[GRASS-SVN] r51061 - grass/branches/develbranch_6/lib/python
svn_grass at osgeo.org
Wed Mar 14 18:15:55 EDT 2012
Author: martinl
Date: 2012-03-14 15:15:54 -0700 (Wed, 14 Mar 2012)
New Revision: 51061
grass/branches/develbranch_6/lib/python/core.py
grass/branches/develbranch_6/lib/python/pythonlib.dox
pythonlib: introduce region_env()
add 3D support for region()
(merge r51058, r51059, r51060 from trunk)
Modified: grass/branches/develbranch_6/lib/python/core.py
--- grass/branches/develbranch_6/lib/python/core.py 2012-03-14 22:13:32 UTC (rev 51060)
+++ grass/branches/develbranch_6/lib/python/core.py 2012-03-14 22:15:54 UTC (rev 51061)
@@ -560,10 +560,12 @@
# interface to g.region
-def region():
+def region(region3d = False):
"""!Returns the output from running "g.region -g", as a
dictionary. Example:
+ \param region3d True to get 3D region
\code
>>> region = grass.region()
>>> [region[key] for key in "nsew"]
@@ -574,12 +576,95 @@
@return dictionary of region values
- s = read_command("g.region", flags='g')
+ flgs = 'g'
+ if region3d:
+ flgs += '3'
+ s = read_command("g.region", flags = flgs)
reg = parse_key_val(s, val_type = float)
- for k in ['rows', 'cols']:
+ for k in ['rows', 'cols', 'cells',
+ 'rows3', 'cols3', 'cells3', 'depths']:
+ if k not in reg:
+ continue
reg[k] = int(reg[k])
return reg
+def region_env(region3d = False,
+ **kwargs):
+ """!Returns region settings as a string which can used as
+ GRASS_REGION environmental variable.
+ If no 'kwargs' are given then the current region is used. Note
+ that this function doesn't modify the current region!
+ See also use_temp_region() for alternative method how to define
+ temporary region used for raster-based computation.
+ \param kwargs g.region's parameters like 'rast', 'vect' or 'region'
+ \code
+ os.environ['GRASS_REGION'] = grass.region_env(region = 'detail')
+ grass.mapcalc('map = 1', overwrite = True)
+ os.environ.pop('GRASS_REGION')
+ \endcode
+ @return string with region values
+ @return empty string on error
+ # read proj/zone from WIND file
+ env = gisenv()
+ windfile = os.path.join (env['GISDBASE'], env['LOCATION_NAME'],
+ env['MAPSET'], "WIND")
+ fd = open(windfile, "r")
+ grass_region = ''
+ for line in fd.readlines():
+ key, value = map(lambda x: x.strip(), line.split(":", 1))
+ if kwargs and key not in ('proj', 'zone'):
+ continue
+ if not kwargs and not region3d and \
+ key in ('top', 'bottom', 'cols3', 'rows3',
+ 'depths', 'e-w resol3', 'n-s resol3', 't-b resol'):
+ continue
+ grass_region += '%s: %s;' % (key, value)
+ if not kwargs: # return current region
+ return grass_region
+ # read other values from `g.region -g`
+ flgs = 'ug'
+ if region3d:
+ flgs += '3'
+ s = read_command('g.region', flags = flgs, **kwargs)
+ if not s:
+ return ''
+ reg = parse_key_val(s)
+ kwdata = [('north', 'n'),
+ ('south', 's'),
+ ('east', 'e'),
+ ('west', 'w'),
+ ('cols', 'cols'),
+ ('rows', 'rows'),
+ ('e-w resol', 'ewres'),
+ ('n-s resol', 'nsres')]
+ if region3d:
+ kwdata += [('top', 't'),
+ ('bottom', 'b'),
+ ('cols3', 'cols3'),
+ ('rows3', 'rows3'),
+ ('depths', 'depths'),
+ ('e-w resol3', 'ewres3'),
+ ('n-s resol3', 'nsres3'),
+ ('t-b resol', 'tbres')]
+ for wkey, rkey in kwdata:
+ grass_region += '%s: %s;' % (wkey, reg[rkey])
def use_temp_region():
"""!Copies the current region to a temporary region with "g.region save=",
then sets WIND_OVERRIDE to refer to that region. Installs an atexit
Modified: grass/branches/develbranch_6/lib/python/pythonlib.dox
--- grass/branches/develbranch_6/lib/python/pythonlib.dox 2012-03-14 22:13:32 UTC (rev 51060)
+++ grass/branches/develbranch_6/lib/python/pythonlib.dox 2012-03-14 22:15:54 UTC (rev 51061)
@@ -158,6 +158,8 @@
- python::core::region()
+ - python::core::region_env()
- python::core::use_temp_region()
<b>Interface to g.findfile</b>
