[GRASS-SVN] r51124 - grass/trunk/lib/gis
svn_grass at osgeo.org
Wed Mar 21 07:04:49 EDT 2012
Author: martinl
Date: 2012-03-21 04:04:49 -0700 (Wed, 21 Mar 2012)
New Revision: 51124
grass/trunk/lib/gis/key_value1.c
grass/trunk/lib/gis/key_value2.c
grass/trunk/lib/gis/key_value3.c
libgis: doxygen docs update (key_value_[1|2|3].c)
use G_zero() when initializing Key_Value structure
Modified: grass/trunk/lib/gis/key_value1.c
--- grass/trunk/lib/gis/key_value1.c 2012-03-21 02:00:01 UTC (rev 51123)
+++ grass/trunk/lib/gis/key_value1.c 2012-03-21 11:04:49 UTC (rev 51124)
@@ -1,14 +1,12 @@
- \file key_value1.c
+ \file lib/gis/key_value1.c
- \brief Key_Value management.
+ \brief Subroutines for Key/Value management.
- (C) 2001-2008 by the GRASS Development Team
+ (C) 2001-2008, 2012 by the GRASS Development Team
- This program is free software under the
- GNU General Public License (>=v2).
- Read the file COPYING that comes with GRASS
- for details.
+ This program is free software under the GNU General Public License
+ (>=v2). Read the file COPYING that comes with GRASS for details.
\author CERL
@@ -25,23 +23,18 @@
struct Key_Value *G_create_key_value(void)
struct Key_Value *kv = G_malloc(sizeof(struct Key_Value));
- kv->nitems = 0;
- kv->nalloc = 0;
- kv->key = NULL;
- kv->value = NULL;
+ G_zero(kv, sizeof(struct Key_Value));
return kv;
\brief Set value for given key
- \param[in] key key to be set up
- \param[in] value value for given key
+ \param key key to be set up
+ \param value value for given key
\param[in,out] kv Key_value structure to be modified
void G_set_key_value(const char *key, const char *value, struct Key_Value *kv)
int n;
@@ -80,10 +73,10 @@
- \brief Find given key
+ \brief Find given key (case sensitive)
- \param[in] key key to be found
- \param[in] kv Key_value structure
+ \param key key to be found
+ \param kv pointer to Key_value structure
\return poiter to value of key
\return NULL if no key found
@@ -105,9 +98,7 @@
\brief Free allocated Key_Value structure
- \param[in] kv Key_Value structure
- \return
+ \param[in] kv Key_Value structure to be freed
void G_free_key_value(struct Key_Value *kv)
Modified: grass/trunk/lib/gis/key_value2.c
--- grass/trunk/lib/gis/key_value2.c 2012-03-21 02:00:01 UTC (rev 51123)
+++ grass/trunk/lib/gis/key_value2.c 2012-03-21 11:04:49 UTC (rev 51124)
@@ -1,14 +1,12 @@
- \file key_value2.c
+ \file lib/gis/key_value2.c
\brief Read/write Key_Value from/to file.
- for details.
\author CERL
@@ -19,7 +17,7 @@
\brief Write key/value pairs to file
\param[in,out] fd file to write to
+ \param kv pointer Key_Value structure
\return 0 success
\return -1 error writing
@@ -43,7 +41,7 @@
Allocated memory must be freed G_free_key_value().
- \param[in] fd file to read key/values from
+ \param fd file to read key/values from
\return pointer to allocated Key_Value structure
\return NULL on error
Modified: grass/trunk/lib/gis/key_value3.c
--- grass/trunk/lib/gis/key_value3.c 2012-03-21 02:00:01 UTC (rev 51123)
+++ grass/trunk/lib/gis/key_value3.c 2012-03-21 11:04:49 UTC (rev 51124)
@@ -1,14 +1,12 @@
- \file key_value3.c
+ \file lib/gis/key_value3.c
- for details.
\author CERL
@@ -19,13 +17,12 @@
- \param[in] file filename for writing
+ \param file filename for writing
\return 0 success
\return 1 error writing
void G_write_key_value_file(const char *file,
const struct Key_Value *kv)
@@ -43,10 +40,10 @@
\brief Read key/values pairs from file
- Allocated memory must be freed G_free_key_value().
+ Allocated memory must be freed G_free_key_value(). Call
+ G_fatal_error() when unable to read key/value items from the file.
\param[in] file filename for reading
- \param[out] stat status (0 ok, -1 cannot open file, -2 error writing key/value)
\return poiter to allocated Key_Value structure
