[GRASS-SVN] r51114 - grass/trunk/vector/v.external.out
svn_grass at osgeo.org
Mon Mar 19 17:38:57 EDT 2012
Author: martinl
Date: 2012-03-19 14:38:57 -0700 (Mon, 19 Mar 2012)
New Revision: 51114
grass/trunk/vector/v.external.out/Makefile
grass/trunk/vector/v.external.out/args.c
grass/trunk/vector/v.external.out/format.c
grass/trunk/vector/v.external.out/link.c
grass/trunk/vector/v.external.out/list.c
grass/trunk/vector/v.external.out/local_proto.h
grass/trunk/vector/v.external.out/main.c
grass/trunk/vector/v.external.out/status.c
v.external.out: major update for pg support
Modified: grass/trunk/vector/v.external.out/Makefile
--- grass/trunk/vector/v.external.out/Makefile 2012-03-19 20:23:14 UTC (rev 51113)
+++ grass/trunk/vector/v.external.out/Makefile 2012-03-19 21:38:57 UTC (rev 51114)
@@ -10,6 +10,6 @@
include $(MODULE_TOPDIR)/include/Make/Module.make
-ifneq ($(USE_OGR),)
+ifneq ($(filter 1,$(USE_OGR) $(USE_POSTGRES)),)
default: cmd
endif
Modified: grass/trunk/vector/v.external.out/args.c
--- grass/trunk/vector/v.external.out/args.c 2012-03-19 20:23:14 UTC (rev 51113)
+++ grass/trunk/vector/v.external.out/args.c 2012-03-19 21:38:57 UTC (rev 51114)
@@ -10,20 +10,31 @@
options->dsn = G_define_option();
options->dsn->key = "dsn";
- options->dsn->description = _("Name for output OGR datasource");
+ options->dsn->label = _("Name for output OGR/PostGIS data source");
+ options->dsn->description = _("Examples:\n"
+ "\t\tESRI Shapefile: directory containing a shapefile\n"
+ "\t\tMapInfo File: directory containing a mapinfo file\n"
+ "\t\tPostGIS: connection string, eg. 'PG:dbname=db user=grass'");
options->dsn->required = YES;
options->dsn->type = TYPE_STRING;
options->format = G_define_option();
options->format->key = "format";
- options->format->description = _("Format of output files");
+ options->format->label = _("Format for output vector data");
+ options->format->description = _("PostGIS is supported via PG ('format=PostGIS') or "
+ "OGR (format=PostgreSQL) data driver");
options->format->required = YES;
options->format->type = TYPE_STRING;
options->format->options = format_list();
options->opts = G_define_option();
options->opts->key = "options";
- options->opts->description = _("Creation options");
+ options->opts->label = _("Creation options");
+ options->opts->description = _("Examples:\n"
+ "\t\t'SHPT=POINTZ': use 3D point Shapefile data\n"
+ "\t\t'GEOM_TYPE=geography': use geography PostGIS data\n"
+ "\t\t'SCHEMA=grass': create new PostGIS tables in 'grass' schema");
options->opts->required = NO;
options->opts->multiple = YES;
options->opts->type = TYPE_STRING;
@@ -36,7 +47,7 @@
flags->r = G_define_flag();
flags->r->key = 'r';
- flags->r->description = _("Cease using OGR, revert to native output and exit");
+ flags->r->description = _("Cease using OGR/PostGIS, revert to native output and exit");
flags->r->suppress_required = YES;
flags->r->guisection = _("Native");
Modified: grass/trunk/vector/v.external.out/format.c
--- grass/trunk/vector/v.external.out/format.c 2012-03-19 20:23:14 UTC (rev 51113)
+++ grass/trunk/vector/v.external.out/format.c 2012-03-19 21:38:57 UTC (rev 51114)
@@ -1,10 +1,16 @@
#include <grass/gis.h>
#include <grass/glocale.h>
+#ifdef HAVE_OGR
#include "ogr_api.h"
+#endif
void check_format(char *format)
+ if(strcmp(format, "PostGIS") == 0)
+ return;
+#ifdef HAVE_OGR
OGRSFDriverH driver;
G_strchg(format, '_', ' ');
@@ -17,4 +23,5 @@
return;
G_fatal_error(_("Format <%s> does not support writing"), format);
+#endif
Modified: grass/trunk/vector/v.external.out/link.c
--- grass/trunk/vector/v.external.out/link.c 2012-03-19 20:23:14 UTC (rev 51113)
+++ grass/trunk/vector/v.external.out/link.c 2012-03-19 21:38:57 UTC (rev 51114)
@@ -5,46 +5,78 @@
void make_link(const char *dsn,
- const char *format, char **options)
+ const char *format,
+ char *option_str, char **options)
- struct Key_Value *key_val = G_create_key_value();
- char *opt_str = NULL;
+ int i, use_ogr;
+ char *filename, *pg_schema;
FILE *fp;
+ struct Key_Value *key_val;
+ key_val = G_create_key_value();
- if (options && *options) {
- int n_opts = 0, opt_len = 0, i;
- char *p;
+ /* use OGR ? */
+ if (strcmp(format, "PostGIS") == 0) {
+ use_ogr = FALSE;
+ filename = "PG";
+ G_remove("", "OGR");
+ else {
+ use_ogr = TRUE;
+ filename = "OGR";
+ G_remove("", "PG");
+ /* parse options */
+ pg_schema = NULL;
+ if (options && *options && !use_ogr) {
+ int opt_len;
+ char *opt_schema;
+ opt_schema = NULL;
for (i = 0; options[i]; i++) {
- n_opts++;
- opt_len += strlen(options[i]) + 1;
+ if (G_strncasecmp("schema=", options[i], 6) == 0)
+ opt_schema = options[i];
+ else
+ G_warning(_("Option '%s' ignored for 'PostGIS' format"),
+ options[i]);
- opt_str = G_malloc(opt_len);
- p = opt_str;
- for (i = 0; i < n_opts; i++) {
- if (i > 0)
- *p++ = ',';
- strcpy(p, options[i]);
- p += strlen(options[i]);
+ if (opt_schema) {
+ opt_len = strlen(opt_schema);
+ pg_schema = G_malloc(opt_len - 6);
+ for (i = 7; i < opt_len; i++) {
+ pg_schema[i - 7] = opt_schema[i];
+ pg_schema[opt_len - 7] = '\0';
- *p++ = '\0';
- if (dsn)
- G_set_key_value("dsn", dsn, key_val);
- if (format)
+ /* add key/value items */
+ if (dsn) {
+ if (use_ogr)
+ G_set_key_value("dsn", dsn, key_val);
+ else
+ G_set_key_value("conninfo", dsn, key_val);
+ if (format && use_ogr)
G_set_key_value("format", format, key_val);
- if (opt_str)
- G_set_key_value("options", opt_str, key_val);
- fp = G_fopen_new("", "OGR");
+ if (use_ogr && option_str)
+ G_set_key_value("options", option_str, key_val);
+ if (!use_ogr && pg_schema)
+ G_set_key_value("schema", pg_schema, key_val);
+ /* save file - OGR or PG */
+ fp = G_fopen_new("", filename);
if (!fp)
- G_fatal_error(_("Unable to create OGR file"));
+ G_fatal_error(_("Unable to create %s file"), filename);
if (G_fwrite_key_value(fp, key_val) < 0)
- G_fatal_error(_("Error writing OGR file"));
+ G_fatal_error(_("Error writing %s file"), filename);
fclose(fp);
Modified: grass/trunk/vector/v.external.out/list.c
--- grass/trunk/vector/v.external.out/list.c 2012-03-19 20:23:14 UTC (rev 51113)
+++ grass/trunk/vector/v.external.out/list.c 2012-03-19 21:38:57 UTC (rev 51114)
@@ -1,22 +1,33 @@
+#include <string.h>
+#ifdef HAVE_OGR
-static int cmp(const void *, const void *);
+int cmp(const void *a, const void *b)
+ return (strcmp(*(char **)a, *(char **)b));
+#endif /* HAVE_OGR */
char *format_list(void)
int i, count;
size_t len;
- OGRSFDriverH Ogr_driver;
- char buf[2000];
char **list, *ret;
list = NULL;
count = len = 0;
+ ret = NULL;
+#ifdef HAVE_OGR
+ char buf[2000];
+ OGRSFDriverH Ogr_driver;
/* Open OGR DSN */
OGRRegisterAll();
G_debug(2, "driver count = %d", OGRGetDriverCount());
@@ -39,7 +50,12 @@
qsort(list, count, sizeof(char *), cmp);
+#endif
+#ifdef HAVE_POSTGRES
+ list = G_realloc(list, (count + 1) * sizeof(char *));
+ list[count++] = G_store("PostGIS");
+ len += strlen("PostGIS") + 1;
+#endif
if (len > 0) {
ret = G_malloc((len + 1) * sizeof(char)); /* \0 */
*ret = '\0';
@@ -56,12 +72,15 @@
G_debug(2, "all drivers: %s", ret);
return ret;
void list_formats(void)
+ G_message(_("List of supported formats:"));
+#ifdef HAVE_OGR
/* List supported formats and exit. */
/* code from GDAL 1.2.5 gcore/gdal_misc.cpp */
@@ -70,19 +89,18 @@
int iDr;
- G_message(_("Supported Formats:"));
for (iDr = 0; iDr < OGRGetDriverCount(); iDr++) {
driver = OGRGetDriver(iDr);
if (!OGR_Dr_TestCapability(driver, ODrCCreateDataSource))
continue;
- fprintf(stdout, " %s\n", OGR_Dr_GetName(driver));
+ fprintf(stdout, "%s\n", OGR_Dr_GetName(driver));
+#endif
+ fprintf(stdout, "PostGIS\n");
+#endif
fflush(stdout);
-int cmp(const void *a, const void *b)
- return (strcmp(*(char **)a, *(char **)b));
Modified: grass/trunk/vector/v.external.out/local_proto.h
--- grass/trunk/vector/v.external.out/local_proto.h 2012-03-19 20:23:14 UTC (rev 51113)
+++ grass/trunk/vector/v.external.out/local_proto.h 2012-03-19 21:38:57 UTC (rev 51114)
@@ -18,7 +18,7 @@
/* link.c */
void make_link(const char *,
- const char *, char **);
+ const char *, const char *, char **);
/* list.c */
char *format_list(void);
Modified: grass/trunk/vector/v.external.out/main.c
--- grass/trunk/vector/v.external.out/main.c 2012-03-19 20:23:14 UTC (rev 51113)
+++ grass/trunk/vector/v.external.out/main.c 2012-03-19 21:38:57 UTC (rev 51114)
@@ -15,11 +15,16 @@
+#include <stdlib.h>
#include <grass/vector.h>
+#ifdef HAVE_OGR
+#endif
#include "local_proto.h"
int main(int argc, char *argv[])
@@ -35,11 +40,13 @@
G_add_keyword(_("export"));
G_add_keyword(_("output"));
G_add_keyword(_("external"));
- module->description =
- _("Defines vector output format utilizing OGR library.");
+ G_add_keyword(_("OGR"));
+ G_add_keyword(_("PostGIS"));
+ module->description = _("Defines vector output format.");
+#ifdef HAVE_OGR
OGRRegisterAll();
+#endif
parse_args(argc, argv, &options, &flags);
if (flags.f->answer) {
@@ -48,7 +55,8 @@
if (flags.r->answer) {
- G_remove("", "OGR");
+ if (G_remove("", "OGR") == 0)
exit(EXIT_SUCCESS);
@@ -56,8 +64,8 @@
check_format(options.format->answer);
if (options.dsn->answer)
- make_link(options.dsn->answer,
- options.format->answer, options.opts->answers);
+ make_link(options.dsn->answer, options.format->answer,
+ options.opts->answer, options.opts->answers);
if (flags.p->answer || flags.g->answer) {
print_status(flags.g->answer ? 1 : 0);
Modified: grass/trunk/vector/v.external.out/status.c
--- grass/trunk/vector/v.external.out/status.c 2012-03-19 20:23:14 UTC (rev 51113)
+++ grass/trunk/vector/v.external.out/status.c 2012-03-19 21:38:57 UTC (rev 51114)
@@ -1,49 +1,81 @@
#include <stdlib.h>
+static int print_status_file(const char *, int shell);
void print_status(int shell)
+ /* try to print OGR first then PG if needed */
+ if (print_status_file("OGR", shell))
+ return;
+ if (print_status_file("PG", shell))
+ return;
+ if (shell)
+ fprintf(stdout, "format=%s\n", "native");
+ else
+ fprintf(stdout, _("format: native\n"));
+int print_status_file(const char *file, int shell)
FILE *fp;
- struct Key_Value *key_val;
const char *p;
- if (!G_find_file2("", "OGR", G_mapset())) {
- if (shell)
- fprintf(stdout, "format=%s\n", "native");
- else
- fprintf(stdout, _("format: native\n"));
- return;
- fp = G_fopen_old("", "OGR", G_mapset());
+ fp = G_fopen_old("", file, G_mapset());
if (!fp)
- G_fatal_error(_("Unable to open OGR file"));
+ return FALSE;
key_val = G_fread_key_value(fp);
fclose(fp);
- p = G_find_key_value("dsn", key_val);
- if (shell)
- fprintf(stdout, "dsn=%s\n",
- p ? p : "ogr");
- else
- fprintf(stdout, _("dsn: %s\n"),
- p ? p : _("not set (default 'ogr')"));
+ if (strcmp(file, "OGR") == 0) {
+ p = G_find_key_value("dsn", key_val);
+ if (!p)
+ G_fatal_error(_("OGR datasource (dsn) not defined"));
+ if (shell)
+ fprintf(stdout, "dsn=%s\n", p);
+ else
+ fprintf(stdout, "dsn: %s\n", p);
+ p = G_find_key_value("format", key_val);
+ if (!p)
+ G_fatal_error(_("OGR format not defined"));
+ if (shell)
+ fprintf(stdout, "format=%s\n", p);
+ else
+ fprintf(stdout, "format: %s\n", p);
+ p = G_find_key_value("options", key_val);
+ if (shell)
+ fprintf(stdout, "options=%s\n", p ? p : "");
+ else
+ fprintf(stdout, _("options: %s\n"), p ? p : _("<none>"));
+ else { /* PG */
+ p = G_find_key_value("conninfo", key_val);
+ if (!p)
+ G_fatal_error(_("PG connection info (conninfo) not defined"));
+ if (shell)
+ fprintf(stdout, "conninfo=%s\n", p);
+ else
+ fprintf(stdout, "conninfo: %s\n", p);
+ p = G_find_key_value("schema", key_val);
+ if (p) {
+ if (shell)
+ fprintf(stdout, "schema=%s\n", p);
+ else
+ fprintf(stdout, "schema: %s\n", p);
- p = G_find_key_value("format", key_val);
- if (shell)
- p ? p : "ESRI_Shapefile");
- else
- fprintf(stdout, _("format: %s\n"),
- p ? p : _("not set (default ESRI_Shapefile)"));
- p = G_find_key_value("options", key_val);
- if (shell)
- fprintf(stdout, "options=%s\n", p ? p : "");
- else
- fprintf(stdout, _("options: %s\n"), p ? p : _("<none>"));
G_free_key_value(key_val);
+ return TRUE;
