[GRASS-SVN] r51069 - grass/trunk/vector/v.info
svn_grass at osgeo.org
Fri Mar 16 06:18:20 EDT 2012
Author: martinl
Date: 2012-03-16 03:18:20 -0700 (Fri, 16 Mar 2012)
New Revision: 51069
grass/trunk/vector/v.info/print.c
v.info: print feature type for non-native formats
print timestamp info also in shell script output
minor re-ordering
Modified: grass/trunk/vector/v.info/print.c
--- grass/trunk/vector/v.info/print.c 2012-03-16 08:41:21 UTC (rev 51068)
+++ grass/trunk/vector/v.info/print.c 2012-03-16 10:18:20 UTC (rev 51069)
@@ -168,6 +168,23 @@
void print_shell(const struct Map_info *Map)
int map_type;
+ int time_ok, first_time_ok, second_time_ok;
+ char timebuff[256];
+ struct TimeStamp ts;
+ time_ok = first_time_ok = second_time_ok = FALSE;
+ /* Check the Timestamp */
+ time_ok = G_read_vector_timestamp(Vect_get_name(Map), NULL, "", &ts);
+ /* Check for valid entries, show none if no timestamp available */
+ if (time_ok == TRUE) {
+ if (ts.count > 0)
+ first_time_ok = TRUE;
+ if (ts.count > 1)
+ second_time_ok = TRUE;
map_type = Vect_maptype(Map);
@@ -183,7 +200,21 @@
Vect_get_map_name(Map));
fprintf(stdout, "scale=1:%d\n",
Vect_get_scale(Map));
+ fprintf(stdout, "creator=%s\n",
+ Vect_get_person(Map));
+ fprintf(stdout, "organization=%s\n",
+ Vect_get_organization(Map));
+ fprintf(stdout, "source_date=%s\n",
+ Vect_get_map_date(Map));
+ /* This shows the TimeStamp (if present) */
+ if (time_ok == TRUE && (first_time_ok || second_time_ok)) {
+ G_format_timestamp(&ts, timebuff);
+ fprintf(stdout, "timestamp=%s\n", timebuff);
+ else {
+ fprintf(stdout, "timestamp=none\n");
if (map_type == GV_FORMAT_OGR ||
map_type == GV_FORMAT_OGR_DIRECT) {
fprintf(stdout, "format=%s,%s\n",
@@ -192,6 +223,9 @@
Vect_get_finfo_layer_name(Map));
fprintf(stdout, "ogr_dsn=%s\n",
Vect_get_finfo_dsn_name(Map));
+ fprintf(stdout, "feature_type=%s\n",
+ Vect_get_finfo_geometry_type(Map));
else if (map_type == GV_FORMAT_POSTGIS) {
fprintf(stdout, "format=%s\n",
@@ -200,18 +234,14 @@
fprintf(stdout, "pg_dbname=%s\n",
else {
Vect_maptype_info(Map));
- fprintf(stdout, "creator=%s\n",
- Vect_get_person(Map));
- fprintf(stdout, "organization=%s\n",
- Vect_get_organization(Map));
- fprintf(stdout, "source_date=%s\n",
- Vect_get_map_date(Map));
fprintf(stdout, "level=%d\n",
Vect_level(Map));
@@ -239,10 +269,12 @@
char tmp1[100], tmp2[100];
char timebuff[256];
- int time_ok = FALSE, first_time_ok = FALSE, second_time_ok = FALSE;
struct bound_box box;
- int utm_zone = -1;
+ int utm_zone;
+ utm_zone = -1;
@@ -278,6 +310,29 @@
printline(line);
+ sprintf(line, "%-17s%s", _("Name of creator:"),
+ printline(line);
+ sprintf(line, "%-17s%s", _("Organization:"),
+ printline(line);
+ sprintf(line, "%-17s%s", _("Source date:"),
+ printline(line);
+ sprintf(line, "%-17s%s", _("Timestamp (first layer): "), timebuff);
+ printline(line);
+ else {
+ strcpy(line, _("Timestamp (first layer): none"));
+ printline(line);
+ divider('|');
sprintf(line, "%-17s%s (%s)", _("Map format:"),
@@ -291,19 +346,25 @@
sprintf(line, "%-17s%s", _("OGR datasource:"),
printline(line);
+ sprintf(line, "%-17s%s", _("Feature type:"),
+ printline(line);
sprintf(line, "%-17s%s", _("Map format:"),
printline(line);
- /* for OGR format print also datasource and layer */
+ /* for PostGIS format print also datasource and layer */
sprintf(line, "%-17s%s", _("PostGIS table:"),
printline(line);
sprintf(line, "%-17s%s", _("PostGIS database:"),
printline(line);
+ printline(line);
else {
@@ -311,32 +372,11 @@
printline(line);
- sprintf(line, "%-17s%s", _("Name of creator:"),
- printline(line);
- sprintf(line, "%-17s%s", _("Organization:"),
- printline(line);
- sprintf(line, "%-17s%s", _("Source date:"),
- printline(line);
- /* This shows the TimeStamp (if present) */
- if (time_ok == TRUE && (first_time_ok || second_time_ok)) {
- G_format_timestamp(&ts, timebuff);
- sprintf(line, "%-17s%s", _("Timestamp (first layer): "), timebuff);
- printline(line);
-/* else
- strcpy(line, _("Timestamp (first layer): none"));
- printline(line); */
divider('|');
sprintf(line, " %s: %s (%s: %i)",
_("Type of map"), _("vector"), _("level"), Vect_level(Map));
printline(line);
if (Vect_level(Map) > 0) {
