[GRASS-SVN] r51140 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Wed Mar 21 19:59:57 EDT 2012
Author: martinl
Date: 2012-03-21 16:59:57 -0700 (Wed, 21 Mar 2012)
New Revision: 51140
grass/trunk/lib/vector/Vlib/open_pg.c
vlib(pg): create schema if not exist
fix creating sidx
Modified: grass/trunk/lib/vector/Vlib/open_pg.c
--- grass/trunk/lib/vector/Vlib/open_pg.c 2012-03-21 23:33:53 UTC (rev 51139)
+++ grass/trunk/lib/vector/Vlib/open_pg.c 2012-03-21 23:59:57 UTC (rev 51140)
@@ -26,6 +26,7 @@
static char *get_key_column(struct Format_info_pg *);
static SF_FeatureType ftype_from_string(const char *);
static int drop_table(struct Format_info_pg *);
+static int check_schema(const struct Format_info_pg*);
static int create_table(struct Format_info_pg *, const struct field_info *);
#endif
@@ -444,6 +445,45 @@
return 0;
+int check_schema(const struct Format_info_pg *pg_info)
+ int i, found, nschema;
+ char stmt[DB_SQL_MAX];
+ PGresult *result;
+ /* add geometry column */
+ sprintf(stmt, "SELECT nspname FROM pg_namespace");
+ G_debug(2, "SQL: %s", stmt);
+ result = PQexec(pg_info->conn, stmt);
+ if (!result || PQresultStatus(result) != PGRES_TUPLES_OK) {
+ PQclear(result);
+ execute(pg_info->conn, "ROLLBACK");
+ return -1;
+ found = FALSE;
+ nschema = PQntuples(result);
+ for (i = 0; i < nschema && !found; i++) {
+ if (strcmp(pg_info->schema_name, PQgetvalue(result, i, 0)) == 0)
+ found = TRUE;
+ PQclear(result);
+ if (!found) {
+ sprintf(stmt, "CREATE SCHEMA %s", pg_info->schema_name);
+ if (execute(pg_info->conn, stmt) == -1) {
+ return -1;
+ G_warning(_("Schema <%s> doesn't exist, created"), pg_info->schema_name);
+ return 0;
int create_table(struct Format_info_pg *pg_info, const struct field_info *Fi)
int spatial_index, primary_key;
@@ -476,6 +516,12 @@
primary_key = FALSE;
+ /* create schema if not exists */
+ if (G_strcasecmp(pg_info->schema_name, "public") != 0) {
+ if (check_schema(pg_info) != 0)
+ return -1;
/* prepare CREATE TABLE statement */
sprintf(stmt, "CREATE TABLE \"%s\".\"%s\" (%s SERIAL",
pg_info->schema_name, pg_info->table_name,
@@ -619,8 +665,9 @@
/* create index ? */
if (spatial_index) {
- sprintf(stmt, "CREATE INDEX %s_%s_idx ON %s USING GIST (%s)",
- pg_info->table_name, pg_info->geom_column, pg_info->table_name,
+ sprintf(stmt, "CREATE INDEX %s_%s_idx ON \"%s\".\"%s\" USING GIST (%s)",
+ pg_info->table_name, pg_info->geom_column,
+ pg_info->schema_name, pg_info->table_name,
pg_info->geom_column);
