[GRASS-SVN] r51002 - in grass-addons: . models
svn_grass at osgeo.org
Wed Mar 7 07:12:36 EST 2012
Author: martinl
Date: 2012-03-07 04:12:35 -0800 (Wed, 07 Mar 2012)
New Revision: 51002
Added:
grass-addons/models/
grass-addons/models/README
grass-addons/models/atcorr_g6.gxm
addons: add directory for models (wxGUI modeler files)
Added: grass-addons/models/README
--- grass-addons/models/README (rev 0)
+++ grass-addons/models/README 2012-03-07 12:12:35 UTC (rev 51002)
@@ -0,0 +1,7 @@
+User-defined models for wxGUI Modeler
+(http://grass.osgeo.org/wiki/WxGUI_Modeler)
+File :
+Purpose :
+Author :
Property changes on: grass-addons/models/README
___________________________________________________________________
Added: svn:mime-type
+ text/plain
Added: svn:keywords
+ Author Date Id
Added: svn:eol-style
+ native
Added: grass-addons/models/atcorr_g6.gxm
--- grass-addons/models/atcorr_g6.gxm (rev 0)
+++ grass-addons/models/atcorr_g6.gxm 2012-03-07 12:12:35 UTC (rev 51002)
@@ -0,0 +1,119 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<!DOCTYPE gxm SYSTEM "grass-gxm.dtd">
+<gxm>
+ <window pos="234,111" size="697,583" />
+ <properties>
+ <name>atcorr</name>
+ <description>Model for i.atcorr to determine S6 parameters from metadata file</description>
+ <author>Martin Landa</author>
+ </properties>
+ <variables>
+ <variable name="input" type="raster">
+ <value>Btoar1</value>
+ <description>Name of input raster map</description>
+ </variable>
+ <variable name="amodel" type="integer">
+ <value>2</value>
+ <description>Atmospheric model (2 - summer / 3 - winter)</description>
+ </variable>
+ <variable name="long" type="float">
+ <value>16.232</value>
+ <description>Longitude</description>
+ </variable>
+ <variable name="month" type="integer">
+ <value>6</value>
+ <description>Month</description>
+ </variable>
+ <variable name="band" type="integer">
+ <value>31</value>
+ <description>Band id (TM - 25/30; MS - 31/34)</description>
+ </variable>
+ <variable name="elev" type="float">
+ <value>0.428</value>
+ <description>Elevation in km</description>
+ </variable>
+ <variable name="time" type="float">
+ <value>9.25</value>
+ <description>Time (hh.ddd)</description>
+ </variable>
+ <variable name="lat" type="float">
+ <value>48.873</value>
+ <description>Latitude</description>
+ </variable>
+ <variable name="output" type="raster">
+ <value>Batcorr1</value>
+ <description>Name for output raster map</description>
+ </variable>
+ <variable name="day" type="integer">
+ <value>8</value>
+ <description>Day</description>
+ </variable>
+ </variables>
+ <action id="1" name="g.region" pos="335,90" size="100,50">
+ <task name="g.region">
+ <parameter name="rast">
+ <value>%input</value>
+ </parameter>
+ </task>
+ </action>
+ <action id="2" name="i.atcorr" pos="335,200" size="104,50">
+ <task name="i.atcorr">
+ <parameter name="iimg">
+ </parameter>
+ <parameter name="iscl">
+ <value>0,255</value>
+ </parameter>
+ <parameter name="oimg">
+ <value>%output</value>
+ </parameter>
+ <parameter name="oscl">
+ </parameter>
+ </task>
+ </action>
+ <action id="3" name="r.colors" pos="335,300" size="100,50">
+ <task name="r.colors">
+ <parameter name="map">
+ </parameter>
+ <parameter name="color">
+ <value>grey.eq</value>
+ </parameter>
+ </task>
+ </action>
+ <data pos="100,200" size="175,50">
+ <data-parameter prompt="raster">
+ </data-parameter>
+ <relation dir="from" id="1" name="iimg">
+ <point>
+ <x>100</x>
+ <y>90</y>
+ </point>
+ </relation>
+ <relation dir="from" id="2" name="iimg">
+ </relation>
+ </data>
+ <data pos="560,200" size="175,50">
+ </data-parameter>
+ <relation dir="from" id="2" name="map">
+ </relation>
+ <relation dir="from" id="3" name="map">
+ <point>
+ <x>560</x>
+ <y>300</y>
+ </point>
+ </relation>
+ <relation dir="to" id="1" name="oimg">
+ <point>
+ <x>560</x>
+ <y>90</y>
+ </point>
+ </relation>
+ <relation dir="to" id="2" name="oimg">
+ </relation>
+ </data>
+</gxm>
Property changes on: grass-addons/models/atcorr_g6.gxm
+ text/xml
+ native
