[GRASS-SVN] r51007 - grass/trunk/display/d.vect
svn_grass at osgeo.org
Wed Mar 7 08:19:32 EST 2012
Author: martinl
Date: 2012-03-07 05:19:32 -0800 (Wed, 07 Mar 2012)
New Revision: 51007
grass/trunk/display/d.vect/shape.c
d.vect: switch invalid color definition from fatal error to warning (common user mistake)
Modified: grass/trunk/display/d.vect/shape.c
--- grass/trunk/display/d.vect/shape.c 2012-03-07 12:23:19 UTC (rev 51006)
+++ grass/trunk/display/d.vect/shape.c 2012-03-07 13:19:32 UTC (rev 51007)
@@ -55,23 +55,17 @@
G_debug(3, "nrec_rgb (%s) = %d", rgb_column, nrec_rgb);
if (cvarr_rgb.ctype != DB_C_TYPE_STRING)
- G_fatal_error(_("Color definition column (%s) not a string. "
- "Column must be of form RRR:GGG:BBB where RGB values range 0-255."),
- rgb_column);
- if (nrec_rgb < 0)
- G_fatal_error(_("Unable to select data (%s) from table"),
- rgb_column);
- G_debug(2, "\n%d records selected from table", nrec_rgb);
- for (i = 0; i < cvarr_rgb.n_values; i++) {
- G_debug(4, "cat = %d %s = %s", cvarr_rgb.value[i].cat,
- rgb_column, db_get_string(cvarr_rgb.value[i].val.s));
+ G_warning(_("Color definition column (%s) not a string. "
+ "Column must be of form RRR:GGG:BBB where RGB values range 0-255."),
+ rgb_column);
+ else {
+ if (nrec_rgb < 0)
+ G_fatal_error(_("Unable to select data (%s) from table"),
+ rgb_column);
+ G_debug(2, "\n%d records selected from table", nrec_rgb);
if (width_column) {
if (*width_column == '\0')
G_fatal_error(_("Line width column not specified"));
