[GRASS-SVN] r50994 - grass/trunk/locale/po
Mon Mar 5 03:16:45 EST 2012
Author: neteler
Date: 2012-03-05 00:16:45 -0800 (Mon, 05 Mar 2012)
New Revision: 50994
   grass/trunk/locale/po/grasslibs_ja.po
   grass/trunk/locale/po/grassmods_ja.po
   grass/trunk/locale/po/grasswxpy_ja.po
Naoki Ueda and team: cont'ed
Modified: grass/trunk/locale/po/grasslibs_ja.po
--- grass/trunk/locale/po/grasslibs_ja.po	2012-03-05 08:14:15 UTC (rev 50993)
+++ grass/trunk/locale/po/grasslibs_ja.po	2012-03-05 08:16:45 UTC (rev 50994)
@@ -1,6 +1,6 @@
 # translation of grasslibs_ja.po to Japanese
 # This file is distributed under the same license as the GRASS package.
-# Copyright (C) 2005,2010 GRASS Development Team
+# Copyright (C) 2005,2010,2012 GRASS Development Team
 # Shinji Masumoto <masumoto at sci.osaka-cu.ac.jp>, 2004
 # Susumu Nonogaki <nonogaki at sci.osaka-cu.ac.jp>, 2005
@@ -13,8 +13,8 @@
 "Project-Id-Version: grasslibs_ja\n"
 "Report-Msgid-Bugs-To: \n"
 "POT-Creation-Date: 2012-01-28 11:12+0100\n"
-"PO-Revision-Date: 2011-11-15 15:01+0900\n"
-"Last-Translator: ueda <nao at locapoint.com>\n"
+"PO-Revision-Date: 2012-03-05 12:14+0900\n"
+"Last-Translator: Naoki Ueda <nao at locapoint.com>\n"
 "Language-Team: Japanese <grass-translations at lists.osgeo.org>\n"
 "Language: ja\n"
 "MIME-Version: 1.0\n"
@@ -2004,19 +2004,19 @@
 msgstr "グループ <%s> は次のラスターマップを参照します\n"
 #: ../lib/imagery/sigsetfile.c:41
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> is not current mapset"
-msgstr "グループ [%s in %s] の サブグループ [%s] のファイル [%s] を作成できません"
+msgstr "署名ファイル <%s> が作成できません。 サブグループ: <%s> 、グループ: <%s> - <%s> は現在のマップセットにありません"
 #: ../lib/imagery/sigsetfile.c:57
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s>"
+msgstr "署名ファイル <%s> が作成できません。 サブグループ: <%s> 、グループ: <%s>"
 #: ../lib/imagery/sigsetfile.c:86
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open signature file <%s> for subgroup <%s> of group <%s@%s>"
-msgstr "グループ [%s in %s] の サブグループ [%s] のファイル [%s] を開けません"
+msgstr "署名ファイル <%s> が開けません。 サブグループ: <%s> 、グループ:<%s@%s>"
 #: ../lib/imagery/fopen.c:23
 #, c-format
@@ -7013,6 +7013,242 @@
 msgid "End time must be later than start time"
 msgstr "東は西より大きくないといけません"
+#, fuzzy
+msgid "Unable to delete file '%s'. Reason: %s"
+msgstr "ファイル '%s' を削除できません"
+#, fuzzy
+msgid "Unable to rename directory '%s' to '%s'. Reason: %s"
+msgstr "ディレクトリ名を  '%s'  から  '%s' に変更できません"
+#, fuzzy
+msgid "Unable to remove directory '%s'. Reason: %s"
+msgstr "ディレクトリ  '%s' を削除できません"
+#, fuzzy
+msgid "Unable to delete prior null-cells file"
+#, fuzzy
+msgid "Unable to close the null-cells file"
+msgstr "追加ファイルにヘッドを書き込めません"
+#, fuzzy
+msgid "closecell: can't move [%s] to null-cells file [%s]"
+msgstr ""
+"closecell:  移動できません%s\n"
+"null ファイル %s"
+#, fuzzy
+msgid "Unable to delete the temporary null-cells file"
+msgstr "一時NULLファイルが見つかりません %s"
+#, fuzzy
+msgid "Unable to delete the empty temporary null-cells file"
+#, fuzzy
+msgid "Unable to delete the prior null-cells file"
+#, fuzzy
+msgid "Unable to close the 'cell' file"
+msgstr "ヘッドファイルを読み込めません"
+#, fuzzy
+msgid "Unable to delete prior 'fcell' file"
+#, fuzzy
+msgid "Unable to delete the prior %s file"
+msgstr "テーブル <%s> を削除できません"
+#, fuzzy
+msgid "Unable to close file"
+msgstr "ファイルが開けません %s"
+#, fuzzy
+msgid "Unable to delete the prior 'cell' file"
+#, fuzzy
+msgid "closecell: can't move [%s] to cell file [%s]"
+msgstr ""
+"セルファイル %s"
+#, fuzzy
+msgid "Unable to delete the temporary 'cell' file"
+msgstr "一時ファイルが開けません"
+#, fuzzy
+msgid "Unable to write quant file!"
+msgstr "量子化ファイルに書き込みできません!"
+#, fuzzy
+msgid "Unable to delete the %s file"
+#, fuzzy
+msgid "Unable to write f_format file for CELL maps"
+msgstr "セルマップにf_formatを書き込めません"
+msgid "Requested g3d map <%s> not found"
+msgstr "要求された3Dグリッドマップ <%s> は見つかりませんでした"
+#, fuzzy
+msgid "Unable to delete layer/category %d/%d line %d"
+msgstr "����� ���� ���\n"
+#, fuzzy
+msgid "Cannot open database %s"
+msgstr "���"
+#, fuzzy
+msgid "Cannot read topo for line [%d]"
+msgstr "���"
+#, fuzzy
+msgid "Output name '%s' is not valid rast name."
+msgstr "���."
+#, fuzzy
+msgid "Cannot get field info"
+msgstr "���"
+#, fuzzy
+msgid "Cannot open database"
+msgstr "���"
+#, fuzzy
+msgid "Output name '%s' is not valid vector name."
+msgstr "���."
+#, fuzzy
+msgid "Cannot open existing vector map <%s>"
+msgstr "���"
+#, fuzzy
+msgid "Cannot delete existing vector <%s>"
+msgstr "���"
+#, fuzzy
+msgid "Cannot open new vector %s"
+msgstr "���"
+#, fuzzy
+msgid "Cannot open history file for vector '%s'"
+msgstr "���"
+#, fuzzy
+msgid "Can't open directory %s"
+msgstr "���"
+#, fuzzy
+msgid "No such graphics monitor as <%s>.\n"
+msgstr "����������<%s> � �����.\n"
+#, fuzzy
+msgid "Please run \"d.mon\" to select a valid graphics monitor.\n"
+msgstr "�����\"d.mon\" ����� �����������\n"
+#, fuzzy
+msgid "Error - Monitor <%s> is in use.\n"
+msgstr "��� - ����<%s> ���\n"
+#, fuzzy
+msgid "Error - Could not complete locking process for monitor <%s>.\n"
+msgstr "��� - � �� ����������(lock) ������<%s>.\n"
+#, fuzzy
+msgid "Error - Can't set up pipe to graphics device.\n"
+msgstr "��� - ����� (pipe) ������� �����.\n"
+#, fuzzy
+msgid "Error - Graphics monitor <%s> not running!\n"
+msgstr "��� - ����������<%s> � ����\n"
+#, fuzzy
+msgid "Please start graphics monitor <%s>.\n"
+msgstr "���� ����������<%s>.\n"
+#, fuzzy
+msgid "Not connected...\n"
+msgstr "�������...\n"
+#, fuzzy
+msgid "Couldn't connect to monitor. Will try once more.\n"
+msgstr "����� ����� ���� ���� ����\n"
+#, fuzzy
+msgid "ERROR: GISBASE not set\n"
+msgstr "���: GISBASE � �����\n"
+#, fuzzy
+msgid "%s/%s' was found in more mapsets (also found in <%s>)"
+msgstr "%s/%s' was found in more mapsets (also found in <%s>) "
+msgid "taking too long to find points for interpolation--please change the region to area where your points are. Continuing calculations..."
+msgstr "補間のポイントを見つけるのに時間がかかりすぎています--領域をポイントのあるエリアに変更してください. 引き続き計算しています..."
+msgid "Reading lines from vector map ... "
+msgstr "ベクトルマップからラインを読み込んでいます ...  "
+msgid "Reading nodes from vector map ... "
+msgstr "ベクトルマップからノードを読み込んでいます ...  "
+msgid "strip exists with insufficient data"
+msgstr "stripは不十分なデータと存在します"
+msgid "there are points outside specified 2D/3D region--ignored %d points"
+msgstr "指定された2D/3D 領域外にポイントがあります--無視された %d ポイント"
+msgid "ignoring %d points -- too dense"
+msgstr "ポイント %d を無視しています -- 密集しすぎです"
+msgid "some points outside of region -- will ignore..."
+msgstr "いくつかのポイントは領域外です -- 無視します..."
+msgid "Unable to feature %d from vector map <%s>"
+msgstr "Unable to feature %d from vector map <%s>"
+msgid "Invalid view position coordinates, using %f,%f"
+msgstr "不正な視点位置座標,用法は %f,%f"
+msgid "Unknown Location"
+msgstr "不明なロケーション"
+msgid "Too many arguments"
+msgstr "独立変数が多すぎます"
+msgid "Table has no columns"
+msgstr "テーブルには列がありません"
+msgid "Vector is not 3D"
+msgstr "ベクトルは3Dではありません"
+msgid "Cannot find z column <%s> (please verify name, e.g. with v.info)"
+msgstr "z 列 <%s> が見つかりません(名前を確認してください、 e.g. with v.info)"
+msgid "Column type of z column is not supported (must be integer or double)"
+msgstr "z列の列型はサポートされていません (整数型か倍でなければなりません)"
+msgid "Cannot read column type of smooth column"
+msgstr "スムース列のタイプを読み込めません"
+msgid "Column type of smooth column (datetime) is not supported"
+msgstr "スムース列 (日時) のタイプはサポートされていません"
+msgid "Column type of s column is not supported (must be integer or double)"
+msgstr " s列の列タイプはサポートされていません (整数または倍数でなければなりません)"
+msgid ""
+"\n"
+"%s invalid; Try again >"
+msgstr ""
+"\n"
+"%s 無効; 再試行 >  "
 #~ msgid "Partial build for OGR is not supported"
 #~ msgstr "OGR の差分作成はサポートされていません"
@@ -7202,18 +7438,6 @@
 #~ msgid "Unable to write raster row %i"
 #~ msgstr "ラスター行 %i を書き込めません"
-#, fuzzy
-#~ msgid "Unable to delete file '%s'. Reason: %s"
-#~ msgstr "ファイル '%s' を削除できません"
-#, fuzzy
-#~ msgid "Unable to rename directory '%s' to '%s'. Reason: %s"
-#~ msgstr "ディレクトリ名を  '%s'  から  '%s' に変更できません"
-#, fuzzy
-#~ msgid "Unable to remove directory '%s'. Reason: %s"
-#~ msgstr "ディレクトリ  '%s' を削除できません"
 #~ msgid "not implemented"
 #~ msgstr "実行されていません"
@@ -7998,77 +8222,9 @@
 #~ msgid "can't create histogram for [%s in %s]"
 #~ msgstr "ヒストグラムを作成できません [%s in %s]"
-#, fuzzy
-#~ msgid "Unable to delete prior null-cells file"
-#, fuzzy
-#~ msgid "Unable to close the null-cells file"
-#~ msgstr "追加ファイルにヘッドを書き込めません"
-#, fuzzy
-#~ msgid "closecell: can't move [%s] to null-cells file [%s]"
-#~ msgstr ""
-#~ "closecell:  移動できません%s\n"
-#~ "null ファイル %s"
-#, fuzzy
-#~ msgid "Unable to delete the temporary null-cells file"
-#~ msgstr "一時NULLファイルが見つかりません %s"
-#, fuzzy
-#~ msgid "Unable to delete the empty temporary null-cells file"
-#, fuzzy
-#~ msgid "Unable to delete the prior null-cells file"
 #~ msgid "Error writing floating point format file for map %s"
 #~ msgstr " マップ%sに浮動小数点のフォーマットファイルを書き込みできません"
-#, fuzzy
-#~ msgid "Unable to close the 'cell' file"
-#~ msgstr "ヘッドファイルを読み込めません"
-#, fuzzy
-#~ msgid "Unable to delete prior 'fcell' file"
-#, fuzzy
-#~ msgid "Unable to delete the prior %s file"
-#~ msgstr "テーブル <%s> を削除できません"
-#, fuzzy
-#~ msgid "Unable to close file"
-#~ msgstr "ファイルが開けません %s"
-#, fuzzy
-#~ msgid "Unable to delete the prior 'cell' file"
-#, fuzzy
-#~ msgid "closecell: can't move [%s] to cell file [%s]"
-#~ msgstr ""
-#~ "セルファイル %s"
-#, fuzzy
-#~ msgid "Unable to delete the temporary 'cell' file"
-#~ msgstr "一時ファイルが開けません"
-#, fuzzy
-#~ msgid "Unable to write quant file!"
-#~ msgstr "量子化ファイルに書き込みできません!"
-#, fuzzy
-#~ msgid "Unable to delete the %s file"
-#, fuzzy
-#~ msgid "Unable to write f_format file for CELL maps"
-#~ msgstr "セルマップにf_formatを書き込めません"
 #~ msgid "G_distance_point_to_line_segment: shouldn't happen: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
 #~ msgstr "G_distance_point_to_line_segment: 起こりえません: コード=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
@@ -8081,162 +8237,6 @@
 #~ msgid "Illegal table map name <%s>. Character <%c> not allowed.\n"
 #~ msgstr "不正なテーブルマップ名 <%s>. 文字 <%c> は許可されていません.\n"
-#~ msgid "Requested g3d map <%s> not found"
-#~ msgstr "要求された3Dグリッドマップ <%s> は見つかりませんでした"
-#, fuzzy
-#~ msgid "Unable to delete layer/category %d/%d line %d"
-#~ msgstr "����� ���� ���\n"
-#, fuzzy
-#~ msgid "Cannot open database %s"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Cannot read topo for line [%d]"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Output name '%s' is not valid rast name."
-#~ msgstr "���."
-#, fuzzy
-#~ msgid "Cannot get field info"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Cannot open database"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Output name '%s' is not valid vector name."
-#~ msgstr "���."
-#, fuzzy
-#~ msgid "Cannot open existing vector map <%s>"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Cannot delete existing vector <%s>"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Cannot open new vector %s"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Cannot open history file for vector '%s'"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Can't open directory %s"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "No such graphics monitor as <%s>.\n"
-#~ msgstr "����������<%s> � �����.\n"
-#, fuzzy
-#~ msgid "Please run \"d.mon\" to select a valid graphics monitor.\n"
-#~ msgstr "�����\"d.mon\" ����� �����������\n"
-#, fuzzy
-#~ msgid "Error - Monitor <%s> is in use.\n"
-#~ msgstr "��� - ����<%s> ���\n"
-#, fuzzy
-#~ msgid "Error - Could not complete locking process for monitor <%s>.\n"
-#~ msgstr "��� - � �� ����������(lock) ������<%s>.\n"
-#, fuzzy
-#~ msgid "Error - Can't set up pipe to graphics device.\n"
-#~ msgstr "��� - ����� (pipe) ������� �����.\n"
-#, fuzzy
-#~ msgid "Error - Graphics monitor <%s> not running!\n"
-#~ msgstr "��� - ����������<%s> � ����\n"
-#, fuzzy
-#~ msgid "Please start graphics monitor <%s>.\n"
-#~ msgstr "���� ����������<%s>.\n"
-#, fuzzy
-#~ msgid "Not connected...\n"
-#~ msgstr "�������...\n"
-#, fuzzy
-#~ msgid "Couldn't connect to monitor. Will try once more.\n"
-#~ msgstr "����� ����� ���� ���� ����\n"
-#, fuzzy
-#~ msgid "ERROR: GISBASE not set\n"
-#~ msgstr "���: GISBASE � �����\n"
-#, fuzzy
-#~ msgid "%s/%s' was found in more mapsets (also found in <%s>)"
-#~ msgstr "%s/%s' was found in more mapsets (also found in <%s>) "
-#~ msgid "taking too long to find points for interpolation--please change the region to area where your points are. Continuing calculations..."
-#~ msgstr "補間のポイントを見つけるのに時間がかかりすぎています--領域をポイントのあるエリアに変更してください. 引き続き計算しています..."
-#~ msgid "Reading lines from vector map ... "
-#~ msgstr "ベクトルマップからラインを読み込んでいます ...  "
-#~ msgid "Reading nodes from vector map ... "
-#~ msgstr "ベクトルマップからノードを読み込んでいます ...  "
-#~ msgid "strip exists with insufficient data"
-#~ msgstr "stripは不十分なデータと存在します"
-#~ msgid "there are points outside specified 2D/3D region--ignored %d points"
-#~ msgstr "指定された2D/3D 領域外にポイントがあります--無視された %d ポイント"
-#~ msgid "ignoring %d points -- too dense"
-#~ msgstr "ポイント %d を無視しています -- 密集しすぎです"
-#~ msgid "some points outside of region -- will ignore..."
-#~ msgstr "いくつかのポイントは領域外です -- 無視します..."
-#~ msgid "Unable to feature %d from vector map <%s>"
-#~ msgstr "Unable to feature %d from vector map <%s>"
-#~ msgid "Invalid view position coordinates, using %f,%f"
-#~ msgstr "不正な視点位置座標,用法は %f,%f"
-#~ msgid "Unknown Location"
-#~ msgstr "不明なロケーション"
-#~ msgid "Too many arguments"
-#~ msgstr "独立変数が多すぎます"
-#~ msgid "Table has no columns"
-#~ msgstr "テーブルには列がありません"
-#~ msgid "Vector is not 3D"
-#~ msgstr "ベクトルは3Dではありません"
-#~ msgid "Cannot find z column <%s> (please verify name, e.g. with v.info)"
-#~ msgstr "z 列 <%s> が見つかりません(名前を確認してください、 e.g. with v.info)"
-#~ msgid "Column type of z column is not supported (must be integer or double)"
-#~ msgstr "z列の列型はサポートされていません (整数型か倍でなければなりません)"
-#~ msgid "Cannot read column type of smooth column"
-#~ msgstr "スムース列のタイプを読み込めません"
-#~ msgid "Column type of smooth column (datetime) is not supported"
-#~ msgstr "スムース列 (日時) のタイプはサポートされていません"
-#~ msgid "Column type of s column is not supported (must be integer or double)"
-#~ msgstr " s列の列タイプはサポートされていません (整数または倍数でなければなりません)"
-#~ msgid ""
-#~ "\n"
-#~ "%s invalid; Try again >"
-#~ msgstr ""
-#~ "\n"
-#~ "%s 無効; 再試行 >  "
 #~ msgid "Unable to open driver <%s>"
 #~ msgstr "ドライバー <%s> を開けません"
Modified: grass/trunk/locale/po/grassmods_ja.po
--- grass/trunk/locale/po/grassmods_ja.po	2012-03-05 08:14:15 UTC (rev 50993)
+++ grass/trunk/locale/po/grassmods_ja.po	2012-03-05 08:16:45 UTC (rev 50994)
@@ -14,7 +14,7 @@
 "Project-Id-Version: grassmods_ja\n"
-"PO-Revision-Date: 2012-02-01 16:13+0900\n"
+"PO-Revision-Date: 2012-03-05 11:56+0900\n"
 "Language: ja\n"
@@ -2215,7 +2215,7 @@
 #: ../misc/m.nviz.image/main.c:55
 msgid "Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster data) in 3D."
-msgstr ""
+msgstr "曲面(ラスターデータ)、2D/3Dベクトルデータ、体積(3Dラスターデータ)をレンダリングする"
 #: ../misc/m.nviz.image/main.c:138
 #, c-format
@@ -2544,15 +2544,13 @@
 #: ../raster/r.external/window.c:93 ../raster/r.in.gdal/main.c:635
 #: ../vector/v.in.ogr/main.c:1257
-#, fuzzy
 msgid "Default region for this location updated"
-msgstr "投影情報はアップデートされました!  "
+msgstr "このロケーションのデフォルト領域が更新されました  "
 #: ../raster/r.external/window.c:96 ../raster/r.in.gdal/main.c:638
 #: ../vector/v.in.ogr/main.c:1260
-#, fuzzy
 msgid "Region for the current mapset updated"
-msgstr "<%s> はすでに現存のマップセットです"
+msgstr "現在のマップセットの領域が更新されました"
 #: ../raster/r.external/list.c:22
 #, fuzzy
@@ -2674,14 +2672,13 @@
 #: ../raster/r.external/main.c:105 ../raster/r.in.gdal/main.c:144
 #: ../vector/v.in.ogr/main.c:259 ../vector/v.in.lidar/main.c:213
-#, fuzzy
 msgid "Extend region extents based on new dataset"
-msgstr "データセットをもとにロケーションを拡張"
+msgstr "新しいデータセットをもとにロケーションを拡張"
 #: ../raster/r.external/main.c:106 ../raster/r.in.gdal/main.c:146
 #: ../vector/v.in.ogr/main.c:261
 msgid "Also updates the default region if in the PERMANENT mapset"
-msgstr ""
+msgstr "PERMANENTマップセットのデフォルト領域も更新します。"
 #: ../raster/r.external/main.c:110
 msgid "Require exact range"
@@ -8040,7 +8037,7 @@
 #: ../raster/r.in.bin/main.c:252
 msgid "Signed data (two's complement)"
-msgstr ""
+msgstr "署名済みデータ(2の補数)"
 #: ../raster/r.in.bin/main.c:253 ../raster/r.in.bin/main.c:258
 #: ../raster/r.in.bin/main.c:287 ../raster/r.in.bin/main.c:348
@@ -9461,7 +9458,7 @@
 #: ../raster/r.univar/r.univar_main.c:36
 msgid "Raster map used for zoning, must be of type CELL"
-msgstr ""
+msgstr "ゾーニングに使用されたDラスターマップはCELLタイプでなければなりません"
 #: ../raster/r.univar/r.univar_main.c:51
 #: ../raster/r.univar/r3.univar_main.c:52 ../vector/v.univar/main.c:89
@@ -9499,7 +9496,7 @@
 #: ../raster/r.univar/r3.univar_main.c:37
 msgid "3D Raster map used for zoning, must be of type CELL"
-msgstr "ゾーニングに使用された3Dラスターマップ, タイプCELLでなければなりません"
+msgstr "ゾーニングに使用された3DラスターマップはCELLタイプでなければなりません"
 #: ../raster/r.univar/r3.univar_main.c:102
 msgid "Calculates univariate statistics from the non-null 3d cells of a raster3d map."
@@ -9678,7 +9675,7 @@
 #: ../raster/r.sunmask/g_solposition.c:88
 #, c-format
 msgid "Specified point %f, %f outside of current region, is that intended? Anyway, it will be used."
-msgstr ""
+msgstr "指定されたポイント %f, %f は現在の領域外ですが適用されました。意図的に指定されましたか?"
 #: ../raster/r.sunmask/g_solposition.c:98
 msgid "Unable to get projection info of current location"
@@ -12878,7 +12875,7 @@
 #: ../raster/r.out.gdal/main.c:445
 #, c-format
 msgid "Precision loss: The range of <%s> can not be accurately preserved with GDAL datatype Float32. This can be avoided by exporting to Int32 or Float64."
-msgstr ""
+msgstr "精度が失われます:レンジ <%s> GDALデータタイプ Float32では温存されません。 Int32もしくはFloat64でエクスポートすることで回避できます。"
 #: ../raster/r.out.gdal/main.c:453
 #, c-format
@@ -15261,7 +15258,7 @@
 #: ../imagery/i.rectify/main.c:125
 msgid "Target resolution (ignored if -c flag used)"
-msgstr ""
+msgstr "目標精度(-c フラグがあれば無視されます)"
 #: ../imagery/i.rectify/main.c:133
 msgid "Amount of memory to use in MB"
@@ -15312,7 +15309,7 @@
 #: ../imagery/i.rectify/main.c:280 ../vector/v.rectify/main.c:182
 #, c-format
 msgid "target LOCATION %s, MAPSET %s:"
-msgstr ""
+msgstr "目標 ロケーション %s、マップセット %s:"
 #: ../imagery/i.rectify/main.c:283
 msgid "Orthorectification cancelled."
@@ -15320,7 +15317,7 @@
 #: ../imagery/i.rectify/main.c:298
 msgid "Target resolution must be > 0, ignored"
-msgstr ""
+msgstr "目標精度はゼロ以上である必要があります。値は無視されました。"
 #: ../imagery/i.rectify/main.c:309
 #, c-format
@@ -19647,11 +19644,11 @@
 #: ../general/g.access/exp_perms.c:11 ../general/g.access/exp_perms.c:29
 msgid "have"
-msgstr ""
+msgstr "所有"
 #: ../general/g.access/exp_perms.c:12
 msgid "read "
-msgstr ""
+msgstr "読込"
 #: ../general/g.access/exp_perms.c:15
 msgid "Everyone"
@@ -19659,7 +19656,7 @@
 #: ../general/g.access/exp_perms.c:16
 msgid "has"
-msgstr "
+msgstr "所有"
 #: ../general/g.access/exp_perms.c:19
 msgid "Only users in your group"
@@ -19680,7 +19677,7 @@
 #: ../general/g.access/exp_perms.c:32
 msgid "will"
-msgstr ""
+msgstr "今後"
 msgid "now"
@@ -20323,7 +20320,7 @@
 #: ../general/g.mlist/main.c:118
 msgid "Print fully-qualified map names (including mapsets)"
-msgstr ""
+msgstr "(マップセットを含む)完全なマップ名を入力"
 #: ../general/g.mlist/main.c:123
 msgid "Pretty printing in human readable format"
@@ -21420,7 +21417,7 @@
 #: ../vector/v.net.centrality/main.c:100
 msgid "Computes degree, centrality, betweeness, closeness and eigenvector centrality measures in the network."
-msgstr ""
+msgstr "ネットワークの角度、中心性、中間性、近接性、固有ベクトル中心性を計算する"
 #: ../vector/v.net.centrality/main.c:110 ../vector/v.net.centrality/main.c:116
 #: ../vector/v.net.centrality/main.c:130 ../vector/v.net.centrality/main.c:136
@@ -21837,9 +21834,9 @@
 msgstr "入力するファイル"
 #: ../vector/v.overlay/main.c:232
-#, fuzzy, c-format
+#, c-format
 msgid "No %s features found in vector map <%s>. Verify '%s' parameter."
-msgstr "%d のエリアがありますがエクスポートの指定がありません.'type' パラメーターを確認して下さい"
+msgstr "フィーチャー %s がベクトルマップ <%s> に存在しません。'%s' パラメータを確認してください"
 #: ../vector/v.overlay/main.c:267
 msgid "Collecting input attributes..."
@@ -21940,7 +21937,7 @@
 #: ../vector/v.kernel/main.c:194
 msgid "In network mode, normalize values by sum of density multiplied by length of each segment. Integral over the output map then gives 1.0 * mult"
-msgstr ""
+msgstr "ネットワークモードでは、各セグメント長を掛けた密度の合計で値を正規化します。 出力マップの総計では1.0の係数になります。"
 #: ../vector/v.kernel/main.c:199
 msgid "In network mode, multiply the result by number of input points."
@@ -22031,7 +22028,7 @@
 #: ../vector/v.kernel/function.c:220
 msgid "Dimension > 2 supported only by gaussian function"
-msgstr ""
+msgstr "2以上の次元はガウス関数のみでサポートされています"
 #: ../vector/v.in.ogr/main.c:123
 #, fuzzy
@@ -24955,9 +24952,8 @@
 msgstr "2つの最近接のフィーチャー間の関係を記述する値"
 #: ../vector/v.distance/main.c:152
-#, fuzzy
 msgid "cat;category of the nearest feature;dist;minimum distance to nearest feature;to_x;x coordinate of the nearest point on the 'to' feature;to_y;y coordinate of the nearest point on the 'to' feature;to_along;distance to the nearest point on the 'to' feature along that linear feature;to_angle;angle along the nearest linear feature in the 'to' map, measured CCW from the +x axis, in radians, between -Pi and Pi inclusive;to_attr;attribute of nearest feature given by to_column option"
-msgstr "cat;最近接フィーチャーのカテゴリー;dist;最近接フィーチャーへの最短距離;to_x;'to' フィーチャーにおける最近接ポイントの;x 座標;to_y;'to' フィーチャーにおける最近接ポイントのy 座標;to_along; 'from' マップにおけるポイント/セントロイド間の距離と'to'マップにおける線形フィーチャーの開始点, along this linear feature;to_angle;angle between the linear feature in 'to' マップと正のx軸の間の角度, 'from' マップ, 反時計周り, ラジアン, -PI と PIの間にあるポイント/セントロイドのロケーションにおける'to' マップと正のx軸の間の角度;to_attr;to_column オプションによって与えられている最近接フィーチャーの属性"
+msgstr "cat;最近接フィーチャーのカテゴリー;dist;最近接フィーチャーへの最短距離;to_x;'to' フィーチャーにおける最近接ポイントのx 座標;to_y;'to' フィーチャーにおける最近接ポイントのy 座標;to_along;'to' フィーチャーにおける最近接ポイントへの線形フィーチャーに沿った距離;o_angle;'to' フィーチャーにおける最近接の線形フィーチャーに沿った角度。X軸プラス方向を基点に反時計回りに-πからπの間のラジアン値;to_attr;to_column オプションによって与えられている最近接フィーチャーの属性"
 #: ../vector/v.distance/main.c:173
 msgid "Column name(s) where values specified by 'upload' option will be uploaded"
@@ -24989,9 +24985,8 @@
 msgstr "閾値内のすべてのフィーチャーへの距離を計算します"
 #: ../vector/v.distance/main.c:199
-#, fuzzy
 msgid "Output is written to stdout but may be uploaded to a new table created by this module; multiple 'upload' options may be used."
-msgstr "出力はstdoutに書き込まれましたがこのモジュールによって作成された新しい表にアップロードされた可能性があります. Fromカテゴリーは重複しているかもしれません.  "
+msgstr "出力はstdoutに書き込まれましたがこのモジュールによって作成された新しい表にアップロードされた可能性があります. 複数のアップロードオプションが使われているかもしれません.  "
 #: ../vector/v.distance/main.c:254
 msgid "to_column option missing"
@@ -26236,9 +26231,8 @@
 msgstr "不正な入力フォーマット: %s  "
 #: ../vector/v.net.timetable/main.c:504
-#, fuzzy
 msgid "'From' and 'To' stops are the same"
-msgstr "入力と出力で同一のロケーションは指定出来ません"
+msgstr "同一の入力と出力は指定出来ません"
 #: ../vector/v.net.timetable/main.c:513
 msgid "No path between the stops"
@@ -26642,7 +26636,7 @@
 #: ../vector/v.out.ogr/args.c:82
 msgid "Skip export of GRASS category ID ('cat') attribute"
-msgstr ""
+msgstr "GRASSカテゴリID('cat'属性)のエクスポートをスキップ"
 #: ../vector/v.out.ogr/args.c:88
 msgid "Also export features without category (not labeled). Otherwise only features with category are exported."
@@ -27111,7 +27105,7 @@
 #: ../vector/v.select/args.c:57
 msgid "overlap;features partially or completely overlap;equals;features are spatially equals (using GEOS);disjoint;features do not spatially intersect (using GEOS);intersects;features spatially intersect (using GEOS);touches;features spatially touches (using GEOS);crosses;features spatially crosses (using GEOS);within;feature A is completely inside feature B (using GEOS);contains;feature B is completely inside feature A (using GEOS);overlaps;features spatially overlap (using GEOS);relate;feature A is spatially related to feature B (using GEOS, requires 'relate' option);"
-msgstr ""
+msgstr "overlap;フィーチャーが部分的あるいは全体的にオーバーラップする;equals;フィーチャーが空間的に等しい(GEOSを使用);disjoint;フィーチャーが空間的に交差(intersect)していない(GEOSを使用);intersects;フィーチャーが空間的に交差(intersect)する(GEOSを使用);touches;フィーチャーが空間的に接する(GEOSを使用);crosses;フィーチャーが空間的に交差(cross)する (GEOSを使用);within;フィーチャーAが完全にフィーチャーBの内部にある(GEOSを使用);contains;フィーチャーBが完全にフィーチャーAの内部にある(GEOSを使用);overlaps;フィーチャーが空間的にオーバーラップしている(GEOSを使用);relate;フィーチャーA は空間的にフィーチャーBと関連する(GEOSを使用, 'relate'オプションが必要);"
 #: ../vector/v.select/args.c:74
 msgid "Intersection Matrix Pattern used for 'relate' operator"
@@ -29237,11 +29231,11 @@
 #: ../vector/v.generalize/main.c:511
 msgid "reduced"
-msgstr ""
+msgstr "減少"
 msgid "changed"
-msgstr "行の変更"
+msgstr "変更"
 #: ../vector/v.vol.rst/main.c:245
 msgid "Interpolates point data to a 3D raster map using regularized spline with tension (RST) algorithm."
@@ -30992,7 +30986,7 @@
 #: ../db/db.select/main.c:264
 msgid "Selects data from attribute table (performs SQL query statement(s))."
-msgstr ""
+msgstr "属性テーブルからデータを取得(SQLクエリーを実行します)."
 #: ../db/db.connect/main.c:46 ../db/db.login/main.c:39
 #, fuzzy
@@ -33864,6 +33858,4548 @@
 msgid "Cannot allocate memory for auxiliar matrix.Consider changing region (resolution)"
 msgstr "auxiliarマトリックスにメモリーを割り当てられません.領域の解像度を変更してみてください  "
+#, fuzzy
+msgid "Watershed basin analysis program"
+msgstr "分水域の解析を行います "
+#, fuzzy
+msgid "Name of input raster map with real depressions"
+msgstr "再投影するラスターマップ名"
+#, fuzzy
+msgid "Name of input raster map blocking overland surface flow"
+msgstr "入力:曲面流でブロック化した地形を示すファイル "
+#, fuzzy
+msgid "Name for output raster map useful for visual display of results (DEPRECATED)"
+msgstr "出力:結果を可視化したファイル"
+#, fuzzy
+msgid "Direction raster found <%s>"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Name for output direction map for depressionless elevation raster map"
+msgstr "(o)   凹みのない標高マップの方向マップ"
+#, fuzzy
+msgid "raster, export, animation"
+msgstr "ラスター、標高"
+#, fuzzy
+msgid "(requires r.out.ppm with stdout option)"
+msgstr ""
+"オン・ザ・フライで変換、省ディスクスペース\n"
+"\t(r.out.ppm の stdout オプションが必要)  "
+#, fuzzy
+msgid "Name for output elevation raster map after filling"
+msgstr "充填後にラスターマップを出力"
+#, fuzzy
+msgid "Name for output direction raster map"
+msgstr "出力する傾斜方位ラスターマップ名"
+#, fuzzy
+msgid "Reading input data..."
+msgstr "読込中 ... "
+#, fuzzy
+msgid "Writing output data..."
+msgstr "出力中..."
+#, fuzzy
+msgid "raster, reclassification"
+msgstr "ラスター、標高"
+#, fuzzy
+msgid "Name of input raster map with seed (at least 1 cell > 0)"
+msgstr "シード付きラスターマップ名 (少なくとも 1セル>0)"
+#, fuzzy
+msgid "Constructs flow lines."
+msgstr "等値線のコスト "
+#, fuzzy
+msgid "Name for flowpath length raster map"
+msgstr "出力フローパス長さラスターマップ"
+#, fuzzy
+msgid "imagery, landsat, acca"
+msgstr "画像, 分類, MLC"
+#, fuzzy
+msgid "Cannot write to raster map <%s>"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Creates, edits, and lists groups and subgroups of imagery data."
+msgstr "グループと画像ファイルサブグループの作成、編集、入力"
+#, fuzzy
+msgid "Extract quality control parameters from Modis QC layers"
+msgstr "DEM から地形パラメーターを抽出します"
+#, fuzzy
+msgid "Name of the surface reflectance QC layer [bit array]"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Computing means and standard deviations..."
+msgstr "バンドの演算手段 %d..."
+#, fuzzy
+msgid "Computing means..."
+msgstr "方程式を計算中..."
+#, fuzzy
+msgid "Other"
+msgstr "ディザ"
+#, fuzzy
+msgid "Offset in map units."
+msgstr "マップユニットのバッファー距離"
+#, fuzzy
+msgid "Cannot describe table"
+msgstr "表をコピーできません\n"
+#, fuzzy
+msgid "DEPRECATED Buffer distance in map units"
+#, fuzzy
+msgid "Line buffers... "
+msgstr "ラインバッファー、、、"
+#, fuzzy
+msgid "Zero area size, please clean input vector first."
+msgstr "指定したベクトルラインに平行な線を作成"
+#, fuzzy
+msgid "Could not get outside buffer for line id %d"
+msgstr "南の緩衝地帯をよみこめませんでした. 中断しています"
+#, fuzzy
+msgid "Area buffers... "
+msgstr "エリアバッファー、、、"
+#, fuzzy
+msgid "Selecting areas..."
+msgstr "フィーチャーを選択中、、、"
+msgid "Converts to one of the supported OGR vector formats."
+msgstr "サポートするOGRベクトルフォーマットのひとつに変換"
+#, fuzzy
+msgid "Cannot allocate %u bytes of memory"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Skip the join column in other table"
+msgstr "他のテーブルに列を結合"
+#, fuzzy
+msgid "Copy all the columns from other table to map"
+#, fuzzy
+msgid "Name of input raster map in which to fill nulls"
+msgstr "nullで埋められたラスターマップ"
+#, fuzzy
+msgid "Name for output raster map with nulls filled by interpolation"
+msgstr "周囲の値からの補間によって埋められたnullで出力するラスターマップ"
+#, fuzzy
+msgid "Mosaics up to four images, extending the color table."
+msgstr "モザイクは最大4つの画像まで、 カラーマップを拡張する; マップ *.mosaicを作成する  "
+#, fuzzy
+msgid "creates map *.mosaic"
+msgstr "第3モザイクマップ"
+#, fuzzy
+msgid "1st map for mosaic (top of image stack)"
+msgstr "第1モザイクマップ (画像スタックの上部).  "
+#, fuzzy
+msgid "2nd map for mosaic"
+msgstr "第2モザイクマップ"
+#, fuzzy
+msgid "3rd map for mosaic"
+msgstr "第3モザイクマップ"
+#, fuzzy
+msgid "4th map for mosaic"
+msgstr "第4モザイクマップ"
+msgid "Could not close G3D map"
+msgstr "3Dグリッドマップを閉じれません"
+msgid "Use g3d mask (if exists) with input map"
+msgstr "入力マップに3Dグリッドマスクを使う"
+msgid "Could not write raster row"
+msgstr "ラスター行が書き込めません"
+msgid "Could not close G3D map <%s>"
+msgstr "3Dグリッドマップ <%s> が閉じれません"
+msgid "Converts 3D raster maps (G3D) into the VTK-Ascii format"
+msgstr "3Dラスターマップ(3Dグリッド)をVTK-Ascii フォーマットに変換する"
+msgid "unable to close input 3d raster map"
+msgstr "入力3Dラスターマップを閉じれません"
+msgid "Use g3d mask (if exists) with input maps"
+msgstr "3Dグリッドマスク(存在する時に限る)を入力マップに使用します"
+msgid "Could not get top raster row \n"
+msgstr "ラスターの先頭行を取得できない\n"
+msgid "Could not get bottom raster row \n"
+msgstr "ラスターの最終行を取得できない\n"
+msgid "Use G3D mask (if exists)"
+msgstr "(可能であれば)3Dグリッドマスクの使用"
+msgid "Name of an existing raster map layer"
+msgstr "既存のラスターマップ レイヤー名"
+#, fuzzy
+msgid "writing edges..."
+msgstr "入力するファイル"
+#, fuzzy
+msgid "input,cell,raster"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "output,cell,raster"
+msgstr "出力するファイル"
+msgid "raster3d, statistics"
+msgstr "ラスター3D、統計"
+#, fuzzy
+msgid "raster, png"
+msgstr "ラスター、タイル表示"
+msgid "Construction of slope curves (flowlines), flowpath lengths, and flowline densities (upslope areas) from a raster digital elevation model (DEM)"
+msgstr "傾斜カーブの建築(フローライン)、フローパスの長さ、そしてラスターデジタル標高モデル(DEM)からのフローライン密度(上り坂エリア) "
+msgid "vector, networking"
+msgstr "ベクトル, ネットワーク"
+msgid "raster, vector, visualization"
+msgstr "ラスター,ベクトル,可視化"
+msgid "Convert all old GRASS < Ver5.7 vector maps in current mapset to current format"
+msgstr "現在のマップセット内のすべての前のGRASS < Ver5.7 ベクトルマップ を現在のフォーマットに変換する"
+msgid "Import Mapgen or Matlab vector maps into GRASS."
+msgstr "MapgenあるいはMatlabベクトルマップをGRASSにインポート"
+msgid "Ascii file containing spectral signatures"
+msgstr "スペクトルシグネチャを含むASCIIファイル"
+#, fuzzy
+msgid "Unhandled vector feature type <%s>"
+msgstr "NULL値に代入する値"
+#, fuzzy
+msgid "No areas found, skipping type=area"
+msgstr "現在の設定を表示"
+#, fuzzy
+msgid "No points found, skipping%s%s"
+msgstr "現在の設定を表示"
+#, fuzzy
+msgid "No lines found, skipping%s%s"
+msgstr "現在の設定を表示"
+msgid "Raster value"
+msgstr "ラスター値"
+msgid "Slower but accurate (applies to FP maps only)"
+msgstr "遅いですが正確です (FPマップのみ適用)  "
+msgid "Rescaling range for output maps (for no rescaling use 0,0)"
+msgstr "出力マップの範囲を再計測 (0,0を使う再計測はありません)"
+#, fuzzy
+msgid "GDAL datatype: %s, range: %f - %f"
+msgstr "���."
+#, fuzzy
+msgid "The '-q' flag is superseded and will be removed "
+msgstr "���."
+#, fuzzy
+msgid "Unable to create table <%s_edge_Interpolation>"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Rescale output raster map [0,255]"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Output drain raster map"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Can't find %d,%d:%f"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Reading %s"
+msgstr "���%s ..."
+#, fuzzy
+msgid "Writing %s"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in a local text file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
+msgstr "緯度 (dd:mm:ss{N|S})."
+#, fuzzy
+msgid "It was impossible to open table"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Spline type of interpolation"
+msgstr "アイコンの種類"
+#, fuzzy
+msgid "Script kill option"
+msgstr "スクリプトの終了"
+#, fuzzy
+msgid "Start in Demo mode"
+msgstr "デモモード"
+#, fuzzy
+msgid "Output more comments (default=quiet)"
+msgstr "タイトル"
+#, fuzzy
+msgid "Vector map to display thematically"
+msgstr "対象マップ"
+#, fuzzy
+msgid "Vector map type"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Layer to use for thematic display"
+msgstr "タイトル"
+#, fuzzy
+msgid "Mapset(s) to list (default: current mapset search path)"
+msgstr "対象マップセット(デフォルト=現在のマップセット)"
+#, fuzzy
+msgid "Output separator (default: newline)"
+msgstr "区切り(デフォルト:タブ)"
+#, fuzzy
+msgid "Raster to remove"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "3d raster to remove"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Vector to remove"
+msgstr "対象ファイル<%s>"
+#, fuzzy
+msgid "Region to remove"
+#, fuzzy
+msgid "Label to remove"
+#, fuzzy
+msgid "3dview to remove"
+#, fuzzy
+msgid "Group to remove"
+#, fuzzy
+msgid "raster input maps"
+msgstr "目的ファイルを含むマップセット"
+#, fuzzy
+msgid "Output field seperator"
+msgstr "区切り"
+#, fuzzy
+msgid "ERROR: Problem opening output file."
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Density of output walkers"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "File [%s] not found"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Unable to open file [%s]"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Reading sites map (%s) ..."
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Name of the output walkers vector points map"
+msgstr "���"
+#, fuzzy
+msgid "You are not outputting any raster or vector points maps"
+msgstr "���"
+#, fuzzy
+msgid "%s=%s - illegal value"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Unable to read current region parameters"
+msgstr "現在の設定を表示"
+#, fuzzy
+msgid "Cannot open cover raster map <%s>"
+msgstr ""
+"#-#-#-#-#  grassmods_ja.po (grassmods_ja)  #-#-#-#-#\n"
+"出力するファイル"
+#, fuzzy
+msgid "No map specified"
+msgstr "傾斜方位を示すファイル(入力)"
+#, fuzzy
+msgid "%s - unable to remove color table"
+msgstr "シグネチャファイル"
+#, fuzzy
+msgid "%s - color table not found"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Unable to properly read input raster map"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Unable to properly write output raster map"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Name of raster map layer to be used for <%s>"
+msgstr "<%s>に対応させるラスターマップ"
+#, fuzzy
+msgid "Run verbosly"
+msgstr "説明つき表示"
+#, fuzzy
+msgid "%d points converted to centroids"
+msgstr "タイトル"
+#, fuzzy
+msgid "%d centroids converted to points"
+msgstr "出力ファイルの上書き"
+#, fuzzy
+msgid "%d lines converted to boundaries"
+#, fuzzy
+msgid "CrossCorrelation: %d points read in region.\n"
+msgstr "現在の設定を表示"
+#, fuzzy
+msgid "CrossCorrelation: Cannot open database %s by driver %s"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "CrossCorrelation: Cannot select data from table"
+msgstr "統一する属性の値"
+#, fuzzy
+msgid "vector, attribute table"
+msgstr "���"
+#, fuzzy
+msgid "Cannot fetch data"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Do not print polyline info"
+msgstr "統一する属性の値"
+#, fuzzy
+msgid "Feature id(s)"
+msgstr "ファイルの種類"
+#, fuzzy
+msgid "Input vector was not found."
+msgstr "���."
+#, fuzzy
+msgid "Node layer (points)"
+msgstr "色相ファイル"
+#, fuzzy
+msgid "Reading data from the map..."
+msgstr "カバーマップ"
+#, fuzzy
+msgid "Query layer (used by 'query' option)"
+msgstr "ラベルの属性"
+#, fuzzy
+msgid "%d categories read from map"
+msgstr "タイトル"
+#, fuzzy
+msgid "Processing ainput lines ..."
+msgstr "線に沿って点を補間"
+#, fuzzy
+msgid "Writing attributes ..."
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Current region does not include the entire input vector map <%s>"
+msgstr "���"
+#, fuzzy
+msgid "Output inverse raster map after IFFT"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "%s: %s - Unable to find the real-image map."
+msgstr "入力するファイル"
+#, fuzzy
+msgid "%s: %s - Unable to find the imaginary-image."
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Reading the raster maps..."
+msgstr "カバーマップ"
+#, fuzzy
+msgid "Rotating data arrays..."
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Unable to open output file."
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Hue map name"
+msgstr "対象マップ"
+#, fuzzy
+msgid "Intensity map name"
+msgstr "対象マップ"
+#, fuzzy
+msgid "Saturation map name"
+msgstr "対象マップ"
+#, fuzzy
+msgid "Output map representing the red"
+msgstr "出力:排出方向を示すファイル"
+#, fuzzy
+msgid "Output map representing the green"
+#, fuzzy
+msgid "Output map representing the blue"
+msgstr "���"
+#, fuzzy
+msgid "Cannot read row from raster map"
+msgstr "対象マップ1"
+#, fuzzy
+msgid "Cannot write row to raster map"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Red input raster map"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Green input raster map"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Blue input raster map"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Output intensity raster map"
+msgstr "流線の密度を示すファイル(出力)"
+#, fuzzy
+msgid "Name of imagery signaturefile"
+msgstr "シグネチャファイル"
+#, fuzzy
+msgid "Subgroup [%s] not found."
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Signature file [%s] is missing or not readable."
+msgstr "������."
+#, fuzzy
+msgid "Cannot write color table of raster map <%s>"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Imagery group"
+msgstr "画像グループ"
+#, fuzzy
+msgid "Subgroup containing image files"
+msgstr "サブ画像グループ"
+#, fuzzy
+msgid "Resultant signature file"
+msgstr "シグネチャファイル"
+#, fuzzy
+msgid "Input raster map being fft"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Illegal file name for real part: %s"
+msgstr "虚部を含む入力ファイル"
+#, fuzzy
+msgid "Illegal file name for imaginary part: %s"
+#, fuzzy
+msgid "Reading the raster map..."
+msgstr "カバーマップ"
+#, fuzzy
+msgid "subgroup <%s> not found"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "** Can't open seed singature file <%s> **"
+msgstr "���"
+#, fuzzy
+msgid "** Can't read signature file <%s> **"
+msgstr "シグネチャファイル"
+#, fuzzy
+msgid "Group of imagery files to be clustered"
+msgstr "画像グループ"
+#, fuzzy
+msgid "Subgroup name in the above group"
+msgstr "サブ画像グループ"
+#, fuzzy
+msgid "Reading image ... "
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Unable to read head of %s"
+#, fuzzy
+msgid "group=[%s] - not found."
+msgstr "入力するファイル"
+#, fuzzy
+msgid "subgroup=[%s] (of group [%s]) - not found."
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Can't read signature file [%s]."
+msgstr "シグネチャファイル"
+#, fuzzy
+msgid "Unable to create reject layer [%s]."
+#, fuzzy
+msgid "Imagery group to be classified"
+msgstr "画像グループ"
+#, fuzzy
+msgid "Subgroup containing image files to be classified"
+msgstr "サブ画像グループ"
+#, fuzzy
+msgid "Signatures to use for classification"
+msgstr "シグネチャファイル"
+#, fuzzy
+msgid "Raster map to hold classification results"
+msgstr "分類結果を出力するファイル"
+#, fuzzy
+msgid "Cannot select attributes: %s"
+msgstr "統一する属性の値"
+#, fuzzy
+msgid "Background color, either a standard GRASS color, R:G:B triplet, or \"none\""
+msgstr "線の色"
+#, fuzzy
+msgid "Saving new map"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Output raster map with lake"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Terrain raster map <%s> not found!"
+msgstr "対象マップ"
+#, fuzzy
+msgid "Cannot open terrain raster map <%s@%s>!"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Seed map <%s> not found!"
+msgstr "対象マップ"
+#, fuzzy
+msgid "Cannot open seed map <%s@%s>!"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Failure to allocate memory for row pointers"
+msgstr "マップのカテゴリー値について統計解析を行います"
+#, fuzzy
+msgid "Loading maps: "
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Error reading terrain raster map. Probably broken file."
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Error reading seed raster map. Probably broken file."
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Cannot write lake raster map <%s@%s>!"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Error writing color file for <%s@%s>!"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Name of the vector points map with x,y locations"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Number of time iterations (sec.)"
+msgstr "補間に用いる近傍点"
+#, fuzzy
+msgid "Multiscale simulation"
+msgstr "ロケーション"
+#, fuzzy
+msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Calculates <simple> index on a raster map"
+msgstr "サイトマップにラスター形式のマスクをかけ新しいマップを作成します"
+#, fuzzy
+msgid "Raster input maps(s)"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Output file name"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "%s: can't read fp range for [%s]"
+msgstr "出力するファイル"
+#, fuzzy
+msgid ""
+"Raster map [%s] already exists.\n"
+"Please try another."
+msgstr "対象マップ"
+#, fuzzy
+msgid "Error reading '%s' map"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Threshold distance"
+msgstr "閾値"
+#, fuzzy
+msgid "Cannot execute: %s"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Cannot link table: %s"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "DXF input file"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Cannot open dxf file <%s>"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Cannot open new vector map <%s>"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Conversion of <%s> to vector map:"
+msgstr "���."
+#, fuzzy
+msgid "Create 3D file"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "imagery subgroup"
+msgstr "サブ画像グループ"
+#, fuzzy
+msgid ""
+"\n"
+"<%s> -- illegal result signature file name"
+msgstr "シグネチャファイル"
+#, fuzzy
+msgid "Raster file(s) for Elevation"
+msgstr "色に用いるラスターマップ"
+#, fuzzy
+msgid "Raster file(s) for Color"
+#, fuzzy
+msgid "Raster map to zoom into"
+msgstr "ズームするラスターマップ"
+#, fuzzy
+msgid "Save the current region to region definition file"
+msgstr "  region (地域定義ファイル)\n"
+#, fuzzy
+msgid "Could not open input file <%s>."
+msgstr "���"
+#, fuzzy
+msgid "Adding files to subgroup [%s]"
+msgstr "サブ画像グループ"
+#, fuzzy
+msgid "Writing subgroup REF"
+msgstr "サブ画像グループ"
+#, fuzzy
+msgid "Multiplier"
+msgstr "高さの強調"
+#, fuzzy
+msgid "Name of the resultant map"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Raster map not found."
+msgstr "対象マップ"
+#, fuzzy
+msgid "%s: can't read range for [%s]"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Raster file [%s] not found"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "It was not possible writing in <%s>."
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Cannot create table: '%s'"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Unable to get category list <%s>, editing terminated"
+msgstr "���"
+#, fuzzy
+msgid "Unable to delete layer/category [%d/%d] line %d"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Unable to write line %d"
+msgstr "シグネチャファイル"
+#, fuzzy
+msgid "Unable to delete line %d"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Unknown query tool '%s'"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "No layer database connection"
+msgstr "ロケーション"
+#, fuzzy
+msgid "%d categories loaded from the database"
+msgstr "タイトル"
+#, fuzzy
+msgid "Cannot open OGR data source '%s'"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Cannot create layer"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
+msgstr "対象マップ"
+#, fuzzy
+msgid "Load values from vector to database. For uploaded/printed category values '-1' is used for 'no category' and 'null'/'-' if category cannot be found or multiple categories were found."
+msgstr "���."
+#, fuzzy
+msgid "Column(s)"
+msgstr "更新するカラム1"
+#, fuzzy
+msgid "Cannot read map header for <%s>"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Cannot read category file for <%s>"
+msgstr "���"
+#, fuzzy
+msgid "Print;Shell Script"
+msgstr "総セル数の出力"
+#, fuzzy
+msgid "Creating support files for [%s]."
+#, fuzzy
+msgid "%s: <%s> raster map not found"
+msgstr ""
+"対象マップ\n"
+"入力するファイル"
+#, fuzzy
+msgid "%s: <%s> raster map exists already"
+msgstr "対象マップ"
+#, fuzzy
+msgid "Cannot read category file of raster map <%s>"
+msgstr "���"
+#, fuzzy
+msgid "%s - map not found"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "%s not found"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Vector map %s - not found"
+msgstr "���"
+#, fuzzy
+msgid "Raster map containing elevation data"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Raster map name for storing results"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Height of the viewing location"
+msgstr "視点の高さ"
+#, fuzzy
+msgid "%s: <%s> cellfile not found"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Cell file [%s] not found\n"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "rgb cell map [%s] not found\n"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "vector cell map [%s] not found\n"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "%s - %s not found"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Unable to read category file for raster map <%s>"
+msgstr "���"
+#, fuzzy
+msgid "Creating support files"
+#, fuzzy
+msgid "%s file [%s] not found!"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "%s: %s - map not found"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "%s: unable to open %s"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "%s - not found"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Cannot read %s"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Reading %s ... "
+msgstr "入力するファイル"
+#, fuzzy
+msgid "[%s] map not found."
+msgstr "入力するファイル"
+#, fuzzy
+msgid "[%s] map not found"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "min computed aspect %.4f  max computed aspect %.4f"
+msgstr "����� �����"
+#, fuzzy
+msgid "min computed slope %.4f  max computed slope %.4f"
+msgstr "��� ���"
+#, fuzzy
+msgid "Cannot describe table <%s>"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Cannot insert values: %s"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "%s given an illegal number of points [%d]"
+msgstr "初期のクラスター数"
+#, fuzzy
+msgid "Unable to open database %s by driver %s"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Could not find input %s"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Could not find input map <%s>"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Can't read header for <%s> in <%s>"
+msgstr "���"
+#, fuzzy
+msgid "Can't read header for 3D raster <%s> in <%s>"
+msgstr "���"
+#, fuzzy
+msgid "Can't write region <%s>"
+msgstr "���"
+#, fuzzy
+msgid "No graphics device selected."
+msgstr "グラフィックデバイスが選択されていない"
+#, fuzzy
+msgid "Unable to read raster row."
+msgstr "出力するファイル"
+#, fuzzy
+msgid "%s map not found"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "cannot read head of %s"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Illegal file name: %s"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Cannot get layer info for vector map"
+msgstr "���"
+#, fuzzy
+msgid "Cannot open raster map <%s> in <%s>"
+msgstr ""
+"出力するファイル"
+#, fuzzy
+msgid "cover values extracted from the category labels of the cover map"
+msgstr "カテゴリー値の代わりにカテゴリーラベルを使用"
+#, fuzzy
+msgid "%s: %s - raster map not found"
+msgstr "対象マップ"
+#, fuzzy
+msgid "%s: %s - illegal name"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "%s: ERROR reading category file for %s"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "%s: %s - not found"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "%s: %s - illegal units"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "%s: %s - can't open"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Reading input map (%s)    ... "
+msgstr "入力するファイル"
+#, fuzzy
+msgid "%s - ERROR reading %s"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "%s: %s - can't create raster map"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Writing output map (%s)   ... "
+msgstr "出力するファイル"
+#, fuzzy
+msgid "%s - ERROR re-reading %s"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Reading raster map... "
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Writing raster map... "
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Category list: e.g. 1,3-8,13"
+msgstr "カテゴリーラベルのリスト(例 1,3-8,13)"
+#, fuzzy
+msgid "Output separator character (default: tab)"
+#, fuzzy
+msgid "Cannot read category file of raster map <%s> in <%s>"
+msgstr "���"
+#, fuzzy
+msgid "Cannot create raster map %s"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Cannot create vector map %s"
+msgstr "���"
+#, fuzzy
+msgid "Cannot create raster map '%s'"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Number of raster rows to hold in memory"
+msgstr "メモリに残す行"
+#, fuzzy
+msgid "Print raster map title only"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "unknown type: %d"
+msgstr "ファイルの種類"
+#, fuzzy
+msgid "Cannot open raster map [%s]"
+msgstr ""
+"出力するファイル"
+#, fuzzy
+msgid "Cannot get raster band."
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Cannot read GRASS raster."
+msgstr "���"
+#, fuzzy
+msgid "Cannot get [%s] driver"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Couldn't set geo transform."
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Couldn't set projection."
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Cannot export [%s] raster map."
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Cannot create [%s] raster map using [%s] driver."
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Cannot read header of raster map <%s>"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Cannot open TIFF file <%s>"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Reading raster map"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Cannot open output map."
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Illegal file name. Please try another."
+msgstr "出力するファイル"
+#, fuzzy
+msgid "%s: can't open %s"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Reading raster map <%s> ..."
+msgstr "入力するファイル"
+#, fuzzy
+msgid "memory allocation failure"
+msgstr "ロケーション"
+#, fuzzy
+msgid "Cannot open vector map <%s> at the topological level"
+msgstr "���"
+#, fuzzy
+msgid "Rebuilding topology ..."
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Removing duplicates ..."
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Attaching islands ..."
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Attaching centroids ..."
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Vector map <%s> not found in current mapset"
+msgstr "���"
+#, fuzzy
+msgid "The number of lines in the input vector map is [%d]"
+msgstr "ピクセルの最小値"
+#, fuzzy
+msgid "Cannot get layer info"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "cell file [%s] not found"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "can't open raster map [%s]"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Cannot rewrite line %d"
+msgstr "���"
+#, fuzzy
+msgid "Editing tool"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Cannot copy line %d, editing terminated"
+msgstr "���"
+#, fuzzy
+msgid "No layer database connection."
+msgstr "ロケーション"
+#, fuzzy
+msgid "Cannot snap lines %d,%d"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "%d lines modified"
+msgstr "タイトル"
+#, fuzzy
+msgid "Could not open ASCII file <%s>"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Print vector map region only"
+msgstr "���"
+#, fuzzy
+msgid "Cannot open vector map <%s> at topo level [%d]"
+msgstr "���"
+#, fuzzy
+msgid "Cannot get layer info for vector map <%s>"
+msgstr "���"
+#, fuzzy
+msgid "Cannot select attribute."
+msgstr "統一する属性の値"
+#, fuzzy
+msgid "Number of ROWS and COLUMNS in grid"
+msgstr "格子数"
+#, fuzzy
+msgid "Creating vector grid..."
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Could not find vector map <%s> in current mapset"
+msgstr "���"
+#, fuzzy
+msgid "Could not find input map <%s>."
+msgstr "出力するファイル"
+#, fuzzy
+msgid "[%d] features written"
+msgstr "���"
+#, fuzzy
+msgid "Output map where segments will be written"
+msgstr "���."
+#, fuzzy
+msgid "<%s> cellfile not found"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Not able to open vector map <%s>"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "No table."
+msgstr "テーブル"
+#, fuzzy
+msgid "Can't read raster"
+msgstr "���"
+#, fuzzy
+msgid "driver name"
+msgstr "ドライバ"
+#, fuzzy
+msgid "database name"
+msgstr "データベース"
+#, fuzzy
+msgid "Driver name"
+msgstr "ドライバ"
+#, fuzzy
+msgid "output field separator"
+msgstr "区切り"
+#, fuzzy
+msgid "output vertical record separator"
+msgstr "上下方向の区切り"
+#, fuzzy
+msgid "null value indicator"
+msgstr "NULL値の識別子"
+#, fuzzy
+msgid "do not include column names in output"
+msgstr "ルートに沿ってセル値をコピー"
+#, fuzzy
+msgid "vertical output (instead of horizontal)"
+msgstr "8bitで出力"
+#, fuzzy
+msgid "Cannot find mapset for %s"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Label file [%s] not available"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Can't open label file [%s]"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "unable to open [%s] in [%s]"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "warning: unable to open [%s] in [%s]"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Unable to open raster map [%s] in [%s]"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Unable to find input cell map '%s'"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Unable to open cellfile for <%s>"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Unable to create raster map [%s]"
+#, fuzzy
+msgid "Unable to create output <%s>"
+#, fuzzy
+msgid "Input file [%s] not found."
+msgstr "���."
+#, fuzzy
+msgid "Unable to open output file <%s>."
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Multiplier for ascii data"
+msgstr "高さの強調"
+#, fuzzy
+msgid "Could not open temporary file: [%s]"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Could not open input file [%s]"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "unable to create raster"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Unable to create output raster map <%s>"
+#, fuzzy
+msgid "Name of the random surface to be produced"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "%s: Unable to find raster map <%s>"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "%s: Unable to open raster map <%s> in mapset <%s>"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "%s:  Unable to open output raster map <%s>"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Vector <%s> could not be opened"
+msgstr "���"
+#, fuzzy
+msgid "Table name"
+msgstr "テーブル"
+#, fuzzy
+msgid "x column name"
+msgstr "キーカラム"
+#, fuzzy
+msgid "z column name"
+msgstr "キーカラム"
+#, fuzzy
+msgid "Cannot drop table: %s"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Cannot open labels <%s>"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Cannot open file [%s]"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "SVG file <%s> cannot be opened"
+msgstr "���"
+#, fuzzy
+msgid "Querying input '%s' ... "
+msgstr "���%s ..."
+#, fuzzy
+msgid "Copying %s input lines ... "
+msgstr "���."
+#, fuzzy
+msgid "Cannot create table <%s>"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "cannot insert row: %s"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Cannot find line of cat %d"
+msgstr "���"
+#, fuzzy
+msgid "Unalbe to open vector map <%s>"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Transforms a vector map via a set of tie points."
+msgstr "ベクトルマップの座標変換を行います"
+#, fuzzy
+msgid "Raster map <%s>] not found"
+msgstr "対象マップ"
+#, fuzzy
+msgid "Cannot start driver <%s>."
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Not able to find cellfile [%s]"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Raster map [%s] not found"
+msgstr "対象マップ"
+#, fuzzy
+msgid "Unable to open raster map [%s]"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Vector file [%s] not available"
+msgstr "対象マップ"
+#, fuzzy
+msgid "<%s> illegal name"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "%s: %s - Unable to open the input raster map\n"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "%s: %s - illegal name for output raster map."
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Exports GRASS raster data into various formats (requires GDAL)."
+msgstr "ラスターマップをバイナリーファイルとしてエクスポートします"
+#, fuzzy
+msgid "Couldn't find raster map %s"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "%s: <%s> not found"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "%s: Cannot open <%s>"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Cannot find %s"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "could not read range file"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Unable to create raster map [%s]."
+#, fuzzy
+msgid "Filtering [%s] in [%s]"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Open raster map %s in %s = %d"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Closing raster map"
+msgstr "カバーマップ"
+#, fuzzy
+msgid "Swap temp files"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Writing [%s]"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "%s: illegal map name"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "%s: <%s> illegal file name"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "can't open raster map <%s> in mapset %s"
+msgstr "���"
+#, fuzzy
+msgid "Converts a GRASS raster map to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION."
+msgstr "ラスターマップをPPMファイルとしてエクスポートします"
+#, fuzzy
+msgid "Mapset of input map"
+#, fuzzy
+msgid "Checking location %s, mapset %s:"
+#, fuzzy
+msgid "Error writing output map"
+msgstr "解像度"
+#, fuzzy
+msgid "[%s] is an illegal file name"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Can't open temp file [%s]"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Names of existing raster maps"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Unable to open input map <%s> in mapset <%s>"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "%s - illegal name "
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Couldn't find raster map [%s]"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "%s - can't create raster map"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Cell file [%s] not found"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Requested 3d raster map not found <%s>"
+msgstr "���."
+#, fuzzy
+msgid "Could not open output map"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "unable to close output map"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Could not close the 3d raster map"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Cannot create output map [%s]"
+#, fuzzy
+msgid "Cannot open vector points map <%s>"
+msgstr "���."
+#, fuzzy
+msgid "Cannot create vector map <%s>"
+msgstr "���"
+#, fuzzy
+msgid "Vector file [%s] not available in search list"
+msgstr "対象マップ"
+#, fuzzy
+msgid "Cannot open table <%s>"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "The vector '%s' already exists."
+msgstr "���."
+#, fuzzy
+msgid "Could not find input map '%s'."
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Could not find network input map '%s'."
+msgstr "出力するファイル"
+#, fuzzy
+msgid "error opening raster map [%s]."
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Patching file <%s@%s>"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "[%d] files patched"
+msgstr "���"
+#, fuzzy
+msgid "Could not open vector map <%s>"
+msgstr "���"
+#, fuzzy
+msgid "Illegal output name: '%s'"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Can't create output map"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "%s: cellfile [%s] not found."
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Unable to open cellfile [%s]."
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Error reading wildcard."
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Sets the grid color, either a standard GRASS color or R:G:B triplet (separated by colons)"
+msgstr "線の色"
+#, fuzzy
+msgid "Sets the border color, either a standard GRASS color or R:G:B triplet"
+msgstr "線の色"
+#, fuzzy
+msgid "Unable to open the temporary file."
+msgstr "シグネチャファイル"
+#, fuzzy
+msgid "Unable to open raster map [%s]."
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Unable to find raster [%s]."
+msgstr "出力するファイル"
+#, fuzzy
+msgid "name for new raster map"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Output GRASS image file"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "name for new vector map (omit for display to stdout)"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Input vector map"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "%s: ERROR can't open tempfile"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "unable to find raster map [%s]"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "<%s> raster map not found"
+msgstr "対象マップ"
+#, fuzzy
+msgid "<%s> unable to open raster map"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Cannot find vector map [%s]"
+msgstr "���"
+#, fuzzy
+msgid "%s - can't open raster map"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Can't get row %d from raster map %s"
+msgstr "対象マップ1"
+#, fuzzy
+msgid "%s - raster map not found"
+msgstr "対象マップ"
+#, fuzzy
+msgid "string representing no data cell value"
+msgstr "データのないセルに代入する記号"
+#, fuzzy
+msgid "File name of reference classes"
+msgstr "初期のクラスター数"
+#, fuzzy
+msgid "wide report, 132 columns (default: 80)"
+msgstr "レポート幅の拡大"
+#, fuzzy
+msgid "quiet"
+msgstr "説明なし"
+#, fuzzy
+msgid "<%s> - illegal output file name"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "%s: <%s> reference map not found"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Base raster map"
+msgstr "ベースマップ"
+#, fuzzy
+msgid "%s: raster map not found"
+msgstr "対象マップ"
+#, fuzzy
+msgid "Problem opening input file [%s]"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Problem opening output file [%s]"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "can't write category file for <%s>"
+msgstr "���"
+#, fuzzy
+msgid "%s: can't open tempfile"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Unable to read row %d in raster map [%s]"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Output verbosely"
+msgstr "説明つき表示"
+#, fuzzy
+msgid "Can't open raster map %s"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "It could not be find input map <%s>"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "It could not be found input map <%s>"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Cannot find input map <%s>"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Input vector map <%s> not found."
+msgstr "���."
+#, fuzzy
+msgid "Category ranges: e.g. 1,3-8,13"
+#, fuzzy
+msgid "Writing attributes ...\n"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Could not open ascii file <%s>"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Could not open temp file <%s>"
+msgstr "���"
+#, fuzzy
+msgid "Vector map <%s> not fould"
+msgstr "���"
+#, fuzzy
+msgid "SVG output file"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Could not find vector '%s'"
+msgstr "���"
+#, fuzzy
+msgid "Could not find vector map %s"
+msgstr "���"
+#, fuzzy
+msgid "Unable to get row %d from <%s>"
+msgstr "対象マップ1"
+#, fuzzy
+msgid "No input coordinates provided"
+msgstr "X座標値"
+#, fuzzy
+msgid "Unable to allocate memory."
+#, fuzzy
+msgid "Raster output file"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Writing raster map ... "
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Keep existing color table"
+msgstr "カラーテーブルを上書きしない"
+#, fuzzy
+msgid "Name of the output walkers site file"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Verbose mode."
+msgstr "説明付き表示"
+#, fuzzy
+msgid " %d rows, %d cols."
+msgstr "���"
+#, fuzzy
+msgid "%s in %s - can't read header file"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "%s - unable to create raster map"
+#, fuzzy
+msgid "%s - unable to create category file"
+msgstr "シグネチャファイル"
+#, fuzzy
+msgid "verbose mode"
+msgstr "説明付き表示"
+#, fuzzy
+msgid "Vector map with points for which to modify the attribute table"
+msgstr "���"
+#, fuzzy
+msgid "Layer of the vector for which to modify the attribute table"
+msgstr "���"
+#, fuzzy
+msgid "Path to the input file"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Path to an output file"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Name of existing raster map to be displayed"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Database name:"
+msgstr "データベース"
+#, fuzzy
+msgid "ASCII file to be converted to binary vector map, if not given (or \"-\") reads from standard input"
+msgstr "���"
+#, fuzzy
+msgid "could not find input map <%s>"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "unable to open raster map [%s]"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "cannot get layer info for vector map"
+msgstr "���"
+#, fuzzy
+msgid "cannot create table: %s"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "cannot create index"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "cannot grant privileges on table %s"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Cannot find vector map"
+msgstr "���"
+#, fuzzy
+msgid "Cannot find raster map"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Cannot open raster map"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Unknown keyword [%s] in vector head."
+msgstr "���."
+#, fuzzy
+msgid "Error while reading cell map."
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Error while writing new cell map."
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Error in opening output file <%s>"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Unable to find input cell map <%s>"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Error in opening input file <%s>"
+msgstr "���"
+#, fuzzy
+msgid "Cannot find map %s"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Cannot open map %s"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Name of predefined rules file"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "no such value"
+msgstr "閾値"
+#, fuzzy
+msgid "Unable to find base map <%s>"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Unable to find cover map <%s>"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "%s: reading category file for %s"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "%s: unable to open raster map [%s]"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "%s: unable to create raster map [%s]"
+#, fuzzy
+msgid "Unable to open database %s with driver %s"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "%s: Unable to read raster map [%s]"
+#, fuzzy
+msgid "%s: unable to open raster map <%s>"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "%s: Failed to read raster row %d"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Unable to read cats table for %s"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Could not open raster <%s>"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Screen coordinates to place the legend (as percentage)"
+msgstr "下,上,左,右の値(パーセンテージ)"
+#, fuzzy
+msgid "%s: o_open_file: raster map %s not found"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "%s: o_open_file: could not open raster map %s in %s"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "No record for category for [%d]"
+msgstr "���"
+#, fuzzy
+msgid "Error reading ASCII file <%s>"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "List of point coordinates. Required for add and move actions."
+msgstr "タイプ"
+#, fuzzy
+msgid "Could not find input vector '%s'"
+msgstr "���"
+#, fuzzy
+msgid "Failed opening output vector map '%s'"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Do not create attribute table."
+msgstr "統一する属性の値"
+#, fuzzy
+msgid "Error reading ascii file: [%s]"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "List vector maps in input location and exit (a dummy value must be given for input)"
+msgstr "目的ロケーション内のベクトルマップ一覧表示"
+#, fuzzy
+msgid "Allows the user to interactively query a vector map layer at user-selected locations within the current geographic region"
+msgstr "マウスで指定した位置でのベクトルマップのカテゴリー情報を表示します(ここはどこ?なに?)"
+#, fuzzy
+msgid "%s: <%s> vector map not found"
+msgstr "���"
+#, fuzzy
+msgid "Vector <%s> could not be open"
+msgstr "���"
+#, fuzzy
+msgid "Raster <%s> could not be open."
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Interpolation()"
+msgstr "補間方法"
+#, fuzzy
+msgid "Interpolation: Setting regions and boxes"
+msgstr "補間方法"
+#, fuzzy
+msgid "Interpolation: nsply = %d"
+msgstr "補間方法"
+#, fuzzy
+msgid "Interpolation: (%d,%d): Bilinear interpolation..."
+msgstr "補間に用いる近傍点"
+#, fuzzy
+msgid "Interpolation: (%d,%d): Bicubic interpolation..."
+msgstr "補間に用いる近傍点"
+#, fuzzy
+msgid "%s: Dropping <s>"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Interpolation was a success!"
+msgstr "補間方法"
+#, fuzzy
+msgid "CrossCorrelation: %d points read in region. "
+msgstr "現在の設定を表示"
+#, fuzzy
+msgid "CrossCorrelation: It shouldn't take too long."
+msgstr "統一する属性の値"
+#, fuzzy
+msgid "%s -- illegal output file name"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Sorry, with method '%s' you have to define an output map."
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Existing raster map name"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "%s - can't read raster cellhd"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "error reading cell data"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "No line found."
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Do not build topology."
+msgstr "統一する属性の値"
+#, fuzzy
+msgid "Could not open ascii file [%s]"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "%s: Cannot open dxf file"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Conversion of [%s] to vector map ..."
+msgstr "���."
+#, fuzzy
+msgid "Name of output 3d raster map"
+msgstr "出力するファイル"
+#, fuzzy
+msgid ""
+"\n"
+"Where %s is one of:\n"
+msgstr ""
+"\n"
+"ここでの %s は次のうちのいずれかです:\n"
+#, fuzzy
+msgid "ERROR: <%s> not found\n"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "ERROR: <%s> illegal name\n"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Cannot open toolbox: %s"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Cannot open toolbox."
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Vector map(s) -- source for composite"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Append files to existing file"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Vector map '%s' not found"
+msgstr "���"
+#, fuzzy
+msgid "Input elevation file"
+msgstr "標高を示すファイル(入力)"
+#, fuzzy
+msgid "Input aspect file"
+#, fuzzy
+msgid "Input barrier file"
+msgstr "バリアを示すファイル(入力)"
+#, fuzzy
+msgid "Quiet operation"
+msgstr "説明なし"
+#, fuzzy
+msgid "Display Reference Information"
+msgstr "ヘッダーの表示"
+#, fuzzy
+msgid "Aspect file's resolution differs from                        current region resolution"
+msgstr "値の読みとり間隔(デフォルト:現在の解像度)"
+#, fuzzy
+msgid "output layer name"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Imagery files subgroup"
+msgstr "サブ画像グループ"
+#, fuzzy
+msgid "Warning: illegal output file name <%s>."
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Category <%d>: Line color and background color are the same!"
+msgstr "���!"
+#, fuzzy
+msgid "Line color and background color are the same!"
+msgstr "���!"
+#, fuzzy
+msgid "datetime, datetime1/datetime2, or none"
+msgstr "タイムスタンプ"
+#, fuzzy
+msgid "Open vector 3d raster map %s"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Open 3d raster map %s"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Vector import complete"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Unable to create raster map for [%s]"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "error opening 3d raster map"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Read fp map as integer (use map's quant rules"
+msgstr "実数を整数に変換して使用"
+#, fuzzy
+msgid "Name for the resulting raster map"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Open Raster file %s in Mapset %s"
+msgstr "���"
+#, fuzzy
+msgid "Open 3d raster map %s\n"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Open elev raster map %s\n"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Could not open map %s\n"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Bin raster map to be imported"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Output partial derivatives instead"
+msgstr "傾斜値、傾斜方位、曲率の代わりに偏導関数を出力"
+#, fuzzy
+msgid "Maximum distance"
+msgstr "最大値"
+#, fuzzy
+msgid "Makes 3D trees from input point vector map"
+msgstr "���"
+#, fuzzy
+msgid "Diameter of the tree crown in map units"
+msgstr "視点座標"
+#, fuzzy
+msgid "Height of tree trunk in meters"
+msgstr "地表からの高さ(単位:メートル)"
+#, fuzzy
+msgid "Name of the column with tree crown width"
+msgstr "最終レポートを出力するファイル"
+#, fuzzy
+msgid "Cannot select attributes for point #%d"
+msgstr "統一する属性の値"
+#, fuzzy
+msgid "Map coordinates"
+msgstr "Z座標値"
+#, fuzzy
+msgid "%s Quit\n"
+msgstr "説明なし"
+#, fuzzy
+msgid "Quiet mode"
+msgstr "説明なし"
+#, fuzzy
+msgid "%s[%d]: No raster map specified."
+msgstr "対象マップ"
+#, fuzzy
+msgid "Query column name"
+msgstr "キーカラム"
+#, fuzzy
+msgid "name for new binary vector map (omit for display to stdout)"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Name for G3d raster map"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "No output maps"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Connect to the database through DBMI."
+msgstr "データベースに接続します"
+#, fuzzy
+msgid "The resolution of raster and raster3d maps should be equal!"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Compute upslope flowlines"
+msgstr "流路を遡って計算"
+#, fuzzy
+msgid "The map E and N grid coordinates of a starting point"
+msgstr "始点の座標値"
+#, fuzzy
+msgid "Invoke fast, but memory intensive operation"
+msgstr "高速計算(大きなメモリが必要)"
+#, fuzzy
+msgid "You first need to run v.build on vector map <%s>"
+msgstr "���"
+#, fuzzy
+msgid "unknown interpolation method"
+msgstr "補間方法"
+#, fuzzy
+msgid "Name of existing raster map."
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Name of new raster map."
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Name of input map"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Name of existing input raster map"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "cover raster map"
+msgstr "カバーマップ"
+#, fuzzy
+msgid "resultant raster map"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Input layer name"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Output layer name"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Name of the resulting map"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Aspect"
+msgstr "傾斜方位またはdy値を出力するファイル"
+#, fuzzy
+msgid "Profile curvature"
+msgstr "断面曲率またはdxx値を出力するファイル"
+#, fuzzy
+msgid "Tangential curvature"
+msgstr "正接曲率またはdyy値を出力するファイル"
+#, fuzzy
+msgid "Mean curvature"
+msgstr "平均曲率またはdxy値を出力するファイル"
+#, fuzzy
+msgid "Enter name for the resulting signature file"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "page length (default: %d lines)"
+msgstr "1ページの行数"
+#, fuzzy
+msgid "page width (default: %d characters)"
+msgstr "1行の文字数"
+#, fuzzy
+msgid "suppress page headers"
+msgstr "ヘッダーの削除"
+#, fuzzy
+msgid "use formfeeds between pages"
+msgstr "フォームフィードの使用"
+#, fuzzy
+msgid "Write an Arc-Info line/polygon coverage in e00 format."
+msgstr "ベクトルマップをARC/INFO E00ファイルとしてエクスポートします"
+#, fuzzy
+msgid "Mapset holding vector map to be exported (Default = current)"
+msgstr "入力するファイルを含むマップセット(デフォルト=現在のマップセット)"
+#, fuzzy
+msgid "Name of .e00 output file (Default: stdout)"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Process spaghetti-digitized binary vector map."
+msgstr "スパゲッティデータ(バイナリー形式)の編集を行います"
+#, fuzzy
+msgid "Only run identical line tests"
+msgstr "指定したラインのみで実行"
+#, fuzzy
+msgid "Snap nodes"
+msgstr "端点をスナップ"
+#, fuzzy
+msgid ""
+"Set line types to:   \n"
+"             source        same as in binary vector map\n"
+"             line          lines\n"
+"             area          area edges\n"
+"             point         points (sites)\n"
+msgstr ""
+"線の種類:   \n"
+"             source        元のベクトルマップと同じ\n"
+"             line          線\n"
+"             area          エリアエッジ\n"
+"             point         点(サイトデータ)\n"
+#, fuzzy
+msgid "Output file is ASCII map"
+msgstr "ASCII形式のベクトルマップを出力"
+#, fuzzy
+msgid "Copy attributes and category files"
+msgstr "属性およびカテゴリーファイルをコピー"
+#, fuzzy
+msgid "Converts point data in a binary GRASS vector map layer into a GRASS site_lists file."
+msgstr "ベクトルマップからデータを抽出してサイトマップに変換します"
+#, fuzzy
+msgid "Use Category NUMERIC data instead of attribute"
+msgstr "属性の代わりに数値データを使用"
+#, fuzzy
+msgid "Use Category TEXT data instead of attribute"
+msgstr "属性の代わりにテキストデータを使用"
+#, fuzzy
+msgid "Test routine for developing MIF import."
+msgstr " ESRI シェープファイルをベクトルマップとしてインポートします"
+#, fuzzy
+msgid "Debugging level : 0 (silent) - 3 (verbose)"
+msgstr "デバッグレベル"
+#, fuzzy
+msgid "Name of file where to log operations"
+msgstr "ログファイル"
+#, fuzzy
+msgid "Snap distance in ground units (Default = 10^-10)"
+msgstr "端点のスナップ距離"
+#, fuzzy
+msgid "Set initial scale [1:2400]"
+msgstr "スケール"
+#, fuzzy
+msgid "Name of attribute to use as category"
+msgstr "属性番号のフィールド名"
+#, fuzzy
+msgid "Allow overwrite of existing vector map with the same name"
+msgstr "上書き"
+#, fuzzy
+msgid "Force writing  polygon coverage as a line coverage"
+msgstr "強制インポート"
+#, fuzzy
+msgid "Create unique value for parts of compound object"
+msgstr "ID番号を属性として使用"
+#, fuzzy
+msgid "List fields of DBF file"
+msgstr "データベースのフィールド一覧を表示して終了"
+#, fuzzy
+msgid "new categories table title"
+msgstr "タイトル"
+#, fuzzy
+msgid "Build topology info (default) OR Edit categories"
+msgstr "トポロジーの構築かカテゴリーの編集"
+#, fuzzy
+msgid "Prompt user for threshold         (Valid only with Build option)"
+msgstr "閾値のユーザ定義"
+#, fuzzy
+msgid "read data into memory"
+msgstr "タイトル"
+#, fuzzy
+msgid "Set map region from data          (Valid only with Build option)"
+msgstr "データから地域を設定"
+#, fuzzy
+msgid "Snap Threshold value       (Valid only with Build option and -s)"
+msgstr "スナップの閾値"
+#, fuzzy
+msgid "Suppress drawing of text outlines"
+msgstr "テキストのアウトラインを非表示"
+#, fuzzy
+msgid "DXF layers with line data"
+msgstr "ラインデータを含むファイル"
+#, fuzzy
+msgid "DXF layers with label data"
+msgstr "ラベルデータを含むファイル"
+#, fuzzy
+msgid "Prefix for dig or dig_ascii and dig_att output files"
+msgstr "出力するファイル"
+#, fuzzy
+msgid ""
+"\n"
+"\n"
+"Where lines and labels are one or more of:\n"
+"\n"
+msgstr ""
+"\n"
+"\n"
+"ここでのlines,labelsの入力形式は以下の通りです:\n"
+"\n"
+#, fuzzy
+msgid ""
+"      and/or   \n"
+"\n"
+msgstr ""
+"      または   \n"
+"\n"
+#, fuzzy
+msgid "angle of rotation"
+msgstr "回転角度"
+#, fuzzy
+msgid "provide attributes of type: const,rows,cols"
+msgstr "属性タイプ"
+#, fuzzy
+msgid "binary vector map to be converted to ascii"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Converts ASCII vector map layers into binary vector map layers."
+msgstr " ASCII形式のファイルをベクトルマップとしてインポートします"
+#, fuzzy
+msgid "what load"
+msgstr "更新する対象"
+#, fuzzy
+msgid "key column"
+msgstr "キーカラム"
+#, fuzzy
+msgid "Prints information about a binary GRASS vector map layer."
+msgstr "ベクトルマップについての情報を表示します"
+#, fuzzy
+msgid "Cleans out dead lines in GRASS vector maps."
+msgstr "ベクトルマップのデータ中で削除マークの付いた線を全て取り除きます"
+#, fuzzy
+msgid "Key (id) column name"
+msgstr "キーカラム"
+#, fuzzy
+msgid "Select area, line, or site "
+msgstr "タイプ"
+#, fuzzy
+msgid "input vector map for ARC/INFO conversion"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "coverage type"
+msgstr "抽出するタイプ"
+#, fuzzy
+msgid "prefix for ARC/INFO output filenames"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "The postscript versions of these papers are available via Internet at"
+msgstr "これらの文献はポストスクリプト形式で下のURLから入手できます"
+#, fuzzy
+msgid "Please cite these references in publications where the results of this"
+msgstr "このプログラムの結果を論文等に公表する場合, "
+#, fuzzy
+msgid "Do zero attributes/cats represent elevation?"
+msgstr "入力ファイルの値0を標高に置き換える"
+#, fuzzy
+msgid "path to GRASS database of input location"
+msgstr "目的ロケーションを含むデータベース"
+#, fuzzy
+msgid "Automatically run \"v.support\" on newly created vector map."
+msgstr "'v.support'コマンドを自動的に実行"
+#, fuzzy
+msgid "Type of object to extract (area, line or both)"
+msgstr "抽出する線のタイプ"
+#, fuzzy
+msgid "Limit line output to area-edge arcs"
+msgstr "エリアエッジのみ抽出"
+#, fuzzy
+msgid "Limit line output to line arcs"
+msgstr "線のみ抽出"
+#, fuzzy
+msgid "Polygon Cookie Cutter  (Boolean AND Overlay)."
+msgstr "2つの既存するベクトルマップの交差関係にもとづいた演算(ブール代数のANDオーバーレイ)を行い、新しいマップを作成します"
+#, fuzzy
+msgid "ARC/INFO ungenerate lines file"
+msgstr "入力するラインファイル"
+#, fuzzy
+msgid "ARC/INFO ungenerate label-points file"
+msgstr "入力するラベル(ポイント)ファイル"
+#, fuzzy
+msgid "ARC/INFO label-text file"
+msgstr "入力するラベル(テキスト)ファイル"
+#, fuzzy
+msgid "resultant Vector output file"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "ID Number column in label-text file"
+msgstr "テキストの列数(ID番号)"
+#, fuzzy
+msgid "GRASS category column in label-text file"
+msgstr "テキストの列数(カテゴリー値)"
+#, fuzzy
+msgid "GRASS attribute column in label-text file"
+msgstr "テキストの列数(属性)"
+#, fuzzy
+msgid "new pruned vector map"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "reports attribute, label, and other information about a sites file"
+msgstr "サイトマップの基礎情報を出力します"
+#, fuzzy
+msgid "Name of sites file."
+msgstr "対象マップ"
+#, fuzzy
+msgid "Load quietly"
+msgstr "説明なし"
+#, fuzzy
+msgid "Only count sites in current window for min/max."
+msgstr "最大値と最小値のみ出力"
+#, fuzzy
+msgid "Show quartiles for decimal attributes"
+msgstr "属性番号の出力"
+#, fuzzy
+msgid "Name of input sites map"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "which decimal attribute (if multiple)"
+msgstr "属性番号"
+#, fuzzy
+msgid "Use raster's region vs. current region"
+msgstr "ラスターマップの領域の使用"
+#, fuzzy
+msgid "Name of sites file to filter"
+msgstr "入力するファイル(サイト)"
+#, fuzzy
+msgid "Converts a GRASS site list file into an ASCII listing of site locations and their descriptions."
+msgstr "サイトマップをASCII形式のサイトリストとしてエクスポートします"
+#, fuzzy
+msgid "Include site attributes in the output"
+msgstr "カテゴリーラベルも出力"
+#, fuzzy
+msgid "Include site attribute identifiers in the output"
+msgstr "属性識別子も出力"
+#, fuzzy
+msgid "Name of input site list"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Number of cells to surround site cell"
+msgstr "考慮する周辺のセル数"
+#, fuzzy
+msgid "Attribute field type to use for operation"
+msgstr "属性タイプ"
+#, fuzzy
+msgid "Attribute field number to use for operation"
+msgstr "属性番号"
+#, fuzzy
+msgid "String attribute number to use for description"
+msgstr "文字型属性番号"
+#, fuzzy
+msgid "Create a single-valued (0/1) raster map"
+msgstr "0と1のみで構成されるラスターマップを出力"
+#, fuzzy
+msgid "Average an attribute of a site_list for all the sites within each cell of the current region."
+msgstr "サイトマップ全体から属性の平均を出力します"
+#, fuzzy
+msgid "Attribute to average values over"
+msgstr "属性タイプ"
+#, fuzzy
+msgid "Index of attribute type (ignored for cat)"
+msgstr "属性番号"
+#, fuzzy
+msgid "sites list to store means"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Suppress windows with zero averages"
+msgstr "データのないセルは出力しない"
+#, fuzzy
+msgid "Output in g.gnuplot format (overrides -z and writes to stdout)"
+msgstr "'g.gnuplot'コマンド形式で出力"
+#, fuzzy
+msgid "Convert an ASCII listing of site locations into a GRASS site list file."
+#, fuzzy
+msgid "sites file to be created"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "number of dimensions (default=2)"
+msgstr "配列の数(デフォルト2)"
+#, fuzzy
+msgid "input field separator"
+msgstr "区切り"
+#, fuzzy
+msgid "datetime or datetime1/datetime2"
+msgstr "タイムスタンプ"
+#, fuzzy
+msgid "Allows the user to re-project a sites file from one location to the current location (no datum transformation yet)."
+msgstr "サイトマップの投影変換を行います"
+#, fuzzy
+msgid "input sites list"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "location of input sites list"
+msgstr "再投影を行うロケーション"
+#, fuzzy
+msgid "mapset of input sites list"
+#, fuzzy
+msgid "output sites list"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "List sites files in input location and exit"
+msgstr "目的ロケーション内のサイトマップ一覧表示"
+#, fuzzy
+msgid "Don't prompt for Map header information"
+msgstr "ヘッダーを削除"
+#, fuzzy
+msgid "Field type (\"string\", \"dim\", or \"decimal\") and index to use for category value (uses \"cat\" by default)"
+msgstr "属性タイプまたは属性番号"
+#, fuzzy
+msgid "Allows the user to interactively adjust the settings (zoom  and  pan) of the current geographic region using a pointing device such as a mouse."
+msgstr "対象地域のズーム/パンをマウスにより行います"
+#, fuzzy
+msgid "Displays points, as icons, at user-defined locations in the active display frame on the graphics monitor."
+msgstr "アイコンでポイントマーカーを表示します"
+#, fuzzy
+msgid "Name of existing sites file"
+msgstr "対象マップ"
+#, fuzzy
+msgid "Identify just one site"
+msgstr "1度のみ実行"
+#, fuzzy
+msgid "For parsing by programs: Terse output"
+msgstr "簡易表示"
+#, fuzzy
+msgid "Allows the user to interactively query site list descriptions. "
+msgstr "マウスで指定した位置でのサイトマップのカテゴリー情報を表示します(ここはどこ?なに?)"
+#, fuzzy
+msgid "Color to erase with"
+msgstr "塗りつぶす色"
+#, fuzzy
+msgid "Name of a spheroid (for lat/lon coordinate conversion)"
+msgstr "変換先の楕円体"
+#, fuzzy
+msgid "Displays three-dimensional images based on raster map layers"
+msgstr "ラスターマップを3次元で表示します"
+#, fuzzy
+msgid "The raster map used to generate the color"
+msgstr "色のラスターマップ"
+#, fuzzy
+msgid "The raster map used to generate the 3-d texture"
+msgstr "標高のラスターマップ"
+#, fuzzy
+msgid "coordinates of center of view"
+msgstr "視野の中心座標"
+#, fuzzy
+msgid "Frequency of vector lines in output"
+msgstr "格子間隔"
+#, fuzzy
+msgid "Field of view"
+msgstr "視野の角度"
+#, fuzzy
+msgid "Color of bounding box"
+msgstr "枠の色"
+#, fuzzy
+msgid "Show null elevations"
+msgstr "NULL値を表示"
+#, fuzzy
+msgid "Draw labelled vector lines to the current display device"
+msgstr "ベクトルラインを表示します"
+#, fuzzy
+msgid "Name of existing vector map to draw"
+msgstr "対象マップ"
+#, fuzzy
+msgid "Draw all lines using either a GRASS standard color or R:G:B triplet (separated by colons)"
+msgstr "線の色"
+#, fuzzy
+msgid "Only draw areas with a matching category number (for constant color option only)"
+msgstr "表示するカテゴリー番号"
+#, fuzzy
+msgid "Draw lines according to a legend file (<cat> <R> <G> <B>)"
+msgstr "凡例用ファイル"
+#, fuzzy
+msgid "Use random colors"
+msgstr "ランダムな色を使用"
+#, fuzzy
+msgid "Line color -- a GRASS named color, an R:G:B triplet, or \"none\""
+msgstr "境界線の色"
+#, fuzzy
+msgid "Limit to matching category number(s) (constant color option only)"
+msgstr "表示するカテゴリー番号(色が指定されているときのみ有効)"
+#, fuzzy
+msgid "Use a legend file: (<cat> <R> <G> <B> [<R> <G> <B>])"
+msgstr "凡例用ファイル"
+#, fuzzy
+msgid "Sets the current color to that stated"
+msgstr "色"
+#, fuzzy
+msgid "Size, in pixels, in which the icon is to be drawn"
+msgstr "アイコンのサイズ(ピクセル)"
+#, fuzzy
+msgid "Interactively label sites using a string or double attribute value or the category value on the current graphics monitor."
+msgstr "サイトラベルを表示します"
+#, fuzzy
+msgid "Name of sites file"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Index of attribute. Ignored when attr=cat or attr=coords."
+msgstr "属性番号"
+#, fuzzy
+msgid "Relative horizontal position 'left|center|right'"
+msgstr "位置(水平方向)"
+#, fuzzy
+msgid "Relative vertical position 'top|center|bottom'"
+msgstr "位置(鉛直方向)"
+#, fuzzy
+msgid "Size of text (pixels)"
+msgstr "テキストのサイズ"
+#, fuzzy
+msgid "Sets the font"
+msgstr "フォント"
+#, fuzzy
+msgid "Sets the current grid color"
+msgstr "線の色"
+#, fuzzy
+msgid "displays vector maps, optionally only selected categories in current monitor window."
+msgstr "ベクトルマップを表示します"
+#, fuzzy
+msgid "Vector category number(s) to be displayed"
+#, fuzzy
+msgid "Input is a UNIX file name"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Allows the user to establish whether a map will be displayed using its own color table or the fixed color table of the graphics monitor."
+msgstr "モニターに用いるカラーテーブルを設定します"
+#, fuzzy
+msgid "Creates and modifies icons for use with ps.map."
+msgstr "ポストスクリプトマップに使用するアイコンの作成/編集を行います"
+#, fuzzy
+msgid "icon filename"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "file containing mapping instructions (or use input=- to enter from keyboard)"
+msgstr "設定ファイル"
+#, fuzzy
+msgid "scale of the output map, e.g. 1:25000 (default: 1panel)"
+msgstr "スケール (例: 1:25000)"
+#, fuzzy
+msgid "number of copies to print"
+msgstr "部数"
+#, fuzzy
+msgid "Selects a PostScript device for GRASS hardcopy output."
+msgstr "ハードコピーを出力するデバイスを選択します"
+#, fuzzy
+msgid "name of PostScript painter to select"
+msgstr "使用するデバイス"
+#, fuzzy
+msgid "list all available PostScript painters"
+msgstr "ポストスクリプトペインタの一覧表示"
+#, fuzzy
+msgid "print name of currently selected PostScript painter"
+msgstr "現在選択されているペインタ名を表示"
+#, fuzzy
+msgid "quietly select PostScript painter"
+msgstr "説明なし"
+#, fuzzy
+msgid "Creates raster maps from ERDAS files."
+msgstr "ERDAS/LANファイルをラスターマップとしてインポートします"
+#, fuzzy
+msgid "List the ERDAS header only"
+msgstr "ヘッダーのみ一覧表示"
+#, fuzzy
+msgid "Disable autoswap detection"
+msgstr "自動でビット反転しない"
+#, fuzzy
+msgid "Force Swapping (overrides default auto)"
+msgstr "強制ビット反転"
+#, fuzzy
+msgid "output prefix of the GRASS raster maps to be created."
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Erdas trailer input file name"
+msgstr "ERDASトレイラーファイル"
+#, fuzzy
+msgid "Starting row."
+msgstr "開始行"
+#, fuzzy
+msgid "Starting column."
+msgstr "開始列"
+#, fuzzy
+msgid "Number of rows to extract."
+msgstr "抽出する行数"
+#, fuzzy
+msgid "Number of columns to extract."
+msgstr "抽出する列数"
+#, fuzzy
+msgid "Creates ERDAS files from raster maps."
+msgstr "GRASSの画像ファイルをERDAS/LANファイルとしてエクスポートします"
+#, fuzzy
+msgid "Output 16-bit image (default 8)"
+msgstr "16bitイメージで出力"
+#, fuzzy
+msgid "Force byte swapping"
+msgstr "強制ビット反転"
+#, fuzzy
+msgid "Erdas output file name"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Allows category values from several raster map layers to be combined."
+msgstr "ラスターマップのカテゴリー値を論理操作します"
+#, fuzzy
+msgid "Use symbols (instead of graphics)"
+msgstr "シンボルを使用"
+#, fuzzy
+msgid "Create floating-point maps (0.0 - 1.0)."
+msgstr "実数形式のマップを作成"
+#, fuzzy
+msgid "Output image file header only."
+msgstr "ヘッダーのみ出力"
+#, fuzzy
+msgid "Enable extend memory option: Operation is slow"
+msgstr "仮想メモリを使用"
+#, fuzzy
+msgid "Name of an output binary map (use out=- for stdout)"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Converts point data in a GRASS raster map layer into a GRASS site_lists file."
+msgstr "ラスターマップからデータを抽出してサイトマップに変換します"
+#, fuzzy
+msgid "Output as decimal attribute rather than cat"
+msgstr "属性番号として出力"
+#, fuzzy
+msgid "Output as third dimension rather than cat"
+msgstr "標高値として出力"
+#, fuzzy
+msgid "Name of raster map."
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Creates a new binary GRASS vector (v.digit) file by extracting linear features from a thinned raster map."
+msgstr "細線化したラスターマップからベクトルマップを作成します"
+#, fuzzy
+msgid "Creates a raster map layer and site list file containing randomly located sites."
+msgstr "任意抽出を行います"
+#, fuzzy
+msgid "Name of the output sites map"
+msgstr "出力するファイル(サイトマップ)"
+#, fuzzy
+msgid "Imports a TIFF (8 or 24 bit) raster map into GRASS raster map(s)"
+msgstr "TIFFファイルをラスターマップとしてインポートします"
+#, fuzzy
+msgid "Name on TIFF file to input."
+msgstr "入力するファイル"
+#, fuzzy
+msgid "Bayesian expert system development program."
+msgstr "ベイズの統計に基づいた推論規則を適用し新しいラスターマップを作成します"
+#, fuzzy
+msgid "Run verbosely with debugging output"
+msgstr "説明付き表示"
+#, fuzzy
+msgid "The site list"
+msgstr "出力:クランプの重心を示すファイル"
+#, fuzzy
+msgid "raster map(s) to report on"
+msgstr "対象マップ"
+#, fuzzy
+msgid "mi(les),me(ters),k(ilometers),a(cres),h(ectacres),c(ell_counts),p(ercent_cover)"
+msgstr "単位"
+#, fuzzy
+msgid "name of an output file to hold the report"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "number of fp subranges to collect stats from"
+msgstr "誤差の桁数"
+#, fuzzy
+msgid "filter out all no data cells"
+msgstr "NULL値を対象に含まない"
+#, fuzzy
+msgid "filter out cells where all maps have no data"
+msgstr "すべてのマップでNULL値となっているセルを除く"
+#, fuzzy
+msgid "report for cats fp ranges (fp maps only)"
+msgstr "実数でレポートを出力"
+#, fuzzy
+msgid "Generates an output raster map layer with contiguous areas grown by one cell (pixel)."
+msgstr "エリアを拡大したラスターマップを作成します"
+#, fuzzy
+msgid "re-project a raster map from one location to the current location (no datum transformation yet)"
+msgstr "ラスターマップの投影変換を行います"
+#, fuzzy
+msgid "mapset of input map"
+#, fuzzy
+msgid "resolution of output map"
+msgstr "解像度"
+#, fuzzy
+msgid "Don't attempt to crop output map"
+msgstr "投影後の不要部分を削除しない"
+#, fuzzy
+msgid "Print grid coordinates (east and north) (requires -1 flag)"
+msgstr "格子点の座標を出力"
+#, fuzzy
+msgid "output is the interpolation error"
+msgstr "誤差を出力"
+#, fuzzy
+msgid "read fp map as integer"
+#, fuzzy
+msgid "format for reporting the slope"
+msgstr "傾斜の単位"
+#, fuzzy
+msgid "type of output aspect and slope maps"
+msgstr "出力する値の型"
+#, fuzzy
+msgid "Output E-W slope filename"
+msgstr "東西方向の傾斜を出力するファイル"
+#, fuzzy
+msgid "Output N-S slope filename"
+msgstr "南北方向の傾斜を出力するファイル"
+#, fuzzy
+msgid "Output partial derivative dxx filename"
+msgstr "dxx値の偏導関数を出力するファイル"
+#, fuzzy
+msgid "Output partial derivative dyy filename"
+msgstr "dyy値の偏導関数を出力するファイル"
+#, fuzzy
+msgid "Output partial derivative dxy filename"
+msgstr "dxy値の偏導関数を出力するファイル"
+#, fuzzy
+msgid "Name of file for output (use out=- for stdout)"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "print range only."
+#, fuzzy
+msgid "Converts raster data referenced using latitude and longitude coordinates to a UTM-referenced map layer in GRASS raster format."
+msgstr "緯度/経度座標ファイルから UTM座標ファイルを作成します"
+#, fuzzy
+msgid "input file"
+msgstr "入力するファイル"
+#, fuzzy
+msgid ""
+"one corner latitude and longitude of the input\n"
+"format: {nw|ne|sw|se},%s,%s"
+msgstr "領域の端の座標値 入力形式: {nw|ne|sw|se},%s,%s"
+#, fuzzy
+msgid "resolution of the input (in arc seconds)"
+msgstr "解像度(秒角)"
+#, fuzzy
+msgid "Starting points site file"
+msgstr "始点を示すサイトマップ"
+#, fuzzy
+msgid "Stop points site file"
+msgstr "終点を示すサイトマップ"
+#, fuzzy
+msgid "Extracts area edges from a raster map layer and converts data to GRASS vector format."
+msgstr "ラスターマップからエリアエッジを抽出してベクトルマップを作成します"
+#, fuzzy
+msgid "Output only area borders as vector lines"
+msgstr "ベクトルラインを出力"
+#, fuzzy
+msgid "Number of values printed before wrapping a line"
+msgstr "読み込む桁数"
+#, fuzzy
+msgid "raster map name from which to copy color table"
+msgstr "カラーテーブルに用いるラスターマップ"
+#, fuzzy
+msgid ""
+"\n"
+"Where color type is one of:\n"
+msgstr ""
+"\n"
+"ここでのカラーテーブル(colorパラメータ)は次のうちのいずれかです:\n"
+#, fuzzy
+msgid "  aspect    (aspect oriented grey colors)\n"
+msgstr "  aspect    (グレーカラー)\n"
+#, fuzzy
+msgid "  grey      (linear grey scale)\n"
+msgstr "  grey      (グレースケール)\n"
+#, fuzzy
+msgid "  grey.eq   (histogram equalized grey scale)\n"
+msgstr "  grey.eq   (ヒストグラムを平滑化したグレースケール)\n"
+#, fuzzy
+msgid "  grey.log  (histogram logarithmic transformed grey scale)\n"
+msgstr "  grey.log  (ヒストグラムを対数化したグレースケール)\n"
+#, fuzzy
+msgid "  byg       (blue through yellow to green colors)\n"
+msgstr "  byg       (青→黄→緑)\n"
+#, fuzzy
+msgid "  byr       (blue through yellow to red colors)\n"
+msgstr "  byr       (青→黄→赤)\n"
+#, fuzzy
+msgid "  gyr       (green through yellow to red colors)\n"
+msgstr "  gyr       (緑→黄→赤)\n"
+#, fuzzy
+msgid "  rainbow   (rainbow color table)\n"
+msgstr "  rainbow   (レインボー)\n"
+#, fuzzy
+msgid "  ramp      (color ramp)\n"
+msgstr "  ramp      (ランプ)\n"
+#, fuzzy
+msgid "  ryg       (red through yellow to green colors)\n"
+msgstr "  ryg       (赤→黄→緑)\n"
+#, fuzzy
+msgid "  random    (random color table)\n"
+msgstr "  random    (ランダム)\n"
+#, fuzzy
+msgid "  wave      (color wave)\n"
+msgstr "  wave      (カラーウェーブ)\n"
+#, fuzzy
+msgid "  rules     (create new color table by rules)\n"
+msgstr "  rules     (ルールの新規作成)\n"
+#, fuzzy
+msgid "method of object-based statistic"
+msgstr "統計解析方法"
+#, fuzzy
+msgid "resultant raster map (not used with 'distribution')"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Northern limit of geographic region"
+msgstr "領域の北端"
+#, fuzzy
+msgid "Eastern limit of geographic region"
+msgstr "領域の東端"
+#, fuzzy
+msgid "Western limit of geographic region"
+msgstr "領域の西端"
+#, fuzzy
+msgid "Override projection (use locations projection)"
+msgstr "現在のロケーションの投影法を使用"
+#, fuzzy
+msgid "Extend location extents based on new dataset."
+msgstr "データセットをもとにロケーションを拡張"
+#, fuzzy
+msgid "Maximum magnitude of random grid point offset"
+msgstr "ランダムにとるオフセットの最大値"
+#, fuzzy
+msgid "Outputs a raster map layer whose category values represent the application of user-specified criteria (rules statements) to other raster map layers' category values."
+msgstr "指定した推論規則を適用し新しいラスターマップを作成します"
+#, fuzzy
+msgid "Converts a PPM image file to GRASS raster map(s)."
+msgstr "PPMファイルをラスターマップとしてインポートします"
+#, fuzzy
+msgid "Create separate red/green/blue maps."
+msgstr "赤/緑/青に対応するラスターマップを出力"
+#, fuzzy
+msgid "Create composite color map."
+msgstr "合成した色のラスターマップを出力"
+#, fuzzy
+msgid "Converts Universal Transverse Mercator (UTM) coordinates to geographic (latitude/longitude) coordinates."
+msgstr "UTM座標値から緯度/経度座標値に変換します"
+#, fuzzy
+msgid "reference spheroid (ellipsoid)"
+msgstr "楕円体"
+#, fuzzy
+msgid "Specified zone is in the southern hemisphere"
+msgstr "領域を南半球で指定"
+#, fuzzy
+msgid "Input is reversed: north,east"
+msgstr "入力する座標値を反転(north,east)"
+#, fuzzy
+msgid "Do not flag invalid east,north input lines as errors"
+msgstr "領域外の座標が入力されても続行"
+#, fuzzy
+msgid "Flag other input lines as errors"
+msgstr "他の形式で入力があった場合は中止"
+#, fuzzy
+msgid "Output in decimal degrees"
+msgstr "10進数で出力"
+#, fuzzy
+msgid "Converts geographic coordinates to Universal Transverse Mercator (UTM) coordinates."
+msgstr "緯度/経度座標値からUTM座標値に変換します"
+#, fuzzy
+msgid "utm zone (results will be forced into this zone)"
+msgstr "UTMゾーン"
+#, fuzzy
+msgid "Input is reversed: lat,lon"
+msgstr "入力する座標値を反転(経度,緯度)"
+#, fuzzy
+msgid "Do not flag invalid lon,lat input lines as errors"
+#, fuzzy
+msgid "Suppress printing the utm zone"
+msgstr "UTMゾーンを出力しない"
+#, fuzzy
+msgid "Rotates elevation data extracted by either m.dted.extract or m.dmaUSGSread."
+msgstr "抽出した標高データを90度回転します"
+#, fuzzy
+msgid "Output file"
+msgstr "出力するファイル"
+#, fuzzy
+msgid "Number of bytes per cell (i.e. per data value)"
+msgstr "1セルのバイト数"
+#, fuzzy
+msgid "Provides a terse description of level 1 and 2 digital terrain elevation data (DTED) files produced and distributed by the Defense Mapping Agency (DMA) on 1/2-inch magnetic tapes."
+msgstr "1/2インチ磁気テープのデータからDTEDを簡易表示します"
+#, fuzzy
+msgid "Name of tape drive device"
+msgstr "入力するデバイス"
+#, fuzzy
+msgid "Datum shift program. Return geographic coordinates based on a different datum that the one used to obtain the original coordinates. "
+msgstr "楕円体間のデータシフトを行います"
+#, fuzzy
+msgid "use block shift transformation (default)"
+msgstr "ブロック変換によるシフト(デフォルト)"
+#, fuzzy
+msgid "use bursa wolf 3d similarity transformation (not implemented)"
+msgstr "BURSA変換によるシフト(未実装)"
+#, fuzzy
+msgid "height above ellipsoid"
+msgstr "長円からの高さ"
+#, fuzzy
+msgid "input spheroid"
+msgstr "元の楕円体"
+#, fuzzy
+msgid "output spheroid"
+msgstr "シフト先の楕円体"
+#, fuzzy
+msgid "input datum"
+msgstr "元のデータ"
+#, fuzzy
+msgid "output datum"
+msgstr "シフト先のデータ"
+#, fuzzy
+msgid "x shift"
+msgstr "X方向のシフト"
+#, fuzzy
+msgid "y shift"
+msgstr "Y方向のシフト"
+#, fuzzy
+msgid "z shift"
+msgstr "Z方向のシフト"
+#, fuzzy
+msgid "Rx rotational parameter"
+msgstr "スムージングパラメータ"
+#, fuzzy
+msgid "Ry rotational parameter"
+#, fuzzy
+msgid "Rz rotational parameter"
+#, fuzzy
+msgid "Converts UTM coordinates falling within the current geographic region to geographic (latitude/longitude) coordinates. "
+msgstr "現在の領域をUTM座標から緯度/経度座標に変換します"
+#, fuzzy
+msgid "Flips elevation data extracted from systems that retrieve data by rows from south to north."
+msgstr "抽出した標高データを180度回転します180度回転します"
+#, fuzzy
+msgid "Number of bytes per cell (ie, per data value)"
+msgstr "1セルのバイト数"
+#, fuzzy
+msgid "Finds geographic region information for U.S. Census Bureau TIGER input data."
+msgstr "TMS(TIGER MAPPING SERVISE)に入力する地域情報データを検索します"
+#, fuzzy
+msgid "Filename for raw tiger data (type 1)"
+msgstr "入力するファイル"
+#, fuzzy
+msgid "UTM zone for this county"
+msgstr "UTMゾーン"
+#, fuzzy
+msgid "Provides a terse description of USGS Digital Elevation Model (DEM) data files stored on 1/2-inch magnetic tape."
+msgstr "1/2インチ磁気テープのデータからDEMを簡易表示します"
+#, fuzzy
+msgid "Tape input device"
+msgstr "入力するデバイス"
+#, fuzzy
+msgid "Blocksize of tape data"
+msgstr "データのブロックサイズ"
+#, fuzzy
+msgid "First file to examine"
+msgstr "開始ファイル"
+#, fuzzy
+msgid "Last file to examine"
+msgstr "終了ファイル"
+#, fuzzy
+msgid "y coordinate"
+msgstr "Y座標値"
+#, fuzzy
+msgid "max iterations"
+msgstr "最大反復回数"
+#, fuzzy
+msgid "Extracts digital terrain elevation data (DTED - levels 1 and 2) produced and supplied by the Defense Mapping Agency (DMA) on 1/2-inch magnetic tapes."
+msgstr "1/2インチ磁気テープのデータからDTEDを抽出します"
+#, fuzzy
+msgid "Name of header output file"
+msgstr "ヘッダーを出力するファイル"
+#, fuzzy
+msgid "North latitude of region to extract (format: %s)"
+msgstr "北端(入力形式: %s)"
+#, fuzzy
+msgid "South latitude of region to extract (format: %s)"
+msgstr "南端(入力形式: %s)"
+#, fuzzy
+msgid "East longitude of region to extract (format: %s)"
+msgstr "東端(入力形式: %s)"
+#, fuzzy
+msgid "West longitude of region to extract (format: %s)"
+msgstr "西端(入力形式: %s)"
+#, fuzzy
+msgid "Read the entire tape in all cases"
+msgstr "すべてのテープを読み込む"
+#, fuzzy
+msgid "Extracts USGS Digital Elevation Model (DEM) data from 1/2-inch magnetic tape."
+msgstr "1/2インチ磁気テープのデータからDEMデータを抽出します"
+#, fuzzy
+msgid "Input device or file"
+msgstr "入力するデバイスまたはファイル"
+#, fuzzy
+msgid "Output raster map (examine only if none specified)"
+msgstr "出力するファイル(未入力の場合はチェックのみ)"
+#, fuzzy
+msgid "First file to look at"
+msgstr "開始ファイル"
+#, fuzzy
+msgid "Last file to look at"
+msgstr "終了ファイル"
+#, fuzzy
+msgid "Selects a device (printer) for GRASS hardcopy output."
+#, fuzzy
+msgid "list all available painters"
+msgstr "ペインタの一覧表示"
+#, fuzzy
+msgid "print name of currently selected painter"
+#, fuzzy
+msgid "quietly select painter"
+msgstr "説明なし"
+#, fuzzy
+msgid "Color map output utility."
+msgstr "ハードコピー出力の設定を行います"
+#, fuzzy
+msgid "Align region to resolution [default = align to bounds]"
+msgstr "境界を分解能に合わせる"
+#, fuzzy
+msgid "Set region to match this sites map"
+msgstr "設定に用いるサイトマップ"
+#, fuzzy
+msgid "Value for the eastern edge "
+msgstr "南端"
+#, fuzzy
+msgid "Value for the western edge "
+msgstr "西端"
+#, fuzzy
+msgid "Grid resolution (both north-south and east-west)"
+msgstr "格子の分解能"
+#, fuzzy
+msgid "Overwrite <to> file(s)"
+msgstr "上書き"
+#, fuzzy
+msgid "Overwrite <new> file(s)"
+msgstr "上書き"
+#, fuzzy
+msgid "  vect   (binary vector maps)\n"
+msgstr "  vect   (ベクトルマップ)\n"
+#, fuzzy
+msgid "  icon   (paint icon files)\n"
+msgstr "  icon   (ペイントアイコンファイル)\n"
+#, fuzzy
+msgid "  labels (paint label files)\n"
+msgstr "  labels (ペイントラベルファイル)\n"
+#, fuzzy
+msgid "  sites  (site list files)\n"
+msgstr "  sites  (サイトマップ)\n"
+#, fuzzy
+msgid "  group  (imagery group files)\n"
+msgstr "  group  (画像グループ)\n"
+#, fuzzy
+msgid "  3dview (3D view parameters)\n"
+msgstr "  3dview (3次元表示パラメータファイル)\n"
+msgid "Do not export long colortable"
+msgstr "大きいサイズのカラーテーブルをエクスポートしない"
+msgid "unable to open new L map layer."
+msgstr "新規の Lマップレイヤーが開けません"
+msgid "unable to open new S map layer."
+msgstr "新規の S マップレイヤーが開けません"
+msgid ""
+"Sorry, if any of the following options are set:\n"
+"    basin, stream, half.basin, slope, or lS\n"
+"    you MUST provide a value for the basin threshold parameter."
+msgstr ""
+"次のオプションのいずれかがセットされています:\n"
+"    basin, stream, half.basin, slope, lS\n"
+"    盆地境界パラメータの値を必ずしていする必要があります  "
+msgid "SECTION 4: Length Slope determination."
+msgstr "セクション 4: 長さ・傾斜の決定"
+msgid "SECTION 3: Accumulating Surface Flow."
+msgstr "セクション 3: 表層流の累計"
+msgid "Default value: GRASS_GUI if defined otherwise tcltk"
+msgstr "既定値: 定義されていればGRASS_GUI そうでなければtcltk  "
+msgid "tcltk;Tcl/Tk based GUI - GIS Manager (gis.m);oldtcltk;Old Tcl/Tk based GUI - Display Manager (d.m);wxpython;wxPython based next generation GUI;text;command line interface only"
+msgstr "tcltk;GUI に基づく Tcl/Tk - GIS管理者 (gis.m);oldtcltk;GUI に基づく Old Tcl/Tk - 表示管理者 (d.m);wxpython;次世代 GUIに基づくwxPython;テキスト;コマンドラインインターフェースのみ"
+msgid "Input raster map contains cells with NULL-value (no-data). The value %d was used to represent no-data values in the input map. You can specify nodata value by %s parameter."
+msgstr "入力したラスターマップはNULL値(データ無し)セルを含んでいます.この指定されたマップで値 %d はデータ無し値を示します.%s パラメーターでデータ無し値を指定できます"
+msgid "Output aspect filename"
+msgstr "方位を出力するファイル名"
+msgid "vector, query"
+msgstr "ベクトル,検索"
+msgid "Exporting %i points/lines..."
+msgstr "%i のポイント/ラインをエクスポート中、、、"
+msgid "Computing row %d of covariance matrix..."
+msgstr "共分散マトリックスの計算をしている行 %d..."
+msgid "Feature type. Combination of types is not supported by all formats."
+msgstr "地物の型. 複合型は全てのフォーマットでサポートされる訳ではありません"
+msgid "%d faces found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d の面がありますがエクスポートの指定がありません.'type' パラメーターを確認して下さい"
+msgid "Create a MASK for limiting raster operation"
+msgstr "制限ラスターオプションのMASKを作成する"
+msgid "Cannot make stat of %s configuration file"
+msgstr "%s 設定ファイルの統計を作成できません"
+msgid "Illegal configuration file"
+msgstr "不正な設定ファイル"
+msgid "CHILD[pid = %i]: unable to open %s mask ... continue without!!!"
+msgstr "CHILD[pid = %i]: %s マスクを開けません、、、何もしません!!!  "
+msgid "r.li.worker (pid %i) exited with abnormal status %i"
+msgstr "r.li.worker (pid %i) が異常状態 %i で終了"
+msgid "r.li.worker (pid %i) terminated"
+msgstr "r.li.worker (pid %i) は終了しました"
+msgid "Seed [%d] larger than maximum [%d]"
+msgstr "シード [%d] は最大値 [%d] より大きい"
+msgid "Seed [%d] smaller than minimum [%d]"
+msgstr "シード [%d] が最小値 [%d] より小さい"
+msgid "point;simple x,y[,z] list;standard;GRASS's vector ASCII format"
+msgstr "ポイント;単に x,y [,z] リスト;標準;GRASSのベクトルASCIIフォーマット"
+msgid "Number of column used as y coordinate (first column is 1) for points mode"
+msgstr "ポイントモードで y 座標に使う列の数(最初の列は1)"
+msgid "Number of column used as z coordinate (first column is 1) for points mode"
+msgstr "ポイントモードで z 座標に使う列の数(最初の列は1)"
+msgid "If 0, z coordinate is not used"
+msgstr "0の場合,z 座標は使用しない"
+msgid "Number of column used as category (first column is 1) for points mode"
+msgstr "ポイントモードでカテゴリーに使う列の数(最初の列は1)"
+msgid "If 0, unique category is assigned to each row and written to new column 'cat'"
+msgstr "0の場合,各行に1つだけのカテゴリーが指定されて新規に「cat」列が書き込まれます"
+msgid "Create a new empty vector map and exit. Nothing is read from input"
+msgstr "新規に空のベクトルマップを作成し、入力から読み込まない"
+msgid "Show the category label in the grid cell(s)"
+msgstr "グリッドセルでカテゴリーラベルを表示します"
+msgid "Unable to read symbol, unable todisplay points"
+msgstr "記号を読み込めません、ポイントを表示できません"
+msgid "Converting %s..."
+msgstr "%s を変換中... "
+msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)"
+msgstr "経路サンプリングメソッド (SIMWE) を用いた土砂流送、侵食/堆積のシミュレーション"
+msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)"
+msgstr "経路サンプリングメソッド(SIMWE)を用いた地表流の水文学シミュレーション"
+msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation layer."
+msgstr "指定された標高レイヤーをフィルタリングし,凹みのない標高マップと流れ方向マップを作成"
+msgid "Calculates cast shadow areas from sun position and DEM. Either A: exact sun position is specified, or B: date/time to calculate the sun position by r.sunmask itself."
+msgstr "太陽位置と DEM をもとに陰影領域を計算.r.sunmask 自身から,A: 正確な太陽位置の指定,または B: 太陽位置を計算するための日付/時刻を指定"
+msgid "A: altitude of the sun above horizon, degrees"
+msgstr "A: 水平からの太陽の高度、単位は度"
+msgid "A: azimuth of the sun from the north, degrees"
+msgstr "A: 北からの太陽の方位角 単位は度  "
+msgid "B: minutes (0..60)"
+msgstr "B: 分(0..60)  "
+msgid "B: seconds (0..60)"
+msgstr "B: 秒(0..60)  "
+msgid "B: timezone (east positive, offset from GMT, also use to adjust daylight savings)"
+msgstr "B: タイムゾーン(東が正, GMTオフセット、 サマータイム調整あり)  "
+msgid "Creates topographic index [ln(a/tan(beta))] map from elevation map."
+msgstr "標高マップからトポグラフィックインデックス [ln(a/tan(beta))] マップ を作成します.  "
+msgid "New LOCATION name (not location path)"
+msgstr "新しいロケーション名 (ロケーションパスではありません)  "
+msgid "New GISDBASE (full path to the directory where the new location is)"
+msgstr "新しいGISDBASE (新しいロケーションのあるディレクトリーへのフルパス)  "
+msgid "Name for output file (do not add extension)"
+msgstr "出力ファイル名(拡張を追加しないように)"
+msgid "Width and height of output image"
+msgstr "出力画像の幅と高さ"
+msgid "Surface"
+msgstr "曲面"
+msgid "Volume"
+msgstr "ボリューム"
+#, fuzzy
+msgid "Import Mapgen or Matlab-ASCII vector maps into GRASS."
+msgstr "MapgenあるいはMatlabベクトルマップをGRASSにインポート"
+msgid "Vector map for which to edit attribute table"
+msgstr "属性テーブルを編集するためのベクトルマップ"
+msgid "Layer where to add column"
+msgstr "列を追加するレイヤー"
+msgid "Swapping header data"
+msgstr "ヘッダデータの交換"
+msgid "Exporting raster as double values (bytes=%d)"
+msgstr "倍精度値としてラスターをエクスポート(バイト=%d)"
+msgid "Reading map"
+msgstr "マップの読み込み"
+msgid "Signed data (high bit means negative value)"
+msgstr "負の値を含む(最上位ビットが符号ビット) "
+msgid "Number of bytes per cell (1, 2, 4)"
+msgstr "1セルのバイト数(1, 2, 4) "
+msgid "Parsing bytes per cell"
+msgstr "1セルのバイト数 "
+msgid "Byte Swapping Turned On."
+msgstr "バイトスワップが有効です  "
+msgid ""
+"Missing parameters ...\n"
+"Must provide at least[north= south= east= west=] OR [r=\tc=]"
+msgstr ""
+"パラメータが不足しています ...\n"
+"[north= south= east= west=]の内の一つ以上、または[r=\tc=] を指定してください "
+msgid "You have to provide all limits of geographic region (n,s,e,w)"
+msgstr "地理領域の全ての制限設定をする必要があります(n, s, e, w)"
+msgid "Illegal number of rows <%s>"
+msgstr "無効な行の数 <%s> "
+msgid "Illegal number of columns <%s>"
+msgstr "無効な列の数 <%s> "
+msgid "Using N=%f S=%f E=%f W=%f"
+msgstr "使用する値 N=%f S=%f E=%f W=%f  "
+msgid "Using rows=%d cols=%d\n"
+msgstr "使用する値 rows=%d cols=%d\n"
+msgid "File Size %d ... Total Bytes %d"
+msgstr "ファイルサイズ %d ... Total Bytes %d  "
+msgid "Try bytes=%d or adjusting input parameters"
+msgstr "試行するbyte値=%d または、補正値の指定"
+msgid "Conversion failed at row %d"
+msgstr "行の変換に失敗 %d  "
+msgid "Remove lines and areas smaller than threshold"
+msgstr "閾値より小さいラインとエリアを除去"
+msgid "%d boundaries were deleted, input areas are not preserved"
+msgstr "%d 境界は削除されました, 入力領域は保存されていません"
+msgid "Unable to calculate centroid for area %d"
+msgstr "エリア %d のセントロイドを計算できません"
+msgid "New centroids were calculated, attribute attachment may be changed"
+msgstr "新しいセントロイドが計算されました, 属性添付が変更されている可能性があります"
+msgid "Areas may have disappeared and/or area attribute attachment may have changed"
+msgstr "エリアが消失しそして/もしくはエリア属性添付が変更している可能性があります"
+msgid "Try v.clean tool=prune thresh=%f"
+msgstr "v.clean tool=prune thresh=%f を試みます "
+msgid ""
+"\n"
+"ERROR: Required parameter <%s> not set:\n"
+"    (%s).\n"
+msgstr ""
+"\n"
+"エラー: 要求されたパラメーター <%s> は設定されません:\n"
+"    (%s).\n"
+msgid "into  <%s@%s> (location <%s>) ... %s"
+msgstr "へ  <%s@%s> (ロケーション <%s>) ... %s"
+msgid "data compression required an additional"
+msgstr "追加を要求されたデータ圧縮"
+msgid "Rectified input raster map <%s> will be saved as <%s>"
+msgstr "修正されたラスターマップ <%s>は <%s>として保存されます"
+#, fuzzy
+msgid "Target information for group <%s> missing.\n"
+msgstr "グループのターゲット情報 <%s>が見つかりません"
+#, fuzzy
+msgid "Target location <%s> not found\n"
+msgstr "ターゲットロケーション <%s> は見つかりません"
+#, fuzzy
+msgid " %d rows, %d cols (%ld cells) completed in "
+msgstr "%d 行, %d 列 (%ld セル) は完成しました "
+#, fuzzy
+msgid " %.1f cells per minute\n"
+msgstr "1分ごとの%.1f セル"
+msgid "Location of input raster map"
+msgstr "入力ラスターマップのロケーション "
+msgid "Mapset of input raster map"
+msgstr "入力するラスターマップのマップセット "
+msgid "Checking location <%s>, mapset <%s>..."
+msgstr "ロケーション <%s>、マップセット <%s> をチェックしています..."
+msgid " %d.%02d.%02d, daynum %d, time: %02i:%02i:%02i (decimal time: %f)\n"
+msgstr " %d.%02d.%02d, 日付 %d, 時間: %02i:%02i:%02i (小数以下の時間: %f)\n"
+msgid " long: %f, lat: %f, timezone: %f\n"
+msgstr "経度: %f, 緯度: %f, タイムゾーン: %f\n"
+msgid ""
+" Solar position: sun azimuth: %f,\n"
+"   sun angle above horz.(refraction corrected): %f\n"
+msgstr ""
+" 太陽位置: 太陽方位: %f,\n"
+"   地平線からの太陽高度.(屈折補正済み): %f\n"
+msgid " Sunrise time (without refraction): %02d:%02d:%02d\n"
+msgstr " 日の出時刻 (大気差を含まない): %02d:%02d:%02d\n"
+msgid " Sunset time  (without refraction): %02d:%02d:%02d\n"
+msgstr " 日の入時刻 (大気差を含まない):: %02d:%02d:%02d\n"
+msgid "No map calculation requested. Finished.\n"
+msgstr "マップ計算が要求されませんでした。終了します.\n"
+msgid "Can't open range file for %s"
+msgstr " %s に対する範囲fileが開けません"
+msgid "Can't read row in input elevation map"
+msgstr "入力した標高マップから行を読み取れません"
+msgid "<%s> created"
+msgstr "<%s> 作成されました"
+msgid "You have to use a different location for input than the current"
+msgstr "入力には現在とは違ったロケーションを使用してください"
+msgid "Raster map to be recoded"
+msgstr "記録するラスターマップ"
+msgid "Unable to open rules file <%s>"
+msgstr "ルールファイル <%s> を開けません"
+msgid "Displays and overlays raster map layers in the active display frame on the graphics monitor."
+msgstr "グラフィックモニターでアクティブな表示フレームに、ラスターマップレイヤーを重ねて表示します"
+msgid "Raster map to be displayed"
+msgstr "表示するラスターマップ"
+msgid "Displays vector data in the active frame on the graphics monitor."
+msgstr "グラフィックモニター上で動作中のフレームにベクトルデータを表示します"
+msgid "Area size [%.1e], area not imported"
+msgstr "領域サイズ [%.1e], 領域はインポートされていません"
+msgid "Island size [%.1e], island not imported"
+msgstr "島のサイズ [%.1e], 島はインポートされていません"
+msgid "vector, projection"
+msgstr "ベクトル,投影"
+msgid "Allows projection conversion of vector maps."
+msgstr "ベクトルマップの矢の投影変換"
+msgid "Duplicate area centroids"
+msgstr "重複するエリアセントロイド"
+msgid "Vector output map"
+msgstr "ベクトル出力マップ"
+msgid "Error while writing to temp file"
+msgstr "一時ファイルに書き込み中のエラー"
+msgid "Error writing row %d"
+msgstr "行の書き込みエラー %d"
+msgid "Poorly placed psuedo control points. "
+msgstr "不完全に設置された疑似コントロールポイント"
+msgid "Cannot generate the transformation equation."
+msgstr "変換方程式が作成できません"
+msgid "No active psuedo control points"
+msgstr "アクティブな疑似コントロールマップはありません"
+msgid "Unable to write temp file: %s"
+msgstr "一時ファイルに書き込みできません: %s"
+msgid "Unable to open map %s"
+msgstr "マップが開けません %s"
+msgid "Unable to write row %d"
+msgstr "行に書き込みできません %d"
+msgid "Unable to write raster map. You might want to check available disk space and write permissions."
+msgstr "ラスターマップを書き込めません。利用できるディスクを確認し、許可を書き込んでください。"
+msgid "Please select the file(s) you wish to rectify by naming an output file"
+msgstr "出力ファイルに名づけて修正したいファイルを選択してください"
+msgid "%s@%s: projection doesn't match current settings"
+msgstr "%s@%s: 投影は現在の設定と一致していません"
+msgid "%s@%s: zone doesn't match current settings"
+msgstr "%s@%s: ゾーンは現在の設定と一致していません"
+msgid "New MAPSET name"
+msgstr "新しいマップセット名"
+msgid "Failed in attempt to open %s"
+msgstr "%s を開けませんでした"
+msgid "Generates raster map layers of slope, aspect, curvatures and partial derivatives from a raster map layer of true elevation values. Aspect is calculated counterclockwise from east."
+msgstr "真の標高値ラスターマップレイヤーから、斜面、方位、曲面、偏導関数のラスターマップを作成します. 方位は東から反時計回りに計算します"
+msgid "Output slope filename"
+msgstr "傾斜を出力するファイル名"
+msgid "Output profile curvature filename"
+msgstr "断面曲率を出力するファイル名"
+msgid "Output tangential curvature filename"
+msgstr "正接曲率を出力するファイル名"
+msgid "Output first order partial derivative dx (E-W slope) filename"
+msgstr "一次の偏導関数 dx (E-W 傾斜) を出力するファイル名"
+msgid "Output first order partial derivative dy (N-S slope) filename"
+msgstr "一次の偏導関数 dy (N-S 傾斜) を出力するファイル名"
+msgid "Output second order partial derivative dxx filename"
+msgstr "二次の偏導関数 dxx を出力するファイル名"
+msgid "Output second order partial derivative dyy filename"
+msgstr "二次の偏導関数 dyy を出力するファイル名"
+msgid "Output second order partial derivative dxy filename"
+msgstr "二次の偏導関数 dxy を出力するファイル名"
+msgid "wrong type: %s"
+msgstr "間違ったタイプ: %s"
+msgid "Creating support files..."
+msgstr "サポートファイルを作成中..."
+msgid "Elevation products for mapset [%s] in [%s]"
+msgstr "マップセット [%s] ([%s] 内)の標高のプロダクト"
+msgid "ASPECT [%s] COMPLETE"
+msgstr "方位 [%s] 完了"
+msgid "SLOPE [%s] COMPLETE"
+msgstr "傾斜 [%s] 完了"
+msgid "PROFILE CURVE [%s] COMPLETE"
+msgstr "プロファイル曲線 [%s] 完了"
+msgid "TANGENTIAL CURVE [%s] COMPLETE"
+msgstr "正接曲線 [%s] 完了"
+msgid "E-W SLOPE [%s] COMPLETE"
+msgstr "E-W 傾斜 [%s] 完了"
+msgid "N-S SLOPE [%s] COMPLETE"
+msgstr "N-S 傾斜 [%s] 完了"
+msgid "DXX [%s] COMPLETE"
+msgstr "DXX [%s] 完了"
+msgid "DYY [%s] COMPLETE"
+msgstr "DYY [%s] 完了"
+msgid "DXY [%s] COMPLETE"
+msgstr "DXY [%s] 完了"
+msgid "Generates a raster map layer showing watershed subbasins."
+msgstr "分水域を示すラスターマップを作成します "
+msgid "Coded stream network file name"
+msgstr "河川ファイル"
+msgid "Thinned ridge network file name"
+msgstr "分水稜ファイル "
+msgid "Name for the resultant watershed partition file"
+msgstr "出力する分水界ファイル "
+msgid "Output raster map having shadows"
+msgstr "出力する影のラスターマップ名"
+msgid "By_position"
+msgstr "位置を使う  "
+msgid "B: year (1950..2050)"
+msgstr "B: 年(1950..2050)  "
+msgid "By_time"
+msgstr "By_time  "
+msgid "B: month (0..12)"
+msgstr "B: 月(0..12)  "
+msgid "B: day (0..31)"
+msgstr "B: 日(0..31)  "
+msgid "B: hour (0..24)"
+msgstr "B: 時(0..24)  "
+msgid "East coordinate (point of interest, default: map center)"
+msgstr "東西座標(POI、既定値はマップ中心)"
+msgid "North coordinate (point of interest, default: map center)"
+msgstr "南北座標(POI、既定値はマップ中心)"
+msgid "Zero is a real elevation"
+msgstr "ゼロは実際の標高"
+msgid "raster, terrain analysis"
+msgstr "ラスター、地形分析"
+msgid "                No topology present"
+msgstr "地形がありません"
+msgid "Uses a GRASS vector points map to produce a convex hull vector map."
+msgstr "GRASSのベクトルポイントマップを使用して凸包ベクトルマップを作成"
+msgid "Name of input vector points map"
+msgstr "指定するベクトルポイントマップ名"
+msgid "Name of output vector area map"
+msgstr "出力するベクトルエリアマップ名"
+msgid "Cannot open vector map <%s>"
+msgstr "ベクトルマップ <%s> を開けません"
+msgid "Experimental NVIZ CLI prototype."
+msgstr "実験段階の NVIZ CLI 試作品"
+msgid "It was impossible to create <Auxiliar_outlier_table>."
+msgstr "<Auxiliar_outlier_table>は作成できませんでひた.  "
+msgid "It was not possible to drop <%s> table. Nothing will be done. Try to drop it manually."
+msgstr "<%s> 表をドロップできませんでした. 何も変更されません. 手動でドロップしてください.  "
+msgid "Cross Validation was success!"
+msgstr "交差検証は成功しました!  "
+msgid "Interpolation: The region resolution is too high: %d cells. Consider to change it."
+msgstr "補間: この領域の解像度は高すぎます: %d セル. 変更してください."
+msgid "Creating auxiliar table for archiving overlapping zones"
+msgstr "重複する地域のためauxiliar表を作成しています"
+msgid "<Auxiliar_edge_table> created in database."
+msgstr "<Auxiliar_edge_table> はデータベースに作成されました."
+msgid "Unable to open table <%s_edge_Interpolation>"
+msgstr "表 <%s_edge_Interpolation> を開けません"
+msgid "M.Q. solution"
+msgstr "M.Q.ソリューション"
+msgid "3-d data in dxf file. Polyline_flag: %d"
+msgstr " dxf fileの3-d データ. Polyline_flag: %d  "
+msgid "Selects data from table."
+msgstr "テーブルからデータを選択"
+msgid "Unable to open MASK"
+msgstr "マスクを開けません"
+msgid "Name of the longitude input raster map [decimal degrees]"
+msgstr "経度入力ラスターマップ名(小数点付の度) "
+msgid "Starting map [%s]"
+msgstr "マップを開始 [%s]"
+msgid "Percent done:"
+msgstr "完了率(パーセント)"
+msgid "Starting filter #%d, distance: %.*lf, exponent: %.*lf, flat: %.*lf"
+msgstr "フィルタリングを開始 #%d, 距離: %.*lf,指数: %.*lf,均一: %.*lf  "
+msgid ""
+"%s: saving [%s] raster map layer.\n"
+"Percent complete:"
+msgstr ""
+"%s: 保存しています・・・[%s] ラスタマップレイヤー.\n"
+"パーセント終了:  "
+msgid "Number of column used as x coordinate (first column is 1) for points mode"
+msgstr "ポイントモードで x 座標に使う列の数(最初の列は1)"
+msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares)"
+msgstr "単位 "
+msgid "Allocation memory for bilinear interpolation"
+msgstr "双線形補間のための割り当てメモリー"
+msgid "Allocation memory for bicubic interpolation"
+msgstr "バイキュービック補間のための割り当てメモリー  "
+msgid "No raster nor vector output"
+msgstr "ラスターもベクトル出力もありません"
+msgid "No data within this subzone. Consider changing the spline step."
+msgstr "このサブゾーン内にデータはありません. スプラインステップを変更してみてください.  "
+msgid "Mean's calculation"
+msgstr "平均値の計算"
+msgid "Bad format in initial exposusre station file for group [%s]"
+msgstr "グループ [%s]の初期暴露駅ファイルの不正なフォーマット"
+msgid "Name of elevation raster map"
+msgstr "標高ラスターマップ名"
+msgid "Input raster map contains cells with NULL-value (no-data). The value %g was used to represent no-data values in the input map. You can specify nodata value by %s parameter."
+msgstr "入力したラスターマップはNULL値(データ無し)セルを含んでいます.この指定されたマップで値 %g はデータ無し値を示します.%s パラメーターでデータ無し値を指定できます"
+msgid "douglas;Douglas-Peucker Algorithm;douglas_reduction;Douglas-Peucker Algorithm with reduction parameter;lang;Lang Simplification Algorithm;reduction;Vertex Reduction Algorithm eliminates points close to each other;reumann;Reumann-Witkam Algorithm;remove_small;Removes lines shorter than threshold and areas of area less than threshold;boyle;Boyle's Forward-Looking Algorithm;sliding_averaging;McMaster's Sliding Averaging Algorithm;distance_weighting;McMaster's Distance-Weighting Algorithm;chaiken;Chaiken's Algorithm;hermite;Interpolation by Cubic Hermite Splines;snakes;Snakes method for line smoothing;network;Network generalization;displacement;Displacement of lines close to each other;"
+msgstr "douglas;Douglas-Peucker アルゴリズム;douglas_reduction;縮小パラメーターをもつDouglas-Peucker アルゴリズム;lang;Lang Simplification アルゴリズム;縮小;Vertex Reduction アルゴリズムは互いに近いポイントを削除します;reumann;Reumann-Witkam アルゴリズム;remove_small;閾値と閾値より小さいエリアより短いラインを除去;boyle;Boyle's Forward-Looking アルゴリズム;sliding_averaging;McMaster's Sliding Averaging アルゴリズム;distance_weighting;McMaster's Distance-Weighting アルゴリズム;chaiken;Chaiken's アルゴリズム;hermite;Cubic Hermite Splinesによる補間;snakes;ラインスムージングのスネークメソッド;ネットワーク;ネットワーク汎化;置換;互いに近いラインの置換;"
+msgid "Number of vertices was reduced from %d to %d [%d%%]"
+msgstr "頂点の数は %d から %d [%d%%] に減少されました"
+msgid ""
+"Input raster map <%s> does not exist in group <%s>.\n"
+" Try:\n"
+msgstr ""
+"入力するラスターマップ <%s> はグループ <%s>にありません\n"
+" 再試行:\n"
+msgid "Band to select"
+msgstr "選択するバンド"
 #~ msgid "Input grid3 filename"
 #~ msgstr "3Dグリッドファイル名入力"
@@ -38090,7 +42626,7 @@
 #~ msgstr "テーブルに許可がありません\n"
 #~ msgid "Cannot add database link to vector, link for given field probably already exists."
-#~ msgstr "ベクターにデータベースへのリンクを付加できません。該当項目へのリンクは既に存在している可能性があります。"
+#~ msgstr "ベクトルにデータベースへのリンクを付加できません。該当項目へのリンクは既に存在している可能性があります。"
 #~ msgid "Cannot open driver"
 #~ msgstr "を開けません"
@@ -38216,7 +42752,7 @@
 #~ msgstr "新規レコードがインサートできません: %s"
 #~ msgid "vector, network, centrality measures"
-#~ msgstr "centrality measures を計算しています..."
+#~ msgstr "ベクトル、ネットワーク、中心性を計算しています..."
 #~ msgid "Print all map connection parameters and exit in shell script style"
 #~ msgstr "全てのマップ接続パラメーターをシェルスクリプト形式に出力して終了"
@@ -39196,7 +43732,7 @@
 #~ msgstr "グループ[%s]のカメラファイルにある不正なフォーマット"
 #~ msgid "Calculating camera angle to local surface..."
+#~ msgstr "ローカルの地表に対するカメラアングルを計算しています..."
 #~ msgid "Could not open elevation raster"
 #~ msgstr "標高マップレイヤーが開けません"
@@ -39480,9 +44016,8 @@
 #~ msgid "'%s' being saved\n"
 #~ msgstr "'%s' が保存されています\n"
-#, fuzzy
 #~ msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %f gets converted to %d by selected GDAL datatype."
-#~ msgstr "エクスポートされたラスターにおけるメタデータのデータなし値と実際のデータなし値の間の不一致: 指定のデータなし値%fは選択されたGDALデータタイプによって%dへと変換されます"
+#~ msgstr "エクスポートされたラスターにおけるメタデータのデータなし値と実際のデータなし値の間の不一致: 指定のデータなし値 %fは選択されたGDALデータタイプによって %d へと変換されます"
 #~ msgid "Input map"
 #~ msgstr "入力するファイル"
@@ -39529,11 +44064,12 @@
 #~ msgid "Bad format in camera file for group <%s>"
-#, fuzzy
 #~ msgid ""
 #~ "Reference Point file for group [%s] in [%s] \n"
 #~ " \n"
-#~ msgstr "グループのコントロールポイントファイル <%s@%s> - "
+#~ msgstr ""
+#~ "グループ [%s]([%s]中)の参照点ファイル \n"
+#~ " \n"
 #~ msgid "Please select a target for group"
 #~ msgstr "グループのターゲットを選択してください"
@@ -39541,11 +44077,12 @@
 #~ msgid "Orthorectification cancelled"
 #~ msgstr "オルソ補正はキャンセルされました"
-#, fuzzy
 #~ msgid ""
 #~ "\n"
 #~ "Rectify all images in the group? "
-#~ msgstr "グループの全ラスターマップを修正する"
+#~ msgstr ""
+#~ "\n"
+#~ "グループの全ラスターマップを修正しますか?"
 #~ msgid ""
 #~ "\n"
@@ -39802,4544 +44339,45 @@
 #~ msgid "Interpolates point data to a G3D grid volume using regularized spline with tension (RST) algorithm."
 #~ msgstr "テンション (RST) アルゴリズムの正規化スプライン曲線を使って,ポイントデータを3Dグリッドボリュームへ挿入"
-#, fuzzy
-#~ msgid "Watershed basin analysis program"
-#~ msgstr "分水域の解析を行います "
-#, fuzzy
-#~ msgid "Name of input raster map with real depressions"
-#~ msgstr "再投影するラスターマップ名"
-#, fuzzy
-#~ msgid "Name of input raster map blocking overland surface flow"
-#~ msgstr "入力:曲面流でブロック化した地形を示すファイル "
-#, fuzzy
-#~ msgid "Name for output raster map useful for visual display of results (DEPRECATED)"
-#~ msgstr "出力:結果を可視化したファイル"
-#, fuzzy
-#~ msgid "Direction raster found <%s>"
-#~ msgstr "入力するファイル"
-#, fuzzy
-#~ msgid "Name for output direction map for depressionless elevation raster map"
-#~ msgstr "(o)   凹みのない標高マップの方向マップ"
-#, fuzzy
-#~ msgid "raster, export, animation"
-#~ msgstr "ラスター、標高"
-#, fuzzy
-#~ msgid "(requires r.out.ppm with stdout option)"
-#~ msgstr ""
-#~ "オン・ザ・フライで変換、省ディスクスペース\n"
-#~ "\t(r.out.ppm の stdout オプションが必要)  "
-#, fuzzy
-#~ msgid "Name for output elevation raster map after filling"
-#~ msgstr "充填後にラスターマップを出力"
-#, fuzzy
-#~ msgid "Name for output direction raster map"
-#~ msgstr "出力する傾斜方位ラスターマップ名"
-#, fuzzy
-#~ msgid "Reading input data..."
-#~ msgstr "読込中 ... "
-#, fuzzy
-#~ msgid "Writing output data..."
-#~ msgstr "出力中..."
-#, fuzzy
-#~ msgid "raster, reclassification"
-#, fuzzy
-#~ msgid "Name of input raster map with seed (at least 1 cell > 0)"
-#~ msgstr "シード付きラスターマップ名 (少なくとも 1セル>0)"
-#, fuzzy
-#~ msgid "Constructs flow lines."
-#~ msgstr "等値線のコスト "
-#, fuzzy
-#~ msgid "Name for flowpath length raster map"
-#~ msgstr "出力フローパス長さラスターマップ"
-#, fuzzy
-#~ msgid "imagery, landsat, acca"
-#~ msgstr "画像, 分類, MLC"
-#, fuzzy
-#~ msgid "Cannot write to raster map <%s>"
-#~ msgstr "出力するファイル"
-#, fuzzy
-#~ msgid "Creates, edits, and lists groups and subgroups of imagery data."
-#~ msgstr "グループと画像ファイルサブグループの作成、編集、入力"
-#, fuzzy
-#~ msgid "Extract quality control parameters from Modis QC layers"
-#~ msgstr "DEM から地形パラメーターを抽出します"
-#, fuzzy
-#~ msgid "Name of the surface reflectance QC layer [bit array]"
-#, fuzzy
-#~ msgid "Computing means and standard deviations..."
-#~ msgstr "バンドの演算手段 %d..."
-#, fuzzy
-#~ msgid "Computing means..."
-#~ msgstr "方程式を計算中..."
-#, fuzzy
-#~ msgid "Other"
-#~ msgstr "ディザ"
-#, fuzzy
-#~ msgid "Offset in map units."
-#~ msgstr "マップユニットのバッファー距離"
-#, fuzzy
-#~ msgid "Cannot describe table"
-#~ msgstr "表をコピーできません\n"
-#, fuzzy
-#~ msgid "DEPRECATED Buffer distance in map units"
-#, fuzzy
-#~ msgid "Line buffers... "
-#~ msgstr "ラインバッファー、、、"
-#, fuzzy
-#~ msgid "Zero area size, please clean input vector first."
-#~ msgstr "指定したベクトルラインに平行な線を作成"
-#, fuzzy
-#~ msgid "Could not get outside buffer for line id %d"
-#~ msgstr "南の緩衝地帯をよみこめませんでした. 中断しています"
-#, fuzzy
-#~ msgid "Area buffers... "
-#~ msgstr "エリアバッファー、、、"
-#, fuzzy
-#~ msgid "Selecting areas..."
-#~ msgstr "フィーチャーを選択中、、、"
-#~ msgid "Converts to one of the supported OGR vector formats."
-#~ msgstr "サポートするOGRベクトルフォーマットのひとつに変換"
-#, fuzzy
-#~ msgid "Cannot allocate %u bytes of memory"
-#, fuzzy
-#~ msgid "Skip the join column in other table"
-#~ msgstr "他のテーブルに列を結合"
-#, fuzzy
-#~ msgid "Copy all the columns from other table to map"
-#, fuzzy
-#~ msgid "Name of input raster map in which to fill nulls"
-#~ msgstr "nullで埋められたラスターマップ"
-#, fuzzy
-#~ msgid "Name for output raster map with nulls filled by interpolation"
-#~ msgstr "周囲の値からの補間によって埋められたnullで出力するラスターマップ"
-#, fuzzy
-#~ msgid "Mosaics up to four images, extending the color table."
-#~ msgstr "モザイクは最大4つの画像まで、 カラーマップを拡張する; マップ *.mosaicを作成する  "
-#, fuzzy
-#~ msgid "creates map *.mosaic"
-#~ msgstr "第3モザイクマップ"
-#, fuzzy
-#~ msgid "1st map for mosaic (top of image stack)"
-#~ msgstr "第1モザイクマップ (画像スタックの上部).  "
-#, fuzzy
-#~ msgid "2nd map for mosaic"
-#~ msgstr "第2モザイクマップ"
-#, fuzzy
-#~ msgid "3rd map for mosaic"
-#, fuzzy
-#~ msgid "4th map for mosaic"
-#~ msgstr "第4モザイクマップ"
-#~ msgid "Could not close G3D map"
-#~ msgstr "3Dグリッドマップを閉じれません"
-#~ msgid "Use g3d mask (if exists) with input map"
-#~ msgstr "入力マップに3Dグリッドマスクを使う"
-#~ msgid "Could not write raster row"
-#~ msgstr "ラスター行が書き込めません"
-#~ msgid "Could not close G3D map <%s>"
-#~ msgstr "3Dグリッドマップ <%s> が閉じれません"
-#~ msgid "Converts 3D raster maps (G3D) into the VTK-Ascii format"
-#~ msgstr "3Dラスターマップ(3Dグリッド)をVTK-Ascii フォーマットに変換する"
-#~ msgid "unable to close input 3d raster map"
-#~ msgstr "入力3Dラスターマップを閉じれません"
-#~ msgid "Use g3d mask (if exists) with input maps"
-#~ msgstr "3Dグリッドマスク(存在する時に限る)を入力マップに使用します"
-#~ msgid "Could not get top raster row \n"
-#~ msgstr "ラスターの先頭行を取得できない\n"
-#~ msgid "Could not get bottom raster row \n"
-#~ msgstr "ラスターの最終行を取得できない\n"
-#~ msgid "Use G3D mask (if exists)"
-#~ msgstr "(可能であれば)3Dグリッドマスクの使用"
-#~ msgid "Name of an existing raster map layer"
-#~ msgstr "既存のラスターマップ レイヤー名"
-#, fuzzy
-#~ msgid "writing edges..."
-#, fuzzy
-#~ msgid "input,cell,raster"
-#, fuzzy
-#~ msgid "output,cell,raster"
-#~ msgid "raster3d, statistics"
-#~ msgstr "ラスター3D、統計"
-#, fuzzy
-#~ msgid "raster, png"
-#~ msgstr "ラスター、タイル表示"
-#~ msgid "Construction of slope curves (flowlines), flowpath lengths, and flowline densities (upslope areas) from a raster digital elevation model (DEM)"
-#~ msgstr "傾斜カーブの建築(フローライン)、フローパスの長さ、そしてラスターデジタル標高モデル(DEM)からのフローライン密度(上り坂エリア) "
-#~ msgid "vector, networking"
-#~ msgstr "ベクトル, ネットワーク"
-#~ msgid "raster, vector, visualization"
-#~ msgstr "ラスター,ベクトル,可視化"
-#~ msgid "Convert all old GRASS < Ver5.7 vector maps in current mapset to current format"
-#~ msgstr "現在のマップセット内のすべての前のGRASS < Ver5.7 ベクトルマップ を現在のフォーマットに変換する"
-#~ msgid "Import Mapgen or Matlab vector maps into GRASS."
-#~ msgstr "MapgenあるいはMatlabベクトルマップをGRASSにインポート"
-#~ msgid "Ascii file containing spectral signatures"
-#~ msgstr "スペクトルシグネチャを含むASCIIファイル"
-#, fuzzy
-#~ msgid "Unhandled vector feature type <%s>"
-#~ msgstr "NULL値に代入する値"
-#, fuzzy
-#~ msgid "No areas found, skipping type=area"
-#~ msgstr "現在の設定を表示"
-#, fuzzy
-#~ msgid "No points found, skipping%s%s"
-#, fuzzy
-#~ msgid "No lines found, skipping%s%s"
-#~ msgid "Raster value"
-#~ msgstr "ラスター値"
-#~ msgid "Slower but accurate (applies to FP maps only)"
-#~ msgstr "遅いですが正確です (FPマップのみ適用)  "
-#~ msgid "Rescaling range for output maps (for no rescaling use 0,0)"
-#~ msgstr "出力マップの範囲を再計測 (0,0を使う再計測はありません)"
-#, fuzzy
-#~ msgid "GDAL datatype: %s, range: %f - %f"
-#~ msgstr "���."
-#, fuzzy
-#~ msgid "The '-q' flag is superseded and will be removed "
-#~ msgstr "���."
-#, fuzzy
-#~ msgid "Unable to create table <%s_edge_Interpolation>"
-#, fuzzy
-#~ msgid "Rescale output raster map [0,255]"
-#, fuzzy
-#~ msgid "Output drain raster map"
-#, fuzzy
-#~ msgid "Can't find %d,%d:%f"
-#, fuzzy
-#~ msgid "Reading %s"
-#~ msgstr "���%s ..."
-#, fuzzy
-#~ msgid "Writing %s"
-#, fuzzy
-#~ msgid "Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in a local text file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
-#~ msgstr "緯度 (dd:mm:ss{N|S})."
-#, fuzzy
-#~ msgid "It was impossible to open table"
-#, fuzzy
-#~ msgid "Spline type of interpolation"
-#~ msgstr "アイコンの種類"
-#, fuzzy
-#~ msgid "Script kill option"
-#~ msgstr "スクリプトの終了"
-#, fuzzy
-#~ msgid "Start in Demo mode"
-#~ msgstr "デモモード"
-#, fuzzy
-#~ msgid "Output more comments (default=quiet)"
-#~ msgstr "タイトル"
-#, fuzzy
-#~ msgid "Vector map to display thematically"
-#~ msgstr "対象マップ"
-#, fuzzy
-#~ msgid "Vector map type"
-#, fuzzy
-#~ msgid "Layer to use for thematic display"
-#~ msgstr "タイトル"
-#, fuzzy
-#~ msgid "Mapset(s) to list (default: current mapset search path)"
-#~ msgstr "対象マップセット(デフォルト=現在のマップセット)"
-#, fuzzy
-#~ msgid "Output separator (default: newline)"
-#~ msgstr "区切り(デフォルト:タブ)"
-#, fuzzy
-#~ msgid "Raster to remove"
-#, fuzzy
-#~ msgid "3d raster to remove"
-#, fuzzy
-#~ msgid "Vector to remove"
-#~ msgstr "対象ファイル<%s>"
-#, fuzzy
-#~ msgid "Region to remove"
-#, fuzzy
-#~ msgid "Label to remove"
-#, fuzzy
-#~ msgid "3dview to remove"
-#, fuzzy
-#~ msgid "Group to remove"
-#, fuzzy
-#~ msgid "raster input maps"
-#~ msgstr "目的ファイルを含むマップセット"
-#, fuzzy
-#~ msgid "Output field seperator"
-#~ msgstr "区切り"
-#, fuzzy
-#~ msgid "ERROR: Problem opening output file."
-#, fuzzy
-#~ msgid "Density of output walkers"
-#, fuzzy
-#~ msgid "File [%s] not found"
-#, fuzzy
-#~ msgid "Unable to open file [%s]"
-#, fuzzy
-#~ msgid "Reading sites map (%s) ..."
-#, fuzzy
-#~ msgid "Name of the output walkers vector points map"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "You are not outputting any raster or vector points maps"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "%s=%s - illegal value"
-#, fuzzy
-#~ msgid "Unable to read current region parameters"
-#, fuzzy
-#~ msgid "Cannot open cover raster map <%s>"
-#~ msgstr ""
-#~ "#-#-#-#-#  grassmods_ja.po (grassmods_ja)  #-#-#-#-#\n"
-#~ "出力するファイル"
-#, fuzzy
-#~ msgid "No map specified"
-#~ msgstr "傾斜方位を示すファイル(入力)"
-#, fuzzy
-#~ msgid "%s - unable to remove color table"
-#~ msgstr "シグネチャファイル"
-#, fuzzy
-#~ msgid "%s - color table not found"
-#, fuzzy
-#~ msgid "Unable to properly read input raster map"
-#, fuzzy
-#~ msgid "Unable to properly write output raster map"
-#, fuzzy
-#~ msgid "Name of raster map layer to be used for <%s>"
-#~ msgstr "<%s>に対応させるラスターマップ"
-#, fuzzy
-#~ msgid "Run verbosly"
-#~ msgstr "説明つき表示"
-#, fuzzy
-#~ msgid "%d points converted to centroids"
-#~ msgstr "タイトル"
-#, fuzzy
-#~ msgid "%d centroids converted to points"
-#~ msgstr "出力ファイルの上書き"
-#, fuzzy
-#~ msgid "%d lines converted to boundaries"
-#, fuzzy
-#~ msgid "CrossCorrelation: %d points read in region.\n"
-#, fuzzy
-#~ msgid "CrossCorrelation: Cannot open database %s by driver %s"
-#, fuzzy
-#~ msgid "CrossCorrelation: Cannot select data from table"
-#~ msgstr "統一する属性の値"
-#, fuzzy
-#~ msgid "vector, attribute table"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Cannot fetch data"
-#, fuzzy
-#~ msgid "Do not print polyline info"
-#, fuzzy
-#~ msgid "Feature id(s)"
-#~ msgstr "ファイルの種類"
-#, fuzzy
-#~ msgid "Input vector was not found."
-#~ msgstr "���."
-#, fuzzy
-#~ msgid "Node layer (points)"
-#~ msgstr "色相ファイル"
-#, fuzzy
-#~ msgid "Reading data from the map..."
-#~ msgstr "カバーマップ"
-#, fuzzy
-#~ msgid "Query layer (used by 'query' option)"
-#~ msgstr "ラベルの属性"
-#, fuzzy
-#~ msgid "%d categories read from map"
-#~ msgstr "タイトル"
-#, fuzzy
-#~ msgid "Processing ainput lines ..."
-#~ msgstr "線に沿って点を補間"
-#, fuzzy
-#~ msgid "Writing attributes ..."
-#, fuzzy
-#~ msgid "Current region does not include the entire input vector map <%s>"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Output inverse raster map after IFFT"
-#, fuzzy
-#~ msgid "%s: %s - Unable to find the real-image map."
-#, fuzzy
-#~ msgid "%s: %s - Unable to find the imaginary-image."
-#, fuzzy
-#~ msgid "Reading the raster maps..."
-#~ msgstr "カバーマップ"
-#, fuzzy
-#~ msgid "Rotating data arrays..."
-#, fuzzy
-#~ msgid "Unable to open output file."
-#, fuzzy
-#~ msgid "Hue map name"
-#~ msgstr "対象マップ"
-#, fuzzy
-#~ msgid "Intensity map name"
-#~ msgstr "対象マップ"
-#, fuzzy
-#~ msgid "Saturation map name"
-#~ msgstr "対象マップ"
-#, fuzzy
-#~ msgid "Output map representing the red"
-#~ msgstr "出力:排出方向を示すファイル"
-#, fuzzy
-#~ msgid "Output map representing the green"
-#, fuzzy
-#~ msgid "Output map representing the blue"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Cannot read row from raster map"
-#~ msgstr "対象マップ1"
-#, fuzzy
-#~ msgid "Cannot write row to raster map"
-#, fuzzy
-#~ msgid "Red input raster map"
-#, fuzzy
-#~ msgid "Green input raster map"
-#, fuzzy
-#~ msgid "Blue input raster map"
-#, fuzzy
-#~ msgid "Output intensity raster map"
-#~ msgstr "流線の密度を示すファイル(出力)"
-#, fuzzy
-#~ msgid "Name of imagery signaturefile"
-#, fuzzy
-#~ msgid "Subgroup [%s] not found."
-#, fuzzy
-#~ msgid "Signature file [%s] is missing or not readable."
-#~ msgstr "������."
-#, fuzzy
-#~ msgid "Cannot write color table of raster map <%s>"
-#, fuzzy
-#~ msgid "Imagery group"
-#~ msgstr "画像グループ"
-#, fuzzy
-#~ msgid "Subgroup containing image files"
-#~ msgstr "サブ画像グループ"
-#, fuzzy
-#~ msgid "Resultant signature file"
-#, fuzzy
-#~ msgid "Input raster map being fft"
-#, fuzzy
-#~ msgid "Illegal file name for real part: %s"
-#~ msgstr "虚部を含む入力ファイル"
-#, fuzzy
-#~ msgid "Illegal file name for imaginary part: %s"
-#, fuzzy
-#~ msgid "Reading the raster map..."
-#~ msgstr "カバーマップ"
-#, fuzzy
-#~ msgid "subgroup <%s> not found"
-#, fuzzy
-#~ msgid "** Can't open seed singature file <%s> **"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "** Can't read signature file <%s> **"
-#, fuzzy
-#~ msgid "Group of imagery files to be clustered"
-#~ msgstr "画像グループ"
-#, fuzzy
-#~ msgid "Subgroup name in the above group"
-#, fuzzy
-#~ msgid "Reading image ... "
-#, fuzzy
-#~ msgid "Unable to read head of %s"
-#, fuzzy
-#~ msgid "group=[%s] - not found."
-#, fuzzy
-#~ msgid "subgroup=[%s] (of group [%s]) - not found."
-#, fuzzy
-#~ msgid "Can't read signature file [%s]."
-#, fuzzy
-#~ msgid "Unable to create reject layer [%s]."
-#, fuzzy
-#~ msgid "Imagery group to be classified"
-#~ msgstr "画像グループ"
-#, fuzzy
-#~ msgid "Subgroup containing image files to be classified"
-#, fuzzy
-#~ msgid "Signatures to use for classification"
-#, fuzzy
-#~ msgid "Raster map to hold classification results"
-#~ msgstr "分類結果を出力するファイル"
-#, fuzzy
-#~ msgid "Cannot select attributes: %s"
-#, fuzzy
-#~ msgid "Background color, either a standard GRASS color, R:G:B triplet, or \"none\""
-#~ msgstr "線の色"
-#, fuzzy
-#~ msgid "Saving new map"
-#, fuzzy
-#~ msgid "Output raster map with lake"
-#, fuzzy
-#~ msgid "Terrain raster map <%s> not found!"
-#~ msgstr "対象マップ"
-#, fuzzy
-#~ msgid "Cannot open terrain raster map <%s@%s>!"
-#, fuzzy
-#~ msgid "Seed map <%s> not found!"
-#~ msgstr "対象マップ"
-#, fuzzy
-#~ msgid "Cannot open seed map <%s@%s>!"
-#, fuzzy
-#~ msgid "Failure to allocate memory for row pointers"
-#~ msgstr "マップのカテゴリー値について統計解析を行います"
-#, fuzzy
-#~ msgid "Loading maps: "
-#, fuzzy
-#~ msgid "Error reading terrain raster map. Probably broken file."
-#, fuzzy
-#~ msgid "Error reading seed raster map. Probably broken file."
-#, fuzzy
-#~ msgid "Cannot write lake raster map <%s@%s>!"
-#, fuzzy
-#~ msgid "Error writing color file for <%s@%s>!"
-#, fuzzy
-#~ msgid "Name of the vector points map with x,y locations"
-#, fuzzy
-#~ msgid "Number of time iterations (sec.)"
-#~ msgstr "補間に用いる近傍点"
-#, fuzzy
-#~ msgid "Multiscale simulation"
-#~ msgstr "ロケーション"
-#, fuzzy
-#~ msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
-#, fuzzy
-#~ msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
-#, fuzzy
-#~ msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
-#, fuzzy
-#~ msgid "Calculates <simple> index on a raster map"
-#~ msgstr "サイトマップにラスター形式のマスクをかけ新しいマップを作成します"
-#, fuzzy
-#~ msgid "Raster input maps(s)"
-#, fuzzy
-#~ msgid "Output file name"
-#, fuzzy
-#~ msgid "%s: can't read fp range for [%s]"
-#, fuzzy
 #~ msgid ""
-#~ "Raster map [%s] already exists.\n"
-#~ "Please try another."
-#~ msgstr "対象マップ"
-#, fuzzy
-#~ msgid "Error reading '%s' map"
-#, fuzzy
-#~ msgid "Threshold distance"
-#~ msgstr "閾値"
-#, fuzzy
-#~ msgid "Cannot execute: %s"
-#, fuzzy
-#~ msgid "Cannot link table: %s"
-#, fuzzy
-#~ msgid "DXF input file"
-#, fuzzy
-#~ msgid "Cannot open dxf file <%s>"
-#, fuzzy
-#~ msgid "Cannot open new vector map <%s>"
-#, fuzzy
-#~ msgid "Conversion of <%s> to vector map:"
-#~ msgstr "���."
-#, fuzzy
-#~ msgid "Create 3D file"
-#, fuzzy
-#~ msgid "imagery subgroup"
-#, fuzzy
-#~ msgid ""
+#~ "USAGE for basin delineation:\n"
+#~ "%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
 #~ "\n"
-#~ "<%s> -- illegal result signature file name"
-#, fuzzy
-#~ msgid "Raster file(s) for Elevation"
-#~ msgstr "色に用いるラスターマップ"
-#, fuzzy
-#~ msgid "Raster file(s) for Color"
-#, fuzzy
-#~ msgid "Raster map to zoom into"
-#~ msgstr "ズームするラスターマップ"
-#, fuzzy
-#~ msgid "Save the current region to region definition file"
-#~ msgstr "  region (地域定義ファイル)\n"
-#, fuzzy
-#~ msgid "Could not open input file <%s>."
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Adding files to subgroup [%s]"
-#, fuzzy
-#~ msgid "Writing subgroup REF"
-#, fuzzy
-#~ msgid "Multiplier"
-#~ msgstr "高さの強調"
-#, fuzzy
-#~ msgid "Name of the resultant map"
-#, fuzzy
-#~ msgid "Raster map not found."
-#~ msgstr "対象マップ"
-#, fuzzy
-#~ msgid "%s: can't read range for [%s]"
-#, fuzzy
-#~ msgid "Raster file [%s] not found"
-#, fuzzy
-#~ msgid "It was not possible writing in <%s>."
-#, fuzzy
-#~ msgid "Cannot create table: '%s'"
-#, fuzzy
-#~ msgid "Unable to get category list <%s>, editing terminated"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Unable to delete layer/category [%d/%d] line %d"
-#, fuzzy
-#~ msgid "Unable to write line %d"
-#, fuzzy
-#~ msgid "Unable to delete line %d"
-#, fuzzy
-#~ msgid "Unknown query tool '%s'"
-#, fuzzy
-#~ msgid "No layer database connection"
-#~ msgstr "ロケーション"
-#, fuzzy
-#~ msgid "%d categories loaded from the database"
-#~ msgstr "タイトル"
-#, fuzzy
-#~ msgid "Cannot open OGR data source '%s'"
-#, fuzzy
-#~ msgid "Cannot create layer"
-#, fuzzy
-#~ msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
-#~ msgstr "対象マップ"
-#, fuzzy
-#~ msgid "Load values from vector to database. For uploaded/printed category values '-1' is used for 'no category' and 'null'/'-' if category cannot be found or multiple categories were found."
-#~ msgstr "���."
-#, fuzzy
-#~ msgid "Column(s)"
-#~ msgstr "更新するカラム1"
-#, fuzzy
-#~ msgid "Cannot read map header for <%s>"
-#, fuzzy
-#~ msgid "Cannot read category file for <%s>"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Print;Shell Script"
-#~ msgstr "総セル数の出力"
-#, fuzzy
-#~ msgid "Creating support files for [%s]."
-#, fuzzy
-#~ msgid "%s: <%s> raster map not found"
-#~ msgstr ""
-#~ "対象マップ\n"
-#~ "入力するファイル"
-#, fuzzy
-#~ msgid "%s: <%s> raster map exists already"
-#~ msgstr "対象マップ"
-#, fuzzy
-#~ msgid "Cannot read category file of raster map <%s>"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "%s - map not found"
-#, fuzzy
-#~ msgid "%s not found"
-#, fuzzy
-#~ msgid "Vector map %s - not found"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Raster map containing elevation data"
-#, fuzzy
-#~ msgid "Raster map name for storing results"
-#, fuzzy
-#~ msgid "Height of the viewing location"
-#~ msgstr "視点の高さ"
-#, fuzzy
-#~ msgid "%s: <%s> cellfile not found"
-#, fuzzy
-#~ msgid "Cell file [%s] not found\n"
-#, fuzzy
-#~ msgid "rgb cell map [%s] not found\n"
-#, fuzzy
-#~ msgid "vector cell map [%s] not found\n"
-#, fuzzy
-#~ msgid "%s - %s not found"
-#, fuzzy
-#~ msgid "Unable to read category file for raster map <%s>"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Creating support files"
-#, fuzzy
-#~ msgid "%s file [%s] not found!"
-#, fuzzy
-#~ msgid "%s: %s - map not found"
-#, fuzzy
-#~ msgid "%s: unable to open %s"
-#, fuzzy
-#~ msgid "%s - not found"
-#, fuzzy
-#~ msgid "Cannot read %s"
-#, fuzzy
-#~ msgid "Reading %s ... "
-#, fuzzy
-#~ msgid "[%s] map not found."
-#, fuzzy
-#~ msgid "[%s] map not found"
-#, fuzzy
-#~ msgid "min computed aspect %.4f  max computed aspect %.4f"
-#~ msgstr "����� �����"
-#, fuzzy
-#~ msgid "min computed slope %.4f  max computed slope %.4f"
-#~ msgstr "��� ���"
-#, fuzzy
-#~ msgid "Cannot describe table <%s>"
-#, fuzzy
-#~ msgid "Cannot insert values: %s"
-#, fuzzy
-#~ msgid "%s given an illegal number of points [%d]"
-#~ msgstr "初期のクラスター数"
-#, fuzzy
-#~ msgid "Unable to open database %s by driver %s"
-#, fuzzy
-#~ msgid "Could not find input %s"
-#, fuzzy
-#~ msgid "Could not find input map <%s>"
-#, fuzzy
-#~ msgid "Can't read header for <%s> in <%s>"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Can't read header for 3D raster <%s> in <%s>"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Can't write region <%s>"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "No graphics device selected."
-#~ msgstr "グラフィックデバイスが選択されていない"
-#, fuzzy
-#~ msgid "Unable to read raster row."
-#, fuzzy
-#~ msgid "%s map not found"
-#, fuzzy
-#~ msgid "cannot read head of %s"
-#, fuzzy
-#~ msgid "Illegal file name: %s"
-#, fuzzy
-#~ msgid "Cannot get layer info for vector map"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Cannot open raster map <%s> in <%s>"
-#~ msgstr ""
-#~ "出力するファイル"
-#, fuzzy
-#~ msgid "cover values extracted from the category labels of the cover map"
-#~ msgstr "カテゴリー値の代わりにカテゴリーラベルを使用"
-#, fuzzy
-#~ msgid "%s: %s - raster map not found"
-#~ msgstr "対象マップ"
-#, fuzzy
-#~ msgid "%s: %s - illegal name"
-#, fuzzy
-#~ msgid "%s: ERROR reading category file for %s"
-#, fuzzy
-#~ msgid "%s: %s - not found"
-#, fuzzy
-#~ msgid "%s: %s - illegal units"
-#, fuzzy
-#~ msgid "%s: %s - can't open"
-#, fuzzy
-#~ msgid "Reading input map (%s)    ... "
-#, fuzzy
-#~ msgid "%s - ERROR reading %s"
-#, fuzzy
-#~ msgid "%s: %s - can't create raster map"
-#, fuzzy
-#~ msgid "Writing output map (%s)   ... "
-#, fuzzy
-#~ msgid "%s - ERROR re-reading %s"
-#, fuzzy
-#~ msgid "Reading raster map... "
-#, fuzzy
-#~ msgid "Writing raster map... "
-#, fuzzy
-#~ msgid "Category list: e.g. 1,3-8,13"
-#~ msgstr "カテゴリーラベルのリスト(例 1,3-8,13)"
-#, fuzzy
-#~ msgid "Output separator character (default: tab)"
-#, fuzzy
-#~ msgid "Cannot read category file of raster map <%s> in <%s>"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Cannot create raster map %s"
-#, fuzzy
-#~ msgid "Cannot create vector map %s"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Cannot create raster map '%s'"
-#, fuzzy
-#~ msgid "Number of raster rows to hold in memory"
-#~ msgstr "メモリに残す行"
-#, fuzzy
-#~ msgid "Print raster map title only"
-#, fuzzy
-#~ msgid "unknown type: %d"
-#, fuzzy
-#~ msgid "Cannot open raster map [%s]"
-#~ msgstr ""
-#~ "出力するファイル"
-#, fuzzy
-#~ msgid "Cannot get raster band."
-#, fuzzy
-#~ msgid "Cannot read GRASS raster."
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Cannot get [%s] driver"
-#, fuzzy
-#~ msgid "Couldn't set geo transform."
-#, fuzzy
-#~ msgid "Couldn't set projection."
-#, fuzzy
-#~ msgid "Cannot export [%s] raster map."
-#, fuzzy
-#~ msgid "Cannot create [%s] raster map using [%s] driver."
-#, fuzzy
-#~ msgid "Cannot read header of raster map <%s>"
-#, fuzzy
-#~ msgid "Cannot open TIFF file <%s>"
-#, fuzzy
-#~ msgid "Reading raster map"
-#, fuzzy
-#~ msgid "Cannot open output map."
-#, fuzzy
-#~ msgid "Illegal file name. Please try another."
-#, fuzzy
-#~ msgid "%s: can't open %s"
-#, fuzzy
-#~ msgid "Reading raster map <%s> ..."
-#, fuzzy
-#~ msgid "memory allocation failure"
-#~ msgstr "ロケーション"
-#, fuzzy
-#~ msgid "Cannot open vector map <%s> at the topological level"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Rebuilding topology ..."
-#, fuzzy
-#~ msgid "Removing duplicates ..."
-#, fuzzy
-#~ msgid "Attaching islands ..."
-#, fuzzy
-#~ msgid "Attaching centroids ..."
-#, fuzzy
-#~ msgid "Vector map <%s> not found in current mapset"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "The number of lines in the input vector map is [%d]"
-#~ msgstr "ピクセルの最小値"
-#, fuzzy
-#~ msgid "Cannot get layer info"
-#, fuzzy
-#~ msgid "cell file [%s] not found"
-#, fuzzy
-#~ msgid "can't open raster map [%s]"
-#, fuzzy
-#~ msgid "Cannot rewrite line %d"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Editing tool"
-#, fuzzy
-#~ msgid "Cannot copy line %d, editing terminated"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "No layer database connection."
-#~ msgstr "ロケーション"
-#, fuzzy
-#~ msgid "Cannot snap lines %d,%d"
-#, fuzzy
-#~ msgid "%d lines modified"
-#~ msgstr "タイトル"
-#, fuzzy
-#~ msgid "Could not open ASCII file <%s>"
-#, fuzzy
-#~ msgid "Print vector map region only"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Cannot open vector map <%s> at topo level [%d]"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Cannot get layer info for vector map <%s>"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Cannot select attribute."
-#, fuzzy
-#~ msgid "Number of ROWS and COLUMNS in grid"
-#~ msgstr "格子数"
-#, fuzzy
-#~ msgid "Creating vector grid..."
-#, fuzzy
-#~ msgid "Could not find vector map <%s> in current mapset"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Could not find input map <%s>."
-#, fuzzy
-#~ msgid "[%d] features written"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Output map where segments will be written"
-#~ msgstr "���."
-#, fuzzy
-#~ msgid "<%s> cellfile not found"
-#, fuzzy
-#~ msgid "Not able to open vector map <%s>"
-#, fuzzy
-#~ msgid "No table."
-#~ msgstr "テーブル"
-#, fuzzy
-#~ msgid "Can't read raster"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "driver name"
-#~ msgstr "ドライバ"
-#, fuzzy
-#~ msgid "database name"
-#~ msgstr "データベース"
-#, fuzzy
-#~ msgid "Driver name"
-#~ msgstr "ドライバ"
-#, fuzzy
-#~ msgid "output field separator"
-#~ msgstr "区切り"
-#, fuzzy
-#~ msgid "output vertical record separator"
-#~ msgstr "上下方向の区切り"
-#, fuzzy
-#~ msgid "null value indicator"
-#~ msgstr "NULL値の識別子"
-#, fuzzy
-#~ msgid "do not include column names in output"
-#~ msgstr "ルートに沿ってセル値をコピー"
-#, fuzzy
-#~ msgid "vertical output (instead of horizontal)"
-#~ msgstr "8bitで出力"
-#, fuzzy
-#~ msgid "Cannot find mapset for %s"
-#, fuzzy
-#~ msgid "Label file [%s] not available"
-#, fuzzy
-#~ msgid "Can't open label file [%s]"
-#, fuzzy
-#~ msgid "unable to open [%s] in [%s]"
-#, fuzzy
-#~ msgid "warning: unable to open [%s] in [%s]"
-#, fuzzy
-#~ msgid "Unable to open raster map [%s] in [%s]"
-#, fuzzy
-#~ msgid "Unable to find input cell map '%s'"
-#, fuzzy
-#~ msgid "Unable to open cellfile for <%s>"
-#, fuzzy
-#~ msgid "Unable to create raster map [%s]"
-#, fuzzy
-#~ msgid "Unable to create output <%s>"
-#, fuzzy
-#~ msgid "Input file [%s] not found."
-#~ msgstr "���."
-#, fuzzy
-#~ msgid "Unable to open output file <%s>."
-#, fuzzy
-#~ msgid "Multiplier for ascii data"
-#~ msgstr "高さの強調"
-#, fuzzy
-#~ msgid "Could not open temporary file: [%s]"
-#, fuzzy
-#~ msgid "Could not open input file [%s]"
-#, fuzzy
-#~ msgid "unable to create raster"
-#, fuzzy
-#~ msgid "Unable to create output raster map <%s>"
-#, fuzzy
-#~ msgid "Name of the random surface to be produced"
-#, fuzzy
-#~ msgid "%s: Unable to find raster map <%s>"
-#, fuzzy
-#~ msgid "%s: Unable to open raster map <%s> in mapset <%s>"
-#, fuzzy
-#~ msgid "%s:  Unable to open output raster map <%s>"
-#, fuzzy
-#~ msgid "Vector <%s> could not be opened"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Table name"
-#~ msgstr "テーブル"
-#, fuzzy
-#~ msgid "x column name"
-#~ msgstr "キーカラム"
-#, fuzzy
-#~ msgid "z column name"
-#~ msgstr "キーカラム"
-#, fuzzy
-#~ msgid "Cannot drop table: %s"
-#, fuzzy
-#~ msgid "Cannot open labels <%s>"
-#, fuzzy
-#~ msgid "Cannot open file [%s]"
-#, fuzzy
-#~ msgid "SVG file <%s> cannot be opened"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Querying input '%s' ... "
-#, fuzzy
-#~ msgid "Copying %s input lines ... "
-#~ msgstr "���."
-#, fuzzy
-#~ msgid "Cannot create table <%s>"
-#, fuzzy
-#~ msgid "cannot insert row: %s"
-#, fuzzy
-#~ msgid "Cannot find line of cat %d"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Unalbe to open vector map <%s>"
-#, fuzzy
-#~ msgid "Transforms a vector map via a set of tie points."
-#~ msgstr "ベクトルマップの座標変換を行います"
-#, fuzzy
-#~ msgid "Raster map <%s>] not found"
-#~ msgstr "対象マップ"
-#, fuzzy
-#~ msgid "Cannot start driver <%s>."
-#, fuzzy
-#~ msgid "Not able to find cellfile [%s]"
-#, fuzzy
-#~ msgid "Raster map [%s] not found"
-#~ msgstr "対象マップ"
-#, fuzzy
-#~ msgid "Unable to open raster map [%s]"
-#, fuzzy
-#~ msgid "Vector file [%s] not available"
-#~ msgstr "対象マップ"
-#, fuzzy
-#~ msgid "<%s> illegal name"
-#, fuzzy
-#~ msgid "%s: %s - Unable to open the input raster map\n"
-#, fuzzy
-#~ msgid "%s: %s - illegal name for output raster map."
-#, fuzzy
-#~ msgid "Exports GRASS raster data into various formats (requires GDAL)."
-#~ msgstr "ラスターマップをバイナリーファイルとしてエクスポートします"
-#, fuzzy
-#~ msgid "Couldn't find raster map %s"
-#, fuzzy
-#~ msgid "%s: <%s> not found"
-#, fuzzy
-#~ msgid "%s: Cannot open <%s>"
-#, fuzzy
-#~ msgid "Cannot find %s"
-#, fuzzy
-#~ msgid "could not read range file"
-#, fuzzy
-#~ msgid "Unable to create raster map [%s]."
-#, fuzzy
-#~ msgid "Filtering [%s] in [%s]"
-#, fuzzy
-#~ msgid "Open raster map %s in %s = %d"
-#, fuzzy
-#~ msgid "Closing raster map"
-#~ msgstr "カバーマップ"
-#, fuzzy
-#~ msgid "Swap temp files"
-#, fuzzy
-#~ msgid "Writing [%s]"
-#, fuzzy
-#~ msgid "%s: illegal map name"
-#, fuzzy
-#~ msgid "%s: <%s> illegal file name"
-#, fuzzy
-#~ msgid "can't open raster map <%s> in mapset %s"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Converts a GRASS raster map to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION."
-#~ msgstr "ラスターマップをPPMファイルとしてエクスポートします"
-#, fuzzy
-#~ msgid "Mapset of input map"
-#, fuzzy
-#~ msgid "Checking location %s, mapset %s:"
-#, fuzzy
-#~ msgid "Error writing output map"
-#~ msgstr "解像度"
-#, fuzzy
-#~ msgid "[%s] is an illegal file name"
-#, fuzzy
-#~ msgid "Can't open temp file [%s]"
-#, fuzzy
-#~ msgid "Names of existing raster maps"
-#, fuzzy
-#~ msgid "Unable to open input map <%s> in mapset <%s>"
-#, fuzzy
-#~ msgid "%s - illegal name "
-#, fuzzy
-#~ msgid "Couldn't find raster map [%s]"
-#, fuzzy
-#~ msgid "%s - can't create raster map"
-#, fuzzy
-#~ msgid "Cell file [%s] not found"
-#, fuzzy
-#~ msgid "Requested 3d raster map not found <%s>"
-#~ msgstr "���."
-#, fuzzy
-#~ msgid "Could not open output map"
-#, fuzzy
-#~ msgid "unable to close output map"
-#, fuzzy
-#~ msgid "Could not close the 3d raster map"
-#, fuzzy
-#~ msgid "Cannot create output map [%s]"
-#, fuzzy
-#~ msgid "Cannot open vector points map <%s>"
-#~ msgstr "���."
-#, fuzzy
-#~ msgid "Cannot create vector map <%s>"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Vector file [%s] not available in search list"
-#~ msgstr "対象マップ"
-#, fuzzy
-#~ msgid "Cannot open table <%s>"
-#, fuzzy
-#~ msgid "The vector '%s' already exists."
-#~ msgstr "���."
-#, fuzzy
-#~ msgid "Could not find input map '%s'."
-#, fuzzy
-#~ msgid "Could not find network input map '%s'."
-#, fuzzy
-#~ msgid "error opening raster map [%s]."
-#, fuzzy
-#~ msgid "Patching file <%s@%s>"
-#, fuzzy
-#~ msgid "[%d] files patched"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Could not open vector map <%s>"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Illegal output name: '%s'"
-#, fuzzy
-#~ msgid "Can't create output map"
-#, fuzzy
-#~ msgid "%s: cellfile [%s] not found."
-#, fuzzy
-#~ msgid "Unable to open cellfile [%s]."
-#, fuzzy
-#~ msgid "Error reading wildcard."
-#, fuzzy
-#~ msgid "Sets the grid color, either a standard GRASS color or R:G:B triplet (separated by colons)"
-#~ msgstr "線の色"
-#, fuzzy
-#~ msgid "Sets the border color, either a standard GRASS color or R:G:B triplet"
-#~ msgstr "線の色"
-#, fuzzy
-#~ msgid "Unable to open the temporary file."
-#, fuzzy
-#~ msgid "Unable to open raster map [%s]."
-#, fuzzy
-#~ msgid "Unable to find raster [%s]."
-#, fuzzy
-#~ msgid "name for new raster map"
-#, fuzzy
-#~ msgid "Output GRASS image file"
-#, fuzzy
-#~ msgid "name for new vector map (omit for display to stdout)"
-#, fuzzy
-#~ msgid "Input vector map"
-#, fuzzy
-#~ msgid "%s: ERROR can't open tempfile"
-#, fuzzy
-#~ msgid "unable to find raster map [%s]"
-#, fuzzy
-#~ msgid "<%s> raster map not found"
-#~ msgstr "対象マップ"
-#, fuzzy
-#~ msgid "<%s> unable to open raster map"
-#, fuzzy
-#~ msgid "Cannot find vector map [%s]"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "%s - can't open raster map"
-#, fuzzy
-#~ msgid "Can't get row %d from raster map %s"
-#~ msgstr "対象マップ1"
-#, fuzzy
-#~ msgid "%s - raster map not found"
-#~ msgstr "対象マップ"
-#, fuzzy
-#~ msgid "string representing no data cell value"
-#~ msgstr "データのないセルに代入する記号"
-#, fuzzy
-#~ msgid "File name of reference classes"
-#, fuzzy
-#~ msgid "wide report, 132 columns (default: 80)"
-#~ msgstr "レポート幅の拡大"
-#, fuzzy
-#~ msgid "quiet"
-#~ msgstr "説明なし"
-#, fuzzy
-#~ msgid "<%s> - illegal output file name"
-#, fuzzy
-#~ msgid "%s: <%s> reference map not found"
-#, fuzzy
-#~ msgid "Base raster map"
-#~ msgstr "ベースマップ"
-#, fuzzy
-#~ msgid "%s: raster map not found"
-#~ msgstr "対象マップ"
-#, fuzzy
-#~ msgid "Problem opening input file [%s]"
-#, fuzzy
-#~ msgid "Problem opening output file [%s]"
-#, fuzzy
-#~ msgid "can't write category file for <%s>"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "%s: can't open tempfile"
-#, fuzzy
-#~ msgid "Unable to read row %d in raster map [%s]"
-#, fuzzy
-#~ msgid "Output verbosely"
-#~ msgstr "説明つき表示"
-#, fuzzy
-#~ msgid "Can't open raster map %s"
-#, fuzzy
-#~ msgid "It could not be find input map <%s>"
-#, fuzzy
-#~ msgid "It could not be found input map <%s>"
-#, fuzzy
-#~ msgid "Cannot find input map <%s>"
-#, fuzzy
-#~ msgid "Input vector map <%s> not found."
-#~ msgstr "���."
-#, fuzzy
-#~ msgid "Category ranges: e.g. 1,3-8,13"
-#, fuzzy
-#~ msgid "Writing attributes ...\n"
-#, fuzzy
-#~ msgid "Could not open ascii file <%s>"
-#, fuzzy
-#~ msgid "Could not open temp file <%s>"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Vector map <%s> not fould"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "SVG output file"
-#, fuzzy
-#~ msgid "Could not find vector '%s'"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Could not find vector map %s"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Unable to get row %d from <%s>"
-#~ msgstr "対象マップ1"
-#, fuzzy
-#~ msgid "No input coordinates provided"
-#~ msgstr "X座標値"
-#, fuzzy
-#~ msgid "Unable to allocate memory."
-#, fuzzy
-#~ msgid "Raster output file"
-#, fuzzy
-#~ msgid "Writing raster map ... "
-#, fuzzy
-#~ msgid "Keep existing color table"
-#~ msgstr "カラーテーブルを上書きしない"
-#, fuzzy
-#~ msgid "Name of the output walkers site file"
-#, fuzzy
-#~ msgid "Verbose mode."
-#~ msgstr "説明付き表示"
-#, fuzzy
-#~ msgid " %d rows, %d cols."
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "%s in %s - can't read header file"
-#, fuzzy
-#~ msgid "%s - unable to create raster map"
-#, fuzzy
-#~ msgid "%s - unable to create category file"
-#, fuzzy
-#~ msgid "verbose mode"
-#~ msgstr "説明付き表示"
-#, fuzzy
-#~ msgid "Vector map with points for which to modify the attribute table"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Layer of the vector for which to modify the attribute table"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Path to the input file"
-#, fuzzy
-#~ msgid "Path to an output file"
-#, fuzzy
-#~ msgid "Name of existing raster map to be displayed"
-#, fuzzy
-#~ msgid "Database name:"
-#~ msgstr "データベース"
-#, fuzzy
-#~ msgid "ASCII file to be converted to binary vector map, if not given (or \"-\") reads from standard input"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "could not find input map <%s>"
-#, fuzzy
-#~ msgid "unable to open raster map [%s]"
-#, fuzzy
-#~ msgid "cannot get layer info for vector map"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "cannot create table: %s"
-#, fuzzy
-#~ msgid "cannot create index"
-#, fuzzy
-#~ msgid "cannot grant privileges on table %s"
-#, fuzzy
-#~ msgid "Cannot find vector map"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Cannot find raster map"
-#, fuzzy
-#~ msgid "Cannot open raster map"
-#, fuzzy
-#~ msgid "Unknown keyword [%s] in vector head."
-#~ msgstr "���."
-#, fuzzy
-#~ msgid "Error while reading cell map."
-#, fuzzy
-#~ msgid "Error while writing new cell map."
-#, fuzzy
-#~ msgid "Error in opening output file <%s>"
-#, fuzzy
-#~ msgid "Unable to find input cell map <%s>"
-#, fuzzy
-#~ msgid "Error in opening input file <%s>"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Cannot find map %s"
-#, fuzzy
-#~ msgid "Cannot open map %s"
-#, fuzzy
-#~ msgid "Name of predefined rules file"
-#, fuzzy
-#~ msgid "no such value"
-#~ msgstr "閾値"
-#, fuzzy
-#~ msgid "Unable to find base map <%s>"
-#, fuzzy
-#~ msgid "Unable to find cover map <%s>"
-#, fuzzy
-#~ msgid "%s: reading category file for %s"
-#, fuzzy
-#~ msgid "%s: unable to open raster map [%s]"
-#, fuzzy
-#~ msgid "%s: unable to create raster map [%s]"
-#, fuzzy
-#~ msgid "Unable to open database %s with driver %s"
-#, fuzzy
-#~ msgid "%s: Unable to read raster map [%s]"
-#, fuzzy
-#~ msgid "%s: unable to open raster map <%s>"
-#, fuzzy
-#~ msgid "%s: Failed to read raster row %d"
-#, fuzzy
-#~ msgid "Unable to read cats table for %s"
-#, fuzzy
-#~ msgid "Could not open raster <%s>"
-#, fuzzy
-#~ msgid "Screen coordinates to place the legend (as percentage)"
-#~ msgstr "下,上,左,右の値(パーセンテージ)"
-#, fuzzy
-#~ msgid "%s: o_open_file: raster map %s not found"
-#, fuzzy
-#~ msgid "%s: o_open_file: could not open raster map %s in %s"
-#, fuzzy
-#~ msgid "No record for category for [%d]"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Error reading ASCII file <%s>"
-#, fuzzy
-#~ msgid "List of point coordinates. Required for add and move actions."
-#~ msgstr "タイプ"
-#, fuzzy
-#~ msgid "Could not find input vector '%s'"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Failed opening output vector map '%s'"
-#, fuzzy
-#~ msgid "Do not create attribute table."
-#, fuzzy
-#~ msgid "Error reading ascii file: [%s]"
-#, fuzzy
-#~ msgid "List vector maps in input location and exit (a dummy value must be given for input)"
-#~ msgstr "目的ロケーション内のベクトルマップ一覧表示"
-#, fuzzy
-#~ msgid "Allows the user to interactively query a vector map layer at user-selected locations within the current geographic region"
-#~ msgstr "マウスで指定した位置でのベクトルマップのカテゴリー情報を表示します(ここはどこ?なに?)"
-#, fuzzy
-#~ msgid "%s: <%s> vector map not found"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Vector <%s> could not be open"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Raster <%s> could not be open."
-#, fuzzy
-#~ msgid "Interpolation()"
-#~ msgstr "補間方法"
-#, fuzzy
-#~ msgid "Interpolation: Setting regions and boxes"
-#~ msgstr "補間方法"
-#, fuzzy
-#~ msgid "Interpolation: nsply = %d"
-#~ msgstr "補間方法"
-#, fuzzy
-#~ msgid "Interpolation: (%d,%d): Bilinear interpolation..."
-#, fuzzy
-#~ msgid "Interpolation: (%d,%d): Bicubic interpolation..."
-#, fuzzy
-#~ msgid "%s: Dropping <s>"
-#, fuzzy
-#~ msgid "Interpolation was a success!"
-#~ msgstr "補間方法"
-#, fuzzy
-#~ msgid "CrossCorrelation: %d points read in region. "
-#, fuzzy
-#~ msgid "CrossCorrelation: It shouldn't take too long."
-#, fuzzy
-#~ msgid "%s -- illegal output file name"
-#, fuzzy
-#~ msgid "Sorry, with method '%s' you have to define an output map."
-#, fuzzy
-#~ msgid "Existing raster map name"
-#, fuzzy
-#~ msgid "%s - can't read raster cellhd"
-#, fuzzy
-#~ msgid "error reading cell data"
-#, fuzzy
-#~ msgid "No line found."
-#, fuzzy
-#~ msgid "Do not build topology."
-#, fuzzy
-#~ msgid "Could not open ascii file [%s]"
-#, fuzzy
-#~ msgid "%s: Cannot open dxf file"
-#, fuzzy
-#~ msgid "Conversion of [%s] to vector map ..."
-#~ msgstr "���."
-#, fuzzy
-#~ msgid "Name of output 3d raster map"
-#, fuzzy
-#~ msgid ""
+#~ "USAGE for ARMSED FILE creation:\n"
+#~ "%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] ha=half_basin_map ar=ARMSED_file_name\n"
 #~ "\n"
-#~ "Where %s is one of:\n"
+#~ "USAGE for slope length determination:\n"
+#~ "%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or map]"
 #~ msgstr ""
+#~ "使用方法 盆地描画:\n"
 #~ "\n"
-#~ "ここでの %s は次のうちのいずれかです:\n"
-#, fuzzy
-#~ msgid "ERROR: <%s> not found\n"
-#, fuzzy
-#~ msgid "ERROR: <%s> illegal name\n"
-#, fuzzy
-#~ msgid "Cannot open toolbox: %s"
-#, fuzzy
-#~ msgid "Cannot open toolbox."
-#, fuzzy
-#~ msgid "Vector map(s) -- source for composite"
-#, fuzzy
-#~ msgid "Append files to existing file"
-#, fuzzy
-#~ msgid "Vector map '%s' not found"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Input elevation file"
-#~ msgstr "標高を示すファイル(入力)"
-#, fuzzy
-#~ msgid "Input aspect file"
-#, fuzzy
-#~ msgid "Input barrier file"
-#~ msgstr "バリアを示すファイル(入力)"
-#, fuzzy
-#~ msgid "Quiet operation"
-#~ msgstr "説明なし"
-#, fuzzy
-#~ msgid "Display Reference Information"
-#~ msgstr "ヘッダーの表示"
-#, fuzzy
-#~ msgid "Aspect file's resolution differs from                        current region resolution"
-#~ msgstr "値の読みとり間隔(デフォルト:現在の解像度)"
-#, fuzzy
-#~ msgid "output layer name"
-#, fuzzy
-#~ msgid "Imagery files subgroup"
-#, fuzzy
-#~ msgid "Warning: illegal output file name <%s>."
-#, fuzzy
-#~ msgid "Category <%d>: Line color and background color are the same!"
-#~ msgstr "���!"
-#, fuzzy
-#~ msgid "Line color and background color are the same!"
-#~ msgstr "���!"
-#, fuzzy
-#~ msgid "datetime, datetime1/datetime2, or none"
-#~ msgstr "タイムスタンプ"
-#, fuzzy
-#~ msgid "Open vector 3d raster map %s"
-#, fuzzy
-#~ msgid "Open 3d raster map %s"
-#, fuzzy
-#~ msgid "Vector import complete"
-#, fuzzy
-#~ msgid "Unable to create raster map for [%s]"
-#, fuzzy
-#~ msgid "error opening 3d raster map"
-#, fuzzy
-#~ msgid "Read fp map as integer (use map's quant rules"
-#~ msgstr "実数を整数に変換して使用"
-#, fuzzy
-#~ msgid "Name for the resulting raster map"
-#, fuzzy
-#~ msgid "Open Raster file %s in Mapset %s"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Open 3d raster map %s\n"
-#, fuzzy
-#~ msgid "Open elev raster map %s\n"
-#, fuzzy
-#~ msgid "Could not open map %s\n"
-#, fuzzy
-#~ msgid "Bin raster map to be imported"
-#, fuzzy
-#~ msgid "Output partial derivatives instead"
-#~ msgstr "傾斜値、傾斜方位、曲率の代わりに偏導関数を出力"
-#, fuzzy
-#~ msgid "Maximum distance"
-#~ msgstr "最大値"
-#, fuzzy
-#~ msgid "Makes 3D trees from input point vector map"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "Diameter of the tree crown in map units"
-#~ msgstr "視点座標"
-#, fuzzy
-#~ msgid "Height of tree trunk in meters"
-#~ msgstr "地表からの高さ(単位:メートル)"
-#, fuzzy
-#~ msgid "Name of the column with tree crown width"
-#~ msgstr "最終レポートを出力するファイル"
-#, fuzzy
-#~ msgid "Cannot select attributes for point #%d"
-#, fuzzy
-#~ msgid "Map coordinates"
-#~ msgstr "Z座標値"
-#, fuzzy
-#~ msgid "%s Quit\n"
-#~ msgstr "説明なし"
-#, fuzzy
-#~ msgid "Quiet mode"
-#~ msgstr "説明なし"
-#, fuzzy
-#~ msgid "%s[%d]: No raster map specified."
-#~ msgstr "対象マップ"
-#, fuzzy
-#~ msgid "Query column name"
-#~ msgstr "キーカラム"
-#, fuzzy
-#~ msgid "name for new binary vector map (omit for display to stdout)"
-#, fuzzy
-#~ msgid "Name for G3d raster map"
-#, fuzzy
-#~ msgid "No output maps"
-#, fuzzy
-#~ msgid "Connect to the database through DBMI."
-#~ msgstr "データベースに接続します"
-#, fuzzy
-#~ msgid "The resolution of raster and raster3d maps should be equal!"
-#, fuzzy
-#~ msgid "Compute upslope flowlines"
-#~ msgstr "流路を遡って計算"
-#, fuzzy
-#~ msgid "The map E and N grid coordinates of a starting point"
-#~ msgstr "始点の座標値"
-#, fuzzy
-#~ msgid "Invoke fast, but memory intensive operation"
-#~ msgstr "高速計算(大きなメモリが必要)"
-#, fuzzy
-#~ msgid "You first need to run v.build on vector map <%s>"
-#~ msgstr "���"
-#, fuzzy
-#~ msgid "unknown interpolation method"
-#~ msgstr "補間方法"
-#, fuzzy
-#~ msgid "Name of existing raster map."
-#, fuzzy
-#~ msgid "Name of new raster map."
-#, fuzzy
-#~ msgid "Name of input map"
-#, fuzzy
-#~ msgid "Name of existing input raster map"
-#, fuzzy
-#~ msgid "cover raster map"
-#~ msgstr "カバーマップ"
-#, fuzzy
-#~ msgid "resultant raster map"
-#, fuzzy
-#~ msgid "Input layer name"
-#, fuzzy
-#~ msgid "Output layer name"
-#, fuzzy
-#~ msgid "Name of the resulting map"
-#, fuzzy
-#~ msgid "Aspect"
-#~ msgstr "傾斜方位またはdy値を出力するファイル"
-#, fuzzy
-#~ msgid "Profile curvature"
-#~ msgstr "断面曲率またはdxx値を出力するファイル"
-#, fuzzy
-#~ msgid "Tangential curvature"
-#~ msgstr "正接曲率またはdyy値を出力するファイル"
-#, fuzzy
-#~ msgid "Mean curvature"
-#~ msgstr "平均曲率またはdxy値を出力するファイル"
-#, fuzzy
-#~ msgid "Enter name for the resulting signature file"
-#, fuzzy
-#~ msgid "page length (default: %d lines)"
-#~ msgstr "1ページの行数"
-#, fuzzy
-#~ msgid "page width (default: %d characters)"
-#~ msgstr "1行の文字数"
-#, fuzzy
-#~ msgid "suppress page headers"
-#~ msgstr "ヘッダーの削除"
-#, fuzzy
-#~ msgid "use formfeeds between pages"
-#~ msgstr "フォームフィードの使用"
-#, fuzzy
-#~ msgid "Write an Arc-Info line/polygon coverage in e00 format."
-#~ msgstr "ベクトルマップをARC/INFO E00ファイルとしてエクスポートします"
-#, fuzzy
-#~ msgid "Mapset holding vector map to be exported (Default = current)"
-#~ msgstr "入力するファイルを含むマップセット(デフォルト=現在のマップセット)"
-#, fuzzy
-#~ msgid "Name of .e00 output file (Default: stdout)"
-#, fuzzy
-#~ msgid "Process spaghetti-digitized binary vector map."
-#~ msgstr "スパゲッティデータ(バイナリー形式)の編集を行います"
-#, fuzzy
-#~ msgid "Only run identical line tests"
-#~ msgstr "指定したラインのみで実行"
-#, fuzzy
-#~ msgid "Snap nodes"
-#~ msgstr "端点をスナップ"
-#, fuzzy
-#~ msgid ""
-#~ "Set line types to:   \n"
-#~ "             source        same as in binary vector map\n"
-#~ "             line          lines\n"
-#~ "             area          area edges\n"
-#~ "             point         points (sites)\n"
-#~ msgstr ""
-#~ "線の種類:   \n"
-#~ "             source        元のベクトルマップと同じ\n"
-#~ "             line          線\n"
-#~ "             area          エリアエッジ\n"
-#~ "             point         点(サイトデータ)\n"
-#, fuzzy
-#~ msgid "Output file is ASCII map"
-#~ msgstr "ASCII形式のベクトルマップを出力"
-#, fuzzy
-#~ msgid "Copy attributes and category files"
-#~ msgstr "属性およびカテゴリーファイルをコピー"
-#, fuzzy
-#~ msgid "Converts point data in a binary GRASS vector map layer into a GRASS site_lists file."
-#~ msgstr "ベクトルマップからデータを抽出してサイトマップに変換します"
-#, fuzzy
-#~ msgid "Use Category NUMERIC data instead of attribute"
-#~ msgstr "属性の代わりに数値データを使用"
-#, fuzzy
-#~ msgid "Use Category TEXT data instead of attribute"
-#~ msgstr "属性の代わりにテキストデータを使用"
-#, fuzzy
-#~ msgid "Test routine for developing MIF import."
-#~ msgstr " ESRI シェープファイルをベクトルマップとしてインポートします"
-#, fuzzy
-#~ msgid "Debugging level : 0 (silent) - 3 (verbose)"
-#~ msgstr "デバッグレベル"
-#, fuzzy
-#~ msgid "Name of file where to log operations"
-#~ msgstr "ログファイル"
-#, fuzzy
-#~ msgid "Snap distance in ground units (Default = 10^-10)"
-#~ msgstr "端点のスナップ距離"
-#, fuzzy
-#~ msgid "Set initial scale [1:2400]"
-#~ msgstr "スケール"
-#, fuzzy
-#~ msgid "Name of attribute to use as category"
-#~ msgstr "属性番号のフィールド名"
-#, fuzzy
-#~ msgid "Allow overwrite of existing vector map with the same name"
-#~ msgstr "上書き"
-#, fuzzy
-#~ msgid "Force writing  polygon coverage as a line coverage"
-#~ msgstr "強制インポート"
-#, fuzzy
-#~ msgid "Create unique value for parts of compound object"
-#~ msgstr "ID番号を属性として使用"
-#, fuzzy
-#~ msgid "List fields of DBF file"
-#~ msgstr "データベースのフィールド一覧を表示して終了"
-#, fuzzy
-#~ msgid "new categories table title"
-#~ msgstr "タイトル"
-#, fuzzy
-#~ msgid "Build topology info (default) OR Edit categories"
-#~ msgstr "トポロジーの構築かカテゴリーの編集"
-#, fuzzy
-#~ msgid "Prompt user for threshold         (Valid only with Build option)"
-#~ msgstr "閾値のユーザ定義"
-#, fuzzy
-#~ msgid "read data into memory"
-#~ msgstr "タイトル"
-#, fuzzy
-#~ msgid "Set map region from data          (Valid only with Build option)"
-#~ msgstr "データから地域を設定"
-#, fuzzy
-#~ msgid "Snap Threshold value       (Valid only with Build option and -s)"
-#~ msgstr "スナップの閾値"
-#, fuzzy
-#~ msgid "Suppress drawing of text outlines"
-#~ msgstr "テキストのアウトラインを非表示"
-#, fuzzy
-#~ msgid "DXF layers with line data"
-#~ msgstr "ラインデータを含むファイル"
-#, fuzzy
-#~ msgid "DXF layers with label data"
-#~ msgstr "ラベルデータを含むファイル"
-#, fuzzy
-#~ msgid "Prefix for dig or dig_ascii and dig_att output files"
-#, fuzzy
-#~ msgid ""
+#~ "使用方法 ARMSEDファイルの作成:\n"
 #~ "\n"
-#~ "\n"
-#~ "Where lines and labels are one or more of:\n"
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "ここでのlines,labelsの入力形式は以下の通りです:\n"
-#~ "\n"
+#~ "使用方法 for スロープ長決定:\n"
-#, fuzzy
-#~ msgid ""
-#~ "      and/or   \n"
-#~ "\n"
-#~ msgstr ""
-#~ "      または   \n"
-#~ "\n"
+#~ msgid "Raster map with camera angle relative to ground surface"
+#~ msgstr "地面と相対的なカメラアングル値を持つラスターマップ"
-#, fuzzy
-#~ msgid "angle of rotation"
-#~ msgstr "回転角度"
+#~ msgid "Run OPTION 7 of i.ortho.photo again!\n"
+#~ msgstr "i.ortho.photo のオプション7を再度実行してください\n"
-#, fuzzy
-#~ msgid "provide attributes of type: const,rows,cols"
-#~ msgstr "属性タイプ"
+#~ msgid "Run OPTION 7 of i.ortho.photo!\n"
+#~ msgstr "i.ortho.photo のオプション7を実行してください\n"
-#, fuzzy
-#~ msgid "binary vector map to be converted to ascii"
+#~ msgid "Run OPTION 5 of i.ortho.photo again!\n"
+#~ msgstr "i.ortho.photo のオプション5を再度実行してください\n"
-#, fuzzy
-#~ msgid "Converts ASCII vector map layers into binary vector map layers."
-#~ msgstr " ASCII形式のファイルをベクトルマップとしてインポートします"
+#~ msgid "Run OPTION 5 of i.ortho.photo!\n"
+#~ msgstr "i.ortho.photo のオプション5を実行してください\n"
-#, fuzzy
-#~ msgid "what load"
-#~ msgstr "更新する対象"
+#~ msgid "shape;Display geometry of features;cat;Display category numbers of features;topo;Display topology information (nodes, edges);dir;Display direction of linear features;attr;Display selected attribute based on 'attrcol';zcoor;Display z-coordinate of features (only for 3D vector maps)"
+#~ msgstr "shape;フィーチャーのジオメトリを表示;cat;フィーチャーのカテゴリ数を表示;topo;トポロジー情報を表示(nodes、edges);dir;線形フィーチャーの方向を表示;attr;'attcol'で指定した属性を表示;zcoor;フィーチャーのZ軸を表示(3Dベクトルマップのみ)"
-#, fuzzy
-#~ msgid "key column"
-#~ msgstr "キーカラム"
+#~ msgid "driver: %s<BR>database: %s<BR>table: %s<BR>key column: %s<BR>"
+#~ msgstr "ドライバ: %s<BR>データベース: %s<BR>テーブル: %s<BR>キー項目: %s<BR>"
-#, fuzzy
-#~ msgid "Prints information about a binary GRASS vector map layer."
-#~ msgstr "ベクトルマップについての情報を表示します"
-#, fuzzy
-#~ msgid "Cleans out dead lines in GRASS vector maps."
-#~ msgstr "ベクトルマップのデータ中で削除マークの付いた線を全て取り除きます"
-#, fuzzy
-#~ msgid "Key (id) column name"
-#~ msgstr "キーカラム"
-#, fuzzy
-#~ msgid "Select area, line, or site "
-#~ msgstr "タイプ"
-#, fuzzy
-#~ msgid "input vector map for ARC/INFO conversion"
-#, fuzzy
-#~ msgid "coverage type"
-#~ msgstr "抽出するタイプ"
-#, fuzzy
-#~ msgid "prefix for ARC/INFO output filenames"
-#, fuzzy
-#~ msgid "The postscript versions of these papers are available via Internet at"
-#~ msgstr "これらの文献はポストスクリプト形式で下のURLから入手できます"
-#, fuzzy
-#~ msgid "Please cite these references in publications where the results of this"
-#~ msgstr "このプログラムの結果を論文等に公表する場合, "
-#, fuzzy
-#~ msgid "Do zero attributes/cats represent elevation?"
-#~ msgstr "入力ファイルの値0を標高に置き換える"
-#, fuzzy
-#~ msgid "path to GRASS database of input location"
-#~ msgstr "目的ロケーションを含むデータベース"
-#, fuzzy
-#~ msgid "Automatically run \"v.support\" on newly created vector map."
-#~ msgstr "'v.support'コマンドを自動的に実行"
-#, fuzzy
-#~ msgid "Type of object to extract (area, line or both)"
-#~ msgstr "抽出する線のタイプ"
-#, fuzzy
-#~ msgid "Limit line output to area-edge arcs"
-#~ msgstr "エリアエッジのみ抽出"
-#, fuzzy
-#~ msgid "Limit line output to line arcs"
-#~ msgstr "線のみ抽出"
-#, fuzzy
-#~ msgid "Polygon Cookie Cutter  (Boolean AND Overlay)."
-#~ msgstr "2つの既存するベクトルマップの交差関係にもとづいた演算(ブール代数のANDオーバーレイ)を行い、新しいマップを作成します"
-#, fuzzy
-#~ msgid "ARC/INFO ungenerate lines file"
-#~ msgstr "入力するラインファイル"
-#, fuzzy
-#~ msgid "ARC/INFO ungenerate label-points file"
-#~ msgstr "入力するラベル(ポイント)ファイル"
-#, fuzzy
-#~ msgid "ARC/INFO label-text file"
-#~ msgstr "入力するラベル(テキスト)ファイル"
-#, fuzzy
-#~ msgid "resultant Vector output file"
-#, fuzzy
-#~ msgid "ID Number column in label-text file"
-#~ msgstr "テキストの列数(ID番号)"
-#, fuzzy
-#~ msgid "GRASS category column in label-text file"
-#~ msgstr "テキストの列数(カテゴリー値)"
-#, fuzzy
-#~ msgid "GRASS attribute column in label-text file"
-#~ msgstr "テキストの列数(属性)"
-#, fuzzy
-#~ msgid "new pruned vector map"
-#, fuzzy
-#~ msgid "reports attribute, label, and other information about a sites file"
-#~ msgstr "サイトマップの基礎情報を出力します"
-#, fuzzy
-#~ msgid "Name of sites file."
-#~ msgstr "対象マップ"
-#, fuzzy
-#~ msgid "Load quietly"
-#~ msgstr "説明なし"
-#, fuzzy
-#~ msgid "Only count sites in current window for min/max."
-#~ msgstr "最大値と最小値のみ出力"
-#, fuzzy
-#~ msgid "Show quartiles for decimal attributes"
-#~ msgstr "属性番号の出力"
-#, fuzzy
-#~ msgid "Name of input sites map"
-#, fuzzy
-#~ msgid "which decimal attribute (if multiple)"
-#~ msgstr "属性番号"
-#, fuzzy
-#~ msgid "Use raster's region vs. current region"
-#~ msgstr "ラスターマップの領域の使用"
-#, fuzzy
-#~ msgid "Name of sites file to filter"
-#~ msgstr "入力するファイル(サイト)"
-#, fuzzy
-#~ msgid "Converts a GRASS site list file into an ASCII listing of site locations and their descriptions."
-#~ msgstr "サイトマップをASCII形式のサイトリストとしてエクスポートします"
-#, fuzzy
-#~ msgid "Include site attributes in the output"
-#~ msgstr "カテゴリーラベルも出力"
-#, fuzzy
-#~ msgid "Include site attribute identifiers in the output"
-#~ msgstr "属性識別子も出力"
-#, fuzzy
-#~ msgid "Name of input site list"
-#, fuzzy
-#~ msgid "Number of cells to surround site cell"
-#~ msgstr "考慮する周辺のセル数"
-#, fuzzy
-#~ msgid "Attribute field type to use for operation"
-#~ msgstr "属性タイプ"
-#, fuzzy
-#~ msgid "Attribute field number to use for operation"
-#~ msgstr "属性番号"
-#, fuzzy
-#~ msgid "String attribute number to use for description"
-#~ msgstr "文字型属性番号"
-#, fuzzy
-#~ msgid "Create a single-valued (0/1) raster map"
-#~ msgstr "0と1のみで構成されるラスターマップを出力"
-#, fuzzy
-#~ msgid "Average an attribute of a site_list for all the sites within each cell of the current region."
-#~ msgstr "サイトマップ全体から属性の平均を出力します"
-#, fuzzy
-#~ msgid "Attribute to average values over"
-#~ msgstr "属性タイプ"
-#, fuzzy
-#~ msgid "Index of attribute type (ignored for cat)"
-#~ msgstr "属性番号"
-#, fuzzy
-#~ msgid "sites list to store means"
-#, fuzzy
-#~ msgid "Suppress windows with zero averages"
-#~ msgstr "データのないセルは出力しない"
-#, fuzzy
-#~ msgid "Output in g.gnuplot format (overrides -z and writes to stdout)"
-#~ msgstr "'g.gnuplot'コマンド形式で出力"
-#, fuzzy
-#~ msgid "Convert an ASCII listing of site locations into a GRASS site list file."
-#, fuzzy
-#~ msgid "sites file to be created"
-#, fuzzy
-#~ msgid "number of dimensions (default=2)"
-#~ msgstr "配列の数(デフォルト2)"
-#, fuzzy
-#~ msgid "input field separator"
-#~ msgstr "区切り"
-#, fuzzy
-#~ msgid "datetime or datetime1/datetime2"
-#, fuzzy
-#~ msgid "Allows the user to re-project a sites file from one location to the current location (no datum transformation yet)."
-#~ msgstr "サイトマップの投影変換を行います"
-#, fuzzy
-#~ msgid "input sites list"
-#, fuzzy
-#~ msgid "location of input sites list"
-#~ msgstr "再投影を行うロケーション"
-#, fuzzy
-#~ msgid "mapset of input sites list"
-#, fuzzy
-#~ msgid "output sites list"
-#, fuzzy
-#~ msgid "List sites files in input location and exit"
-#~ msgstr "目的ロケーション内のサイトマップ一覧表示"
-#, fuzzy
-#~ msgid "Don't prompt for Map header information"
-#~ msgstr "ヘッダーを削除"
-#, fuzzy
-#~ msgid "Field type (\"string\", \"dim\", or \"decimal\") and index to use for category value (uses \"cat\" by default)"
-#~ msgstr "属性タイプまたは属性番号"
-#, fuzzy
-#~ msgid "Allows the user to interactively adjust the settings (zoom  and  pan) of the current geographic region using a pointing device such as a mouse."
-#~ msgstr "対象地域のズーム/パンをマウスにより行います"
-#, fuzzy
-#~ msgid "Displays points, as icons, at user-defined locations in the active display frame on the graphics monitor."
-#~ msgstr "アイコンでポイントマーカーを表示します"
-#, fuzzy
-#~ msgid "Name of existing sites file"
-#~ msgstr "対象マップ"
-#, fuzzy
-#~ msgid "Identify just one site"
-#~ msgstr "1度のみ実行"
-#, fuzzy
-#~ msgid "For parsing by programs: Terse output"
-#~ msgstr "簡易表示"
-#, fuzzy
-#~ msgid "Allows the user to interactively query site list descriptions. "
-#~ msgstr "マウスで指定した位置でのサイトマップのカテゴリー情報を表示します(ここはどこ?なに?)"
-#, fuzzy
-#~ msgid "Color to erase with"
-#~ msgstr "塗りつぶす色"
-#, fuzzy
-#~ msgid "Name of a spheroid (for lat/lon coordinate conversion)"
-#~ msgstr "変換先の楕円体"
-#, fuzzy
-#~ msgid "Displays three-dimensional images based on raster map layers"
-#~ msgstr "ラスターマップを3次元で表示します"
-#, fuzzy
-#~ msgid "The raster map used to generate the color"
-#~ msgstr "色のラスターマップ"
-#, fuzzy
-#~ msgid "The raster map used to generate the 3-d texture"
-#~ msgstr "標高のラスターマップ"
-#, fuzzy
-#~ msgid "coordinates of center of view"
-#~ msgstr "視野の中心座標"
-#, fuzzy
-#~ msgid "Frequency of vector lines in output"
-#~ msgstr "格子間隔"
-#, fuzzy
-#~ msgid "Field of view"
-#~ msgstr "視野の角度"
-#, fuzzy
-#~ msgid "Color of bounding box"
-#~ msgstr "枠の色"
-#, fuzzy
-#~ msgid "Show null elevations"
-#~ msgstr "NULL値を表示"
-#, fuzzy
-#~ msgid "Draw labelled vector lines to the current display device"
-#~ msgstr "ベクトルラインを表示します"
-#, fuzzy
-#~ msgid "Name of existing vector map to draw"
-#~ msgstr "対象マップ"
-#, fuzzy
-#~ msgid "Draw all lines using either a GRASS standard color or R:G:B triplet (separated by colons)"
-#~ msgstr "線の色"
-#, fuzzy
-#~ msgid "Only draw areas with a matching category number (for constant color option only)"
-#~ msgstr "表示するカテゴリー番号"
-#, fuzzy
-#~ msgid "Draw lines according to a legend file (<cat> <R> <G> <B>)"
-#~ msgstr "凡例用ファイル"
-#, fuzzy
-#~ msgid "Use random colors"
-#~ msgstr "ランダムな色を使用"
-#, fuzzy
-#~ msgid "Line color -- a GRASS named color, an R:G:B triplet, or \"none\""
-#~ msgstr "境界線の色"
-#, fuzzy
-#~ msgid "Limit to matching category number(s) (constant color option only)"
-#~ msgstr "表示するカテゴリー番号(色が指定されているときのみ有効)"
-#, fuzzy
-#~ msgid "Use a legend file: (<cat> <R> <G> <B> [<R> <G> <B>])"
-#, fuzzy
-#~ msgid "Sets the current color to that stated"
-#~ msgstr "色"
-#, fuzzy
-#~ msgid "Size, in pixels, in which the icon is to be drawn"
-#~ msgstr "アイコンのサイズ(ピクセル)"
-#, fuzzy
-#~ msgid "Interactively label sites using a string or double attribute value or the category value on the current graphics monitor."
-#~ msgstr "サイトラベルを表示します"
-#, fuzzy
-#~ msgid "Name of sites file"
-#, fuzzy
-#~ msgid "Index of attribute. Ignored when attr=cat or attr=coords."
-#~ msgstr "属性番号"
-#, fuzzy
-#~ msgid "Relative horizontal position 'left|center|right'"
-#~ msgstr "位置(水平方向)"
-#, fuzzy
-#~ msgid "Relative vertical position 'top|center|bottom'"
-#~ msgstr "位置(鉛直方向)"
-#, fuzzy
-#~ msgid "Size of text (pixels)"
-#~ msgstr "テキストのサイズ"
-#, fuzzy
-#~ msgid "Sets the font"
-#~ msgstr "フォント"
-#, fuzzy
-#~ msgid "Sets the current grid color"
-#~ msgstr "線の色"
-#, fuzzy
-#~ msgid "displays vector maps, optionally only selected categories in current monitor window."
-#~ msgstr "ベクトルマップを表示します"
-#, fuzzy
-#~ msgid "Vector category number(s) to be displayed"
-#, fuzzy
-#~ msgid "Input is a UNIX file name"
-#, fuzzy
-#~ msgid "Allows the user to establish whether a map will be displayed using its own color table or the fixed color table of the graphics monitor."
-#~ msgstr "モニターに用いるカラーテーブルを設定します"
-#, fuzzy
-#~ msgid "Creates and modifies icons for use with ps.map."
-#~ msgstr "ポストスクリプトマップに使用するアイコンの作成/編集を行います"
-#, fuzzy
-#~ msgid "icon filename"
-#, fuzzy
-#~ msgid "file containing mapping instructions (or use input=- to enter from keyboard)"
-#~ msgstr "設定ファイル"
-#, fuzzy
-#~ msgid "scale of the output map, e.g. 1:25000 (default: 1panel)"
-#~ msgstr "スケール (例: 1:25000)"
-#, fuzzy
-#~ msgid "number of copies to print"
-#~ msgstr "部数"
-#, fuzzy
-#~ msgid "Selects a PostScript device for GRASS hardcopy output."
-#~ msgstr "ハードコピーを出力するデバイスを選択します"
-#, fuzzy
-#~ msgid "name of PostScript painter to select"
-#~ msgstr "使用するデバイス"
-#, fuzzy
-#~ msgid "list all available PostScript painters"
-#~ msgstr "ポストスクリプトペインタの一覧表示"
-#, fuzzy
-#~ msgid "print name of currently selected PostScript painter"
-#~ msgstr "現在選択されているペインタ名を表示"
-#, fuzzy
-#~ msgid "quietly select PostScript painter"
-#~ msgstr "説明なし"
-#, fuzzy
-#~ msgid "Creates raster maps from ERDAS files."
-#~ msgstr "ERDAS/LANファイルをラスターマップとしてインポートします"
-#, fuzzy
-#~ msgid "List the ERDAS header only"
-#~ msgstr "ヘッダーのみ一覧表示"
-#, fuzzy
-#~ msgid "Disable autoswap detection"
-#~ msgstr "自動でビット反転しない"
-#, fuzzy
-#~ msgid "Force Swapping (overrides default auto)"
-#~ msgstr "強制ビット反転"
-#, fuzzy
-#~ msgid "output prefix of the GRASS raster maps to be created."
-#, fuzzy
-#~ msgid "Erdas trailer input file name"
-#~ msgstr "ERDASトレイラーファイル"
-#, fuzzy
-#~ msgid "Starting row."
-#~ msgstr "開始行"
-#, fuzzy
-#~ msgid "Starting column."
-#~ msgstr "開始列"
-#, fuzzy
-#~ msgid "Number of rows to extract."
-#~ msgstr "抽出する行数"
-#, fuzzy
-#~ msgid "Number of columns to extract."
-#~ msgstr "抽出する列数"
-#, fuzzy
-#~ msgid "Creates ERDAS files from raster maps."
-#~ msgstr "GRASSの画像ファイルをERDAS/LANファイルとしてエクスポートします"
-#, fuzzy
-#~ msgid "Output 16-bit image (default 8)"
-#~ msgstr "16bitイメージで出力"
-#, fuzzy
-#~ msgid "Force byte swapping"
-#, fuzzy
-#~ msgid "Erdas output file name"
-#, fuzzy
-#~ msgid "Allows category values from several raster map layers to be combined."
-#~ msgstr "ラスターマップのカテゴリー値を論理操作します"
-#, fuzzy
-#~ msgid "Use symbols (instead of graphics)"
-#~ msgstr "シンボルを使用"
-#, fuzzy
-#~ msgid "Create floating-point maps (0.0 - 1.0)."
-#~ msgstr "実数形式のマップを作成"
-#, fuzzy
-#~ msgid "Output image file header only."
-#~ msgstr "ヘッダーのみ出力"
-#, fuzzy
-#~ msgid "Enable extend memory option: Operation is slow"
-#~ msgstr "仮想メモリを使用"
-#, fuzzy
-#~ msgid "Name of an output binary map (use out=- for stdout)"
-#, fuzzy
-#~ msgid "Converts point data in a GRASS raster map layer into a GRASS site_lists file."
-#~ msgstr "ラスターマップからデータを抽出してサイトマップに変換します"
-#, fuzzy
-#~ msgid "Output as decimal attribute rather than cat"
-#~ msgstr "属性番号として出力"
-#, fuzzy
-#~ msgid "Output as third dimension rather than cat"
-#~ msgstr "標高値として出力"
-#, fuzzy
-#~ msgid "Name of raster map."
-#, fuzzy
-#~ msgid "Creates a new binary GRASS vector (v.digit) file by extracting linear features from a thinned raster map."
-#~ msgstr "細線化したラスターマップからベクトルマップを作成します"
-#, fuzzy
-#~ msgid "Creates a raster map layer and site list file containing randomly located sites."
-#~ msgstr "任意抽出を行います"
-#, fuzzy
-#~ msgid "Name of the output sites map"
-#~ msgstr "出力するファイル(サイトマップ)"
-#, fuzzy
-#~ msgid "Imports a TIFF (8 or 24 bit) raster map into GRASS raster map(s)"
-#~ msgstr "TIFFファイルをラスターマップとしてインポートします"
-#, fuzzy
-#~ msgid "Name on TIFF file to input."
-#~ msgstr "入力するファイル"
-#, fuzzy
-#~ msgid "Bayesian expert system development program."
-#~ msgstr "ベイズの統計に基づいた推論規則を適用し新しいラスターマップを作成します"
-#, fuzzy
-#~ msgid "Run verbosely with debugging output"
-#~ msgstr "説明付き表示"
-#, fuzzy
-#~ msgid "The site list"
-#~ msgstr "出力:クランプの重心を示すファイル"
-#, fuzzy
-#~ msgid "raster map(s) to report on"
-#~ msgstr "対象マップ"
-#, fuzzy
-#~ msgid "mi(les),me(ters),k(ilometers),a(cres),h(ectacres),c(ell_counts),p(ercent_cover)"
-#~ msgstr "単位"
-#, fuzzy
-#~ msgid "name of an output file to hold the report"
-#, fuzzy
-#~ msgid "number of fp subranges to collect stats from"
-#~ msgstr "誤差の桁数"
-#, fuzzy
-#~ msgid "filter out all no data cells"
-#~ msgstr "NULL値を対象に含まない"
-#, fuzzy
-#~ msgid "filter out cells where all maps have no data"
-#~ msgstr "すべてのマップでNULL値となっているセルを除く"
-#, fuzzy
-#~ msgid "report for cats fp ranges (fp maps only)"
-#~ msgstr "実数でレポートを出力"
-#, fuzzy
-#~ msgid "Generates an output raster map layer with contiguous areas grown by one cell (pixel)."
-#~ msgstr "エリアを拡大したラスターマップを作成します"
-#, fuzzy
-#~ msgid "re-project a raster map from one location to the current location (no datum transformation yet)"
-#~ msgstr "ラスターマップの投影変換を行います"
-#, fuzzy
-#~ msgid "mapset of input map"
-#, fuzzy
-#~ msgid "resolution of output map"
-#~ msgstr "解像度"
-#, fuzzy
-#~ msgid "Don't attempt to crop output map"
-#~ msgstr "投影後の不要部分を削除しない"
-#, fuzzy
-#~ msgid "Print grid coordinates (east and north) (requires -1 flag)"
-#~ msgstr "格子点の座標を出力"
-#, fuzzy
-#~ msgid "output is the interpolation error"
-#~ msgstr "誤差を出力"
-#, fuzzy
-#~ msgid "read fp map as integer"
-#, fuzzy
-#~ msgid "format for reporting the slope"
-#~ msgstr "傾斜の単位"
-#, fuzzy
-#~ msgid "type of output aspect and slope maps"
-#~ msgstr "出力する値の型"
-#, fuzzy
-#~ msgid "Output E-W slope filename"
-#~ msgstr "東西方向の傾斜を出力するファイル"
-#, fuzzy
-#~ msgid "Output N-S slope filename"
-#~ msgstr "南北方向の傾斜を出力するファイル"
-#, fuzzy
-#~ msgid "Output partial derivative dxx filename"
-#~ msgstr "dxx値の偏導関数を出力するファイル"
-#, fuzzy
-#~ msgid "Output partial derivative dyy filename"
-#~ msgstr "dyy値の偏導関数を出力するファイル"
-#, fuzzy
-#~ msgid "Output partial derivative dxy filename"
-#~ msgstr "dxy値の偏導関数を出力するファイル"
-#, fuzzy
-#~ msgid "Name of file for output (use out=- for stdout)"
-#~ msgstr "出力するファイル"
-#, fuzzy
-#~ msgid "print range only."
-#, fuzzy
-#~ msgid "Converts raster data referenced using latitude and longitude coordinates to a UTM-referenced map layer in GRASS raster format."
-#~ msgstr "緯度/経度座標ファイルから UTM座標ファイルを作成します"
-#, fuzzy
-#~ msgid "input file"
-#, fuzzy
-#~ msgid ""
-#~ "one corner latitude and longitude of the input\n"
-#~ "format: {nw|ne|sw|se},%s,%s"
-#~ msgstr "領域の端の座標値 入力形式: {nw|ne|sw|se},%s,%s"
-#, fuzzy
-#~ msgid "resolution of the input (in arc seconds)"
-#~ msgstr "解像度(秒角)"
-#, fuzzy
-#~ msgid "Starting points site file"
-#~ msgstr "始点を示すサイトマップ"
-#, fuzzy
-#~ msgid "Stop points site file"
-#~ msgstr "終点を示すサイトマップ"
-#, fuzzy
-#~ msgid "Extracts area edges from a raster map layer and converts data to GRASS vector format."
-#~ msgstr "ラスターマップからエリアエッジを抽出してベクトルマップを作成します"
-#, fuzzy
-#~ msgid "Output only area borders as vector lines"
-#~ msgstr "ベクトルラインを出力"
-#, fuzzy
-#~ msgid "Number of values printed before wrapping a line"
-#~ msgstr "読み込む桁数"
-#, fuzzy
-#~ msgid "raster map name from which to copy color table"
-#~ msgstr "カラーテーブルに用いるラスターマップ"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Where color type is one of:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "ここでのカラーテーブル(colorパラメータ)は次のうちのいずれかです:\n"
-#, fuzzy
-#~ msgid "  aspect    (aspect oriented grey colors)\n"
-#~ msgstr "  aspect    (グレーカラー)\n"
-#, fuzzy
-#~ msgid "  grey      (linear grey scale)\n"
-#~ msgstr "  grey      (グレースケール)\n"
-#, fuzzy
-#~ msgid "  grey.eq   (histogram equalized grey scale)\n"
-#~ msgstr "  grey.eq   (ヒストグラムを平滑化したグレースケール)\n"
-#, fuzzy
-#~ msgid "  grey.log  (histogram logarithmic transformed grey scale)\n"
-#~ msgstr "  grey.log  (ヒストグラムを対数化したグレースケール)\n"
-#, fuzzy
-#~ msgid "  byg       (blue through yellow to green colors)\n"
-#~ msgstr "  byg       (青→黄→緑)\n"
-#, fuzzy
-#~ msgid "  byr       (blue through yellow to red colors)\n"
-#~ msgstr "  byr       (青→黄→赤)\n"
-#, fuzzy
-#~ msgid "  gyr       (green through yellow to red colors)\n"
-#~ msgstr "  gyr       (緑→黄→赤)\n"
-#, fuzzy
-#~ msgid "  rainbow   (rainbow color table)\n"
-#~ msgstr "  rainbow   (レインボー)\n"
-#, fuzzy
-#~ msgid "  ramp      (color ramp)\n"
-#~ msgstr "  ramp      (ランプ)\n"
-#, fuzzy
-#~ msgid "  ryg       (red through yellow to green colors)\n"
-#~ msgstr "  ryg       (赤→黄→緑)\n"
-#, fuzzy
-#~ msgid "  random    (random color table)\n"
-#~ msgstr "  random    (ランダム)\n"
-#, fuzzy
-#~ msgid "  wave      (color wave)\n"
-#~ msgstr "  wave      (カラーウェーブ)\n"
-#, fuzzy
-#~ msgid "  rules     (create new color table by rules)\n"
-#~ msgstr "  rules     (ルールの新規作成)\n"
-#, fuzzy
-#~ msgid "method of object-based statistic"
-#~ msgstr "統計解析方法"
-#, fuzzy
-#~ msgid "resultant raster map (not used with 'distribution')"
-#, fuzzy
-#~ msgid "Northern limit of geographic region"
-#~ msgstr "領域の北端"
-#, fuzzy
-#~ msgid "Eastern limit of geographic region"
-#~ msgstr "領域の東端"
-#, fuzzy
-#~ msgid "Western limit of geographic region"
-#~ msgstr "領域の西端"
-#, fuzzy
-#~ msgid "Override projection (use locations projection)"
-#~ msgstr "現在のロケーションの投影法を使用"
-#, fuzzy
-#~ msgid "Extend location extents based on new dataset."
-#~ msgstr "データセットをもとにロケーションを拡張"
-#, fuzzy
-#~ msgid "Maximum magnitude of random grid point offset"
-#~ msgstr "ランダムにとるオフセットの最大値"
-#, fuzzy
-#~ msgid "Outputs a raster map layer whose category values represent the application of user-specified criteria (rules statements) to other raster map layers' category values."
-#~ msgstr "指定した推論規則を適用し新しいラスターマップを作成します"
-#, fuzzy
-#~ msgid "Converts a PPM image file to GRASS raster map(s)."
-#~ msgstr "PPMファイルをラスターマップとしてインポートします"
-#, fuzzy
-#~ msgid "Create separate red/green/blue maps."
-#~ msgstr "赤/緑/青に対応するラスターマップを出力"
-#, fuzzy
-#~ msgid "Create composite color map."
-#~ msgstr "合成した色のラスターマップを出力"
-#, fuzzy
-#~ msgid "Converts Universal Transverse Mercator (UTM) coordinates to geographic (latitude/longitude) coordinates."
-#~ msgstr "UTM座標値から緯度/経度座標値に変換します"
-#, fuzzy
-#~ msgid "reference spheroid (ellipsoid)"
-#~ msgstr "楕円体"
-#, fuzzy
-#~ msgid "Specified zone is in the southern hemisphere"
-#~ msgstr "領域を南半球で指定"
-#, fuzzy
-#~ msgid "Input is reversed: north,east"
-#~ msgstr "入力する座標値を反転(north,east)"
-#, fuzzy
-#~ msgid "Do not flag invalid east,north input lines as errors"
-#~ msgstr "領域外の座標が入力されても続行"
-#, fuzzy
-#~ msgid "Flag other input lines as errors"
-#~ msgstr "他の形式で入力があった場合は中止"
-#, fuzzy
-#~ msgid "Output in decimal degrees"
-#~ msgstr "10進数で出力"
-#, fuzzy
-#~ msgid "Converts geographic coordinates to Universal Transverse Mercator (UTM) coordinates."
-#~ msgstr "緯度/経度座標値からUTM座標値に変換します"
-#, fuzzy
-#~ msgid "utm zone (results will be forced into this zone)"
-#~ msgstr "UTMゾーン"
-#, fuzzy
-#~ msgid "Input is reversed: lat,lon"
-#~ msgstr "入力する座標値を反転(経度,緯度)"
-#, fuzzy
-#~ msgid "Do not flag invalid lon,lat input lines as errors"
-#, fuzzy
-#~ msgid "Suppress printing the utm zone"
-#~ msgstr "UTMゾーンを出力しない"
-#, fuzzy
-#~ msgid "Rotates elevation data extracted by either m.dted.extract or m.dmaUSGSread."
-#~ msgstr "抽出した標高データを90度回転します"
-#, fuzzy
-#~ msgid "Output file"
-#, fuzzy
-#~ msgid "Number of bytes per cell (i.e. per data value)"
-#~ msgstr "1セルのバイト数"
-#, fuzzy
-#~ msgid "Provides a terse description of level 1 and 2 digital terrain elevation data (DTED) files produced and distributed by the Defense Mapping Agency (DMA) on 1/2-inch magnetic tapes."
-#~ msgstr "1/2インチ磁気テープのデータからDTEDを簡易表示します"
-#, fuzzy
-#~ msgid "Name of tape drive device"
-#~ msgstr "入力するデバイス"
-#, fuzzy
-#~ msgid "Datum shift program. Return geographic coordinates based on a different datum that the one used to obtain the original coordinates. "
-#~ msgstr "楕円体間のデータシフトを行います"
-#, fuzzy
-#~ msgid "use block shift transformation (default)"
-#~ msgstr "ブロック変換によるシフト(デフォルト)"
-#, fuzzy
-#~ msgid "use bursa wolf 3d similarity transformation (not implemented)"
-#~ msgstr "BURSA変換によるシフト(未実装)"
-#, fuzzy
-#~ msgid "height above ellipsoid"
-#~ msgstr "長円からの高さ"
-#, fuzzy
-#~ msgid "input spheroid"
-#~ msgstr "元の楕円体"
-#, fuzzy
-#~ msgid "output spheroid"
-#~ msgstr "シフト先の楕円体"
-#, fuzzy
-#~ msgid "input datum"
-#~ msgstr "元のデータ"
-#, fuzzy
-#~ msgid "output datum"
-#~ msgstr "シフト先のデータ"
-#, fuzzy
-#~ msgid "x shift"
-#~ msgstr "X方向のシフト"
-#, fuzzy
-#~ msgid "y shift"
-#~ msgstr "Y方向のシフト"
-#, fuzzy
-#~ msgid "z shift"
-#~ msgstr "Z方向のシフト"
-#, fuzzy
-#~ msgid "Rx rotational parameter"
-#~ msgstr "スムージングパラメータ"
-#, fuzzy
-#~ msgid "Ry rotational parameter"
-#, fuzzy
-#~ msgid "Rz rotational parameter"
-#, fuzzy
-#~ msgid "Converts UTM coordinates falling within the current geographic region to geographic (latitude/longitude) coordinates. "
-#~ msgstr "現在の領域をUTM座標から緯度/経度座標に変換します"
-#, fuzzy
-#~ msgid "Flips elevation data extracted from systems that retrieve data by rows from south to north."
-#~ msgstr "抽出した標高データを180度回転します180度回転します"
-#, fuzzy
-#~ msgid "Number of bytes per cell (ie, per data value)"
-#, fuzzy
-#~ msgid "Finds geographic region information for U.S. Census Bureau TIGER input data."
-#~ msgstr "TMS(TIGER MAPPING SERVISE)に入力する地域情報データを検索します"
-#, fuzzy
-#~ msgid "Filename for raw tiger data (type 1)"
-#, fuzzy
-#~ msgid "UTM zone for this county"
-#~ msgstr "UTMゾーン"
-#, fuzzy
-#~ msgid "Provides a terse description of USGS Digital Elevation Model (DEM) data files stored on 1/2-inch magnetic tape."
-#~ msgstr "1/2インチ磁気テープのデータからDEMを簡易表示します"
-#, fuzzy
-#~ msgid "Tape input device"
-#, fuzzy
-#~ msgid "Blocksize of tape data"
-#~ msgstr "データのブロックサイズ"
-#, fuzzy
-#~ msgid "First file to examine"
-#~ msgstr "開始ファイル"
-#, fuzzy
-#~ msgid "Last file to examine"
-#~ msgstr "終了ファイル"
-#, fuzzy
-#~ msgid "y coordinate"
-#~ msgstr "Y座標値"
-#, fuzzy
-#~ msgid "max iterations"
-#~ msgstr "最大反復回数"
-#, fuzzy
-#~ msgid "Extracts digital terrain elevation data (DTED - levels 1 and 2) produced and supplied by the Defense Mapping Agency (DMA) on 1/2-inch magnetic tapes."
-#~ msgstr "1/2インチ磁気テープのデータからDTEDを抽出します"
-#, fuzzy
-#~ msgid "Name of header output file"
-#~ msgstr "ヘッダーを出力するファイル"
-#, fuzzy
-#~ msgid "North latitude of region to extract (format: %s)"
-#~ msgstr "北端(入力形式: %s)"
-#, fuzzy
-#~ msgid "South latitude of region to extract (format: %s)"
-#~ msgstr "南端(入力形式: %s)"
-#, fuzzy
-#~ msgid "East longitude of region to extract (format: %s)"
-#~ msgstr "東端(入力形式: %s)"
-#, fuzzy
-#~ msgid "West longitude of region to extract (format: %s)"
-#~ msgstr "西端(入力形式: %s)"
-#, fuzzy
-#~ msgid "Read the entire tape in all cases"
-#~ msgstr "すべてのテープを読み込む"
-#, fuzzy
-#~ msgid "Extracts USGS Digital Elevation Model (DEM) data from 1/2-inch magnetic tape."
-#~ msgstr "1/2インチ磁気テープのデータからDEMデータを抽出します"
-#, fuzzy
-#~ msgid "Input device or file"
-#~ msgstr "入力するデバイスまたはファイル"
-#, fuzzy
-#~ msgid "Output raster map (examine only if none specified)"
-#~ msgstr "出力するファイル(未入力の場合はチェックのみ)"
-#, fuzzy
-#~ msgid "First file to look at"
-#~ msgstr "開始ファイル"
-#, fuzzy
-#~ msgid "Last file to look at"
-#~ msgstr "終了ファイル"
-#, fuzzy
-#~ msgid "Selects a device (printer) for GRASS hardcopy output."
-#, fuzzy
-#~ msgid "list all available painters"
-#~ msgstr "ペインタの一覧表示"
-#, fuzzy
-#~ msgid "print name of currently selected painter"
-#, fuzzy
-#~ msgid "quietly select painter"
-#~ msgstr "説明なし"
-#, fuzzy
-#~ msgid "Color map output utility."
-#~ msgstr "ハードコピー出力の設定を行います"
-#, fuzzy
-#~ msgid "Align region to resolution [default = align to bounds]"
-#~ msgstr "境界を分解能に合わせる"
-#, fuzzy
-#~ msgid "Set region to match this sites map"
-#~ msgstr "設定に用いるサイトマップ"
-#, fuzzy
-#~ msgid "Value for the eastern edge "
-#~ msgstr "南端"
-#, fuzzy
-#~ msgid "Value for the western edge "
-#~ msgstr "西端"
-#, fuzzy
-#~ msgid "Grid resolution (both north-south and east-west)"
-#~ msgstr "格子の分解能"
-#, fuzzy
-#~ msgid "Overwrite <to> file(s)"
-#~ msgstr "上書き"
-#, fuzzy
-#~ msgid "Overwrite <new> file(s)"
-#~ msgstr "上書き"
-#, fuzzy
-#~ msgid "  vect   (binary vector maps)\n"
-#~ msgstr "  vect   (ベクトルマップ)\n"
-#, fuzzy
-#~ msgid "  icon   (paint icon files)\n"
-#~ msgstr "  icon   (ペイントアイコンファイル)\n"
-#, fuzzy
-#~ msgid "  labels (paint label files)\n"
-#~ msgstr "  labels (ペイントラベルファイル)\n"
-#, fuzzy
-#~ msgid "  sites  (site list files)\n"
-#~ msgstr "  sites  (サイトマップ)\n"
-#, fuzzy
-#~ msgid "  group  (imagery group files)\n"
-#~ msgstr "  group  (画像グループ)\n"
-#, fuzzy
-#~ msgid "  3dview (3D view parameters)\n"
-#~ msgstr "  3dview (3次元表示パラメータファイル)\n"
-#~ msgid "Do not export long colortable"
-#~ msgstr "大きいサイズのカラーテーブルをエクスポートしない"
-#~ msgid "unable to open new L map layer."
-#~ msgstr "新規の Lマップレイヤーが開けません"
-#~ msgid "unable to open new S map layer."
-#~ msgstr "新規の S マップレイヤーが開けません"
-#~ msgid ""
-#~ "Sorry, if any of the following options are set:\n"
-#~ "    basin, stream, half.basin, slope, or lS\n"
-#~ "    you MUST provide a value for the basin threshold parameter."
-#~ msgstr ""
-#~ "次のオプションのいずれかがセットされています:\n"
-#~ "    basin, stream, half.basin, slope, lS\n"
-#~ "    盆地境界パラメータの値を必ずしていする必要があります  "
-#~ msgid "SECTION 4: Length Slope determination."
-#~ msgstr "セクション 4: 長さ・傾斜の決定"
-#~ msgid "SECTION 3: Accumulating Surface Flow."
-#~ msgstr "セクション 3: 表層流の累計"
-#~ msgid "Default value: GRASS_GUI if defined otherwise tcltk"
-#~ msgstr "既定値: 定義されていればGRASS_GUI そうでなければtcltk  "
-#~ msgid "tcltk;Tcl/Tk based GUI - GIS Manager (gis.m);oldtcltk;Old Tcl/Tk based GUI - Display Manager (d.m);wxpython;wxPython based next generation GUI;text;command line interface only"
-#~ msgstr "tcltk;GUI に基づく Tcl/Tk - GIS管理者 (gis.m);oldtcltk;GUI に基づく Old Tcl/Tk - 表示管理者 (d.m);wxpython;次世代 GUIに基づくwxPython;テキスト;コマンドラインインターフェースのみ"
-#~ msgid "Input raster map contains cells with NULL-value (no-data). The value %d was used to represent no-data values in the input map. You can specify nodata value by %s parameter."
-#~ msgstr "入力したラスターマップはNULL値(データ無し)セルを含んでいます.この指定されたマップで値 %d はデータ無し値を示します.%s パラメーターでデータ無し値を指定できます"
-#~ msgid "Output aspect filename"
-#~ msgstr "方位を出力するファイル名"
-#~ msgid "vector, query"
-#~ msgstr "ベクトル,検索"
-#~ msgid "Exporting %i points/lines..."
-#~ msgstr "%i のポイント/ラインをエクスポート中、、、"
-#~ msgid "Computing row %d of covariance matrix..."
-#~ msgstr "共分散マトリックスの計算をしている行 %d..."
-#~ msgid "Feature type. Combination of types is not supported by all formats."
-#~ msgstr "地物の型. 複合型は全てのフォーマットでサポートされる訳ではありません"
-#~ msgid "%d faces found, but not requested to be exported. Verify 'type' parameter."
-#~ msgstr "%d の面がありますがエクスポートの指定がありません.'type' パラメーターを確認して下さい"
-#~ msgid "Create a MASK for limiting raster operation"
-#~ msgstr "制限ラスターオプションのMASKを作成する"
-#~ msgid "Cannot make stat of %s configuration file"
-#~ msgstr "%s 設定ファイルの統計を作成できません"
-#~ msgid "Illegal configuration file"
-#~ msgstr "不正な設定ファイル"
-#~ msgid "CHILD[pid = %i]: unable to open %s mask ... continue without!!!"
-#~ msgstr "CHILD[pid = %i]: %s マスクを開けません、、、何もしません!!!  "
-#~ msgid "r.li.worker (pid %i) exited with abnormal status %i"
-#~ msgstr "r.li.worker (pid %i) が異常状態 %i で終了"
-#~ msgid "r.li.worker (pid %i) terminated"
-#~ msgstr "r.li.worker (pid %i) は終了しました"
-#~ msgid "Seed [%d] larger than maximum [%d]"
-#~ msgstr "シード [%d] は最大値 [%d] より大きい"
-#~ msgid "Seed [%d] smaller than minimum [%d]"
-#~ msgstr "シード [%d] が最小値 [%d] より小さい"
-#~ msgid "point;simple x,y[,z] list;standard;GRASS's vector ASCII format"
-#~ msgstr "ポイント;単に x,y [,z] リスト;標準;GRASSのベクトルASCIIフォーマット"
-#~ msgid "Number of column used as y coordinate (first column is 1) for points mode"
-#~ msgstr "ポイントモードで y 座標に使う列の数(最初の列は1)"
-#~ msgid "Number of column used as z coordinate (first column is 1) for points mode"
-#~ msgstr "ポイントモードで z 座標に使う列の数(最初の列は1)"
-#~ msgid "If 0, z coordinate is not used"
-#~ msgstr "0の場合,z 座標は使用しない"
-#~ msgid "Number of column used as category (first column is 1) for points mode"
-#~ msgstr "ポイントモードでカテゴリーに使う列の数(最初の列は1)"
-#~ msgid "If 0, unique category is assigned to each row and written to new column 'cat'"
-#~ msgstr "0の場合,各行に1つだけのカテゴリーが指定されて新規に「cat」列が書き込まれます"
-#~ msgid "Create a new empty vector map and exit. Nothing is read from input"
-#~ msgstr "新規に空のベクトルマップを作成し、入力から読み込まない"
-#~ msgid "Show the category label in the grid cell(s)"
-#~ msgstr "グリッドセルでカテゴリーラベルを表示します"
-#~ msgid "Unable to read symbol, unable todisplay points"
-#~ msgstr "記号を読み込めません、ポイントを表示できません"
-#~ msgid "Converting %s..."
-#~ msgstr "%s を変換中... "
-#~ msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)"
-#~ msgstr "経路サンプリングメソッド (SIMWE) を用いた土砂流送、侵食/堆積のシミュレーション"
-#~ msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)"
-#~ msgstr "経路サンプリングメソッド(SIMWE)を用いた地表流の水文学シミュレーション"
-#~ msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation layer."
-#~ msgstr "指定された標高レイヤーをフィルタリングし,凹みのない標高マップと流れ方向マップを作成"
-#~ msgid "Calculates cast shadow areas from sun position and DEM. Either A: exact sun position is specified, or B: date/time to calculate the sun position by r.sunmask itself."
-#~ msgstr "太陽位置と DEM をもとに陰影領域を計算.r.sunmask 自身から,A: 正確な太陽位置の指定,または B: 太陽位置を計算するための日付/時刻を指定"
-#~ msgid "A: altitude of the sun above horizon, degrees"
-#~ msgstr "A: 水平からの太陽の高度、単位は度"
-#~ msgid "A: azimuth of the sun from the north, degrees"
-#~ msgstr "A: 北からの太陽の方位角 単位は度  "
-#~ msgid "B: minutes (0..60)"
-#~ msgstr "B: 分(0..60)  "
-#~ msgid "B: seconds (0..60)"
-#~ msgstr "B: 秒(0..60)  "
-#~ msgid "B: timezone (east positive, offset from GMT, also use to adjust daylight savings)"
-#~ msgstr "B: タイムゾーン(東が正, GMTオフセット、 サマータイム調整あり)  "
-#~ msgid "Creates topographic index [ln(a/tan(beta))] map from elevation map."
-#~ msgstr "標高マップからトポグラフィックインデックス [ln(a/tan(beta))] マップ を作成します.  "
-#~ msgid "New LOCATION name (not location path)"
-#~ msgstr "新しいロケーション名 (ロケーションパスではありません)  "
-#~ msgid "New GISDBASE (full path to the directory where the new location is)"
-#~ msgstr "新しいGISDBASE (新しいロケーションのあるディレクトリーへのフルパス)  "
-#~ msgid "Name for output file (do not add extension)"
-#~ msgstr "出力ファイル名(拡張を追加しないように)"
-#~ msgid "Width and height of output image"
-#~ msgstr "出力画像の幅と高さ"
-#~ msgid "Surface"
-#~ msgstr "曲面"
-#~ msgid "Volume"
-#~ msgstr "ボリューム"
-#, fuzzy
-#~ msgid "Import Mapgen or Matlab-ASCII vector maps into GRASS."
-#~ msgstr "MapgenあるいはMatlabベクトルマップをGRASSにインポート"
-#~ msgid "Vector map for which to edit attribute table"
-#~ msgstr "属性テーブルを編集するためのベクトルマップ"
-#~ msgid "Layer where to add column"
-#~ msgstr "列を追加するレイヤー"
-#~ msgid "Swapping header data"
-#~ msgstr "ヘッダデータの交換"
-#~ msgid "Exporting raster as double values (bytes=%d)"
-#~ msgstr "倍精度値としてラスターをエクスポート(バイト=%d)"
-#~ msgid "Reading map"
-#~ msgstr "マップの読み込み"
-#~ msgid "Signed data (high bit means negative value)"
-#~ msgstr "負の値を含む(最上位ビットが符号ビット) "
-#~ msgid "Number of bytes per cell (1, 2, 4)"
-#~ msgstr "1セルのバイト数(1, 2, 4) "
-#~ msgid "Parsing bytes per cell"
-#~ msgstr "1セルのバイト数 "
-#~ msgid "Byte Swapping Turned On."
-#~ msgstr "バイトスワップが有効です  "
-#~ msgid ""
-#~ "Missing parameters ...\n"
-#~ "Must provide at least[north= south= east= west=] OR [r=\tc=]"
-#~ msgstr ""
-#~ "パラメータが不足しています ...\n"
-#~ "[north= south= east= west=]の内の一つ以上、または[r=\tc=] を指定してください "
-#~ msgid "You have to provide all limits of geographic region (n,s,e,w)"
-#~ msgstr "地理領域の全ての制限設定をする必要があります(n, s, e, w)"
-#~ msgid "Illegal number of rows <%s>"
-#~ msgstr "無効な行の数 <%s> "
-#~ msgid "Illegal number of columns <%s>"
-#~ msgstr "無効な列の数 <%s> "
-#~ msgid "Using N=%f S=%f E=%f W=%f"
-#~ msgstr "使用する値 N=%f S=%f E=%f W=%f  "
-#~ msgid "Using rows=%d cols=%d\n"
-#~ msgstr "使用する値 rows=%d cols=%d\n"
-#~ msgid "File Size %d ... Total Bytes %d"
-#~ msgstr "ファイルサイズ %d ... Total Bytes %d  "
-#~ msgid "Try bytes=%d or adjusting input parameters"
-#~ msgstr "試行するbyte値=%d または、補正値の指定"
-#~ msgid "Conversion failed at row %d"
-#~ msgstr "行の変換に失敗 %d  "
-#~ msgid "Remove lines and areas smaller than threshold"
-#~ msgstr "閾値より小さいラインとエリアを除去"
-#~ msgid "%d boundaries were deleted, input areas are not preserved"
-#~ msgstr "%d 境界は削除されました, 入力領域は保存されていません"
-#~ msgid "Unable to calculate centroid for area %d"
-#~ msgstr "エリア %d のセントロイドを計算できません"
-#~ msgid "New centroids were calculated, attribute attachment may be changed"
-#~ msgstr "新しいセントロイドが計算されました, 属性添付が変更されている可能性があります"
-#~ msgid "Areas may have disappeared and/or area attribute attachment may have changed"
-#~ msgstr "エリアが消失しそして/もしくはエリア属性添付が変更している可能性があります"
-#~ msgid "Try v.clean tool=prune thresh=%f"
-#~ msgstr "v.clean tool=prune thresh=%f を試みます "
-#~ msgid ""
-#~ "\n"
-#~ "ERROR: Required parameter <%s> not set:\n"
-#~ "    (%s).\n"
-#~ msgstr ""
-#~ "\n"
-#~ "エラー: 要求されたパラメーター <%s> は設定されません:\n"
-#~ "    (%s).\n"
-#~ msgid "into  <%s@%s> (location <%s>) ... %s"
-#~ msgstr "へ  <%s@%s> (ロケーション <%s>) ... %s"
-#~ msgid "data compression required an additional"
-#~ msgstr "追加を要求されたデータ圧縮"
-#~ msgid "Rectified input raster map <%s> will be saved as <%s>"
-#~ msgstr "修正されたラスターマップ <%s>は <%s>として保存されます"
-#, fuzzy
-#~ msgid "Target information for group <%s> missing.\n"
-#~ msgstr "グループのターゲット情報 <%s>が見つかりません"
-#, fuzzy
-#~ msgid "Target location <%s> not found\n"
-#~ msgstr "ターゲットロケーション <%s> は見つかりません"
-#, fuzzy
-#~ msgid " %d rows, %d cols (%ld cells) completed in "
-#~ msgstr "%d 行, %d 列 (%ld セル) は完成しました "
-#, fuzzy
-#~ msgid " %.1f cells per minute\n"
-#~ msgstr "1分ごとの%.1f セル"
-#~ msgid "Location of input raster map"
-#~ msgstr "入力ラスターマップのロケーション "
-#~ msgid "Mapset of input raster map"
-#~ msgstr "入力するラスターマップのマップセット "
-#~ msgid "Checking location <%s>, mapset <%s>..."
-#~ msgstr "ロケーション <%s>、マップセット <%s> をチェックしています..."
-#~ msgid " %d.%02d.%02d, daynum %d, time: %02i:%02i:%02i (decimal time: %f)\n"
-#~ msgstr " %d.%02d.%02d, 日付 %d, 時間: %02i:%02i:%02i (小数以下の時間: %f)\n"
-#~ msgid " long: %f, lat: %f, timezone: %f\n"
-#~ msgstr "経度: %f, 緯度: %f, タイムゾーン: %f\n"
-#~ msgid ""
-#~ " Solar position: sun azimuth: %f,\n"
-#~ "   sun angle above horz.(refraction corrected): %f\n"
-#~ msgstr ""
-#~ " 太陽位置: 太陽方位: %f,\n"
-#~ "   地平線からの太陽高度.(屈折補正済み): %f\n"
-#~ msgid " Sunrise time (without refraction): %02d:%02d:%02d\n"
-#~ msgstr " 日の出時刻 (大気差を含まない): %02d:%02d:%02d\n"
-#~ msgid " Sunset time  (without refraction): %02d:%02d:%02d\n"
-#~ msgstr " 日の入時刻 (大気差を含まない):: %02d:%02d:%02d\n"
-#~ msgid "No map calculation requested. Finished.\n"
-#~ msgstr "マップ計算が要求されませんでした。終了します.\n"
-#~ msgid "Can't open range file for %s"
-#~ msgstr " %s に対する範囲fileが開けません"
-#~ msgid "Can't read row in input elevation map"
-#~ msgstr "入力した標高マップから行を読み取れません"
-#~ msgid "<%s> created"
-#~ msgstr "<%s> 作成されました"
-#~ msgid "You have to use a different location for input than the current"
-#~ msgstr "入力には現在とは違ったロケーションを使用してください"
-#~ msgid "Raster map to be recoded"
-#~ msgstr "記録するラスターマップ"
-#~ msgid "Unable to open rules file <%s>"
-#~ msgstr "ルールファイル <%s> を開けません"
-#~ msgid "Displays and overlays raster map layers in the active display frame on the graphics monitor."
-#~ msgstr "グラフィックモニターでアクティブな表示フレームに、ラスターマップレイヤーを重ねて表示します"
-#~ msgid "Raster map to be displayed"
-#~ msgstr "表示するラスターマップ"
-#~ msgid "Displays vector data in the active frame on the graphics monitor."
-#~ msgstr "グラフィックモニター上で動作中のフレームにベクトルデータを表示します"
-#~ msgid "Area size [%.1e], area not imported"
-#~ msgstr "領域サイズ [%.1e], 領域はインポートされていません"
-#~ msgid "Island size [%.1e], island not imported"
-#~ msgstr "島のサイズ [%.1e], 島はインポートされていません"
-#~ msgid "vector, projection"
-#~ msgstr "ベクトル,投影"
-#~ msgid "Allows projection conversion of vector maps."
-#~ msgstr "ベクトルマップの矢の投影変換"
-#~ msgid "Duplicate area centroids"
-#~ msgstr "重複するエリアセントロイド"
-#~ msgid "Vector output map"
-#~ msgstr "ベクトル出力マップ"
-#~ msgid "Error while writing to temp file"
-#~ msgstr "一時ファイルに書き込み中のエラー"
-#~ msgid "Error writing row %d"
-#~ msgstr "行の書き込みエラー %d"
-#~ msgid "Poorly placed psuedo control points. "
-#~ msgstr "不完全に設置された疑似コントロールポイント"
-#~ msgid "Cannot generate the transformation equation."
-#~ msgstr "変換方程式が作成できません"
-#~ msgid "No active psuedo control points"
-#~ msgstr "アクティブな疑似コントロールマップはありません"
-#~ msgid "Unable to write temp file: %s"
-#~ msgstr "一時ファイルに書き込みできません: %s"
-#~ msgid "Unable to open map %s"
-#~ msgstr "マップが開けません %s"
-#~ msgid "Unable to write row %d"
-#~ msgstr "行に書き込みできません %d"
-#~ msgid "Unable to write raster map. You might want to check available disk space and write permissions."
-#~ msgstr "ラスターマップを書き込めません。利用できるディスクを確認し、許可を書き込んでください。"
-#~ msgid "Please select the file(s) you wish to rectify by naming an output file"
-#~ msgstr "出力ファイルに名づけて修正したいファイルを選択してください"
-#~ msgid "%s@%s: projection doesn't match current settings"
-#~ msgstr "%s@%s: 投影は現在の設定と一致していません"
-#~ msgid "%s@%s: zone doesn't match current settings"
-#~ msgstr "%s@%s: ゾーンは現在の設定と一致していません"
-#~ msgid "New MAPSET name"
-#~ msgstr "新しいマップセット名"
-#~ msgid "Failed in attempt to open %s"
-#~ msgstr "%s を開けませんでした"
-#~ msgid "Generates raster map layers of slope, aspect, curvatures and partial derivatives from a raster map layer of true elevation values. Aspect is calculated counterclockwise from east."
-#~ msgstr "真の標高値ラスターマップレイヤーから、斜面、方位、曲面、偏導関数のラスターマップを作成します. 方位は東から反時計回りに計算します"
-#~ msgid "Output slope filename"
-#~ msgstr "傾斜を出力するファイル名"
-#~ msgid "Output profile curvature filename"
-#~ msgstr "断面曲率を出力するファイル名"
-#~ msgid "Output tangential curvature filename"
-#~ msgstr "正接曲率を出力するファイル名"
-#~ msgid "Output first order partial derivative dx (E-W slope) filename"
-#~ msgstr "一次の偏導関数 dx (E-W 傾斜) を出力するファイル名"
-#~ msgid "Output first order partial derivative dy (N-S slope) filename"
-#~ msgstr "一次の偏導関数 dy (N-S 傾斜) を出力するファイル名"
-#~ msgid "Output second order partial derivative dxx filename"
-#~ msgstr "二次の偏導関数 dxx を出力するファイル名"
-#~ msgid "Output second order partial derivative dyy filename"
-#~ msgstr "二次の偏導関数 dyy を出力するファイル名"
-#~ msgid "Output second order partial derivative dxy filename"
-#~ msgstr "二次の偏導関数 dxy を出力するファイル名"
-#~ msgid "wrong type: %s"
-#~ msgstr "間違ったタイプ: %s"
-#~ msgid "Creating support files..."
-#~ msgstr "サポートファイルを作成中..."
-#~ msgid "Elevation products for mapset [%s] in [%s]"
-#~ msgstr "マップセット [%s] ([%s] 内)の標高のプロダクト"
-#~ msgid "ASPECT [%s] COMPLETE"
-#~ msgstr "方位 [%s] 完了"
-#~ msgid "SLOPE [%s] COMPLETE"
-#~ msgstr "傾斜 [%s] 完了"
-#~ msgid "PROFILE CURVE [%s] COMPLETE"
-#~ msgstr "プロファイル曲線 [%s] 完了"
-#~ msgid "TANGENTIAL CURVE [%s] COMPLETE"
-#~ msgstr "正接曲線 [%s] 完了"
-#~ msgid "E-W SLOPE [%s] COMPLETE"
-#~ msgstr "E-W 傾斜 [%s] 完了"
-#~ msgid "N-S SLOPE [%s] COMPLETE"
-#~ msgstr "N-S 傾斜 [%s] 完了"
-#~ msgid "DXX [%s] COMPLETE"
-#~ msgstr "DXX [%s] 完了"
-#~ msgid "DYY [%s] COMPLETE"
-#~ msgstr "DYY [%s] 完了"
-#~ msgid "DXY [%s] COMPLETE"
-#~ msgstr "DXY [%s] 完了"
-#~ msgid "Generates a raster map layer showing watershed subbasins."
-#~ msgstr "分水域を示すラスターマップを作成します "
-#~ msgid "Coded stream network file name"
-#~ msgstr "河川ファイル"
-#~ msgid "Thinned ridge network file name"
-#~ msgstr "分水稜ファイル "
-#~ msgid "Name for the resultant watershed partition file"
-#~ msgstr "出力する分水界ファイル "
-#~ msgid "Output raster map having shadows"
-#~ msgstr "出力する影のラスターマップ名"
-#~ msgid "By_position"
-#~ msgstr "位置を使う  "
-#~ msgid "B: year (1950..2050)"
-#~ msgstr "B: 年(1950..2050)  "
-#~ msgid "By_time"
-#~ msgstr "By_time  "
-#~ msgid "B: month (0..12)"
-#~ msgstr "B: 月(0..12)  "
-#~ msgid "B: day (0..31)"
-#~ msgstr "B: 日(0..31)  "
-#~ msgid "B: hour (0..24)"
-#~ msgstr "B: 時(0..24)  "
-#~ msgid "East coordinate (point of interest, default: map center)"
-#~ msgstr "東西座標(POI、既定値はマップ中心)"
-#~ msgid "North coordinate (point of interest, default: map center)"
-#~ msgstr "南北座標(POI、既定値はマップ中心)"
-#~ msgid "Zero is a real elevation"
-#~ msgstr "ゼロは実際の標高"
-#~ msgid "raster, terrain analysis"
-#~ msgstr "ラスター、地形分析"
-#~ msgid "                No topology present"
-#~ msgstr "地形がありません"
-#~ msgid "Uses a GRASS vector points map to produce a convex hull vector map."
-#~ msgstr "GRASSのベクトルポイントマップを使用して凸包ベクトルマップを作成"
-#~ msgid "Name of input vector points map"
-#~ msgstr "指定するベクトルポイントマップ名"
-#~ msgid "Name of output vector area map"
-#~ msgstr "出力するベクトルエリアマップ名"
-#~ msgid "Cannot open vector map <%s>"
-#~ msgstr "ベクトルマップ <%s> を開けません"
-#~ msgid "Experimental NVIZ CLI prototype."
-#~ msgstr "実験段階の NVIZ CLI 試作品"
-#~ msgid "It was impossible to create <Auxiliar_outlier_table>."
-#~ msgstr "<Auxiliar_outlier_table>は作成できませんでひた.  "
-#~ msgid "It was not possible to drop <%s> table. Nothing will be done. Try to drop it manually."
-#~ msgstr "<%s> 表をドロップできませんでした. 何も変更されません. 手動でドロップしてください.  "
-#~ msgid "Cross Validation was success!"
-#~ msgstr "交差検証は成功しました!  "
-#~ msgid "Interpolation: The region resolution is too high: %d cells. Consider to change it."
-#~ msgstr "補間: この領域の解像度は高すぎます: %d セル. 変更してください."
-#~ msgid "Creating auxiliar table for archiving overlapping zones"
-#~ msgstr "重複する地域のためauxiliar表を作成しています"
-#~ msgid "<Auxiliar_edge_table> created in database."
-#~ msgstr "<Auxiliar_edge_table> はデータベースに作成されました."
-#~ msgid "Unable to open table <%s_edge_Interpolation>"
-#~ msgstr "表 <%s_edge_Interpolation> を開けません"
-#~ msgid "M.Q. solution"
-#~ msgstr "M.Q.ソリューション"
-#~ msgid "3-d data in dxf file. Polyline_flag: %d"
-#~ msgstr " dxf fileの3-d データ. Polyline_flag: %d  "
-#~ msgid "Selects data from table."
-#~ msgstr "テーブルからデータを選択"
-#~ msgid "Unable to open MASK"
-#~ msgstr "マスクを開けません"
-#~ msgid "Name of the longitude input raster map [decimal degrees]"
-#~ msgstr "経度入力ラスターマップ名(小数点付の度) "
-#~ msgid "Starting map [%s]"
-#~ msgstr "マップを開始 [%s]"
-#~ msgid "Percent done:"
-#~ msgstr "完了率(パーセント)"
-#~ msgid "Starting filter #%d, distance: %.*lf, exponent: %.*lf, flat: %.*lf"
-#~ msgstr "フィルタリングを開始 #%d, 距離: %.*lf,指数: %.*lf,均一: %.*lf  "
-#~ msgid ""
-#~ "%s: saving [%s] raster map layer.\n"
-#~ "Percent complete:"
-#~ msgstr ""
-#~ "%s: 保存しています・・・[%s] ラスタマップレイヤー.\n"
-#~ "パーセント終了:  "
-#~ msgid "Number of column used as x coordinate (first column is 1) for points mode"
-#~ msgstr "ポイントモードで x 座標に使う列の数(最初の列は1)"
-#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares)"
-#~ msgstr "単位 "
-#~ msgid "Allocation memory for bilinear interpolation"
-#~ msgstr "双線形補間のための割り当てメモリー"
-#~ msgid "Allocation memory for bicubic interpolation"
-#~ msgstr "バイキュービック補間のための割り当てメモリー  "
-#~ msgid "No raster nor vector output"
-#~ msgstr "ラスターもベクトル出力もありません"
-#~ msgid "No data within this subzone. Consider changing the spline step."
-#~ msgstr "このサブゾーン内にデータはありません. スプラインステップを変更してみてください.  "
-#~ msgid "Mean's calculation"
-#~ msgstr "平均値の計算"
-#~ msgid "Bad format in initial exposusre station file for group [%s]"
-#~ msgstr "グループ [%s]の初期暴露駅ファイルの不正なフォーマット"
-#~ msgid "Name of elevation raster map"
-#~ msgstr "標高ラスターマップ名"
-#~ msgid "Input raster map contains cells with NULL-value (no-data). The value %g was used to represent no-data values in the input map. You can specify nodata value by %s parameter."
-#~ msgstr "入力したラスターマップはNULL値(データ無し)セルを含んでいます.この指定されたマップで値 %g はデータ無し値を示します.%s パラメーターでデータ無し値を指定できます"
-#~ msgid "douglas;Douglas-Peucker Algorithm;douglas_reduction;Douglas-Peucker Algorithm with reduction parameter;lang;Lang Simplification Algorithm;reduction;Vertex Reduction Algorithm eliminates points close to each other;reumann;Reumann-Witkam Algorithm;remove_small;Removes lines shorter than threshold and areas of area less than threshold;boyle;Boyle's Forward-Looking Algorithm;sliding_averaging;McMaster's Sliding Averaging Algorithm;distance_weighting;McMaster's Distance-Weighting Algorithm;chaiken;Chaiken's Algorithm;hermite;Interpolation by Cubic Hermite Splines;snakes;Snakes method for line smoothing;network;Network generalization;displacement;Displacement of lines close to each other;"
-#~ msgstr "douglas;Douglas-Peucker アルゴリズム;douglas_reduction;縮小パラメーターをもつDouglas-Peucker アルゴリズム;lang;Lang Simplification アルゴリズム;縮小;Vertex Reduction アルゴリズムは互いに近いポイントを削除します;reumann;Reumann-Witkam アルゴリズム;remove_small;閾値と閾値より小さいエリアより短いラインを除去;boyle;Boyle's Forward-Looking アルゴリズム;sliding_averaging;McMaster's Sliding Averaging アルゴリズム;distance_weighting;McMaster's Distance-Weighting アルゴリズム;chaiken;Chaiken's アルゴリズム;hermite;Cubic Hermite Splinesによる補間;snakes;ラインスムージングのスネークメソッド;ネットワーク;ネットワーク汎化;置換;互いに近いラインの置換;"
-#~ msgid "Number of vertices was reduced from %d to %d [%d%%]"
-#~ msgstr "頂点の数は %d から %d [%d%%] に減少されました"
-#~ msgid ""
-#~ "Input raster map <%s> does not exist in group <%s>.\n"
-#~ " Try:\n"
-#~ msgstr ""
-#~ "入力するラスターマップ <%s> はグループ <%s>にありません\n"
-#~ " 再試行:\n"
-#~ msgid "Band to select"
-#~ msgstr "選択するバンド"
+#~ msgid "Skipping all boundaries that are not part of an area."
+#~ msgstr "エリアの一部ではない全ての境界をスキップします"
Modified: grass/trunk/locale/po/grasswxpy_ja.po
--- grass/trunk/locale/po/grasswxpy_ja.po	2012-03-05 08:14:15 UTC (rev 50993)
+++ grass/trunk/locale/po/grasswxpy_ja.po	2012-03-05 08:16:45 UTC (rev 50994)
@@ -12,8 +12,8 @@
 "Project-Id-Version: grasswxpy_ja\n"
 "Report-Msgid-Bugs-To: \n"
 "POT-Creation-Date: 2012-01-28 11:12+0100\n"
-"PO-Revision-Date: 2012-02-08 19:40+0900\n"
-"Last-Translator: taniguchi <taniguti at apptec.co.jp>\n"
+"PO-Revision-Date: 2012-03-05 11:25+0900\n"
+"Last-Translator: Naoki Ueda <nao at locapoint.com>\n"
 "Language-Team: Japanese <grass-translations at lists.osgeo.org>\n"
 "Language: ja\n"
 "MIME-Version: 1.0\n"
@@ -906,9 +906,9 @@
 msgstr "このモジュールはインポートされないNumpyモジュールを必要とします. おそらくインストールされていません(標準的なPython分布の一環ではありません). ソースまたはバイナリのダウンロードに関する情報は数値Pythonのサイト(http://numpy.scipy.org)を参照してください"
 #: ../gui/wxpython/nviz/wxnviz.py:50
-#, fuzzy, python-format
+#, python-format
 msgid "3D view mode: %s\n"
-msgstr "3Dビューモードツール"
+msgstr "3Dビューモード: %s\n"
 #: ../gui/wxpython/nviz/wxnviz.py:323 ../gui/wxpython/nviz/wxnviz.py:334
 #: ../gui/wxpython/modules/histogram.py:333
@@ -2119,7 +2119,7 @@
 msgstr "マップセットの作成ができません: %s "
 #: ../gui/wxpython/gis_set.py:737
+#, python-format
 msgid ""
 "GRASS is already running in selected mapset <%(mapset)s>\n"
 "(file %(lock)s found).\n"
@@ -2129,7 +2129,7 @@
 "Do you want to try to remove .gislock (note that you need permission for this operation) and continue?"
 msgstr ""
 "GRASS は選択されたマップセット <%(mapset)s> で既に動作しています\n"
-"(ファイル %(lock)が存在します).\n"
+"(ファイル %(lock)sが存在します).\n"
 "\n"
 "同時使用はできません。\n"
 "\n"
@@ -2145,6 +2145,9 @@
 "\n"
 "If you really are running another GRASS session doing this could corrupt your data. Have another look in the processor manager just to be sure..."
 msgstr ""
+"本当によろしいですか?\n"
+"\n"
+"他にGRASSのセッションが動作中であれば、データを破損する可能性があります。タスクマネージャにて再度確認してください..."
 #: ../gui/wxpython/gis_set.py:766
 #, python-format
@@ -2347,12 +2350,10 @@
 #: ../gui/wxpython/dbmgr/manager.py:873
 #: ../gui/wxpython/modules/colorrules.py:983
-#, fuzzy
 msgid "Add column"
 msgstr "列追加"
 #: ../gui/wxpython/dbmgr/manager.py:881 ../gui/wxpython/dbmgr/manager.py:932
-#, fuzzy
 msgid "Column"
 msgstr "列"
@@ -2363,7 +2364,6 @@
 msgstr "タイプ"
 #: ../gui/wxpython/dbmgr/manager.py:908
-#, fuzzy
 msgid "Length"
 msgstr "長さ"
@@ -3822,6 +3822,10 @@
 "\n"
 "Option <%(opt)s>: read from standard input is not supported by wxGUI"
 msgstr ""
+"次のコマンドを実行できません:\n"
+"%(cmd)s\n"
+"\n"
+"オプション <%(opt)s>: wxGUIでは標準入力からの読込はサポートされていません"
 #: ../gui/wxpython/gui_core/goutput.py:634
 msgid "Save file as..."
@@ -3894,11 +3898,13 @@
 msgstr "ベクトルマップを作れません <%s>"
 #: ../gui/wxpython/gui_core/dialogs.py:404
+#, python-format
 msgid ""
 "Invalid or empty key column.\n"
 "Unable to create vector map <%s>."
-msgstr "ベクトルマップを作れません <%s>"
+msgstr ""
+"不正もしくは空のキー項目\n"
+"ベクトルマップを作れません <%s>"
 #: ../gui/wxpython/gui_core/dialogs.py:431
 #, python-format
@@ -4840,14 +4846,12 @@
 msgstr "Vis5Dのエクスポート "
 #: ../gui/wxpython/menustrings.py:147
-#, fuzzy
 msgid "Exports GRASS 3D raster map to 3-dimensional Vis5D file."
-msgstr "GRASS 3D ラスターマップを3D Vis5D ファイルにエキスポート "
+msgstr "GRASS 3D ラスターマップを3D Vis5D ファイルにエクスポート "
 #: ../gui/wxpython/menustrings.py:149
-#, fuzzy
 msgid "Converts 3D raster maps into the VTK-ASCII format."
-msgstr "ラスターマップを VTK-Ascii フォーマットへ変換"
+msgstr "3Dラスターマップを VTK-Ascii フォーマットへ変換"
 #: ../gui/wxpython/menustrings.py:150
 msgid "Export database table"
@@ -4909,18 +4913,16 @@
 msgstr "リスト "
 #: ../gui/wxpython/menustrings.py:166
-#, fuzzy
 msgid "Lists available GRASS data base files of the user-specified data type."
-msgstr "現在使用できるマップが出力可能な形式の一覧を表示 "
+msgstr "ユーザーが指定したデータ型の、現在使用できるGRASSデータベースファイルの一覧を表示 "
 #: ../gui/wxpython/menustrings.py:167
 msgid "List filtered"
 msgstr "フィルター "
 #: ../gui/wxpython/menustrings.py:168
-#, fuzzy
 msgid "Lists available GRASS data base files of the user-specified data type optionally using the search pattern."
+msgstr "ユーザーが検索オプションを使って指定したデータ型の、現在使用できるGRASSデータベースファイルの一覧を表示 "
 #: ../gui/wxpython/menustrings.py:170
 msgid "Renames data base element files in the user's current mapset."
@@ -5042,13 +5044,12 @@
 msgstr "nviz - GRASSの視覚化&アニメーションツール "
 #: ../gui/wxpython/menustrings.py:200
-#, fuzzy
 msgid "3D image rendering"
-msgstr "自動レンダリングを有効にする"
+msgstr "3Dイメージのレンダリング"
 #: ../gui/wxpython/menustrings.py:201
 msgid "Creates a 3D rendering of GIS data."
-msgstr ""
+msgstr "GISデータの3Dレンダリングを作成する"
 #: ../gui/wxpython/menustrings.py:202
 msgid "Bearing/distance to coordinates"
@@ -5214,31 +5215,28 @@
 #: ../gui/wxpython/menustrings.py:246
 msgid "Install extension from add-ons"
-msgstr "アドオンのエクステンションをインストール"
+msgstr "アドオンをインストール"
 #: ../gui/wxpython/menustrings.py:247
-#, fuzzy
 msgid "Installs new extension from GRASS AddOns SVN repository."
-msgstr "GRASSのアドオン SVNレポジトリから新しいエクステンションをインストール"
+msgstr "GRASSのアドオン SVNレポジトリから新しいアドオンをインストール"
 #: ../gui/wxpython/menustrings.py:248
-#, fuzzy
 msgid "Update installed extensions"
-msgstr "拡張子リスト"
+msgstr "インストールされたアドオンを更新する"
 #: ../gui/wxpython/menustrings.py:249
 msgid "Rebuilds all locally installed GRASS Addons extensions."
-msgstr ""
+msgstr "ローカルにインストールされた全てのGRASSアドオンをリビルドする"
 #: ../gui/wxpython/menustrings.py:250
 #: ../gui/wxpython/modules/extensions.py:463
-#, fuzzy
 msgid "Remove extension"
-msgstr "頂点の削除 "
+msgstr "拡張機能の削除 "
 #: ../gui/wxpython/menustrings.py:251
 msgid "Removes installed GRASS AddOns extension."
-msgstr ""
+msgstr "インストールされたGRASSアドオンを削除する"
 #: ../gui/wxpython/menustrings.py:252 ../gui/wxpython/menustrings.py:906
 msgid "Preferences"
@@ -6321,7 +6319,6 @@
 msgstr "線形回帰"
 #: ../gui/wxpython/menustrings.py:520
-#, fuzzy
 msgid "Calculates linear regression from two raster maps: y = a + b*x."
 msgstr "2つのラスターマップでの線形回帰計算: y = a + b*x"
@@ -6919,7 +6916,6 @@
 msgstr "ポイントの位置のベクトルの値をテーブルにアップロード"
 #: ../gui/wxpython/menustrings.py:671
-#, fuzzy
 msgid "Update database values from vector"
 msgstr "ベクトルのフィーチャからデータベースの値を設定"
@@ -7208,9 +7204,8 @@
 msgstr "高速フーリエ逆変換を行います "
 #: ../gui/wxpython/menustrings.py:743
-#, fuzzy
 msgid "Satellite images tools"
-msgstr "イメージサイズの設定"
+msgstr "衛星画像ツール"
 #: ../gui/wxpython/menustrings.py:744
 msgid "Aster DN to radiance/reflectance"
@@ -7274,7 +7269,7 @@
 #: ../gui/wxpython/menustrings.py:758
 msgid "Satellite images products"
-msgstr ""
+msgstr "衛星画像製品"
 #: ../gui/wxpython/menustrings.py:759
 #, fuzzy
@@ -7513,9 +7508,8 @@
 msgstr "3Dグリッド統計"
 #: ../gui/wxpython/menustrings.py:819
-#, fuzzy
 msgid "Generates volume statistics for 3D raster maps."
-msgstr "3Dラスターマップにおいて統計解析値を作成"
+msgstr "3Dラスターマップにおいてボリューム統計解析値を作成"
 #: ../gui/wxpython/menustrings.py:820
 msgid "Univariate statistics for volumes"
@@ -8530,9 +8524,9 @@
 msgstr "ベクトル設定"
 #: ../gui/wxpython/psmap/dialogs.py:3231
+#, python-format
 msgid "%s properties"
-msgstr "プロパティ "
+msgstr "%s プロパティ "
 #: ../gui/wxpython/psmap/dialogs.py:3282
 msgid "Data selection"
@@ -8720,9 +8714,9 @@
 msgstr "ラスターマップの選択:"
 #: ../gui/wxpython/psmap/dialogs.py:4146 ../gui/wxpython/psmap/dialogs.py:4832
+#, python-format
 msgid "%(rast)s: type %(type)s"
-msgstr "%(rast): タイプ %(type)"
+msgstr "%(rast)s: タイプ %(type)s"
 #: ../gui/wxpython/psmap/dialogs.py:4165
 msgid "Type of legend"
@@ -9498,7 +9492,6 @@
 msgstr "拡張子リスト"
 #: ../gui/wxpython/modules/extensions.py:58
-#, fuzzy
 msgid "Fetch full info including description and keywords"
 msgstr "説明やキーワードなど完全な情報を取得(時間がかかります)"
@@ -9536,29 +9529,24 @@
 msgstr "GRASSアドオンのSVN(患者が)からモジュールのリストを取得中(お待ちください)..."
 #: ../gui/wxpython/modules/extensions.py:388
-#, fuzzy
 msgid "Uninstall GRASS Addons extensions"
-msgstr "拡張子リスト"
+msgstr "GRASS アドオンGRASSモジュールのアンインストール"
 #: ../gui/wxpython/modules/extensions.py:397
-#, fuzzy
 msgid "List of installed extensions"
-msgstr "拡張子リスト"
+msgstr "インストールされたアドオンGRASSモジュールの一覧"
 #: ../gui/wxpython/modules/extensions.py:403
-#, fuzzy
 msgid "&Uninstall"
-msgstr "インストール(&I)"
+msgstr "アンインストール(&U)"
 #: ../gui/wxpython/modules/extensions.py:404
-#, fuzzy
 msgid "Uninstall selected AddOns extensions"
-msgstr "選択されたアドオンGRASSモジュールのインストール"
+msgstr "選択されたアドオンGRASSモジュールのアンインストール"
 #: ../gui/wxpython/modules/extensions.py:451
-#, fuzzy
 msgid "No extension selected for removal. Operation canceled."
-msgstr "マップレイヤーが選択されていません 処理はキャンセルされました "
+msgstr "削除するアドオンGRASSモジュールが選択されていません 処理はキャンセルされました "
 #: ../gui/wxpython/modules/extensions.py:460
 #, python-format
@@ -9568,11 +9556,14 @@
 "\n"
 "Do you want really to remove <%(ext)s> extension?"
 msgstr ""
+"削除されるファイル一覧:\n"
+"%(files)s\n"
+"\n"
+"これらの拡張機能 <%(ext)s> を本当に削除しますか?"
 #: ../gui/wxpython/modules/extensions.py:488
-#, fuzzy
 msgid "Extension"
-msgstr "発光度"
+msgstr "拡張機能"
 #: ../gui/wxpython/modules/vclean.py:31 ../gui/wxpython/modules/vclean.py:113
 msgid "Set up vector cleaning tools"
@@ -12562,9 +12553,8 @@
 msgstr "中間データ削除"
 #: ../gui/wxpython/gmodeler/preferences.py:50
-#, fuzzy
 msgid "Item properties"
-msgstr "データプロパティ"
+msgstr "アイテムのプロパティ"
 #: ../gui/wxpython/gmodeler/preferences.py:58
 msgid "Disabled:"
@@ -12607,7 +12597,7 @@
 #: ../gui/wxpython/gmodeler/preferences.py:321
 msgid "Loop"
-msgstr ""
+msgstr "ループ"
 #: ../gui/wxpython/gmodeler/preferences.py:430
 msgid "Commands"
@@ -12977,9 +12967,9 @@
 msgstr "不明なタグ"
 #: ../gui/wxpython/core/utils.py:297
+#, python-format
 msgid "Vector map <%(map)s>: %(msg)s\n"
-msgstr "新しいベクトルマップ <%s> が作成されました"
+msgstr "ベクトルマップ <%(map)s>: %(msg)s\n"
 #: ../gui/wxpython/core/utils.py:520
 #, python-format
@@ -13208,42 +13198,37 @@
 msgid "Unable to render overlay <%s>"
 msgstr "<%s> をレンダーオーバーレイできません"
-#, fuzzy
 msgid ""
 "No attribute table linked to vector map <%(vector)s> found. %(msg)s\n"
 "\n"
 "New attribute table can be created by Attribute Table Manager."
 msgstr ""
 "ベクトルマップ <%(vector)s>とリンクした属性テーブルが見つかりません%(msg)s\n"
-"このメッセージはデジタイザ設定か属性テーブルマネージャー機能を利用してベクトルマップと属性テーブルのリンク付けをする事で消すことができます"
+"\n"
+"属性テーブルマネージャー機能を利用して新しい属性テーブルを作成する事ができます"
-#, fuzzy
 msgid ""
 "No layers marked for import.\n"
 "Operation canceled."
+msgstr ""
+"マップレイヤーが選択されていません\n"
+"処理はキャンセルされました "
-#, fuzzy
 msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
-msgstr "3D ASCII ラスターテキストファイルを 3Dラスターマップレイヤーへインポート "
+msgstr "3D ASCII ラスターテキストファイルを (バイナリ)3Dラスターマップレイヤーへインポート "
-#, fuzzy
 msgid "Imports 3-dimensional Vis5D files (i.e. the V5D file with 1 variable and 1 time step)."
 msgstr "3D Vis5Dファイルのインポート (つまり1変数と1タイムステップを使用したv5dファイル) "
-#, fuzzy
 msgid "Converts a 3D raster map layer into an ASCII text file."
 msgstr "3D ラスターマップをASCIIテキストファイルに変換"
-#, fuzzy
 msgid "Topographic correction"
-msgstr "大気補正 "
+msgstr "地形的補正 "
-#, fuzzy
 msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map."
 msgstr "2D標高マップに基づいた3Dラスターから2Dのラスター断面マップを作成"
-#, fuzzy
 msgid "Calculates numerically transient, confined groundwater flow in three dimensions."
 msgstr "3次元の地下水の流れに限定した一時的な数値解析プログラム "
@@ -14059,13 +14044,11 @@
 msgid "Set ground control points (GCPs)"
 msgstr "GCP(地上基準点)の定義"
-#, fuzzy
 msgid "Topology maintenance"
-msgstr "サポートファイルの保守 "
+msgstr "トポロジーの保守 "
-#, fuzzy
 msgid "Feature selection"
-msgstr "断面図"
+msgstr "フィーチャーの選択"
 #~ msgid "Unable to switch to location <%(loc)s> mapset <%(mapset)s>."
 #~ msgstr "ロケーション <%(loc)s> マップセット <%(mapset)s> へ変更できません."
@@ -15005,3 +14988,9 @@
 #~ msgid "All data records (%d) will permanently deleted from table. Do you want to delete them?"
 #~ msgstr "全てのレコード (%d) は、テーブルから完全に消去されます  削除してよろしいですか?"
+#~ msgid "'%(cmd)s' failed. Details: %(det)s"
+#~ msgstr "'%(cmd)s' が失敗しました。 詳細: %(det)s"
+#~ msgid "Computes topographic correction of reflectance."
+#~ msgstr "反射率の地形的補正を計算する"
