[GRASS-SVN] r51092 - in grass/trunk: include/vect lib/vector/Vlib
svn_grass at osgeo.org
Sat Mar 17 11:27:57 EDT 2012
Author: martinl
Date: 2012-03-17 08:27:57 -0700 (Sat, 17 Mar 2012)
New Revision: 51092
grass/trunk/include/vect/dig_structs.h
grass/trunk/lib/vector/Vlib/open_ogr.c
grass/trunk/lib/vector/Vlib/read_ogr.c
grass/trunk/lib/vector/Vlib/read_pg.c
grass/trunk/lib/vector/Vlib/read_sfa.c
vlib(pg): improve reading PostGIS features
eliminate feature_cache_id (use cache.fid)
Modified: grass/trunk/include/vect/dig_structs.h
--- grass/trunk/include/vect/dig_structs.h 2012-03-17 15:26:58 UTC (rev 51091)
+++ grass/trunk/include/vect/dig_structs.h 2012-03-17 15:27:57 UTC (rev 51092)
@@ -562,12 +562,8 @@
#else
void *feature_cache;
#endif
- \brief Feature id read in feature_cache (level 2)
- int feature_cache_id;
\brief Offset list used for building pseudo-topology
struct Format_info_offset offset;
Modified: grass/trunk/lib/vector/Vlib/open_ogr.c
--- grass/trunk/lib/vector/Vlib/open_ogr.c 2012-03-17 15:26:58 UTC (rev 51091)
+++ grass/trunk/lib/vector/Vlib/open_ogr.c 2012-03-17 15:27:57 UTC (rev 51092)
@@ -119,7 +119,7 @@
break;
- ogr_info->feature_cache_id = -1; /* FID >= 0 */
+ ogr_info->cache.fid = -1; /* FID >= 0 */
return 0;
#else
Modified: grass/trunk/lib/vector/Vlib/read_ogr.c
--- grass/trunk/lib/vector/Vlib/read_ogr.c 2012-03-17 15:26:58 UTC (rev 51091)
+++ grass/trunk/lib/vector/Vlib/read_ogr.c 2012-03-17 15:27:57 UTC (rev 51092)
@@ -204,7 +204,7 @@
/* coordinates */
if (line_p != NULL) {
/* read feature to cache if necessary */
- if (ogr_info->feature_cache_id != fid) {
+ if (ogr_info->cache.fid != fid) {
G_debug(4, "Read feature (fid = %ld) to cache", fid);
if (ogr_info->feature_cache) {
OGR_F_Destroy(ogr_info->feature_cache);
@@ -216,7 +216,7 @@
fid);
return -1;
- ogr_info->feature_cache_id = fid;
+ ogr_info->cache.fid = fid;
hGeom = OGR_F_GetGeometryRef(ogr_info->feature_cache);
@@ -385,8 +385,8 @@
/* cache OGR feature */
- ogr_info->feature_cache_id = (int)OGR_F_GetFID(hFeature);
- if (ogr_info->feature_cache_id == OGRNullFID) {
+ ogr_info->cache.fid = (int)OGR_F_GetFID(hFeature);
+ if (ogr_info->cache.fid == OGRNullFID) {
G_warning(_("OGR feature without ID"));
@@ -429,8 +429,8 @@
Vect_append_points(line_p,
ogr_info->cache.lines[ogr_info->cache.lines_next], GV_FORWARD);
- if (line_c != NULL && ogr_info->feature_cache_id != OGRNullFID)
- Vect_cat_set(line_c, 1, ogr_info->feature_cache_id);
+ if (line_c != NULL && ogr_info->cache.fid != OGRNullFID)
+ Vect_cat_set(line_c, 1, ogr_info->cache.fid);
ogr_info->cache.lines_next++;
G_debug(4, "next line read, type = %d", itype);
Modified: grass/trunk/lib/vector/Vlib/read_pg.c
--- grass/trunk/lib/vector/Vlib/read_pg.c 2012-03-17 15:26:58 UTC (rev 51091)
+++ grass/trunk/lib/vector/Vlib/read_pg.c 2012-03-17 15:27:57 UTC (rev 51092)
@@ -172,6 +172,9 @@
else {
/* ignore constraints, Map->next_line incremented */
ret = read_next_line_pg(Map, line_p, line_c, TRUE);
+ if (ret != Line->type)
+ G_fatal_error(_("Unexpected feature type (%s) - should be (%d)"),
+ ret, Line->type);
if (Map->constraint.region_flag) {
@@ -215,13 +218,13 @@
#ifdef HAVE_POSTGRES
long fid;
- int i, ipart, type;
- SF_FeatureType sf_type;
+ int ipart, type;
+ static SF_FeatureType sf_type;
- struct line_pnts *line_i;
- struct Format_info_pg *pg_info;
+ struct Format_info_pg *pg_info;
pg_info = &(Map->fInfo.pg);
G_debug(3, "V1_read_line_pg(): offset = %lu offset_num = %lu",
(long) offset, (long) pg_info->offset.array_num);
@@ -249,7 +252,7 @@
if ((int) sf_type < 0) /* -1 || - 2 */
return (int) sf_type;
/* get data from cache */
if (sf_type == SF_POINT || sf_type == SF_LINESTRING)
ipart = 0;
@@ -259,20 +262,13 @@
G_debug(4, "read feature part: %d -> type = %d",
ipart, type);
- if (line_p != NULL) {
- /* coordinates */
- line_i = pg_info->cache.lines[ipart];
- for (i = 0; i < line_i->n_points; i++) {
- Vect_append_point(line_p,
- line_i->x[i], line_i->y[i], line_i->z[i]);
+ if (line_p)
+ Vect_append_points(line_p,
+ pg_info->cache.lines[ipart], GV_FORWARD);
- if (line_c != NULL) {
- /* category */
+ if (line_c)
Vect_cat_set(line_c, 1, (int) fid);
return type;
#else
G_fatal_error(_("GRASS is not compiled with PostgreSQL support"));
@@ -299,20 +295,20 @@
struct line_pnts *line_p, struct line_cats *line_c,
int ignore_constraints)
- int i, ltype;
+ int line, itype;
struct bound_box mbox, lbox;
+ struct line_pnts *iline;
if (Map->constraint.region_flag && !ignore_constraints)
Vect_get_constraint_box(Map, &mbox);
while (TRUE) {
- Map->next_line++; /* level 2 only */
+ line = Map->next_line++; /* level 2 only */
/* reset data structures */
if (line_p != NULL)
@@ -322,13 +318,12 @@
while (pg_info->cache.lines_next == pg_info->cache.lines_num) {
- pg_info->cache.lines_next = pg_info->cache.lines_num = 0;
/* cache feature -> line_p & line_c */
sf_type = get_feature(pg_info, -1);
if (sf_type == SF_NONE) {
G_warning(_("Feature %d without geometry skipped"),
- Map->next_line);
+ line);
return -1;
@@ -342,33 +337,28 @@
G_debug(4, "%d lines read to cache", pg_info->cache.lines_num);
+ /* next to be read from cache */
+ pg_info->cache.lines_next = 0;
- ltype = pg_info->cache.lines_types[pg_info->cache.lines_next];
- if (line_p) {
- line_i = pg_info->cache.lines[pg_info->cache.lines_next];
- if (line_c) {
- Vect_cat_set(line_c, 1, (int) pg_info->cache.fid);
- pg_info->cache.lines_next++;
+ G_debug(4, "read next cached line %d", pg_info->cache.lines_next);
+ itype = pg_info->cache.lines_types[pg_info->cache.lines_next];
+ iline = pg_info->cache.lines[pg_info->cache.lines_next];
/* apply constraints */
if (Map->constraint.type_flag && !ignore_constraints) {
/* skip feature by type */
- if (!(ltype & Map->constraint.type))
+ if (!(itype & Map->constraint.type))
continue;
if (line_p && Map->constraint.region_flag &&
/* skip feature by region */
- Vect_line_box(line_p, &lbox);
+ Vect_line_box(iline, &lbox);
if (!Vect_box_overlap(&lbox, &mbox))
continue;
@@ -376,7 +366,16 @@
/* skip feature by field ignored */
- return ltype;
+ if (line_p)
+ Vect_append_points(line_p, iline, GV_FORWARD);
+ if (line_c)
+ Vect_cat_set(line_c, 1, (int) pg_info->cache.fid);
+ pg_info->cache.lines_next++;
+ G_debug(4, "next line read, type = %d", itype);
+ return itype;
return -1; /* not reached */
@@ -571,6 +570,12 @@
unsigned char *wkb_data;
unsigned int wkb_flags;
SF_FeatureType ftype;
+ /* reset cache */
+ cache->lines_num = 0;
+ cache->fid = -1;
+ if (fparts)
+ fparts->n_parts = 0;
wkb_flags = 0;
wkb_data = hex_to_wkb(data, &nbytes);
@@ -642,9 +647,6 @@
if (!cache->lines) {
reallocate_cache(cache, 1);
- cache->lines_num = 0;
- if (fparts)
- fparts->n_parts = 0;
ret = -1;
if (ftype == SF_POINT) {
@@ -855,6 +857,9 @@
/* get the rings */
nsize = 9;
for (i = 0; i < nrings; i++ ) {
+ if (cache->lines_next >= cache->lines_num)
+ G_fatal_error(_("Invalid cache index %d (max: %d)"),
+ cache->lines_next, cache->lines_num);
line_i = cache->lines[cache->lines_next];
cache->lines_types[cache->lines_next++] = GV_BOUNDARY;
Modified: grass/trunk/lib/vector/Vlib/read_sfa.c
--- grass/trunk/lib/vector/Vlib/read_sfa.c 2012-03-17 15:26:58 UTC (rev 51091)
+++ grass/trunk/lib/vector/Vlib/read_sfa.c 2012-03-17 15:27:57 UTC (rev 51092)
@@ -39,6 +39,7 @@
struct line_cats *line_c, int line)
#if defined HAVE_OGR || defined HAVE_POSTGRES
+ int type;
struct P_line *Line;
G_debug(4, "V2_read_line_sfa() line = %d", line);
@@ -101,9 +102,15 @@
return Line->type;
if (Map->format == GV_FORMAT_POSTGIS)
- return V1_read_line_pg(Map, line_p, line_c, Line->offset);
- return V1_read_line_ogr(Map, line_p, line_c, Line->offset);
+ type = V1_read_line_pg(Map, line_p, line_c, Line->offset);
+ else
+ type = V1_read_line_ogr(Map, line_p, line_c, Line->offset);
+ if (type != Line->type)
+ type, Line->type);
+ return type;
#else
G_fatal_error(_("GRASS is not compiled with OGR/PostgreSQL support"));
return -1;
