[GRASS-SVN] r51186 - grass/trunk/lib/gis
Thu Mar 29 13:58:24 EDT 2012
Author: martinl
Date: 2012-03-29 10:58:24 -0700 (Thu, 29 Mar 2012)
New Revision: 51186
   grass/trunk/lib/gis/parser_html.c
libgis (parser): html description
       - lower-case tags
       - escape tabs
       - wrap options (put extra space between options)
       - note required parameters
Modified: grass/trunk/lib/gis/parser_html.c
--- grass/trunk/lib/gis/parser_html.c	2012-03-29 15:33:01 UTC (rev 51185)
+++ grass/trunk/lib/gis/parser_html.c	2012-03-29 17:58:24 UTC (rev 51186)
@@ -6,8 +6,8 @@
 #include "parser_local_proto.h"
 static void print_escaped_for_html(FILE * f, const char *str);
+static void print_escaped_for_html_options(FILE * f, const char *str);
   \brief Print module usage description in HTML format.
@@ -124,45 +124,45 @@
     if (st->n_flags || new_prompt) {
 	flag = &st->first_flag;
 	fprintf(stdout, "<h3>%s:</h3>\n", _("Flags"));
-	fprintf(stdout, "<DL>\n");
+	fprintf(stdout, "<dl>\n");
 	while (st->n_flags && flag != NULL) {
-	    fprintf(stdout, "<DT><b>-%c</b></DT>\n", flag->key);
+	    fprintf(stdout, "<dt><b>-%c</b></dt>\n", flag->key);
 	    if (flag->label) {
-		fprintf(stdout, "<DD>");
+		fprintf(stdout, "<dd>");
 		fprintf(stdout, "%s", flag->label);
-		fprintf(stdout, "</DD>\n");
+		fprintf(stdout, "</dd>\n");
 	    if (flag->description) {
 		fprintf(stdout, "%s", flag->description);
 	    flag = flag->next_flag;
 	    fprintf(stdout, "\n");
 	if (new_prompt) {
-	    fprintf(stdout, "<DT><b>--overwrite</b></DT>\n");
-	    fprintf(stdout, "<DD>%s</DD>\n",
+	    fprintf(stdout, "<dt><b>--overwrite</b></dt>\n");
+	    fprintf(stdout, "<dd>%s</dd>\n",
 		    _("Allow output files to overwrite existing files"));
-	fprintf(stdout, "<DT><b>--verbose</b></DT>\n");
-	fprintf(stdout, "<DD>%s</DD>\n", _("Verbose module output"));
+	fprintf(stdout, "<dt><b>--verbose</b></dt>\n");
+	fprintf(stdout, "<dd>%s</dd>\n", _("Verbose module output"));
-	fprintf(stdout, "<DT><b>--quiet</b></DT>\n");
-	fprintf(stdout, "<DD>%s</DD>\n", _("Quiet module output"));
+	fprintf(stdout, "<dt><b>--quiet</b></dt>\n");
+	fprintf(stdout, "<dd>%s</dd>\n", _("Quiet module output"));
-	fprintf(stdout, "</DL>\n");
+	fprintf(stdout, "</dl>\n");
     if (st->n_opts) {
 	opt = &st->first_option;
 	fprintf(stdout, "<h3>%s:</h3>\n", _("Parameters"));
 	while (opt != NULL) {
 	    /* TODO: make this a enumeration type? */
@@ -183,33 +183,37 @@
 		    type = "string";
 		    break;
-	    fprintf(stdout, "<DT><b>%s</b>=<em>%s", opt->key, type);
+	    fprintf(stdout, "<dt><b>%s</b>=<em>%s", opt->key, type);
 	    if (opt->multiple) {
 		fprintf(stdout, "[,<i>%s</i>,...]", type);
-	    fprintf(stdout, "</em></DT>\n");
+	    fprintf(stdout, "</em>");
+	    if (opt->required) {
+		fprintf(stdout, "&nbsp;<b>[required]</b>");
+	    fprintf(stdout, "</dt>\n");
 	    if (opt->label) {
 		print_escaped_for_html(stdout, opt->label);
 	    if (opt->description) {
 		print_escaped_for_html(stdout, opt->description);
 	    if (opt->options) {
-		fprintf(stdout, "<DD>%s: <em>", _("Options"));
-		print_escaped_for_html(stdout, opt->options);
-		fprintf(stdout, "</em></DD>\n");
+		fprintf(stdout, "<dd>%s: <em>", _("Options"));
+		print_escaped_for_html_options(stdout, opt->options);
+		fprintf(stdout, "</em></dd>\n");
 	    if (opt->def) {
-		fprintf(stdout, "<DD>%s: <em>", _("Default"));
+		fprintf(stdout, "<dd>%s: <em>", _("Default"));
 		print_escaped_for_html(stdout, opt->def);
 	    if (opt->descs) {
@@ -217,11 +221,11 @@
 		while (opt->opts[i]) {
 		    if (opt->descs[i]) {
-			fprintf(stdout, "<DD><b>");
+			fprintf(stdout, "<dd><b>");
 			print_escaped_for_html(stdout, opt->opts[i]);
 			fprintf(stdout, "</b>: ");
 			print_escaped_for_html(stdout, opt->descs[i]);
 		    i++;
@@ -230,7 +234,7 @@
 	    opt = opt->next_opt;
     fprintf(stdout, "</body>\n</html>\n");
@@ -241,7 +245,7 @@
  * \brief Format text for HTML output
 #define do_escape(c,escaped) case c: fputs(escaped,f);break
-static void print_escaped_for_html(FILE * f, const char *str)
+void print_escaped_for_html(FILE * f, const char *str)
     const char *s;
@@ -251,9 +255,28 @@
 	    do_escape('<', "&lt;");
 	    do_escape('>', "&gt;");
 	    do_escape('\n', "<br>");
+	    do_escape('\t', "&nbsp;&nbsp;&nbsp;&nbsp;");
 	default:
 	    fputc(*s, f);
+void print_escaped_for_html_options(FILE * f, const char *str)
+    const char *s;
+    for (s = str; *s; s++) {
+	switch (*s) {
+	    do_escape('&', "&amp;");
+	    do_escape('<', "&lt;");
+	    do_escape('>', "&gt;");
+	    do_escape('\n', "<br>");
+	    do_escape(',',  ", ");
+	default:
+	    fputc(*s, f);
 #undef do_escape
