[GRASS-SVN] r51177 - in grass/trunk: include lib/gis
vector/v.in.dxf vector/v.in.lidar vector/v.in.ogr
vector/v.overlay vector/v.select vector/v.to.points vector/v.voronoi
svn_grass at osgeo.org
Wed Mar 28 10:36:46 EDT 2012
Author: martinl
Date: 2012-03-28 07:36:45 -0700 (Wed, 28 Mar 2012)
New Revision: 51177
grass/trunk/include/gis.h
grass/trunk/lib/gis/parser_standard_options.c
grass/trunk/vector/v.in.dxf/main.c
grass/trunk/vector/v.in.lidar/main.c
grass/trunk/vector/v.in.ogr/main.c
grass/trunk/vector/v.overlay/main.c
grass/trunk/vector/v.select/args.c
grass/trunk/vector/v.to.points/main.c
grass/trunk/vector/v.voronoi/main.c
G_FLG_DB_TABLE -> G_FLG_V_TABLE
update modules to use G_FLG_V_TABLE
Modified: grass/trunk/include/gis.h
--- grass/trunk/include/gis.h 2012-03-28 13:59:36 UTC (rev 51176)
+++ grass/trunk/include/gis.h 2012-03-28 14:36:45 UTC (rev 51177)
@@ -256,7 +256,7 @@
/**/ typedef enum
G_FLG_UNDEFINED,
- G_FLG_DB_TABLE, /* do not create table */
+ G_FLG_V_TABLE, /* do not create attribute table */
G_FLG_V_TOPO, /* do not build topology */
} STD_FLG;
Modified: grass/trunk/lib/gis/parser_standard_options.c
--- grass/trunk/lib/gis/parser_standard_options.c 2012-03-28 13:59:36 UTC (rev 51176)
+++ grass/trunk/lib/gis/parser_standard_options.c 2012-03-28 14:36:45 UTC (rev 51177)
@@ -781,7 +781,7 @@
If an invalid parameter was specified a empty Flag structure will be
returned (not NULL).
- - G_FLG_DB_TABLE (do not create attribute table)
+ - G_FLG_V_TABLE (do not create attribute table)
- G_FLG_V_TOPO (do not build topology)
\param flag type of Flag struct to create
@@ -795,7 +795,7 @@
Flg = G_define_flag();
switch (flag) {
- case G_FLG_DB_TABLE:
+ case G_FLG_V_TABLE:
Flg->key = 't';
Flg->description = _("Do not create attribute table");
break;
Modified: grass/trunk/vector/v.in.dxf/main.c
--- grass/trunk/vector/v.in.dxf/main.c 2012-03-28 13:59:36 UTC (rev 51176)
+++ grass/trunk/vector/v.in.dxf/main.c 2012-03-28 14:36:45 UTC (rev 51177)
@@ -71,9 +71,7 @@
flag.extent->key = 'e';
flag.extent->description = _("Ignore the map extent of DXF file");
- flag.table = G_define_flag();
- flag.table->key = 't';
- flag.table->description = _("Do not create attribute tables");
+ flag.table = G_define_standard_flag(G_FLG_V_TABLE);
flag.topo = G_define_standard_flag(G_FLG_V_TOPO);
Modified: grass/trunk/vector/v.in.lidar/main.c
--- grass/trunk/vector/v.in.lidar/main.c 2012-03-28 13:59:36 UTC (rev 51176)
+++ grass/trunk/vector/v.in.lidar/main.c 2012-03-28 14:36:45 UTC (rev 51177)
@@ -192,9 +192,7 @@
_("Print LAS file info and exit");
print_flag->suppress_required = YES;
- notab_flag = G_define_flag();
- notab_flag->key = 't';
- notab_flag->description = _("Do not create attribute table");
+ notab_flag = G_define_standard_flag(G_FLG_V_TABLE);
notab_flag->guisection = _("Attributes");
over_flag = G_define_flag();
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c 2012-03-28 13:59:36 UTC (rev 51176)
+++ grass/trunk/vector/v.in.ogr/main.c 2012-03-28 14:36:45 UTC (rev 51177)
@@ -230,9 +230,7 @@
flag.z->description = _("Create 3D output");
flag.z->guisection = _("Output");
- flag.notab = G_define_flag();
- flag.notab->key = 't';
- flag.notab->description = _("Do not create attribute table");
+ flag.notab = G_define_standard_flag(G_FLG_V_TABLE);
flag.notab->guisection = _("Attributes");
flag.over = G_define_flag();
Modified: grass/trunk/vector/v.overlay/main.c
--- grass/trunk/vector/v.overlay/main.c 2012-03-28 13:59:36 UTC (rev 51176)
+++ grass/trunk/vector/v.overlay/main.c 2012-03-28 14:36:45 UTC (rev 51177)
@@ -33,7 +33,6 @@
int i, input, line, nlines, operator;
int type[2], field[2], ofield[3];
- char *pre[2];
struct GModule *module;
struct Option *in_opt[2], *out_opt, *type_opt[2], *field_opt[2],
*ofield_opt, *operator_opt;
@@ -51,9 +50,6 @@
G_gisinit(argv[0]);
- pre[0] = "a";
- pre[1] = "b";
module = G_define_module();
G_add_keyword(_("vector"));
G_add_keyword(_("geometry"));
@@ -118,9 +114,7 @@
ofield_opt->description = _("If 0 or not given, "
"the category is not written");
- table_flag = G_define_flag();
- table_flag->key = 't';
- table_flag->description = _("Do not create attribute table");
+ table_flag = G_define_standard_flag(G_FLG_V_TABLE);
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
Modified: grass/trunk/vector/v.select/args.c
--- grass/trunk/vector/v.select/args.c 2012-03-28 13:59:36 UTC (rev 51176)
+++ grass/trunk/vector/v.select/args.c 2012-03-28 14:36:45 UTC (rev 51177)
@@ -74,9 +74,7 @@
parm->relate->description = _("Intersection Matrix Pattern used for 'relate' operator");
#endif
- flag->table = G_define_flag();
- flag->table->key = 't';
- flag->table->description = _("Do not create attribute table");
+ flag->table = G_define_standard_flag(G_FLG_V_TABLE);
flag->cat = G_define_flag();
flag->cat->key = 'c';
Modified: grass/trunk/vector/v.to.points/main.c
--- grass/trunk/vector/v.to.points/main.c 2012-03-28 13:59:36 UTC (rev 51176)
+++ grass/trunk/vector/v.to.points/main.c 2012-03-28 14:36:45 UTC (rev 51177)
@@ -210,9 +210,7 @@
dmax_opt->answer = "100";
dmax_opt->description = _("Maximum distance between points in map units");
exit(EXIT_FAILURE);
Modified: grass/trunk/vector/v.voronoi/main.c
--- grass/trunk/vector/v.voronoi/main.c 2012-03-28 13:59:36 UTC (rev 51176)
+++ grass/trunk/vector/v.voronoi/main.c 2012-03-28 14:36:45 UTC (rev 51177)
@@ -135,7 +135,7 @@
flag.line->description =
_("Output tessellation as a graph (lines), not areas");
- flag.table = G_define_standard_flag(G_FLG_DB_TABLE);
exit(EXIT_FAILURE);
