex from selected vector lines;vertexadd;Add new vertex to selected vector lines;merge;Merge selected vector lines;break;Break/split vector lines;select;Select lines and print their ID's;catadd;Set new categories to selected vector features for defined layer;catdel;Delete categories from selected vector features for defined layer;copy;Copy selected features;snap;Snap vector features in given threshold;flip;Flip direction of selected vector lines;connect;Connect two lines;zbulk;Z bulk-labeling (automated assignment of z coordinate to vector lines);chtype;Change feature type (point<->centroid, line<->boundary)"
+msgstr "createï¼æ°è¦ã«ï¼ä¸èº«ã®ãªãï¼ãã¯ãã«ãããã使ï¼addï¼ä»ãããã¯ãã«ãããã¸æ°è¦ã«ãã£ã¼ãã£ã¼ãå ããï¼deleteï¼ãã¯ãã«ããããã鏿ãããã£ã¼ãã£ã¼ãåé¤ï¼moveï¼ãã¯ãã«ãããä¸ã®é¸æãããã£ã¼ãã£ã¼ãç§»åï¼vertexmoveï¼é¸æãããã¯ãã«ã©ã¤ã³ã®äº¤ç¹ãç§»åï¼vertexdelï¼é¸æãããã¯ãã«ã©ã¤ã³ãã交ç¹ãåé¤ï¼vertexaddï¼é¸æãããã¯ãã«ã©ã¤ã³ã¸æ°è¦ã«äº¤ç¹ã追å ï¼mergeï¼é¸æãããã¯ãã«ã©ã¤ã³ããã¼ã¸ï¼break;ãã¯ãã«ã©ã¤ã³ãåæ/åå²ï¼selectï¼ã©ã¤ã³ã鏿ããã®IDãåºåï¼cataddï¼æå®ããã¬ã¤ã¤ã¼ã®é¸æãããã¯ãã«ãã£ã¼ãã£ã¼ã«æ°è¦ã«ãã´ãªã¼ãè¨å®ï¼catdelï¼æå®ããã¬ã¤ã¤ã¼ã®é¸æãããã¯ãã«ãã£ã¼ãã£ã¼ã®ã«ãã´ãªã¼ãåé¤ï¼copyï¼é¸æãããã£ã¼ãã£ã¼ãåé¤ï¼snapï¼æå®ããé¾å¤å
ã®ãã¯ã
ã«ãã£ã¼ãã£ã¼ãæ¥åï¼flipï¼é¸æãããã¯ãã«ã©ã¤ã³ã®æ¹åãåå²ï¼connectï¼2æ¬ã®ã©ã¤ã³ãç¹ããï¼zbulkï¼Z ãã«ã¯ã©ããªã³ã° ï¼ãã¯ãã«ã©ã¤ã³ã¸ z 座æ¨ãèªåè¨å®ï¼ï¼chtypeï¼ãã£ã¼ãã£ã¼ã¿ã¤ãã夿´ (ãã¤ã³ã <-> ã»ã³ããã¤ãï¼ã©ã¤ã³ <-> å¢ç) "
#: ../vector/v.edit/args.c:100
msgid "ASCII file to be converted to binary vector map"
@@ -23334,31 +22069,20 @@
msgstr "çã' ã®æå®ã¯è² ã®é¾å¤ã使ç¨ãã¦ä¸ããï¼'é·ã'ã®æã¯æ£ã®é¾å¤ã§ã"
#: ../vector/v.edit/args.c:170
-msgid ""
-"length;Select only lines or boundaries shorter/longer than threshold "
-"distance;dangle;Select dangles shorter/longer than threshold distance"
-msgstr ""
-"lengthï¼è·é¢ã®é¾å¤ãããé·ã/çãã©ã¤ã³ãããã¯å¢çã ãã鏿ï¼dangleï¼è·é¢ã®"
-"é¾å¤ãããé·ã/çããã³ã°ã«ã鏿"
+msgid "length;Select only lines or boundaries shorter/longer than threshold distance;dangle;Select dangles shorter/longer than threshold distance"
+msgstr "lengthï¼è·é¢ã®é¾å¤ãããé·ã/çãã©ã¤ã³ãããã¯å¢çã ãã鏿ï¼dangleï¼è·é¢ã®é¾å¤ãããé·ã/çããã³ã°ã«ã鏿"
#: ../vector/v.edit/args.c:178
msgid "Name of background vector map(s)"
msgstr "èæ¯ã®ãã¯ãã«ãããå"
#: ../vector/v.edit/args.c:185
-msgid ""
-"Snap added or modified features in the given threshold to the nearest "
-"existing feature"
-msgstr ""
-"追å ã¾ãã¯ä¿®æ£ãããæå®ããé¾å¤å
ã®ãã£ã¼ãã£ã¼ã¨æãè¿ãã«ãããã£ã¼ãã£ã¼"
-"ãæ¥å"
+msgid "Snap added or modified features in the given threshold to the nearest existing feature"
+msgstr "追å ã¾ãã¯ä¿®æ£ãããæå®ããé¾å¤å
ã®ãã£ã¼ãã£ã¼ã¨æãè¿ãã«ãããã£ã¼ãã£ã¼ãæ¥å"
#: ../vector/v.edit/args.c:187
-msgid ""
-"no;Not apply snapping;node;Snap only to node;vertex;Allow snapping also to "
-"vertex"
-msgstr ""
-"noï¼æ¥åãè¡ããªãï¼nodeï¼ãã¼ãã¸ã®ã¿æ¥åï¼vertexï¼äº¤ç¹ã¸ã®æ¥åæ¥åã許å¯"
+msgid "no;Not apply snapping;node;Snap only to node;vertex;Allow snapping also to vertex"
+msgstr "noï¼æ¥åãè¡ããªãï¼nodeï¼ãã¼ãã¸ã®ã¿æ¥åï¼vertexï¼äº¤ç¹ã¸ã®æ¥åæ¥åã許å¯"
#: ../vector/v.edit/args.c:195
msgid "Starting value and step for z bulk-labeling"
@@ -23416,11 +22140,8 @@
msgstr "ãã¯ãã«ï¼ç·¨éï¼ã¸ãªã¡ããªã¼"
#: ../vector/v.edit/main.c:56
-msgid ""
-"Edits a vector map, allows adding, deleting and modifying selected vector "
-"features."
-msgstr ""
-"ãã¯ãã«ããããç·¨éï¼é¸æãããã¯ãã«ãã£ã¼ãã£ã¼ã®è¿½å ï¼åé¤ï¼ä¿®æ£ã許å¯"
+msgid "Edits a vector map, allows adding, deleting and modifying selected vector features."
+msgstr "ãã¯ãã«ããããç·¨éï¼é¸æãããã¯ãã«ãã£ã¼ãã£ã¼ã®è¿½å ï¼åé¤ï¼ä¿®æ£ã許å¯"
#: ../vector/v.edit/main.c:65
#, c-format
@@ -23443,12 +22164,8 @@
#: ../vector/v.edit/main.c:153
#, c-format
-msgid ""
-"Unable to open vector map <%s> as the background map. It is given as vector "
-"map to be edited."
-msgstr ""
-"ãã¯ãã«ããã <%s> ãèæ¯ãããã¨ãã¦éãã¾ããï¼ç·¨éããããã¯ãã«ãããã«"
-"æå®ããã¦ãã¾ã"
+msgid "Unable to open vector map <%s> as the background map. It is given as vector map to be edited."
+msgstr "ãã¯ãã«ããã <%s> ãèæ¯ãããã¨ãã¦éãã¾ããï¼ç·¨éããããã¯ãã«ãããã«æå®ããã¦ãã¾ã"
#: ../vector/v.edit/main.c:168
#, c-format
@@ -23465,12 +22182,8 @@
#: ../vector/v.edit/main.c:228
#, c-format
-msgid ""
-"Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert "
-"the vector map to 3D using e.g. %s."
-msgstr ""
-"ãã¯ãã«ããã <%s> 3D ã§ã¯ããã¾ããï¼ãã¼ã« '%s' 㯠3D ãã¯ãã«ããããè¦æ±"
-"ãã¦ãã¾ãï¼%s ã使ç¨ãã¦ï¼ãã¯ãã«ãããã 3D ã«å¤æãã¦ä¸ãã"
+msgid "Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert the vector map to 3D using e.g. %s."
+msgstr "ãã¯ãã«ããã <%s> 3D ã§ã¯ããã¾ããï¼ãã¼ã« '%s' 㯠3D ãã¯ãã«ããããè¦æ±ãã¦ãã¾ãï¼%s ã使ç¨ãã¦ï¼ãã¯ãã«ãããã 3D ã«å¤æãã¦ä¸ãã"
#: ../vector/v.edit/main.c:266
#, c-format
@@ -23536,12 +22249,8 @@
#: ../vector/v.edit/main.c:346
#, c-format
-msgid ""
-"Multiple background maps were given. Selected features will be copied only "
-"from vector map <%s>."
-msgstr ""
-"è¤æ°ã®èæ¯ããããä¸ãããã¾ããï¼é¸æããããã£ã¼ãã£ã¼ã¯ãã¯ãã«ããã <"
-"%s> ããã ãã³ãã¼ããã¾ã"
+msgid "Multiple background maps were given. Selected features will be copied only from vector map <%s>."
+msgstr "è¤æ°ã®èæ¯ããããä¸ãããã¾ããï¼é¸æããããã£ã¼ãã£ã¼ã¯ãã¯ãã«ããã <%s> ããã ãã³ãã¼ããã¾ã"
#: ../vector/v.edit/main.c:356
#, c-format
@@ -23633,9 +22342,7 @@
#: ../vector/v.in.dwg/main.c:84 ../vector/v.in.dxf/main.c:88
msgid "Invert selection by layers (don't import layers in list)"
-msgstr ""
-"ã¬ã¤ã¤ã¼ã«ãã£ã¦é¸æãå転ãã¾ã (ã¬ã¤ã¤ã¼ããªã¹ãã«ã¤ã³ãã¼ãããªãã§ä¸ã"
-"ã) "
+msgstr "ã¬ã¤ã¤ã¼ã«ãã£ã¦é¸æãå転ãã¾ã (ã¬ã¤ã¤ã¼ããªã¹ãã«ã¤ã³ãã¼ãããªãã§ä¸ãã) "
#: ../vector/v.in.dwg/main.c:88 ../vector/v.in.ascii/in.c:141
msgid "Create 3D vector map"
@@ -23948,12 +22655,8 @@
msgstr "ãã¼ãã«ã«è¨±å¯ãããã¾ãã\n"
#: ../vector/v.digit/c_face.c:312
-msgid ""
-"Cannot add database link to vector, link for given field probably already "
-"exists."
-msgstr ""
-"ãã¯ã¿ã¼ã«ãã¼ã¿ãã¼ã¹ã¸ã®ãªã³ã¯ãä»å ã§ãã¾ããã該å½é
ç®ã¸ã®ãªã³ã¯ã¯æ¢ã«å"
-"å¨ãã¦ããå¯è½æ§ãããã¾ãã"
+msgid "Cannot add database link to vector, link for given field probably already exists."
+msgstr "ãã¯ãã«ã«ãã¼ã¿ãã¼ã¹ã¸ã®ãªã³ã¯ãä»å ã§ãã¾ããã該å½é
ç®ã¸ã®ãªã³ã¯ã¯æ¢ã«åå¨ãã¦ããå¯è½æ§ãããã¾ãã"
#: ../vector/v.digit/attr.c:94
msgid "Cannot create new record."
@@ -24016,7 +22719,7 @@
#: ../vector/v.digit/attr.c:553
#, c-format
msgid "driver: %s<BR>database: %s<BR>table: %s<BR>key column: %s<BR>"
-msgstr ""
+msgstr "ãã©ã¤ã: %s<BR>ãã¼ã¿ãã¼ã¹: %s<BR>ãã¼ãã«: %s<BR>ãã¼é
ç®: %s<BR>"
#: ../vector/v.digit/attr.c:571
#, c-format
@@ -24029,12 +22732,8 @@
#: ../vector/v.digit/attr.c:668
#, c-format
-msgid ""
-"There are no more features with category %d (layer %d) in the map, but there "
-"is record in the table. Delete this record?"
-msgstr ""
-"ã«ãã´ãª%dï¼ã¬ã¤ã¤ã¼%dï¼ãå«ããã£ã¼ãã£ã¯ãã以ä¸ããã¾ãããããã¼ãã«ã«ã¬"
-"ã³ã¼ããããã¾ãããã®ã¬ã³ã¼ããåé¤ãã¾ããï¼"
+msgid "There are no more features with category %d (layer %d) in the map, but there is record in the table. Delete this record?"
+msgstr "ã«ãã´ãª%dï¼ã¬ã¤ã¤ã¼%dï¼ãå«ããã£ã¼ãã£ã¯ãã以ä¸ããã¾ãããããã¼ãã«ã«ã¬ã³ã¼ããããã¾ãããã®ã¬ã³ã¼ããåé¤ãã¾ããï¼"
#: ../vector/v.digit/attr.c:680
#, c-format
@@ -24065,11 +22764,8 @@
#: ../vector/v.digit/generate.c:110
#, c-format
-msgid ""
-"Cannot open select cursor:<BR>'%s'<BR>on database '%s' by driver '%s'<BR>"
-msgstr ""
-"鏿ã«ã¼ã½ã«ãéãã¾ãã:<BR>'%s'<BR>ãã¼ã¿ãã¼ã¹ä¸ã§ '%s' ãã©ã¤ãã«ãã£ã¦ "
-"'%s'<BR>"
+msgid "Cannot open select cursor:<BR>'%s'<BR>on database '%s' by driver '%s'<BR>"
+msgstr "鏿ã«ã¼ã½ã«ãéãã¾ãã:<BR>'%s'<BR>ãã¼ã¿ãã¼ã¹ä¸ã§ '%s' ãã©ã¤ãã«ãã£ã¦ '%s'<BR>"
#: ../vector/v.digit/generate.c:121
msgid "Cannot fetch next record"
@@ -24082,9 +22778,7 @@
#: ../vector/v.digit/generate.c:223
#, c-format
msgid "<HR> Assume data encoding as:<BR><BR><SELECT NAME=%s SIZE=4><HR><BR>"
-msgstr ""
-"<HR> ã¨ãã¦ãã¼ã¿ã¨ã³ã³ã¼ãã£ã³ã°ãæ³å®:<BR><BR><SELECT NAME=%s "
-"SIZE=4><HR><BR>"
+msgstr "<HR> ã¨ãã¦ãã¼ã¿ã¨ã³ã³ã¼ãã£ã³ã°ãæ³å®:<BR><BR><SELECT NAME=%s SIZE=4><HR><BR>"
#: ../vector/v.digit/main.c:104
msgid "vector, editing, digitization"
@@ -24104,11 +22798,8 @@
#: ../vector/v.digit/main.c:157
#, c-format
-msgid ""
-"Map <%s> does not exist in current mapset. Add flag -n to create a new map."
-msgstr ""
-"ããã <%s> ã¯ç¾å¨ã®ãããã»ããä¸ã«åå¨ãã¾ããï¼ -n ãã©ãã°ã追å ãã¦æ°è¦"
-"ã«ãããã使ãã¦ä¸ãã"
+msgid "Map <%s> does not exist in current mapset. Add flag -n to create a new map."
+msgstr "ããã <%s> ã¯ç¾å¨ã®ãããã»ããä¸ã«åå¨ãã¾ããï¼ -n ãã©ãã°ã追å ãã¦æ°è¦ã«ãããã使ãã¦ä¸ãã"
#: ../vector/v.digit/centre.c:56
msgid "Select tool"
@@ -24185,20 +22876,12 @@
msgstr "æè¿æ¥ã®ä¸å¿ã«ãµãããããå²ãå½ã¦ã¾ã (ä¸å¿ããã¿ã¦). "
#: ../vector/v.net.alloc/main.c:65
-msgid ""
-"Centre node must be opened (costs >= 0). Costs of centre node are used in "
-"calculation"
-msgstr ""
-"ä¸å¿ãã¼ãã¯éãããªããã°ãªãã¾ãã (ã³ã¹ã >= 0). ä¸å¿ãã¼ãã®ã³ã¹ãã¯è¨ç®"
-"ã«ä½¿ç¨ããã¦ãã¾ã "
+msgid "Centre node must be opened (costs >= 0). Costs of centre node are used in calculation"
+msgstr "ä¸å¿ãã¼ãã¯éãããªããã°ãªãã¾ãã (ã³ã¹ã >= 0). ä¸å¿ãã¼ãã®ã³ã¹ãã¯è¨ç®ã«ä½¿ç¨ããã¦ãã¾ã "
#: ../vector/v.net.alloc/main.c:110
-msgid ""
-"Categories of centres (points on nodes) to which net will be allocated, "
-"layer for this categories is given by nlayer option"
-msgstr ""
-"ããããå²ãå½ã¦ãããä¸å¿ã®ã«ãã´ãªã¼ (ãã¼ãä¸ã®ãã¤ã³ã), ãã®ã«ãã´ãªã¼ã®"
-"ã¬ã¤ã¤ã¼ã¯ nlayer ãªãã·ã§ã³ã«ãã£ã¦ä¸ãããã¦ãã¾ã"
+msgid "Categories of centres (points on nodes) to which net will be allocated, layer for this categories is given by nlayer option"
+msgstr "ããããå²ãå½ã¦ãããä¸å¿ã®ã«ãã´ãªã¼ (ãã¼ãä¸ã®ãã¤ã³ã), ãã®ã«ãã´ãªã¼ã®ã¬ã¤ã¤ã¼ã¯ nlayer ãªãã·ã§ã³ã«ãã£ã¦ä¸ãããã¦ãã¾ã"
#: ../vector/v.net.alloc/main.c:186
#, c-format
@@ -24245,12 +22928,8 @@
msgstr "ãã¯ãã«ãæ½åº"
#: ../vector/v.extract/main.c:93
-msgid ""
-"Selects vector objects from an existing vector map and creates a new map "
-"containing only the selected objects."
-msgstr ""
-"åå¨ãããã¯ãã«ããããããã¯ãã«ãªãã¸ã§ã¯ãã鏿ãã鏿ããããªãã¸ã§ã¯"
-"ãã®ã¿ãå«ãæ°ãããããã使ãã¦ãã ãã"
+msgid "Selects vector objects from an existing vector map and creates a new map containing only the selected objects."
+msgstr "åå¨ãããã¯ãã«ããããããã¯ãã«ãªãã¸ã§ã¯ãã鏿ãã鏿ããããªãã¸ã§ã¯ãã®ã¿ãå«ãæ°ãããããã使ãã¦ãã ãã"
#: ../vector/v.extract/main.c:98
msgid "Dissolve common boundaries (default is no)"
@@ -24265,11 +22944,8 @@
msgstr "æ½åºãããã¿ã¤ã"
#: ../vector/v.extract/main.c:122
-msgid ""
-"Layer number (if -1, all features in all layers of given type are extracted)"
-msgstr ""
-"ã¬ã¤ã¤ã¼æ° (if -1, ä¸ããããåã®å
¨ã¦ã®ã¬ã¤ã¤ã¼ã®å
¨ã¦ã®ãã£ã¼ãã£ã¼ã¯æ½åºãã"
-"ã¦ãã¾ã) "
+msgid "Layer number (if -1, all features in all layers of given type are extracted)"
+msgstr "ã¬ã¤ã¤ã¼æ° (if -1, ä¸ããããåã®å
¨ã¦ã®ã¬ã¤ã¤ã¼ã®å
¨ã¦ã®ãã£ã¼ãã£ã¼ã¯æ½åºããã¦ãã¾ã) "
#: ../vector/v.extract/main.c:136
msgid "Input text file with category numbers/number ranges to be extracted"
@@ -24289,21 +22965,15 @@
#: ../vector/v.extract/main.c:156
msgid "Enter -1 to keep original categories or the desired NEW category value"
-msgstr ""
-"æåã®ã«ãã´ãªã¼ã¾ãã¯æå®ããæ°ããã«ãã´ãªã¼å¤ã®ä¿åã«ã¯ -1 ãå
¥åãã¦ãã "
-"ãã "
+msgstr "æåã®ã«ãã´ãªã¼ã¾ãã¯æå®ããæ°ããã«ãã´ãªã¼å¤ã®ä¿åã«ã¯ -1 ãå
¥åãã¦ãã ãã "
#: ../vector/v.extract/main.c:157
msgid "If new >= 0, table is not copied"
msgstr "æ°ãã >= 0 ã®å ´å, ãã¼ãã«ã¯ã³ãã¼ããã¦ãã¾ãã"
#: ../vector/v.extract/main.c:175
-msgid ""
-"List, file, where and random options are exclusive. Please specify only one "
-"of them"
-msgstr ""
-"ãªã¹ã, ãã¡ã¤ã«, å ´æããã¦ã©ã³ãã ãªãã·ã§ã³ã¯æä»çã§ã. ã©ã¡ããä¸ã¤ãæ"
-"å®ãã¦ãã ãã"
+msgid "List, file, where and random options are exclusive. Please specify only one of them"
+msgstr "ãªã¹ã, ãã¡ã¤ã«, å ´æããã¦ã©ã³ãã ãªãã·ã§ã³ã¯æä»çã§ã. ã©ã¡ããä¸ã¤ãæå®ãã¦ãã ãã"
#: ../vector/v.extract/main.c:204 ../vector/v.drape/main.c:220
msgid "Layer 0 not supported"
@@ -24340,12 +23010,8 @@
msgstr "ã«ãã´ãªã¼ %d ããã¼ãã« <%s> ãããã¼ãããã¾ãã"
#: ../vector/v.extract/main.c:313
-msgid ""
-"This map has no categories attached. Use v.category to attach categories to "
-"this vector map."
-msgstr ""
-"ãã®ãããã«ä»å±ããã«ãã´ãªã¼ã¯ããã¾ãã. ãã®ãã¯ãã«ãããã«ã«ãã´ãªã¼ã"
-"å ããã«ã¯ v.category ã使ç¨ãã¦ãã ãã "
+msgid "This map has no categories attached. Use v.category to attach categories to this vector map."
+msgstr "ãã®ãããã«ä»å±ããã«ãã´ãªã¼ã¯ããã¾ãã. ãã®ãã¯ãã«ãããã«ã«ãã´ãªã¼ãå ããã«ã¯ v.category ã使ç¨ãã¦ãã ãã "
#: ../vector/v.extract/main.c:319
msgid "Please specify random number larger than 0"
@@ -24353,21 +23019,13 @@
#: ../vector/v.extract/main.c:323
#, c-format
-msgid ""
-"Random category count must be smaller than feature count. There are only %d "
-"features of type(s): %s"
-msgstr ""
-"ã©ã³ãã ã«ãã´ãªã¼æ°ã¯ãã£ã¼ãã£ã¼æ°ããå°ãããªããã°ãªãã¾ãã.ã%d ã¿ã¤ã"
-"ã®ãã£ã¼ãã£ã¼ããããã«ããã¾ã: %s "
+msgid "Random category count must be smaller than feature count. There are only %d features of type(s): %s"
+msgstr "ã©ã³ãã ã«ãã´ãªã¼æ°ã¯ãã£ã¼ãã£ã¼æ°ããå°ãããªããã°ãªãã¾ãã.ã%d ã¿ã¤ãã®ãã£ã¼ãã£ã¼ããããã«ããã¾ã: %s "
#: ../vector/v.extract/main.c:346
#, c-format
-msgid ""
-"Random category count is larger or equal to uniq \"%s\" feature category "
-"count %d"
-msgstr ""
-"ã©ã³ãã ã«ãã´ãªã¼æ°ã¯ ã¦ãã¼ã¯ \"%s\" ãã£ã¼ãã£ã«ãã´ãªã¼æ° %d ãã大ããã¾"
-"ãã¯çãã"
+msgid "Random category count is larger or equal to uniq \"%s\" feature category count %d"
+msgstr "ã©ã³ãã ã«ãã´ãªã¼æ°ã¯ ã¦ãã¼ã¯ \"%s\" ãã£ã¼ãã£ã«ãã´ãªã¼æ° %d ãã大ããã¾ãã¯çãã"
#: ../vector/v.extract/main.c:383
msgid "Extracting features..."
@@ -24426,8 +23084,7 @@
#: ../vector/v.db.connect/main.c:93
msgid "Format: layer[/layer name] table key database driver"
-msgstr ""
-"ãã©ã¼ãããï¼ ã¬ã¤ã¤ã¼[/ã¬ã¤ã¤ã¼å]ããã¼ãã«ããã¼ããã¼ã¿ãã¼ã¹ ãã©ã¤ãã¼"
+msgstr "ãã©ã¼ãããï¼ ã¬ã¤ã¤ã¼[/ã¬ã¤ã¤ã¼å]ããã¼ãã«ããã¼ããã¼ã¿ãã¼ã¹ ãã©ã¤ãã¼"
#: ../vector/v.db.connect/main.c:103
msgid "When printing, limit to layer specified by the layer option"
@@ -24461,11 +23118,8 @@
#: ../vector/v.db.connect/main.c:198
#, c-format
-msgid ""
-"layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
-msgstr ""
-"ã¬ã¤ã¤ã¼ <%d> ãã¼ãã« <%s> ã¯ãã¼ã¿ãã¼ã¹ <%s> ãããã©ã¤ãã¼ <%s> ã«key <"
-"%s> ã¨ä¸ç·ã«\n"
+msgid "layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
+msgstr "ã¬ã¤ã¤ã¼ <%d> ãã¼ãã« <%s> ã¯ãã¼ã¿ãã¼ã¹ <%s> ãããã©ã¤ãã¼ <%s> ã«key <%s> ã¨ä¸ç·ã«\n"
#: ../vector/v.db.connect/main.c:261
#, c-format
@@ -24489,24 +23143,16 @@
#: ../vector/v.db.connect/main.c:297 ../vector/v.db.connect/main.c:315
#, c-format
-msgid ""
-"The table <%s> is now part of vector map <%s> and may be deleted or "
-"overwritten by GRASS modules"
-msgstr ""
-"ãã¼ãã« <%s> ã¯ãã¯ãã«ããã <%s> ã®ä¸é¨ã§ããï¼GRASS ã¢ã¸ã¥ã¼ã«ã«ãã£ã¦å"
-"é¤ã¾ãã¯ä¸æ¸ãããã¾ã"
+msgid "The table <%s> is now part of vector map <%s> and may be deleted or overwritten by GRASS modules"
+msgstr "ãã¼ãã« <%s> ã¯ãã¯ãã«ããã <%s> ã®ä¸é¨ã§ããï¼GRASS ã¢ã¸ã¥ã¼ã«ã«ãã£ã¦åé¤ã¾ãã¯ä¸æ¸ãããã¾ã"
#: ../vector/v.db.connect/main.c:339
msgid "Select privileges were granted on the table"
msgstr "ãã¼ãã«ã«è¨±å¯ãä¸ãããã¾ãã"
#: ../vector/v.db.connect/main.c:346
-msgid ""
-"For defining a new connection you have to specify these parameters: driver, "
-"database, table [, key [, layer]]"
-msgstr ""
-"æ°ããæ¥ç¶ãå®ç¾©ããããï¼æ¬¡ã®ãã©ã¡ã¼ã¿ã¼ãå®ç¾©ããå¿
è¦ãããã¾ãï¼ãã©ã¤"
-"ãã¼ï¼ãã¼ã¿ãã¼ã¹ï¼ãã¼ãã« [, key [, layer]] "
+msgid "For defining a new connection you have to specify these parameters: driver, database, table [, key [, layer]]"
+msgstr "æ°ããæ¥ç¶ãå®ç¾©ããããï¼æ¬¡ã®ãã©ã¡ã¼ã¿ã¼ãå®ç¾©ããå¿
è¦ãããã¾ãï¼ãã©ã¤ãã¼ï¼ãã¼ã¿ãã¼ã¹ï¼ãã¼ãã« [, key [, layer]] "
#: ../vector/v.delaunay2/main.c:141
msgid "no points to triangulate"
@@ -24545,8 +23191,7 @@
#: ../vector/v.in.ascii/in.c:50
msgid "Creates a vector map from ASCII points file or ASCII vector file."
-msgstr ""
-"ASCII ãã¤ã³ããã¡ã¤ã«ã¾ãã¯ASCII ãã¯ãã«ãã¡ã¤ã«ããï¼ãã¯ãã«ãããã使"
+msgstr "ASCII ãã¤ã³ããã¡ã¤ã«ã¾ãã¯ASCII ãã¯ãã«ãã¡ã¤ã«ããï¼ãã¯ãã«ãããã使"
#: ../vector/v.in.ascii/in.c:56
msgid "ASCII file to be imported, if not given reads from standard input"
@@ -24554,8 +23199,7 @@
#: ../vector/v.in.ascii/in.c:67
msgid "point;simple x,y[,z] list;standard;GRASS vector ASCII format"
-msgstr ""
-"pointï¼åã« x,y [,z] ãªã¹ãï¼standardï¼GRASSã®ãã¯ãã«ASCIIãã©ã¼ããã"
+msgstr "pointï¼åã« x,y [,z] ãªã¹ãï¼standardï¼GRASSã®ãã¯ãã«ASCIIãã©ã¼ããã"
#: ../vector/v.in.ascii/in.c:70
msgid "Input file format"
@@ -24575,9 +23219,7 @@
msgstr "SQLã¹ã¿ã¤ã«ã§ã®åã®å®ç¾©ï¼ãã¤ã³ãã¢ã¼ãï¼"
#: ../vector/v.in.ascii/in.c:93
-msgid ""
-"For example: 'x double precision, y double precision, cat int, name varchar"
-"(10)'"
+msgid "For example: 'x double precision, y double precision, cat int, name varchar(10)'"
msgstr "ä¾ï¼'x å精度ï¼y å精度ï¼cat æ´æ°ï¼åå varchar(10)'"
#: ../vector/v.in.ascii/in.c:105 ../vector/v.in.ascii/in.c:115
@@ -24601,11 +23243,8 @@
msgstr "ãã¤ã³ãã¢ã¼ãã§ã«ãã´ãªã¼ã«ä½¿ãåã®æ°ï¼æåã®åã¯1ï¼"
#: ../vector/v.in.ascii/in.c:137
-msgid ""
-"First column is 1. If 0, unique category is assigned to each row and written "
-"to new column 'cat'"
-msgstr ""
-"0ã®å ´åï¼åè¡ã«1ã¤ã ãã®ã«ãã´ãªã¼ãæå®ããã¦æ°è¦ã«ãcatãåãæ¸ãè¾¼ã¾ãã¾ã"
+msgid "First column is 1. If 0, unique category is assigned to each row and written to new column 'cat'"
+msgstr "0ã®å ´åï¼åè¡ã«1ã¤ã ãã®ã«ãã´ãªã¼ãæå®ããã¦æ°è¦ã«ãcatãåãæ¸ãè¾¼ã¾ãã¾ã"
#: ../vector/v.in.ascii/in.c:146
msgid "Create a new empty vector map and exit. Nothing is read from input."
@@ -24671,17 +23310,12 @@
"ï¼ä¸æ£ãªãã£ã¼ã«ãã»ãã¬ã¼ã¿ã¼ï¼ï¼"
#: ../vector/v.in.ascii/in.c:271
-msgid ""
-"z column number > minimum last column number (incorrect field separator?)"
-msgstr ""
-"z ã®åçªå· > æå¾ã«ä½¿ç¨ããæå°ã®åçªå·ï¼ä¸æ£ãªãã£ã¼ã«ãã»ãã¬ã¼ã¿ã¼ï¼ï¼"
+msgid "z column number > minimum last column number (incorrect field separator?)"
+msgstr "z ã®åçªå· > æå¾ã«ä½¿ç¨ããæå°ã®åçªå·ï¼ä¸æ£ãªãã£ã¼ã«ãã»ãã¬ã¼ã¿ã¼ï¼ï¼"
#: ../vector/v.in.ascii/in.c:276
-msgid ""
-"cat column number > minimum last column number (incorrect field separator?)"
-msgstr ""
-"ã«ãã´ãªã¼ã®åçªå· > æå¾ã«ä½¿ç¨ããæå°ã®åçªå·ï¼ä¸æ£ãªãã£ã¼ã«ãã»ãã¬ã¼"
-"ã¿ã¼ï¼ï¼"
+msgid "cat column number > minimum last column number (incorrect field separator?)"
+msgstr "ã«ãã´ãªã¼ã®åçªå· > æå¾ã«ä½¿ç¨ããæå°ã®åçªå·ï¼ä¸æ£ãªãã£ã¼ã«ãã»ãã¬ã¼ã¿ã¼ï¼ï¼"
#: ../vector/v.in.ascii/in.c:282
msgid "x column is not of number type"
@@ -24705,8 +23339,7 @@
#: ../vector/v.in.ascii/in.c:417
#, c-format
-msgid ""
-"Number of columns defined (%d) does not match number of columns (%d) in input"
+msgid "Number of columns defined (%d) does not match number of columns (%d) in input"
msgstr "å®ç¾©ããåã®æ°ï¼%dï¼ãå
¥åããåã®æ°ï¼%dï¼ã¨ä¸è´ãã¦ãã¾ãã"
#: ../vector/v.in.ascii/in.c:445
@@ -24749,11 +23382,8 @@
msgstr "ãã¼ãã«ã追å ãã¦ãã¾ãããã"
#: ../vector/v.in.ascii/in.c:530
-msgid ""
-"Could not close attribute table. The DBMI driver did not accept all "
-"attributes"
-msgstr ""
-"屿§ãã¼ãã«ãéãããã¾ããï¼DBMIãã©ã¤ãã¼ãä¸é¨ã®å±æ§ã許å¯ãã¾ããã§ãã"
+msgid "Could not close attribute table. The DBMI driver did not accept all attributes"
+msgstr "屿§ãã¼ãã«ãéãããã¾ããï¼DBMIãã©ã¤ãã¼ãä¸é¨ã®å±æ§ã許å¯ãã¾ããã§ãã"
#: ../vector/v.in.ascii/head.c:22
#, c-format
@@ -24857,12 +23487,8 @@
msgstr "ãµã³ããªã³ã°ããã©ã¹ã¿ã¼ããã"
#: ../vector/v.sample/main.c:113
-msgid ""
-"Option scaling factor for values read from raster map. Sampled values will "
-"be multiplied by this factor"
-msgstr ""
-"ã©ã¹ã¿ã¼ãããããèªã¿è¾¼ãã å¤ã®ãªãã·ã§ã³åç. ãµã³ãã«å¤ã¯ãã®åçã«ãã£ã¦"
-"æãããã¾ã "
+msgid "Option scaling factor for values read from raster map. Sampled values will be multiplied by this factor"
+msgstr "ã©ã¹ã¿ã¼ãããããèªã¿è¾¼ãã å¤ã®ãªãã·ã§ã³åç. ãµã³ãã«å¤ã¯ãã®åçã«ãã£ã¦æãããã¾ã "
#: ../vector/v.sample/main.c:119
msgid "Bilinear interpolation (default is nearest neighbor)"
@@ -24879,8 +23505,7 @@
#: ../vector/v.sample/main.c:181
#, c-format
msgid "Column type <%s> not supported (must be integer or double precision)"
-msgstr ""
-"åå <%s> ã¯ãµãã¼ãããã¦ãã¾ãã (æ´æ°åã¾ãã¯å精度ã§ãªããã°ãªãã¾ãã) "
+msgstr "åå <%s> ã¯ãµãã¼ãããã¦ãã¾ãã (æ´æ°åã¾ãã¯å精度ã§ãªããã°ãªãã¾ãã) "
#: ../vector/v.sample/main.c:187 ../vector/v.normal/main.c:155
#: ../vector/v.surf.idw/read_sites.c:54
@@ -24898,12 +23523,8 @@
msgstr "ãã¯ãã«ãã¤ã³ãã確èªãã¦ãã¾ã... "
#: ../vector/v.distance/main.c:116
-msgid ""
-"Finds the nearest element in vector map 'to' for elements in vector map "
-"'from'."
-msgstr ""
-"ãã¯ãã«ããã 'from'ã«ãããè¦ç´ ã®ããã«ãã¯ãã«ããã 'to' ã«ãããæè¿æ¥ã®"
-"è¦ç´ ãæ¢ãåºãã¾ã."
+msgid "Finds the nearest element in vector map 'to' for elements in vector map 'from'."
+msgstr "ãã¯ãã«ããã 'from'ã«ãããè¦ç´ ã®ããã«ãã¯ãã«ããã 'to' ã«ãããæè¿æ¥ã®è¦ç´ ãæ¢ãåºãã¾ã."
#: ../vector/v.distance/main.c:120
msgid "Name of existing vector map (from)"
@@ -24946,28 +23567,11 @@
msgstr "2ã¤ã®æè¿æ¥ã®ãã£ã¼ãã£ã¼éã®é¢ä¿ãè¨è¿°ããå¤"
#: ../vector/v.distance/main.c:181
-#, fuzzy
-msgid ""
-"cat;category of the nearest feature;dist;minimum distance to nearest feature;"
-"to_x;x coordinate of the nearest point on the 'to' feature;to_y;y coordinate "
-"of the nearest point on the 'to' feature;to_along;distance to the nearest "
-"point on the 'to' feature along that linear feature;to_angle;angle along the "
-"nearest linear feature in the 'to' map, measured CCW from the +x axis, in "
-"radians, between -Pi and Pi inclusive;to_attr;attribute of nearest feature "
-"given by to_column option"
-msgstr ""
-"cat;æè¿æ¥ãã£ã¼ãã£ã¼ã®ã«ãã´ãªã¼;dist;æè¿æ¥ãã£ã¼ãã£ã¼ã¸ã®æçè·é¢;"
-"to_x;'to' ãã£ã¼ãã£ã¼ã«ãããæè¿æ¥ãã¤ã³ãã®;x 座æ¨;to_y;'to' ãã£ã¼ãã£ã¼"
-"ã«ãããæè¿æ¥ãã¤ã³ãã®y 座æ¨;to_along; 'from' ãããã«ããããã¤ã³ã/ã»ã³ã"
-"ãã¤ãéã®è·é¢ã¨'to'ãããã«ãããç·å½¢ãã£ã¼ãã£ã¼ã®éå§ç¹, along this "
-"linear feature;to_angle;angle between the linear feature in 'to' ãããã¨æ£ã®"
-"x軸ã®éã®è§åº¦, 'from' ããã, åæè¨å¨ã, ã©ã¸ã¢ã³, -PI 㨠PIã®éã«ãããã¤ã³"
-"ã/ã»ã³ããã¤ãã®ãã±ã¼ã·ã§ã³ã«ããã'to' ãããã¨æ£ã®x軸ã®éã®è§åº¦;to_attr;"
-"to_column ãªãã·ã§ã³ã«ãã£ã¦ä¸ãããã¦ããæè¿æ¥ãã£ã¼ãã£ã¼ã®å±æ§"
+msgid "cat;category of the nearest feature;dist;minimum distance to nearest feature;to_x;x coordinate of the nearest point on the 'to' feature;to_y;y coordinate of the nearest point on the 'to' feature;to_along;distance to the nearest point on the 'to' feature along that linear feature;to_angle;angle along the nearest linear feature in the 'to' map, measured CCW from the +x axis, in radians, between -Pi and Pi inclusive;to_attr;attribute of nearest feature given by to_column option"
+msgstr "cat;æè¿æ¥ãã£ã¼ãã£ã¼ã®ã«ãã´ãªã¼;dist;æè¿æ¥ãã£ã¼ãã£ã¼ã¸ã®æçè·é¢;to_x;'to' ãã£ã¼ãã£ã¼ã«ãããæè¿æ¥ãã¤ã³ãã®x 座æ¨;to_y;'to' ãã£ã¼ãã£ã¼ã«ãããæè¿æ¥ãã¤ã³ãã®y 座æ¨;to_along;'to' ãã£ã¼ãã£ã¼ã«ãããæè¿æ¥ãã¤ã³ãã¸ã®ç·å½¢ãã£ã¼ãã£ã¼ã«æ²¿ã£ãè·é¢;o_angle;'to' ãã£ã¼ãã£ã¼ã«ãããæè¿æ¥ã®ç·å½¢ãã£ã¼ãã£ã¼ã«æ²¿ã£ãè§åº¦ãX軸ãã©ã¹æ¹åãåºç¹ã«åæè¨åãã«-ÏããÏã®éã®ã©ã¸ã¢ã³å¤;to_attr;to_column ãªãã·ã§ã³ã«ãã£ã¦ä¸ãããã¦ããæè¿æ¥ãã£ã¼ãã£ã¼ã®å±æ§"
#: ../vector/v.distance/main.c:202
-msgid ""
-"Column name(s) where values specified by 'upload' option will be uploaded"
+msgid "Column name(s) where values specified by 'upload' option will be uploaded"
msgstr "upload'ãªãã·ã§ã³ã«ãã£ã¦æå®ãããå¤ãã¢ãããã¼ããããã§ãããåå "
#: ../vector/v.distance/main.c:203
@@ -24980,8 +23584,7 @@
#: ../vector/v.distance/main.c:214
msgid "Name of table created for output when the distance to all flag is used"
-msgstr ""
-"å
¨ã¦ã®ãã©ãã°ã¸ã®è·é¢ã使ç¨ããã¦ããã¨ãã®ã¢ã¦ããããã®ãã使ããã表å"
+msgstr "å
#: ../vector/v.distance/main.c:219
msgid "Print output to stdout, don't update attribute table"
@@ -24989,22 +23592,15 @@
#: ../vector/v.distance/main.c:221
msgid "First column is always category of 'from' feature called from_cat"
-msgstr ""
-"æåã®åã¯ãã¤ã from_cat ã¨ãã°ãã 'from' ãã£ã¼ãã£ã¼ã®ã«ãã´ãªã¼ã§ã "
+msgstr "æåã®åã¯ãã¤ã from_cat ã¨ãã°ãã 'from' ãã£ã¼ãã£ã¼ã®ã«ãã´ãªã¼ã§ã "
#: ../vector/v.distance/main.c:226
msgid "Calculate distances to all features within the threshold"
msgstr "é¾å¤å
ã®ãã¹ã¦ã®ãã£ã¼ãã£ã¼ã¸ã®è·é¢ãè¨ç®ãã¾ã"
#: ../vector/v.distance/main.c:228
-#, fuzzy
-msgid ""
-"Output is written to stdout but may be uploaded to a new table created by "
-"this module; multiple 'upload' options may be used."
-msgstr ""
-"åºåã¯stdoutã«æ¸ãè¾¼ã¾ãã¾ããããã®ã¢ã¸ã¥ã¼ã«ã«ãã£ã¦ä½æãããæ°ãã表ã«"
-"ã¢ãããã¼ããããå¯è½æ§ãããã¾ã. Fromã«ãã´ãªã¼ã¯éè¤ãã¦ããããããã¾ã"
-"ã. "
+msgid "Output is written to stdout but may be uploaded to a new table created by this module; multiple 'upload' options may be used."
+msgstr "åºåã¯stdoutã«æ¸ãè¾¼ã¾ãã¾ããããã®ã¢ã¸ã¥ã¼ã«ã«ãã£ã¦ä½æãããæ°ãã表ã«ã¢ãããã¼ããããå¯è½æ§ãããã¾ã. è¤æ°ã®ã¢ãããã¼ããªãã·ã§ã³ã使ããã¦ããããããã¾ãã. "
#: ../vector/v.distance/main.c:280
msgid "to_column option missing"
@@ -25021,8 +23617,7 @@
#: ../vector/v.distance/main.c:306
#, c-format
msgid "Vector map <%s> is not in user mapset and cannot be updated"
-msgstr ""
-"ãã¯ãã«ããã <%s> ã¯ã¦ã¼ã¶ã¼ãããã»ããã«ãªãããã¢ãããã¼ãã§ãã¾ãã"
+msgstr "ãã¯ãã«ããã <%s> ã¯ã¦ã¼ã¶ã¼ãããã»ããã«ãªãããã¢ãããã¼ãã§ãã¾ãã"
#: ../vector/v.distance/main.c:387
msgid "Unable to open default database"
@@ -25047,14 +23642,12 @@
#: ../vector/v.distance/main.c:859
msgid "DATETIME type not yet supported, no attributes will be uploaded"
-msgstr ""
-"DATETIMEåã¯ã¾ã ãµãã¼ãããã¦ãã¾ãããã¢ãããã¼ãããã屿§ã¯ããã¾ãã"
+msgstr "DATETIMEåã¯ã¾ã ãµãã¼ãããã¦ãã¾ãããã¢ãããã¼ãããã屿§ã¯ããã¾ãã"
#: ../vector/v.distance/main.c:1108
#, c-format
msgid "%d categories with more than 1 feature in vector map <%s>"
-msgstr ""
-"ä¸ã¤ä»¥ä¸ã®ãã£ã¼ãã£ã¼ãæã¤ã«ãã´ãªã¼ %d (ãã¯ãã«ããã <%s> ã«ããã¦)"
+msgstr "ä¸ã¤ä»¥ä¸ã®ãã£ã¼ãã£ã¼ãæã¤ã«ãã´ãªã¼ %d (ãã¯ãã«ããã <%s> ã«ããã¦)"
#: ../vector/v.distance/main.c:1111
#, c-format
@@ -25089,9 +23682,7 @@
#: ../vector/v.distance/main.c:1131
#, c-format
msgid "%d categories read from the map exist in the table"
-msgstr ""
-"表ã«åå¨ãããããããèªã¿è¾¼ãã ã«ãã´ãªã¼%d categories read from the map "
-"exist in the table"
+msgstr "表ã«åå¨ãããããããèªã¿è¾¼ãã ã«ãã´ãªã¼%d categories read from the map exist in the table"
#: ../vector/v.distance/main.c:1134
#, c-format
@@ -25117,9 +23708,7 @@
#: ../vector/v.to.db/update.c:28 ../vector/v.to.db/update.c:32
#, c-format
msgid "Database connection not defined for layer %d. Use v.db.connect first."
-msgstr ""
-"ã¬ã¤ã¤ã¼ %d ã«å®ç¾©ããã¦ããªããã¼ã¿ãã¼ã¹æ¥ç¶. åãã« v.db.æ¥ç¶ã使ç¨ãã¦ã"
-"ã ãã."
+msgstr "ã¬ã¤ã¤ã¼ %d ã«å®ç¾©ããã¦ããªããã¼ã¿ãã¼ã¹æ¥ç¶. åãã« v.db.æ¥ç¶ã使ç¨ãã¦ãã ãã."
#: ../vector/v.to.db/query.c:93
msgid "Querying database... "
@@ -25127,12 +23716,8 @@
#: ../vector/v.to.db/query.c:108
#, c-format
-msgid ""
-"Query for category '0' (no category) was not executed because of too many "
-"(%d) query categories. All later reported values for cat 0 are not valid."
-msgstr ""
-"ã¯ã¨ãªã«ãã´ãªã¼ãå¤ããããã (%d) ã¯ã¨ãªã«ãã´ãªã¼ '0' (ã«ãã´ãªã¼ãªã) ã®"
-"ã¯ã¨ãªã¯å®è¡ããã¾ããã§ãã. å¾ã«å ±åããã cat 0 ã®å¤ã¯å
¨ã¦ä¸æ£ã§ã. "
+msgid "Query for category '0' (no category) was not executed because of too many (%d) query categories. All later reported values for cat 0 are not valid."
+msgstr "ã¯ã¨ãªã«ãã´ãªã¼ãå¤ããããã (%d) ã¯ã¨ãªã«ãã´ãªã¼ '0' (ã«ãã´ãªã¼ãªã) ã®ã¯ã¨ãªã¯å®è¡ããã¾ããã§ãã. å¾ã«å ±åããã cat 0 ã®å¤ã¯å
¨ã¦ä¸æ£ã§ã. "
#: ../vector/v.to.db/query.c:145
#, c-format
@@ -25188,10 +23773,8 @@
msgstr "ã¢ãããã¼ãããå¤"
#: ../vector/v.to.db/parse.c:87
-msgid ""
-"mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d(egrees)"
-msgstr ""
-"ãã¤ã«ããã£ã¼ããã¡ã¼ãã«ãããã¡ã¼ãã«ãã¨ã¼ã«ã¼ããã¯ã¿ã¼ã«ããã¼ã»ã³ã"
+msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d(egrees)"
+msgstr "ãã¤ã«ããã£ã¼ããã¡ã¼ãã«ãããã¡ã¼ãã«ãã¨ã¼ã«ã¼ããã¯ã¿ã¼ã«ããã¼ã»ã³ã"
#: ../vector/v.to.db/parse.c:93
msgid "Name of attribute column used for 'query' option"
@@ -25297,9 +23880,7 @@
msgstr "横"
#: ../vector/v.parallel2/main.c:84
-msgid ""
-"left;Parallel line is on the left;right;Parallel line is on the right;both;"
-"Parallel lines on both sides"
+msgid "left;Parallel line is on the left;right;Parallel line is on the right;both;Parallel lines on both sides"
msgstr "leftï¼ä¸¦è¡ç·ã¯å·¦ï¼rightï¼å¹³è¡ç·ã¯å³ï¼bothï¼å¹³è¡ç·ã¯ä¸¡å´"
#: ../vector/v.parallel2/main.c:94
@@ -25411,13 +23992,8 @@
msgstr "ã«ãã´ãªã¼çªå·ã¢ã¼ã"
#: ../vector/v.build.polylines/main.c:121
-msgid ""
-"no;Do not assign any category number to polyline;first;Assign category "
-"number of first line to polyline;multi;Assign multiple category numbers to "
-"polyline"
-msgstr ""
-"noï¼ããªã©ã¤ã³ã«ã«ãã´ãªã¼çªå·ãå²ãå½ãªãï¼firstï¼æåã®ã©ã¤ã³ã®ã«ãã´ãªã¼çª"
-"å·ãããªã©ã¤ã³ã«å²ãå½ã¦ï¼multiï¼è¤æ°ã®ã«ãã´ãªã¼çªå·ãããªã©ã¤ã³ã«å²ãå½ã¦"
+msgid "no;Do not assign any category number to polyline;first;Assign category number of first line to polyline;multi;Assign multiple category numbers to polyline"
+msgstr "noï¼ããªã©ã¤ã³ã«ã«ãã´ãªã¼çªå·ãå²ãå½ãªãï¼firstï¼æåã®ã©ã¤ã³ã®ã«ãã´ãªã¼çªå·ãããªã©ã¤ã³ã«å²ãå½ã¦ï¼multiï¼è¤æ°ã®ã«ãã´ãªã¼çªå·ãããªã©ã¤ã³ã«å²ãå½ã¦"
#: ../vector/v.build.polylines/main.c:212
#, c-format
@@ -25474,19 +24050,8 @@
msgstr "åä½ãçµäºãã¾ãã"
#: ../vector/v.category/main.c:84
-msgid ""
-"add;add a new category;del;delete all categories of given layer;chlayer;"
-"change layer number (e.g. layer=3,1 changes layer 3 to layer 1);sum;add the "
-"value specified by cat option to the current category value;report;print "
-"report (statistics), in shell style: layer type count min max;print;print "
-"category values, more cats in the same layer are separated by '/'"
-msgstr ""
-"addï¼æ°ããã«ãã´ãªã¼ã追å ï¼delï¼æå®ããã¬ã¤ã¤ã¼ã®ã«ãã´ãªã¼ãå
¨ã¦åé¤ï¼"
-"chlayerï¼ã¬ã¤ã¤ã¼çªå·ã夿´ (ä¾ï¼layer=3,1 ã¬ã¤ã¤ã¼3 ããã¬ã¤ã¤ã¼1 ã¸å¤æ´)ï¼"
-"sumï¼cat ãªãã·ã§ã³ã«ãã£ã¦æå®ãããå¤ãç¾å¨ã®ã«ãã´ãªã¼å¤ã¸å ããï¼reportï¼"
-"ãªãã¼ã (çµ±è¨) ãåºåï¼ ã·ã§ã«ã¹ã¿ã¤ã«ï¼ ã¬ã¤ã¤ã¼ãã¹ã¿ã¤ã«ãã«ã¦ã³ããæå°"
-"ãæå¤§ï¼printï¼ã«ãã´ãªã¼å¤ãåºåï¼ åä¸ã¬ã¤ã¤ã¼ä¸ã®å¥ã«ãã´ãªã¼ã¯ '/' ã§åã"
-"ã"
+msgid "add;add a new category;del;delete all categories of given layer;chlayer;change layer number (e.g. layer=3,1 changes layer 3 to layer 1);sum;add the value specified by cat option to the current category value;report;print report (statistics), in shell style: layer type count min max;print;print category values, more cats in the same layer are separated by '/'"
+msgstr "addï¼æ°ããã«ãã´ãªã¼ã追å ï¼delï¼æå®ããã¬ã¤ã¤ã¼ã®ã«ãã´ãªã¼ãå
¨ã¦åé¤ï¼chlayerï¼ã¬ã¤ã¤ã¼çªå·ã夿´ (ä¾ï¼layer=3,1 ã¬ã¤ã¤ã¼3 ããã¬ã¤ã¤ã¼1 ã¸å¤æ´)ï¼sumï¼cat ãªãã·ã§ã³ã«ãã£ã¦æå®ãããå¤ãç¾å¨ã®ã«ãã´ãªã¼å¤ã¸å ããï¼reportï¼ãªãã¼ã (çµ±è¨) ãåºåï¼ ã·ã§ã«ã¹ã¿ã¤ã«ï¼ ã¬ã¤ã¤ã¼ãã¹ã¿ã¤ã«ãã«ã¦ã³ããæå°ãæå¤§ï¼printï¼ã«ãã´ãªã¼å¤ãåºåï¼ åä¸ã¬ã¤ã¤ã¼ä¸ã®å¥ã«ãã´ãªã¼ã¯ '/' ã§åãã"
#: ../vector/v.category/main.c:100
msgid "Feature ids (by default all features are processed)"
@@ -25506,16 +24071,12 @@
msgstr "ãã©ã¼ãããï¼ ã¬ã¤ã¤ã¼ãã¿ã¤ããã«ã¦ã³ããæå°ãæå¤§"
#: ../vector/v.category/main.c:135
-msgid ""
-"Database connection and attribute tables for concerned layers are not changed"
+msgid "Database connection and attribute tables for concerned layers are not changed"
msgstr "æ¥ç¶ããã¬ã¤ã¤ã¼ã®ãã¼ã¿ãã¼ã¹ã®æ¥ç¶ã¨å±æ§ãã¼ãã«ã¯å¤åãã¾ãã"
#: ../vector/v.category/main.c:153
-msgid ""
-"Invalid category number (must be equal to or greater than 0). Normally "
-"category number starts at 1."
-msgstr ""
-"ç¡å¹ãªã«ãã´ãªã¼çªå· ï¼0以ä¸ã®å¤ï¼ï¼ é常ï¼ã«ãã´ãªã¼çªå·ã¯1ããå§ã¾ãã¾ã"
+msgid "Invalid category number (must be equal to or greater than 0). Normally category number starts at 1."
+msgstr "ç¡å¹ãªã«ãã´ãªã¼çªå· ï¼0以ä¸ã®å¤ï¼ï¼ é常ï¼ã«ãã´ãªã¼çªå·ã¯1ããå§ã¾ãã¾ã"
#: ../vector/v.category/main.c:162
#, c-format
@@ -25701,13 +24262,8 @@
msgstr "ãã¯ãã«ãè£é"
#: ../vector/v.surf.rst/main.c:166
-msgid ""
-"Spatial approximation and topographic analysis from given point or isoline "
-"data in vector format to floating point raster format using regularized "
-"spline with tension."
-msgstr ""
-"ãã¯ãã«ãã©ã¼ãããå
ã®æå®ããããã¤ã³ãã¾ãã¯çå¤ç·ãã¼ã¿ãï¼ãã³ã·ã§ã³æ³"
-"æ£è¦åã¹ãã©ã¤ã³ã«ããï¼æµ®åå°æ°ç¹ã©ã¹ã¿ã¼ãã©ã¼ãããã«ï¼ç©ºéè¿ä¼¼ã¨å°å½¢è§£æ"
+msgid "Spatial approximation and topographic analysis from given point or isoline data in vector format to floating point raster format using regularized spline with tension."
+msgstr "ãã¯ãã«ãã©ã¼ãããå
ã®æå®ããããã¤ã³ãã¾ãã¯çå¤ç·ãã¼ã¿ãï¼ãã³ã·ã§ã³æ³æ£è¦åã¹ãã©ã¤ã³ã«ããï¼æµ®åå°æ°ç¹ã©ã¹ã¿ã¼ãã©ã¼ãããã«ï¼ç©ºéè¿ä¼¼ã¨å°å½¢è§£æ"
#: ../vector/v.surf.rst/main.c:192
msgid "Use z-coordinates (3D vector only)"
@@ -25770,9 +24326,7 @@
msgstr "ãã¹ã¯ã«ä½¿ç¨ããã©ã¹ã¿ã¼ãããå"
#: ../vector/v.surf.rst/main.c:300
-msgid ""
-"Name of the attribute column with values to be used for approximation (if "
-"layer>0)"
+msgid "Name of the attribute column with values to be used for approximation (if layer>0)"
msgstr "è¿ä¼¼ï¼layer > 0 ã®æï¼ã«ä½¿ç¨ãããå¤ãå«ã屿§åå"
#: ../vector/v.surf.rst/main.c:308 ../vector/v.vol.rst/main.c:260
@@ -25800,8 +24354,7 @@
msgstr "2ç¹éã®æå°è·é¢ï¼ä¸è´ãããã¤ã³ããé¤å¤ããããï¼"
#: ../vector/v.surf.rst/main.c:358
-msgid ""
-"Maximum distance between points on isoline (to insert additional points)"
+msgid "Maximum distance between points on isoline (to insert additional points)"
msgstr "çå¤ç·ä¸ã®2ç¹éã®æå¤§è·é¢ï¼ãã¤ã³ããè¿½å æ¿å
¥ããããï¼"
#: ../vector/v.surf.rst/main.c:367
@@ -25823,19 +24376,12 @@
msgstr "ã©ã¹ã¿ã¼ãããã¾ãã¯ãã¯ãã«ããããæå®ãã¦ãã¾ãã"
#: ../vector/v.surf.rst/main.c:456
-msgid ""
-"Both cross-validation options (-c flag and cvdev vector output) must be "
-"specified"
-msgstr ""
-"ç¸äºæ¤è¨¼ãªãã·ã§ã³ (-c ãã©ã㰠㨠cvdev ãã¯ãã«åºå) ã®ä¸¡æ¹ãæå®ããå¿
è¦ã"
-"ããã¾ã"
+msgid "Both cross-validation options (-c flag and cvdev vector output) must be specified"
+msgstr "ç¸äºæ¤è¨¼ãªãã·ã§ã³ (-c ãã©ã㰠㨠cvdev ãã¯ãã«åºå) ã®ä¸¡æ¹ãæå®ããå¿
è¦ãããã¾ã"
#: ../vector/v.surf.rst/main.c:459
-msgid ""
-"The cross-validation cannot be computed simultaneously with output raster or "
-"devi file"
-msgstr ""
-"ç¸äºæ¤è¨¼è¨ç®ã¯ã©ã¹ã¿ãã¡ã¤ã«ã devi ãã¡ã¤ã«ã®åºåã¨åæã«è¨ç®ã§ãã¾ãã"
+msgid "The cross-validation cannot be computed simultaneously with output raster or devi file"
+msgstr "ç¸äºæ¤è¨¼è¨ç®ã¯ã©ã¹ã¿ãã¡ã¤ã«ã devi ãã¡ã¤ã«ã®åºåã¨åæã«è¨ç®ã§ãã¾ãã"
#: ../vector/v.surf.rst/main.c:462
msgid "Both z-coordinate and zcol attribute defined, only one is allowed"
@@ -25930,9 +24476,7 @@
msgstr "ãã¯ãã«ï¼å¤æ"
#: ../vector/v.transform/main.c:74
-msgid ""
-"Performs an affine transformation (shift, scale and rotate, or GPCs) on "
-"vector map."
+msgid "Performs an affine transformation (shift, scale and rotate, or GPCs) on vector map."
msgstr "ãã¯ãã«ãããä¸ã®ã¢ãã£ã³å¤æ (ããï¼ç¸®å°ºï¼å転ã¾ã㯠GPCs) ãå®è¡"
#: ../vector/v.transform/main.c:80
@@ -25956,24 +24500,16 @@
msgstr "夿è¡åãæ¨æºåºåã¸åºå"
#: ../vector/v.transform/main.c:96
-msgid ""
-"Instead of points use transformation parameters (xshift, yshift, zshift, "
-"xscale, yscale, zscale, zrot)"
-msgstr ""
-"ãã¤ã³ãã®ä»£ããã«å¤æãã©ã¡ã¼ã¿ã¼ (xshift, yshift, zshift, xscale, yscale, "
-"zscale, zrot) ã使ç¨"
+msgid "Instead of points use transformation parameters (xshift, yshift, zshift, xscale, yscale, zscale, zrot)"
+msgstr "ãã¤ã³ãã®ä»£ããã«å¤æãã©ã¡ã¼ã¿ã¼ (xshift, yshift, zshift, xscale, yscale, zscale, zrot) ã使ç¨"
#: ../vector/v.transform/main.c:109
msgid "ASCII file holding transform coordinates"
msgstr "å¤æåº§æ¨ãä¿æããASCIIãã¡ã¤ã«"
#: ../vector/v.transform/main.c:110
-msgid ""
-"If not given, transformation parameters (xshift, yshift, zshift, xscale, "
-"yscale, zscale, zrot) are used instead"
-msgstr ""
-"æå®ããªãå ´åï¼å¤æãã©ã¡ã¼ã¿ã¼ (xshift, yshift, zshift, xscale, yscale, "
-"zscale, zrot) ã使ç¨ããã¾ã"
+msgid "If not given, transformation parameters (xshift, yshift, zshift, xscale, yscale, zscale, zrot) are used instead"
+msgstr "æå®ããªãå ´åï¼å¤æãã©ã¡ã¼ã¿ã¼ (xshift, yshift, zshift, xscale, yscale, zscale, zrot) ã使ç¨ããã¾ã"
#: ../vector/v.transform/main.c:121
msgid "Shifting value for x coordinates"
@@ -26017,21 +24553,13 @@
#: ../vector/v.transform/main.c:206
#, c-format
-msgid ""
-"The '%c' flag is deprecated and will be removed in future. Transformation "
-"parameters are used automatically when no pointsfile is given."
-msgstr ""
-"%c' ãã©ãã°ã¯å»æ¢ããã¾ããï¼ããã¯åé¤ãããäºå®ã§ãï¼ãã¤ã³ããå«ã¾ãªã"
-"ãã¡ã¤ã«ãæå®ãããå ´åï¼å¤æãã©ã¡ã¼ã¿ã¼ã¯èªåçã«ä½¿ç¨ããã¾ã"
+msgid "The '%c' flag is deprecated and will be removed in future. Transformation parameters are used automatically when no pointsfile is given."
+msgstr "%c' ãã©ãã°ã¯å»æ¢ããã¾ããï¼ããã¯åé¤ãããäºå®ã§ãï¼ãã¤ã³ããå«ã¾ãªããã¡ã¤ã«ãæå®ãããå ´åï¼å¤æãã©ã¡ã¼ã¿ã¼ã¯èªåçã«ä½¿ç¨ããã¾ã"
#: ../vector/v.transform/main.c:211
#, c-format
-msgid ""
-"The '%c' flag is deprecated and will be removed in future. Please use '--"
-"quiet' instead."
-msgstr ""
-"%c' ãã©ãã°ã¯å»æ¢ããã¾ããï¼ããã¯åé¤ãããäºå®ã§ãï¼ä»£ããã« '--quiet' ã"
-"使ç¨ãã¦ä¸ãã"
+msgid "The '%c' flag is deprecated and will be removed in future. Please use '--quiet' instead."
+msgstr "%c' ãã©ãã°ã¯å»æ¢ããã¾ããï¼ããã¯åé¤ãããäºå®ã§ãï¼ä»£ããã« '--quiet' ã使ç¨ãã¦ä¸ãã"
#: ../vector/v.transform/main.c:217
#, c-format
@@ -26039,12 +24567,8 @@
msgstr "ãã¼ãã«åãå®ç¾©ããã¦ãã¾ããï¼'%s' ãã©ã¡ã¼ã¿ã¼ã使ç¨ãã¦ä¸ãã"
#: ../vector/v.transform/main.c:222
-msgid ""
-"Name of table and name for output vector map must be different. Otherwise "
-"the table is overwritten."
-msgstr ""
-"ãã¼ãã«åã¨åºåãããã¯ãã«ãããåã¯å¥åã«ããå¿
è¦ãããã¾ãï¼ããã§ãªãå ´"
-"åï¼ãã¼ãã«ã¯ä¸æ¸ãããã¾ã"
+msgid "Name of table and name for output vector map must be different. Otherwise the table is overwritten."
+msgstr "ãã¼ãã«åã¨åºåãããã¯ãã«ãããåã¯å¥åã«ããå¿
è¦ãããã¾ãï¼ããã§ãªãå ´åï¼ãã¼ãã«ã¯ä¸æ¸ãããã¾ã"
#: ../vector/v.transform/main.c:236
#, c-format
@@ -26091,12 +24615,8 @@
#: ../vector/v.transform/trans_digit.c:104
#, c-format
-msgid ""
-"Unable to select value for category %d from table <%s>, column <%s>. For "
-"category %d using default transformation parameter %.3f."
-msgstr ""
-"ã«ãã´ãªã¼ %d ã®å¤ãã表 <%s> ã®å <%s> ãã鏿ã§ãã¾ããï¼ã«ãã´ãªã¼ %d ã«"
-"ã¯å¤æãã©ã¡ã¼ã¿ã¼ã®æ¢å®å¤ %.3f ã使ç¨"
+msgid "Unable to select value for category %d from table <%s>, column <%s>. For category %d using default transformation parameter %.3f."
+msgstr "ã«ãã´ãªã¼ %d ã®å¤ãã表 <%s> ã®å <%s> ãã鏿ã§ãã¾ããï¼ã«ãã´ãªã¼ %d ã«ã¯å¤æãã©ã¡ã¼ã¿ã¼ã®æ¢å®å¤ %.3f ã使ç¨"
#: ../vector/v.transform/trans_digit.c:115
msgid "No category number defined. Using default transformation parameters."
@@ -26117,11 +24637,8 @@
#: ../vector/lidar/v.lidar.edgedetection/main.c:86
#: ../vector/lidar/v.lidar.correction/main.c:81
#: ../vector/lidar/v.surf.bspline/main.c:96
-msgid ""
-"Estimate point density and distance for the input vector points within the "
-"current region extends and quit"
-msgstr ""
-"ç¾å¨ã®é åç¯å²å
ã§ãã¤ã³ãå¯åº¦ã¨å
¥åãã¯ãã«ãã¤ã³ãã®è·é¢ãæ¨å®ãã¦çµäº"
+msgid "Estimate point density and distance for the input vector points within the current region extends and quit"
+msgstr "ç¾å¨ã®é åç¯å²å
ã§ãã¤ã³ãå¯åº¦ã¨å
#: ../vector/lidar/v.outlier/main.c:92
msgid "Name of output outlier vector map"
@@ -26176,9 +24693,7 @@
#: ../vector/lidar/v.lidar.growing/main.c:166
#, c-format
msgid "No database connection for driver <%s> is defined. Run db.connect."
-msgstr ""
-"ãã©ã¤ãã¼ <%s> ã®ãã¼ã¿ãã¼ã¹æ¥ç¶ã¯å®ç¾©ããã¦ãã¾ãã. db.æ¥ç¶ãå®è¡ãã¦ãã "
-"ãã. "
+msgstr "ãã©ã¤ãã¼ <%s> ã®ãã¼ã¿ãã¼ã¹æ¥ç¶ã¯å®ç¾©ããã¦ãã¾ãã. db.æ¥ç¶ãå®è¡ãã¦ãã ãã. "
#: ../vector/lidar/v.outlier/main.c:174
#: ../vector/lidar/v.lidar.edgedetection/main.c:196
@@ -26254,9 +24769,7 @@
#: ../vector/lidar/v.lidar.correction/main.c:429
#: ../vector/lidar/v.surf.bspline/main.c:681
msgid "No data within this subregion. Consider changing the spline step."
-msgstr ""
-"ãã®ãµãã¾ã¼ã³å
ã«ãã¼ã¿ã¯ããã¾ãã. ã¹ãã©ã¤ã³ã¹ãããã夿´ãã¦ã¿ã¦ãã ã"
-"ã. "
+msgstr "ãã®ãµãã¾ã¼ã³å
ã«ãã¼ã¿ã¯ããã¾ãã. ã¹ãã©ã¤ã³ã¹ãããã夿´ãã¦ã¿ã¦ãã ãã. "
#: ../vector/lidar/v.outlier/main.c:433
#: ../vector/lidar/v.lidar.edgedetection/main.c:470
@@ -26379,11 +24892,8 @@
msgstr "ãã¯ãã«, ã©ã¤ãã¼ "
#: ../vector/lidar/v.lidar.correction/main.c:75
-msgid ""
-"Correction of the v.lidar.growing output. It is the last of the three "
-"algorithms for LIDAR filtering."
-msgstr ""
-"å¢ããv.lidar.åºåã®ä¿®æ£. LIDARãã£ã«ã¿ãªã³ã°ã®3ã¤ã®ã¢ã«ã´ãªãºã ã®æå¾ã§ã. "
+msgid "Correction of the v.lidar.growing output. It is the last of the three algorithms for LIDAR filtering."
+msgstr "å¢ããv.lidar.åºåã®ä¿®æ£. LIDARãã£ã«ã¿ãªã³ã°ã®3ã¤ã®ã¢ã«ã´ãªãºã ã®æå¾ã§ã. "
#: ../vector/lidar/v.lidar.correction/main.c:85
msgid "Input observation vector map name (v.lidar.growing output)"
@@ -26467,12 +24977,8 @@
msgstr "Tykhonovæ£è¦åã«ä¼´ããã¤ãã¥ã¼ããã¯ã¾ãã¯ãã¤ãªã㢠ã¹ãã©ã¤ã³è£é. "
#: ../vector/lidar/v.surf.bspline/main.c:90
-msgid ""
-"Find the best Tykhonov regularizing parameter using a \"leave-one-out\" "
-"cross validation method"
-msgstr ""
-"\"leave-one-out\" 交差æ¤è¨¼ãç¨ãã¦æä¸ã®Tykhonovæ£è¦ãã©ã¡ã¼ã¿ã¼ãè¦ã¤ãã¦ã"
-"ã ãã"
+msgid "Find the best Tykhonov regularizing parameter using a \"leave-one-out\" cross validation method"
+msgstr "\"leave-one-out\" 交差æ¤è¨¼ãç¨ãã¦æä¸ã®Tykhonovæ£è¦ãã©ã¡ã¼ã¿ã¼ãè¦ã¤ãã¦ãã ãã"
#: ../vector/lidar/v.surf.bspline/main.c:104
msgid "Name of input vector map of sparse points"
@@ -26525,12 +25031,8 @@
#: ../vector/lidar/v.surf.bspline/main.c:268
#, c-format
-msgid ""
-"No vector map of sparse points to interpolate was specified. Interpolation "
-"will be done with <%s> vector map"
-msgstr ""
-"è£éã«å¯¾ããå°éãã¤ã³ãã®ãã¯ãã«ãããã¯æå®ããã¾ããã§ãã. è£éã¯ãã¯ã"
-"ã«ãããã¨è¡ãªããã¾ã <%s> "
+msgid "No vector map of sparse points to interpolate was specified. Interpolation will be done with <%s> vector map"
+msgstr "è£éã«å¯¾ããå°éãã¤ã³ãã®ãã¯ãã«ãããã¯æå®ããã¾ããã§ãã. è£éã¯ãã¯ãã«ãããã¨è¡ãªããã¾ã <%s> "
#: ../vector/lidar/v.surf.bspline/main.c:274
#, c-format
@@ -26539,12 +25041,8 @@
#: ../vector/lidar/v.surf.bspline/main.c:290
#, c-format
-msgid ""
-"Sorry, <%s> driver is not allowed for vector output in this module. Try with "
-"a raster output or other driver."
-msgstr ""
-"<%s> ãã©ã¤ãã¼ã¯ãã®ã¢ã¸ã¥ã¼ã«ã«ããããã¯ãã«åºåã«è¨±å¯ããã¦ãã¾ãã. ã©ã¹"
-"ã¿ã¼åºåã¾ãã¯ä»ã®ãã©ã¤ãã¼ã§è©¦ãã¦ãã ãã."
+msgid "Sorry, <%s> driver is not allowed for vector output in this module. Try with a raster output or other driver."
+msgstr "<%s> ãã©ã¤ãã¼ã¯ãã®ã¢ã¸ã¥ã¼ã«ã«ããããã¯ãã«åºåã«è¨±å¯ããã¦ãã¾ãã. ã©ã¹ã¿ã¼åºåã¾ãã¯ä»ã®ãã©ã¤ãã¼ã§è©¦ãã¦ãã ãã."
#: ../vector/lidar/v.surf.bspline/main.c:328
msgid "Cannot read field info"
@@ -26561,12 +25059,8 @@
msgstr "è£é: è¡¨ä½æ: 表 <%s>ã使ã§ãã¾ããã§ãã."
#: ../vector/lidar/v.surf.bspline/main.c:391
-msgid ""
-"Cannot allocate memory for auxiliar matrix.Consider changing region "
-"resolution"
-msgstr ""
-"auxiliarãããªãã¯ã¹ã«ã¡ã¢ãªã¼ãå²ãå½ã¦ããã¾ãã.é åã®è§£å度ã夿´ãã¦ã¿ã¦"
-"ãã ãã "
+msgid "Cannot allocate memory for auxiliar matrix.Consider changing region resolution"
+msgstr "auxiliarãããªãã¯ã¹ã«ã¡ã¢ãªã¼ãå²ãå½ã¦ããã¾ãã.é åã®è§£å度ã夿´ãã¦ã¿ã¦ãã ãã "
#: ../vector/lidar/v.surf.bspline/main.c:568
#, c-format
@@ -26588,9 +25082,7 @@
msgstr "ãã®é åã«èªã¿è¾¼ã¾ãããã¤ã³ã %d"
#: ../vector/lidar/v.surf.bspline/crosscorr.c:90
-msgid ""
-"Maybe, it takes too long. It will depend on how many points you are "
-"considering."
+msgid "Maybe, it takes too long. It will depend on how many points you are considering."
msgstr "æéãããããããããããã¾ãã. ãã¤ã³ãã®æ°ã«ããã¾ã"
#: ../vector/lidar/v.surf.bspline/crosscorr.c:119
@@ -26605,11 +25097,8 @@
#: ../vector/lidar/v.surf.bspline/crosscorr.c:151
#, c-format
-msgid ""
-"Too many splines (%d x %d). Consider changing spline steps \"sie=\" \"sin=\"."
-msgstr ""
-"ã¹ãã©ã¤ã³ (%d x %d) ãå¤ããã¾ã. ã¹ãã©ã¤ã³ã¹ãããã夿´ãã¦ãã ãã "
-"\"sie=\" \"sin=\". "
+msgid "Too many splines (%d x %d). Consider changing spline steps \"sie=\" \"sin=\"."
+msgstr "ã¹ãã©ã¤ã³ (%d x %d) ãå¤ããã¾ã. ã¹ãã©ã¤ã³ã¹ãããã夿´ãã¦ãã ãã \"sie=\" \"sin=\". "
#: ../vector/lidar/v.surf.bspline/crosscorr.c:169
#, c-format
@@ -26633,15 +25122,12 @@
msgstr "äºä¹å¹³åå¹³æ¹æ ¹ (RMS) = %.5lf"
#: ../vector/lidar/v.surf.bspline/crosscorr.c:306
-msgid ""
-"Different number of splines and lambda_i values have been taken for the "
-"cross correlation"
+msgid "Different number of splines and lambda_i values have been taken for the cross correlation"
msgstr "ç°ãªãæ°ã®ã¹ãã©ã¤ã³ã¨lambda_i å¤ã¯ç¸äºç¸é¢ã«ä½¿ç¨ããã¦ãã¾ã "
#: ../vector/lidar/v.surf.bspline/crosscorr.c:308
#, c-format
-msgid ""
-"The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
+msgid "The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
msgstr "ãã¹ã (rms=%lf) ã®æå°å¤ã¯: lambda_i = %.3f ã¨åå¾ããã¾ãã "
#: ../vector/lidar/v.surf.bspline/crosscorr.c:316
@@ -26666,9 +25152,7 @@
msgstr "...ã·ã¹ãã ã«åºã¦ããã¾ã... "
#: ../vector/lidar/v.lidar.growing/main.c:81
-msgid ""
-"Building contour determination and Region Growing algorithm for determining "
-"the building inside"
+msgid "Building contour determination and Region Growing algorithm for determining the building inside"
msgstr "å
é¨å»ºç©æ¸¬å®ã®è¼ªé測å®ã¨é åæé·ã¢ã«ã´ãªãºã "
#: ../vector/lidar/v.lidar.growing/main.c:86
@@ -26719,12 +25203,8 @@
msgstr "ãã¯ãã«ï¼ååé¡ï¼å±æ§"
#: ../vector/v.reclass/main.c:65
-msgid ""
-"Changes vector category values for an existing vector map according to "
-"results of SQL queries or a value in attribute table column."
-msgstr ""
-"ä»ããSQLæ¤ç´¢ã®çµæã¾ãã¯å±æ§ãã¼ãã«å
ã®åã®å¤ããå¾ãããï¼ãã¯ãã«ã®ã«ãã´"
-"ãªã¼å¤ã夿´"
+msgid "Changes vector category values for an existing vector map according to results of SQL queries or a value in attribute table column."
+msgstr "ä»ããSQLæ¤ç´¢ã®çµæã¾ãã¯å±æ§ãã¼ãã«å
ã®åã®å¤ããå¾ãããï¼ãã¯ãã«ã®ã«ãã´ãªã¼å¤ã夿´"
#: ../vector/v.reclass/main.c:82
msgid "The name of the column whose values are to be used as new categories"
@@ -26867,9 +25347,8 @@
msgstr "䏿£ãªå
¥åãã©ã¼ãããï¼ %s "
#: ../vector/v.net.timetable/main.c:467
-#, fuzzy
msgid "'From' and 'To' stops are the same"
-msgstr "å
¥åã¨åºåã§åä¸ã®ãã±ã¼ã·ã§ã³ã¯æå®åºæ¥ã¾ãã"
+msgstr "åä¸ã®å
¥åã¨åºåã¯æå®åºæ¥ã¾ãã"
#: ../vector/v.net.timetable/main.c:476
msgid "No path between the stops"
@@ -26992,9 +25471,7 @@
msgstr "ãµãã¼ãããOGRãã¯ãã«ãã©ã¼ãããã®ã²ã¨ã¤ã«å¤æ"
#: ../vector/v.out.ogr/main.c:106
-msgid ""
-"Feature type(s). Combinations not supported by all output formats. Default: "
-"first type found in input."
+msgid "Feature type(s). Combinations not supported by all output formats. Default: first type found in input."
msgstr "å°ç©ã®åï¼ è¤ååã¯å
¨ã¦ã®ãã©ã¼ãããã§ãµãã¼ãããã訳ã§ã¯ããã¾ãã"
#: ../vector/v.out.ogr/main.c:114
@@ -27036,25 +25513,19 @@
#: ../vector/v.out.ogr/main.c:167
msgid "Skip export of GRASS category ID ('cat') attribute"
-msgstr ""
+msgstr "GRASSã«ãã´ãªID('cat'屿§)ã®ã¨ã¯ã¹ãã¼ããã¹ããã"
#: ../vector/v.out.ogr/main.c:171
-msgid ""
-"Export features with category (labeled) only. Otherwise all features are "
-"exported"
-msgstr ""
-"å°ç©ãã«ãã´ãªã¼ï¼ã©ãã«ä»ï¼ã ããä»ãã¦ã¨ã¯ã¹ãã¼ã ãã§ãã¯ããªãã¨å
¨ã¦ã®å°"
-"ç©ãã¨ã¯ã¹ãã¼ã"
+msgid "Export features with category (labeled) only. Otherwise all features are exported"
+msgstr "å°ç©ãã«ãã´ãªã¼ï¼ã©ãã«ä»ï¼ã ããä»ãã¦ã¨ã¯ã¹ãã¼ã ãã§ãã¯ããªãã¨å
¨ã¦ã®å°ç©ãã¨ã¯ã¹ãã¼ã"
#: ../vector/v.out.ogr/main.c:176
msgid "Use ESRI-style .prj file format (applies to Shapefile output only)"
-msgstr ""
-"ESRIã¹ã¿ã¤ã«ã® .prj ãã©ã¼ããããä½¿ç¨ (ã·ã§ã¼ããã¡ã¤ã«ã®åºåã®ã¿ãè¦æ±) "
+msgstr "ESRIã¹ã¿ã¤ã«ã® .prj ãã©ã¼ããããä½¿ç¨ (ã·ã§ã¼ããã¡ã¤ã«ã®åºåã®ã¿ãè¦æ±) "
#: ../vector/v.out.ogr/main.c:181
msgid "Create 3D output if input is 3D (applies to Shapefile output only)"
-msgstr ""
#: ../vector/v.out.ogr/main.c:186
msgid "Export lines as polygons"
@@ -27062,7 +25533,7 @@
#: ../vector/v.out.ogr/main.c:230
msgid "Skipping all boundaries that are not part of an area."
-msgstr ""
+msgstr "ã¨ãªã¢ã®ä¸é¨ã§ã¯ãªãå
¨ã¦ã®å¢çãã¹ããããã¾ã"
#: ../vector/v.out.ogr/main.c:249
msgid "Volumes will be exported as sets of faces."
@@ -27077,137 +25548,80 @@
msgstr "è¤ååã¯å
¨ã¦ã®ãã©ã¼ãããã§ãµãã¼ãããã¦ãã¾ãã"
#: ../vector/v.out.ogr/main.c:326
-msgid ""
-"The map contains islands. To preserve them in the output map, use the -c flag"
-msgstr ""
-"ãããä¸ã«å³¶ãããã¾ãï¼ããããåºåãããã«ä¿åããããã« -c ãã©ãã°ã使ç¨"
-"ãã¦ãã ãã"
+msgid "The map contains islands. To preserve them in the output map, use the -c flag"
+msgstr "ãããä¸ã«å³¶ãããã¾ãï¼ããããåºåãããã«ä¿åããããã« -c ãã©ãã°ã使ç¨ãã¦ãã ãã"
#: ../vector/v.out.ogr/main.c:331
#, c-format
-msgid ""
-"%d point(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr ""
-"%d ã®ãã¤ã³ããããã¾ããã¨ã¯ã¹ãã¼ãã®æå®ãããã¾ããï¼'type' ãã©ã¡ã¼ã¿ã¼"
-"ã確èªãã¦ä¸ãã"
+msgid "%d point(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d ã®ãã¤ã³ããããã¾ããã¨ã¯ã¹ãã¼ãã®æå®ãããã¾ããï¼'type' ãã©ã¡ã¼ã¿ã¼ã確èªãã¦ä¸ãã"
#: ../vector/v.out.ogr/main.c:336
#, c-format
-msgid ""
-"%d line(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr ""
-"%d ã®ã©ã¤ã³ãããã¾ããã¨ã¯ã¹ãã¼ãã®æå®ãããã¾ããï¼'type' ãã©ã¡ã¼ã¿ã¼ã"
-"確èªãã¦ä¸ãã"
+msgid "%d line(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d ã®ã©ã¤ã³ãããã¾ããã¨ã¯ã¹ãã¼ãã®æå®ãããã¾ããï¼'type' ãã©ã¡ã¼ã¿ã¼ã確èªãã¦ä¸ãã"
#: ../vector/v.out.ogr/main.c:342
#, c-format
-msgid ""
-"%d boundary(ies) found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgstr ""
-"%d ã®å¢çãããã¾ããã¨ã¯ã¹ãã¼ãã®æå®ãããã¾ããï¼'type' ãã©ã¡ã¼ã¿ã¼ã確"
-"èªãã¦ä¸ãã"
+msgid "%d boundary(ies) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d ã®å¢çãããã¾ããã¨ã¯ã¹ãã¼ãã®æå®ãããã¾ããï¼'type' ãã©ã¡ã¼ã¿ã¼ã確èªãã¦ä¸ãã"
#: ../vector/v.out.ogr/main.c:348
#, c-format
-msgid ""
-"%d centroid(s) found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgstr ""
-"%d ã®ã»ã³ããã¤ããããã¾ããã¨ã¯ã¹ãã¼ãã®æå®ãããã¾ããï¼'type' ãã©ã¡ã¼"
-"ã¿ã¼ã確èªãã¦ä¸ãã"
+msgid "%d centroid(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d ã®ã»ã³ããã¤ããããã¾ããã¨ã¯ã¹ãã¼ãã®æå®ãããã¾ããï¼'type' ãã©ã¡ã¼ã¿ã¼ã確èªãã¦ä¸ãã"
#: ../vector/v.out.ogr/main.c:353
#, c-format
-msgid ""
-"%d areas found, but not requested to be exported. Verify 'type' parameter."
-msgstr ""
-"%d ã®ã¨ãªã¢ãããã¾ããã¨ã¯ã¹ãã¼ãã®æå®ãããã¾ããï¼'type' ãã©ã¡ã¼ã¿ã¼ã"
-"確èªãã¦ä¸ãã"
+msgid "%d areas found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d ã®ã¨ãªã¢ãããã¾ããã¨ã¯ã¹ãã¼ãã®æå®ãããã¾ããï¼'type' ãã©ã¡ã¼ã¿ã¼ã確èªãã¦ä¸ãã"
#: ../vector/v.out.ogr/main.c:357
#, c-format
-msgid ""
-"%d face(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr ""
-"%d ã®é¢ãããã¾ããã¨ã¯ã¹ãã¼ãã®æå®ãããã¾ããï¼'type' ãã©ã¡ã¼ã¿ã¼ã確èª"
-"ãã¦ä¸ãã"
+msgid "%d face(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d ã®é¢ãããã¾ããã¨ã¯ã¹ãã¼ãã®æå®ãããã¾ããï¼'type' ãã©ã¡ã¼ã¿ã¼ã確èªãã¦ä¸ãã"
#: ../vector/v.out.ogr/main.c:363
#, c-format
-msgid ""
-"%d kernel(s) found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgstr ""
-"確èªãã¦ä¸ãã"
+msgid "%d kernel(s) found, but not requested to be exported. Verify 'type' parameter."
#: ../vector/v.out.ogr/main.c:368
#, c-format
-msgid ""
-"%d volume(s) found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgstr ""
-"確èªãã¦ä¸ãã"
+msgid "%d volume(s) found, but not requested to be exported. Verify 'type' parameter."
#: ../vector/v.out.ogr/main.c:374
-msgid ""
-"No points found, but requested to be exported. Will skip this geometry type."
-msgstr ""
-"ã確èªãã¦ä¸ãã"
+msgid "No points found, but requested to be exported. Will skip this geometry type."
#: ../vector/v.out.ogr/main.c:383
-msgid ""
-"No lines found, but requested to be exported. Will skip this geometry type."
-msgstr ""
-"確èªãã¦ä¸ãã"
+msgid "No lines found, but requested to be exported. Will skip this geometry type."
#: ../vector/v.out.ogr/main.c:393
-msgid ""
-"No boundaries found, but requested to be exported. Will skip this geometry "
-"type."
-msgstr ""
-"èªãã¦ä¸ãã"
+msgid "No boundaries found, but requested to be exported. Will skip this geometry type."
#: ../vector/v.out.ogr/main.c:402
-msgid ""
-"No areas found, but requested to be exported. Will skip this geometry type."
-msgstr ""
-"確èªãã¦ä¸ãã"
+msgid "No areas found, but requested to be exported. Will skip this geometry type."
#: ../vector/v.out.ogr/main.c:412
-msgid ""
-"No centroids found, but requested to be exported. Will skip this geometry "
-"type."
-msgstr ""
-"ã¿ã¼ã確èªãã¦ä¸ãã"
+msgid "No centroids found, but requested to be exported. Will skip this geometry type."
#: ../vector/v.out.ogr/main.c:421
-msgid ""
-"No faces found, but requested to be exported. Will skip this geometry type."
-msgstr ""
-"ãã¦ä¸ãã"
+msgid "No faces found, but requested to be exported. Will skip this geometry type."
#: ../vector/v.out.ogr/main.c:430
-msgid ""
-"No kernels found, but requested to be exported. Will skip this geometry type."
-msgstr ""
-"確èªãã¦ä¸ãã"
+msgid "No kernels found, but requested to be exported. Will skip this geometry type."
#: ../vector/v.out.ogr/main.c:439
-msgid ""
-"No volumes found, but requested to be exported. Will skip this geometry type."
-msgstr ""
-"確èªãã¦ä¸ãã"
+msgid "No volumes found, but requested to be exported. Will skip this geometry type."
#: ../vector/v.out.ogr/main.c:450
msgid "Nothing to export"
@@ -27239,21 +25653,13 @@
#: ../vector/v.out.ogr/main.c:583
#, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options (parameter "
-"'lco') or '-z' flag to export in 3D rather than 2D (default)"
-msgstr ""
-"ãã¯ãã«ããã <%s> ã¯3Dï¼ã¨ã¯ã¹ãã¼ãããããã«2Dã§ã¯ãªã3Dã§ãã©ã¼ãããæ"
-"å®ã¬ã¤ã¤ã¼ä½æãªãã·ã§ã³ (ãã©ã¡ã¼ã¿ã¼ 'lco') ã使ç¨ãã¦ä¸ãã (æ¨æºè¨å®)"
+msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
+msgstr "ãã¯ãã«ããã <%s> ã¯3Dï¼ã¨ã¯ã¹ãã¼ãããããã«2Dã§ã¯ãªã3Dã§ãã©ã¼ãããæå®ã¬ã¤ã¤ã¼ä½æãªãã·ã§ã³ (ãã©ã¡ã¼ã¿ã¼ 'lco') ã使ç¨ãã¦ä¸ãã (æ¨æºè¨å®)"
#: ../vector/v.out.ogr/main.c:590
#, c-format
-msgid ""
-"'lco') to export in 3D rather than 2D (default)"
-msgstr ""
+msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') to export in 3D rather than 2D (default)"
#: ../vector/v.out.ogr/main.c:603
msgid "Unable to create OGR layer"
@@ -27265,8 +25671,7 @@
#: ../vector/v.out.ogr/main.c:617
msgid "Exporting 'cat' anyway, as it is the only attribute table field"
-msgstr ""
-"å¯ä¸ã®å±æ§ãã¼ãã«ãã£ã¼ã«ãã§ãããã, ã¨ã«ãã'cat'ãã¨ã¯ã¹ãã¼ããã¾ã "
+msgstr "å¯ä¸ã®å±æ§ãã¼ãã«ãã£ã¼ã«ãã§ãããã, ã¨ã«ãã'cat'ãã¨ã¯ã¹ãã¼ããã¾ã "
#: ../vector/v.out.ogr/main.c:694
#, c-format
@@ -27337,17 +25742,12 @@
msgstr "ä»ã®ãã¯ãã«ãããã¬ã¤ã¤ã¼ãçµåãã¦æ°ãããã¯ãã«ãããã¬ã¤ã¤ã¼ã使"
#: ../vector/v.patch/main.c:80
-msgid ""
-"Name for output vector map where bounding boxes of input vector maps are "
-"written to"
+msgid "Name for output vector map where bounding boxes of input vector maps are written to"
msgstr "æå®ãããã¯ãã«ãããã®å¢çããã¯ã¹ãæ¸ãè¾¼ã¾ãããã¯ãã«ãããå"
#: ../vector/v.patch/main.c:84
-msgid ""
-"Append files to existing file (overwriting existing files must be activated)"
-msgstr ""
-"ãã¡ã¤ã«ãç¾å¨ã®ãã¡ã¤ã«ã¸è¿½å ï¼ç¾å¨ã®ãã¡ã¤ã«ã¸ã®ä¸æ¸ããæå¹ã§ãããã¨ãå¿
-"è¦ï¼"
+msgid "Append files to existing file (overwriting existing files must be activated)"
+msgstr "ãã¡ã¤ã«ãç¾å¨ã®ãã¡ã¤ã«ã¸è¿½å ï¼ç¾å¨ã®ãã¡ã¤ã«ã¸ã®ä¸æ¸ããæå¹ã§ãããã¨ãå¿
è¦ï¼"
#: ../vector/v.patch/main.c:89
msgid "Copy also attribute table"
@@ -27397,8 +25797,7 @@
#: ../vector/v.patch/main.c:322
#, c-format
msgid "Error reading vector map <%s> - some data may not be correct"
-msgstr ""
-"ã¨ã©ã¼ï¼ãã¯ãã«ããã <%s> ãèªã¿è¾¼ã¿ä¸ - ä¸é¨ã®ãã¼ã¿ãæ£ãããªãããã§ã"
+msgstr "ã¨ã©ã¼ï¼ãã¯ãã«ããã <%s> ãèªã¿è¾¼ã¿ä¸ - ä¸é¨ã®ãã¼ã¿ãæ£ãããªãããã§ã"
#: ../vector/v.patch/main.c:364
#, c-format
@@ -27462,30 +25861,16 @@
msgstr "æ¼ç®åã¯å°ç©éã®è¦æ±ããé¢ä¿ãå®ç¾©"
#: ../vector/v.select/args.c:47
-msgid ""
-"A feature is written to output if the result of operation 'ainput operator "
-"binput' is true. An input feature is considered to be true, if category of "
-"given layer is defined."
-msgstr ""
-"ãã 'ainput operator binput' ã®æ¼ç®çµæãçã§ããã°ï¼å°ç©ã¯åºåã«æ¸ãè¾¼ã¾ã"
-"ã¾ãï¼ ããä¸ããããã¬ã¤ã¤ã¼ã®ã«ãã´ãªã¼ãå®ç¾©ããã¦ããã°ï¼æå®ãããå°ç©ã¯"
-"çã¨å¤æãã¾ã"
+msgid "A feature is written to output if the result of operation 'ainput operator binput' is true. An input feature is considered to be true, if category of given layer is defined."
+msgstr "ãã 'ainput operator binput' ã®æ¼ç®çµæãçã§ããã°ï¼å°ç©ã¯åºåã«æ¸ãè¾¼ã¾ãã¾ãï¼ ããä¸ããããã¬ã¤ã¤ã¼ã®ã«ãã´ãªã¼ãå®ç¾©ããã¦ããã°ï¼æå®ãããå°ç©ã¯çã¨å¤æãã¾ã"
#: ../vector/v.select/args.c:53
msgid "overlap;features partially or completely overlap"
msgstr "éè¤ï¼ å°ç©ãé¨åçã¾ãã¯å®å
¨ã«éãªã£ã¦ãã¾ã"
#: ../vector/v.select/args.c:58
-msgid ""
-"overlap;features partially or completely overlap;equals;features are "
-"spatially equals (using GEOS);disjoint;features do not spatially intersect "
-"(using GEOS);intersects;features spatially intersect (using GEOS);touches;"
-"features spatially touches (using GEOS);crosses;features spatially crosses "
-"(using GEOS);within;feature A is completely inside feature B (using GEOS);"
-"contains;feature B is completely inside feature A (using GEOS);overlaps;"
-"features spatially overlap (using GEOS);relate;feature A is spatially "
-"related to feature B (using GEOS, requires 'relate' option);"
-msgstr ""
+msgid "overlap;features partially or completely overlap;equals;features are spatially equals (using GEOS);disjoint;features do not spatially intersect (using GEOS);intersects;features spatially intersect (using GEOS);touches;features spatially touches (using GEOS);crosses;features spatially crosses (using GEOS);within;feature A is completely inside feature B (using GEOS);contains;feature B is completely inside feature A (using GEOS);overlaps;features spatially overlap (using GEOS);relate;feature A is spatially related to feature B (using GEOS, requires 'relate' option);"
+msgstr "overlap;ãã£ã¼ãã£ã¼ãé¨åçãããã¯å
¨ä½çã«ãªã¼ãã¼ã©ãããã;equals;ãã£ã¼ãã£ã¼ã空éçã«çãã(GEOSã使ç¨);disjoint;ãã£ã¼ãã£ã¼ã空éçã«äº¤å·®ï¼intersectï¼ãã¦ããªã(GEOSã使ç¨);intersects;ãã£ã¼ãã£ã¼ã空éçã«äº¤å·®(intersect)ãã(GEOSã使ç¨);touches;ãã£ã¼ãã£ã¼ã空éçã«æ¥ãã(GEOSã使ç¨);crosses;ãã£ã¼ãã£ã¼ã空éçã«äº¤å·®ï¼crossï¼ãã (GEOSã使ç¨);within;ãã£ã¼ãã£ã¼Aãå®å
¨ã«ãã£ã¼ãã£ã¼Bã®å
é¨ã«ãã(GEOSã使ç¨);contains;ãã£ã¼ãã£ã¼Bãå®å
¨ã«ãã£ã¼ãã£ã¼Aã®å
é¨ã«ãã(GEOSã使ç¨);overlaps;ãã£ã¼ãã£ã¼ã空éçã«ãªã¼ãã¼ã©ãããã¦ãã(GEOSã使ç¨);relate;ãã£ã¼ãã£ã¼A ã¯ç©ºéçã«ãã£ã¼ãã£ã¼Bã¨é¢é£ãã(GEOSã使ç¨, 'relate'ãªãã·ã§ã³ãå¿
è¦);"
#: ../vector/v.select/args.c:75
msgid "Intersection Matrix Pattern used for 'relate' operator"
@@ -27500,8 +25885,7 @@
msgstr "ãã¯ãã«ï¼æ¤ç´¢"
#: ../vector/v.select/main.c:54
-msgid ""
-"Selects features from vector map (A) by features from other vector map (B)."
+msgid "Selects features from vector map (A) by features from other vector map (B)."
msgstr "ä»ã®ãã¯ãã«ããã (B) ã®å°ç©ãå
ã«ï¼ãã¯ãã«ããã (A) ããå°ç©ã鏿"
#: ../vector/v.select/main.c:87
@@ -27552,8 +25936,7 @@
#: ../vector/v.convert/att.c:36
msgid "No category labels (dig_cats) found, no table created"
-msgstr ""
-"ã«ãã´ãªã¼ã©ãã« (dig_cats) ãããã¾ããï¼ãã¼ãã«ã¯ä½æããã¾ããã§ãã"
+msgstr "ã«ãã´ãªã¼ã©ãã« (dig_cats) ãããã¾ããï¼ãã¼ãã«ã¯ä½æããã¾ããã§ãã"
#: ../vector/v.convert/att.c:41
msgid "Unable to open dig_cats file"
@@ -27621,12 +26004,8 @@
msgstr "å
¥åãã¡ã¤ã«ã¯ãã¼ã¿ãã«ã§ã"
#: ../vector/v.convert/read.c:99
-msgid ""
-"Input file is not portable. We will attempt to convert anyway but conversion "
-"may fail. Please read manual for detail information."
-msgstr ""
-"å
¥åãã¡ã¤ã«ã¯ãã¼ã¿ãã«ã§ã¯ããã¾ããï¼å¤æã試ã¿ã¾ãã失æããããããã¾ã"
-"ãï¼è©³ããã¯ããã¥ã¢ã«ãåç
§ãã¦ä¸ããï¼"
+msgid "Input file is not portable. We will attempt to convert anyway but conversion may fail. Please read manual for detail information."
+msgstr "å
¥åãã¡ã¤ã«ã¯ãã¼ã¿ãã«ã§ã¯ããã¾ããï¼å¤æã試ã¿ã¾ãã失æããããããã¾ããï¼è©³ããã¯ããã¥ã¢ã«ãåç
§ãã¦ä¸ããï¼"
#: ../vector/v.convert/read.c:185
#, c-format
@@ -27819,8 +26198,7 @@
"%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
msgstr ""
"\n"
-"%d ã®äº¤ç¹ãæå®ããã %d (æå®ãããã¿ã¤ãã®äº¤ç¹) ããåé¤ããã¾ããï¼ ä¾ "
-"%.2f %% "
+"%d ã®äº¤ç¹ãæå®ããã %d (æå®ãããã¿ã¤ãã®äº¤ç¹) ããåé¤ããã¾ããï¼ ä¾ %.2f %% "
#: ../vector/v.clean/prune.c:221
#, c-format
@@ -27840,44 +26218,12 @@
msgstr "ã¯ãªã¼ãã³ã°ãã¼ã«"
#: ../vector/v.clean/main.c:66
-msgid ""
-"break;break lines at each intersection;rmdupl;remove duplicate geometry "
-"features (pay attention to categories!);rmdangle;remove dangles, threshold "
-"ignored if < 0;chdangle;change the type of boundary dangle to line, "
-"threshold ignored if < 0, input line type is ignored;rmbridge;remove bridges "
-"connecting area and island or 2 islands;chbridge;change the type of bridges "
-"connecting area and island or 2 islands from boundary to line;snap;snap "
-"lines to vertex in threshold;rmdac;remove duplicate area centroids ('type' "
-"option ignored);bpol;break (topologically clean) polygons (imported from non "
-"topological format, like ShapeFile). Boundaries are broken on each point "
-"shared between 2 and more polygons where angles of segments are different;"
-"prune;remove vertices in threshold from lines and boundaries, boundary is "
-"pruned only if topology is not damaged (new intersection, changed "
-"attachement of centroid), first and last segment of the boundary is never "
-"changed;rmarea;remove small areas, the longest boundary with adjacent area "
-"is removed;rmline;remove all lines or boundaries of zero length, threshold "
-"is ignored;rmsa;remove small angles between lines at nodes"
-msgstr ""
-"breakï¼ å
¨ã¦ã®äº¤ç¹ã§ã©ã¤ã³ãåæï¼rmduplï¼åãå½¢ç¶ã®ãã£ã¼ãã£ã¼ãåé¤ (ã«ã"
-"ã´ãªã¼ã«æ³¨æï¼)ï¼rmdangleï¼ãã³ã°ã«ãåé¤ï¼ãã < 0 ãªãã°é¾å¤ãç¡è¦ï¼"
-"chdangleï¼ã©ã¤ã³ã¸ã®å¢çã®ãã³ã°ã«ã®ã¿ã¤ãã夿ï¼ãã < 0 ãªãã°é¾å¤ãç¡è¦ã"
-"ã¦æå®ãããã©ã¤ã³ã¿ã¤ãã¯ç¡è¦ï¼rmbridgeï¼ã¨ãªã¢ãå³¶ãçµã¶æ©ãåé¤ï¼"
-"chbridgeï¼å¢çããã©ã¤ã³ã®ï¼ã¨ãªã¢ãå³¶ãçµã¶æ©ã®ã¿ã¤ãã夿´ï¼snapï¼é¾å¤å
-"ã®ï¼ã©ã¤ã³ãã交ç¹ãç¹ãï¼rmdacï¼ã¨ãªã¢ã®éè¤ããã»ã³ããã¤ããåé¤ ('type' "
-"ãªãã·ã§ã³ã¯ç¡è¦ããã¾ã)ï¼bpolï¼ããªã´ã³ãè§£æ¶ (å°å½¢çã«ã¯ãªã¼ãã³ã°) "
-"(ã·ã§ã¼ããã¡ã¤ã«ã®ãããªå°å½¢ã§ãªããã©ã¼ãããããã¤ã³ãã¼ã). å¢çã¯ï¼ã»ã°"
-"ã¡ã³ãã®è§åº¦ãç°ãªã2ã¤ä»¥ä¸ã®ããªã´ã³ã§å
±æãããåãã¤ã³ãã§ï¼è§£æ¶ãããï¼"
-"pruneï¼é¾å¤å
ã®ã©ã¤ã³ã¨å¢çããã®äº¤ç¹ãåé¤ï¼ å°å½¢ãç ´æãã¦ããªããã°å¢çã¯"
-"åãé¤ããã¾ã (æ°ãã交ç¹ï¼ 夿´ãããã»ã³ããã¤ããæ·»ä»)ï¼ æåã¨æå¾ã®å¢ç"
-"ã®ã»ã°ã¡ã³ãã¯å¤æ´ããã¾ããï¼rmareaï¼å°ããã¨ãªã¢ãåé¤ï¼ 飿¥ããã¨ãªã¢ã¨æ"
-"é·ã®å¢çã¯åé¤ï¼rmlineï¼remove é·ã0ã®å
¨ã¦ã®ã©ã¤ã³ã¨å¢çãåé¤ï¼é¾å¤ã¯ç¡è¦ã"
-"ãã¾ãï¼rmsaï¼ãã¼ãã®ã©ã¤ã³éã®å°ããè§åº¦ãåé¤"
+msgid "break;break lines at each intersection;rmdupl;remove duplicate geometry features (pay attention to categories!);rmdangle;remove dangles, threshold ignored if < 0;chdangle;change the type of boundary dangle to line, threshold ignored if < 0, input line type is ignored;rmbridge;remove bridges connecting area and island or 2 islands;chbridge;change the type of bridges connecting area and island or 2 islands from boundary to line;snap;snap lines to vertex in threshold;rmdac;remove duplicate area centroids ('type' option ignored);bpol;break (topologically clean) polygons (imported from non topological format, like ShapeFile). Boundaries are broken on each point shared between 2 and more polygons where angles of segments are different;prune;remove vertices in threshold from lines and boundaries, boundary is pruned only if topology is not damaged (new intersection, changed attachement of centroid), first and last segment of the boundary is never changed;rmarea;remove small a
reas, the longest boundary with adjacent area is removed;rmline;remove all lines or boundaries of zero length, threshold is ignored;rmsa;remove small angles between lines at nodes"
+msgstr "breakï¼ å
¨ã¦ã®äº¤ç¹ã§ã©ã¤ã³ãåæï¼rmduplï¼åãå½¢ç¶ã®ãã£ã¼ãã£ã¼ãåé¤ (ã«ãã´ãªã¼ã«æ³¨æï¼)ï¼rmdangleï¼ãã³ã°ã«ãåé¤ï¼ãã < 0 ãªãã°é¾å¤ãç¡è¦ï¼chdangleï¼ã©ã¤ã³ã¸ã®å¢çã®ãã³ã°ã«ã®ã¿ã¤ãã夿ï¼ãã < 0 ãªãã°é¾å¤ãç¡è¦ãã¦æå®ãããã©ã¤ã³ã¿ã¤ãã¯ç¡è¦ï¼rmbridgeï¼ã¨ãªã¢ãå³¶ãçµã¶æ©ãåé¤ï¼chbridgeï¼å¢çããã©ã¤ã³ã®ï¼ã¨ãªã¢ãå³¶ãçµã¶æ©ã®ã¿ã¤ãã夿´ï¼snapï¼é¾å¤å
ã®ï¼ã©ã¤ã³ãã交ç¹ãç¹ãï¼rmdacï¼ã¨ãªã¢ã®éè¤ããã»ã³ããã¤ããåé¤ ('type' ãªãã·ã§ã³ã¯ç¡è¦ããã¾ã)ï¼bpolï¼ããªã´ã³ãè§£æ¶ (å°å½¢çã«ã¯ãªã¼ãã³ã°) (ã·ã§ã¼ããã¡ã¤ã«ã®ãããªå°å½¢ã§ãªããã©ã¼ãããããã¤ã³ãã¼ã). å¢çã¯ï¼ã»ã°ã¡ã³ãã®è§åº¦ãç°ãªã2ã¤ä»¥ä¸ã®ããªã´ã³ã§å
±æãããåãã¤ã³ãã§ï¼è§£æ¶ãããï¼pruneï¼é¾å¤å
ã®ã©ã¤ã³ã
¨å¢çããã®äº¤ç¹ãåé¤ï¼ å°å½¢ãç ´æãã¦ããªããã°å¢çã¯åãé¤ããã¾ã (æ°ãã交ç¹ï¼ 夿´ãããã»ã³ããã¤ããæ·»ä»)ï¼ æåã¨æå¾ã®å¢çã®ã»ã°ã¡ã³ãã¯å¤æ´ããã¾ããï¼rmareaï¼å°ããã¨ãªã¢ãåé¤ï¼ 飿¥ããã¨ãªã¢ã¨æé·ã®å¢çã¯åé¤ï¼rmlineï¼remove é·ã0ã®å
¨ã¦ã®ã©ã¤ã³ã¨å¢çãåé¤ï¼é¾å¤ã¯ç¡è¦ããã¾ãï¼rmsaï¼ãã¼ãã®ã©ã¤ã³éã®å°ããè§åº¦ãåé¤"
#: ../vector/v.clean/main.c:94
-msgid ""
-"Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
-msgstr ""
-"ãããã¦ãããã®é¾å¤ï¼ ä¸ã¤ã®å¤ãåãã¼ã«ã« (ããã©ã«ãï¼ 0.0[,0.0,...]) "
+msgid "Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
+msgstr "ãããã¦ãããã®é¾å¤ï¼ ä¸ã¤ã®å¤ãåãã¼ã«ã« (ããã©ã«ãï¼ 0.0[,0.0,...]) "
#: ../vector/v.clean/main.c:100
msgid "Don't build topology for the output vector"
@@ -28061,13 +26407,8 @@
msgstr "æåã®åå¸ "
#: ../vector/v.perturb/main.c:96
-msgid ""
-"Parameter(s) of distribution. If the distribution is uniform, only one "
-"parameter, the maximum, is needed. For a normal distribution, two "
-"parameters, the mean and standard deviation, are required."
-msgstr ""
-"ãã©ã¡ã¼ã¿ã¼åå¸. ããåå¸ãåä¸ã§ããã°æå¤§å¤ã®ã¿å¿
è¦. æ£è¦åå¸ã«ã¯ã2ã¤ã®ã"
-"ã©ã¡ã¼ã¿ã¼ãå¹³åå¤ããã¦æ¨æºåå·®ãå¿
è¦ã§ã. "
+msgid "Parameter(s) of distribution. If the distribution is uniform, only one parameter, the maximum, is needed. For a normal distribution, two parameters, the mean and standard deviation, are required."
+msgstr "ãã©ã¡ã¼ã¿ã¼åå¸. ããåå¸ãåä¸ã§ããã°æå¤§å¤ã®ã¿å¿
è¦. æ£è¦åå¸ã«ã¯ã2ã¤ã®ãã©ã¡ã¼ã¿ã¼ãå¹³åå¤ããã¦æ¨æºåå·®ãå¿
è¦ã§ã. "
#: ../vector/v.perturb/main.c:106
msgid "Minimum deviation in map units"
@@ -28110,13 +26451,8 @@
msgstr "ã¯ã©ã¹ã®åå²ã®ã¿ãåºå(min, max ãå«ã¾ãªã) "
#: ../vector/v.class/main.c:166
-msgid ""
-"The discontinuities algorithm indicates that some class breaks are not "
-"statistically significant at alpha=0.05. You are advised to reduce the "
-"number of classes."
-msgstr ""
-"ä¸é£ç¶ã¢ã«ã´ãªãºã ã¯ï¼alpha=0.05 ã§ã¯æ°åã®ã¯ã©ã¹åå²ã¯çµ±è¨çã«å½±é¿ãç¡ããã¨"
-"ã示ãã¦ãã¾ãï¼ããã¤ãã®ã¯ã©ã¹ã¯ã©ã¹æ°ãæ¸ãããã¨ããå§ããã¾ã"
+msgid "The discontinuities algorithm indicates that some class breaks are not statistically significant at alpha=0.05. You are advised to reduce the number of classes."
+msgstr "ä¸é£ç¶ã¢ã«ã´ãªãºã ã¯ï¼alpha=0.05 ã§ã¯æ°åã®ã¯ã©ã¹åå²ã¯çµ±è¨çã«å½±é¿ãç¡ããã¨ã示ãã¦ãã¾ãï¼ããã¤ãã®ã¯ã©ã¹ã¯ã©ã¹æ°ãæ¸ãããã¨ããå§ããã¾ã"
#: ../vector/v.class/main.c:193
#, c-format
@@ -28296,8 +26632,7 @@
#: ../vector/v.net.components/main.c:71
msgid "Computes strongly and weakly connected components in the network."
-msgstr ""
-"ãããã¯ã¼ã¯ä¸ã®æ¥ç¶ã®å¼±ãã³ã³ãã¼ãã³ãã¨å¼·ãã³ã³ãã¼ãã³ããè¨ç®ãã¾ã"
+msgstr "ãããã¯ã¼ã¯ä¸ã®æ¥ç¶ã®å¼±ãã³ã³ãã¼ãã³ãã¨å¼·ãã³ã³ãã¼ãã³ããè¨ç®ãã¾ã"
#: ../vector/v.net.components/main.c:85
msgid "weak;Weakly connected components;strong;Strongly connected components;"
@@ -28344,8 +26679,7 @@
#: ../vector/v.to.3d/trans3.c:102
#, c-format
msgid "Feature id %d has more categories. Using category %d."
-msgstr ""
-"ãã£ã¼ãã£ã¼ ID %d ã¯æ´ã«å¤ãã®ã«ãã´ãªã¼ãæã£ã¦ãã¾ãï¼ã«ãã´ãªã¼ %d ã使ç¨"
+msgstr "ãã£ã¼ãã£ã¼ ID %d ã¯æ´ã«å¤ãã®ã«ãã´ãªã¼ãæã£ã¦ãã¾ãï¼ã«ãã´ãªã¼ %d ã使ç¨"
#: ../vector/v.to.3d/trans2.c:98
msgid "Skipping feature without category"
@@ -28432,8 +26766,7 @@
msgstr "NULLå¤ã®èå¥å "
#: ../vector/v.db.select/main.c:89
-msgid ""
-"Print minimal region extent of selected vector features instead of attributes"
+msgid "Print minimal region extent of selected vector features instead of attributes"
msgstr "屿§ã®ä»£ããã«é¸æããããã¯ãã«ãã£ã¼ãã£ã¼ã®æå°é åç¯å²ãåºåãã¾ã"
#: ../vector/v.db.select/main.c:93 ../db/base/select.c:237
@@ -28446,12 +26779,8 @@
#: ../vector/v.db.select/main.c:141
#, c-format
-msgid ""
-"Unable to open vector map <%s> at topology level. Flag '%c' requires "
-"topology level."
-msgstr ""
-"ãã¯ãã«ããã <%s> ããããã¸ã¼æ°´æºã§éãã¾ãã. ãã©ãã° '%c' ã¯ãããã¸ã¼"
-"æ°´æºãè¦æ±ãã¦ãã¾ã. "
+msgid "Unable to open vector map <%s> at topology level. Flag '%c' requires topology level."
+msgstr "ãã¯ãã«ããã <%s> ããããã¸ã¼æ°´æºã§éãã¾ãã. ãã©ãã° '%c' ã¯ãããã¸ã¼æ°´æºãè¦æ±ãã¦ãã¾ã. "
#: ../vector/v.db.select/main.c:176
msgid "Unable to open select cursor"
@@ -28485,8 +26814,7 @@
#: ../vector/v.in.dxf/main.c:62
msgid "Converts files in DXF format to GRASS vector map format."
-msgstr ""
-"DXFãã©ã¼ãããã®ãã¡ã¤ã«ãGRASSãã¯ãã«ããããã©ã¼ãããã«å¤æãã¾ã. "
+msgstr "DXFãã©ã¼ãããã®ãã¡ã¤ã«ãGRASSãã¯ãã«ããããã©ã¼ãããã«å¤æãã¾ã. "
#: ../vector/v.in.dxf/main.c:66
msgid "Ignore the map extent of DXF file"
@@ -28629,16 +26957,11 @@
#: ../vector/v.net.salesman/main.c:99
msgid "Creates a cycle connecting given nodes (Traveling salesman problem)."
-msgstr ""
-"ä¸ãããããã¼ããæ¥ç¶ãããµã¤ã¯ã«ã使ãã¾ã (å·¡åã»ã¼ã«ã¹ãã³åé¡). "
+msgstr "ä¸ãããããã¼ããæ¥ç¶ãããµã¤ã¯ã«ã使ãã¾ã (å·¡åã»ã¼ã«ã¹ãã³åé¡). "
#: ../vector/v.net.salesman/main.c:101
-msgid ""
-"Note that TSP is NP-hard, heuristic algorithm is used by this module and "
-"created cycle may be sub optimal"
-msgstr ""
-"TSPã¯NP-hardã§ã, è¿ä¼¼ã¢ã«ã´ãªãºã ã¯ãã®ã¢ã¸ã¥ã¼ã«ã«ãã£ã¦ä½¿ç¨ããã¦ãã使"
-"ããããµã¤ã¯ã«ã¯æé©ã§ã¯ãªãããããã¾ãã"
+msgid "Note that TSP is NP-hard, heuristic algorithm is used by this module and created cycle may be sub optimal"
+msgstr "TSPã¯NP-hardã§ã, è¿ä¼¼ã¢ã«ã´ãªãºã ã¯ãã®ã¢ã¸ã¥ã¼ã«ã«ãã£ã¦ä½¿ç¨ããã¦ãã使ããããµã¤ã¯ã«ã¯æé©ã§ã¯ãªãããããã¾ãã"
#: ../vector/v.net.salesman/main.c:119
msgid "Node layer (used for cities)"
@@ -28646,9 +26969,7 @@
#: ../vector/v.net.salesman/main.c:130
msgid "Categories of points ('cities') on nodes (layer is specified by nlayer)"
-msgstr ""
-"ãã¼ãã«ããããã¤ã³ã ('é½å¸') ã®ã«ãã´ãªã¼(ã¬ã¤ã¤ã¼ã¯nlayerã«ãã£ã¦æå®ãã"
-"ã¦ãã¾ã) "
+msgstr "ãã¼ãã«ããããã¤ã³ã ('é½å¸') ã®ã«ãã´ãªã¼(ã¬ã¤ã¤ã¼ã¯nlayerã«ãã£ã¦æå®ããã¦ãã¾ã) "
#: ../vector/v.net.salesman/main.c:193
#, c-format
@@ -28666,8 +26987,7 @@
#: ../vector/v.to.points/main.c:175
msgid "Create points along input lines in new vector with 2 layers."
-msgstr ""
-"2ã¤ã®ã¬ã¤ã¤ã¼ã®æ°ãããã¯ãã«å
ã«ï¼æå®ããã©ã¤ã³ã«æ²¿ã£ã¦ãã¤ã³ãã使"
+msgstr "2ã¤ã®ã¬ã¤ã¤ã¼ã®æ°ãããã¯ãã«å
#: ../vector/v.to.points/main.c:182
msgid "Output vector map where points will be written"
@@ -28791,8 +27111,7 @@
"Unable to get point on line: cat = %d offset = %f (line length = %.15g)\n"
"%s"
msgstr ""
-"ã©ã¤ã³ä¸ãããã¤ã³ããåå¾ã§ãã¾ããï¼ cat = %d offset = %f (ã©ã¤ã³é· = "
-"%.15g)\n"
+"ã©ã¤ã³ä¸ãããã¤ã³ããåå¾ã§ãã¾ããï¼ cat = %d offset = %f (ã©ã¤ã³é· = %.15g)\n"
"%s "
#: ../vector/v.segment/main.c:194
@@ -29043,9 +27362,7 @@
msgstr "ã³ã³ããªã¯ãã解決ãã¦ãã¾ã"
#: ../vector/v.generalize/main.c:76
-msgid ""
-"vector, generalization, simplification, smoothing, displacement, network "
-"generalization"
+msgid "vector, generalization, simplification, smoothing, displacement, network generalization"
msgstr "ãã¯ãã«, ä¸è¬å, ç°¡ç´ å, ã¹ã ã¼ã¸ã³ã°, ç½®æ, ãããã¯ã¼ã¯æ±å "
#: ../vector/v.generalize/main.c:77
@@ -29053,26 +27370,8 @@
msgstr "ãã¯ãã«ã«åºã¥ãä¸è¬å"
#: ../vector/v.generalize/main.c:94
-msgid ""
-"douglas;Douglas-Peucker Algorithm;douglas_reduction;Douglas-Peucker "
-"Algorithm with reduction parameter;lang;Lang Simplification Algorithm;"
-"reduction;Vertex Reduction Algorithm eliminates points close to each other;"
-"reumann;Reumann-Witkam Algorithm;boyle;Boyle's Forward-Looking Algorithm;"
-"sliding_averaging;McMaster's Sliding Averaging Algorithm;distance_weighting;"
-"McMaster's Distance-Weighting Algorithm;chaiken;Chaiken's Algorithm;hermite;"
-"Interpolation by Cubic Hermite Splines;snakes;Snakes method for line "
-"smoothing;network;Network generalization;displacement;Displacement of lines "
-"close to each other;"
-msgstr ""
-"douglas;Douglas-Peucker ã¢ã«ã´ãªãºã ;douglas_reduction;縮å°ãã©ã¡ã¼ã¿ã¼ããã¤"
-"Douglas-Peucker ã¢ã«ã´ãªãºã ;lang;Lang Simplification ã¢ã«ã´ãªãºã ;縮å°;"
-"Vertex Reduction ã¢ã«ã´ãªãºã ã¯äºãã«è¿ããã¤ã³ããåé¤ãã¾ã;reumann;"
-"Reumann-Witkam ã¢ã«ã´ãªãºã ;remove_small;é¾å¤ã¨é¾å¤ããå°ããã¨ãªã¢ããçãã©"
-"ã¤ã³ãé¤å»;boyle;Boyle's Forward-Looking ã¢ã«ã´ãªãºã ;sliding_averaging;"
-"McMaster's Sliding Averaging ã¢ã«ã´ãªãºã ;distance_weighting;McMaster's "
-"Distance-Weighting ã¢ã«ã´ãªãºã ;chaiken;Chaiken's ã¢ã«ã´ãªãºã ;hermite;Cubic "
-"Hermite Splinesã«ããè£é;snakes;ã©ã¤ã³ã¹ã ã¼ã¸ã³ã°ã®ã¹ãã¼ã¯ã¡ã½ãã;ããã"
-"ã¯ã¼ã¯;ãããã¯ã¼ã¯æ±å;ç½®æ;äºãã«è¿ãã©ã¤ã³ã®ç½®æ;"
+msgid "douglas;Douglas-Peucker Algorithm;douglas_reduction;Douglas-Peucker Algorithm with reduction parameter;lang;Lang Simplification Algorithm;reduction;Vertex Reduction Algorithm eliminates points close to each other;reumann;Reumann-Witkam Algorithm;boyle;Boyle's Forward-Looking Algorithm;sliding_averaging;McMaster's Sliding Averaging Algorithm;distance_weighting;McMaster's Distance-Weighting Algorithm;chaiken;Chaiken's Algorithm;hermite;Interpolation by Cubic Hermite Splines;snakes;Snakes method for line smoothing;network;Network generalization;displacement;Displacement of lines close to each other;"
+msgstr "douglas;Douglas-Peucker ã¢ã«ã´ãªãºã ;douglas_reduction;縮å°ãã©ã¡ã¼ã¿ã¼ããã¤Douglas-Peucker ã¢ã«ã´ãªãºã ;lang;Lang Simplification ã¢ã«ã´ãªãºã ;縮å°;Vertex Reduction ã¢ã«ã´ãªãºã ã¯äºãã«è¿ããã¤ã³ããåé¤ãã¾ã;reumann;Reumann-Witkam ã¢ã«ã´ãªãºã ;remove_small;é¾å¤ã¨é¾å¤ããå°ããã¨ãªã¢ããçãã©ã¤ã³ãé¤å»;boyle;Boyle's Forward-Looking ã¢ã«ã´ãªãºã ;sliding_averaging;McMaster's Sliding Averaging ã¢ã«ã´ãªãºã ;distance_weighting;McMaster's Distance-Weighting ã¢ã«ã´ãªãºã ;chaiken;Chaiken's ã¢ã«ã´ãªãºã ;hermite;Cubic Hermite Splinesã«ããè£é;snakes;ã©ã¤ã³ã¹ã ã¼ã¸ã³ã°ã®ã¹ãã¼ã¯ã¡ã½ãã;ãããã¯ã¼ã¯;ãããã¯ã¼ã¯æ±å;ç½®æ;äºãã«è¿ãã©ã¤ã³ã®ç½®æ;"
#: ../vector/v.generalize/main.c:108
msgid "Generalization algorithm"
@@ -29159,8 +27458,7 @@
#: ../vector/v.generalize/main.c:494
#, c-format
-msgid ""
-"%d boundaries were not modified because modification would damage topology"
+msgid "%d boundaries were not modified because modification would damage topology"
msgstr "å°å½¢ãç ´æããå¯è½æ§ãããããï¼%d ã®å¢çãåãè©°ãããã¾ããã§ãã"
#: ../vector/v.generalize/main.c:497
@@ -29175,19 +27473,15 @@
#: ../vector/v.generalize/main.c:513
msgid "reduced"
-msgstr ""
+msgstr "æ¸å°"
msgid "changed"
-msgstr "è¡ã®å¤æ´"
+msgstr "夿´"
#: ../vector/v.vol.rst/main.c:204
-msgid ""
-"Interpolates point data to a 3D raster map using regularized spline with "
-"tension (RST) algorithm."
-msgstr ""
-"ãã³ã·ã§ã³ (RST) ã¢ã«ã´ãªãºã ã®æ£è¦åã¹ãã©ã¤ã³æ²ç·ã使ã£ã¦ï¼ãã¤ã³ããã¼ã¿ã"
-"3Dã°ãªããããªã¥ã¼ã ã¸æ¿å
+msgid "Interpolates point data to a 3D raster map using regularized spline with tension (RST) algorithm."
+msgstr "ãã³ã·ã§ã³ (RST) ã¢ã«ã´ãªãºã ã®æ£è¦åã¹ãã©ã¤ã³æ²ç·ã使ã£ã¦ï¼ãã¤ã³ããã¼ã¿ã3Dã°ãªããããªã¥ã¼ã ã¸æ¿å
#: ../vector/v.vol.rst/main.c:237
msgid "Name of the vector map with input x,y,z,w"
@@ -29287,8 +27581,7 @@
msgstr "wã®åã¯ãµãã¼ããããåã®åã§ã¯ããã¾ãã (æ´æ°ãå精度ãæå¹) "
#: ../vector/v.vol.rst/user1.c:126
-msgid ""
-"Column type of smooth column is not supported (must be integer or double)"
+msgid "Column type of smooth column is not supported (must be integer or double)"
msgstr "å¹³æ»ååã®åã®åã¯ãµãã¼ãããã¦ãã¾ããï¼æ´æ°ãå精度ãæå¹ï¼ "
#: ../vector/v.to.rast3/main.c:45
@@ -29296,12 +27589,8 @@
msgstr "ãã¯ãã«, ããªã¥ã¼ã , 夿 "
#: ../vector/v.to.rast3/main.c:46
-msgid ""
-"Converts a binary GRASS vector map (only points) layer into a 3D GRASS "
-"raster map layer."
-msgstr ""
-"ãã¤ããªGRASSãã¯ãã«ãããï¼ãã¤ã³ãã®ã¿ï¼ã¬ã¤ã¤ã¼ã3D GRASSã©ã¹ã¿ã¼ãããã¬"
-"ã¤ã¤ã¼ã«å¤æãã¾ã. "
+msgid "Converts a binary GRASS vector map (only points) layer into a 3D GRASS raster map layer."
+msgstr "ãã¤ããªGRASSãã¯ãã«ãããï¼ãã¤ã³ãã®ã¿ï¼ã¬ã¤ã¤ã¼ã3D GRASSã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ã«å¤æãã¾ã. "
#: ../vector/v.to.rast3/main.c:59
msgid "Column name (type must be numeric)"
@@ -29354,10 +27643,8 @@
#: ../vector/v.label.sa/labels.c:223
#, c-format
-msgid ""
-"Cannot load overlap weights. Column %s is not of numeric type in table <%s>"
-msgstr ""
-"éè¤ããã¦ã§ã¼ãããã¼ãã§ãã¾ãã. 表 <%s> ã®å %s ã¯æ°å¤åã§ã¯ããã¾ãã "
+msgid "Cannot load overlap weights. Column %s is not of numeric type in table <%s>"
+msgstr "éè¤ããã¦ã§ã¼ãããã¼ãã§ãã¾ãã. 表 <%s> ã®å %s ã¯æ°å¤åã§ã¯ããã¾ãã "
#: ../vector/v.label.sa/labels.c:281
#, c-format
@@ -29381,11 +27668,8 @@
msgstr "å¢çå¹
(ps.ãããåºåã®ããã®ã¿) "
#: ../vector/v.label.sa/main.c:207
-msgid ""
-"Numeric column to give precedence in case of overlapping labels. The label "
-"with a smaller weight is hidden."
-msgstr ""
-"éè¤ããã©ãã«ã«åªå
権ãä¸ããæ°å¤å. ä½ã¦ã§ã¼ãã®ã©ãã«ã¯é ããã¦ãã¾ã. "
+msgid "Numeric column to give precedence in case of overlapping labels. The label with a smaller weight is hidden."
+msgstr "éè¤ããã©ãã«ã«åªå
#: ../vector/v.label.sa/font.c:55
#, c-format
@@ -29402,11 +27686,8 @@
msgstr "ãã¯ãã«ãã¤ã³ãã¼ãããã¼ã¿ãã¼ã¹ããã¤ã³ã"
#: ../vector/v.in.db/main.c:54
-msgid ""
-"Creates new vector (points) map from database table containing coordinates."
-msgstr ""
-"座æ¨ãå«ããã¼ã¿ãã¼ã¹è¡¨ããæ°ãããã¯ãã«ï¼ãã¤ã³ãï¼ãããã使ãã¦ä¸ã"
-"ã. "
+msgid "Creates new vector (points) map from database table containing coordinates."
+msgstr "座æ¨ãå«ããã¼ã¿ãã¼ã¹è¡¨ããæ°ãããã¯ãã«ï¼ãã¤ã³ãï¼ãããã使ãã¦ä¸ãã. "
#: ../vector/v.in.db/main.c:58
msgid "Input table name"
@@ -29435,11 +27716,8 @@
#: ../vector/v.in.db/main.c:130
#, c-format
-msgid ""
-"Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
-msgstr ""
-"åºåãã¯ãã«ããã, 表 <%s> (ãã©ã¤ãã¼: <%s>, ãã¼ã¿ãã¼ã¹: <%s>) æ¢ã«åå¨ã"
-"ã¾ã "
+msgid "Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
+msgstr "åºåãã¯ãã«ããã, 表 <%s> (ãã©ã¤ãã¼: <%s>, ãã¼ã¿ãã¼ã¹: <%s>) æ¢ã«åå¨ãã¾ã "
#: ../vector/v.in.db/main.c:173
msgid "Writing features..."
@@ -29459,11 +27737,8 @@
msgstr "ãã¯ãã«ãããã«æ¸ãè¾¼ã¾ãããã¤ã³ã. %d "
#: ../vector/v.surf.idw/main.c:86
-msgid ""
-"Surface interpolation from vector point data by Inverse Distance Squared "
-"Weighting."
-msgstr ""
-"Inverse Distance Squared å éã«ãããã¯ãã«ãã¤ã³ããã¼ã¿ãã§ã®æ²é¢è£é"
+msgid "Surface interpolation from vector point data by Inverse Distance Squared Weighting."
+msgstr "Inverse Distance Squared å éã«ãããã¯ãã«ãã¤ã³ããã¼ã¿ãã§ã®æ²é¢è£é"
#: ../vector/v.surf.idw/main.c:95
msgid "If set to 0, z coordinates are used (3D vector only)"
@@ -29482,8 +27757,7 @@
msgstr "ã¬ã¤ã¤ã¼ã0ãã大ããå ´åã«è¦æ±"
#: ../vector/v.surf.idw/main.c:122
-msgid ""
-"Power parameter; greater values assign greater influence to closer points"
+msgid "Power parameter; greater values assign greater influence to closer points"
msgstr "ãã¯ã¼ãã©ã¡ã¼ã¿ã¼ï¼ 大ããªå¤ã¯è¿ããã¤ã³ãã¸ã®å¤§ããå½±é¿ãæå®ãã¾ã"
#: ../vector/v.surf.idw/main.c:127
@@ -29491,12 +27765,8 @@
msgstr "ã©ã¹ã¿ã¼ã»ã«ã«ãããã¤ã³ãã®ã¤ã³ããã¯ã¹ãè¡ããªã"
#: ../vector/v.surf.idw/main.c:128
-msgid ""
-"Slower but uses less memory and includes points from outside region in the "
-"interpolation"
-msgstr ""
-"Slower but uses less memory and includes ãã¤ã³ã from outside é å in the è£"
-"é "
+msgid "Slower but uses less memory and includes points from outside region in the interpolation"
+msgstr "Slower but uses less memory and includes ãã¤ã³ã from outside é å in the è£é "
#: ../vector/v.surf.idw/main.c:147
msgid "No attribute column specified"
@@ -29628,11 +27898,8 @@
msgstr "ã¨ã©ã¼ã®ããï¼å±æ§ã-ã¿ã¯æ°ãããããã¸ç§»åãã¾ãã"
#: ../vector/v.drape/main.c:425
-msgid ""
-"No features drapped. Check Your computational region and input raster map."
-msgstr ""
-"drappedãããããã£ã¼ãã£ã¼ãããã¾ããï¼è¨ç®é åã¨æå®ããã©ã¹ã¿ã¼ãããã確"
-"èªãã¦ä¸ãã"
+msgid "No features drapped. Check Your computational region and input raster map."
+msgstr "drappedãããããã£ã¼ãã£ã¼ãããã¾ããï¼è¨ç®é åã¨æå®ããã©ã¹ã¿ã¼ãããã確èªãã¦ä¸ãã"
#: ../vector/v.net.path/path.c:82
#, c-format
@@ -29647,9 +27914,7 @@
#: ../vector/v.net.path/path.c:205
#, c-format
msgid "Point with category [%d] is not reachable from point with category [%d]"
-msgstr ""
-"ã«ãã´ãªã¼ä»ãã®ãã¤ã³ã [%d] ã¯ã«ãã´ãªã¼ä»ãã®ãã¤ã³ã [%d] ããå°éã§ãã¾"
-"ãã"
+msgstr "ã«ãã´ãªã¼ä»ãã®ãã¤ã³ã [%d] ã¯ã«ãã´ãªã¼ä»ãã®ãã¤ã³ã [%d] ããå°éã§ãã¾ãã"
#: ../vector/v.net.path/path.c:262
#, c-format
@@ -29676,8 +27941,7 @@
msgstr "ãã¯ãã«ãããã¯ã¼ã¯ã®æççµè·¯ãæ¢ç´¢"
#: ../vector/v.net.path/main.c:65
-msgid ""
-"Name of file containing start and end points. If not given, read from stdin"
+msgid "Name of file containing start and end points. If not given, read from stdin"
msgstr "å§ç¹ã¨çµç¹ãå«ããã¡ã¤ã«åï¼æå®ãç¡ãå ´åã¯æ¨æºå
¥åããèªã¿è¾¼ã"
#: ../vector/v.net.path/main.c:92
@@ -29685,20 +27949,12 @@
msgstr "ãããã¯ã¼ã¯ã¸ã®æå¤§è·é¢"
#: ../vector/v.net.path/main.c:93
-msgid ""
-"If start/end are given as coordinates. If start/end point is outside this "
-"threshold, the path is not found and error message is printed. To speed up "
-"the process, keep this value as low as possible."
-msgstr ""
-"å§ç¹ã»çµç¹åº§æ¨ãä¸ããããå ´åï¼ã¾ãã¯å§ç¹ã»çµç¹ãé¾å¤å¤ã®å ´åã«ã¯ï¼çµè·¯ãè¦"
-"ã¤ãããã¨ãã§ããã¨ã©ã¼ã¡ãã»ã¼ã¸ãåºåãã¾ãï¼å¦çãé«éã«ãããå ´åï¼ãã®"
-"å¤ã¯ã§ããéãå°ãããã¦ãã ãã"
+msgid "If start/end are given as coordinates. If start/end point is outside this threshold, the path is not found and error message is printed. To speed up the process, keep this value as low as possible."
+msgstr "å§ç¹ã»çµç¹åº§æ¨ãä¸ããããå ´åï¼ã¾ãã¯å§ç¹ã»çµç¹ãé¾å¤å¤ã®å ´åã«ã¯ï¼çµè·¯ãè¦ã¤ãããã¨ãã§ããã¨ã©ã¼ã¡ãã»ã¼ã¸ãåºåãã¾ãï¼å¦çãé«éã«ãããå ´åï¼ãã®å¤ã¯ã§ããéãå°ãããã¦ãã ãã"
#: ../vector/v.net.path/main.c:106
msgid "Write output as original input segments, not each path as one line."
-msgstr ""
-"åçµè·¯ãä¸ã¤ã®ã©ã¤ã³ã¨ãã¦ã§ã¯ãªãï¼ åºåããªãªã¸ãã«ã®æå®ã»ã°ã¡ã³ãã¨ãã¦æ¸"
-"ãè¾¼ã"
+msgstr "åçµè·¯ãä¸ã¤ã®ã©ã¤ã³ã¨ãã¦ã§ã¯ãªãï¼ åºåããªãªã¸ãã«ã®æå®ã»ã°ã¡ã³ãã¨ãã¦æ¸ãè¾¼ã"
#: ../vector/v.net.connectivity/main.c:53
msgid "vector, network, connectivity"
@@ -29874,14 +28130,8 @@
msgstr "ã©ã¹ã¿ã¼å¤ã®ã½ã¼ã¹"
#: ../vector/v.to.rast/main.c:61
-msgid ""
-"attr;read values from attribute table;cat;use category values;val;use value "
-"specified by value option;z;use z coordinate (points or contours only);dir;"
-"output as flow direction (lines only)"
-msgstr ""
-"attrï¼å±æ§ãã¼ãã«ããå¤ãèªã¿è¾¼ãï¼catï¼ã«ãã´ãªã¼å¤ã使ç¨ï¼valï¼å¤ãvalueãª"
-"ãã·ã§ã³ã§æå®ï¼zï¼z 座æ¨ãä½¿ç¨ (ãã¤ã³ãã¾ãã¯ã«ã¦ã³ã¿ã¼ã®ã¿)ï¼dir;æµãæ¹å"
-"ã«åºå (ã©ã¤ã³ã®ã¿) "
+msgid "attr;read values from attribute table;cat;use category values;val;use value specified by value option;z;use z coordinate (points or contours only);dir;output as flow direction (lines only)"
+msgstr "attrï¼å±æ§ãã¼ãã«ããå¤ãèªã¿è¾¼ãï¼catï¼ã«ãã´ãªã¼å¤ã使ç¨ï¼valï¼å¤ãvalueãªãã·ã§ã³ã§æå®ï¼zï¼z 座æ¨ãä½¿ç¨ (ãã¤ã³ãã¾ãã¯ã«ã¦ã³ã¿ã¼ã®ã¿)ï¼dir;æµãæ¹åã«åºå (ã©ã¤ã³ã®ã¿) "
#: ../vector/v.to.rast/main.c:70
msgid "Name of column for 'attr' parameter (data type must be numeric)"
@@ -29948,10 +28198,8 @@
msgstr "ã«ãã´ãªã¼ãªãã®ï¼ã¨ãªã¢ã®ã»ã³ããã¤ã"
#: ../vector/v.out.vtk/writeVTK.c:187
-msgid ""
-"No coordinates to generate the output! Maybe an empty vector type chosen?"
-msgstr ""
-"åºåã使ãã座æ¨ãããã¾ãã! 空ã®ãã¯ãã«ã¿ã¤ãã鏿ããã¦ãã¾ããã? "
+msgid "No coordinates to generate the output! Maybe an empty vector type chosen?"
+msgstr "åºåã使ãã座æ¨ãããã¾ãã! 空ã®ãã¯ãã«ã¿ã¤ãã鏿ããã¦ãã¾ããã? "
#: ../vector/v.out.vtk/writeVTK.c:622
msgid "Cannot export attribute table fields for layer < 1. Skipping export"
@@ -30039,12 +28287,8 @@
#: ../db/drivers/ogr/describe.c:157
#, c-format
-msgid ""
-"column '%s', type 'string': unknown width -> stored as varchar(250) some "
-"data may be lost"
-msgstr ""
-"å '%s', ã¿ã¤ã 'string': 䏿ãªå¹
-> varchar(250)ã¨ãã¦ä¿åãããããã¤ãã®"
-"ãã¼ã¿ã¯ç´å¤±ãã¦ãã¾ã "
+msgid "column '%s', type 'string': unknown width -> stored as varchar(250) some data may be lost"
+msgstr "å '%s', ã¿ã¤ã 'string': 䏿ãªå¹
-> varchar(250)ã¨ãã¦ä¿åãããããã¤ãã®ãã¼ã¿ã¯ç´å¤±ãã¦ãã¾ã "
#: ../db/drivers/mysql/cursor.c:46
msgid "Cannot allocate cursor."
@@ -30112,14 +28356,11 @@
#: ../db/drivers/mysql/parse.c:71 ../db/drivers/postgres/parse.c:55
msgid "'user' in database definition is not supported, use db.login"
-msgstr ""
-"ãã¼ã¿ãã¼ã¹ä¸ã®'user'ã®å®ç¾©ã¯ãµãã¼ãããã¾ããï¼db.loginã使ç¨ãã¦ãã ãã"
+msgstr "ãã¼ã¿ãã¼ã¹ä¸ã®'user'ã®å®ç¾©ã¯ãµãã¼ãããã¾ããï¼db.loginã使ç¨ãã¦ãã ãã"
#: ../db/drivers/mysql/parse.c:75 ../db/drivers/postgres/parse.c:59
msgid "'password' in database definition is not supported, use db.login"
-msgstr ""
-"ãã¼ã¿ãã¼ã¹ä¸ã®'password'ã®å®ç¾©ã¯ãµãã¼ãããã¾ããï¼db.loginã使ç¨ãã¦ä¸ã"
-"ã"
+msgstr "ãã¼ã¿ãã¼ã¹ä¸ã®'password'ã®å®ç¾©ã¯ãµãã¼ãããã¾ããï¼db.loginã使ç¨ãã¦ä¸ãã"
#: ../db/drivers/mysql/parse.c:79
msgid "Unknown option in database definition for "
@@ -30132,12 +28373,8 @@
#: ../db/drivers/mysql/describe.c:126
#, c-format
-msgid ""
-"column '%s' : type BIGINT is stored as integer (4 bytes) some data may be "
-"damaged"
-msgstr ""
-"å '%s' : ã¿ã¤ã BIGINT æ´æ° (4 ãã¤ã)ã¨ãã¦ä¿åãããããã¤ãã®ãã¼ã¿ã¯å£ã"
-"ã¦ãã¾ã"
+msgid "column '%s' : type BIGINT is stored as integer (4 bytes) some data may be damaged"
+msgstr "å '%s' : ã¿ã¤ã BIGINT æ´æ° (4 ãã¤ã)ã¨ãã¦ä¿åãããããã¤ãã®ãã¼ã¿ã¯å£ãã¦ãã¾ã"
#: ../db/drivers/mysql/select.c:43
msgid "Cannot select data: \n"
@@ -30163,30 +28400,18 @@
#: ../db/drivers/postgres/describe.c:116
#, c-format
-msgid ""
-"column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data "
-"may be damaged"
-msgstr ""
-"å '%s' ï¼ å int8 (bigint) ã¯æ´æ° (4 bytes) ã¨ãã¦ä¿ç®¡ããã¾ãï¼ãã¼ã¿ãç ´æ"
-"ããæããããã¾ã"
+msgid "column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data may be damaged"
+msgstr "å '%s' ï¼ å int8 (bigint) ã¯æ´æ° (4 bytes) ã¨ãã¦ä¿ç®¡ããã¾ãï¼ãã¼ã¿ãç ´æããæããããã¾ã"
#: ../db/drivers/postgres/describe.c:120
#, c-format
-msgid ""
-"column '%s' : type character varying is stored as varchar(250) some data may "
-"be lost"
-msgstr ""
-"å '%s' ï¼ å character 㯠varchar(250) ã¨ãã¦å¤æãã¦ä¿ç®¡ããã¾ãï¼ãã¼ã¿ã"
-"失ãæããããã¾ã"
+msgid "column '%s' : type character varying is stored as varchar(250) some data may be lost"
+msgstr "å '%s' ï¼ å character 㯠varchar(250) ã¨ãã¦å¤æãã¦ä¿ç®¡ããã¾ãï¼ãã¼ã¿ã失ãæããããã¾ã"
#: ../db/drivers/postgres/describe.c:126
#, c-format
-msgid ""
-"column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 "
-"(true)"
-msgstr ""
-"å '%s' ï¼ å bool (boolean) 㯠char(1) ã¨ãã¦ä¿ç®¡ããã¾ãï¼ valuesï¼ 0 "
-"(false)ï¼ 1 (true)"
+msgid "column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 (true)"
+msgstr "å '%s' ï¼ å bool (boolean) 㯠char(1) ã¨ãã¦ä¿ç®¡ããã¾ãï¼ valuesï¼ 0 (false)ï¼ 1 (true)"
#: ../db/drivers/sqlite/db.c:85
msgid "Unable to open database: "
@@ -30257,11 +28482,8 @@
msgstr "ãã¼ã¿ãã¼ã¹ã¹ãã¼ã"
#: ../db/base/connect.c:75
-msgid ""
-"Do not use this option if schemas are not supported by driver/database server"
-msgstr ""
-"ãã©ã¤ãã¼/ãã¼ã¿ãã¼ã¹ã«ãã£ã¦ãµãã¼ãããã¦ããªãã¹ãã¼ãã®å ´åã¯ãªãã·ã§ã³"
-"ã使ç¨ããªãã§ãã ãã"
+msgid "Do not use this option if schemas are not supported by driver/database server"
+msgstr "ãã©ã¤ãã¼/ãã¼ã¿ãã¼ã¹ã«ãã£ã¦ãµãã¼ãããã¦ããªãã¹ãã¼ãã®å ´åã¯ãªãã·ã§ã³ã使ç¨ããªãã§ãã ãã"
#: ../db/base/connect.c:85
msgid "Default group of database users to which select privilege is granted"
@@ -30352,12 +28574,8 @@
msgstr "ãã¼ãã«ã®ã³ãã¼"
#: ../db/base/copy.c:40
-msgid ""
-"Either 'from_table' (optionally with 'where') can be used or 'select' "
-"option, but not 'from_table' and 'select' at the same time."
-msgstr ""
-"from_table' (ä»»æã§'where'ã使ç¨) ã 'select' ãªãã·ã§ã³ã使ç¨ã§ãã¾ããã "
-"'from_table'㨠'select'ã¯åæã«ä½¿ããã¾ãã"
+msgid "Either 'from_table' (optionally with 'where') can be used or 'select' option, but not 'from_table' and 'select' at the same time."
+msgstr "from_table' (ä»»æã§'where'ã使ç¨) ã 'select' ãªãã·ã§ã³ã使ç¨ã§ãã¾ããã 'from_table'㨠'select'ã¯åæã«ä½¿ããã¾ãã"
#: ../db/base/copy.c:46
msgid "Input driver name"
@@ -30450,7 +28668,7 @@
#: ../db/base/select.c:256
msgid "Selects data from attribute table (performs SQL query statement(s))."
-msgstr ""
+msgstr "屿§ãã¼ãã«ãããã¼ã¿ãåå¾(SQLã¯ã¨ãªã¼ãå®è¡ãã¾ã)."
#: ../db/db.login/main.c:43
msgid "database, connection settings"
@@ -30513,12 +28731,8 @@
msgstr "ã¦ã£ã³ãã¦ã®æ°ããé«ã"
#: ../locale/scriptstrings/v.in.gns_to_translate.c:1
-msgid ""
-"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
-"points map."
-msgstr ""
-"US-NGA GEOnet Names Server (GNS) ã«ã³ããªã¼ãã¡ã¤ã«ãGRASSãã¯ãã«ãã¤ã³ã"
-"ãããã¸ã¤ã³ãã¼ã"
+msgid "Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector points map."
+msgstr "US-NGA GEOnet Names Server (GNS) ã«ã³ããªã¼ãã¡ã¤ã«ãGRASSãã¯ãã«ãã¤ã³ããããã¸ã¤ã³ãã¼ã"
#: ../locale/scriptstrings/v.in.gns_to_translate.c:2
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:2
@@ -30560,12 +28774,8 @@
msgstr "表示ãããããã¥ã¢ã«å
¥å"
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:1
-msgid ""
-"Calculates univariate statistics from a raster map based on vector polygons "
-"and uploads statistics to new attribute columns."
-msgstr ""
-"ãã¯ãã«ããªã´ã³ã¨ã¢ãããã¼ããããçµ±è¨ããã¼ã¹ã«ããGRASSã©ã¹ã¿ã¼ããããã"
-"æ°ãã屿§åã¸ä¸å¤éã®çµ±è¨ãè¨ç®ãã"
+msgid "Calculates univariate statistics from a raster map based on vector polygons and uploads statistics to new attribute columns."
+msgstr "ãã¯ãã«ããªã´ã³ã¨ã¢ãããã¼ããããçµ±è¨ããã¼ã¹ã«ããGRASSã©ã¹ã¿ã¼ãããããæ°ãã屿§åã¸ä¸å¤éã®çµ±è¨ãè¨ç®ãã"
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:2
msgid "vector, raster, statistics"
@@ -30580,12 +28790,8 @@
msgstr "ãã¯ãã«ããªã´ã³ãããå"
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:6
-msgid ""
-"A single vector map can be connected to multiple database tables. This "
-"number determines which table to use"
-msgstr ""
-"åç¬ã®ãã¯ãã«ãããã¯å¤æ°ã®ãã¼ã¿ãã¼ã¹ãã¼ãã«ã«æ¥ç¶ããã¦ããªããã°ãªãã¾"
-"ããããã®æ°å¤ã¯ã©ã®ãã¼ãã«ã使ç¨ãã¦ãããæ±ºå®ãã¾ã"
+msgid "A single vector map can be connected to multiple database tables. This number determines which table to use"
+msgstr "åç¬ã®ãã¯ãã«ãããã¯å¤æ°ã®ãã¼ã¿ãã¼ã¹ãã¼ãã«ã«æ¥ç¶ããã¦ããªããã°ãªãã¾ããããã®æ°å¤ã¯ã©ã®ãã¼ãã«ã使ç¨ãã¦ãããæ±ºå®ãã¾ã"
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:7
msgid "Name of raster map to calculate statistics from"
@@ -30834,8 +29040,7 @@
msgstr "æ°´å¹³ã¦ãããããæ¨é«ã¦ãããã¸ã®å¤æåç"
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:9
-msgid ""
-"Set scaling factor (applies to lat./long. locations only, none: scale=1)"
+msgid "Set scaling factor (applies to lat./long. locations only, none: scale=1)"
msgstr "åçãè¨å® (緯度./çµåº¦ ãã±ã¼ã·ã§ã³ã®ã¿é©ç¨ããªã: ã¹ã±ã¼ã«=1) "
#: ../locale/scriptstrings/d.redraw_to_translate.c:1
@@ -30871,12 +29076,8 @@
msgstr "å¤ããã¼ã¿ãã¼ã¹å"
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:4
-msgid ""
-"The database must be in form printed by v.db.connect -g, i.e. with "
-"substituted variables"
-msgstr ""
-"ãã¼ã¿ãã¼ã¹ã¯ç½®æå¤æ°ã¨ã¨ãã«v.db.connect -g, i.e. ã¨åºåããããã©ã¼ã ã®ä¸"
-"ã«ãªãã¨ããã¾ããã "
+msgid "The database must be in form printed by v.db.connect -g, i.e. with substituted variables"
+msgstr "ãã¼ã¿ãã¼ã¹ã¯ç½®æå¤æ°ã¨ã¨ãã«v.db.connect -g, i.e. ã¨åºåããããã©ã¼ã ã®ä¸ã«ãªãã¨ããã¾ããã "
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
msgid "Name of new database"
@@ -30892,8 +29093,7 @@
#: ../locale/scriptstrings/d.out.png_to_translate.c:1
msgid "Saves active display monitor to PNG file in home directory"
-msgstr ""
-"ã¢ã¯ãã£ããã£ã¹ãã¬ã¤ã¢ãã¿ã¼ããã¼ã ãã£ã¬ã¯ããªã®PNGãã¡ã¤ã«ã«ä¿åãã"
+msgstr "ã¢ã¯ãã£ããã£ã¹ãã¬ã¤ã¢ãã¿ã¼ããã¼ã ãã£ã¬ã¯ããªã®PNGãã¡ã¤ã«ã«ä¿åãã"
#: ../locale/scriptstrings/d.out.png_to_translate.c:2
#: ../locale/scriptstrings/d.out.file_to_translate.c:2
@@ -30919,9 +29119,7 @@
#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:3
msgid "Also import quality map (SM status map layer) and filter NDVI map"
-msgstr ""
-"æ§è³ªããã (SM ã¹ãã¼ã¿ã¹ãããã¬ã¤ã¤ã¼) ã¨ãã£ã«ã¿ã¼NDVIãããã«ãã¤ã³ãã¼"
-"ã "
+msgstr "æ§è³ªããã (SM ã¹ãã¼ã¿ã¹ãããã¬ã¤ã¤ã¼) ã¨ãã£ã«ã¿ã¼NDVIãããã«ãã¤ã³ãã¼ã "
#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:4
msgid "existing SPOT VGT NDVI HDF file (0001_NDV.HDF)"
@@ -31013,11 +29211,8 @@
msgstr "é åã®ç²¾åº¦ã®é«ãåºå"
#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:9
-msgid ""
-"Creation option to the output format driver. Multiple options may be listed"
-msgstr ""
-"åºåãããã©ã¼ããããã©ã¤ãã¼ã®ä½æãªãã·ã§ã³ï¼éè¤ãããªãã·ã§ã³ããªã¹ãã"
-"ãã¦ãã¾ã"
+msgid "Creation option to the output format driver. Multiple options may be listed"
+msgstr "åºåãããã©ã¼ããããã©ã¤ãã¼ã®ä½æãªãã·ã§ã³ï¼éè¤ãããªãã·ã§ã³ããªã¹ãããã¦ãã¾ã"
#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:10
msgid "Metadata key passed on the output dataset if possible"
@@ -31025,9 +29220,7 @@
#: ../locale/scriptstrings/v.db.univar_to_translate.c:1
#: ../locale/scriptstrings/v.univar.sh_to_translate.c:1
-msgid ""
-"Calculates univariate statistics on selected table column for a GRASS vector "
-"map."
+msgid "Calculates univariate statistics on selected table column for a GRASS vector map."
msgstr "GRASSãã¯ãã«ãããã®é¸æããããã¼ãã«åã®ä¸å¤éã®çµ±è¨ãè¨ç®ãã¾ã"
#: ../locale/scriptstrings/v.db.univar_to_translate.c:3
@@ -31077,8 +29270,7 @@
#: ../locale/scriptstrings/v.report_to_translate.c:8
msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
-msgstr ""
-"ãã¤ã«ããã£ã¼ããã¡ã¼ãã«ãããã¡ã¼ãã«ãã¨ã¼ã«ã¼ããã¯ã¿ã¼ã«ããã¼ã»ã³ã"
+msgstr "ãã¤ã«ããã£ã¼ããã¡ã¼ãã«ãããã¡ã¼ãã«ãã¨ã¼ã«ã¼ããã¯ã¿ã¼ã«ããã¼ã»ã³ã"
#: ../locale/scriptstrings/d.slide.show_to_translate.c:1
msgid "Slide show of GRASS raster/vector maps."
@@ -31153,12 +29345,8 @@
msgstr "GISããã¼ã¸ã£ã¼è¨å®ãã¡ã¤ã«å(.grc)"
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
-msgid ""
-"Reclasses a raster map greater or less than user specified area size (in "
-"hectares)."
-msgstr ""
-"ã©ã¹ã¿ã¼ããããã¦ã¼ã¶ã¼ãç¹å®ããã¨ãªã¢ãµã¤ãºãã大ããããããã¯å°ããåå"
-"é¡ããï¼ãã¯ã¿ã¼ã«ï¼"
+msgid "Reclasses a raster map greater or less than user specified area size (in hectares)."
+msgstr "ã©ã¹ã¿ã¼ããããã¦ã¼ã¶ã¼ãç¹å®ããã¨ãªã¢ãµã¤ãºãã大ããããããã¯å°ããååé¡ããï¼ãã¯ã¿ã¼ã«ï¼"
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:2
msgid "raster, statistics, aggregation"
@@ -31277,11 +29465,8 @@
msgstr "æ¨æºã®è²ã®ç¯å²ã¸ãªã»ãã"
#: ../locale/scriptstrings/i.spectral_to_translate.c:1
-msgid ""
-"Displays spectral response at user specified locations in group or images."
-msgstr ""
-"ã°ã«ã¼ããããã¯ç»åå
ã®ãã±ã¼ã·ã§ã³ãæç¢ºã«ããã¦ã¼ã¶ã¼ã«ã¹ãã¯ãã«æåº¦ã表"
-"示ãã"
+msgid "Displays spectral response at user specified locations in group or images."
+msgstr "ã°ã«ã¼ããããã¯ç»åå
ã®ãã±ã¼ã·ã§ã³ãæç¢ºã«ããã¦ã¼ã¶ã¼ã«ã¹ãã¯ãã«æåº¦ã表示ãã"
#: ../locale/scriptstrings/i.spectral_to_translate.c:2
msgid "imagery, raster, multispectral"
@@ -31312,17 +29497,12 @@
msgstr "çªå·ä»ãã®ä»£ããã«åº§æ¨ãã©ãã«ä»ããã"
#: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
-msgid ""
-"Export a raster map to a text file as x,y,z values based on cell centers."
-msgstr ""
-"ãã©ã¹ã¿ã¼ããããã»ã«ã®ä¸å¿ã®x,y,z å¤ã¨ããããã¹ããã¡ã¤ã«ã«ã¨ã¯ã¹ãã¼ã"
+msgid "Export a raster map to a text file as x,y,z values based on cell centers."
+msgstr "ãã©ã¹ã¿ã¼ããããã»ã«ã®ä¸å¿ã®x,y,z å¤ã¨ããããã¹ããã¡ã¤ã«ã«ã¨ã¯ã¹ãã¼ã"
#: ../locale/scriptstrings/r.plane_to_translate.c:1
-msgid ""
-"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
-"point."
-msgstr ""
-" ãã¼ã¿ (徿)ã æ¹ä½ (ã¢ã¸ãã¹) ã1ç¹ ãä¸ããããã©ã¹ã¿ã¼å¹³é¢ãããã®ä½æ"
+msgid "Creates raster plane map given dip (inclination), aspect (azimuth) and one point."
+msgstr " ãã¼ã¿ (徿)ã æ¹ä½ (ã¢ã¸ãã¹) ã1ç¹ ãä¸ããããã©ã¹ã¿ã¼å¹³é¢ãããã®ä½æ"
#: ../locale/scriptstrings/r.plane_to_translate.c:3
msgid "Name of raster plane to be created"
@@ -31392,20 +29572,15 @@
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:1
msgid "Imports geonames.org country files into a GRASS vector points map."
-msgstr ""
-"geonames.org ã«ã³ããªã¼ãã¡ã¤ã«ãGRASSãã¯ãã«ãã¤ã³ããããã«ã¤ã³ãã¼ã"
+msgstr "geonames.org ã«ã³ããªã¼ãã¡ã¤ã«ãGRASSãã¯ãã«ãã¤ã³ããããã«ã¤ã³ãã¼ã"
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:3
msgid "Uncompressed geonames file from (with .txt extension)"
msgstr "è§£åããã geonamesãã¡ã¤ã«( .txt æ¡å¼µå) "
#: ../locale/scriptstrings/v.in.garmin_to_translate.c:1
-msgid ""
-"Download waypoints, routes, and tracks from a Garmin GPS receiver into a "
-"vector map."
-msgstr ""
-"Garmin GPSã¬ã·ã¼ãã¼ãããã¯ãã«ãããã¸ã¦ã§ã¤ãã¤ã³ããã«ã¼ãããã©ãã¯ãã"
-"ã¦ã³ãã¼ããã"
+msgid "Download waypoints, routes, and tracks from a Garmin GPS receiver into a vector map."
+msgstr "Garmin GPSã¬ã·ã¼ãã¼ãããã¯ãã«ãããã¸ã¦ã§ã¤ãã¤ã³ããã«ã¼ãããã©ãã¯ããã¦ã³ãã¼ããã"
#: ../locale/scriptstrings/v.in.garmin_to_translate.c:2
#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:2
@@ -31446,11 +29621,8 @@
msgstr "Port Garmin ã¬ã·ã¼ãã¼ã¯æ¥ç¶ããã¦ãã¾ã"
#: ../locale/scriptstrings/r.in.aster_to_translate.c:1
-msgid ""
-"Georeference, rectify and import Terra-ASTER imagery and relative DEM's "
-"using gdalwarp."
-msgstr ""
-"å°çåç
§ãä¿®æ£ã¨Terra-ASTERç»åã¨GDALwarpã使ç¨ããè¿æ¥ã®DEMã®ã¤ã³ãã¼ã "
+msgid "Georeference, rectify and import Terra-ASTER imagery and relative DEM's using gdalwarp."
+msgstr "å°çåç
#: ../locale/scriptstrings/r.in.aster_to_translate.c:3
msgid "Input ASTER image to be georeferenced & rectified"
@@ -31461,12 +29633,8 @@
msgstr "ASTER ç»åå¦çã¿ã¤ã (ã¬ãã« 1A, ã¬ãã« 1B, ããã㯠ç¸å¯¾ DEM) "
#: ../locale/scriptstrings/r.in.aster_to_translate.c:5
-msgid ""
-"L1A or L1B band to translate (1, 2, 3n, 3b, 4-14). Can only translate a "
-"single band"
-msgstr ""
-"夿ããL1A ããã㯠L1B ãã³ã (1, 2, 3n, 3b, 4-14)ãåä¸ã®ãã³ãã¨ã®ã¿å¤æ"
-"ã§ãã¾ãã"
+msgid "L1A or L1B band to translate (1, 2, 3n, 3b, 4-14). Can only translate a single band"
+msgstr "夿ããL1A ããã㯠L1B ãã³ã (1, 2, 3n, 3b, 4-14)ãåä¸ã®ãã³ãã¨ã®ã¿å¤æã§ãã¾ãã"
#: ../locale/scriptstrings/db.droptable_to_translate.c:1
msgid "Drops an attribute table."
@@ -31566,8 +29734,7 @@
msgstr "追å ããGeoTIFF ã¡ã¿ãã¼ã¿ãã¼ã¨å¤ "
#: ../locale/scriptstrings/d.out.file_to_translate.c:24
-msgid ""
-"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma."
+msgid "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma."
msgstr " \"META-TAG=VALUE\"ã®ãã©ã¼ã ãã³ã³ãã§éè¤ããé
ç®ãåãã"
#: ../locale/scriptstrings/d.out.file_to_translate.c:26
@@ -31615,9 +29782,7 @@
msgstr "ãã¼ãããåã®æå¤§æ°"
#: ../locale/scriptstrings/v.db.addcol_to_translate.c:1
-msgid ""
-"Adds one or more columns to the attribute table connected to a given vector "
-"map."
+msgid "Adds one or more columns to the attribute table connected to a given vector map."
msgstr "ä¸ãããããã¯ãã«ãããã«æ¥ç¶ããã屿§ãã¼ãã«ã«1ã¤ä»¥ä¸ã®åã追å "
#: ../locale/scriptstrings/v.db.addcol_to_translate.c:3
@@ -31631,28 +29796,19 @@
#: ../locale/scriptstrings/v.db.addcol_to_translate.c:5
#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:11
#: ../locale/scriptstrings/v.dissolve_to_translate.c:6
-msgid ""
-"number determines which table to use."
-msgstr ""
+msgid "A single vector map can be connected to multiple database tables. This number determines which table to use."
#: ../locale/scriptstrings/v.db.addcol_to_translate.c:6
msgid "Name and type of the new column(s) ('name type [,name type, ...]')"
msgstr "æ°è¦åã®ååã¨ã¿ã¤ãï¼'name type [,name type, ...]'ï¼"
#: ../locale/scriptstrings/v.db.addcol_to_translate.c:7
-msgid ""
-"Data types depend on database backend, but all support VARCHAR(), INT, "
-"DOUBLE PRECISION and DATE"
-msgstr ""
-"æ°ããååã¨ã¿ã¤ã(ã¿ã¤ãã¯ãã¼ã¿ãã¼ã¹ã®å¾é¨ã«ä¾åãã¾ãããVARCHAR(), INT, "
-"DOUBLE PRECISION and DATEã®ãã¹ã¦ããµãã¼ããã¾ã)"
+msgid "Data types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE"
+msgstr "æ°ããååã¨ã¿ã¤ã(ã¿ã¤ãã¯ãã¼ã¿ãã¼ã¹ã®å¾é¨ã«ä¾åãã¾ãããVARCHAR(), INT, DOUBLE PRECISION and DATEã®ãã¹ã¦ããµãã¼ããã¾ã)"
#: ../locale/scriptstrings/v.db.update_to_translate.c:1
-msgid ""
-"Allows to update a column in the attribute table connected to a vector map."
+msgid "Allows to update a column in the attribute table connected to a vector map."
msgstr "ãã¯ãã«ãããã«æ¥ç¶ãã屿§ãã¼ãã«ã®åã®ã¢ãããã¼ãã許å¯ããã"
#: ../locale/scriptstrings/v.db.update_to_translate.c:3
@@ -31668,23 +29824,16 @@
msgstr "ã¢ãããã¼ãããå"
#: ../locale/scriptstrings/v.db.update_to_translate.c:6
-msgid ""
-"Value to update the column with (varchar values have to be in single quotes, "
-"e.g. 'grass')"
-msgstr ""
-"åãã¢ãããã¼ãããå¤ (varcharå¤ã¯ä¸éå¼ç¨ç¬¦ããªãã¨ããã¾ããã ä¾. "
-"'grass') "
+msgid "Value to update the column with (varchar values have to be in single quotes, e.g. 'grass')"
+msgstr "åãã¢ãããã¼ãããå¤ (varcharå¤ã¯ä¸éå¼ç¨ç¬¦ããªãã¨ããã¾ããã ä¾. 'grass') "
#: ../locale/scriptstrings/v.db.update_to_translate.c:7
msgid "Column to query"
msgstr "æ¤ç´¢ããå"
#: ../locale/scriptstrings/v.db.update_to_translate.c:8
-msgid ""
-"WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/"
-"col2>1)"
-msgstr ""
-"where' å¥ãªãã®ã¢ãããã¼ãã®WHEREã³ã³ãã£ã·ã§ã³ (ä¾ãcat=1 or col1/col2>1) "
+msgid "WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/col2>1)"
+msgstr "where' å¥ãªãã®ã¢ãããã¼ãã®WHEREã³ã³ãã£ã·ã§ã³ (ä¾ãcat=1 or col1/col2>1) "
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:1
msgid "Exports attribute tables into various formats."
@@ -31703,8 +29852,7 @@
msgstr "ãã¼ãã«ãã©ã¼ããã"
#: ../locale/scriptstrings/v.colors_to_translate.c:1
-msgid ""
-"Set color rules for features in a vector using a numeric attribute column."
+msgid "Set color rules for features in a vector using a numeric attribute column."
msgstr "æ°å¤å±æ§ã®åã§ã®ãã¯ãã«ã®ç¹å¾´ã®è²ã«ã¼ã«"
#: ../locale/scriptstrings/v.colors_to_translate.c:2
@@ -31736,11 +29884,8 @@
msgstr "d.legendã¨ä½¿ç¨ãããã¬ã¤ã¹ãã«ãã¼ã©ã¹ã¿ã¼ããããä¿å"
#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:1
-msgid ""
-"Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
-msgstr ""
-"ç¾å¨ã®ãããã»ããå
ã®ãã¹ã¦ã®åã®GRASS < Ver5.7 ãµã¤ããããããã¯ãã«ããã"
-"ã«å¤æãã"
+msgid "Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
+msgstr "ç¾å¨ã®ãããã»ããå
ã®ãã¹ã¦ã®åã®GRASS < Ver5.7 ãµã¤ããããããã¯ãã«ãããã«å¤æãã"
#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:2
msgid "sites, vector, import"
@@ -31751,11 +29896,8 @@
msgstr "é対話形å¼ã§å®è¡"
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:1
-msgid ""
-"Fills no-data areas in raster maps using v.surf.rst splines interpolation"
-msgstr ""
-"v.surf.rst ã¹ãã©ã¤ã³è£éã使ããã¦ããã©ã¹ã¿ã¼ãããã«ãã¼ã¿ãªãã¨ãªã¢ãåã"
-"ã"
+msgid "Fills no-data areas in raster maps using v.surf.rst splines interpolation"
+msgstr "v.surf.rst ã¹ãã©ã¤ã³è£éã使ããã¦ããã©ã¹ã¿ã¼ãããã«ãã¼ã¿ãªãã¨ãªã¢ãåãã"
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:2
msgid "raster, elevation, interpolation"
@@ -31766,8 +29908,7 @@
msgstr "nullã§åããããã©ã¹ã¿ã¼ããã"
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:4
-msgid ""
-"Output raster map with nulls filled by interpolation from surrounding values"
+msgid "Output raster map with nulls filled by interpolation from surrounding values"
msgstr "å¨å²ã®å¤ããã®è£éã«ãã£ã¦åããããnullã§åºåããã©ã¹ã¿ã¼ããã"
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:5
@@ -31819,11 +29960,8 @@
msgstr "ã«ãã´ãªæ°ã®åæå¤"
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:1
-msgid ""
-"Creates and connects a new attribute table to a given layer of an existing "
-"vector map."
-msgstr ""
-"æ°ãã屿§ãã¼ãã«ãæ¢åã®ãã¯ãã«ãããã«ä¸ããããã¬ã¤ã¤ã¼ã«ä½æãæ¥ç¶ãã"
+msgid "Creates and connects a new attribute table to a given layer of an existing vector map."
+msgstr "æ°ãã屿§ãã¼ãã«ãæ¢åã®ãã¯ãã«ãããã«ä¸ããããã¬ã¤ã¤ã¼ã«ä½æãæ¥ç¶ãã"
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:3
msgid "Vector map for which to add new attribute table"
@@ -31838,16 +29976,11 @@
msgstr "æ°ãã屿§ãã¼ãã«ã追å ããã¬ã¤ã¤ã¼"
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:6
-msgid ""
-"Name and type of the new column(s) (types depend on database backend, but "
-"all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
-msgstr ""
+msgid "Name and type of the new column(s) (types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:1
-msgid ""
-"Renames a column in the attribute table connected to a given vector map."
+msgid "Renames a column in the attribute table connected to a given vector map."
msgstr "æ¥ç¶ããã屿§ãã¼ãã«ã®åãä¸ãããããã¯ãã«ãããã«ååã夿´ãã"
#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:3
@@ -31944,21 +30077,15 @@
#: ../locale/scriptstrings/db.test_to_translate.c:1
msgid "Test database driver, database must exist and set by db.connect."
-msgstr ""
-"ãã¹ããã¼ã¿ãã¼ã¹ãã©ã¤ãã¼ããã¼ã¿ãã¼ã¹ã¯åå¨ããdb.æ¥ç¶ã«è¨å®ããªããã°ãª"
-"ãã¾ããã"
+msgstr "ãã¹ããã¼ã¿ãã¼ã¹ãã©ã¤ãã¼ããã¼ã¿ãã¼ã¹ã¯åå¨ããdb.æ¥ç¶ã«è¨å®ããªããã°ãªãã¾ããã"
#: ../locale/scriptstrings/db.test_to_translate.c:3
msgid "Test name"
msgstr "ãã¹ãå"
#: ../locale/scriptstrings/v.convert.all_to_translate.c:1
-msgid ""
-"Converts all older versions of GRASS vector maps in current mapset to "
-"current format."
-msgstr ""
-"ç¾å¨ã®ãããã»ããå
ã®ãã¹ã¦ã®åã®GRASS < Ver5.7 ãã¯ãã«ããã ãç¾å¨ã®"
-"ãã©ã¼ãããã«å¤æãã"
+msgid "Converts all older versions of GRASS vector maps in current mapset to current format."
ã®ãã¹ã¦ã®åã®GRASS < Ver5.7 ãã¯ãã«ããã ãç¾å¨ã®ãã©ã¼ãããã«å¤æãã"
#: ../locale/scriptstrings/v.convert.all_to_translate.c:3
msgid "run non-interactively"
@@ -32040,17 +30167,12 @@
msgstr "å
¥åã«ç¾å¨ã®ãã±ã¼ã·ã§ã³ãåºåããæå½±ã« LL WGS84ã使ç¨"
#: ../locale/scriptstrings/m.proj_to_translate.c:17
-msgid ""
-"Output long/lat in decimal degrees, or other projections with many decimal "
-"places"
+msgid "Output long/lat in decimal degrees, or other projections with many decimal places"
msgstr "å鲿³ãããã¯å°æ°ä½ã§ä»ã®æå½±ã§ åºåãã çµåº¦/緯度 "
#: ../locale/scriptstrings/m.proj_to_translate.c:19
-msgid ""
-"Script style output in CSV format respecting the field separator settings"
-msgstr ""
-"ãã£ã¼ã«ãã»ãã¬ã¼ã¿ã¼è¨å®ã«é¢ããCSVãã©ã¼ãããã®ã¹ã¯ãªããã¹ã¿ã¤ã«ã¢ã¦ã"
-"ããã"
+msgid "Script style output in CSV format respecting the field separator settings"
+msgstr "ãã£ã¼ã«ãã»ãã¬ã¼ã¿ã¼è¨å®ã«é¢ããCSVãã©ã¼ãããã®ã¹ã¯ãªããã¹ã¿ã¤ã«ã¢ã¦ãããã"
#: ../locale/scriptstrings/m.proj_to_translate.c:21
msgid "Verbose mode (print projection parameters and filenames to stderr)"
@@ -32089,8 +30211,7 @@
msgstr "LANDSAT TM ãã³ã 7. "
#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:1
-msgid ""
-"Drops a column from the attribute table connected to a given vector map."
+msgid "Drops a column from the attribute table connected to a given vector map."
msgstr "æ¥ç¶ããã屿§ãã¼ãã«ããä¸ãããããã¯ãã«ãããã¸åãåé¤"
#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:3
@@ -32138,12 +30259,8 @@
msgstr "éç´ã§ã¯ãªãæ°´å¹³ã«åå²"
#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:1
-msgid ""
-"Import waypoints, routes, and tracks from a GPS receiver or GPS download "
-"file into a vector map."
-msgstr ""
-"GPSã¬ã·ã¼ãã¼ãããã¯GPSãã¦ã³ãã¼ããã¡ã¤ã«ãããã¯ãã«ãããã¸ã¦ã§ã¤ãã¤ã³"
-"ããã«ã¼ãããã©ãã¯ãã¤ã³ãã¼ã"
+msgid "Import waypoints, routes, and tracks from a GPS receiver or GPS download file into a vector map."
+msgstr "GPSã¬ã·ã¼ãã¼ãããã¯GPSãã¦ã³ãã¼ããã¡ã¤ã«ãããã¯ãã«ãããã¸ã¦ã§ã¤ãã¤ã³ããã«ã¼ãããã©ãã¯ãã¤ã³ãã¼ã"
#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:4
msgid "Import waypoints"
@@ -32170,18 +30287,12 @@
msgstr "GPSå
¥åãã¼ã¿ã®ãã©ã¼ããã(GPSããã«ã§ãµãã¼ãããããã©ã¼ããã) "
#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:12
-msgid ""
-"Projection of input data (PROJ.4 style), if not set Lat/Lon WGS84 is assumed"
-msgstr ""
-"å
¥åãã¼ã¿(PROJ.4 ã¹ã¿ã¤ã«)ã®æå½±. 緯度çµåº¦ãè¨å®ããã¦ããªãã¨ãã¯WGS84ã¨ä»®"
-"å®"
+msgid "Projection of input data (PROJ.4 style), if not set Lat/Lon WGS84 is assumed"
+msgstr "å
¥åãã¼ã¿(PROJ.4 ã¹ã¿ã¤ã«)ã®æå½±. 緯度çµåº¦ãè¨å®ããã¦ããªãã¨ãã¯WGS84ã¨ä»®å®"
-msgid ""
-"Exports a vector map to a GPS receiver or file format supported by GpsBabel."
-msgstr ""
-"ãã¯ãã«ããããGPSã¬ã·ã¼ãã¼ãããã¯GpsBabelã«ãµãã¼ãããããã¡ã¤ã«ãã©ã¼"
-"ãããã«ã¨ã¯ã¹ãã¼ã"
+msgid "Exports a vector map to a GPS receiver or file format supported by GpsBabel."
+msgstr "ãã¯ãã«ããããGPSã¬ã·ã¼ãã¼ãããã¯GpsBabelã«ãµãã¼ãããããã¡ã¤ã«ãã©ã¼ãããã«ã¨ã¯ã¹ãã¼ã"
#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:2
msgid "vector, export, GPS"
@@ -32237,9 +30348,7 @@
#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:1
msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
-msgstr ""
-"ã¢ã¶ã¤ã¯ã¯æå¤§4ã¤ã®ç»åã¾ã§ã ã«ã©ã¼ããããæ¡å¼µãã; ããã *.mosaicã使ã"
-"ã "
+msgstr "ã¢ã¶ã¤ã¯ã¯æå¤§4ã¤ã®ç»åã¾ã§ã ã«ã©ã¼ããããæ¡å¼µãã; ããã *.mosaicã使ãã "
#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:2
msgid "raster, imagery, mosaicking"
@@ -32274,9 +30383,7 @@
msgstr "ç¾åçã§è¨ç®(-e flagãå¿
è¦)"
#: ../locale/scriptstrings/r.tileset_to_translate.c:1
-msgid ""
-"Produces tilings of the source projection for use in the destination region "
-"and projection."
+msgid "Produces tilings of the source projection for use in the destination region and projection."
msgstr "ç®çé åã¨æå½±ã®ä½¿ç¨ã®ããã®ã½ã¼ã¹æå½±ã¿ã¤ã«ã使ãã"
#: ../locale/scriptstrings/r.tileset_to_translate.c:2
@@ -32292,8 +30399,7 @@
msgstr "ã¦ã§ãããããµã¼ãã¼æ¤ç´¢æååã¢ã¦ããããã使ãã"
#: ../locale/scriptstrings/r.tileset_to_translate.c:5
-msgid ""
-"Name of region to use instead of current region for bounds and resolution"
+msgid "Name of region to use instead of current region for bounds and resolution"
msgstr "å¢çã¨è§£å度ç¨ã®ç¾å¨ã®é åã®ä»£ããã«ä½¿ç¨ãããé åå"
#: ../locale/scriptstrings/r.tileset_to_translate.c:6
@@ -32427,9 +30533,7 @@
#: ../locale/scriptstrings/r.in.wms_to_translate.c:37
msgid "Named region to request data for. Current region used if omitted"
-msgstr ""
-"ãã¼ã¿ãè¦æ±ããããã®åã¥ããããé åãé¤ããã¦ããå ´åã¯ç¾å¨ã®é åã使ç¨ã"
-"ã¾ãã"
+msgstr "ãã¼ã¿ãè¦æ±ããããã®åã¥ããããé åãé¤ããã¦ããå ´åã¯ç¾å¨ã®é åã使ç¨ãã¾ãã"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:39
msgid "Folder to save downloaded data to"
@@ -32504,12 +30608,8 @@
msgstr "ã©ã¹ã¿ã¼ã¢ã¦ããããTCãããããªãã£ãã¯ã¹"
#: ../locale/scriptstrings/d.split_to_translate.c:1
-msgid ""
-"Divides active display into two frames & displays maps/executes commands in "
-"each frame."
-msgstr ""
-"ã¢ã¯ãã£ããªãã£ã¹ãã¬ã¤ã2ã¤ã®ãã¬ã¼ã ã«åããï¼åãã¬ã¼ã ã®ããã/å®è¡ã³ã"
-"ã³ãã表示ãã"
+msgid "Divides active display into two frames & displays maps/executes commands in each frame."
+msgstr "ã¢ã¯ãã£ããªãã£ã¹ãã¬ã¤ã2ã¤ã®ãã¬ã¼ã ã«åããï¼åãã¬ã¼ã ã®ããã/å®è¡ã³ãã³ãã表示ãã"
#: ../locale/scriptstrings/d.split_to_translate.c:3
msgid "Enter raster map to display in 1st frame"
@@ -32532,8 +30632,7 @@
msgstr "ãã£ã¹ãã¬ã¤ã®å岿¹æ³"
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:1
-msgid ""
-"Brovey transform to merge multispectral and high-res panchromatic channels"
+msgid "Brovey transform to merge multispectral and high-res panchromatic channels"
msgstr "è¤æ°æ³¢é·ã¨é«è§£å度ãã³ã¯ããã£ã³ãã«ãçµ±åããBrovey夿"
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:2
@@ -32583,12 +30682,8 @@
msgstr "ãã¼ã«ã«GRASSã¤ã³ã¹ãã¼ã«ã®GRASSæ¡å¼µåãç¶æãããã¼ã«"
#: ../locale/scriptstrings/g.extension_to_translate.c:2
-msgid ""
-"Downloads, installs extensions from GRASS Addons SVN repository into local "
-"GRASS installation or removes installed extensions."
-msgstr ""
-"GRASSã¢ããªã³SVNã¬ãã¸ããªãããã¼ã«ã«GRASSã¤ã³ã¹ãã¼ã«ã«æ¡å¼µåããã¦ã³ãã¼"
-"ã,ã¤ã³ã¹ãã¼ã«ã¾ãã¯ã¤ã³ã¹ãã¼ã«ãããæ¡å¼µåãåé¤ãã¾ã"
+msgid "Downloads, installs extensions from GRASS Addons SVN repository into local GRASS installation or removes installed extensions."
+msgstr "GRASSã¢ããªã³SVNã¬ãã¸ããªãããã¼ã«ã«GRASSã¤ã³ã¹ãã¼ã«ã«æ¡å¼µåããã¦ã³ãã¼ã,ã¤ã³ã¹ãã¼ã«ã¾ãã¯ã¤ã³ã¹ãã¼ã«ãããæ¡å¼µåãåé¤ãã¾ã"
#: ../locale/scriptstrings/g.extension_to_translate.c:3
msgid "general, extensions"
@@ -32627,11 +30722,8 @@
msgstr "ã©ã¹ã¿ã¼ãæ¯è¦³ã®æ§é è§£æ"
#: ../locale/scriptstrings/v.dissolve_to_translate.c:1
-msgid ""
-"Dissolves boundaries between adjacent areas sharing a common category number "
-"or attribute."
-msgstr ""
-"å
±éã®ã«ãã´ãªæ°ãããã¯å±æ§ã¨å
±æããç´åã®ã¨ãªã¢éã®å¢çããã£ã¾ã«ããã"
+msgid "Dissolves boundaries between adjacent areas sharing a common category number or attribute."
+msgstr "å
#: ../locale/scriptstrings/v.dissolve_to_translate.c:2
msgid "vector, area, dissolve"
@@ -32704,14 +30796,10 @@
#~ msgstr "-1'ã§æå®ããé åã®è¨å®ã®é¾å¤ãåºæºã«ãã"
#~ msgid "user' in database definition is not supported, use db.login"
-#~ msgstr ""
-#~ "ãã¼ã¿ãã¼ã¹ä¸ã®'user'ã®å®ç¾©ã¯ãµãã¼ãããã¾ããï¼db.loginã使ç¨ãã¦ãã ã"
-#~ "ã"
+#~ msgstr "ãã¼ã¿ãã¼ã¹ä¸ã®'user'ã®å®ç¾©ã¯ãµãã¼ãããã¾ããï¼db.loginã使ç¨ãã¦ãã ãã"
#~ msgid "password' in database definition is not supported, use db.login"
-#~ msgstr ""
-#~ "ãã¼ã¿ãã¼ã¹ä¸ã®'password'ã®å®ç¾©ã¯ãµãã¼ãããã¾ããï¼db.loginã使ç¨ãã¦ä¸"
-#~ "ãã"
+#~ msgstr "ãã¼ã¿ãã¼ã¹ä¸ã®'password'ã®å®ç¾©ã¯ãµãã¼ãããã¾ããï¼db.loginã使ç¨ãã¦ä¸ãã"
#~ msgid ""
#~ "Reference Point file for group [%s] in [%s] \n"
@@ -32730,46 +30818,14 @@
#~ msgid "Extend location extents based on new dataset"
#~ msgstr "ãã¼ã¿ã»ããããã¨ã«ãã±ã¼ã·ã§ã³ãæ¡å¼µ"
-#~ msgid ""
-#~ "Precision loss: The range of <%s> can not be accurately preserved with "
-#~ "GDAL dat"
-#~ msgstr ""
-#~ "精度ã失ããã¾ãï¼ã©ã¹ã¿ã¼ããã <%s> ã®ã¬ã³ã¸ã¯GDALã®Float32ãã¼ã¿ã¿ã¤ã"
-#~ "ã§ã¯ç²¾åº¦ãä¿æã§ãã¾ãããInt32ãããã¯Float64ã«ã¨ã¯ã¹ãã¼ããããã¨åé¿ã§"
-#~ "ãã¾ãã"
+#~ msgid "Precision loss: The range of <%s> can not be accurately preserved with GDAL dat"
+#~ msgstr "精度ã失ããã¾ãï¼ã©ã¹ã¿ã¼ããã <%s> ã®ã¬ã³ã¸ã¯GDALã®Float32ãã¼ã¿ã¿ã¤ãã§ã¯ç²¾åº¦ãä¿æã§ãã¾ãããInt32ãããã¯Float64ã«ã¨ã¯ã¹ãã¼ããããã¨åé¿ã§ãã¾ãã"
-#~ msgid ""
-#~ "cat;category of the nearest feature;dist;minimum distance to nearest "
-#~ "feature;to_x;x coordinate of the nearest point on 'to' feature;to_y;y "
-#~ "coordinate of the nearest point on 'to' feature;to_along;distance between "
-#~ "points/centroids in 'from' map and the linear feature's start point in "
-#~ "'to' map, along this linear feature;to_angle;angle between the linear "
-#~ "feature in 'to' map and the positive x axis, at the location of point/"
-#~ "centroid in 'from' map, counterclockwise, in radians, which is between -"
-#~ "PI and PI inclusive;to_attr;attribute of nearest feature given by "
-#~ "to_column option"
-#~ msgstr ""
-#~ "cat;æè¿æ¥ãã£ã¼ãã£ã¼ã®ã«ãã´ãªã¼;dist;æè¿æ¥ãã£ã¼ãã£ã¼ã¸ã®æçè·é¢;"
-#~ "to_x;'to' ãã£ã¼ãã£ã¼ã«ãããæè¿æ¥ãã¤ã³ãã®;x 座æ¨;to_y;'to' ãã£ã¼"
-#~ "ãã£ã¼ã«ãããæè¿æ¥ãã¤ã³ãã®y 座æ¨;to_along; 'from' ãããã«ããããã¤ã³"
-#~ "ã/ã»ã³ããã¤ãéã®è·é¢ã¨'to'ãããã«ãããç·å½¢ãã£ã¼ãã£ã¼ã®éå§ç¹, "
-#~ "along this linear feature;to_angle;angle between the linear feature in "
-#~ "'to' ãããã¨æ£ã®x軸ã®éã®è§åº¦, 'from' ããã, åæè¨å¨ã, ã©ã¸ã¢ã³, -PI "
-#~ "㨠PIã®éã«ãããã¤ã³ã/ã»ã³ããã¤ãã®ãã±ã¼ã·ã§ã³ã«ããã'to' ãããã¨æ£"
-#~ "ã®x軸ã®éã®è§åº¦;to_attr;to_column ãªãã·ã§ã³ã«ãã£ã¦ä¸ãããã¦ããæè¿æ¥"
-#~ "ãã£ã¼ãã£ã¼ã®å±æ§"
+#~ msgid "cat;category of the nearest feature;dist;minimum distance to nearest feature;to_x;x coordinate of the nearest point on 'to' feature;to_y;y coordinate of the nearest point on 'to' feature;to_along;distance between points/centroids in 'from' map and the linear feature's start point in 'to' map, along this linear feature;to_angle;angle between the linear feature in 'to' map and the positive x axis, at the location of point/centroid in 'from' map, counterclockwise, in radians, which is between -PI and PI inclusive;to_attr;attribute of nearest feature given by to_column option"
+#~ msgstr "cat;æè¿æ¥ãã£ã¼ãã£ã¼ã®ã«ãã´ãªã¼;dist;æè¿æ¥ãã£ã¼ãã£ã¼ã¸ã®æçè·é¢;to_x;'to' ãã£ã¼ãã£ã¼ã«ãããæè¿æ¥ãã¤ã³ãã®;x 座æ¨;to_y;'to' ãã£ã¼ãã£ã¼ã«ãããæè¿æ¥ãã¤ã³ãã®y 座æ¨;to_along; 'from' ãããã«ããããã¤ã³ã/ã»ã³ããã¤ãéã®è·é¢ã¨'to'ãããã«ãããç·å½¢ãã£ã¼ãã£ã¼ã®éå§ç¹, along this linear feature;to_angle;angle between the linear feature in 'to' ãããã¨æ£ã®x軸ã®éã®è§åº¦, 'from' ããã, åæè¨å¨ã, ã©ã¸ã¢ã³, -PI 㨠PIã®éã«ãããã¤ã³ã/ã»ã³ããã¤ãã®ãã±ã¼ã·ã§ã³ã«ããã'to' ãããã¨æ£ã®x軸ã®éã®è§åº¦;to_attr;to_column ãªãã·ã§ã³ã«ãã£ã¦ä¸ãããã¦ããæè¿æ¥ãã£ã¼ãã£ã¼ã®å±æ§"
-#~ msgid ""
-#~ "The output is written to stdout but may be uploaded to a new table "
-#~ "created by this module. From categories are may be multiple."
-#~ msgstr ""
-#~ "åºåã¯stdoutã«æ¸ãè¾¼ã¾ãã¾ããããã®ã¢ã¸ã¥ã¼ã«ã«ãã£ã¦ä½æãããæ°ãã表ã«"
-#~ "ã¢ãããã¼ããããå¯è½æ§ãããã¾ã. Fromã«ãã´ãªã¼ã¯éè¤ãã¦ããããããã¾"
-#~ "ãã. "
+#~ msgid "The output is written to stdout but may be uploaded to a new table created by this module. From categories are may be multiple."
+#~ msgstr "åºåã¯stdoutã«æ¸ãè¾¼ã¾ãã¾ããããã®ã¢ã¸ã¥ã¼ã«ã«ãã£ã¦ä½æãããæ°ãã表ã«ã¢ãããã¼ããããå¯è½æ§ãããã¾ã. Fromã«ãã´ãªã¼ã¯éè¤ãã¦ããããããã¾ãã. "
-#~ msgid ""
-#~ "Interpolates point data to a G3D grid volume using regularized spline "
-#~ "with tension (RST) algorithm."
-#~ msgstr ""
-#~ "ãã³ã·ã§ã³ (RST) ã¢ã«ã´ãªãºã ã®æ£è¦åã¹ãã©ã¤ã³æ²ç·ã使ã£ã¦ï¼ãã¤ã³ããã¼"
-#~ "ã¿ã3Dã°ãªããããªã¥ã¼ã ã¸æ¿å
+#~ msgid "Interpolates point data to a G3D grid volume using regularized spline with tension (RST) algorithm."
+#~ msgstr "ãã³ã·ã§ã³ (RST) ã¢ã«ã´ãªãºã ã®æ£è¦åã¹ãã©ã¤ã³æ²ç·ã使ã£ã¦ï¼ãã¤ã³ããã¼ã¿ã3Dã°ãªããããªã¥ã¼ã ã¸æ¿å
Modified: grass/branches/releasebranch_6_4/locale/po/grassnviz_ja.po
--- grass/branches/releasebranch_6_4/locale/po/grassnviz_ja.po 2012-03-04 12:43:05 UTC (rev 50991)
+++ grass/branches/releasebranch_6_4/locale/po/grassnviz_ja.po 2012-03-05 08:10:54 UTC (rev 50992)
@@ -6,8 +6,8 @@
"Project-Id-Version: grassnviz_ja\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2012-02-01 08:43+0100\n"
-"PO-Revision-Date: 2011-11-15 20:55+0900\n"
-"Last-Translator: ueda <nao at locapoint.com>\n"
+"PO-Revision-Date: 2012-03-05 12:15+0900\n"
+"Last-Translator: Naoki Ueda <nao at locapoint.com>\n"
"Language-Team: Japanese <grass-translations at lists.osgeo.org>\n"
"Language: ja\n"
"MIME-Version: 1.0\n"
@@ -663,9 +663,7 @@
msgstr "å¡ä¾ä½ç½®"
#: ../visualization/nviz/scripts/panel_legend.tcl:133
-msgid ""
-"Use mouse to place legend; left button defines first corner, right button "
-"defines opposite corner."
+msgid "Use mouse to place legend; left button defines first corner, right button defines opposite corner."
msgstr "ãã¦ã¹ã使ã£ã¦å¤ä¾ãé
ç½®; å·¦ãã¿ã³ã¨å³ãã¿ã³ã§å¯¾è§ãæå®"
#: ../visualization/nviz/scripts/panel_legend.tcl:135
@@ -1948,20 +1946,12 @@
msgstr "ã¢ã¤ã³ã³è¨å®"
#: ../visualization/nviz/scripts/site_attr.tcl:411
-msgid ""
-"Fill 2 or more entry fields with desired min and max values, then press "
-"[Apply]. Or press [Auto] to automatically generate a range of symbol sizes."
-msgstr ""
-"2ã¤ä»¥ä¸ã®æå¤§å¤ãæå°å¤ãå
¥åãã [Apply]ãæ¼ãã¦ãã ããã [Auto] ãæ¼ãã¨ã·"
-"ã³ãã«ãµã¤ãºã®ã¬ã³ã¸ã¯èªåçã«ä½æããã¾ãã"
+msgid "Fill 2 or more entry fields with desired min and max values, then press [Apply]. Or press [Auto] to automatically generate a range of symbol sizes."
+msgstr "2ã¤ä»¥ä¸ã®æå¤§å¤ãæå°å¤ãå
¥åãã [Apply]ãæ¼ãã¦ãã ããã [Auto] ãæ¼ãã¨ã·ã³ãã«ãµã¤ãºã®ã¬ã³ã¸ã¯èªåçã«ä½æããã¾ãã"
#: ../visualization/nviz/scripts/site_attr.tcl:422
-msgid ""
-"Fill 2 or more entry fields with desired colors, then press [Apply]. Or "
-"press [Auto] to automatically generate a color table."
-msgstr ""
-"2ã¤ä»¥ä¸ã®è²ãå
¥åã [é©ç¨]ãæ¼ãã¦ãã ããã[èªå]ãæ¼ãã¨ã«ã©ã¼ãã¼ãã«ãèª"
-"åã§ä½æãã¾ãã"
+msgid "Fill 2 or more entry fields with desired colors, then press [Apply]. Or press [Auto] to automatically generate a color table."
+msgstr "2ã¤ä»¥ä¸ã®è²ãå
¥åã [é©ç¨]ãæ¼ãã¦ãã ããã[èªå]ãæ¼ãã¨ã«ã©ã¼ãã¼ãã«ãèªåã§ä½æãã¾ãã"
#: ../visualization/nviz/scripts/site_attr.tcl:428
#, tcl-format
@@ -1992,9 +1982,7 @@
msgstr "èªå"
#: ../visualization/nviz/scripts/site_attr.tcl:479
-msgid ""
-"Automatically generate a color table distributed across range of attribute "
-"values"
+msgid "Automatically generate a color table distributed across range of attribute values"
msgstr "屿§å¤ã®ã¬ã³ã¸ããã«ã©ã¼ãã¼ãã«ãèªåã§çæ"
#: ../visualization/nviz/scripts/site_attr.tcl:485
@@ -2133,8 +2121,7 @@
#: ../visualization/nviz/scripts/site_attr.tcl:1627
#, tcl-format
msgid "*** ERROR *** Some thematic pref component are missing in file \"%s\""
-msgstr ""
-"*** ã¨ã©ã¼ *** ããã¤ãã®ä¸»é¡å³è¨å®æ
å ±ããã¡ã¤ã« \"%s\" ãæ¶ãã¦ãã¾ãã¾ãã"
+msgstr "*** ã¨ã©ã¼ *** ããã¤ãã®ä¸»é¡å³è¨å®æ
#: ../visualization/nviz/scripts/site_attr.tcl:1700
#, tcl-format
Modified: grass/branches/releasebranch_6_4/locale/po/grasstcl_ja.po
--- grass/branches/releasebranch_6_4/locale/po/grasstcl_ja.po 2012-03-04 12:43:05 UTC (rev 50991)
+++ grass/branches/releasebranch_6_4/locale/po/grasstcl_ja.po 2012-03-05 08:10:54 UTC (rev 50992)
@@ -1,6 +1,6 @@
# translation of grasstcl_ja.po to Japanese
# This file is distributed under the same license as the GRASS package.
-# Copyright (C) 2005,2010 GRASS Development Team
+# Copyright (C) 2005, 2010, 2012 GRASS Development Team
# Shinji Masumoto <masumoto at sci.osaka-cu.ac.jp>, 2004
# Susumu Nonogaki <nonogaki at sci.osaka-cu.ac.jp>, 2008
# Markus Neteler <neteler at itc.it>, 2004, 2005, 2006.
@@ -10,8 +10,8 @@
"Project-Id-Version: grasstcl_ja\n"
-"PO-Revision-Date: 2011-11-15 18:22+0900\n"
+"PO-Revision-Date: 2012-03-05 08:27+0900\n"
"Language: ja\n"
@@ -108,14 +108,8 @@
msgstr "ãã¼ã¿ã 夿ãã©ã¡ã¼ã¿é¸æï¼"
#: ../lib/init/file_option.tcl:244 ../lib/init/epsg_option.tcl:290
-msgid ""
-"Continue without specifying parameters - if used when creating a location, "
-"other GRASS modules will use the \"default\" (likely non-optimum) parameters "
-"for this datum if necessary in the future."
-msgstr ""
-"ãã©ã¡ã¼ã¿ãæå®ããã«ç¶è¡ - ãã±ã¼ã·ã§ã³ã使ããå ´åãä»ã®GRASSã®ãã¼ã¿ã "
-"ã使ç¨ããå ´åã¯ã\"ããã©ã«ã\"ï¼æé©åããã¦ããªãå¯è½æ§ãããã¾ãï¼ãé©ç¨"
-"ããã¾ã"
+msgid "Continue without specifying parameters - if used when creating a location, other GRASS modules will use the \"default\" (likely non-optimum) parameters for this datum if necessary in the future."
+msgstr "ãã©ã¡ã¼ã¿ãæå®ããã«ç¶è¡ - ãã±ã¼ã·ã§ã³ã使ããå ´åãä»ã®GRASSã®ãã¼ã¿ã ã使ç¨ããå ´åã¯ã\"ããã©ã«ã\"ï¼æé©åããã¦ããªãå¯è½æ§ãããã¾ãï¼ãé©ç¨ããã¾ã"
#: ../lib/init/file_option.tcl:263 ../lib/init/epsg_option.tcl:309
#: ../vector/v.digit/settings.tcl:174 ../gui/tcltk/gis.m/gm.tcl:465
@@ -146,11 +140,8 @@
#: ../lib/init/gis_set.tcl:132
#, tcl-format
-msgid ""
-"Warning: location <%s> at GISDBASE <%s> is not a directory or does not exist."
-msgstr ""
-"è¦å: ãã±ã¼ã·ã§ã³ <%s> ï¼GISãã¼ã¿ãã¼ã¹ <%s>ï¼ ã¯ãã£ã¬ã¯ããªã§ãªããã¾ã"
-"ã¯ãã£ã¬ã¯ããªãåå¨ãã¾ãã"
+msgid "Warning: location <%s> at GISDBASE <%s> is not a directory or does not exist."
+msgstr "è¦å: ãã±ã¼ã·ã§ã³ <%s> ï¼GISãã¼ã¿ãã¼ã¹ <%s>ï¼ ã¯ãã£ã¬ã¯ããªã§ãªããã¾ãã¯ãã£ã¬ã¯ããªãåå¨ãã¾ãã"
#: ../lib/init/gis_set.tcl:183
#, tcl-format
@@ -330,13 +321,8 @@
msgstr "GRASSã®ååå®è¡"
#: ../lib/init/gis_set.tcl:584
-msgid ""
-"GRASS needs a directory in which to store its data. Create one now if you "
-"have not already done so. A popular choice is \"grassdata\", located in "
-"your home directory."
-msgstr ""
-"GRASSãã¹ã¿ã¼ããããããã«ã¯ãã¼ã¿ãæ ¼ç´ãããã£ã¬ã¯ããªãå¿
è¦ã§ãã®ã§ã使"
-"ãã¦ãã ãããä¸è¬ã«ã¯ \"grassdata\"ã使ç¨ããã¾ãã"
+msgid "GRASS needs a directory in which to store its data. Create one now if you have not already done so. A popular choice is \"grassdata\", located in your home directory."
+msgstr "GRASSãã¹ã¿ã¼ããããããã«ã¯ãã¼ã¿ãæ ¼ç´ãããã£ã¬ã¯ããªãå¿
è¦ã§ãã®ã§ã使ãã¦ãã ãããä¸è¬ã«ã¯ \"grassdata\"ã使ç¨ããã¾ãã"
#: ../lib/init/gis_set.tcl:589
msgid "Select GIS data directory"
@@ -391,11 +377,11 @@
msgid ""
"\n"
"\n"
-"On MS-Windows systems failure might be caused by non-latin letter in GISRC "
-"file path. Check that Your username doesn't contain non-latin letters. Due "
-"to non-latin letter encoding handling in MS-Windows, it's not possible to "
-"run GRASS if username contains non-latin letters."
+"On MS-Windows systems failure might be caused by non-latin letter in GISRC file path. Check that Your username doesn't contain non-latin letters. Due to non-latin letter encoding handling in MS-Windows, it's not possible to run GRASS if username contains non-latin letters."
msgstr ""
+"\n"
+"\n"
+"GISRSã®ãã¡ã¤ã«ãã¹åã«è±æ°å以å¤ã使ããã¦ããã¨ãWindowsã®ã·ã¹ãã ã¨ã©ã¼ãçºçããå¯è½æ§ãããã¾ããã¦ã¼ã¶ã¼åã«è±æ°å以å¤ã®æåã使ããã¦ããªãã確èªãã¦ãã ãããWindowsã·ã¹ãã ã§ä½¿ããã¦ãããã«ããã¤ãã¨ã³ã³ã¼ãã£ã³ã°ã®å¶ç´ã§ãéã©ãã³æåã®ã¦ã¼ã¶ã¼åã§ã¯GRASSãå®è¡ãããã¨ãã§ãã¾ããã"
#: ../lib/init/gis_set.tcl:942
msgid "ERROR: unable to read GISRC"
@@ -409,8 +395,7 @@
msgid ""
"Warning: Unable to get environmental variable GRASS_PROJSHARE. \n"
"This is a GRASS installation error. \n"
-"Set environmental variable GRASS_PROJSHARE to point to directory with Proj4 "
-"EPSG file. "
+"Set environmental variable GRASS_PROJSHARE to point to directory with Proj4 EPSG file. "
msgstr ""
"è¦åï¼ç°å¢å¤æ°GRASS_PROJSHAREãåå¾ãããã¨ãã§ãã¾ãã \n"
"ããã¯ãGRASSã®ã¤ã³ã¹ãã¼ã«æã®ã¨ã©ã¼ã§ã \n"
@@ -1135,12 +1120,8 @@
msgstr " ã¾ã㯠< "
#: ../gui/tcltk/gis.m/gm.tcl:75
-msgid ""
-"GISDBASE or LOCATION_NAME or MAPSET is empty. This is a fatal error. gis.m "
-"can not work without proper settings."
-msgstr ""
-"ãã¼ã¿ãã¼ã¹ ã¾ã㯠ãã±ã¼ã·ã§ã³å ã¾ã㯠ãããã»ãã ã¯ããã§ã. è´å½çãª"
-"ã¨ã©ã¼ã§ã. gis.mã¯é©åãªè¨å®ç¡ããã¦ã¯å®è¡ã§ãã¾ãã"
+msgid "GISDBASE or LOCATION_NAME or MAPSET is empty. This is a fatal error. gis.m can not work without proper settings."
+msgstr "ãã¼ã¿ãã¼ã¹ ã¾ã㯠ãã±ã¼ã·ã§ã³å ã¾ã㯠ãããã»ãã ã¯ããã§ã. è´å½çãªã¨ã©ã¼ã§ã. gis.mã¯é©åãªè¨å®ç¡ããã¦ã¯å®è¡ã§ãã¾ãã"
#: ../gui/tcltk/gis.m/gm.tcl:219 ../gui/tcltk/d.m/d.m.tcl:314
msgid "Loading GIS Manager"
@@ -1190,15 +1171,13 @@
"\n"
"This action will close all sessions gis.m instances.\n"
"\n"
-"If You have running some GRASS module from comandline, GRASS will terminate "
-"after it finishes to run."
+"If You have running some GRASS module from comandline, GRASS will terminate after it finishes to run."
msgstr ""
"GRASSãçµäºãã¦ãããããã§ãã?\n"
"\n"
"ãã®åä½ã¯gis.mã¤ã³ã¹ã¿ã³ã¹ã®å
¨ã¦ã®ã»ãã·ã§ã³ãçµäºãã¾ã.\n"
"\n"
-"GRASSã®ã³ãã³ãã©ã¤ã³ããå®è¡ãã¦ããå ´åã¯, ãã®ã³ãã³ããå®äºããå¾ã§GRASS"
-"ãçµäºãã¾ã."
+"GRASSã®ã³ãã³ãã©ã¤ã³ããå®è¡ãã¦ããå ´åã¯, ãã®ã³ãã³ããå®äºããå¾ã§GRASSãçµäºãã¾ã."
#: ../gui/tcltk/gis.m/gm.tcl:543
msgid "Terminate current GRASS session"
@@ -1521,8 +1500,7 @@
msgstr "éã¾ãã¯å½©åº¦ãã£ã³ãã«ã®ã©ã¹ã¿ã¼ããã"
#: ../gui/tcltk/gis.m/rgbhis.tcl:136
-msgid ""
-"Display 3 raster maps as Red/Green/Blue or Hue/Intensity/Saturation channels"
+msgid "Display 3 raster maps as Red/Green/Blue or Hue/Intensity/Saturation channels"
msgstr "Rï¼Gï¼Bã¾ãã¯è²ç¸/ç
§åº¦/彩度ãã£ã³ãã«ã¨ãã¦ï¼ã¤ã®ã©ã¹ã¿ã¼ã表示"
#: ../gui/tcltk/gis.m/rgbhis.tcl:155 ../gui/tcltk/d.m/rgbhis.tcl:128
@@ -1982,8 +1960,7 @@
#: ../gui/tcltk/gis.m/rastnums.tcl:286
msgid ""
"Cell values can only be displayed for \n"
-"regions of < 10,000 cells. Map in explore mode may contain more than 10,000 "
-"cells.\n"
+"regions of < 10,000 cells. Map in explore mode may contain more than 10,000 cells.\n"
"\n"
" It's suggested to constrain map to region geometry to display cell values."
msgstr ""
@@ -3747,8 +3724,7 @@
msgstr " %s ã®ã°ã©ã"
#: ../gui/tcltk/gis.m/chart.tcl:185
-msgid ""
-"Display pie and bar charts of attribute values at vector object locations"
+msgid "Display pie and bar charts of attribute values at vector object locations"
msgstr "ãã¯ãã«ãªãã¸ã§ã¯ãã®ä½ç½®ã«å±æ§ã®åã°ã©ãã¨æ£ã°ã©ãã表示"
#: ../gui/tcltk/gis.m/chart.tcl:202 ../gui/tcltk/d.m/chart.tcl:91
@@ -3994,20 +3970,12 @@
msgstr " å転ã®è¨å®ãç¡è¦ãã¦æ°´å¹³æ¹åã«æç»"
#: ../gui/tcltk/gis.m/georect.tcl:285
-msgid ""
-"There is no raster group file (REF). You must select the 'create/edit group' "
-"option to create a group file."
-msgstr ""
-"ã©ã¹ã¿ã¼ã°ã«ã¼ããã¡ã¤ã«(REF)ãããã¾ãã ã°ã«ã¼ã 使/ç·¨éãªãã·ã§ã³ã使ç¨"
-"ãã¦ã°ã«ã¼ããã¡ã¤ã«ã使ãã¦ãã ãã"
+msgid "There is no raster group file (REF). You must select the 'create/edit group' option to create a group file."
+msgstr "ã©ã¹ã¿ã¼ã°ã«ã¼ããã¡ã¤ã«(REF)ãããã¾ãã ã°ã«ã¼ã 使/ç·¨éãªãã·ã§ã³ã使ç¨ãã¦ã°ã«ã¼ããã¡ã¤ã«ã使ãã¦ãã ãã"
#: ../gui/tcltk/gis.m/georect.tcl:307
-msgid ""
-"There is no vector group file (VREF). You must select the 'create/edit "
-"group' option to create a group file."
-msgstr ""
-"ãã¯ãã«ã°ã«ã¼ããã¡ã¤ã«(VREF)ãããã¾ãã ã°ã«ã¼ã 使/ç·¨éãªãã·ã§ã³ã使ç¨"
+msgid "There is no vector group file (VREF). You must select the 'create/edit group' option to create a group file."
+msgstr "ãã¯ãã«ã°ã«ã¼ããã¡ã¤ã«(VREF)ãããã¾ãã ã°ã«ã¼ã 使/ç·¨éãªãã·ã§ã³ã使ç¨ãã¦ã°ã«ã¼ããã¡ã¤ã«ã使ãã¦ãã ãã"
#: ../gui/tcltk/gis.m/georect.tcl:388
msgid "Select mapset of raster to georectify"
@@ -4086,9 +4054,7 @@
msgstr "ï¼ï¼ããã鏿"
#: ../gui/tcltk/gis.m/georect.tcl:683
-msgid ""
-"Select non-georectified raster or vector to display for marking ground "
-"control points"
+msgid "Select non-georectified raster or vector to display for marking ground control points"
msgstr "å°ä¸åºæºç¹ã使ããããéå¹¾ä½è£æ£ã©ã¹ã¿ã¼ã¾ãã¯ãã¯ãã«ã鏿"
#: ../gui/tcltk/gis.m/georect.tcl:693
@@ -4188,29 +4154,16 @@
msgstr "å¹¾ä½è£æ£"
#: ../gui/tcltk/gis.m/georect.tcl:1323
-msgid ""
-"There is no POINTS file of ground control points for group. You must create "
-"ground control points before georectifying map."
-msgstr ""
-"ã°ã«ã¼ãã®å°çåºæºç¹ããã¤ã³ããã¡ã¤ã«ã«åå¨ãã¾ãã å¹¾ä½è£æ£ã®åã«ä½æããå¿
-"è¦ãããã¾ã"
+msgid "There is no POINTS file of ground control points for group. You must create ground control points before georectifying map."
+msgstr "ã°ã«ã¼ãã®å°çåºæºç¹ããã¤ã³ããã¡ã¤ã«ã«åå¨ãã¾ãã å¹¾ä½è£æ£ã®åã«ä½æããå¿
è¦ãããã¾ã"
#: ../gui/tcltk/gis.m/georect.tcl:1353
-msgid ""
-"Insufficient ground control points for georectification method. You need at "
-"least 3 points for 1st order, 6 points for 2nd order and 10 points for 3rd "
-"order."
-msgstr ""
-"ãããå¹¾ä½è£æ£ã®ããã®å°ä¸åºæºç¹ãä¸è¶³ãã¦ãã¾ã 第ï¼é¸æã§ã¯æä½ï¼ç¹ã第ï¼ã§"
-"ã¯ï¼ç¹ã第ï¼ã§ã¯ï¼ï¼ç¹ä»¥ä¸å¿
è¦ã§ã"
+msgid "Insufficient ground control points for georectification method. You need at least 3 points for 1st order, 6 points for 2nd order and 10 points for 3rd order."
+msgstr "ãããå¹¾ä½è£æ£ã®ããã®å°ä¸åºæºç¹ãä¸è¶³ãã¦ãã¾ã 第ï¼é¸æã§ã¯æä½ï¼ç¹ã第ï¼ã§ã¯ï¼ç¹ã第ï¼ã§ã¯ï¼ï¼ç¹ä»¥ä¸å¿
è¦ã§ã"
#: ../gui/tcltk/gis.m/georect.tcl:1384
-msgid ""
-"No valid ground control points in GCP file. You must create valid ground "
-"control points before georectifying map."
-msgstr ""
-"GCPãã¡ã¤ã«ã®ãã¤ã³ãã«å¤ãå®ç¾©ããã¦ãã¾ãã å¹¾ä½è£æ£ã®åã«GCPã使ããå¿
è¦"
-"ãããã¾ã"
+msgid "No valid ground control points in GCP file. You must create valid ground control points before georectifying map."
+msgstr "GCPãã¡ã¤ã«ã®ãã¤ã³ãã«å¤ãå®ç¾©ããã¦ãã¾ãã å¹¾ä½è£æ£ã®åã«GCPã使ããå¿
è¦ãããã¾ã"
#: ../gui/tcltk/gis.m/georect.tcl:1587
msgid "Error setting region"
@@ -4494,12 +4447,8 @@
msgstr "ã«ã¼ã«ãã¡ã¤ã«ä½æã¨ã©ã¼"
#: ../gui/tcltk/gis.m/maptext.tcl:129
-msgid ""
-"Create postscript text object (for postscript eps, pdf, and print output "
-"only)"
-msgstr ""
-"ãã¹ãã¹ã¯ãªããããã¹ããªãã¸ã§ã¯ã使 (ãã¹ãã¹ã¯ãªãã eps, pdf, ããªã³ã"
-"åºåã®ã¿) "
+msgid "Create postscript text object (for postscript eps, pdf, and print output only)"
+msgstr "ãã¹ãã¹ã¯ãªããããã¹ããªãã¸ã§ã¯ã使 (ãã¹ãã¹ã¯ãªãã eps, pdf, ããªã³ãåºåã®ã¿) "
#: ../gui/tcltk/gis.m/maptext.tcl:136
msgid "Text to display:"
@@ -4726,8 +4675,7 @@
#: ../gui/tcltk/gis.m/animate.tcl:479
msgid "Select maps to animate in one or more frames (1 frame required)"
-msgstr ""
-"1ã¤ã¾ãã¯è¤æ°ã®ãã¬ã¼ã ã§ã¢ãã¡ã¼ã·ã§ã³åããããã鏿(1 ãã¬ã¼ã å¿
è¦) "
+msgstr "1ã¤ã¾ãã¯è¤æ°ã®ãã¬ã¼ã ã§ã¢ãã¡ã¼ã·ã§ã³åããããã鏿(1 ãã¬ã¼ã å¿
è¦) "
#: ../gui/tcltk/gis.m/animate.tcl:492
msgid "Maps for frame 1 (required): "
@@ -5043,7 +4991,7 @@
#: ../gui/tcltk/gis.m/legend.tcl:235
#, fuzzy, tcl-format
msgid " x,y of lower left corner (in % from display top left)"
-msgstr " å·¦ä¸ç«¯ã®XY (ãã£ã¹ãã¬ã¤ã®å·¦ä¸ç«¯ãã % ) "
+msgstr " å·¦ä¸ç«¯ã®XY (ï¼
ã®æã¯ãã£ã¹ãã¬ã¤ã®å·¦ä¸ç«¯ãã ) "
#: ../gui/tcltk/gis.m/legend.tcl:246
msgid " legend height "
@@ -5535,8 +5483,7 @@
#: ../gui/tcltk/d.m/menu.tcl:138
msgid "ASCII vector or point file/old GRASS ASCII vector file"
-msgstr ""
-"GRASS ASCIIãã¯ãã«ãã¡ã¤ã«(æ§ãã©ã¼ããããå¯)ãããã¯ASCIIãã¤ã³ããã¡ã¤ã« "
+msgstr "GRASS ASCIIãã¯ãã«ãã¡ã¤ã«(æ§ãã©ã¼ããããå¯)ãããã¯ASCIIãã¤ã³ããã¡ã¤ã« "
#: ../gui/tcltk/d.m/menu.tcl:140
msgid "POV-Ray format"
@@ -5799,9 +5746,7 @@
msgstr "RGBãã¡ã¤ã«ããã«ã©ã¼ç»å使 "
#: ../gui/tcltk/d.m/menu.tcl:250
-msgid ""
-"Create 3 RGB (red, green, blue) maps from 3 HIS (hue, intensity, saturation) "
-"maps"
+msgid "Create 3 RGB (red, green, blue) maps from 3 HIS (hue, intensity, saturation) maps"
msgstr "ï¼HIS(è²ç¸/æåº¦/彩度)ãããããï¼RGBï¼èµ¤/ç·/é)ãããã使"
#: ../gui/tcltk/d.m/menu.tcl:255
@@ -6006,8 +5951,7 @@
#: ../gui/tcltk/d.m/menu.tcl:354
msgid "Regularized spline tension interpolation from vector points or contours"
-msgstr ""
-"ãã¯ãã«ãã¤ã³ãã¾ãã¯çé«ç·ãç¨ããã¬ã®ã¥ã©ã¼ã¹ãã©ã¤ã³ã»ãã³ã·ã§ã³è£é "
+msgstr "ãã¯ãã«ãã¤ã³ãã¾ãã¯çé«ç·ãç¨ããã¬ã®ã¥ã©ã¼ã¹ãã©ã¤ã³ã»ãã³ã·ã§ã³è£é "
#: ../gui/tcltk/d.m/menu.tcl:356
msgid "Fill NULL cells by interpolation using regularized spline tension"
@@ -6134,20 +6078,12 @@
msgstr "å
¥åã©ã¤ã³ããé
置測ç¹ã¨ç·ååç
§ã·ã¹ãã 使"
#: ../gui/tcltk/d.m/menu.tcl:416
-msgid ""
-"Create points/segments from input lines, linear reference system and "
-"positions read from stdin"
-msgstr ""
-"å
¥åã©ã¤ã³ãããã¤ã³ã/ã»ã°ã¡ã³ããä½æã¨æ¨æºå
¥åããã®ä½ç½®ã«ããç·ååç
§ã·ã¹"
-"ãã "
+msgid "Create points/segments from input lines, linear reference system and positions read from stdin"
+msgstr "å
§ã·ã¹ãã "
#: ../gui/tcltk/d.m/menu.tcl:417
-msgid ""
-"Find line id and real km+offset for given points in vector map using linear "
-"reference system"
-msgstr ""
-"ç·å½¢åç
§ã·ã¹ãã ãå©ç¨ãããã¯ãã«ãããã®ãã¤ã³ãããã©ã¤ã³IDã¨å®è·é¢ï¼Km)ãª"
-"ãã»ããã表示"
+msgid "Find line id and real km+offset for given points in vector map using linear reference system"
+msgstr "ç·å½¢åç
§ã·ã¹ãã ãå©ç¨ãããã¯ãã«ãããã®ãã¤ã³ãããã©ã¤ã³IDã¨å®è·é¢ï¼Km)ãªãã»ããã表示"
#: ../gui/tcltk/d.m/menu.tcl:420
msgid "Locate nearest features to points or centroids"
@@ -6266,18 +6202,15 @@
msgstr "4ã¤ã®é£ãåãç»åã¾ã§ã®ã¢ã¶ã¤ã¯ "
#: ../gui/tcltk/d.m/menu.tcl:484
-msgid ""
-"Color balance and enhance color tables of multiband imagery for rgb display"
+msgid "Color balance and enhance color tables of multiband imagery for rgb display"
msgstr "RGB表示ãããã«ããã³ãç»åã®ã«ã©ã¼ãã©ã³ã¹ã¨æ¡å¼µã«ã©ã¼ãã¼ãã«"
#: ../gui/tcltk/d.m/menu.tcl:485
-msgid ""
-"Transform HIS (Hue/Intensity/Saturation) color image to RGB (Red/Green/Blue)"
+msgid "Transform HIS (Hue/Intensity/Saturation) color image to RGB (Red/Green/Blue)"
msgstr "HIS(è²ç¸/æåº¦/彩度)ã«ã©ã¼ããRGBï¼èµ¤/ç·/é)ã«ã©ã¼ã¸å¤æ"
#: ../gui/tcltk/d.m/menu.tcl:486
-msgid ""
-"Transform RGB (Red/Green/Blue) color image to HIS (Hue/Intensity/Saturation)"
+msgid "Transform RGB (Red/Green/Blue) color image to HIS (Hue/Intensity/Saturation)"
msgstr "RGBï¼èµ¤/ç·/é)ã«ã©ã¼ããHIS(è²ç¸/æåº¦/彩度)ã«ã©ã¼ã¸å¤æ"
#: ../gui/tcltk/d.m/menu.tcl:488
@@ -6286,13 +6219,11 @@
#: ../gui/tcltk/d.m/menu.tcl:489
msgid "Set ground control points (GCP's) from raster map or keyboard entry"
-msgstr ""
-"ã©ã¹ã¿ã¼ãããã¯ãã¼ãã¼ãããã®ã°ã©ã¦ã³ãã³ã³ããã¼ã«ãã¤ã³ã(GCP)ã®è¨å® "
+msgstr "ã©ã¹ã¿ã¼ãããã¯ãã¼ãã¼ãããã®ã°ã©ã¦ã³ãã³ã³ããã¼ã«ãã¤ã³ã(GCP)ã®è¨å® "
#: ../gui/tcltk/d.m/menu.tcl:491
msgid "Set ground control points (GCP's) from vector map or keyboard entry"
-msgstr ""
-"ãã¯ãã«ãããã¯ãã¼ãã¼ãããã®ã°ã©ã¦ã³ãã³ã³ããã¼ã«ãã¤ã³ã(GCP)ã®è¨å® "
+msgstr "ãã¯ãã«ãããã¯ãã¼ãã¼ãããã®ã°ã©ã¦ã³ãã³ã³ããã¼ã«ãã¤ã³ã(GCP)ã®è¨å® "
#: ../gui/tcltk/d.m/menu.tcl:493
msgid "Affine and Polynomial rectification (rubber sheet)"
@@ -6608,10 +6539,8 @@
#: ../gui/tcltk/d.m/fttext.tcl:120
-msgid ""
-" (for coordinates, % is from bottom left of display, pixels from top "
-"left)"
-msgstr " (座æ¨ã¯, % ã¯ç»é¢ã®å·¦ä¸ããå®ç¾©,ãã¯ã»ã«ã¯å·¦ä¸)"
+msgid " (for coordinates, % is from bottom left of display, pixels from top left)"
+msgstr " (座æ¨ï¼ % ã¯ç»é¢ã®å·¦ä¸ããå®ç¾©ããã¯ã»ã«ã¯å·¦ä¸ããå®ç¾©)"
#: ../gui/tcltk/d.m/fttext.tcl:126
msgid " text rotation (degrees counterclockwise)"
Modified: grass/branches/releasebranch_6_4/locale/po/grasswxpy_ja.po
--- grass/branches/releasebranch_6_4/locale/po/grasswxpy_ja.po 2012-03-04 12:43:05 UTC (rev 50991)
+++ grass/branches/releasebranch_6_4/locale/po/grasswxpy_ja.po 2012-03-05 08:10:54 UTC (rev 50992)
@@ -12,8 +12,8 @@
"Project-Id-Version: grasswxpy_ja\n"
-"PO-Revision-Date: 2012-02-08 19:40+0900\n"
-"Last-Translator: taniguchi <taniguti at apptec.co.jp>\n"
+"PO-Revision-Date: 2012-03-05 11:25+0900\n"
"Language: ja\n"
@@ -215,7 +215,7 @@
#: ../gui/wxpython/gui_modules/render.py:188
#, python-format
msgid "'%(cmd)s' failed. Details: %(det)s"
-msgstr ""
+msgstr "'%(cmd)s' ã失æãã¾ãããã詳細: %(det)s"
#: ../gui/wxpython/gui_modules/render.py:287
#, python-format
@@ -619,14 +619,15 @@
msgstr "DBãã¡ã¤ã«ã«æ¥ç¶è¨å®ãå®ç¾©ããã¦ãã¾ãã"
#: ../gui/wxpython/gui_modules/dbm_dialogs.py:71
-#, fuzzy, python-format
+#, python-format
msgid ""
"No attribute table linked to vector map <%(vector)s> found. %(msg)s\n"
"\n"
"New attribute table can be created by Attribute Table Manager."
msgstr ""
"ãã¯ãã«ããã <%(vector)s>ã¨ãªã³ã¯ãã屿§ãã¼ãã«ãè¦ã¤ããã¾ãã%(msg)s\n"
-"ãã®ã¡ãã»ã¼ã¸ã¯ãã¸ã¿ã¤ã¶è¨å®ã屿§ãã¼ãã«ããã¼ã¸ã£ã¼æ©è½ãå©ç¨ãã¦ãã¯ãã«ãããã¨å±æ§ãã¼ãã«ã®ãªã³ã¯ä»ããããäºã§æ¶ããã¨ãã§ãã¾ã"
+"\n"
+"屿§ãã¼ãã«ããã¼ã¸ã£ã¼æ©è½ãå©ç¨ãã¦æ°ãã屿§ãã¼ãã«ã使ããäºãã§ãã¾ã"
#: ../gui/wxpython/gui_modules/dbm_dialogs.py:88
msgid "Close dialog on submit"
@@ -1071,9 +1072,8 @@
msgstr "ä¸è¬"
#: ../gui/wxpython/gui_modules/gmodeler.py:3259
-#, fuzzy
msgid "Item properties"
-msgstr "ãã¼ã¿ããããã£"
+msgstr "ã¢ã¤ãã ã®ããããã£"
#: ../gui/wxpython/gui_modules/gmodeler.py:3267
msgid "Disabled:"
@@ -1145,7 +1145,7 @@
#: ../gui/wxpython/gui_modules/gmodeler.py:3530
msgid "Loop"
-msgstr ""
+msgstr "ã«ã¼ã"
#: ../gui/wxpython/gui_modules/gmodeler.py:3630
#: ../gui/wxpython/menustrings.py:875
@@ -1888,11 +1888,13 @@
msgstr "ãã¯ãã«ããããä½ãã¾ãã <%s>"
#: ../gui/wxpython/gui_modules/gdialogs.py:363
+#, python-format
msgid ""
"Invalid or empty key column.\n"
"Unable to create vector map <%s>."
-msgstr "ãã¯ãã«ããããä½ãã¾ãã <%s>"
+msgstr ""
+"䏿£ãããã¯ç©ºã®ãã¼é
ç®\n"
+"ãã¯ãã«ããããä½ãã¾ãã <%s>"
#: ../gui/wxpython/gui_modules/gdialogs.py:380
#, python-format
@@ -2095,11 +2097,12 @@
msgstr "ãã¤ã¢ãã° %s ãªã¼ãã³"
#: ../gui/wxpython/gui_modules/gdialogs.py:1283
-#, fuzzy
msgid ""
"No layers marked for import.\n"
"Operation canceled."
-msgstr "ãããã¬ã¤ã¤ã¼ã鏿ããã¦ãã¾ãã å¦çã¯ãã£ã³ã»ã«ããã¾ãã "
+msgstr ""
+"ãããã¬ã¤ã¤ã¼ã鏿ããã¦ãã¾ãã\n"
+"å¦çã¯ãã£ã³ã»ã«ããã¾ãã "
#: ../gui/wxpython/gui_modules/gdialogs.py:1356
msgid "Import DXF layers"
@@ -2163,9 +2166,9 @@
msgstr "ãã³ãã¬ã¼ã:"
#: ../gui/wxpython/gui_modules/utils.py:303
+#, python-format
msgid "Vector map <%(map)s>: %(msg)s\n"
-msgstr "æ°ãããã¯ãã«ããã <%s> ã使ããã¾ãã"
+msgstr "ãã¯ãã«ããã <%(map)s>: %(msg)s\n"
#: ../gui/wxpython/gui_modules/utils.py:526
#, python-format
@@ -4393,9 +4396,9 @@
msgstr "ãã¯ãã«è¨å®"
#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2979
+#, python-format
msgid "%s properties"
-msgstr "ãããã㣠"
+msgstr "%s ãããã㣠"
#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3029
msgid "Data selection"
@@ -4588,9 +4591,9 @@
#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3869
#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4555
+#, python-format
msgid "%(rast)s: type %(type)s"
-msgstr "%(rast): ã¿ã¤ã %(type)"
+msgstr "%(rast)s: ã¿ã¤ã %(type)s"
#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3888
msgid "Type of legend"
@@ -4981,7 +4984,6 @@
msgstr "æ¡å¼µåãªã¹ã"
#: ../gui/wxpython/gui_modules/ghelp.py:805
-#, fuzzy
msgid "Fetch full info including description and keywords"
msgstr "説æããã¼ã¯ã¼ããªã©å®å
¨ãªæ
å ±ãåå¾ï¼æéããããã¾ãï¼"
@@ -5019,29 +5021,24 @@
msgstr "GRASSã¢ããªã³ã®SVNï¼æ£è
ãï¼ããã¢ã¸ã¥ã¼ã«ã®ãªã¹ããåå¾ä¸(ãå¾
ã¡ãã ãã)..."
#: ../gui/wxpython/gui_modules/ghelp.py:1133
-#, fuzzy
msgid "Uninstall GRASS Addons extensions"
-msgstr "æ¡å¼µåãªã¹ã"
+msgstr "GRASS ã¢ããªã³GRASSã¢ã¸ã¥ã¼ã«ã®ã¢ã³ã¤ã³ã¹ãã¼ã«"
#: ../gui/wxpython/gui_modules/ghelp.py:1142
-#, fuzzy
msgid "List of installed extensions"
+msgstr "ã¤ã³ã¹ãã¼ã«ãããã¢ããªã³GRASSã¢ã¸ã¥ã¼ã«ã®ä¸è¦§"
#: ../gui/wxpython/gui_modules/ghelp.py:1148
-#, fuzzy
msgid "&Uninstall"
-msgstr "ã¤ã³ã¹ãã¼ã«(&I)"
+msgstr "ã¢ã³ã¤ã³ã¹ãã¼ã«(&U)"
#: ../gui/wxpython/gui_modules/ghelp.py:1149
-#, fuzzy
msgid "Uninstall selected AddOns extensions"
-msgstr "鏿ãããã¢ããªã³GRASSã¢ã¸ã¥ã¼ã«ã®ã¤ã³ã¹ãã¼ã«"
+msgstr "鏿ãããã¢ããªã³GRASSã¢ã¸ã¥ã¼ã«ã®ã¢ã³ã¤ã³ã¹ãã¼ã«"
#: ../gui/wxpython/gui_modules/ghelp.py:1196
-#, fuzzy
msgid "No extension selected for removal. Operation canceled."
+msgstr "åé¤ããã¢ããªã³GRASSã¢ã¸ã¥ã¼ã«ã鏿ããã¦ãã¾ãã å¦çã¯ãã£ã³ã»ã«ããã¾ãã "
#: ../gui/wxpython/gui_modules/ghelp.py:1205
#, python-format
@@ -5051,17 +5048,19 @@
"\n"
"Do you want really to remove <%(ext)s> extension?"
msgstr ""
+"åé¤ããããã¡ã¤ã«ä¸è¦§:\n"
+"%(files)s\n"
+"\n"
+"ãããã®æ¡å¼µæ©è½ <%(ext)s> ãæ¬å½ã«åé¤ãã¾ãã?"
#: ../gui/wxpython/gui_modules/ghelp.py:1208
#: ../gui/wxpython/menustrings.py:236
-#, fuzzy
msgid "Remove extension"
-msgstr "é ç¹ã®åé¤ "
+msgstr "æ¡å¼µæ©è½ã®åé¤ "
#: ../gui/wxpython/gui_modules/ghelp.py:1233
-#, fuzzy
msgid "Extension"
-msgstr "çºå
度"
+msgstr "æ¡å¼µæ©è½"
#: ../gui/wxpython/gui_modules/ghelp.py:1357
msgid "&Next"
@@ -5072,9 +5071,9 @@
msgstr "å(&P)"
#: ../gui/wxpython/gui_modules/wxnviz.py:31
+#, python-format
msgid "3D view mode: %s\n"
-msgstr "3Dãã¥ã¼ã¢ã¼ããã¼ã«"
+msgstr "3Dãã¥ã¼ã¢ã¼ã: %s\n"
#: ../gui/wxpython/gui_modules/wxnviz.py:305
#, python-format
@@ -5429,6 +5428,10 @@
"\n"
"Option <%(opt)s>: read from standard input is not supported by wxGUI"
msgstr ""
+"次ã®ã³ãã³ããå®è¡ã§ãã¾ãã:\n"
+"%(cmd)s\n"
+"\n"
+"ãªãã·ã§ã³ <%(opt)s>: wxGUIã§ã¯æ¨æºå
¥åããã®èªè¾¼ã¯ãµãã¼ãããã¦ãã¾ãã"
#: ../gui/wxpython/gui_modules/goutput.py:625
msgid "Save file as..."
@@ -6775,18 +6778,15 @@
msgstr "ãã¼ãã« <%s> - å³ã¯ãªãã¯ã§åãåé¤"
#: ../gui/wxpython/gui_modules/dbm.py:865
-#, fuzzy
msgid "Add column"
msgstr "å追å "
#: ../gui/wxpython/gui_modules/dbm.py:873
#: ../gui/wxpython/gui_modules/dbm.py:924
-#, fuzzy
msgid "Column"
msgstr "å"
#: ../gui/wxpython/gui_modules/dbm.py:900
-#, fuzzy
msgid "Length"
msgstr "é·ã"
@@ -7322,7 +7322,7 @@
msgstr "ãããã»ããã®ä½æãã§ãã¾ããï¼ %s "
#: ../gui/wxpython/gis_set.py:742
+#, python-format
msgid ""
"GRASS is already running in selected mapset <%(mapset)s>\n"
"(file %(lock)s found).\n"
@@ -7332,7 +7332,7 @@
"Do you want to try to remove .gislock (note that you need permission for this operation) and continue?"
msgstr ""
"GRASSãã¯é¸æããããããã»ãã <%(mapset)s> ã§æ¢ã«åä½ãã¦ãã¾ã\n"
-"(ãã¡ã¤ã« %(lock)ãåå¨ãã¾ã).\n"
+"(ãã¡ã¤ã« %(lock)sãåå¨ãã¾ã).\n"
"\n"
"åæä½¿ç¨ã¯ã§ãã¾ããã\n"
"\n"
@@ -7348,6 +7348,9 @@
"\n"
"If you really are running another GRASS session doing this could corrupt your data. Have another look in the processor manager just to be sure..."
msgstr ""
+"æ¬å½ã«ããããã§ãã?\n"
+"\n"
+"ä»ã«GRASSã®ã»ãã·ã§ã³ãåä½ä¸ã§ããã°ããã¼ã¿ãç ´æããå¯è½æ§ãããã¾ããã¿ã¹ã¯ããã¼ã¸ã£ã«ã¦å度確èªãã¦ãã ãã..."
#: ../gui/wxpython/gis_set.py:771
#, python-format
@@ -7876,16 +7879,14 @@
msgstr "ASCII 3Dã®ã¤ã³ãã¼ã "
#: ../gui/wxpython/menustrings.py:83
-#, fuzzy
msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
-msgstr "3D ASCII ã©ã¹ã¿ã¼ããã¹ããã¡ã¤ã«ã 3Dã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ã¸ã¤ã³ãã¼ã "
+msgstr "3D ASCII ã©ã¹ã¿ã¼ããã¹ããã¡ã¤ã«ã ï¼ãã¤ããªï¼3Dã©ã¹ã¿ã¼ãããã¬ã¤ã¤ã¼ã¸ã¤ã³ãã¼ã "
#: ../gui/wxpython/menustrings.py:84
msgid "Vis5D import"
msgstr "Vis5Dã®ã¤ã³ãã¼ã "
#: ../gui/wxpython/menustrings.py:85
-#, fuzzy
msgid "Imports 3-dimensional Vis5D files (i.e. the V5D file with 1 variable and 1 time step)."
msgstr "3D Vis5Dãã¡ã¤ã«ã®ã¤ã³ãã¼ã (ã¤ã¾ã1夿°ã¨1ã¿ã¤ã ã¹ãããã使ç¨ããv5dãã¡ã¤ã«) "
@@ -8083,7 +8084,6 @@
msgstr "ASCII 3Dã®ã¨ã¯ã¹ãã¼ã "
#: ../gui/wxpython/menustrings.py:137
-#, fuzzy
msgid "Converts a 3D raster map layer into an ASCII text file."
msgstr "3D ã©ã¹ã¿ã¼ããããASCIIããã¹ããã¡ã¤ã«ã«å¤æ"
@@ -8092,14 +8092,12 @@
msgstr "Vis5Dã®ã¨ã¯ã¹ãã¼ã "
#: ../gui/wxpython/menustrings.py:139
-#, fuzzy
msgid "Exports GRASS 3D raster map to 3-dimensional Vis5D file."
-msgstr "GRASS 3D ã©ã¹ã¿ã¼ãããã3D Vis5D ãã¡ã¤ã«ã«ã¨ãã¹ãã¼ã "
+msgstr "GRASS 3D ã©ã¹ã¿ã¼ãããã3D Vis5D ãã¡ã¤ã«ã«ã¨ã¯ã¹ãã¼ã "
#: ../gui/wxpython/menustrings.py:141
-#, fuzzy
msgid "Converts 3D raster maps into the VTK-ASCII format."
-msgstr "ã©ã¹ã¿ã¼ãããã VTK-Ascii ãã©ã¼ãããã¸å¤æ"
+msgstr "3Dã©ã¹ã¿ã¼ãããã VTK-Ascii ãã©ã¼ãããã¸å¤æ"
#: ../gui/wxpython/menustrings.py:142
msgid "Export database table"
@@ -8142,18 +8140,16 @@
msgstr "ãªã¹ã "
#: ../gui/wxpython/menustrings.py:154
-#, fuzzy
msgid "Lists available GRASS data base files of the user-specified data type."
-msgstr "ç¾å¨ä½¿ç¨ã§ããããããåºåå¯è½ãªå½¢å¼ã®ä¸è¦§ã表示 "
+msgstr "ã¦ã¼ã¶ã¼ãæå®ãããã¼ã¿åã®ãç¾å¨ä½¿ç¨ã§ããGRASSãã¼ã¿ãã¼ã¹ãã¡ã¤ã«ã®ä¸è¦§ã表示 "
#: ../gui/wxpython/menustrings.py:155
msgid "List filtered"
msgstr "ãã£ã«ã¿ã¼ "
#: ../gui/wxpython/menustrings.py:156
-#, fuzzy
msgid "Lists available GRASS data base files of the user-specified data type optionally using the search pattern."
+msgstr "ã¦ã¼ã¶ã¼ãæ¤ç´¢ãªãã·ã§ã³ã使ã£ã¦æå®ãããã¼ã¿åã®ãç¾å¨ä½¿ç¨ã§ããGRASSãã¼ã¿ãã¼ã¹ãã¡ã¤ã«ã®ä¸è¦§ã表示 "
#: ../gui/wxpython/menustrings.py:158
msgid "Renames data base element files in the user's current mapset."
@@ -8270,13 +8266,12 @@
msgstr "nviz - GRASSã®è¦è¦åï¼ã¢ãã¡ã¼ã·ã§ã³ãã¼ã« "
#: ../gui/wxpython/menustrings.py:188
-#, fuzzy
msgid "3D image rendering"
-msgstr "èªåã¬ã³ããªã³ã°ãæå¹ã«ãã"
+msgstr "3Dã¤ã¡ã¼ã¸ã®ã¬ã³ããªã³ã°"
#: ../gui/wxpython/menustrings.py:189
msgid "Creates a 3D rendering of GIS data."
-msgstr ""
+msgstr "GISãã¼ã¿ã®3Dã¬ã³ããªã³ã°ã使ãã"
#: ../gui/wxpython/menustrings.py:190
msgid "Bearing/distance to coordinates"
@@ -8440,25 +8435,23 @@
#: ../gui/wxpython/menustrings.py:232
msgid "Install extension from add-ons"
-msgstr "ã¢ããªã³ã®ã¨ã¯ã¹ãã³ã·ã§ã³ãã¤ã³ã¹ãã¼ã«"
+msgstr "ã¢ããªã³ãã¤ã³ã¹ãã¼ã«"
#: ../gui/wxpython/menustrings.py:233
-#, fuzzy
msgid "Installs new extension from GRASS AddOns SVN repository."
-msgstr "GRASSã®ã¢ããªã³ SVNã¬ãã¸ããªããæ°ããã¨ã¯ã¹ãã³ã·ã§ã³ãã¤ã³ã¹ãã¼ã«"
+msgstr "GRASSã®ã¢ããªã³ SVNã¬ãã¸ããªããæ°ããã¢ããªã³ãã¤ã³ã¹ãã¼ã«"
#: ../gui/wxpython/menustrings.py:234
-#, fuzzy
msgid "Update installed extensions"
+msgstr "ã¤ã³ã¹ãã¼ã«ãããã¢ããªã³ãæ´æ°ãã"
#: ../gui/wxpython/menustrings.py:235
msgid "Rebuilds all locally installed GRASS Addons extensions."
-msgstr ""
+msgstr "ãã¼ã«ã«ã«ã¤ã³ã¹ãã¼ã«ãããå
¨ã¦ã®GRASSã¢ããªã³ããªãã«ããã"
#: ../gui/wxpython/menustrings.py:237
msgid "Removes installed GRASS AddOns extension."
-msgstr ""
+msgstr "ã¤ã³ã¹ãã¼ã«ãããGRASSã¢ããªã³ãåé¤ãã"
#: ../gui/wxpython/menustrings.py:238 ../gui/wxpython/menustrings.py:860
msgid "Preferences"
@@ -9489,7 +9482,6 @@
msgstr "ç·å½¢å帰"
#: ../gui/wxpython/menustrings.py:506
-#, fuzzy
msgid "Calculates linear regression from two raster maps: y = a + b*x."
msgstr "2ã¤ã®ã©ã¹ã¿ã¼ãããã§ã®ç·å½¢å帰è¨ç®: y = a + b*x"
@@ -9606,9 +9598,8 @@
msgstr "ãã¯ãã«ãããã¡ã¿ãã¼ã¿æ´æ°"
#: ../gui/wxpython/menustrings.py:537
-#, fuzzy
msgid "Topology maintenance"
-msgstr "ãµãã¼ããã¡ã¤ã«ã®ä¿å® "
+msgstr "ãããã¸ã¼ã®ä¿å® "
#: ../gui/wxpython/menustrings.py:538
msgid "Create or rebuild topology"
@@ -9699,9 +9690,8 @@
msgstr "ãã¯ãã«ãããã®å±æ§ãåºå"
#: ../gui/wxpython/menustrings.py:564
-#, fuzzy
msgid "Feature selection"
-msgstr "æé¢å³"
+msgstr "ãã£ã¼ãã£ã¼ã®é¸æ"
#: ../gui/wxpython/menustrings.py:565
msgid "Query with attributes"
@@ -10076,7 +10066,6 @@
msgstr "ãã¤ã³ãã®ä½ç½®ã®ãã¯ãã«ã®å¤ããã¼ãã«ã«ã¢ãããã¼ã"
#: ../gui/wxpython/menustrings.py:669
-#, fuzzy
msgid "Update database values from vector"
msgstr "ãã¯ãã«ã®ãã£ã¼ãã£ãããã¼ã¿ãã¼ã¹ã®å¤ãè¨å®"
@@ -10365,9 +10354,8 @@
msgstr "é«éãã¼ãªã¨é夿ãè¡ãã¾ã "
#: ../gui/wxpython/menustrings.py:743
-#, fuzzy
msgid "Satellite images tools"
-msgstr "ã¤ã¡ã¼ã¸ãµã¤ãºã®è¨å®"
+msgstr "è¡æç»åãã¼ã«"
#: ../gui/wxpython/menustrings.py:744
msgid "Atmospheric correction"
@@ -10378,17 +10366,16 @@
msgstr "6Sã¢ã«ã´ãªãºã ã使ç¨ã大æ°è£æ£ãè¡ãã¾ã"
#: ../gui/wxpython/menustrings.py:746
-#, fuzzy
msgid "Topographic correction"
-msgstr "大æ°è£æ£ "
+msgstr "å°å½¢çè£æ£ "
#: ../gui/wxpython/menustrings.py:747
msgid "Computes topographic correction of reflectance."
-msgstr ""
+msgstr "åå°çã®å°å½¢çè£æ£ãè¨ç®ãã"
#: ../gui/wxpython/menustrings.py:748
msgid "Satellite images products"
-msgstr ""
+msgstr "è¡æç»å製å"
#: ../gui/wxpython/menustrings.py:749
msgid "Tasseled cap vegetation index"
@@ -10467,12 +10454,10 @@
msgstr "æé¢å³"
#: ../gui/wxpython/menustrings.py:772
-#, fuzzy
msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map."
msgstr "2Dæ¨é«ãããã«åºã¥ãã3Dã©ã¹ã¿ã¼ãã2Dã®ã©ã¹ã¿ã¼æé¢ãããã使"
#: ../gui/wxpython/menustrings.py:774
-#, fuzzy
msgid "Calculates numerically transient, confined groundwater flow in three dimensions."
msgstr "3次å
ã®å°ä¸æ°´ã®æµãã«éå®ãã䏿çãªæ°å¤è§£æããã°ã©ã "
@@ -10501,9 +10486,8 @@
msgstr "3Dã°ãªããçµ±è¨"
#: ../gui/wxpython/menustrings.py:781
-#, fuzzy
msgid "Generates volume statistics for 3D raster maps."
-msgstr "3Dã©ã¹ã¿ã¼ãããã«ããã¦çµ±è¨è§£æå¤ã使"
+msgstr "3Dã©ã¹ã¿ã¼ãããã«ããã¦ããªã¥ã¼ã çµ±è¨è§£æå¤ã使"
#: ../gui/wxpython/menustrings.py:782
msgid "Univariate statistics for volumes"
