[GRASS-SVN] r51159 - grass/trunk/vector/v.external.out
svn_grass at osgeo.org
Mon Mar 26 02:52:14 EDT 2012
Author: martinl
Date: 2012-03-25 23:52:14 -0700 (Sun, 25 Mar 2012)
New Revision: 51159
grass/trunk/vector/v.external.out/status.c
v.external.out: print `format` explicitly for PostGIS links
print all creation options in shell script style output
Modified: grass/trunk/vector/v.external.out/status.c
--- grass/trunk/vector/v.external.out/status.c 2012-03-23 21:16:11 UTC (rev 51158)
+++ grass/trunk/vector/v.external.out/status.c 2012-03-26 06:52:14 UTC (rev 51159)
@@ -24,11 +24,11 @@
void print_key_value(const char *key, const char *value, int shell)
- if (!value)
+ if (!value && !shell)
return;
if (shell)
- fprintf(stdout, "%s=%s\n", key, value);
+ fprintf(stdout, "%s=%s\n", key, value ? value : "");
else
fprintf(stdout, "%s: %s\n", key, value);
@@ -71,6 +71,9 @@
G_fatal_error(_("PG connection info (conninfo) not defined"));
print_key_value("conninfo", p, shell);
+ /* format (hardcoded) */
+ print_key_value("format", "PostGIS", shell);
/* schema */
p = G_find_key_value("schema", key_val);
print_key_value("schema", p, shell);
