[GRASS-SVN] r51053 - grass-addons/grass6/raster/r.hazard.flood
Mon Mar 12 18:18:32 EDT 2012
Author: madi
Date: 2012-03-12 15:18:32 -0700 (Mon, 12 Mar 2012)
New Revision: 51053
   grass-addons/grass6/raster/r.hazard.flood/r.hazard.flood.py
overwrite option fixed
Modified: grass-addons/grass6/raster/r.hazard.flood/r.hazard.flood.py
--- grass-addons/grass6/raster/r.hazard.flood/r.hazard.flood.py	2012-03-12 20:59:23 UTC (rev 51052)
+++ grass-addons/grass6/raster/r.hazard.flood/r.hazard.flood.py	2012-03-12 22:18:32 UTC (rev 51053)
@@ -6,7 +6,7 @@
 # AUTHOR(S):   Margherita Di Leo
 # PURPOSE:     Fast procedure to detect flood prone areas on the basis of a
 #              topographic index
-# COPYRIGHT:   (C) 2010 by Margherita Di Leo and the GRASS Development Team
+# COPYRIGHT:   (C) 2010 by Margherita Di Leo
 #              dileomargherita at gmail.com
 #              This program is free software under the GNU General Public
@@ -83,7 +83,12 @@
     # MTI map
     grass.message("Calculating mti raster map.. ")
-    grass.mapcalc("$r_mti = log((exp((($rast1+1)*$resolution) , $n)) / (tan($rast2+0.001)))", r_mti = r_mti, rast1 = 'r_accumulation', resolution = resolution, rast2 = 'r_slope', n = n)
+    grass.mapcalc("$r_mti = log((exp((($rast1+1)*$resolution) , $n)) / (tan($rast2+0.001)))",
+                   r_mti = r_mti,
+                   rast1 = 'r_accumulation',
+                   resolution = resolution,
+                   rast2 = 'r_slope',
+                   n = n)
     # Cleaning up
     grass.message("Cleaning up.. ")
@@ -92,12 +97,16 @@
     # flood map
     grass.message("Calculating flood raster map.. ")
-    grass.mapcalc("r_flood = if($rast1 >  $mti_th, 1, 0)", rast1 = r_mti, mti_th = mti_th)
+    grass.mapcalc("r_flood = if($rast1 >  $mti_th, 1, 0)",
+                   rast1 = r_mti,
+                   mti_th = mti_th)
     ## # Deleting isolated pixels
     # Recategorizes data in a raster map by grouping cells that form physically discrete areas into unique categories (preliminar to r.area)
     grass.message("Running r.clump.. ")
-    grass.run_command('r.clump', input = 'r_flood', output = 'r_clump', flags = '-o')
+    grass.run_command('r.clump', input = 'r_flood',
+                                 output = 'r_clump',
+                                 overwrite = 'True')
     # Delete areas of less than a threshold of cells (corresponding to 1 square kilometer)
     # Calculating threshold
