[GRASS-SVN] r51181 - grass/trunk/lib/python/temporal
svn_grass at osgeo.org
Thu Mar 29 09:56:24 EDT 2012
Author: huhabla
Date: 2012-03-29 06:56:23 -0700 (Thu, 29 Mar 2012)
New Revision: 51181
grass/trunk/lib/python/temporal/abstract_dataset.py
grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
grass/trunk/lib/python/temporal/space_time_datasets.py
grass/trunk/lib/python/temporal/space_time_datasets_tools.py
grass/trunk/lib/python/temporal/spatial_extent.py
Bugfixing
Modified: grass/trunk/lib/python/temporal/abstract_dataset.py
--- grass/trunk/lib/python/temporal/abstract_dataset.py 2012-03-29 08:34:35 UTC (rev 51180)
+++ grass/trunk/lib/python/temporal/abstract_dataset.py 2012-03-29 13:56:23 UTC (rev 51181)
@@ -52,6 +52,11 @@
raise IOError("This method must be implemented in the subclasses")
+ def spatial_relation(self, dataset):
+ """Return the spatial relationship between self and dataset"""
+ raise IOError("This method must be implemented in the subclasses")
def print_info(self):
"""Print information about this class in human readable style"""
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2012-03-29 08:34:35 UTC (rev 51180)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2012-03-29 13:56:23 UTC (rev 51181)
@@ -438,7 +438,7 @@
In case nothing found None is returned
use_start = False
use_during = False
use_overlap = False
@@ -498,7 +498,7 @@
where = create_temporal_relation_sql_where_statement(start, end, use_start, \
use_during, use_overlap, use_contain, use_equal)
maps = self.get_registered_maps_as_objects(where, "start_time", dbif)
result = {}
@@ -743,7 +743,7 @@
sql += " AND %s" % (where)
if order:
sql += " ORDER BY %s" % (order)
try:
dbif.cursor.execute(sql)
rows = dbif.cursor.fetchall()
@@ -1370,6 +1370,10 @@
where += "(start_time = '%s' and end_time = '%s')" % (start, end)
where += ")"
+ # Catch empty where statement
+ if where == "()":
+ where = None
return where
Modified: grass/trunk/lib/python/temporal/space_time_datasets.py
--- grass/trunk/lib/python/temporal/space_time_datasets.py 2012-03-29 08:34:35 UTC (rev 51180)
+++ grass/trunk/lib/python/temporal/space_time_datasets.py 2012-03-29 13:56:23 UTC (rev 51181)
@@ -67,8 +67,13 @@
def spatial_overlapping(self, dataset):
"""Return True if the spatial extents 2d overlap"""
- return self.spatial_extent.overlap_2d(dataset.spatial_extent)
+ return self.spatial_extent.overlapping_2d(dataset.spatial_extent)
+ """Return the two dimensional spatial relation"""
+ return self.spatial_extent.spatial_relation_2d(dataset.spatial_extent)
def reset(self, ident):
"""Reset the internal structure and set the identifier"""
self.ident = ident
@@ -151,10 +156,18 @@
"""Return True if the spatial extents overlap"""
if self.get_type() == dataset.get_type() or dataset.get_type() == "str3ds":
- return self.spatial_extent.overlap(dataset.spatial_extent)
+ return self.spatial_extent.overlapping(dataset.spatial_extent)
else:
+ """Return the two or three dimensional spatial relation"""
+ if self.get_type() == dataset.get_type() or dataset.get_type() == "str3ds":
+ return self.spatial_extent.spatial_relation(dataset.spatial_extent)
+ else:
self.ident = ident
@@ -244,8 +257,14 @@
self.ident = ident
@@ -309,8 +328,13 @@
@@ -358,11 +382,19 @@
- if self.get_type() == dataset.get_type() or dataset.get_type() == "rast3d":
else:
+ else:
@@ -410,8 +442,13 @@
Modified: grass/trunk/lib/python/temporal/space_time_datasets_tools.py
--- grass/trunk/lib/python/temporal/space_time_datasets_tools.py 2012-03-29 08:34:35 UTC (rev 51180)
+++ grass/trunk/lib/python/temporal/space_time_datasets_tools.py 2012-03-29 13:56:23 UTC (rev 51181)
@@ -166,7 +166,7 @@
for count in range(len(maplist)):
core.percent(count, num_maps, 1)
- # Get a new instance of the space time dataset map type
+ # Get a new instance of the map type
map = dataset_factory(type, maplist[count]["id"])
# Use the time data from file
@@ -189,7 +189,6 @@
# Load the data from the grass file database
map.load()
- # We need to check the temporal type based on the time stamp
if unit:
map.set_time_to_relative()
else:
@@ -384,7 +383,6 @@
string += "%s%s" % ("end_time", separator)
string += "%s%s" % ("interval_length", separator)
string += "%s" % ("distance_from_begin")
- print string
if maps and len(maps) > 0:
@@ -545,7 +543,6 @@
- print string
first_time, dummy = mapmatrizes[0][0]["granule"].get_valid_time()
Modified: grass/trunk/lib/python/temporal/spatial_extent.py
--- grass/trunk/lib/python/temporal/spatial_extent.py 2012-03-29 08:34:35 UTC (rev 51180)
+++ grass/trunk/lib/python/temporal/spatial_extent.py 2012-03-29 13:56:23 UTC (rev 51181)
@@ -61,16 +61,16 @@
E -= 360.0
W -= 360.0
- if(self.get_north() <= S):
+ if(self.get_north() < S):
return False
- if(self.get_south() >= N):
+ if(self.get_south() > N):
return False
- if self.get_east() <= W:
+ if self.get_east() < W:
return False
- if self.get_west() >= E:
+ if self.get_west() > E:
return False
return True
