[GRASS-SVN] r51172 - grass/trunk/lib/python
svn_grass at osgeo.org
Wed Mar 28 06:28:16 EDT 2012
Author: lucadelu
Date: 2012-03-28 03:28:15 -0700 (Wed, 28 Mar 2012)
New Revision: 51172
grass/trunk/lib/python/core.py
rast, raster and cell can be used in all the function that search raster maps
Modified: grass/trunk/lib/python/core.py
--- grass/trunk/lib/python/core.py 2012-03-28 08:11:34 UTC (rev 51171)
+++ grass/trunk/lib/python/core.py 2012-03-28 10:28:15 UTC (rev 51172)
@@ -723,6 +723,9 @@
@return parsed output of g.findfile
+ if element == 'raster' or element == 'rast':
+ verbose(_('Element type should be "cell" and not "%s"') % element)
+ element = 'cell'
s = read_command("g.findfile", flags='n', element = element, file = name, mapset = mapset)
return parse_key_val(s)
@@ -745,6 +748,9 @@
@return directory of mapsets/elements
+ if type == 'raster' or type == 'cell':
+ verbose(_('Element type should be "rast" and not "%s"') % element)
+ type = 'rast'
dashes_re = re.compile("^----+$")
mapset_re = re.compile("<(.*)>")
result = {}
@@ -825,6 +831,9 @@
@return list of elements
+ type = 'rast'
result = list()
for line in read_command("g.mlist",
quiet = True,
@@ -870,6 +879,9 @@
+ type = 'rast'
result = {}
if check_search_path:
for mapset in mapsets(search_path = True):
