[GRASS-SVN] r51109 - grass/branches/releasebranch_6_4/locale/po
svn_grass at osgeo.org
Mon Mar 19 11:28:03 EDT 2012
Author: lucadelu
Date: 2012-03-19 08:28:03 -0700 (Mon, 19 Mar 2012)
New Revision: 51109
grass/branches/releasebranch_6_4/locale/po/grassmods_it.po
Marco Curreli: cont'ed
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_it.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_it.po 2012-03-18 15:10:09 UTC (rev 51108)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_it.po 2012-03-19 15:28:03 UTC (rev 51109)
@@ -14,7 +14,7 @@
"Project-Id-Version: grassmods_it\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2012-02-01 08:43+0100\n"
-"PO-Revision-Date: 2012-03-09 18:12+0100\n"
+"PO-Revision-Date: 2012-03-18 23:57+0100\n"
"Last-Translator: \n"
"Language-Team: Italian <grass-translations at lists.osgeo.org>\n"
"Language: it\n"
@@ -7152,7 +7152,7 @@
#: ../raster/r.in.bin/main.c:255
msgid "Byte Swap the Data During Import"
-msgstr ""
+msgstr "Cambia l'ordine dei byte (byte swapping) durante l'importazione"
#: ../raster/r.in.bin/main.c:260
msgid "Get region info from GMT style header"
@@ -9123,7 +9123,7 @@
#: ../raster/r.describe/main.c:80
msgid "Number of quantization steps"
-msgstr ""
+msgstr "Numero di livelli di quantizzazione"
#: ../raster/r.describe/main.c:86
msgid "Print the output one value per line"
@@ -11973,7 +11973,7 @@
#: ../raster/r.out.gdal/main.c:276
#, c-format
msgid "Driver <%s> does not support creating rasters"
-msgstr ""
+msgstr "Il driver <%s> non supporta la creazione di raster"
#: ../raster/r.out.gdal/main.c:352
#, c-format
@@ -17733,7 +17733,7 @@
#: ../vector/v.net.spanningtree/main.c:64 ../vector/v.net.allpairs/main.c:85
#: ../vector/v.net.salesman/main.c:136 ../vector/v.net.path/main.c:102
msgid "Use geodesic calculation for longitude-latitude locations"
-msgstr ""
+msgstr "Usa il calcolo geodetico per le location longitudine-latitudine"
#: ../display/d.path/main.c:127
msgid "Render bold lines"
@@ -17949,7 +17949,7 @@
#: ../display/d.legend/main.c:174
msgid "Skip categories with no label"
-msgstr ""
+msgstr "Ignora le categoria senza etichetta"
#: ../display/d.legend/main.c:179
msgid "Draw smooth gradient"
@@ -19571,13 +19571,12 @@
msgstr "general, impostazioni, percorso di ricerca"
#: ../general/g.mapsets/main.c:60
-#, fuzzy
msgid "Modifies the user's current mapset search path."
-msgstr "Modifica il percorso di ricerca corrente dell'utente"
+msgstr "Modifica l'attuale percorso di ricerca dell'utente per i mapset."
#: ../general/g.mapsets/main.c:61
msgid "Affects the user's access to data existing under the other mapsets in the current location."
-msgstr ""
+msgstr "Influisce sull'accesso da parte dell'utente ai dati esistenti negli altri mapset nella location corrente."
#: ../general/g.mapsets/main.c:69
msgid "Name(s) of existing mapset(s)"
@@ -19605,7 +19604,7 @@
#: ../general/g.mapsets/main.c:92
msgid "Special characters: newline, space, comma, tab"
-msgstr ""
+msgstr "Caratteri speciali: newline, spazio, virgola, tabulazione"
#: ../general/g.mapsets/main.c:97
msgid "List all available mapsets in alphabetical order"
@@ -19613,11 +19612,11 @@
#: ../general/g.mapsets/main.c:102
msgid "Print mapsets in current search path"
-msgstr ""
+msgstr "Visualizza i mapset presenti nel percorso di ricerca corrente"
#: ../general/g.mapsets/main.c:107
msgid "Show mapset selection dialog"
-msgstr ""
+msgstr "Mostra la finestra di dialogo per la selezione"
#: ../general/g.mapsets/main.c:132 ../general/g.mapsets/main.c:161
#, c-format
@@ -19655,7 +19654,7 @@
#: ../locale/scriptstrings/v.db.univar_to_translate.c:2
#: ../locale/scriptstrings/v.univar.sh_to_translate.c:2
msgid "vector, statistics"
-msgstr ""
+msgstr "vettoriale, statistica"
#: ../vector/v.random/main.c:85
msgid "Randomly generate a 2D/3D vector points map."
@@ -19680,7 +19679,7 @@
#: ../vector/v.random/main.c:119
msgid "Column name and type (i.e. INTEGER, DOUBLE PRECISION) for z values"
-msgstr ""
+msgstr "Nomi di colonna e tipo (i.e. INTEGER, DOUBLE PRECISION) per i valori z"
#: ../vector/v.random/main.c:121
msgid "If type is not given then DOUBLE PRECISION is used. Writes Z data to column instead of 3D vector."
@@ -19719,7 +19718,7 @@
#: ../vector/v.random/main.c:234
msgid "You have created unsupported column type. This module supports only INTEGER and DOUBLE PRECISION column types."
-msgstr ""
+msgstr "Sono stati creati tipi di colonna non supportati. Questo modulo supporta solo tipi di colonna INTEGER (numeri interi) e DOUBLE PRECISION (precisione doppia)"
#: ../vector/v.random/main.c:264
msgid "Generating points..."
@@ -19727,7 +19726,7 @@
#: ../vector/v.net.iso/main.c:72
msgid "Splits net by cost isolines."
-msgstr "Dividi rete dal costo delle linee."
+msgstr "Divide la rete in isolinee di costo."
#: ../vector/v.net.iso/main.c:73
msgid "vector, network, isolines"
@@ -19735,7 +19734,7 @@
#: ../vector/v.net.iso/main.c:75
msgid "Splits net to bands between cost isolines (direction from centre). Centre node must be opened (costs >= 0). Costs of centre node are used in calculation."
-msgstr ""
+msgstr "Divide la rete in fasce comprese fra isolinee di costo (a partire da un centro). l nodo definito come centro dev'essere aperto (costi >= 0). I costi del centro vengono utilizzati nel calcolo."
#: ../vector/v.net.iso/main.c:99 ../vector/v.net.alloc/main.c:92
msgid "Arc forward/both direction(s) cost column (number)"
@@ -19751,11 +19750,11 @@
#: ../vector/v.net.iso/main.c:113
msgid "Categories of centres (points on nodes) to which net will be allocated. Layer for this categories is given by nlayer option."
-msgstr ""
+msgstr "Categorie dei centri (punti o nodi) ai quali dev'essere assegnata la rete. Il layer per queste categorie è dato dall'opzione nlayer."
#: ../vector/v.net.iso/main.c:122
msgid "Costs for isolines"
-msgstr ""
+msgstr "Costi per le isolinee"
#: ../vector/v.net.iso/main.c:159
#, c-format
@@ -19821,9 +19820,8 @@
msgstr "Colonna costo direzione indietro per gli archi"
#: ../vector/v.net.centrality/main.c:127
-#, fuzzy
msgid "Name of degree centrality column"
-msgstr "Nome della colonna"
+msgstr "Nome della colonna del grado di centralità (degree centrality)"
#: ../vector/v.net.centrality/main.c:128 ../vector/v.net.centrality/main.c:134
#: ../vector/v.net.centrality/main.c:140 ../vector/v.net.centrality/main.c:146
@@ -19831,33 +19829,28 @@
msgstr "Colonne"
#: ../vector/v.net.centrality/main.c:133
-#, fuzzy
msgid "Name of closeness centrality column"
+msgstr "Nome della colonna della closeness centrality (vicinanza) "
#: ../vector/v.net.centrality/main.c:139
-#, fuzzy
msgid "Name of betweenness centrality column"
+msgstr "Nome della colonna della betweenness centrality"
#: ../vector/v.net.centrality/main.c:145
-#, fuzzy
msgid "Name of eigenvector centrality column"
-msgstr "Nome della mappa vettoriale di input contenente le linee"
+msgstr "Nome della colonna della centralità per autovettore (eigenvector centrality)"
#: ../vector/v.net.centrality/main.c:154
-#, fuzzy
msgid "Maximum number of iterations to compute eigenvector centrality"
-msgstr "Numero massimo di righe per una tile nella proiezione di origine"
+msgstr "Numero massimo di iterazioni per calcolare la centralità per autovettore"
#: ../vector/v.net.centrality/main.c:162
msgid "Cummulative error tolerance for eigenvector centrality"
-msgstr ""
+msgstr "Tolleranza d'errore cumulativa per la centralità per autovettore"
#: ../vector/v.net.centrality/main.c:171 ../vector/v.net.components/main.c:91
-#, fuzzy
msgid "Add points on nodes"
-msgstr "%d punti caricati"
+msgstr "Aggiunge punti sui nodi"
#: ../vector/v.net.centrality/main.c:244 ../vector/v.net.distance/main.c:212
#: ../vector/v.digit/c_face.c:282 ../vector/v.db.connect/main.c:331
@@ -19898,7 +19891,7 @@
#: ../vector/v.to.points/main.c:173 ../vector/v.segment/main.c:52
#: ../vector/v.hull/main.c:273
msgid "vector, geometry"
-msgstr ""
+msgstr "vettoriale, geometria"
#: ../vector/v.type/main.c:48
msgid "Change the type of geometry elements."
@@ -19996,9 +19989,8 @@
msgstr ""
#: ../vector/v.voronoi/vo_main.c:447
-#, fuzzy
msgid "Removing incorrect boundaries from output"
-msgstr "Rimuovi la mappa raster <%s> al gruppo"
+msgstr "Rimozione dei confini non corretti dall'output"
#: ../vector/v.voronoi/dt_main.c:47 ../vector/v.delaunay2/main.c:87
msgid "Creates a Delaunay triangulation from an input vector map containing points or centroids."
@@ -20017,11 +20009,11 @@
#: ../vector/v.buffer2/main.c:683 ../vector/v.buffer/main.c:663
#: ../vector/v.buffer/main.c:750
msgid "Cannot calculate area centroid"
-msgstr ""
+msgstr "Non è possibile calcolare il centroide dell'area"
#: ../vector/v.voronoi/dt_main.c:149
msgid "Cannot calculate area centroid z coordinate"
-msgstr ""
+msgstr "Non è possibile calcolare la coordinata z del centroide dell'area"
#: ../vector/v.net.steiner/main.c:58
#, c-format
@@ -20034,27 +20026,27 @@
#: ../vector/v.net.steiner/main.c:347
msgid "Create Steiner tree for the network and given terminals"
-msgstr "Crea albero di Streiner per la rete e i punti scelti"
+msgstr "Crea un albero di Steiner per la rete e i punti scelti."
#: ../vector/v.net.steiner/main.c:349
msgid "Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm is used in this module so the result may be sub optimal"
-msgstr ""
+msgstr "Da notare che il problema 'Minimum Steiner Tree' è NP-hard e in questo modulo viene utilizzato un algoritmo euristico, per cui il risultato può essere sub-ottimale"
#: ../vector/v.net.steiner/main.c:369
msgid "Node layer (used for terminals)"
-msgstr ""
+msgstr "Layer dei nodi (usato per i punti terminali)"
#: ../vector/v.net.steiner/main.c:375 ../vector/v.net.salesman/main.c:125
msgid "Arcs' cost column (for both directions)"
-msgstr ""
+msgstr "Colonna dei costi per gli archi (per entrambe le direzioni)"
#: ../vector/v.net.steiner/main.c:381
msgid "Categories of points on terminals (layer is specified by nlayer)"
-msgstr ""
+msgstr "Categorie dei punti sui punti terminali (il layer è specificato da nlayer)"
#: ../vector/v.net.steiner/main.c:389
msgid "Number of steiner points (-1 for all possible)"
-msgstr "Numero di punti di steiner (-1 per tutti quelli possibili"
+msgstr "Numero di punti di steiner (-1 per tutti quelli possibili)"
#: ../vector/v.net.steiner/main.c:453
msgid "Not enough terminals (< 2)"
@@ -20328,9 +20320,9 @@
msgstr "%d punti esterni ai limiti"
#: ../vector/v.kernel/main.c:334
-#, fuzzy, c-format
+#, c-format
msgid "Automatic choice of smoothing parameter (standard deviation), maximum possible value of standard deviation is set to %f"
-msgstr "Scegli automaticamente i parametri di smoothing (deviazione standard), il massimo valore possibile della deviazione standard è stato posto pari a %f"
+msgstr "Scelta automatica dei parametri di smoothing (deviazione standard), il massimo valore possibile della deviazione standard è stato posto pari a %f"
#: ../vector/v.kernel/main.c:341
#, c-format
@@ -20788,11 +20780,11 @@
#: ../vector/v.net/main.c:71
msgid "nodes;new point is placed on each node (line end) if doesn't exist;connect;connect still unconnected points to vector network by inserting new line(s);report;print to standard output {line_category start_point_category end_point_category};nreport;print to standard output {point_category line_category[,line_category...]}"
-msgstr ""
+msgstr "nodes;viene inserito un nuovo punto, se non esiste già, su ogni nodo (fine linea); connect;connette i punti non ancora connessi alla rete vettoriale inserendo nuove linee; report;stampa sullo standard output {line_category start_point_category end_point_category}; nreport;stampa sullo standard output {point_category line_category[,line_category...]}"
#: ../vector/v.net/main.c:97
msgid "Required for operation 'connect'. Connect points in given threshold."
-msgstr ""
+msgstr "Richiesto per l'operazione 'connect'. Connette i punti entro una data soglia."
#: ../vector/v.net/main.c:101
msgid "Assign unique categories to new points"
@@ -22970,7 +22962,7 @@
#: ../vector/v.db.connect/main.c:103
msgid "When printing, limit to layer specified by the layer option"
-msgstr ""
+msgstr "Limita la stampa al layer specificato dall'opzione layer"
#: ../vector/v.db.connect/main.c:108
msgid "Print types/names of table columns for specified layer and exit"
@@ -23416,19 +23408,19 @@
#: ../vector/v.distance/main.c:132
msgid "Feature type (from)"
-msgstr "Tipo di elemento (da)"
+msgstr "Tipo di elemento (from)"
#: ../vector/v.distance/main.c:139
msgid "Feature type (to)"
-msgstr "Tipo di elemento (a)"
+msgstr "Tipo di elemento (to)"
#: ../vector/v.distance/main.c:144
msgid "Layer number (from)"
-msgstr "Numero del layer (da)"
+msgstr "Numero del layer (from)"
#: ../vector/v.distance/main.c:149
msgid "Layer number (to)"
-msgstr "Numero del layer (a)"
+msgstr "Numero del layer (to)"
#: ../vector/v.distance/main.c:155
msgid "Name for output vector map containing lines connecting nearest elements"
@@ -23446,7 +23438,6 @@
msgid "Values describing the relation between two nearest features"
msgstr "Valori che descrivono la relazione fra due elementi più vicini"
-# finire
#: ../vector/v.distance/main.c:181
msgid "cat;category of the nearest feature;dist;minimum distance to nearest feature;to_x;x coordinate of the nearest point on the 'to' feature;to_y;y coordinate of the nearest point on the 'to' feature;to_along;distance to the nearest point on the 'to' feature along that linear feature;to_angle;angle along the nearest linear feature in the 'to' map, measured CCW from the +x axis, in radians, between -Pi and Pi inclusive;to_attr;attribute of nearest feature given by to_column option"
msgstr "cat;categoria dell'elemento più vicino;dist;distanza minima dall'elemento più vicino;to_x;coordinata x del punto più vicino sull'elemento 'to';to_y; coordinata y del punto più vicino sull'elemento 'to';to_along;distanza dal punto più vicino sull'elemento 'to' lungo lo stesso elemento lineare;to_angle;angolo lungo l'elemento lineare più vicino nella mappa 'to', misurato in senso antiorario dall'asse +x, in radianti, fra -Pi e Pi inclusi;to_attr;attributo dell'elemento più vicino dato dall'opzione to_column"
@@ -23463,7 +23454,6 @@
msgid "Column name of nearest feature (used with upload=to_attr)"
msgstr "Nome della colonna dell'elemento più vicino (usato con upload=to_attr)"
-# finire
#: ../vector/v.distance/main.c:214
msgid "Name of table created for output when the distance to all flag is used"
msgstr "Nome della tabella creata per l'output quando è utilizzato il flag della distanza da tutti (-a)"
@@ -23476,7 +23466,6 @@
msgid "First column is always category of 'from' feature called from_cat"
msgstr "La prima colonna è sempre la categoria dell'elemento 'from' chiamato da from_cat"
-# finire
#: ../vector/v.distance/main.c:226
msgid "Calculate distances to all features within the threshold"
msgstr "Calcola le distanze da tutti gli elementi entro la soglia"
@@ -23613,7 +23602,7 @@
#: ../vector/v.to.db/main.c:34
msgid "Populates database values from vector features."
-msgstr "Popola i valori del database da features vettoriali"
+msgstr "Popola i valori del database da elementi vettoriali"
#: ../vector/v.to.db/update.c:82
msgid "Updating database..."
@@ -25745,9 +25734,8 @@
msgstr ""
#: ../vector/v.net.spanningtree/main.c:59
-#, fuzzy
msgid "Name of Arc cost column"
+msgstr "Nome della colonna dei costi per gli archi"
#: ../vector/v.out.pov/main.c:207
#, c-format
@@ -25780,7 +25768,7 @@
#: ../vector/v.select/main.c:52
msgid "vector, spatial query"
-msgstr ""
+msgstr "vettoriale, interrogazioni spaziali"
#: ../vector/v.select/main.c:54
msgid "Selects features from vector map (A) by features from other vector map (B)."
@@ -26750,7 +26738,7 @@
#: ../vector/v.in.dxf/main.c:189
msgid "Building topology failed"
-msgstr "Costruizione della topologia fallita"
+msgstr "Costruzione della topologia fallita"
#: ../vector/v.in.dxf/main.c:195
msgid "Failed to import DXF file!"
@@ -26845,19 +26833,19 @@
#: ../vector/v.net.salesman/main.c:97
msgid "vector, network, salesman"
-msgstr "vettore, rete, salesman"
+msgstr "vettoriale, rete, salesman"
#: ../vector/v.net.salesman/main.c:99
msgid "Creates a cycle connecting given nodes (Traveling salesman problem)."
-msgstr "Crea un ciclo connettendo i nodi dati (problema del commesso viaggiatore)"
+msgstr "Crea un ciclo connettendo i nodi dati (TSP - problema del commesso viaggiatore)."
#: ../vector/v.net.salesman/main.c:101
msgid "Note that TSP is NP-hard, heuristic algorithm is used by this module and created cycle may be sub optimal"
-msgstr ""
+msgstr "Da notare che TSP è NP-hard, e in questo modulo viene utilizzato un algoritmo euristico per cui il ciclo creato può essere sub-ottimale"
#: ../vector/v.net.salesman/main.c:119
msgid "Node layer (used for cities)"
-msgstr ""
+msgstr "Layer dei nodi (usato per le città)"
#: ../vector/v.net.salesman/main.c:130
msgid "Categories of points ('cities') on nodes (layer is specified by nlayer)"
@@ -27831,23 +27819,23 @@
#: ../vector/v.net.path/main.c:65
msgid "Name of file containing start and end points. If not given, read from stdin"
-msgstr ""
+msgstr "Nome del file contenente i punti d'inizio e di fine. Se non sono definiti legge dallo stdin"
#: ../vector/v.net.path/main.c:92
msgid "Maximum distance to the network"
-msgstr ""
+msgstr "Distanza massima dalla rete"
#: ../vector/v.net.path/main.c:93
msgid "If start/end are given as coordinates. If start/end point is outside this threshold, the path is not found and error message is printed. To speed up the process, keep this value as low as possible."
-msgstr ""
+msgstr "Se inizio/fine sono dati come coordinate. Se il punto inizio/fine è al di fuori di questa soglia, il percorso non viene trovato e viene stampato un messaggio d'errore. Per velocizzare il processo è meglio tenere questo valore più basso possibile."
#: ../vector/v.net.path/main.c:106
msgid "Write output as original input segments, not each path as one line."
-msgstr ""
+msgstr "Disegna sull'output i segmenti originali di input, anziché rappresentare ogni percorso con una linea."
#: ../vector/v.net.connectivity/main.c:53
msgid "vector, network, connectivity"
-msgstr ""
+msgstr "vettoriale, rete, connettività"
#: ../vector/v.net.connectivity/main.c:55
msgid "Computes vertex connectivity between two sets of nodes in the network."
@@ -28147,7 +28135,7 @@
#: ../vector/v.net.visibility/main.c:46
msgid "vector, path, visibility"
-msgstr ""
+msgstr "vettoriale, percorso, visibilità"
#: ../vector/v.net.visibility/main.c:47
msgid "Visibility graph construction."
