[GRASS-SVN] r50998 - grass/trunk/scripts/v.build.all
Tue Mar 6 08:42:51 EST 2012
Author: martinl
Date: 2012-03-06 05:42:51 -0800 (Tue, 06 Mar 2012)
New Revision: 50998
   grass/trunk/scripts/v.build.all/v.build.all.py
v.build.all: prettified message ('-' * 80)
Modified: grass/trunk/scripts/v.build.all/v.build.all.py
--- grass/trunk/scripts/v.build.all/v.build.all.py	2012-03-05 21:58:34 UTC (rev 50997)
+++ grass/trunk/scripts/v.build.all/v.build.all.py	2012-03-06 13:42:51 UTC (rev 50998)
@@ -37,8 +37,8 @@
     i = 1
     for vect in vectors:
 	map = "%s@%s" % (vect, mapset)
-	grass.message(_("Build topology for vector map <%s> (%d of %d)...") % \
-                          (map, i, num_vectors))
+	grass.message(_("%s\nBuild topology for vector map <%s> (%d of %d)...\n%s") % \
+                          ('-' * 80, map, i, num_vectors, '-' * 80))
 	grass.verbose(_("v.build map=%s") % map)
 	if grass.run_command("v.build", map = map, quiet = quiet) != 0:
             grass.error(_("Building topology for vector map <%s> failed") % map)
