[GRASS-SVN] r51009 - grass/branches/develbranch_6/display/d.vect
svn_grass at osgeo.org
Wed Mar 7 09:06:50 EST 2012
Author: martinl
Date: 2012-03-07 06:06:49 -0800 (Wed, 07 Mar 2012)
New Revision: 51009
grass/branches/develbranch_6/display/d.vect/area.c
grass/branches/develbranch_6/display/d.vect/plot1.c
d.vect: close DB connection of fatal error
invalid color rules is just a warning
Modified: grass/branches/develbranch_6/display/d.vect/area.c
--- grass/branches/develbranch_6/display/d.vect/area.c 2012-03-07 13:42:37 UTC (rev 51008)
+++ grass/branches/develbranch_6/display/d.vect/area.c 2012-03-07 14:06:49 UTC (rev 51009)
@@ -65,8 +65,12 @@
if (table_colors_flag) {
/* for reading RRR:GGG:BBB color strings from table */
- if (rgb_column == NULL || *rgb_column == '\0')
+ if (rgb_column == NULL || *rgb_column == '\0') {
+ if (open_db)
+ db_close_database_shutdown_driver(driver);
G_fatal_error(_("Color definition column not specified."));
db_CatValArray_init(&cvarr_rgb);
@@ -76,27 +80,39 @@
G_debug(3, "nrec_rgb (%s) = %d", rgb_column, nrec_rgb);
if (cvarr_rgb.ctype != DB_C_TYPE_STRING)
- G_fatal_error(_("Color definition column (%s) not a string. "
- "Column must be of form RRR:GGG:BBB where RGB values range 0-255."),
- rgb_column);
+ G_warning(_("Color definition column ('%s') not a string. "
+ "Column must be of form 'RRR:GGG:BBB' where RGB values range 0-255. "
+ "You can use '%s' module to define color rules. "
+ "Unable to colorize features."),
+ rgb_column, "v.colors");
+ else {
+ if (nrec_rgb < 0) {
+ if (open_db)
+ G_fatal_error(_("Cannot select data (%s) from table"),
+ rgb_column);
+ G_debug(2, "\n%d records selected from table", nrec_rgb);
- if (nrec_rgb < 0)
- G_fatal_error(_("Cannot select data (%s) from table"),
- rgb_column);
- G_debug(2, "\n%d records selected from table", nrec_rgb);
- for (i = 0; i < cvarr_rgb.n_values; i++) {
- G_debug(4, "cat = %d %s = %s", cvarr_rgb.value[i].cat,
- rgb_column, db_get_string(cvarr_rgb.value[i].val.s));
+ for (i = 0; i < cvarr_rgb.n_values; i++) {
+ G_debug(4, "cat = %d %s = %s", cvarr_rgb.value[i].cat,
+ rgb_column, db_get_string(cvarr_rgb.value[i].val.s));
if (width_column) {
- if (*width_column == '\0')
+ if (*width_column == '\0') {
+ if (open_db)
G_fatal_error(_("Line width column not specified."));
db_CatValArray_init(&cvarr_width);
nrec_width = db_select_CatValArray(driver, fi->table, fi->key,
@@ -105,14 +121,22 @@
G_debug(3, "nrec_width (%s) = %d", width_column, nrec_width);
if (cvarr_width.ctype != DB_C_TYPE_INT &&
- cvarr_width.ctype != DB_C_TYPE_DOUBLE)
+ cvarr_width.ctype != DB_C_TYPE_DOUBLE) {
+ if (open_db)
G_fatal_error(_("Line width column (%s) not a number."),
width_column);
- if (nrec_width < 0)
+ if (nrec_width < 0) {
+ if (open_db)
width_column);
G_debug(2, "\n%d records selected from table", nrec_width);
for (i = 0; i < cvarr_width.n_values; i++) {
Modified: grass/branches/develbranch_6/display/d.vect/plot1.c
--- grass/branches/develbranch_6/display/d.vect/plot1.c 2012-03-07 13:42:37 UTC (rev 51008)
+++ grass/branches/develbranch_6/display/d.vect/plot1.c 2012-03-07 14:06:49 UTC (rev 51009)
@@ -212,8 +212,12 @@
+ if (open_db)
G_fatal_error(_("Color definition column not specified"));
@@ -223,25 +227,36 @@
- rgb_column);
+ else {
+ if (open_db)
+ rgb_column);
- if (nrec_rgb < 0)
- rgb_column);
+ if (width_column) {
+ if (open_db)
- if (width_column) {
@@ -251,14 +266,22 @@
+ if (open_db)
G_fatal_error(_("Line width column (%s) is not numeric."),
width_column);
+ if (open_db)
width_column);
G_debug(2, " %d records selected from table", nrec_width);
@@ -271,9 +294,13 @@
if (size_column) {
- if (*size_column == '\0')
+ if (*size_column == '\0') {
+ if (open_db)
G_fatal_error(_("Symbol size column not specified."));
db_CatValArray_init(&cvarr_size);
nrec_size = db_select_CatValArray(driver, fi->table, fi->key,
@@ -282,14 +309,22 @@
G_debug(3, "nrec_size (%s) = %d", size_column, nrec_size);
if (cvarr_size.ctype != DB_C_TYPE_INT &&
- cvarr_size.ctype != DB_C_TYPE_DOUBLE)
+ cvarr_size.ctype != DB_C_TYPE_DOUBLE) {
+ if (open_db)
G_fatal_error(_("Symbol size column (%s) is not numeric."),
size_column);
+ if (nrec_size < 0) {
+ if (open_db)
- if (nrec_size < 0)
size_column);
G_debug(2, " %d records selected from table", nrec_size);
for (i = 0; i < cvarr_size.n_values; i++) {
@@ -302,9 +337,13 @@
if (rot_column) {
- if (*rot_column == '\0')
+ if (*rot_column == '\0') {
+ if (open_db)
G_fatal_error(_("Symbol rotation column not specified."));
db_CatValArray_init(&cvarr_rot);
nrec_rot = db_select_CatValArray(driver, fi->table, fi->key,
@@ -313,14 +352,22 @@
G_debug(3, "nrec_rot (%s) = %d", rot_column, nrec_rot);
if (cvarr_rot.ctype != DB_C_TYPE_INT &&
- cvarr_rot.ctype != DB_C_TYPE_DOUBLE)
+ cvarr_rot.ctype != DB_C_TYPE_DOUBLE) {
+ if (open_db)
G_fatal_error(_("Symbol rotation column (%s) is not numeric."),
rot_column);
- if (nrec_rot < 0)
+ if (nrec_rot < 0) {
+ if (open_db)
rot_column);
G_debug(2, " %d records selected from table", nrec_rot);
for (i = 0; i < cvarr_rot.n_values; i++) {
